[参考译文] BQ78350-R1:EDV2、EDV1、EDV0阈值未按预期更新 RSOC。
Guru**** 2611705 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1016510/bq78350-r1-edv2-edv1-edv0-thresholds-not-updating-rsoc-as-expected
器件型号:BQ78350-R1
我将 CEDV 值设置为所附代码中所示的值:
"Settings","Configuration","CEDV Gauging Configuration","0092","hex"
"Fuel Gauging","CEDV cfg","EMF","3850","-"
"Fuel Gauging","CEDV cfg","C0","235","-"
"Fuel Gauging","CEDV cfg","R0","1783","-"
"Fuel Gauging","CEDV cfg","T0","4475","-"
"Fuel Gauging","CEDV cfg","R1","250","-"
"Fuel Gauging","CEDV cfg","TC","3","-"
"Fuel Gauging","CEDV cfg","C1","0","-"
"Fuel Gauging","CEDV cfg","Age Factor","0","-"
"Fuel Gauging","CEDV cfg","Fixed EDV 0","2552","-"
"Fuel Gauging","CEDV cfg","EDV 0 Hold Time","1","s"
"Fuel Gauging","CEDV cfg","Fixed EDV 1","2856","-"
"Fuel Gauging","CEDV cfg","EDV 1 Hold Time","1","s"
"Fuel Gauging","CEDV cfg","Fixed EDV 2","3057","-"
"Fuel Gauging","CEDV cfg","EDV 2 Hold Time","1","s"
"Fuel Gauging","CEDV cfg","Battery Low %","7.00","%"
"Fuel Gauging","CEDV cfg","Min Delta V Filter","10","mV"
"Fuel Gauging","CEDV cfg","FCC Learn Up","256","mAh"
"Fuel Gauging","CEDV cfg","FCC Learn Down","128","mAh"
"Fuel Gauging","CEDV cfg","Learning Low Temp","119","0.1degC"
"Fuel Gauging","CEDV cfg","Requested Learning cycle count","20","num"
"Fuel Gauging","CEDV cfg","OverLoad Current","2500","mA"
"Fuel Gauging","CEDV cfg","Self Discharge Rate","20","0.01%/day"
"Fuel Gauging","CEDV cfg","Electronics Load","0","3uA"
"Fuel Gauging","CEDV cfg","Near Full","100","mAh"
"Fuel Gauging","CEDV cfg","Reserve Capacity","0","mAh"
"Fuel Gauging","CEDV cfg","RemCap Init Percent","100","%"
我还没有适当的 CEDV 补偿值可供使用、因此我尝试使用 GG 中设置的 EDV0、EDV1和 EDV2值、以便在测试期间获得大致准确的 RSOC。 根据应用手册、我认为我的 CEDV 配置应该能够做到这一点。
当电池电压为3057mV 时、我希望 RSOC 设置为7%。 相反、当电池电压接近3600mV 时、它会将自身设置为7%。 为什么忽略我的 EDVn 值?
    您好、Greg、
    我需要查看一个日志文件来了解正在发生的情况。 在日志文件中、最好监测电池电压、待定 EDV 和显示 EDV 检测位的监测状态寄存器。 如果 SOC 突然跳至7%、则可能表示 EDV 是原因、但如果它根据库仑计数提前达到7%、则可能是容量和电流配置设置的问题。
    Matt
    这是日志文件。 在5032行、RSOC 从58%跃升至7%
    25,5/26/2021 19:14,100.229,0.03,701,300,10,6001,0,65535,65535,1,24,28813,0,-1,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.7,963,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    26,5/26/2021 19:14,104.245,0.03,701,300,10,6001,0,65535,65535,1,24,28816,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4120,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.7,959,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    27,5/26/2021 19:14,108.251,0.03,701,300,10,6001,0,65535,65535,1,24,28814,0,-1,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4120,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.7,939,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    28,5/26/2021 19:14,112.261,0.03,701,300,10,6001,0,65535,65535,1,24,28814,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4120,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.5,961,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    29,5/26/2021 19:14,116.266,0.03,701,300,10,6001,0,65535,65535,1,24,28812,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4120,4125,4126,4123,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.7,939,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    30,5/26/2021 19:14,120.272,0.03,701,300,10,6001,0,65535,65535,1,24,28814,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.7,932,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    31,5/26/2021 19:14,124.275,0.03,701,300,10,6001,0,65535,65535,1,24,28813,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.6,965,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    32,5/26/2021 19:14,128.283,0.04,701,300,10,6001,0,65535,65535,1,24,28813,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.7,955,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    33,5/26/2021 19:14,132.294,0.04,701,300,10,6001,0,65535,65535,1,24,28814,0,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4125,4126,4122,4107,4110,4104,0,0,0,0,0,0,0,0,2879,23.7,24,-273.2,24,-273.2,23.8,960,SUCCESS,,3887.995546,64,0,0.1,0.2,0.3,263,1.4,1.5
    34,5/26/2021 19:15,136.31,0.04,701,300,10,6001,0,65535,65535,1,24,28809,-15,0,100,100,12,3888,3888,65535,65535,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4124,4125,4122,4106,4109,4103,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.7,958,SUCCESS,,3887.978812,64,0,0.1,0.2,0.3,263,1.4,1.5
    35,5/26/2021 19:15,140.315,0.04,701,300,10,6001,0,65535,65535,1,24,28808,-17,-5,100,100,12,3888,3888,13722,46656,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4124,4125,4122,4106,4110,4103,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.7,958,SUCCESS,,3887.9599,64,0,0.1,0.2,0.3,263,1.4,1.5
    36,5/26/2021 19:15,144.32,0.04,701,300,10,6001,0,65535,65535,1,24,28808,-17,-8,100,100,12,3888,3888,11109,29160,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4124,4125,4122,4106,4109,4103,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.4,963,SUCCESS,,3887.940987,64,0,0.1,0.2,0.3,263,1.4,1.5
    37,5/26/2021 19:15,148.328,0.04,701,300,10,6001,0,65535,65535,1,24,28808,-19,-10,100,100,12,3888,3888,11109,23328,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4119,4124,4125,4122,4106,4109,4103,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.8,939,SUCCESS,,3887.919834,64,0,0.1,0.2,0.3,263,1.4,1.5
    38,5/26/2021 19:15,152.343,0.04,701,300,10,6001,0,65535,65535,1,24,28803,-23,-13,100,100,12,3888,3888,10143,17945,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4118,4123,4125,4121,4105,4109,4103,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.8,940,SUCCESS,,3887.894183,64,0,0.1,0.2,0.3,263,1.4,1.5
    39,5/26/2021 19:15,156.349,0.04,701,300,10,6001,0,65535,65535,1,24,28802,-28,-16,100,100,12,3888,3888,8972,14580,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4118,4123,4124,4121,4105,4108,4102,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.8,972,SUCCESS,,3887.863025,64,0,0.1,0.2,0.3,263,1.4,1.5
    40,5/26/2021 19:15,160.353,0.04,701,300,10,6001,0,65535,65535,1,24,28799,-36,-21,100,100,12,3888,3888,5832,11109,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4118,4123,4124,4120,4105,4108,4102,0,0,0,0,0,0,0,0,2879,23.8,24,-273.2,24,-273.2,23.8,969,SUCCESS,,3887.822985,64,0,0.1,0.2,0.3,263,1.4,1.5
    41,5/26/2021 19:15,164.365,0.05,701,300,10,6001,0,65535,65535,1,24,28797,-47,-25,100,100,12,3888,3888,5554,9331,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4117,4123,4124,4120,4104,4108,4102,0,0,0,0,0,0,0,0,2876,23.8,24,-273.2,24,-273.2,23.7,987,SUCCESS,,3887.770606,64,0,0.1,0.2,0.3,263,1.4,1.5
    42,5/26/2021 19:15,168.38,0.05,701,300,10,6001,0,65535,65535,1,24,28797,-47,-30,100,100,12,3888,3888,4963,7776,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4117,4122,4124,4120,4104,4108,4102,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,950,SUCCESS,,3887.718188,64,0,0.1,0.2,0.3,263,1.4,1.5
    43,5/26/2021 19:15,172.391,0.05,701,300,10,6001,0,65535,65535,1,24,28796,-57,-34,100,100,12,3888,3888,4761,6861,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4117,4122,4124,4120,4104,4107,4101,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.8,940,SUCCESS,,3887.65468,64,0,0.1,0.2,0.3,263,1.4,1.5
    44,5/26/2021 19:15,176.396,0.05,701,300,10,6001,0,65535,65535,1,24,28792,-66,-40,100,100,12,3888,3888,3645,5554,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4116,4122,4123,4119,4103,4107,4101,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,972,SUCCESS,,3887.581255,64,0,0.1,0.2,0.3,263,1.4,1.5
    45,5/26/2021 19:15,180.41,0.05,701,300,10,6001,0,65535,65535,1,24,28789,-81,-49,100,100,12,3888,3888,2880,4761,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,10,0,0,0,0,4116,4121,4122,4119,4103,4106,4100,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.6,950,SUCCESS,,3887.49094,64,0,0.1,0.2,0.3,263,1.4,1.5
    46,5/26/2021 19:15,184.417,0.05,701,300,10,6001,0,65535,65535,1,24,28783,-87,-57,100,100,12,3887,3888,2681,4092,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,0,0,0,0,0,4115,4120,4122,4118,4102,4106,4100,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.8,950,SUCCESS,,3887.394104,64,0,0.1,0.2,0.3,263,1.4,1.5
    47,5/26/2021 19:15,188.426,0.05,701,300,10,6001,0,65535,65535,1,24,28781,-93,-65,100,100,12,3887,3888,2508,3588,65535,3000,28875,4.00E+01,0,3097,12,107,0,4,82,4A,8006,0,0,0,0,0,0,0,4115,4120,4121,4117,4102,4105,4099,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.8,935,SUCCESS,,3887.290539,64,0,0.1,0.2,0.3,263,1.4,1.5
    48,5/26/2021 19:15,192.429,0.05,701,300,10,6001,0,65535,65535,1,24,28778,-96,-100,100,100,12,3887,3888,2429,2332,65535,3000,28875,4.00E+01,0,3660,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4114,4119,4121,4117,4102,4105,4099,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,965,SUCCESS,,3887.183792,64,0,0.1,0.2,0.3,263,1.4,1.5
    49,5/26/2021 19:16,196.441,0.05,701,300,10,6001,0,65535,65535,1,24,28774,-108,-101,100,100,12,3887,3888,2159,2309,65535,3000,28875,4.00E+01,0,3659,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4114,4119,4120,4117,4101,4104,4099,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.8,957,SUCCESS,,3887.063432,64,0,0.1,0.2,0.3,263,1.4,1.5
    50,5/26/2021 19:16,200.443,0.06,701,300,10,6001,0,65535,65535,1,24,28776,-119,-103,100,100,12,3887,3888,1960,2264,65535,3000,28875,4.00E+01,0,3657,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4113,4119,4120,4116,4100,4104,4098,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.8,950,SUCCESS,,3886.931144,64,0,0.1,0.2,0.3,263,1.4,1.5
    51,5/26/2021 19:16,204.451,0.06,701,300,10,6001,0,65535,65535,1,24,28768,-119,-107,100,100,12,3887,3888,1960,2180,65535,3000,28875,4.00E+01,0,3657,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4113,4118,4120,4116,4100,4104,4098,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,970,SUCCESS,,3886.798657,64,0,0.1,0.2,0.3,263,1.4,1.5
    52,5/26/2021 19:16,208.455,0.06,701,300,10,6001,0,65535,65535,1,24,28767,-125,-110,100,100,12,3887,3888,1866,2120,65535,3000,28875,4.00E+01,0,3657,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4113,4118,4119,4116,4100,4104,4098,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,938,SUCCESS,,3886.659629,64,0,0.1,0.2,0.3,263,1.4,1.5
    53,5/26/2021 19:16,212.456,0.06,701,300,10,6001,0,65535,65535,1,24,28763,-136,-115,100,100,12,3887,3888,1715,2028,65535,3000,28875,4.00E+01,0,3656,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4112,4117,4119,4115,4099,4103,4097,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,938,SUCCESS,,3886.50848,64,0,0.1,0.2,0.3,263,1.4,1.5
    54,5/26/2021 19:16,216.469,0.06,701,300,10,6001,0,65535,65535,1,24,28762,-138,-120,100,100,12,3886,3888,1690,1943,65535,3000,28875,4.00E+01,0,3655,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4112,4117,4119,4115,4099,4103,4097,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.8,939,SUCCESS,,3886.354649,64,0,0.1,0.2,0.3,263,1.4,1.5
    55,5/26/2021 19:16,220.469,0.06,701,300,10,6001,0,65535,65535,1,24,28759,-147,-126,100,100,12,3886,3888,1586,1850,65535,3000,28875,4.00E+01,0,3654,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4112,4117,4118,4114,4099,4101,4096,0,0,0,0,0,0,0,0,2875,23.8,24,-273.2,24,-273.2,23.7,939,SUCCESS,,3886.191315,64,0,0.1,0.2,0.3,263,1.4,1.5
    56,5/26/2021 19:16,224.482,0.06,701,300,10,6001,0,65535,65535,1,24,28755,-157,-133,100,100,12,3886,3888,1448,1753,65535,3000,28875,4.00E+01,0,3653,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4111,4116,4117,4114,4098,4101,4096,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,946,SUCCESS,,3886.016304,64,0,0.1,0.2,0.3,263,1.4,1.5
    57,5/26/2021 19:16,228.492,0.06,701,300,10,6001,0,65535,65535,1,24,28749,-166,-140,100,100,12,3886,3888,1405,1665,65535,3000,28875,4.00E+01,0,3652,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4110,4116,4117,4113,4098,4101,4095,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,932,SUCCESS,,3885.831398,64,0,0.1,0.2,0.3,263,1.4,1.5
    58,5/26/2021 19:16,232.495,0.06,701,300,10,6001,0,65535,65535,1,24,28746,-179,-148,100,100,12,3886,3888,1303,1575,65535,3000,28875,4.00E+01,0,3651,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4110,4115,4116,4113,4097,4099,4094,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,964,SUCCESS,,3885.63236,64,0,0.1,0.2,0.3,263,1.4,1.5
    59,5/26/2021 19:16,236.5,0.07,701,300,10,6001,0,65535,65535,1,24,28743,-189,-156,100,100,12,3886,3888,1247,1495,65535,3000,28875,4.00E+01,0,3650,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4110,4114,4116,4112,4096,4100,4094,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,941,SUCCESS,,3885.422098,64,0,0.1,0.2,0.3,263,1.4,1.5
    60,5/26/2021 19:16,240.512,0.07,701,300,10,6001,0,65535,65535,1,24,28737,-195,-165,100,100,12,3885,3888,1166,1413,65535,3000,28875,4.00E+01,0,3649,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4109,4114,4115,4111,4096,4099,4093,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.7,946,SUCCESS,,3885.204781,64,0,0.1,0.2,0.3,263,1.4,1.5
    61,5/26/2021 19:16,244.524,0.07,701,300,10,6001,0,65535,65535,1,24,28734,-202,-173,100,100,12,3885,3888,1154,1347,65535,3000,28875,4.00E+01,0,3649,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4108,4113,4114,4111,4095,4099,4093,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.7,965,SUCCESS,,3884.979663,64,0,0.1,0.2,0.3,263,1.4,1.5
    62,5/26/2021 19:16,248.538,0.07,701,300,10,6001,0,65535,65535,1,24,28730,-215,-181,100,100,12,3885,3888,1100,1288,65535,3000,28875,4.00E+01,0,3647,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4108,4113,4114,4110,4095,4098,4092,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,953,SUCCESS,,3884.739938,64,0,0.1,0.2,0.3,263,1.4,1.5
    63,5/26/2021 19:16,252.551,0.07,701,300,10,6001,0,65535,65535,1,24,28724,-225,-190,100,100,12,3885,3888,1064,1227,65535,3000,28875,4.00E+01,0,3647,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4107,4112,4114,4110,4094,4097,4091,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,985,SUCCESS,,3884.489126,64,0,0.1,0.2,0.3,263,1.4,1.5
    64,5/26/2021 19:17,256.553,0.07,701,300,10,6001,0,65535,65535,1,24,28723,-236,-199,100,100,12,3884,3888,1027,1171,65535,3000,28875,4.00E+01,0,3645,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4107,4111,4113,4109,4093,4097,4091,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,980,SUCCESS,,3884.226773,64,0,0.1,0.2,0.3,263,1.4,1.5
    65,5/26/2021 19:17,260.567,0.07,701,300,10,6001,0,65535,65535,1,24,28716,-242,-209,100,100,12,3884,3888,979,1115,65535,3000,28875,4.00E+01,0,3644,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4105,4110,4112,4109,4093,4096,4090,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.8,981,SUCCESS,,3883.956943,64,0,0.1,0.2,0.3,263,1.4,1.5
    66,5/26/2021 19:17,264.571,0.07,701,300,10,6001,0,65535,65535,1,24,28714,-250,-218,100,100,12,3884,3888,940,1069,65535,3000,28875,4.00E+01,0,3643,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4105,4110,4112,4108,4091,4095,4090,0,0,0,0,0,0,0,0,2870,23.8,24,-273.2,24,-273.2,23.7,963,SUCCESS,,3883.678887,64,0,0.1,0.2,0.3,263,1.4,1.5
    67,5/26/2021 19:17,268.579,0.07,701,300,10,6001,0,65535,65535,1,24,28711,-259,-227,100,100,12,3884,3888,900,1027,65535,3000,28875,4.00E+01,0,3642,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4105,4109,4111,4107,4091,4099,4089,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.4,970,SUCCESS,,3883.390534,64,0,0.1,0.2,0.3,263,1.4,1.5
    68,5/26/2021 19:17,272.589,0.08,701,300,10,6001,0,65535,65535,1,24,28705,-268,-237,100,100,12,3883,3888,869,983,65535,3000,28875,4.00E+01,0,3641,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4104,4109,4111,4107,4091,4095,4089,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,960,SUCCESS,,3883.092011,64,0,0.1,0.2,0.3,263,1.4,1.5
    69,5/26/2021 19:17,276.59,0.08,701,300,10,6001,0,65535,65535,1,24,28702,-278,-246,100,100,12,3883,3888,838,947,65535,3000,28875,4.00E+01,0,3640,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4103,4108,4110,4107,4091,4093,4088,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,960,SUCCESS,,3882.783045,64,0,0.1,0.2,0.3,263,1.4,1.5
    70,5/26/2021 19:17,280.598,0.08,701,300,10,6001,0,65535,65535,1,24,28699,-285,-255,100,100,12,3883,3888,812,914,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4103,4108,4110,4106,4090,4094,4088,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,935,SUCCESS,,3882.465745,64,0,0.1,0.2,0.3,263,1.4,1.5
    71,5/26/2021 19:17,284.598,0.08,701,300,10,6001,0,65535,65535,1,24,28695,-287,-263,100,100,12,3882,3888,817,886,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4103,4107,4109,4105,4089,4093,4086,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,966,SUCCESS,,3882.146856,64,0,0.1,0.2,0.3,263,1.4,1.5
    72,5/26/2021 19:17,288.6,0.08,701,300,10,6001,0,65535,65535,1,24,28691,-298,-271,100,100,12,3882,3888,776,859,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4102,4107,4109,4105,4089,4090,4086,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,964,SUCCESS,,3881.81558,64,0,0.1,0.2,0.3,263,1.4,1.5
    73,5/26/2021 19:17,292.605,0.08,701,300,10,6001,0,65535,65535,1,24,28690,-298,-278,100,100,12,3882,3888,782,838,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4102,4107,4108,4105,4089,4092,4086,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,950,SUCCESS,,3881.484055,64,0,0.1,0.2,0.3,263,1.4,1.5
    74,5/26/2021 19:17,296.609,0.08,701,300,10,6001,0,65535,65535,1,24,28688,-296,-282,100,100,12,3881,3888,781,826,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4101,4106,4108,4104,4089,4092,4086,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,941,SUCCESS,,3881.154837,64,0,0.1,0.2,0.3,263,1.4,1.5
    75,5/26/2021 19:17,300.613,0.08,701,300,10,6001,0,65535,65535,1,24,28686,-298,-286,100,100,12,3881,3888,776,814,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4102,4106,4108,4104,4088,4092,4086,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,937,SUCCESS,,3880.823395,64,0,0.1,0.2,0.3,263,1.4,1.5
    76,5/26/2021 19:17,304.63,0.08,701,300,10,6001,0,65535,65535,1,24,28685,-296,-289,100,100,12,3881,3888,781,806,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4101,4106,4108,4104,4088,4092,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.4,992,SUCCESS,,3880.493108,64,0,0.1,0.2,0.3,263,1.4,1.5
    77,5/26/2021 19:17,308.645,0.09,701,300,10,6001,0,65535,65535,1,24,28682,-300,-291,100,100,12,3880,3888,781,800,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4101,4106,4107,4104,4088,4092,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,966,SUCCESS,,3880.158525,64,0,0.1,0.2,0.3,263,1.4,1.5
    78,5/26/2021 19:17,312.651,0.09,701,300,10,6001,0,65535,65535,1,24,28681,-298,-293,100,100,12,3880,3888,781,795,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4101,4105,4107,4103,4088,4091,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,952,SUCCESS,,3879.826917,64,0,0.1,0.2,0.3,263,1.4,1.5
    79,5/26/2021 19:18,316.661,0.09,701,300,10,6001,0,65535,65535,1,24,28679,-298,-294,100,100,12,3880,3888,781,792,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4100,4105,4107,4103,4088,4091,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,957,SUCCESS,,3879.494978,64,0,0.1,0.2,0.3,263,1.4,1.5
    80,5/26/2021 19:18,320.668,0.09,701,300,10,6001,0,65535,65535,1,24,28679,-300,-295,100,100,12,3879,3888,776,789,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4100,4105,4107,4103,4087,4091,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,964,SUCCESS,,3879.161061,64,0,0.1,0.2,0.3,263,1.4,1.5
    81,5/26/2021 19:18,324.679,0.09,701,300,10,6001,0,65535,65535,1,24,28678,-298,-296,100,100,12,3879,3888,781,786,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4100,4105,4107,4103,4087,4091,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,962,SUCCESS,,3878.82904,64,0,0.1,0.2,0.3,263,1.4,1.5
    82,5/26/2021 19:18,328.686,0.09,701,300,10,6001,0,65535,65535,1,24,28677,-298,-296,100,100,12,3879,3888,781,786,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4100,4105,4107,4103,4087,4091,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,962,SUCCESS,,3878.497349,64,0,0.1,0.2,0.3,263,1.4,1.5
    83,5/26/2021 19:18,332.695,0.09,701,300,10,6001,0,65535,65535,1,24,28677,-300,-297,100,100,12,3878,3888,776,783,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4100,4105,4107,4103,4087,4091,4085,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,956,SUCCESS,,3878.163266,64,0,0.1,0.2,0.3,263,1.4,1.5
    84,5/26/2021 19:18,336.697,0.09,701,300,10,6001,0,65535,65535,1,24,28676,-298,-297,100,100,12,3878,3888,781,783,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4100,4105,4107,4103,4086,4090,4084,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,1015,SUCCESS,,3877.831989,64,0,0.1,0.2,0.3,263,1.4,1.5
    85,5/26/2021 19:18,340.712,0.09,701,300,10,6001,0,65535,65535,1,24,28672,-298,-297,100,100,12,3878,3888,781,783,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4104,4106,4102,4086,4090,4084,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,986,SUCCESS,,3877.499636,64,0,0.1,0.2,0.3,263,1.4,1.5
    86,5/26/2021 19:18,344.72,0.1,701,300,10,6001,0,65535,65535,1,24,28671,-300,-298,100,100,12,3877,3888,775,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4104,4106,4102,4086,4090,4083,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,943,SUCCESS,,3877.165636,64,0,0.1,0.2,0.3,263,1.4,1.5
    87,5/26/2021 19:18,348.735,0.1,701,300,10,6001,0,65535,65535,1,24,28669,-298,-298,100,100,12,3877,3888,781,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4104,4105,4102,4086,4090,4084,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,958,SUCCESS,,3876.833284,64,0,0.1,0.2,0.3,263,1.4,1.5
    88,5/26/2021 19:18,352.736,0.1,701,300,10,6001,0,65535,65535,1,24,28669,-300,-298,100,100,12,3877,3888,775,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4103,4105,4102,4086,4090,4083,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,958,SUCCESS,,3876.499867,64,0,0.1,0.2,0.3,263,1.4,1.5
    89,5/26/2021 19:18,356.743,0.1,701,300,10,6001,0,65535,65535,1,24,28667,-298,-298,100,100,12,3876,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4103,4105,4102,4086,4089,4083,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.8,939,SUCCESS,,3876.168176,64,0,0.1,0.2,0.3,263,1.4,1.5
    90,5/26/2021 19:18,360.749,0.1,701,300,10,6001,0,65535,65535,1,24,28668,-298,-298,100,100,12,3876,3888,786,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4103,4105,4102,4086,4089,4083,0,0,0,0,0,0,0,0,2866,23.8,24,-273.2,24,-273.2,23.7,941,SUCCESS,,3875.836569,64,0,0.1,0.2,0.3,263,1.4,1.5
    91,5/26/2021 19:18,364.759,0.1,701,300,10,6001,0,65535,65535,1,24,28666,-296,-298,100,100,12,3876,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4103,4105,4102,4086,4089,4083,0,0,0,0,0,0,0,0,2862,23.8,24,-273.2,24,-273.2,23.8,984,SUCCESS,,3875.506858,64,0,0.1,0.2,0.3,263,1.4,1.5
    92,5/26/2021 19:18,368.77,0.1,701,300,10,6001,0,65535,65535,1,24,28666,-298,-298,100,100,12,3875,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4098,4103,4105,4101,4085,4089,4083,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.7,968,SUCCESS,,3875.174836,64,0,0.1,0.2,0.3,263,1.4,1.5
    93,5/26/2021 19:18,372.78,0.1,701,300,10,6001,0,65535,65535,1,24,28664,-300,-298,100,100,12,3875,3888,775,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4099,4103,4105,4101,4085,4089,4083,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.8,946,SUCCESS,,3874.840669,64,0,0.1,0.2,0.3,263,1.4,1.5
    94,5/26/2021 19:19,376.784,0.1,701,300,10,6001,0,65535,65535,1,24,28664,-298,-298,100,100,12,3875,3888,785,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4098,4103,4105,4101,4085,4089,4083,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.8,952,SUCCESS,,3874.509227,64,0,0.1,0.2,0.3,263,1.4,1.5
    95,5/26/2021 19:19,380.788,0.11,701,300,10,6001,0,65535,65535,1,24,28663,-298,-298,100,100,12,3874,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4098,4103,4104,4101,4085,4089,4082,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.8,987,SUCCESS,,3874.177785,64,0,0.1,0.2,0.3,263,1.4,1.5
    96,5/26/2021 19:19,384.801,0.11,701,300,10,6001,0,65535,65535,1,24,28662,-298,-298,100,100,12,3874,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4098,4102,4104,4101,4085,4089,4082,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.8,950,SUCCESS,,3873.845598,64,0,0.1,0.2,0.3,263,1.4,1.5
    97,5/26/2021 19:19,388.816,0.11,701,300,10,6001,0,65535,65535,1,24,28662,-296,-298,100,100,12,3874,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4098,4102,4104,4101,4085,4088,4082,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.8,939,SUCCESS,,3873.515475,64,0,0.1,0.2,0.3,263,1.4,1.5
    98,5/26/2021 19:19,392.831,0.11,701,300,10,6001,0,65535,65535,1,24,28660,-298,-298,100,100,12,3873,3888,785,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4098,4102,4104,4100,4084,4088,4082,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.7,968,SUCCESS,,3873.183123,64,0,0.1,0.2,0.3,263,1.4,1.5
    99,5/26/2021 19:19,396.837,0.11,701,300,10,6001,0,65535,65535,1,24,28658,-298,-298,100,100,12,3873,3888,785,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4102,4103,4100,4084,4088,4082,0,0,0,0,0,0,0,0,2861,23.8,24,-273.2,24,-273.2,23.2,956,SUCCESS,,3872.851515,64,0,0.1,0.2,0.3,263,1.4,1.5
    100,5/26/2021 19:19,400.841,0.11,701,300,10,6001,0,65535,65535,1,24,28657,-296,-298,100,100,12,3873,3888,785,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4102,4104,4100,4084,4088,4082,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.8,983,SUCCESS,,3872.522297,64,0,0.1,0.2,0.3,263,1.4,1.5
    101,5/26/2021 19:19,404.855,0.11,701,300,10,6001,0,65535,65535,1,24,28657,-298,-298,100,100,12,3872,3888,780,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4102,4104,4100,4084,4088,4082,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,965,SUCCESS,,3872.190027,64,0,0.1,0.2,0.3,263,1.4,1.5
    102,5/26/2021 19:19,408.861,0.11,701,300,10,6001,0,65535,65535,1,24,28655,-300,-298,100,100,12,3872,3888,769,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4102,4103,4100,4083,4087,4082,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,945,SUCCESS,,3871.856194,64,0,0.1,0.2,0.3,263,1.4,1.5
    103,5/26/2021 19:19,412.874,0.11,701,300,10,6001,0,65535,65535,1,24,28655,-298,-298,100,100,12,3872,3888,785,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4102,4103,4100,4083,4088,4082,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,963,SUCCESS,,3871.524006,64,0,0.1,0.2,0.3,263,1.4,1.5
    104,5/26/2021 19:19,416.878,0.12,701,300,10,6001,0,65535,65535,1,24,28654,-298,-298,100,100,12,3871,3888,779,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4101,4103,4100,4083,4088,4081,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,943,SUCCESS,,3871.192564,64,0,0.1,0.2,0.3,263,1.4,1.5
    105,5/26/2021 19:19,420.884,0.12,701,300,10,6001,0,65535,65535,1,24,28653,-298,-298,100,100,12,3871,3888,779,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4101,4103,4100,4082,4088,4081,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,982,SUCCESS,,3870.860956,64,0,0.1,0.2,0.3,263,1.4,1.5
    106,5/26/2021 19:19,424.891,0.12,701,300,10,6001,0,65535,65535,1,24,28651,-298,-298,100,100,12,3871,3888,785,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4101,4103,4100,4082,4088,4081,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,943,SUCCESS,,3870.529266,64,0,0.1,0.2,0.3,263,1.4,1.5
    107,5/26/2021 19:19,428.899,0.12,701,300,10,6001,0,65535,65535,1,24,28651,-298,-298,100,100,12,3870,3888,779,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4101,4103,4099,4082,4088,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,22.9,1003,SUCCESS,,3870.197493,64,0,0.1,0.2,0.3,263,1.4,1.5
    108,5/26/2021 19:20,432.905,0.12,701,300,10,6001,0,65535,65535,1,24,28650,-296,-298,100,100,12,3870,3888,779,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4101,4103,4099,4082,4087,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,944,SUCCESS,,3869.86811,64,0,0.1,0.2,0.3,263,1.4,1.5
    109,5/26/2021 19:20,436.907,0.12,701,300,10,6001,0,65535,65535,1,24,28649,-298,-298,100,100,12,3870,3888,779,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4097,4101,4103,4099,4082,4087,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,942,SUCCESS,,3869.536834,64,0,0.1,0.2,0.3,263,1.4,1.5
    110,5/26/2021 19:20,440.91,0.12,701,300,10,6001,0,65535,65535,1,24,28648,-298,-298,100,100,12,3869,3888,779,779,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4101,4103,4099,4082,4087,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.8,965,SUCCESS,,3869.205474,64,0,0.1,0.2,0.3,263,1.4,1.5
    111,5/26/2021 19:20,444.924,0.12,701,300,10,6001,0,65535,65535,1,24,28648,-296,-297,100,100,12,3869,3888,779,782,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4101,4102,4099,4082,4087,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,954,SUCCESS,,3868.875434,64,0,0.1,0.2,0.3,263,1.4,1.5
    112,5/26/2021 19:20,448.929,0.12,701,300,10,6001,0,65535,65535,1,24,28647,-298,-297,100,100,12,3869,3888,784,782,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4099,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,953,SUCCESS,,3868.543909,64,0,0.1,0.2,0.3,263,1.4,1.5
    113,5/26/2021 19:20,452.933,0.13,701,300,10,6001,0,65535,65535,1,24,28646,-298,-297,100,100,12,3868,3888,779,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4099,4082,4087,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,952,SUCCESS,,3868.212467,64,0,0.1,0.2,0.3,263,1.4,1.5
    114,5/26/2021 19:20,456.947,0.13,701,300,10,6001,0,65535,65535,1,24,28645,-294,-297,100,100,12,3868,3888,784,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4099,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,982,SUCCESS,,3867.884657,64,0,0.1,0.2,0.3,263,1.4,1.5
    115,5/26/2021 19:20,460.948,0.13,701,300,10,6001,0,65535,65535,1,24,28643,-298,-297,100,100,12,3868,3888,779,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4099,4082,4087,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,945,SUCCESS,,3867.553463,64,0,0.1,0.2,0.3,263,1.4,1.5
    116,5/26/2021 19:20,464.953,0.13,701,300,10,6001,0,65535,65535,1,24,28644,-296,-297,100,100,12,3867,3888,784,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4099,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.4,998,SUCCESS,,3867.224163,64,0,0.1,0.2,0.3,263,1.4,1.5
    117,5/26/2021 19:20,468.96,0.13,701,300,10,6001,0,65535,65535,1,24,28645,-298,-297,100,100,12,3867,3888,779,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4099,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,23.9,-273.2,23.9,-273.2,23.7,935,SUCCESS,,3866.892473,64,0,0.1,0.2,0.3,263,1.4,1.5
    118,5/26/2021 19:20,472.971,0.13,701,300,10,6001,0,65535,65535,1,24,28643,-298,-297,100,100,12,3867,3888,779,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4096,4100,4102,4098,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,24,-273.2,24,-273.2,23.7,969,SUCCESS,,3866.560451,64,0,0.1,0.2,0.3,263,1.4,1.5
    119,5/26/2021 19:20,476.975,0.13,701,300,10,6001,0,65535,65535,1,23.9,28644,-298,-297,100,100,12,3866,3888,778,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4100,4102,4098,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,23.9,-273.2,23.9,-273.2,23.7,986,SUCCESS,,3866.229009,64,0,0.1,0.2,0.3,263,1.4,1.5
    120,5/26/2021 19:20,480.98,0.13,701,300,10,6001,0,65535,65535,1,23.9,28643,-298,-297,100,100,12,3866,3888,778,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4100,4102,4098,4082,4086,4080,0,0,0,0,0,0,0,0,2861,23.7,23.9,-273.2,23.9,-273.2,23.6,972,SUCCESS,,3865.897484,64,0,0.1,0.2,0.3,263,1.4,1.5
    121,5/26/2021 19:20,484.992,0.13,701,300,10,6001,0,65535,65535,1,23.9,28643,-298,-297,100,100,12,3866,3888,778,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4100,4101,4098,4082,4086,4079,0,0,0,0,0,0,0,0,2861,23.7,23.9,-273.2,23.9,-273.2,23.7,971,SUCCESS,,3865.565379,64,0,0.1,0.2,0.3,263,1.4,1.5
    122,5/26/2021 19:20,489.004,0.14,701,300,10,6001,0,65535,65535,1,23.9,28640,-296,-297,100,100,12,3865,3888,783,781,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4099,4101,4098,4082,4086,4079,0,0,0,0,0,0,0,0,2861,23.7,23.9,-273.2,23.9,-273.2,23.6,961,SUCCESS,,3865.235504,64,0,0.1,0.2,0.3,263,1.4,1.5
    123,5/26/2021 19:21,493.007,0.14,701,300,10,6001,0,65535,65535,1,23.9,28640,-300,-298,100,100,12,3865,3888,773,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4099,4101,4098,4082,4086,4079,0,0,0,0,0,0,0,0,2861,23.7,23.9,-273.2,23.9,-273.2,23.6,954,SUCCESS,,3864.90192,64,0,0.1,0.2,0.3,263,1.4,1.5
    124,5/26/2021 19:21,497.014,0.14,701,300,10,6001,0,65535,65535,1,23.8,28639,-298,-298,100,100,12,3865,3888,778,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4101,4097,4082,4086,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,963,SUCCESS,,3864.57023,64,0,0.1,0.2,0.3,263,1.4,1.5
    125,5/26/2021 19:21,501.022,0.14,701,300,10,6001,0,65535,65535,1,23.8,28640,-300,-298,100,100,12,3864,3888,773,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4099,4101,4097,4082,4086,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.7,1001,SUCCESS,,3864.23623,64,0,0.1,0.2,0.3,263,1.4,1.5
    126,5/26/2021 19:21,505.023,0.14,701,300,10,6001,0,65535,65535,1,23.8,28637,-300,-298,100,100,12,3864,3888,773,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4095,4099,4101,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,954,SUCCESS,,3863.902813,64,0,0.1,0.2,0.3,263,1.4,1.5
    127,5/26/2021 19:21,509.027,0.14,701,300,10,6001,0,65535,65535,1,23.8,28637,-298,-298,100,100,12,3864,3888,783,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4100,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,981,SUCCESS,,3863.571371,64,0,0.1,0.2,0.3,263,1.4,1.5
    128,5/26/2021 19:21,513.038,0.14,701,300,10,6001,0,65535,65535,1,23.8,28636,-300,-298,100,100,12,3863,3888,778,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4100,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.7,970,SUCCESS,,3863.237121,64,0,0.1,0.2,0.3,263,1.4,1.5
    129,5/26/2021 19:21,517.039,0.14,701,300,10,6001,0,65535,65535,1,23.8,28636,-300,-298,100,100,12,3863,3888,778,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4101,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.7,978,SUCCESS,,3862.903704,64,0,0.1,0.2,0.3,263,1.4,1.5
    130,5/26/2021 19:21,521.054,0.14,701,300,10,6001,0,65535,65535,1,23.8,28636,-294,-297,100,100,12,3863,3888,783,780,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4100,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,22.9,959,SUCCESS,,3862.575813,64,0,0.1,0.2,0.3,263,1.4,1.5
    131,5/26/2021 19:21,525.068,0.15,701,300,10,6001,0,65535,65535,1,23.8,28636,-296,-298,100,100,12,3862,3888,778,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4100,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,942,SUCCESS,,3862.245773,64,0,0.1,0.2,0.3,263,1.4,1.5
    132,5/26/2021 19:21,529.083,0.15,701,300,10,6001,0,65535,65535,1,23.8,28635,-296,-298,100,100,12,3862,3888,783,778,65535,3000,28875,4.00E+01,0,3638,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4100,4097,4082,4085,4079,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,951,SUCCESS,,3861.91565,64,0,0.1,0.2,0.3,263,1.4,1.5
    133,5/26/2021 19:21,533.085,0.15,701,300,10,6001,0,65535,65535,1,23.8,28635,-298,-297,100,100,12,3862,3888,778,780,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4099,4100,4097,4082,4085,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,954,SUCCESS,,3861.584374,64,0,0.1,0.2,0.3,263,1.4,1.5
    134,5/26/2021 19:21,537.099,0.15,701,300,10,6001,0,65535,65535,1,23.8,28635,-300,-297,100,100,12,3861,3888,777,780,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4098,4100,4097,4082,4085,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,967,SUCCESS,,3861.249874,64,0,0.1,0.2,0.3,263,1.4,1.5
    135,5/26/2021 19:21,541.105,0.15,701,300,10,6001,0,65535,65535,1,23.8,28634,-296,-298,100,100,12,3861,3888,777,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4098,4100,4097,4082,4086,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,960,SUCCESS,,3860.920491,64,0,0.1,0.2,0.3,263,1.4,1.5
    136,5/26/2021 19:21,545.106,0.15,701,300,10,6001,0,65535,65535,1,23.8,28634,-298,-297,100,100,12,3861,3888,777,780,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4098,4100,4097,4082,4085,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,943,SUCCESS,,3860.589298,64,0,0.1,0.2,0.3,263,1.4,1.5
    137,5/26/2021 19:21,549.119,0.15,701,300,10,6001,0,65535,65535,1,23.8,28633,-298,-297,100,100,12,3860,3888,777,780,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4098,4100,4096,4082,4084,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,967,SUCCESS,,3860.25711,64,0,0.1,0.2,0.3,263,1.4,1.5
    138,5/26/2021 19:22,553.128,0.15,701,300,10,6001,0,65535,65535,1,23.8,28633,-296,-297,100,100,12,3860,3888,782,780,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4098,4100,4096,4082,4089,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.5,939,SUCCESS,,3859.927481,64,0,0.1,0.2,0.3,263,1.4,1.5
    139,5/26/2021 19:22,557.137,0.15,701,300,10,6001,0,65535,65535,1,23.8,28631,-298,-297,100,100,12,3860,3888,777,780,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4094,4098,4099,4096,4082,4084,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.7,959,SUCCESS,,3859.595625,64,0,0.1,0.2,0.3,263,1.4,1.5
    140,5/26/2021 19:22,561.137,0.16,701,300,10,6001,0,65535,65535,1,23.8,28630,-298,-298,100,100,12,3859,3888,777,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4084,4078,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,943,SUCCESS,,3859.264514,64,0,0.1,0.2,0.3,263,1.4,1.5
    141,5/26/2021 19:22,565.143,0.16,701,300,10,6001,0,65535,65535,1,23.8,28629,-296,-298,100,100,12,3859,3888,782,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4098,4099,4096,4082,4084,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,951,SUCCESS,,3858.935132,64,0,0.1,0.2,0.3,263,1.4,1.5
    142,5/26/2021 19:22,569.157,0.16,701,300,10,6001,0,65535,65535,1,23.8,28628,-300,-298,100,100,12,3859,3888,772,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4084,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.7,969,SUCCESS,,3858.600632,64,0,0.1,0.2,0.3,263,1.4,1.5
    143,5/26/2021 19:22,573.168,0.16,701,300,10,6001,0,65535,65535,1,23.8,28628,-298,-298,100,100,12,3858,3888,777,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4081,4080,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,950,SUCCESS,,3858.26861,64,0,0.1,0.2,0.3,263,1.4,1.5
    144,5/26/2021 19:22,577.175,0.16,701,300,10,6001,0,65535,65535,1,23.8,28627,-298,-297,100,100,12,3858,3888,782,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4084,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,974,SUCCESS,,3857.93692,64,0,0.1,0.2,0.3,263,1.4,1.5
    145,5/26/2021 19:22,581.189,0.16,701,300,10,6001,0,65535,65535,1,23.8,28628,-300,-297,100,100,12,3858,3888,777,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4084,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,938,SUCCESS,,3857.60242,64,0,0.1,0.2,0.3,263,1.4,1.5
    146,5/26/2021 19:22,585.205,0.16,701,300,10,6001,0,65535,65535,1,23.8,28629,-296,-297,100,100,12,3857,3888,782,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4085,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23.6,945,SUCCESS,,3857.272215,64,0,0.1,0.2,0.3,263,1.4,1.5
    147,5/26/2021 19:22,589.212,0.16,701,300,10,6001,0,65535,65535,1,23.8,28628,-298,-297,100,100,12,3857,3888,777,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4095,4082,4083,4077,0,0,0,0,0,0,0,0,2861,23.7,23.8,-273.2,23.8,-273.2,23,1026,SUCCESS,,3856.940525,64,0,0.1,0.2,0.3,263,1.4,1.5
    148,5/26/2021 19:22,593.225,0.16,701,300,10,6001,0,65535,65535,1,23.8,28628,-298,-297,100,100,12,3857,3888,777,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4084,4077,0,0,0,0,0,0,0,0,2861,23.6,23.8,-273.2,23.8,-273.2,23.6,985,SUCCESS,,3856.608338,64,0,0.1,0.2,0.3,263,1.4,1.5
    149,5/26/2021 19:22,597.237,0.17,701,300,10,6001,0,65535,65535,1,23.8,28626,-296,-297,100,100,12,3856,3888,782,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4096,4082,4085,4077,0,0,0,0,0,0,0,0,2861,23.6,23.8,-273.2,23.8,-273.2,23.6,953,SUCCESS,,3856.278462,64,0,0.1,0.2,0.3,263,1.4,1.5
    150,5/26/2021 19:22,601.242,0.17,701,300,10,6001,0,65535,65535,1,23.8,28626,-300,-297,100,100,12,3856,3888,782,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4099,4095,4081,4083,4077,0,0,0,0,0,0,0,0,2861,23.6,23.8,-273.2,23.8,-273.2,23.6,984,SUCCESS,,3855.944712,64,0,0.1,0.2,0.3,263,1.4,1.5
    151,5/26/2021 19:22,605.246,0.17,701,300,10,6001,0,65535,65535,1,23.8,28625,-298,-297,100,100,12,3856,3888,782,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4093,4097,4098,4095,4080,4083,4077,0,0,0,0,0,0,0,0,2860,23.6,23.8,-273.2,23.8,-273.2,23.6,965,SUCCESS,,3855.61327,64,0,0.1,0.2,0.3,263,1.4,1.5
    152,5/26/2021 19:22,609.261,0.17,701,300,10,6001,0,65535,65535,1,23.8,28623,-298,-297,100,100,12,3855,3888,776,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4097,4098,4095,4080,4083,4077,0,0,0,0,0,0,0,0,2861,23.6,23.8,-273.2,23.8,-273.2,23.6,943,SUCCESS,,3855.280917,64,0,0.1,0.2,0.3,263,1.4,1.5
    153,5/26/2021 19:23,613.273,0.17,701,300,10,6001,0,65535,65535,1,23.8,28621,-300,-298,100,100,12,3855,3888,771,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4095,4080,4083,4077,0,0,0,0,0,0,0,0,2858,23.6,23.8,-273.2,23.8,-273.2,23.6,1026,SUCCESS,,3854.946584,64,0,0.1,0.2,0.3,263,1.4,1.5
    154,5/26/2021 19:23,617.286,0.17,701,300,10,6001,0,65535,65535,1,23.8,28621,-296,-298,100,100,12,3855,3888,781,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4095,4080,4083,4077,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,935,SUCCESS,,3854.616626,64,0,0.1,0.2,0.3,263,1.4,1.5
    155,5/26/2021 19:23,621.29,0.17,701,300,10,6001,0,65535,65535,1,23.8,28621,-298,-298,100,100,12,3854,3888,776,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4095,4080,4083,4077,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,968,SUCCESS,,3854.285184,64,0,0.1,0.2,0.3,263,1.4,1.5
    156,5/26/2021 19:23,625.3,0.17,701,300,10,6001,0,65535,65535,1,23.8,28620,-298,-298,100,100,12,3854,3888,776,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4095,4080,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,959,SUCCESS,,3853.953245,64,0,0.1,0.2,0.3,263,1.4,1.5
    157,5/26/2021 19:23,629.306,0.17,701,300,10,6001,0,65535,65535,1,23.8,28619,-296,-298,100,100,12,3854,3888,781,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4095,4080,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,951,SUCCESS,,3853.623863,64,0,0.1,0.2,0.3,263,1.4,1.5
    158,5/26/2021 19:23,633.315,0.18,701,300,10,6001,0,65535,65535,1,23.8,28620,-298,-298,100,100,12,3853,3888,776,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4094,4080,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,961,SUCCESS,,3853.292006,64,0,0.1,0.2,0.3,263,1.4,1.5
    159,5/26/2021 19:23,637.322,0.18,701,300,10,6001,0,65535,65535,1,23.8,28618,-296,-298,100,100,12,3853,3888,781,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4097,4094,4080,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.5,964,SUCCESS,,3852.962542,64,0,0.1,0.2,0.3,263,1.4,1.5
    160,5/26/2021 19:23,641.33,0.18,701,300,10,6001,0,65535,65535,1,23.8,28619,-296,-297,100,100,12,3853,3888,781,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4098,4094,4080,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.5,940,SUCCESS,,3852.632995,64,0,0.1,0.2,0.3,263,1.4,1.5
    161,5/26/2021 19:23,645.339,0.18,701,300,10,6001,0,65535,65535,1,23.8,28618,-298,-298,100,100,12,3852,3888,770,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4097,4094,4079,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,981,SUCCESS,,3852.301139,64,0,0.1,0.2,0.3,263,1.4,1.5
    162,5/26/2021 19:23,649.349,0.18,701,300,10,6001,0,65535,65535,1,23.8,28618,-296,-297,100,100,12,3852,3888,781,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4092,4096,4097,4094,4079,4083,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,1005,SUCCESS,,3851.971428,64,0,0.1,0.2,0.3,263,1.4,1.5
    163,5/26/2021 19:23,653.356,0.18,701,300,10,6001,0,65535,65535,1,23.8,28615,-298,-297,100,100,12,3852,3888,781,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4096,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,949,SUCCESS,,3851.639738,64,0,0.1,0.2,0.3,263,1.4,1.5
    164,5/26/2021 19:23,657.364,0.18,701,300,10,6001,0,65535,65535,1,23.8,28616,-298,-297,100,100,12,3851,3888,775,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4096,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,989,SUCCESS,,3851.307964,64,0,0.1,0.2,0.3,263,1.4,1.5
    165,5/26/2021 19:23,661.364,0.18,701,300,10,6001,0,65535,65535,1,23.8,28615,-296,-297,100,100,12,3851,3888,781,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4096,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,956,SUCCESS,,3850.979075,64,0,0.1,0.2,0.3,263,1.4,1.5
    166,5/26/2021 19:23,665.379,0.18,701,300,10,6001,0,65535,65535,1,23.8,28615,-298,-297,100,100,12,3851,3888,775,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4096,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.6,973,SUCCESS,,3850.646723,64,0,0.1,0.2,0.3,263,1.4,1.5
    167,5/26/2021 19:23,669.38,0.19,701,300,10,6001,0,65535,65535,1,23.8,28613,-296,-297,100,100,12,3850,3888,775,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.5,975,SUCCESS,,3850.317751,64,0,0.1,0.2,0.3,263,1.4,1.5
    168,5/26/2021 19:24,673.381,0.19,701,300,10,6001,0,65535,65535,1,23.7,28613,-296,-297,100,100,12,3850,3888,780,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4096,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.8,-273.2,23.8,-273.2,23.5,982,SUCCESS,,3849.98878,64,0,0.1,0.2,0.3,263,1.4,1.5
    169,5/26/2021 19:24,677.388,0.19,701,300,10,6001,0,65535,65535,1,23.7,28614,-298,-297,100,100,12,3850,3888,775,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4097,4094,4079,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,980,SUCCESS,,3849.65709,64,0,0.1,0.2,0.3,263,1.4,1.5
    170,5/26/2021 19:24,681.403,0.19,701,300,10,6001,0,65535,65535,1,23.8,28614,-296,-297,100,99,12,3849,3888,780,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4097,4094,4079,4082,4076,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,959,SUCCESS,,3849.326968,64,0,0.1,0.2,0.3,263,1.4,1.5
    171,5/26/2021 19:24,685.413,0.19,701,300,10,6001,0,65535,65535,1,23.8,28612,-296,-297,100,99,12,3849,3888,775,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4097,4094,4079,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,963,SUCCESS,,3848.997256,64,0,0.1,0.2,0.3,263,1.4,1.5
    172,5/26/2021 19:24,689.418,0.19,701,300,10,6001,0,65535,65535,1,23.7,28613,-294,-297,100,99,12,3849,3888,775,778,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4097,4094,4079,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,964,SUCCESS,,3848.670181,64,0,0.1,0.2,0.3,263,1.4,1.5
    173,5/26/2021 19:24,693.426,0.19,701,300,10,6001,0,65535,65535,1,23.7,28611,-296,-297,100,99,12,3848,3888,780,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4096,4093,4079,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,1008,SUCCESS,,3848.340635,64,0,0.1,0.2,0.3,263,1.4,1.5
    174,5/26/2021 19:24,697.429,0.19,701,300,10,6001,0,65535,65535,1,23.7,28612,-298,-297,100,99,12,3848,3888,775,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4097,4093,4078,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.3,980,SUCCESS,,3848.009275,64,0,0.1,0.2,0.3,263,1.4,1.5
    175,5/26/2021 19:24,701.436,0.19,701,300,10,6001,0,65535,65535,1,23.7,28610,-296,-297,100,99,12,3848,3888,780,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4096,4093,4078,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.6,948,SUCCESS,,3847.679811,64,0,0.1,0.2,0.3,263,1.4,1.5
    176,5/26/2021 19:24,705.439,0.2,701,300,10,6001,0,65535,65535,1,23.7,28609,-298,-297,100,99,12,3847,3888,780,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4096,4093,4078,4081,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,962,SUCCESS,,3847.348451,64,0,0.1,0.2,0.3,263,1.4,1.5
    177,5/26/2021 19:24,709.439,0.2,701,300,10,6001,0,65535,65535,1,23.7,28609,-298,-297,100,99,12,3847,3888,775,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4078,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,960,SUCCESS,,3847.01734,64,0,0.1,0.2,0.3,263,1.4,1.5
    178,5/26/2021 19:24,713.442,0.2,701,300,10,6001,0,65535,65535,1,23.7,28608,-296,-297,100,99,12,3847,3888,780,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4091,4095,4096,4093,4078,4082,4075,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.6,969,SUCCESS,,3846.688205,64,0,0.1,0.2,0.3,263,1.4,1.5
    179,5/26/2021 19:24,717.442,0.2,701,300,10,6001,0,65535,65535,1,23.7,28606,-296,-297,100,99,12,3846,3888,774,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4078,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.6,989,SUCCESS,,3846.359316,64,0,0.1,0.2,0.3,263,1.4,1.5
    180,5/26/2021 19:24,721.443,0.2,701,300,10,6001,0,65535,65535,1,23.7,28606,-298,-297,100,99,12,3846,3888,780,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4078,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,997,SUCCESS,,3846.028122,64,0,0.1,0.2,0.3,263,1.4,1.5
    181,5/26/2021 19:24,725.453,0.2,701,300,10,6001,0,65535,65535,1,23.7,28605,-296,-297,100,99,12,3846,3888,780,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4078,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,963,SUCCESS,,3845.698411,64,0,0.1,0.2,0.3,263,1.4,1.5
    182,5/26/2021 19:24,729.467,0.2,701,300,10,6001,0,65535,65535,1,23.7,28606,-300,-296,100,99,12,3845,3888,774,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4077,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,963,SUCCESS,,3845.363911,64,0,0.1,0.2,0.3,263,1.4,1.5
    183,5/26/2021 19:25,733.482,0.2,701,300,10,6001,0,65535,65535,1,23.7,28606,-296,-297,100,99,12,3845,3888,779,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4078,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,22.9,952,SUCCESS,,3845.033789,64,0,0.1,0.2,0.3,263,1.4,1.5
    184,5/26/2021 19:25,737.486,0.2,701,300,10,6001,0,65535,65535,1,23.7,28606,-296,-296,100,99,12,3845,3888,785,779,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4077,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,954,SUCCESS,,3844.704571,64,0,0.1,0.2,0.3,263,1.4,1.5
    185,5/26/2021 19:25,741.489,0.21,701,300,10,6001,0,65535,65535,1,23.7,28605,-298,-297,100,99,12,3844,3888,774,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4077,4081,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.6,942,SUCCESS,,3844.373211,64,0,0.1,0.2,0.3,263,1.4,1.5
    186,5/26/2021 19:25,745.501,0.21,701,300,10,6001,0,65535,65535,1,23.7,28603,-298,-297,100,99,12,3844,3888,779,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4090,4094,4096,4093,4077,4080,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,962,SUCCESS,,3844.041107,64,0,0.1,0.2,0.3,263,1.4,1.5
    187,5/26/2021 19:25,749.513,0.21,701,300,10,6001,0,65535,65535,1,23.7,28605,-296,-297,100,99,12,3844,3888,774,777,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4094,4095,4092,4077,4080,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,948,SUCCESS,,3843.711231,64,0,0.1,0.2,0.3,263,1.4,1.5
    188,5/26/2021 19:25,753.517,0.21,701,300,10,6001,0,65535,65535,1,23.7,28603,-298,-297,100,99,12,3843,3888,779,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4094,4096,4092,4077,4080,4073,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,956,SUCCESS,,3843.379789,64,0,0.1,0.2,0.3,263,1.4,1.5
    189,5/26/2021 19:25,757.519,0.21,701,300,10,6001,0,65535,65535,1,23.7,28600,-296,-297,100,99,12,3843,3888,779,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4094,4095,4092,4077,4080,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,987,SUCCESS,,3843.050736,64,0,0.1,0.2,0.3,263,1.4,1.5
    190,5/26/2021 19:25,761.52,0.21,701,300,10,6001,0,65535,65535,1,23.7,28602,-298,-297,100,99,12,3843,3888,774,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4094,4095,4092,4077,4080,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,939,SUCCESS,,3842.719542,64,0,0.1,0.2,0.3,263,1.4,1.5
    191,5/26/2021 19:25,765.533,0.21,701,300,10,6001,0,65535,65535,1,23.7,28600,-296,-297,100,99,12,3842,3888,779,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4094,4095,4092,4077,4080,4073,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.4,986,SUCCESS,,3842.389584,64,0,0.1,0.2,0.3,263,1.4,1.5
    192,5/26/2021 19:25,769.537,0.21,701,300,10,6001,0,65535,65535,1,23.7,28598,-296,-297,100,99,12,3842,3888,779,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4092,4077,4080,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,969,SUCCESS,,3842.060366,64,0,0.1,0.2,0.3,263,1.4,1.5
    193,5/26/2021 19:25,773.539,0.21,701,300,10,6001,0,65535,65535,1,23.7,28599,-296,-297,100,99,12,3842,3888,779,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4092,4077,4080,4074,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.6,937,SUCCESS,,3841.731313,64,0,0.1,0.2,0.3,263,1.4,1.5
    194,5/26/2021 19:25,777.548,0.22,701,300,10,6001,0,65535,65535,1,23.7,28599,-298,-297,100,99,12,3841,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4092,4077,4080,4073,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.6,987,SUCCESS,,3841.399457,64,0,0.1,0.2,0.3,263,1.4,1.5
    195,5/26/2021 19:25,781.555,0.22,701,300,10,6001,0,65535,65535,1,23.7,28598,-298,-297,100,99,12,3841,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4092,4077,4080,4073,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,1014,SUCCESS,,3841.067766,64,0,0.1,0.2,0.3,263,1.4,1.5
    196,5/26/2021 19:25,785.562,0.22,701,300,10,6001,0,65535,65535,1,23.7,28598,-298,-297,100,99,12,3841,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4091,4076,4080,4073,0,0,0,0,0,0,0,0,2857,23.6,23.7,-273.2,23.7,-273.2,23.5,962,SUCCESS,,3840.736076,64,0,0.1,0.2,0.3,263,1.4,1.5
    197,5/26/2021 19:25,789.573,0.22,701,300,10,6001,0,65535,65535,1,23.7,28598,-298,-297,100,99,12,3840,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4091,4076,4080,4073,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.6,968,SUCCESS,,3840.404054,64,0,0.1,0.2,0.3,263,1.4,1.5
    198,5/26/2021 19:26,793.58,0.22,701,300,10,6001,0,65535,65535,1,23.7,28597,-298,-297,100,99,12,3840,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4094,4091,4077,4080,4073,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,946,SUCCESS,,3840.072364,64,0,0.1,0.2,0.3,263,1.4,1.5
    199,5/26/2021 19:26,797.59,0.22,701,300,10,6001,0,65535,65535,1,23.7,28597,-298,-297,100,99,12,3840,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4095,4091,4076,4079,4073,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,961,SUCCESS,,3839.740425,64,0,0.1,0.2,0.3,263,1.4,1.5
    200,5/26/2021 19:26,801.597,0.22,701,300,10,6001,0,65535,65535,1,23.7,28596,-296,-297,100,99,12,3839,3888,778,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4094,4091,4076,4080,4073,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,941,SUCCESS,,3839.41096,64,0,0.1,0.2,0.3,263,1.4,1.5
    201,5/26/2021 19:26,805.605,0.22,701,300,10,6001,0,65535,65535,1,23.7,28596,-298,-297,100,99,12,3839,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4094,4091,4076,4080,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.6,959,SUCCESS,,3839.079187,64,0,0.1,0.2,0.3,263,1.4,1.5
    202,5/26/2021 19:26,809.607,0.22,701,300,10,6001,0,65535,65535,1,23.7,28595,-298,-297,100,99,12,3839,3888,773,776,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4094,4091,4076,4079,4073,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,944,SUCCESS,,3838.74791,64,0,0.1,0.2,0.3,263,1.4,1.5
    203,5/26/2021 19:26,813.613,0.23,701,300,10,6001,0,65535,65535,1,23.7,28594,-298,-297,100,99,12,3838,3888,773,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4089,4093,4094,4091,4076,4079,4073,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,943,SUCCESS,,3838.416303,64,0,0.1,0.2,0.3,263,1.4,1.5
    204,5/26/2021 19:26,817.62,0.23,701,300,10,6001,0,65535,65535,1,23.7,28594,-300,-297,100,99,12,3838,3888,768,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4093,4094,4091,4076,4080,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,959,SUCCESS,,3838.082386,64,0,0.1,0.2,0.3,263,1.4,1.5
    205,5/26/2021 19:26,821.626,0.23,701,300,10,6001,0,65535,65535,1,23.7,28593,-296,-297,100,99,12,3838,3888,783,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4076,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,945,SUCCESS,,3837.753004,64,0,0.1,0.2,0.3,263,1.4,1.5
    206,5/26/2021 19:26,825.641,0.23,701,300,10,6001,0,65535,65535,1,23.7,28592,-298,-297,100,99,12,3837,3888,778,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4093,4094,4091,4076,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,962,SUCCESS,,3837.420651,64,0,0.1,0.2,0.3,263,1.4,1.5
    207,5/26/2021 19:26,829.654,0.23,701,300,10,6001,0,65535,65535,1,23.7,28593,-298,-297,100,99,12,3837,3888,778,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4076,4080,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,995,SUCCESS,,3837.088464,64,0,0.1,0.2,0.3,263,1.4,1.5
    208,5/26/2021 19:26,833.66,0.23,701,300,10,6001,0,65535,65535,1,23.7,28593,-298,-297,100,99,12,3837,3888,778,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4093,4094,4091,4076,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,951,SUCCESS,,3836.756856,64,0,0.1,0.2,0.3,263,1.4,1.5
    209,5/26/2021 19:26,837.66,0.23,701,300,10,6001,0,65535,65535,1,23.7,28592,-296,-297,100,99,12,3836,3888,772,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4076,4078,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,991,SUCCESS,,3836.427967,64,0,0.1,0.2,0.3,263,1.4,1.5
    210,5/26/2021 19:26,841.676,0.23,701,300,10,6001,0,65535,65535,1,23.7,28592,-298,-297,100,99,12,3836,3888,772,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4076,4083,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.6,938,SUCCESS,,3836.095531,64,0,0.1,0.2,0.3,263,1.4,1.5
    211,5/26/2021 19:26,845.687,0.23,701,300,10,6001,0,65535,65535,1,23.7,28592,-298,-297,100,99,12,3836,3888,778,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4075,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,940,SUCCESS,,3835.76351,64,0,0.1,0.2,0.3,263,1.4,1.5
    212,5/26/2021 19:26,849.695,0.24,701,300,10,6001,0,65535,65535,1,23.7,28592,-300,-297,100,99,12,3835,3888,777,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4075,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,955,SUCCESS,,3835.42951,64,0,0.1,0.2,0.3,263,1.4,1.5
    213,5/26/2021 19:27,853.699,0.24,701,300,10,6001,0,65535,65535,1,23.7,28591,-298,-297,100,99,12,3835,3888,777,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4091,4075,4080,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,981,SUCCESS,,3835.098068,64,0,0.1,0.2,0.3,263,1.4,1.5
    214,5/26/2021 19:27,857.713,0.24,701,300,10,6001,0,65535,65535,1,23.7,28589,-300,-297,100,99,12,3835,3888,767,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4094,4090,4075,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,976,SUCCESS,,3834.763568,64,0,0.1,0.2,0.3,263,1.4,1.5
    215,5/26/2021 19:27,861.727,0.24,701,300,10,6001,0,65535,65535,1,23.7,28590,-298,-297,100,99,12,3834,3888,772,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4093,4091,4075,4077,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,949,SUCCESS,,3834.431298,64,0,0.1,0.2,0.3,263,1.4,1.5
    216,5/26/2021 19:27,865.735,0.24,701,300,10,6001,0,65535,65535,1,23.7,28589,-296,-297,100,99,12,3834,3888,782,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4093,4090,4075,4079,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,948,SUCCESS,,3834.101751,64,0,0.1,0.2,0.3,263,1.4,1.5
    217,5/26/2021 19:27,869.75,0.24,701,300,10,6001,0,65535,65535,1,23.7,28589,-296,-297,100,99,12,3834,3888,777,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4093,4090,4075,4079,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,945,SUCCESS,,3833.771629,64,0,0.1,0.2,0.3,263,1.4,1.5
    218,5/26/2021 19:27,873.762,0.24,701,300,10,6001,0,65535,65535,1,23.7,28587,-298,-297,100,99,12,3833,3888,772,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4075,4078,4072,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,991,SUCCESS,,3833.439524,64,0,0.1,0.2,0.3,263,1.4,1.5
    219,5/26/2021 19:27,877.773,0.24,701,300,10,6001,0,65535,65535,1,23.7,28587,-298,-297,100,99,12,3833,3888,772,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4092,4093,4090,4075,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,970,SUCCESS,,3833.107503,64,0,0.1,0.2,0.3,263,1.4,1.5
    220,5/26/2021 19:27,881.789,0.24,701,300,10,6001,0,65535,65535,1,23.7,28586,-298,-297,100,99,12,3833,3888,772,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4075,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,946,SUCCESS,,3832.775067,64,0,0.1,0.2,0.3,263,1.4,1.5
    221,5/26/2021 19:27,885.798,0.25,701,300,10,6001,0,65535,65535,1,23.7,28585,-296,-297,100,99,12,3832,3888,777,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4088,4091,4093,4090,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.4,1048,SUCCESS,,3832.445438,64,0,0.1,0.2,0.3,263,1.4,1.5
    222,5/26/2021 19:27,889.802,0.25,701,300,10,6001,0,65535,65535,1,23.7,28584,-296,-297,100,99,12,3832,3888,777,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4075,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,956,SUCCESS,,3832.11622,64,0,0.1,0.2,0.3,263,1.4,1.5
    223,5/26/2021 19:27,893.813,0.25,701,300,10,6001,0,65535,65535,1,23.7,28584,-300,-297,100,99,12,3832,3888,766,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4075,4078,4071,0,0,0,0,0,0,0,0,2853,23.5,23.7,-273.2,23.7,-273.2,23.5,975,SUCCESS,,3831.78197,64,0,0.1,0.2,0.3,263,1.4,1.5
    224,5/26/2021 19:27,897.823,0.25,701,300,10,6001,0,65535,65535,1,23.7,28584,-296,-297,100,99,12,3831,3888,777,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4074,4079,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,22.8,1003,SUCCESS,,3831.452259,64,0,0.1,0.2,0.3,263,1.4,1.5
    225,5/26/2021 19:27,901.825,0.25,701,300,10,6001,0,65535,65535,1,23.7,28584,-298,-297,100,99,12,3831,3888,771,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,966,SUCCESS,,3831.120983,64,0,0.1,0.2,0.3,263,1.4,1.5
    226,5/26/2021 19:27,905.828,0.25,701,300,10,6001,0,65535,65535,1,23.7,28583,-296,-297,100,99,12,3831,3888,771,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4090,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.4,970,SUCCESS,,3830.791847,64,0,0.1,0.2,0.3,263,1.4,1.5
    227,5/26/2021 19:27,909.842,0.25,701,300,10,6001,0,65535,65535,1,23.7,28583,-296,-297,100,99,12,3830,3888,776,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.7,-273.2,23.7,-273.2,23.5,946,SUCCESS,,3830.461807,64,0,0.1,0.2,0.3,263,1.4,1.5
    228,5/26/2021 19:28,913.851,0.25,701,300,10,6001,0,65535,65535,1,23.6,28583,-300,-297,100,99,12,3830,3888,771,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4077,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,986,SUCCESS,,3830.127724,64,0,0.1,0.2,0.3,263,1.4,1.5
    229,5/26/2021 19:28,917.865,0.25,701,300,10,6001,0,65535,65535,1,23.6,28583,-298,-297,100,99,12,3830,3888,776,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,998,SUCCESS,,3829.795454,64,0,0.1,0.2,0.3,263,1.4,1.5
    230,5/26/2021 19:28,921.874,0.26,701,300,10,6001,0,65535,65535,1,23.6,28583,-296,-297,100,99,12,3829,3888,776,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,941,SUCCESS,,3829.465825,64,0,0.1,0.2,0.3,263,1.4,1.5
    231,5/26/2021 19:28,925.875,0.26,701,300,10,6001,0,65535,65535,1,23.6,28582,-296,-297,100,99,12,3829,3888,771,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4077,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,954,SUCCESS,,3829.136854,64,0,0.1,0.2,0.3,263,1.4,1.5
    232,5/26/2021 19:28,929.879,0.26,701,300,10,6001,0,65535,65535,1,23.6,28582,-294,-297,100,99,12,3829,3888,776,774,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4077,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,940,SUCCESS,,3828.80986,64,0,0.1,0.2,0.3,263,1.4,1.5
    233,5/26/2021 19:28,933.883,0.26,701,300,10,6001,0,65535,65535,1,23.6,28581,-296,-297,100,99,12,3828,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4093,4089,4074,4077,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,951,SUCCESS,,3828.480643,64,0,0.1,0.2,0.3,263,1.4,1.5
    234,5/26/2021 19:28,937.892,0.26,701,300,10,6001,0,65535,65535,1,23.6,28579,-294,-297,100,99,12,3828,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4091,4092,4089,4074,4077,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,943,SUCCESS,,3828.153241,64,0,0.1,0.2,0.3,263,1.4,1.5
    235,5/26/2021 19:28,941.898,0.26,701,300,10,6001,0,65535,65535,1,23.6,28580,-296,-297,100,99,12,3828,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4087,4091,4092,4089,4074,4077,4070,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,971,SUCCESS,,3827.823859,64,0,0.1,0.2,0.3,263,1.4,1.5
    236,5/26/2021 19:28,945.913,0.26,701,300,10,6001,0,65535,65535,1,23.6,28580,-298,-297,100,99,12,3827,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4091,4092,4089,4074,4078,4071,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.4,991,SUCCESS,,3827.491506,64,0,0.1,0.2,0.3,263,1.4,1.5
    237,5/26/2021 19:28,949.916,0.26,701,300,10,6001,0,65535,65535,1,23.6,28578,-296,-297,100,99,12,3827,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4074,4077,4070,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,950,SUCCESS,,3827.16237,64,0,0.1,0.2,0.3,263,1.4,1.5
    238,5/26/2021 19:28,953.928,0.26,701,300,10,6001,0,65535,65535,1,23.6,28578,-296,-297,100,99,12,3827,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4074,4077,4070,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,985,SUCCESS,,3826.832495,64,0,0.1,0.2,0.3,263,1.4,1.5
    239,5/26/2021 19:28,957.928,0.27,701,300,10,6001,0,65535,65535,1,23.6,28578,-296,-297,100,99,12,3826,3888,770,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4073,4077,4070,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,951,SUCCESS,,3826.503606,64,0,0.1,0.2,0.3,263,1.4,1.5
    240,5/26/2021 19:28,961.941,0.27,701,300,10,6001,0,65535,65535,1,23.6,28577,-296,-297,100,99,12,3826,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4073,4077,4070,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.4,984,SUCCESS,,3826.173648,64,0,0.1,0.2,0.3,263,1.4,1.5
    241,5/26/2021 19:28,965.956,0.27,701,300,10,6001,0,65535,65535,1,23.6,28577,-298,-297,100,99,12,3826,3888,776,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4073,4077,4069,0,0,0,0,0,0,0,0,2853,23.5,23.6,-273.2,23.6,-273.2,23.5,944,SUCCESS,,3825.841295,64,0,0.1,0.2,0.3,263,1.4,1.5
    242,5/26/2021 19:28,969.968,0.27,701,300,10,6001,0,65535,65535,1,23.6,28577,-296,-297,100,99,12,3825,3888,770,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4073,4077,4069,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.5,964,SUCCESS,,3825.51142,64,0,0.1,0.2,0.3,263,1.4,1.5
    243,5/26/2021 19:29,973.983,0.27,701,300,10,6001,0,65535,65535,1,23.6,28576,-298,-297,100,99,12,3825,3888,775,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4092,4089,4073,4077,4069,0,0,0,0,0,0,0,0,2853,23.5,23.6,-273.2,23.6,-273.2,23.5,947,SUCCESS,,3825.179067,64,0,0.1,0.2,0.3,263,1.4,1.5
    244,5/26/2021 19:29,977.998,0.27,701,300,10,6001,0,65535,65535,1,23.6,28574,-296,-297,100,99,12,3825,3888,770,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4091,4088,4073,4077,4069,0,0,0,0,0,0,0,0,2853,23.5,23.6,-273.2,23.6,-273.2,23.5,946,SUCCESS,,3824.848945,64,0,0.1,0.2,0.3,263,1.4,1.5
    245,5/26/2021 19:29,982.009,0.27,701,300,10,6001,0,65535,65535,1,23.6,28577,-298,-297,100,99,12,3824,3888,780,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4091,4089,4073,4077,4070,0,0,0,0,0,0,0,0,2856,23.5,23.6,-273.2,23.6,-273.2,23.5,986,SUCCESS,,3824.516923,64,0,0.1,0.2,0.3,263,1.4,1.5
    246,5/26/2021 19:29,986.013,0.27,701,300,10,6001,0,65535,65535,1,23.6,28576,-296,-297,100,99,12,3824,3888,775,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4091,4088,4073,4077,4070,0,0,0,0,0,0,0,0,2853,23.5,23.6,-273.2,23.6,-273.2,23.5,943,SUCCESS,,3824.187705,64,0,0.1,0.2,0.3,263,1.4,1.5
    247,5/26/2021 19:29,990.027,0.28,701,300,10,6001,0,65535,65535,1,23.6,28576,-296,-297,100,99,12,3824,3888,770,773,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4091,4088,4073,4077,4069,0,0,0,0,0,0,0,0,2853,23.5,23.6,-273.2,23.6,-273.2,23.1,949,SUCCESS,,3823.857665,64,0,0.1,0.2,0.3,263,1.4,1.5
    248,5/26/2021 19:29,994.039,0.28,701,300,10,6001,0,65535,65535,1,23.6,28574,-296,-297,100,99,12,3823,3888,775,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4090,4091,4088,4073,4076,4069,0,0,0,0,0,0,0,0,2857,23.5,23.6,-273.2,23.6,-273.2,23.4,1013,SUCCESS,,3823.52779,64,0,0.1,0.2,0.3,263,1.4,1.5
    249,5/26/2021 19:29,998.054,0.28,701,300,10,6001,0,65535,65535,1,23.6,28573,-296,-296,100,99,12,3823,3888,775,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4086,4089,4091,4088,4073,4077,4069,0,0,0,0,0,0,0,0,2853,23.5,23.6,-273.2,23.6,-273.2,23.4,995,SUCCESS,,3823.197668,64,0,0.1,0.2,0.3,263,1.4,1.5
    250,5/26/2021 19:29,1002.066,0.28,701,300,10,6001,0,65535,65535,1,23.6,28572,-298,-297,100,99,12,3823,3888,770,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4073,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,937,SUCCESS,,3822.865563,64,0,0.1,0.2,0.3,263,1.4,1.5
    251,5/26/2021 19:29,1006.068,0.28,701,300,10,6001,0,65535,65535,1,23.6,28572,-296,-296,100,99,12,3822,3888,775,775,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4073,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.4,937,SUCCESS,,3822.53651,64,0,0.1,0.2,0.3,263,1.4,1.5
    252,5/26/2021 19:29,1010.075,0.28,701,300,10,6001,0,65535,65535,1,23.6,28571,-298,-297,100,99,12,3822,3888,770,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.4,996,SUCCESS,,3822.204819,64,0,0.1,0.2,0.3,263,1.4,1.5
    253,5/26/2021 19:29,1014.088,0.28,701,300,10,6001,0,65535,65535,1,23.6,28571,-296,-297,100,99,12,3822,3888,775,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.4,945,SUCCESS,,3821.874861,64,0,0.1,0.2,0.3,263,1.4,1.5
    254,5/26/2021 19:29,1018.099,0.28,701,300,10,6001,0,65535,65535,1,23.6,28570,-298,-297,100,99,12,3821,3888,769,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,959,SUCCESS,,3821.54284,64,0,0.1,0.2,0.3,263,1.4,1.5
    255,5/26/2021 19:29,1022.111,0.28,701,300,10,6001,0,65535,65535,1,23.6,28570,-296,-297,100,99,12,3821,3888,775,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,960,SUCCESS,,3821.212964,64,0,0.1,0.2,0.3,263,1.4,1.5
    256,5/26/2021 19:29,1026.124,0.29,701,300,10,6001,0,65535,65535,1,23.6,28570,-298,-297,100,99,12,3821,3888,769,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.4,943,SUCCESS,,3820.880777,64,0,0.1,0.2,0.3,263,1.4,1.5
    257,5/26/2021 19:29,1030.139,0.29,701,300,10,6001,0,65535,65535,1,23.6,28570,-298,-297,100,99,12,3820,3888,769,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,974,SUCCESS,,3820.548424,64,0,0.1,0.2,0.3,263,1.4,1.5
    258,5/26/2021 19:30,1034.151,0.29,701,300,10,6001,0,65535,65535,1,23.6,28570,-298,-297,100,99,12,3820,3888,769,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,985,SUCCESS,,3820.21632,64,0,0.1,0.2,0.3,263,1.4,1.5
    259,5/26/2021 19:30,1038.151,0.29,701,300,10,6001,0,65535,65535,1,23.6,28570,-296,-297,100,99,12,3820,3888,774,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,965,SUCCESS,,3819.887431,64,0,0.1,0.2,0.3,263,1.4,1.5
    260,5/26/2021 19:30,1042.165,0.29,701,300,10,6001,0,65535,65535,1,23.6,28569,-300,-297,100,99,12,3819,3888,769,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4087,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,938,SUCCESS,,3819.552931,64,0,0.1,0.2,0.3,263,1.4,1.5
    261,5/26/2021 19:30,1046.171,0.29,701,300,10,6001,0,65535,65535,1,23.6,28570,-298,-297,100,99,12,3819,3888,774,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4091,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.5,23.6,-273.2,23.6,-273.2,23.5,950,SUCCESS,,3819.221323,64,0,0.1,0.2,0.3,263,1.4,1.5
    262,5/26/2021 19:30,1050.175,0.29,701,300,10,6001,0,65535,65535,1,23.6,28568,-300,-297,100,99,12,3819,3888,774,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4090,4088,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.5,937,SUCCESS,,3818.887656,64,0,0.1,0.2,0.3,263,1.4,1.5
    263,5/26/2021 19:30,1054.183,0.29,701,300,10,6001,0,65535,65535,1,23.6,28570,-296,-297,100,99,12,3818,3888,769,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4090,4087,4072,4076,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.5,961,SUCCESS,,3818.55811,64,0,0.1,0.2,0.3,263,1.4,1.5
    264,5/26/2021 19:30,1058.197,0.29,701,300,10,6001,0,65535,65535,1,23.6,28566,-296,-297,100,99,12,3818,3888,774,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4090,4087,4072,4076,4069,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.5,937,SUCCESS,,3818.22807,64,0,0.1,0.2,0.3,263,1.4,1.5
    265,5/26/2021 19:30,1062.201,0.3,701,300,10,6001,0,65535,65535,1,23.6,28569,-298,-297,100,99,12,3818,3888,769,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4089,4090,4087,4072,4076,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,965,SUCCESS,,3817.896628,64,0,0.1,0.2,0.3,263,1.4,1.5
    266,5/26/2021 19:30,1066.206,0.3,701,300,10,6001,0,65535,65535,1,23.6,28567,-296,-297,100,99,12,3817,3888,774,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4088,4090,4087,4072,4076,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.5,945,SUCCESS,,3817.567328,64,0,0.1,0.2,0.3,263,1.4,1.5
    267,5/26/2021 19:30,1070.209,0.3,701,300,10,6001,0,65535,65535,1,23.6,28566,-296,-297,100,99,12,3817,3888,774,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4085,4088,4090,4087,4072,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,992,SUCCESS,,3817.238192,64,0,0.1,0.2,0.3,263,1.4,1.5
    268,5/26/2021 19:30,1074.22,0.3,701,300,10,6001,0,65535,65535,1,23.6,28567,-300,-297,100,99,12,3817,3888,769,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4072,4076,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,972,SUCCESS,,3816.903942,64,0,0.1,0.2,0.3,263,1.4,1.5
    269,5/26/2021 19:30,1078.222,0.3,701,300,10,6001,0,65535,65535,1,23.6,28564,-298,-297,100,99,12,3816,3888,768,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4072,4076,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.3,951,SUCCESS,,3816.572665,64,0,0.1,0.2,0.3,263,1.4,1.5
    270,5/26/2021 19:30,1082.235,0.3,701,300,10,6001,0,65535,65535,1,23.6,28563,-298,-297,100,99,12,3816,3888,774,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4072,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,980,SUCCESS,,3816.240478,64,0,0.1,0.2,0.3,263,1.4,1.5
    271,5/26/2021 19:30,1086.249,0.3,701,300,10,6001,0,65535,65535,1,23.6,28569,-298,-297,100,99,12,3816,3888,768,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4071,4076,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,944,SUCCESS,,3815.908208,64,0,0.1,0.2,0.3,263,1.4,1.5
    272,5/26/2021 19:30,1090.26,0.3,701,300,10,6001,0,65535,65535,1,23.6,28563,-296,-297,100,99,12,3815,3888,773,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,956,SUCCESS,,3815.578415,64,0,0.1,0.2,0.3,263,1.4,1.5
    273,5/26/2021 19:31,1094.264,0.3,701,300,10,6001,0,65535,65535,1,23.6,28563,-296,-297,100,99,12,3815,3888,768,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,948,SUCCESS,,3815.249197,64,0,0.1,0.2,0.3,263,1.4,1.5
    274,5/26/2021 19:31,1098.267,0.31,701,300,10,6001,0,65535,65535,1,23.6,28562,-298,-297,100,99,12,3815,3888,768,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4090,4087,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,962,SUCCESS,,3814.917838,64,0,0.1,0.2,0.3,263,1.4,1.5
    275,5/26/2021 19:31,1102.278,0.31,701,300,10,6001,0,65535,65535,1,23.6,28563,-294,-297,100,99,12,3814,3888,773,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4087,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,952,SUCCESS,,3814.590273,64,0,0.1,0.2,0.3,263,1.4,1.5
    276,5/26/2021 19:31,1106.28,0.31,701,300,10,6001,0,65535,65535,1,23.6,28561,-298,-297,100,99,12,3814,3888,773,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4074,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,949,SUCCESS,,3814.258996,64,0,0.1,0.2,0.3,263,1.4,1.5
    277,5/26/2021 19:31,1110.289,0.31,701,300,10,6001,0,65535,65535,1,23.6,28561,-298,-297,100,99,12,3814,3888,773,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,955,SUCCESS,,3813.92714,64,0,0.1,0.2,0.3,263,1.4,1.5
    278,5/26/2021 19:31,1114.292,0.31,701,300,10,6001,0,65535,65535,1,23.6,28561,-298,-297,100,99,12,3813,3888,778,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.5,940,SUCCESS,,3813.59578,64,0,0.1,0.2,0.3,263,1.4,1.5
    279,5/26/2021 19:31,1118.305,0.31,701,300,10,6001,0,65535,65535,1,23.6,28561,-298,-297,100,99,12,3813,3888,768,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,22.8,976,SUCCESS,,3813.263593,64,0,0.1,0.2,0.3,263,1.4,1.5
    280,5/26/2021 19:31,1122.318,0.31,701,300,10,6001,0,65535,65535,1,23.6,28561,-298,-297,100,99,12,3813,3888,773,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,936,SUCCESS,,3812.931406,64,0,0.1,0.2,0.3,263,1.4,1.5
    281,5/26/2021 19:31,1126.319,0.31,701,300,10,6001,0,65535,65535,1,23.6,28561,-298,-297,100,99,12,3812,3888,768,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4075,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,973,SUCCESS,,3812.600212,64,0,0.1,0.2,0.3,263,1.4,1.5
    282,5/26/2021 19:31,1130.326,0.31,701,300,10,6001,0,65535,65535,1,23.6,28559,-298,-297,100,99,12,3812,3888,768,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4071,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,950,SUCCESS,,3812.268521,64,0,0.1,0.2,0.3,263,1.4,1.5
    283,5/26/2021 19:31,1134.328,0.32,701,300,10,6001,0,65535,65535,1,23.6,28561,-296,-297,100,99,12,3812,3888,768,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4084,4088,4089,4086,4071,4074,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,947,SUCCESS,,3811.939468,64,0,0.1,0.2,0.3,263,1.4,1.5
    284,5/26/2021 19:31,1138.341,0.32,701,300,10,6001,0,65535,65535,1,23.6,28559,-300,-297,100,99,12,3811,3888,762,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4088,4089,4086,4071,4074,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,965,SUCCESS,,3811.605051,64,0,0.1,0.2,0.3,263,1.4,1.5
    285,5/26/2021 19:31,1142.348,0.32,701,300,10,6001,0,65535,65535,1,23.6,28559,-298,-297,100,99,12,3811,3888,773,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4088,4089,4086,4071,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,937,SUCCESS,,3811.273361,64,0,0.1,0.2,0.3,263,1.4,1.5
    286,5/26/2021 19:31,1146.355,0.32,701,300,10,6001,0,65535,65535,1,23.6,28557,-298,-297,100,99,12,3811,3888,767,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,,0,0,4083,4087,4089,4086,4071,4074,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,955,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,3810.94167,64,0,0.1,0.2,0.3,263,1.4,1.5
    287,5/26/2021 19:31,1150.364,0.32,701,300,10,6001,0,65535,65535,1,23.6,28557,-300,-297,100,98,12,3810,3888,762,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4071,4074,4068,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,944,SUCCESS,,3810.607587,64,0,0.1,0.2,0.3,263,1.4,1.5
    288,5/26/2021 19:32,1154.374,0.32,701,300,10,6001,0,65535,65535,1,23.6,28558,-298,-297,100,98,12,3810,3888,767,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4071,4076,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,939,SUCCESS,,3810.275648,64,0,0.1,0.2,0.3,263,1.4,1.5
    289,5/26/2021 19:32,1158.377,0.32,701,300,10,6001,0,65535,65535,1,23.6,28557,-296,-297,100,98,12,3810,3888,772,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,944,SUCCESS,,3809.946513,64,0,0.1,0.2,0.3,263,1.4,1.5
    290,5/26/2021 19:32,1162.38,0.32,701,300,10,6001,0,65535,65535,1,23.6,28557,-296,-297,100,98,12,3809,3888,772,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,974,SUCCESS,,3809.617377,64,0,0.1,0.2,0.3,263,1.4,1.5
    291,5/26/2021 19:32,1166.384,0.32,701,300,10,6001,0,65535,65535,1,23.6,28557,-294,-297,100,98,12,3809,3888,777,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4071,4075,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.3,960,SUCCESS,,3809.290384,64,0,0.1,0.2,0.3,263,1.4,1.5
    292,5/26/2021 19:32,1170.385,0.33,701,300,10,6001,0,65535,65535,1,23.5,28556,-296,-297,100,98,12,3809,3888,772,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,965,SUCCESS,,3808.961413,64,0,0.1,0.2,0.3,263,1.4,1.5
    293,5/26/2021 19:32,1174.388,0.33,701,300,10,6001,0,65535,65535,1,23.6,28555,-296,-297,100,98,12,3808,3888,772,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4089,4086,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,945,SUCCESS,,3808.632277,64,0,0.1,0.2,0.3,263,1.4,1.5
    294,5/26/2021 19:32,1178.399,0.33,701,300,10,6001,0,65535,65535,1,23.6,28555,-296,-297,100,98,12,3808,3888,772,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4088,4085,4070,4076,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,954,SUCCESS,,3808.302484,64,0,0.1,0.2,0.3,263,1.4,1.5
    295,5/26/2021 19:32,1182.403,0.33,701,300,10,6001,0,65535,65535,1,23.6,28554,-298,-297,100,98,12,3808,3888,767,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4088,4085,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,967,SUCCESS,,3807.971041,64,0,0.1,0.2,0.3,263,1.4,1.5
    296,5/26/2021 19:32,1186.416,0.33,701,300,10,6001,0,65535,65535,1,23.5,28555,-294,-297,100,98,12,3807,3888,777,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4088,4086,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,934,SUCCESS,,3807.643313,64,0,0.1,0.2,0.3,263,1.4,1.5
    297,5/26/2021 19:32,1190.423,0.33,701,300,10,6001,0,65535,65535,1,23.6,28554,-298,-296,100,98,12,3807,3888,772,772,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4088,4085,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.6,-273.2,23.6,-273.2,23.4,964,SUCCESS,,3807.311623,64,0,0.1,0.2,0.3,263,1.4,1.5
    298,5/26/2021 19:32,1194.432,0.33,701,300,10,6001,0,65535,65535,1,23.5,28554,-296,-297,100,98,12,3807,3888,767,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4086,4088,4085,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,952,SUCCESS,,3806.981994,64,0,0.1,0.2,0.3,263,1.4,1.5
    299,5/26/2021 19:32,1198.443,0.33,701,300,10,6001,0,65535,65535,1,23.5,28553,-294,-296,100,98,12,3806,3888,777,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4087,4088,4085,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,947,SUCCESS,,3806.654429,64,0,0.1,0.2,0.3,263,1.4,1.5
    300,5/26/2021 19:32,1202.454,0.33,701,300,10,6001,0,65535,65535,1,23.5,28551,-296,-296,100,98,12,3806,3888,771,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4086,4088,4085,4070,4074,4067,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,961,SUCCESS,,3806.324635,64,0,0.1,0.2,0.3,263,1.4,1.5
    301,5/26/2021 19:32,1206.469,0.34,701,300,10,6001,0,65535,65535,1,23.5,28553,-296,-297,100,98,12,3806,3888,766,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4070,4074,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,959,SUCCESS,,3805.994513,64,0,0.1,0.2,0.3,263,1.4,1.5
    302,5/26/2021 19:32,1210.507,0.34,701,300,10,6001,0,65535,65535,1,23.5,28551,-296,-296,100,98,12,3805,3888,766,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4086,4088,4085,4070,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,953,SUCCESS,,3805.6625,64,0,0.1,0.2,0.3,263,1.4,1.5
    303,5/26/2021 19:33,1214.501,0.34,701,300,10,6001,0,65535,65535,1,23.5,28552,-296,-297,100,98,12,3805,3888,766,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4070,4074,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,956,SUCCESS,,3805.334104,64,0,0.1,0.2,0.3,263,1.4,1.5
    304,5/26/2021 19:33,1218.516,0.34,701,300,10,6001,0,65535,65535,1,23.5,28551,-298,-297,100,98,12,3805,3888,766,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4083,4086,4088,4085,4070,4074,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,955,SUCCESS,,3805.001751,64,0,0.1,0.2,0.3,263,1.4,1.5
    305,5/26/2021 19:33,1222.541,0.34,701,300,10,6001,0,65535,65535,1,23.5,28549,-296,-297,100,98,12,3804,3888,771,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4070,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,945,SUCCESS,,3804.670807,64,0,0.1,0.2,0.3,263,1.4,1.5
    306,5/26/2021 19:33,1226.532,0.34,701,300,10,6001,0,65535,65535,1,23.5,28551,-296,-297,100,98,12,3804,3888,766,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,958,SUCCESS,,3804.342658,64,0,0.1,0.2,0.3,263,1.4,1.5
    307,5/26/2021 19:33,1230.547,0.34,701,300,10,6001,0,65535,65535,1,23.5,28551,-296,-297,100,98,12,3804,3888,766,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4070,4074,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,961,SUCCESS,,3804.012536,64,0,0.1,0.2,0.3,263,1.4,1.5
    308,5/26/2021 19:33,1234.585,0.34,701,300,10,6001,0,65535,65535,1,23.5,28549,-296,-297,100,98,12,3803,3888,766,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4070,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,974,SUCCESS,,3803.680523,64,0,0.1,0.2,0.3,263,1.4,1.5
    309,5/26/2021 19:33,1238.593,0.34,701,300,10,6001,0,65535,65535,1,23.5,28549,-298,-297,100,98,12,3803,3888,766,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,956,SUCCESS,,3803.348749,64,0,0.1,0.2,0.3,263,1.4,1.5
    310,5/26/2021 19:33,1242.595,0.35,701,300,10,6001,0,65535,65535,1,23.5,28550,-296,-296,100,98,12,3803,3888,776,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,976,SUCCESS,,3803.019696,64,0,0.1,0.2,0.3,263,1.4,1.5
    311,5/26/2021 19:33,1246.631,0.35,701,300,10,6001,0,65535,65535,1,23.5,28549,-296,-297,100,98,12,3802,3888,766,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4074,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,933,SUCCESS,,3802.687847,64,0,0.1,0.2,0.3,263,1.4,1.5
    312,5/26/2021 19:33,1250.549,0.35,701,300,10,6001,0,65535,65535,1,23.5,28549,-294,-297,100,98,12,3802,3888,771,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4087,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,971,SUCCESS,,3802.367877,64,0,0.1,0.2,0.3,263,1.4,1.5
    313,5/26/2021 19:33,1254.559,0.35,701,300,10,6001,0,65535,65535,1,23.5,28549,-296,-296,100,98,12,3802,3888,771,771,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,959,SUCCESS,,3802.038166,64,0,0.1,0.2,0.3,263,1.4,1.5
    314,5/26/2021 19:33,1258.562,0.35,701,300,10,6001,0,65535,65535,1,23.5,28549,-296,-297,100,98,12,3801,3888,765,768,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4074,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,946,SUCCESS,,3801.70903,64,0,0.1,0.2,0.3,263,1.4,1.5
