[参考译文] TPS6594EVM:您能否提供 TPS6594的演示配置文件?
Guru**** 2585085 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1127509/tps6594evm-can-you-provide-the-demo-configuration-file-of-tps6594
器件型号:TPS6594EVM
  • 您能否提供 TPS6594的演示配置文件?
    您好 、Xiaofu、
     您能不能再多讲一讲您需要什么? 您要求的 EVM 器件型号确切是什么? 您是否已经查看过 EVM 的用户指南?
    Phil
     确切的 EVM 器件型号为 TPS65941111RWERQ1。
    当前状态:
    1.可以通过 PC 正常访问 PMIC (TPS65941111RWERQ1)评估板
    2. PC 可以读取和写入 PMIC 的 EEPROM。
    故障:根据文档配置 PFSM 后、PFSM 无法正确输出电压和时间序列
    • 请帮助查看 PFSM 配置是否正常?
        "details": {
          "name": "sample_template",
          "description": "description for sample template",
          "revision": "0.4.0"
        "content": {
          "staticConfig": [
              "name": "TPS6594x",
              "devices": []
              "name": "TPS6594x_2p0",
              "devices": [
                  "alias": "TPS65940",
                  "type": "TPS6594x_2p0",
                  "masterOrSlave": "master",
                  "master": true,
                  "staticConfigJSON": {
                    "groups": [
                        "name": "Buck",
                        "blocks": [
                            "name": "Buck1_2_3_4",
                            "type": "visible",
                            "registers": [
                                "regID": "BUCK1_CTRL",
                                "fixedFields": [
                                    "fieldID": "BUCK1_EN",
                                    "value": 0
                                    "fieldID": "BUCK1_PLDN",
                                    "value": 1
                                    "fieldID": "BUCK1_VMON_EN",
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_VMON_EN"
                                "fields": [
                                  "BUCK1_EN",
                                  "BUCK1_FPWM",
                                  "BUCK1_FPWM_MP",
                                  "BUCK1_VSEL",
                                  "BUCK1_VMON_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_RV_SEL"
                                "regID": "BUCK1_CONF",
                                "fields": [
                                  "BUCK1_SLEW_RATE",
                                  "BUCK1_ILIM"
                                "regID": "BUCK1_VOUT_1",
                                "fields": [
                                  "BUCK1_VSET1"
                                "regID": "BUCK1_VOUT_2",
                                "fields": [
                                  "BUCK1_VSET2"
                                "regID": "BUCK1_PG_WINDOW",
                                "fields": [
                                  "BUCK1_OV_THR",
                                  "BUCK1_UV_THR"
                                "regID": "RAIL_SEL_1",
                                "fields": [
                                  "BUCK1_GRP_SEL"
                                "regID": "BUCK_RESET_REG",
                                "fixedFields": [
                                    "fieldID": "BUCK1_RESET",
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_RESET"
                                "fields": [
                                  "BUCK1_RESET"
                                "regID": "FREQ_SEL",
                                "hideFields": [
                                  "BUCK1_FREQ_SEL"
                                "fields": [
                                  "BUCK1_FREQ_SEL"
                                "regID": "BUCK_CONFIG_ANALOG_1",
                                "hideFields": [
                                  "BUCK1_SEL_NEG_OCP_HYST"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_1",
                                "hideFields": [
                                  "BUCK1_SEL_POS_OCP_HYST"
                                "fields": [
                                "regID": "BUCK_CONFIG_ANALOG_3",
                                "hideFields": [
                                  "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION",
                                  "BUCK1_SEL_VOUT_ADC_LEVEL"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_0",
                                "fixedFields": [
                                    "fieldID": "BUCK1_SEL_PHASE_ADD",
                                    "value": 1
                                    "fieldID": "BUCK1_SEL_PHASE_SHEDD",
                                    "value": 0
                                    "fieldID": "EN_LOAD_COMP_BLANK",
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_4",
                                "hideFields": [
                                  "BUCK1_SEL_OUTPUT_CAPS"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_6",
                                "hideFields": [
                                  "BUCK1_SEL_RAMP"
                                "fields": [
                                  "BUCK1_SEL_RAMP"
                                "regID": "BUCK_CONFIG_DIGITAL_12",
                                "hideFields": [
                                  "BUCK1_FREQ_8MHZ"
                                "fields": [
                                  "BUCK1_FREQ_8MHZ"
                                "regID": "BUCK_CONFIG_DIGITAL_13",
                                "hideFields": [
                                  "BUCK1_EN_P_10M_BODY_DIODE"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_14",
                                "hideFields": [
                                  "BUCK1_DOUBLE_PFM_PULSE"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_15",
                                "hideFields": [
                                  "BUCK1_CHANGE_2MHZ_BELOW_0V5"
                                "fields": [
                                "regID": "BUCK_CONFIG_RADAR",
                                "hideFields": [
                                  "BUCK1_EN_RADAR_MODE"
                                "fields": [
                                "regID": "BUCK1_DTEST_REG_0",
                                "fixedFields": [
                                    "fieldID": "swc_buck_hiz_1",
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_1"
                                "fields": [
                                  "swc_buck_hiz_1"
                            "regConfig": {
                              "question": "Is this rail used for VTT?",
                              "id": "vtt_config",
                              "selectedOption": "yes",
                              "options": [
                                  "name": "yes",
                                  "configurationDisplayName": "2.2MHz Single Phase for DDR Termination",
                                  "configuration": "DDR VTT (SP)",
                                  "inductor": "470nH"
                                  "name": "no",
                                  "question": "What is this rail's switching frequency?",
                                  "id": "switching_frequency_config",
                                  "selectedOption": "4.4MHz",
                                  "options": [
                                      "name": "4.4MHz",
                                      "question": "Does this rail want to be optimized for multiphase configuration?",
                                      "id": "multiphase_config",
                                      "options": [
                                          "name": "yes",
                                          "configurationDisplayName": "4.4MHz Multiphase Configuration",
                                          "configuration": "4.4MHz HiCur (MP)",
                                          "inductor": "220nH"
                                          "name": "no",
                                          "question": "What is the output of this rail?",
                                          "id": "output_rail_config",
                                          "selectedOption": "1.8V or less",
                                          "options": [
                                              "name": "1.8V or less",
                                              "question": "What is the output capacitance on this rail?",
                                              "id": "output_capacitance_config",
                                              "selectedOption": "greater than 100 uF",
                                              "options": [
                                                  "name": "greater than 100 uF",
                                                  "inductor": "220nH"
                                                  "name": "less than 100uF",
                                                  "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage",
                                                  "configuration": "4.4MHz LoCur (SP)",
                                                  "inductor": "220nH"
                                              "name": "greater than 1.8V",
                                              "configurationDisplayName": "4.4MHz Single Phase High Output Voltage",
                                              "configuration": "4.4MHz HiVolt (SP)",
                                              "inductor": "470nH"
                                      "name": "2.2MHz",
                                      "options": [
                                          "name": "yes",
                                          "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN",
                                          "configuration": "2.2MHz (MP)",
                                          "inductor": "470nH"
                                          "name": "no",
                                          "options": [
                                              "inductor": "470nH"
                                              "name": "full range",
                                              "question": "What is the input voltage of this rail?",
                                              "id": "input_voltage_config",
                                              "selectedOption": "Only greater than 4.5V",
                                              "options": [
                                                  "name": "Only greater than 4.5V",
                                                  "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN",
                                                  "configuration": "5Vin (SP)",
                                                  "inductor": "470nH"
                                                  "name": "Supports full input voltage range",
                                                  "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN",
                                                  "configuration": "2.2MHz (SP)",
                                                  "inductor": "1000nH"
                            "name": "Buck1_2_3",
                            "type": "hidden",
                            "registers": [
                                "fixedFields": [
                                    "value": 0
                                    "value": 1
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_VMON_EN"
                                "fields": [
                                  "BUCK1_EN",
                                  "BUCK1_FPWM",
                                  "BUCK1_FPWM_MP",
                                  "BUCK1_VSEL",
                                  "BUCK1_VMON_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_RV_SEL"
                                "fields": [
                                  "BUCK1_SLEW_RATE",
                                  "BUCK1_ILIM"
                                "fields": [
                                  "BUCK1_VSET1"
                                "fields": [
                                  "BUCK1_VSET2"
                                "fields": [
                                  "BUCK1_OV_THR",
                                  "BUCK1_UV_THR"
                                "fields": [
                                  "BUCK1_GRP_SEL"
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_RESET"
                                "fields": [
                                  "BUCK1_RESET"
                                "hideFields": [
                                  "BUCK1_FREQ_SEL"
                                "fields": [
                                  "BUCK1_FREQ_SEL"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 1
                                    "value": 0
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                  "BUCK1_SEL_RAMP"
                                "fields": [
                                  "BUCK1_SEL_RAMP"
                                "hideFields": [
                                  "BUCK1_FREQ_8MHZ"
                                "fields": [
                                  "BUCK1_FREQ_8MHZ"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_1"
                                "fields": [
                                  "swc_buck_hiz_1"
                            "name": "Buck1_2",
                            "type": "hidden",
                            "registers": [
                                "fixedFields": [
                                    "value": 0
                                    "value": 1
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_VMON_EN"
                                "fields": [
                                  "BUCK1_EN",
                                  "BUCK1_FPWM",
                                  "BUCK1_FPWM_MP",
                                  "BUCK1_VSEL",
                                  "BUCK1_VMON_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_RV_SEL"
                                "fields": [
                                  "BUCK1_SLEW_RATE",
                                  "BUCK1_ILIM"
                                "fields": [
                                  "BUCK1_VSET1"
                                "fields": [
                                  "BUCK1_VSET2"
                                "fields": [
                                  "BUCK1_OV_THR",
                                  "BUCK1_UV_THR"
                                "fields": [
                                  "BUCK1_GRP_SEL"
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_RESET"
                                "fields": [
                                  "BUCK1_RESET"
                                "hideFields": [
                                  "BUCK1_FREQ_SEL"
                                "fields": [
                                  "BUCK1_FREQ_SEL"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 1
                                    "value": 0
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                  "BUCK1_SEL_RAMP"
                                "fields": [
                                  "BUCK1_SEL_RAMP"
                                "hideFields": [
                                  "BUCK1_FREQ_8MHZ"
                                "fields": [
                                  "BUCK1_FREQ_8MHZ"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_1"
                                "fields": [
                                  "swc_buck_hiz_1"
                            "name": "Buck3_4",
                            "type": "hidden",
                            "registers": [
                                "regID": "BUCK3_CTRL",
                                "fixedFields": [
                                    "fieldID": "BUCK3_EN",
                                    "value": 0
                                    "fieldID": "BUCK3_PLDN",
                                    "value": 1
                                    "fieldID": "BUCK3_VMON_EN",
                                    "value": 0
                                "hideFields": [
                                  "BUCK3_EN",
                                  "BUCK3_PLDN",
                                  "BUCK3_VMON_EN"
                                "fields": [
                                  "BUCK3_EN",
                                  "BUCK3_FPWM",
                                  "BUCK3_FPWM_MP",
                                  "BUCK3_VSEL",
                                  "BUCK3_VMON_EN",
                                  "BUCK3_PLDN",
                                  "BUCK3_RV_SEL"
                                "regID": "BUCK3_CONF",
                                "fields": [
                                  "BUCK3_SLEW_RATE",
                                  "BUCK3_ILIM"
                                "regID": "BUCK3_VOUT_1",
                                "fields": [
                                  "BUCK3_VSET1"
                                "regID": "BUCK3_VOUT_2",
                                "fields": [
                                  "BUCK3_VSET2"
                                "regID": "BUCK3_PG_WINDOW",
                                "fields": [
                                  "BUCK3_OV_THR",
                                  "BUCK3_UV_THR"
                                "fields": [
                                  "BUCK3_GRP_SEL"
                                "fixedFields": [
                                    "fieldID": "BUCK3_RESET",
                                    "value": 0
                                "hideFields": [
                                  "BUCK3_RESET"
                                "fields": [
                                  "BUCK3_RESET"
                                "hideFields": [
                                  "BUCK3_FREQ_SEL"
                                "fields": [
                                  "BUCK3_FREQ_SEL"
                                "hideFields": [
                                  "BUCK3_SEL_NEG_OCP_HYST"
                                "fields": [
                                "hideFields": [
                                  "BUCK3_SEL_POS_OCP_HYST"
                                "fields": [
                                "regID": "BUCK_CONFIG_ANALOG_5",
                                "hideFields": [
                                  "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION",
                                  "BUCK3_SEL_VOUT_ADC_LEVEL"
                                "fields": [
                                "fixedFields": [
                                    "fieldID": "BUCK3_SEL_PHASE_SHEDD",
                                    "value": 0
                                    "fieldID": "BUCK3_SEL_PHASE_ADD",
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                  "BUCK3_SEL_OUTPUT_CAPS"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_7",
                                "hideFields": [
                                  "BUCK3_SEL_RAMP"
                                "fields": [
                                  "BUCK3_SEL_RAMP"
                                "hideFields": [
                                  "BUCK3_FREQ_8MHZ"
                                "fields": [
                                  "BUCK3_FREQ_8MHZ"
                                "hideFields": [
                                  "BUCK3_EN_P_10M_BODY_DIODE"
                                "fields": [
                                "hideFields": [
                                  "BUCK3_DOUBLE_PFM_PULSE"
                                "fields": [
                                "hideFields": [
                                  "BUCK3_CHANGE_2MHZ_BELOW_0V5"
                                "fields": [
                                "hideFields": [
                                  "BUCK3_EN_RADAR_MODE"
                                "fields": [
                                "regID": "BUCK3_DTEST_REG_0",
                                "fixedFields": [
                                    "fieldID": "swc_buck_hiz_3",
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_3"
                                "fields": [
                                  "swc_buck_hiz_3"
                            "name": "Buck3 Monitor",
                            "type": "visible",
                            "registers": [
                                "fields": [
                                  "BUCK3_VSEL",
                                  "BUCK3_RV_SEL"
                                "fields": [
                                  "BUCK3_SLEW_RATE"
                                "fields": [
                                  "BUCK3_VSET1"
                                "fields": [
                                  "BUCK3_VSET2"
                                "fields": [
                                  "BUCK3_OV_THR",
                                  "BUCK3_UV_THR"
                                "fields": [
                                  "BUCK3_GRP_SEL"
                            "name": "Buck4 Monitor",
                            "type": "visible",
                            "registers": [
                                "regID": "BUCK4_CTRL",
                                "fields": [
                                  "BUCK4_VSEL",
                                  "BUCK4_RV_SEL"
                                "regID": "BUCK4_CONF",
                                "fields": [
                                  "BUCK4_SLEW_RATE"
                                "regID": "BUCK4_VOUT_1",
                                "fields": [
                                  "BUCK4_VSET1"
                                "regID": "BUCK4_VOUT_2",
                                "fields": [
                                  "BUCK4_VSET2"
                                "regID": "BUCK4_PG_WINDOW",
                                "fields": [
                                  "BUCK4_OV_THR",
                                  "BUCK4_UV_THR"
                                "fields": [
                                  "BUCK4_GRP_SEL"
                            "name": "Buck1",
                            "registers": [
                                "fixedFields": [
                                    "value": 0
                                    "value": 1
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_VMON_EN"
                                "fields": [
                                  "BUCK1_EN",
                                  "BUCK1_FPWM",
                                  "BUCK1_FPWM_MP",
                                  "BUCK1_VSEL",
                                  "BUCK1_VMON_EN",
                                  "BUCK1_PLDN",
                                  "BUCK1_RV_SEL"
                                "fields": [
                                  "BUCK1_SLEW_RATE",
                                  "BUCK1_ILIM"
                                "fields": [
                                  "BUCK1_VSET1"
                                "fields": [
                                  "BUCK1_VSET2"
                                "fields": [
                                  "BUCK1_OV_THR",
                                  "BUCK1_UV_THR"
                                "fields": [
                                  "BUCK1_GRP_SEL"
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "BUCK1_RESET"
                                "fields": [
                                  "BUCK1_RESET"
                                "hideFields": [
                                  "BUCK1_FREQ_SEL"
                                "fields": [
                                  "BUCK1_FREQ_SEL"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 1
                                    "value": 0
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                  "BUCK1_SEL_RAMP"
                                "fields": [
                                  "BUCK1_SEL_RAMP"
                                "hideFields": [
                                  "BUCK1_FREQ_8MHZ"
                                "fields": [
                                  "BUCK1_FREQ_8MHZ"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_1"
                                "fields": [
                                  "swc_buck_hiz_1"
                            "regConfig": {
                              "id": "vtt_config",
                              "options": [
                                  "name": "yes",
                                  "inductor": "470nH"
                                  "name": "no",
                                  "options": [
                                      "name": "4.4MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "220nH"
                                          "name": "no",
                                          "options": [
                                              "options": [
                                                  "inductor": "220nH"
                                                  "inductor": "220nH"
                                              "inductor": "470nH"
                                      "name": "2.2MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "470nH"
                                          "name": "no",
                                          "options": [
                                              "inductor": "470nH"
                                              "options": [
                                                  "inductor": "470nH"
                            "name": "Buck2",
                            "registers": [
                                "regID": "BUCK2_CTRL",
                                "fixedFields": [
                                    "fieldID": "BUCK2_EN",
                                    "value": 0
                                    "fieldID": "BUCK2_PLDN",
                                    "value": 1
                                    "fieldID": "BUCK2_VMON_EN",
                                    "value": 0
                                "hideFields": [
                                  "BUCK2_EN",
                                  "BUCK2_PLDN",
                                  "BUCK2_VMON_EN"
                                "fields": [
                                  "BUCK2_EN",
                                  "BUCK2_FPWM",
                                  "BUCK2_VSEL",
                                  "BUCK2_VMON_EN",
                                  "BUCK2_PLDN",
                                  "BUCK2_RV_SEL"
                                "regID": "BUCK2_CONF",
                                "fields": [
                                  "BUCK2_SLEW_RATE",
                                  "BUCK2_ILIM"
                                "regID": "BUCK2_VOUT_1",
                                "fields": [
                                  "BUCK2_VSET1"
                                "regID": "BUCK2_VOUT_2",
                                "fields": [
                                  "BUCK2_VSET2"
                                "regID": "BUCK2_PG_WINDOW",
                                "fields": [
                                  "BUCK2_OV_THR",
                                  "BUCK2_UV_THR"
                                "fields": [
                                  "BUCK2_GRP_SEL"
                                "fixedFields": [
                                    "fieldID": "BUCK2_RESET",
                                    "value": 0
                                "hideFields": [
                                  "BUCK2_RESET"
                                "fields": [
                                  "BUCK2_RESET"
                                "hideFields": [
                                  "BUCK2_FREQ_SEL"
                                "fields": [
                                  "BUCK2_FREQ_SEL"
                                "hideFields": [
                                  "BUCK2_SEL_NEG_OCP_HYST"
                                "fields": [
                                "hideFields": [
                                  "BUCK2_SEL_POS_OCP_HYST"
                                "fields": [
                                "regID": "BUCK_CONFIG_ANALOG_4",
                                "hideFields": [
                                  "BUCK2_SEL_ISENSE_SLOPE_COMPENSATION",
                                  "BUCK2_SEL_VOUT_ADC_LEVEL"
                                "fields": [
                                "hideFields": [
                                  "BUCK2_SEL_OUTPUT_CAPS"
                                "fields": [
                                "hideFields": [
                                  "BUCK2_SEL_RAMP"
                                "fields": [
                                  "BUCK2_SEL_RAMP"
                                "hideFields": [
                                  "BUCK2_FREQ_8MHZ"
                                "fields": [
                                  "BUCK2_FREQ_8MHZ"
                                "hideFields": [
                                  "BUCK2_EN_P_10M_BODY_DIODE"
                                "fields": [
                                "hideFields": [
                                  "BUCK2_DOUBLE_PFM_PULSE"
                                "fields": [
                                "hideFields": [
                                  "BUCK2_CHANGE_2MHZ_BELOW_0V5"
                                "fields": [
                                "hideFields": [
                                  "BUCK2_EN_RADAR_MODE"
                                "fields": [
                                "regID": "BUCK2_DTEST_REG_0",
                                "fixedFields": [
                                    "fieldID": "swc_buck_hiz_2",
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_2"
                                "fields": [
                                  "swc_buck_hiz_2"
                            "regConfig": {
                              "id": "vtt_config",
                              "options": [
                                  "name": "yes",
                                  "inductor": "470nH"
                                  "name": "no",
                                  "options": [
                                      "name": "4.4MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "220nH"
                                          "name": "no",
                                          "options": [
                                              "options": [
                                                  "inductor": "220nH"
                                                  "inductor": "220nH"
                                              "inductor": "470nH"
                                      "name": "2.2MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "470nH"
                                          "name": "no",
                                          "options": [
                                              "inductor": "470nH"
                                              "options": [
                                                  "inductor": "470nH"
                            "name": "Buck3",
                            "registers": [
                                "fixedFields": [
                                    "value": 0
                                    "value": 1
                                    "value": 0
                                "hideFields": [
                                  "BUCK3_EN",
                                  "BUCK3_PLDN",
                                  "BUCK3_VMON_EN"
                                "fields": [
                                  "BUCK3_EN",
                                  "BUCK3_FPWM",
                                  "BUCK3_FPWM_MP",
                                  "BUCK3_VSEL",
                                  "BUCK3_VMON_EN",
