[参考译文] BQ27426:在电池电压为3.6V 且负载电流为2A 的情况下、是否有特殊的方法来提供电源测试的精度?
Guru**** 2540720 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1053478/bq27426-hen-the-battery-voltage-is-3-6v-and-the-load-current-is-2a-is-there-a-special-method-to-provide-the-accuracy-of-the-power-test
器件型号:BQ27426
