[参考译文] TPS22975:散热焊盘连接
Guru**** 2529560 points
Other Parts Discussed in Thread: TPS22975
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1520823/tps22975-thermal-pad-connection
器件型号:TPS22975
您好团队:
 TPS22975的哪个部分是散热焊盘内部连接的?
Shotaro