                                  "BUCK3_PLDN",
                                  "BUCK3_RV_SEL"
                                "fields": [
                                  "BUCK3_SLEW_RATE",
                                  "BUCK3_ILIM"
                                "fields": [
                                  "BUCK3_VSET1"
                                "fields": [
                                  "BUCK3_VSET2"
                                "fields": [
                                  "BUCK3_OV_THR",
                                  "BUCK3_UV_THR"
                                "fields": [
                                  "BUCK3_GRP_SEL"
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "BUCK3_RESET"
                                "fields": [
                                  "BUCK3_RESET"
                                "hideFields": [
                                  "BUCK3_FREQ_SEL"
                                "fields": [
                                  "BUCK3_FREQ_SEL"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 0
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                  "BUCK3_SEL_RAMP"
                                "fields": [
                                  "BUCK3_SEL_RAMP"
                                "hideFields": [
                                  "BUCK3_FREQ_8MHZ"
                                "fields": [
                                  "BUCK3_FREQ_8MHZ"
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_3"
                                "fields": [
                                  "swc_buck_hiz_3"
                            "regConfig": {
                              "id": "vtt_config",
                              "options": [
                                  "name": "yes",
                                  "inductor": "470nH"
                                  "name": "no",
                                  "options": [
                                      "name": "4.4MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "220nH"
                                          "name": "no",
                                          "options": [
                                              "options": [
                                                  "inductor": "220nH"
                                                  "inductor": "220nH"
                                              "inductor": "470nH"
                                      "name": "2.2MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "470nH"
                                          "name": "no",
                                          "options": [
                                              "inductor": "470nH"
                                              "options": [
                                                  "inductor": "470nH"
                            "name": "Buck4",
                            "registers": [
                                "fixedFields": [
                                    "fieldID": "BUCK4_EN",
                                    "value": 0
                                    "fieldID": "BUCK4_PLDN",
                                    "value": 1
                                    "fieldID": "BUCK4_VMON_EN",
                                    "value": 0
                                "hideFields": [
                                  "BUCK4_EN",
                                  "BUCK4_PLDN",
                                  "BUCK4_VMON_EN"
                                "fields": [
                                  "BUCK4_EN",
                                  "BUCK4_FPWM",
                                  "BUCK4_VSEL",
                                  "BUCK4_VMON_EN",
                                  "BUCK4_PLDN",
                                  "BUCK4_RV_SEL"
                                "fields": [
                                  "BUCK4_SLEW_RATE",
                                  "BUCK4_ILIM"
                                "fields": [
                                  "BUCK4_VSET1"
                                "fields": [
                                  "BUCK4_VSET2"
                                "fields": [
                                  "BUCK4_OV_THR",
                                  "BUCK4_UV_THR"
                                "fields": [
                                  "BUCK4_GRP_SEL"
                                "fixedFields": [
                                    "fieldID": "BUCK4_RESET",
                                    "value": 0
                                "hideFields": [
                                  "BUCK4_RESET"
                                "fields": [
                                  "BUCK4_RESET"
                                "hideFields": [
                                  "BUCK4_FREQ_SEL"
                                "fields": [
                                  "BUCK4_FREQ_SEL"
                                "hideFields": [
                                  "BUCK4_SEL_NEG_OCP_HYST"
                                "fields": [
                                "hideFields": [
                                  "BUCK4_SEL_POS_OCP_HYST"
                                "fields": [
                                "regID": "BUCK_CONFIG_ANALOG_6",
                                "hideFields": [
                                  "BUCK4_SEL_ISENSE_SLOPE_COMPENSATION",
                                  "BUCK4_SEL_VOUT_ADC_LEVEL"
                                "fields": [
                                "hideFields": [
                                  "BUCK4_SEL_OUTPUT_CAPS"
                                "fields": [
                                "hideFields": [
                                  "BUCK4_SEL_RAMP"
                                "fields": [
                                  "BUCK4_SEL_RAMP"
                                "hideFields": [
                                  "BUCK4_FREQ_8MHZ"
                                "fields": [
                                  "BUCK4_FREQ_8MHZ"
                                "hideFields": [
                                  "BUCK4_EN_P_10M_BODY_DIODE"
                                "fields": [
                                "hideFields": [
                                  "BUCK4_DOUBLE_PFM_PULSE"
                                "fields": [
                                "hideFields": [
                                  "BUCK4_CHANGE_2MHZ_BELOW_0V5"
                                "fields": [
                                "hideFields": [
                                  "BUCK4_EN_RADAR_MODE"
                                "fields": [
                                "regID": "BUCK4_DTEST_REG_0",
                                "fixedFields": [
                                    "fieldID": "swc_buck_hiz_4",
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_4"
                                "fields": [
                                  "swc_buck_hiz_4"
                            "regConfig": {
                              "id": "vtt_config",
                              "options": [
                                  "name": "yes",
                                  "inductor": "470nH"
                                  "name": "no",
                                  "options": [
                                      "name": "4.4MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "220nH"
                                          "name": "no",
                                          "options": [
                                              "options": [
                                                  "inductor": "220nH"
                                                  "inductor": "220nH"
                                              "inductor": "470nH"
                                      "name": "2.2MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "470nH"
                                          "name": "no",
                                          "options": [
                                              "inductor": "470nH"
                                              "options": [
                                                  "inductor": "470nH"
                            "name": "Buck5",
                            "type": "visible",
                            "registers": [
                                "regID": "BUCK5_CTRL",
                                "fixedFields": [
                                    "fieldID": "BUCK5_EN",
                                    "value": 0
                                    "fieldID": "BUCK5_PLDN",
                                    "value": 1
                                    "fieldID": "BUCK5_VMON_EN",
                                    "value": 0
                                "hideFields": [
                                  "BUCK5_EN",
                                  "BUCK5_PLDN",
                                  "BUCK5_VMON_EN"
                                "fields": [
                                  "BUCK5_EN",
                                  "BUCK5_FPWM",
                                  "BUCK5_VSEL",
                                  "BUCK5_VMON_EN",
                                  "BUCK5_PLDN",
                                  "BUCK5_RV_SEL"
                                "regID": "BUCK5_CONF",
                                "fields": [
                                  "BUCK5_SLEW_RATE",
                                  "BUCK5_ILIM"
                                "regID": "BUCK5_VOUT_1",
                                "fields": [
                                  "BUCK5_VSET1"
                                "regID": "BUCK5_VOUT_2",
                                "fields": [
                                  "BUCK5_VSET2"
                                "regID": "BUCK5_PG_WINDOW",
                                "fields": [
                                  "BUCK5_OV_THR",
                                  "BUCK5_UV_THR"
                                "regID": "RAIL_SEL_2",
                                "fields": [
                                  "BUCK5_GRP_SEL"
                                "fixedFields": [
                                    "fieldID": "BUCK5_RESET",
                                    "value": 0
                                "hideFields": [
                                  "BUCK5_RESET"
                                "fields": [
                                  "BUCK5_RESET"
                                "hideFields": [
                                  "BUCK5_FREQ_SEL"
                                "fields": [
                                  "BUCK5_FREQ_SEL"
                                "hideFields": [
                                  "BUCK5_SEL_NEG_OCP_HYST"
                                "fields": [
                                "hideFields": [
                                  "BUCK5_SEL_POS_OCP_HYST"
                                "fields": [
                                "regID": "BUCK_CONFIG_ANALOG_7",
                                "hideFields": [
                                  "BUCK5_SEL_ISENSE_SLOPE_COMPENSATION",
                                  "BUCK5_SEL_VOUT_ADC_LEVEL"
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_5",
                                "hideFields": [
                                  "BUCK5_SEL_OUTPUT_CAPS"
                                "fields": [
                                "hideFields": [
                                  "BUCK5_SEL_RAMP"
                                "fields": [
                                  "BUCK5_SEL_RAMP"
                                "hideFields": [
                                  "BUCK5_FREQ_8MHZ"
                                "fields": [
                                  "BUCK5_FREQ_8MHZ"
                                "hideFields": [
                                  "BUCK5_EN_P_10M_BODY_DIODE"
                                "fields": [
                                "hideFields": [
                                  "BUCK5_DOUBLE_PFM_PULSE"
                                "fields": [
                                "hideFields": [
                                  "BUCK5_CHANGE_2MHZ_BELOW_0V5"
                                "fields": [
                                "hideFields": [
                                  "BUCK5_EN_RADAR_MODE"
                                "fields": [
                                "regID": "BUCK5_DTEST_REG_0",
                                "fixedFields": [
                                    "fieldID": "swc_buck_hiz_5",
                                    "value": 0
                                "hideFields": [
                                  "swc_buck_hiz_5"
                                "fields": [
                                  "swc_buck_hiz_5"
                            "regConfig": {
                              "id": "vtt_config",
                              "options": [
                                  "name": "yes",
                                  "inductor": "470nH"
                                  "name": "no",
                                  "options": [
                                      "name": "4.4MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "220nH"
                                          "name": "no",
                                          "options": [
                                              "options": [
                                                  "inductor": "220nH"
                                                  "inductor": "220nH"
                                              "inductor": "470nH"
                                      "name": "2.2MHz",
                                      "options": [
                                          "name": "yes",
                                          "inductor": "470nH"
                                          "name": "no",
                                          "options": [
                                              "inductor": "470nH"
                                              "options": [
                                                  "inductor": "470nH"
                            "name": "Miscellaneous Buck",
                            "type": "visible",
                            "registers": [
                                "regID": "BUCK_CONFIG_ANALOG_0",
                                "fixedFields": [
                                    "fieldID": "SEL_LOOP_NEG_HYST",
                                    "value": 2
                                    "fieldID": "SEL_GATE_EARLY_SENSE",
                                    "value": 0
                                    "fieldID": "SEL_TRAD_NON_OVERLAP",
                                    "value": 0
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "fieldID": "SEL_FB_FILTER",
                                    "value": 3
                                "hideFields": [
                                  "SEL_FB_FILTER"
                                "fields": [
                                  "SEL_FB_FILTER"
                                "regID": "BUCK_CONFIG_ANALOG_2",
                                "fixedFields": [
                                    "fieldID": "SEL_RAMP_ARTIF",
                                    "value": 1
                                "hideFields": [
                                  "SEL_RAMP_ARTIF"
                                "fields": [
                                  "SEL_RAMP_ARTIF"
                                "regID": "BUCK_CONFIG_ANALOG_8",
                                "fixedFields": [
                                    "fieldID": "EN_SW_RT_SHORT_DETECTORS",
                                    "value": 0
                                    "fieldID": "EN_IAVE_LOOP_INJECTOR",
                                    "value": 0
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "fieldID": "EN_PLL_PROP_EXTEND",
                                    "value": 1
                                    "fieldID": "EN_SMART_OCP_BLANK",
                                    "value": 1
                                "hideFields": [
                                "fields": [
                                "regID": "BUCK_CONFIG_DIGITAL_2",
                                "fixedFields": [
                                    "fieldID": "SEL_HS_DETECTOR",
                                    "value": 1
                                    "fieldID": "EN_LONG_PFM_EXIT_CNTR",
                                    "value": 1
                                "hideFields": [
                                  "SEL_HS_DETECTOR",
                                "fields": [
                                  "SEL_HS_DETECTOR",
                                "regID": "BUCK_CONFIG_DIGITAL_3",
                                "fixedFields": [
                                    "fieldID": "EN_NEG_OCP",
                                    "value": 1
                                    "fieldID": "EN_POS_OCP",
                                    "value": 1
                                    "fieldID": "EN_PFM_LOAD",
                                    "value": 1
                                    "fieldID": "EN_DOT_MODE",
                                    "value": 1
                                "hideFields": [
                                  "DOUBLE_PFM_PULSE",
                                  "EN_P_10M_BODY_DIODE",
                                  "EN_NEG_OCP",
                                  "EN_POS_OCP",
                                  "EN_PFM_LOAD",
                                  "EN_DOT_MODE"
                                "fields": [
                                  "EN_DOT_MODE",
                                  "EN_PFM_LOAD",
                                  "DOUBLE_PFM_PULSE",
                                  "EN_POS_OCP",
                                  "EN_NEG_OCP"
                                "fixedFields": [
                                    "fieldID": "EN_AUTO_LOOP_COEFFS",
                                    "value": 1
                                    "fieldID": "LOOP_COEFF_FB_MSB",
                                    "value": 1
                                    "fieldID": "LOOP_COEFF_I_BALANCE",
                                    "value": 1
                                    "fieldID": "SEL_ZERO_CROSS_FILTER_AVE",
                                    "value": 1
                                    "fieldID": "EN_LONG_ZERO_CROSS_FILTER",
                                    "value": 0
                                "hideFields": [
                                "fields": [
                                "fixedFields": [
                                    "fieldID": "EN_PFM_PULSE_WAIT_LS_OCP",
                                    "value": 1
                                    "fieldID": "EN_SLOW_PLL_COEFFS",
                                    "value": 0
                                    "fieldID": "FORCE_SS_ADAPT",
                                    "value": 0
                                "hideFields": [
                                  "FORCE_SS_ADAPT"
                                "fields": [
                                  "FORCE_SS_ADAPT"
                                "fixedFields": [
                                    "fieldID": "EN_FAST_PLL_0P7",
                                    "value": 1
                                    "fieldID": "EN_SW_SHORT_DETECTORS",
                                    "value": 1
                                "hideFields": [
                                  "EN_FAST_PLL_0P7",
                                "fields": [
                                  "EN_FAST_PLL_0P7",
                                "regID": "BUCK_CONFIG_DIGITAL_8",
                                "fixedFields": [
                                    "fieldID": "EN_FAST_VOUT_INTEGRATION",
                                    "value": 1
                                    "fieldID": "EN_I_BALANCE_INTEGRATOR",
                                    "value": 1
                                    "fieldID": "DIS_PFM_WAITS_LS_DETECTOR",
                                    "value": 0
                                    "fieldID": "DIS_PFM_WAITS_HS_DETECTOR",
                                    "value": 0
                                    "fieldID": "DIS_DVS_WAIT_COMPARATORS",
                                    "value": 0
                                    "fieldID": "EN_SLOW_PLL_0P3",
                                    "value": 1
                                    "fieldID": "EN_CONSTANT_PLL_DVS_COEFF",
                                    "value": 0
                                "hideFields": [
                                  "EN_SLOW_PLL_0P3"
                                "fields": [
                                  "EN_SLOW_PLL_0P3"
                                "regID": "BUCK_CONFIG_DIGITAL_9",
                                "fixedFields": [
                                    "fieldID": "EN_M_10M_TRAN_DETECTOR",
                                    "value": 1
                                    "fieldID": "EN_LS_AFTER_HIZ",
                                    "value": 0
                                    "fieldID": "EN_PWM_LS_DETECTION",
                                    "value": 0
                                    "fieldID": "I_COEFF",
                                    "value": 1
                                    "fieldID": "EN_FAST_INTEGRATION_BYPASS_RAMP_RES",
                                    "value": 1
                                "hideFields": [
                                  "EN_LS_AFTER_HIZ",
                                  "I_COEFF",
                                "fields": [
                                  "EN_LS_AFTER_HIZ",
                                  "I_COEFF",
                                "regID": "BUCK_CONFIG_DIGITAL_10",
                                "fixedFields": [
                                    "fieldID": "BUCK_NEG_ILIM",
                                    "value": 1
                                    "fieldID": "EN_ADAPTIVE_SINGLE_SHOT",
                                    "value": 1
                                "hideFields": [
                                  "BUCK_NEG_ILIM",
                                "fields": [
                                  "BUCK_NEG_ILIM",
                                "regID": "BUCK_CONFIG_DIGITAL_11",
                                "fixedFields": [
                                    "fieldID": "FIXED_SS_LENGTH",
                                    "value": 24
                                    "fieldID": "LONG_SINGLE_SHOT",
                                    "value": 1
                                "hideFields": [
                                  "FIXED_SS_LENGTH",
                                  "LONG_SINGLE_SHOT"
                                "fields": [
                                  "FIXED_SS_LENGTH",
                                  "LONG_SINGLE_SHOT"
                  "registerJSON": {
                    "regblocks": [
                        "id": "UserRegisters1-user_mem",
                        "registers": [
                            "id": "DEV_REV",
                            "value": "0",
                            "fields": [
                                "id": "TI_DEVICE_ID",
                                "value": "0",
                                "staticConfig": true
                            "id": "NVM_CODE_1",
                            "value": "0",
                            "fields": [
                                "id": "TI_NVM_ID",
                                "value": "0",
                            "id": "NVM_CODE_2",
                            "value": "0",
                            "fields": [
                                "id": "TI_NVM_REV",
                                "value": "0",
                            "id": "BUCK1_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_EN",
                                "value": 0
                                "id": "BUCK1_FPWM",
                                "value": "0"
                                "id": "BUCK1_FPWM_MP",
                                "value": "0"
                                "id": "BUCK1_VMON_EN",
                                "value": 0
                                "id": "BUCK1_VSEL",
                                "value": "0"
                                "id": "BUCK1_PLDN",
                                "value": 1
                                "id": "BUCK1_RV_SEL",
                                "value": "0"
                            "id": "BUCK1_CONF",
                            "value": "0x22",
                            "fields": [
                                "id": "BUCK1_SLEW_RATE",
                                "value": "2"
                                "id": "BUCK1_ILIM",
                                "value": "4"
                            "id": "BUCK2_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "BUCK2_EN",
                                "value": 0
                                "id": "BUCK2_FPWM",
                                "value": 0
                                "id": "BUCK2_VMON_EN",
                                "value": 0
                                "id": "BUCK2_VSEL",
                                "value": 0
                                "id": "BUCK2_PLDN",
                                "value": 1
                                "id": "BUCK2_RV_SEL",
                                "value": 0
                            "id": "BUCK2_CONF",
                            "value": "0x22",
                            "fields": [
                                "id": "BUCK2_SLEW_RATE",
                                "value": 2
                                "id": "BUCK2_ILIM",
                                "value": 4
                            "id": "BUCK3_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_EN",
                                "value": 0
                                "id": "BUCK3_FPWM",
                                "value": "0"
                                "id": "BUCK3_FPWM_MP",
                                "value": "0"
                                "id": "BUCK3_VMON_EN",
                                "value": 0
                                "id": "BUCK3_VSEL",
                                "value": "0"
                                "id": "BUCK3_PLDN",
                                "value": 1
                                "id": "BUCK3_RV_SEL",
                                "value": "0"
                            "id": "BUCK3_CONF",
                            "value": "0x22",
                            "fields": [
                                "id": "BUCK3_SLEW_RATE",
                                "value": "2"
                                "id": "BUCK3_ILIM",
                                "value": "4"
                            "id": "BUCK4_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "BUCK4_EN",
                                "value": 0
                                "id": "BUCK4_FPWM",
                                "value": "0"
                                "id": "BUCK4_VMON_EN",
                                "value": 0
                                "id": "BUCK4_VSEL",
                                "value": "0"
                                "id": "BUCK4_PLDN",
                                "value": 1
                                "id": "BUCK4_RV_SEL",
                                "value": "0"
                            "id": "BUCK4_CONF",
                            "value": "0x22",
                            "fields": [
                                "id": "BUCK4_SLEW_RATE",
                                "value": "2"
                                "id": "BUCK4_ILIM",
                                "value": "4"
                            "id": "BUCK5_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_EN",
                                "value": 0
                                "id": "BUCK5_FPWM",
                                "value": "0"
                                "id": "BUCK5_VMON_EN",
                                "value": 0
                                "id": "BUCK5_VSEL",
                                "value": "0"
                                "id": "BUCK5_PLDN",
                                "value": 1
                                "id": "BUCK5_RV_SEL",
                                "value": "0"
                            "id": "BUCK5_CONF",
                            "value": "0x22",
                            "fields": [
                                "id": "BUCK5_SLEW_RATE",
                                "value": "2"
                                "id": "BUCK5_ILIM",
                                "value": "2"
                            "id": "BUCK1_VOUT_1",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_VSET1",
                                "value": "0"
                            "id": "BUCK1_VOUT_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_VSET2",
                                "value": "0"
                            "id": "BUCK2_VOUT_1",
                            "value": "0",
                            "fields": [
                                "id": "BUCK2_VSET1",
                                "value": 0
                            "id": "BUCK2_VOUT_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK2_VSET2",
                                "value": 0
                            "id": "BUCK3_VOUT_1",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_VSET1",
                                "value": "0"
                            "id": "BUCK3_VOUT_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_VSET2",
                                "value": "0"
                            "id": "BUCK4_VOUT_1",
                            "value": "0",
                            "fields": [
                                "id": "BUCK4_VSET1",
                                "value": "0"
                            "id": "BUCK4_VOUT_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK4_VSET2",
                                "value": "0"
                            "id": "BUCK5_VOUT_1",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_VSET1",
                                "value": "0"
                            "id": "BUCK5_VOUT_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_VSET2",
                                "value": "0"
                            "id": "BUCK1_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_OV_THR",
                                "value": "0"
                                "id": "BUCK1_UV_THR",
                                "value": "0"
                            "id": "BUCK2_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "BUCK2_OV_THR",
                                "value": 0
                                "id": "BUCK2_UV_THR",
                                "value": 0
                            "id": "BUCK3_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_OV_THR",
                                "value": "0"
                                "id": "BUCK3_UV_THR",
                                "value": "0"
                            "id": "BUCK4_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "BUCK4_OV_THR",
                                "value": "0"
                                "id": "BUCK4_UV_THR",
                                "value": "0"
                            "id": "BUCK5_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_OV_THR",
                                "value": "0"
                                "id": "BUCK5_UV_THR",
                                "value": "0"
                            "id": "LDO1_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_EN",
