[参考译文] TPS25751:USBCPD 自定义工具中的配置不应用于 VIF 文件和 EEPROM 内容
Guru**** 2927270 points
Other Parts Discussed in Thread: TPS25751
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1643558/tps25751-configuration-in-usbcpd-customization-tool-not-applied-in-vif-file-and-eeprom-content
器件型号: TPS25751
您好、
我正在使用 TPS25751 作为 USB 控制器进行设计、这是因为 USBCPD 自定义工具 v1.1.1 对其存储器进行了配置
在测试配置时,一些信息是不可知的 VIF 文件,并在数据 PD 控制器发送 USB 测试仪我使用:
  • VID:0x0451、而不是 0x28D4、PID 正常
  • USB 设备速度: USB 3.2 Gen 2x2 代替 USB 2.0
您是否知道如何解决此问题?
以下是来自 USB 测试仪的 json、VIF 和报告文件:
  "questionnaire": {
    "device": "TPS25751",
    "toolBuildVersion": "1.1.1",
    "answers": [
      null,
      5,
      4,
      3,
      1,
      1,
      2,
      3,
      1,
      0,
      0,
      0,
      0,
      0,
      12.6,
      1.7,
      0.04,
      0.24,
      0
    "vendorId": "28D4",
    "productId": "000E",
    "version": "1.0.0.2"
  "configuration": {
    "data": {
      "selected_ace": [
          "register": 6,
          "data": [
            250,
            79,
            251,
            105,
            0,
            0,
            0,
            0
          "register": 22,
          "data": [
            2,
            2,
            0,
            9,
            10,
            0,
            0,
            0,
            0,
            0,
            0
          "register": 40,
          "data": [
            0,
            8,
            46,
            1,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            3
          "register": 41,
          "data": [
            48,
            48,
            145,
            194
          "register": 50,
          "data": [
            0,
            170,
            42,
            44,
            145,
            1,
            36,
            44,
            209,
            2,
            0,
            44,
            177,
            4,
            0,
            244,
            65,
            6,
            0,
            244,
            65,
            6,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0
          "register": 51,
          "data": [
            5,
            44,
            145,
            1,
            16,
            44,
            209,
            2,
            0,
            44,
            193,
            3,
            0,
            44,
            177,
            4,
            0,
            44,
            65,
            6,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0
          "register": 55,
          "data": [
            63,
            192,
            18,
            15,
            144,
            145,
            1,
            0,
            1,
            0,
            0,
            0,
            60,
            176,
            4,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0
          "register": 66,
          "data": [
            26,
            12,
            10,
            0
          "register": 92,
          "data": [
            4,
            12,
            0,
            0,
            128,
            0,
            0,
            0,
            4,
            0,
            0,
            0,
            4,
            4,
            0,
            0,
            48,
            4,
            0,
            0,
            0,
            0,
            0,
            0,
            128,
            4,
            0,
            0,
            48,
            0,
            0,
            0,
            4,
            0,
            0,
            0,
            0,
            0,
            1,
            0,
            0,
            0,
            0,
            33,
            0,
            0,
            0,
            0,
            0
          "register": 112,
          "data": [
            5
          "register": 119,
          "data": [
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            4,
            1,
            0,
            0
          "register": 120,
          "data": [
            0,
            0,
            0,
            128
          "register": 122,
          "data": [
            0,
            0,
            0,
            0
          "register": 123,
          "data": [
            0,
            2,
            255,
            255,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0
          "register": 125,
          "data": [
            255,
            255,
            0,
            0,
            110,
            1,
            110,
            1,
            0,
            255,
            255,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            255,
            255,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            255,
            255,
            0,
            0,
            0,
            0,
            0,
            0,
            0
          "register": 126,
          "data": [
            1,
            0,
            0,
            0,
            0,
            0,
            1,
            10,
            1,
            30,
            60,
            0,
            0,
            0
          "register": 152,
          "data": [
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0,
            0
USB_VENDOR_INFO_FILE_TPS25751x_1778077690.xml
USB_tester_report.html
Guillaume
    尊敬的 Guillaume:
    感谢您联系我们!
    1- GUI 似乎重置了默认 VID 值。 请参阅随附的更正了 json。
    2-应在 VIF Editor 工具中修改 USB 设备速度以匹配您的项目配置。
    e2e.ti.com/.../Guillaume_5F00_E2E_5F00_modified_5F00_VID.json
    Aya Khedr
    尊敬的 Aya:
    感谢您的回答。
    我从您发送的 json 生成了一个 VIF 文件。 它解决了 VID 的问题、但 USB 速度仍设置为 USB 3.2 Gen 2x2、而不是 USB 2。
    USB 速度的问题在于、器件在连接到主机时声明其支持 USB 3.2。
    Guillaume
    尊敬的 Guillaume:
    1 — 使用 TI GUI VIF 生成工具生成的 VIF 仅填充 PD 控制器特定的字段。 某些字段特意留空(以红色表示)、供用户根据并非仅由 PD 控制器管理的系统级要求进行配置。
    有关如何下载 VIF 编辑器工具和配置其余字段的信息、请参阅以下应用手册。
    2-应将 USB Device Speed 修改为“USB 2“以匹配项目设置。
    Aya Khedr
