[参考译文] EV2400:ev2400和 EV2300之间有何区别? ev2400与 EV2300完全兼容
Guru**** 2874030 points
Other Parts Discussed in Thread: EV2400
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1120585/ev2400-what-is-the-difference-between-ev2400-and-ev2300-is-ev2400-fully-compatible-with-ev2300
器件型号:EV2400
您好,工程师团队:
    ev2400与 EV2300之间有何区别? ev2400与 EV2300?完全兼容
    真诚地期待您的回复