                                "value": 0
                                "id": "LDO1_PLDN",
                                "value": "0"
                                "id": "LDO1_VMON_EN",
                                "value": 0
                                "id": "LDO1_RV_SEL",
                                "value": "0"
                                "id": "LDO1_SLOW_RAMP",
                                "value": "0"
                            "id": "LDO2_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "LDO2_EN",
                                "value": 0
                                "id": "LDO2_PLDN",
                                "value": "0"
                                "id": "LDO2_VMON_EN",
                                "value": 0
                                "id": "LDO2_RV_SEL",
                                "value": "0"
                                "id": "LDO2_SLOW_RAMP",
                                "value": "0"
                            "id": "LDO3_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_EN",
                                "value": 0
                                "id": "LDO3_PLDN",
                                "value": "0"
                                "id": "LDO3_VMON_EN",
                                "value": 0
                                "id": "LDO3_RV_SEL",
                                "value": "0"
                                "id": "LDO3_SLOW_RAMP",
                                "value": "0"
                            "id": "LDO4_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "LDO4_EN",
                                "value": 0
                                "id": "LDO4_PLDN",
                                "value": "0"
                                "id": "LDO4_VMON_EN",
                                "value": 0
                                "id": "LDO4_RV_SEL",
                                "value": "0"
                                "id": "LDO4_SLOW_RAMP",
                                "value": "0"
                            "id": "LDOINT_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "LDOINT_DIS",
                                "value": "0"
                            "id": "LDORTC_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "LDORTC_DIS",
                                "value": "0"
                            "id": "LDO1_VOUT",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_VSET",
                                "value": "4"
                                "id": "LDO1_BYPASS",
                                "value": "0"
                            "id": "LDO2_VOUT",
                            "value": "0",
                            "fields": [
                                "id": "LDO2_VSET",
                                "value": "4"
                                "id": "LDO2_BYPASS",
                                "value": "0"
                            "id": "LDO3_VOUT",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_VSET",
                                "value": "4"
                                "id": "LDO3_BYPASS",
                                "value": "0"
                            "id": "LDO4_VOUT",
                            "value": "0",
                            "fields": [
                                "id": "LDO4_VSET",
                                "value": "32"
                            "id": "LDO1_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_OV_THR",
                                "value": "0"
                                "id": "LDO1_UV_THR",
                                "value": "0"
                            "id": "LDO2_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "LDO2_OV_THR",
                                "value": "0"
                                "id": "LDO2_UV_THR",
                                "value": "0"
                            "id": "LDO3_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_OV_THR",
                                "value": "0"
                                "id": "LDO3_UV_THR",
                                "value": "0"
                            "id": "LDO4_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "LDO4_OV_THR",
                                "value": "0"
                                "id": "LDO4_UV_THR",
                                "value": "0"
                            "id": "VCCA_VMON_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "VCCA_VMON_EN",
                                "value": "0"
                                "id": "VMON_DEGLITCH_SEL",
                                "value": "0"
                            "id": "VCCA_PG_WINDOW",
                            "value": "0",
                            "fields": [
                                "id": "VCCA_OV_THR",
                                "value": "0"
                                "id": "VCCA_UV_THR",
                                "value": "0"
                                "id": "VCCA_PG_SET",
                                "value": "0"
                            "id": "GPIO1_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_OD",
                                "value": "0"
                                "id": "GPIO1_DIR",
                                "value": "0"
                                "id": "GPIO1_SEL",
                                "value": "0"
                                "id": "GPIO1_PU_SEL",
                                "value": "0"
                                "id": "GPIO1_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO1_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO2_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO2_OD",
                                "value": "0"
                                "id": "GPIO2_DIR",
                                "value": "0"
                                "id": "GPIO2_SEL",
                                "value": "0"
                                "id": "GPIO2_PU_SEL",
                                "value": "0"
                                "id": "GPIO2_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO2_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO3_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO3_OD",
                                "value": "0"
                                "id": "GPIO3_DIR",
                                "value": "0"
                                "id": "GPIO3_SEL",
                                "value": "0"
                                "id": "GPIO3_PU_SEL",
                                "value": "0"
                                "id": "GPIO3_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO3_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO4_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO4_OD",
                                "value": "0"
                                "id": "GPIO4_DIR",
                                "value": "0"
                                "id": "GPIO4_SEL",
                                "value": "0"
                                "id": "GPIO4_PU_SEL",
                                "value": "0"
                                "id": "GPIO4_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO4_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO5_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO5_OD",
                                "value": "0"
                                "id": "GPIO5_DIR",
                                "value": "0"
                                "id": "GPIO5_SEL",
                                "value": "0"
                                "id": "GPIO5_PU_SEL",
                                "value": "0"
                                "id": "GPIO5_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO5_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO6_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO6_OD",
                                "value": "0"
                                "id": "GPIO6_DIR",
                                "value": "0"
                                "id": "GPIO6_SEL",
                                "value": "0"
                                "id": "GPIO6_PU_SEL",
                                "value": "0"
                                "id": "GPIO6_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO6_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO7_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO7_OD",
                                "value": "0"
                                "id": "GPIO7_DIR",
                                "value": "0"
                                "id": "GPIO7_SEL",
                                "value": "0"
                                "id": "GPIO7_PU_SEL",
                                "value": "0"
                                "id": "GPIO7_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO7_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO8_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO8_OD",
                                "value": "0"
                                "id": "GPIO8_DIR",
                                "value": "0"
                                "id": "GPIO8_SEL",
                                "value": "0"
                                "id": "GPIO8_PU_SEL",
                                "value": "0"
                                "id": "GPIO8_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO8_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO9_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO9_OD",
                                "value": "0"
                                "id": "GPIO9_DIR",
                                "value": "0"
                                "id": "GPIO9_SEL",
                                "value": "0"
                                "id": "GPIO9_PU_SEL",
                                "value": "0"
                                "id": "GPIO9_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO9_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO10_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO10_OD",
                                "value": "0"
                                "id": "GPIO10_DIR",
                                "value": "0"
                                "id": "GPIO10_SEL",
                                "value": "0"
                                "id": "GPIO10_PU_SEL",
                                "value": "0"
                                "id": "GPIO10_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO10_DEGLITCH_EN",
                                "value": "0"
                            "id": "GPIO11_CONF",
                            "value": "0",
                            "fields": [
                                "id": "GPIO11_OD",
                                "value": "0"
                                "id": "GPIO11_DIR",
                                "value": "0"
                                "id": "GPIO11_SEL",
                                "value": "0"
                                "id": "GPIO11_PU_SEL",
                                "value": "0"
                                "id": "GPIO11_PU_PD_EN",
                                "value": "0"
                                "id": "GPIO11_DEGLITCH_EN",
                                "value": "0"
                            "id": "NPWRON_CONF",
                            "value": "0",
                            "fields": [
                                "id": "NPWRON_SEL",
                                "value": "0"
                                "id": "ENABLE_PU_SEL",
                                "value": "0"
                                "id": "ENABLE_PU_PD_EN",
                                "value": "0"
                                "id": "ENABLE_DEGLITCH_EN",
                                "value": "0"
                                "id": "ENABLE_POL",
                                "value": "0"
                                "id": "NRSTOUT_OD",
                                "value": "0"
                            "id": "GPIO_OUT_1",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_OUT",
                                "value": 0
                                "id": "GPIO2_OUT",
                                "value": 0
                                "id": "GPIO3_OUT",
                                "value": 0
                                "id": "GPIO4_OUT",
                                "value": 0
                                "id": "GPIO5_OUT",
                                "value": 0
                                "id": "GPIO6_OUT",
                                "value": 0
                                "id": "GPIO7_OUT",
                                "value": 0
                                "id": "GPIO8_OUT",
                                "value": 0
                            "id": "GPIO_OUT_2",
                            "value": "0",
                            "fields": [
                                "id": "GPIO9_OUT",
                                "value": 0
                                "id": "GPIO10_OUT",
                                "value": 0
                                "id": "GPIO11_OUT",
                                "value": 0
                            "id": "GPIO_IN_1",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_IN",
                                "value": "0"
                                "id": "GPIO2_IN",
                                "value": "0"
                                "id": "GPIO3_IN",
                                "value": "0"
                                "id": "GPIO4_IN",
                                "value": "0"
                                "id": "GPIO5_IN",
                                "value": "0"
                                "id": "GPIO6_IN",
                                "value": "0"
                                "id": "GPIO7_IN",
                                "value": "0"
                                "id": "GPIO8_IN",
                                "value": "0"
                            "id": "GPIO_IN_2",
                            "value": "0",
                            "fields": [
                                "id": "GPIO9_IN",
                                "value": "0"
                                "id": "GPIO10_IN",
                                "value": "0"
                                "id": "GPIO11_IN",
                                "value": "0"
                                "id": "NPWRON_IN",
                                "value": "0"
                            "id": "RAIL_SEL_1",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_GRP_SEL",
                                "value": "0"
                                "id": "BUCK2_GRP_SEL",
                                "value": 0
                                "id": "BUCK3_GRP_SEL",
                                "value": 0
                                "id": "BUCK4_GRP_SEL",
                                "value": 0
                            "id": "RAIL_SEL_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_GRP_SEL",
                                "value": "0"
                                "id": "LDO1_GRP_SEL",
                                "value": "0"
                                "id": "LDO2_GRP_SEL",
                                "value": "0"
                                "id": "LDO3_GRP_SEL",
                                "value": "0"
                            "id": "RAIL_SEL_3",
                            "value": "0",
                            "fields": [
                                "id": "LDO4_GRP_SEL",
                                "value": "0"
                                "id": "VCCA_GRP_SEL",
                                "value": "0"
                            "id": "FSM_TRIG_SEL_1",
                            "value": "0",
                            "fields": [
                                "id": "MCU_RAIL_TRIG",
                                "value": "0"
                                "id": "SOC_RAIL_TRIG",
                                "value": "0"
                                "id": "OTHER_RAIL_TRIG",
                                "value": "0"
                                "id": "SEVERE_ERR_TRIG",
                                "value": "0"
                            "id": "FSM_TRIG_SEL_2",
                            "value": "0",
                            "fields": [
                                "id": "MODERATE_ERR_TRIG",
                                "value": "0"
                            "id": "FSM_TRIG_MASK_1",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_FSM_MASK",
                                "value": "0"
                                "id": "GPIO1_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO2_FSM_MASK",
                                "value": "0"
                                "id": "GPIO2_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO3_FSM_MASK",
                                "value": "0"
                                "id": "GPIO3_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO4_FSM_MASK",
                                "value": "0"
                                "id": "GPIO4_FSM_MASK_POL",
                                "value": "0"
                            "id": "FSM_TRIG_MASK_2",
                            "value": "0",
                            "fields": [
                                "id": "GPIO5_FSM_MASK",
                                "value": "0"
                                "id": "GPIO5_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO6_FSM_MASK",
                                "value": "0"
                                "id": "GPIO6_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO7_FSM_MASK",
                                "value": "0"
                                "id": "GPIO7_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO8_FSM_MASK",
                                "value": "0"
                                "id": "GPIO8_FSM_MASK_POL",
                                "value": "0"
                            "id": "FSM_TRIG_MASK_3",
                            "value": "0",
                            "fields": [
                                "id": "GPIO9_FSM_MASK",
                                "value": "0"
                                "id": "GPIO9_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO10_FSM_MASK",
                                "value": "0"
                                "id": "GPIO10_FSM_MASK_POL",
                                "value": "0"
                                "id": "GPIO11_FSM_MASK",
                                "value": "0"
                                "id": "GPIO11_FSM_MASK_POL",
                                "value": "0"
                            "id": "MASK_BUCK1_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_ILIM_MASK",
                                "value": "0"
                                "id": "BUCK1_OV_MASK",
                                "value": "0"
                                "id": "BUCK1_UV_MASK",
                                "value": "0"
                                "id": "BUCK2_ILIM_MASK",
                                "value": "0"
                                "id": "BUCK2_OV_MASK",
                                "value": "0"
                                "id": "BUCK2_UV_MASK",
                                "value": "0"
                            "id": "MASK_BUCK3_4",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_ILIM_MASK",
                                "value": "0"
                                "id": "BUCK3_OV_MASK",
                                "value": "0"
                                "id": "BUCK3_UV_MASK",
                                "value": "0"
                                "id": "BUCK4_OV_MASK",
                                "value": "0"
                                "id": "BUCK4_UV_MASK",
                                "value": "0"
                                "id": "BUCK4_ILIM_MASK",
                                "value": "0"
                            "id": "MASK_BUCK5",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_ILIM_MASK",
                                "value": "0"
                                "id": "BUCK5_OV_MASK",
                                "value": "0"
                                "id": "BUCK5_UV_MASK",
                                "value": "0"
                            "id": "MASK_LDO1_2",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_OV_MASK",
                                "value": "0"
                                "id": "LDO1_UV_MASK",
                                "value": "0"
                                "id": "LDO2_OV_MASK",
                                "value": "0"
                                "id": "LDO2_UV_MASK",
                                "value": "0"
                                "id": "LDO1_ILIM_MASK",
                                "value": "0"
                                "id": "LDO2_ILIM_MASK",
                                "value": "0"
                            "id": "MASK_LDO3_4",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_OV_MASK",
                                "value": "0"
                                "id": "LDO3_UV_MASK",
                                "value": "0"
                                "id": "LDO4_OV_MASK",
                                "value": "0"
                                "id": "LDO4_UV_MASK",
                                "value": "0"
                                "id": "LDO3_ILIM_MASK",
                                "value": "0"
                                "id": "LDO4_ILIM_MASK",
                                "value": "0"
                            "id": "MASK_VMON",
                            "value": "0",
                            "fields": [
                                "id": "VCCA_OV_MASK",
                                "value": "0"
                                "id": "VCCA_UV_MASK",
                                "value": "0"
                            "id": "MASK_GPIO1_8_FALL",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_FALL_MASK",
                                "value": "0"
                                "id": "GPIO2_FALL_MASK",
                                "value": "0"
                                "id": "GPIO3_FALL_MASK",
                                "value": "0"
                                "id": "GPIO4_FALL_MASK",
                                "value": "0"
                                "id": "GPIO5_FALL_MASK",
                                "value": "0"
                                "id": "GPIO6_FALL_MASK",
                                "value": "0"
                                "id": "GPIO7_FALL_MASK",
                                "value": "0"
                                "id": "GPIO8_FALL_MASK",
                                "value": "0"
                            "id": "MASK_GPIO1_8_RISE",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_RISE_MASK",
                                "value": "0"
                                "id": "GPIO2_RISE_MASK",
                                "value": "0"
                                "id": "GPIO3_RISE_MASK",
                                "value": "0"
                                "id": "GPIO4_RISE_MASK",
                                "value": "0"
                                "id": "GPIO5_RISE_MASK",
                                "value": "0"
                                "id": "GPIO6_RISE_MASK",
                                "value": "0"
                                "id": "GPIO7_RISE_MASK",
                                "value": "0"
                                "id": "GPIO8_RISE_MASK",
                                "value": "0"
                            "id": "MASK_GPIO9_11",
                            "value": "0",
                            "fields": [
                                "id": "GPIO9_FALL_MASK",
                                "value": "0"
                                "id": "GPIO9_RISE_MASK",
                                "value": "0"
                                "id": "GPIO10_FALL_MASK",
                                "value": "0"
                                "id": "GPIO11_FALL_MASK",
                                "value": "0"
                                "id": "GPIO10_RISE_MASK",
                                "value": "0"
                                "id": "GPIO11_RISE_MASK",
                                "value": "0"
                            "id": "MASK_STARTUP",
                            "value": "0",
                            "fields": [
                                "id": "NPWRON_START_MASK",
                                "value": "0"
                                "id": "ENABLE_MASK",
                                "value": "0"
                                "id": "FSD_MASK",
                                "value": "0"
                                "id": "SOFT_REBOOT_MASK",
                                "value": "0"
                            "id": "MASK_MISC",
                            "value": "0",
                            "fields": [
                                "id": "TWARN_MASK",
                                "value": "0"
                                "id": "BIST_PASS_MASK",
                                "value": "0"
                                "id": "EXT_CLK_MASK",
                                "value": "0"
                            "id": "MASK_MODERATE_ERR",
                            "value": "0",
                            "fields": [
                                "id": "BIST_FAIL_MASK",
                                "value": "0"
                                "id": "REG_CRC_ERR_MASK",
                                "value": "0"
                                "id": "SPMI_ERR_MASK",
                                "value": "0"
                                "id": "NPWRON_LONG_MASK",
                                "value": "0"
                                "id": "NINT_READBACK_MASK",
                                "value": "0"
                                "id": "NRSTOUT_READBACK_MASK",
                                "value": "0"
                            "id": "MASK_FSM_ERR",
                            "value": "0",
                            "fields": [
                                "id": "IMM_SHUTDOWN_MASK",
                                "value": "0"
                                "id": "MCU_PWR_ERR_MASK",
                                "value": "0"
                                "id": "SOC_PWR_ERR_MASK",
                                "value": "0"
                                "id": "ORD_SHUTDOWN_MASK",
                                "value": "0"
                            "id": "MASK_COMM_ERR",
                            "value": "0",
                            "fields": [
                                "id": "COMM_FRM_ERR_MASK",
                                "value": "0"
                                "id": "COMM_CRC_ERR_MASK",
                                "value": "0"
                                "id": "COMM_ADR_ERR_MASK",
                                "value": "0"
                                "id": "I2C2_CRC_ERR_MASK",
                                "value": "0"
                                "id": "I2C2_ADR_ERR_MASK",
                                "value": "0"
                            "id": "MASK_READBACK_ERR",
                            "value": "0",
                            "fields": [
                                "id": "EN_DRV_READBACK_MASK",
                                "value": "0"
                                "id": "NRSTOUT_SOC_READBACK_MASK",
                                "value": "0"
                            "id": "MASK_ESM",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_PIN_MASK",
                                "value": "0"
                                "id": "ESM_SOC_RST_MASK",
                                "value": "0"
                                "id": "ESM_SOC_FAIL_MASK",
                                "value": "0"
                                "id": "ESM_MCU_PIN_MASK",
                                "value": "0"
                                "id": "ESM_MCU_RST_MASK",
                                "value": "0"
                                "id": "ESM_MCU_FAIL_MASK",
                                "value": "0"
                            "id": "INT_TOP",
                            "value": "0",
                            "fields": [
                                "id": "MODERATE_ERR_INT",
                                "value": "0"
                                "id": "GPIO_INT",
                                "value": "0"
                                "id": "SEVERE_ERR_INT",
                                "value": "0"
                                "id": "BUCK_INT",
                                "value": "0"
                                "id": "LDO_VMON_INT",
                                "value": "0"
                                "id": "FSM_ERR_INT",
                                "value": "0"
                                "id": "STARTUP_INT",
                                "value": "0"
                                "id": "MISC_INT",
                                "value": "0"
                            "id": "INT_BUCK",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_2_INT",
                                "value": "0"
                                "id": "BUCK3_4_INT",
                                "value": "0"
                                "id": "BUCK5_INT",
                                "value": "0"
                            "id": "INT_BUCK1_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_OV_INT",
                                "value": "0"
                                "id": "BUCK1_UV_INT",
                                "value": "0"
                                "id": "BUCK1_ILIM_INT",
                                "value": "0"
                                "id": "BUCK1_SC_INT",
                                "value": "0"
                                "id": "BUCK2_OV_INT",
                                "value": "0"
                                "id": "BUCK2_UV_INT",
                                "value": "0"
                                "id": "BUCK2_SC_INT",
                                "value": "0"
                                "id": "BUCK2_ILIM_INT",
                                "value": "0"
                            "id": "INT_BUCK3_4",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_OV_INT",
                                "value": "0"
                                "id": "BUCK3_UV_INT",
                                "value": "0"
                                "id": "BUCK3_ILIM_INT",
                                "value": "0"
                                "id": "BUCK3_SC_INT",
                                "value": "0"
                                "id": "BUCK4_OV_INT",
                                "value": "0"
                                "id": "BUCK4_UV_INT",
                                "value": "0"
                                "id": "BUCK4_SC_INT",
                                "value": "0"
                                "id": "BUCK4_ILIM_INT",
                                "value": "0"
                            "id": "INT_BUCK5",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_OV_INT",
                                "value": "0"
                                "id": "BUCK5_UV_INT",
                                "value": "0"
                                "id": "BUCK5_ILIM_INT",
                                "value": "0"
                                "id": "BUCK5_SC_INT",