    315,5/26/2021 19:33,1262.565,0.35,701,300,10,6001,0,65535,65535,1,23.5,28548,-298,-296,100,98,12,3801,3888,770,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4087,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,936,SUCCESS,,3801.377671,64,0,0.1,0.2,0.3,263,1.4,1.5
    316,5/26/2021 19:33,1266.569,0.35,701,300,10,6001,0,65535,65535,1,23.5,28548,-296,-296,100,98,12,3801,3888,776,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4088,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,955,SUCCESS,,3801.048453,64,0,0.1,0.2,0.3,263,1.4,1.5
    317,5/26/2021 19:33,1270.571,0.35,701,300,10,6001,0,65535,65535,1,23.5,28549,-298,-296,100,98,12,3800,3888,765,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4087,4085,4069,4073,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,948,SUCCESS,,3800.717176,64,0,0.1,0.2,0.3,263,1.4,1.5
    318,5/26/2021 19:34,1274.573,0.35,701,300,10,6001,0,65535,65535,1,23.5,28546,-296,-296,100,98,12,3800,3888,776,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4087,4085,4069,4072,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,960,SUCCESS,,3800.388123,64,0,0.1,0.2,0.3,263,1.4,1.5
    319,5/26/2021 19:34,1278.583,0.36,701,300,10,6001,0,65535,65535,1,23.5,28547,-298,-296,100,98,12,3800,3888,765,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4087,4085,4069,4072,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,942,SUCCESS,,3800.056184,64,0,0.1,0.2,0.3,263,1.4,1.5
    320,5/26/2021 19:34,1282.591,0.36,701,300,10,6001,0,65535,65535,1,23.5,28546,-296,-297,100,98,12,3799,3888,770,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4069,4072,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,980,SUCCESS,,3799.726638,64,0,0.1,0.2,0.3,263,1.4,1.5
    321,5/26/2021 19:34,1286.605,0.36,701,300,10,6001,0,65535,65535,1,23.5,28545,-298,-297,100,98,12,3799,3888,765,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4086,4087,4084,4069,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,960,SUCCESS,,3799.394368,64,0,0.1,0.2,0.3,263,1.4,1.5
    322,5/26/2021 19:34,1290.612,0.36,701,300,10,6001,0,65535,65535,1,23.5,28545,-298,-297,100,98,12,3799,3888,765,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4082,4085,4087,4084,4069,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,973,SUCCESS,,3799.062677,64,0,0.1,0.2,0.3,263,1.4,1.5
    323,5/26/2021 19:34,1294.622,0.36,701,300,10,6001,0,65535,65535,1,23.5,28543,-296,-297,100,98,12,3798,3888,770,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4069,4072,4066,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,964,SUCCESS,,3798.732966,64,0,0.1,0.2,0.3,263,1.4,1.5
    324,5/26/2021 19:34,1298.629,0.36,701,300,10,6001,0,65535,65535,1,23.5,28543,-296,-297,100,98,12,3798,3888,770,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4069,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,941,SUCCESS,,3798.403501,64,0,0.1,0.2,0.3,263,1.4,1.5
    325,5/26/2021 19:34,1302.637,0.36,701,300,10,6001,0,65535,65535,1,23.5,28544,-296,-297,100,98,12,3798,3888,770,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4069,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,22.6,964,SUCCESS,,3798.073955,64,0,0.1,0.2,0.3,263,1.4,1.5
    326,5/26/2021 19:34,1306.638,0.36,701,300,10,6001,0,65535,65535,1,23.5,28542,-294,-296,100,98,12,3797,3888,775,770,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4069,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,946,SUCCESS,,3797.747206,64,0,0.1,0.2,0.3,263,1.4,1.5
    327,5/26/2021 19:34,1310.65,0.36,701,300,10,6001,0,65535,65535,1,23.5,28544,-298,-297,100,98,12,3797,3888,764,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4084,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,951,SUCCESS,,3797.415102,64,0,0.1,0.2,0.3,263,1.4,1.5
    328,5/26/2021 19:34,1314.665,0.37,701,300,10,6001,0,65535,65535,1,23.5,28543,-296,-297,100,98,12,3797,3888,770,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,930,SUCCESS,,3797.08498,64,0,0.1,0.2,0.3,263,1.4,1.5
    329,5/26/2021 19:34,1318.675,0.37,701,300,10,6001,0,65535,65535,1,23.5,28543,-298,-297,100,98,12,3796,3888,764,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4087,4084,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,954,SUCCESS,,3796.753041,64,0,0.1,0.2,0.3,263,1.4,1.5
    330,5/26/2021 19:34,1322.684,0.37,701,300,10,6001,0,65535,65535,1,23.5,28542,-298,-297,100,98,12,3796,3888,764,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4084,4069,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,949,SUCCESS,,3796.421185,64,0,0.1,0.2,0.3,263,1.4,1.5
    331,5/26/2021 19:34,1326.692,0.37,701,300,10,6001,0,65535,65535,1,23.5,28540,-296,-297,100,98,12,3796,3888,769,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4084,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,935,SUCCESS,,3796.091638,64,0,0.1,0.2,0.3,263,1.4,1.5
    332,5/26/2021 19:34,1330.695,0.37,701,300,10,6001,0,65535,65535,1,23.5,28541,-294,-297,100,98,12,3795,3888,774,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,953,SUCCESS,,3795.764726,64,0,0.1,0.2,0.3,263,1.4,1.5
    333,5/26/2021 19:35,1334.703,0.37,701,300,10,6001,0,65535,65535,1,23.5,28540,-298,-297,100,98,12,3795,3888,769,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,971,SUCCESS,,3795.432953,64,0,0.1,0.2,0.3,263,1.4,1.5
    334,5/26/2021 19:35,1338.718,0.37,701,300,10,6001,0,65535,65535,1,23.5,28540,-296,-296,100,98,12,3795,3888,774,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,945,SUCCESS,,3795.102831,64,0,0.1,0.2,0.3,263,1.4,1.5
    335,5/26/2021 19:35,1342.728,0.37,701,300,10,6001,0,65535,65535,1,23.5,28541,-296,-297,100,98,12,3794,3888,764,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,933,SUCCESS,,3794.77312,64,0,0.1,0.2,0.3,263,1.4,1.5
    336,5/26/2021 19:35,1346.731,0.37,701,300,10,6001,0,65535,65535,1,23.5,28540,-298,-297,100,98,12,3794,3888,764,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4081,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,980,SUCCESS,,3794.44176,64,0,0.1,0.2,0.3,263,1.4,1.5
    337,5/26/2021 19:35,1350.743,0.38,701,300,10,6001,0,65535,65535,1,23.5,28538,-294,-296,100,98,12,3794,3888,769,769,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4071,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,1026,SUCCESS,,3794.114114,64,0,0.1,0.2,0.3,263,1.4,1.5
    338,5/26/2021 19:35,1354.746,0.38,701,300,10,6001,0,65535,65535,1,23.5,28543,-298,-297,100,98,12,3793,3888,764,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,959,SUCCESS,,3793.782754,64,0,0.1,0.2,0.3,263,1.4,1.5
    339,5/26/2021 19:35,1358.747,0.38,701,300,10,6001,0,65535,65535,1,23.5,28539,-296,-297,100,98,12,3793,3888,769,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,22.8,954,SUCCESS,,3793.453783,64,0,0.1,0.2,0.3,263,1.4,1.5
    340,5/26/2021 19:35,1362.753,0.38,701,300,10,6001,0,65535,65535,1,23.5,28538,-296,-297,100,98,12,3793,3888,764,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,936,SUCCESS,,3793.124401,64,0,0.1,0.2,0.3,263,1.4,1.5
    341,5/26/2021 19:35,1366.759,0.38,701,300,10,6001,0,65535,65535,1,23.5,28543,-298,-297,100,98,12,3792,3888,763,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4072,4065,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,984,SUCCESS,,3792.792793,64,0,0.1,0.2,0.3,263,1.4,1.5
    342,5/26/2021 19:35,1370.771,0.38,701,300,10,6001,0,65535,65535,1,23.5,28537,-294,-297,100,98,12,3792,3888,769,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4072,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,952,SUCCESS,,3792.465146,64,0,0.1,0.2,0.3,263,1.4,1.5
    343,5/26/2021 19:35,1374.775,0.38,701,300,10,6001,0,65535,65535,1,23.5,28536,-298,-297,100,98,12,3792,3888,763,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,984,SUCCESS,,3792.133704,64,0,0.1,0.2,0.3,263,1.4,1.5
    344,5/26/2021 19:35,1378.787,0.38,701,300,10,6001,0,65535,65535,1,23.5,28538,-300,-297,100,98,12,3791,3888,763,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4085,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,1003,SUCCESS,,3791.799371,64,0,0.1,0.2,0.3,263,1.4,1.5
    345,5/26/2021 19:35,1382.79,0.38,701,300,10,6001,0,65535,65535,1,23.5,28536,-298,-297,100,98,12,3791,3888,768,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,965,SUCCESS,,3791.468011,64,0,0.1,0.2,0.3,263,1.4,1.5
    346,5/26/2021 19:35,1386.798,0.39,701,300,10,6001,0,65535,65535,1,23.5,28536,-298,-297,100,98,12,3791,3888,768,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4086,4083,4068,4070,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,945,SUCCESS,,3791.136238,64,0,0.1,0.2,0.3,263,1.4,1.5
    347,5/26/2021 19:35,1390.805,0.39,701,300,10,6001,0,65535,65535,1,23.5,28536,-296,-297,100,98,12,3790,3888,773,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,967,SUCCESS,,3790.806774,64,0,0.1,0.2,0.3,263,1.4,1.5
    348,5/26/2021 19:36,1394.82,0.39,701,300,10,6001,0,65535,65535,1,23.5,28536,-294,-297,100,98,12,3790,3888,768,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,22.9,1007,SUCCESS,,3790.478882,64,0,0.1,0.2,0.3,263,1.4,1.5
    349,5/26/2021 19:36,1398.828,0.39,701,300,10,6001,0,65535,65535,1,23.5,28535,-298,-297,100,98,12,3790,3888,763,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4086,4083,4067,4072,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,977,SUCCESS,,3790.147109,64,0,0.1,0.2,0.3,263,1.4,1.5
    350,5/26/2021 19:36,1402.837,0.39,701,300,10,6001,0,65535,65535,1,23.5,28534,-298,-297,100,98,12,3789,3888,763,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4085,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,991,SUCCESS,,3789.815253,64,0,0.1,0.2,0.3,263,1.4,1.5
    351,5/26/2021 19:36,1406.845,0.39,701,300,10,6001,0,65535,65535,1,23.5,28533,-298,-297,100,98,12,3789,3888,768,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4086,4083,4068,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,945,SUCCESS,,3789.483479,64,0,0.1,0.2,0.3,263,1.4,1.5
    352,5/26/2021 19:36,1410.856,0.39,701,300,10,6001,0,65535,65535,1,23.5,28534,-296,-297,100,98,12,3789,3888,763,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4084,4086,4083,4068,4070,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,964,SUCCESS,,3789.153686,64,0,0.1,0.2,0.3,263,1.4,1.5
    353,5/26/2021 19:36,1414.871,0.39,701,300,10,6001,0,65535,65535,1,23.5,28535,-296,-297,100,98,12,3789,3888,768,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4085,4083,4067,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,959,SUCCESS,,3788.823564,64,0,0.1,0.2,0.3,263,1.4,1.5
    354,5/26/2021 19:36,1418.88,0.39,701,300,10,6001,0,65535,65535,1,23.5,28533,-298,-297,100,98,12,3788,3888,763,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4084,4085,4083,4067,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,959,SUCCESS,,3788.491708,64,0,0.1,0.2,0.3,263,1.4,1.5
    355,5/26/2021 19:36,1422.887,0.4,701,300,10,6001,0,65535,65535,1,23.5,28530,-298,-297,100,98,12,3788,3888,768,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4084,4085,4082,4067,4071,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,1012,SUCCESS,,3788.160017,64,0,0.1,0.2,0.3,263,1.4,1.5
    356,5/26/2021 19:36,1426.896,0.4,701,300,10,6001,0,65535,65535,1,23.5,28530,-296,-297,100,98,12,3788,3888,768,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4083,4085,4082,4067,4070,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,988,SUCCESS,,3787.830388,64,0,0.1,0.2,0.3,263,1.4,1.5
    357,5/26/2021 19:36,1430.911,0.4,701,300,10,6001,0,65535,65535,1,23.5,28531,-298,-297,100,98,12,3787,3888,757,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4080,4084,4085,4082,4067,4071,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,941,SUCCESS,,3787.498035,64,0,0.1,0.2,0.3,263,1.4,1.5
    358,5/26/2021 19:36,1434.923,0.4,701,300,10,6001,0,65535,65535,1,23.5,28531,-296,-297,100,98,12,3787,3888,768,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4084,4085,4082,4067,4071,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,943,SUCCESS,,3787.16816,64,0,0.1,0.2,0.3,263,1.4,1.5
    359,5/26/2021 19:36,1438.927,0.4,701,300,10,6001,0,65535,65535,1,23.5,28530,-296,-297,100,98,12,3786,3888,767,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4083,4085,4082,4067,4070,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.2,967,SUCCESS,,3786.838942,64,0,0.1,0.2,0.3,263,1.4,1.5
    360,5/26/2021 19:36,1442.935,0.4,701,300,10,6001,0,65535,65535,1,23.5,28529,-296,-297,100,98,12,3786,3888,767,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4079,4084,4085,4082,4067,4070,4064,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,964,SUCCESS,,3786.509395,64,0,0.1,0.2,0.3,263,1.4,1.5
    361,5/26/2021 19:36,1446.939,0.4,701,300,10,6001,0,65535,65535,1,23.5,28528,-296,-296,100,98,12,3786,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4072,4063,0,0,0,0,0,0,0,0,2849,23.4,23.5,-273.2,23.5,-273.2,23.4,937,SUCCESS,,3786.180178,64,0,0.1,0.2,0.3,263,1.4,1.5
    362,5/26/2021 19:36,1450.943,0.4,701,300,10,6001,0,65535,65535,1,23.5,28530,-296,-296,100,98,12,3785,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4070,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.1,963,SUCCESS,,3785.85096,64,0,0.1,0.2,0.3,263,1.4,1.5
    363,5/26/2021 19:37,1454.944,0.4,701,300,10,6001,0,65535,65535,1,23.5,28529,-296,-296,100,98,12,3785,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4070,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,988,SUCCESS,,3785.521989,64,0,0.1,0.2,0.3,263,1.4,1.5
    364,5/26/2021 19:37,1458.947,0.41,701,300,10,6001,0,65535,65535,1,23.5,28528,-296,-296,100,98,12,3785,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4072,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,952,SUCCESS,,3785.192853,64,0,0.1,0.2,0.3,263,1.4,1.5
    365,5/26/2021 19:37,1462.954,0.41,701,300,10,6001,0,65535,65535,1,23.5,28527,-296,-296,100,98,12,3784,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4070,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.4,938,SUCCESS,,3784.863389,64,0,0.1,0.2,0.3,263,1.4,1.5
    366,5/26/2021 19:37,1466.965,0.41,701,300,10,6001,0,65535,65535,1,23.5,28528,-294,-296,100,98,12,3784,3888,772,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4066,4069,4064,0,0,0,0,0,0,0,0,2849,23.4,23.5,-273.2,23.5,-273.2,23.3,949,SUCCESS,,3784.535824,64,0,0.1,0.2,0.3,263,1.4,1.5
    367,5/26/2021 19:37,1470.971,0.41,701,300,10,6001,0,65535,65535,1,23.5,28528,-298,-296,100,98,12,3784,3888,762,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4073,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,959,SUCCESS,,3784.204216,64,0,0.1,0.2,0.3,263,1.4,1.5
    368,5/26/2021 19:37,1474.986,0.41,701,300,10,6001,0,65535,65535,1,23.5,28527,-296,-297,100,98,12,3783,3888,767,764,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4070,4063,0,0,0,0,0,0,0,0,2852,23.4,23.5,-273.2,23.5,-273.2,23.3,968,SUCCESS,,3783.874094,64,0,0.1,0.2,0.3,263,1.4,1.5
    369,5/26/2021 19:37,1478.987,0.41,701,300,10,6001,0,65535,65535,1,23.5,28528,-296,-296,100,98,12,3783,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4067,4070,4063,0,0,0,0,0,0,0,0,2849,23.4,23.5,-273.2,23.5,-273.2,23.3,990,SUCCESS,,3783.545123,64,0,0.1,0.2,0.3,263,1.4,1.5
    370,5/26/2021 19:37,1483.002,0.41,701,300,10,6001,0,65535,65535,1,23.5,28528,-298,-297,100,98,12,3783,3888,762,764,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4066,4070,4063,0,0,0,0,0,0,0,0,2852,23.3,23.5,-273.2,23.5,-273.2,23.4,985,SUCCESS,,3783.21277,64,0,0.1,0.2,0.3,263,1.4,1.5
    371,5/26/2021 19:37,1487.012,0.41,701,300,10,6001,0,65535,65535,1,23.5,28527,-294,-297,100,98,12,3782,3888,767,764,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4066,4070,4063,0,0,0,0,0,0,0,0,2852,23.3,23.5,-273.2,23.5,-273.2,23.3,944,SUCCESS,,3782.885286,64,0,0.1,0.2,0.3,263,1.4,1.5
    372,5/26/2021 19:37,1491.026,0.41,701,300,10,6001,0,65535,65535,1,23.5,28526,-296,-297,100,98,12,3782,3888,761,764,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4066,4070,4063,0,0,0,0,0,0,0,0,2849,23.4,23.5,-273.2,23.5,-273.2,23.3,947,SUCCESS,,3782.555246,64,0,0.1,0.2,0.3,263,1.4,1.5
    373,5/26/2021 19:37,1495.038,0.42,701,300,10,6001,0,65535,65535,1,23.5,28527,-298,-297,100,98,12,3782,3888,761,764,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4066,4070,4063,0,0,0,0,0,0,0,0,2852,23.3,23.5,-273.2,23.5,-273.2,23.3,950,SUCCESS,,3782.223142,64,0,0.1,0.2,0.3,263,1.4,1.5
    374,5/26/2021 19:37,1499.044,0.42,701,300,10,6001,0,65535,65535,1,23.5,28526,-296,-296,100,98,12,3782,3888,767,767,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4084,4082,4066,4069,4062,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.3,942,SUCCESS,,3781.89376,64,0,0.1,0.2,0.3,263,1.4,1.5
    375,5/26/2021 19:37,1503.059,0.42,701,300,10,6001,0,65535,65535,1,23.5,28525,-298,-296,100,98,12,3781,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4085,4082,4066,4069,4063,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.3,946,SUCCESS,,3781.561407,64,0,0.1,0.2,0.3,263,1.4,1.5
    376,5/26/2021 19:37,1507.072,0.42,701,300,10,6001,0,65535,65535,1,23.5,28526,-296,-296,100,98,12,3781,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4084,4081,4066,4069,4063,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.3,945,SUCCESS,,3781.231449,64,0,0.1,0.2,0.3,263,1.4,1.5
    377,5/26/2021 19:37,1511.075,0.42,701,300,10,6001,0,65535,65535,1,23.5,28524,-294,-296,100,98,12,3781,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4069,4062,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.2,971,SUCCESS,,3780.904538,64,0,0.1,0.2,0.3,263,1.4,1.5
    378,5/26/2021 19:38,1515.082,0.42,701,300,10,6001,0,65535,65535,1,23.4,28523,-296,-296,100,98,12,3780,3888,761,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4084,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.4,942,SUCCESS,,3780.575073,64,0,0.1,0.2,0.3,263,1.4,1.5
    379,5/26/2021 19:38,1519.088,0.42,701,300,10,6001,0,65535,65535,1,23.5,28523,-296,-296,100,98,12,3780,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4069,4062,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.3,1008,SUCCESS,,3780.245691,64,0,0.1,0.2,0.3,263,1.4,1.5
    380,5/26/2021 19:38,1523.103,0.42,701,300,10,6001,0,65535,65535,1,23.5,28522,-296,-296,100,98,12,3780,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4084,4081,4066,4069,4062,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.3,967,SUCCESS,,3779.915569,64,0,0.1,0.2,0.3,263,1.4,1.5
    381,5/26/2021 19:38,1527.119,0.42,701,300,10,6001,0,65535,65535,1,23.4,28522,-298,-296,100,98,12,3779,3888,761,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4083,4084,4081,4066,4068,4063,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,1012,SUCCESS,,3779.583133,64,0,0.1,0.2,0.3,263,1.4,1.5
    382,5/26/2021 19:38,1531.121,0.43,701,300,10,6001,0,65535,65535,1,23.5,28522,-294,-296,100,98,12,3779,3888,771,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4069,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,943,SUCCESS,,3779.256303,64,0,0.1,0.2,0.3,263,1.4,1.5
    383,5/26/2021 19:38,1535.127,0.43,701,300,10,6001,0,65535,65535,1,23.4,28521,-298,-296,100,98,12,3779,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.5,-273.2,23.5,-273.2,23.3,969,SUCCESS,,3778.924695,64,0,0.1,0.2,0.3,263,1.4,1.5
    384,5/26/2021 19:38,1539.137,0.43,701,300,10,6001,0,65535,65535,1,23.4,28520,-298,-297,100,98,12,3778,3888,761,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,958,SUCCESS,,3778.592756,64,0,0.1,0.2,0.3,263,1.4,1.5
    385,5/26/2021 19:38,1543.138,0.43,701,300,10,6001,0,65535,65535,1,23.5,28521,-296,-296,100,98,12,3778,3888,766,766,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,22.8,971,SUCCESS,,3778.263785,64,0,0.1,0.2,0.3,263,1.4,1.5
    386,5/26/2021 19:38,1547.146,0.43,701,300,10,6001,0,65535,65535,1,23.4,28521,-298,-297,100,98,12,3778,3888,761,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,951,SUCCESS,,3777.932012,64,0,0.1,0.2,0.3,263,1.4,1.5
    387,5/26/2021 19:38,1551.151,0.43,701,300,10,6001,0,65535,65535,1,23.4,28520,-296,-297,100,98,12,3777,3888,766,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,965,SUCCESS,,3777.602712,64,0,0.1,0.2,0.3,263,1.4,1.5
    388,5/26/2021 19:38,1555.158,0.43,701,300,10,6001,0,65535,65535,1,23.4,28521,-298,-297,100,98,12,3777,3888,760,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,940,SUCCESS,,3777.271021,64,0,0.1,0.2,0.3,263,1.4,1.5
    389,5/26/2021 19:38,1559.159,0.43,701,300,10,6001,0,65535,65535,1,23.4,28521,-298,-297,100,98,12,3777,3888,766,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,957,SUCCESS,,3776.939828,64,0,0.1,0.2,0.3,263,1.4,1.5
    390,5/26/2021 19:38,1563.167,0.43,701,300,10,6001,0,65535,65535,1,23.4,28518,-296,-297,100,98,12,3776,3888,765,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4081,4066,4069,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.4,958,SUCCESS,,3776.610281,64,0,0.1,0.2,0.3,263,1.4,1.5
    391,5/26/2021 19:38,1567.173,0.44,701,300,10,6001,0,65535,65535,1,23.4,28519,-296,-297,100,98,12,3776,3888,765,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4084,4081,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,961,SUCCESS,,3776.280899,64,0,0.1,0.2,0.3,263,1.4,1.5
    392,5/26/2021 19:38,1571.181,0.44,701,300,10,6001,0,65535,65535,1,23.4,28519,-296,-297,100,98,12,3776,3888,765,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4081,4066,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,958,SUCCESS,,3775.951352,64,0,0.1,0.2,0.3,263,1.4,1.5
    393,5/26/2021 19:39,1575.193,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-296,-297,100,98,12,3775,3888,765,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,988,SUCCESS,,3775.621476,64,0,0.1,0.2,0.3,263,1.4,1.5
    394,5/26/2021 19:39,1579.208,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-298,-296,100,98,12,3775,3888,755,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,1023,SUCCESS,,3775.289124,64,0,0.1,0.2,0.3,263,1.4,1.5
    395,5/26/2021 19:39,1583.221,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-294,-297,100,98,12,3775,3888,765,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,943,SUCCESS,,3774.961395,64,0,0.1,0.2,0.3,263,1.4,1.5
    396,5/26/2021 19:39,1587.233,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-294,-296,100,98,12,3774,3888,770,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,941,SUCCESS,,3774.633749,64,0,0.1,0.2,0.3,263,1.4,1.5
    397,5/26/2021 19:39,1591.24,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-298,-297,100,98,12,3774,3888,760,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,935,SUCCESS,,3774.302058,64,0,0.1,0.2,0.3,263,1.4,1.5
    398,5/26/2021 19:39,1595.255,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-296,-297,100,98,12,3774,3888,765,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,972,SUCCESS,,3773.971936,64,0,0.1,0.2,0.3,263,1.4,1.5
    399,5/26/2021 19:39,1599.27,0.44,701,300,10,6001,0,65535,65535,1,23.4,28518,-294,-296,100,98,12,3773,3888,770,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,22.8,962,SUCCESS,,3773.644044,64,0,0.1,0.2,0.3,263,1.4,1.5
    400,5/26/2021 19:39,1603.273,0.45,701,300,10,6001,0,65535,65535,1,23.4,28518,-296,-297,100,98,12,3773,3888,765,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,954,SUCCESS,,3773.314909,64,0,0.1,0.2,0.3,263,1.4,1.5
    401,5/26/2021 19:39,1607.288,0.45,701,300,10,6001,0,65535,65535,1,23.4,28517,-296,-296,100,98,12,3773,3888,765,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,970,SUCCESS,,3772.984786,64,0,0.1,0.2,0.3,263,1.4,1.5
    402,5/26/2021 19:39,1611.302,0.45,701,300,10,6001,0,65535,65535,1,23.4,28518,-298,-297,100,98,12,3772,3888,759,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,997,SUCCESS,,3772.652516,64,0,0.1,0.2,0.3,263,1.4,1.5
    403,5/26/2021 19:39,1615.304,0.45,701,300,10,6001,0,65535,65535,1,23.4,28517,-296,-297,100,98,12,3772,3888,765,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4062,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,986,SUCCESS,,3772.323463,64,0,0.1,0.2,0.3,263,1.4,1.5
    404,5/26/2021 19:39,1619.313,0.45,701,300,10,6001,0,65535,65535,1,23.4,28517,-296,-296,100,98,12,3772,3888,765,765,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,960,SUCCESS,,3771.993834,64,0,0.1,0.2,0.3,263,1.4,1.5
    405,5/26/2021 19:39,1623.321,0.45,701,300,10,6001,0,65535,65535,1,23.4,28517,-298,-297,100,97,12,3771,3888,759,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,966,SUCCESS,,3771.662061,64,0,0.1,0.2,0.3,263,1.4,1.5
    406,5/26/2021 19:39,1627.323,0.45,701,300,10,6001,0,65535,65535,1,23.4,28516,-296,-297,100,97,12,3771,3888,764,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4082,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,938,SUCCESS,,3771.333008,64,0,0.1,0.2,0.3,263,1.4,1.5
    407,5/26/2021 19:39,1631.329,0.45,701,300,10,6001,0,65535,65535,1,23.4,28516,-298,-297,100,97,12,3771,3888,759,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,944,SUCCESS,,3771.0014,64,0,0.1,0.2,0.3,263,1.4,1.5
    408,5/26/2021 19:40,1635.339,0.45,701,300,10,6001,0,65535,65535,1,23.4,28517,-298,-297,100,97,12,3770,3888,754,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,952,SUCCESS,,3770.669461,64,0,0.1,0.2,0.3,263,1.4,1.5
    409,5/26/2021 19:40,1639.35,0.46,701,300,10,6001,0,65535,65535,1,23.4,28516,-298,-297,100,97,12,3770,3888,764,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,949,SUCCESS,,3770.337439,64,0,0.1,0.2,0.3,263,1.4,1.5
    410,5/26/2021 19:40,1643.356,0.46,701,300,10,6001,0,65535,65535,1,23.4,28516,-298,-297,100,97,12,3770,3888,769,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,1005,SUCCESS,,3770.005831,64,0,0.1,0.2,0.3,263,1.4,1.5
    411,5/26/2021 19:40,1647.367,0.46,701,300,10,6001,0,65535,65535,1,23.4,28517,-298,-297,100,97,12,3769,3888,759,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,993,SUCCESS,,3769.67381,64,0,0.1,0.2,0.3,263,1.4,1.5
    412,5/26/2021 19:40,1651.368,0.46,701,300,10,6001,0,65535,65535,1,23.4,28515,-296,-297,100,97,12,3769,3888,764,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,960,SUCCESS,,3769.344839,64,0,0.1,0.2,0.3,263,1.4,1.5
    413,5/26/2021 19:40,1655.384,0.46,701,300,10,6001,0,65535,65535,1,23.4,28516,-296,-297,100,97,12,3769,3888,764,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4080,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,966,SUCCESS,,3769.014634,64,0,0.1,0.2,0.3,263,1.4,1.5
    414,5/26/2021 19:40,1659.384,0.46,701,300,10,6001,0,65535,65535,1,23.4,28516,-296,-297,100,97,12,3768,3888,759,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,960,SUCCESS,,3768.685745,64,0,0.1,0.2,0.3,263,1.4,1.5
    415,5/26/2021 19:40,1663.397,0.46,701,300,10,6001,0,65535,65535,1,23.4,28515,-294,-297,100,97,12,3768,3888,759,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4083,4080,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,973,SUCCESS,,3768.358017,64,0,0.1,0.2,0.3,263,1.4,1.5
    416,5/26/2021 19:40,1667.406,0.46,701,300,10,6001,0,65535,65535,1,23.4,28515,-300,-297,100,97,12,3768,3888,754,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4080,4065,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,961,SUCCESS,,3768.023934,64,0,0.1,0.2,0.3,263,1.4,1.5
    417,5/26/2021 19:40,1671.412,0.46,701,300,10,6001,0,65535,65535,1,23.4,28513,-296,-297,100,97,12,3767,3888,764,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4080,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,972,SUCCESS,,3767.694551,64,0,0.1,0.2,0.3,263,1.4,1.5
    418,5/26/2021 19:40,1675.416,0.47,701,300,10,6001,0,65535,65535,1,23.4,28513,-296,-297,100,97,12,3767,3888,758,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4080,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,948,SUCCESS,,3767.365334,64,0,0.1,0.2,0.3,263,1.4,1.5
    419,5/26/2021 19:40,1679.42,0.47,701,300,10,6001,0,65535,65535,1,23.4,28512,-298,-297,100,97,12,3767,3888,764,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4080,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,965,SUCCESS,,3767.033891,64,0,0.1,0.2,0.3,263,1.4,1.5
    420,5/26/2021 19:40,1683.435,0.47,701,300,10,6001,0,65535,65535,1,23.4,28512,-294,-297,100,97,12,3766,3888,763,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4079,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,967,SUCCESS,,3766.706,64,0,0.1,0.2,0.3,263,1.4,1.5
    421,5/26/2021 19:40,1687.436,0.47,701,300,10,6001,0,65535,65535,1,23.4,28512,-298,-297,100,97,12,3766,3888,758,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,942,SUCCESS,,3766.374806,64,0,0.1,0.2,0.3,263,1.4,1.5
    422,5/26/2021 19:40,1691.441,0.47,701,300,10,6001,0,65535,65535,1,23.4,28512,-294,-297,100,97,12,3766,3888,763,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4079,4064,4068,4061,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,961,SUCCESS,,3766.047731,64,0,0.1,0.2,0.3,263,1.4,1.5
    423,5/26/2021 19:41,1695.449,0.47,701,300,10,6001,0,65535,65535,1,23.4,28511,-294,-296,100,97,12,3765,3888,768,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,964,SUCCESS,,3765.720411,64,0,0.1,0.2,0.3,263,1.4,1.5
    424,5/26/2021 19:41,1699.453,0.47,701,300,10,6001,0,65535,65535,1,23.4,28512,-296,-297,100,97,12,3765,3888,758,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4081,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,940,SUCCESS,,3765.391193,64,0,0.1,0.2,0.3,263,1.4,1.5
    425,5/26/2021 19:41,1703.462,0.47,701,300,10,6001,0,65535,65535,1,23.4,28511,-292,-297,100,97,12,3765,3888,763,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,998,SUCCESS,,3765.066019,64,0,0.1,0.2,0.3,263,1.4,1.5
    426,5/26/2021 19:41,1707.473,0.47,701,300,10,6001,0,65535,65535,1,23.4,28511,-298,-296,100,97,12,3764,3888,758,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,941,SUCCESS,,3764.733997,64,0,0.1,0.2,0.3,263,1.4,1.5
    427,5/26/2021 19:41,1711.478,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3764,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,932,SUCCESS,,3764.404697,64,0,0.1,0.2,0.3,263,1.4,1.5
    428,5/26/2021 19:41,1715.479,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3764,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,952,SUCCESS,,3764.075726,64,0,0.1,0.2,0.3,263,1.4,1.5
    429,5/26/2021 19:41,1719.492,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3763,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,961,SUCCESS,,3763.745768,64,0,0.1,0.2,0.3,263,1.4,1.5
    430,5/26/2021 19:41,1723.493,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3763,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,934,SUCCESS,,3763.416797,64,0,0.1,0.2,0.3,263,1.4,1.5
    431,5/26/2021 19:41,1727.5,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3763,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,22.7,969,SUCCESS,,3763.087333,64,0,0.1,0.2,0.3,263,1.4,1.5
    432,5/26/2021 19:41,1731.509,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3762,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,963,SUCCESS,,3762.757704,64,0,0.1,0.2,0.3,263,1.4,1.5
    433,5/26/2021 19:41,1735.52,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-298,-296,100,97,12,3762,3888,757,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,939,SUCCESS,,3762.425682,64,0,0.1,0.2,0.3,263,1.4,1.5
    434,5/26/2021 19:41,1739.522,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-296,-296,100,97,12,3762,3888,763,763,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,950,SUCCESS,,3762.096629,64,0,0.1,0.2,0.3,263,1.4,1.5
    435,5/26/2021 19:41,1743.526,0.48,701,300,10,6001,0,65535,65535,1,23.4,28511,-298,-297,100,97,12,3761,3888,757,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,965,SUCCESS,,3761.765186,64,0,0.1,0.2,0.3,263,1.4,1.5
    436,5/26/2021 19:41,1747.536,0.49,701,300,10,6001,0,65535,65535,1,23.4,28510,-294,-296,100,97,12,3761,3888,768,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,989,SUCCESS,,3761.437703,64,0,0.1,0.2,0.3,263,1.4,1.5
    437,5/26/2021 19:41,1751.55,0.49,701,300,10,6001,0,65535,65535,1,23.4,28510,-298,-297,100,97,12,3761,3888,757,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,958,SUCCESS,,3761.105433,64,0,0.1,0.2,0.3,263,1.4,1.5
    438,5/26/2021 19:42,1755.557,0.49,701,300,10,6001,0,65535,65535,1,23.4,28510,-296,-297,100,97,12,3760,3888,762,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,983,SUCCESS,,3760.775969,64,0,0.1,0.2,0.3,263,1.4,1.5
    439,5/26/2021 19:42,1759.558,0.49,701,300,10,6001,0,65535,65535,1,23.4,28510,-296,-296,100,97,12,3760,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4078,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,984,SUCCESS,,3760.446998,64,0,0.1,0.2,0.3,263,1.4,1.5
    440,5/26/2021 19:42,1763.563,0.49,701,300,10,6001,0,65535,65535,1,23.4,28508,-298,-297,100,97,12,3760,3888,757,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4078,4064,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,940,SUCCESS,,3760.115473,64,0,0.1,0.2,0.3,263,1.4,1.5
    441,5/26/2021 19:42,1767.573,0.49,701,300,10,6001,0,65535,65535,1,23.4,28510,-296,-296,100,97,12,3759,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,976,SUCCESS,,3759.785761,64,0,0.1,0.2,0.3,263,1.4,1.5
    442,5/26/2021 19:42,1771.584,0.49,701,300,10,6001,0,65535,65535,1,23.4,28508,-296,-296,100,97,12,3759,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,949,SUCCESS,,3759.455968,64,0,0.1,0.2,0.3,263,1.4,1.5
    443,5/26/2021 19:42,1775.585,0.49,701,300,10,6001,0,65535,65535,1,23.4,28507,-296,-296,100,97,12,3759,3888,767,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4082,4079,4063,4069,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,949,SUCCESS,,3759.126997,64,0,0.1,0.2,0.3,263,1.4,1.5
    444,5/26/2021 19:42,1779.595,0.49,701,300,10,6001,0,65535,65535,1,23.4,28508,-296,-296,100,97,12,3758,3888,767,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,940,SUCCESS,,3758.797286,64,0,0.1,0.2,0.3,263,1.4,1.5
    445,5/26/2021 19:42,1783.596,0.5,701,300,10,6001,0,65535,65535,1,23.4,28508,-294,-296,100,97,12,3758,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4060,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,22.7,938,SUCCESS,,3758.470538,64,0,0.1,0.2,0.3,263,1.4,1.5
    446,5/26/2021 19:42,1787.601,0.5,701,300,10,6001,0,65535,65535,1,23.4,28507,-296,-296,100,97,12,3758,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,947,SUCCESS,,3758.141238,64,0,0.1,0.2,0.3,263,1.4,1.5
    447,5/26/2021 19:42,1791.601,0.5,701,300,10,6001,0,65535,65535,1,23.4,28507,-298,-296,100,97,12,3757,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,964,SUCCESS,,3757.810126,64,0,0.1,0.2,0.3,263,1.4,1.5
    448,5/26/2021 19:42,1795.607,0.5,701,300,10,6001,0,65535,65535,1,23.4,28508,-296,-296,100,97,12,3757,3888,762,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,950,SUCCESS,,3757.480744,64,0,0.1,0.2,0.3,263,1.4,1.5
    449,5/26/2021 19:42,1799.618,0.5,701,300,10,6001,0,65535,65535,1,23.4,28507,-296,-296,100,97,12,3757,3888,756,762,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4080,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,953,SUCCESS,,3757.150951,64,0,0.1,0.2,0.3,263,1.4,1.5
    450,5/26/2021 19:42,1803.62,0.5,701,300,10,6001,0,65535,65535,1,23.4,28506,-296,-296,100,97,12,3756,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4079,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,972,SUCCESS,,3756.821898,64,0,0.1,0.2,0.3,263,1.4,1.5
    451,5/26/2021 19:42,1807.624,0.5,701,300,10,6001,0,65535,65535,1,23.4,28506,-296,-296,100,97,12,3756,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4079,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,940,SUCCESS,,3756.49268,64,0,0.1,0.2,0.3,263,1.4,1.5
    452,5/26/2021 19:42,1811.635,0.5,701,300,10,6001,0,65535,65535,1,23.4,28506,-296,-296,100,97,12,3756,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,998,SUCCESS,,3756.162886,64,0,0.1,0.2,0.3,263,1.4,1.5
    453,5/26/2021 19:43,1815.644,0.5,701,300,10,6001,0,65535,65535,1,23.4,28506,-298,-296,100,97,12,3755,3888,756,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4079,4081,4077,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,936,SUCCESS,,3755.83103,64,0,0.1,0.2,0.3,263,1.4,1.5
    454,5/26/2021 19:43,1819.659,0.51,701,300,10,6001,0,65535,65535,1,23.4,28505,-296,-297,100,97,12,3755,3888,761,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4079,4081,4077,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,939,SUCCESS,,3755.500908,64,0,0.1,0.2,0.3,263,1.4,1.5
    455,5/26/2021 19:43,1823.666,0.51,701,300,10,6001,0,65535,65535,1,23.4,28504,-296,-297,100,97,12,3755,3888,761,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4081,4078,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,999,SUCCESS,,3755.171444,64,0,0.1,0.2,0.3,263,1.4,1.5
    456,5/26/2021 19:43,1827.671,0.51,701,300,10,6001,0,65535,65535,1,23.4,28505,-298,-297,100,97,12,3754,3888,761,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4078,4079,4081,4077,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,993,SUCCESS,,3754.839919,64,0,0.1,0.2,0.3,263,1.4,1.5
    457,5/26/2021 19:43,1831.684,0.51,701,300,10,6001,0,65535,65535,1,23.4,28504,-296,-297,100,97,12,3754,3888,761,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4081,4077,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,944,SUCCESS,,3754.509961,64,0,0.1,0.2,0.3,263,1.4,1.5
    458,5/26/2021 19:43,1835.686,0.51,701,300,10,6001,0,65535,65535,1,23.4,28502,-298,-296,100,97,12,3754,3888,766,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4080,4077,4062,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,948,SUCCESS,,3754.178684,64,0,0.1,0.2,0.3,263,1.4,1.5
    459,5/26/2021 19:43,1839.689,0.51,701,300,10,6001,0,65535,65535,1,23.4,28502,-298,-296,100,97,12,3753,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4081,4077,4063,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,22.7,957,SUCCESS,,3753.847325,64,0,0.1,0.2,0.3,263,1.4,1.5
    460,5/26/2021 19:43,1843.702,0.51,701,300,10,6001,0,65535,65535,1,23.4,28502,-296,-296,100,97,12,3753,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4080,4077,4063,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,955,SUCCESS,,3753.517367,64,0,0.1,0.2,0.3,263,1.4,1.5
    461,5/26/2021 19:43,1847.707,0.51,701,300,10,6001,0,65535,65535,1,23.4,28501,-298,-296,100,97,12,3753,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4080,4078,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,942,SUCCESS,,3753.185842,64,0,0.1,0.2,0.3,263,1.4,1.5
    462,5/26/2021 19:43,1851.707,0.51,701,300,10,6001,0,65535,65535,1,23.4,28500,-296,-296,100,97,12,3752,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,988,SUCCESS,,3752.856953,64,0,0.1,0.2,0.3,263,1.4,1.5
    463,5/26/2021 19:43,1855.722,0.52,701,300,10,6001,0,65535,65535,1,23.4,28500,-294,-296,100,97,12,3752,3888,761,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4080,4077,4062,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,954,SUCCESS,,3752.529061,64,0,0.1,0.2,0.3,263,1.4,1.5
    464,5/26/2021 19:43,1859.735,0.52,701,300,10,6001,0,65535,65535,1,23.4,28500,-296,-296,100,97,12,3752,3888,766,761,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4080,4077,4062,4068,4059,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,939,SUCCESS,,3752.199104,64,0,0.1,0.2,0.3,263,1.4,1.5
    465,5/26/2021 19:43,1863.749,0.52,701,300,10,6001,0,65535,65535,1,23.4,28501,-298,-296,100,97,12,3751,3888,760,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4077,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,949,SUCCESS,,3751.866834,64,0,0.1,0.2,0.3,263,1.4,1.5
    466,5/26/2021 19:43,1867.754,0.52,701,300,10,6001,0,65535,65535,1,23.4,28499,-296,-296,100,97,12,3751,3888,760,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,940,SUCCESS,,3751.537534,64,0,0.1,0.2,0.3,263,1.4,1.5
    467,5/26/2021 19:43,1871.762,0.52,701,300,10,6001,0,65535,65535,1,23.4,28500,-298,-297,100,97,12,3751,3888,750,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,944,SUCCESS,,3751.20576,64,0,0.1,0.2,0.3,263,1.4,1.5
    468,5/26/2021 19:44,1875.774,0.52,701,300,10,6001,0,65535,65535,1,23.4,28500,-296,-297,100,97,12,3750,3888,760,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,969,SUCCESS,,3750.875885,64,0,0.1,0.2,0.3,263,1.4,1.5
    469,5/26/2021 19:44,1879.774,0.52,701,300,10,6001,0,65535,65535,1,23.4,28499,-298,-296,100,97,12,3750,3888,755,760,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,979,SUCCESS,,3750.544774,64,0,0.1,0.2,0.3,263,1.4,1.5
    470,5/26/2021 19:44,1883.785,0.52,701,300,10,6001,0,65535,65535,1,23.4,28500,-298,-297,100,97,12,3750,3888,755,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.3,990,SUCCESS,,3750.212752,64,0,0.1,0.2,0.3,263,1.4,1.5
    471,5/26/2021 19:44,1887.794,0.52,701,300,10,6001,0,65535,65535,1,23.4,28500,-298,-297,100,97,12,3749,3888,755,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.3,23.4,-273.2,23.4,-273.2,23.2,943,SUCCESS,,3749.880896,64,0,0.1,0.2,0.3,263,1.4,1.5
    472,5/26/2021 19:44,1891.809,0.53,701,300,10,6001,0,65535,65535,1,23.4,28500,-300,-297,100,97,12,3749,3888,750,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,981,SUCCESS,,3749.546313,64,0,0.1,0.2,0.3,263,1.4,1.5
    473,5/26/2021 19:44,1895.811,0.53,701,300,10,6001,0,65535,65535,1,23.4,28499,-296,-297,100,97,12,3749,3888,760,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4076,4062,4067,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,22.7,954,SUCCESS,,3749.217259,64,0,0.1,0.2,0.3,263,1.4,1.5
    474,5/26/2021 19:44,1899.814,0.53,701,300,10,6001,0,65535,65535,1,23.4,28500,-296,-297,100,97,12,3748,3888,760,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4079,4080,4077,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,941,SUCCESS,,3748.888124,64,0,0.1,0.2,0.3,263,1.4,1.5
    475,5/26/2021 19:44,1903.814,0.53,701,300,10,6001,0,65535,65535,1,23.4,28496,-296,-297,100,97,12,3748,3888,760,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4076,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,976,SUCCESS,,3748.559235,64,0,0.1,0.2,0.3,263,1.4,1.5
    476,5/26/2021 19:44,1907.824,0.53,701,300,10,6001,0,65535,65535,1,23.4,28497,-296,-297,100,97,12,3748,3888,760,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4076,4062,4066,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,983,SUCCESS,,3748.229524,64,0,0.1,0.2,0.3,263,1.4,1.5
    477,5/26/2021 19:44,1911.834,0.53,701,300,10,6001,0,65535,65535,1,23.4,28497,-298,-297,100,97,12,3747,3888,754,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4075,4062,4068,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,1017,SUCCESS,,3747.897585,64,0,0.1,0.2,0.3,263,1.4,1.5
    478,5/26/2021 19:44,1915.837,0.53,701,300,10,6001,0,65535,65535,1,23.4,28496,-296,-297,100,97,12,3747,3888,760,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4076,4062,4067,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,993,SUCCESS,,3747.568449,64,0,0.1,0.2,0.3,263,1.4,1.5
    479,5/26/2021 19:44,1919.852,0.53,701,300,10,6001,0,65535,65535,1,23.4,28496,-294,-297,100,97,12,3747,3888,765,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4076,4062,4066,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,982,SUCCESS,,3747.240558,64,0,0.1,0.2,0.3,263,1.4,1.5
    480,5/26/2021 19:44,1923.866,0.53,701,300,10,6001,0,65535,65535,1,23.4,28497,-296,-297,100,97,12,3746,3888,754,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4076,4078,4080,4076,4062,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,997,SUCCESS,,3746.910518,64,0,0.1,0.2,0.3,263,1.4,1.5
    481,5/26/2021 19:44,1927.867,0.54,701,300,10,6001,0,65535,65535,1,23.4,28495,-294,-297,100,97,12,3746,3888,764,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4080,4076,4062,4067,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,1016,SUCCESS,,3746.583769,64,0,0.1,0.2,0.3,263,1.4,1.5
    482,5/26/2021 19:44,1931.88,0.54,701,300,10,6001,0,65535,65535,1,23.4,28495,-296,-296,100,97,12,3746,3888,759,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4080,4075,4062,4066,4058,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,997,SUCCESS,,3746.253811,64,0,0.1,0.2,0.3,263,1.4,1.5
    483,5/26/2021 19:45,1935.885,0.54,701,300,10,6001,0,65535,65535,1,23.4,28494,-300,-297,100,97,12,3745,3888,754,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4080,4076,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,968,SUCCESS,,3745.920061,64,0,0.1,0.2,0.3,263,1.4,1.5
    484,5/26/2021 19:45,1939.891,0.54,701,300,10,6001,0,65535,65535,1,23.4,28494,-296,-297,100,97,12,3745,3888,759,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4080,4076,4062,4067,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,963,SUCCESS,,3745.590679,64,0,0.1,0.2,0.3,263,1.4,1.5
    485,5/26/2021 19:45,1943.907,0.54,701,300,10,6001,0,65535,65535,1,23.4,28495,-296,-296,100,97,12,3745,3888,759,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4079,4075,4062,4067,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,960,SUCCESS,,3745.260475,64,0,0.1,0.2,0.3,263,1.4,1.5
    486,5/26/2021 19:45,1947.92,0.54,701,300,10,6001,0,65535,65535,1,23.4,28492,-296,-297,100,97,12,3744,3888,754,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4080,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,948,SUCCESS,,3744.930517,64,0,0.1,0.2,0.3,263,1.4,1.5
    487,5/26/2021 19:45,1951.932,0.54,701,300,10,6001,0,65535,65535,1,23.4,28493,-294,-296,100,97,12,3744,3888,764,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4079,4075,4062,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23,948,SUCCESS,,3744.60287,64,0,0.1,0.2,0.3,263,1.4,1.5
    488,5/26/2021 19:45,1955.938,0.54,701,300,10,6001,0,65535,65535,1,23.4,28491,-296,-296,100,97,12,3744,3888,759,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4079,4075,4062,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,954,SUCCESS,,3744.273488,64,0,0.1,0.2,0.3,263,1.4,1.5
    489,5/26/2021 19:45,1959.95,0.54,701,300,10,6001,0,65535,65535,1,23.4,28491,-294,-297,100,97,12,3743,3888,759,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,950,SUCCESS,,3743.945841,64,0,0.1,0.2,0.3,263,1.4,1.5
    490,5/26/2021 19:45,1963.964,0.55,701,300,10,6001,0,65535,65535,1,23.4,28490,-296,-296,100,97,12,3743,3888,759,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4078,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,961,SUCCESS,,3743.615801,64,0,0.1,0.2,0.3,263,1.4,1.5
    491,5/26/2021 19:45,1967.968,0.55,701,300,10,6001,0,65535,65535,1,23.4,28491,-298,-297,100,97,12,3743,3888,759,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,961,SUCCESS,,3743.284359,64,0,0.1,0.2,0.3,263,1.4,1.5
    492,5/26/2021 19:45,1971.978,0.55,701,300,10,6001,0,65535,65535,1,23.4,28489,-296,-297,100,97,12,3742,3888,753,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,952,SUCCESS,,3742.954648,64,0,0.1,0.2,0.3,263,1.4,1.5
    493,5/26/2021 19:45,1975.979,0.55,701,300,10,6001,0,65535,65535,1,23.4,28491,-296,-296,100,97,12,3742,3888,759,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,951,SUCCESS,,3742.625677,64,0,0.1,0.2,0.3,263,1.4,1.5
    494,5/26/2021 19:45,1979.982,0.55,701,300,10,6001,0,65535,65535,1,23.4,28490,-296,-296,100,97,12,3742,3888,759,759,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,966,SUCCESS,,3742.296541,64,0,0.1,0.2,0.3,263,1.4,1.5
    495,5/26/2021 19:45,1983.987,0.55,701,300,10,6001,0,65535,65535,1,23.4,28490,-296,-296,100,97,12,3741,3888,758,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,937,SUCCESS,,3741.967241,64,0,0.1,0.2,0.3,263,1.4,1.5
    496,5/26/2021 19:45,1988.002,0.55,701,300,10,6001,0,65535,65535,1,23.4,28490,-296,-296,100,97,12,3741,3888,753,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,990,SUCCESS,,3741.637119,64,0,0.1,0.2,0.3,263,1.4,1.5
    497,5/26/2021 19:45,1992.016,0.55,701,300,10,6001,0,65535,65535,1,23.4,28490,-296,-296,100,97,12,3741,3888,753,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4066,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,946,SUCCESS,,3741.307079,64,0,0.1,0.2,0.3,263,1.4,1.5
    498,5/26/2021 19:46,1996.024,0.55,701,300,10,6001,0,65535,65535,1,23.4,28488,-294,-296,100,97,12,3740,3888,763,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4075,4077,4079,4075,4061,4065,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,965,SUCCESS,,3740.979759,64,0,0.1,0.2,0.3,263,1.4,1.5
    499,5/26/2021 19:46,2000.027,0.56,701,300,10,6001,0,65535,65535,1,23.4,28489,-296,-296,100,97,12,3740,3888,758,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,951,SUCCESS,,3740.650624,64,0,0.1,0.2,0.3,263,1.4,1.5
    500,5/26/2021 19:46,2004.034,0.56,701,300,10,6001,0,65535,65535,1,23.4,28488,-296,-296,100,97,12,3740,3888,763,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4056,0,0,0,0,0,0,0,0,2847,23.2,23.4,-273.2,23.4,-273.2,23.2,941,SUCCESS,,3740.321159,64,0,0.1,0.2,0.3,263,1.4,1.5
    501,5/26/2021 19:46,2008.044,0.56,701,300,10,6001,0,65535,65535,1,23.4,28489,-298,-296,100,97,12,3739,3888,758,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4064,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,943,SUCCESS,,3739.98922,64,0,0.1,0.2,0.3,263,1.4,1.5
    502,5/26/2021 19:46,2012.058,0.56,701,300,10,6001,0,65535,65535,1,23.4,28488,-296,-296,100,97,12,3739,3888,753,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,950,SUCCESS,,3739.65918,64,0,0.1,0.2,0.3,263,1.4,1.5
    503,5/26/2021 19:46,2016.07,0.56,701,300,10,6001,0,65535,65535,1,23.4,28488,-298,-296,100,97,12,3739,3888,763,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,952,SUCCESS,,3739.327076,64,0,0.1,0.2,0.3,263,1.4,1.5
    504,5/26/2021 19:46,2020.073,0.56,701,300,10,6001,0,65535,65535,1,23.4,28486,-298,-296,100,97,12,3738,3888,753,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4060,4065,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,960,SUCCESS,,3738.995716,64,0,0.1,0.2,0.3,263,1.4,1.5
    505,5/26/2021 19:46,2024.081,0.56,701,300,10,6001,0,65535,65535,1,23.4,28488,-296,-296,100,97,12,3738,3888,758,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4057,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,944,SUCCESS,,3738.66617,64,0,0.1,0.2,0.3,263,1.4,1.5
    506,5/26/2021 19:46,2028.096,0.56,701,300,10,6001,0,65535,65535,1,23.4,28486,-294,-296,100,97,12,3738,3888,763,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4061,4065,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,937,SUCCESS,,3738.338278,64,0,0.1,0.2,0.3,263,1.4,1.5
    507,5/26/2021 19:46,2032.097,0.56,701,300,10,6001,0,65535,65535,1,23.4,28486,-296,-296,100,97,12,3737,3888,758,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4060,4065,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.1,986,SUCCESS,,3738.009307,64,0,0.1,0.2,0.3,263,1.4,1.5
    508,5/26/2021 19:46,2036.105,0.57,701,300,10,6001,0,65535,65535,1,23.4,28487,-298,-297,100,97,12,3737,3888,752,755,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4060,4065,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.1,965,SUCCESS,,3737.677534,64,0,0.1,0.2,0.3,263,1.4,1.5
    509,5/26/2021 19:46,2040.11,0.57,701,300,10,6001,0,65535,65535,1,23.4,28486,-296,-296,100,97,12,3737,3888,758,758,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4060,4065,4056,0,0,0,0,0,0,0,0,2847,23.2,23.4,-273.2,23.4,-273.2,23.1,955,SUCCESS,,3737.348234,64,0,0.1,0.2,0.3,263,1.4,1.5
    510,5/26/2021 19:46,2044.123,0.57,701,300,10,6001,0,65535,65535,1,23.4,28486,-296,-296,100,97,12,3736,3888,757,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4079,4075,4060,4066,4055,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,957,SUCCESS,,3737.018276,64,0,0.1,0.2,0.3,263,1.4,1.5
    511,5/26/2021 19:46,2048.136,0.57,701,300,10,6001,0,65535,65535,1,23.4,28485,-296,-296,100,97,12,3736,3888,757,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4078,4075,4061,4064,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,961,SUCCESS,,3736.688318,64,0,0.1,0.2,0.3,263,1.4,1.5
    512,5/26/2021 19:46,2052.142,0.57,701,300,10,6001,0,65535,65535,1,23.4,28484,-298,-296,100,97,12,3736,3888,752,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4076,4078,4075,4061,4065,4055,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,943,SUCCESS,,3736.35671,64,0,0.1,0.2,0.3,263,1.4,1.5
    513,5/26/2021 19:47,2056.142,0.57,701,300,10,6001,0,65535,65535,1,23.4,28485,-296,-296,100,97,12,3735,3888,757,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4078,4075,4060,4065,4055,0,0,0,0,0,0,0,0,2844,23.2,23.4,-273.2,23.4,-273.2,23.2,940,SUCCESS,,3736.027821,64,0,0.1,0.2,0.3,263,1.4,1.5
    514,5/26/2021 19:47,2060.15,0.57,701,300,10,6001,0,65535,65535,1,23.4,28483,-294,-296,100,97,12,3735,3888,762,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4078,4075,4060,4065,4056,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,951,SUCCESS,,3735.700501,64,0,0.1,0.2,0.3,263,1.4,1.5
    515,5/26/2021 19:47,2064.162,0.57,701,300,10,6001,0,65535,65535,1,23.4,28485,-298,-296,100,97,12,3735,3888,757,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4076,4078,4075,4059,4064,4055,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.3,984,SUCCESS,,3735.368397,64,0,0.1,0.2,0.3,263,1.4,1.5
    516,5/26/2021 19:47,2068.171,0.57,701,300,10,6001,0,65535,65535,1,23.4,28484,-296,-296,100,97,12,3734,3888,762,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4078,4075,4060,4068,4055,0,0,0,0,0,0,0,0,2848,23.2,23.4,-273.2,23.4,-273.2,23.2,941,SUCCESS,,3735.038768,64,0,0.1,0.2,0.3,263,1.4,1.5
    517,5/26/2021 19:47,2072.181,0.58,701,300,10,6001,0,65535,65535,1,23.4,28483,-298,-296,100,97,12,3734,3888,752,757,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4078,4075,4060,4065,4055,0,0,0,0,0,0,0,0,2844,23.2,23.4,-273.2,23.4,-273.2,23.2,947,SUCCESS,,3734.706829,64,0,0.1,0.2,0.3,263,1.4,1.5
    518,5/26/2021 19:47,2076.182,0.58,701,300,10,6001,0,65535,65535,1,23.4,28484,-300,-297,100,97,12,3734,3888,747,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4077,4078,4075,4060,4065,4055,0,0,0,0,0,0,0,0,2844,23.2,23.4,-273.2,23.4,-273.2,23.1,988,SUCCESS,,3734.373413,64,0,0.1,0.2,0.3,263,1.4,1.5
    519,5/26/2021 19:47,2080.186,0.58,701,300,10,6001,0,65535,65535,1,23.4,28484,-294,-297,100,97,12,3733,3888,757,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4074,4076,4078,4075,4060,4065,4055,0,0,0,0,0,0,0,0,2847,23.2,23.4,-273.2,23.4,-273.2,22.5,958,SUCCESS,,3734.046419,64,0,0.1,0.2,0.3,263,1.4,1.5
    520,5/26/2021 19:47,2084.197,0.58,701,300,10,6001,0,65535,65535,1,23.4,28483,-296,-297,100,97,12,3733,3888,752,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4065,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,967,SUCCESS,,3733.716626,64,0,0.1,0.2,0.3,263,1.4,1.5
    521,5/26/2021 19:47,2088.209,0.58,701,300,10,6001,0,65535,65535,1,23.4,28482,-296,-297,100,97,12,3733,3888,752,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2844,23.2,23.4,-273.2,23.4,-273.2,23.2,988,SUCCESS,,3733.38675,64,0,0.1,0.2,0.3,263,1.4,1.5
    522,5/26/2021 19:47,2092.219,0.58,701,300,10,6001,0,65535,65535,1,23.4,28481,-296,-296,100,96,12,3732,3888,756,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,941,SUCCESS,,3733.057039,64,0,0.1,0.2,0.3,263,1.4,1.5
    523,5/26/2021 19:47,2096.225,0.58,701,300,10,6001,0,65535,65535,1,23.4,28481,-296,-297,100,96,12,3732,3888,751,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2847,23.2,23.4,-273.2,23.4,-273.2,23.1,985,SUCCESS,,3732.727657,64,0,0.1,0.2,0.3,263,1.4,1.5
    524,5/26/2021 19:47,2100.226,0.58,701,300,10,6001,0,65535,65535,1,23.4,28481,-296,-296,100,96,12,3732,3888,762,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2844,23.2,23.4,-273.2,23.4,-273.2,23.2,963,SUCCESS,,3732.398686,64,0,0.1,0.2,0.3,263,1.4,1.5
    525,5/26/2021 19:47,2104.229,0.58,701,300,10,6001,0,65535,65535,1,23.4,28482,-296,-297,100,96,12,3731,3888,751,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,946,SUCCESS,,3732.06955,64,0,0.1,0.2,0.3,263,1.4,1.5
    526,5/26/2021 19:47,2108.239,0.59,701,300,10,6001,0,65535,65535,1,23.4,28480,-296,-297,100,96,12,3731,3888,756,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,941,SUCCESS,,3731.739839,64,0,0.1,0.2,0.3,263,1.4,1.5
    527,5/26/2021 19:47,2112.252,0.59,701,300,10,6001,0,65535,65535,1,23.3,28482,-296,-297,100,96,12,3731,3888,756,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4078,4075,4060,4065,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,959,SUCCESS,,3731.409881,64,0,0.1,0.2,0.3,263,1.4,1.5
    528,5/26/2021 19:48,2116.252,0.59,701,300,10,6001,0,65535,65535,1,23.3,28480,-296,-296,100,96,12,3730,3888,756,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,22.6,956,SUCCESS,,3731.080993,64,0,0.1,0.2,0.3,263,1.4,1.5
    529,5/26/2021 19:48,2120.259,0.59,701,300,10,6001,0,65535,65535,1,23.4,28480,-296,-296,100,96,12,3730,3888,756,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.1,964,SUCCESS,,3730.751528,64,0,0.1,0.2,0.3,263,1.4,1.5
    530,5/26/2021 19:48,2124.266,0.59,701,300,10,6001,0,65535,65535,1,23.3,28480,-294,-296,100,96,12,3730,3888,761,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,978,SUCCESS,,3730.42429,64,0,0.1,0.2,0.3,263,1.4,1.5
    531,5/26/2021 19:48,2128.274,0.59,701,300,10,6001,0,65535,65535,1,23.4,28481,-296,-296,100,96,12,3729,3888,756,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,949,SUCCESS,,3730.094743,64,0,0.1,0.2,0.3,263,1.4,1.5
    532,5/26/2021 19:48,2132.276,0.59,701,300,10,6001,0,65535,65535,1,23.3,28481,-296,-296,100,96,12,3729,3888,756,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4059,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,988,SUCCESS,,3729.76569,64,0,0.1,0.2,0.3,263,1.4,1.5
    533,5/26/2021 19:48,2136.284,0.59,701,300,10,6001,0,65535,65535,1,23.3,28481,-296,-296,100,96,12,3729,3888,751,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,960,SUCCESS,,3729.436143,64,0,0.1,0.2,0.3,263,1.4,1.5
    534,5/26/2021 19:48,2140.297,0.59,701,300,10,6001,0,65535,65535,1,23.3,28479,-298,-296,100,96,12,3728,3888,751,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,958,SUCCESS,,3729.103956,64,0,0.1,0.2,0.3,263,1.4,1.5
    535,5/26/2021 19:48,2144.302,0.6,701,300,10,6001,0,65535,65535,1,23.3,28479,-296,-297,100,96,12,3728,3888,751,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4076,4077,4075,4059,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,976,SUCCESS,,3728.774656,64,0,0.1,0.2,0.3,263,1.4,1.5
    536,5/26/2021 19:48,2148.315,0.6,701,300,10,6001,0,65535,65535,1,23.3,28478,-296,-296,100,96,12,3728,3888,751,756,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4076,4077,4075,4060,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,955,SUCCESS,,3728.444698,64,0,0.1,0.2,0.3,263,1.4,1.5
    537,5/26/2021 19:48,2152.32,0.6,701,300,10,6001,0,65535,65535,1,23.3,28476,-296,-297,100,96,12,3727,3888,745,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4073,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,949,SUCCESS,,3728.115398,64,0,0.1,0.2,0.3,263,1.4,1.5
    538,5/26/2021 19:48,2156.335,0.6,701,300,10,6001,0,65535,65535,1,23.3,28477,-296,-297,100,96,12,3727,3888,750,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4076,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,975,SUCCESS,,3727.785276,64,0,0.1,0.2,0.3,263,1.4,1.5
    539,5/26/2021 19:48,2160.342,0.6,701,300,10,6001,0,65535,65535,1,23.4,28477,-296,-297,100,96,12,3727,3888,755,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4064,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,965,SUCCESS,,3727.455811,64,0,0.1,0.2,0.3,263,1.4,1.5
    540,5/26/2021 19:48,2164.353,0.6,701,300,10,6001,0,65535,65535,1,23.4,28477,-296,-297,100,96,12,3727,3888,755,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.4,-273.2,23.4,-273.2,23.2,938,SUCCESS,,3727.126018,64,0,0.1,0.2,0.3,263,1.4,1.5
    541,5/26/2021 19:48,2168.366,0.6,701,300,10,6001,0,65535,65535,1,23.3,28478,-296,-297,100,96,12,3726,3888,760,755,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4076,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,974,SUCCESS,,3726.79606,64,0,0.1,0.2,0.3,263,1.4,1.5
    542,5/26/2021 19:48,2172.369,0.6,701,300,10,6001,0,65535,65535,1,23.3,28477,-298,-297,100,96,12,3726,3888,750,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,968,SUCCESS,,3726.464701,64,0,0.1,0.2,0.3,263,1.4,1.5
    543,5/26/2021 19:49,2176.369,0.6,701,300,10,6001,0,65535,65535,1,23.3,28476,-296,-296,100,96,12,3725,3888,755,755,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,933,SUCCESS,,3726.135812,64,0,0.1,0.2,0.3,263,1.4,1.5
    544,5/26/2021 19:49,2180.38,0.61,701,300,10,6001,0,65535,65535,1,23.3,28478,-296,-296,100,96,12,3725,3888,755,755,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,936,SUCCESS,,3725.806019,64,0,0.1,0.2,0.3,263,1.4,1.5
    545,5/26/2021 19:49,2184.38,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-298,-297,100,96,12,3725,3888,750,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,988,SUCCESS,,3725.474908,64,0,0.1,0.2,0.3,263,1.4,1.5
    546,5/26/2021 19:49,2188.383,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-296,-296,100,96,12,3724,3888,755,755,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,988,SUCCESS,,3725.145772,64,0,0.1,0.2,0.3,263,1.4,1.5
    547,5/26/2021 19:49,2192.389,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-298,-297,100,96,12,3724,3888,750,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,951,SUCCESS,,3724.814164,64,0,0.1,0.2,0.3,263,1.4,1.5
    548,5/26/2021 19:49,2196.4,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-298,-297,100,96,12,3724,3888,750,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,984,SUCCESS,,3724.482143,64,0,0.1,0.2,0.3,263,1.4,1.5
    549,5/26/2021 19:49,2200.407,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-296,-297,100,96,12,3723,3888,755,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,941,SUCCESS,,3724.152678,64,0,0.1,0.2,0.3,263,1.4,1.5
    550,5/26/2021 19:49,2204.412,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-298,-297,100,96,12,3723,3888,750,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,950,SUCCESS,,3723.821153,64,0,0.1,0.2,0.3,263,1.4,1.5
    551,5/26/2021 19:49,2208.416,0.61,701,300,10,6001,0,65535,65535,1,23.4,28476,-298,-297,100,96,12,3723,3888,750,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23,977,SUCCESS,,3723.489711,64,0,0.1,0.2,0.3,263,1.4,1.5
    552,5/26/2021 19:49,2212.422,0.61,701,300,10,6001,0,65535,65535,1,23.3,28476,-298,-297,100,96,12,3722,3888,749,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,941,SUCCESS,,3723.158103,64,0,0.1,0.2,0.3,263,1.4,1.5
    553,5/26/2021 19:49,2216.433,0.62,701,300,10,6001,0,65535,65535,1,23.3,28475,-298,-297,100,96,12,3722,3888,749,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4076,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,946,SUCCESS,,3722.826081,64,0,0.1,0.2,0.3,263,1.4,1.5
    554,5/26/2021 19:49,2220.448,0.62,701,300,10,6001,0,65535,65535,1,23.3,28474,-294,-297,100,96,12,3722,3888,760,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4059,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,948,SUCCESS,,3722.49819,64,0,0.1,0.2,0.3,263,1.4,1.5
    555,5/26/2021 19:49,2224.457,0.62,701,300,10,6001,0,65535,65535,1,23.3,28475,-298,-297,100,96,12,3721,3888,749,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,938,SUCCESS,,3722.166334,64,0,0.1,0.2,0.3,263,1.4,1.5
    556,5/26/2021 19:49,2228.467,0.62,701,300,10,6001,0,65535,65535,1,23.3,28474,-296,-297,100,96,12,3721,3888,754,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,943,SUCCESS,,3721.836623,64,0,0.1,0.2,0.3,263,1.4,1.5
    557,5/26/2021 19:49,2232.478,0.62,701,300,10,6001,0,65535,65535,1,23.3,28474,-296,-297,100,96,12,3721,3888,759,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4077,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,937,SUCCESS,,3721.506829,64,0,0.1,0.2,0.3,263,1.4,1.5
    558,5/26/2021 19:50,2236.488,0.62,701,300,10,6001,0,65535,65535,1,23.3,28474,-298,-297,100,96,12,3720,3888,754,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4077,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,1000,SUCCESS,,3721.17489,64,0,0.1,0.2,0.3,263,1.4,1.5
    559,5/26/2021 19:50,2240.491,0.62,701,300,10,6001,0,65535,65535,1,23.3,28470,-298,-297,100,96,12,3720,3888,749,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4075,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,965,SUCCESS,,3720.843531,64,0,0.1,0.2,0.3,263,1.4,1.5
    560,5/26/2021 19:50,2244.5,0.62,701,300,10,6001,0,65535,65535,1,23.3,28473,-298,-296,100,96,12,3720,3888,754,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,946,SUCCESS,,3720.511675,64,0,0.1,0.2,0.3,263,1.4,1.5
    561,5/26/2021 19:50,2248.515,0.62,701,300,10,6001,0,65535,65535,1,23.3,28473,-298,-297,100,96,12,3720,3888,749,752,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,962,SUCCESS,,3720.179322,64,0,0.1,0.2,0.3,263,1.4,1.5
    562,5/26/2021 19:50,2252.526,0.63,701,300,10,6001,0,65535,65535,1,23.3,28473,-294,-297,100,96,12,3719,3888,754,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,932,SUCCESS,,3719.851757,64,0,0.1,0.2,0.3,263,1.4,1.5
    563,5/26/2021 19:50,2256.533,0.63,701,300,10,6001,0,65535,65535,1,23.3,28471,-298,-296,100,96,12,3719,3888,749,754,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,956,SUCCESS,,3719.520066,64,0,0.1,0.2,0.3,263,1.4,1.5
    564,5/26/2021 19:50,2260.541,0.63,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-297,100,96,12,3719,3888,754,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,949,SUCCESS,,3719.19052,64,0,0.1,0.2,0.3,263,1.4,1.5
    565,5/26/2021 19:50,2264.547,0.63,701,300,10,6001,0,65535,65535,1,23.3,28474,-294,-297,100,96,12,3718,3888,754,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4072,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,941,SUCCESS,,3718.863363,64,0,0.1,0.2,0.3,263,1.4,1.5
    566,5/26/2021 19:50,2268.55,0.63,701,300,10,6001,0,65535,65535,1,23.3,28471,-298,-297,100,96,12,3718,3888,749,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,987,SUCCESS,,3718.532004,64,0,0.1,0.2,0.3,263,1.4,1.5
    567,5/26/2021 19:50,2272.552,0.63,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-297,100,96,12,3718,3888,749,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,969,SUCCESS,,3718.20295,64,0,0.1,0.2,0.3,263,1.4,1.5
    568,5/26/2021 19:50,2276.566,0.63,701,300,10,6001,0,65535,65535,1,23.3,28473,-298,-297,100,96,12,3717,3888,748,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,940,SUCCESS,,3717.87068,64,0,0.1,0.2,0.3,263,1.4,1.5
    569,5/26/2021 19:50,2280.568,0.63,701,300,10,6001,0,65535,65535,1,23.3,28471,-298,-297,100,96,12,3717,3888,748,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,951,SUCCESS,,3717.539404,64,0,0.1,0.2,0.3,263,1.4,1.5
    570,5/26/2021 19:50,2284.571,0.63,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-297,100,96,12,3717,3888,753,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,954,SUCCESS,,3717.210268,64,0,0.1,0.2,0.3,263,1.4,1.5
    571,5/26/2021 19:50,2288.573,0.64,701,300,10,6001,0,65535,65535,1,23.3,28474,-298,-297,100,96,12,3716,3888,753,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.2,930,SUCCESS,,3716.878991,64,0,0.1,0.2,0.3,263,1.4,1.5
    572,5/26/2021 19:50,2292.58,0.64,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-297,100,96,12,3716,3888,748,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.2,23.3,-273.2,23.3,-273.2,23.1,993,SUCCESS,,3716.549527,64,0,0.1,0.2,0.3,263,1.4,1.5
    573,5/26/2021 19:51,2296.591,0.64,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-297,100,96,12,3716,3888,758,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,976,SUCCESS,,3716.219734,64,0,0.1,0.2,0.3,263,1.4,1.5
    574,5/26/2021 19:51,2300.606,0.64,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-297,100,96,12,3715,3888,748,751,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4063,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,967,SUCCESS,,3715.889611,64,0,0.1,0.2,0.3,263,1.4,1.5
    575,5/26/2021 19:51,2304.615,0.64,701,300,10,6001,0,65535,65535,1,23.3,28471,-296,-296,100,96,12,3715,3888,758,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,1003,SUCCESS,,3715.559983,64,0,0.1,0.2,0.3,263,1.4,1.5
    576,5/26/2021 19:51,2308.619,0.64,701,300,10,6001,0,65535,65535,1,23.3,28471,-294,-296,100,96,12,3715,3888,753,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,949,SUCCESS,,3715.232989,64,0,0.1,0.2,0.3,263,1.4,1.5
    577,5/26/2021 19:51,2312.631,0.64,701,300,10,6001,0,65535,65535,1,23.3,28470,-298,-296,100,96,12,3714,3888,748,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4074,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,974,SUCCESS,,3714.900885,64,0,0.1,0.2,0.3,263,1.4,1.5
    578,5/26/2021 19:51,2316.635,0.64,701,300,10,6001,0,65535,65535,1,23.3,28470,-296,-297,100,96,12,3714,3888,753,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4074,4076,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,969,SUCCESS,,3714.571667,64,0,0.1,0.2,0.3,263,1.4,1.5
    579,5/26/2021 19:51,2320.651,0.64,701,300,10,6001,0,65535,65535,1,23.3,28469,-298,-296,100,96,12,3713,3888,748,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4076,4075,4058,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,931,SUCCESS,,3714.239231,64,0,0.1,0.2,0.3,263,1.4,1.5
    580,5/26/2021 19:51,2324.66,0.65,701,300,10,6001,0,65535,65535,1,23.3,28469,-296,-297,100,96,12,3713,3888,753,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4075,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,953,SUCCESS,,3713.909603,64,0,0.1,0.2,0.3,263,1.4,1.5
    581,5/26/2021 19:51,2328.673,0.65,701,300,10,6001,0,65535,65535,1,23.3,28470,-298,-296,100,96,12,3713,3888,748,753,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4075,4074,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,945,SUCCESS,,3713.577415,64,0,0.1,0.2,0.3,263,1.4,1.5
    582,5/26/2021 19:51,2332.684,0.65,701,300,10,6001,0,65535,65535,1,23.3,28468,-298,-297,100,96,12,3713,3888,748,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4076,4074,4057,4058,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,951,SUCCESS,,3713.245394,64,0,0.1,0.2,0.3,263,1.4,1.5
    583,5/26/2021 19:51,2336.693,0.65,701,300,10,6001,0,65535,65535,1,23.3,28469,-298,-297,100,96,12,3712,3888,747,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4076,4074,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,937,SUCCESS,,3712.913538,64,0,0.1,0.2,0.3,263,1.4,1.5
    584,5/26/2021 19:51,2340.705,0.65,701,300,10,6001,0,65535,65535,1,23.3,28469,-296,-297,100,96,12,3712,3888,752,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4075,4075,4058,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,945,SUCCESS,,3712.583662,64,0,0.1,0.2,0.3,263,1.4,1.5
    585,5/26/2021 19:51,2344.71,0.65,701,300,10,6001,0,65535,65535,1,23.3,28468,-298,-297,100,96,12,3712,3888,747,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4072,4076,4074,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,971,SUCCESS,,3712.252137,64,0,0.1,0.2,0.3,263,1.4,1.5
    586,5/26/2021 19:51,2348.72,0.65,701,300,10,6001,0,65535,65535,1,23.3,28466,-298,-297,100,96,12,3711,3888,747,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4076,4074,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,942,SUCCESS,,3711.920198,64,0,0.1,0.2,0.3,263,1.4,1.5
    587,5/26/2021 19:51,2352.734,0.65,701,300,10,6001,0,65535,65535,1,23.3,28467,-298,-297,100,96,12,3711,3888,752,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4072,4075,4074,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,940,SUCCESS,,3711.587928,64,0,0.1,0.2,0.3,263,1.4,1.5
    588,5/26/2021 19:52,2356.745,0.65,701,300,10,6001,0,65535,65535,1,23.3,28467,-296,-297,100,96,12,3711,3888,747,750,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4073,4075,4074,4057,4064,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,978,SUCCESS,,3711.258135,64,0,0.1,0.2,0.3,263,1.4,1.5
    589,5/26/2021 19:52,2360.756,0.66,701,300,10,6001,0,65535,65535,1,23.3,28467,-296,-297,100,96,12,3710,3888,752,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4072,4075,4073,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,954,SUCCESS,,3710.928341,64,0,0.1,0.2,0.3,263,1.4,1.5
    590,5/26/2021 19:52,2364.756,0.66,701,300,10,6001,0,65535,65535,1,23.3,28464,-298,-297,100,96,12,3710,3888,747,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4072,4075,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,955,SUCCESS,,3710.59723,64,0,0.1,0.2,0.3,263,1.4,1.5
    591,5/26/2021 19:52,2368.762,0.66,701,300,10,6001,0,65535,65535,1,23.3,28464,-296,-297,100,96,12,3710,3888,752,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4072,4075,4073,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,950,SUCCESS,,3710.267848,64,0,0.1,0.2,0.3,263,1.4,1.5
    592,5/26/2021 19:52,2372.768,0.66,701,300,10,6001,0,65535,65535,1,23.3,28463,-298,-297,100,96,12,3709,3888,757,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,941,SUCCESS,,3709.93624,64,0,0.1,0.2,0.3,263,1.4,1.5
    593,5/26/2021 19:52,2376.782,0.66,701,300,10,6001,0,65535,65535,1,23.3,28462,-298,-297,100,96,12,3709,3888,752,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,942,SUCCESS,,3709.60397,64,0,0.1,0.2,0.3,263,1.4,1.5
    594,5/26/2021 19:52,2380.797,0.66,701,300,10,6001,0,65535,65535,1,23.3,28464,-296,-297,100,96,12,3709,3888,752,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,948,SUCCESS,,3709.273848,64,0,0.1,0.2,0.3,263,1.4,1.5
    595,5/26/2021 19:52,2384.802,0.66,701,300,10,6001,0,65535,65535,1,23.3,28463,-302,-297,100,96,12,3708,3888,747,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4073,4057,4061,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,1006,SUCCESS,,3708.937873,64,0,0.1,0.2,0.3,263,1.4,1.5
    596,5/26/2021 19:52,2388.811,0.66,701,300,10,6001,0,65535,65535,1,23.3,28463,-296,-297,100,96,12,3708,3888,747,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4073,4057,4062,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,980,SUCCESS,,3708.608244,64,0,0.1,0.2,0.3,263,1.4,1.5
    597,5/26/2021 19:52,2392.815,0.66,701,300,10,6001,0,65535,65535,1,23.3,28462,-296,-297,100,96,12,3708,3888,752,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,956,SUCCESS,,3708.279026,64,0,0.1,0.2,0.3,263,1.4,1.5
    598,5/26/2021 19:52,2396.817,0.67,701,300,10,6001,0,65535,65535,1,23.3,28461,-298,-297,100,96,12,3707,3888,746,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,957,SUCCESS,,3707.94775,64,0,0.1,0.2,0.3,263,1.4,1.5
    599,5/26/2021 19:52,2400.824,0.67,701,300,10,6001,0,65535,65535,1,23.3,28462,-296,-297,100,96,12,3707,3888,746,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,981,SUCCESS,,3707.618285,64,0,0.1,0.2,0.3,263,1.4,1.5
    600,5/26/2021 19:52,2404.839,0.67,701,300,10,6001,0,65535,65535,1,23.3,28462,-298,-297,100,96,12,3707,3888,751,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4075,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,968,SUCCESS,,3707.285933,64,0,0.1,0.2,0.3,263,1.4,1.5
    601,5/26/2021 19:52,2408.85,0.67,701,300,10,6001,0,65535,65535,1,23.3,28463,-296,-297,100,96,12,3706,3888,751,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4071,4072,4075,4073,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23,977,SUCCESS,,3706.956139,64,0,0.1,0.2,0.3,263,1.4,1.5
    602,5/26/2021 19:53,2412.854,0.67,701,300,10,6001,0,65535,65535,1,23.3,28462,-296,-297,100,96,12,3706,3888,751,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,951,SUCCESS,,3706.626921,64,0,0.1,0.2,0.3,263,1.4,1.5
    603,5/26/2021 19:53,2416.864,0.67,701,300,10,6001,0,65535,65535,1,23.3,28461,-298,-297,100,96,12,3706,3888,746,749,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,970,SUCCESS,,3706.294983,64,0,0.1,0.2,0.3,263,1.4,1.5
    604,5/26/2021 19:53,2420.877,0.67,701,300,10,6001,0,65535,65535,1,23.3,28460,-298,-297,100,96,12,3705,3888,746,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,970,SUCCESS,,3705.962795,64,0,0.1,0.2,0.3,263,1.4,1.5
    605,5/26/2021 19:53,2424.882,0.67,701,300,10,6001,0,65535,65535,1,23.3,28460,-298,-297,100,96,12,3705,3888,746,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,982,SUCCESS,,3705.63127,64,0,0.1,0.2,0.3,263,1.4,1.5
    606,5/26/2021 19:53,2428.896,0.67,701,300,10,6001,0,65535,65535,1,23.3,28461,-296,-297,100,96,12,3705,3888,746,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,968,SUCCESS,,3705.30123,64,0,0.1,0.2,0.3,263,1.4,1.5
    607,5/26/2021 19:53,2432.898,0.68,701,300,10,6001,0,65535,65535,1,23.3,28460,-296,-297,100,96,12,3704,3888,746,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4060,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,981,SUCCESS,,3704.972177,64,0,0.1,0.2,0.3,263,1.4,1.5
    608,5/26/2021 19:53,2436.906,0.68,701,300,10,6001,0,65535,65535,1,23.3,28460,-298,-297,100,96,12,3704,3888,751,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4057,4061,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,940,SUCCESS,,3704.640404,64,0,0.1,0.2,0.3,263,1.4,1.5
    609,5/26/2021 19:53,2440.909,0.68,701,300,10,6001,0,65535,65535,1,23.3,28459,-300,-297,100,96,12,3704,3888,746,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4060,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,943,SUCCESS,,3704.30682,64,0,0.1,0.2,0.3,263,1.4,1.5
    610,5/26/2021 19:53,2444.915,0.68,701,300,10,6001,0,65535,65535,1,23.3,28459,-296,-297,100,96,12,3703,3888,751,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4057,4060,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,22.6,978,SUCCESS,,3703.977438,64,0,0.1,0.2,0.3,263,1.4,1.5
    611,5/26/2021 19:53,2448.921,0.68,701,300,10,6001,0,65535,65535,1,23.3,28458,-296,-297,100,96,12,3703,3888,751,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4070,4072,4074,4072,4056,4060,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,947,SUCCESS,,3703.648056,64,0,0.1,0.2,0.3,263,1.4,1.5
    612,5/26/2021 19:53,2452.931,0.68,701,300,10,6001,0,65535,65535,1,23.3,28458,-298,-297,100,96,12,3703,3888,746,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,932,SUCCESS,,3703.316117,64,0,0.1,0.2,0.3,263,1.4,1.5
    613,5/26/2021 19:53,2456.937,0.68,701,300,10,6001,0,65535,65535,1,23.3,28458,-296,-297,100,96,12,3702,3888,750,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,941,SUCCESS,,3702.986735,64,0,0.1,0.2,0.3,263,1.4,1.5
    614,5/26/2021 19:53,2460.952,0.68,701,300,10,6001,0,65535,65535,1,23.3,28458,-298,-297,100,96,12,3702,3888,745,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,950,SUCCESS,,3702.654382,64,0,0.1,0.2,0.3,263,1.4,1.5
    615,5/26/2021 19:53,2464.953,0.68,701,300,10,6001,0,65535,65535,1,23.3,28458,-298,-297,100,96,12,3702,3888,745,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,941,SUCCESS,,3702.323188,64,0,0.1,0.2,0.3,263,1.4,1.5
    616,5/26/2021 19:53,2468.964,0.69,701,300,10,6001,0,65535,65535,1,23.3,28458,-298,-297,100,96,12,3701,3888,745,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4061,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,947,SUCCESS,,3701.991166,64,0,0.1,0.2,0.3,263,1.4,1.5
    617,5/26/2021 19:54,2472.965,0.69,701,300,10,6001,0,65535,65535,1,23.3,28457,-296,-297,100,96,12,3701,3888,750,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,953,SUCCESS,,3701.662195,64,0,0.1,0.2,0.3,263,1.4,1.5
    618,5/26/2021 19:54,2476.979,0.69,701,300,10,6001,0,65535,65535,1,23.3,28456,-296,-297,100,96,12,3701,3888,750,748,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,968,SUCCESS,,3701.332155,64,0,0.1,0.2,0.3,263,1.4,1.5
    619,5/26/2021 19:54,2480.994,0.69,701,300,10,6001,0,65535,65535,1,23.3,28457,-296,-297,100,96,12,3700,3888,750,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,22.8,1023,SUCCESS,,3701.002033,64,0,0.1,0.2,0.3,263,1.4,1.5
    620,5/26/2021 19:54,2484.998,0.69,701,300,10,6001,0,65535,65535,1,23.3,28457,-300,-297,100,96,12,3700,3888,740,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,943,SUCCESS,,3700.668366,64,0,0.1,0.2,0.3,263,1.4,1.5
    621,5/26/2021 19:54,2489.012,0.69,701,300,10,6001,0,65535,65535,1,23.3,28456,-298,-297,100,96,12,3700,3888,745,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,954,SUCCESS,,3700.336096,64,0,0.1,0.2,0.3,263,1.4,1.5
    622,5/26/2021 19:54,2493.014,0.69,701,300,10,6001,0,65535,65535,1,23.3,28456,-298,-297,100,96,12,3699,3888,745,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4071,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,942,SUCCESS,,3700.00482,64,0,0.1,0.2,0.3,263,1.4,1.5
    623,5/26/2021 19:54,2497.019,0.69,701,300,10,6001,0,65535,65535,1,23.3,28456,-298,-297,100,96,12,3699,3888,745,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4055,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,990,SUCCESS,,3699.673295,64,0,0.1,0.2,0.3,263,1.4,1.5
    624,5/26/2021 19:54,2501.028,0.69,701,300,10,6001,0,65535,65535,1,23.3,28456,-296,-297,100,96,12,3699,3888,750,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4074,4072,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,959,SUCCESS,,3699.343666,64,0,0.1,0.2,0.3,263,1.4,1.5
    625,5/26/2021 19:54,2505.042,0.7,701,300,10,6001,0,65535,65535,1,23.3,28455,-296,-297,100,96,12,3698,3888,745,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,969,SUCCESS,,3699.013626,64,0,0.1,0.2,0.3,263,1.4,1.5
    626,5/26/2021 19:54,2509.049,0.7,701,300,10,6001,0,65535,65535,1,23.3,28454,-298,-297,100,96,12,3698,3888,755,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,940,SUCCESS,,3698.681935,64,0,0.1,0.2,0.3,263,1.4,1.5
    627,5/26/2021 19:54,2513.059,0.7,701,300,10,6001,0,65535,65535,1,23.3,28455,-296,-297,100,96,12,3698,3888,750,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,967,SUCCESS,,3698.352224,64,0,0.1,0.2,0.3,263,1.4,1.5
    628,5/26/2021 19:54,2517.061,0.7,701,300,10,6001,0,65535,65535,1,23.3,28454,-298,-297,100,96,12,3697,3888,754,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4054,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,944,SUCCESS,,3698.020948,64,0,0.1,0.2,0.3,263,1.4,1.5
    629,5/26/2021 19:54,2521.064,0.7,701,300,10,6001,0,65535,65535,1,23.3,28454,-296,-297,100,96,12,3697,3888,749,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4056,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,961,SUCCESS,,3697.691812,64,0,0.1,0.2,0.3,263,1.4,1.5
    630,5/26/2021 19:54,2525.068,0.7,701,300,10,6001,0,65535,65535,1,23.3,28454,-298,-297,100,96,12,3697,3888,744,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4055,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,975,SUCCESS,,3697.36037,64,0,0.1,0.2,0.3,263,1.4,1.5
    631,5/26/2021 19:54,2529.081,0.7,701,300,10,6001,0,65535,65535,1,23.3,28454,-296,-297,100,96,12,3696,3888,744,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,942,SUCCESS,,3697.030412,64,0,0.1,0.2,0.3,263,1.4,1.5
    632,5/26/2021 19:55,2533.091,0.7,701,300,10,6001,0,65535,65535,1,23.3,28451,-296,-297,100,96,12,3696,3888,754,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4072,4071,4055,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,950,SUCCESS,,3696.700701,64,0,0.1,0.2,0.3,263,1.4,1.5
    633,5/26/2021 19:55,2537.106,0.7,701,300,10,6001,0,65535,65535,1,23.3,28452,-298,-297,100,96,12,3696,3888,749,747,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,951,SUCCESS,,3696.368348,64,0,0.1,0.2,0.3,263,1.4,1.5
    634,5/26/2021 19:55,2541.108,0.71,701,300,10,6001,0,65535,65535,1,23.3,28453,-298,-297,100,96,12,3695,3888,744,746,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4069,4072,4073,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,951,SUCCESS,,3696.037071,64,0,0.1,0.2,0.3,263,1.4,1.5
    635,5/26/2021 19:55,2545.117,0.71,701,300,10,6001,0,65535,65535,1,23.3,28450,-296,-297,100,96,12,3695,3888,749,746,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4068,4072,4073,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,939,SUCCESS,,3695.707443,64,0,0.1,0.2,0.3,263,1.4,1.5
    636,5/26/2021 19:55,2549.128,0.71,701,300,10,6001,0,65535,65535,1,23.3,28450,-298,-297,100,96,12,3695,3888,749,746,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4068,4072,4073,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,954,SUCCESS,,3695.375421,64,0,0.1,0.2,0.3,263,1.4,1.5
    637,5/26/2021 19:55,2553.143,0.71,701,300,10,6001,0,65535,65535,1,23.3,28451,-294,-297,100,96,12,3694,3888,754,746,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,956,SUCCESS,,3695.047529,64,0,0.1,0.2,0.3,263,1.4,1.5
    638,5/26/2021 19:55,2557.155,0.71,701,300,10,6001,0,65535,65535,1,23.3,28449,-298,-297,100,96,12,3694,3888,744,746,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4059,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,959,SUCCESS,,3694.715425,64,0,0.1,0.2,0.3,263,1.4,1.5
    639,5/26/2021 19:55,2561.162,0.71,701,300,10,6001,0,65535,65535,1,23.3,28449,-296,-297,100,96,12,3694,3888,749,746,65535,3000,28875,4.00E+01,0,3639,12,107,0,4,2,804A,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4060,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,940,SUCCESS,,3694.38596,64,0,0.1,0.2,0.3,263,1.4,1.5
    640,5/26/2021 19:55,2565.172,0.71,701,300,10,6001,0,65535,65535,1,23.3,28449,-296,-297,100,95,12,3693,3888,749,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,946,SUCCESS,,3694.056249,192,0,0.1,0.2,0.3,263,1.4,1.5
    641,5/26/2021 19:55,2569.176,0.71,701,300,10,6001,0,65535,65535,1,23.3,28448,-296,-296,100,95,12,3693,3888,744,749,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4070,4055,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,962,SUCCESS,,3693.727031,192,0,0.1,0.2,0.3,263,1.4,1.5
    642,5/26/2021 19:55,2573.187,0.71,701,300,10,6001,0,65535,65535,1,23.3,28445,-298,-296,100,95,12,3693,3888,754,749,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4060,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,941,SUCCESS,,3693.39501,192,0,0.1,0.2,0.3,263,1.4,1.5
    643,5/26/2021 19:55,2577.189,0.72,701,300,10,6001,0,65535,65535,1,23.3,28448,-296,-296,100,95,12,3692,3888,753,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,961,SUCCESS,,3693.065956,192,0,0.1,0.2,0.3,263,1.4,1.5
    644,5/26/2021 19:55,2581.204,0.72,701,300,10,6001,0,65535,65535,1,23.3,28449,-296,-296,100,95,12,3692,3888,753,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,964,SUCCESS,,3692.735834,192,0,0.1,0.2,0.3,263,1.4,1.5
    645,5/26/2021 19:55,2585.219,0.72,701,300,10,6001,0,65535,65535,1,23.3,28449,-294,-296,100,95,12,3692,3888,748,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4071,4055,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,957,SUCCESS,,3692.407943,192,0,0.1,0.2,0.3,263,1.4,1.5
    646,5/26/2021 19:55,2589.232,0.72,701,300,10,6001,0,65535,65535,1,23.3,28448,-296,-296,100,95,12,3691,3888,748,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4070,4055,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,967,SUCCESS,,3692.077985,192,0,0.1,0.2,0.3,263,1.4,1.5
    647,5/26/2021 19:56,2593.247,0.72,701,300,10,6001,0,65535,65535,1,23.3,28447,-298,-296,100,95,12,3691,3888,748,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4071,4055,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,949,SUCCESS,,3691.745632,192,0,0.1,0.2,0.3,263,1.4,1.5
    648,5/26/2021 19:56,2597.252,0.72,701,300,10,6001,0,65535,65535,1,23.3,28447,-296,-296,100,95,12,3691,3888,748,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4055,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,970,SUCCESS,,3691.416332,192,0,0.1,0.2,0.3,263,1.4,1.5
