[参考译文] TPS61099:器件标识
Guru**** 2513185 points
Other Parts Discussed in Thread: TPS61099
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1518844/tps61099-part-marking
器件型号:TPS61099
尊敬的先生:
PLS 有助于提供 TPS61099器件标识。类似于 TPS62085RLT !
    尊敬的 Anson:
    此器件的产品标识为12G。
