[参考译文] CSD95373BQ5M:A 和 B 之间有何区别?
Guru**** 2553450 points
Other Parts Discussed in Thread: CSD95373BQ5M, CSD95373AQ5M
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1079127/csd95373bq5m-what-is-the-difference-between-a-and-b
部件号:CSD95373BQ5M
CSD95373BQ5M 和 CSD95373AQ5M
A 和 B 之间有何区别?
    CSD95373A 没有与电流感应相关的功能,而 CSD95373B 具有 集成电流感应以及过电流和高侧短路检测。
