[参考译文] :迟滞功能时、TPS2116 μ A ST 监测引脚是否会失效?
Guru**** 2618835 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1576452/tps2116-will-the-st-monitoring-pin-become-ineffective-when-the-hysteresis-function-is-used
器件型号:TPS2116
您好:
使用迟滞功能时、ST 监测引脚是否会失效?
