[参考译文] BQ78350-R1A:bq78350-R1和 BQ78350-R1A 之间的差异
Guru**** 2595805 points
Other Parts Discussed in Thread: BQ78350-R1A, BQ78350-R1
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1064405/bq78350-r1a-the-difference-between-bq78350-r1-and-bq78350-r1a
器件型号:BQ78350-R1A
主题中讨论的其他器件: BQ78350-R1
尊敬的,
BQ78350-R1和 BQ78350-R1A?之间的区别是什么
