[参考译文] TPS61027:输出电容器-混合电解,替代钽
Guru**** 2510095 points
Other Parts Discussed in Thread: TPS61027
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1087572/tps61027-output-capacitor---hybrid-electrolytic-as-alternative-to-tantalum
部件号:TPS61027
您好,Team,
是否可以将混合电解电容器用作 TPS61027的输出电容器?
例如: eeh-ZK 系列| Panasonic 工业设备
https://na.industrial.panasonic.com/products/capacitors/aluminum-electrolytic-capacitors/lineup/conductive-polymer-hybrid-aluminum-electrolytic/series/89
非常感谢
约瑟夫
