[参考译文] LMR50410:相邻引脚之间的开路/短路测试
Guru**** 2595800 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1115094/lmr50410-open-short-test-between-adjacent-pins
器件型号:LMR50410
您好专家、
 您是否有相邻引脚之间引脚开路测试和短路测试的数据?
穆克
