[参考译文] TPS7A7001:TPS7A7001
Guru**** 2553260 points
Other Parts Discussed in Thread: TPS7A7001
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1116704/tps7a7001-tps7a7001
器件型号:TPS7A7001
尊敬的先生:
我读取 TPS7A7001数据流、发现  RθJA  μ W 为46.4°C/W、 RθJC μ W (顶部) 为54.2°C/W 我不确定  Δ I (RθJC)是否出错。  为什么 RθJC (top)值大于 RθJA 1?
