[参考译文] TPS40210:我需要可调输出;FB 引脚是否可以接地以设置 COMP 上的电压? 在内部原理图中、内部运算放大器是否存在开路泄漏输出?
Guru**** 2542190 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1054046/tps40210-i-need-adjustable-output-can-fb-pin-be-grounded-to-set-voltage-on-comp-in-the-internal-schematic-diagram-is-the-internal-operational-amplifier-open-leakage-output
器件型号:TPS40210
