[参考译文] LM27341:解决方案选择
Guru**** 2815505 points
Other Parts Discussed in Thread: BQ24640
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1056139/lm27341-solution-select
器件型号:LM27341
主题中讨论的其他器件:bq24640
尊敬的团队
TI 拥有集成了超级电容器充电器的解决方案可以替代 LTC3355?
https://www.analogue.com/media/en/technical-documentation/data-sheets/3355fb.pdf
非常感谢
丹尼
