[参考译文] TPS22975:手动焊接和放大器;耐流动热
Guru**** 2529560 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1549585/tps22975-hand-soldering-flow-heat-resistant
器件型号:TPS22975
对于该元件、手工焊接或波动焊接是否适用? 如果是、您能否提供建议的温度和焊接过程持续时间?
