[参考译文] TPS5430:TPS5430MDDAREP
Guru**** 2529560 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1117806/tps5430-tps5430mddarep
器件型号:TPS5430
您好,您对此部件是否有 ltspice 或 Tina 模型:TPS5430MDDAREP?
https://www.ti.com/lit/ds/symlink/tps5430-ep.pdf?ts=1657739316752&ref_url=https%253A%252F%252Fwww.google.com%252F
谢谢你