    649,5/26/2021 19:56,2601.256,0.72,701,300,10,6001,0,65535,65535,1,23.3,28448,-298,-296,100,95,12,3690,3888,743,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,937,SUCCESS,,3691.08489,192,0,0.1,0.2,0.3,263,1.4,1.5
    650,5/26/2021 19:56,2605.266,0.72,701,300,10,6001,0,65535,65535,1,23.3,28446,-296,-297,100,95,12,3690,3888,743,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4072,4070,4055,4059,4052,0,0,0,0,0,0,0,0,2842,23.1,23.3,-273.2,23.3,-273.2,23.1,960,SUCCESS,,3690.755179,192,0,0.1,0.2,0.3,263,1.4,1.5
    651,5/26/2021 19:56,2609.297,0.72,701,300,10,6001,0,65535,65535,1,23.3,28446,-296,-296,100,95,12,3690,3888,753,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4055,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23,943,SUCCESS,,3690.423741,192,0,0.1,0.2,0.3,263,1.4,1.5
    652,5/26/2021 19:56,2613.314,0.73,701,300,10,6001,0,65535,65535,1,23.3,28446,-298,-297,100,95,12,3689,3888,748,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4055,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,943,SUCCESS,,3690.091223,192,0,0.1,0.2,0.3,263,1.4,1.5
    653,5/26/2021 19:56,2617.312,0.73,701,300,10,6001,0,65535,65535,1,23.3,28446,-296,-297,100,95,12,3689,3888,748,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4055,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,948,SUCCESS,,3689.762498,192,0,0.1,0.2,0.3,263,1.4,1.5
    654,5/26/2021 19:56,2621.329,0.73,701,300,10,6001,0,65535,65535,1,23.3,28445,-296,-297,100,95,12,3689,3888,748,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4055,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,945,SUCCESS,,3689.432211,192,0,0.1,0.2,0.3,263,1.4,1.5
    655,5/26/2021 19:56,2625.345,0.73,701,300,10,6001,0,65535,65535,1,23.3,28445,-296,-297,100,95,12,3688,3888,743,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,945,SUCCESS,,3689.102007,192,0,0.1,0.2,0.3,263,1.4,1.5
    656,5/26/2021 19:56,2629.358,0.73,701,300,10,6001,0,65535,65535,1,23.3,28444,-296,-297,100,95,12,3688,3888,743,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,944,SUCCESS,,3688.772049,192,0,0.1,0.2,0.3,263,1.4,1.5
    657,5/26/2021 19:56,2633.361,0.73,701,300,10,6001,0,65535,65535,1,23.3,28444,-298,-296,100,95,12,3688,3888,743,748,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4059,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,942,SUCCESS,,3688.44069,192,0,0.1,0.2,0.3,263,1.4,1.5
    658,5/26/2021 19:56,2637.39,0.73,701,300,10,6001,0,65535,65535,1,23.3,28444,-296,-297,100,95,12,3687,3888,747,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,940,SUCCESS,,3688.109416,192,0,0.1,0.2,0.3,263,1.4,1.5
    659,5/26/2021 19:56,2641.391,0.73,701,300,10,6001,0,65535,65535,1,23.3,28444,-298,-296,100,95,12,3687,3888,747,747,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4058,4053,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,971,SUCCESS,,3687.778223,192,0,0.1,0.2,0.3,263,1.4,1.5
    660,5/26/2021 19:56,2645.407,0.73,701,300,10,6001,0,65535,65535,1,23.3,28444,-296,-296,100,95,12,3687,3888,747,747,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4069,4054,4062,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,22.5,942,SUCCESS,,3687.448018,192,0,0.1,0.2,0.3,263,1.4,1.5
    661,5/26/2021 19:56,2649.33,0.74,701,300,10,6001,0,65535,65535,1,23.3,28445,-296,-297,100,95,12,3686,3888,742,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4070,4054,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,22.6,949,SUCCESS,,3687.12546,192,0,0.1,0.2,0.3,263,1.4,1.5
    662,5/26/2021 19:57,2653.34,0.74,701,300,10,6001,0,65535,65535,1,23.3,28444,-296,-296,100,95,12,3686,3888,747,747,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,950,SUCCESS,,3686.795749,192,0,0.1,0.2,0.3,263,1.4,1.5
    663,5/26/2021 19:57,2657.35,0.74,701,300,10,6001,0,65535,65535,1,23.3,28444,-298,-297,100,95,12,3686,3888,747,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4070,4054,4063,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,956,SUCCESS,,3686.46381,192,0,0.1,0.2,0.3,263,1.4,1.5
    664,5/26/2021 19:57,2661.354,0.74,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-296,100,95,12,3685,3888,752,747,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4068,4072,4071,4069,4054,4058,4052,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,1001,SUCCESS,,3686.134593,192,0,0.1,0.2,0.3,263,1.4,1.5
    665,5/26/2021 19:57,2665.369,0.74,701,300,10,6001,0,65535,65535,1,23.3,28442,-298,-296,100,95,12,3685,3888,742,747,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4057,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,1000,SUCCESS,,3685.80224,192,0,0.1,0.2,0.3,263,1.4,1.5
    666,5/26/2021 19:57,2669.375,0.74,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-297,100,95,12,3685,3888,747,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4060,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,971,SUCCESS,,3685.472858,192,0,0.1,0.2,0.3,263,1.4,1.5
    667,5/26/2021 19:57,2673.379,0.74,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-297,100,95,12,3684,3888,752,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,935,SUCCESS,,3685.14364,192,0,0.1,0.2,0.3,263,1.4,1.5
    668,5/26/2021 19:57,2677.38,0.74,701,300,10,6001,0,65535,65535,1,23.3,28442,-298,-297,100,95,12,3684,3888,742,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,973,SUCCESS,,3684.812446,192,0,0.1,0.2,0.3,263,1.4,1.5
    669,5/26/2021 19:57,2681.394,0.74,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-297,100,95,12,3684,3888,747,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,956,SUCCESS,,3684.482406,192,0,0.1,0.2,0.3,263,1.4,1.5
    670,5/26/2021 19:57,2685.401,0.75,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-297,100,95,12,3683,3888,747,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,931,SUCCESS,,3684.152941,192,0,0.1,0.2,0.3,263,1.4,1.5
    671,5/26/2021 19:57,2689.403,0.75,701,300,10,6001,0,65535,65535,1,23.3,28442,-298,-297,100,95,12,3683,3888,742,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.2,961,SUCCESS,,3683.821665,192,0,0.1,0.2,0.3,263,1.4,1.5
    672,5/26/2021 19:57,2693.41,0.75,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-297,100,95,12,3683,3888,742,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4057,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,951,SUCCESS,,3683.4922,192,0,0.1,0.2,0.3,263,1.4,1.5
    673,5/26/2021 19:57,2697.419,0.75,701,300,10,6001,0,65535,65535,1,23.3,28441,-296,-297,100,95,12,3682,3888,741,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2840,23.1,23.3,-273.2,23.3,-273.2,23.1,992,SUCCESS,,3683.162571,192,0,0.1,0.2,0.3,263,1.4,1.5
    674,5/26/2021 19:57,2701.425,0.75,701,300,10,6001,0,65535,65535,1,23.3,28441,-296,-297,100,95,12,3682,3888,746,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2842,23.1,23.3,-273.2,23.3,-273.2,23.1,952,SUCCESS,,3682.833189,192,0,0.1,0.2,0.3,263,1.4,1.5
    675,5/26/2021 19:57,2705.435,0.75,701,300,10,6001,0,65535,65535,1,23.3,28442,-296,-297,100,95,12,3682,3888,754,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4057,4051,0,0,0,0,0,0,0,0,2842,23.1,23.3,-273.2,23.3,-273.2,23.1,943,SUCCESS,,3682.503478,192,0,0.1,0.2,0.3,263,1.4,1.5
    676,5/26/2021 19:57,2709.439,0.75,701,300,10,6001,0,65535,65535,1,23.3,28441,-296,-297,100,95,12,3681,3888,741,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4057,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,939,SUCCESS,,3682.17426,192,0,0.1,0.2,0.3,263,1.4,1.5
    677,5/26/2021 19:58,2713.443,0.75,701,300,10,6001,0,65535,65535,1,23.3,28441,-296,-297,100,95,12,3681,3888,751,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2843,23.1,23.3,-273.2,23.3,-273.2,23.1,997,SUCCESS,,3681.845043,192,0,0.1,0.2,0.3,263,1.4,1.5
    678,5/26/2021 19:58,2717.456,0.75,701,300,10,6001,0,65535,65535,1,23.3,28440,-298,-296,100,95,12,3681,3888,741,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4057,4051,0,0,0,0,0,0,0,0,2839,23.1,23.3,-273.2,23.3,-273.2,23.1,944,SUCCESS,,3681.512855,192,0,0.1,0.2,0.3,263,1.4,1.5
    679,5/26/2021 19:58,2721.468,0.76,701,300,10,6001,0,65535,65535,1,23.3,28440,-296,-296,100,95,12,3680,3888,746,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4072,4071,4069,4053,4057,4051,0,0,0,0,0,0,0,0,2839,23.1,23.3,-273.2,23.3,-273.2,23.1,947,SUCCESS,,3681.18298,192,0,0.1,0.2,0.3,263,1.4,1.5
    680,5/26/2021 19:58,2725.475,0.76,701,300,10,6001,0,65535,65535,1,23.3,28440,-298,-297,100,95,12,3680,3888,741,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4067,4072,4071,4069,4054,4058,4051,0,0,0,0,0,0,0,0,2842,23.1,23.3,-273.2,23.3,-273.2,23.1,971,SUCCESS,,3680.851289,192,0,0.1,0.2,0.3,263,1.4,1.5
    681,5/26/2021 19:58,2729.481,0.76,701,300,10,6001,0,65535,65535,1,23.3,28439,-296,-296,100,95,12,3680,3888,746,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4069,4053,4057,4051,0,0,0,0,0,0,0,0,2842,23.1,23.3,-273.2,23.3,-273.2,23.1,977,SUCCESS,,3680.521907,192,0,0.1,0.2,0.3,263,1.4,1.5
    682,5/26/2021 19:58,2733.491,0.76,701,300,10,6001,0,65535,65535,1,23.3,28440,-294,-297,100,95,12,3679,3888,751,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4072,4071,4068,4054,4057,4051,0,0,0,0,0,0,0,0,2839,23.1,23.3,-273.2,23.3,-273.2,23.1,980,SUCCESS,,3680.194424,192,0,0.1,0.2,0.3,263,1.4,1.5
    683,5/26/2021 19:58,2737.497,0.76,701,300,10,6001,0,65535,65535,1,23.3,28439,-296,-296,100,95,12,3679,3888,746,746,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4058,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.7,963,SUCCESS,,3679.865041,192,0,0.1,0.2,0.3,263,1.4,1.5
    684,5/26/2021 19:58,2741.508,0.76,701,300,10,6001,0,65535,65535,1,23.3,28438,-296,-297,100,95,12,3679,3888,746,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4069,4053,4057,4051,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,965,SUCCESS,,3679.535248,192,0,0.1,0.2,0.3,263,1.4,1.5
    685,5/26/2021 19:58,2745.51,0.76,701,300,10,6001,0,65535,65535,1,23.2,28437,-296,-297,100,95,12,3678,3888,746,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4069,4053,4057,4051,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,946,SUCCESS,,3679.206195,192,0,0.1,0.2,0.3,263,1.4,1.5
    686,5/26/2021 19:58,2749.516,0.76,701,300,10,6001,0,65535,65535,1,23.2,28438,-296,-297,100,95,12,3678,3888,746,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,947,SUCCESS,,3678.876813,192,0,0.1,0.2,0.3,263,1.4,1.5
    687,5/26/2021 19:58,2753.52,0.76,701,300,10,6001,0,65535,65535,1,23.2,28436,-296,-297,100,95,12,3678,3888,741,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,938,SUCCESS,,3678.547595,192,0,0.1,0.2,0.3,263,1.4,1.5
    688,5/26/2021 19:58,2757.535,0.77,701,300,10,6001,0,65535,65535,1,23.2,28437,-296,-297,100,95,12,3677,3888,750,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3678.217473,192,0,0.1,0.2,0.3,263,1.4,1.5
    689,5/26/2021 19:58,2761.541,0.77,701,300,10,6001,0,65535,65535,1,23.2,28436,-296,-297,100,95,12,3677,3888,740,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.2,967,SUCCESS,,3677.88809,192,0,0.1,0.2,0.3,263,1.4,1.5
    690,5/26/2021 19:58,2765.543,0.77,701,300,10,6001,0,65535,65535,1,23.2,28436,-298,-297,100,95,12,3677,3888,745,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4056,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3677.556814,192,0,0.1,0.2,0.3,263,1.4,1.5
    691,5/26/2021 19:58,2769.551,0.77,701,300,10,6001,0,65535,65535,1,23.2,28436,-296,-296,100,95,12,3676,3888,750,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,1022,SUCCESS,,3677.227267,192,0,0.1,0.2,0.3,263,1.4,1.5
    692,5/26/2021 19:59,2773.559,0.77,701,300,10,6001,0,65535,65535,1,23.2,28436,-296,-296,100,95,12,3676,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,952,SUCCESS,,3676.89772,192,0,0.1,0.2,0.3,263,1.4,1.5
    693,5/26/2021 19:59,2777.572,0.77,701,300,10,6001,0,65535,65535,1,23.2,28435,-296,-296,100,95,12,3676,3888,750,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4056,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,954,SUCCESS,,3676.567763,192,0,0.1,0.2,0.3,263,1.4,1.5
    694,5/26/2021 19:59,2781.574,0.77,701,300,10,6001,0,65535,65535,1,23.2,28435,-296,-296,100,95,12,3675,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4071,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,966,SUCCESS,,3676.238709,192,0,0.1,0.2,0.3,263,1.4,1.5
    695,5/26/2021 19:59,2785.589,0.77,701,300,10,6001,0,65535,65535,1,23.2,28435,-298,-296,100,95,12,3675,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,967,SUCCESS,,3675.906356,192,0,0.1,0.2,0.3,263,1.4,1.5
    696,5/26/2021 19:59,2789.601,0.77,701,300,10,6001,0,65535,65535,1,23.2,28434,-296,-296,100,95,12,3675,3888,750,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4056,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,1000,SUCCESS,,3675.576481,192,0,0.1,0.2,0.3,263,1.4,1.5
    697,5/26/2021 19:59,2793.601,0.78,701,300,10,6001,0,65535,65535,1,23.2,28434,-296,-296,100,95,12,3674,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4052,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,950,SUCCESS,,3675.247592,192,0,0.1,0.2,0.3,263,1.4,1.5
    698,5/26/2021 19:59,2797.606,0.78,701,300,10,6001,0,65535,65535,1,23.2,28435,-296,-296,100,95,12,3674,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,944,SUCCESS,,3674.918292,192,0,0.1,0.2,0.3,263,1.4,1.5
    699,5/26/2021 19:59,2801.614,0.78,701,300,10,6001,0,65535,65535,1,23.2,28432,-294,-296,100,95,12,3674,3888,740,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,965,SUCCESS,,3674.590972,192,0,0.1,0.2,0.3,263,1.4,1.5
    700,5/26/2021 19:59,2805.625,0.78,701,300,10,6001,0,65535,65535,1,23.2,28433,-296,-296,100,95,12,3673,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4052,4056,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,939,SUCCESS,,3674.261179,192,0,0.1,0.2,0.3,263,1.4,1.5
    701,5/26/2021 19:59,2809.627,0.78,701,300,10,6001,0,65535,65535,1,23.2,28431,-296,-297,100,95,12,3673,3888,745,742,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4057,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,962,SUCCESS,,3673.932125,192,0,0.1,0.2,0.3,263,1.4,1.5
    702,5/26/2021 19:59,2813.642,0.78,701,300,10,6001,0,65535,65535,1,23.2,28432,-294,-296,100,95,12,3673,3888,745,745,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4052,4057,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,959,SUCCESS,,3673.604234,192,0,0.1,0.2,0.3,263,1.4,1.5
    703,5/26/2021 19:59,2817.656,0.78,701,300,10,6001,0,65535,65535,1,23.2,28433,-298,-296,100,95,12,3672,3888,744,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4053,4056,4050,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,948,SUCCESS,,3673.271964,192,0,0.1,0.2,0.3,263,1.4,1.5
    704,5/26/2021 19:59,2821.666,0.78,701,300,10,6001,0,65535,65535,1,23.2,28433,-296,-296,100,95,12,3672,3888,744,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4066,4070,4071,4068,4052,4057,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,954,SUCCESS,,3672.942253,192,0,0.1,0.2,0.3,263,1.4,1.5
    705,5/26/2021 19:59,2825.675,0.78,701,300,10,6001,0,65535,65535,1,23.2,28432,-296,-296,100,95,12,3672,3888,749,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4070,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,952,SUCCESS,,3672.612624,192,0,0.1,0.2,0.3,263,1.4,1.5
    706,5/26/2021 19:59,2829.682,0.79,701,300,10,6001,0,65535,65535,1,23.2,28432,-298,-296,100,95,12,3671,3888,739,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4070,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,966,SUCCESS,,3672.280933,192,0,0.1,0.2,0.3,263,1.4,1.5
    707,5/26/2021 20:00,2833.684,0.79,701,300,10,6001,0,65535,65535,1,23.2,28432,-296,-296,100,95,12,3671,3888,749,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.2,959,SUCCESS,,3671.95188,192,0,0.1,0.2,0.3,263,1.4,1.5
    708,5/26/2021 20:00,2837.693,0.79,701,300,10,6001,0,65535,65535,1,23.2,28431,-294,-296,100,95,12,3671,3888,749,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,950,SUCCESS,,3671.624478,192,0,0.1,0.2,0.3,263,1.4,1.5
    709,5/26/2021 20:00,2841.697,0.79,701,300,10,6001,0,65535,65535,1,23.2,28429,-296,-296,100,95,12,3670,3888,749,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4070,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,966,SUCCESS,,3671.29526,192,0,0.1,0.2,0.3,263,1.4,1.5
    710,5/26/2021 20:00,2845.699,0.79,701,300,10,6001,0,65535,65535,1,23.2,28434,-296,-296,100,95,12,3670,3888,749,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,950,SUCCESS,,3670.966207,192,0,0.1,0.2,0.3,263,1.4,1.5
    711,5/26/2021 20:00,2849.714,0.79,701,300,10,6001,0,65535,65535,1,23.2,28429,-296,-296,100,95,12,3670,3888,739,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.4,956,SUCCESS,,3670.636085,192,0,0.1,0.2,0.3,263,1.4,1.5
    712,5/26/2021 20:00,2853.729,0.79,701,300,10,6001,0,65535,65535,1,23.2,28428,-296,-296,100,95,12,3669,3888,744,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,953,SUCCESS,,3670.305963,192,0,0.1,0.2,0.3,263,1.4,1.5
    713,5/26/2021 20:00,2857.743,0.79,701,300,10,6001,0,65535,65535,1,23.2,28429,-298,-296,100,95,12,3669,3888,739,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4068,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,993,SUCCESS,,3669.973693,192,0,0.1,0.2,0.3,263,1.4,1.5
    714,5/26/2021 20:00,2861.747,0.79,701,300,10,6001,0,65535,65535,1,23.2,28429,-298,-296,100,95,12,3669,3888,739,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,947,SUCCESS,,3669.64225,192,0,0.1,0.2,0.3,263,1.4,1.5
    715,5/26/2021 20:00,2865.751,0.8,701,300,10,6001,0,65535,65535,1,23.2,28426,-296,-296,100,95,12,3668,3888,744,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3669.313033,192,0,0.1,0.2,0.3,263,1.4,1.5
    716,5/26/2021 20:00,2869.761,0.8,701,300,10,6001,0,65535,65535,1,23.2,28428,-298,-296,100,95,12,3668,3888,739,744,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,944,SUCCESS,,3668.981094,192,0,0.1,0.2,0.3,263,1.4,1.5
    717,5/26/2021 20:00,2873.764,0.8,701,300,10,6001,0,65535,65535,1,23.2,28429,-296,-297,100,95,12,3668,3888,744,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,941,SUCCESS,,3668.651958,192,0,0.1,0.2,0.3,263,1.4,1.5
    718,5/26/2021 20:00,2877.771,0.8,701,300,10,6001,0,65535,65535,1,23.2,28427,-296,-297,100,95,12,3667,3888,743,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4051,4054,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,972,SUCCESS,,3668.322494,192,0,0.1,0.2,0.3,263,1.4,1.5
    719,5/26/2021 20:00,2881.787,0.8,701,300,10,6001,0,65535,65535,1,23.2,28428,-294,-296,100,95,12,3667,3888,748,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,988,SUCCESS,,3667.99452,192,0,0.1,0.2,0.3,263,1.4,1.5
    720,5/26/2021 20:00,2885.798,0.8,701,300,10,6001,0,65535,65535,1,23.2,28428,-298,-297,100,95,12,3667,3888,738,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4051,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,947,SUCCESS,,3667.662499,192,0,0.1,0.2,0.3,263,1.4,1.5
    721,5/26/2021 20:00,2889.812,0.8,701,300,10,6001,0,65535,65535,1,23.2,28428,-296,-296,100,95,12,3666,3888,743,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,941,SUCCESS,,3667.332459,192,0,0.1,0.2,0.3,263,1.4,1.5
    722,5/26/2021 20:01,2893.826,0.8,701,300,10,6001,0,65535,65535,1,23.2,28428,-296,-296,100,95,12,3666,3888,743,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4051,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,941,SUCCESS,,3667.002419,192,0,0.1,0.2,0.3,263,1.4,1.5
    723,5/26/2021 20:01,2897.841,0.8,701,300,10,6001,0,65535,65535,1,23.2,28426,-296,-296,100,95,12,3666,3888,748,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4051,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,957,SUCCESS,,3666.672296,192,0,0.1,0.2,0.3,263,1.4,1.5
    724,5/26/2021 20:01,2901.857,0.81,701,300,10,6001,0,65535,65535,1,23.2,28428,-296,-296,100,95,12,3665,3888,738,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4052,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,963,SUCCESS,,3666.342092,192,0,0.1,0.2,0.3,263,1.4,1.5
    725,5/26/2021 20:01,2905.862,0.81,701,300,10,6001,0,65535,65535,1,23.2,28426,-296,-296,100,95,12,3665,3888,738,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4051,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.7,982,SUCCESS,,3666.012792,192,0,0.1,0.2,0.3,263,1.4,1.5
    726,5/26/2021 20:01,2909.866,0.81,701,300,10,6001,0,65535,65535,1,23.2,28426,-296,-296,100,95,12,3665,3888,748,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4069,4071,4067,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,981,SUCCESS,,3665.683574,192,0,0.1,0.2,0.3,263,1.4,1.5
    727,5/26/2021 20:01,2913.875,0.81,701,300,10,6001,0,65535,65535,1,23.2,28424,-298,-296,100,95,12,3664,3888,738,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4068,4071,4066,4052,4056,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,957,SUCCESS,,3665.351718,192,0,0.1,0.2,0.3,263,1.4,1.5
    728,5/26/2021 20:01,2917.882,0.81,701,300,10,6001,0,65535,65535,1,23.2,28426,-296,-296,100,95,12,3664,3888,738,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,946,SUCCESS,,3665.022254,192,0,0.1,0.2,0.3,263,1.4,1.5
    729,5/26/2021 20:01,2921.885,0.81,701,300,10,6001,0,65535,65535,1,23.2,28425,-296,-296,100,95,12,3664,3888,743,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4055,4049,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,961,SUCCESS,,3664.693118,192,0,0.1,0.2,0.3,263,1.4,1.5
    730,5/26/2021 20:01,2925.899,0.81,701,300,10,6001,0,65535,65535,1,23.2,28424,-298,-296,100,95,12,3663,3888,733,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4065,4068,4071,4066,4051,4056,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,968,SUCCESS,,3664.360848,192,0,0.1,0.2,0.3,263,1.4,1.5
    731,5/26/2021 20:01,2929.901,0.81,701,300,10,6001,0,65535,65535,1,23.2,28423,-296,-296,100,95,12,3663,3888,738,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,947,SUCCESS,,3664.031795,192,0,0.1,0.2,0.3,263,1.4,1.5
    732,5/26/2021 20:01,2933.91,0.81,701,300,10,6001,0,65535,65535,1,23.2,28424,-298,-296,100,95,12,3663,3888,743,743,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,969,SUCCESS,,3663.699939,192,0,0.1,0.2,0.3,263,1.4,1.5
    733,5/26/2021 20:01,2937.911,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-296,-297,100,95,12,3662,3888,737,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4056,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,957,SUCCESS,,3663.370968,192,0,0.1,0.2,0.3,263,1.4,1.5
    734,5/26/2021 20:01,2941.922,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-298,-296,100,95,12,3662,3888,742,742,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,939,SUCCESS,,3663.038946,192,0,0.1,0.2,0.3,263,1.4,1.5
    735,5/26/2021 20:01,2945.929,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-298,-296,100,95,12,3662,3888,742,742,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,939,SUCCESS,,3662.707255,192,0,0.1,0.2,0.3,263,1.4,1.5
    736,5/26/2021 20:01,2949.937,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-296,-297,100,95,12,3661,3888,737,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4059,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,962,SUCCESS,,3662.377709,192,0,0.1,0.2,0.3,263,1.4,1.5
    737,5/26/2021 20:02,2953.938,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-294,-297,100,95,12,3661,3888,742,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,944,SUCCESS,,3662.05096,192,0,0.1,0.2,0.3,263,1.4,1.5
    738,5/26/2021 20:02,2957.953,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-298,-297,100,95,12,3661,3888,737,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4053,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,940,SUCCESS,,3661.718608,192,0,0.1,0.2,0.3,263,1.4,1.5
    739,5/26/2021 20:02,2961.964,0.82,701,300,10,6001,0,65535,65535,1,23.2,28423,-296,-297,100,95,12,3660,3888,742,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.6,964,SUCCESS,,3661.388814,192,0,0.1,0.2,0.3,263,1.4,1.5
    740,5/26/2021 20:02,2965.97,0.82,701,300,10,6001,0,65535,65535,1,23.2,28422,-296,-296,100,95,12,3660,3888,747,742,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4070,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,957,SUCCESS,,3661.059432,192,0,0.1,0.2,0.3,263,1.4,1.5
    741,5/26/2021 20:02,2969.977,0.82,701,300,10,6001,0,65535,65535,1,23.2,28421,-296,-297,100,95,12,3660,3888,737,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4070,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,964,SUCCESS,,3660.729968,192,0,0.1,0.2,0.3,263,1.4,1.5
    742,5/26/2021 20:02,2973.985,0.83,701,300,10,6001,0,65535,65535,1,23.2,28421,-294,-296,100,95,12,3659,3888,742,742,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4071,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,945,SUCCESS,,3660.402648,192,0,0.1,0.2,0.3,263,1.4,1.5
    743,5/26/2021 20:02,2977.993,0.83,701,300,10,6001,0,65535,65535,1,23.2,28422,-298,-296,100,95,12,3659,3888,742,742,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4070,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,970,SUCCESS,,3660.070874,192,0,0.1,0.2,0.3,263,1.4,1.5
    744,5/26/2021 20:02,2981.998,0.83,701,300,10,6001,0,65535,65535,1,23.2,28421,-296,-297,100,95,12,3659,3888,742,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4070,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,942,SUCCESS,,3659.741574,192,0,0.1,0.2,0.3,263,1.4,1.5
    745,5/26/2021 20:02,2986.003,0.83,701,300,10,6001,0,65535,65535,1,23.2,28420,-298,-296,100,95,12,3658,3888,741,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4064,4068,4070,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,936,SUCCESS,,3659.410049,192,0,0.1,0.2,0.3,263,1.4,1.5
    746,5/26/2021 20:02,2990.007,0.83,701,300,10,6001,0,65535,65535,1,23.2,28419,-298,-297,100,95,12,3658,3888,737,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4068,4069,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,956,SUCCESS,,3659.078607,192,0,0.1,0.2,0.3,263,1.4,1.5
    747,5/26/2021 20:02,2994.019,0.83,701,300,10,6001,0,65535,65535,1,23.2,28419,-296,-297,100,95,12,3658,3888,727,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4068,4069,4066,4051,4055,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,954,SUCCESS,,3658.748731,192,0,0.1,0.2,0.3,263,1.4,1.5
    748,5/26/2021 20:02,2998.03,0.83,701,300,10,6001,0,65535,65535,1,23.2,28420,-296,-297,100,95,12,3657,3888,741,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4068,4069,4066,4051,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3658.418938,192,0,0.1,0.2,0.3,263,1.4,1.5
    749,5/26/2021 20:02,3002.038,0.83,701,300,10,6001,0,65535,65535,1,23.2,28419,-296,-297,100,95,12,3657,3888,736,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4068,4069,4066,4050,4054,4048,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,980,SUCCESS,,3658.089391,192,0,0.1,0.2,0.3,263,1.4,1.5
    750,5/26/2021 20:02,3006.053,0.84,701,300,10,6001,0,65535,65535,1,23.2,28417,-294,-297,100,95,12,3657,3888,746,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,980,SUCCESS,,3657.7615,192,0,0.1,0.2,0.3,263,1.4,1.5
    751,5/26/2021 20:02,3010.055,0.84,701,300,10,6001,0,65535,65535,1,23.2,28418,-298,-297,100,95,12,3656,3888,736,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,930,SUCCESS,,3657.430223,192,0,0.1,0.2,0.3,263,1.4,1.5
    752,5/26/2021 20:03,3014.063,0.84,701,300,10,6001,0,65535,65535,1,23.2,28418,-296,-297,100,95,12,3656,3888,741,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3657.100676,192,0,0.1,0.2,0.3,263,1.4,1.5
    753,5/26/2021 20:03,3018.069,0.84,701,300,10,6001,0,65535,65535,1,23.2,28416,-294,-296,100,95,12,3656,3888,746,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.8,965,SUCCESS,,3656.77352,192,0,0.1,0.2,0.3,263,1.4,1.5
    754,5/26/2021 20:03,3022.071,0.84,701,300,10,6001,0,65535,65535,1,23.2,28416,-298,-297,100,95,12,3655,3888,736,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,985,SUCCESS,,3656.442243,192,0,0.1,0.2,0.3,263,1.4,1.5
    755,5/26/2021 20:03,3026.077,0.84,701,300,10,6001,0,65535,65535,1,23.2,28416,-296,-297,100,95,12,3655,3888,741,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,963,SUCCESS,,3656.112861,192,0,0.1,0.2,0.3,263,1.4,1.5
    756,5/26/2021 20:03,3030.081,0.84,701,300,10,6001,0,65535,65535,1,23.2,28415,-296,-296,100,95,12,3655,3888,741,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,975,SUCCESS,,3655.783643,192,0,0.1,0.2,0.3,263,1.4,1.5
    757,5/26/2021 20:03,3034.09,0.84,701,300,10,6001,0,65535,65535,1,23.2,28415,-296,-296,100,94,12,3654,3888,741,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,948,SUCCESS,,3655.454014,192,0,0.1,0.2,0.3,263,1.4,1.5
    758,5/26/2021 20:03,3038.093,0.84,701,300,10,6001,0,65535,65535,1,23.2,28415,-296,-296,100,94,12,3654,3888,741,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,946,SUCCESS,,3655.124879,192,0,0.1,0.2,0.3,263,1.4,1.5
    759,5/26/2021 20:03,3042.101,0.85,701,300,10,6001,0,65535,65535,1,23.2,28414,-298,-296,100,94,12,3654,3888,736,741,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,969,SUCCESS,,3654.793105,192,0,0.1,0.2,0.3,263,1.4,1.5
    760,5/26/2021 20:03,3046.107,0.85,701,300,10,6001,0,65535,65535,1,23.2,28414,-298,-297,100,94,12,3653,3888,736,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4053,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,958,SUCCESS,,3654.461498,192,0,0.1,0.2,0.3,263,1.4,1.5
    761,5/26/2021 20:03,3050.114,0.85,701,300,10,6001,0,65535,65535,1,23.2,28415,-296,-296,100,94,12,3653,3888,740,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,940,SUCCESS,,3654.132033,192,0,0.1,0.2,0.3,263,1.4,1.5
    762,5/26/2021 20:03,3054.117,0.85,701,300,10,6001,0,65535,65535,1,23.2,28415,-298,-296,100,94,12,3653,3888,740,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4069,4065,4050,4054,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,970,SUCCESS,,3653.800674,192,0,0.1,0.2,0.3,263,1.4,1.5
    763,5/26/2021 20:03,3058.124,0.85,701,300,10,6001,0,65535,65535,1,23.2,28414,-294,-296,100,94,12,3652,3888,740,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4068,4065,4050,4053,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,948,SUCCESS,,3653.473435,192,0,0.1,0.2,0.3,263,1.4,1.5
    764,5/26/2021 20:03,3062.125,0.85,701,300,10,6001,0,65535,65535,1,23.2,28412,-296,-296,100,94,12,3652,3888,735,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4066,4068,4065,4050,4053,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,939,SUCCESS,,3653.144464,192,0,0.1,0.2,0.3,263,1.4,1.5
    765,5/26/2021 20:03,3066.126,0.85,701,300,10,6001,0,65535,65535,1,23.2,28412,-298,-297,100,94,12,3652,3888,740,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4066,4069,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,938,SUCCESS,,3652.81327,192,0,0.1,0.2,0.3,263,1.4,1.5
    766,5/26/2021 20:03,3070.138,0.85,701,300,10,6001,0,65535,65535,1,23.2,28411,-296,-297,100,94,12,3651,3888,740,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4068,4065,4049,4053,4047,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,947,SUCCESS,,3652.483395,192,0,0.1,0.2,0.3,263,1.4,1.5
    767,5/26/2021 20:04,3074.138,0.85,701,300,10,6001,0,65535,65535,1,23.2,28411,-296,-296,100,94,12,3651,3888,740,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4067,4068,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.3,969,SUCCESS,,3652.154506,192,0,0.1,0.2,0.3,263,1.4,1.5
    768,5/26/2021 20:04,3078.152,0.86,701,300,10,6001,0,65535,65535,1,23.2,28412,-298,-297,100,94,12,3651,3888,740,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4066,4068,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,944,SUCCESS,,3651.822236,192,0,0.1,0.2,0.3,263,1.4,1.5
    769,5/26/2021 20:04,3082.164,0.86,701,300,10,6001,0,65535,65535,1,23.2,28409,-296,-296,100,94,12,3650,3888,745,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4063,4066,4068,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,957,SUCCESS,,3651.49236,192,0,0.1,0.2,0.3,263,1.4,1.5
    770,5/26/2021 20:04,3086.171,0.86,701,300,10,6001,0,65535,65535,1,23.2,28409,-298,-296,100,94,12,3650,3888,735,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,963,SUCCESS,,3651.16067,192,0,0.1,0.2,0.3,263,1.4,1.5
    771,5/26/2021 20:04,3090.185,0.86,701,300,10,6001,0,65535,65535,1,23.2,28409,-296,-297,100,94,12,3650,3888,740,737,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,945,SUCCESS,,3650.83063,192,0,0.1,0.2,0.3,263,1.4,1.5
    772,5/26/2021 20:04,3094.2,0.86,701,300,10,6001,0,65535,65535,1,23.2,28409,-294,-296,100,94,12,3649,3888,745,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4065,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,969,SUCCESS,,3650.502738,192,0,0.1,0.2,0.3,263,1.4,1.5
    773,5/26/2021 20:04,3098.206,0.86,701,300,10,6001,0,65535,65535,1,23.2,28408,-298,-296,100,94,12,3649,3888,735,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4065,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,982,SUCCESS,,3650.17113,192,0,0.1,0.2,0.3,263,1.4,1.5
    774,5/26/2021 20:04,3102.208,0.86,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-296,100,94,12,3649,3888,745,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,968,SUCCESS,,3649.842077,192,0,0.1,0.2,0.3,263,1.4,1.5
    775,5/26/2021 20:04,3106.209,0.86,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-296,100,94,12,3649,3888,740,740,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,991,SUCCESS,,3649.513106,192,0,0.1,0.2,0.3,263,1.4,1.5
    776,5/26/2021 20:04,3110.21,0.86,701,300,10,6001,0,65535,65535,1,23.2,28407,-294,-296,100,94,12,3648,3888,739,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4065,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,1004,SUCCESS,,3649.186358,192,0,0.1,0.2,0.3,263,1.4,1.5
    777,5/26/2021 20:04,3114.224,0.87,701,300,10,6001,0,65535,65535,1,23.2,28408,-296,-296,100,94,12,3648,3888,739,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,959,SUCCESS,,3648.856318,192,0,0.1,0.2,0.3,263,1.4,1.5
    778,5/26/2021 20:04,3118.239,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-298,-296,100,94,12,3648,3888,739,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4053,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,956,SUCCESS,,3648.523965,192,0,0.1,0.2,0.3,263,1.4,1.5
    779,5/26/2021 20:04,3122.254,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-296,100,94,12,3647,3888,739,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,939,SUCCESS,,3648.193843,192,0,0.1,0.2,0.3,263,1.4,1.5
    780,5/26/2021 20:04,3126.255,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-296,100,94,12,3647,3888,739,739,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,940,SUCCESS,,3647.864871,192,0,0.1,0.2,0.3,263,1.4,1.5
    781,5/26/2021 20:04,3130.258,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-298,-297,100,94,12,3647,3888,739,737,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,979,SUCCESS,,3647.533512,192,0,0.1,0.2,0.3,263,1.4,1.5
    782,5/26/2021 20:05,3134.273,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-297,100,94,12,3646,3888,739,737,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4067,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,948,SUCCESS,,3647.20339,192,0,0.1,0.2,0.3,263,1.4,1.5
    783,5/26/2021 20:05,3138.285,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-298,-297,100,94,12,3646,3888,734,737,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4068,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,974,SUCCESS,,3646.871285,192,0,0.1,0.2,0.3,263,1.4,1.5
    784,5/26/2021 20:05,3142.288,0.87,701,300,10,6001,0,65535,65535,1,23.2,28407,-298,-297,100,94,12,3646,3888,734,737,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4067,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,953,SUCCESS,,3646.539926,192,0,0.1,0.2,0.3,263,1.4,1.5
    785,5/26/2021 20:05,3146.296,0.87,701,300,10,6001,0,65535,65535,1,23.2,28405,-296,-297,100,94,12,3645,3888,744,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4067,4064,4049,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,950,SUCCESS,,3646.210379,192,0,0.1,0.2,0.3,263,1.4,1.5
    786,5/26/2021 20:05,3150.3,0.88,701,300,10,6001,0,65535,65535,1,23.2,28409,-296,-297,100,94,12,3645,3888,734,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4067,4064,4048,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,936,SUCCESS,,3645.881161,192,0,0.1,0.2,0.3,263,1.4,1.5
    787,5/26/2021 20:05,3154.312,0.88,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-297,100,94,12,3645,3888,739,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4067,4064,4048,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,942,SUCCESS,,3645.551286,192,0,0.1,0.2,0.3,263,1.4,1.5
    788,5/26/2021 20:05,3158.326,0.88,701,300,10,6001,0,65535,65535,1,23.2,28403,-296,-297,100,94,12,3644,3888,739,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4065,4067,4064,4048,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,942,SUCCESS,,3645.221246,192,0,0.1,0.2,0.3,263,1.4,1.5
    789,5/26/2021 20:05,3162.329,0.88,701,300,10,6001,0,65535,65535,1,23.2,28404,-298,-297,100,94,12,3644,3888,734,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4066,4067,4063,4048,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,970,SUCCESS,,3644.889886,192,0,0.1,0.2,0.3,263,1.4,1.5
    790,5/26/2021 20:05,3166.341,0.88,701,300,10,6001,0,65535,65535,1,23.2,28404,-296,-297,100,94,12,3643,3888,738,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4066,4067,4063,4048,4052,4046,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,950,SUCCESS,,3644.560011,192,0,0.1,0.2,0.3,263,1.4,1.5
    791,5/26/2021 20:05,3170.342,0.88,701,300,10,6001,0,65535,65535,1,23.2,28402,-296,-296,100,94,12,3643,3888,738,738,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4062,4065,4067,4063,4048,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,956,SUCCESS,,3644.23104,192,0,0.1,0.2,0.3,263,1.4,1.5
    792,5/26/2021 20:05,3174.343,0.88,701,300,10,6001,0,65535,65535,1,23.2,28407,-296,-297,100,94,12,3643,3888,738,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,946,SUCCESS,,3643.902069,192,0,0.1,0.2,0.3,263,1.4,1.5
    793,5/26/2021 20:05,3178.349,0.88,701,300,10,6001,0,65535,65535,1,23.2,28401,-296,-297,100,94,12,3642,3888,738,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,980,SUCCESS,,3643.572686,192,0,0.1,0.2,0.3,263,1.4,1.5
    794,5/26/2021 20:05,3182.354,0.88,701,300,10,6001,0,65535,65535,1,23.2,28401,-296,-297,100,94,12,3642,3888,738,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,984,SUCCESS,,3643.243386,192,0,0.1,0.2,0.3,263,1.4,1.5
    795,5/26/2021 20:05,3186.355,0.89,701,300,10,6001,0,65535,65535,1,23.2,28401,-298,-297,100,94,12,3642,3888,733,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,22.9,975,SUCCESS,,3642.912193,192,0,0.1,0.2,0.3,263,1.4,1.5
    796,5/26/2021 20:05,3190.368,0.89,701,300,10,6001,0,65535,65535,1,23.2,28400,-296,-297,100,94,12,3641,3888,738,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,952,SUCCESS,,3642.582235,192,0,0.1,0.2,0.3,263,1.4,1.5
    797,5/26/2021 20:06,3194.369,0.89,701,300,10,6001,0,65535,65535,1,23.2,28400,-298,-297,100,94,12,3641,3888,733,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,969,SUCCESS,,3642.251041,192,0,0.1,0.2,0.3,263,1.4,1.5
    798,5/26/2021 20:06,3198.377,0.89,701,300,10,6001,0,65535,65535,1,23.2,28401,-296,-297,100,94,12,3641,3888,738,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,943,SUCCESS,,3641.921494,192,0,0.1,0.2,0.3,263,1.4,1.5
    799,5/26/2021 20:06,3202.385,0.89,701,300,10,6001,0,65535,65535,1,23.2,28400,-298,-297,100,94,12,3641,3888,733,736,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,976,SUCCESS,,3641.589721,192,0,0.1,0.2,0.3,263,1.4,1.5
    800,5/26/2021 20:06,3206.395,0.89,701,300,10,6001,0,65535,65535,1,23.2,28400,-298,-297,100,94,12,3640,3888,733,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4067,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,987,SUCCESS,,3641.257782,192,0,0.1,0.2,0.3,263,1.4,1.5
    801,5/26/2021 20:06,3210.407,0.89,701,300,10,6001,0,65535,65535,1,23.2,28399,-296,-297,100,94,12,3640,3888,738,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,944,SUCCESS,,3640.927906,192,0,0.1,0.2,0.3,263,1.4,1.5
    802,5/26/2021 20:06,3214.407,0.89,701,300,10,6001,0,65535,65535,1,23.2,28399,-296,-297,100,94,12,3640,3888,738,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,957,SUCCESS,,3640.599018,192,0,0.1,0.2,0.3,263,1.4,1.5
    803,5/26/2021 20:06,3218.42,0.89,701,300,10,6001,0,65535,65535,1,23.2,28399,-300,-297,100,94,12,3639,3888,738,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4049,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,952,SUCCESS,,3640.264601,192,0,0.1,0.2,0.3,263,1.4,1.5
    804,5/26/2021 20:06,3222.421,0.9,701,300,10,6001,0,65535,65535,1,23.2,28398,-296,-297,100,94,12,3639,3888,738,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,941,SUCCESS,,3639.93563,192,0,0.1,0.2,0.3,263,1.4,1.5
    805,5/26/2021 20:06,3226.434,0.9,701,300,10,6001,0,65535,65535,1,23.2,28399,-298,-297,100,94,12,3639,3888,738,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4061,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,965,SUCCESS,,3639.603443,192,0,0.1,0.2,0.3,263,1.4,1.5
    806,5/26/2021 20:06,3230.442,0.9,701,300,10,6001,0,65535,65535,1,23.2,28398,-296,-297,100,94,12,3638,3888,737,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4065,4066,4063,4048,4048,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,969,SUCCESS,,3639.273896,192,0,0.1,0.2,0.3,263,1.4,1.5
    807,5/26/2021 20:06,3234.452,0.9,701,300,10,6001,0,65535,65535,1,23.2,28399,-296,-297,100,94,12,3638,3888,732,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4065,4066,4063,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,955,SUCCESS,,3638.944185,192,0,0.1,0.2,0.3,263,1.4,1.5
    808,5/26/2021 20:06,3238.463,0.9,701,300,10,6001,0,65535,65535,1,23.2,28398,-300,-297,100,94,12,3638,3888,732,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4065,4066,4062,4048,4051,4045,0,0,0,0,0,0,0,0,2838,23.1,23.2,-273.2,23.2,-273.2,23.1,977,SUCCESS,,3638.609935,192,0,0.1,0.2,0.3,263,1.4,1.5
    809,5/26/2021 20:06,3242.473,0.9,701,300,10,6001,0,65535,65535,1,23.2,28398,-298,-297,100,94,12,3637,3888,732,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4065,4066,4063,4048,4047,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,982,SUCCESS,,3638.277996,192,0,0.1,0.2,0.3,263,1.4,1.5
    810,5/26/2021 20:06,3246.487,0.9,701,300,10,6001,0,65535,65535,1,23.2,28398,-298,-297,100,94,12,3637,3888,737,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4065,4066,4062,4047,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,954,SUCCESS,,3637.945726,192,0,0.1,0.2,0.3,263,1.4,1.5
    811,5/26/2021 20:06,3250.491,0.9,701,300,10,6001,0,65535,65535,1,23.2,28396,-298,-297,100,94,12,3637,3888,732,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4048,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,959,SUCCESS,,3637.614284,192,0,0.1,0.2,0.3,263,1.4,1.5
    812,5/26/2021 20:07,3254.505,0.9,701,300,10,6001,0,65535,65535,1,23.2,28395,-296,-297,100,94,12,3636,3888,737,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4065,4066,4062,4047,4051,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23,965,SUCCESS,,3637.284244,192,0,0.1,0.2,0.3,263,1.4,1.5
    813,5/26/2021 20:07,3258.52,0.91,701,300,10,6001,0,65535,65535,1,23.2,28395,-296,-297,100,94,12,3636,3888,727,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4047,4050,4045,0,0,0,0,0,0,0,0,2838,23.1,23.2,-273.2,23.2,-273.2,23.1,966,SUCCESS,,3636.954121,192,0,0.1,0.2,0.3,263,1.4,1.5
    814,5/26/2021 20:07,3262.53,0.91,701,300,10,6001,0,65535,65535,1,23.2,28396,-296,-297,100,94,12,3636,3888,737,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4047,4050,4044,0,0,0,0,0,0,0,0,2838,23.1,23.2,-273.2,23.2,-273.2,23.1,940,SUCCESS,,3636.62441,192,0,0.1,0.2,0.3,263,1.4,1.5
    815,5/26/2021 20:07,3266.533,0.91,701,300,10,6001,0,65535,65535,1,23.2,28394,-296,-297,100,94,12,3635,3888,737,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4047,4052,4045,0,0,0,0,0,0,0,0,2839,23.1,23.2,-273.2,23.2,-273.2,23.1,956,SUCCESS,,3636.295275,192,0,0.1,0.2,0.3,263,1.4,1.5
    816,5/26/2021 20:07,3270.543,0.91,701,300,10,6001,0,65535,65535,1,23.2,28393,-298,-297,100,94,12,3635,3888,732,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4047,4051,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,969,SUCCESS,,3635.963336,192,0,0.1,0.2,0.3,263,1.4,1.5
    817,5/26/2021 20:07,3274.555,0.91,701,300,10,6001,0,65535,65535,1,23.2,28393,-296,-297,100,94,12,3635,3888,732,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4047,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,22.9,1007,SUCCESS,,3635.63346,192,0,0.1,0.2,0.3,263,1.4,1.5
    818,5/26/2021 20:07,3278.569,0.91,701,300,10,6001,0,65535,65535,1,23.2,28392,-298,-297,100,94,12,3634,3888,737,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4066,4062,4047,4051,4044,0,0,0,0,0,0,0,0,2835,23.1,23.2,-273.2,23.2,-273.2,23.1,969,SUCCESS,,3635.30119,192,0,0.1,0.2,0.3,263,1.4,1.5
    819,5/26/2021 20:07,3282.575,0.91,701,300,10,6001,0,65535,65535,1,23.2,28392,-298,-297,100,94,12,3634,3888,732,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4065,4062,4047,4050,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,968,SUCCESS,,3634.969583,192,0,0.1,0.2,0.3,263,1.4,1.5
    820,5/26/2021 20:07,3286.579,0.91,701,300,10,6001,0,65535,65535,1,23.2,28392,-296,-297,100,94,12,3634,3888,732,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4065,4062,4047,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,970,SUCCESS,,3634.640365,192,0,0.1,0.2,0.3,263,1.4,1.5
    821,5/26/2021 20:07,3290.587,0.91,701,300,10,6001,0,65535,65535,1,23.2,28392,-298,-297,100,94,12,3633,3888,731,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4065,4062,4047,4054,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,979,SUCCESS,,3634.308591,192,0,0.1,0.2,0.3,263,1.4,1.5
    822,5/26/2021 20:07,3294.598,0.92,701,300,10,6001,0,65535,65535,1,23.2,28391,-294,-297,100,94,12,3633,3888,736,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4065,4062,4047,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,1021,SUCCESS,,3633.981026,192,0,0.1,0.2,0.3,263,1.4,1.5
    823,5/26/2021 20:07,3298.606,0.92,701,300,10,6001,0,65535,65535,1,23.2,28390,-296,-297,100,94,12,3633,3888,736,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4065,4062,4046,4050,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3633.65148,192,0,0.1,0.2,0.3,263,1.4,1.5
    824,5/26/2021 20:07,3302.617,0.92,701,300,10,6001,0,65535,65535,1,23.2,28391,-300,-297,100,94,12,3632,3888,731,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4064,4065,4062,4046,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,980,SUCCESS,,3633.31723,192,0,0.1,0.2,0.3,263,1.4,1.5
    825,5/26/2021 20:07,3306.633,0.92,701,300,10,6001,0,65535,65535,1,23.2,28389,-296,-297,100,94,12,3632,3888,736,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4060,4063,4065,4062,4046,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,982,SUCCESS,,3632.987025,192,0,0.1,0.2,0.3,263,1.4,1.5
    826,5/26/2021 20:07,3310.648,0.92,701,300,10,6001,0,65535,65535,1,23.2,28390,-296,-297,100,94,12,3632,3888,736,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4062,4046,4049,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,938,SUCCESS,,3632.656903,192,0,0.1,0.2,0.3,263,1.4,1.5
    827,5/26/2021 20:08,3314.662,0.92,701,300,10,6001,0,65535,65535,1,23.2,28388,-298,-297,100,94,12,3631,3888,731,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,941,SUCCESS,,3632.324633,192,0,0.1,0.2,0.3,263,1.4,1.5
    828,5/26/2021 20:08,3318.672,0.92,701,300,10,6001,0,65535,65535,1,23.2,28391,-296,-297,100,94,12,3631,3888,736,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4064,4065,4062,4046,4050,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,941,SUCCESS,,3631.994922,192,0,0.1,0.2,0.3,263,1.4,1.5
    829,5/26/2021 20:08,3322.683,0.92,701,300,10,6001,0,65535,65535,1,23.2,28387,-296,-297,100,94,12,3631,3888,736,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4062,4046,4050,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,946,SUCCESS,,3631.665129,192,0,0.1,0.2,0.3,263,1.4,1.5
    830,5/26/2021 20:08,3326.697,0.92,701,300,10,6001,0,65535,65535,1,23.2,28387,-298,-297,100,94,12,3630,3888,731,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,1016,SUCCESS,,3631.332859,192,0,0.1,0.2,0.3,263,1.4,1.5
    831,5/26/2021 20:08,3330.702,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-298,-297,100,94,12,3630,3888,731,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4044,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,939,SUCCESS,,3631.001334,192,0,0.1,0.2,0.3,263,1.4,1.5
    832,5/26/2021 20:08,3334.707,0.93,701,300,10,6001,0,65535,65535,1,23.2,28387,-296,-297,100,94,12,3630,3888,736,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4050,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,22.8,937,SUCCESS,,3630.672034,192,0,0.1,0.2,0.3,263,1.4,1.5
    833,5/26/2021 20:08,3338.714,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-296,-297,100,94,12,3629,3888,731,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,944,SUCCESS,,3630.342569,192,0,0.1,0.2,0.3,263,1.4,1.5
    834,5/26/2021 20:08,3342.716,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-296,-297,100,94,12,3629,3888,736,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,943,SUCCESS,,3630.013516,192,0,0.1,0.2,0.3,263,1.4,1.5
    835,5/26/2021 20:08,3346.722,0.93,701,300,10,6001,0,65535,65535,1,23.2,28387,-296,-297,100,94,12,3629,3888,736,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,944,SUCCESS,,3629.684134,192,0,0.1,0.2,0.3,263,1.4,1.5
    836,5/26/2021 20:08,3350.728,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-296,-297,100,94,12,3628,3888,735,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,970,SUCCESS,,3629.354751,192,0,0.1,0.2,0.3,263,1.4,1.5
    837,5/26/2021 20:08,3354.734,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-298,-297,100,94,12,3628,3888,730,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,947,SUCCESS,,3629.023144,192,0,0.1,0.2,0.3,263,1.4,1.5
    838,5/26/2021 20:08,3358.736,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-296,-297,100,94,12,3628,3888,735,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,947,SUCCESS,,3628.69409,192,0,0.1,0.2,0.3,263,1.4,1.5
    839,5/26/2021 20:08,3362.742,0.93,701,300,10,6001,0,65535,65535,1,23.2,28386,-296,-296,100,94,12,3627,3888,735,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,984,SUCCESS,,3628.364708,192,0,0.1,0.2,0.3,263,1.4,1.5
    840,5/26/2021 20:08,3366.742,0.94,701,300,10,6001,0,65535,65535,1,23.2,28386,-298,-297,100,94,12,3627,3888,730,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4059,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,968,SUCCESS,,3628.033597,192,0,0.1,0.2,0.3,263,1.4,1.5
    841,5/26/2021 20:08,3370.75,0.94,701,300,10,6001,0,65535,65535,1,23.2,28384,-296,-296,100,94,12,3627,3888,735,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4065,4061,4046,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,943,SUCCESS,,3627.70405,192,0,0.1,0.2,0.3,263,1.4,1.5
    842,5/26/2021 20:09,3374.757,0.94,701,300,10,6001,0,65535,65535,1,23.2,28384,-296,-296,100,94,12,3626,3888,735,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4061,4046,4048,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,970,SUCCESS,,3627.374586,192,0,0.1,0.2,0.3,263,1.4,1.5
    843,5/26/2021 20:09,3378.769,0.94,701,300,10,6001,0,65535,65535,1,23.2,28382,-298,-296,100,94,12,3626,3888,735,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4060,4045,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,945,SUCCESS,,3627.042481,192,0,0.1,0.2,0.3,263,1.4,1.5
    844,5/26/2021 20:09,3382.781,0.94,701,300,10,6001,0,65535,65535,1,23.2,28382,-294,-296,100,94,12,3626,3888,735,735,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4061,4045,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,961,SUCCESS,,3626.714835,192,0,0.1,0.2,0.3,263,1.4,1.5
    845,5/26/2021 20:09,3386.796,0.94,701,300,10,6001,0,65535,65535,1,23.2,28381,-298,-297,100,94,12,3625,3888,730,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4060,4046,4048,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,941,SUCCESS,,3626.382482,192,0,0.1,0.2,0.3,263,1.4,1.5
    846,5/26/2021 20:09,3390.808,0.94,701,300,10,6001,0,65535,65535,1,23.2,28382,-296,-297,100,94,12,3625,3888,735,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4060,4045,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,22.6,956,SUCCESS,,3626.052606,192,0,0.1,0.2,0.3,263,1.4,1.5
    847,5/26/2021 20:09,3394.81,0.94,701,300,10,6001,0,65535,65535,1,23.2,28382,-296,-297,100,94,12,3625,3888,735,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4060,4045,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,958,SUCCESS,,3625.723553,192,0,0.1,0.2,0.3,263,1.4,1.5
    848,5/26/2021 20:09,3398.825,0.94,701,300,10,6001,0,65535,65535,1,23.2,28380,-296,-297,100,94,12,3624,3888,730,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4064,4060,4045,4049,4043,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,944,SUCCESS,,3625.393431,192,0,0.1,0.2,0.3,263,1.4,1.5
    849,5/26/2021 20:09,3402.836,0.95,701,300,10,6001,0,65535,65535,1,23.2,28381,-298,-297,100,94,12,3624,3888,730,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4064,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,965,SUCCESS,,3625.061409,192,0,0.1,0.2,0.3,263,1.4,1.5
    850,5/26/2021 20:09,3406.844,0.95,701,300,10,6001,0,65535,65535,1,23.2,28382,-298,-297,100,94,12,3624,3888,730,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4063,4064,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,945,SUCCESS,,3624.729636,192,0,0.1,0.2,0.3,263,1.4,1.5
    851,5/26/2021 20:09,3410.859,0.95,701,300,10,6001,0,65535,65535,1,23.2,28380,-296,-297,100,94,12,3623,3888,729,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4064,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,962,SUCCESS,,3624.399514,192,0,0.1,0.2,0.3,263,1.4,1.5
    852,5/26/2021 20:09,3414.872,0.95,701,300,10,6001,0,65535,65535,1,23.2,28379,-296,-297,100,94,12,3623,3888,734,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4064,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23.1,958,SUCCESS,,3624.069556,192,0,0.1,0.2,0.3,263,1.4,1.5
    853,5/26/2021 20:09,3418.886,0.95,701,300,10,6001,0,65535,65535,1,23.2,28379,-300,-297,100,94,12,3623,3888,734,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4064,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,975,SUCCESS,,3623.735056,192,0,0.1,0.2,0.3,263,1.4,1.5
    854,5/26/2021 20:09,3422.889,0.95,701,300,10,6001,0,65535,65535,1,23.2,28378,-298,-297,100,94,12,3622,3888,729,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,941,SUCCESS,,3623.403696,192,0,0.1,0.2,0.3,263,1.4,1.5
    855,5/26/2021 20:09,3426.893,0.95,701,300,10,6001,0,65535,65535,1,23.2,28379,-296,-297,100,94,12,3622,3888,734,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23.1,955,SUCCESS,,3623.074479,192,0,0.1,0.2,0.3,263,1.4,1.5
    856,5/26/2021 20:09,3430.908,0.95,701,300,10,6001,0,65535,65535,1,23.2,28379,-298,-297,100,94,12,3622,3888,734,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23.1,977,SUCCESS,,3622.742126,192,0,0.1,0.2,0.3,263,1.4,1.5
    857,5/26/2021 20:10,3434.924,0.95,701,300,10,6001,0,65535,65535,1,23.2,28378,-294,-297,100,94,12,3621,3888,734,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4058,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,940,SUCCESS,,3622.414153,192,0,0.1,0.2,0.3,263,1.4,1.5
    858,5/26/2021 20:10,3438.938,0.96,701,300,10,6001,0,65535,65535,1,23.2,28376,-296,-296,100,94,12,3621,3888,729,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,961,SUCCESS,,3622.084113,192,0,0.1,0.2,0.3,263,1.4,1.5
    859,5/26/2021 20:10,3442.945,0.96,701,300,10,6001,0,65535,65535,1,23.2,28380,-298,-297,100,94,12,3621,3888,729,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,985,SUCCESS,,3621.752422,192,0,0.1,0.2,0.3,263,1.4,1.5
    860,5/26/2021 20:10,3446.952,0.96,701,300,10,6001,0,65535,65535,1,23.1,28376,-296,-297,100,94,12,3620,3888,734,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,22.8,950,SUCCESS,,3621.422958,192,0,0.1,0.2,0.3,263,1.4,1.5
    861,5/26/2021 20:10,3450.967,0.96,701,300,10,6001,0,65535,65535,1,23.1,28377,-296,-296,100,94,12,3620,3888,734,734,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4060,4045,4048,4041,0,0,0,0,0,0,0,0,2834,23.1,23.1,-273.2,23.1,-273.2,23.1,961,SUCCESS,,3621.092835,192,0,0.1,0.2,0.3,263,1.4,1.5
    862,5/26/2021 20:10,3454.973,0.96,701,300,10,6001,0,65535,65535,1,23.1,28377,-296,-297,100,94,12,3620,3888,734,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4060,4045,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,971,SUCCESS,,3620.763453,192,0,0.1,0.2,0.3,263,1.4,1.5
    863,5/26/2021 20:10,3458.987,0.96,701,300,10,6001,0,65535,65535,1,23.2,28374,-294,-297,100,94,12,3619,3888,739,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4059,4045,4048,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,937,SUCCESS,,3620.435643,192,0,0.1,0.2,0.3,263,1.4,1.5
    864,5/26/2021 20:10,3462.999,0.96,701,300,10,6001,0,65535,65535,1,23.2,28372,-298,-297,100,94,12,3619,3888,729,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4059,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23.1,942,SUCCESS,,3620.103539,192,0,0.1,0.2,0.3,263,1.4,1.5
    865,5/26/2021 20:10,3467,0.96,701,300,10,6001,0,65535,65535,1,23.2,28375,-294,-297,100,94,12,3619,3888,739,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4059,4044,4048,4042,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23.1,946,SUCCESS,,3619.77679,192,0,0.1,0.2,0.3,263,1.4,1.5
    866,5/26/2021 20:10,3471.012,0.96,701,300,10,6001,0,65535,65535,1,23.2,28374,-298,-297,100,94,12,3618,3888,728,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4063,4059,4045,4048,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,966,SUCCESS,,3619.444686,192,0,0.1,0.2,0.3,263,1.4,1.5
    867,5/26/2021 20:10,3475.027,0.97,701,300,10,6001,0,65535,65535,1,23.2,28372,-298,-297,100,94,12,3618,3888,728,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4059,4044,4048,4041,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,961,SUCCESS,,3619.112333,192,0,0.1,0.2,0.3,263,1.4,1.5
    868,5/26/2021 20:10,3479.037,0.97,701,300,10,6001,0,65535,65535,1,23.2,28373,-296,-297,100,94,12,3618,3888,733,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4063,4059,4044,4048,4041,0,0,0,0,0,0,0,0,2834,23.1,23.2,-273.2,23.2,-273.2,23,950,SUCCESS,,3618.782622,192,0,0.1,0.2,0.3,263,1.4,1.5
    869,5/26/2021 20:10,3483.044,0.97,701,300,10,6001,0,65535,65535,1,23.2,28373,-298,-297,100,94,12,3617,3888,733,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4062,4063,4059,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23.1,948,SUCCESS,,3618.450931,192,0,0.1,0.2,0.3,263,1.4,1.5
    870,5/26/2021 20:10,3487.05,0.97,701,300,10,6001,0,65535,65535,1,23.1,28369,-296,-297,100,94,12,3617,3888,728,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4063,4059,4044,4048,4041,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,947,SUCCESS,,3618.121549,192,0,0.1,0.2,0.3,263,1.4,1.5
    871,5/26/2021 20:10,3491.055,0.97,701,300,10,6001,0,65535,65535,1,23.1,28372,-294,-297,100,94,12,3617,3888,738,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4063,4059,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,983,SUCCESS,,3617.794474,192,0,0.1,0.2,0.3,263,1.4,1.5
    872,5/26/2021 20:11,3495.057,0.97,701,300,10,6001,0,65535,65535,1,23.2,28372,-298,-297,100,94,12,3616,3888,728,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4062,4059,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,966,SUCCESS,,3617.463198,192,0,0.1,0.2,0.3,263,1.4,1.5
    873,5/26/2021 20:11,3499.06,0.97,701,300,10,6001,0,65535,65535,1,23.2,28372,-296,-297,100,94,12,3616,3888,738,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4062,4058,4044,4046,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,944,SUCCESS,,3617.134062,192,0,0.1,0.2,0.3,263,1.4,1.5
    874,5/26/2021 20:11,3503.066,0.97,701,300,10,6001,0,65535,65535,1,23.1,28372,-296,-296,100,94,12,3616,3888,738,733,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4062,4059,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,940,SUCCESS,,3616.80468,192,0,0.1,0.2,0.3,263,1.4,1.5
    875,5/26/2021 20:11,3507.073,0.97,701,300,10,6001,0,65535,65535,1,23.2,28372,-298,-297,100,93,12,3615,3888,728,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4062,4059,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23.1,983,SUCCESS,,3616.472989,192,0,0.1,0.2,0.3,263,1.4,1.5
    876,5/26/2021 20:11,3511.075,0.98,701,300,10,6001,0,65535,65535,1,23.2,28370,-298,-297,100,93,12,3615,3888,738,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4057,4061,4062,4058,4044,4047,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,960,SUCCESS,,3616.141713,192,0,0.1,0.2,0.3,263,1.4,1.5
    877,5/26/2021 20:11,3515.089,0.98,701,300,10,6001,0,65535,65535,1,23.2,28369,-298,-297,100,93,12,3615,3888,728,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4061,4062,4058,4043,4046,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,963,SUCCESS,,3615.809443,192,0,0.1,0.2,0.3,263,1.4,1.5
    878,5/26/2021 20:11,3519.09,0.98,701,300,10,6001,0,65535,65535,1,23.2,28367,-298,-297,100,93,12,3614,3888,728,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4061,4062,4058,4043,4046,4041,0,0,0,0,0,0,0,0,2834,22.9,23.2,-273.2,23.2,-273.2,23,958,SUCCESS,,3615.478249,192,0,0.1,0.2,0.3,263,1.4,1.5
    879,5/26/2021 20:11,3523.106,0.98,701,300,10,6001,0,65535,65535,1,23.2,28368,-294,-297,100,93,12,3614,3888,733,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4061,4062,4058,4043,4046,4041,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,976,SUCCESS,,3615.150275,192,0,0.1,0.2,0.3,263,1.4,1.5
    880,5/26/2021 20:11,3527.114,0.98,701,300,10,6001,0,65535,65535,1,23.1,28367,-298,-297,100,93,12,3614,3888,733,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4061,4062,4058,4043,4046,4041,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,965,SUCCESS,,3614.818502,192,0,0.1,0.2,0.3,263,1.4,1.5
    881,5/26/2021 20:11,3531.116,0.98,701,300,10,6001,0,65535,65535,1,23.1,28366,-296,-297,100,93,12,3613,3888,732,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4061,4062,4058,4044,4046,4041,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,983,SUCCESS,,3614.489449,192,0,0.1,0.2,0.3,263,1.4,1.5
    882,5/26/2021 20:11,3535.12,0.98,701,300,10,6001,0,65535,65535,1,23.1,28366,-296,-297,100,93,12,3613,3888,732,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4061,4062,4058,4043,4048,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,991,SUCCESS,,3614.160231,192,0,0.1,0.2,0.3,263,1.4,1.5
    883,5/26/2021 20:11,3539.125,0.98,701,300,10,6001,0,65535,65535,1,23.1,28367,-296,-297,100,93,12,3613,3888,727,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.4,974,SUCCESS,,3613.830931,192,0,0.1,0.2,0.3,263,1.4,1.5
    884,5/26/2021 20:11,3543.125,0.98,701,300,10,6001,0,65535,65535,1,23.1,28366,-296,-297,100,93,12,3612,3888,737,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,942,SUCCESS,,3613.502042,192,0,0.1,0.2,0.3,263,1.4,1.5
    885,5/26/2021 20:11,3547.14,0.99,701,300,10,6001,0,65535,65535,1,23.1,28365,-298,-296,100,93,12,3612,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4043,4047,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,963,SUCCESS,,3613.169689,192,0,0.1,0.2,0.3,263,1.4,1.5
    886,5/26/2021 20:11,3551.146,0.99,701,300,10,6001,0,65535,65535,1,23.1,28365,-298,-297,100,93,12,3612,3888,727,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,958,SUCCESS,,3612.838081,192,0,0.1,0.2,0.3,263,1.4,1.5
    887,5/26/2021 20:12,3555.151,0.99,701,300,10,6001,0,65535,65535,1,23.1,28365,-296,-297,100,93,12,3611,3888,727,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,965,SUCCESS,,3612.508781,192,0,0.1,0.2,0.3,263,1.4,1.5
    888,5/26/2021 20:12,3559.157,0.99,701,300,10,6001,0,65535,65535,1,23.1,28365,-296,-296,100,93,12,3611,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4043,4050,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,939,SUCCESS,,3612.179399,192,0,0.1,0.2,0.3,263,1.4,1.5
    889,5/26/2021 20:12,3563.16,0.99,701,300,10,6001,0,65535,65535,1,23.1,28365,-298,-297,100,93,12,3611,3888,727,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4056,4060,4062,4058,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,951,SUCCESS,,3611.84804,192,0,0.1,0.2,0.3,263,1.4,1.5
    890,5/26/2021 20:12,3567.175,0.99,701,300,10,6001,0,65535,65535,1,23.1,28365,-298,-296,100,93,12,3610,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4062,4058,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,975,SUCCESS,,3611.515687,192,0,0.1,0.2,0.3,263,1.4,1.5
    891,5/26/2021 20:12,3571.177,0.99,701,300,10,6001,0,65535,65535,1,23.1,28362,-298,-296,100,93,12,3610,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4058,4043,4050,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,953,SUCCESS,,3611.18441,192,0,0.1,0.2,0.3,263,1.4,1.5
    892,5/26/2021 20:12,3575.185,0.99,701,300,10,6001,0,65535,65535,1,23.1,28363,-296,-296,100,93,12,3610,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4058,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,941,SUCCESS,,3610.854864,192,0,0.1,0.2,0.3,263,1.4,1.5
    893,5/26/2021 20:12,3579.191,0.99,701,300,10,6001,0,65535,65535,1,23.1,28362,-296,-296,100,93,12,3609,3888,737,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4043,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,936,SUCCESS,,3610.525481,192,0,0.1,0.2,0.3,263,1.4,1.5
    894,5/26/2021 20:12,3583.197,1,701,300,10,6001,0,65535,65535,1,23.1,28364,-294,-296,100,93,12,3609,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,944,SUCCESS,,3610.198325,192,0,0.1,0.2,0.3,263,1.4,1.5
    895,5/26/2021 20:12,3587.206,1,701,300,10,6001,0,65535,65535,1,23.1,28360,-296,-296,100,93,12,3609,3888,732,732,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4043,4046,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,1004,SUCCESS,,3609.868696,192,0,0.1,0.2,0.3,263,1.4,1.5
    896,5/26/2021 20:12,3591.215,1,701,300,10,6001,0,65535,65535,1,23.1,28360,-296,-296,100,93,12,3608,3888,726,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4043,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,947,SUCCESS,,3609.539067,192,0,0.1,0.2,0.3,263,1.4,1.5
    897,5/26/2021 20:12,3595.219,1,701,300,10,6001,0,65535,65535,1,23.1,28360,-296,-297,100,93,12,3608,3888,731,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.8,957,SUCCESS,,3609.209849,192,0,0.1,0.2,0.3,263,1.4,1.5
    898,5/26/2021 20:12,3599.219,1,701,300,10,6001,0,65535,65535,1,23.1,28360,-296,-296,100,93,12,3608,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,956,SUCCESS,,3608.88096,192,0,0.1,0.2,0.3,263,1.4,1.5
    899,5/26/2021 20:12,3603.221,1,701,300,10,6001,0,65535,65535,1,23.1,28359,-296,-297,100,93,12,3607,3888,731,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4059,4061,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,962,SUCCESS,,3608.551907,192,0,0.1,0.2,0.3,263,1.4,1.5
    900,5/26/2021 20:12,3607.231,1,701,300,10,6001,0,65535,65535,1,23.1,28360,-296,-297,100,93,12,3607,3888,731,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4060,4061,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,964,SUCCESS,,3608.222196,192,0,0.1,0.2,0.3,263,1.4,1.5
    901,5/26/2021 20:12,3611.233,1,701,300,10,6001,0,65535,65535,1,23.1,28358,-296,-296,100,93,12,3607,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4059,4061,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,946,SUCCESS,,3607.893143,192,0,0.1,0.2,0.3,263,1.4,1.5
    902,5/26/2021 20:13,3615.241,1,701,300,10,6001,0,65535,65535,1,23.1,28359,-298,-297,100,93,12,3606,3888,726,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4059,4061,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,969,SUCCESS,,3607.561369,192,0,0.1,0.2,0.3,263,1.4,1.5
    903,5/26/2021 20:13,3619.252,1.01,701,300,10,6001,0,65535,65535,1,23.1,28359,-296,-296,100,93,12,3606,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4059,4060,4057,4042,4045,4040,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,948,SUCCESS,,3607.231576,192,0,0.1,0.2,0.3,263,1.4,1.5
    904,5/26/2021 20:13,3623.256,1.01,701,300,10,6001,0,65535,65535,1,23.1,28358,-298,-296,100,93,12,3606,3888,726,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4059,4061,4057,4042,4045,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,958,SUCCESS,,3606.900134,192,0,0.1,0.2,0.3,263,1.4,1.5
    905,5/26/2021 20:13,3627.265,1.01,701,300,10,6001,0,65535,65535,1,23.1,28356,-296,-296,100,93,12,3605,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4059,4060,4057,4042,4046,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,996,SUCCESS,,3606.570505,192,0,0.1,0.2,0.3,263,1.4,1.5
    906,5/26/2021 20:13,3631.267,1.01,701,300,10,6001,0,65535,65535,1,23.1,28358,-296,-296,100,93,12,3605,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4055,4059,4060,4057,4042,4045,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,940,SUCCESS,,3606.241451,192,0,0.1,0.2,0.3,263,1.4,1.5
    907,5/26/2021 20:13,3635.275,1.01,701,300,10,6001,0,65535,65535,1,23.1,28356,-296,-296,100,93,12,3605,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4059,4060,4057,4042,4045,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,969,SUCCESS,,3605.911905,192,0,0.1,0.2,0.3,263,1.4,1.5
    908,5/26/2021 20:13,3639.279,1.01,701,300,10,6001,0,65535,65535,1,23.1,28355,-296,-296,100,93,11,3604,3888,731,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4059,4060,4057,4042,4045,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,960,SUCCESS,,3605.582687,192,0,0.1,0.2,0.3,263,1.4,1.5
    909,5/26/2021 20:13,3643.291,1.01,701,300,10,6001,0,65535,65535,1,23.1,28356,-296,-296,100,93,11,3604,3888,726,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4059,4060,4056,4041,4044,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,979,SUCCESS,,3605.252811,192,0,0.1,0.2,0.3,263,1.4,1.5
    910,5/26/2021 20:13,3647.295,1.01,701,300,10,6001,0,65535,65535,1,23.1,28354,-298,-296,100,93,11,3604,3888,726,731,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4045,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,949,SUCCESS,,3604.921369,192,0,0.1,0.2,0.3,263,1.4,1.5
    911,5/26/2021 20:13,3651.295,1.01,701,300,10,6001,0,65535,65535,1,23.1,28353,-296,-296,100,93,11,3603,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4045,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,980,SUCCESS,,3604.59248,192,0,0.1,0.2,0.3,263,1.4,1.5
    912,5/26/2021 20:13,3655.297,1.02,701,300,10,6001,0,65535,65535,1,23.1,28353,-298,-296,100,93,11,3603,3888,725,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4059,4060,4056,4041,4044,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,970,SUCCESS,,3604.261204,192,0,0.1,0.2,0.3,263,1.4,1.5
    913,5/26/2021 20:13,3659.299,1.02,701,300,10,6001,0,65535,65535,1,23.1,28352,-298,-296,100,93,11,3603,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,954,SUCCESS,,3603.929927,192,0,0.1,0.2,0.3,263,1.4,1.5
    914,5/26/2021 20:13,3663.314,1.02,701,300,10,6001,0,65535,65535,1,23.1,28351,-296,-296,100,93,11,3602,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,945,SUCCESS,,3603.599805,192,0,0.1,0.2,0.3,263,1.4,1.5
    915,5/26/2021 20:13,3667.316,1.02,701,300,10,6001,0,65535,65535,1,23.1,28353,-298,-296,100,93,11,3602,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4043,4039,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,970,SUCCESS,,3603.268528,192,0,0.1,0.2,0.3,263,1.4,1.5
    916,5/26/2021 20:13,3671.33,1.02,701,300,10,6001,0,65535,65535,1,23.1,28353,-298,-297,100,93,11,3602,3888,730,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23.1,976,SUCCESS,,3602.936258,192,0,0.1,0.2,0.3,263,1.4,1.5
    917,5/26/2021 20:14,3675.336,1.02,701,300,10,6001,0,65535,65535,1,23.1,28350,-296,-297,100,93,11,3601,3888,725,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,955,SUCCESS,,3602.606876,192,0,0.1,0.2,0.3,263,1.4,1.5
    918,5/26/2021 20:14,3679.35,1.02,701,300,10,6001,0,65535,65535,1,23.1,28350,-298,-297,100,93,11,3601,3888,730,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,984,SUCCESS,,3602.274606,192,0,0.1,0.2,0.3,263,1.4,1.5
    919,5/26/2021 20:14,3683.351,1.02,701,300,10,6001,0,65535,65535,1,23.1,28351,-296,-296,100,93,11,3601,3888,735,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,958,SUCCESS,,3601.945635,192,0,0.1,0.2,0.3,263,1.4,1.5
    920,5/26/2021 20:14,3687.364,1.02,701,300,10,6001,0,65535,65535,1,23.1,28351,-296,-296,100,93,11,3600,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4060,4056,4041,4044,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.4,1002,SUCCESS,,3601.615677,192,0,0.1,0.2,0.3,263,1.4,1.5
    921,5/26/2021 20:14,3691.367,1.03,701,300,10,6001,0,65535,65535,1,23.1,28350,-298,-297,100,93,11,3600,3888,725,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4054,4058,4059,4056,4041,4044,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,934,SUCCESS,,3601.284318,192,0,0.1,0.2,0.3,263,1.4,1.5
    922,5/26/2021 20:14,3695.378,1.03,701,300,10,6001,0,65535,65535,1,23.1,28349,-296,-296,100,93,11,3600,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4041,4043,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,985,SUCCESS,,3600.954524,192,0,0.1,0.2,0.3,263,1.4,1.5
    923,5/26/2021 20:14,3699.381,1.03,701,300,10,6001,0,65535,65535,1,23.1,28348,-296,-296,100,93,11,3599,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4041,4043,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,990,SUCCESS,,3600.625389,192,0,0.1,0.2,0.3,263,1.4,1.5
    924,5/26/2021 20:14,3703.385,1.03,701,300,10,6001,0,65535,65535,1,23.1,28347,-296,-296,100,93,11,3599,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4041,4043,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,947,SUCCESS,,3600.296171,192,0,0.1,0.2,0.3,263,1.4,1.5
    925,5/26/2021 20:14,3707.386,1.03,701,300,10,6001,0,65535,65535,1,23.1,28346,-296,-296,100,93,11,3599,3888,730,730,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4041,4043,4038,0,0,0,0,0,0,0,0,2831,22.9,23.1,-273.2,23.1,-273.2,23,1015,SUCCESS,,3599.9672,192,0,0.1,0.2,0.3,263,1.4,1.5
    926,5/26/2021 20:14,3711.393,1.03,701,300,10,6001,0,65535,65535,1,23.1,28347,-298,-296,100,93,11,3598,3888,724,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4041,4043,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,23,1001,SUCCESS,,3599.635509,192,0,0.1,0.2,0.3,263,1.4,1.5
    927,5/26/2021 20:14,3715.398,1.03,701,300,10,6001,0,65535,65535,1,23.1,28346,-296,-296,100,93,11,3598,3888,729,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4040,4043,4038,0,0,0,0,0,0,0,0,2834,22.9,23.1,-273.2,23.1,-273.2,22.9,970,SUCCESS,,3599.306209,192,0,0.1,0.2,0.3,263,1.4,1.5
    928,5/26/2021 20:14,3719.407,1.03,701,300,10,6001,0,65535,65535,1,23.1,28346,-298,-296,100,93,11,3598,3888,729,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4040,4043,4038,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,974,SUCCESS,,3598.974353,192,0,0.1,0.2,0.3,263,1.4,1.5
    929,5/26/2021 20:14,3723.416,1.03,701,300,10,6001,0,65535,65535,1,23.1,28347,-298,-296,100,93,11,3597,3888,724,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4040,4043,4038,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,946,SUCCESS,,3598.642497,192,0,0.1,0.2,0.3,263,1.4,1.5
    930,5/26/2021 20:14,3727.424,1.04,701,300,10,6001,0,65535,65535,1,23.1,28346,-296,-296,100,93,11,3597,3888,734,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4058,4059,4055,4040,4043,4038,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,986,SUCCESS,,3598.31295,192,0,0.1,0.2,0.3,263,1.4,1.5
    931,5/26/2021 20:14,3731.439,1.04,701,300,10,6001,0,65535,65535,1,23.1,28345,-296,-296,100,93,11,3597,3888,724,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4059,4055,4040,4043,4038,0,0,0,0,0,0,0,0,2831,22.9,23.1,-273.2,23.1,-273.2,23,962,SUCCESS,,3597.982828,192,0,0.1,0.2,0.3,263,1.4,1.5
    932,5/26/2021 20:15,3735.445,1.04,701,300,10,6001,0,65535,65535,1,23.1,28346,-298,-297,100,93,11,3596,3888,724,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4059,4055,4040,4043,4038,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,950,SUCCESS,,3597.65122,192,0,0.1,0.2,0.3,263,1.4,1.5
    933,5/26/2021 20:15,3739.448,1.04,701,300,10,6001,0,65535,65535,1,23.1,28342,-296,-296,100,93,11,3596,3888,734,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4057,4058,4055,4040,4043,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,964,SUCCESS,,3597.322085,192,0,0.1,0.2,0.3,263,1.4,1.5
    934,5/26/2021 20:15,3743.459,1.04,701,300,10,6001,0,65535,65535,1,23.1,28342,-296,-297,100,93,11,3596,3888,724,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4053,4057,4058,4055,4040,4043,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.7,1027,SUCCESS,,3596.992291,192,0,0.1,0.2,0.3,263,1.4,1.5
    935,5/26/2021 20:15,3747.462,1.04,701,300,10,6001,0,65535,65535,1,23.1,28347,-296,-297,100,93,11,3595,3888,724,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4055,4040,4043,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23.1,951,SUCCESS,,3596.663156,192,0,0.1,0.2,0.3,263,1.4,1.5
    936,5/26/2021 20:15,3751.465,1.04,701,300,10,6001,0,65535,65535,1,23.1,28342,-300,-297,100,93,11,3595,3888,729,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4055,4040,4043,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,961,SUCCESS,,3596.329573,192,0,0.1,0.2,0.3,263,1.4,1.5
    937,5/26/2021 20:15,3755.479,1.04,701,300,10,6001,0,65535,65535,1,23.1,28341,-296,-297,100,93,11,3595,3888,729,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4055,4040,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,963,SUCCESS,,3595.999533,192,0,0.1,0.2,0.3,263,1.4,1.5
    938,5/26/2021 20:15,3759.484,1.04,701,300,10,6001,0,65535,65535,1,23.1,28341,-296,-296,100,93,11,3594,3888,729,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4040,4043,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,965,SUCCESS,,3595.670233,192,0,0.1,0.2,0.3,263,1.4,1.5
    939,5/26/2021 20:15,3763.493,1.05,701,300,10,6001,0,65535,65535,1,23.1,28340,-298,-296,100,93,11,3594,3888,724,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4055,4040,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,987,SUCCESS,,3595.338376,192,0,0.1,0.2,0.3,263,1.4,1.5
    940,5/26/2021 20:15,3767.496,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-296,-296,100,93,11,3594,3888,729,729,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4040,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,1003,SUCCESS,,3595.009241,192,0,0.1,0.2,0.3,263,1.4,1.5
    941,5/26/2021 20:15,3771.497,1.05,701,300,10,6001,0,65535,65535,1,23.1,28340,-296,-296,100,93,11,3593,3888,728,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4040,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,960,SUCCESS,,3594.68027,192,0,0.1,0.2,0.3,263,1.4,1.5
    942,5/26/2021 20:15,3775.507,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-300,-297,100,93,11,3593,3888,719,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4040,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,972,SUCCESS,,3594.346103,192,0,0.1,0.2,0.3,263,1.4,1.5
    943,5/26/2021 20:15,3779.522,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-296,-297,100,93,11,3593,3888,728,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4041,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,937,SUCCESS,,3594.015981,192,0,0.1,0.2,0.3,263,1.4,1.5
    944,5/26/2021 20:15,3783.527,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-296,-296,100,93,11,3592,3888,728,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23.1,946,SUCCESS,,3593.686681,192,0,0.1,0.2,0.3,263,1.4,1.5
    945,5/26/2021 20:15,3787.539,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-296,-296,100,93,11,3592,3888,728,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,943,SUCCESS,,3593.356805,192,0,0.1,0.2,0.3,263,1.4,1.5
    946,5/26/2021 20:15,3791.542,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-294,-297,100,93,11,3592,3888,728,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,979,SUCCESS,,3593.029894,192,0,0.1,0.2,0.3,263,1.4,1.5
    947,5/26/2021 20:16,3795.557,1.05,701,300,10,6001,0,65535,65535,1,23.1,28339,-298,-297,100,93,11,3591,3888,723,725,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4041,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,970,SUCCESS,,3592.697541,192,0,0.1,0.2,0.3,263,1.4,1.5
    948,5/26/2021 20:16,3799.557,1.06,701,300,10,6001,0,65535,65535,1,23.1,28339,-296,-297,100,93,11,3591,3888,723,725,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.3,947,SUCCESS,,3592.368652,192,0,0.1,0.2,0.3,263,1.4,1.5
    949,5/26/2021 20:16,3803.56,1.06,701,300,10,6001,0,65535,65535,1,23.1,28339,-296,-297,100,93,11,3591,3888,733,725,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4042,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,943,SUCCESS,,3592.039516,192,0,0.1,0.2,0.3,263,1.4,1.5
    950,5/26/2021 20:16,3807.569,1.06,701,300,10,6001,0,65535,65535,1,23.1,28336,-296,-297,100,93,11,3590,3888,728,725,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4056,4058,4054,4039,4041,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,952,SUCCESS,,3591.709888,192,0,0.1,0.2,0.3,263,1.4,1.5
    951,5/26/2021 20:16,3811.57,1.06,701,300,10,6001,0,65535,65535,1,23.1,28337,-296,-297,100,93,11,3590,3888,728,725,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4041,4037,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,949,SUCCESS,,3591.380916,192,0,0.1,0.2,0.3,263,1.4,1.5
    952,5/26/2021 20:16,3815.577,1.06,701,300,10,6001,0,65535,65535,1,23.1,28337,-296,-296,100,93,11,3590,3888,728,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4052,4057,4058,4054,4039,4043,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,949,SUCCESS,,3591.051452,192,0,0.1,0.2,0.3,263,1.4,1.5
    953,5/26/2021 20:16,3819.581,1.06,701,300,10,6001,0,65535,65535,1,23.1,28334,-294,-296,100,93,11,3589,3888,728,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4058,4054,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,938,SUCCESS,,3590.724459,192,0,0.1,0.2,0.3,263,1.4,1.5
    954,5/26/2021 20:16,3823.584,1.06,701,300,10,6001,0,65535,65535,1,23.1,28335,-296,-296,100,93,11,3589,3888,723,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4054,4039,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,958,SUCCESS,,3590.395323,192,0,0.1,0.2,0.3,263,1.4,1.5
    955,5/26/2021 20:16,3827.584,1.06,701,300,10,6001,0,65535,65535,1,23.1,28333,-296,-296,100,93,11,3589,3888,732,728,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4054,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,970,SUCCESS,,3590.066434,192,0,0.1,0.2,0.3,263,1.4,1.5
    956,5/26/2021 20:16,3831.586,1.06,701,300,10,6001,0,65535,65535,1,23.1,28332,-296,-296,100,93,11,3588,3888,722,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4053,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,958,SUCCESS,,3589.737381,192,0,0.1,0.2,0.3,263,1.4,1.5
    957,5/26/2021 20:16,3835.589,1.07,701,300,10,6001,0,65535,65535,1,23.1,28332,-296,-296,100,93,11,3588,3888,732,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4053,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,962,SUCCESS,,3589.408245,192,0,0.1,0.2,0.3,263,1.4,1.5
    958,5/26/2021 20:16,3839.596,1.07,701,300,10,6001,0,65535,65535,1,23.1,28332,-298,-296,100,93,11,3588,3888,727,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4055,4057,4053,4038,4043,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,984,SUCCESS,,3589.076555,192,0,0.1,0.2,0.3,263,1.4,1.5
    959,5/26/2021 20:16,3843.605,1.07,701,300,10,6001,0,65535,65535,1,23.1,28331,-296,-296,100,93,11,3587,3888,732,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4053,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,967,SUCCESS,,3588.746926,192,0,0.1,0.2,0.3,263,1.4,1.5
    960,5/26/2021 20:16,3847.619,1.07,701,300,10,6001,0,65535,65535,1,23.1,28332,-296,-296,100,93,11,3587,3888,727,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4053,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,962,SUCCESS,,3588.416886,192,0,0.1,0.2,0.3,263,1.4,1.5
    961,5/26/2021 20:16,3851.632,1.07,701,300,10,6001,0,65535,65535,1,23.1,28332,-300,-296,100,93,11,3587,3888,722,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4056,4057,4053,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,972,SUCCESS,,3588.082469,192,0,0.1,0.2,0.3,263,1.4,1.5
    962,5/26/2021 20:17,3855.646,1.07,701,300,10,6001,0,65535,65535,1,23.1,28330,-296,-296,100,93,11,3586,3888,732,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4055,4057,4053,4038,4041,4036,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,942,SUCCESS,,3587.752429,192,0,0.1,0.2,0.3,263,1.4,1.5
    963,5/26/2021 20:17,3859.65,1.07,701,300,10,6001,0,65535,65535,1,23.1,28329,-298,-296,100,93,11,3586,3888,727,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4055,4057,4053,4038,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,936,SUCCESS,,3587.420987,192,0,0.1,0.2,0.3,263,1.4,1.5
    964,5/26/2021 20:17,3863.654,1.07,701,300,10,6001,0,65535,65535,1,23.1,28330,-296,-296,100,93,11,3586,3888,722,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4055,4057,4053,4038,4045,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3587.091769,192,0,0.1,0.2,0.3,263,1.4,1.5
    965,5/26/2021 20:17,3867.669,1.07,701,300,10,6001,0,65535,65535,1,23.1,28330,-298,-296,100,93,11,3585,3888,727,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4057,4052,4038,4041,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,952,SUCCESS,,3586.759416,192,0,0.1,0.2,0.3,263,1.4,1.5
    966,5/26/2021 20:17,3871.671,1.08,701,300,10,6001,0,65535,65535,1,23.1,28328,-298,-296,100,93,11,3585,3888,727,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4051,4055,4057,4052,4038,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,948,SUCCESS,,3586.42814,192,0,0.1,0.2,0.3,263,1.4,1.5
    967,5/26/2021 20:17,3875.683,1.08,701,300,10,6001,0,65535,65535,1,23.1,28328,-294,-296,100,93,11,3585,3888,727,727,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4057,4052,4038,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,951,SUCCESS,,3586.100493,192,0,0.1,0.2,0.3,263,1.4,1.5
    968,5/26/2021 20:17,3879.696,1.08,701,300,10,6001,0,65535,65535,1,23.1,28328,-296,-296,100,93,11,3584,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4057,4052,4038,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,954,SUCCESS,,3585.770535,192,0,0.1,0.2,0.3,263,1.4,1.5
    969,5/26/2021 20:17,3883.709,1.08,701,300,10,6001,0,65535,65535,1,23.1,28327,-296,-296,100,93,11,3584,3888,722,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4038,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,968,SUCCESS,,3585.440578,192,0,0.1,0.2,0.3,263,1.4,1.5
