[FAQ] [参考译文] [常见问题解答] BQ25792:如果未连接电池且禁用充电、此窄电压直流(NVDC)充电器会将 SYS 输出调节到什么电压?
Guru**** 2601915 points
Other Parts Discussed in Thread: BQ25792
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1023434/faq-bq25792-what-voltage-does-this-narrow-voltage-dc-nvdc-charger-regulate-the-sys-output-to-if-no-battery-is-attached-and-charge-is-disabled
器件型号:BQ25792
在禁用充电且未连接电池的情况下、BQ25792会将 SYS 调节为 BQ25792最低系统电压寄存器 REG00[5:0]设置的 MINSYS (SysMin)电压。