                                "value": "0"
                            "id": "INT_LDO_VMON",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_2_INT",
                                "value": "0"
                                "id": "LDO3_4_INT",
                                "value": "0"
                                "id": "VCCA_INT",
                                "value": "0"
                            "id": "INT_LDO1_2",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_OV_INT",
                                "value": "0"
                                "id": "LDO1_UV_INT",
                                "value": "0"
                                "id": "LDO1_SC_INT",
                                "value": "0"
                                "id": "LDO2_OV_INT",
                                "value": "0"
                                "id": "LDO2_UV_INT",
                                "value": "0"
                                "id": "LDO2_SC_INT",
                                "value": "0"
                                "id": "LDO2_ILIM_INT",
                                "value": "0"
                                "id": "LDO1_ILIM_INT",
                                "value": "0"
                            "id": "INT_LDO3_4",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_OV_INT",
                                "value": "0"
                                "id": "LDO3_UV_INT",
                                "value": "0"
                                "id": "LDO3_SC_INT",
                                "value": "0"
                                "id": "LDO4_OV_INT",
                                "value": "0"
                                "id": "LDO4_UV_INT",
                                "value": "0"
                                "id": "LDO4_SC_INT",
                                "value": "0"
                                "id": "LDO4_ILIM_INT",
                                "value": "0"
                                "id": "LDO3_ILIM_INT",
                                "value": "0"
                            "id": "INT_VMON",
                            "value": "0",
                            "fields": [
                                "id": "VCCA_OV_INT",
                                "value": "0"
                                "id": "VCCA_UV_INT",
                                "value": "0"
                            "id": "INT_GPIO",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_8_INT",
                                "value": "0"
                                "id": "GPIO9_INT",
                                "value": "0"
                                "id": "GPIO10_INT",
                                "value": "0"
                                "id": "GPIO11_INT",
                                "value": "0"
                            "id": "INT_GPIO1_8",
                            "value": "0",
                            "fields": [
                                "id": "GPIO1_INT",
                                "value": "0"
                                "id": "GPIO2_INT",
                                "value": "0"
                                "id": "GPIO3_INT",
                                "value": "0"
                                "id": "GPIO4_INT",
                                "value": "0"
                                "id": "GPIO5_INT",
                                "value": "0"
                                "id": "GPIO6_INT",
                                "value": "0"
                                "id": "GPIO7_INT",
                                "value": "0"
                                "id": "GPIO8_INT",
                                "value": "0"
                            "id": "INT_STARTUP",
                            "value": "0",
                            "fields": [
                                "id": "FSD_INT",
                                "value": "0"
                                "id": "NPWRON_START_INT",
                                "value": "0"
                                "id": "RTC_INT",
                                "value": "0"
                                "id": "ENABLE_INT",
                                "value": "0"
                                "id": "SOFT_REBOOT_INT",
                                "value": "0"
                            "id": "INT_MISC",
                            "value": "0",
                            "fields": [
                                "id": "EXT_CLK_INT",
                                "value": "0"
                                "id": "TWARN_INT",
                                "value": "0"
                                "id": "BIST_PASS_INT",
                                "value": "0"
                            "id": "INT_MODERATE_ERR",
                            "value": "0",
                            "fields": [
                                "id": "TSD_ORD_INT",
                                "value": "0"
                                "id": "BIST_FAIL_INT",
                                "value": "0"
                                "id": "SPMI_ERR_INT",
                                "value": "0"
                                "id": "REG_CRC_ERR_INT",
                                "value": "0"
                                "id": "NPWRON_LONG_INT",
                                "value": "0"
                                "id": "RECOV_CNT_INT",
                                "value": "0"
                                "id": "NINT_READBACK_INT",
                                "value": "0"
                                "id": "NRSTOUT_READBACK_INT",
                                "value": "0"
                            "id": "INT_SEVERE_ERR",
                            "value": "0",
                            "fields": [
                                "id": "TSD_IMM_INT",
                                "value": "0"
                                "id": "VCCA_OVP_INT",
                                "value": "0"
                                "id": "PFSM_ERR_INT",
                                "value": "0"
                            "id": "INT_FSM_ERR",
                            "value": "0",
                            "fields": [
                                "id": "IMM_SHUTDOWN_INT",
                                "value": "0"
                                "id": "MCU_PWR_ERR_INT",
                                "value": "0"
                                "id": "SOC_PWR_ERR_INT",
                                "value": "0"
                                "id": "ORD_SHUTDOWN_INT",
                                "value": "0"
                                "id": "COMM_ERR_INT",
                                "value": "0"
                                "id": "READBACK_ERR_INT",
                                "value": "0"
                                "id": "ESM_INT",
                                "value": "0"
                                "id": "WD_INT",
                                "value": "0"
                            "id": "INT_COMM_ERR",
                            "value": "0",
                            "fields": [
                                "id": "COMM_FRM_ERR_INT",
                                "value": "0"
                                "id": "COMM_CRC_ERR_INT",
                                "value": "0"
                                "id": "COMM_ADR_ERR_INT",
                                "value": "0"
                                "id": "I2C2_CRC_ERR_INT",
                                "value": "0"
                                "id": "I2C2_ADR_ERR_INT",
                                "value": "0"
                            "id": "INT_READBACK_ERR",
                            "value": "0",
                            "fields": [
                                "id": "NRSTOUT_SOC_READBACK_INT",
                                "value": "0"
                                "id": "EN_DRV_READBACK_INT",
                                "value": "0"
                            "id": "INT_ESM",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_RST_INT",
                                "value": "0"
                                "id": "ESM_MCU_FAIL_INT",
                                "value": "0"
                                "id": "ESM_MCU_PIN_INT",
                                "value": "0"
                                "id": "ESM_SOC_PIN_INT",
                                "value": "0"
                                "id": "ESM_SOC_RST_INT",
                                "value": "0"
                                "id": "ESM_SOC_FAIL_INT",
                                "value": "0"
                            "id": "STAT_BUCK1_2",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_OV_STAT",
                                "value": "0"
                                "id": "BUCK1_UV_STAT",
                                "value": "0"
                                "id": "BUCK1_ILIM_STAT",
                                "value": "0"
                                "id": "BUCK2_OV_STAT",
                                "value": "0"
                                "id": "BUCK2_UV_STAT",
                                "value": "0"
                                "id": "BUCK2_ILIM_STAT",
                                "value": "0"
                            "id": "STAT_BUCK3_4",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_OV_STAT",
                                "value": "0"
                                "id": "BUCK3_UV_STAT",
                                "value": "0"
                                "id": "BUCK3_ILIM_STAT",
                                "value": "0"
                                "id": "BUCK4_OV_STAT",
                                "value": "0"
                                "id": "BUCK4_UV_STAT",
                                "value": "0"
                                "id": "BUCK4_ILIM_STAT",
                                "value": "0"
                            "id": "STAT_BUCK5",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_OV_STAT",
                                "value": "0"
                                "id": "BUCK5_UV_STAT",
                                "value": "0"
                                "id": "BUCK5_ILIM_STAT",
                                "value": "0"
                            "id": "STAT_LDO1_2",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_OV_STAT",
                                "value": "0"
                                "id": "LDO1_UV_STAT",
                                "value": "0"
                                "id": "LDO2_OV_STAT",
                                "value": "0"
                                "id": "LDO2_UV_STAT",
                                "value": "0"
                                "id": "LDO1_ILIM_STAT",
                                "value": "0"
                                "id": "LDO2_ILIM_STAT",
                                "value": "0"
                            "id": "STAT_LDO3_4",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_OV_STAT",
                                "value": "0"
                                "id": "LDO3_UV_STAT",
                                "value": "0"
                                "id": "LDO4_OV_STAT",
                                "value": "0"
                                "id": "LDO4_UV_STAT",
                                "value": "0"
                                "id": "LDO3_ILIM_STAT",
                                "value": "0"
                                "id": "LDO4_ILIM_STAT",
                                "value": "0"
                            "id": "STAT_VMON",
                            "value": "0",
                            "fields": [
                                "id": "VCCA_OV_STAT",
                                "value": "0"
                                "id": "VCCA_UV_STAT",
                                "value": "0"
                            "id": "STAT_STARTUP",
                            "value": "0",
                            "fields": [
                                "id": "ENABLE_STAT",
                                "value": "0"
                            "id": "STAT_MISC",
                            "value": "0",
                            "fields": [
                                "id": "EXT_CLK_STAT",
                                "value": "0"
                                "id": "TWARN_STAT",
                                "value": "0"
                            "id": "STAT_MODERATE_ERR",
                            "value": "0",
                            "fields": [
                                "id": "TSD_ORD_STAT",
                                "value": "0"
                            "id": "STAT_SEVERE_ERR",
                            "value": "0",
                            "fields": [
                                "id": "TSD_IMM_STAT",
                                "value": "0"
                                "id": "VCCA_OVP_STAT",
                                "value": "0"
                            "id": "STAT_READBACK_ERR",
                            "value": "0",
                            "fields": [
                                "id": "NRSTOUT_SOC_READBACK_STAT",
                                "value": "0"
                                "id": "EN_DRV_READBACK_STAT",
                                "value": "0"
                                "id": "NINT_READBACK_STAT",
                                "value": "0"
                                "id": "NRSTOUT_READBACK_STAT",
                                "value": "0"
                            "id": "PGOOD_SEL_1",
                            "value": "0",
                            "fields": [
                                "id": "PGOOD_SEL_BUCK1",
                                "value": "0",
                                "id": "PGOOD_SEL_BUCK2",
                                "value": "0",
                                "id": "PGOOD_SEL_BUCK3",
                                "value": "0",
                                "id": "PGOOD_SEL_BUCK4",
                                "value": "0",
                            "id": "PGOOD_SEL_2",
                            "value": "0",
                            "fields": [
                                "id": "PGOOD_SEL_BUCK5",
                                "value": "0",
                            "id": "PGOOD_SEL_3",
                            "value": "0",
                            "fields": [
                                "id": "PGOOD_SEL_LDO1",
                                "value": "0",
                                "id": "PGOOD_SEL_LDO2",
                                "value": "0",
                                "id": "PGOOD_SEL_LDO3",
                                "value": "0",
                                "id": "PGOOD_SEL_LDO4",
                                "value": "0",
                            "id": "PGOOD_SEL_4",
                            "value": "0",
                            "fields": [
                                "id": "PGOOD_SEL_VCCA",
                                "value": "0",
                                "id": "PGOOD_SEL_TDIE_WARN",
                                "value": "0",
                                "id": "PGOOD_SEL_NRSTOUT",
                                "value": "0",
                                "id": "PGOOD_SEL_NRSTOUT_SOC",
                                "value": "0",
                                "id": "PGOOD_POL",
                                "value": "0",
                                "id": "PGOOD_WINDOW",
                                "value": "0",
                            "id": "PLL_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "EXT_CLK_FREQ",
                                "value": "0",
                                "staticConfig": true,
                                "isTouched": false
                            "id": "CONFIG_1",
                            "value": "0",
                            "fields": [
                                "id": "TWARN_LEVEL",
                                "value": "0",
                                "isTouched": false
                                "id": "I2C1_HS",
                                "value": "0",
                                "isTouched": false
                                "id": "I2C2_HS",
                                "value": "0",
                                "isTouched": false
                                "id": "EN_ILIM_FSM_CTRL",
                                "value": "0",
                                "isTouched": false
                                "id": "NSLEEP1_MASK",
                                "value": "0",
                                "isTouched": false
                                "id": "NSLEEP2_MASK",
                                "value": "0",
                                "isTouched": false
                                "id": "TSD_ORD_LEVEL",
                                "value": "0",
                                "isTouched": false
                            "id": "CONFIG_2",
                            "value": "0",
                            "fields": [
                                "id": "BB_CHARGER_EN",
                                "value": "0",
                                "isTouched": false
                                "id": "BB_VEOC",
                                "value": "0",
                                "isTouched": false
                                "id": "BB_ICHR",
                                "value": "0",
                                "isTouched": false
                                "id": "BB_EOC_RDY",
                                "value": "0",
                                "staticConfig": false
                            "id": "ENABLE_DRV_REG",
                            "value": "0",
                            "fields": [
                                "id": "ENABLE_DRV",
                                "value": "0"
                            "id": "MISC_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "NRSTOUT",
                                "value": "0"
                                "id": "NRSTOUT_SOC",
                                "value": "0"
                                "id": "LPM_EN",
                                "value": "0"
                                "id": "CLKMON_EN",
                                "value": "0"
                                "id": "AMUXOUT_EN",
                                "value": "0"
                                "id": "SEL_EXT_CLK",
                                "value": "0"
                                "id": "SYNCCLKOUT_FREQ_SEL",
                                "value": "0"
                            "id": "ENABLE_DRV_STAT",
                            "value": "0",
                            "fields": [
                                "id": "EN_DRV_IN",
                                "value": "0"
                                "id": "NRSTOUT_IN",
                                "value": "0"
                                "id": "NRSTOUT_SOC_IN",
                                "value": "0"
                                "id": "FORCE_EN_DRV_LOW",
                                "value": "0"
                                "id": "SPMI_LPM_EN",
                                "value": "0"
                            "id": "RECOV_CNT_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "RECOV_CNT",
                                "value": "0"
                            "id": "RECOV_CNT_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "RECOV_CNT_THR",
                                "value": "0"
                                "id": "RECOV_CNT_CLR",
                                "value": "0"
                            "id": "FSM_I2C_TRIGGERS",
                            "value": "0",
                            "fields": [
                                "id": "TRIGGER_I2C_1",
                                "value": "0"
                                "id": "TRIGGER_I2C_2",
                                "value": "0"
                                "id": "TRIGGER_I2C_3",
                                "value": "0"
                                "id": "TRIGGER_I2C_4",
                                "value": "0"
                                "id": "TRIGGER_I2C_5",
                                "value": "0"
                                "id": "TRIGGER_I2C_6",
                                "value": "0"
                                "id": "TRIGGER_I2C_7",
                                "value": "0"
                                "id": "TRIGGER_I2C_0",
                                "value": "0"
                            "id": "FSM_NSLEEP_TRIGGERS",
                            "value": "0",
                            "fields": [
                                "id": "NSLEEP1B",
                                "value": "0"
                                "id": "NSLEEP2B",
                                "value": "0"
                            "id": "BUCK_RESET_REG",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_RESET",
                                "value": 0
                                "id": "BUCK2_RESET",
                                "value": 0
                                "id": "BUCK3_RESET",
                                "value": 0
                                "id": "BUCK4_RESET",
                                "value": 0
                                "id": "BUCK5_RESET",
                                "value": 0
                            "id": "SPREAD_SPECTRUM_1",
                            "value": "0",
                            "fields": [
                                "id": "SS_EN",
                                "value": "0"
                                "id": "SS_DEPTH",
                                "value": "0"
                            "id": "FREQ_SEL",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_FREQ_SEL",
                                "value": 0
                                "id": "BUCK2_FREQ_SEL",
                                "value": 0
                                "id": "BUCK3_FREQ_SEL",
                                "value": 0
                                "id": "BUCK4_FREQ_SEL",
                                "value": 0
                                "id": "BUCK5_FREQ_SEL",
                                "value": 0
                            "id": "FSM_STEP_SIZE",
                            "value": "0",
                            "fields": [
                                "id": "PFSM_DELAY_STEP",
                                "value": 11,
                            "id": "LDO_RV_TIMEOUT_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_RV_TIMEOUT",
                                "value": "0"
                                "id": "LDO2_RV_TIMEOUT",
                                "value": "0"
                            "id": "LDO_RV_TIMEOUT_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "LDO3_RV_TIMEOUT",
                                "value": "0"
                                "id": "LDO4_RV_TIMEOUT",
                                "value": "0"
                            "id": "USER_SPARE_REGS",
                            "value": "0",
                            "fields": [
                                "id": "USER_SPARE_1",
                                "value": 0,
                                "id": "USER_SPARE_2",
                                "value": 0,
                                "id": "USER_SPARE_3",
                                "value": 0,
                                "id": "USER_SPARE_4",
                                "value": 0,
                            "id": "ESM_MCU_START_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_START",
                                "value": "0"
                            "id": "ESM_MCU_DELAY1_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_DELAY1",
                                "value": "0"
                            "id": "ESM_MCU_DELAY2_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_DELAY2",
                                "value": "0"
                            "id": "ESM_MCU_MODE_CFG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_ERR_CNT_TH",
                                "value": "0"
                                "id": "ESM_MCU_ENDRV",
                                "value": "0"
                                "id": "ESM_MCU_EN",
                                "value": 0
                                "id": "ESM_MCU_MODE",
                                "value": "0"
                            "id": "ESM_MCU_HMAX_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_HMAX",
                                "value": "0"
                            "id": "ESM_MCU_HMIN_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_HMIN",
                                "value": "0"
                            "id": "ESM_MCU_LMAX_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_LMAX",
                                "value": "0"
                            "id": "ESM_MCU_LMIN_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_LMIN",
                                "value": "0"
                            "id": "ESM_MCU_ERR_CNT_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_MCU_ERR_CNT",
                                "value": "0"
                            "id": "ESM_SOC_START_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_START",
                                "value": "0"
                            "id": "ESM_SOC_DELAY1_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_DELAY1",
                                "value": "0"
                            "id": "ESM_SOC_DELAY2_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_DELAY2",
                                "value": "0"
                            "id": "ESM_SOC_MODE_CFG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_ERR_CNT_TH",
                                "value": "0"
                                "id": "ESM_SOC_ENDRV",
                                "value": "0"
                                "id": "ESM_SOC_EN",
                                "value": 0
                                "id": "ESM_SOC_MODE",
                                "value": "0"
                            "id": "ESM_SOC_HMAX_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_HMAX",
                                "value": "0"
                            "id": "ESM_SOC_HMIN_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_HMIN",
                                "value": "0"
                            "id": "ESM_SOC_LMAX_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_LMAX",
                                "value": "0"
                            "id": "ESM_SOC_LMIN_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_LMIN",
                                "value": "0"
                            "id": "ESM_SOC_ERR_CNT_REG",
                            "value": "0",
                            "fields": [
                                "id": "ESM_SOC_ERR_CNT",
                                "value": "0"
                            "id": "REGISTER_LOCK",
                            "value": "0",
                            "fields": [
                                "id": "REGISTER_LOCK_STATUS",
                                "value": "0"
                            "id": "USER_EE_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "USER_EE_PROG_UNLOCK_SEQ",
                                "value": "0"
                            "id": "USER_EE_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "USER_PROG_ALLOWED",
                                "value": "0"
                                "id": "USER_PROG_UNLOCKED",
                                "value": "0"
                                "id": "EE_PROG_USER",
                                "value": "0"
                                "id": "EE_PROG_PFSM",
                                "value": "0"
                                "id": "EE_PROG_STATUS",
                                "value": "0"
                                "id": "EE_PROG_MODE",
                                "value": "0"
                            "id": "SRAM_ADDR_CTRL",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_SEL",
                                "value": "0"
                            "id": "RECOV_CNT_PFSM_INCR",
                            "value": "0",
                            "fields": [
                                "id": "INCREMENT_RECOV_CNT",
                                "value": "0"
                            "id": "MANUFACTURING_VER",
                            "value": "0",
                            "fields": [
                                "id": "SILICON_REV",
                                "value": "0"
                            "id": "CUSTOMER_NVM_ID_REG",
                            "value": "0",
                            "fields": [
                                "id": "CUSTOMER_NVM_ID",
                                "value": "0",
                            "id": "SOFT_REBOOT_REG",
                            "value": "0",
                            "fields": [
                                "id": "SOFT_REBOOT",
                                "value": "0"
                        "id": "UserRegisters2-user_mem",
                        "registers": [
                            "id": "RTC_SECONDS",
                            "value": "0",
                            "fields": [
                                "id": "SECOND_0",
                                "value": "0"
                                "id": "SECOND_1",
                                "value": "0"
                            "id": "RTC_MINUTES",
                            "value": "0",
                            "fields": [
                                "id": "MINUTE_0",
                                "value": "0"
                                "id": "MINUTE_1",
                                "value": "0"
                            "id": "RTC_HOURS",
                            "value": "0",
                            "fields": [
                                "id": "HOUR_0",
                                "value": "0"
                                "id": "HOUR_1",
                                "value": "0"
                                "id": "PM_NAM",
                                "value": "0"
                            "id": "RTC_DAYS",
                            "value": "0",
                            "fields": [
                                "id": "DAY_0",
                                "value": "0"
                                "id": "DAY_1",
                                "value": "0"
                            "id": "RTC_MONTHS",
                            "value": "0",
                            "fields": [
                                "id": "MONTH_0",
                                "value": "0"
                                "id": "MONTH_1",
                                "value": "0"
                            "id": "RTC_YEARS",
                            "value": "0",
                            "fields": [
                                "id": "YEAR_0",
                                "value": "0"
                                "id": "YEAR_1",
                                "value": "0"
                            "id": "RTC_WEEKS",
                            "value": "0",
                            "fields": [
                                "id": "WEEK",
                                "value": "0"
                            "id": "ALARM_SECONDS",
                            "value": "0",
                            "fields": [