    970,5/26/2021 20:17,3887.715,1.08,701,300,10,6001,0,65535,65535,1,23.1,28325,-296,-296,100,93,11,3584,3888,731,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,965,SUCCESS,,3585.111195,192,0,0.1,0.2,0.3,263,1.4,1.5
    971,5/26/2021 20:17,3891.727,1.08,701,300,10,6001,0,65535,65535,1,23.1,28325,-294,-296,100,93,11,3584,3888,731,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.5,961,SUCCESS,,3584.783549,192,0,0.1,0.2,0.3,263,1.4,1.5
    972,5/26/2021 20:17,3895.729,1.08,701,300,10,6001,0,65535,65535,1,23.1,28325,-296,-296,100,93,11,3583,3888,731,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,951,SUCCESS,,3584.454495,192,0,0.1,0.2,0.3,263,1.4,1.5
    973,5/26/2021 20:17,3899.73,1.08,701,300,10,6001,0,65535,65535,1,23.1,28325,-294,-296,100,93,11,3583,3888,731,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4038,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3584.127747,192,0,0.1,0.2,0.3,263,1.4,1.5
    974,5/26/2021 20:17,3903.74,1.08,701,300,10,6001,0,65535,65535,1,23.1,28325,-296,-296,100,93,11,3582,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,938,SUCCESS,,3583.798036,192,0,0.1,0.2,0.3,263,1.4,1.5
    975,5/26/2021 20:17,3907.754,1.09,701,300,10,6001,0,65535,65535,1,23.1,28325,-296,-296,100,93,11,3582,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4050,4055,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,960,SUCCESS,,3583.467996,192,0,0.1,0.2,0.3,263,1.4,1.5
    976,5/26/2021 20:17,3911.782,1.09,701,300,10,6001,0,65535,65535,1,23.1,28325,-296,-296,100,93,11,3582,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4055,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,978,SUCCESS,,3583.136805,192,0,0.1,0.2,0.3,263,1.4,1.5
    977,5/26/2021 20:18,3915.797,1.09,701,300,10,6001,0,65535,65535,1,23.1,28323,-298,-296,100,93,11,3581,3888,721,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4055,4055,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,961,SUCCESS,,3582.804452,192,0,0.1,0.2,0.3,263,1.4,1.5
    978,5/26/2021 20:18,3919.797,1.09,701,300,10,6001,0,65535,65535,1,23.1,28322,-296,-296,100,93,11,3581,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4056,4052,4037,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,972,SUCCESS,,3582.475563,192,0,0.1,0.2,0.3,263,1.4,1.5
    979,5/26/2021 20:18,3923.814,1.09,701,300,10,6001,0,65535,65535,1,23.1,28323,-298,-296,100,93,11,3581,3888,721,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4056,4052,4037,4040,4035,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,985,SUCCESS,,3582.143045,192,0,0.1,0.2,0.3,263,1.4,1.5
    980,5/26/2021 20:18,3927.827,1.09,701,300,10,6001,0,65535,65535,1,23.1,28321,-298,-297,100,93,11,3580,3888,721,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4052,4037,4040,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,964,SUCCESS,,3581.810858,192,0,0.1,0.2,0.3,263,1.4,1.5
    981,5/26/2021 20:18,3931.845,1.09,701,300,10,6001,0,65535,65535,1,23.1,28319,-296,-296,100,93,11,3580,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4052,4037,4040,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,962,SUCCESS,,3581.480489,192,0,0.1,0.2,0.3,263,1.4,1.5
    982,5/26/2021 20:18,3935.861,1.09,701,300,10,6001,0,65535,65535,1,23.1,28319,-298,-296,100,93,11,3580,3888,726,726,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4037,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,939,SUCCESS,,3581.148053,192,0,0.1,0.2,0.3,263,1.4,1.5
    983,5/26/2021 20:18,3939.882,1.09,701,300,10,6001,0,65535,65535,1,23.1,28319,-296,-297,100,93,11,3579,3888,725,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4037,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,934,SUCCESS,,3580.817438,192,0,0.1,0.2,0.3,263,1.4,1.5
    984,5/26/2021 20:18,3943.892,1.1,701,300,10,6001,0,65535,65535,1,23.1,28319,-296,-297,100,93,11,3579,3888,725,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4037,4040,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,974,SUCCESS,,3580.487726,192,0,0.1,0.2,0.3,263,1.4,1.5
    985,5/26/2021 20:18,3947.891,1.1,701,300,10,6001,0,65535,65535,1,23.1,28319,-296,-297,100,93,11,3579,3888,721,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4036,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.6,948,SUCCESS,,3580.15892,192,0,0.1,0.2,0.3,263,1.4,1.5
    986,5/26/2021 20:18,3951.916,1.1,701,300,10,6001,0,65535,65535,1,23.1,28318,-298,-297,100,93,11,3578,3888,725,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4037,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,951,SUCCESS,,3579.825739,192,0,0.1,0.2,0.3,263,1.4,1.5
    987,5/26/2021 20:18,3955.923,1.1,701,300,10,6001,0,65535,65535,1,23.1,28318,-298,-297,100,93,11,3578,3888,725,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4036,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,967,SUCCESS,,3579.494049,192,0,0.1,0.2,0.3,263,1.4,1.5
    988,5/26/2021 20:18,3959.922,1.1,701,300,10,6001,0,65535,65535,1,23.1,28317,-298,-297,100,93,11,3578,3888,720,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4036,4038,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,939,SUCCESS,,3579.16302,192,0,0.1,0.2,0.3,263,1.4,1.5
    989,5/26/2021 20:18,3963.952,1.1,701,300,10,6001,0,65535,65535,1,23.1,28317,-296,-297,100,93,11,3577,3888,725,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4036,4038,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,940,SUCCESS,,3578.831665,192,0,0.1,0.2,0.3,263,1.4,1.5
    990,5/26/2021 20:18,3967.938,1.1,701,300,10,6001,0,65535,65535,1,23.1,28318,-298,-297,100,93,11,3577,3888,720,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4036,4039,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,977,SUCCESS,,3578.501713,192,0,0.1,0.2,0.3,263,1.4,1.5
    991,5/26/2021 20:18,3971.859,1.1,701,300,10,6001,0,65535,65535,1,23.1,28317,-298,-297,100,93,11,3577,3888,720,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4049,4054,4055,4051,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,958,SUCCESS,,3578.177141,192,0,0.1,0.2,0.3,263,1.4,1.5
    992,5/26/2021 20:19,3975.861,1.1,701,300,10,6001,0,65535,65535,1,23.1,28317,-298,-297,100,93,11,3577,3888,725,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4054,4055,4051,4036,4038,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,953,SUCCESS,,3577.845864,192,0,0.1,0.2,0.3,263,1.4,1.5
    993,5/26/2021 20:19,3979.877,1.11,701,300,10,6001,0,65535,65535,1,23.1,28315,-296,-297,100,92,11,3576,3888,720,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4054,4055,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,963,SUCCESS,,3577.51566,192,0,0.1,0.2,0.3,263,1.4,1.5
    994,5/26/2021 20:19,3983.891,1.11,701,300,10,6001,0,65535,65535,1,23.1,28314,-296,-297,100,92,11,3576,3888,725,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4055,4051,4036,4038,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,939,SUCCESS,,3577.18562,192,0,0.1,0.2,0.3,263,1.4,1.5
    995,5/26/2021 20:19,3987.901,1.11,701,300,10,6001,0,65535,65535,1,23.1,28313,-296,-297,100,92,11,3576,3888,725,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4051,4035,4038,4034,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.6,944,SUCCESS,,3576.855909,192,0,0.1,0.2,0.3,263,1.4,1.5
    996,5/26/2021 20:19,3991.91,1.11,701,300,10,6001,0,65535,65535,1,23.1,28313,-298,-297,100,92,11,3575,3888,720,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,952,SUCCESS,,3576.524053,192,0,0.1,0.2,0.3,263,1.4,1.5
    997,5/26/2021 20:19,3995.919,1.11,701,300,10,6001,0,65535,65535,1,23.1,28310,-294,-297,100,92,11,3575,3888,725,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,944,SUCCESS,,3576.196651,192,0,0.1,0.2,0.3,263,1.4,1.5
    998,5/26/2021 20:19,3999.925,1.11,701,300,10,6001,0,65535,65535,1,23.1,28311,-298,-297,100,92,11,3575,3888,720,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,959,SUCCESS,,3575.865043,192,0,0.1,0.2,0.3,263,1.4,1.5
    999,5/26/2021 20:19,4003.94,1.11,701,300,10,6001,0,65535,65535,1,23.1,28311,-298,-297,100,92,11,3574,3888,720,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,951,SUCCESS,,3575.53269,192,0,0.1,0.2,0.3,263,1.4,1.5
    1000,5/26/2021 20:19,4007.94,1.11,701,300,10,6001,0,65535,65535,1,23.1,28310,-296,-297,100,92,11,3574,3888,724,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,938,SUCCESS,,3575.203801,192,0,0.1,0.2,0.3,263,1.4,1.5
    1001,5/26/2021 20:19,4011.955,1.11,701,300,10,6001,0,65535,65535,1,23.1,28310,-298,-297,100,92,11,3574,3888,720,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,943,SUCCESS,,3574.871449,192,0,0.1,0.2,0.3,263,1.4,1.5
    1002,5/26/2021 20:19,4015.965,1.12,701,300,10,6001,0,65535,65535,1,23.1,28311,-296,-297,100,92,11,3573,3888,724,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,952,SUCCESS,,3574.541738,192,0,0.1,0.2,0.3,263,1.4,1.5
    1003,5/26/2021 20:19,4019.978,1.12,701,300,10,6001,0,65535,65535,1,23.1,28311,-294,-297,100,92,11,3573,3888,724,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4053,4054,4050,4035,4038,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,980,SUCCESS,,3574.214009,192,0,0.1,0.2,0.3,263,1.4,1.5
    1004,5/26/2021 20:19,4023.984,1.12,701,300,10,6001,0,65535,65535,1,23.1,28308,-296,-297,100,92,11,3573,3888,724,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4052,4054,4049,4035,4037,4033,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,958,SUCCESS,,3573.884627,192,0,0.1,0.2,0.3,263,1.4,1.5
    1005,5/26/2021 20:19,4027.989,1.12,701,300,10,6001,0,65535,65535,1,23.1,28306,-296,-297,100,92,11,3572,3888,724,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4054,4049,4035,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,957,SUCCESS,,3573.555327,192,0,0.1,0.2,0.3,263,1.4,1.5
    1006,5/26/2021 20:19,4031.994,1.12,701,300,10,6001,0,65535,65535,1,23.1,28308,-298,-297,100,92,11,3572,3888,724,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4054,4049,4035,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,961,SUCCESS,,3573.223802,192,0,0.1,0.2,0.3,263,1.4,1.5
    1007,5/26/2021 20:20,4036.003,1.12,701,300,10,6001,0,65535,65535,1,23.1,28309,-296,-297,100,92,11,3572,3888,719,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4054,4049,4035,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,1007,SUCCESS,,3572.894173,192,0,0.1,0.2,0.3,263,1.4,1.5
    1008,5/26/2021 20:20,4040.004,1.12,701,300,10,6001,0,65535,65535,1,23.1,28308,-296,-297,100,92,11,3571,3888,724,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4048,4052,4054,4049,4035,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.5,949,SUCCESS,,3572.565202,192,0,0.1,0.2,0.3,263,1.4,1.5
    1009,5/26/2021 20:20,4044.004,1.12,701,300,10,6001,0,65535,65535,1,23.1,28305,-296,-297,100,92,11,3571,3888,724,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4054,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,972,SUCCESS,,3572.236313,192,0,0.1,0.2,0.3,263,1.4,1.5
    1010,5/26/2021 20:20,4048.016,1.12,701,300,10,6001,0,65535,65535,1,23.1,28306,-298,-297,100,92,11,3571,3888,719,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4054,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2826,22.9,23.1,-273.2,23.1,-273.2,23,940,SUCCESS,,3571.904209,192,0,0.1,0.2,0.3,263,1.4,1.5
    1011,5/26/2021 20:20,4052.019,1.13,701,300,10,6001,0,65535,65535,1,23.1,28308,-298,-297,100,92,11,3570,3888,719,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4053,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,23,936,SUCCESS,,3571.572849,192,0,0.1,0.2,0.3,263,1.4,1.5
    1012,5/26/2021 20:20,4056.023,1.13,701,300,10,6001,0,65535,65535,1,23.1,28304,-298,-297,100,92,11,3570,3888,719,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4053,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2829,22.9,23.1,-273.2,23.1,-273.2,22.9,948,SUCCESS,,3571.241407,192,0,0.1,0.2,0.3,263,1.4,1.5
    1013,5/26/2021 20:20,4060.038,1.13,701,300,10,6001,0,65535,65535,1,23.1,28303,-298,-297,100,92,11,3570,3888,719,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4047,4052,4053,4049,4034,4036,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,948,SUCCESS,,3570.909054,192,0,0.1,0.2,0.3,263,1.4,1.5
    1014,5/26/2021 20:20,4064.053,1.13,701,300,10,6001,0,65535,65535,1,23.1,28307,-298,-297,100,92,11,3569,3888,719,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4052,4053,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2830,22.9,23.1,-273.2,23.1,-273.2,22.9,966,SUCCESS,,3570.576701,192,0,0.1,0.2,0.3,263,1.4,1.5
    1015,5/26/2021 20:20,4068.055,1.13,701,300,10,6001,0,65535,65535,1,23.1,28303,-296,-297,100,92,11,3569,3888,723,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4053,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,952,SUCCESS,,3570.247648,192,0,0.1,0.2,0.3,263,1.4,1.5
    1016,5/26/2021 20:20,4072.063,1.13,701,300,10,6001,0,65535,65535,1,23.1,28302,-294,-297,100,92,11,3569,3888,728,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4052,4053,4049,4034,4036,4032,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,951,SUCCESS,,3569.920328,192,0,0.1,0.2,0.3,263,1.4,1.5
    1017,5/26/2021 20:20,4076.066,1.13,701,300,10,6001,0,65535,65535,1,23.1,28303,-298,-297,100,92,11,3568,3888,718,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4052,4053,4049,4034,4037,4032,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,956,SUCCESS,,3569.588969,192,0,0.1,0.2,0.3,263,1.4,1.5
    1018,5/26/2021 20:20,4080.073,1.13,701,300,10,6001,0,65535,65535,1,23.1,28304,-296,-297,100,92,11,3568,3888,723,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4052,4053,4049,4034,4036,4032,0,0,0,0,0,0,0,0,2829,22.9,23.1,-273.2,23.1,-273.2,23,984,SUCCESS,,3569.259504,192,0,0.1,0.2,0.3,263,1.4,1.5
    1019,5/26/2021 20:20,4084.088,1.13,701,300,10,6001,0,65535,65535,1,23.1,28302,-296,-297,100,92,11,3568,3888,723,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4053,4049,4034,4036,4032,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,961,SUCCESS,,3568.929382,192,0,0.1,0.2,0.3,263,1.4,1.5
    1020,5/26/2021 20:20,4088.095,1.14,701,300,10,6001,0,65535,65535,1,23.1,28299,-296,-297,100,92,11,3567,3888,723,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4034,4036,4032,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,992,SUCCESS,,3568.599918,192,0,0.1,0.2,0.3,263,1.4,1.5
    1021,5/26/2021 20:20,4092.106,1.14,701,300,10,6001,0,65535,65535,1,23.1,28299,-298,-297,100,92,11,3567,3888,723,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4034,4036,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,950,SUCCESS,,3568.267896,192,0,0.1,0.2,0.3,263,1.4,1.5
    1022,5/26/2021 20:21,4096.114,1.14,701,300,10,6001,0,65535,65535,1,23.1,28297,-296,-297,100,92,11,3567,3888,723,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4034,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.8,959,SUCCESS,,3567.938349,192,0,0.1,0.2,0.3,263,1.4,1.5
    1023,5/26/2021 20:21,4100.13,1.14,701,300,10,6001,0,65535,65535,1,23.1,28297,-300,-297,100,92,11,3566,3888,718,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4033,4036,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,958,SUCCESS,,3567.603683,192,0,0.1,0.2,0.3,263,1.4,1.5
    1024,5/26/2021 20:21,4104.141,1.14,701,300,10,6001,0,65535,65535,1,23.1,28297,-296,-297,100,92,11,3566,3888,723,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4033,4036,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,973,SUCCESS,,3567.273889,192,0,0.1,0.2,0.3,263,1.4,1.5
    1025,5/26/2021 20:21,4108.144,1.14,701,300,10,6001,0,65535,65535,1,23.1,28296,-298,-297,100,92,11,3566,3888,718,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4033,4033,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,935,SUCCESS,,3566.94253,192,0,0.1,0.2,0.3,263,1.4,1.5
    1026,5/26/2021 20:21,4112.147,1.14,701,300,10,6001,0,65535,65535,1,23.1,28296,-296,-297,100,92,11,3565,3888,718,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4046,4051,4052,4048,4033,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,979,SUCCESS,,3566.613394,192,0,0.1,0.2,0.3,263,1.4,1.5
    1027,5/26/2021 20:21,4116.157,1.14,701,300,10,6001,0,65535,65535,1,23.1,28296,-296,-296,100,92,11,3565,3888,728,723,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4051,4052,4048,4033,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,945,SUCCESS,,3566.283683,192,0,0.1,0.2,0.3,263,1.4,1.5
    1028,5/26/2021 20:21,4120.165,1.14,701,300,10,6001,0,65535,65535,1,23.1,28296,-298,-297,100,92,11,3565,3888,718,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4051,4052,4048,4033,4032,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,970,SUCCESS,,3565.95191,192,0,0.1,0.2,0.3,263,1.4,1.5
    1029,5/26/2021 20:21,4124.173,1.15,701,300,10,6001,0,65535,65535,1,23.1,28295,-296,-297,100,92,11,3564,3888,722,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4051,4052,4048,4033,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,941,SUCCESS,,3565.622363,192,0,0.1,0.2,0.3,263,1.4,1.5
    1030,5/26/2021 20:21,4128.175,1.15,701,300,10,6001,0,65535,65535,1,23.1,28295,-298,-297,100,92,11,3564,3888,722,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4051,4052,4048,4033,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,998,SUCCESS,,3565.291086,192,0,0.1,0.2,0.3,263,1.4,1.5
    1031,5/26/2021 20:21,4132.184,1.15,701,300,10,6001,0,65535,65535,1,23.1,28294,-298,-297,100,92,11,3564,3888,718,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4051,4052,4047,4033,4032,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,948,SUCCESS,,3564.95923,192,0,0.1,0.2,0.3,263,1.4,1.5
    1032,5/26/2021 20:21,4136.192,1.15,701,300,10,6001,0,65535,65535,1,23.1,28295,-296,-297,100,92,11,3563,3888,727,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4051,4052,4048,4033,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,950,SUCCESS,,3564.629684,192,0,0.1,0.2,0.3,263,1.4,1.5
    1033,5/26/2021 20:21,4140.192,1.15,701,300,10,6001,0,65535,65535,1,23.1,28294,-298,-297,100,92,11,3563,3888,722,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4052,4047,4033,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,987,SUCCESS,,3564.298573,192,0,0.1,0.2,0.3,263,1.4,1.5
    1034,5/26/2021 20:21,4144.197,1.15,701,300,10,6001,0,65535,65535,1,23.1,28290,-296,-297,100,92,11,3563,3888,717,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4034,4034,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,946,SUCCESS,,3563.969273,192,0,0.1,0.2,0.3,263,1.4,1.5
    1035,5/26/2021 20:21,4148.209,1.15,701,300,10,6001,0,65535,65535,1,23.1,28290,-296,-296,100,92,11,3562,3888,727,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,949,SUCCESS,,3563.639397,192,0,0.1,0.2,0.3,263,1.4,1.5
    1036,5/26/2021 20:21,4152.212,1.15,701,300,10,6001,0,65535,65535,1,23.1,28290,-296,-296,100,92,11,3562,3888,717,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4035,4031,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,937,SUCCESS,,3563.310261,192,0,0.1,0.2,0.3,263,1.4,1.5
    1037,5/26/2021 20:22,4156.22,1.15,701,300,10,6001,0,65535,65535,1,23.1,28290,-298,-297,100,92,11,3562,3888,717,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4035,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,940,SUCCESS,,3562.978488,192,0,0.1,0.2,0.3,263,1.4,1.5
    1038,5/26/2021 20:22,4160.236,1.16,701,300,10,6001,0,65535,65535,1,23.1,28290,-294,-296,100,92,11,3561,3888,722,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4034,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,953,SUCCESS,,3562.650515,192,0,0.1,0.2,0.3,263,1.4,1.5
    1039,5/26/2021 20:22,4164.237,1.16,701,300,10,6001,0,65535,65535,1,23.1,28289,-302,-297,100,92,11,3561,3888,712,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4034,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,955,SUCCESS,,3562.314875,192,0,0.1,0.2,0.3,263,1.4,1.5
    1040,5/26/2021 20:22,4168.24,1.16,701,300,10,6001,0,65535,65535,1,23.1,28290,-296,-296,100,92,11,3561,3888,722,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4034,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,937,SUCCESS,,3561.98574,192,0,0.1,0.2,0.3,263,1.4,1.5
    1041,5/26/2021 20:22,4172.254,1.16,701,300,10,6001,0,65535,65535,1,23.1,28289,-296,-296,100,92,11,3560,3888,727,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4045,4050,4051,4047,4032,4034,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,967,SUCCESS,,3561.6557,192,0,0.1,0.2,0.3,263,1.4,1.5
    1042,5/26/2021 20:22,4176.267,1.16,701,300,10,6001,0,65535,65535,1,23.1,28286,-298,-296,100,92,11,3560,3888,717,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4051,4046,4032,4034,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,992,SUCCESS,,3561.323513,192,0,0.1,0.2,0.3,263,1.4,1.5
    1043,5/26/2021 20:22,4180.276,1.16,701,300,10,6001,0,65535,65535,1,23.1,28286,-296,-296,100,92,11,3560,3888,727,722,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4051,4046,4032,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,945,SUCCESS,,3560.993884,192,0,0.1,0.2,0.3,263,1.4,1.5
    1044,5/26/2021 20:22,4184.279,1.16,701,300,10,6001,0,65535,65535,1,23.1,28286,-298,-297,100,92,11,3559,3888,712,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4050,4051,4046,4032,4034,4030,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,949,SUCCESS,,3560.662524,192,0,0.1,0.2,0.3,263,1.4,1.5
    1045,5/26/2021 20:22,4188.294,1.16,701,300,10,6001,0,65535,65535,1,23.1,28285,-296,-297,100,92,11,3559,3888,717,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4051,4046,4032,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,967,SUCCESS,,3560.332402,192,0,0.1,0.2,0.3,263,1.4,1.5
    1046,5/26/2021 20:22,4192.303,1.16,701,300,10,6001,0,65535,65535,1,23.1,28285,-296,-297,100,92,11,3559,3888,717,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4050,4046,4032,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,980,SUCCESS,,3560.002773,192,0,0.1,0.2,0.3,263,1.4,1.5
    1047,5/26/2021 20:22,4196.304,1.17,701,300,10,6001,0,65535,65535,1,23.1,28285,-298,-297,100,92,11,3558,3888,721,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4051,4046,4031,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,971,SUCCESS,,3559.671579,192,0,0.1,0.2,0.3,263,1.4,1.5
    1048,5/26/2021 20:22,4200.311,1.17,701,300,10,6001,0,65535,65535,1,23.1,28284,-298,-297,100,92,11,3558,3888,716,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4050,4046,4031,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,968,SUCCESS,,3559.339889,192,0,0.1,0.2,0.3,263,1.4,1.5
    1049,5/26/2021 20:22,4204.318,1.17,701,300,10,6001,0,65535,65535,1,23.1,28283,-296,-297,100,92,11,3558,3888,721,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4050,4046,4032,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,933,SUCCESS,,3559.010424,192,0,0.1,0.2,0.3,263,1.4,1.5
    1050,5/26/2021 20:22,4208.325,1.17,701,300,10,6001,0,65535,65535,1,23.1,28283,-298,-297,100,92,11,3557,3888,716,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4044,4049,4050,4046,4031,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,949,SUCCESS,,3558.678734,192,0,0.1,0.2,0.3,263,1.4,1.5
    1051,5/26/2021 20:22,4212.334,1.17,701,300,10,6001,0,65535,65535,1,23.1,28283,-294,-297,100,92,11,3557,3888,726,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4049,4050,4046,4031,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,965,SUCCESS,,3558.351332,192,0,0.1,0.2,0.3,263,1.4,1.5
    1052,5/26/2021 20:23,4216.346,1.17,701,300,10,6001,0,65535,65535,1,23.1,28282,-298,-297,100,92,11,3557,3888,716,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4049,4050,4046,4031,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,952,SUCCESS,,3558.019228,192,0,0.1,0.2,0.3,263,1.4,1.5
    1053,5/26/2021 20:23,4220.355,1.17,701,300,10,6001,0,65535,65535,1,23.1,28281,-296,-297,100,92,11,3556,3888,721,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4049,4050,4046,4031,4034,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,947,SUCCESS,,3557.689599,192,0,0.1,0.2,0.3,263,1.4,1.5
    1054,5/26/2021 20:23,4224.356,1.17,701,300,10,6001,0,65535,65535,1,23.1,28280,-298,-297,100,92,11,3556,3888,716,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4049,4050,4046,4031,4033,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.5,943,SUCCESS,,3557.358405,192,0,0.1,0.2,0.3,263,1.4,1.5
    1055,5/26/2021 20:23,4228.362,1.17,701,300,10,6001,0,65535,65535,1,23.1,28280,-298,-297,100,92,11,3556,3888,716,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4049,4050,4046,4031,4033,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,955,SUCCESS,,3557.026797,192,0,0.1,0.2,0.3,263,1.4,1.5
    1056,5/26/2021 20:23,4232.367,1.18,701,300,10,6001,0,65535,65535,1,23.1,28280,-296,-297,100,92,11,3555,3888,721,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4031,4033,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,964,SUCCESS,,3556.697497,192,0,0.1,0.2,0.3,263,1.4,1.5
    1057,5/26/2021 20:23,4236.369,1.18,701,300,10,6001,0,65535,65535,1,23.1,28279,-296,-296,100,92,11,3555,3888,721,721,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4031,4033,4029,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,962,SUCCESS,,3556.368444,192,0,0.1,0.2,0.3,263,1.4,1.5
    1058,5/26/2021 20:23,4240.38,1.18,701,300,10,6001,0,65535,65535,1,23.1,28278,-296,-297,100,92,11,3555,3888,726,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4031,4033,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,982,SUCCESS,,3556.03865,192,0,0.1,0.2,0.3,263,1.4,1.5
    1059,5/26/2021 20:23,4244.391,1.18,701,300,10,6001,0,65535,65535,1,23.1,28278,-296,-297,100,92,11,3554,3888,720,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4031,4033,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,955,SUCCESS,,3555.708857,192,0,0.1,0.2,0.3,263,1.4,1.5
    1060,5/26/2021 20:23,4248.398,1.18,701,300,10,6001,0,65535,65535,1,23.1,28277,-300,-296,100,92,11,3554,3888,720,720,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4030,4033,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.8,990,SUCCESS,,3555.37494,192,0,0.1,0.2,0.3,263,1.4,1.5
    1061,5/26/2021 20:23,4252.398,1.18,701,300,10,6001,0,65535,65535,1,23.1,28276,-296,-297,100,92,11,3554,3888,720,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4030,4032,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,1039,SUCCESS,,3555.046051,192,0,0.1,0.2,0.3,263,1.4,1.5
    1062,5/26/2021 20:23,4256.407,1.18,701,300,10,6001,0,65535,65535,1,23.1,28276,-298,-297,100,92,11,3553,3888,715,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4030,4033,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,1008,SUCCESS,,3554.714195,192,0,0.1,0.2,0.3,263,1.4,1.5
    1063,5/26/2021 20:23,4260.417,1.18,701,300,10,6001,0,65535,65535,1,23.1,28275,-298,-297,100,92,11,3553,3888,715,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4043,4048,4049,4045,4030,4032,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,944,SUCCESS,,3554.382256,192,0,0.1,0.2,0.3,263,1.4,1.5
    1064,5/26/2021 20:23,4264.427,1.18,701,300,10,6001,0,65535,65535,1,23.1,28274,-296,-297,100,92,11,3553,3888,720,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4045,4030,4032,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,983,SUCCESS,,3554.052545,192,0,0.1,0.2,0.3,263,1.4,1.5
    1065,5/26/2021 20:23,4268.431,1.19,701,300,10,6001,0,65535,65535,1,23.1,28273,-298,-297,100,92,11,3552,3888,710,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4045,4030,4032,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,963,SUCCESS,,3553.721103,192,0,0.1,0.2,0.3,263,1.4,1.5
    1066,5/26/2021 20:23,4272.438,1.19,701,300,10,6001,0,65535,65535,1,23.1,28273,-298,-297,100,92,11,3552,3888,710,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4045,4030,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,961,SUCCESS,,3553.389413,192,0,0.1,0.2,0.3,263,1.4,1.5
    1067,5/26/2021 20:24,4276.439,1.19,701,300,10,6001,0,65535,65535,1,23.1,28274,-296,-297,100,92,11,3552,3888,720,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4044,4030,4032,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,959,SUCCESS,,3553.060441,192,0,0.1,0.2,0.3,263,1.4,1.5
    1068,5/26/2021 20:24,4280.444,1.19,701,300,10,6001,0,65535,65535,1,23.1,28274,-296,-297,100,92,11,3551,3888,715,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4045,4030,4032,4028,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.6,978,SUCCESS,,3552.731141,192,0,0.1,0.2,0.3,263,1.4,1.5
    1069,5/26/2021 20:24,4284.454,1.19,701,300,10,6001,0,65535,65535,1,23.1,28270,-296,-297,100,92,11,3551,3888,725,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4044,4030,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,974,SUCCESS,,3552.40143,192,0,0.1,0.2,0.3,263,1.4,1.5
    1070,5/26/2021 20:24,4288.463,1.19,701,300,10,6001,0,65535,65535,1,23.1,28271,-294,-297,100,92,11,3551,3888,720,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4045,4029,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,946,SUCCESS,,3552.074029,192,0,0.1,0.2,0.3,263,1.4,1.5
    1071,5/26/2021 20:24,4292.477,1.19,701,300,10,6001,0,65535,65535,1,23.1,28269,-300,-297,100,92,11,3550,3888,720,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4047,4049,4044,4029,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,984,SUCCESS,,3551.739529,192,0,0.1,0.2,0.3,263,1.4,1.5
    1072,5/26/2021 20:24,4296.481,1.19,701,300,10,6001,0,65535,65535,1,23.1,28269,-296,-297,100,92,11,3550,3888,720,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4042,4048,4049,4044,4029,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,968,SUCCESS,,3551.410311,192,0,0.1,0.2,0.3,263,1.4,1.5
    1073,5/26/2021 20:24,4300.496,1.19,701,300,10,6001,0,65535,65535,1,23.1,28269,-296,-297,100,92,11,3550,3888,720,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4049,4044,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,985,SUCCESS,,3551.080189,192,0,0.1,0.2,0.3,263,1.4,1.5
    1074,5/26/2021 20:24,4304.508,1.2,701,300,10,6001,0,65535,65535,1,23.1,28267,-298,-297,100,92,11,3549,3888,719,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4048,4044,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,970,SUCCESS,,3550.748084,192,0,0.1,0.2,0.3,263,1.4,1.5
    1075,5/26/2021 20:24,4308.511,1.2,701,300,10,6001,0,65535,65535,1,23.1,28266,-296,-297,100,92,11,3549,3888,715,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4048,4044,4029,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,960,SUCCESS,,3550.418949,192,0,0.1,0.2,0.3,263,1.4,1.5
    1076,5/26/2021 20:24,4312.526,1.2,701,300,10,6001,0,65535,65535,1,23.1,28267,-298,-297,100,92,11,3549,3888,719,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4048,4044,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,976,SUCCESS,,3550.086596,192,0,0.1,0.2,0.3,263,1.4,1.5
    1077,5/26/2021 20:24,4316.541,1.2,701,300,10,6001,0,65535,65535,1,23.1,28267,-296,-297,100,92,11,3548,3888,714,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4048,4044,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.4,947,SUCCESS,,3549.756474,192,0,0.1,0.2,0.3,263,1.4,1.5
    1078,5/26/2021 20:24,4320.556,1.2,701,300,10,6001,0,65535,65535,1,23.1,28266,-296,-297,100,92,11,3548,3888,719,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4048,4043,4029,4032,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,955,SUCCESS,,3549.426351,192,0,0.1,0.2,0.3,263,1.4,1.5
    1079,5/26/2021 20:24,4324.557,1.2,701,300,10,6001,0,65535,65535,1,23.1,28266,-298,-297,100,92,11,3548,3888,714,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4047,4048,4043,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,977,SUCCESS,,3549.095158,192,0,0.1,0.2,0.3,263,1.4,1.5
    1080,5/26/2021 20:24,4328.561,1.2,701,300,10,6001,0,65535,65535,1,23.1,28265,-296,-297,100,92,11,3547,3888,719,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4048,4043,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,945,SUCCESS,,3548.76594,192,0,0.1,0.2,0.3,263,1.4,1.5
    1081,5/26/2021 20:24,4332.563,1.2,701,300,10,6001,0,65535,65535,1,23.1,28261,-296,-297,100,92,11,3547,3888,719,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4048,4043,4029,4031,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,991,SUCCESS,,3548.436886,192,0,0.1,0.2,0.3,263,1.4,1.5
    1082,5/26/2021 20:25,4336.567,1.2,701,300,10,6001,0,65535,65535,1,23.1,28266,-298,-297,100,92,11,3547,3888,719,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4048,4043,4029,4031,4027,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,967,SUCCESS,,3548.105444,192,0,0.1,0.2,0.3,263,1.4,1.5
    1083,5/26/2021 20:25,4340.57,1.21,701,300,10,6001,0,65535,65535,1,23.1,28263,-298,-297,100,92,11,3546,3888,724,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4048,4043,4028,4031,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,932,SUCCESS,,3547.774085,192,0,0.1,0.2,0.3,263,1.4,1.5
    1084,5/26/2021 20:25,4344.583,1.21,701,300,10,6001,0,65535,65535,1,23.1,28262,-296,-297,100,92,11,3546,3888,714,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4048,4043,4028,4031,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,968,SUCCESS,,3547.444127,192,0,0.1,0.2,0.3,263,1.4,1.5
    1085,5/26/2021 20:25,4348.597,1.21,701,300,10,6001,0,65535,65535,1,23.1,28262,-296,-297,100,92,11,3546,3888,719,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4048,4043,4028,4030,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,937,SUCCESS,,3547.114087,192,0,0.1,0.2,0.3,263,1.4,1.5
    1086,5/26/2021 20:25,4352.608,1.21,701,300,10,6001,0,65535,65535,1,23.1,28261,-296,-296,100,92,11,3545,3888,719,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4043,4028,4031,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,941,SUCCESS,,3546.784294,192,0,0.1,0.2,0.3,263,1.4,1.5
    1087,5/26/2021 20:25,4356.611,1.21,701,300,10,6001,0,65535,65535,1,23.1,28260,-296,-296,100,92,11,3545,3888,719,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4041,4046,4047,4043,4028,4031,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,953,SUCCESS,,3546.455158,192,0,0.1,0.2,0.3,263,1.4,1.5
    1088,5/26/2021 20:25,4360.621,1.21,701,300,10,6001,0,65535,65535,1,23.1,28260,-296,-296,100,92,11,3545,3888,719,719,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4043,4028,4030,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,962,SUCCESS,,3546.125447,192,0,0.1,0.2,0.3,263,1.4,1.5
    1089,5/26/2021 20:25,4364.632,1.21,701,300,10,6001,0,65535,65535,1,23.1,28259,-296,-296,100,92,11,3544,3888,718,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4043,4028,4030,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.9,947,SUCCESS,,3545.795654,192,0,0.1,0.2,0.3,263,1.4,1.5
    1090,5/26/2021 20:25,4368.639,1.21,701,300,10,6001,0,65535,65535,1,23.1,28260,-298,-297,100,92,11,3544,3888,714,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4043,4028,4030,4026,0,0,0,0,0,0,0,0,2821,22.9,23.1,-273.2,23.1,-273.2,22.9,964,SUCCESS,,3545.463963,192,0,0.1,0.2,0.3,263,1.4,1.5
    1091,5/26/2021 20:25,4372.652,1.21,701,300,10,6001,0,65535,65535,1,23.1,28259,-296,-296,100,92,11,3544,3888,718,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4042,4027,4030,4026,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,22.4,951,SUCCESS,,3545.134005,192,0,0.1,0.2,0.3,263,1.4,1.5
    1092,5/26/2021 20:25,4376.652,1.22,701,300,10,6001,0,65535,65535,1,23.1,28258,-296,-296,100,92,11,3543,3888,718,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4042,4027,4030,4026,0,0,0,0,0,0,0,0,2821,22.9,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3544.805116,192,0,0.1,0.2,0.3,263,1.4,1.5
    1093,5/26/2021 20:25,4380.666,1.22,701,300,10,6001,0,65535,65535,1,23.1,28257,-296,-297,100,92,11,3543,3888,718,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4042,4027,4030,4025,0,0,0,0,0,0,0,0,2825,22.9,23.1,-273.2,23.1,-273.2,23,979,SUCCESS,,3544.475076,192,0,0.1,0.2,0.3,263,1.4,1.5
    1094,5/26/2021 20:25,4384.671,1.22,701,300,10,6001,0,65535,65535,1,23.1,28256,-296,-296,100,92,11,3543,3888,718,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4046,4047,4042,4027,4030,4025,0,0,0,0,0,0,0,0,2824,22.9,23.1,-273.2,23.1,-273.2,22.9,959,SUCCESS,,3544.145776,192,0,0.1,0.2,0.3,263,1.4,1.5
    1095,5/26/2021 20:25,4388.678,1.22,701,300,10,6001,0,65535,65535,1,23.1,28255,-298,-297,100,92,11,3542,3888,708,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4045,4046,4042,4027,4030,4025,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,971,SUCCESS,,3543.814086,192,0,0.1,0.2,0.3,263,1.4,1.5
    1096,5/26/2021 20:25,4392.685,1.22,701,300,10,6001,0,65535,65535,1,23.1,28254,-298,-297,100,92,11,3542,3888,718,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4045,4046,4042,4027,4030,4025,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,952,SUCCESS,,3543.482395,192,0,0.1,0.2,0.3,263,1.4,1.5
    1097,5/26/2021 20:26,4396.698,1.22,701,300,10,6001,0,65535,65535,1,23.1,28254,-296,-297,100,92,11,3542,3888,718,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4045,4046,4042,4027,4029,4025,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,985,SUCCESS,,3543.152438,192,0,0.1,0.2,0.3,263,1.4,1.5
    1098,5/26/2021 20:26,4400.702,1.22,701,300,10,6001,0,65535,65535,1,23.1,28254,-298,-297,100,92,11,3541,3888,718,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4040,4045,4046,4041,4027,4029,4025,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,962,SUCCESS,,3542.820995,192,0,0.1,0.2,0.3,263,1.4,1.5
    1099,5/26/2021 20:26,4404.714,1.22,701,300,10,6001,0,65535,65535,1,23.1,28252,-296,-296,100,92,11,3541,3888,723,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4027,4030,4025,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,983,SUCCESS,,3542.49112,192,0,0.1,0.2,0.3,263,1.4,1.5
    1100,5/26/2021 20:26,4408.72,1.22,701,300,10,6001,0,65535,65535,1,23.1,28252,-296,-296,100,92,11,3541,3888,713,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4027,4029,4025,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,23,948,SUCCESS,,3542.161738,192,0,0.1,0.2,0.3,263,1.4,1.5
    1101,5/26/2021 20:26,4412.72,1.23,701,300,10,6001,0,65535,65535,1,23.1,28252,-296,-296,100,92,11,3540,3888,718,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4026,4029,4025,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,961,SUCCESS,,3541.832849,192,0,0.1,0.2,0.3,263,1.4,1.5
    1102,5/26/2021 20:26,4416.732,1.23,701,300,10,6001,0,65535,65535,1,23.1,28252,-296,-296,100,92,11,3540,3888,722,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4027,4030,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,23,947,SUCCESS,,3541.502973,192,0,0.1,0.2,0.3,263,1.4,1.5
    1103,5/26/2021 20:26,4420.742,1.23,701,300,10,6001,0,65535,65535,1,23.1,28252,-298,-296,100,92,11,3540,3888,718,718,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4026,4029,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,941,SUCCESS,,3541.171034,192,0,0.1,0.2,0.3,263,1.4,1.5
    1104,5/26/2021 20:26,4424.744,1.23,701,300,10,6001,0,65535,65535,1,23.1,28250,-298,-296,100,92,11,3539,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4027,4028,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,952,SUCCESS,,3540.839758,192,0,0.1,0.2,0.3,263,1.4,1.5
    1105,5/26/2021 20:26,4428.747,1.23,701,300,10,6001,0,65535,65535,1,23.1,28251,-296,-296,100,92,11,3539,3888,713,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4026,4033,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.5,958,SUCCESS,,3540.510622,192,0,0.1,0.2,0.3,263,1.4,1.5
    1106,5/26/2021 20:26,4432.761,1.23,701,300,10,6001,0,65535,65535,1,23.1,28250,-296,-296,100,92,11,3539,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4026,4029,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,23,944,SUCCESS,,3540.180582,192,0,0.1,0.2,0.3,263,1.4,1.5
    1107,5/26/2021 20:26,4436.761,1.23,701,300,10,6001,0,65535,65535,1,23.1,28250,-294,-296,100,91,11,3538,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4039,4045,4046,4041,4026,4028,4024,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,969,SUCCESS,,3539.853915,192,0,0.1,0.2,0.3,263,1.4,1.5
    1108,5/26/2021 20:26,4440.763,1.23,701,300,10,6001,0,65535,65535,1,23.1,28248,-298,-296,100,91,11,3538,3888,722,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4041,4026,4031,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,958,SUCCESS,,3539.522639,192,0,0.1,0.2,0.3,263,1.4,1.5
    1109,5/26/2021 20:26,4444.769,1.23,701,300,10,6001,0,65535,65535,1,23.1,28247,-296,-296,100,91,11,3538,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4041,4026,4028,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,985,SUCCESS,,3539.193256,192,0,0.1,0.2,0.3,263,1.4,1.5
    1110,5/26/2021 20:26,4448.778,1.24,701,300,10,6001,0,65535,65535,1,23.1,28246,-294,-296,100,91,11,3537,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4041,4026,4027,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,23,945,SUCCESS,,3538.865855,192,0,0.1,0.2,0.3,263,1.4,1.5
    1111,5/26/2021 20:26,4452.789,1.24,701,300,10,6001,0,65535,65535,1,23.1,28246,-296,-296,100,91,11,3537,3888,712,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4040,4026,4028,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,963,SUCCESS,,3538.536061,192,0,0.1,0.2,0.3,263,1.4,1.5
    1112,5/26/2021 20:27,4456.789,1.24,701,300,10,6001,0,65535,65535,1,23.1,28246,-296,-297,100,91,11,3537,3888,717,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4040,4026,4028,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,964,SUCCESS,,3538.207173,192,0,0.1,0.2,0.3,263,1.4,1.5
    1113,5/26/2021 20:27,4460.79,1.24,701,300,10,6001,0,65535,65535,1,23.1,28244,-296,-297,100,91,11,3536,3888,717,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4040,4026,4027,4024,0,0,0,0,0,0,0,0,2820,22.9,23.1,-273.2,23.1,-273.2,22.9,978,SUCCESS,,3537.878201,192,0,0.1,0.2,0.3,263,1.4,1.5
    1114,5/26/2021 20:27,4464.795,1.24,701,300,10,6001,0,65535,65535,1,23.1,28245,-298,-297,100,91,11,3536,3888,712,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4040,4025,4027,4024,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,956,SUCCESS,,3537.546676,192,0,0.1,0.2,0.3,263,1.4,1.5
    1115,5/26/2021 20:27,4468.797,1.24,701,300,10,6001,0,65535,65535,1,23.1,28244,-296,-297,100,91,11,3536,3888,717,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4040,4026,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,23,938,SUCCESS,,3537.217623,192,0,0.1,0.2,0.3,263,1.4,1.5
    1116,5/26/2021 20:27,4472.809,1.24,701,300,10,6001,0,65535,65535,1,23.1,28243,-296,-296,100,91,11,3535,3888,721,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4043,4045,4040,4026,4028,4024,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,949,SUCCESS,,3536.887748,192,0,0.1,0.2,0.3,263,1.4,1.5
    1117,5/26/2021 20:27,4476.822,1.24,701,300,10,6001,0,65535,65535,1,23.1,28242,-298,-296,100,91,11,3535,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4044,4045,4040,4025,4027,4024,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.8,956,SUCCESS,,3536.55556,192,0,0.1,0.2,0.3,263,1.4,1.5
    1118,5/26/2021 20:27,4480.824,1.24,701,300,10,6001,0,65535,65535,1,23.1,28241,-294,-296,100,91,11,3535,3888,717,717,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4043,4045,4040,4025,4028,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.8,964,SUCCESS,,3536.22873,192,0,0.1,0.2,0.3,263,1.4,1.5
    1119,5/26/2021 20:27,4484.83,1.25,701,300,10,6001,0,65535,65535,1,23.1,28241,-298,-296,100,91,11,3534,3888,712,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4038,4043,4045,4040,4025,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,937,SUCCESS,,3535.897123,192,0,0.1,0.2,0.3,263,1.4,1.5
    1120,5/26/2021 20:27,4488.84,1.25,701,300,10,6001,0,65535,65535,1,23.1,28240,-296,-297,100,91,11,3534,3888,716,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4040,4025,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,974,SUCCESS,,3535.567411,192,0,0.1,0.2,0.3,263,1.4,1.5
    1121,5/26/2021 20:27,4492.845,1.25,701,300,10,6001,0,65535,65535,1,23.1,28239,-294,-296,100,91,11,3534,3888,712,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4045,4040,4025,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.8,961,SUCCESS,,3535.240336,192,0,0.1,0.2,0.3,263,1.4,1.5
    1122,5/26/2021 20:27,4496.847,1.25,701,300,10,6001,0,65535,65535,1,23.1,28239,-294,-296,100,91,11,3533,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4040,4025,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3534.913506,192,0,0.1,0.2,0.3,263,1.4,1.5
    1123,5/26/2021 20:27,4500.863,1.25,701,300,10,6001,0,65535,65535,1,23.1,28238,-296,-296,100,91,11,3533,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4040,4025,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,23,1001,SUCCESS,,3534.583302,192,0,0.1,0.2,0.3,263,1.4,1.5
    1124,5/26/2021 20:27,4504.871,1.25,701,300,10,6001,0,65535,65535,1,23.1,28239,-296,-296,100,91,11,3533,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4040,4024,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,23,983,SUCCESS,,3534.253755,192,0,0.1,0.2,0.3,263,1.4,1.5
    1125,5/26/2021 20:27,4508.885,1.25,701,300,10,6001,0,65535,65535,1,23.1,28236,-296,-296,100,91,11,3532,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4040,4025,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,982,SUCCESS,,3533.923715,192,0,0.1,0.2,0.3,263,1.4,1.5
    1126,5/26/2021 20:28,4512.887,1.25,701,300,10,6001,0,65535,65535,1,23.1,28237,-296,-296,100,91,11,3532,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4039,4024,4027,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,980,SUCCESS,,3533.594662,192,0,0.1,0.2,0.3,263,1.4,1.5
    1127,5/26/2021 20:28,4516.899,1.25,701,300,10,6001,0,65535,65535,1,23.1,28237,-296,-296,100,91,11,3532,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4039,4024,4026,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,948,SUCCESS,,3533.264786,192,0,0.1,0.2,0.3,263,1.4,1.5
    1128,5/26/2021 20:28,4520.906,1.26,701,300,10,6001,0,65535,65535,1,23.1,28237,-298,-297,100,91,11,3531,3888,711,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4039,4024,4027,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.2,957,SUCCESS,,3532.933096,192,0,0.1,0.2,0.3,263,1.4,1.5
    1129,5/26/2021 20:28,4524.92,1.26,701,300,10,6001,0,65535,65535,1,23.1,28236,-296,-296,100,91,11,3531,3888,716,716,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4043,4044,4039,4024,4026,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3532.603056,192,0,0.1,0.2,0.3,263,1.4,1.5
    1130,5/26/2021 20:28,4528.924,1.26,701,300,10,6001,0,65535,65535,1,23.1,28233,-298,-297,100,91,11,3531,3888,711,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4042,4044,4039,4024,4026,4023,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,952,SUCCESS,,3532.271614,192,0,0.1,0.2,0.3,263,1.4,1.5
    1131,5/26/2021 20:28,4532.932,1.26,701,300,10,6001,0,65535,65535,1,23.1,28233,-294,-297,100,91,11,3530,3888,720,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4036,4042,4043,4039,4024,4026,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,984,SUCCESS,,3531.944294,192,0,0.1,0.2,0.3,263,1.4,1.5
    1132,5/26/2021 20:28,4536.94,1.26,701,300,10,6001,0,65535,65535,1,23.1,28233,-298,-297,100,91,11,3530,3888,711,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4042,4043,4038,4024,4026,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,939,SUCCESS,,3531.61252,192,0,0.1,0.2,0.3,263,1.4,1.5
    1133,5/26/2021 20:28,4540.956,1.26,701,300,10,6001,0,65535,65535,1,23.1,28231,-298,-297,100,91,11,3530,3888,716,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4036,4042,4043,4038,4024,4026,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,951,SUCCESS,,3531.280085,192,0,0.1,0.2,0.3,263,1.4,1.5
    1134,5/26/2021 20:28,4544.967,1.26,701,300,10,6001,0,65535,65535,1,23.1,28232,-294,-297,100,91,11,3529,3888,720,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4037,4042,4043,4039,4024,4026,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3530.95252,192,0,0.1,0.2,0.3,263,1.4,1.5
    1135,5/26/2021 20:28,4548.97,1.26,701,300,10,6001,0,65535,65535,1,23.1,28231,-298,-296,100,91,11,3529,3888,715,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4036,4042,4043,4039,4024,4026,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3530.62116,192,0,0.1,0.2,0.3,263,1.4,1.5
    1136,5/26/2021 20:28,4552.985,1.26,701,300,10,6001,0,65535,65535,1,23.1,28231,-294,-296,100,91,11,3529,3888,720,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,,0,0,0,0,0,4036,4042,4043,4038,4024,4026,4022,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,2978,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,3530.293269,192,0,0.1,0.2,0.3,263,1.4,1.5
    1137,5/26/2021 20:28,4556.999,1.27,701,300,10,6001,0,65535,65535,1,23.1,28230,-298,-296,100,91,11,3528,3888,715,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4036,4042,4043,4038,4023,4026,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,23,986,SUCCESS,,3529.960999,192,0,0.1,0.2,0.3,263,1.4,1.5
    1138,5/26/2021 20:28,4561.014,1.27,701,300,10,6001,0,65535,65535,1,23.1,28228,-298,-296,100,91,11,3528,3888,715,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4036,4041,4043,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,947,SUCCESS,,3529.628646,192,0,0.1,0.2,0.3,263,1.4,1.5
    1139,5/26/2021 20:28,4565.023,1.27,701,300,10,6001,0,65535,65535,1,23.1,28227,-296,-296,100,91,11,3528,3888,715,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4036,4041,4043,4038,4023,4026,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,967,SUCCESS,,3529.299017,192,0,0.1,0.2,0.3,263,1.4,1.5
    1140,5/26/2021 20:28,4569.026,1.27,701,300,10,6001,0,65535,65535,1,23.1,28227,-296,-296,100,91,11,3527,3888,710,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4043,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,1007,SUCCESS,,3528.969881,192,0,0.1,0.2,0.3,263,1.4,1.5
    1141,5/26/2021 20:29,4573.029,1.27,701,300,10,6001,0,65535,65535,1,23.1,28226,-298,-297,100,91,11,3527,3888,710,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4042,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.8,948,SUCCESS,,3528.638522,192,0,0.1,0.2,0.3,263,1.4,1.5
    1142,5/26/2021 20:29,4577.039,1.27,701,300,10,6001,0,65535,65535,1,23.1,28225,-296,-296,100,91,11,3527,3888,720,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4043,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.3,1007,SUCCESS,,3528.308811,192,0,0.1,0.2,0.3,263,1.4,1.5
    1143,5/26/2021 20:29,4581.045,1.27,701,300,10,6001,0,65535,65535,1,23.1,28225,-296,-296,100,91,11,3526,3888,715,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4043,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,947,SUCCESS,,3527.979429,192,0,0.1,0.2,0.3,263,1.4,1.5
    1144,5/26/2021 20:29,4585.056,1.27,701,300,10,6001,0,65535,65535,1,23.1,28225,-296,-297,100,91,11,3526,3888,710,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4042,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,23,989,SUCCESS,,3527.649635,192,0,0.1,0.2,0.3,263,1.4,1.5
    1145,5/26/2021 20:29,4589.059,1.27,701,300,10,6001,0,65535,65535,1,23.1,28224,-296,-297,100,91,11,3526,3888,715,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4042,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,965,SUCCESS,,3527.3205,192,0,0.1,0.2,0.3,263,1.4,1.5
    1146,5/26/2021 20:29,4593.066,1.28,701,300,10,6001,0,65535,65535,1,23.1,28224,-300,-297,100,91,11,3525,3888,715,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4042,4038,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,961,SUCCESS,,3526.986583,192,0,0.1,0.2,0.3,263,1.4,1.5
    1147,5/26/2021 20:29,4597.075,1.28,701,300,10,6001,0,65535,65535,1,23.1,28223,-296,-297,100,91,11,3525,3888,719,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4042,4037,4023,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,943,SUCCESS,,3526.656954,192,0,0.1,0.2,0.3,263,1.4,1.5
    1148,5/26/2021 20:29,4601.079,1.28,701,300,10,6001,0,65535,65535,1,23.1,28223,-296,-296,100,91,11,3525,3888,719,715,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4041,4037,4023,4024,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,940,SUCCESS,,3526.327736,192,0,0.1,0.2,0.3,263,1.4,1.5
    1149,5/26/2021 20:29,4605.081,1.28,701,300,10,6001,0,65535,65535,1,23.1,28222,-298,-296,100,91,11,3524,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4041,4042,4037,4022,4025,4021,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,958,SUCCESS,,3525.99646,192,0,0.1,0.2,0.3,263,1.4,1.5
    1150,5/26/2021 20:29,4609.085,1.28,701,300,10,6001,0,65535,65535,1,23.1,28221,-296,-297,100,91,11,3524,3888,710,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,964,SUCCESS,,3525.667242,192,0,0.1,0.2,0.3,263,1.4,1.5
    1151,5/26/2021 20:29,4613.097,1.28,701,300,10,6001,0,65535,65535,1,23.1,28220,-296,-296,100,91,11,3524,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4040,4041,4037,4023,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,969,SUCCESS,,3525.337366,192,0,0.1,0.2,0.3,263,1.4,1.5
    1152,5/26/2021 20:29,4617.108,1.28,701,300,10,6001,0,65535,65535,1,23.1,28219,-296,-297,100,91,11,3523,3888,714,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,947,SUCCESS,,3525.007573,192,0,0.1,0.2,0.3,263,1.4,1.5
    1153,5/26/2021 20:29,4621.112,1.28,701,300,10,6001,0,65535,65535,1,23.1,28218,-294,-296,100,91,11,3523,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4035,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,937,SUCCESS,,3524.68058,192,0,0.1,0.2,0.3,263,1.4,1.5
    1154,5/26/2021 20:29,4625.122,1.28,701,300,10,6001,0,65535,65535,1,23,28217,-298,-296,100,91,11,3523,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23,-273.2,23,-273.2,22.9,960,SUCCESS,,3524.348641,192,0,0.1,0.2,0.3,263,1.4,1.5
    1155,5/26/2021 20:29,4629.131,1.29,701,300,10,6001,0,65535,65535,1,23.1,28220,-296,-296,100,91,11,3522,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2819,22.8,23.1,-273.2,23.1,-273.2,22.8,983,SUCCESS,,3524.019012,192,0,0.1,0.2,0.3,263,1.4,1.5
    1156,5/26/2021 20:30,4633.137,1.29,701,300,10,6001,0,65535,65535,1,23,28218,-296,-296,100,91,11,3522,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23,-273.2,22.9,942,SUCCESS,,3523.68963,192,0,0.1,0.2,0.3,263,1.4,1.5
    1157,5/26/2021 20:30,4637.138,1.29,701,300,10,6001,0,65535,65535,1,23,28216,-296,-296,100,91,11,3522,3888,709,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4037,4022,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23,-273.2,23,-273.2,23,942,SUCCESS,,3523.360659,192,0,0.1,0.2,0.3,263,1.4,1.5
    1158,5/26/2021 20:30,4641.153,1.29,701,300,10,6001,0,65535,65535,1,23.1,28221,-296,-296,100,91,11,3521,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4037,4021,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,964,SUCCESS,,3523.030536,192,0,0.1,0.2,0.3,263,1.4,1.5
    1159,5/26/2021 20:30,4645.158,1.29,701,300,10,6001,0,65535,65535,1,23.1,28216,-296,-296,100,91,11,3521,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4036,4021,4024,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,941,SUCCESS,,3522.701236,192,0,0.1,0.2,0.3,263,1.4,1.5
    1160,5/26/2021 20:30,4649.171,1.29,701,300,10,6001,0,65535,65535,1,23.1,28215,-296,-296,100,91,11,3521,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4036,4021,4023,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,945,SUCCESS,,3522.371279,192,0,0.1,0.2,0.3,263,1.4,1.5
    1161,5/26/2021 20:30,4653.176,1.29,701,300,10,6001,0,65535,65535,1,23.1,28220,-296,-296,100,91,11,3520,3888,714,714,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4040,4041,4036,4021,4023,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,940,SUCCESS,,3522.041979,192,0,0.1,0.2,0.3,263,1.4,1.5
    1162,5/26/2021 20:30,4657.181,1.29,701,300,10,6001,0,65535,65535,1,23.1,28214,-298,-297,100,91,11,3520,3888,709,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4039,4040,4036,4021,4023,4020,0,0,0,0,0,0,0,0,2817,22.8,23.1,-273.2,23.1,-273.2,22.9,985,SUCCESS,,3521.710454,192,0,0.1,0.2,0.3,263,1.4,1.5
    1163,5/26/2021 20:30,4661.189,1.29,701,300,10,6001,0,65535,65535,1,23.1,28212,-296,-297,100,91,11,3520,3888,714,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4034,4039,4040,4036,4021,4023,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.8,938,SUCCESS,,3521.380907,192,0,0.1,0.2,0.3,263,1.4,1.5
    1164,5/26/2021 20:30,4665.204,1.3,701,300,10,6001,0,65535,65535,1,23.1,28210,-296,-296,100,91,11,3519,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4036,4021,4023,4020,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,986,SUCCESS,,3521.050785,192,0,0.1,0.2,0.3,263,1.4,1.5
    1165,5/26/2021 20:30,4669.213,1.3,701,300,10,6001,0,65535,65535,1,23.1,28211,-296,-296,100,91,11,3519,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4021,4023,4019,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.5,963,SUCCESS,,3520.721156,192,0,0.1,0.2,0.3,263,1.4,1.5
    1166,5/26/2021 20:30,4673.225,1.3,701,300,10,6001,0,65535,65535,1,23.1,28210,-296,-296,100,91,11,3519,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4021,4023,4019,0,0,0,0,0,0,0,0,2817,22.8,23.1,-273.2,23.1,-273.2,23,965,SUCCESS,,3520.39128,192,0,0.1,0.2,0.3,263,1.4,1.5
    1167,5/26/2021 20:30,4677.229,1.3,701,300,10,6001,0,65535,65535,1,23.1,28210,-298,-296,100,91,11,3518,3888,708,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4021,4023,4019,0,0,0,0,0,0,0,0,2820,22.8,23.1,-273.2,23.1,-273.2,22.9,960,SUCCESS,,3520.059838,192,0,0.1,0.2,0.3,263,1.4,1.5
    1168,5/26/2021 20:30,4681.24,1.3,701,300,10,6001,0,65535,65535,1,23.1,28210,-296,-296,100,91,11,3518,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4021,4023,4019,0,0,0,0,0,0,0,0,2816,22.8,23.1,-273.2,23.1,-273.2,22.9,997,SUCCESS,,3519.730045,192,0,0.1,0.2,0.3,263,1.4,1.5
    1169,5/26/2021 20:30,4685.248,1.3,701,300,10,6001,0,65535,65535,1,23.1,28209,-294,-296,100,91,11,3518,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4020,4022,4019,0,0,0,0,0,0,0,0,2816,22.8,23.1,-273.2,23.1,-273.2,22.9,941,SUCCESS,,3519.402725,192,0,0.1,0.2,0.3,263,1.4,1.5
    1170,5/26/2021 20:30,4689.254,1.3,701,300,10,6001,0,65535,65535,1,23.1,28210,-294,-296,100,91,11,3517,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4020,4022,4019,0,0,0,0,0,0,0,0,2816,22.8,23.1,-273.2,23.1,-273.2,22.9,942,SUCCESS,,3519.075568,192,0,0.1,0.2,0.3,263,1.4,1.5
    1171,5/26/2021 20:31,4693.269,1.3,701,300,10,6001,0,65535,65535,1,23.1,28209,-296,-296,100,91,11,3517,3888,718,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4033,4039,4040,4035,4020,4023,4019,0,0,0,0,0,0,0,0,2816,22.8,23.1,-273.2,23.1,-273.2,22.9,937,SUCCESS,,3518.745446,192,0,0.1,0.2,0.3,263,1.4,1.5
    1172,5/26/2021 20:31,4697.28,1.3,701,300,10,6001,0,65535,65535,1,23,28205,-294,-296,100,91,11,3517,3888,718,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4040,4035,4020,4018,4019,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,946,SUCCESS,,3518.417881,192,0,0.1,0.2,0.3,263,1.4,1.5
    1173,5/26/2021 20:31,4701.288,1.31,701,300,10,6001,0,65535,65535,1,23,28205,-294,-296,100,91,11,3516,3888,718,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4035,4020,4022,4019,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,985,SUCCESS,,3518.090561,192,0,0.1,0.2,0.3,263,1.4,1.5
    1174,5/26/2021 20:31,4705.298,1.31,701,300,10,6001,0,65535,65535,1,23,28205,-296,-296,100,91,11,3516,3888,708,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4040,4035,4020,4022,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,937,SUCCESS,,3517.76085,192,0,0.1,0.2,0.3,263,1.4,1.5
    1175,5/26/2021 20:31,4709.306,1.31,701,300,10,6001,0,65535,65535,1,23,28204,-298,-296,100,91,11,3516,3888,708,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4035,4020,4021,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,978,SUCCESS,,3517.429076,192,0,0.1,0.2,0.3,263,1.4,1.5
    1176,5/26/2021 20:31,4713.315,1.31,701,300,10,6001,0,65535,65535,1,23,28204,-296,-296,100,91,11,3515,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4035,4020,4022,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,959,SUCCESS,,3517.099448,192,0,0.1,0.2,0.3,263,1.4,1.5
    1177,5/26/2021 20:31,4717.319,1.31,701,300,10,6001,0,65535,65535,1,23,28204,-296,-296,100,91,11,3515,3888,713,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4035,4020,4022,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,971,SUCCESS,,3516.77023,192,0,0.1,0.2,0.3,263,1.4,1.5
    1178,5/26/2021 20:31,4721.327,1.31,701,300,10,6001,0,65535,65535,1,23,28204,-300,-296,100,91,11,3515,3888,708,713,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4034,4020,4023,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,972,SUCCESS,,3516.43623,192,0,0.1,0.2,0.3,263,1.4,1.5
    1179,5/26/2021 20:31,4725.339,1.31,701,300,10,6001,0,65535,65535,1,23,28203,-296,-296,100,91,11,3514,3888,708,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4034,4020,4021,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.3,985,SUCCESS,,3516.106354,192,0,0.1,0.2,0.3,263,1.4,1.5
    1180,5/26/2021 20:31,4729.345,1.31,701,300,10,6001,0,65535,65535,1,23,28202,-296,-296,100,91,11,3514,3888,712,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4034,4020,4022,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,977,SUCCESS,,3515.776972,192,0,0.1,0.2,0.3,263,1.4,1.5
    1181,5/26/2021 20:31,4733.349,1.31,701,300,10,6001,0,65535,65535,1,23,28202,-296,-296,100,91,11,3514,3888,712,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4034,4020,4023,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,998,SUCCESS,,3515.447754,192,0,0.1,0.2,0.3,263,1.4,1.5
    1182,5/26/2021 20:31,4737.355,1.32,701,300,10,6001,0,65535,65535,1,23,28202,-296,-296,100,91,11,3514,3888,712,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4039,4034,4020,4021,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,966,SUCCESS,,3515.118372,192,0,0.1,0.2,0.3,263,1.4,1.5
    1183,5/26/2021 20:31,4741.361,1.32,701,300,10,6001,0,65535,65535,1,23,28202,-294,-296,100,91,11,3513,3888,717,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4037,4038,4034,4020,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,939,SUCCESS,,3514.791215,192,0,0.1,0.2,0.3,263,1.4,1.5
    1184,5/26/2021 20:31,4745.37,1.32,701,300,10,6001,0,65535,65535,1,23,28201,-296,-296,100,91,11,3513,3888,712,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4032,4038,4038,4034,4019,4023,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,944,SUCCESS,,3514.461586,192,0,0.1,0.2,0.3,263,1.4,1.5
    1185,5/26/2021 20:31,4749.378,1.32,701,300,10,6001,0,65535,65535,1,23,28200,-294,-296,100,91,11,3513,3888,712,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4034,4019,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,953,SUCCESS,,3514.134266,192,0,0.1,0.2,0.3,263,1.4,1.5
    1186,5/26/2021 20:32,4753.381,1.32,701,300,10,6001,0,65535,65535,1,23,28197,-298,-296,100,91,11,3512,3888,707,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4034,4019,4021,4018,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,951,SUCCESS,,3513.802907,192,0,0.1,0.2,0.3,263,1.4,1.5
    1187,5/26/2021 20:32,4757.39,1.32,701,300,10,6001,0,65535,65535,1,23,28197,-294,-296,100,91,11,3512,3888,722,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4034,4019,4023,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,957,SUCCESS,,3513.475505,192,0,0.1,0.2,0.3,263,1.4,1.5
    1188,5/26/2021 20:32,4761.399,1.32,701,300,10,6001,0,65535,65535,1,23,28196,-296,-296,100,91,11,3512,3888,712,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4034,4019,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,995,SUCCESS,,3513.145876,192,0,0.1,0.2,0.3,263,1.4,1.5
    1189,5/26/2021 20:32,4765.414,1.32,701,300,10,6001,0,65535,65535,1,23,28196,-294,-296,100,91,11,3511,3888,707,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4034,4019,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,962,SUCCESS,,3512.817985,192,0,0.1,0.2,0.3,263,1.4,1.5
    1190,5/26/2021 20:32,4769.419,1.32,701,300,10,6001,0,65535,65535,1,23,28197,-294,-296,100,91,11,3511,3888,717,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4033,4019,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,979,SUCCESS,,3512.49091,192,0,0.1,0.2,0.3,263,1.4,1.5
    1191,5/26/2021 20:32,4773.433,1.33,701,300,10,6001,0,65535,65535,1,23,28196,-296,-296,100,91,11,3511,3888,717,712,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4033,4019,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,950,SUCCESS,,3512.16087,192,0,0.1,0.2,0.3,263,1.4,1.5
    1192,5/26/2021 20:32,4777.437,1.33,701,300,10,6001,0,65535,65535,1,23,28195,-298,-296,100,91,11,3510,3888,702,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4033,4018,4021,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,938,SUCCESS,,3511.829428,192,0,0.1,0.2,0.3,263,1.4,1.5
    1193,5/26/2021 20:32,4781.438,1.33,701,300,10,6001,0,65535,65535,1,23,28195,-296,-296,100,91,11,3510,3888,716,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4033,4018,4020,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.6,942,SUCCESS,,3511.500456,192,0,0.1,0.2,0.3,263,1.4,1.5
    1194,5/26/2021 20:32,4785.44,1.33,701,300,10,6001,0,65535,65535,1,23,28193,-296,-296,100,91,11,3510,3888,707,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4037,4038,4033,4018,4020,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,943,SUCCESS,,3511.171403,192,0,0.1,0.2,0.3,263,1.4,1.5
    1195,5/26/2021 20:32,4789.441,1.33,701,300,10,6001,0,65535,65535,1,23,28193,-296,-297,100,91,11,3509,3888,711,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4031,4036,4038,4033,4018,4020,4017,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,974,SUCCESS,,3510.842432,192,0,0.1,0.2,0.3,263,1.4,1.5
    1196,5/26/2021 20:32,4793.449,1.33,701,300,10,6001,0,65535,65535,1,23,28191,-296,-296,100,91,11,3509,3888,711,711,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4038,4033,4018,4020,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,967,SUCCESS,,3510.512885,192,0,0.1,0.2,0.3,263,1.4,1.5
    1197,5/26/2021 20:32,4797.452,1.33,701,300,10,6001,0,65535,65535,1,23,28190,-298,-297,100,91,11,3508,3888,706,709,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4018,4020,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,962,SUCCESS,,3510.181526,192,0,0.1,0.2,0.3,263,1.4,1.5
    1198,5/26/2021 20:32,4801.464,1.33,701,300,10,6001,0,65535,65535,1,23,28189,-296,-297,100,91,11,3508,3888,711,709,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4018,4020,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,946,SUCCESS,,3509.85165,192,0,0.1,0.2,0.3,263,1.4,1.5
    1199,5/26/2021 20:32,4805.467,1.33,701,300,10,6001,0,65535,65535,1,23,28190,-298,-297,100,91,11,3508,3888,706,709,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4017,4020,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,942,SUCCESS,,3509.520291,192,0,0.1,0.2,0.3,263,1.4,1.5
    1200,5/26/2021 20:32,4809.478,1.34,701,300,10,6001,0,65535,65535,1,23,28190,-298,-297,100,91,11,3508,3888,706,709,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4018,4020,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,1002,SUCCESS,,3509.188269,192,0,0.1,0.2,0.3,263,1.4,1.5
    1201,5/26/2021 20:33,4813.49,1.34,701,300,10,6001,0,65535,65535,1,23,28189,-296,-297,100,91,11,3507,3888,711,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4017,4019,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,987,SUCCESS,,3508.858394,192,0,0.1,0.2,0.3,263,1.4,1.5
    1202,5/26/2021 20:33,4817.505,1.34,701,300,10,6001,0,65535,65535,1,23,28189,-298,-297,100,91,11,3507,3888,706,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4017,4020,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,935,SUCCESS,,3508.526041,192,0,0.1,0.2,0.3,263,1.4,1.5
    1203,5/26/2021 20:33,4821.517,1.34,701,300,10,6001,0,65535,65535,1,23,28187,-298,-297,100,91,11,3507,3888,706,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4030,4036,4037,4032,4017,4019,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,939,SUCCESS,,3508.193936,192,0,0.1,0.2,0.3,263,1.4,1.5
    1204,5/26/2021 20:33,4825.523,1.34,701,300,10,6001,0,65535,65535,1,23,28185,-296,-297,100,91,11,3506,3888,711,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4037,4032,4017,4019,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,968,SUCCESS,,3507.864554,192,0,0.1,0.2,0.3,263,1.4,1.5
    1205,5/26/2021 20:33,4829.528,1.34,701,300,10,6001,0,65535,65535,1,23,28184,-296,-297,100,91,11,3506,3888,711,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4037,4032,4017,4019,4016,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,942,SUCCESS,,3507.535254,192,0,0.1,0.2,0.3,263,1.4,1.5
    1206,5/26/2021 20:33,4833.539,1.34,701,300,10,6001,0,65535,65535,1,23,28183,-296,-297,100,91,11,3506,3888,716,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4032,4017,4019,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,968,SUCCESS,,3507.205461,192,0,0.1,0.2,0.3,263,1.4,1.5
    1207,5/26/2021 20:33,4837.554,1.34,701,300,10,6001,0,65535,65535,1,23,28183,-298,-297,100,91,11,3505,3888,706,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4032,4017,4019,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,970,SUCCESS,,3506.873108,192,0,0.1,0.2,0.3,263,1.4,1.5
    1208,5/26/2021 20:33,4841.555,1.34,701,300,10,6001,0,65535,65535,1,23,28183,-298,-297,100,91,11,3505,3888,706,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4032,4017,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,967,SUCCESS,,3506.541914,192,0,0.1,0.2,0.3,263,1.4,1.5
    1209,5/26/2021 20:33,4845.563,1.35,701,300,10,6001,0,65535,65535,1,23,28183,-296,-297,100,91,11,3505,3888,710,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4032,4017,4019,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,946,SUCCESS,,3506.212368,192,0,0.1,0.2,0.3,263,1.4,1.5
    1210,5/26/2021 20:33,4849.567,1.35,701,300,10,6001,0,65535,65535,1,23,28181,-296,-297,100,91,11,3504,3888,710,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4031,4017,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,957,SUCCESS,,3505.88315,192,0,0.1,0.2,0.3,263,1.4,1.5
    1211,5/26/2021 20:33,4853.57,1.35,701,300,10,6001,0,65535,65535,1,23,28182,-298,-297,100,91,11,3504,3888,706,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4031,4017,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,969,SUCCESS,,3505.55179,192,0,0.1,0.2,0.3,263,1.4,1.5
    1212,5/26/2021 20:33,4857.574,1.35,701,300,10,6001,0,65535,65535,1,23,28180,-296,-297,100,91,11,3504,3888,710,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4031,4016,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,981,SUCCESS,,3505.222573,192,0,0.1,0.2,0.3,263,1.4,1.5
    1213,5/26/2021 20:33,4861.585,1.35,701,300,10,6001,0,65535,65535,1,23,28181,-298,-297,100,91,11,3503,3888,710,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4031,4016,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,980,SUCCESS,,3504.890551,192,0,0.1,0.2,0.3,263,1.4,1.5
    1214,5/26/2021 20:33,4865.591,1.35,701,300,10,6001,0,65535,65535,1,23,28179,-296,-297,100,91,11,3503,3888,710,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4035,4036,4031,4016,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,958,SUCCESS,,3504.561169,192,0,0.1,0.2,0.3,263,1.4,1.5
    1215,5/26/2021 20:33,4869.591,1.35,701,300,10,6001,0,65535,65535,1,23,28178,-298,-297,100,91,11,3503,3888,705,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4034,4035,4031,4016,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,949,SUCCESS,,3504.230058,192,0,0.1,0.2,0.3,263,1.4,1.5
    1216,5/26/2021 20:34,4873.593,1.35,701,300,10,6001,0,65535,65535,1,23,28177,-296,-297,100,91,11,3502,3888,710,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4028,4034,4035,4031,4016,4018,4015,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,947,SUCCESS,,3503.901004,192,0,0.1,0.2,0.3,263,1.4,1.5
    1217,5/26/2021 20:34,4877.597,1.35,701,300,10,6001,0,65535,65535,1,23,28177,-296,-297,100,91,11,3502,3888,705,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4029,4034,4035,4031,4016,4018,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,985,SUCCESS,,3503.571786,192,0,0.1,0.2,0.3,263,1.4,1.5
    1218,5/26/2021 20:34,4881.606,1.36,701,300,10,6001,0,65535,65535,1,23,28176,-296,-297,100,91,11,3502,3888,705,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4028,4034,4035,4031,4016,4018,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,946,SUCCESS,,3503.242158,192,0,0.1,0.2,0.3,263,1.4,1.5
    1219,5/26/2021 20:34,4885.62,1.36,701,300,10,6001,0,65535,65535,1,23,28175,-296,-297,100,91,11,3501,3888,710,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4028,4034,4035,4031,4016,4018,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,997,SUCCESS,,3502.912118,192,0,0.1,0.2,0.3,263,1.4,1.5
    1220,5/26/2021 20:34,4889.623,1.36,701,300,10,6001,0,65535,65535,1,23,28176,-294,-296,100,91,11,3501,3888,714,710,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4028,4034,4035,4031,4016,4018,4014,0,0,0,0,0,0,0,0,2812,22.8,23,-273.2,23,-273.2,22.8,943,SUCCESS,,3502.585206,192,0,0.1,0.2,0.3,263,1.4,1.5
    1221,5/26/2021 20:34,4893.633,1.36,701,300,10,6001,0,65535,65535,1,23,28174,-296,-297,100,91,11,3501,3888,705,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4028,4034,4035,4030,4016,4018,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,995,SUCCESS,,3502.255495,192,0,0.1,0.2,0.3,263,1.4,1.5
    1222,5/26/2021 20:34,4897.637,1.36,701,300,10,6001,0,65535,65535,1,23,28174,-296,-297,100,91,11,3500,3888,709,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4028,4034,4035,4030,4015,4018,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,946,SUCCESS,,3501.926277,192,0,0.1,0.2,0.3,263,1.4,1.5
    1223,5/26/2021 20:34,4901.646,1.36,701,300,10,6001,0,65535,65535,1,23,28173,-294,-296,100,91,11,3500,3888,709,709,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4034,4035,4030,4015,4017,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,936,SUCCESS,,3501.598875,192,0,0.1,0.2,0.3,263,1.4,1.5
    1224,5/26/2021 20:34,4905.658,1.36,701,300,10,6001,0,65535,65535,1,23,28172,-296,-297,100,91,11,3500,3888,705,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4034,4035,4030,4015,4017,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,959,SUCCESS,,3501.269,192,0,0.1,0.2,0.3,263,1.4,1.5
    1225,5/26/2021 20:34,4909.659,1.36,701,300,10,6001,0,65535,65535,1,23,28168,-296,-297,100,90,11,3499,3888,704,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4034,4035,4030,4015,4017,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,946,SUCCESS,,3500.940029,192,0,0.1,0.2,0.3,263,1.4,1.5
    1226,5/26/2021 20:34,4913.664,1.36,701,300,10,6001,0,65535,65535,1,23,28171,-298,-297,100,90,11,3499,3888,709,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4034,4035,4030,4015,4017,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,971,SUCCESS,,3500.608504,192,0,0.1,0.2,0.3,263,1.4,1.5
    1227,5/26/2021 20:34,4917.667,1.37,701,300,10,6001,0,65535,65535,1,23,28171,-298,-297,100,90,11,3499,3888,704,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4033,4034,4030,4015,4017,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,954,SUCCESS,,3500.277144,192,0,0.1,0.2,0.3,263,1.4,1.5
    1228,5/26/2021 20:34,4921.678,1.37,701,300,10,6001,0,65535,65535,1,23,28165,-294,-297,100,90,11,3498,3888,709,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4033,4034,4029,4015,4017,4013,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.8,982,SUCCESS,,3499.949579,192,0,0.1,0.2,0.3,263,1.4,1.5
    1229,5/26/2021 20:34,4925.68,1.37,701,300,10,6001,0,65535,65535,1,23,28169,-298,-297,100,90,11,3498,3888,704,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4033,4034,4029,4015,4017,4014,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,957,SUCCESS,,3499.618303,192,0,0.1,0.2,0.3,263,1.4,1.5
    1230,5/26/2021 20:34,4929.68,1.37,701,300,10,6001,0,65535,65535,1,23,28168,-296,-297,100,90,11,3498,3888,704,707,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4033,4034,4030,4015,4017,4013,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.6,990,SUCCESS,,3499.289414,192,0,0.1,0.2,0.3,263,1.4,1.5
    1231,5/26/2021 20:35,4933.695,1.37,701,300,10,6001,0,65535,65535,1,23,28164,-296,-297,100,90,11,3497,3888,709,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4033,4034,4029,4015,4017,4013,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,971,SUCCESS,,3498.959291,192,0,0.1,0.2,0.3,263,1.4,1.5
    1232,5/26/2021 20:35,4937.698,1.37,701,300,10,6001,0,65535,65535,1,23,28168,-298,-297,100,90,11,3497,3888,704,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4027,4033,4034,4029,4014,4016,4013,0,0,0,0,0,0,0,0,2816,22.8,23,-273.2,23,-273.2,22.9,967,SUCCESS,,3498.627932,192,0,0.1,0.2,0.3,263,1.4,1.5
    1233,5/26/2021 20:35,4941.703,1.37,701,300,10,6001,0,65535,65535,1,23,28167,-296,-297,100,90,11,3497,3888,709,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4033,4034,4029,4014,4016,4013,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,965,SUCCESS,,3498.298632,192,0,0.1,0.2,0.3,263,1.4,1.5
    1234,5/26/2021 20:35,4945.707,1.37,701,300,10,6001,0,65535,65535,1,23,28168,-298,-297,100,90,11,3496,3888,704,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4034,4029,4014,4016,4012,0,0,0,0,0,0,0,0,2812,22.8,23,-273.2,23,-273.2,22.9,959,SUCCESS,,3497.96719,192,0,0.1,0.2,0.3,263,1.4,1.5
    1235,5/26/2021 20:35,4949.717,1.37,701,300,10,6001,0,65535,65535,1,23,28164,-296,-297,100,90,11,3496,3888,709,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4029,4014,4016,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,948,SUCCESS,,3497.637479,192,0,0.1,0.2,0.3,263,1.4,1.5
    1236,5/26/2021 20:35,4953.73,1.38,701,300,10,6001,0,65535,65535,1,23,28162,-296,-297,100,90,11,3496,3888,709,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4029,4014,4016,4013,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,953,SUCCESS,,3497.307521,192,0,0.1,0.2,0.3,263,1.4,1.5
    1237,5/26/2021 20:35,4957.731,1.38,701,300,10,6001,0,65535,65535,1,23,28162,-296,-297,100,90,11,3495,3888,708,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4029,4014,4016,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,960,SUCCESS,,3496.97855,192,0,0.1,0.2,0.3,263,1.4,1.5
    1238,5/26/2021 20:35,4961.744,1.38,701,300,10,6001,0,65535,65535,1,23,28162,-298,-297,100,90,11,3495,3888,704,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4028,4014,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,955,SUCCESS,,3496.646363,192,0,0.1,0.2,0.3,263,1.4,1.5
    1239,5/26/2021 20:35,4965.745,1.38,701,300,10,6001,0,65535,65535,1,23,28161,-296,-296,100,90,11,3495,3888,708,708,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4029,4014,4016,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,1017,SUCCESS,,3496.317391,192,0,0.1,0.2,0.3,263,1.4,1.5
    1240,5/26/2021 20:35,4969.75,1.38,701,300,10,6001,0,65535,65535,1,23,28161,-298,-297,100,90,11,3494,3888,703,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4028,4014,4016,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,977,SUCCESS,,3495.985866,192,0,0.1,0.2,0.3,263,1.4,1.5
    1241,5/26/2021 20:35,4973.751,1.38,701,300,10,6001,0,65535,65535,1,23,28160,-296,-297,100,90,11,3494,3888,708,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4028,4014,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,942,SUCCESS,,3495.656895,192,0,0.1,0.2,0.3,263,1.4,1.5
    1242,5/26/2021 20:35,4977.762,1.38,701,300,10,6001,0,65535,65535,1,23,28160,-296,-297,100,90,11,3494,3888,708,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4028,4014,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,945,SUCCESS,,3495.327102,192,0,0.1,0.2,0.3,263,1.4,1.5
    1243,5/26/2021 20:35,4981.771,1.38,701,300,10,6001,0,65535,65535,1,23,28161,-298,-297,100,90,11,3493,3888,703,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4028,4014,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,972,SUCCESS,,3494.995246,192,0,0.1,0.2,0.3,263,1.4,1.5
    1244,5/26/2021 20:35,4985.786,1.38,701,300,10,6001,0,65535,65535,1,23,28159,-296,-297,100,90,11,3493,3888,708,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4026,4032,4033,4028,4013,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.4,993,SUCCESS,,3494.665124,192,0,0.1,0.2,0.3,263,1.4,1.5
    1245,5/26/2021 20:35,4989.792,1.39,701,300,10,6001,0,65535,65535,1,23,28156,-298,-297,100,90,11,3493,3888,708,706,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4028,4013,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,954,SUCCESS,,3494.333516,192,0,0.1,0.2,0.3,263,1.4,1.5
    1246,5/26/2021 20:36,4993.805,1.39,701,300,10,6001,0,65535,65535,1,23,28156,-298,-297,100,90,11,3492,3888,703,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4027,4013,4016,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,968,SUCCESS,,3494.001329,192,0,0.1,0.2,0.3,263,1.4,1.5
    1247,5/26/2021 20:36,4997.811,1.39,701,300,10,6001,0,65535,65535,1,23,28154,-296,-297,100,90,11,3492,3888,708,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4027,4013,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,951,SUCCESS,,3493.671946,192,0,0.1,0.2,0.3,263,1.4,1.5
    1248,5/26/2021 20:36,5001.825,1.39,701,300,10,6001,0,65535,65535,1,23,28154,-296,-297,100,90,11,3492,3888,703,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4027,4012,4015,4012,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,950,SUCCESS,,3493.341906,192,0,0.1,0.2,0.3,263,1.4,1.5
    1249,5/26/2021 20:36,5005.83,1.39,701,300,10,6001,0,65535,65535,1,23,28154,-296,-297,100,90,11,3491,3888,712,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4027,4013,4017,4011,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,939,SUCCESS,,3493.012606,192,0,0.1,0.2,0.3,263,1.4,1.5
    1250,5/26/2021 20:36,5009.845,1.39,701,300,10,6001,0,65535,65535,1,23,28154,-296,-297,100,90,11,3491,3888,708,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4027,4013,4015,4011,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,957,SUCCESS,,3492.682484,192,0,0.1,0.2,0.3,263,1.4,1.5
    1251,5/26/2021 20:36,5013.846,1.39,701,300,10,6001,0,65535,65535,1,23,28153,-296,-297,100,90,11,3491,3888,708,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4025,4031,4032,4027,4013,4014,4011,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,959,SUCCESS,,3492.353513,192,0,0.1,0.2,0.3,263,1.4,1.5
    1252,5/26/2021 20:36,5017.853,1.39,701,300,10,6001,0,65535,65535,1,23,28152,-296,-297,100,90,11,3490,3888,703,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4031,4032,4027,4012,4016,4011,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,970,SUCCESS,,3492.024049,192,0,0.1,0.2,0.3,263,1.4,1.5
    1253,5/26/2021 20:36,5021.864,1.39,701,300,10,6001,0,65535,65535,1,23,28153,-296,-297,100,90,11,3490,3888,707,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4031,4032,4027,4012,4014,4011,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,1023,SUCCESS,,3491.694255,192,0,0.1,0.2,0.3,263,1.4,1.5
    1254,5/26/2021 20:36,5025.87,1.4,701,300,10,6001,0,65535,65535,1,23,28151,-296,-297,100,90,11,3490,3888,703,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4031,4032,4027,4012,4013,4011,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,948,SUCCESS,,3491.364873,192,0,0.1,0.2,0.3,263,1.4,1.5
    1255,5/26/2021 20:36,5029.872,1.4,701,300,10,6001,0,65535,65535,1,23,28151,-296,-297,100,90,11,3489,3888,712,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4031,4032,4027,4012,4019,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,962,SUCCESS,,3491.03582,192,0,0.1,0.2,0.3,263,1.4,1.5
    1256,5/26/2021 20:36,5033.884,1.4,701,300,10,6001,0,65535,65535,1,23,28151,-296,-297,100,90,11,3489,3888,707,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4031,4032,4027,4012,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,963,SUCCESS,,3490.705944,192,0,0.1,0.2,0.3,263,1.4,1.5
    1257,5/26/2021 20:36,5037.896,1.4,701,300,10,6001,0,65535,65535,1,23,28149,-296,-297,100,90,11,3489,3888,702,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4030,4031,4026,4012,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,967,SUCCESS,,3490.376069,192,0,0.1,0.2,0.3,263,1.4,1.5
    1258,5/26/2021 20:36,5041.899,1.4,701,300,10,6001,0,65535,65535,1,23,28150,-298,-297,100,90,11,3488,3888,707,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4031,4031,4027,4012,4018,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.2,991,SUCCESS,,3490.044709,192,0,0.1,0.2,0.3,263,1.4,1.5
    1259,5/26/2021 20:36,5045.904,1.4,701,300,10,6001,0,65535,65535,1,23,28147,-298,-297,100,90,11,3488,3888,702,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4030,4031,4026,4012,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,990,SUCCESS,,3489.713184,192,0,0.1,0.2,0.3,263,1.4,1.5
    1260,5/26/2021 20:36,5049.917,1.4,701,300,10,6001,0,65535,65535,1,23,28147,-296,-297,100,90,11,3488,3888,707,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4030,4031,4026,4012,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,945,SUCCESS,,3489.383226,192,0,0.1,0.2,0.3,263,1.4,1.5
    1261,5/26/2021 20:37,5053.917,1.4,701,300,10,6001,0,65535,65535,1,23,28147,-296,-297,100,90,11,3487,3888,702,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4030,4031,4026,4012,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,976,SUCCESS,,3489.054338,192,0,0.1,0.2,0.3,263,1.4,1.5
    1262,5/26/2021 20:37,5057.919,1.4,701,300,10,6001,0,65535,65535,1,23,28146,-298,-297,100,90,11,3487,3888,697,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4030,4031,4026,4011,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,945,SUCCESS,,3488.723061,192,0,0.1,0.2,0.3,263,1.4,1.5
    1263,5/26/2021 20:37,5061.923,1.41,701,300,10,6001,0,65535,65535,1,23,28146,-296,-297,100,90,11,3487,3888,707,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4030,4031,4026,4012,4013,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,1004,SUCCESS,,3488.393843,192,0,0.1,0.2,0.3,263,1.4,1.5
    1264,5/26/2021 20:37,5065.935,1.41,701,300,10,6001,0,65535,65535,1,23,28145,-296,-297,100,90,11,3486,3888,702,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4024,4030,4031,4026,4011,4014,4010,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,959,SUCCESS,,3488.063968,192,0,0.1,0.2,0.3,263,1.4,1.5
    1265,5/26/2021 20:37,5069.949,1.41,701,300,10,6001,0,65535,65535,1,23,28143,-296,-297,100,90,11,3486,3888,702,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4030,4031,4026,4011,4013,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,963,SUCCESS,,3487.733928,192,0,0.1,0.2,0.3,263,1.4,1.5
    1266,5/26/2021 20:37,5073.962,1.41,701,300,10,6001,0,65535,65535,1,23,28143,-296,-297,100,90,11,3486,3888,707,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4031,4026,4011,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,951,SUCCESS,,3487.40397,192,0,0.1,0.2,0.3,263,1.4,1.5
