[参考译文] LM3535:LM3535上电默认状态、输出电流是多少? 输出电流是否需要 IIC 和时钟配置?
Guru**** 2513185 points
Other Parts Discussed in Thread: LM3535
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1114803/lm3535-lm3535-power-on-default-state-what-is-the-output-current-does-the-output-current-need-iic-and-clock-configuration
器件型号:LM3535
    你好,小福
    亮度寄存器中的默认代码为0、您必须配置 I2C 来设置所需的电流。