                                "id": "ALR_SECOND_0",
                                "value": "0"
                                "id": "ALR_SECOND_1",
                                "value": "0"
                            "id": "ALARM_MINUTES",
                            "value": "0",
                            "fields": [
                                "id": "ALR_MINUTE_0",
                                "value": "0"
                                "id": "ALR_MINUTE_1",
                                "value": "0"
                            "id": "ALARM_HOURS",
                            "value": "0",
                            "fields": [
                                "id": "ALR_HOUR_0",
                                "value": "0"
                                "id": "ALR_HOUR_1",
                                "value": "0"
                                "id": "ALR_PM_NAM",
                                "value": "0"
                            "id": "ALARM_DAYS",
                            "value": "0",
                            "fields": [
                                "id": "ALR_DAY_0",
                                "value": "0"
                                "id": "ALR_DAY_1",
                                "value": "0"
                            "id": "ALARM_MONTHS",
                            "value": "0",
                            "fields": [
                                "id": "ALR_MONTH_0",
                                "value": "0"
                                "id": "ALR_MONTH_1",
                                "value": "0"
                            "id": "ALARM_YEARS",
                            "value": "0",
                            "fields": [
                                "id": "ALR_YEAR_0",
                                "value": "0"
                                "id": "ALR_YEAR_1",
                                "value": "0"
                            "id": "RTC_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "STOP_RTC",
                                "value": "0"
                                "id": "ROUND_30S",
                                "value": "0"
                                "id": "AUTO_COMP",
                                "value": "0"
                                "id": "MODE_12_24",
                                "value": "0"
                                "id": "SET_32_COUNTER",
                                "value": "0"
                                "id": "GET_TIME",
                                "value": "0"
                                "id": "RTC_V_OPT",
                                "value": "0"
                            "id": "RTC_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "XTAL_EN",
                                "value": "0",
                                "isTouched": false
                                "id": "LP_STANDBY_SEL",
                                "value": "0",
                                "isTouched": false
                                "id": "FAST_BIST",
                                "value": "0",
                                "id": "STARTUP_DEST",
                                "value": "3",
                                "isTouched": true
                                "id": "FIRST_STARTUP_DONE",
                                "value": "0",
                                "id": "XTAL_SEL",
                                "value": "0",
                                "isTouched": false
                            "id": "RTC_STATUS",
                            "value": "0",
                            "fields": [
                                "id": "RUN",
                                "value": "0"
                                "id": "TIMER",
                                "value": "0"
                                "id": "ALARM",
                                "value": "0"
                                "id": "POWER_UP",
                                "value": "0"
                            "id": "RTC_INTERRUPTS",
                            "value": "0",
                            "fields": [
                                "id": "EVERY",
                                "value": "0"
                                "id": "IT_TIMER",
                                "value": "0"
                                "id": "IT_ALARM",
                                "value": "0"
                            "id": "RTC_COMP_LSB",
                            "value": "0",
                            "fields": [
                                "id": "COMP_LSB_RTC",
                                "value": "0"
                            "id": "RTC_COMP_MSB",
                            "value": "0",
                            "fields": [
                                "id": "COMP_MSB_RTC",
                                "value": "0"
                            "id": "RTC_RESET_STATUS",
                            "value": "0",
                            "fields": [
                                "id": "RESET_STATUS_RTC",
                                "value": "0"
                            "id": "SCRATCH_PAD_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "SCRATCH_PAD_1",
                                "value": "0"
                            "id": "SCRATCH_PAD_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "SCRATCH_PAD_2",
                                "value": "0"
                            "id": "SCRATCH_PAD_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "SCRATCH_PAD_3",
                                "value": "0"
                            "id": "SCRATCH_PAD_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "SCRATCH_PAD_4",
                                "value": "0"
                            "id": "PFSM_DELAY_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "PFSM_DELAY1",
                                "value": "0",
                                "isTouched": false
                            "id": "PFSM_DELAY_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "PFSM_DELAY2",
                                "value": "0",
                                "isTouched": false
                            "id": "PFSM_DELAY_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "PFSM_DELAY3",
                                "value": "0",
                                "isTouched": false
                            "id": "PFSM_DELAY_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "PFSM_DELAY4",
                                "value": "0",
                                "isTouched": false
                            "id": "RTS_SPARE_REG",
                            "value": "0",
                            "fields": [
                                "id": "RTC_SPARE_0",
                                "value": "0",
                                "isTouched": false
                                "id": "RTC_SPARE_1",
                                "value": "0",
                                "isTouched": false
                                "id": "RTC_SPARE_2",
                                "value": "0",
                                "isTouched": false
                                "id": "RTC_SPARE_3",
                                "value": "0",
                                "isTouched": false
                        "id": "CRCRegisters-user_mem",
                        "registers": [
                            "id": "CRC_CALC_CONTROL",
                            "value": "0",
                            "fields": [
                                "id": "RUN_CRC_BIST",
                                "value": "0"
                                "id": "RUN_CRC_UPDATE",
                                "value": "0"
                            "id": "CRC_1",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_USER_INCLUDE_PERSIST_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_2",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_USER_INCLUDE_PERSIST_CRC16_HIGH",
                                "value": "0"
                            "id": "CRC_3",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_USER_EXCLUDE_PERSIST_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_4",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_USER_EXCLUDE_PERSIST_CRC16_HIGH",
                                "value": "0"
                            "id": "CRC_5",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_CONFIG_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_6",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_CONFIG_CRC16_HIGH",
                                "value": "0"
                            "id": "CRC_7",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_BANK0_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_8",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_BANK0_CRC16_HIGH",
                                "value": "0"
                            "id": "CRC_9",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_BANK1_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_10",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_BANK1_CRC16_HIGH",
                                "value": "0"
                            "id": "CRC_11",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_BANK2_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_12",
                            "value": "0",
                            "fields": [
                                "id": "SRAM_BANK2_CRC16_HIGH",
                                "value": "0"
                            "id": "CRC_15",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_TRIM_CRC16_LOW",
                                "value": "0"
                            "id": "CRC_16",
                            "value": "0",
                            "fields": [
                                "id": "REGMAP_TRIM_CRC16_HIGH",
                                "value": "0"
                        "id": "ConfigRegisters-user_mem",
                        "registers": [
                            "id": "BUCK_CONFIG_ANALOG_0",
                            "value": "0",
                            "fields": [
                                "id": "SEL_LOOP_NEG_HYST",
                                "value": 2
                                "id": "SEL_GATE_EARLY_SENSE",
                                "value": 0
                                "id": "SEL_TRAD_NON_OVERLAP",
                                "value": 0
                            "id": "BUCK_CONFIG_ANALOG_1",
                            "value": "0",
                            "fields": [
                                "id": "SEL_FB_FILTER",
                                "value": 3
                                "id": "BUCK1_SEL_NEG_OCP_HYST",
                                "value": 1
                                "id": "BUCK2_SEL_NEG_OCP_HYST",
                                "value": 1
                                "id": "BUCK3_SEL_NEG_OCP_HYST",
                                "value": 1
                                "id": "BUCK4_SEL_NEG_OCP_HYST",
                                "value": 1
                                "id": "BUCK5_SEL_NEG_OCP_HYST",
                                "value": 1
                            "id": "BUCK_CONFIG_ANALOG_2",
                            "value": "0",
                            "fields": [
                                "id": "SEL_RAMP_ARTIF",
                                "value": 1
                            "id": "BUCK_CONFIG_ANALOG_3",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION",
                                "value": 2
                                "id": "BUCK1_SEL_VOUT_ADC_LEVEL",
                                "value": 0
                            "id": "BUCK_CONFIG_ANALOG_4",
                            "value": "0",
                            "fields": [
                                "id": "BUCK2_SEL_ISENSE_SLOPE_COMPENSATION",
                                "value": 2
                                "id": "BUCK2_SEL_VOUT_ADC_LEVEL",
                                "value": 0
                            "id": "BUCK_CONFIG_ANALOG_5",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION",
                                "value": 2
                                "id": "BUCK3_SEL_VOUT_ADC_LEVEL",
                                "value": 0
                            "id": "BUCK_CONFIG_ANALOG_6",
                            "value": "0",
                            "fields": [
                                "id": "BUCK4_SEL_ISENSE_SLOPE_COMPENSATION",
                                "value": 2
                                "id": "BUCK4_SEL_VOUT_ADC_LEVEL",
                                "value": 0
                            "id": "BUCK_CONFIG_ANALOG_7",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_SEL_ISENSE_SLOPE_COMPENSATION",
                                "value": 2
                                "id": "BUCK5_SEL_VOUT_ADC_LEVEL",
                                "value": 0
                            "id": "BUCK_CONFIG_ANALOG_8",
                            "value": "0",
                            "fields": [
                                "id": "EN_SW_RT_SHORT_DETECTORS",
                                "value": 0
                                "id": "EN_IAVE_LOOP_INJECTOR",
                                "value": 0
                            "id": "BUCK_CONFIG_RADAR",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_EN_RADAR_MODE",
                                "value": 0
                                "id": "BUCK2_EN_RADAR_MODE",
                                "value": 0
                                "id": "BUCK3_EN_RADAR_MODE",
                                "value": 0
                                "id": "BUCK4_EN_RADAR_MODE",
                                "value": 0
                                "id": "BUCK5_EN_RADAR_MODE",
                                "value": 0
                            "id": "BUCK_CONFIG_DIGITAL_0",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_SEL_PHASE_SHEDD",
                                "value": 0
                                "id": "BUCK1_SEL_PHASE_ADD",
                                "value": 1
                                "id": "BUCK3_SEL_PHASE_SHEDD",
                                "value": 0
                                "id": "BUCK3_SEL_PHASE_ADD",
                                "value": 1
                                "id": "EN_LOAD_COMP_BLANK",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_1",
                            "value": "0",
                            "fields": [
                                "id": "EN_PLL_PROP_EXTEND",
                                "value": 1
                                "id": "EN_SMART_OCP_BLANK",
                                "value": 1
                                "id": "BUCK1_SEL_POS_OCP_HYST",
                                "value": 1
                                "id": "BUCK2_SEL_POS_OCP_HYST",
                                "value": 1
                                "id": "BUCK3_SEL_POS_OCP_HYST",
                                "value": 1
                                "id": "BUCK4_SEL_POS_OCP_HYST",
                                "value": 1
                                "id": "BUCK5_SEL_POS_OCP_HYST",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_2",
                            "value": "0",
                            "fields": [
                                "id": "SEL_HS_DETECTOR",
                                "value": 1
                                "id": "EN_LONG_PFM_EXIT_CNTR",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_3",
                            "value": "0",
                            "fields": [
                                "id": "EN_NEG_OCP",
                                "value": 1
                                "id": "EN_POS_OCP",
                                "value": 1
                                "id": "EN_PFM_LOAD",
                                "value": 1
                                "id": "EN_DOT_MODE",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_4",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_SEL_OUTPUT_CAPS",
                                "value": 1
                                "id": "BUCK2_SEL_OUTPUT_CAPS",
                                "value": 1
                                "id": "BUCK3_SEL_OUTPUT_CAPS",
                                "value": 1
                                "id": "BUCK4_SEL_OUTPUT_CAPS",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_5",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_SEL_OUTPUT_CAPS",
                                "value": 1
                                "id": "LOOP_COEFF_I_BALANCE",
                                "value": 1
                                "id": "SEL_ZERO_CROSS_FILTER_AVE",
                                "value": 1
                                "id": "EN_AUTO_LOOP_COEFFS",
                                "value": 1
                                "id": "LOOP_COEFF_FB_MSB",
                                "value": 1
                                "id": "EN_LONG_ZERO_CROSS_FILTER",
                                "value": 0
                            "id": "BUCK_CONFIG_DIGITAL_6",
                            "value": "0",
                            "fields": [
                                "id": "FORCE_SS_ADAPT",
                                "value": 0
                                "id": "BUCK1_SEL_RAMP",
                                "value": 1
                                "id": "BUCK2_SEL_RAMP",
                                "value": 1
                                "id": "EN_PFM_PULSE_WAIT_LS_OCP",
                                "value": 1
                                "id": "EN_SLOW_PLL_COEFFS",
                                "value": 0
                            "id": "BUCK_CONFIG_DIGITAL_7",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_SEL_RAMP",
                                "value": 1
                                "id": "BUCK4_SEL_RAMP",
                                "value": 1
                                "id": "BUCK5_SEL_RAMP",
                                "value": 1
                                "id": "EN_SW_SHORT_DETECTORS",
                                "value": 1
                                "id": "EN_FAST_PLL_0P7",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_8",
                            "value": "0",
                            "fields": [
                                "id": "EN_FAST_VOUT_INTEGRATION",
                                "value": 1
                                "id": "EN_I_BALANCE_INTEGRATOR",
                                "value": 1
                                "id": "DIS_PFM_WAITS_LS_DETECTOR",
                                "value": 0
                                "id": "DIS_PFM_WAITS_HS_DETECTOR",
                                "value": 0
                                "id": "DIS_DVS_WAIT_COMPARATORS",
                                "value": 0
                                "id": "EN_CONSTANT_PLL_DVS_COEFF",
                                "value": 0
                                "id": "EN_SLOW_PLL_0P3",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_9",
                            "value": "0",
                            "fields": [
                                "id": "EN_M_10M_TRAN_DETECTOR",
                                "value": 1
                                "id": "EN_FAST_INTEGRATION_BYPASS_RAMP_RES",
                                "value": 1
                                "id": "EN_LS_AFTER_HIZ",
                                "value": 0
                                "id": "EN_PWM_LS_DETECTION",
                                "value": 0
                                "id": "I_COEFF",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_10",
                            "value": "0",
                            "fields": [
                                "id": "BUCK_NEG_ILIM",
                                "value": 1
                                "id": "EN_ADAPTIVE_SINGLE_SHOT",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_11",
                            "value": "0",
                            "fields": [
                                "id": "FIXED_SS_LENGTH",
                                "value": 24
                                "id": "LONG_SINGLE_SHOT",
                                "value": 1
                            "id": "BUCK_CONFIG_DIGITAL_12",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_FREQ_8MHZ",
                                "value": 0
                                "id": "BUCK2_FREQ_8MHZ",
                                "value": 0
                                "id": "BUCK3_FREQ_8MHZ",
                                "value": 0
                                "id": "BUCK4_FREQ_8MHZ",
                                "value": 0
                                "id": "BUCK5_FREQ_8MHZ",
                                "value": 0
                            "id": "GENERAL_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "EN_OVP",
                                "value": 1,
                                "id": "DIS_UVLO_OVP_RESET",
                                "value": 0,
                                "id": "DIS_TSD",
                                "value": 0,
                                "id": "FAST_BOOT_BIST",
                                "value": "0",
                                "id": "VSYS_DEAD_LOCK_EN",
                                "value": "0",
                                "id": "PFSM_ERR_RESET_DIS",
                                "value": 0,
                                "id": "VMON_ABIST_EN",
                                "value": "0",
                                "id": "ABIST_ERROR_MASK",
                                "value": 0,
                            "id": "GENERAL_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "MAX_ILIM",
                                "value": 5,
                                "id": "FREQ_SEL_UNLOCK",
                                "value": 0,
                                "id": "REG_CRC_EN",
                                "value": "0",
                                "isTouched": false
                                "id": "EN_INITIALIZE_DPLL_RESTART",
                                "value": 0,
                                "id": "PFSM_ERR_MASK",
                                "value": 0,
                                "id": "FAST_VCCA_OVP",
                                "value": "0",
                                "isTouched": false
                            "id": "GENERAL_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "DIS_NRSTOUT_MCU_I2C_SPI_RESET",
                                "value": 0,
                                "id": "SLOW_AUTOZERO_SEL",
                                "value": 0,
                                "id": "EN_FIXED_DPLL_FREQ",
                                "value": 0,
                                "id": "SEL_RC_OSC",
                                "value": 0,
                                "id": "DISABLE_VM_NARROW_LIMITS",
                                "value": 0,
                                "id": "DISABLE_CHANGE_BG",
                                "value": 0,
                                "id": "DISABLE_USE_TRIMS",
                                "value": 0,
                                "id": "WD_EN_EE",
                                "value": 1,
                            "id": "SERIAL_IF_CONFIG",
                            "value": "0",
                            "fields": [
                                "id": "I2C_SPI_SEL",
                                "value": "0"
                                "id": "I2C1_SPI_CRC_EN",
                                "value": "0"
                                "id": "I2C2_CRC_EN",
                                "value": "0"
                            "id": "SPMI_CONFIG_1",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_CRC_EN",
                                "value": 1
                                "id": "SPMI_MASTER_SEL",
                                "value": 1
                                "id": "SPMI_CLK_SEL",
                                "value": 2
                                "id": "SPMI_SLAVE_PASSIVE",
                                "value": 0
                            "id": "SPMI_CONFIG_2",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_IF_SEL",
                                "value": 0
                                "id": "SPMI_RETRY_LIMIT",
                                "value": 3
                                "id": "SPMI_SLAVE_ASR_HOLD",
                                "value": 0
                                "id": "SPMI_WD_AUTO_BOOT",
                                "value": 1
                                "id": "SPMI_EN",
                                "value": 0
                                "id": "SPMI_WD_EN",
                                "value": 0
                                "id": "SPMI_WAKEUP_EN",
                                "value": 0
                            "id": "SPMI_CONFIG_3",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_WD_BOOT_INTERVAL",
                                "value": 8
                                "id": "SPMI_WD_RUNTIME_INTERVAL",
                                "value": 8
                            "id": "SPMI_CONFIG_4",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_WD_RESPONSE_TIMEOUT",
                                "value": 8
                                "id": "SPMI_PFSM_RESPONSE_TIMEOUT",
                                "value": 8
                            "id": "SPMI_CONFIG_5",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_WD_BOOT_BIST_TIMEOUT",
                                "value": 8
                                "id": "SPMI_WD_RUNTIME_BIST_TIMEOUT",
                                "value": 8
                            "id": "SPMI_CONFIG_6",
                            "value": "0",
                            "fields": [
                                "id": "BOOT_DELAY",
                                "value": 0
                            "id": "SPMI_ID",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_SID",
                                "value": 5
                                "id": "SPMI_MID",
                                "value": 0
                            "id": "I2C1_ID_REG",
                            "value": 72,
                            "fields": [
                                "id": "I2C1_ID",
                                "value": "72"
                            "id": "I2C2_ID_REG",
                            "value": 18,
                            "fields": [
                                "id": "I2C2_ID",
                                "value": "18"
                            "id": "CLOCK_REQS",
                            "value": "0",
                            "fields": [
                                "id": "FORCE_CLK_GATE",
                                "value": 0
                                "id": "INT_LDO_PD_FORCE",
                                "value": 0
                                "id": "LDO1_PD_FORCE",
                                "value": 0
                                "id": "LDO2_PD_FORCE",
                                "value": 0
                                "id": "LDO3_PD_FORCE",
                                "value": 0
                                "id": "LDO4_PD_FORCE",
                                "value": 0
                            "id": "PHASE_CONFIG",
                            "value": "0",
                            "fields": [
                                "id": "MP_CONFIG",
                                "value": "0"
                            "id": "SPMI_SLAVE_COUNT",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_SLAVE_CNT",
                                "value": 1
                            "id": "PFSM_CONFIG",
                            "value": "0",
                            "fields": [
                                "id": "PFSM_SEQ_MIN_TIME",
                                "value": 1,
                                "id": "SRAM_RELOAD_LIMIT",
                                "value": 2,
                                "id": "PFSM_PROXY_BRANCH_DIS",
                                "value": 0,
                            "id": "GENERAL_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "LPM_EN_DISABLES_VCCA_VMON",
                                "value": 1,
                            "id": "XCOORD_REG",
                            "value": "0",
                            "fields": [
                                "id": "XCOORD",
                                "value": "0"
                            "id": "YCOORD_REG",
                            "value": "0",
                            "fields": [
                                "id": "YCOORD",
                                "value": "0"
                            "id": "WAFERNUM_REG",
                            "value": "0",
                            "fields": [
                                "id": "WAFERNUM",
                                "value": "0"
                            "id": "WAFERLOTNUM_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "WAFERLOTNUM_23_16",
                                "value": "0"
                            "id": "WAFERLOTNUM_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "WAFERLOTNUM_15_8",
                                "value": "0"
                            "id": "WAFERLOTNUM_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "WAFERLOTNUM_7_0",
                                "value": "0"
                            "id": "WAFERFAB_REG",
                            "value": "0",
                            "fields": [
                                "id": "WAFERFAB",
                                "value": "0"
                            "id": "BUCK_CONFIG_DIGITAL_13",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_EN_P_10M_BODY_DIODE",
                                "value": 0
                                "id": "BUCK2_EN_P_10M_BODY_DIODE",
                                "value": 0
                                "id": "BUCK3_EN_P_10M_BODY_DIODE",
                                "value": 0
                                "id": "BUCK4_EN_P_10M_BODY_DIODE",
                                "value": 0
                                "id": "BUCK5_EN_P_10M_BODY_DIODE",
                                "value": 0
                            "id": "BUCK_CONFIG_DIGITAL_14",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_DOUBLE_PFM_PULSE",
                                "value": 0
                                "id": "BUCK2_DOUBLE_PFM_PULSE",
                                "value": 0
                                "id": "BUCK3_DOUBLE_PFM_PULSE",
                                "value": 0
                                "id": "BUCK4_DOUBLE_PFM_PULSE",
                                "value": 0
                                "id": "BUCK5_DOUBLE_PFM_PULSE",
                                "value": 0
                            "id": "BUCK_CONFIG_DIGITAL_15",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_CHANGE_2MHZ_BELOW_0V5",
                                "value": 1
                                "id": "BUCK2_CHANGE_2MHZ_BELOW_0V5",
                                "value": 1
                                "id": "BUCK3_CHANGE_2MHZ_BELOW_0V5",
                                "value": 1
                                "id": "BUCK4_CHANGE_2MHZ_BELOW_0V5",
                                "value": 1
                                "id": "BUCK5_CHANGE_2MHZ_BELOW_0V5",
                                "value": 1