    1267,5/26/2021 20:37,5077.969,1.41,701,300,10,6001,0,65535,65535,1,23,28143,-300,-297,100,90,11,3485,3888,702,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4031,4026,4010,4013,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,960,SUCCESS,,3487.070053,192,0,0.1,0.2,0.3,263,1.4,1.5
    1268,5/26/2021 20:37,5081.979,1.41,701,300,10,6001,0,65535,65535,1,23,28142,-298,-297,100,90,11,3485,3888,702,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4030,4031,4026,4011,4013,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,984,SUCCESS,,3486.738114,192,0,0.1,0.2,0.3,263,1.4,1.5
    1269,5/26/2021 20:37,5085.982,1.41,701,300,10,6001,0,65535,65535,1,23,28141,-298,-297,100,90,11,3485,3888,706,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4031,4026,4010,4013,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,948,SUCCESS,,3486.406755,192,0,0.1,0.2,0.3,263,1.4,1.5
    1270,5/26/2021 20:37,5089.982,1.41,701,300,10,6001,0,65535,65535,1,23,28139,-296,-297,100,90,11,3484,3888,706,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4030,4025,4010,4013,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,981,SUCCESS,,3486.077866,192,0,0.1,0.2,0.3,263,1.4,1.5
    1271,5/26/2021 20:37,5093.991,1.41,701,300,10,6001,0,65535,65535,1,23,28138,-296,-297,100,90,11,3484,3888,706,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4030,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,981,SUCCESS,,3485.748237,192,0,0.1,0.2,0.3,263,1.4,1.5
    1272,5/26/2021 20:37,5097.996,1.42,701,300,10,6001,0,65535,65535,1,23,28138,-296,-297,100,90,11,3484,3888,706,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4030,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,944,SUCCESS,,3485.418937,192,0,0.1,0.2,0.3,263,1.4,1.5
    1273,5/26/2021 20:37,5102,1.42,701,300,10,6001,0,65535,65535,1,23,28138,-298,-297,100,90,11,3483,3888,701,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4029,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,961,SUCCESS,,3485.087495,192,0,0.1,0.2,0.3,263,1.4,1.5
    1274,5/26/2021 20:37,5106.004,1.42,701,300,10,6001,0,65535,65535,1,23,28138,-296,-297,100,90,11,3483,3888,706,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4030,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,939,SUCCESS,,3484.758277,192,0,0.1,0.2,0.3,263,1.4,1.5
    1275,5/26/2021 20:37,5110.01,1.42,701,300,10,6001,0,65535,65535,1,23,28136,-300,-297,100,90,11,3483,3888,697,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4022,4029,4029,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,955,SUCCESS,,3484.424444,192,0,0.1,0.2,0.3,263,1.4,1.5
    1276,5/26/2021 20:38,5114.01,1.42,701,300,10,6001,0,65535,65535,1,23,28136,-296,-297,100,90,11,3482,3888,706,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4023,4029,4030,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,951,SUCCESS,,3484.095555,192,0,0.1,0.2,0.3,263,1.4,1.5
    1277,5/26/2021 20:38,5118.016,1.42,701,300,10,6001,0,65535,65535,1,23,28133,-298,-297,100,90,11,3482,3888,701,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4022,4028,4029,4025,4010,4012,4009,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,957,SUCCESS,,3483.763947,192,0,0.1,0.2,0.3,263,1.4,1.5
    1278,5/26/2021 20:38,5122.027,1.42,701,300,10,6001,0,65535,65535,1,23,28133,-298,-297,100,90,11,3482,3888,701,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4022,4028,4029,4024,4009,4012,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,947,SUCCESS,,3483.431925,192,0,0.1,0.2,0.3,263,1.4,1.5
    1279,5/26/2021 20:38,5126.033,1.42,701,300,10,6001,0,65535,65535,1,23,28133,-296,-297,100,90,11,3481,3888,706,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4022,4028,4029,4024,4010,4012,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,945,SUCCESS,,3483.102543,192,0,0.1,0.2,0.3,263,1.4,1.5
    1280,5/26/2021 20:38,5130.047,1.43,701,300,10,6001,0,65535,65535,1,23,28132,-296,-297,100,90,11,3481,3888,706,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4022,4028,4029,4024,4010,4012,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,964,SUCCESS,,3482.772503,192,0,0.1,0.2,0.3,263,1.4,1.5
    1281,5/26/2021 20:38,5134.053,1.43,701,300,10,6001,0,65535,65535,1,23,28133,-298,-297,100,90,11,3481,3888,701,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4028,4029,4024,4010,4012,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.3,965,SUCCESS,,3482.440895,192,0,0.1,0.2,0.3,263,1.4,1.5
    1282,5/26/2021 20:38,5138.059,1.43,701,300,10,6001,0,65535,65535,1,23,28131,-296,-297,100,90,11,3480,3888,705,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4028,4029,4024,4009,4011,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,949,SUCCESS,,3482.111513,192,0,0.1,0.2,0.3,263,1.4,1.5
    1283,5/26/2021 20:38,5142.069,1.43,701,300,10,6001,0,65535,65535,1,23,28129,-296,-297,100,90,11,3480,3888,705,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4022,4027,4029,4024,4009,4011,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,972,SUCCESS,,3481.781802,192,0,0.1,0.2,0.3,263,1.4,1.5
    1284,5/26/2021 20:38,5146.079,1.43,701,300,10,6001,0,65535,65535,1,23,28130,-296,-297,100,90,11,3480,3888,705,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4028,4029,4024,4009,4011,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,940,SUCCESS,,3481.452091,192,0,0.1,0.2,0.3,263,1.4,1.5
    1285,5/26/2021 20:38,5150.086,1.43,701,300,10,6001,0,65535,65535,1,23,28129,-298,-296,100,90,11,3479,3888,705,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4029,4024,4009,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,933,SUCCESS,,3481.1204,192,0,0.1,0.2,0.3,263,1.4,1.5
    1286,5/26/2021 20:38,5154.091,1.43,701,300,10,6001,0,65535,65535,1,23,28129,-298,-296,100,90,11,3479,3888,700,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4029,4024,4009,4011,4008,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,967,SUCCESS,,3480.788875,192,0,0.1,0.2,0.3,263,1.4,1.5
    1287,5/26/2021 20:38,5158.097,1.43,701,300,10,6001,0,65535,65535,1,23,28127,-296,-296,100,90,11,3479,3888,705,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4029,4024,4009,4011,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,961,SUCCESS,,3480.459493,192,0,0.1,0.2,0.3,263,1.4,1.5
    1288,5/26/2021 20:38,5162.097,1.43,701,300,10,6001,0,65535,65535,1,23,28125,-296,-296,100,90,11,3478,3888,700,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4028,4023,4009,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,953,SUCCESS,,3480.130604,192,0,0.1,0.2,0.3,263,1.4,1.5
    1289,5/26/2021 20:38,5166.11,1.44,701,300,10,6001,0,65535,65535,1,23,28125,-300,-297,100,90,11,3478,3888,700,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4028,4023,4008,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,945,SUCCESS,,3479.796188,192,0,0.1,0.2,0.3,263,1.4,1.5
    1290,5/26/2021 20:38,5170.118,1.44,701,300,10,6001,0,65535,65535,1,23,28125,-296,-296,100,90,11,3478,3888,710,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4028,4023,4009,4011,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,943,SUCCESS,,3479.466641,192,0,0.1,0.2,0.3,263,1.4,1.5
    1291,5/26/2021 20:39,5174.126,1.44,701,300,10,6001,0,65535,65535,1,23,28125,-296,-297,100,90,11,3477,3888,705,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4028,4023,4009,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,945,SUCCESS,,3479.137094,192,0,0.1,0.2,0.3,263,1.4,1.5
    1292,5/26/2021 20:39,5178.133,1.44,701,300,10,6001,0,65535,65535,1,23,28125,-298,-297,100,90,11,3477,3888,700,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4028,4023,4008,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,996,SUCCESS,,3478.805404,192,0,0.1,0.2,0.3,263,1.4,1.5
    1293,5/26/2021 20:39,5182.137,1.44,701,300,10,6001,0,65535,65535,1,23,28124,-298,-297,100,90,11,3477,3888,700,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4021,4027,4028,4023,4008,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,983,SUCCESS,,3478.473961,192,0,0.1,0.2,0.3,263,1.4,1.5
    1294,5/26/2021 20:39,5186.145,1.44,701,300,10,6001,0,65535,65535,1,23,28124,-296,-297,100,90,11,3476,3888,695,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4027,4028,4023,4008,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.8,969,SUCCESS,,3478.144415,192,0,0.1,0.2,0.3,263,1.4,1.5
    1295,5/26/2021 20:39,5190.151,1.44,701,300,10,6001,0,65535,65535,1,23,28123,-298,-297,100,90,11,3476,3888,700,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4023,4008,4010,4007,0,0,0,0,0,0,0,0,2808,22.8,23,-273.2,23,-273.2,22.5,946,SUCCESS,,3477.812807,192,0,0.1,0.2,0.3,263,1.4,1.5
    1296,5/26/2021 20:39,5194.172,1.44,701,300,10,6001,0,65535,65535,1,23,28121,-296,-296,100,90,11,3476,3888,705,705,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4023,4008,4010,4007,0,0,0,0,0,0,0,0,2811,22.8,23,-273.2,23,-273.2,22.9,939,SUCCESS,,3477.482191,192,0,0.1,0.2,0.3,263,1.4,1.5
    1297,5/26/2021 20:39,5198.209,1.44,701,300,10,6001,0,65535,65535,1,23,28119,-296,-297,100,90,11,3475,3888,704,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4023,4008,4010,4006,0,0,0,0,0,0,0,0,2810,22.8,23,-273.2,23,-273.2,22.9,968,SUCCESS,,3477.15026,192,0,0.1,0.2,0.3,263,1.4,1.5
    1298,5/26/2021 20:39,5202.203,1.45,701,300,10,6001,0,65535,65535,1,23,28120,-296,-296,100,90,11,3475,3888,709,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4023,4007,4010,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,939,SUCCESS,,3476.821865,192,0,0.1,0.2,0.3,263,1.4,1.5
    1299,5/26/2021 20:39,5206.205,1.45,701,300,10,6001,0,65535,65535,1,23,28119,-296,-296,100,90,11,3475,3888,700,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4022,4008,4010,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,940,SUCCESS,,3476.492811,192,0,0.1,0.2,0.3,263,1.4,1.5
    1300,5/26/2021 20:39,5210.224,1.45,701,300,10,6001,0,65535,65535,1,23,28117,-296,-296,100,90,11,3474,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4022,4007,4010,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,973,SUCCESS,,3476.16236,192,0,0.1,0.2,0.3,263,1.4,1.5
    1301,5/26/2021 20:39,5214.25,1.45,701,300,10,6001,0,65535,65535,1,23,28118,-296,-296,100,90,11,3474,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4022,4007,4009,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,960,SUCCESS,,3475.831334,192,0,0.1,0.2,0.3,263,1.4,1.5
    1302,5/26/2021 20:39,5218.251,1.45,701,300,10,6001,0,65535,65535,1,23,28117,-296,-296,100,90,11,3474,3888,699,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4022,4007,4010,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,978,SUCCESS,,3475.502363,192,0,0.1,0.2,0.3,263,1.4,1.5
    1303,5/26/2021 20:39,5222.272,1.45,701,300,10,6001,0,65535,65535,1,23,28117,-296,-296,100,90,11,3473,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4019,4026,4027,4022,4007,4009,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,948,SUCCESS,,3475.171747,192,0,0.1,0.2,0.3,263,1.4,1.5
    1304,5/26/2021 20:39,5226.283,1.45,701,300,10,6001,0,65535,65535,1,23,28117,-296,-296,100,90,11,3473,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4022,4007,4009,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,987,SUCCESS,,3474.841954,192,0,0.1,0.2,0.3,263,1.4,1.5
    1305,5/26/2021 20:39,5230.298,1.45,701,300,10,6001,0,65535,65535,1,23,28118,-296,-296,100,90,11,3473,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4020,4026,4027,4022,4007,4009,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,938,SUCCESS,,3474.511831,192,0,0.1,0.2,0.3,263,1.4,1.5
    1306,5/26/2021 20:40,5234.299,1.45,701,300,10,6001,0,65535,65535,1,23,28114,-296,-296,100,90,11,3472,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4019,4026,4027,4021,4007,4009,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,954,SUCCESS,,3474.18286,192,0,0.1,0.2,0.3,263,1.4,1.5
    1307,5/26/2021 20:40,5238.312,1.46,701,300,10,6001,0,65535,65535,1,23,28113,-296,-296,100,90,11,3472,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4019,4025,4026,4021,4007,4009,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,956,SUCCESS,,3473.852903,192,0,0.1,0.2,0.3,263,1.4,1.5
    1308,5/26/2021 20:40,5242.328,1.46,701,300,10,6001,0,65535,65535,1,23,28113,-296,-296,100,90,11,3472,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4025,4026,4021,4007,4009,4006,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,975,SUCCESS,,3473.522698,192,0,0.1,0.2,0.3,263,1.4,1.5
    1309,5/26/2021 20:40,5246.35,1.46,701,300,10,6001,0,65535,65535,1,23,28112,-296,-296,100,90,11,3471,3888,704,704,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4019,4025,4026,4021,4007,4009,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,935,SUCCESS,,3473.192,192,0,0.1,0.2,0.3,263,1.4,1.5
    1310,5/26/2021 20:40,5250.359,1.46,701,300,10,6001,0,65535,65535,1,23,28110,-296,-297,100,90,11,3471,3888,704,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4019,4025,4026,4021,4006,4009,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,959,SUCCESS,,3472.862371,192,0,0.1,0.2,0.3,263,1.4,1.5
    1311,5/26/2021 20:40,5254.301,1.46,701,300,10,6001,0,65535,65535,1,23,28114,-296,-297,100,90,11,3471,3888,704,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4019,4025,4026,4021,4006,4009,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,936,SUCCESS,,3472.538251,192,0,0.1,0.2,0.3,263,1.4,1.5
    1312,5/26/2021 20:40,5258.313,1.46,701,300,10,6001,0,65535,65535,1,23,28109,-300,-297,100,90,11,3470,3888,694,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4025,4026,4021,4006,4008,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,1034,SUCCESS,,3472.203918,192,0,0.1,0.2,0.3,263,1.4,1.5
    1313,5/26/2021 20:40,5262.327,1.46,701,300,10,6001,0,65535,65535,1,23,28108,-296,-297,100,90,11,3470,3888,703,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4025,4026,4021,4006,4008,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,956,SUCCESS,,3471.873878,192,0,0.1,0.2,0.3,263,1.4,1.5
    1314,5/26/2021 20:40,5266.329,1.46,701,300,10,6001,0,65535,65535,1,23,28109,-294,-297,100,90,11,3470,3888,708,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4025,4026,4021,4006,4009,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.7,968,SUCCESS,,3471.547048,192,0,0.1,0.2,0.3,263,1.4,1.5
    1315,5/26/2021 20:40,5270.335,1.46,701,300,10,6001,0,65535,65535,1,23,28108,-296,-296,100,90,11,3469,3888,703,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4026,4021,4006,4008,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,1003,SUCCESS,,3471.217666,192,0,0.1,0.2,0.3,263,1.4,1.5
    1316,5/26/2021 20:40,5274.336,1.47,701,300,10,6001,0,65535,65535,1,23,28107,-296,-297,100,90,11,3469,3888,703,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4026,4021,4006,4008,4005,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,962,SUCCESS,,3470.888695,192,0,0.1,0.2,0.3,263,1.4,1.5
    1317,5/26/2021 20:40,5278.342,1.47,701,300,10,6001,0,65535,65535,1,23,28105,-298,-297,100,90,11,3469,3888,698,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4025,4021,4006,4008,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,957,SUCCESS,,3470.557087,192,0,0.1,0.2,0.3,263,1.4,1.5
    1318,5/26/2021 20:40,5282.346,1.47,701,300,10,6001,0,65535,65535,1,23,28105,-298,-297,100,90,11,3468,3888,698,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4025,4020,4006,4007,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,971,SUCCESS,,3470.225645,192,0,0.1,0.2,0.3,263,1.4,1.5
    1319,5/26/2021 20:40,5286.357,1.47,701,300,10,6001,0,65535,65535,1,23,28104,-298,-297,100,90,11,3468,3888,703,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4025,4020,4006,4007,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,942,SUCCESS,,3469.893623,192,0,0.1,0.2,0.3,263,1.4,1.5
    1320,5/26/2021 20:40,5290.365,1.47,701,300,10,6001,0,65535,65535,1,23,28103,-298,-296,100,90,11,3468,3888,703,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4025,4020,4005,4007,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,973,SUCCESS,,3469.56185,192,0,0.1,0.2,0.3,263,1.4,1.5
    1321,5/26/2021 20:41,5294.373,1.47,701,300,10,6001,0,65535,65535,1,23,28103,-296,-297,100,90,11,3467,3888,703,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4025,4020,4005,4007,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,941,SUCCESS,,3469.232303,192,0,0.1,0.2,0.3,263,1.4,1.5
    1322,5/26/2021 20:41,5298.374,1.47,701,300,10,6001,0,65535,65535,1,23,28103,-296,-296,100,90,11,3467,3888,703,703,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4024,4025,4020,4005,4006,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,964,SUCCESS,,3468.903332,192,0,0.1,0.2,0.3,263,1.4,1.5
    1323,5/26/2021 20:41,5302.378,1.47,701,300,10,6001,0,65535,65535,1,23,28103,-298,-297,100,90,11,3467,3888,703,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4018,4024,4025,4020,4005,4007,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,943,SUCCESS,,3468.57189,192,0,0.1,0.2,0.3,263,1.4,1.5
    1324,5/26/2021 20:41,5306.39,1.47,701,300,10,6001,0,65535,65535,1,23,28101,-296,-297,100,90,11,3466,3888,703,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4020,4005,4007,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,947,SUCCESS,,3468.242014,192,0,0.1,0.2,0.3,263,1.4,1.5
    1325,5/26/2021 20:41,5310.398,1.48,701,300,10,6001,0,65535,65535,1,23,28100,-296,-297,100,90,11,3466,3888,703,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4020,4005,4007,4004,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,943,SUCCESS,,3467.912468,192,0,0.1,0.2,0.3,263,1.4,1.5
    1326,5/26/2021 20:41,5314.406,1.48,701,300,10,6001,0,65535,65535,1,23,28098,-296,-297,100,90,11,3466,3888,703,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4020,4005,4007,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,940,SUCCESS,,3467.582921,192,0,0.1,0.2,0.3,263,1.4,1.5
    1327,5/26/2021 20:41,5318.413,1.48,701,300,10,6001,0,65535,65535,1,23,28098,-296,-297,100,90,11,3465,3888,702,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4019,4004,4006,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,939,SUCCESS,,3467.253456,192,0,0.1,0.2,0.3,263,1.4,1.5
    1328,5/26/2021 20:41,5322.427,1.48,701,300,10,6001,0,65535,65535,1,23,28096,-298,-297,100,90,11,3465,3888,698,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4019,4004,4003,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,937,SUCCESS,,3466.921186,192,0,0.1,0.2,0.3,263,1.4,1.5
    1329,5/26/2021 20:41,5326.442,1.48,701,300,10,6001,0,65535,65535,1,23,28096,-298,-297,100,90,11,3465,3888,698,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4019,4004,4006,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.5,961,SUCCESS,,3466.588834,192,0,0.1,0.2,0.3,263,1.4,1.5
    1330,5/26/2021 20:41,5330.447,1.48,701,300,10,6001,0,65535,65535,1,23,28096,-296,-297,100,90,11,3464,3888,702,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4017,4023,4024,4019,4004,4006,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,976,SUCCESS,,3466.259534,192,0,0.1,0.2,0.3,263,1.4,1.5
    1331,5/26/2021 20:41,5334.456,1.48,701,300,10,6001,0,65535,65535,1,23,28095,-296,-297,100,90,11,3464,3888,697,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4023,4024,4019,4004,4006,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,971,SUCCESS,,3465.929905,192,0,0.1,0.2,0.3,263,1.4,1.5
    1332,5/26/2021 20:41,5338.47,1.48,701,300,10,6001,0,65535,65535,1,23,28095,-298,-297,100,90,11,3464,3888,702,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4023,4024,4018,4004,4006,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,962,SUCCESS,,3465.597635,192,0,0.1,0.2,0.3,263,1.4,1.5
    1333,5/26/2021 20:41,5342.476,1.48,701,300,10,6001,0,65535,65535,1,23,28094,-294,-297,100,90,11,3463,3888,707,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4023,4024,4019,4004,4006,4003,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,984,SUCCESS,,3465.270478,192,0,0.1,0.2,0.3,263,1.4,1.5
    1334,5/26/2021 20:41,5346.485,1.49,701,300,10,6001,0,65535,65535,1,23,28094,-296,-297,100,90,11,3463,3888,702,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4023,4023,4019,4004,4004,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,944,SUCCESS,,3464.940849,192,0,0.1,0.2,0.3,263,1.4,1.5
    1335,5/26/2021 20:41,5350.499,1.49,701,300,10,6001,0,65535,65535,1,23,28093,-296,-297,100,90,11,3463,3888,702,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4023,4023,4018,4004,4006,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,943,SUCCESS,,3464.610809,192,0,0.1,0.2,0.3,263,1.4,1.5
    1336,5/26/2021 20:42,5354.508,1.49,701,300,10,6001,0,65535,65535,1,23,28092,-296,-296,100,90,11,3462,3888,702,702,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4022,4023,4018,4003,4006,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,977,SUCCESS,,3464.28118,192,0,0.1,0.2,0.3,263,1.4,1.5
    1337,5/26/2021 20:42,5358.516,1.49,701,300,10,6001,0,65535,65535,1,23,28092,-296,-297,100,90,11,3462,3888,697,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4022,4023,4018,4004,4006,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,943,SUCCESS,,3463.951634,192,0,0.1,0.2,0.3,263,1.4,1.5
    1338,5/26/2021 20:42,5362.519,1.49,701,300,10,6001,0,65535,65535,1,23,28091,-298,-297,100,90,11,3462,3888,702,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4022,4023,4018,4004,4005,4002,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.9,968,SUCCESS,,3463.620274,192,0,0.1,0.2,0.3,263,1.4,1.5
    1339,5/26/2021 20:42,5366.523,1.49,701,300,10,6001,0,65535,65535,1,23,28091,-296,-297,100,90,11,3461,3888,697,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4016,4022,4023,4018,4003,4005,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,933,SUCCESS,,3463.291056,192,0,0.1,0.2,0.3,263,1.4,1.5
    1340,5/26/2021 20:42,5370.527,1.49,701,300,10,6001,0,65535,65535,1,23,28090,-294,-297,100,90,11,3461,3888,697,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4022,4023,4018,4003,4005,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,961,SUCCESS,,3462.964063,192,0,0.1,0.2,0.3,263,1.4,1.5
    1341,5/26/2021 20:42,5374.543,1.49,701,300,10,6001,0,65535,65535,1,23,28088,-296,-297,100,90,11,3461,3888,702,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4022,4023,4018,4003,4005,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,950,SUCCESS,,3462.633859,192,0,0.1,0.2,0.3,263,1.4,1.5
    1342,5/26/2021 20:42,5378.543,1.49,701,300,10,6001,0,65535,65535,1,23,28088,-296,-297,100,89,11,3460,3888,697,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4022,4023,4018,4003,4005,4001,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,946,SUCCESS,,3462.30497,192,0,0.1,0.2,0.3,263,1.4,1.5
    1343,5/26/2021 20:42,5382.548,1.5,701,300,10,6001,0,65535,65535,1,23,28089,-296,-297,100,89,11,3460,3888,701,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4022,4023,4018,4003,4005,4001,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.9,963,SUCCESS,,3461.97567,192,0,0.1,0.2,0.3,263,1.4,1.5
    1344,5/26/2021 20:42,5386.549,1.5,701,300,10,6001,0,65535,65535,1,23,28088,-296,-297,100,89,11,3460,3888,701,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4021,4023,4018,4003,4004,4002,0,0,0,0,0,0,0,0,2807,22.8,23,-273.2,23,-273.2,22.8,941,SUCCESS,,3461.646699,192,0,0.1,0.2,0.3,263,1.4,1.5
    1345,5/26/2021 20:42,5390.552,1.5,701,300,10,6001,0,65535,65535,1,23,28086,-296,-297,100,89,11,3459,3888,701,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4021,4023,4018,4003,4005,4002,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,979,SUCCESS,,3461.317563,192,0,0.1,0.2,0.3,263,1.4,1.5
    1346,5/26/2021 20:42,5394.557,1.5,701,300,10,6001,0,65535,65535,1,23,28084,-296,-297,100,89,11,3459,3888,701,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4021,4022,4017,4003,4005,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,976,SUCCESS,,3460.988263,192,0,0.1,0.2,0.3,263,1.4,1.5
    1347,5/26/2021 20:42,5398.559,1.5,701,300,10,6001,0,65535,65535,1,23,28083,-296,-296,100,89,11,3459,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4021,4022,4017,4003,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,967,SUCCESS,,3460.65921,192,0,0.1,0.2,0.3,263,1.4,1.5
    1348,5/26/2021 20:42,5402.572,1.5,701,300,10,6001,0,65535,65535,1,23,28084,-298,-297,100,89,11,3458,3888,696,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4021,4022,4017,4003,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,1009,SUCCESS,,3460.327023,192,0,0.1,0.2,0.3,263,1.4,1.5
    1349,5/26/2021 20:42,5406.587,1.5,701,300,10,6001,0,65535,65535,1,23,28083,-296,-296,100,89,11,3458,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4015,4021,4022,4017,4003,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,954,SUCCESS,,3459.9969,192,0,0.1,0.2,0.3,263,1.4,1.5
    1350,5/26/2021 20:42,5410.591,1.5,701,300,10,6001,0,65535,65535,1,23,28081,-296,-296,100,89,11,3458,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4021,4022,4017,4002,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.7,966,SUCCESS,,3459.667683,192,0,0.1,0.2,0.3,263,1.4,1.5
    1351,5/26/2021 20:43,5414.6,1.5,701,300,10,6001,0,65535,65535,1,23,28081,-296,-296,100,89,11,3457,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4021,4021,4017,4002,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.9,975,SUCCESS,,3459.338054,192,0,0.1,0.2,0.3,263,1.4,1.5
    1352,5/26/2021 20:43,5418.608,1.51,701,300,10,6001,0,65535,65535,1,23,28080,-296,-296,100,89,11,3457,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4017,4002,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,940,SUCCESS,,3459.008507,192,0,0.1,0.2,0.3,263,1.4,1.5
    1353,5/26/2021 20:43,5422.615,1.51,701,300,10,6001,0,65535,65535,1,22.9,28079,-296,-296,100,89,11,3457,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4017,4002,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,22.9,-273.2,22.9,-273.2,22.8,970,SUCCESS,,3458.679043,192,0,0.1,0.2,0.3,263,1.4,1.5
    1354,5/26/2021 20:43,5426.625,1.51,701,300,10,6001,0,65535,65535,1,22.9,28079,-296,-296,100,89,11,3456,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4017,4002,4004,4001,0,0,0,0,0,0,0,0,2807,22.7,22.9,-273.2,22.9,-273.2,22.8,977,SUCCESS,,3458.349331,192,0,0.1,0.2,0.3,263,1.4,1.5
    1355,5/26/2021 20:43,5430.634,1.51,701,300,10,6001,0,65535,65535,1,23,28078,-298,-296,100,89,11,3456,3888,696,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4016,4002,4004,4001,0,0,0,0,0,0,0,0,2803,22.7,23,-273.2,23,-273.2,22.8,992,SUCCESS,,3458.017475,192,0,0.1,0.2,0.3,263,1.4,1.5
    1356,5/26/2021 20:43,5434.641,1.51,701,300,10,6001,0,65535,65535,1,22.9,28076,-296,-296,100,89,11,3456,3888,701,701,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4016,4002,4004,4000,0,0,0,0,0,0,0,0,2807,22.7,22.9,-273.2,22.9,-273.2,22.1,963,SUCCESS,,3457.688011,192,0,0.1,0.2,0.3,263,1.4,1.5
    1357,5/26/2021 20:43,5438.651,1.51,701,300,10,6001,0,65535,65535,1,22.9,28076,-294,-296,100,89,11,3455,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4016,4001,4003,4000,0,0,0,0,0,0,0,0,2807,22.7,22.9,-273.2,22.9,-273.2,22.9,993,SUCCESS,,3457.360528,192,0,0.1,0.2,0.3,263,1.4,1.5
    1358,5/26/2021 20:43,5442.653,1.51,701,300,10,6001,0,65535,65535,1,23,28076,-296,-296,100,89,11,3455,3888,696,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4016,4002,4004,4000,0,0,0,0,0,0,0,0,2807,22.7,23,-273.2,23,-273.2,22.8,951,SUCCESS,,3457.031474,192,0,0.1,0.2,0.3,263,1.4,1.5
    1359,5/26/2021 20:43,5446.661,1.51,701,300,10,6001,0,65535,65535,1,22.9,28075,-296,-296,100,89,11,3455,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4016,4001,4003,4000,0,0,0,0,0,0,0,0,2803,22.7,22.9,-273.2,22.9,-273.2,22.8,935,SUCCESS,,3456.701928,192,0,0.1,0.2,0.3,263,1.4,1.5
    1360,5/26/2021 20:43,5450.675,1.51,701,300,10,6001,0,65535,65535,1,22.9,28075,-296,-296,100,89,11,3454,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4014,4020,4021,4016,4001,4003,4000,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,970,SUCCESS,,3456.371888,192,0,0.1,0.2,0.3,263,1.4,1.5
    1361,5/26/2021 20:43,5454.678,1.52,701,300,10,6001,0,65535,65535,1,23,28074,-298,-296,100,89,11,3454,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4020,4021,4016,4001,4003,4000,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,23,-273.2,22.9,959,SUCCESS,,3456.040528,192,0,0.1,0.2,0.3,263,1.4,1.5
    1362,5/26/2021 20:43,5458.683,1.52,701,300,10,6001,0,65535,65535,1,22.9,28072,-296,-296,100,89,11,3454,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4020,4021,4016,4001,4003,4000,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,945,SUCCESS,,3455.711228,192,0,0.1,0.2,0.3,263,1.4,1.5
    1363,5/26/2021 20:43,5462.689,1.52,701,300,10,6001,0,65535,65535,1,22.9,28072,-296,-296,100,89,11,3453,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4020,4020,4016,4001,4003,4000,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,941,SUCCESS,,3455.381846,192,0,0.1,0.2,0.3,263,1.4,1.5
    1364,5/26/2021 20:43,5466.701,1.52,701,300,10,6001,0,65535,65535,1,23,28072,-296,-296,100,89,11,3453,3888,705,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4020,4020,4015,4001,4003,4000,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,964,SUCCESS,,3455.05197,192,0,0.1,0.2,0.3,263,1.4,1.5
    1365,5/26/2021 20:43,5470.709,1.52,701,300,10,6001,0,65535,65535,1,22.9,28071,-296,-296,100,89,11,3453,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4019,4020,4015,4001,4003,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,957,SUCCESS,,3454.722424,192,0,0.1,0.2,0.3,263,1.4,1.5
    1366,5/26/2021 20:44,5474.723,1.52,701,300,10,6001,0,65535,65535,1,22.9,28071,-296,-296,100,89,11,3452,3888,704,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4019,4020,4015,4001,4002,4000,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.9,976,SUCCESS,,3454.392384,192,0,0.1,0.2,0.3,263,1.4,1.5
    1367,5/26/2021 20:44,5478.726,1.52,701,300,10,6001,0,65535,65535,1,23,28069,-298,-296,100,89,11,3452,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4013,4019,4020,4015,4001,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.9,985,SUCCESS,,3454.061024,192,0,0.1,0.2,0.3,263,1.4,1.5
    1368,5/26/2021 20:44,5482.727,1.52,701,300,10,6001,0,65535,65535,1,22.9,28067,-298,-296,100,89,11,3452,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4019,4020,4015,4000,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,23,-273.2,23,-273.2,22.9,970,SUCCESS,,3453.72983,192,0,0.1,0.2,0.3,263,1.4,1.5
    1369,5/26/2021 20:44,5486.728,1.52,701,300,10,6001,0,65535,65535,1,22.9,28067,-298,-296,100,89,11,3451,3888,695,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4019,4020,4015,4000,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.9,982,SUCCESS,,3453.398636,192,0,0.1,0.2,0.3,263,1.4,1.5
    1370,5/26/2021 20:44,5490.74,1.53,701,300,10,6001,0,65535,65535,1,22.9,28069,-296,-296,100,89,11,3451,3888,700,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4019,4020,4015,4000,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.7,948,SUCCESS,,3453.068761,192,0,0.1,0.2,0.3,263,1.4,1.5
    1371,5/26/2021 20:44,5494.747,1.53,701,300,10,6001,0,65535,65535,1,22.9,28067,-296,-296,100,89,11,3451,3888,704,700,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4019,4020,4015,4000,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,949,SUCCESS,,3452.739296,192,0,0.1,0.2,0.3,263,1.4,1.5
    1372,5/26/2021 20:44,5498.75,1.53,701,300,10,6001,0,65535,65535,1,22.9,28064,-296,-296,100,89,11,3450,3888,699,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4020,4015,4000,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,965,SUCCESS,,3452.410161,192,0,0.1,0.2,0.3,263,1.4,1.5
    1373,5/26/2021 20:44,5502.757,1.53,701,300,10,6001,0,65535,65535,1,22.9,28066,-296,-296,100,89,11,3450,3888,695,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4020,4015,4000,4002,3999,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,953,SUCCESS,,3452.080696,192,0,0.1,0.2,0.3,263,1.4,1.5
    1374,5/26/2021 20:44,5506.769,1.53,701,300,10,6001,0,65535,65535,1,22.9,28064,-296,-296,100,89,11,3450,3888,695,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4020,4014,4000,4001,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,951,SUCCESS,,3451.750821,192,0,0.1,0.2,0.3,263,1.4,1.5
    1375,5/26/2021 20:44,5510.777,1.53,701,300,10,6001,0,65535,65535,1,22.9,28061,-296,-296,100,89,11,3450,3888,699,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4019,4014,4000,4003,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3451.421274,192,0,0.1,0.2,0.3,263,1.4,1.5
    1376,5/26/2021 20:44,5514.784,1.53,701,300,10,6001,0,65535,65535,1,22.9,28062,-298,-296,100,89,11,3449,3888,699,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4019,4014,4000,4001,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,939,SUCCESS,,3451.089584,192,0,0.1,0.2,0.3,263,1.4,1.5
    1377,5/26/2021 20:44,5518.793,1.53,701,300,10,6001,0,65535,65535,1,22.9,28062,-298,-297,100,89,11,3449,3888,694,697,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4019,4014,4000,4001,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,959,SUCCESS,,3450.757728,192,0,0.1,0.2,0.3,263,1.4,1.5
    1378,5/26/2021 20:44,5522.802,1.53,701,300,10,6001,0,65535,65535,1,22.9,28059,-298,-297,100,89,11,3449,3888,690,697,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4019,4014,3999,4001,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,951,SUCCESS,,3450.425871,192,0,0.1,0.2,0.3,263,1.4,1.5
    1379,5/26/2021 20:44,5526.812,1.54,701,300,10,6001,0,65535,65535,1,22.9,28060,-296,-297,100,89,11,3448,3888,699,697,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4019,4014,3999,4001,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,941,SUCCESS,,3450.09616,192,0,0.1,0.2,0.3,263,1.4,1.5
    1380,5/26/2021 20:44,5530.814,1.54,701,300,10,6001,0,65535,65535,1,22.9,28060,-296,-297,100,89,11,3448,3888,699,697,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4012,4018,4018,4014,3999,4001,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,945,SUCCESS,,3449.767107,192,0,0.1,0.2,0.3,263,1.4,1.5
    1381,5/26/2021 20:45,5534.817,1.54,701,300,10,6001,0,65535,65535,1,22.9,28059,-296,-297,100,89,11,3448,3888,699,697,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4011,4018,4018,4014,3999,4000,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,953,SUCCESS,,3449.437971,192,0,0.1,0.2,0.3,263,1.4,1.5
    1382,5/26/2021 20:45,5538.819,1.54,701,300,10,6001,0,65535,65535,1,22.9,28059,-298,-296,100,89,11,3447,3888,699,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4011,4017,4019,4014,3999,4000,3998,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,953,SUCCESS,,3449.106695,192,0,0.1,0.2,0.3,263,1.4,1.5
    1383,5/26/2021 20:45,5542.828,1.54,701,300,10,6001,0,65535,65535,1,22.9,28056,-296,-296,100,89,11,3447,3888,694,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4011,4017,4018,4013,3999,4001,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,947,SUCCESS,,3448.777066,192,0,0.1,0.2,0.3,263,1.4,1.5
    1384,5/26/2021 20:45,5546.831,1.54,701,300,10,6001,0,65535,65535,1,22.9,28055,-294,-296,100,89,11,3447,3888,703,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4011,4017,4018,4013,3999,4001,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.5,970,SUCCESS,,3448.450154,192,0,0.1,0.2,0.3,263,1.4,1.5
    1385,5/26/2021 20:45,5550.836,1.54,701,300,10,6001,0,65535,65535,1,22.9,28054,-298,-296,100,89,11,3446,3888,694,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4011,4017,4018,4013,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,966,SUCCESS,,3448.118629,192,0,0.1,0.2,0.3,263,1.4,1.5
    1386,5/26/2021 20:45,5554.852,1.54,701,300,10,6001,0,65535,65535,1,22.9,28054,-296,-296,100,89,11,3446,3888,699,699,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4017,4018,4013,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,987,SUCCESS,,3447.788425,192,0,0.1,0.2,0.3,263,1.4,1.5
    1387,5/26/2021 20:45,5558.863,1.54,701,300,10,6001,0,65535,65535,1,22.9,28054,-298,-296,100,89,11,3445,3888,694,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4017,4018,4013,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,935,SUCCESS,,3447.456403,192,0,0.1,0.2,0.3,263,1.4,1.5
    1388,5/26/2021 20:45,5562.867,1.55,701,300,10,6001,0,65535,65535,1,22.9,28053,-298,-296,100,89,11,3445,3888,694,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4017,4018,4013,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,932,SUCCESS,,3447.124961,192,0,0.1,0.2,0.3,263,1.4,1.5
    1389,5/26/2021 20:45,5566.872,1.55,701,300,10,6001,0,65535,65535,1,22.9,28053,-296,-296,100,89,11,3445,3888,698,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4017,4018,4013,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,943,SUCCESS,,3446.795661,192,0,0.1,0.2,0.3,263,1.4,1.5
    1390,5/26/2021 20:45,5570.884,1.55,701,300,10,6001,0,65535,65535,1,22.9,28053,-296,-296,100,89,11,3444,3888,698,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4017,4018,4013,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,963,SUCCESS,,3446.465785,192,0,0.1,0.2,0.3,263,1.4,1.5
    1391,5/26/2021 20:45,5574.885,1.55,701,300,10,6001,0,65535,65535,1,22.9,28053,-296,-297,100,89,11,3444,3888,698,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4017,4017,4012,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,961,SUCCESS,,3446.136814,192,0,0.1,0.2,0.3,263,1.4,1.5
    1392,5/26/2021 20:45,5578.89,1.55,701,300,10,6001,0,65535,65535,1,22.9,28051,-296,-296,100,89,11,3444,3888,698,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4016,4017,4012,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,941,SUCCESS,,3445.807514,192,0,0.1,0.2,0.3,263,1.4,1.5
    1393,5/26/2021 20:45,5582.898,1.55,701,300,10,6001,0,65535,65535,1,22.9,28050,-296,-296,100,89,11,3444,3888,698,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4016,4017,4012,3998,4000,3997,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.9,932,SUCCESS,,3445.477968,192,0,0.1,0.2,0.3,263,1.4,1.5
    1394,5/26/2021 20:45,5586.91,1.55,701,300,10,6001,0,65535,65535,1,22.9,28048,-296,-297,100,89,11,3443,3888,698,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4016,4017,4012,3998,3999,3996,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,950,SUCCESS,,3445.148092,192,0,0.1,0.2,0.3,263,1.4,1.5
    1395,5/26/2021 20:45,5590.922,1.55,701,300,10,6001,0,65535,65535,1,22.9,28047,-296,-297,100,89,11,3443,3888,698,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4016,4017,4012,3997,3999,3996,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,960,SUCCESS,,3444.818216,192,0,0.1,0.2,0.3,263,1.4,1.5
    1396,5/26/2021 20:46,5594.924,1.55,701,300,10,6001,0,65535,65535,1,22.9,28046,-296,-297,100,89,11,3443,3888,693,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4016,4017,4012,3997,3999,3996,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,939,SUCCESS,,3444.489163,192,0,0.1,0.2,0.3,263,1.4,1.5
    1397,5/26/2021 20:46,5598.926,1.56,701,300,10,6001,0,65535,65535,1,22.9,28046,-296,-297,100,89,11,3442,3888,698,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4010,4016,4017,4012,3997,3999,3996,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,952,SUCCESS,,3444.16011,192,0,0.1,0.2,0.3,263,1.4,1.5
    1398,5/26/2021 20:46,5602.93,1.56,701,300,10,6001,0,65535,65535,1,22.9,28046,-298,-296,100,89,11,3442,3888,698,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4016,4017,4012,3997,3998,3996,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,978,SUCCESS,,3443.828668,192,0,0.1,0.2,0.3,263,1.4,1.5
    1399,5/26/2021 20:46,5606.933,1.56,701,300,10,6001,0,65535,65535,1,22.9,28046,-296,-297,100,89,11,3442,3888,693,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4016,4017,4012,3997,4001,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,947,SUCCESS,,3443.499532,192,0,0.1,0.2,0.3,263,1.4,1.5
    1400,5/26/2021 20:46,5610.946,1.56,701,300,10,6001,0,65535,65535,1,22.9,28043,-296,-296,100,89,11,3441,3888,702,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4017,4012,3997,3999,3996,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,950,SUCCESS,,3443.169574,192,0,0.1,0.2,0.3,263,1.4,1.5
    1401,5/26/2021 20:46,5614.949,1.56,701,300,10,6001,0,65535,65535,1,22.9,28044,-298,-296,100,89,11,3441,3888,698,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4017,4012,3997,3998,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,945,SUCCESS,,3442.838215,192,0,0.1,0.2,0.3,263,1.4,1.5
    1402,5/26/2021 20:46,5618.962,1.56,701,300,10,6001,0,65535,65535,1,22.9,28043,-298,-296,100,89,11,3441,3888,702,698,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4017,4011,3997,4002,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,1016,SUCCESS,,3442.506028,192,0,0.1,0.2,0.3,263,1.4,1.5
    1403,5/26/2021 20:46,5622.965,1.56,701,300,10,6001,0,65535,65535,1,22.9,28041,-296,-296,100,89,11,3440,3888,697,697,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4016,4011,3997,3998,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,975,SUCCESS,,3442.176892,192,0,0.1,0.2,0.3,263,1.4,1.5
    1404,5/26/2021 20:46,5626.979,1.56,701,300,10,6001,0,65535,65535,1,22.9,28040,-298,-297,100,89,11,3440,3888,697,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4016,4011,3996,3998,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,967,SUCCESS,,3441.844622,192,0,0.1,0.2,0.3,263,1.4,1.5
    1405,5/26/2021 20:46,5630.983,1.56,701,300,10,6001,0,65535,65535,1,22.9,28041,-294,-297,100,89,11,3440,3888,702,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4016,4011,3996,4002,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,940,SUCCESS,,3441.517629,192,0,0.1,0.2,0.3,263,1.4,1.5
    1406,5/26/2021 20:46,5634.996,1.57,701,300,10,6001,0,65535,65535,1,22.9,28040,-298,-297,100,89,11,3439,3888,692,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4016,4011,3996,3998,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,959,SUCCESS,,3441.185441,192,0,0.1,0.2,0.3,263,1.4,1.5
    1407,5/26/2021 20:46,5639.001,1.57,701,300,10,6001,0,65535,65535,1,22.9,28039,-298,-297,100,89,11,3439,3888,692,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4009,4015,4016,4011,3996,3998,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.5,949,SUCCESS,,3440.853916,192,0,0.1,0.2,0.3,263,1.4,1.5
    1408,5/26/2021 20:46,5643.006,1.57,701,300,10,6001,0,65535,65535,1,22.9,28039,-294,-297,100,89,11,3439,3888,697,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4008,4015,4015,4011,3996,4001,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,1014,SUCCESS,,3440.526841,192,0,0.1,0.2,0.3,263,1.4,1.5
    1409,5/26/2021 20:46,5647.02,1.57,701,300,10,6001,0,65535,65535,1,22.9,28038,-298,-297,100,89,11,3438,3888,697,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4008,4014,4016,4011,3996,3998,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,936,SUCCESS,,3440.194571,192,0,0.1,0.2,0.3,263,1.4,1.5
    1410,5/26/2021 20:46,5651.025,1.57,701,300,10,6001,0,65535,65535,1,22.9,28038,-298,-297,100,89,11,3438,3888,697,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4008,4014,4015,4010,3996,3997,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,945,SUCCESS,,3439.863046,192,0,0.1,0.2,0.3,263,1.4,1.5
    1411,5/26/2021 20:47,5655.039,1.57,701,300,10,6001,0,65535,65535,1,22.9,28036,-296,-297,100,89,11,3438,3888,697,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4008,4014,4015,4010,3996,3998,3995,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,935,SUCCESS,,3439.533006,192,0,0.1,0.2,0.3,263,1.4,1.5
    1412,5/26/2021 20:47,5659.039,1.57,701,300,10,6001,0,65535,65535,1,22.9,28034,-298,-297,100,89,11,3437,3888,687,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4008,4015,4015,4010,3995,3997,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,933,SUCCESS,,3439.201895,192,0,0.1,0.2,0.3,263,1.4,1.5
    1413,5/26/2021 20:47,5663.041,1.57,701,300,10,6001,0,65535,65535,1,22.9,28033,-296,-297,100,89,11,3437,3888,692,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4008,4014,4015,4010,3996,3997,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,953,SUCCESS,,3438.872842,192,0,0.1,0.2,0.3,263,1.4,1.5
    1414,5/26/2021 20:47,5667.045,1.57,701,300,10,6001,0,65535,65535,1,22.9,28033,-296,-297,100,89,11,3437,3888,692,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4014,4015,4010,3995,3997,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,963,SUCCESS,,3438.543624,192,0,0.1,0.2,0.3,263,1.4,1.5
    1415,5/26/2021 20:47,5671.05,1.58,701,300,10,6001,0,65535,65535,1,22.9,28031,-296,-297,100,89,11,3436,3888,687,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4014,4015,4010,3995,3997,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,942,SUCCESS,,3438.214324,192,0,0.1,0.2,0.3,263,1.4,1.5
    1416,5/26/2021 20:47,5675.052,1.58,701,300,10,6001,0,65535,65535,1,22.9,28032,-294,-297,100,89,11,3436,3888,696,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4014,4015,4010,3995,3997,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22,968,SUCCESS,,3437.887494,192,0,0.1,0.2,0.3,263,1.4,1.5
    1417,5/26/2021 20:47,5679.055,1.58,701,300,10,6001,0,65535,65535,1,22.9,28033,-296,-297,100,89,11,3436,3888,692,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4014,4015,4010,3995,3997,3994,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.9,938,SUCCESS,,3437.558359,192,0,0.1,0.2,0.3,263,1.4,1.5
    1418,5/26/2021 20:47,5683.066,1.58,701,300,10,6001,0,65535,65535,1,22.9,28031,-296,-297,100,89,11,3435,3888,696,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4014,4015,4010,3995,3997,3993,0,0,0,0,0,0,0,0,2802,22.7,22.9,-273.2,22.9,-273.2,22.8,941,SUCCESS,,3437.228565,192,0,0.1,0.2,0.3,263,1.4,1.5
    1419,5/26/2021 20:47,5687.075,1.58,701,300,10,6001,0,65535,65535,1,22.9,28031,-298,-296,100,89,11,3435,3888,696,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4013,4015,4009,3995,3996,3993,0,0,0,0,0,0,0,0,2799,22.7,22.9,-273.2,22.9,-273.2,22.8,967,SUCCESS,,3436.896709,192,0,0.1,0.2,0.3,263,1.4,1.5
    1420,5/26/2021 20:47,5691.088,1.58,701,300,10,6001,0,65535,65535,1,22.9,28029,-296,-296,100,89,11,3435,3888,696,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4014,4014,4009,3994,3997,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,946,SUCCESS,,3436.566751,192,0,0.1,0.2,0.3,263,1.4,1.5
    1421,5/26/2021 20:47,5695.092,1.58,701,300,10,6001,0,65535,65535,1,22.9,28029,-296,-296,100,89,11,3434,3888,701,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4013,4014,4009,3995,3997,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3436.237534,192,0,0.1,0.2,0.3,263,1.4,1.5
    1422,5/26/2021 20:47,5699.096,1.58,701,300,10,6001,0,65535,65535,1,22.9,28027,-296,-296,100,89,11,3434,3888,701,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4013,4014,4009,3994,3996,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,973,SUCCESS,,3435.908316,192,0,0.1,0.2,0.3,263,1.4,1.5
    1423,5/26/2021 20:47,5703.102,1.58,701,300,10,6001,0,65535,65535,1,22.9,28027,-296,-297,100,89,11,3434,3888,687,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4007,4013,4014,4009,3995,3997,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,948,SUCCESS,,3435.578934,192,0,0.1,0.2,0.3,263,1.4,1.5
    1424,5/26/2021 20:47,5707.115,1.59,701,300,10,6001,0,65535,65535,1,22.9,28025,-296,-296,100,89,11,3433,3888,696,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4013,4014,4009,3994,3996,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,933,SUCCESS,,3435.248976,192,0,0.1,0.2,0.3,263,1.4,1.5
    1425,5/26/2021 20:47,5711.12,1.59,701,300,10,6001,0,65535,65535,1,22.9,28026,-296,-296,100,89,11,3433,3888,696,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4013,4014,4009,3994,3996,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,998,SUCCESS,,3434.919676,192,0,0.1,0.2,0.3,263,1.4,1.5
    1426,5/26/2021 20:48,5715.122,1.59,701,300,10,6001,0,65535,65535,1,22.9,28025,-296,-297,100,89,11,3433,3888,696,694,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4013,4014,4009,3994,3996,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,974,SUCCESS,,3434.590623,192,0,0.1,0.2,0.3,263,1.4,1.5
    1427,5/26/2021 20:48,5719.122,1.59,701,300,10,6001,0,65535,65535,1,22.9,28024,-296,-296,100,89,11,3432,3888,696,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4014,4009,3994,3996,3993,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,950,SUCCESS,,3434.261734,192,0,0.1,0.2,0.3,263,1.4,1.5
    1428,5/26/2021 20:48,5723.128,1.59,701,300,10,6001,0,65535,65535,1,22.9,28024,-298,-297,100,89,11,3432,3888,691,693,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4014,4009,3994,3996,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,977,SUCCESS,,3433.930126,192,0,0.1,0.2,0.3,263,1.4,1.5
    1429,5/26/2021 20:48,5727.137,1.59,701,300,10,6001,0,65535,65535,1,22.9,28024,-296,-296,100,89,11,3432,3888,696,696,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4014,4009,3994,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,943,SUCCESS,,3433.600497,192,0,0.1,0.2,0.3,263,1.4,1.5
    1430,5/26/2021 20:48,5731.147,1.59,701,300,10,6001,0,65535,65535,1,22.9,28021,-298,-296,100,89,11,3431,3888,691,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4013,4008,3994,3996,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.5,965,SUCCESS,,3433.268558,192,0,0.1,0.2,0.3,263,1.4,1.5
    1431,5/26/2021 20:48,5735.159,1.59,701,300,10,6001,0,65535,65535,1,22.9,28019,-296,-297,100,89,11,3431,3888,695,693,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3432.938683,192,0,0.1,0.2,0.3,263,1.4,1.5
    1432,5/26/2021 20:48,5739.163,1.59,701,300,10,6001,0,65535,65535,1,22.9,28019,-296,-296,100,89,11,3431,3888,695,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,949,SUCCESS,,3432.609465,192,0,0.1,0.2,0.3,263,1.4,1.5
    1433,5/26/2021 20:48,5743.175,1.6,701,300,10,6001,0,65535,65535,1,22.9,28019,-296,-296,100,89,11,3430,3888,695,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,937,SUCCESS,,3432.279589,192,0,0.1,0.2,0.3,263,1.4,1.5
    1434,5/26/2021 20:48,5747.178,1.6,701,300,10,6001,0,65535,65535,1,22.9,28019,-296,-296,100,89,11,3430,3888,695,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,982,SUCCESS,,3431.950454,192,0,0.1,0.2,0.3,263,1.4,1.5
    1435,5/26/2021 20:48,5751.184,1.6,701,300,10,6001,0,65535,65535,1,22.9,28019,-296,-296,100,89,11,3430,3888,695,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4006,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3431.621071,192,0,0.1,0.2,0.3,263,1.4,1.5
    1436,5/26/2021 20:48,5755.195,1.6,701,300,10,6001,0,65535,65535,1,22.9,28018,-298,-296,100,89,11,3429,3888,690,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4005,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,948,SUCCESS,,3431.28905,192,0,0.1,0.2,0.3,263,1.4,1.5
    1437,5/26/2021 20:48,5759.21,1.6,701,300,10,6001,0,65535,65535,1,22.9,28017,-296,-296,100,89,11,3429,3888,695,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4005,4012,4013,4008,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,969,SUCCESS,,3430.958928,192,0,0.1,0.2,0.3,263,1.4,1.5
    1438,5/26/2021 20:48,5763.225,1.6,701,300,10,6001,0,65535,65535,1,22.9,28015,-296,-296,100,89,11,3429,3888,700,695,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4005,4012,4012,4007,3993,3995,3991,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,948,SUCCESS,,3430.628805,192,0,0.1,0.2,0.3,263,1.4,1.5
    1439,5/26/2021 20:48,5767.229,1.6,701,300,10,6001,0,65535,65535,1,22.9,28016,-298,-297,100,89,11,3428,3888,690,693,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4005,4011,4012,4007,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,946,SUCCESS,,3430.297363,192,0,0.1,0.2,0.3,263,1.4,1.5
    1440,5/26/2021 20:48,5771.234,1.6,701,300,10,6001,0,65535,65535,1,22.9,28013,-296,-297,100,89,11,3428,3888,690,693,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4005,4011,4012,4007,3993,3995,3992,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,956,SUCCESS,,3429.968063,192,0,0.1,0.2,0.3,263,1.4,1.5
    1441,5/26/2021 20:49,5775.244,1.6,701,300,10,6001,0,65535,65535,1,22.9,28012,-296,-297,100,89,11,3428,3888,690,693,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4005,4011,4012,4007,3992,3995,3991,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,965,SUCCESS,,3429.638352,192,0,0.1,0.2,0.3,263,1.4,1.5
    1442,5/26/2021 20:49,5779.25,1.61,701,300,10,6001,0,65535,65535,1,22.9,28011,-298,-297,100,89,11,3427,3888,690,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4011,4012,4007,3992,3994,3991,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,963,SUCCESS,,3429.306744,192,0,0.1,0.2,0.3,263,1.4,1.5
    1443,5/26/2021 20:49,5783.257,1.61,701,300,10,6001,0,65535,65535,1,22.9,28011,-296,-297,100,89,11,3427,3888,690,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4011,4012,4007,3992,3994,3991,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,987,SUCCESS,,3428.97728,192,0,0.1,0.2,0.3,263,1.4,1.5
    1444,5/26/2021 20:49,5787.265,1.61,701,300,10,6001,0,65535,65535,1,22.9,28011,-298,-297,100,89,11,3427,3888,690,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4011,4012,4007,3992,3994,3991,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,946,SUCCESS,,3428.645506,192,0,0.1,0.2,0.3,263,1.4,1.5
    1445,5/26/2021 20:49,5791.273,1.61,701,300,10,6001,0,65535,65535,1,22.9,28009,-298,-297,100,89,11,3426,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4011,4007,3992,3994,3991,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,984,SUCCESS,,3428.313733,192,0,0.1,0.2,0.3,263,1.4,1.5
    1446,5/26/2021 20:49,5795.274,1.61,701,300,10,6001,0,65535,65535,1,22.9,28008,-296,-297,100,89,11,3426,3888,699,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4012,4007,3992,3994,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.7,936,SUCCESS,,3427.984762,192,0,0.1,0.2,0.3,263,1.4,1.5
    1447,5/26/2021 20:49,5799.278,1.61,701,300,10,6001,0,65535,65535,1,22.9,28009,-298,-297,100,89,11,3426,3888,690,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4011,4007,3992,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.7,948,SUCCESS,,3427.65332,192,0,0.1,0.2,0.3,263,1.4,1.5
    1448,5/26/2021 20:49,5803.28,1.61,701,300,10,6001,0,65535,65535,1,22.9,28006,-298,-297,100,89,11,3425,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4011,4006,3991,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,976,SUCCESS,,3427.322043,192,0,0.1,0.2,0.3,263,1.4,1.5
    1449,5/26/2021 20:49,5807.294,1.61,701,300,10,6001,0,65535,65535,1,22.9,28009,-298,-297,100,89,11,3425,3888,690,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4011,4006,3992,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,946,SUCCESS,,3426.989773,192,0,0.1,0.2,0.3,263,1.4,1.5
    1450,5/26/2021 20:49,5811.299,1.61,701,300,10,6001,0,65535,65535,1,22.9,28006,-296,-297,100,89,11,3425,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4011,4006,3992,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,938,SUCCESS,,3426.660473,192,0,0.1,0.2,0.3,263,1.4,1.5
    1451,5/26/2021 20:49,5815.302,1.62,701,300,10,6001,0,65535,65535,1,22.9,28004,-294,-297,100,89,11,3424,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4004,4010,4011,4006,3991,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,934,SUCCESS,,3426.333561,192,0,0.1,0.2,0.3,263,1.4,1.5
    1452,5/26/2021 20:49,5819.317,1.62,701,300,10,6001,0,65535,65535,1,22.9,28008,-298,-297,100,89,11,3424,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4010,4010,4006,3991,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,945,SUCCESS,,3426.001209,192,0,0.1,0.2,0.3,263,1.4,1.5
    1453,5/26/2021 20:49,5823.321,1.62,701,300,10,6001,0,65535,65535,1,22.9,28003,-296,-297,100,89,11,3424,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4010,4011,4006,3991,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,960,SUCCESS,,3425.671991,192,0,0.1,0.2,0.3,263,1.4,1.5
    1454,5/26/2021 20:49,5827.326,1.62,701,300,10,6001,0,65535,65535,1,22.9,28002,-298,-297,100,89,11,3423,3888,694,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4010,4010,4006,3991,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,946,SUCCESS,,3425.340466,192,0,0.1,0.2,0.3,263,1.4,1.5
    1455,5/26/2021 20:49,5831.328,1.62,701,300,10,6001,0,65535,65535,1,22.9,28007,-300,-297,100,89,11,3423,3888,689,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4010,4010,4006,3991,3993,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,963,SUCCESS,,3425.006966,192,0,0.1,0.2,0.3,263,1.4,1.5
    1456,5/26/2021 20:50,5835.34,1.62,701,300,10,6001,0,65535,65535,1,22.9,28001,-298,-297,100,89,11,3423,3888,689,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4006,3991,3993,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.7,958,SUCCESS,,3424.674861,192,0,0.1,0.2,0.3,263,1.4,1.5
    1457,5/26/2021 20:50,5839.344,1.62,701,300,10,6001,0,65535,65535,1,22.9,28000,-298,-297,100,89,11,3422,3888,689,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4006,3991,3992,3990,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,956,SUCCESS,,3424.343419,192,0,0.1,0.2,0.3,263,1.4,1.5
    1458,5/26/2021 20:50,5843.358,1.62,701,300,10,6001,0,65535,65535,1,22.9,28000,-298,-297,100,89,11,3422,3888,689,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.5,958,SUCCESS,,3424.011149,192,0,0.1,0.2,0.3,263,1.4,1.5
    1459,5/26/2021 20:50,5847.365,1.62,701,300,10,6001,0,65535,65535,1,22.9,27998,-298,-297,100,89,11,3422,3888,689,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,955,SUCCESS,,3423.679459,192,0,0.1,0.2,0.3,263,1.4,1.5
    1460,5/26/2021 20:50,5851.366,1.63,701,300,10,6001,0,65535,65535,1,22.9,27998,-300,-297,100,88,11,3421,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.7,985,SUCCESS,,3423.346042,192,0,0.1,0.2,0.3,263,1.4,1.5
    1461,5/26/2021 20:50,5855.374,1.63,701,300,10,6001,0,65535,65535,1,22.9,27998,-298,-297,100,88,11,3421,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,968,SUCCESS,,3423.014269,192,0,0.1,0.2,0.3,263,1.4,1.5
    1462,5/26/2021 20:50,5859.374,1.63,701,300,10,6001,0,65535,65535,1,22.9,27998,-298,-297,100,88,11,3421,3888,689,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,940,SUCCESS,,3422.683158,192,0,0.1,0.2,0.3,263,1.4,1.5
    1463,5/26/2021 20:50,5863.384,1.63,701,300,10,6001,0,65535,65535,1,22.9,27997,-300,-297,100,88,11,3420,3888,684,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4003,4009,4010,4005,3990,3991,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,952,SUCCESS,,3422.348991,192,0,0.1,0.2,0.3,263,1.4,1.5
    1464,5/26/2021 20:50,5867.385,1.63,701,300,10,6001,0,65535,65535,1,22.9,27997,-296,-297,100,88,11,3420,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4002,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,969,SUCCESS,,3422.02002,192,0,0.1,0.2,0.3,263,1.4,1.5
    1465,5/26/2021 20:50,5871.392,1.63,701,300,10,6001,0,65535,65535,1,22.9,27996,-296,-297,100,88,11,3420,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4002,4009,4010,4005,3990,3992,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,938,SUCCESS,,3421.690555,192,0,0.1,0.2,0.3,263,1.4,1.5
    1466,5/26/2021 20:50,5875.399,1.63,701,300,10,6001,0,65535,65535,1,22.9,27994,-300,-297,100,88,11,3419,3888,684,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4002,4009,4009,4004,3989,3988,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.7,979,SUCCESS,,3421.356639,192,0,0.1,0.2,0.3,263,1.4,1.5
    1467,5/26/2021 20:50,5879.412,1.63,701,300,10,6001,0,65535,65535,1,22.9,27993,-296,-297,100,88,11,3419,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4002,4009,4009,4004,3990,3991,3989,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,988,SUCCESS,,3421.026681,192,0,0.1,0.2,0.3,263,1.4,1.5
    1468,5/26/2021 20:50,5883.415,1.63,701,300,10,6001,0,65535,65535,1,22.9,27992,-300,-297,100,88,11,3419,3888,684,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4002,4008,4009,4004,3989,3991,3988,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,955,SUCCESS,,3420.693098,192,0,0.1,0.2,0.3,263,1.4,1.5
    1469,5/26/2021 20:50,5887.423,1.64,701,300,10,6001,0,65535,65535,1,22.9,27990,-296,-297,100,88,11,3418,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4002,4008,4009,4004,3989,3991,3988,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.7,943,SUCCESS,,3420.363551,192,0,0.1,0.2,0.3,263,1.4,1.5
    1470,5/26/2021 20:50,5891.432,1.64,701,300,10,6001,0,65535,65535,1,22.9,27990,-296,-297,100,88,11,3418,3888,693,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4008,4009,4004,3989,3991,3988,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,977,SUCCESS,,3420.033922,192,0,0.1,0.2,0.3,263,1.4,1.5
    1471,5/26/2021 20:51,5895.433,1.64,701,300,10,6001,0,65535,65535,1,22.9,27990,-298,-297,100,88,11,3418,3888,688,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4008,4009,4004,3989,3991,3988,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,951,SUCCESS,,3419.702728,192,0,0.1,0.2,0.3,263,1.4,1.5
    1472,5/26/2021 20:51,5899.44,1.64,701,300,10,6001,0,65535,65535,1,22.9,27991,-296,-297,100,88,11,3417,3888,693,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4008,4009,4004,3989,3992,3988,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22,981,SUCCESS,,3419.373264,192,0,0.1,0.2,0.3,263,1.4,1.5
    1473,5/26/2021 20:51,5903.455,1.64,701,300,10,6001,0,65535,65535,1,22.9,27989,-296,-297,100,88,11,3417,3888,688,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4008,4004,3989,3990,3988,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.7,939,SUCCESS,,3419.043141,192,0,0.1,0.2,0.3,263,1.4,1.5
    1474,5/26/2021 20:51,5907.461,1.64,701,300,10,6001,0,65535,65535,1,22.9,27988,-296,-297,100,88,11,3417,3888,688,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4009,4003,3989,3991,3987,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,979,SUCCESS,,3418.713759,192,0,0.1,0.2,0.3,263,1.4,1.5
    1475,5/26/2021 20:51,5911.461,1.64,701,300,10,6001,0,65535,65535,1,22.9,27987,-296,-297,100,88,11,3416,3888,692,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4008,4003,3989,3992,3987,0,0,0,0,0,0,0,0,2798,22.7,22.9,-273.2,22.9,-273.2,22.8,933,SUCCESS,,3418.38487,192,0,0.1,0.2,0.3,263,1.4,1.5
    1476,5/26/2021 20:51,5915.463,1.64,701,300,10,6001,0,65535,65535,1,22.9,27985,-296,-297,100,88,11,3416,3888,688,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4008,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,980,SUCCESS,,3418.055817,192,0,0.1,0.2,0.3,263,1.4,1.5
    1477,5/26/2021 20:51,5919.463,1.64,701,300,10,6001,0,65535,65535,1,22.9,27985,-296,-297,100,88,11,3416,3888,692,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4008,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,969,SUCCESS,,3417.726928,192,0,0.1,0.2,0.3,263,1.4,1.5
    1478,5/26/2021 20:51,5923.473,1.65,701,300,10,6001,0,65535,65535,1,22.9,27984,-296,-297,100,88,11,3415,3888,692,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4008,4003,3989,3992,3987,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.7,999,SUCCESS,,3417.397217,192,0,0.1,0.2,0.3,263,1.4,1.5
    1479,5/26/2021 20:51,5927.484,1.65,701,300,10,6001,0,65535,65535,1,22.9,27983,-300,-297,100,88,11,3415,3888,683,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4007,4008,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2794,22.6,22.9,-273.2,22.9,-273.2,22.8,956,SUCCESS,,3417.062967,192,0,0.1,0.2,0.3,263,1.4,1.5
    1480,5/26/2021 20:51,5931.488,1.65,701,300,10,6001,0,65535,65535,1,22.9,27983,-294,-297,100,88,11,3415,3888,697,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4001,4007,4008,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2798,22.6,22.9,-273.2,22.9,-273.2,22.8,957,SUCCESS,,3416.735974,192,0,0.1,0.2,0.3,263,1.4,1.5
    1481,5/26/2021 20:51,5935.494,1.65,701,300,10,6001,0,65535,65535,1,22.9,27983,-298,-297,100,88,11,3414,3888,692,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4007,4008,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3416.404366,192,0,0.1,0.2,0.3,263,1.4,1.5
    1482,5/26/2021 20:51,5939.499,1.65,701,300,10,6001,0,65535,65535,1,22.9,27981,-296,-297,100,88,11,3414,3888,687,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4007,4007,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,973,SUCCESS,,3416.075066,192,0,0.1,0.2,0.3,263,1.4,1.5
    1483,5/26/2021 20:51,5943.512,1.65,701,300,10,6001,0,65535,65535,1,22.9,27981,-296,-297,100,88,11,3414,3888,692,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4003,3988,3990,3987,0,0,0,0,0,0,0,0,2793,22.7,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3415.745108,192,0,0.1,0.2,0.3,263,1.4,1.5
    1484,5/26/2021 20:51,5947.518,1.65,701,300,10,6001,0,65535,65535,1,22.9,27981,-296,-296,100,88,11,3413,3888,687,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4002,3988,3990,3987,0,0,0,0,0,0,0,0,2793,22.7,22.9,-273.2,22.9,-273.2,22.7,955,SUCCESS,,3415.415726,192,0,0.1,0.2,0.3,263,1.4,1.5
    1485,5/26/2021 20:51,5951.528,1.65,701,300,10,6001,0,65535,65535,1,22.9,27979,-296,-297,100,88,11,3413,3888,692,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4003,3988,3990,3986,0,0,0,0,0,0,0,0,2793,22.7,22.9,-273.2,22.9,-273.2,22.7,953,SUCCESS,,3415.086015,192,0,0.1,0.2,0.3,263,1.4,1.5
    1486,5/26/2021 20:52,5955.537,1.65,701,300,10,6001,0,65535,65535,1,22.9,27977,-294,-296,100,88,11,3413,3888,697,692,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4002,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.7,22.9,-273.2,22.9,-273.2,22.8,938,SUCCESS,,3414.758613,192,0,0.1,0.2,0.3,263,1.4,1.5
    1487,5/26/2021 20:52,5959.551,1.66,701,300,10,6001,0,65535,65535,1,22.9,27977,-298,-297,100,88,11,3412,3888,687,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4002,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,935,SUCCESS,,3414.426343,192,0,0.1,0.2,0.3,263,1.4,1.5
    1488,5/26/2021 20:52,5963.565,1.66,701,300,10,6001,0,65535,65535,1,22.9,27977,-296,-297,100,88,11,3412,3888,692,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4002,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,958,SUCCESS,,3414.096303,192,0,0.1,0.2,0.3,263,1.4,1.5
    1489,5/26/2021 20:52,5967.573,1.66,701,300,10,6001,0,65535,65535,1,22.9,27977,-296,-297,100,88,11,3412,3888,692,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,4000,4006,4007,4002,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,930,SUCCESS,,3413.766756,192,0,0.1,0.2,0.3,263,1.4,1.5
    1490,5/26/2021 20:52,5971.586,1.66,701,300,10,6001,0,65535,65535,1,22.9,27977,-296,-297,100,88,11,3411,3888,687,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3999,4006,4007,4001,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,951,SUCCESS,,3413.436799,192,0,0.1,0.2,0.3,263,1.4,1.5
    1491,5/26/2021 20:52,5975.596,1.66,701,300,10,6001,0,65535,65535,1,22.9,27976,-296,-297,100,88,11,3411,3888,687,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3999,4006,4006,4001,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,969,SUCCESS,,3413.107088,192,0,0.1,0.2,0.3,263,1.4,1.5
    1492,5/26/2021 20:52,5979.6,1.66,701,300,10,6001,0,65535,65535,1,22.9,27974,-296,-297,100,88,11,3411,3888,687,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3999,4006,4006,4001,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,957,SUCCESS,,3412.77787,192,0,0.1,0.2,0.3,263,1.4,1.5
    1493,5/26/2021 20:52,5983.614,1.66,701,300,10,6001,0,65535,65535,1,22.9,27973,-296,-297,100,88,11,3410,3888,691,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3999,4005,4006,4001,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,942,SUCCESS,,3412.44783,192,0,0.1,0.2,0.3,263,1.4,1.5
    1494,5/26/2021 20:52,5987.627,1.66,701,300,10,6001,0,65535,65535,1,22.9,27973,-296,-297,100,88,11,3410,3888,691,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3999,4005,4006,4001,3987,3989,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3412.117872,192,0,0.1,0.2,0.3,263,1.4,1.5
    1495,5/26/2021 20:52,5991.636,1.66,701,300,10,6001,0,65535,65535,1,22.9,27969,-296,-297,100,88,11,3410,3888,687,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4005,4006,4001,3987,3989,3985,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,949,SUCCESS,,3411.788243,192,0,0.1,0.2,0.3,263,1.4,1.5
    1496,5/26/2021 20:52,5995.64,1.67,701,300,10,6001,0,65535,65535,1,22.9,27971,-296,-297,100,88,11,3409,3888,696,689,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4005,4006,4001,3986,3988,3986,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,957,SUCCESS,,3411.459025,192,0,0.1,0.2,0.3,263,1.4,1.5
    1497,5/26/2021 20:52,5999.656,1.67,701,300,10,6001,0,65535,65535,1,22.9,27969,-294,-297,100,88,11,3409,3888,696,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4005,4006,4001,3986,3988,3985,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,949,SUCCESS,,3411.131052,192,0,0.1,0.2,0.3,263,1.4,1.5
    1498,5/26/2021 20:52,6003.663,1.67,701,300,10,6001,0,65535,65535,1,22.9,27968,-296,-296,100,88,11,3409,3888,696,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4004,4006,4001,3986,3988,3985,0,0,0,0,0,0,0,0,2793,22.7,22.9,-273.2,22.9,-273.2,22.7,968,SUCCESS,,3410.801588,192,0,0.1,0.2,0.3,263,1.4,1.5
    1499,5/26/2021 20:52,6007.666,1.67,701,300,10,6001,0,65535,65535,1,22.9,27969,-298,-296,100,88,11,3408,3888,686,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4005,4006,4001,3986,3988,3985,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,966,SUCCESS,,3410.470228,192,0,0.1,0.2,0.3,263,1.4,1.5
    1500,5/26/2021 20:52,6011.682,1.67,701,300,10,6001,0,65535,65535,1,22.9,27969,-294,-296,100,88,11,3408,3888,696,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4005,4006,4000,3986,3988,3985,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,962,SUCCESS,,3410.142255,192,0,0.1,0.2,0.3,263,1.4,1.5
    1501,5/26/2021 20:53,6015.689,1.67,701,300,10,6001,0,65535,65535,1,22.9,27969,-296,-296,100,88,11,3408,3888,691,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4005,4006,4001,3986,3988,3985,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,943,SUCCESS,,3409.81279,192,0,0.1,0.2,0.3,263,1.4,1.5
    1502,5/26/2021 20:53,6019.697,1.67,701,300,10,6001,0,65535,65535,1,22.9,27967,-296,-296,100,88,11,3407,3888,691,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4004,4005,4000,3986,3988,3985,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,962,SUCCESS,,3409.483244,192,0,0.1,0.2,0.3,263,1.4,1.5
    1503,5/26/2021 20:53,6023.699,1.67,701,300,10,6001,0,65535,65535,1,22.9,27964,-298,-296,100,88,11,3407,3888,686,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4004,4005,4000,3986,3988,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,966,SUCCESS,,3409.151967,192,0,0.1,0.2,0.3,263,1.4,1.5
    1504,5/26/2021 20:53,6027.713,1.67,701,300,10,6001,0,65535,65535,1,22.9,27964,-298,-296,100,88,11,3407,3888,686,691,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4004,4005,4000,3986,3987,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,998,SUCCESS,,3408.819697,192,0,0.1,0.2,0.3,263,1.4,1.5
    1505,5/26/2021 20:53,6031.725,1.68,701,300,10,6001,0,65535,65535,1,22.9,27963,-298,-296,100,88,11,3406,3888,686,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4004,4005,4000,3986,3987,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,932,SUCCESS,,3408.487593,192,0,0.1,0.2,0.3,263,1.4,1.5
    1506,5/26/2021 20:53,6035.737,1.68,701,300,10,6001,0,65535,65535,1,22.9,27964,-296,-296,100,88,11,3406,3888,690,690,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3998,4004,4005,4000,3985,3987,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,943,SUCCESS,,3408.157717,192,0,0.1,0.2,0.3,263,1.4,1.5
    1507,5/26/2021 20:53,6039.75,1.68,701,300,10,6001,0,65535,65535,1,22.9,27962,-294,-297,100,88,11,3406,3888,690,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4004,4004,4000,3985,3987,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,959,SUCCESS,,3407.829989,192,0,0.1,0.2,0.3,263,1.4,1.5
    1508,5/26/2021 20:53,6043.75,1.68,701,300,10,6001,0,65535,65535,1,22.9,27961,-298,-297,100,88,11,3405,3888,686,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4004,4005,4000,3985,3987,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,959,SUCCESS,,3407.498878,192,0,0.1,0.2,0.3,263,1.4,1.5
    1509,5/26/2021 20:53,6047.757,1.68,701,300,10,6001,0,65535,65535,1,22.9,27961,-296,-297,100,88,11,3405,3888,686,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4004,4004,4000,3985,3987,3984,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.2,956,SUCCESS,,3407.169413,192,0,0.1,0.2,0.3,263,1.4,1.5
    1510,5/26/2021 20:53,6051.769,1.68,701,300,10,6001,0,65535,65535,1,22.9,27960,-296,-297,100,88,11,3405,3888,695,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4003,4004,4000,3985,3987,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,955,SUCCESS,,3406.839538,192,0,0.1,0.2,0.3,263,1.4,1.5
    1511,5/26/2021 20:53,6055.777,1.68,701,300,10,6001,0,65535,65535,1,22.9,27958,-298,-297,100,88,11,3404,3888,685,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4003,4004,3999,3985,3987,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3406.507764,192,0,0.1,0.2,0.3,263,1.4,1.5
    1512,5/26/2021 20:53,6059.785,1.68,701,300,10,6001,0,65535,65535,1,22.9,27958,-296,-297,100,88,11,3404,3888,695,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4003,4004,3999,3984,3987,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,959,SUCCESS,,3406.178218,192,0,0.1,0.2,0.3,263,1.4,1.5
    1513,5/26/2021 20:53,6063.788,1.68,701,300,10,6001,0,65535,65535,1,22.9,27957,-296,-297,100,88,11,3404,3888,695,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4003,4004,3999,3985,3987,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,1002,SUCCESS,,3405.849082,192,0,0.1,0.2,0.3,263,1.4,1.5
    1514,5/26/2021 20:53,6067.793,1.69,701,300,10,6001,0,65535,65535,1,22.9,27956,-298,-297,100,88,11,3403,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4003,4004,3999,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,959,SUCCESS,,3405.517557,192,0,0.1,0.2,0.3,263,1.4,1.5
    1515,5/26/2021 20:53,6071.795,1.69,701,300,10,6001,0,65535,65535,1,22.9,27956,-296,-297,100,88,11,3403,3888,690,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3997,4003,4004,3999,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,963,SUCCESS,,3405.188504,192,0,0.1,0.2,0.3,263,1.4,1.5
    1516,5/26/2021 20:54,6075.797,1.69,701,300,10,6001,0,65535,65535,1,22.9,27951,-298,-297,100,88,11,3403,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3996,4003,4004,3999,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,975,SUCCESS,,3404.857227,192,0,0.1,0.2,0.3,263,1.4,1.5
    1517,5/26/2021 20:54,6079.802,1.69,701,300,10,6001,0,65535,65535,1,22.9,27954,-298,-297,100,88,11,3402,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3996,4003,4004,3998,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,972,SUCCESS,,3404.525702,192,0,0.1,0.2,0.3,263,1.4,1.5
    1518,5/26/2021 20:54,6083.806,1.69,701,300,10,6001,0,65535,65535,1,22.9,27954,-296,-297,100,88,11,3402,3888,690,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3996,4003,4004,3999,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,951,SUCCESS,,3404.196484,192,0,0.1,0.2,0.3,263,1.4,1.5
    1519,5/26/2021 20:54,6087.814,1.69,701,300,10,6001,0,65535,65535,1,22.9,27953,-298,-297,100,88,11,3402,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3996,4003,4003,3998,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,963,SUCCESS,,3403.864711,192,0,0.1,0.2,0.3,263,1.4,1.5
    1520,5/26/2021 20:54,6091.824,1.69,701,300,10,6001,0,65535,65535,1,22.9,27952,-296,-297,100,88,11,3401,3888,689,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3996,4002,4003,3998,3984,3985,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,963,SUCCESS,,3403.535,192,0,0.1,0.2,0.3,263,1.4,1.5
    1521,5/26/2021 20:54,6095.834,1.69,701,300,10,6001,0,65535,65535,1,22.9,27952,-296,-297,100,88,11,3401,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3996,4002,4003,3998,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,966,SUCCESS,,3403.205289,192,0,0.1,0.2,0.3,263,1.4,1.5
    1522,5/26/2021 20:54,6099.84,1.69,701,300,10,6001,0,65535,65535,1,22.9,27951,-296,-297,100,88,11,3401,3888,689,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4002,4003,3998,3984,3986,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,948,SUCCESS,,3402.875906,192,0,0.1,0.2,0.3,263,1.4,1.5
    1523,5/26/2021 20:54,6103.845,1.7,701,300,10,6001,0,65535,65535,1,22.9,27949,-296,-297,100,88,11,3400,3888,694,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4002,4003,3998,3984,3985,3983,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3402.546606,192,0,0.1,0.2,0.3,263,1.4,1.5
    1524,5/26/2021 20:54,6107.854,1.7,701,300,10,6001,0,65535,65535,1,22.9,27948,-296,-297,100,88,11,3400,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4002,4003,3998,3983,3985,3982,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,944,SUCCESS,,3402.216978,192,0,0.1,0.2,0.3,263,1.4,1.5
    1525,5/26/2021 20:54,6111.86,1.7,701,300,10,6001,0,65535,65535,1,22.9,27950,-296,-297,100,88,11,3400,3888,685,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4002,4003,3998,3983,3986,3982,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.7,959,SUCCESS,,3401.887595,192,0,0.1,0.2,0.3,263,1.4,1.5
    1526,5/26/2021 20:54,6115.874,1.7,701,300,10,6001,0,65535,65535,1,22.8,27947,-300,-297,100,88,11,3399,3888,689,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4002,4003,3998,3983,3985,3982,0,0,0,0,0,0,0,0,2793,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3401.553095,192,0,0.1,0.2,0.3,263,1.4,1.5
    1527,5/26/2021 20:54,6119.877,1.7,701,300,10,6001,0,65535,65535,1,22.8,27945,-300,-297,100,88,11,3399,3888,684,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4002,4003,3998,3983,3985,3982,0,0,0,0,0,0,0,0,2793,22.6,22.8,-273.2,22.8,-273.2,22.8,945,SUCCESS,,3401.219512,192,0,0.1,0.2,0.3,263,1.4,1.5
    1528,5/26/2021 20:54,6123.884,1.7,701,300,10,6001,0,65535,65535,1,22.8,27948,-298,-297,100,88,11,3399,3888,689,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4001,4002,3998,3983,3985,3982,0,0,0,0,0,0,0,0,2793,22.6,22.8,-273.2,22.8,-273.2,22.8,968,SUCCESS,,3400.887821,192,0,0.1,0.2,0.3,263,1.4,1.5
    1529,5/26/2021 20:54,6127.899,1.7,701,300,10,6001,0,65535,65535,1,22.8,27944,-296,-297,100,88,11,3398,3888,689,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4001,4003,3997,3983,3985,3982,0,0,0,0,0,0,0,0,2793,22.6,22.8,-273.2,22.8,-273.2,22.7,962,SUCCESS,,3400.557699,192,0,0.1,0.2,0.3,263,1.4,1.5
    1530,5/26/2021 20:54,6131.899,1.7,701,300,10,6001,0,65535,65535,1,22.8,27944,-298,-297,100,88,11,3398,3888,689,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4001,4002,3997,3983,3984,3982,0,0,0,0,0,0,0,0,2793,22.6,22.8,-273.2,22.8,-273.2,22.7,952,SUCCESS,,3400.226588,192,0,0.1,0.2,0.3,263,1.4,1.5
    1531,5/26/2021 20:55,6135.912,1.7,701,300,10,6001,0,65535,65535,1,22.9,27946,-294,-297,100,88,11,3398,3888,689,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4001,4003,3997,3983,3985,3981,0,0,0,0,0,0,0,0,2793,22.6,22.9,-273.2,22.9,-273.2,22.8,971,SUCCESS,,3399.89886,192,0,0.1,0.2,0.3,263,1.4,1.5
    1532,5/26/2021 20:55,6139.927,1.71,701,300,10,6001,0,65535,65535,1,22.8,27943,-298,-297,100,88,11,3397,3888,689,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4001,4002,3997,3983,3984,3981,0,0,0,0,0,0,0,0,2793,22.6,22.8,-273.2,22.8,-273.2,22.7,950,SUCCESS,,3399.566507,192,0,0.1,0.2,0.3,263,1.4,1.5
    1533,5/26/2021 20:55,6143.93,1.71,701,300,10,6001,0,65535,65535,1,22.8,27942,-298,-297,100,88,11,3397,3888,689,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3995,4001,4001,3997,3983,3984,3981,0,0,0,0,0,0,0,0,2790,22.6,22.8,-273.2,22.8,-273.2,22.8,999,SUCCESS,,3399.235148,192,0,0.1,0.2,0.3,263,1.4,1.5
    1534,5/26/2021 20:55,6147.943,1.71,701,300,10,6001,0,65535,65535,1,22.8,27942,-296,-297,100,88,11,3397,3888,689,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3994,4001,4002,3997,3982,3984,3981,0,0,0,0,0,0,0,0,2790,22.6,22.8,-273.2,22.8,-273.2,22.8,982,SUCCESS,,3398.90519,192,0,0.1,0.2,0.3,263,1.4,1.5
    1535,5/26/2021 20:55,6151.951,1.71,701,300,10,6001,0,65535,65535,1,22.8,27941,-298,-297,100,88,11,3396,3888,684,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3994,4001,4002,3997,3982,3984,3981,0,0,0,0,0,0,0,0,2792,22.6,22.9,-273.2,22.9,-273.2,22.8,941,SUCCESS,,3398.573416,192,0,0.1,0.2,0.3,263,1.4,1.5
    1536,5/26/2021 20:55,6155.961,1.71,701,300,10,6001,0,65535,65535,1,22.8,27941,-296,-297,100,88,11,3396,3888,688,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3994,4001,4002,3997,3982,3984,3981,0,0,0,0,0,0,0,0,2792,22.6,22.8,-273.2,22.8,-273.2,22.8,966,SUCCESS,,3398.243705,192,0,0.1,0.2,0.3,263,1.4,1.5
    1537,5/26/2021 20:55,6159.969,1.71,701,300,10,6001,0,65535,65535,1,22.8,27939,-296,-297,100,88,11,3396,3888,688,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3994,4001,4001,3997,3982,3985,3981,0,0,0,0,0,0,0,0,2792,22.6,22.8,-273.2,22.8,-273.2,22.5,942,SUCCESS,,3397.914159,192,0,0.1,0.2,0.3,263,1.4,1.5
    1538,5/26/2021 20:55,6163.971,1.71,701,300,10,6001,0,65535,65535,1,22.8,27939,-298,-297,100,88,11,3395,3888,684,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3994,4000,4001,3997,3982,3984,3981,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,982,SUCCESS,,3397.582882,192,0,0.1,0.2,0.3,263,1.4,1.5
    1539,5/26/2021 20:55,6167.977,1.71,701,300,10,6001,0,65535,65535,1,22.8,27935,-296,-297,100,88,11,3395,3888,688,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3994,4000,4001,3997,3981,3982,3981,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.6,938,SUCCESS,,3397.2535,192,0,0.1,0.2,0.3,263,1.4,1.5
    1540,5/26/2021 20:55,6171.984,1.71,701,300,10,6001,0,65535,65535,1,22.8,27936,-298,-297,100,88,11,3395,3888,684,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4001,3996,3981,3985,3981,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,964,SUCCESS,,3396.921809,192,0,0.1,0.2,0.3,263,1.4,1.5
    1541,5/26/2021 20:55,6175.993,1.72,701,300,10,6001,0,65535,65535,1,22.8,27935,-296,-297,100,88,11,3394,3888,688,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4001,3996,3981,3983,3980,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,980,SUCCESS,,3396.59218,192,0,0.1,0.2,0.3,263,1.4,1.5
    1542,5/26/2021 20:55,6180.001,1.72,701,300,10,6001,0,65535,65535,1,22.8,27934,-294,-297,100,88,11,3394,3888,693,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4001,3996,3981,3983,3980,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,949,SUCCESS,,3396.26486,192,0,0.1,0.2,0.3,263,1.4,1.5
    1543,5/26/2021 20:55,6184.003,1.72,701,300,10,6001,0,65535,65535,1,22.8,27934,-298,-297,100,88,11,3394,3888,683,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4001,3996,3981,3983,3980,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,962,SUCCESS,,3395.933584,192,0,0.1,0.2,0.3,263,1.4,1.5
    1544,5/26/2021 20:55,6188.012,1.72,701,300,10,6001,0,65535,65535,1,22.8,27934,-298,-297,100,88,11,3393,3888,683,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4001,3996,3981,3983,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,948,SUCCESS,,3395.601728,192,0,0.1,0.2,0.3,263,1.4,1.5
    1545,5/26/2021 20:55,6192.023,1.72,701,300,10,6001,0,65535,65535,1,22.8,27934,-296,-297,100,88,11,3393,3888,692,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4001,3995,3981,3982,3980,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3395.271934,192,0,0.1,0.2,0.3,263,1.4,1.5
    1546,5/26/2021 20:56,6196.027,1.72,701,300,10,6001,0,65535,65535,1,22.8,27934,-296,-297,100,88,11,3393,3888,688,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4000,3995,3981,3983,3980,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,945,SUCCESS,,3394.942716,192,0,0.1,0.2,0.3,263,1.4,1.5
    1547,5/26/2021 20:56,6200.035,1.72,701,300,10,6001,0,65535,65535,1,22.8,27931,-296,-296,100,88,11,3392,3888,692,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,4000,4000,3995,3981,3983,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,958,SUCCESS,,3394.61317,192,0,0.1,0.2,0.3,263,1.4,1.5
    1548,5/26/2021 20:56,6204.041,1.72,701,300,10,6001,0,65535,65535,1,22.8,27930,-294,-296,100,88,11,3392,3888,692,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,3999,4000,3995,3981,3983,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,938,SUCCESS,,3394.286013,192,0,0.1,0.2,0.3,263,1.4,1.5
    1549,5/26/2021 20:56,6208.045,1.72,701,300,10,6001,0,65535,65535,1,22.8,27929,-298,-296,100,88,11,3392,3888,688,688,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,3999,4000,3995,3981,3983,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,967,SUCCESS,,3393.954571,192,0,0.1,0.2,0.3,263,1.4,1.5
    1550,5/26/2021 20:56,6212.051,1.73,701,300,10,6001,0,65535,65535,1,22.8,27929,-296,-296,100,88,11,3391,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3993,3999,4000,3995,3981,3983,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,970,SUCCESS,,3393.625189,192,0,0.1,0.2,0.3,263,1.4,1.5
    1551,5/26/2021 20:56,6216.06,1.73,701,300,10,6001,0,65535,65535,1,22.8,27927,-296,-296,100,88,11,3391,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3999,4000,3995,3981,3979,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,949,SUCCESS,,3393.29556,192,0,0.1,0.2,0.3,263,1.4,1.5
    1552,5/26/2021 20:56,6220.064,1.73,701,300,10,6001,0,65535,65535,1,22.8,27927,-296,-296,100,88,11,3391,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3999,4000,3995,3980,3982,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,971,SUCCESS,,3392.966342,192,0,0.1,0.2,0.3,263,1.4,1.5
    1553,5/26/2021 20:56,6224.076,1.73,701,300,10,6001,0,65535,65535,1,22.8,27927,-296,-296,100,88,11,3390,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3999,4000,3995,3980,3982,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,958,SUCCESS,,3392.636466,192,0,0.1,0.2,0.3,263,1.4,1.5
    1554,5/26/2021 20:56,6228.088,1.73,701,300,10,6001,0,65535,65535,1,22.8,27927,-296,-296,100,88,11,3390,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3999,4000,3995,3980,3983,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,978,SUCCESS,,3392.306591,192,0,0.1,0.2,0.3,263,1.4,1.5
    1555,5/26/2021 20:56,6232.094,1.73,701,300,10,6001,0,65535,65535,1,22.8,27927,-296,-296,100,88,11,3390,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3998,4000,3995,3980,3982,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,953,SUCCESS,,3391.977209,192,0,0.1,0.2,0.3,263,1.4,1.5
    1556,5/26/2021 20:56,6236.096,1.73,701,300,10,6001,0,65535,65535,1,22.8,27925,-296,-296,100,88,11,3389,3888,682,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3998,3999,3995,3980,3982,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,939,SUCCESS,,3391.648155,192,0,0.1,0.2,0.3,263,1.4,1.5
    1557,5/26/2021 20:56,6240.101,1.73,701,300,10,6001,0,65535,65535,1,22.8,27923,-298,-297,100,88,11,3389,3888,687,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3998,3999,3994,3980,3982,3979,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,956,SUCCESS,,3391.31663,192,0,0.1,0.2,0.3,263,1.4,1.5
    1558,5/26/2021 20:56,6244.102,1.73,701,300,10,6001,0,65535,65535,1,22.8,27922,-294,-297,100,88,11,3389,3888,682,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3998,3999,3994,3980,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,1001,SUCCESS,,3390.989882,192,0,0.1,0.2,0.3,263,1.4,1.5
