[参考译文] TPS6.0151万:FMEA ?? 内部连接热垫到引脚1 GND
Guru**** 2393725 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/581121/tps60151-fmea-internal-connection-thermal-pad-to-pin-1-gnd
部件号:TPS6.0151万
从TPS6.0151万的FMEA角度来看,散热垫是否在内部连接到引脚1 (GND)?
如果引脚1 (GND)开路,但热垫仍连接至GND,TPS6.0151万是否可以正常工作?
