[参考译文] UCC28722:UCC28722 P-SPICE 库存在的问题。
Guru**** 2506395 points
Other Parts Discussed in Thread: UCC28722
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1534096/ucc28722-issue-with-the-ucc28722-p-spice-library
器件型号:UCC28722
我将 UCC28722 用于反激式设计、并使用 LT Spice 作为工具。
下载了 P-SPICE 模型并添加了 sbckt 作为符号。
除仿真外、一切都正常工作。
我已附上 LT SPICE 原理图和误差日志以供参考。
希望得到帮助!
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(885): Expected end of line here.
+ params:  t=100
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(886): Expected node name here.
s_s1         meas 0 reset2 0 s1
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(886): Expected device instantiation or directive here.
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(887): Expected 2 node names here.
e_abm1         ch 0 value { if( v(in)>0.5 | v(out)>0.5,1,0)    }
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(888): Expected node name here.
r_r2         reset2 reset  0.1
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(888): Expected device instantiation or directive here.
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(889): Expected 2 node names here.
e_abm3         out 0 value { if( v(meas)<0.5 & v(ch)>0.5,1,0)    }
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(890): Expected node name here.
r_r1         meas ch  {t}
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(890): Expected device instantiation or directive here.
r_r1         meas ch  {t}
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(891): Expected device instantiation or directive here.
c_c2         0 reset2  1.4427n
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(892): Expected device instantiation or directive here.
c_c1         0 meas  1.4427n
C:\Users\20021165\Desktop\New folder\UCC28722_PSPICE_TRANS\UCC28722_TRANS.lib(893): Expected 2 node names here.
e_abm2         reset 0 value { if(v(ch)<0.5,1,0)    }
    您好:
    由于该模型是在 PSpice 上构建的、因此我们只能支持 PSpice 相关问题。
    感谢您的理解。
    无论如何都要感谢!
