[参考译文] TPS2597:TPS25970:可以在 Vin 之前启用上电?
Guru**** 2826855 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1627957/tps2597-tps25970-can-enable-power-up-before-vin
器件型号: TPS2597
尊敬的先生:
TPS25970 使能引脚可以在 Vin 之前上电吗?
https://e2e.ti.com/support/power-management-group/power-management---internal/f/power-management---internal-forum/1613205/tps25982-enable-before-vin?tisearch=e2e-sitesearch&keymatch=can%25252520enable%25252520pin%25252520power%25252520up%25252520before%25252520VIN#
    是的、您可以确保下游负载应在 VOUT 完全启动后导通。
    Hemanth
