[参考译文] BQ25792:BQ25792 是否支持 100mV 的阶跃大小来调节电压以满足 PD3.2 AVS 要求?
Guru**** 2611705 points
Other Parts Discussed in Thread: BQ25792
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1565253/bq25792-does-bq25792-support-100mv-step-size-to-adjust-voltage-to-meet-pd3-2-avs-requirement
器件型号:BQ25792
您好团队
    您好、Harry:
    实际上为 10mV 阶跃。
    Jeff
