[参考译文] BQ76907:自动关断故障 DSG 和 CHG 条件
Guru**** 2693475 points
Other Parts Discussed in Thread: BQ76907
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1575392/bq76907-automatic-shutdown-fault-dsg-and-chg-conditions
器件型号:BQ76907
BQ76907 发生故障时、它将自动关断 DSG 和 CHG。 当前故障是导致 SAA 关断、还是 SSA 也会关断、还是与 ALERT 相关?
