[参考译文] TPS62745:轨到轨兼容替代产品。
Guru**** 2510095 points
Other Parts Discussed in Thread: TPS62745, TPS629203
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1110576/tps62745-rail-to-rail-compatibility-alternative
器件型号:TPS62745
主题中讨论的其他器件: TPS629203
   我可以选择此 IC ...并且具有轨到轨兼容性...?而且还提供库存...?
