[参考译文] TPS25940:Simulation 模型:SPICE、或 LTSpice 或 TPS25940 器件的 TINA 模型
Guru**** 2609955 points
Other Parts Discussed in Thread: TPS25940
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1564442/tps25940-simulation-model-spice-or-ltspice-or-tina-model-for-tps25940-part
器件型号:TPS25940
您能为 TPS25940 器件提供 PSpice、LTSpice 或 TINA 模型吗?