    1559,5/26/2021 20:56,6248.11,1.74,701,300,10,6001,0,65535,65535,1,22.8,27921,-298,-296,100,88,11,3388,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3998,3999,3994,3979,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,941,SUCCESS,,3390.658109,192,0,0.1,0.2,0.3,263,1.4,1.5
    1560,5/26/2021 20:56,6252.125,1.74,701,300,10,6001,0,65535,65535,1,22.8,27920,-296,-296,100,88,11,3388,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3992,3998,3999,3994,3979,3982,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.4,966,SUCCESS,,3390.327986,192,0,0.1,0.2,0.3,263,1.4,1.5
    1561,5/26/2021 20:57,6256.134,1.74,701,300,10,6001,0,65535,65535,1,22.8,27921,-296,-296,100,88,11,3388,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3991,3998,3999,3994,3979,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,954,SUCCESS,,3389.998358,192,0,0.1,0.2,0.3,263,1.4,1.5
    1562,5/26/2021 20:57,6260.143,1.74,701,300,10,6001,0,65535,65535,1,22.8,27920,-296,-296,100,88,11,3387,3888,682,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3991,3998,3999,3994,3979,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,971,SUCCESS,,3389.668729,192,0,0.1,0.2,0.3,263,1.4,1.5
    1563,5/26/2021 20:57,6264.143,1.74,701,300,10,6001,0,65535,65535,1,22.8,27918,-296,-296,100,88,11,3387,3888,691,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3991,3997,3998,3994,3979,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,976,SUCCESS,,3389.33984,192,0,0.1,0.2,0.3,263,1.4,1.5
    1564,5/26/2021 20:57,6268.154,1.74,701,300,10,6001,0,65535,65535,1,22.8,27917,-296,-296,100,88,11,3387,3888,687,687,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3991,3997,3998,3993,3979,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3389.010046,192,0,0.1,0.2,0.3,263,1.4,1.5
    1565,5/26/2021 20:57,6272.169,1.74,701,300,10,6001,0,65535,65535,1,22.8,27917,-298,-296,100,88,11,3386,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3991,3997,3998,3993,3979,3981,3978,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,965,SUCCESS,,3388.677694,192,0,0.1,0.2,0.3,263,1.4,1.5
    1566,5/26/2021 20:57,6276.184,1.74,701,300,10,6001,0,65535,65535,1,22.8,27916,-296,-296,100,88,11,3386,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3991,3997,3998,3993,3979,3981,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,943,SUCCESS,,3388.347571,192,0,0.1,0.2,0.3,263,1.4,1.5
    1567,5/26/2021 20:57,6280.199,1.74,701,300,10,6001,0,65535,65535,1,22.8,27915,-296,-296,100,88,11,3386,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3979,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,978,SUCCESS,,3388.017449,192,0,0.1,0.2,0.3,263,1.4,1.5
    1568,5/26/2021 20:57,6284.203,1.75,701,300,10,6001,0,65535,65535,1,22.8,27915,-294,-296,100,88,11,3386,3888,682,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3978,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,963,SUCCESS,,3387.690456,192,0,0.1,0.2,0.3,263,1.4,1.5
    1569,5/26/2021 20:57,6288.205,1.75,701,300,10,6001,0,65535,65535,1,22.8,27913,-294,-296,100,88,11,3385,3888,682,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3979,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,940,SUCCESS,,3387.363626,192,0,0.1,0.2,0.3,263,1.4,1.5
    1570,5/26/2021 20:57,6292.221,1.75,701,300,10,6001,0,65535,65535,1,22.8,27913,-298,-296,100,88,11,3385,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3978,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,938,SUCCESS,,3387.03119,192,0,0.1,0.2,0.3,263,1.4,1.5
    1571,5/26/2021 20:57,6296.222,1.75,701,300,10,6001,0,65535,65535,1,22.8,27913,-296,-296,100,88,11,3384,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3978,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3386.702219,192,0,0.1,0.2,0.3,263,1.4,1.5
    1572,5/26/2021 20:57,6300.227,1.75,701,300,10,6001,0,65535,65535,1,22.8,27913,-296,-296,100,88,11,3384,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3978,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,964,SUCCESS,,3386.372919,192,0,0.1,0.2,0.3,263,1.4,1.5
    1573,5/26/2021 20:57,6304.227,1.75,701,300,10,6001,0,65535,65535,1,22.8,27909,-298,-297,100,88,11,3384,3888,681,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3998,3993,3978,3980,3977,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,984,SUCCESS,,3386.041808,192,0,0.1,0.2,0.3,263,1.4,1.5
    1574,5/26/2021 20:57,6308.228,1.75,701,300,10,6001,0,65535,65535,1,22.8,27913,-294,-297,100,88,11,3383,3888,686,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3997,3997,3993,3978,3980,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.1,933,SUCCESS,,3385.71506,192,0,0.1,0.2,0.3,263,1.4,1.5
    1575,5/26/2021 20:57,6312.232,1.75,701,300,10,6001,0,65535,65535,1,22.8,27908,-300,-297,100,88,11,3383,3888,686,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3996,3997,3992,3978,3980,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,964,SUCCESS,,3385.381393,192,0,0.1,0.2,0.3,263,1.4,1.5
    1576,5/26/2021 20:58,6316.239,1.75,701,300,10,6001,0,65535,65535,1,22.8,27908,-298,-297,100,88,11,3383,3888,686,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3996,3997,3992,3978,3979,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,1015,SUCCESS,,3385.049703,192,0,0.1,0.2,0.3,263,1.4,1.5
    1577,5/26/2021 20:58,6320.248,1.76,701,300,10,6001,0,65535,65535,1,22.8,27908,-296,-296,100,87,11,3382,3888,690,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3996,3997,3992,3977,3979,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3384.720074,192,0,0.1,0.2,0.3,263,1.4,1.5
    1578,5/26/2021 20:58,6324.263,1.76,701,300,10,6001,0,65535,65535,1,22.8,27908,-296,-296,100,87,11,3382,3888,686,686,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3990,3996,3997,3992,3978,3979,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,981,SUCCESS,,3384.389951,192,0,0.1,0.2,0.3,263,1.4,1.5
    1579,5/26/2021 20:58,6328.278,1.76,701,300,10,6001,0,65535,65535,1,22.8,27907,-294,-297,100,87,11,3382,3888,686,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3996,3997,3992,3977,3979,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,965,SUCCESS,,3384.06206,192,0,0.1,0.2,0.3,263,1.4,1.5
    1580,5/26/2021 20:58,6332.293,1.76,701,300,10,6001,0,65535,65535,1,22.8,27906,-296,-296,100,87,11,3381,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3996,3997,3992,3977,3979,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3383.731938,192,0,0.1,0.2,0.3,263,1.4,1.5
    1581,5/26/2021 20:58,6336.293,1.76,701,300,10,6001,0,65535,65535,1,22.8,27906,-296,-296,100,87,11,3381,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3996,3997,3992,3976,3979,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,944,SUCCESS,,3383.403049,192,0,0.1,0.2,0.3,263,1.4,1.5
    1582,5/26/2021 20:58,6340.295,1.76,701,300,10,6001,0,65535,65535,1,22.8,27906,-294,-296,100,87,11,3381,3888,690,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3997,3992,3977,3979,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,944,SUCCESS,,3383.076219,192,0,0.1,0.2,0.3,263,1.4,1.5
    1583,5/26/2021 20:58,6344.304,1.76,701,300,10,6001,0,65535,65535,1,22.8,27904,-296,-296,100,87,11,3380,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3997,3991,3976,3978,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,981,SUCCESS,,3382.74659,192,0,0.1,0.2,0.3,263,1.4,1.5
    1584,5/26/2021 20:58,6348.306,1.76,701,300,10,6001,0,65535,65535,1,22.8,27903,-296,-296,100,87,11,3380,3888,681,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3996,3992,3976,3978,3976,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,1016,SUCCESS,,3382.417536,192,0,0.1,0.2,0.3,263,1.4,1.5
    1585,5/26/2021 20:58,6352.31,1.76,701,300,10,6001,0,65535,65535,1,22.8,27901,-296,-296,100,87,11,3380,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3996,3991,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,960,SUCCESS,,3382.088319,192,0,0.1,0.2,0.3,263,1.4,1.5
    1586,5/26/2021 20:58,6356.325,1.77,701,300,10,6001,0,65535,65535,1,22.8,27900,-296,-296,100,87,11,3379,3888,680,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3996,3991,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.6,945,SUCCESS,,3381.758196,192,0,0.1,0.2,0.3,263,1.4,1.5
    1587,5/26/2021 20:58,6360.335,1.77,701,300,10,6001,0,65535,65535,1,22.8,27901,-296,-296,100,87,11,3379,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3996,3991,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,958,SUCCESS,,3381.428485,192,0,0.1,0.2,0.3,263,1.4,1.5
    1588,5/26/2021 20:58,6364.34,1.77,701,300,10,6001,0,65535,65535,1,22.8,27900,-294,-296,100,87,11,3379,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3996,3991,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,968,SUCCESS,,3381.10141,192,0,0.1,0.2,0.3,263,1.4,1.5
    1589,5/26/2021 20:58,6368.345,1.77,701,300,10,6001,0,65535,65535,1,22.8,27898,-296,-296,100,87,11,3379,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3989,3995,3996,3991,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,946,SUCCESS,,3380.77211,192,0,0.1,0.2,0.3,263,1.4,1.5
    1590,5/26/2021 20:58,6372.347,1.77,701,300,10,6001,0,65535,65535,1,22.8,27899,-296,-297,100,87,11,3378,3888,680,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3988,3995,3996,3991,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,976,SUCCESS,,3380.443057,192,0,0.1,0.2,0.3,263,1.4,1.5
    1591,5/26/2021 20:59,6376.359,1.77,701,300,10,6001,0,65535,65535,1,22.8,27899,-296,-296,100,87,11,3378,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3988,3995,3995,3990,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,941,SUCCESS,,3380.113181,192,0,0.1,0.2,0.3,263,1.4,1.5
    1592,5/26/2021 20:59,6380.372,1.77,701,300,10,6001,0,65535,65535,1,22.8,27894,-298,-297,100,87,11,3378,3888,680,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3988,3994,3995,3990,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,955,SUCCESS,,3379.780994,192,0,0.1,0.2,0.3,263,1.4,1.5
    1593,5/26/2021 20:59,6384.378,1.77,701,300,10,6001,0,65535,65535,1,22.8,27896,-296,-297,100,87,11,3377,3888,685,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3988,3994,3995,3990,3976,3978,3975,0,0,0,0,0,0,0,0,2788,22.6,22.8,-273.2,22.8,-273.2,22.8,943,SUCCESS,,3379.451612,192,0,0.1,0.2,0.3,263,1.4,1.5
    1594,5/26/2021 20:59,6388.391,1.77,701,300,10,6001,0,65535,65535,1,22.8,27896,-298,-296,100,87,11,3377,3888,685,685,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3988,3994,3995,3990,3976,3978,3974,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.8,945,SUCCESS,,3379.119425,192,0,0.1,0.2,0.3,263,1.4,1.5
    1595,5/26/2021 20:59,6392.396,1.78,701,300,10,6001,0,65535,65535,1,22.8,27895,-296,-297,100,87,11,3377,3888,685,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3994,3995,3990,3976,3978,3975,0,0,0,0,0,0,0,0,2789,22.6,22.8,-273.2,22.8,-273.2,22.7,975,SUCCESS,,3378.790125,192,0,0.1,0.2,0.3,263,1.4,1.5
    1596,5/26/2021 20:59,6396.407,1.78,701,300,10,6001,0,65535,65535,1,22.8,27894,-296,-296,100,87,11,3376,3888,684,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3994,3995,3990,3975,3977,3974,0,0,0,0,0,0,0,0,2785,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3378.460331,192,0,0.1,0.2,0.3,263,1.4,1.5
    1597,5/26/2021 20:59,6400.416,1.78,701,300,10,6001,0,65535,65535,1,22.8,27893,-296,-296,100,87,11,3376,3888,680,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3994,3995,3990,3975,3977,3974,0,0,0,0,0,0,0,0,2788,22.6,22.8,-273.2,22.8,-273.2,22.4,981,SUCCESS,,3378.130703,192,0,0.1,0.2,0.3,263,1.4,1.5
    1598,5/26/2021 20:59,6404.427,1.78,701,300,10,6001,0,65535,65535,1,22.8,27894,-296,-296,100,87,11,3376,3888,680,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3994,3995,3990,3975,3977,3974,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,951,SUCCESS,,3377.800909,192,0,0.1,0.2,0.3,263,1.4,1.5
    1599,5/26/2021 20:59,6408.441,1.78,701,300,10,6001,0,65535,65535,1,22.8,27891,-296,-296,100,87,11,3375,3888,680,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3993,3994,3990,3975,3977,3974,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,993,SUCCESS,,3377.470869,192,0,0.1,0.2,0.3,263,1.4,1.5
    1600,5/26/2021 20:59,6412.446,1.78,701,300,10,6001,0,65535,65535,1,22.8,27890,-300,-296,100,87,11,3375,3888,684,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3993,3995,3990,3975,3977,3974,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,939,SUCCESS,,3377.137119,192,0,0.1,0.2,0.3,263,1.4,1.5
    1601,5/26/2021 20:59,6416.448,1.78,701,300,10,6001,0,65535,65535,1,22.8,27889,-296,-296,100,87,11,3374,3888,684,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3993,3995,3990,3975,3977,3974,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,965,SUCCESS,,3376.808066,192,0,0.1,0.2,0.3,263,1.4,1.5
    1602,5/26/2021 20:59,6420.452,1.78,701,300,10,6001,0,65535,65535,1,22.8,27887,-298,-296,100,87,11,3374,3888,679,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3993,3994,3989,3975,3977,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,981,SUCCESS,,3376.476624,192,0,0.1,0.2,0.3,263,1.4,1.5
    1603,5/26/2021 20:59,6424.464,1.78,701,300,10,6001,0,65535,65535,1,22.8,27887,-296,-297,100,87,11,3374,3888,684,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3993,3994,3989,3975,3976,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3376.146748,192,0,0.1,0.2,0.3,263,1.4,1.5
    1604,5/26/2021 20:59,6428.465,1.79,701,300,10,6001,0,65535,65535,1,22.8,27888,-296,-296,100,87,11,3373,3888,684,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3993,3994,3989,3975,3976,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,944,SUCCESS,,3375.817777,192,0,0.1,0.2,0.3,263,1.4,1.5
    1605,5/26/2021 20:59,6432.469,1.79,701,300,10,6001,0,65535,65535,1,22.8,27885,-298,-297,100,87,11,3373,3888,679,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3987,3993,3994,3989,3975,3976,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.6,941,SUCCESS,,3375.486335,192,0,0.1,0.2,0.3,263,1.4,1.5
    1606,5/26/2021 21:00,6436.475,1.79,701,300,10,6001,0,65535,65535,1,22.8,27884,-296,-297,100,87,11,3373,3888,684,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3993,3994,3989,3975,3976,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.4,945,SUCCESS,,3375.156953,192,0,0.1,0.2,0.3,263,1.4,1.5
    1607,5/26/2021 21:00,6440.484,1.79,701,300,10,6001,0,65535,65535,1,22.8,27884,-296,-296,100,87,11,3373,3888,684,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3993,3993,3989,3974,3977,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,941,SUCCESS,,3374.827324,192,0,0.1,0.2,0.3,263,1.4,1.5
    1608,5/26/2021 21:00,6444.492,1.79,701,300,10,6001,0,65535,65535,1,22.8,27884,-298,-297,100,87,11,3372,3888,679,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3989,3974,3976,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,950,SUCCESS,,3374.49555,192,0,0.1,0.2,0.3,263,1.4,1.5
    1609,5/26/2021 21:00,6448.494,1.79,701,300,10,6001,0,65535,65535,1,22.8,27884,-296,-297,100,87,11,3372,3888,684,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3989,3974,3976,3973,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3374.166497,192,0,0.1,0.2,0.3,263,1.4,1.5
    1610,5/26/2021 21:00,6452.496,1.79,701,300,10,6001,0,65535,65535,1,22.8,27883,-298,-296,100,87,11,3372,3888,679,684,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3988,3974,3977,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,947,SUCCESS,,3373.83522,192,0,0.1,0.2,0.3,263,1.4,1.5
    1611,5/26/2021 21:00,6456.506,1.79,701,300,10,6001,0,65535,65535,1,22.8,27882,-298,-296,100,87,11,3371,3888,679,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3988,3973,3976,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.6,973,SUCCESS,,3373.503281,192,0,0.1,0.2,0.3,263,1.4,1.5
    1612,5/26/2021 21:00,6460.512,1.79,701,300,10,6001,0,65535,65535,1,22.8,27880,-296,-296,100,87,11,3371,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3988,3973,3975,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3373.173899,192,0,0.1,0.2,0.3,263,1.4,1.5
    1613,5/26/2021 21:00,6464.527,1.8,701,300,10,6001,0,65535,65535,1,22.8,27879,-298,-296,100,87,11,3371,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3988,3973,3976,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3372.841546,192,0,0.1,0.2,0.3,263,1.4,1.5
    1614,5/26/2021 21:00,6468.531,1.8,701,300,10,6001,0,65535,65535,1,22.8,27878,-296,-296,100,87,11,3370,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3985,3992,3993,3988,3973,3975,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,948,SUCCESS,,3372.512329,192,0,0.1,0.2,0.3,263,1.4,1.5
    1615,5/26/2021 21:00,6472.543,1.8,701,300,10,6001,0,65535,65535,1,22.8,27879,-296,-296,100,87,11,3370,3888,688,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3986,3992,3993,3988,3973,3974,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,945,SUCCESS,,3372.182453,192,0,0.1,0.2,0.3,263,1.4,1.5
    1616,5/26/2021 21:00,6476.546,1.8,701,300,10,6001,0,65535,65535,1,22.8,27878,-296,-296,100,87,11,3370,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3985,3992,3993,3988,3973,3979,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,964,SUCCESS,,3371.853318,192,0,0.1,0.2,0.3,263,1.4,1.5
    1617,5/26/2021 21:00,6480.556,1.8,701,300,10,6001,0,65535,65535,1,22.8,27878,-296,-296,100,87,11,3369,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3985,3992,3992,3987,3973,3975,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3371.523606,192,0,0.1,0.2,0.3,263,1.4,1.5
    1618,5/26/2021 21:00,6484.564,1.8,701,300,10,6001,0,65535,65535,1,22.8,27876,-298,-296,100,87,11,3369,3888,688,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3985,3991,3992,3987,3973,3974,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,977,SUCCESS,,3371.191833,192,0,0.1,0.2,0.3,263,1.4,1.5
    1619,5/26/2021 21:00,6488.575,1.8,701,300,10,6001,0,65535,65535,1,22.8,27875,-296,-296,100,87,11,3369,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3985,3992,3992,3987,3973,3976,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,965,SUCCESS,,3370.86204,192,0,0.1,0.2,0.3,263,1.4,1.5
    1620,5/26/2021 21:00,6492.58,1.8,701,300,10,6001,0,65535,65535,1,22.8,27875,-296,-296,100,87,11,3368,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3985,3991,3992,3987,3973,3975,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,958,SUCCESS,,3370.53274,192,0,0.1,0.2,0.3,263,1.4,1.5
    1621,5/26/2021 21:01,6496.594,1.8,701,300,10,6001,0,65535,65535,1,22.8,27871,-296,-296,100,87,11,3368,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3991,3992,3987,3973,3973,3972,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,939,SUCCESS,,3370.2027,192,0,0.1,0.2,0.3,263,1.4,1.5
    1622,5/26/2021 21:01,6500.61,1.81,701,300,10,6001,0,65535,65535,1,22.8,27872,-296,-296,100,87,11,3368,3888,678,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3991,3992,3987,3972,3976,3971,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,970,SUCCESS,,3369.872495,192,0,0.1,0.2,0.3,263,1.4,1.5
    1623,5/26/2021 21:01,6504.61,1.81,701,300,10,6001,0,65535,65535,1,22.8,27872,-296,-296,100,87,11,3367,3888,683,683,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3991,3992,3987,3972,3974,3971,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,994,SUCCESS,,3369.543606,192,0,0.1,0.2,0.3,263,1.4,1.5
    1624,5/26/2021 21:01,6508.625,1.81,701,300,10,6001,0,65535,65535,1,22.8,27871,-298,-297,100,87,11,3367,3888,678,680,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3991,3992,3987,3972,3974,3971,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3369.211254,192,0,0.1,0.2,0.3,263,1.4,1.5
    1625,5/26/2021 21:01,6512.642,1.81,701,300,10,6001,0,65535,65535,1,22.8,27870,-294,-297,100,87,11,3367,3888,683,680,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3992,3987,3972,3974,3971,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,986,SUCCESS,,3368.883199,192,0,0.1,0.2,0.3,263,1.4,1.5
    1626,5/26/2021 21:01,6516.656,1.81,701,300,10,6001,0,65535,65535,1,22.8,27870,-296,-296,100,87,11,3366,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3992,3987,3972,3974,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,977,SUCCESS,,3368.553159,192,0,0.1,0.2,0.3,263,1.4,1.5
    1627,5/26/2021 21:01,6520.656,1.81,701,300,10,6001,0,65535,65535,1,22.8,27870,-296,-296,100,87,11,3366,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3992,3987,3972,3973,3971,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,977,SUCCESS,,3368.22427,192,0,0.1,0.2,0.3,263,1.4,1.5
    1628,5/26/2021 21:01,6524.672,1.81,701,300,10,6001,0,65535,65535,1,22.8,27867,-294,-296,100,87,11,3366,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3991,3986,3972,3974,3971,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,964,SUCCESS,,3367.896296,192,0,0.1,0.2,0.3,263,1.4,1.5
    1629,5/26/2021 21:01,6528.688,1.81,701,300,10,6001,0,65535,65535,1,22.8,27868,-298,-296,100,87,11,3365,3888,678,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3991,3986,3972,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,940,SUCCESS,,3367.563861,192,0,0.1,0.2,0.3,263,1.4,1.5
    1630,5/26/2021 21:01,6532.688,1.81,701,300,10,6001,0,65535,65535,1,22.8,27866,-294,-296,100,87,11,3365,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3991,3986,3972,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3367.237194,192,0,0.1,0.2,0.3,263,1.4,1.5
    1631,5/26/2021 21:01,6536.703,1.82,701,300,10,6001,0,65535,65535,1,22.8,27866,-294,-296,100,87,11,3365,3888,687,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3984,3990,3991,3986,3972,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,940,SUCCESS,,3366.909303,192,0,0.1,0.2,0.3,263,1.4,1.5
    1632,5/26/2021 21:01,6540.703,1.82,701,300,10,6001,0,65535,65535,1,22.8,27865,-298,-296,100,87,11,3364,3888,687,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3990,3991,3986,3971,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,950,SUCCESS,,3366.578191,192,0,0.1,0.2,0.3,263,1.4,1.5
    1633,5/26/2021 21:01,6544.72,1.82,701,300,10,6001,0,65535,65535,1,22.8,27864,-298,-296,100,87,11,3364,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3990,3991,3986,3971,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,955,SUCCESS,,3366.245673,192,0,0.1,0.2,0.3,263,1.4,1.5
    1634,5/26/2021 21:01,6548.72,1.82,701,300,10,6001,0,65535,65535,1,22.8,27863,-294,-296,100,87,11,3364,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3990,3991,3986,3971,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,954,SUCCESS,,3365.919006,192,0,0.1,0.2,0.3,263,1.4,1.5
    1635,5/26/2021 21:01,6552.735,1.82,701,300,10,6001,0,65535,65535,1,22.8,27863,-298,-296,100,87,11,3363,3888,677,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3990,3990,3986,3971,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,972,SUCCESS,,3365.586654,192,0,0.1,0.2,0.3,263,1.4,1.5
    1636,5/26/2021 21:02,6556.749,1.82,701,300,10,6001,0,65535,65535,1,22.8,27862,-296,-296,100,87,11,3363,3888,682,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3989,3990,3986,3971,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3365.256614,192,0,0.1,0.2,0.3,263,1.4,1.5
    1637,5/26/2021 21:02,6560.752,1.82,701,300,10,6001,0,65535,65535,1,22.8,27862,-298,-296,100,87,11,3363,3888,677,682,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3989,3990,3986,3971,3973,3970,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,947,SUCCESS,,3364.925254,192,0,0.1,0.2,0.3,263,1.4,1.5
    1638,5/26/2021 21:02,6564.781,1.82,701,300,10,6001,0,65535,65535,1,22.8,27861,-296,-296,100,87,11,3362,3888,681,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3989,3990,3985,3970,3973,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,949,SUCCESS,,3364.593981,192,0,0.1,0.2,0.3,263,1.4,1.5
    1639,5/26/2021 21:02,6568.796,1.82,701,300,10,6001,0,65535,65535,1,22.8,27860,-296,-296,100,87,11,3362,3888,681,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3989,3990,3985,3971,3973,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22,946,SUCCESS,,3364.263859,192,0,0.1,0.2,0.3,263,1.4,1.5
    1640,5/26/2021 21:02,6572.724,1.83,701,300,10,6001,0,65535,65535,1,22.8,27858,-298,-297,100,87,11,3362,3888,677,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3983,3989,3990,3985,3970,3972,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,935,SUCCESS,,3363.938708,192,0,0.1,0.2,0.3,263,1.4,1.5
    1641,5/26/2021 21:02,6576.739,1.83,701,300,10,6001,0,65535,65535,1,22.8,27857,-296,-297,100,87,11,3361,3888,681,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3989,3990,3985,3970,3972,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,937,SUCCESS,,3363.608585,192,0,0.1,0.2,0.3,263,1.4,1.5
    1642,5/26/2021 21:02,6580.739,1.83,701,300,10,6001,0,65535,65535,1,22.8,27857,-298,-297,100,87,11,3361,3888,677,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3989,3990,3985,3970,3973,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3363.277474,192,0,0.1,0.2,0.3,263,1.4,1.5
    1643,5/26/2021 21:02,6584.752,1.83,701,300,10,6001,0,65535,65535,1,22.8,27856,-298,-297,100,87,11,3361,3888,677,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3989,3990,3984,3970,3972,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.6,946,SUCCESS,,3362.945287,192,0,0.1,0.2,0.3,263,1.4,1.5
    1644,5/26/2021 21:02,6588.752,1.83,701,300,10,6001,0,65535,65535,1,22.8,27856,-296,-297,100,87,11,3360,3888,681,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3989,3989,3984,3970,3972,3969,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,974,SUCCESS,,3362.616398,192,0,0.1,0.2,0.3,263,1.4,1.5
    1645,5/26/2021 21:02,6592.767,1.83,701,300,10,6001,0,65535,65535,1,22.8,27854,-296,-297,100,87,11,3360,3888,681,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3988,3989,3984,3970,3972,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,976,SUCCESS,,3362.286276,192,0,0.1,0.2,0.3,263,1.4,1.5
    1646,5/26/2021 21:02,6596.78,1.83,701,300,10,6001,0,65535,65535,1,22.8,27854,-296,-297,100,87,11,3360,3888,681,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3988,3989,3984,3969,3971,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3361.956318,192,0,0.1,0.2,0.3,263,1.4,1.5
    1647,5/26/2021 21:02,6600.783,1.83,701,300,10,6001,0,65535,65535,1,22.8,27853,-298,-297,100,87,11,3359,3888,676,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3988,3989,3984,3969,3972,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3361.624959,192,0,0.1,0.2,0.3,263,1.4,1.5
    1648,5/26/2021 21:02,6604.788,1.83,701,300,10,6001,0,65535,65535,1,22.8,27851,-296,-297,100,87,11,3359,3888,681,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3982,3988,3989,3984,3969,3972,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.8,972,SUCCESS,,3361.295659,192,0,0.1,0.2,0.3,263,1.4,1.5
    1649,5/26/2021 21:02,6608.791,1.84,701,300,10,6001,0,65535,65535,1,22.8,27850,-296,-297,100,87,11,3359,3888,676,679,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3988,3989,3984,3970,3971,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,966,SUCCESS,,3360.966523,192,0,0.1,0.2,0.3,263,1.4,1.5
    1650,5/26/2021 21:02,6612.799,1.84,701,300,10,6001,0,65535,65535,1,22.8,27851,-296,-296,100,87,11,3358,3888,681,681,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3989,3984,3969,3972,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3360.636976,192,0,0.1,0.2,0.3,263,1.4,1.5
    1651,5/26/2021 21:03,6616.803,1.84,701,300,10,6001,0,65535,65535,1,22.8,27849,-298,-297,100,87,11,3358,3888,676,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3989,3984,3969,3971,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,955,SUCCESS,,3360.305534,192,0,0.1,0.2,0.3,263,1.4,1.5
    1652,5/26/2021 21:03,6620.809,1.84,701,300,10,6001,0,65535,65535,1,22.8,27848,-296,-297,100,87,11,3358,3888,681,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3988,3989,3984,3969,3970,3968,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,942,SUCCESS,,3359.976152,192,0,0.1,0.2,0.3,263,1.4,1.5
    1653,5/26/2021 21:03,6624.822,1.84,701,300,10,6001,0,65535,65535,1,22.8,27847,-296,-297,100,87,11,3357,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3988,3983,3969,3971,3967,0,0,0,0,0,0,0,0,2781,22.6,22.8,-273.2,22.8,-273.2,22.8,966,SUCCESS,,3359.646194,192,0,0.1,0.2,0.3,263,1.4,1.5
    1654,5/26/2021 21:03,6628.833,1.84,701,300,10,6001,0,65535,65535,1,22.8,27847,-298,-297,100,87,11,3357,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3988,3983,3969,3971,3967,0,0,0,0,0,0,0,0,2784,22.6,22.8,-273.2,22.8,-273.2,22.7,1031,SUCCESS,,3359.314173,192,0,0.1,0.2,0.3,263,1.4,1.5
    1655,5/26/2021 21:03,6632.836,1.84,701,300,10,6001,0,65535,65535,1,22.8,27845,-296,-297,100,87,11,3357,3888,685,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3988,3983,3969,3971,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,978,SUCCESS,,3358.985037,192,0,0.1,0.2,0.3,263,1.4,1.5
    1656,5/26/2021 21:03,6636.838,1.84,701,300,10,6001,0,65535,65535,1,22.8,27846,-296,-297,100,87,11,3356,3888,676,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3988,3983,3969,3971,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,949,SUCCESS,,3358.655984,192,0,0.1,0.2,0.3,263,1.4,1.5
    1657,5/26/2021 21:03,6640.848,1.84,701,300,10,6001,0,65535,65535,1,22.8,27844,-296,-297,100,87,11,3356,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3981,3987,3988,3983,3969,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,957,SUCCESS,,3358.326273,192,0,0.1,0.2,0.3,263,1.4,1.5
    1658,5/26/2021 21:03,6644.853,1.85,701,300,10,6001,0,65535,65535,1,22.8,27843,-296,-297,100,87,11,3356,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3987,3988,3983,3969,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,961,SUCCESS,,3357.996973,192,0,0.1,0.2,0.3,263,1.4,1.5
    1659,5/26/2021 21:03,6648.864,1.85,701,300,10,6001,0,65535,65535,1,22.8,27843,-298,-297,100,87,11,3355,3888,676,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3987,3988,3983,3968,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,959,SUCCESS,,3357.664951,192,0,0.1,0.2,0.3,263,1.4,1.5
    1660,5/26/2021 21:03,6652.873,1.85,701,300,10,6001,0,65535,65535,1,22.8,27843,-294,-297,100,87,11,3355,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3986,3988,3983,3968,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3357.337549,192,0,0.1,0.2,0.3,263,1.4,1.5
    1661,5/26/2021 21:03,6656.876,1.85,701,300,10,6001,0,65535,65535,1,22.8,27841,-300,-297,100,87,11,3355,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3987,3987,3983,3968,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,939,SUCCESS,,3357.003966,192,0,0.1,0.2,0.3,263,1.4,1.5
    1662,5/26/2021 21:03,6660.89,1.85,701,300,10,6001,0,65535,65535,1,22.8,27841,-294,-297,100,87,11,3354,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3986,3987,3983,3968,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3356.676156,192,0,0.1,0.2,0.3,263,1.4,1.5
    1663,5/26/2021 21:03,6664.903,1.85,701,300,10,6001,0,65535,65535,1,22.8,27842,-296,-297,100,87,11,3354,3888,684,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3986,3987,3983,3968,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,949,SUCCESS,,3356.346198,192,0,0.1,0.2,0.3,263,1.4,1.5
    1664,5/26/2021 21:03,6668.916,1.85,701,300,10,6001,0,65535,65535,1,22.8,27839,-296,-297,100,87,11,3354,3888,680,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3986,3987,3983,3968,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.6,966,SUCCESS,,3356.01624,192,0,0.1,0.2,0.3,263,1.4,1.5
    1665,5/26/2021 21:04,6672.918,1.85,701,300,10,6001,0,65535,65535,1,22.8,27838,-296,-297,100,87,11,3353,3888,680,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3980,3986,3987,3982,3967,3970,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,949,SUCCESS,,3355.687187,192,0,0.1,0.2,0.3,263,1.4,1.5
    1666,5/26/2021 21:04,6676.926,1.85,701,300,10,6001,0,65535,65535,1,22.8,27838,-298,-297,100,87,11,3353,3888,684,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3987,3982,3967,3970,3967,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,972,SUCCESS,,3355.355414,192,0,0.1,0.2,0.3,263,1.4,1.5
    1667,5/26/2021 21:04,6680.932,1.86,701,300,10,6001,0,65535,65535,1,22.8,27836,-298,-297,100,87,11,3353,3888,680,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3987,3982,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,953,SUCCESS,,3355.023806,192,0,0.1,0.2,0.3,263,1.4,1.5
    1668,5/26/2021 21:04,6684.933,1.86,701,300,10,6001,0,65535,65535,1,22.8,27836,-296,-297,100,87,11,3352,3888,675,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3987,3982,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,964,SUCCESS,,3354.694835,192,0,0.1,0.2,0.3,263,1.4,1.5
    1669,5/26/2021 21:04,6688.948,1.86,701,300,10,6001,0,65535,65535,1,22.8,27837,-296,-297,100,87,11,3352,3888,679,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3987,3982,3967,3970,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3354.364713,192,0,0.1,0.2,0.3,263,1.4,1.5
    1670,5/26/2021 21:04,6692.959,1.86,701,300,10,6001,0,65535,65535,1,22.8,27836,-298,-297,100,87,11,3352,3888,675,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3987,3982,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,935,SUCCESS,,3354.032691,192,0,0.1,0.2,0.3,263,1.4,1.5
    1671,5/26/2021 21:04,6696.971,1.86,701,300,10,6001,0,65535,65535,1,22.8,27834,-296,-297,100,87,11,3351,3888,684,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3987,3981,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,961,SUCCESS,,3353.702815,192,0,0.1,0.2,0.3,263,1.4,1.5
    1672,5/26/2021 21:04,6700.975,1.86,701,300,10,6001,0,65535,65535,1,22.8,27837,-298,-297,100,87,11,3351,3888,675,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3986,3986,3981,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,935,SUCCESS,,3353.371373,192,0,0.1,0.2,0.3,263,1.4,1.5
    1673,5/26/2021 21:04,6704.989,1.86,701,300,10,6001,0,65535,65535,1,22.8,27833,-296,-297,100,87,11,3351,3888,675,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3985,3986,3981,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,953,SUCCESS,,3353.041333,192,0,0.1,0.2,0.3,263,1.4,1.5
    1674,5/26/2021 21:04,6708.992,1.86,701,300,10,6001,0,65535,65535,1,22.8,27833,-296,-297,100,87,11,3350,3888,679,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3985,3986,3981,3967,3969,3966,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3352.712198,192,0,0.1,0.2,0.3,263,1.4,1.5
    1675,5/26/2021 21:04,6712.997,1.86,701,300,10,6001,0,65535,65535,1,22.8,27833,-298,-297,100,87,11,3350,3888,674,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3979,3985,3986,3981,3967,3969,3965,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,942,SUCCESS,,3352.380673,192,0,0.1,0.2,0.3,263,1.4,1.5
    1676,5/26/2021 21:04,6717.011,1.87,701,300,10,6001,0,65535,65535,1,22.8,27831,-296,-297,100,87,11,3350,3888,679,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3985,3986,3981,3966,3968,3965,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,992,SUCCESS,,3352.050633,192,0,0.1,0.2,0.3,263,1.4,1.5
    1677,5/26/2021 21:04,6721.021,1.87,701,300,10,6001,0,65535,65535,1,22.8,27829,-298,-297,100,87,11,3349,3888,674,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3985,3986,3981,3966,3968,3965,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,997,SUCCESS,,3351.718694,192,0,0.1,0.2,0.3,263,1.4,1.5
    1678,5/26/2021 21:04,6725.023,1.87,701,300,10,6001,0,65535,65535,1,22.8,27833,-298,-297,100,87,11,3349,3888,674,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3985,3986,3981,3966,3968,3965,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,996,SUCCESS,,3351.387417,192,0,0.1,0.2,0.3,263,1.4,1.5
    1679,5/26/2021 21:04,6729.028,1.87,701,300,10,6001,0,65535,65535,1,22.8,27828,-298,-297,100,87,11,3349,3888,674,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3986,3981,3966,3968,3965,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3351.055892,192,0,0.1,0.2,0.3,263,1.4,1.5
    1680,5/26/2021 21:05,6733.034,1.87,701,300,10,6001,0,65535,65535,1,22.8,27828,-298,-297,100,87,11,3348,3888,674,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3985,3981,3966,3967,3965,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,943,SUCCESS,,3350.724284,192,0,0.1,0.2,0.3,263,1.4,1.5
    1681,5/26/2021 21:05,6737.036,1.87,701,300,10,6001,0,65535,65535,1,22.8,27828,-296,-297,100,87,11,3348,3888,679,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3985,3981,3966,3969,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3350.395231,192,0,0.1,0.2,0.3,263,1.4,1.5
    1682,5/26/2021 21:05,6741.045,1.87,701,300,10,6001,0,65535,65535,1,22.8,27825,-296,-297,100,87,11,3348,3888,679,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3985,3980,3966,3968,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,961,SUCCESS,,3350.065602,192,0,0.1,0.2,0.3,263,1.4,1.5
    1683,5/26/2021 21:05,6745.052,1.87,701,300,10,6001,0,65535,65535,1,22.8,27824,-298,-297,100,87,11,3347,3888,674,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3985,3981,3966,3966,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3349.733911,192,0,0.1,0.2,0.3,263,1.4,1.5
    1684,5/26/2021 21:05,6749.063,1.87,701,300,10,6001,0,65535,65535,1,22.8,27824,-296,-297,100,87,11,3347,3888,678,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3985,3980,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.6,942,SUCCESS,,3349.404118,192,0,0.1,0.2,0.3,263,1.4,1.5
    1685,5/26/2021 21:05,6753.078,1.88,701,300,10,6001,0,65535,65535,1,22.8,27824,-298,-297,100,87,11,3347,3888,674,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3984,3985,3980,3966,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,993,SUCCESS,,3349.071765,192,0,0.1,0.2,0.3,263,1.4,1.5
    1686,5/26/2021 21:05,6757.08,1.88,701,300,10,6001,0,65535,65535,1,22.8,27823,-298,-297,100,87,11,3346,3888,674,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3978,3984,3985,3980,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3348.740489,192,0,0.1,0.2,0.3,263,1.4,1.5
    1687,5/26/2021 21:05,6761.092,1.88,701,300,10,6001,0,65535,65535,1,22.8,27821,-296,-297,100,87,11,3346,3888,678,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3984,3984,3980,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,946,SUCCESS,,3348.410613,192,0,0.1,0.2,0.3,263,1.4,1.5
    1688,5/26/2021 21:05,6765.096,1.88,701,300,10,6001,0,65535,65535,1,22.8,27821,-298,-297,100,87,11,3346,3888,674,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3984,3984,3980,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3348.079171,192,0,0.1,0.2,0.3,263,1.4,1.5
    1689,5/26/2021 21:05,6769.106,1.88,701,300,10,6001,0,65535,65535,1,22.8,27821,-294,-297,100,87,11,3345,3888,678,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3984,3985,3980,3965,3964,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3347.751688,192,0,0.1,0.2,0.3,263,1.4,1.5
    1690,5/26/2021 21:05,6773.112,1.88,701,300,10,6001,0,65535,65535,1,22.8,27820,-296,-297,100,87,11,3345,3888,678,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3983,3984,3979,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,944,SUCCESS,,3347.422305,192,0,0.1,0.2,0.3,263,1.4,1.5
    1691,5/26/2021 21:05,6777.113,1.88,701,300,10,6001,0,65535,65535,1,22.8,27819,-298,-297,100,87,11,3345,3888,673,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3983,3984,3979,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,973,SUCCESS,,3347.091111,192,0,0.1,0.2,0.3,263,1.4,1.5
    1692,5/26/2021 21:05,6781.118,1.88,701,300,10,6001,0,65535,65535,1,22.8,27817,-296,-297,100,87,11,3344,3888,678,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3983,3984,3979,3965,3967,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3346.761811,192,0,0.1,0.2,0.3,263,1.4,1.5
    1693,5/26/2021 21:05,6785.13,1.88,701,300,10,6001,0,65535,65535,1,22.8,27817,-298,-297,100,87,11,3344,3888,673,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3977,3983,3984,3979,3965,3966,3964,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,987,SUCCESS,,3346.429707,192,0,0.1,0.2,0.3,263,1.4,1.5
    1694,5/26/2021 21:05,6789.135,1.89,701,300,10,6001,0,65535,65535,1,22.8,27816,-298,-297,100,87,11,3344,3888,673,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3983,3984,3979,3965,3967,3963,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,953,SUCCESS,,3346.098182,192,0,0.1,0.2,0.3,263,1.4,1.5
    1695,5/26/2021 21:06,6793.141,1.89,701,300,10,6001,0,65535,65535,1,22.8,27816,-296,-297,100,86,11,3343,3888,678,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3983,3984,3979,3965,3967,3963,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,944,SUCCESS,,3345.7688,192,0,0.1,0.2,0.3,263,1.4,1.5
    1696,5/26/2021 21:06,6797.149,1.89,701,300,10,6001,0,65535,65535,1,22.8,27814,-298,-297,100,86,11,3343,3888,678,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3983,3983,3979,3964,3966,3963,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,1002,SUCCESS,,3345.437026,192,0,0.1,0.2,0.3,263,1.4,1.5
    1697,5/26/2021 21:06,6801.161,1.89,701,300,10,6001,0,65535,65535,1,22.8,27814,-296,-296,100,86,11,3343,3888,678,678,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3983,3983,3978,3964,3966,3963,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,988,SUCCESS,,3345.107151,192,0,0.1,0.2,0.3,263,1.4,1.5
    1698,5/26/2021 21:06,6805.167,1.89,701,300,10,6001,0,65535,65535,1,22.8,27814,-296,-296,100,86,11,3342,3888,677,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3983,3983,3979,3964,3967,3963,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.8,976,SUCCESS,,3344.777769,192,0,0.1,0.2,0.3,263,1.4,1.5
    1699,5/26/2021 21:06,6809.174,1.89,701,300,10,6001,0,65535,65535,1,22.8,27812,-296,-296,100,86,11,3342,3888,673,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3983,3983,3978,3964,3965,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,959,SUCCESS,,3344.448304,192,0,0.1,0.2,0.3,263,1.4,1.5
    1700,5/26/2021 21:06,6813.176,1.89,701,300,10,6001,0,65535,65535,1,22.8,27811,-296,-297,100,86,11,3342,3888,677,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3982,3983,3978,3964,3966,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.6,951,SUCCESS,,3344.119251,192,0,0.1,0.2,0.3,263,1.4,1.5
    1701,5/26/2021 21:06,6817.191,1.89,701,300,10,6001,0,65535,65535,1,22.8,27810,-298,-296,100,86,11,3341,3888,677,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3982,3983,3978,3964,3966,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3343.786898,192,0,0.1,0.2,0.3,263,1.4,1.5
    1702,5/26/2021 21:06,6821.203,1.89,701,300,10,6001,0,65535,65535,1,22.8,27809,-296,-297,100,86,11,3341,3888,673,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3976,3982,3983,3978,3963,3966,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,947,SUCCESS,,3343.457023,192,0,0.1,0.2,0.3,263,1.4,1.5
    1703,5/26/2021 21:06,6825.205,1.9,701,300,10,6001,0,65535,65535,1,22.8,27808,-298,-296,100,86,11,3341,3888,677,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3982,3983,3978,3963,3965,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,970,SUCCESS,,3343.125746,192,0,0.1,0.2,0.3,263,1.4,1.5
    1704,5/26/2021 21:06,6829.219,1.9,701,300,10,6001,0,65535,65535,1,22.8,27809,-298,-297,100,86,11,3340,3888,672,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3982,3983,3978,3963,3966,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3342.793476,192,0,0.1,0.2,0.3,263,1.4,1.5
    1705,5/26/2021 21:06,6833.223,1.9,701,300,10,6001,0,65535,65535,1,22.8,27808,-298,-297,100,86,11,3340,3888,672,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3982,3983,3978,3963,3965,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.6,1005,SUCCESS,,3342.462034,192,0,0.1,0.2,0.3,263,1.4,1.5
    1706,5/26/2021 21:06,6837.225,1.9,701,300,10,6001,0,65535,65535,1,22.8,27806,-296,-297,100,86,11,3340,3888,677,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3983,3978,3963,3965,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,981,SUCCESS,,3342.13298,192,0,0.1,0.2,0.3,263,1.4,1.5
    1707,5/26/2021 21:06,6841.237,1.9,701,300,10,6001,0,65535,65535,1,22.8,27807,-296,-297,100,86,11,3339,3888,677,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3983,3978,3963,3965,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,937,SUCCESS,,3341.803105,192,0,0.1,0.2,0.3,263,1.4,1.5
    1708,5/26/2021 21:06,6845.244,1.9,701,300,10,6001,0,65535,65535,1,22.8,27805,-296,-297,100,86,11,3339,3888,681,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3982,3977,3963,3965,3962,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,998,SUCCESS,,3341.47364,192,0,0.1,0.2,0.3,263,1.4,1.5
    1709,5/26/2021 21:06,6849.249,1.9,701,300,10,6001,0,65535,65535,1,22.8,27803,-296,-296,100,86,11,3339,3888,681,677,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3982,3977,3963,3965,3961,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.4,945,SUCCESS,,3341.14434,192,0,0.1,0.2,0.3,263,1.4,1.5
    1710,5/26/2021 21:07,6853.253,1.9,701,300,10,6001,0,65535,65535,1,22.8,27804,-298,-297,100,86,11,3338,3888,672,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3982,3977,3963,3965,3961,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.6,937,SUCCESS,,3340.812898,192,0,0.1,0.2,0.3,263,1.4,1.5
    1711,5/26/2021 21:07,6857.268,1.9,701,300,10,6001,0,65535,65535,1,22.8,27802,-298,-297,100,86,11,3338,3888,677,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3982,3977,3962,3965,3961,0,0,0,0,0,0,0,0,2776,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3340.480545,192,0,0.1,0.2,0.3,263,1.4,1.5
    1712,5/26/2021 21:07,6861.273,1.91,701,300,10,6001,0,65535,65535,1,22.8,27801,-296,-297,100,86,11,3338,3888,677,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3981,3982,3977,3962,3964,3961,0,0,0,0,0,0,0,0,2779,22.6,22.8,-273.2,22.8,-273.2,22.7,963,SUCCESS,,3340.151245,192,0,0.1,0.2,0.3,263,1.4,1.5
    1713,5/26/2021 21:07,6865.282,1.91,701,300,10,6001,0,65535,65535,1,22.8,27802,-300,-297,100,86,11,3337,3888,676,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3982,3977,3962,3964,3961,0,0,0,0,0,0,0,0,2780,22.6,22.8,-273.2,22.8,-273.2,22.7,939,SUCCESS,,3339.817162,192,0,0.1,0.2,0.3,263,1.4,1.5
    1714,5/26/2021 21:07,6869.296,1.91,701,300,10,6001,0,65535,65535,1,22.8,27802,-296,-297,100,86,11,3337,3888,676,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3975,3981,3982,3977,3962,3964,3961,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,940,SUCCESS,,3339.487122,192,0,0.1,0.2,0.3,263,1.4,1.5
    1715,5/26/2021 21:07,6873.307,1.91,701,300,10,6001,0,65535,65535,1,22.8,27800,-298,-297,100,86,11,3337,3888,672,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3981,3981,3977,3962,3964,3961,0,0,0,0,0,0,0,0,2779,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3339.1551,192,0,0.1,0.2,0.3,263,1.4,1.5
    1716,5/26/2021 21:07,6877.309,1.91,701,300,10,6001,0,65535,65535,1,22.8,27801,-294,-297,100,86,11,3336,3888,681,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3980,3981,3977,3962,3964,3961,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3338.82827,192,0,0.1,0.2,0.3,263,1.4,1.5
    1717,5/26/2021 21:07,6881.309,1.91,701,300,10,6001,0,65535,65535,1,22.8,27798,-296,-296,100,86,11,3336,3888,676,676,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3980,3981,3976,3962,3964,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.6,942,SUCCESS,,3338.499381,192,0,0.1,0.2,0.3,263,1.4,1.5
    1718,5/26/2021 21:07,6885.316,1.91,701,300,10,6001,0,65535,65535,1,22.8,27798,-298,-297,100,86,11,3336,3888,672,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3980,3981,3976,3962,3963,3961,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.8,997,SUCCESS,,3338.167691,192,0,0.1,0.2,0.3,263,1.4,1.5
    1719,5/26/2021 21:07,6889.323,1.91,701,300,10,6001,0,65535,65535,1,22.8,27797,-296,-297,100,86,11,3335,3888,676,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3980,3981,3976,3961,3964,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3337.838226,192,0,0.1,0.2,0.3,263,1.4,1.5
    1720,5/26/2021 21:07,6893.331,1.91,701,300,10,6001,0,65535,65535,1,22.8,27796,-296,-297,100,86,11,3335,3888,676,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3980,3981,3976,3961,3964,3961,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,983,SUCCESS,,3337.50868,192,0,0.1,0.2,0.3,263,1.4,1.5
    1721,5/26/2021 21:07,6897.332,1.92,701,300,10,6001,0,65535,65535,1,22.8,27795,-298,-297,100,86,11,3335,3888,671,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3980,3981,3976,3961,3963,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,954,SUCCESS,,3337.177486,192,0,0.1,0.2,0.3,263,1.4,1.5
    1722,5/26/2021 21:07,6901.336,1.92,701,300,10,6001,0,65535,65535,1,22.8,27795,-296,-297,100,86,11,3334,3888,676,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3980,3981,3976,3961,3964,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,935,SUCCESS,,3336.848268,192,0,0.1,0.2,0.3,263,1.4,1.5
    1723,5/26/2021 21:07,6905.348,1.92,701,300,10,6001,0,65535,65535,1,22.8,27794,-296,-297,100,86,11,3334,3888,676,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3974,3980,3981,3976,3961,3963,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.8,935,SUCCESS,,3336.518393,192,0,0.1,0.2,0.3,263,1.4,1.5
    1724,5/26/2021 21:07,6909.359,1.92,701,300,10,6001,0,65535,65535,1,22.8,27793,-298,-297,100,86,11,3334,3888,671,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3980,3976,3961,3963,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3336.186371,192,0,0.1,0.2,0.3,263,1.4,1.5
    1725,5/26/2021 21:08,6913.371,1.92,701,300,10,6001,0,65535,65535,1,22.8,27793,-296,-297,100,86,11,3333,3888,676,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3980,3975,3961,3963,3960,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,946,SUCCESS,,3335.856495,192,0,0.1,0.2,0.3,263,1.4,1.5
    1726,5/26/2021 21:08,6917.376,1.92,701,300,10,6001,0,65535,65535,1,22.8,27792,-296,-297,100,86,11,3333,3888,671,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3981,3975,3961,3963,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,955,SUCCESS,,3335.527195,192,0,0.1,0.2,0.3,263,1.4,1.5
    1727,5/26/2021 21:08,6921.389,1.92,701,300,10,6001,0,65535,65535,1,22.8,27789,-296,-297,100,86,11,3333,3888,680,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3980,3975,3961,3963,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,955,SUCCESS,,3335.197238,192,0,0.1,0.2,0.3,263,1.4,1.5
    1728,5/26/2021 21:08,6925.395,1.92,701,300,10,6001,0,65535,65535,1,22.8,27790,-298,-297,100,86,11,3332,3888,671,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3980,3975,3961,3963,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,943,SUCCESS,,3334.86563,192,0,0.1,0.2,0.3,263,1.4,1.5
    1729,5/26/2021 21:08,6929.403,1.92,701,300,10,6001,0,65535,65535,1,22.8,27789,-296,-297,100,86,11,3332,3888,675,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3980,3975,3961,3962,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.8,948,SUCCESS,,3334.536083,192,0,0.1,0.2,0.3,263,1.4,1.5
    1730,5/26/2021 21:08,6933.411,1.93,701,300,10,6001,0,65535,65535,1,22.8,27788,-296,-296,100,86,11,3332,3888,675,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3973,3979,3980,3975,3961,3963,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,996,SUCCESS,,3334.206536,192,0,0.1,0.2,0.3,263,1.4,1.5
    1731,5/26/2021 21:08,6937.418,1.93,701,300,10,6001,0,65535,65535,1,22.8,27786,-294,-296,100,86,11,3331,3888,675,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3979,3980,3975,3960,3962,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,943,SUCCESS,,3333.879298,192,0,0.1,0.2,0.3,263,1.4,1.5
    1732,5/26/2021 21:08,6941.426,1.93,701,300,10,6001,0,65535,65535,1,22.8,27786,-298,-297,100,86,11,3331,3888,671,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3979,3979,3975,3960,3962,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,950,SUCCESS,,3333.547525,192,0,0.1,0.2,0.3,263,1.4,1.5
    1733,5/26/2021 21:08,6945.437,1.93,701,300,10,6001,0,65535,65535,1,22.8,27785,-296,-296,100,86,11,3331,3888,680,675,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3979,3979,3975,3960,3962,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.8,962,SUCCESS,,3333.217731,192,0,0.1,0.2,0.3,263,1.4,1.5
    1734,5/26/2021 21:08,6949.442,1.93,701,300,10,6001,0,65535,65535,1,22.8,27786,-298,-297,100,86,11,3330,3888,675,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3975,3960,3962,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,987,SUCCESS,,3332.886206,192,0,0.1,0.2,0.3,263,1.4,1.5
    1735,5/26/2021 21:08,6953.457,1.93,701,300,10,6001,0,65535,65535,1,22.8,27785,-296,-297,100,86,11,3330,3888,670,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3975,3960,3962,3959,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,1004,SUCCESS,,3332.556084,192,0,0.1,0.2,0.3,263,1.4,1.5
    1736,5/26/2021 21:08,6957.463,1.93,701,300,10,6001,0,65535,65535,1,22.8,27783,-298,-297,100,86,11,3330,3888,670,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3974,3960,3962,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,961,SUCCESS,,3332.224476,192,0,0.1,0.2,0.3,263,1.4,1.5
    1737,5/26/2021 21:08,6961.471,1.93,701,300,10,6001,0,65535,65535,1,22.8,27783,-298,-297,100,86,11,3329,3888,670,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3974,3960,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.4,963,SUCCESS,,3331.892703,192,0,0.1,0.2,0.3,263,1.4,1.5
    1738,5/26/2021 21:08,6965.486,1.93,701,300,10,6001,0,65535,65535,1,22.8,27782,-296,-297,100,86,11,3329,3888,675,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3974,3960,3962,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,955,SUCCESS,,3331.562581,192,0,0.1,0.2,0.3,263,1.4,1.5
    1739,5/26/2021 21:08,6969.501,1.94,701,300,10,6001,0,65535,65535,1,22.8,27777,-298,-297,100,86,11,3329,3888,670,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3974,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,939,SUCCESS,,3331.230228,192,0,0.1,0.2,0.3,263,1.4,1.5
    1740,5/26/2021 21:09,6973.502,1.94,701,300,10,6001,0,65535,65535,1,22.8,27781,-296,-297,100,86,11,3328,3888,675,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3974,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,939,SUCCESS,,3330.901257,192,0,0.1,0.2,0.3,263,1.4,1.5
    1741,5/26/2021 21:09,6977.505,1.94,701,300,10,6001,0,65535,65535,1,22.8,27781,-296,-297,100,86,11,3328,3888,679,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3972,3978,3979,3974,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,942,SUCCESS,,3330.572121,192,0,0.1,0.2,0.3,263,1.4,1.5
    1742,5/26/2021 21:09,6981.512,1.94,701,300,10,6001,0,65535,65535,1,22.8,27780,-294,-297,100,86,11,3328,3888,675,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3971,3978,3979,3974,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3330.244883,192,0,0.1,0.2,0.3,263,1.4,1.5
    1743,5/26/2021 21:09,6985.525,1.94,701,300,10,6001,0,65535,65535,1,22.8,27779,-296,-297,100,86,11,3327,3888,674,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3971,3978,3978,3974,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,948,SUCCESS,,3329.914925,192,0,0.1,0.2,0.3,263,1.4,1.5
    1744,5/26/2021 21:09,6989.538,1.94,701,300,10,6001,0,65535,65535,1,22.8,27778,-296,-297,100,86,11,3327,3888,674,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3971,3977,3978,3974,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3329.584968,192,0,0.1,0.2,0.3,263,1.4,1.5
    1745,5/26/2021 21:09,6993.55,1.94,701,300,10,6001,0,65535,65535,1,22.8,27777,-298,-297,100,86,11,3327,3888,670,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3971,3978,3978,3973,3959,3961,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,968,SUCCESS,,3329.252863,192,0,0.1,0.2,0.3,263,1.4,1.5
    1746,5/26/2021 21:09,6997.563,1.94,701,300,10,6001,0,65535,65535,1,22.8,27777,-296,-297,100,86,11,3326,3888,674,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3971,3977,3978,3973,3959,3960,3958,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3328.922905,192,0,0.1,0.2,0.3,263,1.4,1.5
    1747,5/26/2021 21:09,7001.569,1.94,701,300,10,6001,0,65535,65535,1,22.8,27776,-294,-296,100,86,11,3326,3888,679,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3971,3977,3978,3973,3958,3961,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,970,SUCCESS,,3328.595749,192,0,0.1,0.2,0.3,263,1.4,1.5
    1748,5/26/2021 21:09,7005.581,1.95,701,300,10,6001,0,65535,65535,1,22.8,27775,-296,-296,100,86,11,3326,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3977,3978,3973,3959,3961,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,940,SUCCESS,,3328.265873,192,0,0.1,0.2,0.3,263,1.4,1.5
    1749,5/26/2021 21:09,7009.583,1.95,701,300,10,6001,0,65535,65535,1,22.8,27773,-296,-296,100,86,11,3325,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3977,3978,3973,3959,3961,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.6,940,SUCCESS,,3327.93682,192,0,0.1,0.2,0.3,263,1.4,1.5
    1750,5/26/2021 21:09,7013.587,1.95,701,300,10,6001,0,65535,65535,1,22.8,27773,-296,-296,100,86,11,3325,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3978,3973,3958,3960,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.6,995,SUCCESS,,3327.607602,192,0,0.1,0.2,0.3,263,1.4,1.5
    1751,5/26/2021 21:09,7017.596,1.95,701,300,10,6001,0,65535,65535,1,22.8,27771,-296,-296,100,86,11,3325,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3978,3973,3958,3960,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,967,SUCCESS,,3327.277973,192,0,0.1,0.2,0.3,263,1.4,1.5
    1752,5/26/2021 21:09,7021.609,1.95,701,300,10,6001,0,65535,65535,1,22.8,27770,-296,-296,100,86,11,3324,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3977,3973,3958,3960,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3326.948015,192,0,0.1,0.2,0.3,263,1.4,1.5
    1753,5/26/2021 21:09,7025.612,1.95,701,300,10,6001,0,65535,65535,1,22.8,27769,-296,-296,100,86,11,3324,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3977,3972,3958,3960,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3326.61888,192,0,0.1,0.2,0.3,263,1.4,1.5
    1754,5/26/2021 21:09,7029.625,1.95,701,300,10,6001,0,65535,65535,1,22.8,27772,-298,-296,100,86,11,3324,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3977,3972,3958,3960,3957,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,956,SUCCESS,,3326.286693,192,0,0.1,0.2,0.3,263,1.4,1.5
    1755,5/26/2021 21:10,7033.634,1.95,701,300,10,6001,0,65535,65535,1,22.8,27769,-298,-296,100,86,11,3323,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3977,3972,3958,3960,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.8,953,SUCCESS,,3325.954836,192,0,0.1,0.2,0.3,263,1.4,1.5
    1756,5/26/2021 21:10,7037.642,1.95,701,300,10,6001,0,65535,65535,1,22.8,27769,-294,-296,100,86,11,3323,3888,678,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3977,3972,3958,3960,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.6,938,SUCCESS,,3325.627516,192,0,0.1,0.2,0.3,263,1.4,1.5
    1757,5/26/2021 21:10,7041.656,1.96,701,300,10,6001,0,65535,65535,1,22.8,27769,-296,-296,100,86,11,3323,3888,674,674,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3970,3976,3977,3972,3958,3961,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,954,SUCCESS,,3325.297476,192,0,0.1,0.2,0.3,263,1.4,1.5
    1758,5/26/2021 21:10,7045.659,1.96,701,300,10,6001,0,65535,65535,1,22.8,27768,-298,-296,100,86,11,3322,3888,669,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3976,3977,3972,3957,3959,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3324.966117,192,0,0.1,0.2,0.3,263,1.4,1.5
    1759,5/26/2021 21:10,7049.666,1.96,701,300,10,6001,0,65535,65535,1,22.8,27766,-298,-296,100,86,11,3322,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3972,3957,3959,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,965,SUCCESS,,3324.634426,192,0,0.1,0.2,0.3,263,1.4,1.5
    1760,5/26/2021 21:10,7053.683,1.96,701,300,10,6001,0,65535,65535,1,22.8,27765,-296,-296,100,86,11,3322,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3976,3977,3972,3957,3960,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,977,SUCCESS,,3324.30414,192,0,0.1,0.2,0.3,263,1.4,1.5
    1761,5/26/2021 21:10,7057.688,1.96,701,300,10,6001,0,65535,65535,1,22.8,27763,-298,-296,100,86,11,3321,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3972,3957,3959,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,939,SUCCESS,,3323.972615,192,0,0.1,0.2,0.3,263,1.4,1.5
    1762,5/26/2021 21:10,7061.691,1.96,701,300,10,6001,0,65535,65535,1,22.8,27764,-296,-296,100,86,11,3321,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3972,3957,3958,3956,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3323.643479,192,0,0.1,0.2,0.3,263,1.4,1.5
    1763,5/26/2021 21:10,7065.706,1.96,701,300,10,6001,0,65535,65535,1,22.8,27764,-296,-296,100,86,11,3321,3888,669,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3972,3957,3959,3955,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3323.313357,192,0,0.1,0.2,0.3,263,1.4,1.5
    1764,5/26/2021 21:10,7069.715,1.96,701,300,10,6001,0,65535,65535,1,22.8,27762,-296,-296,100,86,11,3320,3888,668,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3971,3957,3959,3955,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.6,983,SUCCESS,,3322.983728,192,0,0.1,0.2,0.3,263,1.4,1.5
    1765,5/26/2021 21:10,7073.726,1.96,701,300,10,6001,0,65535,65535,1,22.8,27761,-296,-296,100,86,11,3320,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3971,3956,3957,3955,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.2,995,SUCCESS,,3322.653935,192,0,0.1,0.2,0.3,263,1.4,1.5
    1766,5/26/2021 21:10,7077.727,1.97,701,300,10,6001,0,65535,65535,1,22.8,27760,-294,-296,100,86,11,3320,3888,678,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3971,3956,3958,3955,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,962,SUCCESS,,3322.327186,192,0,0.1,0.2,0.3,263,1.4,1.5
    1767,5/26/2021 21:10,7081.728,1.97,701,300,10,6001,0,65535,65535,1,22.8,27761,-296,-296,100,86,11,3319,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3971,3956,3958,3955,0,0,0,0,0,0,0,0,2775,22.6,22.8,-273.2,22.8,-273.2,22.7,972,SUCCESS,,3321.998215,192,0,0.1,0.2,0.3,263,1.4,1.5
    1768,5/26/2021 21:10,7085.733,1.97,701,300,10,6001,0,65535,65535,1,22.8,27760,-294,-296,100,86,11,3319,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3971,3956,3956,3955,0,0,0,0,0,0,0,0,2772,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3321.67114,192,0,0.1,0.2,0.3,263,1.4,1.5
    1769,5/26/2021 21:10,7089.737,1.97,701,300,10,6001,0,65535,65535,1,22.8,27758,-298,-296,100,86,11,3319,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3969,3975,3976,3971,3956,3958,3955,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3321.339698,192,0,0.1,0.2,0.3,263,1.4,1.5
    1770,5/26/2021 21:11,7093.744,1.97,701,300,10,6001,0,65535,65535,1,22.8,27758,-296,-296,100,86,11,3318,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3968,3975,3976,3971,3956,3958,3955,0,0,0,0,0,0,0,0,2774,22.6,22.8,-273.2,22.8,-273.2,22.7,979,SUCCESS,,3321.010234,192,0,0.1,0.2,0.3,263,1.4,1.5
    1771,5/26/2021 21:11,7097.746,1.97,701,300,10,6001,0,65535,65535,1,22.8,27757,-298,-296,100,86,11,3318,3888,673,673,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3968,3974,3975,3970,3956,3958,3955,0,0,0,0,0,0,0,0,2774,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3320.678957,192,0,0.1,0.2,0.3,263,1.4,1.5
    1772,5/26/2021 21:11,7101.754,1.97,701,300,10,6001,0,65535,65535,1,22.8,27756,-296,-297,100,86,11,3318,3888,668,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3968,3974,3975,3970,3956,3958,3955,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3320.34941,192,0,0.1,0.2,0.3,263,1.4,1.5
    1773,5/26/2021 21:11,7105.764,1.97,701,300,10,6001,0,65535,65535,1,22.8,27756,-296,-297,100,86,11,3317,3888,672,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3968,3974,3975,3970,3956,3958,3955,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,956,SUCCESS,,3320.019699,192,0,0.1,0.2,0.3,263,1.4,1.5
    1774,5/26/2021 21:11,7109.773,1.97,701,300,10,6001,0,65535,65535,1,22.8,27755,-298,-297,100,86,11,3317,3888,668,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3974,3975,3970,3956,3956,3955,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.8,948,SUCCESS,,3319.687843,192,0,0.1,0.2,0.3,263,1.4,1.5
    1775,5/26/2021 21:11,7113.787,1.98,701,300,10,6001,0,65535,65535,1,22.8,27755,-296,-297,100,86,11,3317,3888,672,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3974,3975,3970,3956,3957,3955,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,956,SUCCESS,,3319.357803,192,0,0.1,0.2,0.3,263,1.4,1.5
    1776,5/26/2021 21:11,7117.787,1.98,701,300,10,6001,0,65535,65535,1,22.8,27753,-296,-296,100,86,11,3317,3888,677,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3975,3970,3955,3958,3955,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,969,SUCCESS,,3319.028914,192,0,0.1,0.2,0.3,263,1.4,1.5
    1777,5/26/2021 21:11,7121.792,1.98,701,300,10,6001,0,65535,65535,1,22.8,27752,-298,-296,100,86,11,3316,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3975,3970,3955,3958,3954,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,966,SUCCESS,,3318.697389,192,0,0.1,0.2,0.3,263,1.4,1.5
    1778,5/26/2021 21:11,7125.806,1.98,701,300,10,6001,0,65535,65535,1,22.8,27751,-294,-296,100,86,11,3316,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3975,3970,3955,3957,3954,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,961,SUCCESS,,3318.369579,192,0,0.1,0.2,0.3,263,1.4,1.5
    1779,5/26/2021 21:11,7129.816,1.98,701,300,10,6001,0,65535,65535,1,22.8,27751,-298,-296,100,86,11,3316,3888,668,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3975,3970,3955,3957,3954,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.1,949,SUCCESS,,3318.03764,192,0,0.1,0.2,0.3,263,1.4,1.5
    1780,5/26/2021 21:11,7133.815,1.98,701,300,10,6001,0,65535,65535,1,22.8,27752,-296,-296,100,86,11,3315,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3970,3955,3957,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3317.708834,192,0,0.1,0.2,0.3,263,1.4,1.5
    1781,5/26/2021 21:11,7137.817,1.98,701,300,10,6001,0,65535,65535,1,22.8,27749,-296,-296,100,86,11,3315,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3969,3955,3956,3954,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,987,SUCCESS,,3317.37978,192,0,0.1,0.2,0.3,263,1.4,1.5
    1782,5/26/2021 21:11,7141.824,1.98,701,300,10,6001,0,65535,65535,1,22.8,27749,-298,-296,100,86,11,3314,3888,667,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3969,3955,3957,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,952,SUCCESS,,3317.04809,192,0,0.1,0.2,0.3,263,1.4,1.5
    1783,5/26/2021 21:11,7145.826,1.98,701,300,10,6001,0,65535,65535,1,22.8,27748,-296,-296,100,86,11,3314,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3969,3955,3957,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3316.719036,192,0,0.1,0.2,0.3,263,1.4,1.5
    1784,5/26/2021 21:11,7149.834,1.99,701,300,10,6001,0,65535,65535,1,22.8,27747,-296,-296,100,86,11,3314,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3969,3955,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,1012,SUCCESS,,3316.38949,192,0,0.1,0.2,0.3,263,1.4,1.5
    1785,5/26/2021 21:12,7153.846,1.99,701,300,10,6001,0,65535,65535,1,22.8,27747,-298,-296,100,86,11,3313,3888,667,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3969,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,952,SUCCESS,,3316.057385,192,0,0.1,0.2,0.3,263,1.4,1.5
    1786,5/26/2021 21:12,7157.852,1.99,701,300,10,6001,0,65535,65535,1,22.8,27746,-296,-296,100,86,11,3313,3888,672,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3967,3973,3974,3969,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,965,SUCCESS,,3315.728003,192,0,0.1,0.2,0.3,263,1.4,1.5
    1787,5/26/2021 21:12,7161.859,1.99,701,300,10,6001,0,65535,65535,1,22.8,27744,-298,-296,100,86,11,3313,3888,667,672,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3969,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,956,SUCCESS,,3315.396313,192,0,0.1,0.2,0.3,263,1.4,1.5
    1788,5/26/2021 21:12,7165.866,1.99,701,300,10,6001,0,65535,65535,1,22.8,27743,-296,-296,100,86,11,3312,3888,671,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3969,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,954,SUCCESS,,3315.066848,192,0,0.1,0.2,0.3,263,1.4,1.5
    1789,5/26/2021 21:12,7169.88,1.99,701,300,10,6001,0,65535,65535,1,22.8,27743,-296,-296,100,86,11,3312,3888,671,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3969,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,973,SUCCESS,,3314.736808,192,0,0.1,0.2,0.3,263,1.4,1.5
    1790,5/26/2021 21:12,7173.896,1.99,701,300,10,6001,0,65535,65535,1,22.8,27743,-294,-296,100,86,11,3312,3888,676,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3969,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,940,SUCCESS,,3314.408835,192,0,0.1,0.2,0.3,263,1.4,1.5
    1791,5/26/2021 21:12,7177.899,1.99,701,300,10,6001,0,65535,65535,1,22.8,27742,-296,-297,100,86,11,3311,3888,671,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3968,3953,3956,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,985,SUCCESS,,3314.079699,192,0,0.1,0.2,0.3,263,1.4,1.5
    1792,5/26/2021 21:12,7181.904,1.99,701,300,10,6001,0,65535,65535,1,22.8,27741,-294,-296,100,86,11,3311,3888,676,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3968,3954,3956,3953,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,965,SUCCESS,,3313.752624,192,0,0.1,0.2,0.3,263,1.4,1.5
    1793,5/26/2021 21:12,7185.909,2,701,300,10,6001,0,65535,65535,1,22.8,27739,-298,-296,100,86,11,3311,3888,671,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3968,3953,3956,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.4,962,SUCCESS,,3313.421099,192,0,0.1,0.2,0.3,263,1.4,1.5
    1794,5/26/2021 21:12,7189.918,2,701,300,10,6001,0,65535,65535,1,22.8,27740,-296,-296,100,86,11,3310,3888,676,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3972,3968,3953,3955,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,960,SUCCESS,,3313.09147,192,0,0.1,0.2,0.3,263,1.4,1.5
    1795,5/26/2021 21:12,7193.921,2,701,300,10,6001,0,65535,65535,1,22.8,27739,-294,-296,100,86,11,3310,3888,676,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3966,3972,3973,3968,3953,3956,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,977,SUCCESS,,3312.764559,192,0,0.1,0.2,0.3,263,1.4,1.5
    1796,5/26/2021 21:12,7197.935,2,701,300,10,6001,0,65535,65535,1,22.8,27738,-296,-296,100,86,11,3310,3888,666,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3972,3973,3968,3953,3956,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,948,SUCCESS,,3312.434519,192,0,0.1,0.2,0.3,263,1.4,1.5
    1797,5/26/2021 21:12,7201.946,2,701,300,10,6001,0,65535,65535,1,22.8,27736,-296,-296,100,86,11,3310,3888,671,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3971,3972,3968,3953,3955,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,1000,SUCCESS,,3312.104725,192,0,0.1,0.2,0.3,263,1.4,1.5
    1798,5/26/2021 21:12,7205.954,2,701,300,10,6001,0,65535,65535,1,22.8,27736,-298,-296,100,86,11,3309,3888,671,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3971,3972,3967,3953,3955,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3311.772952,192,0,0.1,0.2,0.3,263,1.4,1.5
    1799,5/26/2021 21:12,7209.96,2,701,300,10,6001,0,65535,65535,1,22.8,27735,-298,-296,100,86,11,3309,3888,671,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3971,3972,3967,3953,3955,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,949,SUCCESS,,3311.441344,192,0,0.1,0.2,0.3,263,1.4,1.5
    1800,5/26/2021 21:13,7213.962,2,701,300,10,6001,0,65535,65535,1,22.8,27735,-296,-296,100,86,11,3309,3888,675,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3971,3972,3967,3953,3955,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,960,SUCCESS,,3311.112291,192,0,0.1,0.2,0.3,263,1.4,1.5
    1801,5/26/2021 21:13,7217.968,2,701,300,10,6001,0,65535,65535,1,22.8,27734,-298,-296,100,86,11,3308,3888,666,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3971,3972,3967,3953,3955,3952,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,971,SUCCESS,,3310.780683,192,0,0.1,0.2,0.3,263,1.4,1.5
    1802,5/26/2021 21:13,7221.972,2.01,701,300,10,6001,0,65535,65535,1,22.8,27734,-296,-297,100,86,11,3308,3888,671,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3965,3971,3972,3967,3953,3955,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,937,SUCCESS,,3310.451465,192,0,0.1,0.2,0.3,263,1.4,1.5
    1803,5/26/2021 21:13,7225.978,2.01,701,300,10,6001,0,65535,65535,1,22.8,27733,-294,-296,100,86,11,3308,3888,675,671,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3971,3972,3967,3953,3954,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,983,SUCCESS,,3310.124309,192,0,0.1,0.2,0.3,263,1.4,1.5
    1804,5/26/2021 21:13,7229.987,2.01,701,300,10,6001,0,65535,65535,1,22.8,27731,-298,-297,100,86,11,3307,3888,666,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3967,3952,3954,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,941,SUCCESS,,3309.792453,192,0,0.1,0.2,0.3,263,1.4,1.5
    1805,5/26/2021 21:13,7233.991,2.01,701,300,10,6001,0,65535,65535,1,22.8,27730,-298,-297,100,86,11,3307,3888,670,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3967,3952,3955,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,983,SUCCESS,,3309.46101,192,0,0.1,0.2,0.3,263,1.4,1.5
    1806,5/26/2021 21:13,7238.007,2.01,701,300,10,6001,0,65535,65535,1,22.8,27729,-298,-296,100,86,11,3307,3888,675,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3309.128575,192,0,0.1,0.2,0.3,263,1.4,1.5
    1807,5/26/2021 21:13,7242.014,2.01,701,300,10,6001,0,65535,65535,1,22.8,27730,-294,-297,100,86,11,3306,3888,675,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,949,SUCCESS,,3308.801336,192,0,0.1,0.2,0.3,263,1.4,1.5
    1808,5/26/2021 21:13,7246.026,2.01,701,300,10,6001,0,65535,65535,1,22.8,27728,-296,-296,100,86,11,3306,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3951,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,960,SUCCESS,,3308.471461,192,0,0.1,0.2,0.3,263,1.4,1.5
    1809,5/26/2021 21:13,7250.028,2.01,701,300,10,6001,0,65535,65535,1,22.8,27726,-296,-296,100,86,11,3306,3888,665,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,948,SUCCESS,,3308.142408,192,0,0.1,0.2,0.3,263,1.4,1.5
    1810,5/26/2021 21:13,7254.036,2.02,701,300,10,6001,0,65535,65535,1,22.8,27727,-296,-296,100,86,11,3305,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,987,SUCCESS,,3307.812861,192,0,0.1,0.2,0.3,263,1.4,1.5
    1811,5/26/2021 21:13,7258.039,2.02,701,300,10,6001,0,65535,65535,1,22.8,27727,-294,-296,100,86,11,3305,3888,674,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3307.485949,192,0,0.1,0.2,0.3,263,1.4,1.5
    1812,5/26/2021 21:13,7262.054,2.02,701,300,10,6001,0,65535,65535,1,22.8,27726,-298,-296,100,85,11,3304,3888,665,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3964,3970,3971,3966,3952,3954,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,933,SUCCESS,,3307.153596,192,0,0.1,0.2,0.3,263,1.4,1.5
    1813,5/26/2021 21:13,7266.061,2.02,701,300,10,6001,0,65535,65535,1,22.8,27724,-296,-296,100,85,11,3304,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3970,3970,3966,3951,3953,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,940,SUCCESS,,3306.824132,192,0,0.1,0.2,0.3,263,1.4,1.5
    1814,5/26/2021 21:13,7270.065,2.02,701,300,10,6001,0,65535,65535,1,22.8,27724,-296,-296,100,85,11,3304,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3970,3971,3966,3952,3953,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,938,SUCCESS,,3306.494914,192,0,0.1,0.2,0.3,263,1.4,1.5
    1815,5/26/2021 21:14,7274.07,2.02,701,300,10,6001,0,65535,65535,1,22.8,27721,-296,-296,100,85,11,3304,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3969,3970,3966,3952,3954,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,964,SUCCESS,,3306.165614,192,0,0.1,0.2,0.3,263,1.4,1.5
    1816,5/26/2021 21:14,7278.085,2.02,701,300,10,6001,0,65535,65535,1,22.8,27722,-296,-296,100,85,11,3303,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3969,3970,3966,3951,3953,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3305.835492,192,0,0.1,0.2,0.3,263,1.4,1.5
    1817,5/26/2021 21:14,7282.092,2.02,701,300,10,6001,0,65535,65535,1,22.8,27722,-296,-296,100,85,11,3303,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3969,3970,3966,3951,3953,3950,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,945,SUCCESS,,3305.506028,192,0,0.1,0.2,0.3,263,1.4,1.5
    1818,5/26/2021 21:14,7286.095,2.02,701,300,10,6001,0,65535,65535,1,22.8,27722,-298,-296,100,85,11,3303,3888,670,670,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3969,3970,3965,3951,3953,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,975,SUCCESS,,3305.174668,192,0,0.1,0.2,0.3,263,1.4,1.5
    1819,5/26/2021 21:14,7290.101,2.03,701,300,10,6001,0,65535,65535,1,22.8,27720,-296,-296,100,85,11,3302,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3969,3970,3966,3951,3953,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,963,SUCCESS,,3304.845286,192,0,0.1,0.2,0.3,263,1.4,1.5
    1820,5/26/2021 21:14,7294.115,2.03,701,300,10,6001,0,65535,65535,1,22.8,27721,-296,-296,100,85,11,3302,3888,665,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3963,3969,3970,3965,3951,3953,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,936,SUCCESS,,3304.515246,192,0,0.1,0.2,0.3,263,1.4,1.5
    1821,5/26/2021 21:14,7298.121,2.03,701,300,10,6001,0,65535,65535,1,22.8,27718,-296,-296,100,85,11,3302,3888,665,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3969,3970,3965,3950,3953,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22,955,SUCCESS,,3304.185864,192,0,0.1,0.2,0.3,263,1.4,1.5
    1822,5/26/2021 21:14,7302.126,2.03,701,300,10,6001,0,65535,65535,1,22.8,27717,-294,-296,100,85,11,3301,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3969,3970,3965,3950,3952,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,938,SUCCESS,,3303.858789,192,0,0.1,0.2,0.3,263,1.4,1.5
    1823,5/26/2021 21:14,7306.131,2.03,701,300,10,6001,0,65535,65535,1,22.8,27718,-294,-296,100,85,11,3301,3888,665,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3969,3970,3965,3950,3953,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,951,SUCCESS,,3303.531714,192,0,0.1,0.2,0.3,263,1.4,1.5
    1824,5/26/2021 21:14,7310.133,2.03,701,300,10,6001,0,65535,65535,1,22.8,27718,-296,-296,100,85,11,3301,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3969,3969,3965,3950,3953,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,987,SUCCESS,,3303.20266,192,0,0.1,0.2,0.3,263,1.4,1.5
    1825,5/26/2021 21:14,7314.134,2.03,701,300,10,6001,0,65535,65535,1,22.8,27714,-296,-296,100,85,11,3300,3888,664,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3950,3952,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,982,SUCCESS,,3302.873689,192,0,0.1,0.2,0.3,263,1.4,1.5
    1826,5/26/2021 21:14,7318.144,2.03,701,300,10,6001,0,65535,65535,1,22.8,27714,-296,-296,100,85,11,3300,3888,664,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3950,3952,3949,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,971,SUCCESS,,3302.543978,192,0,0.1,0.2,0.3,263,1.4,1.5
    1827,5/26/2021 21:14,7322.148,2.03,701,300,10,6001,0,65535,65535,1,22.8,27714,-296,-296,100,85,11,3300,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3950,3952,3948,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,946,SUCCESS,,3302.21476,192,0,0.1,0.2,0.3,263,1.4,1.5
    1828,5/26/2021 21:14,7326.157,2.04,701,300,10,6001,0,65535,65535,1,22.8,27713,-298,-296,100,85,11,3299,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3950,3952,3948,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.6,980,SUCCESS,,3301.882904,192,0,0.1,0.2,0.3,263,1.4,1.5
    1829,5/26/2021 21:14,7330.169,2.04,701,300,10,6001,0,65535,65535,1,22.8,27713,-294,-296,100,85,11,3299,3888,664,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3950,3952,3948,0,0,0,0,0,0,0,0,2770,22.6,22.8,-273.2,22.8,-273.2,22.6,968,SUCCESS,,3301.555258,192,0,0.1,0.2,0.3,263,1.4,1.5
    1830,5/26/2021 21:15,7334.171,2.04,701,300,10,6001,0,65535,65535,1,22.8,27713,-296,-296,100,85,11,3299,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3950,3952,3948,0,0,0,0,0,0,0,0,2771,22.6,22.8,-273.2,22.8,-273.2,22.7,943,SUCCESS,,3301.226204,192,0,0.1,0.2,0.3,263,1.4,1.5
    1831,5/26/2021 21:15,7338.18,2.04,701,300,10,6001,0,65535,65535,1,22.8,27712,-296,-296,100,85,11,3298,3888,664,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3962,3968,3969,3964,3949,3951,3948,0,0,0,0,0,0,0,0,2767,22.6,22.8,-273.2,22.8,-273.2,22.7,963,SUCCESS,,3300.896575,192,0,0.1,0.2,0.3,263,1.4,1.5
    1832,5/26/2021 21:15,7342.192,2.04,701,300,10,6001,0,65535,65535,1,22.8,27711,-296,-296,100,85,11,3298,3888,669,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3969,3964,3950,3951,3948,0,0,0,0,0,0,0,0,2767,22.6,22.8,-273.2,22.8,-273.2,22.6,965,SUCCESS,,3300.5667,192,0,0.1,0.2,0.3,263,1.4,1.5
    1833,5/26/2021 21:15,7346.201,2.04,701,300,10,6001,0,65535,65535,1,22.8,27711,-296,-296,100,85,11,3298,3888,673,669,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3968,3969,3964,3949,3952,3948,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.6,987,SUCCESS,,3300.237071,192,0,0.1,0.2,0.3,263,1.4,1.5
    1834,5/26/2021 21:15,7350.205,2.04,701,300,10,6001,0,65535,65535,1,22.8,27709,-294,-296,100,85,11,3297,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3969,3964,3949,3951,3948,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.6,938,SUCCESS,,3299.910078,192,0,0.1,0.2,0.3,263,1.4,1.5
    1835,5/26/2021 21:15,7354.207,2.04,701,300,10,6001,0,65535,65535,1,22.8,27708,-296,-296,100,85,11,3297,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3968,3964,3949,3951,3947,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.4,935,SUCCESS,,3299.581024,192,0,0.1,0.2,0.3,263,1.4,1.5
    1836,5/26/2021 21:15,7358.207,2.04,701,300,10,6001,0,65535,65535,1,22.8,27708,-298,-296,100,85,11,3297,3888,664,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3968,3963,3949,3952,3948,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.7,967,SUCCESS,,3299.249913,192,0,0.1,0.2,0.3,263,1.4,1.5
    1837,5/26/2021 21:15,7362.212,2.05,701,300,10,6001,0,65535,65535,1,22.8,27706,-298,-296,100,85,11,3296,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3968,3963,3949,3951,3948,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.6,964,SUCCESS,,3298.918388,192,0,0.1,0.2,0.3,263,1.4,1.5
    1838,5/26/2021 21:15,7366.228,2.05,701,300,10,6001,0,65535,65535,1,22.8,27706,-296,-296,100,85,11,3296,3888,664,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3968,3963,3949,3951,3948,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.7,951,SUCCESS,,3298.588184,192,0,0.1,0.2,0.3,263,1.4,1.5
    1839,5/26/2021 21:15,7370.241,2.05,701,300,10,6001,0,65535,65535,1,22.8,27706,-298,-297,100,85,11,3296,3888,664,666,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3968,3963,3949,3953,3947,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.6,969,SUCCESS,,3298.255996,192,0,0.1,0.2,0.3,263,1.4,1.5
    1840,5/26/2021 21:15,7374.256,2.05,701,300,10,6001,0,65535,65535,1,22.8,27703,-298,-297,100,85,11,3295,3888,663,666,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3961,3967,3967,3963,3948,3951,3947,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,962,SUCCESS,,3297.923644,192,0,0.1,0.2,0.3,263,1.4,1.5
    1841,5/26/2021 21:15,7378.27,2.05,701,300,10,6001,0,65535,65535,1,22.8,27702,-296,-296,100,85,11,3295,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3967,3967,3963,3948,3950,3948,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,953,SUCCESS,,3297.593604,192,0,0.1,0.2,0.3,263,1.4,1.5
    1842,5/26/2021 21:15,7382.27,2.05,701,300,10,6001,0,65535,65535,1,22.8,27702,-296,-296,100,85,11,3295,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3967,3967,3963,3948,3954,3947,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,974,SUCCESS,,3297.264715,192,0,0.1,0.2,0.3,263,1.4,1.5
    1843,5/26/2021 21:15,7386.278,2.05,701,300,10,6001,0,65535,65535,1,22.8,27700,-296,-296,100,85,11,3294,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3966,3967,3962,3948,3951,3947,0,0,0,0,0,0,0,0,2766,22.6,22.8,-273.2,22.8,-273.2,22.7,976,SUCCESS,,3296.935168,192,0,0.1,0.2,0.3,263,1.4,1.5
    1844,5/26/2021 21:15,7390.293,2.05,701,300,10,6001,0,65535,65535,1,22.8,27700,-298,-296,100,85,11,3294,3888,663,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3966,3967,3962,3948,3950,3947,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,943,SUCCESS,,3296.602815,192,0,0.1,0.2,0.3,263,1.4,1.5
    1845,5/26/2021 21:16,7394.294,2.05,701,300,10,6001,0,65535,65535,1,22.8,27700,-296,-296,100,85,11,3294,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3966,3967,3962,3948,3954,3947,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,948,SUCCESS,,3296.273844,192,0,0.1,0.2,0.3,263,1.4,1.5
    1846,5/26/2021 21:16,7398.301,2.06,701,300,10,6001,0,65535,65535,1,22.6,27700,-296,-296,100,85,11,3293,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3966,3967,3962,3948,3950,3947,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,967,SUCCESS,,3295.94438,192,0,0.1,0.2,0.3,263,1.4,1.5
    1847,5/26/2021 21:16,7402.309,2.06,701,300,10,6001,0,65535,65535,1,22.8,27700,-298,-297,100,85,11,3293,3888,663,665,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3960,3966,3967,3962,3948,3950,3947,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,942,SUCCESS,,3295.612606,192,0,0.1,0.2,0.3,263,1.4,1.5
    1848,5/26/2021 21:16,7406.315,2.06,701,300,10,6001,0,65535,65535,1,22.8,27699,-296,-296,100,85,11,3293,3888,668,668,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3966,3967,3962,3948,3950,3947,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,940,SUCCESS,,3295.283224,192,0,0.1,0.2,0.3,263,1.4,1.5
    1849,5/26/2021 21:16,7410.319,2.06,701,300,10,6001,0,65535,65535,1,22.8,27698,-298,-296,100,85,11,3292,3888,663,667,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3966,3967,3962,3948,3950,3946,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.2,965,SUCCESS,,3294.951782,192,0,0.1,0.2,0.3,263,1.4,1.5
    1850,5/26/2021 21:16,7414.325,2.06,701,300,10,6001,0,65535,65535,1,22.8,27696,-296,-297,100,85,11,3292,3888,663,665,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3966,3966,3962,3947,3949,3946,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,943,SUCCESS,,3294.6224,192,0,0.1,0.2,0.3,263,1.4,1.5
    1851,5/26/2021 21:16,7418.329,2.06,701,300,10,6001,0,65535,65535,1,22.8,27696,-296,-296,100,85,11,3292,3888,672,667,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3962,3947,3950,3946,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,963,SUCCESS,,3294.293182,192,0,0.1,0.2,0.3,263,1.4,1.5