                            "id": "SPREAD_SPECTRUM_CONFIG_1",
                            "value": "0",
                            "fields": [
                                "id": "SS_MODE",
                                "value": 1
                            "id": "SPREAD_SPECTRUM_CONFIG_2",
                            "value": "0",
                            "fields": [
                                "id": "SS_PARAM1",
                                "value": 7
                                "id": "SS_PARAM2",
                                "value": 12
                            "id": "USER_EE_PROG_UNLOCK",
                            "value": "0",
                            "fields": [
                                "id": "USER_EE_PROG_UNLOCK_CODE",
                                "value": "0"
                            "id": "INT_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "refsys_bg_buf_hi_bw",
                                "value": 0,
                                "id": "refsys_sel_ibias",
                                "value": 0,
                            "id": "SAFETY_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "safety_speedup",
                                "value": 0,
                                "id": "safety_sel_ibias",
                                "value": 0,
                                "id": "safety_bg_buf_hi_bw",
                                "value": 0,
                            "id": "VM_VSYS_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "vm_vsys_dummy_bit",
                                "value": "0"
                            "id": "RTC_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "xtal_amp_reg_en",
                                "value": 1,
                                "id": "xtal_amp_reg_mode",
                                "value": 1,
                                "id": "xtal_comp_bias_lvl",
                                "value": 0,
                                "id": "xtal_bias_fine",
                                "value": 10,
                            "id": "LDO1_3_FILT_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "vbg_filt_config",
                                "value": 0
                            "id": "LDO1_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo1_en_short_cp",
                                "value": 0
                                "id": "ldo1_dis_short_prot",
                                "value": 0
                                "id": "ldo1_dis_ilim",
                                "value": 0
                                "id": "ldo1_dis_cp_leak_comp",
                                "value": 0
                                "id": "ldo1_en_cp_low_sr",
                                "value": 0
                                "id": "ldo1_dis_ov_pldn",
                                "value": 0
                            "id": "LDO2_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo2_en_short_cp",
                                "value": 0
                                "id": "ldo2_dis_short_prot",
                                "value": 0
                                "id": "ldo2_dis_ilim",
                                "value": 0
                                "id": "ldo2_dis_cp_leak_comp",
                                "value": 0
                                "id": "ldo2_en_cp_low_sr",
                                "value": 0
                                "id": "ldo2_dis_ov_pldn",
                                "value": 0
                            "id": "LDO3_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo3_en_short_cp",
                                "value": 0
                                "id": "ldo3_dis_short_prot",
                                "value": 0
                                "id": "ldo3_dis_ilim",
                                "value": 0
                                "id": "ldo3_dis_cp_leak_comp",
                                "value": 0
                                "id": "ldo3_en_cp_low_sr",
                                "value": 0
                                "id": "ldo3_dis_ov_pldn",
                                "value": 0
                            "id": "LDO4_CONFIG_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo4_sel_low_ilim",
                                "value": 0
                                "id": "ldo4_filter_current",
                                "value": 3
                        "id": "TestRegisters-tm_mem",
                        "registers": [
                            "id": "TEST_MODE_LOCK",
                            "value": "0",
                            "fields": [
                                "id": "TM_UNLOCK_CODE",
                                "value": "0"
                            "id": "TEST_MODE_STATUS",
                            "value": "0",
                            "fields": [
                                "id": "debug_mode",
                                "value": "0"
                                "id": "test_mode",
                                "value": "0"
                            "id": "TEST_SET_SCAN_MODE",
                            "value": "0",
                            "fields": [
                                "id": "SET_SCAN_MODE",
                                "value": "0"
                                "id": "SET_SCAN_OVST_MODE",
                                "value": "0"
                            "id": "DMUX1_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX1_MAIN_SEL",
                                "value": "0"
                                "id": "TM_DMUX1_INV",
                                "value": "0"
                                "id": "TM_DMUX1_MODE",
                                "value": "0"
                            "id": "DMUX1_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX1_SUB_SEL",
                                "value": "0"
                                "id": "TM_DMUX1_DIV",
                                "value": "0"
                            "id": "DMUX2_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX2_MAIN_SEL",
                                "value": "0"
                                "id": "TM_DMUX2_INV",
                                "value": "0"
                                "id": "TM_DMUX2_MODE",
                                "value": "0"
                            "id": "DMUX2_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX2_SUB_SEL",
                                "value": "0"
                                "id": "TM_DMUX2_DIV",
                                "value": "0"
                            "id": "DMUX3_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX3_MAIN_SEL",
                                "value": "0"
                                "id": "TM_DMUX3_INV",
                                "value": "0"
                                "id": "TM_DMUX3_MODE",
                                "value": "0"
                            "id": "DMUX3_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX3_SUB_SEL",
                                "value": "0"
                                "id": "TM_DMUX3_DIV",
                                "value": "0"
                            "id": "DMUX4_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX4_MAIN_SEL",
                                "value": "0"
                                "id": "TM_DMUX4_INV",
                                "value": "0"
                                "id": "TM_DMUX4_MODE",
                                "value": "0"
                            "id": "DMUX4_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX4_SUB_SEL",
                                "value": "0"
                                "id": "TM_DMUX4_DIV",
                                "value": "0"
                            "id": "DMUX5_CTRL_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX5_MAIN_SEL",
                                "value": "0"
                                "id": "TM_DMUX5_INV",
                                "value": "0"
                                "id": "TM_DMUX5_MODE",
                                "value": "0"
                            "id": "DMUX5_CTRL_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_DMUX5_SUB_SEL",
                                "value": "0"
                                "id": "TM_DMUX5_DIV",
                                "value": "0"
                            "id": "TEST_REG_8",
                            "value": "0",
                            "fields": [
                                "id": "NINT_TX_DIS",
                                "value": "0"
                                "id": "USE_TRIMS",
                                "value": "0"
                                "id": "VM_NARROW_LIMITS",
                                "value": "0"
                                "id": "NINT_TX",
                                "value": "0"
                                "id": "CHANGE_BG",
                                "value": "0"
                                "id": "START_ABIST",
                                "value": "0"
                            "id": "TEST_REG_9",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_MODE",
                                "value": "0"
                            "id": "TEST_REG_10",
                            "value": "0",
                            "fields": [
                                "id": "BUCK2_MODE",
                                "value": "0"
                            "id": "TEST_REG_11",
                            "value": "0",
                            "fields": [
                                "id": "BUCK3_MODE",
                                "value": "0"
                            "id": "TEST_REG_12",
                            "value": "0",
                            "fields": [
                                "id": "BUCK4_MODE",
                                "value": "0"
                            "id": "TEST_REG_13",
                            "value": "0",
                            "fields": [
                                "id": "BUCK5_MODE",
                                "value": "0"
                            "id": "TEST_REG_14",
                            "value": "0",
                            "fields": [
                                "id": "BUCK1_VSET_MSB",
                                "value": "0"
                                "id": "TEST_SINGLE_SHOT",
                                "value": "0"
                                "id": "BUCK2_VSET_MSB",
                                "value": "0"
                                "id": "BUCK3_VSET_MSB",
                                "value": "0"
                                "id": "BUCK4_VSET_MSB",
                                "value": "0"
                                "id": "BUCK5_VSET_MSB",
                                "value": "0"
                            "id": "TEST_REG_15",
                            "value": "0",
                            "fields": [
                                "id": "LDO_EE_EN",
                                "value": "0"
                                "id": "LDO_EE_PLDN",
                                "value": "0"
                                "id": "BG_XMON_EN",
                                "value": "0"
                                "id": "SAFETY_EN_REFS",
                                "value": "0"
                                "id": "TEST_WLBI_MODE",
                                "value": "0"
                                "id": "TEST_RTC_LDO_UVLO_DIS",
                                "value": "0"
                            "id": "TEST_REG_16",
                            "value": "0",
                            "fields": [
                                "id": "TSD_FORCE",
                                "value": "0"
                                "id": "TSD_SEL_THRESHOLD",
                                "value": "0"
                                "id": "TSD_SEL_SENSOR",
                                "value": "0"
                            "id": "TEST_SPMI_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_SPMI_TX_PAYLOAD",
                                "value": "0"
                            "id": "TEST_SPMI_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_SPMI_TX_ADDRESS",
                                "value": "0"
                            "id": "TEST_SPMI_5",
                            "value": "0",
                            "fields": [
                                "id": "TM_SPMI_TEST_MODE",
                                "value": "0"
                                "id": "TM_SPMI_TX_REQ",
                                "value": "0"
                                "id": "TM_SPMI_TX_REQ_HIGH",
                                "value": "0"
                                "id": "TM_SPMI_TX_SLAVE_SEL",
                                "value": "0"
                                "id": "SPMI_TX_DONE",
                                "value": "0"
                                "id": "SPMI_RX_DONE",
                                "value": "0"
                            "id": "TEST_SPMI_6",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_RX_CMD",
                                "value": "0"
                            "id": "TEST_SPMI_7",
                            "value": "0",
                            "fields": [
                                "id": "SPMI_RX_PAYLOAD",
                                "value": "0"
                            "id": "TEST_PFSM_0",
                            "value": "0",
                            "fields": [
                                "id": "pfsm_debug_trigger_id",
                                "value": "0"
                                "id": "pfsm_branch_self",
                                "value": "0"
                                "id": "op_ready",
                                "value": "0"
                                "id": "op_end",
                                "value": "0"
                            "id": "TEST_PFSM_1",
                            "value": "0",
                            "fields": [
                                "id": "FREEZE_PFSM",
                                "value": "0"
                                "id": "TM_PFSM_SINGLE_STEP_EN",
                                "value": "0"
                                "id": "TM_PFSM_SINGLE_STEP_PULSE",
                                "value": "0"
                                "id": "TM_PFSM_BREAKPOINT_EN",
                                "value": "0"
                                "id": "op_debug_halt",
                                "value": "0"
                                "id": "op_breakpoint_match",
                                "value": "0"
                            "id": "TEST_PFSM_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_PFSM_BREAKPOINT_ADDRESS_12_8",
                                "value": "0"
                            "id": "TEST_PFSM_3",
                            "value": "0",
                            "fields": [
                                "id": "TM_PFSM_BREAKPOINT_ADDRESS_7_0",
                                "value": "0"
                            "id": "TEST_FFSM_1",
                            "value": "0",
                            "fields": [
                                "id": "fixed_fsm_state",
                                "value": "0"
                            "id": "TEST_FFSM_2",
                            "value": "0",
                            "fields": [
                                "id": "next_fixed_fsm_state",
                                "value": "0"
                                "id": "force_fixed_fsm_state",
                                "value": "0"
                            "id": "TEST_REG_29",
                            "value": "0",
                            "fields": [
                                "id": "LDO1_PD_DISABLE",
                                "value": "0"
                                "id": "LDO2_PD_DISABLE",
                                "value": "0"
                                "id": "LDO3_PD_DISABLE",
                                "value": "0"
                                "id": "LDO4_PD_DISABLE",
                                "value": "0"
                                "id": "LDO_INT_PLDN",
                                "value": "0"
                                "id": "TM_LDOINT_DIS",
                                "value": "0"
                                "id": "FORCE_AUTOZERO_LOW",
                                "value": "0"
                                "id": "FORCE_AUTOZERO_HIGH",
                                "value": "0"
                            "id": "TEST_REG_30",
                            "value": "0",
                            "fields": [
                                "id": "OSC_128KHZ_EN",
                                "value": "0"
                                "id": "DPLL_EN",
                                "value": "0"
                                "id": "OSC_52M8HZ_EN",
                                "value": "0"
                                "id": "OSC_20MHZ_EN",
                                "value": "0"
                                "id": "OSC_MONITOR_20MHZ_EN",
                                "value": "0"
                            "id": "TEST_SRAM_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_SRAM_MARGIN0",
                                "value": "0"
                                "id": "TM_SRAM_MARGIN1",
                                "value": "0"
                            "id": "TEST_RTC_CAL_0",
                            "value": "0",
                            "fields": [
                                "id": "RTC_TEST_MODE1",
                                "value": "0"
                                "id": "RTC_TEST_MODE2",
                                "value": "0"
                            "id": "TEST_PADRING_0",
                            "value": "0",
                            "fields": [
                                "id": "test_en_nint_cp_osc",
                                "value": "0"
                                "id": "test_en_atab_loop_cp",
                                "value": "0"
                                "id": "test_en_atab_loop_cp_current",
                                "value": "0"
                                "id": "test_en_drv_tx_dis",
                                "value": "0"
                            "id": "TEST_PADRING_1",
                            "value": "0",
                            "fields": [
                                "id": "test_en_atab_1v8",
                                "value": "0"
                            "id": "TEST_PADRING_3",
                            "value": "0",
                            "fields": [
                                "id": "test_en_atab_5v",
                                "value": "0"
                            "id": "TEST_PADRING_4",
                            "value": "0",
                            "fields": [
                                "id": "test_en_kelvin_12_8",
                                "value": "0"
                            "id": "TEST_PADRING_5",
                            "value": "0",
                            "fields": [
                                "id": "test_en_kelvin_7_0",
                                "value": "0"
                            "id": "TEST_PADRING_6",
                            "value": "0",
                            "fields": [
                                "id": "test_en_atab_loop_rc",
                                "value": "0"
                            "id": "TEST_PADRING_7",
                            "value": "0",
                            "fields": [
                                "id": "TEST_PADRING_SPARE",
                                "value": "0"
                                "id": "test_dis_nint_cp_pd",
                                "value": "0"
                            "id": "TEST_VMVCCA_0",
                            "value": "0",
                            "fields": [
                                "id": "test_vmvcca_bg",
                                "value": "0"
                                "id": "test_vmvcca_vref_1v2",
                                "value": "0"
                                "id": "test_vmvcca_iptat",
                                "value": "0"
                            "id": "TEST_VMPVIN_0",
                            "value": "0",
                            "fields": [
                                "id": "test_vmpvin_bg",
                                "value": "0"
                                "id": "test_vmpvin_vref_1v2",
                                "value": "0"
                                "id": "test_vmpvin_iptat",
                                "value": "0"
                            "id": "TEST_INT_0",
                            "value": "0",
                            "fields": [
                                "id": "test_refsys_ibias",
                                "value": "0"
                                "id": "test_refsys_bg",
                                "value": "0"
                                "id": "test_refsys_ldo_int_en_vout_kelvin",
                                "value": "0"
                                "id": "test_refsys_ldo_int_en_ovst",
                                "value": "0"
                                "id": "test_refsys_ldo_int_pupd_hiz",
                                "value": "0"
                                "id": "test_refsys_ldo_int_en_ilim",
                                "value": "0"
                                "id": "test_refsys_ldo_int_en_ilim2",
                                "value": "0"
                                "id": "test_refsys_iptat",
                                "value": "0"
                            "id": "TEST_INT_1",
                            "value": "0",
                            "fields": [
                                "id": "test_refsys_bg_buffer",
                                "value": "0"
                                "id": "test_refsys_bg_buffer_en_hiz",
                                "value": "0"
                                "id": "test_refsys_amux_buffer_en_hiz",
                                "value": "0"
                                "id": "test_refsys_ldo_int_out_stage_dis",
                                "value": "0"
                            "id": "TEST_SAFETY_0",
                            "value": "0",
                            "fields": [
                                "id": "test_tsd",
                                "value": "0"
                                "id": "test_vmon_buck",
                                "value": "0"
                            "id": "TEST_SAFETY_1",
                            "value": "0",
                            "fields": [
                                "id": "test_safety_ibias",
                                "value": "0"
                                "id": "test_vmon_ldo",
                                "value": "0"
                                "id": "test_vmon_vcca",
                                "value": "0"
                                "id": "test_safety_bg_buffer_en_hiz",
                                "value": "0"
                            "id": "TEST_SAFETY_2",
                            "value": "0",
                            "fields": [
                                "id": "test_safety_bias_dist",
                                "value": "0"
                                "id": "test_safety_vref_1v2",
                                "value": "0"
                                "id": "test_tsd2",
                                "value": "0"
                            "id": "TEST_VM_VSYS_0",
                            "value": "0",
                            "fields": [
                                "id": "test_vsys_en_ovst",
                                "value": "0"
                                "id": "test_vsys_vdda_voltage",
                                "value": "0"
                                "id": "test_vsys_bg",
                                "value": "0"
                                "id": "test_vsys_ibias",
                                "value": "0"
                                "id": "test_vsys_cp_voltage",
                                "value": "0"
                                "id": "test_vsys_en_cp_osc",
                                "value": "0"
                                "id": "test_vsys_vref_ramp",
                                "value": "0"
                                "id": "test_vsys_dis_osc_and_vcca_pd",
                                "value": "0"
                            "id": "TEST_RTC_0",
                            "value": "0",
                            "fields": [
                                "id": "test_rtc_bg",
                                "value": "0"
                                "id": "test_rtc_force_int_on",
                                "value": "0"
                                "id": "test_rtc_ldo_en_ovst",
                                "value": "0"
                                "id": "test_rtc_ldo_pupd_hiz",
                                "value": "0"
                                "id": "test_rtc_ldo_en_ilim",
                                "value": "0"
                                "id": "test_rtc_ldo_en_ilim2",
                                "value": "0"
                                "id": "test_rtc_iptat",
                                "value": "0"
                                "id": "test_rtc_ldo_pldn",
                                "value": "0"
                            "id": "TEST_RTC_1",
                            "value": "0",
                            "fields": [
                                "id": "test_rtc_xtal",
                                "value": "0"
                                "id": "test_rtc_ldo_out_stage_dis",
                                "value": "0"
                            "id": "TEST_LDO1_3_FILT_0",
                            "value": "0",
                            "fields": [
                                "id": "vbg_filt_test",
                                "value": "0"
                            "id": "TEST_LDO1_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo1_en_ovst",
                                "value": "0"
                                "id": "ldo1_en_unity_gain",
                                "value": "0"
                                "id": "ldo1_dis_ilim1",
                                "value": "0"
                                "id": "ldo1_dis_ilim2",
                                "value": "0"
                                "id": "ldo1_en_hiz",
                                "value": "0"
                                "id": "ldo1_en_ldo_vref",
                                "value": "0"
                                "id": "ldo1_en_ldo_vref_hiz",
                                "value": "0"
                                "id": "ldo1_en_ilim_trim",
                                "value": "0"
                            "id": "TEST_LDO1_1",
                            "value": "0",
                            "fields": [
                                "id": "ldo1_cp_test_sel",
                                "value": "0"
                                "id": "ldo1_en_cp_test_mode",
                                "value": "0"
                            "id": "TEST_LDO2_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo2_en_ovst",
                                "value": "0"
                                "id": "ldo2_en_unity_gain",
                                "value": "0"
                                "id": "ldo2_dis_ilim1",
                                "value": "0"
                                "id": "ldo2_dis_ilim2",
                                "value": "0"
                                "id": "ldo2_en_hiz",
                                "value": "0"
                                "id": "ldo2_en_ldo_vref",
                                "value": "0"
                                "id": "ldo2_en_ldo_vref_hiz",
                                "value": "0"
                                "id": "ldo2_en_ilim_trim",
                                "value": "0"
                            "id": "TEST_LDO2_1",
                            "value": "0",
                            "fields": [
                                "id": "ldo2_cp_test_sel",
                                "value": "0"
                                "id": "ldo2_en_cp_test_mode",
                                "value": "0"
                            "id": "TEST_LDO3_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo3_en_ovst",
                                "value": "0"
                                "id": "ldo3_en_unity_gain",
                                "value": "0"
                                "id": "ldo3_dis_ilim1",
                                "value": "0"
                                "id": "ldo3_dis_ilim2",
                                "value": "0"
                                "id": "ldo3_en_hiz",
                                "value": "0"
                                "id": "ldo3_en_ldo_vref",
                                "value": "0"
                                "id": "ldo3_en_ldo_vref_hiz",
                                "value": "0"
                                "id": "ldo3_en_ilim_trim",
                                "value": "0"
                            "id": "TEST_LDO3_1",
                            "value": "0",
                            "fields": [
                                "id": "ldo3_cp_test_sel",
                                "value": "0"
                                "id": "ldo3_en_cp_test_mode",
                                "value": "0"
                            "id": "TEST_LDO4_0",
                            "value": "0",
                            "fields": [
                                "id": "ldo4_test_en_ilim",
                                "value": "0"
                                "id": "ldo4_test_en_ilim2",
                                "value": "0"
                                "id": "ldo4_en_ovst",
                                "value": "0"
                                "id": "ldo4_en_kelvin",
                                "value": "0"
                                "id": "ldo4_en_hiz",
                                "value": "0"
                                "id": "ldo4_en_ovst2",
                                "value": "0"
                                "id": "ldo4_test_en_faster_trim",
                                "value": "0"
                            "id": "TEST_EE_LDO_0",
                            "value": "0",
                            "fields": [
                                "id": "test_dft_iddq_scale",
                                "value": "0"
                                "id": "test_en_tmux1_in",
                                "value": "0"
                                "id": "test_en_tmux2_in",
                                "value": "0"
                            "id": "TEST_BB_0",
                            "value": "0",
                            "fields": [
                                "id": "TEST_BB_SPARE",
                                "value": "0"
                            "id": "BUCK1_ATEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_atab_sel_1",
                                "value": "0"
                                "id": "test_integ_dac_short_output_1",
                                "value": "0"
                                "id": "test_ramp_artif_1",
                                "value": "0"
