[参考译文] TPS61089:TPS61089体二极管 VF 范围
Guru**** 2390755 points
Other Parts Discussed in Thread: TPS61089
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1119365/tps61089-tps61089-body-diode-vf-range
器件型号:TPS61089
TPS61089中有一个体二极管、如果 TPS6i1089处于关断模式、并且流经体二极管的电流为1mA 至1A、则二极管的正向电压范围是多少?