    1852,5/26/2021 21:16,7422.341,2.06,701,300,10,6001,0,65535,65535,1,22.6,27695,-296,-296,100,85,11,3291,3888,667,667,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3962,3947,3950,3946,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,942,SUCCESS,,3293.963306,192,0,0.1,0.2,0.3,263,1.4,1.5
    1853,5/26/2021 21:16,7426.354,2.06,701,300,10,6001,0,65535,65535,1,22.6,27693,-296,-297,100,85,11,3291,3888,667,665,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3961,3947,3949,3946,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,931,SUCCESS,,3293.633349,192,0,0.1,0.2,0.3,263,1.4,1.5
    1854,5/26/2021 21:16,7430.369,2.06,701,300,10,6001,0,65535,65535,1,22.6,27694,-296,-296,100,85,11,3291,3888,667,667,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3966,3966,3962,3947,3949,3946,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,966,SUCCESS,,3293.303226,192,0,0.1,0.2,0.3,263,1.4,1.5
    1855,5/26/2021 21:16,7434.383,2.07,701,300,10,6001,0,65535,65535,1,22.6,27692,-300,-297,100,85,11,3290,3888,662,665,65535,3000,28875,00C0,0,3639,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3961,3947,3950,3945,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,967,SUCCESS,,3292.968726,192,0,0.1,0.2,0.3,263,1.4,1.5
    1856,5/26/2021 21:16,7438.392,2.07,701,300,10,6001,0,65535,65535,1,22.6,27692,-298,-297,100,85,11,3290,3888,662,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3961,3947,3949,3945,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,969,SUCCESS,,3292.63687,192,0,0.1,0.2,0.3,263,1.4,1.5
    1857,5/26/2021 21:16,7442.404,2.07,701,300,10,6001,0,65535,65535,1,22.8,27692,-300,-297,100,85,11,3290,3888,658,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3961,3947,3949,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,952,SUCCESS,,3292.302537,192,0,0.1,0.2,0.3,263,1.4,1.5
    1858,5/26/2021 21:16,7446.411,2.07,701,300,10,6001,0,65535,65535,1,22.8,27692,-298,-297,100,85,11,3289,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3961,3947,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,953,SUCCESS,,3291.970846,192,0,0.1,0.2,0.3,263,1.4,1.5
    1859,5/26/2021 21:16,7450.416,2.07,701,300,10,6001,0,65535,65535,1,22.8,27691,-296,-297,100,85,11,3289,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3965,3966,3961,3947,3949,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,963,SUCCESS,,3291.641546,192,0,0.1,0.2,0.3,263,1.4,1.5
    1860,5/26/2021 21:17,7454.417,2.07,701,300,10,6001,0,65535,65535,1,22.8,27691,-296,-297,100,85,11,3289,3888,671,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3959,3964,3966,3961,3947,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,944,SUCCESS,,3291.312575,192,0,0.1,0.2,0.3,263,1.4,1.5
    1861,5/26/2021 21:17,7458.431,2.07,701,300,10,6001,0,65535,65535,1,22.8,27688,-296,-297,100,85,11,3288,3888,666,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3961,3946,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,984,SUCCESS,,3290.982535,192,0,0.1,0.2,0.3,263,1.4,1.5
    1862,5/26/2021 21:17,7462.444,2.07,701,300,10,6001,0,65535,65535,1,22.8,27688,-298,-297,100,85,11,3288,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3966,3961,3946,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.7,953,SUCCESS,,3290.650348,192,0,0.1,0.2,0.3,263,1.4,1.5
    1863,5/26/2021 21:17,7466.446,2.07,701,300,10,6001,0,65535,65535,1,22.8,27687,-298,-297,100,85,11,3288,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3961,3946,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,21.8,958,SUCCESS,,3290.319071,192,0,0.1,0.2,0.3,263,1.4,1.5
    1864,5/26/2021 21:17,7470.446,2.08,701,300,10,6001,0,65535,65535,1,22.8,27686,-296,-297,100,85,11,3287,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3961,3946,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,968,SUCCESS,,3289.990183,192,0,0.1,0.2,0.3,263,1.4,1.5
    1865,5/26/2021 21:17,7474.447,2.08,701,300,10,6001,0,65535,65535,1,22.6,27685,-296,-297,100,85,11,3287,3888,666,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3961,3946,3948,3945,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,945,SUCCESS,,3289.661211,192,0,0.1,0.2,0.3,263,1.4,1.5
    1866,5/26/2021 21:17,7478.458,2.08,701,300,10,6001,0,65535,65535,1,22.6,27685,-296,-297,100,85,11,3287,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3960,3945,3948,3944,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,1002,SUCCESS,,3289.331418,192,0,0.1,0.2,0.3,263,1.4,1.5
    1867,5/26/2021 21:17,7482.46,2.08,701,300,10,6001,0,65535,65535,1,22.8,27684,-296,-297,100,85,11,3286,3888,671,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3960,3946,3948,3944,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,972,SUCCESS,,3289.002365,192,0,0.1,0.2,0.3,263,1.4,1.5
    1868,5/26/2021 21:17,7486.465,2.08,701,300,10,6001,0,65535,65535,1,22.6,27684,-298,-297,100,85,11,3286,3888,666,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3964,3960,3945,3948,3944,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,948,SUCCESS,,3288.67084,192,0,0.1,0.2,0.3,263,1.4,1.5
    1869,5/26/2021 21:17,7490.466,2.08,701,300,10,6001,0,65535,65535,1,22.6,27682,-296,-297,100,85,11,3286,3888,662,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3964,3965,3960,3945,3947,3944,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,964,SUCCESS,,3288.341869,192,0,0.1,0.2,0.3,263,1.4,1.5
    1870,5/26/2021 21:17,7494.472,2.08,701,300,10,6001,0,65535,65535,1,22.8,27682,-296,-297,100,85,11,3285,3888,666,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3958,3963,3964,3960,3945,3947,3944,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,1035,SUCCESS,,3288.012486,192,0,0.1,0.2,0.3,263,1.4,1.5
    1871,5/26/2021 21:17,7498.481,2.08,701,300,10,6001,0,65535,65535,1,22.6,27681,-298,-297,100,85,11,3285,3888,661,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3960,3945,3947,3944,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.5,948,SUCCESS,,3287.68063,192,0,0.1,0.2,0.3,263,1.4,1.5
    1872,5/26/2021 21:17,7502.489,2.08,701,300,10,6001,0,65535,65535,1,22.6,27679,-296,-297,100,85,11,3285,3888,666,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3959,3945,3947,3944,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,949,SUCCESS,,3287.351084,192,0,0.1,0.2,0.3,263,1.4,1.5
    1873,5/26/2021 21:17,7506.494,2.09,701,300,10,6001,0,65535,65535,1,22.8,27679,-296,-297,100,85,11,3284,3888,666,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3960,3945,3947,3944,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,983,SUCCESS,,3287.021784,192,0,0.1,0.2,0.3,263,1.4,1.5
    1874,5/26/2021 21:17,7510.498,2.09,701,300,10,6001,0,65535,65535,1,22.6,27679,-298,-297,100,85,11,3284,3888,661,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3959,3945,3947,3944,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,942,SUCCESS,,3286.690341,192,0,0.1,0.2,0.3,263,1.4,1.5
    1875,5/26/2021 21:18,7514.505,2.09,701,300,10,6001,0,65535,65535,1,22.8,27678,-296,-297,100,85,11,3284,3888,666,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3959,3945,3947,3943,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,983,SUCCESS,,3286.360877,192,0,0.1,0.2,0.3,263,1.4,1.5
    1876,5/26/2021 21:18,7518.519,2.09,701,300,10,6001,0,65535,65535,1,22.8,27678,-298,-297,100,85,11,3283,3888,661,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3959,3944,3947,3943,0,0,0,0,0,0,0,0,2766,22.5,22.8,-273.2,22.8,-273.2,22.6,983,SUCCESS,,3286.028607,192,0,0.1,0.2,0.3,263,1.4,1.5
    1877,5/26/2021 21:18,7522.528,2.09,701,300,10,6001,0,65535,65535,1,22.6,27677,-296,-297,100,85,11,3283,3888,665,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3959,3945,3947,3943,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.3,944,SUCCESS,,3285.698978,192,0,0.1,0.2,0.3,263,1.4,1.5
    1878,5/26/2021 21:18,7526.529,2.09,701,300,10,6001,0,65535,65535,1,22.6,27677,-296,-296,100,85,11,3283,3888,665,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3957,3963,3964,3959,3944,3946,3943,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,945,SUCCESS,,3285.370007,192,0,0.1,0.2,0.3,263,1.4,1.5
    1879,5/26/2021 21:18,7530.532,2.09,701,300,10,6001,0,65535,65535,1,22.8,27675,-296,-296,100,85,11,3282,3888,665,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3964,3959,3944,3947,3943,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.8,-273.2,22.6,943,SUCCESS,,3285.040871,192,0,0.1,0.2,0.3,263,1.4,1.5
    1880,5/26/2021 21:18,7534.547,2.09,701,300,10,6001,0,65535,65535,1,22.6,27675,-296,-296,100,85,11,3282,3888,665,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3963,3959,3944,3947,3943,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,954,SUCCESS,,3284.710749,192,0,0.1,0.2,0.3,263,1.4,1.5
    1881,5/26/2021 21:18,7538.563,2.09,701,300,10,6001,0,65535,65535,1,22.8,27673,-296,-296,100,85,11,3282,3888,665,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3963,3959,3944,3946,3943,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.8,-273.2,22.6,957,SUCCESS,,3284.380545,192,0,0.1,0.2,0.3,263,1.4,1.5
    1882,5/26/2021 21:18,7542.573,2.1,701,300,10,6001,0,65535,65535,1,22.6,27672,-298,-296,100,85,11,3281,3888,661,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3963,3959,3944,3946,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,951,SUCCESS,,3284.048606,192,0,0.1,0.2,0.3,263,1.4,1.5
    1883,5/26/2021 21:18,7546.579,2.1,701,300,10,6001,0,65535,65535,1,22.8,27671,-296,-296,100,85,11,3281,3888,665,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3963,3958,3944,3946,3943,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,947,SUCCESS,,3283.719224,192,0,0.1,0.2,0.3,263,1.4,1.5
    1884,5/26/2021 21:18,7550.582,2.1,701,300,10,6001,0,65535,65535,1,22.6,27672,-294,-296,100,85,11,3281,3888,670,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3963,3958,3944,3946,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,989,SUCCESS,,3283.392312,192,0,0.1,0.2,0.3,263,1.4,1.5
    1885,5/26/2021 21:18,7554.59,2.1,701,300,10,6001,0,65535,65535,1,22.6,27671,-298,-297,100,85,11,3280,3888,660,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3962,3963,3958,3944,3946,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3283.060539,192,0,0.1,0.2,0.3,263,1.4,1.5
    1886,5/26/2021 21:18,7558.594,2.1,701,300,10,6001,0,65535,65535,1,22.6,27672,-294,-296,100,85,11,3280,3888,669,665,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3962,3958,3944,3946,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,938,SUCCESS,,3282.733545,192,0,0.1,0.2,0.3,263,1.4,1.5
    1887,5/26/2021 21:18,7562.603,2.1,701,300,10,6001,0,65535,65535,1,22.6,27670,-296,-297,100,85,11,3280,3888,660,663,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3956,3962,3962,3958,3944,3946,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,945,SUCCESS,,3282.403916,192,0,0.1,0.2,0.3,263,1.4,1.5
    1888,5/26/2021 21:18,7566.61,2.1,701,300,10,6001,0,65535,65535,1,22.6,27668,-296,-297,100,85,11,3279,3888,665,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3958,3943,3945,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.7,940,SUCCESS,,3282.074452,192,0,0.1,0.2,0.3,263,1.4,1.5
    1889,5/26/2021 21:18,7570.625,2.1,701,300,10,6001,0,65535,65535,1,22.6,27667,-294,-297,100,85,11,3279,3888,665,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3958,3943,3946,3942,0,0,0,0,0,0,0,0,2766,22.5,22.6,-273.2,22.6,-273.2,22.6,955,SUCCESS,,3281.74656,192,0,0.1,0.2,0.3,263,1.4,1.5
    1890,5/26/2021 21:19,7574.627,2.1,701,300,10,6001,0,65535,65535,1,22.6,27666,-298,-297,100,85,11,3279,3888,660,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3958,3943,3945,3941,0,0,0,0,0,0,0,0,2765,22.5,22.6,-273.2,22.6,-273.2,22.6,942,SUCCESS,,3281.415284,192,0,0.1,0.2,0.3,263,1.4,1.5
    1891,5/26/2021 21:19,7578.64,2.11,701,300,10,6001,0,65535,65535,1,22.6,27666,-294,-297,100,85,11,3278,3888,664,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3958,3943,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.7,941,SUCCESS,,3281.087555,192,0,0.1,0.2,0.3,263,1.4,1.5
    1892,5/26/2021 21:19,7582.646,2.11,701,300,10,6001,0,65535,65535,1,22.6,27667,-298,-297,100,85,11,3278,3888,660,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3958,3943,3945,3941,0,0,0,0,0,0,0,0,2763,22.5,22.6,-273.2,22.6,-273.2,22.6,982,SUCCESS,,3280.755948,192,0,0.1,0.2,0.3,263,1.4,1.5
    1893,5/26/2021 21:19,7586.654,2.11,701,300,10,6001,0,65535,65535,1,22.6,27665,-296,-297,100,85,11,3278,3888,660,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3958,3943,3945,3942,0,0,0,0,0,0,0,0,2765,22.5,22.6,-273.2,22.6,-273.2,22.6,958,SUCCESS,,3280.426401,192,0,0.1,0.2,0.3,263,1.4,1.5
    1894,5/26/2021 21:19,7590.661,2.11,701,300,10,6001,0,65535,65535,1,22.6,27664,-296,-297,100,85,11,3277,3888,669,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3957,3942,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,966,SUCCESS,,3280.096936,192,0,0.1,0.2,0.3,263,1.4,1.5
    1895,5/26/2021 21:19,7594.664,2.11,701,300,10,6001,0,65535,65535,1,22.6,27667,-296,-297,100,85,11,3277,3888,660,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3957,3942,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,933,SUCCESS,,3279.767801,192,0,0.1,0.2,0.3,263,1.4,1.5
    1896,5/26/2021 21:19,7598.679,2.11,701,300,10,6001,0,65535,65535,1,22.6,27663,-296,-297,100,85,11,3277,3888,669,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3957,3942,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,986,SUCCESS,,3279.437679,192,0,0.1,0.2,0.3,263,1.4,1.5
    1897,5/26/2021 21:19,7602.681,2.11,701,300,10,6001,0,65535,65535,1,22.6,27662,-296,-296,100,85,10,3276,3888,664,664,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3957,3942,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,968,SUCCESS,,3279.108625,192,0,0.1,0.2,0.3,263,1.4,1.5
    1898,5/26/2021 21:19,7606.69,2.11,701,300,10,6001,0,65535,65535,1,22.6,27667,-298,-297,100,85,10,3276,3888,660,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3961,3962,3957,3942,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,954,SUCCESS,,3278.776769,192,0,0.1,0.2,0.3,263,1.4,1.5
    1899,5/26/2021 21:19,7610.705,2.11,701,300,10,6001,0,65535,65535,1,22.6,27660,-298,-297,100,85,10,3276,3888,660,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3955,3960,3961,3957,3942,3945,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,945,SUCCESS,,3278.444416,192,0,0.1,0.2,0.3,263,1.4,1.5
    1900,5/26/2021 21:19,7614.711,2.12,701,300,10,6001,0,65535,65535,1,22.6,27659,-296,-297,100,85,10,3275,3888,659,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3960,3961,3957,3942,3944,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,949,SUCCESS,,3278.115034,192,0,0.1,0.2,0.3,263,1.4,1.5
    1901,5/26/2021 21:19,7618.715,2.12,701,300,10,6001,0,65535,65535,1,22.6,27659,-298,-297,100,85,10,3275,3888,659,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3960,3961,3956,3942,3944,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,978,SUCCESS,,3277.783592,192,0,0.1,0.2,0.3,263,1.4,1.5
    1902,5/26/2021 21:19,7622.716,2.12,701,300,10,6001,0,65535,65535,1,22.6,27657,-296,-297,100,85,10,3275,3888,664,662,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3960,3961,3956,3942,3944,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,951,SUCCESS,,3277.454621,192,0,0.1,0.2,0.3,263,1.4,1.5
    1903,5/26/2021 21:19,7626.716,2.12,701,300,10,6001,0,65535,65535,1,22.6,27658,-298,-297,100,85,10,3274,3888,659,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3960,3961,3956,3942,3944,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.7,946,SUCCESS,,3277.12351,192,0,0.1,0.2,0.3,263,1.4,1.5
    1904,5/26/2021 21:19,7630.718,2.12,701,300,10,6001,0,65535,65535,1,22.6,27658,-298,-297,100,85,10,3274,3888,668,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3960,3961,3956,3942,3944,3941,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.7,944,SUCCESS,,3276.792233,192,0,0.1,0.2,0.3,263,1.4,1.5
    1905,5/26/2021 21:20,7634.725,2.12,701,300,10,6001,0,65535,65535,1,22.6,27657,-298,-297,100,85,10,3274,3888,659,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3960,3961,3956,3942,3944,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.7,972,SUCCESS,,3276.460543,192,0,0.1,0.2,0.3,263,1.4,1.5
    1906,5/26/2021 21:20,7638.739,2.12,701,300,10,6001,0,65535,65535,1,22.6,27656,-296,-297,100,85,10,3273,3888,659,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3960,3961,3956,3942,3943,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.7,1014,SUCCESS,,3276.130503,192,0,0.1,0.2,0.3,263,1.4,1.5
    1907,5/26/2021 21:20,7642.743,2.12,701,300,10,6001,0,65535,65535,1,22.6,27654,-296,-297,100,85,10,3273,3888,663,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3954,3959,3961,3956,3941,3944,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,940,SUCCESS,,3275.801285,192,0,0.1,0.2,0.3,263,1.4,1.5
    1908,5/26/2021 21:20,7646.759,2.12,701,300,10,6001,0,65535,65535,1,22.6,27654,-296,-297,100,85,10,3273,3888,663,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3961,3956,3941,3944,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,955,SUCCESS,,3275.47108,192,0,0.1,0.2,0.3,263,1.4,1.5
    1909,5/26/2021 21:20,7650.763,2.13,701,300,10,6001,0,65535,65535,1,22.6,27652,-296,-297,100,85,10,3272,3888,654,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3960,3956,3941,3940,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,953,SUCCESS,,3275.141863,192,0,0.1,0.2,0.3,263,1.4,1.5
    1910,5/26/2021 21:20,7654.769,2.13,701,300,10,6001,0,65535,65535,1,22.6,27652,-296,-297,100,85,10,3272,3888,663,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3960,3956,3941,3943,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,977,SUCCESS,,3274.81248,192,0,0.1,0.2,0.3,263,1.4,1.5
    1911,5/26/2021 21:20,7658.783,2.13,701,300,10,6001,0,65535,65535,1,22.6,27651,-296,-297,100,85,10,3272,3888,654,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3960,3955,3941,3943,3940,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,959,SUCCESS,,3274.48244,192,0,0.1,0.2,0.3,263,1.4,1.5
    1912,5/26/2021 21:20,7662.792,2.13,701,300,10,6001,0,65535,65535,1,22.6,27650,-296,-297,100,85,10,3271,3888,659,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3960,3955,3941,3943,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,951,SUCCESS,,3274.152811,192,0,0.1,0.2,0.3,263,1.4,1.5
    1913,5/26/2021 21:20,7666.796,2.13,701,300,10,6001,0,65535,65535,1,22.6,27650,-296,-297,100,85,10,3271,3888,668,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3960,3955,3941,3943,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,949,SUCCESS,,3273.823594,192,0,0.1,0.2,0.3,263,1.4,1.5
    1914,5/26/2021 21:20,7670.799,2.13,701,300,10,6001,0,65535,65535,1,22.6,27650,-298,-297,100,85,10,3271,3888,663,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3960,3955,3941,3943,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,975,SUCCESS,,3273.492234,192,0,0.1,0.2,0.3,263,1.4,1.5
    1915,5/26/2021 21:20,7674.809,2.13,701,300,10,6001,0,65535,65535,1,22.6,27649,-298,-297,100,85,10,3270,3888,658,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3959,3959,3955,3941,3943,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,951,SUCCESS,,3273.160295,192,0,0.1,0.2,0.3,263,1.4,1.5
    1916,5/26/2021 21:20,7678.824,2.13,701,300,10,6001,0,65535,65535,1,22.6,27647,-298,-297,100,85,10,3270,3888,658,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3959,3959,3955,3940,3942,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,967,SUCCESS,,3272.827943,192,0,0.1,0.2,0.3,263,1.4,1.5
    1917,5/26/2021 21:20,7682.828,2.13,701,300,10,6001,0,65535,65535,1,22.6,27646,-300,-297,100,85,10,3270,3888,654,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3953,3958,3959,3955,3940,3943,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,966,SUCCESS,,3272.494276,192,0,0.1,0.2,0.3,263,1.4,1.5
    1918,5/26/2021 21:20,7686.83,2.14,701,300,10,6001,0,65535,65535,1,22.6,27646,-296,-297,100,85,10,3269,3888,663,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3955,3940,3942,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,986,SUCCESS,,3272.165223,192,0,0.1,0.2,0.3,263,1.4,1.5
    1919,5/26/2021 21:20,7690.836,2.14,701,300,10,6001,0,65535,65535,1,22.6,27646,-298,-297,100,85,10,3269,3888,658,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3955,3940,3942,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.7,960,SUCCESS,,3271.833615,192,0,0.1,0.2,0.3,263,1.4,1.5
    1920,5/26/2021 21:21,7694.849,2.14,701,300,10,6001,0,65535,65535,1,22.6,27645,-296,-297,100,85,10,3269,3888,663,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3955,3940,3942,3939,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,953,SUCCESS,,3271.503657,192,0,0.1,0.2,0.3,263,1.4,1.5
    1921,5/26/2021 21:21,7698.851,2.14,701,300,10,6001,0,65535,65535,1,22.6,27644,-296,-297,100,85,10,3268,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3955,3940,3943,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,974,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,3271.174604,192,0,0.1,0.2,0.3,263,1.4,1.5
    1922,5/26/2021 21:21,7702.864,2.14,701,300,10,6001,0,65535,65535,1,22.6,27644,-296,-297,100,85,10,3268,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3954,3940,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,967,SUCCESS,,3270.844646,192,0,0.1,0.2,0.3,263,1.4,1.5
    1923,5/26/2021 21:21,7706.873,2.14,701,300,10,6001,0,65535,65535,1,22.6,27643,-296,-297,100,85,10,3268,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3954,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,952,SUCCESS,,3270.515017,192,0,0.1,0.2,0.3,263,1.4,1.5
    1924,5/26/2021 21:21,7710.876,2.14,701,300,10,6001,0,65535,65535,1,22.6,27643,-296,-297,100,85,10,3267,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3958,3954,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.2,969,SUCCESS,,3270.185881,192,0,0.1,0.2,0.3,263,1.4,1.5
    1925,5/26/2021 21:21,7714.879,2.14,701,300,10,6001,0,65535,65535,1,22.6,27640,-298,-297,100,85,10,3267,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3959,3954,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,991,SUCCESS,,3269.854522,192,0,0.1,0.2,0.3,263,1.4,1.5
    1926,5/26/2021 21:21,7718.885,2.14,701,300,10,6001,0,65535,65535,1,22.6,27641,-294,-297,100,85,10,3267,3888,658,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3952,3958,3958,3954,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,948,SUCCESS,,3269.527365,192,0,0.1,0.2,0.3,263,1.4,1.5
    1927,5/26/2021 21:21,7722.888,2.15,701,300,10,6001,0,65535,65535,1,22.6,27639,-296,-297,100,85,10,3266,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3958,3958,3954,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,949,SUCCESS,,3269.19823,192,0,0.1,0.2,0.3,263,1.4,1.5
    1928,5/26/2021 21:21,7726.896,2.15,701,300,10,6001,0,65535,65535,1,22.6,27638,-296,-297,100,85,10,3266,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3957,3958,3954,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,974,SUCCESS,,3268.868683,192,0,0.1,0.2,0.3,263,1.4,1.5
    1929,5/26/2021 21:21,7730.905,2.15,701,300,10,6001,0,65535,65535,1,22.6,27638,-296,-297,100,85,10,3266,3888,667,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3957,3958,3954,3939,3941,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,942,SUCCESS,,3268.539054,192,0,0.1,0.2,0.3,263,1.4,1.5
    1930,5/26/2021 21:21,7734.915,2.15,701,300,10,6001,0,65535,65535,1,22.6,27637,-296,-297,100,84,10,3265,3888,657,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3957,3958,3953,3939,3942,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,982,SUCCESS,,3268.209343,192,0,0.1,0.2,0.3,263,1.4,1.5
    1931,5/26/2021 21:21,7738.928,2.15,701,300,10,6001,0,65535,65535,1,22.6,27637,-296,-297,100,84,10,3265,3888,657,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3957,3958,3953,3939,3941,3938,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,975,SUCCESS,,3267.879385,192,0,0.1,0.2,0.3,263,1.4,1.5
    1932,5/26/2021 21:21,7742.938,2.15,701,300,10,6001,0,65535,65535,1,22.6,27636,-296,-297,100,84,10,3265,3888,662,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3957,3958,3953,3938,3941,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,972,SUCCESS,,3267.549674,192,0,0.1,0.2,0.3,263,1.4,1.5
    1933,5/26/2021 21:21,7746.947,2.15,701,300,10,6001,0,65535,65535,1,22.6,27635,-298,-297,100,84,10,3264,3888,657,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3957,3958,3953,3939,3941,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,950,SUCCESS,,3267.217818,192,0,0.1,0.2,0.3,263,1.4,1.5
    1934,5/26/2021 21:21,7750.961,2.15,701,300,10,6001,0,65535,65535,1,22.6,27635,-296,-297,100,84,10,3264,3888,657,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3956,3958,3953,3939,3941,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,934,SUCCESS,,3266.887778,192,0,0.1,0.2,0.3,263,1.4,1.5
    1935,5/26/2021 21:22,7754.962,2.15,701,300,10,6001,0,65535,65535,1,22.6,27633,-296,-297,100,84,10,3264,3888,662,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3951,3956,3958,3953,3938,3941,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,954,SUCCESS,,3266.558807,192,0,0.1,0.2,0.3,263,1.4,1.5
    1936,5/26/2021 21:22,7758.972,2.16,701,300,10,6001,0,65535,65535,1,22.6,27633,-296,-297,100,84,10,3263,3888,657,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3958,3953,3938,3941,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,955,SUCCESS,,3266.229096,192,0,0.1,0.2,0.3,263,1.4,1.5
    1937,5/26/2021 21:22,7762.973,2.16,701,300,10,6001,0,65535,65535,1,22.6,27633,-298,-297,100,84,10,3263,3888,666,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3941,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,953,SUCCESS,,3265.897902,192,0,0.1,0.2,0.3,263,1.4,1.5
    1938,5/26/2021 21:22,7766.974,2.16,701,300,10,6001,0,65535,65535,1,22.6,27632,-296,-297,100,84,10,3263,3888,661,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3953,3938,3940,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22,994,SUCCESS,,3265.568931,192,0,0.1,0.2,0.3,263,1.4,1.5
    1939,5/26/2021 21:22,7770.983,2.16,701,300,10,6001,0,65535,65535,1,22.6,27632,-294,-297,100,84,10,3262,3888,661,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3953,3938,3940,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,960,SUCCESS,,3265.241529,192,0,0.1,0.2,0.3,263,1.4,1.5
    1940,5/26/2021 21:22,7774.991,2.16,701,300,10,6001,0,65535,65535,1,22.6,27629,-296,-297,100,84,10,3262,3888,661,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3940,3937,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,972,SUCCESS,,3264.911983,192,0,0.1,0.2,0.3,263,1.4,1.5
    1941,5/26/2021 21:22,7778.992,2.16,701,300,10,6001,0,65535,65535,1,22.6,27630,-298,-297,100,84,10,3262,3888,657,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3940,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,987,SUCCESS,,3264.580789,192,0,0.1,0.2,0.3,263,1.4,1.5
    1942,5/26/2021 21:22,7783.001,2.16,701,300,10,6001,0,65535,65535,1,22.6,27629,-296,-297,100,84,10,3261,3888,661,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3940,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,940,SUCCESS,,3264.25116,192,0,0.1,0.2,0.3,263,1.4,1.5
    1943,5/26/2021 21:22,7787.017,2.16,701,300,10,6001,0,65535,65535,1,22.6,27629,-296,-297,100,84,10,3261,3888,661,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3940,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,972,SUCCESS,,3263.920955,192,0,0.1,0.2,0.3,263,1.4,1.5
    1944,5/26/2021 21:22,7791.018,2.16,701,300,10,6001,0,65535,65535,1,22.6,27629,-296,-297,100,84,10,3261,3888,661,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3940,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,963,SUCCESS,,3263.591984,192,0,0.1,0.2,0.3,263,1.4,1.5
    1945,5/26/2021 21:22,7795.018,2.17,701,300,10,6001,0,65535,65535,1,22.6,27627,-296,-296,100,84,10,3260,3888,665,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3938,3939,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,940,SUCCESS,,3263.263095,192,0,0.1,0.2,0.3,263,1.4,1.5
    1946,5/26/2021 21:22,7799.03,2.17,701,300,10,6001,0,65535,65535,1,22.6,27629,-298,-296,100,84,10,3260,3888,661,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3950,3956,3957,3952,3937,3939,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,943,SUCCESS,,3262.930991,192,0,0.1,0.2,0.3,263,1.4,1.5
    1947,5/26/2021 21:22,7803.031,2.17,701,300,10,6001,0,65535,65535,1,22.6,27626,-294,-296,100,84,10,3260,3888,661,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3952,3938,3940,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,972,SUCCESS,,3262.604243,192,0,0.1,0.2,0.3,263,1.4,1.5
    1948,5/26/2021 21:22,7807.034,2.17,701,300,10,6001,0,65535,65535,1,22.6,27625,-296,-296,100,84,10,3259,3888,656,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3952,3937,3939,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,969,SUCCESS,,3262.275107,192,0,0.1,0.2,0.3,263,1.4,1.5
    1949,5/26/2021 21:22,7811.043,2.17,701,300,10,6001,0,65535,65535,1,22.6,27624,-298,-296,100,84,10,3259,3888,656,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3952,3937,3939,3936,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,969,SUCCESS,,3261.943251,192,0,0.1,0.2,0.3,263,1.4,1.5
    1950,5/26/2021 21:23,7815.048,2.17,701,300,10,6001,0,65535,65535,1,22.6,27623,-296,-296,100,84,10,3259,3888,661,661,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3952,3937,3939,3935,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.5,940,SUCCESS,,3261.613951,192,0,0.1,0.2,0.3,263,1.4,1.5
    1951,5/26/2021 21:23,7819.063,2.17,701,300,10,6001,0,65535,65535,1,22.6,27623,-298,-296,100,84,10,3258,3888,656,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3952,3937,3939,3935,0,0,0,0,0,0,0,0,2758,22.5,22.6,-273.2,22.6,-273.2,22.5,940,SUCCESS,,3261.281598,192,0,0.1,0.2,0.3,263,1.4,1.5
    1952,5/26/2021 21:23,7823.077,2.17,701,300,10,6001,0,65535,65535,1,22.6,27623,-296,-296,100,84,10,3258,3888,656,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3951,3937,3939,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,945,SUCCESS,,3260.951558,192,0,0.1,0.2,0.3,263,1.4,1.5
    1953,5/26/2021 21:23,7827.088,2.17,701,300,10,6001,0,65535,65535,1,22.6,27621,-296,-296,100,84,10,3258,3888,665,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3949,3955,3956,3951,3937,3939,3935,0,0,0,0,0,0,0,0,2762,22.5,22.6,-273.2,22.6,-273.2,22.6,938,SUCCESS,,3260.621765,192,0,0.1,0.2,0.3,263,1.4,1.5
    1954,5/26/2021 21:23,7831.096,2.18,701,300,10,6001,0,65535,65535,1,22.6,27618,-296,-296,100,84,10,3257,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3955,3955,3951,3937,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,953,SUCCESS,,3260.292218,192,0,0.1,0.2,0.3,263,1.4,1.5
    1955,5/26/2021 21:23,7835.108,2.18,701,300,10,6001,0,65535,65535,1,22.6,27620,-296,-296,100,84,10,3257,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3954,3955,3951,3936,3939,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,958,SUCCESS,,3259.962343,192,0,0.1,0.2,0.3,263,1.4,1.5
    1956,5/26/2021 21:23,7839.123,2.18,701,300,10,6001,0,65535,65535,1,22.6,27618,-296,-296,100,84,10,3257,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3955,3955,3951,3936,3939,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,990,SUCCESS,,3259.63222,192,0,0.1,0.2,0.3,263,1.4,1.5
    1957,5/26/2021 21:23,7843.138,2.18,701,300,10,6001,0,65535,65535,1,22.6,27619,-298,-296,100,84,10,3256,3888,656,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3955,3955,3951,3936,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.3,945,SUCCESS,,3259.299868,192,0,0.1,0.2,0.3,263,1.4,1.5
    1958,5/26/2021 21:23,7847.142,2.18,701,300,10,6001,0,65535,65535,1,22.6,27617,-298,-296,100,84,10,3256,3888,656,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3954,3955,3951,3936,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,947,SUCCESS,,3258.968425,192,0,0.1,0.2,0.3,263,1.4,1.5
    1959,5/26/2021 21:23,7851.149,2.18,701,300,10,6001,0,65535,65535,1,22.6,27617,-296,-296,100,84,10,3256,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3954,3955,3950,3936,3939,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,986,SUCCESS,,3258.638961,192,0,0.1,0.2,0.3,263,1.4,1.5
    1960,5/26/2021 21:23,7855.152,2.18,701,300,10,6001,0,65535,65535,1,22.6,27616,-298,-296,100,84,10,3255,3888,655,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3954,3955,3950,3936,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3258.307601,192,0,0.1,0.2,0.3,263,1.4,1.5
    1961,5/26/2021 21:23,7859.164,2.18,701,300,10,6001,0,65535,65535,1,22.6,27616,-296,-296,100,84,10,3255,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3954,3955,3950,3936,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,972,SUCCESS,,3257.977726,192,0,0.1,0.2,0.3,263,1.4,1.5
    1962,5/26/2021 21:23,7863.174,2.18,701,300,10,6001,0,65535,65535,1,22.6,27617,-296,-296,100,84,10,3255,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3954,3955,3950,3936,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,955,SUCCESS,,3257.648015,192,0,0.1,0.2,0.3,263,1.4,1.5
    1963,5/26/2021 21:23,7867.175,2.19,701,300,10,6001,0,65535,65535,1,22.6,27615,-298,-296,100,84,10,3254,3888,655,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3953,3955,3950,3936,3938,3934,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,959,SUCCESS,,3257.316821,192,0,0.1,0.2,0.3,263,1.4,1.5
    1964,5/26/2021 21:23,7871.182,2.19,701,300,10,6001,0,65535,65535,1,22.6,27613,-296,-296,100,84,10,3254,3888,660,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3953,3955,3950,3936,3938,3935,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,947,SUCCESS,,3256.987356,192,0,0.1,0.2,0.3,263,1.4,1.5
    1965,5/26/2021 21:24,7875.193,2.19,701,300,10,6001,0,65535,65535,1,22.6,27615,-298,-296,100,84,10,3254,3888,655,660,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3955,3950,3936,3938,3934,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,958,SUCCESS,,3256.655335,192,0,0.1,0.2,0.3,263,1.4,1.5
    1966,5/26/2021 21:24,7879.207,2.19,701,300,10,6001,0,65535,65535,1,22.6,27612,-294,-296,100,84,10,3253,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3948,3953,3955,3950,3935,3938,3934,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,937,SUCCESS,,3256.327525,192,0,0.1,0.2,0.3,263,1.4,1.5
    1967,5/26/2021 21:24,7883.219,2.19,701,300,10,6001,0,65535,65535,1,22.6,27610,-296,-296,100,84,10,3253,3888,655,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3955,3950,3935,3938,3934,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,948,SUCCESS,,3255.997649,192,0,0.1,0.2,0.3,263,1.4,1.5
    1968,5/26/2021 21:24,7887.227,2.19,701,300,10,6001,0,65535,65535,1,22.6,27610,-296,-296,100,84,10,3253,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3954,3950,3935,3938,3934,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,967,SUCCESS,,3255.668103,192,0,0.1,0.2,0.3,263,1.4,1.5
    1969,5/26/2021 21:24,7891.233,2.19,701,300,10,6001,0,65535,65535,1,22.6,27609,-294,-296,100,84,10,3252,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3954,3950,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,963,SUCCESS,,3255.340946,192,0,0.1,0.2,0.3,263,1.4,1.5
    1970,5/26/2021 21:24,7895.239,2.19,701,300,10,6001,0,65535,65535,1,22.6,27607,-298,-297,100,84,10,3252,3888,655,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3954,3949,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,1021,SUCCESS,,3255.009338,192,0,0.1,0.2,0.3,263,1.4,1.5
    1971,5/26/2021 21:24,7899.251,2.19,701,300,10,6001,0,65535,65535,1,22.6,27609,-296,-297,100,84,10,3252,3888,659,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3954,3949,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.4,941,SUCCESS,,3254.679463,192,0,0.1,0.2,0.3,263,1.4,1.5
    1972,5/26/2021 21:24,7903.264,2.2,701,300,10,6001,0,65535,65535,1,22.6,27608,-298,-297,100,84,10,3251,3888,663,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3954,3949,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,943,SUCCESS,,3254.347275,192,0,0.1,0.2,0.3,263,1.4,1.5
    1973,5/26/2021 21:24,7907.277,2.2,701,300,10,6001,0,65535,65535,1,22.6,27607,-298,-297,100,84,10,3251,3888,659,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3952,3953,3949,3935,3936,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3254.015088,192,0,0.1,0.2,0.3,263,1.4,1.5
    1974,5/26/2021 21:24,7911.287,2.2,701,300,10,6001,0,65535,65535,1,22.6,27607,-296,-297,100,84,10,3251,3888,659,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3953,3949,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,973,SUCCESS,,3253.685377,192,0,0.1,0.2,0.3,263,1.4,1.5
    1975,5/26/2021 21:24,7915.301,2.2,701,300,10,6001,0,65535,65535,1,22.6,27607,-294,-296,100,84,10,3250,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3953,3953,3949,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,975,SUCCESS,,3253.357567,192,0,0.1,0.2,0.3,263,1.4,1.5
    1976,5/26/2021 21:24,7919.302,2.2,701,300,10,6001,0,65535,65535,1,22.6,27607,-296,-296,100,84,10,3250,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3947,3952,3953,3949,3935,3937,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,956,SUCCESS,,3253.028596,192,0,0.1,0.2,0.3,263,1.4,1.5
    1977,5/26/2021 21:24,7923.31,2.2,701,300,10,6001,0,65535,65535,1,22.6,27604,-296,-296,100,84,10,3250,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3953,3949,3934,3936,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3252.699049,192,0,0.1,0.2,0.3,263,1.4,1.5
    1978,5/26/2021 21:24,7927.311,2.2,701,300,10,6001,0,65535,65535,1,22.6,27603,-296,-296,100,84,10,3249,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3953,3948,3934,3936,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,945,SUCCESS,,3252.370078,192,0,0.1,0.2,0.3,263,1.4,1.5
    1979,5/26/2021 21:24,7931.321,2.2,701,300,10,6001,0,65535,65535,1,22.6,27603,-296,-296,100,84,10,3249,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3953,3948,3934,3936,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,957,SUCCESS,,3252.040367,192,0,0.1,0.2,0.3,263,1.4,1.5
    1980,5/26/2021 21:25,7935.327,2.2,701,300,10,6001,0,65535,65535,1,22.6,27602,-296,-296,100,84,10,3249,3888,659,659,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3953,3948,3934,3936,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,949,SUCCESS,,3251.710985,192,0,0.1,0.2,0.3,263,1.4,1.5
    1981,5/26/2021 21:25,7939.339,2.21,701,300,10,6001,0,65535,65535,1,22.6,27601,-298,-296,100,84,10,3248,3888,654,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3953,3948,3934,3936,3933,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,984,SUCCESS,,3251.37888,192,0,0.1,0.2,0.3,263,1.4,1.5
    1982,5/26/2021 21:25,7943.352,2.21,701,300,10,6001,0,65535,65535,1,22.6,27602,-296,-296,100,84,10,3248,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3953,3948,3934,3936,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,964,SUCCESS,,3251.048923,192,0,0.1,0.2,0.3,263,1.4,1.5
    1983,5/26/2021 21:25,7947.356,2.21,701,300,10,6001,0,65535,65535,1,22.6,27601,-296,-296,100,84,10,3248,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3952,3948,3934,3935,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,977,SUCCESS,,3250.719705,192,0,0.1,0.2,0.3,263,1.4,1.5
    1984,5/26/2021 21:25,7951.363,2.21,701,300,10,6001,0,65535,65535,1,22.6,27599,-296,-296,100,84,10,3247,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3952,3952,3948,3934,3936,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,938,SUCCESS,,3250.39024,192,0,0.1,0.2,0.3,263,1.4,1.5
    1985,5/26/2021 21:25,7955.373,2.21,701,300,10,6001,0,65535,65535,1,22.6,27600,-294,-296,100,84,10,3247,3888,663,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3952,3952,3948,3933,3937,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.3,944,SUCCESS,,3250.062757,192,0,0.1,0.2,0.3,263,1.4,1.5
    1986,5/26/2021 21:25,7959.385,2.21,701,300,10,6001,0,65535,65535,1,22.6,27597,-296,-296,100,84,10,3247,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3946,3951,3952,3948,3933,3935,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,1010,SUCCESS,,3249.732881,192,0,0.1,0.2,0.3,263,1.4,1.5
    1987,5/26/2021 21:25,7963.393,2.21,701,300,10,6001,0,65535,65535,1,22.6,27598,-296,-296,100,84,10,3246,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3948,3933,3936,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,939,SUCCESS,,3249.403335,192,0,0.1,0.2,0.3,263,1.4,1.5
    1988,5/26/2021 21:25,7967.402,2.21,701,300,10,6001,0,65535,65535,1,22.6,27596,-294,-296,100,84,10,3246,3888,662,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3948,3933,3936,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,978,SUCCESS,,3249.075933,192,0,0.1,0.2,0.3,263,1.4,1.5
    1989,5/26/2021 21:25,7971.416,2.21,701,300,10,6001,0,65535,65535,1,22.6,27594,-298,-297,100,84,10,3246,3888,654,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3947,3933,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,937,SUCCESS,,3248.743663,192,0,0.1,0.2,0.3,263,1.4,1.5
    1990,5/26/2021 21:25,7975.426,2.22,701,300,10,6001,0,65535,65535,1,22.6,27594,-296,-297,100,84,10,3245,3888,658,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3947,3933,3935,3932,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.7,955,SUCCESS,,3248.413952,192,0,0.1,0.2,0.3,263,1.4,1.5
    1991,5/26/2021 21:25,7979.435,2.22,701,300,10,6001,0,65535,65535,1,22.6,27594,-296,-296,100,84,10,3245,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3947,3933,3937,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,947,SUCCESS,,3248.084323,192,0,0.1,0.2,0.3,263,1.4,1.5
    1992,5/26/2021 21:25,7983.435,2.22,701,300,10,6001,0,65535,65535,1,22.6,27593,-296,-297,100,84,10,3245,3888,653,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3947,3932,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,948,SUCCESS,,3247.755434,192,0,0.1,0.2,0.3,263,1.4,1.5
    1993,5/26/2021 21:25,7987.437,2.22,701,300,10,6001,0,65535,65535,1,22.6,27593,-292,-296,100,84,10,3244,3888,662,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3951,3952,3947,3932,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,995,SUCCESS,,3247.430828,192,0,0.1,0.2,0.3,263,1.4,1.5
    1994,5/26/2021 21:25,7991.44,2.22,701,300,10,6001,0,65535,65535,1,22.6,27593,-296,-296,100,84,10,3244,3888,653,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3950,3952,3947,3932,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,942,SUCCESS,,3247.101692,192,0,0.1,0.2,0.3,263,1.4,1.5
    1995,5/26/2021 21:26,7995.453,2.22,701,300,10,6001,0,65535,65535,1,22.6,27591,-296,-296,100,84,10,3244,3888,658,658,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3945,3950,3952,3947,3932,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,958,SUCCESS,,3246.771734,192,0,0.1,0.2,0.3,263,1.4,1.5
    1996,5/26/2021 21:26,7999.457,2.22,701,300,10,6001,0,65535,65535,1,22.6,27590,-296,-296,100,84,10,3243,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3951,3947,3932,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,952,SUCCESS,,3246.442516,192,0,0.1,0.2,0.3,263,1.4,1.5
    1997,5/26/2021 21:26,8003.459,2.22,701,300,10,6001,0,65535,65535,1,22.6,27589,-298,-296,100,84,10,3243,3888,653,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3951,3947,3932,3937,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,973,SUCCESS,,3246.11124,192,0,0.1,0.2,0.3,263,1.4,1.5
    1998,5/26/2021 21:26,8007.474,2.22,701,300,10,6001,0,65535,65535,1,22.6,27588,-296,-296,100,84,10,3243,3888,662,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3951,3947,3932,3935,3931,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,954,SUCCESS,,3245.781118,192,0,0.1,0.2,0.3,263,1.4,1.5
    1999,5/26/2021 21:26,8011.489,2.23,701,300,10,6001,0,65535,65535,1,22.6,27588,-298,-296,100,84,10,3242,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3951,3947,3932,3934,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,950,SUCCESS,,3245.448765,192,0,0.1,0.2,0.3,263,1.4,1.5
    2000,5/26/2021 21:26,8015.499,2.23,701,300,10,6001,0,65535,65535,1,22.6,27589,-298,-296,100,84,10,3242,3888,653,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3951,3947,3932,3935,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,948,SUCCESS,,3245.116826,192,0,0.1,0.2,0.3,263,1.4,1.5
    2001,5/26/2021 21:26,8019.513,2.23,701,300,10,6001,0,65535,65535,1,22.6,27586,-296,-296,100,84,10,3242,3888,653,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3951,3946,3931,3934,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,944,SUCCESS,,3244.786786,192,0,0.1,0.2,0.3,263,1.4,1.5
    2002,5/26/2021 21:26,8023.524,2.23,701,300,10,6001,0,65535,65535,1,22.6,27586,-296,-296,100,84,10,3241,3888,653,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3950,3946,3931,3934,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,965,SUCCESS,,3244.456993,192,0,0.1,0.2,0.3,263,1.4,1.5
    2003,5/26/2021 21:26,8027.524,2.23,701,300,10,6001,0,65535,65535,1,22.6,27585,-298,-297,100,84,10,3241,3888,657,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3950,3950,3946,3931,3934,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,951,SUCCESS,,3244.125881,192,0,0.1,0.2,0.3,263,1.4,1.5
    2004,5/26/2021 21:26,8031.539,2.23,701,300,10,6001,0,65535,65535,1,22.6,27585,-294,-296,100,84,10,3241,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3949,3950,3946,3931,3934,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,973,SUCCESS,,3243.79799,192,0,0.1,0.2,0.3,263,1.4,1.5
    2005,5/26/2021 21:26,8035.563,2.23,701,300,10,6001,0,65535,65535,1,22.6,27585,-296,-296,100,84,10,3241,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3949,3950,3946,3931,3933,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,962,SUCCESS,,3243.467128,192,0,0.1,0.2,0.3,263,1.4,1.5
    2006,5/26/2021 21:26,8039.578,2.23,701,300,10,6001,0,65535,65535,1,22.6,27584,-296,-296,100,84,10,3240,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3944,3949,3950,3945,3931,3933,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,980,SUCCESS,,3243.137005,192,0,0.1,0.2,0.3,263,1.4,1.5
    2007,5/26/2021 21:26,8043.595,2.23,701,300,10,6001,0,65535,65535,1,22.6,27582,-298,-296,100,84,10,3240,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3949,3950,3945,3931,3933,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3242.804487,192,0,0.1,0.2,0.3,263,1.4,1.5
    2008,5/26/2021 21:26,8047.611,2.24,701,300,10,6001,0,65535,65535,1,22.6,27581,-298,-296,100,84,10,3240,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3949,3950,3945,3931,3933,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,955,SUCCESS,,3242.472051,192,0,0.1,0.2,0.3,263,1.4,1.5
    2009,5/26/2021 21:26,8051.627,2.24,701,300,10,6001,0,65535,65535,1,22.6,27581,-294,-296,100,84,10,3239,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3949,3950,3945,3931,3933,3930,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,978,SUCCESS,,3242.144078,192,0,0.1,0.2,0.3,263,1.4,1.5
    2010,5/26/2021 21:27,8055.627,2.24,701,300,10,6001,0,65535,65535,1,22.6,27580,-294,-296,100,84,10,3239,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3949,3950,3945,3931,3933,3929,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,974,SUCCESS,,3241.817411,192,0,0.1,0.2,0.3,263,1.4,1.5
    2011,5/26/2021 21:27,8059.642,2.24,701,300,10,6001,0,65535,65535,1,22.6,27579,-296,-296,100,84,10,3239,3888,657,657,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3949,3950,3945,3930,3933,3929,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,944,SUCCESS,,3241.487289,192,0,0.1,0.2,0.3,263,1.4,1.5
    2012,5/26/2021 21:27,8063.655,2.24,701,300,10,6001,0,65535,65535,1,22.6,27579,-294,-296,100,84,10,3238,3888,652,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3948,3950,3945,3931,3933,3929,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.5,942,SUCCESS,,3241.159561,192,0,0.1,0.2,0.3,263,1.4,1.5
    2013,5/26/2021 21:27,8067.688,2.24,701,300,10,6001,0,65535,65535,1,22.6,27579,-296,-296,100,84,10,3238,3888,652,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3948,3950,3945,3930,3933,3929,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,964,SUCCESS,,3240.827959,192,0,0.1,0.2,0.3,263,1.4,1.5
    2014,5/26/2021 21:27,8071.618,2.24,701,300,10,6001,0,65535,65535,1,22.6,27578,-296,-296,100,84,10,3238,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3943,3948,3949,3945,3930,3933,3929,0,0,0,0,0,0,0,0,2754,22.5,22.6,-273.2,22.6,-273.2,22.6,961,SUCCESS,,3240.504825,192,0,0.1,0.2,0.3,263,1.4,1.5
    2015,5/26/2021 21:27,8075.633,2.24,701,300,10,6001,0,65535,65535,1,22.6,27576,-296,-296,100,84,10,3237,3888,663,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3949,3945,3930,3933,3929,0,0,0,0,0,0,0,0,2757,22.5,22.6,-273.2,22.6,-273.2,22.6,963,SUCCESS,,3240.174703,192,0,0.1,0.2,0.3,263,1.4,1.5
    2016,5/26/2021 21:27,8079.64,2.24,701,300,10,6001,0,65535,65535,1,22.6,27576,-298,-296,100,84,10,3237,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3949,3945,3930,3933,3929,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.5,957,SUCCESS,,3239.843013,192,0,0.1,0.2,0.3,263,1.4,1.5
    2017,5/26/2021 21:27,8083.655,2.25,701,300,10,6001,0,65535,65535,1,22.6,27576,-296,-296,100,84,10,3237,3888,660,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3949,3945,3930,3933,3929,0,0,0,0,0,0,0,0,2754,22.5,22.6,-273.2,22.6,-273.2,22.5,977,SUCCESS,,3239.51289,192,0,0.1,0.2,0.3,263,1.4,1.5
    2018,5/26/2021 21:27,8087.659,2.25,701,300,10,6001,0,65535,65535,1,22.6,27575,-296,-296,100,84,10,3236,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3949,3945,3930,3932,3928,0,0,0,0,0,0,0,0,2756,22.5,22.6,-273.2,22.6,-273.2,22.6,942,SUCCESS,,3239.183673,192,0,0.1,0.2,0.3,263,1.4,1.5
    2019,5/26/2021 21:27,8091.667,2.25,701,300,10,6001,0,65535,65535,1,22.6,27574,-296,-296,100,84,10,3236,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3948,3944,3930,3932,3928,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.6,967,SUCCESS,,3238.854126,192,0,0.1,0.2,0.3,263,1.4,1.5
    2020,5/26/2021 21:27,8095.681,2.25,701,300,10,6001,0,65535,65535,1,22.6,27572,-296,-296,100,84,10,3235,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3949,3944,3930,3932,3928,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,974,SUCCESS,,3238.524086,192,0,0.1,0.2,0.3,263,1.4,1.5
    2021,5/26/2021 21:27,8099.69,2.25,701,300,10,6001,0,65535,65535,1,22.6,27573,-296,-296,100,84,10,3235,3888,651,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3948,3949,3944,3930,3932,3928,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.6,991,SUCCESS,,3238.194457,192,0,0.1,0.2,0.3,263,1.4,1.5
    2022,5/26/2021 21:27,8103.694,2.25,701,300,10,6001,0,65535,65535,1,22.6,27572,-296,-296,100,84,10,3235,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3947,3948,3944,3930,3932,3928,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.6,971,SUCCESS,,3237.865239,192,0,0.1,0.2,0.3,263,1.4,1.5
    2023,5/26/2021 21:27,8107.706,2.25,701,300,10,6001,0,65535,65535,1,22.6,27569,-296,-296,100,84,10,3235,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3947,3948,3944,3930,3932,3928,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,968,SUCCESS,,3237.535364,192,0,0.1,0.2,0.3,263,1.4,1.5
    2024,5/26/2021 21:27,8111.718,2.25,701,300,10,6001,0,65535,65535,1,22.6,27569,-296,-296,100,84,10,3234,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3942,3947,3948,3944,3929,3931,3928,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3237.205488,192,0,0.1,0.2,0.3,263,1.4,1.5
    2025,5/26/2021 21:28,8115.723,2.25,701,300,10,6001,0,65535,65535,1,22.6,27570,-296,-296,100,84,10,3234,3888,656,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3944,3929,3932,3928,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,988,SUCCESS,,3236.876188,192,0,0.1,0.2,0.3,263,1.4,1.5
    2026,5/26/2021 21:28,8119.733,2.26,701,300,10,6001,0,65535,65535,1,22.6,27568,-294,-296,100,84,10,3234,3888,660,656,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3944,3929,3933,3927,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.5,958,SUCCESS,,3236.548705,192,0,0.1,0.2,0.3,263,1.4,1.5
    2027,5/26/2021 21:28,8123.734,2.26,701,300,10,6001,0,65535,65535,1,22.6,27568,-296,-296,100,84,10,3233,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3944,3929,3931,3928,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,961,SUCCESS,,3236.219734,192,0,0.1,0.2,0.3,263,1.4,1.5
    2028,5/26/2021 21:28,8127.742,2.26,701,300,10,6001,0,65535,65535,1,22.6,27567,-296,-296,100,84,10,3233,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3944,3929,3931,3928,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,962,SUCCESS,,3235.890187,192,0,0.1,0.2,0.3,263,1.4,1.5
    2029,5/26/2021 21:28,8131.744,2.26,701,300,10,6001,0,65535,65535,1,22.6,27567,-294,-296,100,84,10,3233,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3944,3929,3931,3927,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.5,986,SUCCESS,,3235.563357,192,0,0.1,0.2,0.3,263,1.4,1.5
    2030,5/26/2021 21:28,8135.748,2.26,701,300,10,6001,0,65535,65535,1,22.6,27567,-296,-296,100,84,10,3232,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3944,3929,3931,3927,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,941,SUCCESS,,3235.234139,192,0,0.1,0.2,0.3,263,1.4,1.5
    2031,5/26/2021 21:28,8139.759,2.26,701,300,10,6001,0,65535,65535,1,22.6,27566,-296,-296,100,84,10,3232,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3947,3943,3928,3931,3927,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.6,982,SUCCESS,,3234.904346,192,0,0.1,0.2,0.3,263,1.4,1.5
    2032,5/26/2021 21:28,8143.775,2.26,701,300,10,6001,0,65535,65535,1,22.6,27564,-296,-296,100,84,10,3232,3888,651,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3948,3943,3929,3931,3927,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,21.9,977,SUCCESS,,3234.574141,192,0,0.1,0.2,0.3,263,1.4,1.5
    2033,5/26/2021 21:28,8147.779,2.26,701,300,10,6001,0,65535,65535,1,22.6,27564,-296,-296,100,84,10,3231,3888,651,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3947,3947,3943,3928,3931,3927,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,956,SUCCESS,,3234.244924,192,0,0.1,0.2,0.3,263,1.4,1.5
    2034,5/26/2021 21:28,8151.789,2.26,701,300,10,6001,0,65535,65535,1,22.6,27562,-296,-296,100,84,10,3231,3888,651,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3946,3947,3943,3928,3931,3927,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,986,SUCCESS,,3233.915213,192,0,0.1,0.2,0.3,263,1.4,1.5
    2035,5/26/2021 21:28,8155.793,2.27,701,300,10,6001,0,65535,65535,1,22.6,27560,-298,-296,100,84,10,3231,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3941,3946,3947,3943,3928,3931,3927,0,0,0,0,0,0,0,0,2753,22.5,22.6,-273.2,22.6,-273.2,22.5,943,SUCCESS,,3233.58377,192,0,0.1,0.2,0.3,263,1.4,1.5
    2036,5/26/2021 21:28,8159.805,2.27,701,300,10,6001,0,65535,65535,1,22.6,27561,-298,-297,100,84,10,3230,3888,655,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3946,3947,3942,3928,3930,3927,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,1018,SUCCESS,,3233.251666,192,0,0.1,0.2,0.3,263,1.4,1.5
    2037,5/26/2021 21:28,8163.821,2.27,701,300,10,6001,0,65535,65535,1,22.6,27561,-298,-296,100,84,10,3230,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3946,3947,3942,3928,3930,3927,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,953,SUCCESS,,3232.91923,192,0,0.1,0.2,0.3,263,1.4,1.5
    2038,5/26/2021 21:28,8167.82,2.27,701,300,10,6001,0,65535,65535,1,22.6,27558,-298,-296,100,84,10,3230,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3946,3947,3943,3928,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,969,SUCCESS,,3232.588202,192,0,0.1,0.2,0.3,263,1.4,1.5
    2039,5/26/2021 21:28,8171.821,2.27,701,300,10,6001,0,65535,65535,1,22.6,27559,-296,-296,100,84,10,3229,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3946,3947,3942,3928,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,940,SUCCESS,,3232.259231,192,0,0.1,0.2,0.3,263,1.4,1.5
    2040,5/26/2021 21:29,8175.829,2.27,701,300,10,6001,0,65535,65535,1,22.6,27559,-296,-296,100,84,10,3229,3888,659,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3945,3947,3942,3927,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,990,SUCCESS,,3231.929684,192,0,0.1,0.2,0.3,263,1.4,1.5
    2041,5/26/2021 21:29,8179.843,2.27,701,300,10,6001,0,65535,65535,1,22.6,27555,-298,-296,100,84,10,3229,3888,655,655,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3945,3947,3942,3928,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,948,SUCCESS,,3231.597414,192,0,0.1,0.2,0.3,263,1.4,1.5
    2042,5/26/2021 21:29,8183.856,2.27,701,300,10,6001,0,65535,65535,1,22.6,27557,-296,-296,100,84,10,3228,3888,659,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3945,3946,3942,3928,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,949,SUCCESS,,3231.267456,192,0,0.1,0.2,0.3,263,1.4,1.5
    2043,5/26/2021 21:29,8187.856,2.27,701,300,10,6001,0,65535,65535,1,22.6,27556,-296,-296,100,84,10,3228,3888,650,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3940,3945,3946,3942,3927,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,947,SUCCESS,,3230.938568,192,0,0.1,0.2,0.3,263,1.4,1.5
    2044,5/26/2021 21:29,8191.872,2.28,701,300,10,6001,0,65535,65535,1,22.6,27555,-296,-296,100,84,10,3228,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3942,3927,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,949,SUCCESS,,3230.608363,192,0,0.1,0.2,0.3,263,1.4,1.5
    2045,5/26/2021 21:29,8195.883,2.28,701,300,10,6001,0,65535,65535,1,22.6,27554,-294,-296,100,83,10,3227,3888,659,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3942,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,989,SUCCESS,,3230.280798,192,0,0.1,0.2,0.3,263,1.4,1.5
    2046,5/26/2021 21:29,8199.885,2.28,701,300,10,6001,0,65535,65535,1,22.6,27554,-294,-296,100,83,10,3227,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3942,3927,3930,3926,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,992,SUCCESS,,3229.953968,192,0,0.1,0.2,0.3,263,1.4,1.5
    2047,5/26/2021 21:29,8203.891,2.28,701,300,10,6001,0,65535,65535,1,22.6,27553,-294,-296,100,83,10,3227,3888,659,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3942,3927,3930,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,940,SUCCESS,,3229.626811,192,0,0.1,0.2,0.3,263,1.4,1.5
    2048,5/26/2021 21:29,8207.904,2.28,701,300,10,6001,0,65535,65535,1,22.6,27553,-296,-296,100,83,10,3226,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3942,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,950,SUCCESS,,3229.296854,192,0,0.1,0.2,0.3,263,1.4,1.5
    2049,5/26/2021 21:29,8211.907,2.28,701,300,10,6001,0,65535,65535,1,22.6,27553,-296,-296,100,83,10,3226,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3941,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,946,SUCCESS,,3228.967718,192,0,0.1,0.2,0.3,263,1.4,1.5
    2050,5/26/2021 21:29,8215.91,2.28,701,300,10,6001,0,65535,65535,1,22.6,27553,-298,-296,100,83,10,3226,3888,650,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3941,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,943,SUCCESS,,3228.636359,192,0,0.1,0.2,0.3,263,1.4,1.5
    2051,5/26/2021 21:29,8219.918,2.28,701,300,10,6001,0,65535,65535,1,22.6,27552,-296,-296,100,83,10,3225,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3945,3946,3941,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,944,SUCCESS,,3228.306812,192,0,0.1,0.2,0.3,263,1.4,1.5
    2052,5/26/2021 21:29,8223.933,2.28,701,300,10,6001,0,65535,65535,1,22.6,27550,-296,-296,100,83,10,3225,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3944,3945,3941,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,968,SUCCESS,,3227.97669,192,0,0.1,0.2,0.3,263,1.4,1.5
    2053,5/26/2021 21:29,8227.947,2.29,701,300,10,6001,0,65535,65535,1,22.6,27550,-296,-296,100,83,10,3225,3888,654,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3944,3945,3941,3927,3929,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,969,SUCCESS,,3227.64665,192,0,0.1,0.2,0.3,263,1.4,1.5
    2054,5/26/2021 21:29,8231.952,2.29,701,300,10,6001,0,65535,65535,1,22.6,27549,-296,-297,100,83,10,3224,3888,654,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3941,3927,3928,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,962,SUCCESS,,3227.31735,192,0,0.1,0.2,0.3,263,1.4,1.5
    2055,5/26/2021 21:30,8235.958,2.29,701,300,10,6001,0,65535,65535,1,22.6,27549,-294,-296,100,83,10,3224,3888,658,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3939,3944,3945,3941,3926,3928,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,942,SUCCESS,,3226.990193,192,0,0.1,0.2,0.3,263,1.4,1.5
    2056,5/26/2021 21:30,8239.971,2.29,701,300,10,6001,0,65535,65535,1,22.6,27549,-298,-296,100,83,10,3224,3888,649,654,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3941,3926,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,946,SUCCESS,,3226.658006,192,0,0.1,0.2,0.3,263,1.4,1.5
    2057,5/26/2021 21:30,8243.978,2.29,701,300,10,6001,0,65535,65535,1,22.6,27547,-296,-296,100,83,10,3223,3888,658,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3941,3926,3928,3925,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,932,SUCCESS,,3226.328541,192,0,0.1,0.2,0.3,263,1.4,1.5
    2058,5/26/2021 21:30,8247.984,2.29,701,300,10,6001,0,65535,65535,1,22.6,27547,-296,-296,100,83,10,3223,3888,653,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3941,3926,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,941,SUCCESS,,3225.999159,192,0,0.1,0.2,0.3,263,1.4,1.5
    2059,5/26/2021 21:30,8251.996,2.29,701,300,10,6001,0,65535,65535,1,22.6,27546,-300,-296,100,83,10,3223,3888,653,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3941,3926,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.4,965,SUCCESS,,3225.664826,192,0,0.1,0.2,0.3,263,1.4,1.5
    2060,5/26/2021 21:30,8256.011,2.29,701,300,10,6001,0,65535,65535,1,22.6,27546,-296,-296,100,83,10,3222,3888,653,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3940,3925,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,949,SUCCESS,,3225.334704,192,0,0.1,0.2,0.3,263,1.4,1.5
    2061,5/26/2021 21:30,8260.018,2.29,701,300,10,6001,0,65535,65535,1,22.6,27545,-298,-296,100,83,10,3222,3888,649,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3944,3945,3940,3926,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,938,SUCCESS,,3225.003013,192,0,0.1,0.2,0.3,263,1.4,1.5
    2062,5/26/2021 21:30,8264.033,2.3,701,300,10,6001,0,65535,65535,1,22.6,27543,-298,-297,100,83,10,3222,3888,653,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3943,3944,3940,3925,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,944,SUCCESS,,3224.67066,192,0,0.1,0.2,0.3,263,1.4,1.5
    2063,5/26/2021 21:30,8268.038,2.3,701,300,10,6001,0,65535,65535,1,22.6,27542,-296,-297,100,83,10,3221,3888,653,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3943,3944,3940,3926,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,939,SUCCESS,,3224.34136,192,0,0.1,0.2,0.3,263,1.4,1.5
    2064,5/26/2021 21:30,8272.054,2.3,701,300,10,6001,0,65535,65535,1,22.6,27543,-300,-297,100,83,10,3221,3888,653,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3943,3944,3940,3925,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,965,SUCCESS,,3224.006694,192,0,0.1,0.2,0.3,263,1.4,1.5
    2065,5/26/2021 21:30,8276.057,2.3,701,300,10,6001,0,65535,65535,1,22.6,27542,-296,-297,100,83,10,3221,3888,653,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3943,3944,3940,3925,3929,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,981,SUCCESS,,3223.677558,192,0,0.1,0.2,0.3,263,1.4,1.5
    2066,5/26/2021 21:30,8280.064,2.3,701,300,10,6001,0,65535,65535,1,22.6,27541,-296,-296,100,83,10,3220,3888,657,653,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3943,3944,3939,3925,3927,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,969,SUCCESS,,3223.348094,192,0,0.1,0.2,0.3,263,1.4,1.5
    2067,5/26/2021 21:30,8284.069,2.3,701,300,10,6001,0,65535,65535,1,22.6,27541,-298,-297,100,83,10,3220,3888,653,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3938,3943,3944,3939,3925,3928,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,981,SUCCESS,,3223.016569,192,0,0.1,0.2,0.3,263,1.4,1.5
    2068,5/26/2021 21:30,8288.079,2.3,701,300,10,6001,0,65535,65535,1,22.6,27539,-296,-297,100,83,10,3220,3888,653,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3943,3944,3939,3925,3929,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,953,SUCCESS,,3222.686858,192,0,0.1,0.2,0.3,263,1.4,1.5
    2069,5/26/2021 21:30,8292.093,2.3,701,300,10,6001,0,65535,65535,1,22.6,27537,-296,-297,100,83,10,3219,3888,648,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3943,3944,3939,3925,3927,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,941,SUCCESS,,3222.356818,192,0,0.1,0.2,0.3,263,1.4,1.5
    2070,5/26/2021 21:31,8296.095,2.3,701,300,10,6001,0,65535,65535,1,22.6,27537,-296,-297,100,83,10,3219,3888,648,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3943,3944,3939,3925,3927,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,939,SUCCESS,,3222.027764,192,0,0.1,0.2,0.3,263,1.4,1.5
    2071,5/26/2021 21:31,8300.104,2.31,701,300,10,6001,0,65535,65535,1,22.6,27537,-296,-297,100,83,10,3219,3888,653,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3943,3944,3939,3925,3929,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,945,SUCCESS,,3221.698135,192,0,0.1,0.2,0.3,263,1.4,1.5
    2072,5/26/2021 21:31,8304.113,2.31,701,300,10,6001,0,65535,65535,1,22.6,27536,-296,-297,100,83,10,3218,3888,652,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3942,3943,3939,3925,3927,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,936,SUCCESS,,3221.368506,192,0,0.1,0.2,0.3,263,1.4,1.5
    2073,5/26/2021 21:31,8308.127,2.31,701,300,10,6001,0,65535,65535,1,22.6,27536,-296,-297,100,83,10,3218,3888,648,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3942,3944,3939,3925,3927,3924,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,985,SUCCESS,,3221.038466,192,0,0.1,0.2,0.3,263,1.4,1.5
    2074,5/26/2021 21:31,8312.135,2.31,701,300,10,6001,0,65535,65535,1,22.6,27536,-296,-297,100,83,10,3218,3888,648,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3942,3944,3939,3924,3927,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,992,SUCCESS,,3220.70892,192,0,0.1,0.2,0.3,263,1.4,1.5
    2075,5/26/2021 21:31,8316.15,2.31,701,300,10,6001,0,65535,65535,1,22.6,27533,-300,-297,100,83,10,3217,3888,648,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3937,3942,3943,3939,3924,3927,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,963,SUCCESS,,3220.374336,192,0,0.1,0.2,0.3,263,1.4,1.5
    2076,5/26/2021 21:31,8320.156,2.31,701,300,10,6001,0,65535,65535,1,22.6,27534,-294,-297,100,83,10,3217,3888,652,650,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3942,3943,3939,3924,3927,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,946,SUCCESS,,3220.04718,192,0,0.1,0.2,0.3,263,1.4,1.5
    2077,5/26/2021 21:31,8324.161,2.31,701,300,10,6001,0,65535,65535,1,22.6,27532,-298,-296,100,83,10,3217,3888,652,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3942,3943,3939,3924,3927,3923,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,981,SUCCESS,,3219.715655,192,0,0.1,0.2,0.3,263,1.4,1.5
    2078,5/26/2021 21:31,8328.173,2.31,701,300,10,6001,0,65535,65535,1,22.6,27534,-296,-296,100,83,10,3216,3888,648,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3942,3943,3939,3924,3927,3922,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.5,939,SUCCESS,,3219.385779,192,0,0.1,0.2,0.3,263,1.4,1.5
    2079,5/26/2021 21:31,8332.179,2.31,701,300,10,6001,0,65535,65535,1,22.6,27532,-298,-296,100,83,10,3216,3888,652,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3942,3943,3939,3924,3927,3922,0,0,0,0,0,0,0,0,2752,22.4,22.6,-273.2,22.6,-273.2,22.5,1012,SUCCESS,,3219.054171,192,0,0.1,0.2,0.3,263,1.4,1.5
    2080,5/26/2021 21:31,8336.189,2.32,701,300,10,6001,0,65535,65535,1,22.6,27531,-298,-296,100,83,10,3216,3888,652,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3942,3942,3938,3924,3927,3922,0,0,0,0,0,0,0,0,2753,22.4,22.6,-273.2,22.6,-273.2,22.6,954,SUCCESS,,3218.722233,192,0,0.1,0.2,0.3,263,1.4,1.5
    2081,5/26/2021 21:31,8340.199,2.32,701,300,10,6001,0,65535,65535,1,22.6,27531,-296,-296,100,83,10,3215,3888,652,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3941,3943,3938,3924,3927,3922,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,961,SUCCESS,,3218.392521,192,0,0.1,0.2,0.3,263,1.4,1.5
    2082,5/26/2021 21:31,8344.208,2.32,701,300,10,6001,0,65535,65535,1,22.6,27529,-296,-296,100,83,10,3215,3888,652,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3941,3942,3938,3924,3926,3922,0,0,0,0,0,0,0,0,2749,22.4,22.6,-273.2,22.6,-273.2,22.6,967,SUCCESS,,3218.062893,192,0,0.1,0.2,0.3,263,1.4,1.5
    2083,5/26/2021 21:31,8348.208,2.32,701,300,10,6001,0,65535,65535,1,22.6,27529,-298,-296,100,83,10,3215,3888,647,652,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3941,3942,3938,3924,3926,3922,0,0,0,0,0,0,0,0,2749,22.4,22.6,-273.2,22.6,-273.2,22.5,950,SUCCESS,,3217.731781,192,0,0.1,0.2,0.3,263,1.4,1.5
    2084,5/26/2021 21:31,8352.223,2.32,701,300,10,6001,0,65535,65535,1,22.6,27529,-296,-296,100,83,10,3214,3888,651,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3941,3942,3938,3924,3926,3922,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22,940,SUCCESS,,3217.401659,192,0,0.1,0.2,0.3,263,1.4,1.5
    2085,5/26/2021 21:32,8356.227,2.32,701,300,10,6001,0,65535,65535,1,22.6,27528,-296,-297,100,83,10,3214,3888,651,649,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3941,3942,3938,3924,3926,3922,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,970,SUCCESS,,3217.072441,192,0,0.1,0.2,0.3,263,1.4,1.5
    2086,5/26/2021 21:32,8360.237,2.32,701,300,10,6001,0,65535,65535,1,22.6,27528,-300,-297,100,83,10,3214,3888,643,649,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3936,3941,3942,3938,3923,3926,3922,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,958,SUCCESS,,3216.738275,192,0,0.1,0.2,0.3,263,1.4,1.5
    2087,5/26/2021 21:32,8364.247,2.32,701,300,10,6001,0,65535,65535,1,22.6,27528,-296,-297,100,83,10,3213,3888,651,649,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3941,3942,3938,3923,3926,3922,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,958,SUCCESS,,3216.408564,192,0,0.1,0.2,0.3,263,1.4,1.5
    2088,5/26/2021 21:32,8368.258,2.32,701,300,10,6001,0,65535,65535,1,22.6,27526,-296,-296,100,83,10,3213,3888,651,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3941,3942,3938,3923,3925,3922,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,980,SUCCESS,,3216.07877,192,0,0.1,0.2,0.3,263,1.4,1.5
    2089,5/26/2021 21:32,8372.265,2.33,701,300,10,6001,0,65535,65535,1,22.6,27525,-294,-297,100,83,10,3213,3888,656,649,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3941,3942,3938,3923,3926,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,965,SUCCESS,,3215.751532,192,0,0.1,0.2,0.3,263,1.4,1.5
    2090,5/26/2021 21:32,8376.267,2.33,701,300,10,6001,0,65535,65535,1,22.6,27525,-296,-296,100,83,10,3212,3888,651,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3941,3941,3937,3923,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,943,SUCCESS,,3215.422479,192,0,0.1,0.2,0.3,263,1.4,1.5
    2091,5/26/2021 21:32,8380.28,2.33,701,300,10,6001,0,65535,65535,1,22.6,27525,-296,-296,100,83,10,3212,3888,651,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3941,3942,3937,3923,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,949,SUCCESS,,3215.092521,192,0,0.1,0.2,0.3,263,1.4,1.5
    2092,5/26/2021 21:32,8384.294,2.33,701,300,10,6001,0,65535,65535,1,22.6,27525,-298,-296,100,83,10,3212,3888,647,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3940,3941,3937,3923,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,980,SUCCESS,,3214.760251,192,0,0.1,0.2,0.3,263,1.4,1.5
    2093,5/26/2021 21:32,8388.304,2.33,701,300,10,6001,0,65535,65535,1,22.6,27522,-294,-296,100,83,10,3211,3888,651,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3940,3941,3937,3922,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,986,SUCCESS,,3214.432768,192,0,0.1,0.2,0.3,263,1.4,1.5
    2094,5/26/2021 21:32,8392.307,2.33,701,300,10,6001,0,65535,65535,1,22.6,27521,-296,-296,100,83,10,3211,3888,647,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3940,3941,3937,3922,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,960,SUCCESS,,3214.103632,192,0,0.1,0.2,0.3,263,1.4,1.5
    2095,5/26/2021 21:32,8396.32,2.33,701,300,10,6001,0,65535,65535,1,22.6,27521,-296,-296,100,83,10,3211,3888,655,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3940,3941,3937,3922,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,964,SUCCESS,,3213.773674,192,0,0.1,0.2,0.3,263,1.4,1.5
    2096,5/26/2021 21:32,8400.32,2.33,701,300,10,6001,0,65535,65535,1,22.6,27521,-298,-296,100,83,10,3210,3888,651,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3940,3941,3937,3922,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.4,954,SUCCESS,,3213.442563,192,0,0.1,0.2,0.3,263,1.4,1.5
    2097,5/26/2021 21:32,8404.335,2.33,701,300,10,6001,0,65535,65535,1,22.6,27519,-296,-296,100,83,10,3210,3888,646,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3935,3940,3941,3937,3922,3924,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,1001,SUCCESS,,3213.112441,192,0,0.1,0.2,0.3,263,1.4,1.5
    2098,5/26/2021 21:32,8408.35,2.34,701,300,10,6001,0,65535,65535,1,22.6,27520,-294,-296,100,83,10,3210,3888,655,651,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3940,3941,3937,3922,3925,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,1001,SUCCESS,,3212.784549,192,0,0.1,0.2,0.3,263,1.4,1.5
    2099,5/26/2021 21:32,8412.356,2.34,701,300,10,6001,0,65535,65535,1,22.6,27521,-298,-297,100,83,10,3209,3888,646,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3940,3941,3936,3922,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.1,972,SUCCESS,,3212.452941,192,0,0.1,0.2,0.3,263,1.4,1.5
    2100,5/26/2021 21:33,8416.362,2.34,701,300,10,6001,0,65535,65535,1,22.6,27517,-298,-297,100,83,10,3209,3888,650,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3941,3936,3922,3924,3921,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,1002,SUCCESS,,3212.121334,192,0,0.1,0.2,0.3,263,1.4,1.5
    2101,5/26/2021 21:33,8420.364,2.34,701,300,10,6001,0,65535,65535,1,22.6,27517,-296,-297,100,83,10,3209,3888,650,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3941,3936,3922,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,951,SUCCESS,,3211.79228,192,0,0.1,0.2,0.3,263,1.4,1.5
    2102,5/26/2021 21:33,8424.374,2.34,701,300,10,6001,0,65535,65535,1,22.6,27516,-298,-297,100,83,10,3208,3888,642,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3941,3936,3922,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,945,SUCCESS,,3211.460341,192,0,0.1,0.2,0.3,263,1.4,1.5
    2103,5/26/2021 21:33,8428.389,2.34,701,300,10,6001,0,65535,65535,1,22.6,27514,-296,-297,100,83,10,3208,3888,646,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3941,3936,3922,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,21.7,944,SUCCESS,,3211.130219,192,0,0.1,0.2,0.3,263,1.4,1.5
    2104,5/26/2021 21:33,8432.395,2.34,701,300,10,6001,0,65535,65535,1,22.6,27514,-298,-297,100,83,10,3208,3888,646,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3940,3936,3921,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,943,SUCCESS,,3210.798611,192,0,0.1,0.2,0.3,263,1.4,1.5
    2105,5/26/2021 21:33,8436.405,2.34,701,300,10,6001,0,65535,65535,1,22.6,27513,-296,-297,100,83,10,3207,3888,650,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3941,3936,3921,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,942,SUCCESS,,3210.4689,192,0,0.1,0.2,0.3,263,1.4,1.5
    2106,5/26/2021 21:33,8440.405,2.34,701,300,10,6001,0,65535,65535,1,22.6,27513,-294,-297,100,83,10,3207,3888,654,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3940,3936,3921,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,958,SUCCESS,,3210.142234,192,0,0.1,0.2,0.3,263,1.4,1.5
    2107,5/26/2021 21:33,8444.41,2.35,701,300,10,6001,0,65535,65535,1,22.6,27515,-298,-297,100,83,10,3207,3888,641,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3940,3936,3921,3924,3920,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,951,SUCCESS,,3209.810709,192,0,0.1,0.2,0.3,263,1.4,1.5
    2108,5/26/2021 21:33,8448.416,2.35,701,300,10,6001,0,65535,65535,1,22.6,27512,-296,-297,100,83,10,3206,3888,646,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3939,3940,3936,3921,3924,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,966,SUCCESS,,3209.481326,192,0,0.1,0.2,0.3,263,1.4,1.5
    2109,5/26/2021 21:33,8452.427,2.35,701,300,10,6001,0,65535,65535,1,22.6,27511,-298,-297,100,83,10,3206,3888,650,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3934,3939,3940,3936,3921,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,971,SUCCESS,,3209.149305,192,0,0.1,0.2,0.3,263,1.4,1.5
    2110,5/26/2021 21:33,8456.436,2.35,701,300,10,6001,0,65535,65535,1,22.6,27512,-298,-297,100,83,10,3206,3888,646,648,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3939,3940,3935,3921,3924,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,940,SUCCESS,,3208.817449,192,0,0.1,0.2,0.3,263,1.4,1.5
    2111,5/26/2021 21:33,8460.441,2.35,701,300,10,6001,0,65535,65535,1,22.6,27511,-296,-297,100,83,10,3205,3888,650,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3939,3939,3935,3921,3924,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,941,SUCCESS,,3208.488149,192,0,0.1,0.2,0.3,263,1.4,1.5
    2112,5/26/2021 21:33,8464.442,2.35,701,300,10,6001,0,65535,65535,1,22.6,27508,-298,-297,100,83,10,3205,3888,650,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3921,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,955,SUCCESS,,3208.156955,192,0,0.1,0.2,0.3,263,1.4,1.5
    2113,5/26/2021 21:33,8468.448,2.35,701,300,10,6001,0,65535,65535,1,22.6,27510,-296,-297,100,83,10,3205,3888,645,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3921,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,982,SUCCESS,,3207.827573,192,0,0.1,0.2,0.3,263,1.4,1.5
    2114,5/26/2021 21:33,8472.458,2.35,701,300,10,6001,0,65535,65535,1,22.6,27508,-296,-297,100,83,10,3204,3888,649,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3921,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,971,SUCCESS,,3207.497861,192,0,0.1,0.2,0.3,263,1.4,1.5
    2115,5/26/2021 21:34,8476.467,2.35,701,300,10,6001,0,65535,65535,1,22.6,27507,-298,-297,100,83,10,3204,3888,645,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3921,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,941,SUCCESS,,3207.166005,192,0,0.1,0.2,0.3,263,1.4,1.5
    2116,5/26/2021 21:34,8480.479,2.36,701,300,10,6001,0,65535,65535,1,22.6,27511,-296,-297,100,83,10,3204,3888,649,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3920,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,952,SUCCESS,,3206.83613,192,0,0.1,0.2,0.3,263,1.4,1.5
    2117,5/26/2021 21:34,8484.486,2.36,701,300,10,6001,0,65535,65535,1,22.6,27507,-296,-297,100,83,10,3203,3888,654,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3920,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,952,SUCCESS,,3206.506665,192,0,0.1,0.2,0.3,263,1.4,1.5
    2118,5/26/2021 21:34,8488.498,2.36,701,300,10,6001,0,65535,65535,1,22.6,27505,-296,-297,100,83,10,3203,3888,649,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3920,3923,3919,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,963,SUCCESS,,3206.17679,192,0,0.1,0.2,0.3,263,1.4,1.5
    2119,5/26/2021 21:34,8492.507,2.36,701,300,10,6001,0,65535,65535,1,22.6,27506,-298,-297,100,83,10,3203,3888,649,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3933,3938,3939,3935,3920,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,963,SUCCESS,,3205.844934,192,0,0.1,0.2,0.3,263,1.4,1.5
    2120,5/26/2021 21:34,8496.517,2.36,701,300,10,6001,0,65535,65535,1,22.6,27505,-296,-297,100,83,10,3202,3888,645,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3932,3938,3939,3935,3920,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,961,SUCCESS,,3205.515223,192,0,0.1,0.2,0.3,263,1.4,1.5
    2121,5/26/2021 21:34,8500.526,2.36,701,300,10,6001,0,65535,65535,1,22.6,27502,-298,-297,100,83,10,3202,3888,645,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3932,3938,3939,3934,3920,3923,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,976,SUCCESS,,3205.183366,192,0,0.1,0.2,0.3,263,1.4,1.5
    2122,5/26/2021 21:34,8504.534,2.36,701,300,10,6001,0,65535,65535,1,22.6,27502,-296,-297,100,83,10,3202,3888,649,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3932,3938,3939,3935,3920,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,969,SUCCESS,,3204.85382,192,0,0.1,0.2,0.3,263,1.4,1.5
    2123,5/26/2021 21:34,8508.536,2.36,701,300,10,6001,0,65535,65535,1,22.6,27503,-298,-297,100,83,10,3201,3888,644,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3932,3938,3938,3934,3920,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,957,SUCCESS,,3204.522543,192,0,0.1,0.2,0.3,263,1.4,1.5
    2124,5/26/2021 21:34,8512.543,2.36,701,300,10,6001,0,65535,65535,1,22.6,27501,-296,-297,100,83,10,3201,3888,649,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3932,3938,3938,3934,3919,3921,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,944,SUCCESS,,3204.193079,192,0,0.1,0.2,0.3,263,1.4,1.5
    2125,5/26/2021 21:34,8516.547,2.37,701,300,10,6001,0,65535,65535,1,22.6,27500,-298,-297,100,83,10,3201,3888,644,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3937,3938,3934,3919,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,939,SUCCESS,,3203.861636,192,0,0.1,0.2,0.3,263,1.4,1.5
    2126,5/26/2021 21:34,8520.556,2.37,701,300,10,6001,0,65535,65535,1,22.6,27499,-298,-297,100,83,10,3200,3888,644,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3937,3938,3934,3919,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,944,SUCCESS,,3203.52978,192,0,0.1,0.2,0.3,263,1.4,1.5
    2127,5/26/2021 21:34,8524.557,2.37,701,300,10,6001,0,65535,65535,1,22.6,27499,-296,-297,100,83,10,3200,3888,649,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3937,3938,3934,3919,3923,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,965,SUCCESS,,3203.200809,192,0,0.1,0.2,0.3,263,1.4,1.5
    2128,5/26/2021 21:34,8528.562,2.37,701,300,10,6001,0,65535,65535,1,22.6,27499,-298,-297,100,83,10,3200,3888,644,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3937,3938,3934,3919,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,945,SUCCESS,,3202.869284,192,0,0.1,0.2,0.3,263,1.4,1.5
    2129,5/26/2021 21:34,8532.567,2.37,701,300,10,6001,0,65535,65535,1,22.6,27499,-298,-297,100,83,10,3199,3888,644,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3937,3938,3934,3919,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,971,SUCCESS,,3202.537759,192,0,0.1,0.2,0.3,263,1.4,1.5
    2130,5/26/2021 21:35,8536.571,2.37,701,300,10,6001,0,65535,65535,1,22.6,27497,-296,-297,100,83,10,3199,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3937,3938,3933,3919,3921,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,951,SUCCESS,,3202.208541,192,0,0.1,0.2,0.3,263,1.4,1.5
    2131,5/26/2021 21:35,8540.584,2.37,701,300,10,6001,0,65535,65535,1,22.6,27498,-298,-297,100,83,10,3199,3888,644,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3938,3933,3919,3922,3918,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,970,SUCCESS,,3201.876354,192,0,0.1,0.2,0.3,263,1.4,1.5
    2132,5/26/2021 21:35,8544.592,2.37,701,300,10,6001,0,65535,65535,1,22.6,27495,-294,-297,100,83,10,3198,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3938,3933,3919,3921,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,941,SUCCESS,,3201.549034,192,0,0.1,0.2,0.3,263,1.4,1.5
    2133,5/26/2021 21:35,8548.607,2.37,701,300,10,6001,0,65535,65535,1,22.6,27496,-296,-297,100,83,10,3198,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3938,3933,3919,3922,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,948,SUCCESS,,3201.218912,192,0,0.1,0.2,0.3,263,1.4,1.5
    2134,5/26/2021 21:35,8552.615,2.38,701,300,10,6001,0,65535,65535,1,22.6,27495,-298,-297,100,83,10,3198,3888,644,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3938,3933,3919,3921,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,950,SUCCESS,,3200.887139,192,0,0.1,0.2,0.3,263,1.4,1.5
    2135,5/26/2021 21:35,8556.628,2.38,701,300,10,6001,0,65535,65535,1,22.6,27494,-296,-297,100,83,10,3197,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3938,3933,3919,3921,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,941,SUCCESS,,3200.557181,192,0,0.1,0.2,0.3,263,1.4,1.5
    2136,5/26/2021 21:35,8560.642,2.38,701,300,10,6001,0,65535,65535,1,22.6,27495,-298,-297,100,83,10,3197,3888,644,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3937,3933,3919,3920,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,943,SUCCESS,,3200.224911,192,0,0.1,0.2,0.3,263,1.4,1.5
    2137,5/26/2021 21:35,8564.646,2.38,701,300,10,6001,0,65535,65535,1,22.6,27493,-296,-297,100,83,10,3197,3888,639,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3931,3936,3937,3933,3918,3921,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.6,958,SUCCESS,,3199.895693,192,0,0.1,0.2,0.3,263,1.4,1.5
    2138,5/26/2021 21:35,8568.652,2.38,701,300,10,6001,0,65535,65535,1,22.6,27493,-298,-297,100,83,10,3196,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3936,3937,3933,3919,3921,3917,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,980,SUCCESS,,3199.564085,192,0,0.1,0.2,0.3,263,1.4,1.5
    2139,5/26/2021 21:35,8572.658,2.38,701,300,10,6001,0,65535,65535,1,22.5,27491,-298,-297,100,83,10,3196,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3936,3937,3933,3919,3921,3916,0,0,0,0,0,0,0,0,2748,22.4,22.5,-273.2,22.5,-273.2,22.5,960,SUCCESS,,3199.232478,192,0,0.1,0.2,0.3,263,1.4,1.5
    2140,5/26/2021 21:35,8576.662,2.38,701,300,10,6001,0,65535,65535,1,22.5,27490,-294,-297,100,83,10,3196,3888,648,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3936,3937,3932,3918,3921,3916,0,0,0,0,0,0,0,0,2748,22.4,22.5,-273.2,22.5,-273.2,22.5,943,SUCCESS,,3198.905484,192,0,0.1,0.2,0.3,263,1.4,1.5
    2141,5/26/2021 21:35,8580.67,2.38,701,300,10,6001,0,65535,65535,1,22.5,27491,-296,-297,100,83,10,3195,3888,648,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3936,3937,3933,3918,3921,3916,0,0,0,0,0,0,0,0,2748,22.4,22.5,-273.2,22.5,-273.2,22.6,958,SUCCESS,,3198.575938,192,0,0.1,0.2,0.3,263,1.4,1.5
    2142,5/26/2021 21:35,8584.676,2.38,701,300,10,6001,0,65535,65535,1,22.5,27489,-296,-297,100,83,10,3195,3888,648,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3936,3932,3918,3921,3916,0,0,0,0,0,0,0,0,2748,22.4,22.5,-273.2,22.5,-273.2,22.5,982,SUCCESS,,3198.246555,192,0,0.1,0.2,0.3,263,1.4,1.5