                                "id": "test_ramp_artif_pd_1",
                                "value": "0"
                                "id": "test_ramp_emu_1",
                                "value": "0"
                            "id": "BUCK1_ATEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "test_iave_1",
                                "value": "0"
                                "id": "test_hs_gate_1",
                                "value": "0"
                                "id": "test_ovst_1",
                                "value": "0"
                                "id": "test_ramp_emu_pd_1",
                                "value": "0"
                                "id": "test_sw_short_detector_1",
                                "value": "0"
                            "id": "BUCK1_ATEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "test_spare_1",
                                "value": "0"
                            "id": "BUCK1_DTEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab0_sel_1",
                                "value": "0"
                                "id": "swc_buck_hs_1",
                                "value": "0"
                                "id": "swc_buck_hiz_1",
                                "value": 0
                                "id": "force_pfm_1",
                                "value": "0"
                            "id": "BUCK1_DTEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab1_sel_1",
                                "value": "0"
                                "id": "test_iave_pd_1",
                                "value": "0"
                                "id": "test_sample_izero_1",
                                "value": "0"
                                "id": "test_pulse_generator_1",
                                "value": "0"
                            "id": "BUCK1_DTEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "test_buck_weak_driver_1",
                                "value": "0"
                                "id": "dis_loop_comp_hyst_1",
                                "value": "0"
                                "id": "dis_vref_filter_1",
                                "value": "0"
                                "id": "test_blank_1",
                                "value": "0"
                                "id": "test_single_shot_1",
                                "value": "0"
                                "id": "test_bypass_ramp_bias_res_1",
                                "value": "0"
                            "id": "BUCK1_DTEST_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "test_integrator_word_1",
                                "value": "0"
                            "id": "BUCK1_DTEST_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "test_carousel_ctrl_1",
                                "value": "0"
                                "id": "test_bypass_sw_latches_1",
                                "value": "0"
                                "id": "test_dis_autozero_1",
                                "value": "0"
                                "id": "test_pulse_gen_fixed_1",
                                "value": "0"
                            "id": "BUCK2_ATEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_atab_sel_2",
                                "value": "0"
                                "id": "test_integ_dac_short_output_2",
                                "value": "0"
                                "id": "test_ramp_artif_2",
                                "value": "0"
                                "id": "test_ramp_artif_pd_2",
                                "value": "0"
                                "id": "test_ramp_emu_2",
                                "value": "0"
                            "id": "BUCK2_ATEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "test_iave_2",
                                "value": "0"
                                "id": "test_hs_gate_2",
                                "value": "0"
                                "id": "test_ovst_2",
                                "value": "0"
                                "id": "test_ramp_emu_pd_2",
                                "value": "0"
                                "id": "test_sw_short_detector_2",
                                "value": "0"
                            "id": "BUCK2_ATEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "test_spare_2",
                                "value": "0"
                            "id": "BUCK2_DTEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab0_sel_2",
                                "value": 0
                                "id": "swc_buck_hs_2",
                                "value": 0
                                "id": "swc_buck_hiz_2",
                                "value": 0
                                "id": "force_pfm_2",
                                "value": 0
                            "id": "BUCK2_DTEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab1_sel_2",
                                "value": "0"
                                "id": "test_iave_pd_2",
                                "value": "0"
                                "id": "test_sample_izero_2",
                                "value": "0"
                                "id": "test_pulse_generator_2",
                                "value": "0"
                            "id": "BUCK2_DTEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "dis_loop_comp_hyst_2",
                                "value": "0"
                                "id": "dis_vref_filter_2",
                                "value": "0"
                                "id": "test_blank_2",
                                "value": "0"
                                "id": "test_single_shot_2",
                                "value": "0"
                                "id": "test_buck_weak_driver_2",
                                "value": "0"
                                "id": "test_bypass_ramp_bias_res_2",
                                "value": "0"
                            "id": "BUCK2_DTEST_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "test_integrator_word_2",
                                "value": "0"
                            "id": "BUCK2_DTEST_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "test_carousel_ctrl_2",
                                "value": "0"
                                "id": "test_bypass_sw_latches_2",
                                "value": "0"
                                "id": "test_dis_autozero_2",
                                "value": "0"
                                "id": "test_pulse_gen_fixed_2",
                                "value": "0"
                            "id": "BUCK3_ATEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_atab_sel_3",
                                "value": "0"
                                "id": "test_integ_dac_short_output_3",
                                "value": "0"
                                "id": "test_ramp_artif_3",
                                "value": "0"
                                "id": "test_ramp_artif_pd_3",
                                "value": "0"
                                "id": "test_ramp_emu_3",
                                "value": "0"
                            "id": "BUCK3_ATEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "test_iave_3",
                                "value": "0"
                                "id": "test_hs_gate_3",
                                "value": "0"
                                "id": "test_ovst_3",
                                "value": "0"
                                "id": "test_ramp_emu_pd_3",
                                "value": "0"
                                "id": "test_sw_short_detector_3",
                                "value": "0"
                            "id": "BUCK3_ATEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "test_spare_3",
                                "value": "0"
                            "id": "BUCK3_DTEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab0_sel_3",
                                "value": "0"
                                "id": "swc_buck_hs_3",
                                "value": "0"
                                "id": "swc_buck_hiz_3",
                                "value": 0
                                "id": "force_pfm_3",
                                "value": "0"
                            "id": "BUCK3_DTEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab1_sel_3",
                                "value": "0"
                                "id": "test_iave_pd_3",
                                "value": "0"
                                "id": "test_sample_izero_3",
                                "value": "0"
                                "id": "test_pulse_generator_3",
                                "value": "0"
                            "id": "BUCK3_DTEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "dis_loop_comp_hyst_3",
                                "value": "0"
                                "id": "dis_vref_filter_3",
                                "value": "0"
                                "id": "test_blank_3",
                                "value": "0"
                                "id": "test_single_shot_3",
                                "value": "0"
                                "id": "test_buck_weak_driver_3",
                                "value": "0"
                                "id": "test_bypass_ramp_bias_res_3",
                                "value": "0"
                            "id": "BUCK3_DTEST_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "test_integrator_word_3",
                                "value": "0"
                            "id": "BUCK3_DTEST_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "test_carousel_ctrl_3",
                                "value": "0"
                                "id": "test_bypass_sw_latches_3",
                                "value": "0"
                                "id": "test_dis_autozero_3",
                                "value": "0"
                                "id": "test_pulse_gen_fixed_3",
                                "value": "0"
                            "id": "BUCK4_ATEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_atab_sel_4",
                                "value": "0"
                                "id": "test_integ_dac_short_output_4",
                                "value": "0"
                                "id": "test_ramp_artif_4",
                                "value": "0"
                                "id": "test_ramp_artif_pd_4",
                                "value": "0"
                                "id": "test_ramp_emu_4",
                                "value": "0"
                            "id": "BUCK4_ATEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "test_iave_4",
                                "value": "0"
                                "id": "test_hs_gate_4",
                                "value": "0"
                                "id": "test_ovst_4",
                                "value": "0"
                                "id": "test_ramp_emu_pd_4",
                                "value": "0"
                                "id": "test_sw_short_detector_4",
                                "value": "0"
                            "id": "BUCK4_ATEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "test_spare_4",
                                "value": "0"
                            "id": "BUCK4_DTEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab0_sel_4",
                                "value": "0"
                                "id": "swc_buck_hs_4",
                                "value": "0"
                                "id": "swc_buck_hiz_4",
                                "value": 0
                                "id": "force_pfm_4",
                                "value": "0"
                            "id": "BUCK4_DTEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab1_sel_4",
                                "value": "0"
                                "id": "test_iave_pd_4",
                                "value": "0"
                                "id": "test_sample_izero_4",
                                "value": "0"
                                "id": "test_pulse_generator_4",
                                "value": "0"
                            "id": "BUCK4_DTEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "dis_loop_comp_hyst_4",
                                "value": "0"
                                "id": "dis_vref_filter_4",
                                "value": "0"
                                "id": "test_blank_4",
                                "value": "0"
                                "id": "test_single_shot_4",
                                "value": "0"
                                "id": "test_buck_weak_driver_4",
                                "value": "0"
                                "id": "test_bypass_ramp_bias_res_4",
                                "value": "0"
                            "id": "BUCK4_DTEST_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "test_integrator_word_4",
                                "value": "0"
                            "id": "BUCK4_DTEST_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "test_carousel_ctrl_4",
                                "value": "0"
                                "id": "test_bypass_sw_latches_4",
                                "value": "0"
                                "id": "test_dis_autozero_4",
                                "value": "0"
                                "id": "test_pulse_gen_fixed_4",
                                "value": "0"
                            "id": "BUCK5_ATEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_atab_sel_5",
                                "value": "0"
                                "id": "test_integ_dac_short_output_5",
                                "value": "0"
                                "id": "test_ramp_artif_5",
                                "value": "0"
                                "id": "test_ramp_artif_pd_5",
                                "value": "0"
                                "id": "test_ramp_emu_5",
                                "value": "0"
                            "id": "BUCK5_ATEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "test_iave_5",
                                "value": "0"
                                "id": "test_hs_gate_5",
                                "value": "0"
                                "id": "test_ovst_5",
                                "value": "0"
                                "id": "test_ramp_emu_pd_5",
                                "value": "0"
                                "id": "test_sw_short_detector_5",
                                "value": "0"
                            "id": "BUCK5_ATEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "test_spare_5",
                                "value": "0"
                            "id": "BUCK5_DTEST_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab0_sel_5",
                                "value": "0"
                                "id": "swc_buck_hs_5",
                                "value": "0"
                                "id": "swc_buck_hiz_5",
                                "value": 0
                                "id": "force_pfm_5",
                                "value": "0"
                            "id": "BUCK5_DTEST_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "buck_dtab1_sel_5",
                                "value": "0"
                                "id": "test_iave_pd_5",
                                "value": "0"
                                "id": "test_sample_izero_5",
                                "value": "0"
                                "id": "test_pulse_generator_5",
                                "value": "0"
                            "id": "BUCK5_DTEST_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "dis_loop_comp_hyst_5",
                                "value": "0"
                                "id": "dis_vref_filter_5",
                                "value": "0"
                                "id": "test_blank_5",
                                "value": "0"
                                "id": "test_single_shot_5",
                                "value": "0"
                                "id": "test_buck_weak_driver_5",
                                "value": "0"
                                "id": "test_bypass_ramp_bias_res_5",
                                "value": "0"
                            "id": "BUCK5_DTEST_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "test_integrator_word_5",
                                "value": "0"
                            "id": "BUCK5_DTEST_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "test_carousel_ctrl_5",
                                "value": "0"
                                "id": "test_bypass_sw_latches_5",
                                "value": "0"
                                "id": "test_dis_autozero_5",
                                "value": "0"
                                "id": "test_pulse_gen_fixed_5",
                                "value": "0"
                        "id": "BuckStatus-tm_mem",
                        "registers": [
                            "id": "BUCK1_STATE",
                            "value": "0",
                            "fields": [
                                "id": "buck_state_1",
                                "value": "0"
                            "id": "BUCK2_STATE",
                            "value": "0",
                            "fields": [
                                "id": "buck_state_2",
                                "value": "0"
                            "id": "BUCK3_STATE",
                            "value": "0",
                            "fields": [
                                "id": "buck_state_3",
                                "value": "0"
                            "id": "BUCK4_STATE",
                            "value": "0",
                            "fields": [
                                "id": "buck_state_4",
                                "value": "0"
                            "id": "BUCK5_STATE",
                            "value": "0",
                            "fields": [
                                "id": "buck_state_5",
                                "value": "0"
                            "id": "BUCK1_INTEGRATOR",
                            "value": "0",
                            "fields": [
                                "id": "buck_integrator_word_1",
                                "value": "0"
                            "id": "BUCK2_INTEGRATOR",
                            "value": "0",
                            "fields": [
                                "id": "buck_integrator_word_2",
                                "value": "0"
                            "id": "BUCK3_INTEGRATOR",
                            "value": "0",
                            "fields": [
                                "id": "buck_integrator_word_3",
                                "value": "0"
                            "id": "BUCK4_INTEGRATOR",
                            "value": "0",
                            "fields": [
                                "id": "buck_integrator_word_4",
                                "value": "0"
                            "id": "BUCK5_INTEGRATOR",
                            "value": "0",
                            "fields": [
                                "id": "buck_integrator_word_5",
                                "value": "0"
                            "id": "BUCK_STATUS",
                            "value": "0",
                            "fields": [
                                "id": "buck1_active",
                                "value": "0"
                                "id": "buck2_active",
                                "value": "0"
                                "id": "buck3_active",
                                "value": "0"
                                "id": "buck4_active",
                                "value": "0"
                                "id": "buck5_active",
                                "value": "0"
                        "id": "EEPROMProgControl-tm_mem",
                        "registers": [
                            "id": "EEPROM_CONTROL_1",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_CFG_BULK_PROG",
                                "value": "0"
                                "id": "TM_EE_CFG_CKB_PROG",
                                "value": "0"
                                "id": "TM_EE_CFG_MARGIN_READ",
                                "value": "0"
                                "id": "TM_EE_CFG_BULK_ERASE",
                                "value": "0"
                                "id": "TM_EE_CFG_SHADOW_WRITE_DIS",
                                "value": "0"
                            "id": "EEPROM_CONTROL_2",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_CFG_BANK_DIS",
                                "value": "0"
                                "id": "TM_EE_CFG_SINGLE",
                                "value": "0"
                            "id": "EEPROM_CONTROL_3",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_ADDR",
                                "value": "0"
                            "id": "EEPROM_CONTROL_8",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_WRITE_DATA3",
                                "value": "0"
                            "id": "EEPROM_CONTROL_9",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_WRITE_DATA2",
                                "value": "0"
                            "id": "EEPROM_CONTROL_10",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_WRITE_DATA1",
                                "value": "0"
                            "id": "EEPROM_CONTROL_11",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_WRITE_DATA0",
                                "value": "0"
                            "id": "EEPROM_CONTROL_12",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_READ_DATA3",
                                "value": "0"
                            "id": "EEPROM_CONTROL_13",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_READ_DATA2",
                                "value": "0"
                            "id": "EEPROM_CONTROL_14",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_READ_DATA1",
                                "value": "0"
                            "id": "EEPROM_CONTROL_15",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_READ_DATA0",
                                "value": "0"
                            "id": "EEPROM_CONTROL_16",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_CMD_PROG",
                                "value": "0"
                                "id": "TM_EE_CMD_READ",
                                "value": "0"
                            "id": "EEPROM_CONTROL_17",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_FORCE_CP_EN",
                                "value": "0"
                                "id": "TM_EE_FORCE_IP_EN",
                                "value": "0"
                                "id": "TM_EE_FORCE_ERASE",
                                "value": "0"
                                "id": "TM_EE_FORCE_PROG",
                                "value": "0"
                                "id": "TM_EE_FORCE_READ",
                                "value": "0"
                                "id": "TM_EE_FORCE_EN",
                                "value": "0"
                            "id": "EEPROM_CONTROL_18",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_FAST_ERASE_PROG_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_BULK_ODD_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_BULK_EVEN_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_MARGIN_READ_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_MARGIN_OVR_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_HV_BIAS_WEAK_RATIO_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_OSC_MON_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_CELL_CURRENT_MON_EN",
                                "value": "0"
                            "id": "EEPROM_CONTROL_19",
                            "value": "0",
                            "fields": [
                                "id": "TM_EE_MARGIN_TRIM",
                                "value": "0"
                                "id": "TM_EE_TEST_VTUN_MON_EN",
                                "value": "0"
                                "id": "TM_EE_TEST_V1V_MON_OVR_EN",
                                "value": "0"
                                "id": "TM_EE_PROG_SERIAL",
                                "value": "0"
                            "id": "EEPROM_CONTROL_20",
                            "value": "0",
                            "fields": [
                                "id": "tm_ee_ready",
                                "value": "0"
                                "id": "ee_active",
                                "value": "0"
                                "id": "tm_ee_read_fail",
                                "value": "0"
                        "id": "Trim_ocore",
                        "registers": [
                            "id": "TRIM_VMVCCA_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmvcca_bg",
                                "value": "0"
                            "id": "TRIM_VMVCCA_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmvcca_rdiv_1v2",
                                "value": "0"
                            "id": "TRIM_VMVCCA_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmvcca_rdiv_0v6",
                                "value": "0"
                            "id": "TRIM_VMPVIN_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmpvin_bg",
                                "value": "0"
                            "id": "TRIM_VMPVIN_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmpvin_rdiv_1v2",
                                "value": "0"
                            "id": "TRIM_INT_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_refsys_bg",
                                "value": "0"
                            "id": "TRIM_INT_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_refsys_rdiv_1v2",
                                "value": "0"
                            "id": "TRIM_INT_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_refsys_ibias",
                                "value": "0"
                            "id": "TRIM_INT_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo_int",
                                "value": "0"
                            "id": "TRIM_INT_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_osc_20mhz",
                                "value": "0"
                            "id": "TRIM_INT_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_osc_128khz",
                                "value": "0"
                            "id": "TRIM_INT_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_osc_52mhz",
                                "value": "0"
                            "id": "TRIM_INT_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_amux_buffer",
                                "value": "0"
                            "id": "TRIM_INT_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_monitor_osc_20mhz",
                                "value": "0"
                            "id": "TRIM_SAFETY_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_safety_ibias",
                                "value": "0"
                            "id": "TRIM_SAFETY_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck1_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck1_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck1_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck1_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck2_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck2_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck2_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck2_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_9",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck3_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_10",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck3_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_11",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck3_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_12",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck3_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_13",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck4_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_14",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck4_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_15",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck4_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_16",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck4_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_17",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck5_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_18",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck5_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_19",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck5_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_20",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_buck5_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_21",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo1_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_22",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo1_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_23",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo1_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_24",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo1_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_25",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo2_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_26",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo2_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_27",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo2_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_28",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo2_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_29",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo3_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_30",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo3_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_31",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo3_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_32",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo3_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_33",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo4_lshift_ov",
                                "value": "0"
                            "id": "TRIM_SAFETY_34",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo4_lshift_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_35",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo4_vref_dac",
                                "value": "0"
                            "id": "TRIM_SAFETY_36",
                            "value": "0",
                            "fields": [
                                "id": "trim_vmon_ldo4_rdiv_uv",
