[参考译文] UCC3895:UCC3895:UCC3895 OUTD 占空比不平衡
Guru**** 2389240 points
Other Parts Discussed in Thread: UCC3895
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1125187/ucc3895-ucc3895-ucc3895-outc-outd-duty-cycle-imbalance
器件型号:UCC3895
降级:
  当 UCC3895用作全桥控制时、当单总线交流电压超过380V 时、OUTD 输出的占空比将不平衡、无法保持在50%占空比、从而产生高电流峰值。 测量的波形图和 原理图如下所示:请帮助了解原因、谢谢!
1是电流波形、2、3和4对应于 OUTB outc OUTD
e2e.ti.com/.../JZD_2D00_ICB_2D00_V1.0.pdf