                                "value": "0"
                            "id": "TRIM_SAFETY_37",
                            "value": "0",
                            "fields": [
                                "id": "trim_tsd_offset",
                                "value": "0"
                            "id": "TRIM_SAFETY_38",
                            "value": "0",
                            "fields": [
                                "id": "trim_tsd_gain",
                                "value": "0"
                            "id": "TRIM_SAFETY_39",
                            "value": "0",
                            "fields": [
                                "id": "trim_tsd_offset2",
                                "value": "0"
                            "id": "TRIM_SAFETY_40",
                            "value": "0",
                            "fields": [
                                "id": "trim_tsd_gain2",
                                "value": "0"
                            "id": "TRIM_VM_VSYS_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vsys_mon_bg",
                                "value": "0"
                            "id": "TRIM_VM_VSYS_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_vsys_mon_rdiv_1v2",
                                "value": "0"
                            "id": "TRIM_RTC_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_rtc_bg",
                                "value": "0"
                            "id": "TRIM_RTC_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_rtc_rdiv_1v2",
                                "value": "0"
                            "id": "TRIM_RTC_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_rtc_ldo",
                                "value": "0"
                            "id": "TRIM_DPLL_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_dco",
                                "value": "0"
                            "id": "TRIM_LDO1_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo1_ref",
                                "value": "0"
                            "id": "TRIM_LDO1_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo1",
                                "value": "0"
                            "id": "TRIM_LDO1_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo1_ilim1",
                                "value": "0"
                            "id": "TRIM_LDO1_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo1_ilim2",
                                "value": "0"
                            "id": "TRIM_LDO2_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo2_ref",
                                "value": "0"
                            "id": "TRIM_LDO2_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo2",
                                "value": "0"
                            "id": "TRIM_LDO2_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo2_ilim1",
                                "value": "0"
                            "id": "TRIM_LDO2_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo2_ilim2",
                                "value": "0"
                            "id": "TRIM_LDO3_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo3_ref",
                                "value": "0"
                            "id": "TRIM_LDO3_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo3",
                                "value": "0"
                            "id": "TRIM_LDO3_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo3_ilim1",
                                "value": "0"
                            "id": "TRIM_LDO3_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo3_ilim2",
                                "value": "0"
                            "id": "TRIM_LDO4_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo4_low",
                                "value": "0"
                            "id": "TRIM_LDO4_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo4_high",
                                "value": "0"
                            "id": "TRIM_LDO4_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo4_ilim",
                                "value": "0"
                            "id": "TRIM_LDO4_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo4_sr_fast",
                                "value": "0"
                            "id": "TRIM_LDO4_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_ldo4_sr_slow",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vref_dac_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_level_shift_gain_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_loop_comp_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_gain_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_offset_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_ptat_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_emu_ramp_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_artif_ramp_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_hs_replica_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_9",
                            "value": "0",
                            "fields": [
                                "id": "trim_ls_replica_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_10",
                            "value": "0",
                            "fields": [
                                "id": "trim_fb_gain_stage_offset_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_11",
                            "value": "0",
                            "fields": [
                                "id": "trim_integ_dac_gain_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_12",
                            "value": "0",
                            "fields": [
                                "id": "trim_slope_1",
                                "value": "0"
                            "id": "BUCK1_TRIM_REG_13",
                            "value": "0",
                            "fields": [
                                "id": "trim_spare_1",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vref_dac_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_level_shift_gain_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_loop_comp_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_gain_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_offset_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_ptat_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_emu_ramp_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_artif_ramp_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_hs_replica_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_9",
                            "value": "0",
                            "fields": [
                                "id": "trim_ls_replica_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_10",
                            "value": "0",
                            "fields": [
                                "id": "trim_fb_gain_stage_offset_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_11",
                            "value": "0",
                            "fields": [
                                "id": "trim_integ_dac_gain_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_12",
                            "value": "0",
                            "fields": [
                                "id": "trim_slope_2",
                                "value": "0"
                            "id": "BUCK2_TRIM_REG_13",
                            "value": "0",
                            "fields": [
                                "id": "trim_spare_2",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vref_dac_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_level_shift_gain_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_loop_comp_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_gain_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_offset_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_ptat_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_emu_ramp_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_artif_ramp_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_hs_replica_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_9",
                            "value": "0",
                            "fields": [
                                "id": "trim_ls_replica_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_10",
                            "value": "0",
                            "fields": [
                                "id": "trim_fb_gain_stage_offset_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_11",
                            "value": "0",
                            "fields": [
                                "id": "trim_integ_dac_gain_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_12",
                            "value": "0",
                            "fields": [
                                "id": "trim_slope_3",
                                "value": "0"
                            "id": "BUCK3_TRIM_REG_13",
                            "value": "0",
                            "fields": [
                                "id": "trim_spare_3",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vref_dac_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_level_shift_gain_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_loop_comp_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_gain_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_offset_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_ptat_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_emu_ramp_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_artif_ramp_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_hs_replica_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_9",
                            "value": "0",
                            "fields": [
                                "id": "trim_ls_replica_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_10",
                            "value": "0",
                            "fields": [
                                "id": "trim_fb_gain_stage_offset_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_11",
                            "value": "0",
                            "fields": [
                                "id": "trim_integ_dac_gain_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_12",
                            "value": "0",
                            "fields": [
                                "id": "trim_slope_4",
                                "value": "0"
                            "id": "BUCK4_TRIM_REG_13",
                            "value": "0",
                            "fields": [
                                "id": "trim_spare_4",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_0",
                            "value": "0",
                            "fields": [
                                "id": "trim_vref_dac_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_1",
                            "value": "0",
                            "fields": [
                                "id": "trim_level_shift_gain_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_2",
                            "value": "0",
                            "fields": [
                                "id": "trim_loop_comp_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_3",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_gain_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_4",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_offset_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_5",
                            "value": "0",
                            "fields": [
                                "id": "trim_vout_adc_ptat_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_6",
                            "value": "0",
                            "fields": [
                                "id": "trim_emu_ramp_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_7",
                            "value": "0",
                            "fields": [
                                "id": "trim_artif_ramp_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_8",
                            "value": "0",
                            "fields": [
                                "id": "trim_hs_replica_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_9",
                            "value": "0",
                            "fields": [
                                "id": "trim_ls_replica_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_10",
                            "value": "0",
                            "fields": [
                                "id": "trim_fb_gain_stage_offset_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_11",
                            "value": "0",
                            "fields": [
                                "id": "trim_integ_dac_gain_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_12",
                            "value": "0",
                            "fields": [
                                "id": "trim_slope_5",
                                "value": "0"
                            "id": "BUCK5_TRIM_REG_13",
                            "value": "0",
                            "fields": [
                                "id": "trim_spare_5",
                                "value": "0"
                        "id": "WatchDogRegisters-user_mem",
                        "registers": [
                            "id": "WD_ANSWER_REG",
                            "value": "0",
                            "fields": [
                                "id": "WD_ANSWER",
                                "value": "0"
                            "id": "WD_QUESTION_ANSW_CNT",
                            "value": "0",
                            "fields": [
                                "id": "WD_QUESTION",
                                "value": "0"
                                "id": "WD_ANSW_CNT",
                                "value": "0"
                            "id": "WD_WIN1_CFG",
                            "value": "0",
                            "fields": [
                                "id": "WD_WIN1",
                                "value": "0"
                            "id": "WD_WIN2_CFG",
                            "value": "0",
                            "fields": [
                                "id": "WD_WIN2",
                                "value": "0"
                            "id": "WD_LONGWIN_CFG",
                            "value": "0",
                            "fields": [
                                "id": "WD_LONGWIN",
                                "value": "0"
                            "id": "WD_MODE_REG",
                            "value": "0",
                            "fields": [
                                "id": "WD_PWRHOLD",
                                "value": "0"
                                "id": "WD_MODE_SELECT",
                                "value": "0"
                                "id": "WD_RETURN_LONGWIN",
                                "value": "0"
                            "id": "WD_QA_CFG",
                            "value": "0",
                            "fields": [
                                "id": "WD_QA_FDBK",
                                "value": "0"
                                "id": "WD_QA_LFSR",
                                "value": "0"
                                "id": "WD_QUESTION_SEED",
                                "value": "0"
                            "id": "WD_ERR_STATUS",
                            "value": "0",
                            "fields": [
                                "id": "WD_ANSW_EARLY",
                                "value": "0"
                                "id": "WD_TIMEOUT",
                                "value": "0"
                                "id": "WD_SEQ_ERR",
                                "value": "0"
                                "id": "WD_LONGWIN_TIMEOUT_INT",
                                "value": "0"
                                "id": "WD_ANSW_ERR",
                                "value": "0"
                                "id": "WD_TRIG_EARLY",
                                "value": "0"
                                "id": "WD_RST_INT",
                                "value": "0"
                                "id": "WD_FAIL_INT",
                                "value": "0"
                            "id": "WD_THR_CFG",
                            "value": "0",
                            "fields": [
                                "id": "WD_EN",
                                "value": "0",
                                "id": "WD_RST_EN",
                                "value": 1,
                                "id": "WD_FAIL_TH",
                                "value": 7,
                                "id": "WD_RST_TH",
                                "value": 7,
                            "id": "WD_FAIL_CNT_REG",
                            "value": "0",
                            "fields": [
                                "id": "WD_FAIL_CNT",
                                "value": "0"
                                "id": "WD_FIRST_OK",
                                "value": "0"
                                "id": "WD_BAD_EVENT",
                                "value": "0"
              "name": "TPS6593x_2p0",
              "devices": []
              "name": "LP8764x",
              "devices": []
          "fsmConfig": {
            "states": [
                "id": 0,
                "title": "ACTIVE",
                "x": 248.80233764648438,
                "y": 100,
                "isHardwareState": false,
                "isUserDefinedState": true
                "id": 1,
                "title": "STANDBY",
                "x": 250,
                "y": 300,
                "mandatoryState": true,
            "transitions": [
                "source": {
                  "id": 0,
                  "title": "ACTIVE",
                  "y": 100,
                "target": {
                  "id": 1,
                  "title": "STANDBY",
                  "x": 250,
                  "y": 300,
                "order": 1,
                "label": "",
                "priority": 0,
                "triggers": []
                "source": {
                  "id": 1,
                  "title": "STANDBY",
                  "x": 250,
                  "y": 300,
                "target": {
                  "id": 0,
                  "title": "ACTIVE",
                  "y": 100,
                "order": 2,
                "label": "",
                "priority": 0,
                "triggers": [
                    "id": 0
            "triggers": [
                "trigger": {
                  "trigSel": 12,
                  "name": "SU_ACTIVE"
                "type": "HIGH",
                "isImmediate": true,
                "isEXT": false,
                "isReentrant": false,
                "devices": [
                  "TPS65940"
                "sequence": {
                  "id": 0
                "id": 0
            "triggerPriorityList": [
                "transition": [
                    "source": "STANDBY",
                    "target": "ACTIVE",
                    "priority": 0
                "triggerBase": {
                  "id": 0
            "globalSequences": [
                "name": "any2active",
                "id": 0,
                "sequences": [
                    "command": {
                      "name": "LDO2",
                      "registerName": "LDO2_CTRL",
                      "selectedFields": [
                        "LDO2_EN"
                      "register": {
                        "id": "LDO2_CTRL",
                        "name": "LDO2_CTRL",
                        "desc": "",
                        "anchor": "",
                        "addr": "0x1e",
                        "mode": "",
                        "size": "8",
                        "default": "0",
                        "value": 1,
                        "fields": [
                            "id": "LDO2_EN",
                            "helpTag": "",
                            "name": "LDO2_EN",
                            "desc": "Enable LDO2 regulator:\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "0",
                            "stop": "0",
                            "value": 1,
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "display": "Disabled; LDO2 regulator.",
                                "value": 0
                                "display": "Enabled; LDO2 regulator.",
                                "value": 1
                            "maskOptions": [
                                "type": "Unchanged",
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                            "id": "LDO2_PLDN",
                            "helpTag": "",
                            "name": "LDO2_PLDN",
                            "desc": "Enable output pull-down resistor when LDO2 is disabled:\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "5",
                            "stop": "6",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "display": "50 kOhm",
                                "value": 0
                                "display": "125 Ohm",
                                "value": 1
                                "display": "250 Ohm",
                                "value": 2
                                "display": "500 Ohm\r\n",
                                "value": 3
                            "maskOptions": [
                                "value": "mask"
                                "type": "50 kOhm",
                                "value": 0
                                "type": "125 Ohm",
                                "value": 1
                                "type": "250 Ohm",
                                "value": 2
                                "type": "500 Ohm\r\n",
                                "value": 3
                            "id": "LDO2_VMON_EN",
                            "helpTag": "",
                            "name": "LDO2_VMON_EN",
                            "desc": "Enable LDO2 OV and UV comparators:\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "4",
                            "stop": "4",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "display": "Disabled; OV and UV comparators.",
                                "value": 0
                                "display": "Enabled; OV and UV comparators.",
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                            "id": "LDO2_RV_SEL",
                            "helpTag": "",
                            "name": "LDO2_RV_SEL",
                            "desc": "Select residual voltage checking for LDO2 output pin.\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "7",
                            "stop": "7",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "display": "Disabled",
                                "value": 0
                                "display": "Enabled",
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                            "id": "LDO2_SLOW_RAMP",
                            "helpTag": "",
                            "name": "LDO2_SLOW_RAMP",
                            "desc": "LDO2 startup slew rate selection",
                            "anchor": "",
                            "mode": "RW",
                            "start": "1",
                            "stop": "1",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "display": "25mV/us max ramp up slew rate for LDO output from 0.3V to 90% of LDOn_VSET",
                                "value": 0
                                "display": "3mV/us max ramp up slew rate for LDO output from 0.3V to 90% of LDOn_VSET",
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                        "mask": 254
                    "visible": true,
                    "name": "Rail1",
                    "delay": 0,
                    "delayUnit": "us",
                    "timeout": 0,
                    "timeoutUnit": "us",
                    "waitCondition": {
                      "condSel": 0,
                      "condName": "GPIO1"
                    "conditionType": "LOW",
                    "delayMode": "ALWAYS",
                    "resourceControl": "VOUT",
                    "resourceControlSelect": 0,
                    "scratchRegister": "R0",
                    "bypass": false,
                    "outputVoltageUnit": "V",
                    "outputVoltage": "1.2",
                    "voltageTarget": "VSEL1",
                    "scratchAddress": null,
                    "scratchMask": null,
                    "subSequence": null,
                    "calculatedDelay": 0,
                    "isSubRoutineAction": false,
                    "sequences": [],
                    "destination": null,
                    "vccaVmon": "unchanged",
                    "clkmon": "unchanged",
                    "amuxout": "unchanged",
                    "buckCtrlResetReg": null,
                    "enableDRV": 0,
                    "deviceAlias": "TPS65940",
                    "trigMask": {
                      "value": null,
                      "unmaskTriggerList": []
                    "command": {
                      "name": "LDO3",
                      "registerName": "LDO3_CTRL",
                      "selectedFields": [
                        "LDO3_EN"
                      "visibility": true,
                      "showInSeq": true,
                      "register": {
                        "id": "LDO3_CTRL",
                        "name": "LDO3_CTRL",
                        "desc": "",
                        "anchor": "",
                        "addr": "0x1f",
                        "mode": "",
                        "size": "8",
                        "default": "0",
                        "value": 1,
                        "fields": [
                            "id": "LDO3_EN",
                            "helpTag": "",
                            "name": "LDO3_EN",
                            "desc": "Enable LDO3 regulator:\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "0",
                            "stop": "0",
                            "value": 1,
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "display": "Disabled; LDO3 regulator.",
                                "value": 0
                                "display": "Enabled; LDO3 regulator.",
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                            "id": "LDO3_PLDN",
                            "helpTag": "",
                            "name": "LDO3_PLDN",
                            "desc": "Enable output pull-down resistor when LDO3 is disabled:\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "5",
                            "stop": "6",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "value": 0
                                "value": 1
                                "value": 2
                                "value": 3
                            "maskOptions": [
                                "value": "mask"
                                "type": "50 kOhm",
                                "value": 0
                                "type": "125 Ohm",
                                "value": 1
                                "type": "250 Ohm",
                                "value": 2
                                "value": 3
                            "id": "LDO3_VMON_EN",
                            "helpTag": "",
                            "name": "LDO3_VMON_EN",
                            "desc": "Enable LDO3 OV and UV comparators:\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "4",
                            "stop": "4",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "value": 0
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                            "id": "LDO3_RV_SEL",
                            "helpTag": "",
                            "name": "LDO3_RV_SEL",
                            "desc": "Select residual voltage checking for LDO3 output pin.\r\n(Default from NVM memory)",
                            "anchor": "",
                            "mode": "RW",
                            "start": "7",
                            "stop": "7",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "value": 0
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                            "id": "LDO3_SLOW_RAMP",
                            "helpTag": "",
                            "name": "LDO3_SLOW_RAMP",
                            "desc": "LDO3 startup slew rate selection",
                            "anchor": "",
                            "mode": "RW",
                            "start": "1",
                            "stop": "1",
                            "value": "mask",
                            "attrs": {
                              "isHidden": "0",
                              "isReserved": "0",
                              "isLocked": "0"
                            "options": [
                                "value": 0
                                "value": 1
                            "maskOptions": [
                                "value": "mask"
                                "type": "HIGH",
                                "value": 1
                                "type": "LOW",
                                "value": 0
                        "mask": 254
                    "visible": true,
                    "name": "Rail2",
                    "delay": "100",
                    "delayUnit": "ms",
                    "timeout": 0,
                    "waitCondition": {
                      "condSel": 0,
                      "condName": "GPIO1"
                    "bypass": false,
                    "outputVoltage": "1.8",
                    "calculatedDelay": 100,
                    "sequences": [],
                    "enableDRV": 0,
                    "selectedTimeoutUnit": "us",
                    "trigMask": {
                      "value": null,
                    "command": {
                      "name": "TRIG_MASK",
                      "visibility": true,
                      "showInSeq": false
                    "visible": false,
                    "name": "",
                    "delay": 0,
                    "delayUnit": "us",
                    "timeout": 0,
                    "waitCondition": {
                      "condSel": 0,
                      "condName": "GPIO1"
                    "resourceControl": "VCTRL",
                    "scratchRegister": null,
                    "bypass": false,
                    "outputVoltage": 0,
                    "calculatedDelay": 100000,
                    "sequences": [],
                    "enableDRV": 0,
                    "trigMask": {
                      "value": null,
                "targetState": {
                  "id": 0,
                  "title": "ACTIVE",
                  "y": 100,
                "subRoutineList": [],
                "sequenceType": "others"
            "pfsmGlobalDelay": 102.4,
            "autoShuffle": true,
            "overridenStandbyReadyTrigMask": null,
            "startState": {
              "id": 0,
              "title": "ACTIVE",
              "y": 100,
    您好、Xiaofu、
      TPS65941111EVM   出厂时已针对4+1相配置进行了预编程。 根据设计、它应与 TPS65941212EVM 或 TPS65941213EVM 配合使用。 有关  更多详细信息、请查看其用户指南。
      TPS65941111EVM 通过其出厂预编程的方式具有自己的 PFSM 配置。  如果与 TPS65941212EVM 或 TPS65941213EVM 配合使用、则无需 PFSM 配置。
     我想知道您在哪里可以获得上述 PFSM 配置。
    Phil