    2143,5/26/2021 21:35,8588.689,2.39,701,300,10,6001,0,65535,65535,1,22.6,27488,-294,-297,100,83,10,3195,3888,648,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3937,3932,3918,3920,3916,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,946,SUCCESS,,3197.918827,192,0,0.1,0.2,0.3,263,1.4,1.5
    2144,5/26/2021 21:35,8592.692,2.39,701,300,10,6001,0,65535,65535,1,22.6,27487,-298,-296,100,83,10,3194,3888,647,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3936,3937,3932,3918,3920,3916,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,972,SUCCESS,,3197.587468,192,0,0.1,0.2,0.3,263,1.4,1.5
    2145,5/26/2021 21:36,8596.7,2.39,701,300,10,6001,0,65535,65535,1,22.5,27488,-298,-297,100,83,10,3194,3888,647,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3936,3932,3918,3920,3916,0,0,0,0,0,0,0,0,2748,22.4,22.5,-273.2,22.5,-273.2,22.5,950,SUCCESS,,3197.255694,192,0,0.1,0.2,0.3,263,1.4,1.5
    2146,5/26/2021 21:36,8600.705,2.39,701,300,10,6001,0,65535,65535,1,22.6,27487,-298,-297,100,83,10,3194,3888,647,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3936,3932,3918,3920,3916,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,940,SUCCESS,,3196.924169,192,0,0.1,0.2,0.3,263,1.4,1.5
    2147,5/26/2021 21:36,8604.712,2.39,701,300,10,6001,0,65535,65535,1,22.6,27487,-296,-297,100,83,10,3193,3888,643,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3936,3932,3917,3920,3916,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,946,SUCCESS,,3196.594705,192,0,0.1,0.2,0.3,263,1.4,1.5
    2148,5/26/2021 21:36,8608.725,2.39,701,300,10,6001,0,65535,65535,1,22.6,27485,-298,-297,100,83,10,3193,3888,647,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3936,3932,3918,3921,3916,0,0,0,0,0,0,0,0,2748,22.4,22.6,-273.2,22.6,-273.2,22.5,966,SUCCESS,,3196.262518,192,0,0.1,0.2,0.3,263,1.4,1.5
    2149,5/26/2021 21:36,8612.727,2.39,701,300,10,6001,0,65535,65535,1,22.6,27485,-294,-297,100,83,10,3193,3888,647,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3930,3935,3936,3931,3917,3919,3916,0,0,0,0,0,0,0,0,2747,22.4,22.6,-273.2,22.6,-273.2,22.6,948,SUCCESS,,3195.935688,192,0,0.1,0.2,0.3,263,1.4,1.5
    2150,5/26/2021 21:36,8616.74,2.39,701,300,10,6001,0,65535,65535,1,22.6,27483,-296,-297,100,83,10,3192,3888,643,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3935,3936,3931,3917,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.6,-273.2,22.6,-273.2,22.5,986,SUCCESS,,3195.60573,192,0,0.1,0.2,0.3,263,1.4,1.5
    2151,5/26/2021 21:36,8620.741,2.39,701,300,10,6001,0,65535,65535,1,22.6,27483,-296,-296,100,83,10,3192,3888,651,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3935,3936,3931,3917,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.6,-273.2,22.6,-273.2,22.5,980,SUCCESS,,3195.276759,192,0,0.1,0.2,0.3,263,1.4,1.5
    2152,5/26/2021 21:36,8624.755,2.4,701,300,10,6001,0,65535,65535,1,22.6,27482,-298,-297,100,83,10,3192,3888,643,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3935,3936,3931,3917,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.6,-273.2,22.6,-273.2,22.5,971,SUCCESS,,3194.944489,192,0,0.1,0.2,0.3,263,1.4,1.5
    2153,5/26/2021 21:36,8628.757,2.4,701,300,10,6001,0,65535,65535,1,22.6,27482,-298,-297,100,83,10,3191,3888,642,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3935,3936,3931,3916,3919,3915,0,0,0,0,0,0,0,0,2745,22.4,22.6,-273.2,22.6,-273.2,22.6,966,SUCCESS,,3194.613212,192,0,0.1,0.2,0.3,263,1.4,1.5
    2154,5/26/2021 21:36,8632.765,2.4,701,300,10,6001,0,65535,65535,1,22.6,27482,-296,-297,100,83,10,3191,3888,642,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3935,3936,3931,3917,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.6,-273.2,21.9,941,SUCCESS,,3194.283665,192,0,0.1,0.2,0.3,263,1.4,1.5
    2155,5/26/2021 21:36,8636.773,2.4,701,300,10,6001,0,65535,65535,1,22.6,27480,-298,-296,100,83,10,3191,3888,647,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3934,3935,3931,3917,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.6,-273.2,22.5,971,SUCCESS,,3193.951892,192,0,0.1,0.2,0.3,263,1.4,1.5
    2156,5/26/2021 21:36,8640.777,2.4,701,300,10,6001,0,65535,65535,1,22.5,27479,-298,-297,100,83,10,3190,3888,647,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3929,3934,3935,3931,3916,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,944,SUCCESS,,3193.62045,192,0,0.1,0.2,0.3,263,1.4,1.5
    2157,5/26/2021 21:36,8644.789,2.4,701,300,10,6001,0,65535,65535,1,22.5,27479,-296,-296,100,83,10,3190,3888,651,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,964,SUCCESS,,3193.290574,192,0,0.1,0.2,0.3,263,1.4,1.5
    2158,5/26/2021 21:36,8648.804,2.4,701,300,10,6001,0,65535,65535,1,22.5,27478,-298,-296,100,83,10,3190,3888,642,647,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.6,975,SUCCESS,,3192.958221,192,0,0.1,0.2,0.3,263,1.4,1.5
    2159,5/26/2021 21:36,8652.808,2.4,701,300,10,6001,0,65535,65535,1,22.5,27478,-296,-296,100,83,10,3189,3888,646,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3919,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,943,SUCCESS,,3192.629004,192,0,0.1,0.2,0.3,263,1.4,1.5
    2160,5/26/2021 21:37,8656.816,2.4,701,300,10,6001,0,65535,65535,1,22.5,27477,-296,-296,100,83,10,3189,3888,646,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3919,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,955,SUCCESS,,3192.299457,192,0,0.1,0.2,0.3,263,1.4,1.5
    2161,5/26/2021 21:37,8660.821,2.41,701,300,10,6001,0,65535,65535,1,22.5,27477,-298,-296,100,83,10,3189,3888,642,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3919,3915,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,964,SUCCESS,,3191.967932,192,0,0.1,0.2,0.3,263,1.4,1.5
    2162,5/26/2021 21:37,8664.832,2.41,701,300,10,6001,0,65535,65535,1,22.5,27477,-296,-296,100,82,10,3188,3888,646,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3919,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,942,SUCCESS,,3191.638139,192,0,0.1,0.2,0.3,263,1.4,1.5
    2163,5/26/2021 21:37,8668.836,2.41,701,300,10,6001,0,65535,65535,1,22.5,27476,-296,-296,100,82,10,3188,3888,646,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3934,3935,3931,3916,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.6,965,SUCCESS,,3191.308921,192,0,0.1,0.2,0.3,263,1.4,1.5
    2164,5/26/2021 21:37,8672.836,2.41,701,300,10,6001,0,65535,65535,1,22.5,27474,-298,-296,100,82,10,3188,3888,642,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3916,3919,3914,0,0,0,0,0,0,0,0,2744,22.4,22.6,-273.2,22.6,-273.2,22.5,978,SUCCESS,,3190.97781,192,0,0.1,0.2,0.3,263,1.4,1.5
    2165,5/26/2021 21:37,8676.844,2.41,701,300,10,6001,0,65535,65535,1,22.6,27473,-296,-296,100,82,10,3187,3888,646,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3916,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,945,SUCCESS,,3190.648263,192,0,0.1,0.2,0.3,263,1.4,1.5
    2166,5/26/2021 21:37,8680.845,2.41,701,300,10,6001,0,65535,65535,1,22.5,27475,-296,-297,100,82,10,3187,3888,646,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3916,3919,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,942,SUCCESS,,3190.319292,192,0,0.1,0.2,0.3,263,1.4,1.5
    2167,5/26/2021 21:37,8684.859,2.41,701,300,10,6001,0,65535,65535,1,22.5,27473,-296,-297,100,82,10,3187,3888,646,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3916,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,956,SUCCESS,,3189.989252,192,0,0.1,0.2,0.3,263,1.4,1.5
    2168,5/26/2021 21:37,8688.874,2.41,701,300,10,6001,0,65535,65535,1,22.5,27472,-296,-297,100,82,10,3186,3888,646,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3916,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.1,966,SUCCESS,,3189.65913,192,0,0.1,0.2,0.3,263,1.4,1.5
    2169,5/26/2021 21:37,8692.888,2.41,701,300,10,6001,0,65535,65535,1,22.5,27472,-298,-297,100,82,10,3186,3888,641,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3915,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,947,SUCCESS,,3189.32686,192,0,0.1,0.2,0.3,263,1.4,1.5
    2170,5/26/2021 21:37,8696.891,2.42,701,300,10,6001,0,65535,65535,1,22.5,27472,-296,-297,100,82,10,3186,3888,641,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3928,3933,3934,3930,3915,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,940,SUCCESS,,3188.997724,192,0,0.1,0.2,0.3,263,1.4,1.5
    2171,5/26/2021 21:37,8700.902,2.42,701,300,10,6001,0,65535,65535,1,22.5,27470,-294,-296,100,82,10,3185,3888,650,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3933,3934,3930,3915,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.4,942,SUCCESS,,3188.670159,192,0,0.1,0.2,0.3,263,1.4,1.5
    2172,5/26/2021 21:37,8704.909,2.42,701,300,10,6001,0,65535,65535,1,22.5,27471,-298,-297,100,82,10,3185,3888,646,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3933,3934,3930,3915,3918,3914,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,943,SUCCESS,,3188.338469,192,0,0.1,0.2,0.3,263,1.4,1.5
    2173,5/26/2021 21:37,8708.92,2.42,701,300,10,6001,0,65535,65535,1,22.5,27470,-296,-296,100,82,10,3185,3888,646,646,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3933,3934,3930,3915,3918,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,988,SUCCESS,,3188.008675,192,0,0.1,0.2,0.3,263,1.4,1.5
    2174,5/26/2021 21:38,8712.932,2.42,701,300,10,6001,0,65535,65535,1,22.5,27470,-296,-296,100,82,10,3184,3888,645,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3933,3934,3930,3915,3918,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,969,SUCCESS,,3187.6788,192,0,0.1,0.2,0.3,263,1.4,1.5
    2175,5/26/2021 21:38,8716.937,2.42,701,300,10,6001,0,65535,65535,1,22.5,27468,-294,-296,100,82,10,3184,3888,641,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3915,3918,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,955,SUCCESS,,3187.351725,192,0,0.1,0.2,0.3,263,1.4,1.5
    2176,5/26/2021 21:38,8720.953,2.42,701,300,10,6001,0,65535,65535,1,22.5,27467,-294,-296,100,82,10,3184,3888,650,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3915,3917,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,954,SUCCESS,,3187.023751,192,0,0.1,0.2,0.3,263,1.4,1.5
    2177,5/26/2021 21:38,8724.959,2.42,701,300,10,6001,0,65535,65535,1,22.5,27465,-298,-296,100,82,10,3183,3888,641,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3914,3917,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,972,SUCCESS,,3186.692144,192,0,0.1,0.2,0.3,263,1.4,1.5
    2178,5/26/2021 21:38,8728.964,2.42,701,300,10,6001,0,65535,65535,1,22.5,27466,-298,-296,100,82,10,3183,3888,641,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3914,3917,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,959,SUCCESS,,3186.360619,192,0,0.1,0.2,0.3,263,1.4,1.5
    2179,5/26/2021 21:38,8732.966,2.43,701,300,10,6001,0,65535,65535,1,22.5,27465,-296,-296,100,82,10,3183,3888,645,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3914,3917,3913,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.6,973,SUCCESS,,3186.031565,192,0,0.1,0.2,0.3,263,1.4,1.5
    2180,5/26/2021 21:38,8736.979,2.43,701,300,10,6001,0,65535,65535,1,22.5,27465,-298,-297,100,82,10,3182,3888,641,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3914,3917,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,950,SUCCESS,,3185.699378,192,0,0.1,0.2,0.3,263,1.4,1.5
    2181,5/26/2021 21:38,8740.981,2.43,701,300,10,6001,0,65535,65535,1,22.5,27465,-294,-296,100,82,10,3182,3888,645,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3914,3917,3913,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,944,SUCCESS,,3185.372548,192,0,0.1,0.2,0.3,263,1.4,1.5
    2182,5/26/2021 21:38,8744.987,2.43,701,300,10,6001,0,65535,65535,1,22.5,27464,-298,-296,100,82,10,3182,3888,645,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3932,3933,3929,3914,3917,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22,953,SUCCESS,,3185.04094,192,0,0.1,0.2,0.3,263,1.4,1.5
    2183,5/26/2021 21:38,8749,2.43,701,300,10,6001,0,65535,65535,1,22.5,27463,-298,-297,100,82,10,3181,3888,640,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3927,3931,3933,3929,3914,3916,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,946,SUCCESS,,3184.708753,192,0,0.1,0.2,0.3,263,1.4,1.5
    2184,5/26/2021 21:38,8753.001,2.43,701,300,10,6001,0,65535,65535,1,22.5,27464,-296,-296,100,82,10,3181,3888,645,645,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3932,3933,3928,3914,3916,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,955,SUCCESS,,3184.379782,192,0,0.1,0.2,0.3,263,1.4,1.5
    2185,5/26/2021 21:38,8757.014,2.43,701,300,10,6001,0,65535,65535,1,22.5,27460,-296,-297,100,82,10,3181,3888,640,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3933,3928,3914,3916,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,947,SUCCESS,,3184.049824,192,0,0.1,0.2,0.3,263,1.4,1.5
    2186,5/26/2021 21:38,8761.019,2.43,701,300,10,6001,0,65535,65535,1,22.5,27460,-298,-297,100,82,10,3180,3888,645,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3933,3928,3914,3916,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,940,SUCCESS,,3183.718299,192,0,0.1,0.2,0.3,263,1.4,1.5
    2187,5/26/2021 21:38,8765.027,2.43,701,300,10,6001,0,65535,65535,1,22.5,27462,-300,-297,100,82,10,3180,3888,645,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3933,3928,3914,3916,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,980,SUCCESS,,3183.384299,192,0,0.1,0.2,0.3,263,1.4,1.5
    2188,5/26/2021 21:38,8769.038,2.44,701,300,10,6001,0,65535,65535,1,22.5,27460,-298,-297,100,82,10,3180,3888,645,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3932,3928,3914,3916,3912,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3183.052278,192,0,0.1,0.2,0.3,263,1.4,1.5
    2189,5/26/2021 21:39,8773.041,2.44,701,300,10,6001,0,65535,65535,1,22.5,27457,-296,-297,100,82,10,3180,3888,649,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3932,3928,3913,3916,3911,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,944,SUCCESS,,3182.723142,192,0,0.1,0.2,0.3,263,1.4,1.5
    2190,5/26/2021 21:39,8777.044,2.44,701,300,10,6001,0,65535,65535,1,22.5,27458,-298,-297,100,82,10,3179,3888,636,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3932,3928,3914,3916,3911,0,0,0,0,0,0,0,0,2744,22.4,22.5,-273.2,22.5,-273.2,22.5,942,SUCCESS,,3182.391783,192,0,0.1,0.2,0.3,263,1.4,1.5
    2191,5/26/2021 21:39,8781.046,2.44,701,300,10,6001,0,65535,65535,1,22.5,27457,-296,-297,100,82,10,3179,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3932,3928,3913,3916,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,952,SUCCESS,,3182.062729,192,0,0.1,0.2,0.3,263,1.4,1.5
    2192,5/26/2021 21:39,8785.053,2.44,701,300,10,6001,0,65535,65535,1,22.5,27455,-296,-297,100,82,10,3179,3888,649,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3926,3931,3932,3928,3913,3916,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,965,SUCCESS,,3181.733265,192,0,0.1,0.2,0.3,263,1.4,1.5
    2193,5/26/2021 21:39,8789.067,2.44,701,300,10,6001,0,65535,65535,1,22.5,27459,-296,-297,100,82,10,3178,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3932,3928,3913,3916,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.4,953,SUCCESS,,3181.403225,192,0,0.1,0.2,0.3,263,1.4,1.5
    2194,5/26/2021 21:39,8793.069,2.44,701,300,10,6001,0,65535,65535,1,22.5,27455,-296,-297,100,82,10,3178,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3931,3932,3928,3913,3916,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,964,SUCCESS,,3181.074171,192,0,0.1,0.2,0.3,263,1.4,1.5
    2195,5/26/2021 21:39,8797.077,2.44,701,300,10,6001,0,65535,65535,1,22.5,27454,-298,-297,100,82,10,3177,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3913,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,940,SUCCESS,,3180.742398,192,0,0.1,0.2,0.3,263,1.4,1.5
    2196,5/26/2021 21:39,8801.08,2.44,701,300,10,6001,0,65535,65535,1,22.5,27454,-298,-297,100,82,10,3177,3888,640,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3913,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.1,948,SUCCESS,,3180.411039,192,0,0.1,0.2,0.3,263,1.4,1.5
    2197,5/26/2021 21:39,8805.084,2.45,701,300,10,6001,0,65535,65535,1,22.5,27452,-296,-297,100,82,10,3177,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3913,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3180.081821,192,0,0.1,0.2,0.3,263,1.4,1.5
    2198,5/26/2021 21:39,8809.092,2.45,701,300,10,6001,0,65535,65535,1,22.5,27452,-298,-297,100,82,10,3176,3888,639,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3913,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.4,964,SUCCESS,,3179.750048,192,0,0.1,0.2,0.3,263,1.4,1.5
    2199,5/26/2021 21:39,8813.106,2.45,701,300,10,6001,0,65535,65535,1,22.5,27452,-296,-297,100,82,10,3176,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3913,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,945,SUCCESS,,3179.420008,192,0,0.1,0.2,0.3,263,1.4,1.5
    2200,5/26/2021 21:39,8817.114,2.45,701,300,10,6001,0,65535,65535,1,22.5,27452,-296,-297,100,82,10,3176,3888,644,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3912,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,1002,SUCCESS,,3179.090461,192,0,0.1,0.2,0.3,263,1.4,1.5
    2201,5/26/2021 21:39,8821.121,2.45,701,300,10,6001,0,65535,65535,1,22.5,27451,-298,-297,100,82,10,3175,3888,639,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3912,3914,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3178.75877,192,0,0.1,0.2,0.3,263,1.4,1.5
    2202,5/26/2021 21:39,8825.127,2.45,701,300,10,6001,0,65535,65535,1,22.5,27451,-296,-297,100,82,10,3175,3888,644,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3912,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,936,SUCCESS,,3178.429388,192,0,0.1,0.2,0.3,263,1.4,1.5
    2203,5/26/2021 21:39,8829.141,2.45,701,300,10,6001,0,65535,65535,1,22.5,27451,-294,-296,100,82,10,3175,3888,648,644,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3925,3930,3931,3927,3912,3915,3911,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,961,SUCCESS,,3178.101578,192,0,0.1,0.2,0.3,263,1.4,1.5
    2204,5/26/2021 21:40,8833.143,2.45,701,300,10,6001,0,65535,65535,1,22.5,27450,-300,-297,100,82,10,3174,3888,635,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3930,3931,3927,3912,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,953,SUCCESS,,3177.768078,192,0,0.1,0.2,0.3,263,1.4,1.5
    2205,5/26/2021 21:40,8837.154,2.45,701,300,10,6001,0,65535,65535,1,22.5,27449,-296,-297,100,82,10,3174,3888,643,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3930,3931,3927,3912,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,959,SUCCESS,,3177.438285,192,0,0.1,0.2,0.3,263,1.4,1.5
    2206,5/26/2021 21:40,8841.162,2.46,701,300,10,6001,0,65535,65535,1,22.5,27449,-296,-296,100,82,10,3174,3888,639,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3930,3931,3927,3912,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,986,SUCCESS,,3177.108738,192,0,0.1,0.2,0.3,263,1.4,1.5
    2207,5/26/2021 21:40,8845.167,2.46,701,300,10,6001,0,65535,65535,1,22.5,27446,-296,-296,100,82,10,3173,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3931,3926,3912,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,948,SUCCESS,,3176.779438,192,0,0.1,0.2,0.3,263,1.4,1.5
    2208,5/26/2021 21:40,8849.17,2.46,701,300,10,6001,0,65535,65535,1,22.5,27444,-294,-296,100,82,10,3173,3888,648,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3912,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3176.452526,192,0,0.1,0.2,0.3,263,1.4,1.5
    2209,5/26/2021 21:40,8853.176,2.46,701,300,10,6001,0,65535,65535,1,22.5,27444,-298,-296,100,82,10,3173,3888,639,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3912,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,950,SUCCESS,,3176.120919,192,0,0.1,0.2,0.3,263,1.4,1.5
    2210,5/26/2021 21:40,8857.179,2.46,701,300,10,6001,0,65535,65535,1,22.5,27445,-296,-296,100,82,10,3173,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3912,3915,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,986,SUCCESS,,3175.791783,192,0,0.1,0.2,0.3,263,1.4,1.5
    2211,5/26/2021 21:40,8861.182,2.46,701,300,10,6001,0,65535,65535,1,22.5,27444,-294,-296,100,82,10,3172,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3911,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,968,SUCCESS,,3175.464871,192,0,0.1,0.2,0.3,263,1.4,1.5
    2212,5/26/2021 21:40,8865.182,2.46,701,300,10,6001,0,65535,65535,1,22.5,27444,-298,-296,100,82,10,3172,3888,639,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3911,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.4,978,SUCCESS,,3175.13376,192,0,0.1,0.2,0.3,263,1.4,1.5
    2213,5/26/2021 21:40,8869.189,2.46,701,300,10,6001,0,65535,65535,1,22.5,27444,-296,-296,100,82,10,3172,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3911,3914,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,959,SUCCESS,,3174.804296,192,0,0.1,0.2,0.3,263,1.4,1.5
    2214,5/26/2021 21:40,8873.203,2.46,701,300,10,6001,0,65535,65535,1,22.5,27444,-298,-296,100,82,10,3171,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3926,3911,3913,3910,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,954,SUCCESS,,3174.472026,192,0,0.1,0.2,0.3,263,1.4,1.5
    2215,5/26/2021 21:40,8877.209,2.47,701,300,10,6001,0,65535,65535,1,22.5,27442,-298,-296,100,82,10,3171,3888,638,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3929,3930,3925,3911,3914,3909,0,0,0,0,0,0,0,0,2740,22.3,22.5,-273.2,22.5,-273.2,22.5,938,SUCCESS,,3174.140418,192,0,0.1,0.2,0.3,263,1.4,1.5
    2216,5/26/2021 21:40,8881.221,2.47,701,300,10,6001,0,65535,65535,1,22.5,27442,-296,-296,100,82,10,3171,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3924,3928,3930,3926,3911,3915,3909,0,0,0,0,0,0,0,0,2744,22.3,22.5,-273.2,22.5,-273.2,22.5,938,SUCCESS,,3173.810543,192,0,0.1,0.2,0.3,263,1.4,1.5
    2217,5/26/2021 21:40,8885.236,2.47,701,300,10,6001,0,65535,65535,1,22.5,27440,-296,-296,100,82,10,3170,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3930,3925,3911,3914,3909,0,0,0,0,0,0,0,0,2740,22.3,22.5,-273.2,22.5,-273.2,22.4,953,SUCCESS,,3173.48042,192,0,0.1,0.2,0.3,263,1.4,1.5
    2218,5/26/2021 21:40,8889.242,2.47,701,300,10,6001,0,65535,65535,1,22.5,27441,-298,-296,100,82,10,3170,3888,643,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3930,3925,3911,3913,3909,0,0,0,0,0,0,0,0,2743,22.3,22.5,-273.2,22.5,-273.2,22.5,993,SUCCESS,,3173.148813,192,0,0.1,0.2,0.3,263,1.4,1.5
    2219,5/26/2021 21:41,8893.249,2.47,701,300,10,6001,0,65535,65535,1,22.5,27438,-296,-296,100,82,10,3170,3888,647,643,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3929,3925,3911,3914,3909,0,0,0,0,0,0,0,0,2740,22.3,22.5,-273.2,22.5,-273.2,21.7,951,SUCCESS,,3172.819348,192,0,0.1,0.2,0.3,263,1.4,1.5
    2220,5/26/2021 21:41,8897.255,2.47,701,300,10,6001,0,65535,65535,1,22.5,27438,-298,-296,100,82,10,3169,3888,647,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3929,3925,3911,3913,3909,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,937,SUCCESS,,3172.48774,192,0,0.1,0.2,0.3,263,1.4,1.5
    2221,5/26/2021 21:41,8901.268,2.47,701,300,10,6001,0,65535,65535,1,22.5,27437,-296,-296,100,82,10,3169,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3929,3925,3911,3913,3909,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,965,SUCCESS,,3172.157783,192,0,0.1,0.2,0.3,263,1.4,1.5
    2222,5/26/2021 21:41,8905.272,2.47,701,300,10,6001,0,65535,65535,1,22.5,27438,-298,-296,100,82,10,3169,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3929,3925,3911,3918,3909,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,932,SUCCESS,,3171.82634,192,0,0.1,0.2,0.3,263,1.4,1.5
    2223,5/26/2021 21:41,8909.283,2.47,701,300,10,6001,0,65535,65535,1,22.5,27437,-296,-296,100,82,10,3168,3888,638,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3923,3928,3929,3925,3910,3913,3909,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,953,SUCCESS,,3171.496547,192,0,0.1,0.2,0.3,263,1.4,1.5
    2224,5/26/2021 21:41,8913.297,2.48,701,300,10,6001,0,65535,65535,1,22.5,27436,-294,-296,100,82,10,3168,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3928,3929,3925,3910,3913,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,957,SUCCESS,,3171.168737,192,0,0.1,0.2,0.3,263,1.4,1.5
    2225,5/26/2021 21:41,8917.301,2.48,701,300,10,6001,0,65535,65535,1,22.5,27435,-296,-296,100,82,10,3168,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3928,3929,3925,3910,3913,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,995,SUCCESS,,3170.839519,192,0,0.1,0.2,0.3,263,1.4,1.5
    2226,5/26/2021 21:41,8921.305,2.48,701,300,10,6001,0,65535,65535,1,22.5,27434,-296,-296,100,82,10,3167,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3928,3928,3924,3910,3913,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,934,SUCCESS,,3170.510301,192,0,0.1,0.2,0.3,263,1.4,1.5
    2227,5/26/2021 21:41,8925.317,2.48,701,300,10,6001,0,65535,65535,1,22.5,27434,-296,-296,100,82,10,3167,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3928,3929,3924,3910,3912,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,1001,SUCCESS,,3170.180426,192,0,0.1,0.2,0.3,263,1.4,1.5
    2228,5/26/2021 21:41,8929.329,2.48,701,300,10,6001,0,65535,65535,1,22.5,27433,-296,-296,100,82,10,3167,3888,638,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3928,3929,3924,3910,3913,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,939,SUCCESS,,3169.85055,192,0,0.1,0.2,0.3,263,1.4,1.5
    2229,5/26/2021 21:41,8933.335,2.48,701,300,10,6001,0,65535,65535,1,22.5,27432,-298,-296,100,82,10,3166,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3910,3913,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,982,SUCCESS,,3169.518943,192,0,0.1,0.2,0.3,263,1.4,1.5
    2230,5/26/2021 21:41,8937.345,2.48,701,300,10,6001,0,65535,65535,1,22.5,27431,-296,-296,100,82,10,3166,3888,646,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3910,3912,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,957,SUCCESS,,3169.189231,192,0,0.1,0.2,0.3,263,1.4,1.5
    2231,5/26/2021 21:41,8941.356,2.48,701,300,10,6001,0,65535,65535,1,22.5,27432,-296,-296,100,82,10,3166,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3910,3912,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,947,SUCCESS,,3168.859438,192,0,0.1,0.2,0.3,263,1.4,1.5
    2232,5/26/2021 21:41,8945.358,2.48,701,300,10,6001,0,65535,65535,1,22.5,27431,-296,-296,100,82,10,3165,3888,642,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3909,3912,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,945,SUCCESS,,3168.530385,192,0,0.1,0.2,0.3,263,1.4,1.5
    2233,5/26/2021 21:41,8949.365,2.49,701,300,10,6001,0,65535,65535,1,22.5,27431,-296,-296,100,82,10,3165,3888,637,642,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3909,3912,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,984,SUCCESS,,3168.20092,192,0,0.1,0.2,0.3,263,1.4,1.5
    2234,5/26/2021 21:42,8953.371,2.49,701,300,10,6001,0,65535,65535,1,22.5,27430,-298,-297,100,82,10,3165,3888,637,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3909,3912,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,946,SUCCESS,,3167.869313,192,0,0.1,0.2,0.3,263,1.4,1.5
    2235,5/26/2021 21:42,8957.378,2.49,701,300,10,6001,0,65535,65535,1,22.5,27429,-296,-296,100,82,10,3164,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3909,3912,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,942,SUCCESS,,3167.539848,192,0,0.1,0.2,0.3,263,1.4,1.5
    2236,5/26/2021 21:42,8961.383,2.49,701,300,10,6001,0,65535,65535,1,22.5,27430,-294,-296,100,82,10,3164,3888,646,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3922,3927,3928,3924,3909,3912,3908,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,948,SUCCESS,,3167.212773,192,0,0.1,0.2,0.3,263,1.4,1.5
    2237,5/26/2021 21:42,8965.39,2.49,701,300,10,6001,0,65535,65535,1,22.5,27429,-296,-296,100,82,10,3164,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3927,3928,3924,3909,3912,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,940,SUCCESS,,3166.883309,192,0,0.1,0.2,0.3,263,1.4,1.5
    2238,5/26/2021 21:42,8969.402,2.49,701,300,10,6001,0,65535,65535,1,22.5,27426,-296,-296,100,82,10,3163,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3927,3927,3923,3909,3912,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,964,SUCCESS,,3166.553433,192,0,0.1,0.2,0.3,263,1.4,1.5
    2239,5/26/2021 21:42,8973.405,2.49,701,300,10,6001,0,65535,65535,1,22.5,27425,-298,-296,100,82,10,3163,3888,637,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3924,3909,3912,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,966,SUCCESS,,3166.222074,192,0,0.1,0.2,0.3,263,1.4,1.5
    2240,5/26/2021 21:42,8977.413,2.49,701,300,10,6001,0,65535,65535,1,22.5,27424,-298,-296,100,82,10,3163,3888,637,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3923,3909,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,988,SUCCESS,,3165.8903,192,0,0.1,0.2,0.3,263,1.4,1.5
    2241,5/26/2021 21:42,8981.426,2.49,701,300,10,6001,0,65535,65535,1,22.5,27424,-296,-296,100,82,10,3162,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3923,3909,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,953,SUCCESS,,3165.560343,192,0,0.1,0.2,0.3,263,1.4,1.5
    2242,5/26/2021 21:42,8985.429,2.5,701,300,10,6001,0,65535,65535,1,22.5,27423,-298,-296,100,82,10,3162,3888,637,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3923,3908,3912,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.2,933,SUCCESS,,3165.228983,192,0,0.1,0.2,0.3,263,1.4,1.5
    2243,5/26/2021 21:42,8989.435,2.5,701,300,10,6001,0,65535,65535,1,22.5,27423,-294,-296,100,82,10,3162,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3923,3908,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,943,SUCCESS,,3164.901826,192,0,0.1,0.2,0.3,263,1.4,1.5
    2244,5/26/2021 21:42,8993.441,2.5,701,300,10,6001,0,65535,65535,1,22.5,27423,-298,-296,100,82,10,3161,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3923,3908,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,936,SUCCESS,,3164.570219,192,0,0.1,0.2,0.3,263,1.4,1.5
    2245,5/26/2021 21:42,8997.452,2.5,701,300,10,6001,0,65535,65535,1,22.5,27423,-296,-296,100,82,10,3161,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3923,3908,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,942,SUCCESS,,3164.240425,192,0,0.1,0.2,0.3,263,1.4,1.5
    2246,5/26/2021 21:42,9001.465,2.5,701,300,10,6001,0,65535,65535,1,22.5,27422,-298,-296,100,82,10,3161,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3922,3908,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,944,SUCCESS,,3163.908238,192,0,0.1,0.2,0.3,263,1.4,1.5
    2247,5/26/2021 21:42,9005.474,2.5,701,300,10,6001,0,65535,65535,1,22.5,27421,-298,-297,100,82,10,3160,3888,636,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3921,3926,3927,3922,3908,3911,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,935,SUCCESS,,3163.576382,192,0,0.1,0.2,0.3,263,1.4,1.5
    2248,5/26/2021 21:42,9009.479,2.5,701,300,10,6001,0,65535,65535,1,22.5,27420,-296,-296,100,82,10,3160,3888,641,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3927,3922,3908,3911,3907,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,976,SUCCESS,,3163.247082,192,0,0.1,0.2,0.3,263,1.4,1.5
    2249,5/26/2021 21:43,9013.484,2.5,701,300,10,6001,0,65535,65535,1,22.5,27420,-296,-296,100,82,10,3160,3888,636,641,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3927,3922,3908,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,954,SUCCESS,,3162.917782,192,0,0.1,0.2,0.3,263,1.4,1.5
    2250,5/26/2021 21:43,9017.488,2.5,701,300,10,6001,0,65535,65535,1,22.5,27419,-298,-296,100,82,10,3159,3888,636,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3927,3922,3908,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,951,SUCCESS,,3162.58634,192,0,0.1,0.2,0.3,263,1.4,1.5
    2251,5/26/2021 21:43,9021.497,2.51,701,300,10,6001,0,65535,65535,1,22.5,27417,-296,-296,100,82,10,3159,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3927,3922,3908,3911,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,947,SUCCESS,,3162.256711,192,0,0.1,0.2,0.3,263,1.4,1.5
    2252,5/26/2021 21:43,9025.502,2.51,701,300,10,6001,0,65535,65535,1,22.5,27418,-296,-296,100,82,10,3159,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3926,3922,3908,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,953,SUCCESS,,3161.927411,192,0,0.1,0.2,0.3,263,1.4,1.5
    2253,5/26/2021 21:43,9029.511,2.51,701,300,10,6001,0,65535,65535,1,22.5,27418,-296,-296,100,82,10,3158,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3926,3922,3907,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,981,SUCCESS,,3161.597782,192,0,0.1,0.2,0.3,263,1.4,1.5
    2254,5/26/2021 21:43,9033.526,2.51,701,300,10,6001,0,65535,65535,1,22.5,27417,-296,-296,100,82,10,3158,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3926,3922,3908,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,952,SUCCESS,,3161.26766,192,0,0.1,0.2,0.3,263,1.4,1.5
    2255,5/26/2021 21:43,9037.541,2.51,701,300,10,6001,0,65535,65535,1,22.5,27417,-298,-296,100,82,10,3158,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3926,3922,3908,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,932,SUCCESS,,3160.935307,192,0,0.1,0.2,0.3,263,1.4,1.5
    2256,5/26/2021 21:43,9041.544,2.51,701,300,10,6001,0,65535,65535,1,22.5,27416,-296,-296,100,82,10,3157,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3926,3922,3907,3910,3906,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22,945,SUCCESS,,3160.606171,192,0,0.1,0.2,0.3,263,1.4,1.5
    2257,5/26/2021 21:43,9045.552,2.51,701,300,10,6001,0,65535,65535,1,22.5,27415,-296,-296,100,82,10,3157,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3920,3925,3926,3922,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,997,SUCCESS,,3160.276625,192,0,0.1,0.2,0.3,263,1.4,1.5
    2258,5/26/2021 21:43,9049.558,2.51,701,300,10,6001,0,65535,65535,1,22.5,27413,-298,-296,100,82,10,3157,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3926,3922,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,1016,SUCCESS,,3159.945017,192,0,0.1,0.2,0.3,263,1.4,1.5
    2259,5/26/2021 21:43,9053.56,2.51,701,300,10,6001,0,65535,65535,1,22.5,27413,-296,-296,100,82,10,3156,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3925,3926,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,943,SUCCESS,,3159.615964,192,0,0.1,0.2,0.3,263,1.4,1.5
    2260,5/26/2021 21:43,9057.565,2.52,701,300,10,6001,0,65535,65535,1,22.5,27412,-296,-296,100,82,10,3156,3888,635,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3926,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,947,SUCCESS,,3159.286664,192,0,0.1,0.2,0.3,263,1.4,1.5
    2261,5/26/2021 21:43,9061.568,2.52,701,300,10,6001,0,65535,65535,1,22.5,27411,-296,-296,100,82,10,3156,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,987,SUCCESS,,3158.957528,192,0,0.1,0.2,0.3,263,1.4,1.5
    2262,5/26/2021 21:43,9065.575,2.52,701,300,10,6001,0,65535,65535,1,22.5,27411,-296,-296,100,82,10,3155,3888,640,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,964,SUCCESS,,3158.628064,192,0,0.1,0.2,0.3,263,1.4,1.5
    2263,5/26/2021 21:43,9069.581,2.52,701,300,10,6001,0,65535,65535,1,22.5,27411,-298,-296,100,82,10,3155,3888,644,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,936,SUCCESS,,3158.296456,192,0,0.1,0.2,0.3,263,1.4,1.5
    2264,5/26/2021 21:44,9073.585,2.52,701,300,10,6001,0,65535,65535,1,22.5,27411,-296,-296,100,82,10,3155,3888,635,640,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,953,SUCCESS,,3157.967238,192,0,0.1,0.2,0.3,263,1.4,1.5
    2265,5/26/2021 21:44,9077.597,2.52,701,300,10,6001,0,65535,65535,1,22.5,27410,-296,-296,100,82,10,3154,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,984,SUCCESS,,3157.637363,192,0,0.1,0.2,0.3,263,1.4,1.5
    2266,5/26/2021 21:44,9081.604,2.52,701,300,10,6001,0,65535,65535,1,22.5,27412,-300,-297,100,82,10,3154,3888,635,637,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3910,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3157.303446,192,0,0.1,0.2,0.3,263,1.4,1.5
    2267,5/26/2021 21:44,9085.608,2.52,701,300,10,6001,0,65535,65535,1,22.5,27410,-294,-297,100,82,10,3154,3888,639,637,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3907,3909,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,978,SUCCESS,,3156.976453,192,0,0.1,0.2,0.3,263,1.4,1.5
    2268,5/26/2021 21:44,9089.623,2.52,701,300,10,6001,0,65535,65535,1,22.5,27409,-296,-296,100,82,10,3153,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3906,3909,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,958,SUCCESS,,3156.64633,192,0,0.1,0.2,0.3,263,1.4,1.5
    2269,5/26/2021 21:44,9093.631,2.53,701,300,10,6001,0,65535,65535,1,22.5,27409,-296,-296,100,82,10,3153,3888,635,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3906,3909,3905,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,956,SUCCESS,,3156.316784,192,0,0.1,0.2,0.3,263,1.4,1.5
    2270,5/26/2021 21:44,9097.632,2.53,701,300,10,6001,0,65535,65535,1,22.5,27408,-296,-296,100,82,10,3153,3888,643,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3919,3924,3925,3921,3906,3909,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,21.9,937,SUCCESS,,3155.987813,192,0,0.1,0.2,0.3,263,1.4,1.5
    2271,5/26/2021 21:44,9101.637,2.53,701,300,10,6001,0,65535,65535,1,22.5,27408,-298,-296,100,82,10,3152,3888,635,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3924,3925,3921,3906,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,940,SUCCESS,,3155.656288,192,0,0.1,0.2,0.3,263,1.4,1.5
    2272,5/26/2021 21:44,9105.64,2.53,701,300,10,6001,0,65535,65535,1,22.5,27405,-296,-296,100,82,10,3152,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3906,3909,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,969,SUCCESS,,3155.327152,192,0,0.1,0.2,0.3,263,1.4,1.5
    2273,5/26/2021 21:44,9109.642,2.53,701,300,10,6001,0,65535,65535,1,22.5,27403,-294,-296,100,82,10,3152,3888,643,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3906,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,941,SUCCESS,,3155.000322,192,0,0.1,0.2,0.3,263,1.4,1.5
    2274,5/26/2021 21:44,9113.65,2.53,701,300,10,6001,0,65535,65535,1,22.5,27403,-298,-296,100,82,10,3151,3888,634,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3906,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,933,SUCCESS,,3154.668549,192,0,0.1,0.2,0.3,263,1.4,1.5
    2275,5/26/2021 21:44,9117.662,2.53,701,300,10,6001,0,65535,65535,1,22.5,27403,-294,-296,100,82,10,3151,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3906,3909,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,962,SUCCESS,,3154.340902,192,0,0.1,0.2,0.3,263,1.4,1.5
    2276,5/26/2021 21:44,9121.673,2.53,701,300,10,6001,0,65535,65535,1,22.5,27403,-296,-296,100,82,10,3151,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3906,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,941,SUCCESS,,3154.011109,192,0,0.1,0.2,0.3,263,1.4,1.5
    2277,5/26/2021 21:44,9125.676,2.53,701,300,10,6001,0,65535,65535,1,22.5,27402,-294,-296,100,82,10,3150,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3905,3907,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,953,SUCCESS,,3153.684197,192,0,0.1,0.2,0.3,263,1.4,1.5
    2278,5/26/2021 21:44,9129.677,2.54,701,300,10,6001,0,65535,65535,1,22.5,27402,-296,-296,100,82,10,3150,3888,639,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3920,3905,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,968,SUCCESS,,3153.355226,192,0,0.1,0.2,0.3,263,1.4,1.5
    2279,5/26/2021 21:45,9133.683,2.54,701,300,10,6001,0,65535,65535,1,22.5,27402,-298,-296,100,82,10,3150,3888,630,639,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3919,3905,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,952,SUCCESS,,3153.023618,192,0,0.1,0.2,0.3,263,1.4,1.5
    2280,5/26/2021 21:45,9137.696,2.54,701,300,10,6001,0,65535,65535,1,22.5,27402,-296,-296,100,81,10,3149,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3922,3924,3919,3905,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.5,950,SUCCESS,,3152.69366,192,0,0.1,0.2,0.3,263,1.4,1.5
    2281,5/26/2021 21:45,9141.7,2.54,701,300,10,6001,0,65535,65535,1,22.5,27399,-296,-296,100,81,10,3149,3888,634,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3922,3924,3920,3905,3909,3903,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,963,SUCCESS,,3152.364443,192,0,0.1,0.2,0.3,263,1.4,1.5
    2282,5/26/2021 21:45,9145.706,2.54,701,300,10,6001,0,65535,65535,1,22.5,27401,-298,-296,100,81,10,3149,3888,634,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3922,3924,3919,3905,3908,3904,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,945,SUCCESS,,3152.032835,192,0,0.1,0.2,0.3,263,1.4,1.5
    2283,5/26/2021 21:45,9149.721,2.54,701,300,10,6001,0,65535,65535,1,22.5,27399,-296,-296,100,81,10,3148,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3918,3923,3924,3919,3905,3906,3903,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,947,SUCCESS,,3151.702713,192,0,0.1,0.2,0.3,263,1.4,1.5
    2284,5/26/2021 21:45,9153.734,2.54,701,300,10,6001,0,65535,65535,1,22.5,27398,-298,-296,100,81,10,3148,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3924,3919,3905,3908,3903,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,949,SUCCESS,,3151.370525,192,0,0.1,0.2,0.3,263,1.4,1.5
    2285,5/26/2021 21:45,9157.748,2.54,701,300,10,6001,0,65535,65535,1,22.5,27397,-296,-296,100,81,10,3148,3888,642,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3923,3919,3905,3907,3903,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,943,SUCCESS,,3151.040485,192,0,0.1,0.2,0.3,263,1.4,1.5
    2286,5/26/2021 21:45,9161.756,2.54,701,300,10,6001,0,65535,65535,1,22.5,27397,-294,-296,100,81,10,3147,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3923,3919,3905,3907,3903,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,951,SUCCESS,,3150.713165,192,0,0.1,0.2,0.3,263,1.4,1.5
    2287,5/26/2021 21:45,9165.765,2.55,701,300,10,6001,0,65535,65535,1,22.5,27397,-298,-296,100,81,10,3147,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3923,3919,3905,3907,3903,0,0,0,0,0,0,0,0,2739,22.3,22.5,-273.2,22.5,-273.2,22.4,964,SUCCESS,,3150.381309,192,0,0.1,0.2,0.3,263,1.4,1.5
    2288,5/26/2021 21:45,9169.779,2.55,701,300,10,6001,0,65535,65535,1,22.5,27396,-296,-297,100,81,10,3147,3888,638,636,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3923,3919,3905,3907,3903,0,0,0,0,0,0,0,0,2736,22.3,22.5,-273.2,22.5,-273.2,22.4,943,SUCCESS,,3150.051269,192,0,0.1,0.2,0.3,263,1.4,1.5
    2289,5/26/2021 21:45,9173.783,2.55,701,300,10,6001,0,65535,65535,1,22.5,27395,-296,-296,100,81,10,3146,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3923,3919,3904,3903,3903,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,938,SUCCESS,,3149.722051,192,0,0.1,0.2,0.3,263,1.4,1.5
    2290,5/26/2021 21:45,9177.794,2.55,701,300,10,6001,0,65535,65535,1,22.5,27395,-298,-296,100,81,10,3146,3888,633,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3917,3922,3923,3919,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,942,SUCCESS,,3149.39003,192,0,0.1,0.2,0.3,263,1.4,1.5
    2291,5/26/2021 21:45,9181.807,2.55,701,300,10,6001,0,65535,65535,1,22.5,27394,-296,-296,100,81,10,3146,3888,642,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3922,3923,3919,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,971,SUCCESS,,3149.060072,192,0,0.1,0.2,0.3,263,1.4,1.5
    2292,5/26/2021 21:45,9185.815,2.55,701,300,10,6001,0,65535,65535,1,22.5,27393,-298,-296,100,81,10,3145,3888,629,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3922,3923,3919,3905,3908,3902,0,0,0,0,0,0,0,0,2736,22.3,22.5,-273.2,22.5,-273.2,22.4,957,SUCCESS,,3148.728299,192,0,0.1,0.2,0.3,263,1.4,1.5
    2293,5/26/2021 21:45,9189.827,2.55,701,300,10,6001,0,65535,65535,1,22.5,27392,-298,-296,100,81,10,3145,3888,638,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3922,3923,3919,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,959,SUCCESS,,3148.396194,192,0,0.1,0.2,0.3,263,1.4,1.5
    2294,5/26/2021 21:46,9193.84,2.55,701,300,10,6001,0,65535,65535,1,22.5,27392,-296,-296,100,81,10,3145,3888,642,638,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3922,3922,3918,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,960,SUCCESS,,3148.066236,192,0,0.1,0.2,0.3,263,1.4,1.5
    2295,5/26/2021 21:46,9197.845,2.55,701,300,10,6001,0,65535,65535,1,22.5,27391,-296,-296,100,81,10,3144,3888,637,637,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,947,SUCCESS,,3147.736936,192,0,0.1,0.2,0.3,263,1.4,1.5
    2296,5/26/2021 21:46,9201.846,2.56,701,300,10,6001,0,65535,65535,1,22.5,27390,-296,-297,100,81,10,3144,3888,637,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3906,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,940,SUCCESS,,3147.407965,192,0,0.1,0.2,0.3,263,1.4,1.5
    2297,5/26/2021 21:46,9205.849,2.56,701,300,10,6001,0,65535,65535,1,22.5,27390,-298,-296,100,81,10,3144,3888,642,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,984,SUCCESS,,3147.076606,192,0,0.1,0.2,0.3,263,1.4,1.5
    2298,5/26/2021 21:46,9209.857,2.56,701,300,10,6001,0,65535,65535,1,22.5,27390,-298,-297,100,81,10,3143,3888,633,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3907,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,961,SUCCESS,,3146.744833,192,0,0.1,0.2,0.3,263,1.4,1.5
    2299,5/26/2021 21:46,9213.86,2.56,701,300,10,6001,0,65535,65535,1,22.5,27389,-296,-297,100,81,10,3143,3888,633,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3906,3902,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,996,SUCCESS,,3146.415697,192,0,0.1,0.2,0.3,263,1.4,1.5
    2300,5/26/2021 21:46,9217.874,2.56,701,300,10,6001,0,65535,65535,1,22.5,27389,-298,-297,100,81,10,3143,3888,633,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3903,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,948,SUCCESS,,3146.083427,192,0,0.1,0.2,0.3,263,1.4,1.5
    2301,5/26/2021 21:46,9221.881,2.56,701,300,10,6001,0,65535,65535,1,22.5,27389,-298,-297,100,81,10,3142,3888,633,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,967,SUCCESS,,3145.751736,192,0,0.1,0.2,0.3,263,1.4,1.5
    2302,5/26/2021 21:46,9225.895,2.56,701,300,10,6001,0,65535,65535,1,22.5,27388,-296,-297,100,81,10,3142,3888,637,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3904,3905,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,953,SUCCESS,,3145.421696,192,0,0.1,0.2,0.3,263,1.4,1.5
    2303,5/26/2021 21:46,9229.906,2.56,701,300,10,6001,0,65535,65535,1,22.5,27388,-298,-297,100,81,10,3142,3888,633,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3921,3922,3918,3903,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,946,SUCCESS,,3145.089675,192,0,0.1,0.2,0.3,263,1.4,1.5
    2304,5/26/2021 21:46,9233.913,2.56,701,300,10,6001,0,65535,65535,1,22.5,27387,-298,-297,100,81,10,3141,3888,632,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3916,3920,3922,3917,3903,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,956,SUCCESS,,3144.757984,192,0,0.1,0.2,0.3,263,1.4,1.5
    2305,5/26/2021 21:46,9237.919,2.57,701,300,10,6001,0,65535,65535,1,22.5,27385,-296,-296,100,81,10,3141,3888,637,637,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3922,3918,3903,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,943,SUCCESS,,3144.428602,192,0,0.1,0.2,0.3,263,1.4,1.5
    2306,5/26/2021 21:46,9241.934,2.57,701,300,10,6001,0,65535,65535,1,22.5,27386,-298,-297,100,81,10,3141,3888,632,635,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3903,3905,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,944,SUCCESS,,3144.096249,192,0,0.1,0.2,0.3,263,1.4,1.5
    2307,5/26/2021 21:46,9245.942,2.57,701,300,10,6001,0,65535,65535,1,22.5,27383,-298,-297,100,81,10,3140,3888,632,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3903,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22,950,SUCCESS,,3143.764476,192,0,0.1,0.2,0.3,263,1.4,1.5
    2308,5/26/2021 21:46,9249.957,2.57,701,300,10,6001,0,65535,65535,1,22.5,27383,-298,-297,100,81,10,3140,3888,632,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3903,3906,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,953,SUCCESS,,3143.432123,192,0,0.1,0.2,0.3,263,1.4,1.5
    2309,5/26/2021 21:47,9253.962,2.57,701,300,10,6001,0,65535,65535,1,22.5,27381,-300,-297,100,81,10,3140,3888,632,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3903,3905,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3143.098373,192,0,0.1,0.2,0.3,263,1.4,1.5
    2310,5/26/2021 21:47,9257.977,2.57,701,300,10,6001,0,65535,65535,1,22.5,27380,-296,-297,100,81,10,3139,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3903,3905,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,970,SUCCESS,,3142.768251,192,0,0.1,0.2,0.3,263,1.4,1.5
    2311,5/26/2021 21:47,9261.987,2.57,701,300,10,6001,0,65535,65535,1,22.5,27380,-296,-297,100,81,10,3139,3888,632,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3903,3905,3901,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,953,SUCCESS,,3142.43854,192,0,0.1,0.2,0.3,263,1.4,1.5
    2312,5/26/2021 21:47,9265.99,2.57,701,300,10,6001,0,65535,65535,1,22.5,27379,-296,-297,100,81,10,3139,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3921,3917,3902,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,952,SUCCESS,,3142.109404,192,0,0.1,0.2,0.3,263,1.4,1.5
    2313,5/26/2021 21:47,9269.999,2.57,701,300,10,6001,0,65535,65535,1,22.5,27379,-296,-297,100,81,10,3138,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3915,3920,3921,3917,3902,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,943,SUCCESS,,3141.779775,192,0,0.1,0.2,0.3,263,1.4,1.5
    2314,5/26/2021 21:47,9274.01,2.58,701,300,10,6001,0,65535,65535,1,22.5,27377,-298,-297,100,81,10,3138,3888,632,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3921,3916,3902,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,932,SUCCESS,,3141.447754,192,0,0.1,0.2,0.3,263,1.4,1.5
    2315,5/26/2021 21:47,9278.02,2.58,701,300,10,6001,0,65535,65535,1,22.5,27377,-298,-297,100,81,10,3138,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3921,3916,3902,3904,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,960,SUCCESS,,3141.115815,192,0,0.1,0.2,0.3,263,1.4,1.5
    2316,5/26/2021 21:47,9282.027,2.58,701,300,10,6001,0,65535,65535,1,22.5,27377,-298,-297,100,81,10,3137,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3921,3916,3902,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,946,SUCCESS,,3140.784124,192,0,0.1,0.2,0.3,263,1.4,1.5
    2317,5/26/2021 21:47,9286.032,2.58,701,300,10,6001,0,65535,65535,1,22.5,27377,-298,-297,100,81,10,3137,3888,632,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3902,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,941,SUCCESS,,3140.452599,192,0,0.1,0.2,0.3,263,1.4,1.5
    2318,5/26/2021 21:47,9290.038,2.58,701,300,10,6001,0,65535,65535,1,22.5,27376,-296,-297,100,81,10,3137,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3921,3916,3902,3904,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,935,SUCCESS,,3140.123217,192,0,0.1,0.2,0.3,263,1.4,1.5
    2319,5/26/2021 21:47,9294.052,2.58,701,300,10,6001,0,65535,65535,1,22.4,27376,-298,-297,100,81,10,3136,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3902,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.3,1003,SUCCESS,,3139.790947,192,0,0.1,0.2,0.3,263,1.4,1.5
    2320,5/26/2021 21:47,9298.054,2.58,701,300,10,6001,0,65535,65535,1,22.5,27375,-296,-297,100,81,10,3136,3888,631,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3902,3904,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,996,SUCCESS,,3139.461894,192,0,0.1,0.2,0.3,263,1.4,1.5
    2321,5/26/2021 21:47,9302.069,2.58,701,300,10,6001,0,65535,65535,1,22.5,27373,-294,-297,100,81,10,3136,3888,636,634,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3901,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,966,SUCCESS,,3139.134002,192,0,0.1,0.2,0.3,263,1.4,1.5
    2322,5/26/2021 21:47,9306.08,2.59,701,300,10,6001,0,65535,65535,1,22.5,27374,-298,-297,100,81,10,3135,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3902,3904,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,972,SUCCESS,,3138.80198,192,0,0.1,0.2,0.3,263,1.4,1.5
    2323,5/26/2021 21:47,9310.084,2.59,701,300,10,6001,0,65535,65535,1,22.4,27375,-296,-297,100,81,10,3135,3888,640,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3901,3904,3900,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,934,SUCCESS,,3138.472763,192,0,0.1,0.2,0.3,263,1.4,1.5
    2324,5/26/2021 21:48,9314.094,2.59,701,300,10,6001,0,65535,65535,1,22.5,27373,-298,-297,100,81,10,3135,3888,631,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3901,3905,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,949,SUCCESS,,3138.140824,192,0,0.1,0.2,0.3,263,1.4,1.5
    2325,5/26/2021 21:48,9318.109,2.59,701,300,10,6001,0,65535,65535,1,22.5,27374,-298,-297,100,81,10,3134,3888,631,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3901,3904,3900,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,959,SUCCESS,,3137.808471,192,0,0.1,0.2,0.3,263,1.4,1.5
    2326,5/26/2021 21:48,9322.118,2.59,701,300,10,6001,0,65535,65535,1,22.4,27373,-296,-297,100,81,10,3134,3888,631,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3901,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,954,SUCCESS,,3137.478842,192,0,0.1,0.2,0.3,263,1.4,1.5
    2327,5/26/2021 21:48,9326.123,2.59,701,300,10,6001,0,65535,65535,1,22.5,27373,-296,-297,100,81,10,3134,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3914,3919,3920,3916,3901,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,978,SUCCESS,,3137.149542,192,0,0.1,0.2,0.3,263,1.4,1.5
    2328,5/26/2021 21:48,9330.131,2.59,701,300,10,6001,0,65535,65535,1,22.5,27370,-296,-297,100,81,10,3133,3888,631,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3920,3916,3901,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,935,SUCCESS,,3136.819995,192,0,0.1,0.2,0.3,263,1.4,1.5
    2329,5/26/2021 21:48,9334.142,2.59,701,300,10,6001,0,65535,65535,1,22.5,27369,-296,-297,100,81,10,3133,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3901,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,977,SUCCESS,,3136.490202,192,0,0.1,0.2,0.3,263,1.4,1.5
    2330,5/26/2021 21:48,9338.153,2.59,701,300,10,6001,0,65535,65535,1,22.5,27368,-298,-297,100,81,10,3133,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3900,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,21.9,945,SUCCESS,,3136.15818,192,0,0.1,0.2,0.3,263,1.4,1.5
    2331,5/26/2021 21:48,9342.164,2.6,701,300,10,6001,0,65535,65535,1,22.4,27369,-298,-297,100,81,10,3132,3888,631,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3900,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,973,SUCCESS,,3135.826159,192,0,0.1,0.2,0.3,263,1.4,1.5
    2332,5/26/2021 21:48,9346.164,2.6,701,300,10,6001,0,65535,65535,1,22.4,27369,-298,-297,100,81,10,3132,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3901,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,939,SUCCESS,,3135.495048,192,0,0.1,0.2,0.3,263,1.4,1.5
    2333,5/26/2021 21:48,9350.171,2.6,701,300,10,6001,0,65535,65535,1,22.4,27365,-298,-297,100,81,10,3132,3888,626,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3900,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,957,SUCCESS,,3135.163357,192,0,0.1,0.2,0.3,263,1.4,1.5
    2334,5/26/2021 21:48,9354.171,2.6,701,300,10,6001,0,65535,65535,1,22.4,27366,-296,-297,100,81,10,3131,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3900,3903,3899,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3134.834468,192,0,0.1,0.2,0.3,263,1.4,1.5
    2335,5/26/2021 21:48,9358.181,2.6,701,300,10,6001,0,65535,65535,1,22.5,27367,-298,-297,100,81,10,3131,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3915,3900,3904,3899,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,987,SUCCESS,,3134.502529,192,0,0.1,0.2,0.3,263,1.4,1.5
    2336,5/26/2021 21:48,9362.188,2.6,701,300,10,6001,0,65535,65535,1,22.5,27366,-296,-297,100,81,10,3131,3888,635,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3914,3900,3903,3898,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,980,SUCCESS,,3134.173065,192,0,0.1,0.2,0.3,263,1.4,1.5
    2337,5/26/2021 21:48,9366.191,2.6,701,300,10,6001,0,65535,65535,1,22.5,27365,-296,-297,100,81,10,3130,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3913,3918,3919,3914,3900,3902,3898,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,968,SUCCESS,,3133.843929,192,0,0.1,0.2,0.3,263,1.4,1.5
    2338,5/26/2021 21:48,9370.197,2.6,701,300,10,6001,0,65535,65535,1,22.5,27364,-298,-297,100,81,10,3130,3888,630,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3919,3914,3900,3903,3898,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,947,SUCCESS,,3133.512321,192,0,0.1,0.2,0.3,263,1.4,1.5
    2339,5/26/2021 21:49,9374.201,2.6,701,300,10,6001,0,65535,65535,1,22.4,27364,-298,-297,100,81,10,3130,3888,630,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3919,3914,3900,3903,3898,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,966,SUCCESS,,3133.180879,192,0,0.1,0.2,0.3,263,1.4,1.5
    2340,5/26/2021 21:49,9378.21,2.61,701,300,10,6001,0,65535,65535,1,22.4,27364,-296,-297,100,81,10,3129,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3918,3919,3914,3900,3902,3898,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.5,935,SUCCESS,,3132.85125,192,0,0.1,0.2,0.3,263,1.4,1.5
    2341,5/26/2021 21:49,9382.217,2.61,701,300,10,6001,0,65535,65535,1,22.5,27362,-298,-297,100,81,10,3129,3888,630,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3918,3914,3900,3903,3898,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,943,SUCCESS,,3132.51956,192,0,0.1,0.2,0.3,263,1.4,1.5
    2342,5/26/2021 21:49,9386.227,2.61,701,300,10,6001,0,65535,65535,1,22.4,27363,-296,-297,100,81,10,3129,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3918,3914,3900,3903,3898,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,942,SUCCESS,,3132.189849,192,0,0.1,0.2,0.3,263,1.4,1.5
    2343,5/26/2021 21:49,9390.236,2.61,701,300,10,6001,0,65535,65535,1,22.4,27361,-300,-297,100,81,10,3128,3888,626,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3918,3914,3900,3902,3898,0,0,0,0,0,0,0,0,2735,22.3,22.5,-273.2,22.5,-273.2,22.4,956,SUCCESS,,3131.855765,192,0,0.1,0.2,0.3,263,1.4,1.5
    2344,5/26/2021 21:49,9394.249,2.61,701,300,10,6001,0,65535,65535,1,22.5,27361,-296,-297,100,81,10,3128,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3918,3914,3899,3902,3898,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,21.8,945,SUCCESS,,3131.525808,192,0,0.1,0.2,0.3,263,1.4,1.5
    2345,5/26/2021 21:49,9398.255,2.61,701,300,10,6001,0,65535,65535,1,22.4,27359,-296,-297,100,81,10,3128,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3918,3914,3899,3902,3898,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,990,SUCCESS,,3131.196425,192,0,0.1,0.2,0.3,263,1.4,1.5
    2346,5/26/2021 21:49,9402.259,2.61,701,300,10,6001,0,65535,65535,1,22.4,27358,-298,-297,100,81,10,3127,3888,630,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3917,3918,3914,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,994,SUCCESS,,3130.864983,192,0,0.1,0.2,0.3,263,1.4,1.5
    2347,5/26/2021 21:49,9406.261,2.61,701,300,10,6001,0,65535,65535,1,22.4,27359,-296,-297,100,81,10,3127,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3917,3918,3914,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,956,SUCCESS,,3130.53593,192,0,0.1,0.2,0.3,263,1.4,1.5
    2348,5/26/2021 21:49,9410.263,2.61,701,300,10,6001,0,65535,65535,1,22.4,27359,-296,-297,100,81,10,3127,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3912,3916,3918,3914,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,959,SUCCESS,,3130.206876,192,0,0.1,0.2,0.3,263,1.4,1.5
    2349,5/26/2021 21:49,9414.263,2.62,701,300,10,6001,0,65535,65535,1,22.4,27356,-298,-297,100,81,10,3126,3888,634,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3918,3914,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3129.875765,192,0,0.1,0.2,0.3,263,1.4,1.5
    2350,5/26/2021 21:49,9418.264,2.62,701,300,10,6001,0,65535,65535,1,22.4,27356,-294,-297,100,81,10,3126,3888,638,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3918,3914,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,942,SUCCESS,,3129.549017,192,0,0.1,0.2,0.3,263,1.4,1.5
    2351,5/26/2021 21:49,9422.267,2.62,701,300,10,6001,0,65535,65535,1,22.4,27356,-298,-297,100,81,10,3126,3888,629,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3918,3913,3899,3903,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.3,947,SUCCESS,,3129.217658,192,0,0.1,0.2,0.3,263,1.4,1.5
    2352,5/26/2021 21:49,9426.27,2.62,701,300,10,6001,0,65535,65535,1,22.4,27356,-298,-297,100,81,10,3125,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3918,3913,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,968,SUCCESS,,3128.886298,192,0,0.1,0.2,0.3,263,1.4,1.5
    2353,5/26/2021 21:49,9430.273,2.62,701,300,10,6001,0,65535,65535,1,22.4,27356,-294,-297,100,81,10,3125,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,989,SUCCESS,,3128.559386,192,0,0.1,0.2,0.3,263,1.4,1.5
    2354,5/26/2021 21:50,9434.277,2.62,701,300,10,6001,0,65535,65535,1,22.4,27355,-298,-297,100,81,10,3125,3888,629,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3899,3903,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,948,SUCCESS,,3128.227944,192,0,0.1,0.2,0.3,263,1.4,1.5
    2355,5/26/2021 21:50,9438.284,2.62,701,300,10,6001,0,65535,65535,1,22.4,27354,-296,-297,100,81,10,3124,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3899,3902,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,955,SUCCESS,,3127.89848,192,0,0.1,0.2,0.3,263,1.4,1.5
    2356,5/26/2021 21:50,9442.287,2.62,701,300,10,6001,0,65535,65535,1,22.4,27354,-294,-296,100,81,10,3124,3888,638,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3898,3901,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,936,SUCCESS,,3127.571568,192,0,0.1,0.2,0.3,263,1.4,1.5
    2357,5/26/2021 21:50,9446.295,2.62,701,300,10,6001,0,65535,65535,1,22.4,27353,-298,-297,100,81,10,3124,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3898,3906,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,950,SUCCESS,,3127.239795,192,0,0.1,0.2,0.3,263,1.4,1.5
    2358,5/26/2021 21:50,9450.297,2.63,701,300,10,6001,0,65535,65535,1,22.4,27352,-296,-297,100,81,10,3123,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3898,3901,3897,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,942,SUCCESS,,3126.910741,192,0,0.1,0.2,0.3,263,1.4,1.5
    2359,5/26/2021 21:50,9454.303,2.63,701,300,10,6001,0,65535,65535,1,22.4,27353,-296,-296,100,81,10,3123,3888,629,633,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3916,3917,3913,3898,3900,3896,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.5,983,SUCCESS,,3126.581359,192,0,0.1,0.2,0.3,263,1.4,1.5
    2360,5/26/2021 21:50,9458.305,2.63,701,300,10,6001,0,65535,65535,1,22.4,27351,-298,-297,100,81,10,3123,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3911,3915,3917,3913,3898,3905,3896,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,957,SUCCESS,,3126.250083,192,0,0.1,0.2,0.3,263,1.4,1.5
    2361,5/26/2021 21:50,9462.317,2.63,701,300,10,6001,0,65535,65535,1,22.4,27349,-294,-297,100,81,10,3122,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3917,3913,3898,3901,3896,0,0,0,0,0,0,0,0,2735,22.3,22.4,-273.2,22.4,-273.2,22.4,960,SUCCESS,,3125.922436,192,0,0.1,0.2,0.3,263,1.4,1.5
    2362,5/26/2021 21:50,9466.324,2.63,701,300,10,6001,0,65535,65535,1,22.4,27348,-296,-297,100,81,10,3122,3888,629,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3912,3898,3901,3896,0,0,0,0,0,0,0,0,2734,22.3,22.4,-273.2,22.4,-273.2,22.4,946,SUCCESS,,3125.592971,192,0,0.1,0.2,0.3,263,1.4,1.5
    2363,5/26/2021 21:50,9470.329,2.63,701,300,10,6001,0,65535,65535,1,22.4,27348,-298,-297,100,81,10,3122,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3913,3898,3904,3896,0,0,0,0,0,0,0,0,2734,22.3,22.4,-273.2,22.4,-273.2,22.4,978,SUCCESS,,3125.261446,192,0,0.1,0.2,0.3,263,1.4,1.5
    2364,5/26/2021 21:50,9474.336,2.63,701,300,10,6001,0,65535,65535,1,22.4,27348,-296,-297,100,81,10,3121,3888,628,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3912,3898,3900,3896,0,0,0,0,0,0,0,0,2731,22.3,22.4,-273.2,22.4,-273.2,22.4,974,SUCCESS,,3124.931982,192,0,0.1,0.2,0.3,263,1.4,1.5
    2365,5/26/2021 21:50,9478.34,2.63,701,300,10,6001,0,65535,65535,1,22.4,27347,-298,-297,100,81,10,3121,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3912,3898,3900,3896,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,961,SUCCESS,,3124.60054,192,0,0.1,0.2,0.3,263,1.4,1.5
    2366,5/26/2021 21:50,9482.344,2.63,701,300,10,6001,0,65535,65535,1,22.4,27348,-296,-297,100,81,10,3121,3888,633,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3912,3898,3901,3896,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,946,SUCCESS,,3124.271322,192,0,0.1,0.2,0.3,263,1.4,1.5
    2367,5/26/2021 21:50,9486.36,2.64,701,300,10,6001,0,65535,65535,1,22.4,27348,-298,-297,100,81,10,3120,3888,632,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3912,3898,3900,3895,0,0,0,0,0,0,0,0,2734,22.3,22.4,-273.2,22.4,-273.2,22.4,941,SUCCESS,,3123.938886,192,0,0.1,0.2,0.3,263,1.4,1.5
    2368,5/26/2021 21:50,9490.363,2.64,701,300,10,6001,0,65535,65535,1,22.4,27347,-296,-297,100,81,10,3120,3888,632,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3915,3916,3912,3897,3900,3896,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,950,SUCCESS,,3123.609751,192,0,0.1,0.2,0.3,263,1.4,1.5
    2369,5/26/2021 21:51,9494.375,2.64,701,300,10,6001,0,65535,65535,1,22.4,27345,-294,-297,100,81,10,3120,3888,632,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3914,3916,3912,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,955,SUCCESS,,3123.282104,192,0,0.1,0.2,0.3,263,1.4,1.5
    2370,5/26/2021 21:51,9498.378,2.64,701,300,10,6001,0,65535,65535,1,22.4,27344,-298,-296,100,81,10,3119,3888,637,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3914,3916,3912,3897,3900,3896,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,961,SUCCESS,,3122.950745,192,0,0.1,0.2,0.3,263,1.4,1.5
    2371,5/26/2021 21:51,9502.379,2.64,701,300,10,6001,0,65535,65535,1,22.4,27344,-298,-297,100,81,10,3119,3888,632,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3914,3916,3911,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.3,950,SUCCESS,,3122.619551,192,0,0.1,0.2,0.3,263,1.4,1.5
    2372,5/26/2021 21:51,9506.39,2.64,701,300,10,6001,0,65535,65535,1,22.4,27343,-296,-296,100,81,10,3119,3888,632,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3914,3916,3911,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,958,SUCCESS,,3122.289758,192,0,0.1,0.2,0.3,263,1.4,1.5
    2373,5/26/2021 21:51,9510.413,2.64,701,300,10,6001,0,65535,65535,1,22.4,27343,-296,-297,100,81,10,3118,3888,628,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3910,3914,3916,3911,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,939,SUCCESS,,3121.958978,192,0,0.1,0.2,0.3,263,1.4,1.5
    2374,5/26/2021 21:51,9514.428,2.64,701,300,10,6001,0,65535,65535,1,22.4,27342,-296,-296,100,81,10,3118,3888,636,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3899,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,965,SUCCESS,,3121.628855,192,0,0.1,0.2,0.3,263,1.4,1.5
    2375,5/26/2021 21:51,9518.432,2.64,701,300,10,6001,0,65535,65535,1,22.4,27341,-296,-296,100,81,10,3118,3888,628,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,953,SUCCESS,,3121.299638,192,0,0.1,0.2,0.3,263,1.4,1.5
    2376,5/26/2021 21:51,9522.455,2.65,701,300,10,6001,0,65535,65535,1,22.4,27342,-296,-296,100,81,10,3117,3888,632,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,940,SUCCESS,,3120.968858,192,0,0.1,0.2,0.3,263,1.4,1.5
    2377,5/26/2021 21:51,9526.468,2.65,701,300,10,6001,0,65535,65535,1,22.4,27340,-296,-296,100,81,10,3117,3888,632,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3899,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22,945,SUCCESS,,3120.6389,192,0,0.1,0.2,0.3,263,1.4,1.5
    2378,5/26/2021 21:51,9530.484,2.65,701,300,10,6001,0,65535,65535,1,22.4,27340,-296,-296,100,81,10,3117,3888,632,632,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3900,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,946,SUCCESS,,3120.308695,192,0,0.1,0.2,0.3,263,1.4,1.5
    2379,5/26/2021 21:51,9534.515,2.65,701,300,10,6001,0,65535,65535,1,22.4,27339,-296,-297,100,81,10,3116,3888,632,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,1006,SUCCESS,,3119.977258,192,0,0.1,0.2,0.3,263,1.4,1.5
    2380,5/26/2021 21:51,9538.516,2.65,701,300,10,6001,0,65535,65535,1,22.4,27339,-298,-297,100,81,10,3116,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3897,3899,3895,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,973,SUCCESS,,3119.646064,192,0,0.1,0.2,0.3,263,1.4,1.5
    2381,5/26/2021 21:51,9542.547,2.65,701,300,10,6001,0,65535,65535,1,22.4,27338,-298,-297,100,81,10,3116,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3914,3915,3911,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,990,SUCCESS,,3119.312386,192,0,0.1,0.2,0.3,263,1.4,1.5
    2382,5/26/2021 21:51,9546.565,2.65,701,300,10,6001,0,65535,65535,1,22.4,27337,-296,-297,100,81,10,3115,3888,631,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3915,3911,3897,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3118.982018,192,0,0.1,0.2,0.3,263,1.4,1.5
    2383,5/26/2021 21:51,9550.562,2.65,701,300,10,6001,0,65535,65535,1,22.4,27336,-298,-297,100,81,10,3115,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3909,3913,3915,3911,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,964,SUCCESS,,3118.651155,192,0,0.1,0.2,0.3,263,1.4,1.5
    2384,5/26/2021 21:52,9554.495,2.65,701,300,10,6001,0,65535,65535,1,22.4,27335,-298,-297,100,81,10,3115,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3915,3911,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,959,SUCCESS,,3118.32559,192,0,0.1,0.2,0.3,263,1.4,1.5
    2385,5/26/2021 21:52,9558.506,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-294,-297,100,81,10,3114,3888,636,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3117.998025,192,0,0.1,0.2,0.3,263,1.4,1.5
    2386,5/26/2021 21:52,9562.513,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-298,-297,100,81,10,3114,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3117.666334,192,0,0.1,0.2,0.3,263,1.4,1.5
    2387,5/26/2021 21:52,9566.521,2.66,701,300,10,6001,0,65535,65535,1,22.4,27333,-298,-297,100,81,10,3114,3888,631,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,952,SUCCESS,,3117.334561,192,0,0.1,0.2,0.3,263,1.4,1.5
    2388,5/26/2021 21:52,9570.532,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-296,-297,100,81,10,3113,3888,631,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,941,SUCCESS,,3117.004768,192,0,0.1,0.2,0.3,263,1.4,1.5
    2389,5/26/2021 21:52,9574.54,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-296,-297,100,81,10,3113,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,961,SUCCESS,,3116.675221,192,0,0.1,0.2,0.3,263,1.4,1.5
    2390,5/26/2021 21:52,9578.549,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-296,-297,100,81,10,3113,3888,631,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3899,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,953,SUCCESS,,3116.345592,192,0,0.1,0.2,0.3,263,1.4,1.5
    2391,5/26/2021 21:52,9582.558,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-296,-296,100,81,10,3112,3888,631,631,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3898,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,977,SUCCESS,,3116.015963,192,0,0.1,0.2,0.3,263,1.4,1.5
    2392,5/26/2021 21:52,9586.567,2.66,701,300,10,6001,0,65535,65535,1,22.4,27334,-300,-297,100,81,10,3112,3888,627,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3913,3910,3895,3899,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.1,950,SUCCESS,,3115.68188,192,0,0.1,0.2,0.3,263,1.4,1.5
    2393,5/26/2021 21:52,9590.571,2.66,701,300,10,6001,0,65535,65535,1,22.4,27332,-296,-297,100,81,10,3112,3888,631,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3913,3914,3910,3896,3898,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,1000,SUCCESS,,3115.352662,192,0,0.1,0.2,0.3,263,1.4,1.5
    2394,5/26/2021 21:52,9594.584,2.67,701,300,10,6001,0,65535,65535,1,22.4,27330,-296,-297,100,81,10,3111,3888,626,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3914,3910,3895,3898,3894,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,947,SUCCESS,,3115.022704,192,0,0.1,0.2,0.3,263,1.4,1.5
    2395,5/26/2021 21:52,9598.586,2.67,701,300,10,6001,0,65535,65535,1,22.4,27331,-298,-297,100,81,10,3111,3888,626,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3908,3912,3914,3909,3895,3899,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,953,SUCCESS,,3114.691428,192,0,0.1,0.2,0.3,263,1.4,1.5
    2396,5/26/2021 21:52,9602.598,2.67,701,300,10,6001,0,65535,65535,1,22.4,27327,-296,-297,100,81,10,3111,3888,626,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3913,3909,3895,3898,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,21.8,947,SUCCESS,,3114.361552,192,0,0.1,0.2,0.3,263,1.4,1.5
    2397,5/26/2021 21:52,9606.6,2.67,701,300,10,6001,0,65535,65535,1,22.4,27327,-296,-297,100,81,10,3111,3888,626,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3913,3909,3895,3898,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,987,SUCCESS,,3114.032499,192,0,0.1,0.2,0.3,263,1.4,1.5
    2398,5/26/2021 21:52,9610.611,2.67,701,300,10,6001,0,65535,65535,1,22.4,27326,-294,-297,100,80,10,3110,3888,630,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3913,3909,3895,3898,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.3,973,SUCCESS,,3113.704934,192,0,0.1,0.2,0.3,263,1.4,1.5
    2399,5/26/2021 21:53,9614.625,2.67,701,300,10,6001,0,65535,65535,1,22.4,27327,-298,-297,100,80,10,3110,3888,630,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3913,3909,3895,3897,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.3,945,SUCCESS,,3113.372664,192,0,0.1,0.2,0.3,263,1.4,1.5
    2400,5/26/2021 21:53,9618.629,2.67,701,300,10,6001,0,65535,65535,1,22.4,27326,-298,-297,100,80,10,3110,3888,622,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3913,3909,3895,3897,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,935,SUCCESS,,3113.041221,192,0,0.1,0.2,0.3,263,1.4,1.5
    2401,5/26/2021 21:53,9622.64,2.67,701,300,10,6001,0,65535,65535,1,22.4,27326,-296,-297,100,80,10,3109,3888,630,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3912,3913,3909,3895,3897,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.5,946,SUCCESS,,3112.711428,192,0,0.1,0.2,0.3,263,1.4,1.5
    2402,5/26/2021 21:53,9626.647,2.67,701,300,10,6001,0,65535,65535,1,22.4,27324,-298,-297,100,80,10,3109,3888,630,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3909,3894,3897,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,964,SUCCESS,,3112.379738,192,0,0.1,0.2,0.3,263,1.4,1.5
    2403,5/26/2021 21:53,9630.649,2.68,701,300,10,6001,0,65535,65535,1,22.4,27325,-298,-297,100,80,10,3109,3888,626,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3909,3895,3897,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,937,SUCCESS,,3112.048461,192,0,0.1,0.2,0.3,263,1.4,1.5
    2404,5/26/2021 21:53,9634.656,2.68,701,300,10,6001,0,65535,65535,1,22.4,27321,-296,-296,100,80,10,3108,3888,630,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3909,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,938,SUCCESS,,3111.718996,192,0,0.1,0.2,0.3,263,1.4,1.5
    2405,5/26/2021 21:53,9638.671,2.68,701,300,10,6001,0,65535,65535,1,22.4,27323,-296,-296,100,80,10,3108,3888,626,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,940,SUCCESS,,3111.388874,192,0,0.1,0.2,0.3,263,1.4,1.5
    2406,5/26/2021 21:53,9642.683,2.68,701,300,10,6001,0,65535,65535,1,22.4,27322,-296,-296,100,80,10,3108,3888,630,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3908,3894,3897,3893,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,945,SUCCESS,,3111.058999,192,0,0.1,0.2,0.3,263,1.4,1.5
    2407,5/26/2021 21:53,9646.688,2.68,701,300,10,6001,0,65535,65535,1,22.4,27322,-294,-296,100,80,10,3107,3888,630,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,956,SUCCESS,,3110.731924,192,0,0.1,0.2,0.3,263,1.4,1.5
    2408,5/26/2021 21:53,9650.698,2.68,701,300,10,6001,0,65535,65535,1,22.4,27321,-296,-296,100,80,10,3107,3888,630,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,944,SUCCESS,,3110.402213,192,0,0.1,0.2,0.3,263,1.4,1.5
    2409,5/26/2021 21:53,9654.711,2.68,701,300,10,6001,0,65535,65535,1,22.4,27320,-296,-296,100,80,10,3107,3888,630,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3907,3911,3913,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,985,SUCCESS,,3110.072255,192,0,0.1,0.2,0.3,263,1.4,1.5
    2410,5/26/2021 21:53,9658.713,2.68,701,300,10,6001,0,65535,65535,1,22.4,27319,-298,-296,100,80,10,3106,3888,625,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,21.8,979,SUCCESS,,3109.740978,192,0,0.1,0.2,0.3,263,1.4,1.5
    2411,5/26/2021 21:53,9662.714,2.68,701,300,10,6001,0,65535,65535,1,22.4,27320,-298,-296,100,80,10,3106,3888,625,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3894,3896,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3109.409784,192,0,0.1,0.2,0.3,263,1.4,1.5
    2412,5/26/2021 21:53,9666.714,2.69,701,300,10,6001,0,65535,65535,1,22.4,27320,-296,-296,100,80,10,3106,3888,630,630,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,964,SUCCESS,,3109.080895,192,0,0.1,0.2,0.3,263,1.4,1.5
    2413,5/26/2021 21:53,9670.721,2.69,701,300,10,6001,0,65535,65535,1,22.4,27320,-296,-296,100,80,10,3105,3888,625,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3894,3897,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,953,SUCCESS,,3108.751431,192,0,0.1,0.2,0.3,263,1.4,1.5
    2414,5/26/2021 21:54,9674.73,2.69,701,300,10,6001,0,65535,65535,1,22.4,27319,-298,-296,100,80,10,3105,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3894,3896,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,978,SUCCESS,,3108.419575,192,0,0.1,0.2,0.3,263,1.4,1.5
    2415,5/26/2021 21:54,9678.745,2.69,701,300,10,6001,0,65535,65535,1,22.4,27317,-296,-296,100,80,10,3104,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3893,3896,3892,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,964,SUCCESS,,3108.089453,192,0,0.1,0.2,0.3,263,1.4,1.5
    2416,5/26/2021 21:54,9682.752,2.69,701,300,10,6001,0,65535,65535,1,22.4,27318,-300,-296,100,80,10,3104,3888,621,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3911,3912,3908,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,965,SUCCESS,,3107.755536,192,0,0.1,0.2,0.3,263,1.4,1.5
    2417,5/26/2021 21:54,9686.76,2.69,701,300,10,6001,0,65535,65535,1,22.4,27314,-296,-296,100,80,10,3104,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3910,3912,3908,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,947,SUCCESS,,3107.425989,192,0,0.1,0.2,0.3,263,1.4,1.5
    2418,5/26/2021 21:54,9690.767,2.69,701,300,10,6001,0,65535,65535,1,22.4,27317,-298,-296,100,80,10,3104,3888,625,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3908,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,944,SUCCESS,,3107.094299,192,0,0.1,0.2,0.3,263,1.4,1.5
    2419,5/26/2021 21:54,9694.779,2.69,701,300,10,6001,0,65535,65535,1,22.4,27314,-296,-297,100,80,10,3103,3888,629,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3906,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,939,SUCCESS,,3106.764423,192,0,0.1,0.2,0.3,263,1.4,1.5
    2420,5/26/2021 21:54,9698.785,2.69,701,300,10,6001,0,65535,65535,1,22.4,27313,-294,-296,100,80,10,3103,3888,633,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,971,SUCCESS,,3106.437266,192,0,0.1,0.2,0.3,263,1.4,1.5
    2421,5/26/2021 21:54,9702.794,2.7,701,300,10,6001,0,65535,65535,1,22.4,27313,-296,-296,100,80,10,3103,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,949,SUCCESS,,3106.107638,192,0,0.1,0.2,0.3,263,1.4,1.5
    2422,5/26/2021 21:54,9706.799,2.7,701,300,10,6001,0,65535,65535,1,22.4,27313,-296,-296,100,80,10,3102,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,958,SUCCESS,,3105.778338,192,0,0.1,0.2,0.3,263,1.4,1.5
    2423,5/26/2021 21:54,9710.808,2.7,701,300,10,6001,0,65535,65535,1,22.4,27312,-296,-296,100,80,10,3102,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,960,SUCCESS,,3105.448709,192,0,0.1,0.2,0.3,263,1.4,1.5
    2424,5/26/2021 21:54,9714.813,2.7,701,300,10,6001,0,65535,65535,1,22.4,27311,-296,-296,100,80,10,3102,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,946,SUCCESS,,3105.119409,192,0,0.1,0.2,0.3,263,1.4,1.5
    2425,5/26/2021 21:54,9718.824,2.7,701,300,10,6001,0,65535,65535,1,22.4,27313,-296,-296,100,80,10,3101,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,966,SUCCESS,,3104.789615,192,0,0.1,0.2,0.3,263,1.4,1.5
    2426,5/26/2021 21:54,9722.827,2.7,701,300,10,6001,0,65535,65535,1,22.4,27312,-296,-296,100,80,10,3101,3888,629,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3896,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,962,SUCCESS,,3104.46048,192,0,0.1,0.2,0.3,263,1.4,1.5
    2427,5/26/2021 21:54,9726.833,2.7,701,300,10,6001,0,65535,65535,1,22.4,27312,-298,-296,100,80,10,3101,3888,624,629,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3895,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,953,SUCCESS,,3104.128872,192,0,0.1,0.2,0.3,263,1.4,1.5
    2428,5/26/2021 21:54,9730.841,2.7,701,300,10,6001,0,65535,65535,1,22.4,27310,-294,-296,100,80,10,3100,3888,628,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3910,3911,3907,3893,3897,3891,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,949,SUCCESS,,3103.801552,192,0,0.1,0.2,0.3,263,1.4,1.5
    2429,5/26/2021 21:55,9734.849,2.7,701,300,10,6001,0,65535,65535,1,22.4,27311,-298,-296,100,80,10,3100,3888,624,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3905,3909,3911,3907,3892,3895,3890,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,21.6,978,SUCCESS,,3103.469779,192,0,0.1,0.2,0.3,263,1.4,1.5
    2430,5/26/2021 21:55,9738.856,2.71,701,300,10,6001,0,65535,65535,1,22.4,27308,-296,-297,100,80,10,3100,3888,624,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3894,3890,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,949,SUCCESS,,3103.140314,192,0,0.1,0.2,0.3,263,1.4,1.5
    2431,5/26/2021 21:55,9742.858,2.71,701,300,10,6001,0,65535,65535,1,22.4,27306,-296,-297,100,80,10,3099,3888,624,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3896,3890,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,945,SUCCESS,,3102.811261,192,0,0.1,0.2,0.3,263,1.4,1.5
    2432,5/26/2021 21:55,9746.868,2.71,701,300,10,6001,0,65535,65535,1,22.3,27307,-296,-297,100,80,10,3099,3888,628,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3895,3890,0,0,0,0,0,0,0,0,2730,22.3,22.3,-273.2,22.3,-273.2,22.4,978,SUCCESS,,3102.48155,192,0,0.1,0.2,0.3,263,1.4,1.5
    2433,5/26/2021 21:55,9750.878,2.71,701,300,10,6001,0,65535,65535,1,22.3,27306,-296,-297,100,80,10,3099,3888,628,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3891,3894,3891,0,0,0,0,0,0,0,0,2730,22.3,22.3,-273.2,22.3,-273.2,22.3,1022,SUCCESS,,3102.151839,192,0,0.1,0.2,0.3,263,1.4,1.5
    2434,5/26/2021 21:55,9754.882,2.71,701,300,10,6001,0,65535,65535,1,22.3,27306,-294,-296,100,80,10,3098,3888,628,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3898,3890,0,0,0,0,0,0,0,0,2730,22.3,22.3,-273.2,22.3,-273.2,22.4,1003,SUCCESS,,3101.824845,192,0,0.1,0.2,0.3,263,1.4,1.5
    2435,5/26/2021 21:55,9758.884,2.71,701,300,10,6001,0,65535,65535,1,22.4,27306,-296,-296,100,80,10,3098,3888,624,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3894,3890,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,962,SUCCESS,,3101.495792,192,0,0.1,0.2,0.3,263,1.4,1.5
    2436,5/26/2021 21:55,9762.885,2.71,701,300,10,6001,0,65535,65535,1,22.4,27305,-296,-296,100,80,10,3098,3888,632,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3894,3890,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,982,SUCCESS,,3101.166821,192,0,0.1,0.2,0.3,263,1.4,1.5
    2437,5/26/2021 21:55,9766.886,2.71,701,300,10,6001,0,65535,65535,1,22.4,27305,-298,-296,100,80,10,3097,3888,628,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3910,3906,3892,3899,3890,0,0,0,0,0,0,0,0,2729,22.3,22.4,-273.2,22.4,-273.2,22.4,946,SUCCESS,,3100.835627,192,0,0.1,0.2,0.3,263,1.4,1.5
    2438,5/26/2021 21:55,9770.897,2.71,701,300,10,6001,0,65535,65535,1,22.4,27305,-296,-297,100,80,10,3097,3888,624,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3909,3910,3906,3892,3894,3890,0,0,0,0,0,0,0,0,2727,22.3,22.4,-273.2,22.4,-273.2,22.4,982,SUCCESS,,3100.505834,192,0,0.1,0.2,0.3,263,1.4,1.5
    2439,5/26/2021 21:55,9774.898,2.72,701,300,10,6001,0,65535,65535,1,22.4,27303,-296,-296,100,80,10,3097,3888,628,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3910,3906,3892,3894,3890,0,0,0,0,0,0,0,0,2730,22.3,22.4,-273.2,22.4,-273.2,22.4,951,SUCCESS,,3100.176863,192,0,0.1,0.2,0.3,263,1.4,1.5
    2440,5/26/2021 21:55,9778.911,2.72,701,300,10,6001,0,65535,65535,1,22.4,27302,-296,-296,100,80,10,3096,3888,628,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3910,3906,3891,3898,3889,0,0,0,0,0,0,0,0,2729,22.3,22.4,-273.2,22.4,-273.2,22.4,966,SUCCESS,,3099.846905,192,0,0.1,0.2,0.3,263,1.4,1.5
    2441,5/26/2021 21:55,9782.92,2.72,701,300,10,6001,0,65535,65535,1,22.4,27301,-294,-296,100,80,10,3096,3888,628,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3910,3905,3891,3894,3889,0,0,0,0,0,0,0,0,2726,22.3,22.4,-273.2,22.4,-273.2,22.4,939,SUCCESS,,3099.519503,192,0,0.1,0.2,0.3,263,1.4,1.5
    2442,5/26/2021 21:55,9786.928,2.72,701,300,10,6001,0,65535,65535,1,22.4,27301,-298,-296,100,80,10,3096,3888,623,628,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3910,3905,3891,3894,3890,0,0,0,0,0,0,0,0,2729,22.3,22.4,-273.2,22.4,-273.2,22.4,948,SUCCESS,,3099.18773,192,0,0.1,0.2,0.3,263,1.4,1.5
    2443,5/26/2021 21:55,9790.943,2.72,701,300,10,6001,0,65535,65535,1,22.3,27301,-298,-297,100,80,10,3095,3888,623,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3910,3905,3891,3894,3890,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,951,SUCCESS,,3098.855377,192,0,0.1,0.2,0.3,263,1.4,1.5
    2444,5/26/2021 21:56,9794.956,2.72,701,300,10,6001,0,65535,65535,1,22.3,27300,-296,-297,100,80,10,3095,3888,627,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3909,3905,3891,3894,3889,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,959,SUCCESS,,3098.525419,192,0,0.1,0.2,0.3,263,1.4,1.5
    2445,5/26/2021 21:56,9798.964,2.72,701,300,10,6001,0,65535,65535,1,22.3,27300,-296,-296,100,80,10,3095,3888,623,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3904,3908,3909,3905,3891,3894,3889,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.5,983,SUCCESS,,3098.195873,192,0,0.1,0.2,0.3,263,1.4,1.5
    2446,5/26/2021 21:56,9802.98,2.72,701,300,10,6001,0,65535,65535,1,22.3,27299,-296,-297,100,80,10,3094,3888,623,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3908,3909,3905,3891,3894,3889,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,945,SUCCESS,,3097.865668,192,0,0.1,0.2,0.3,263,1.4,1.5
    2447,5/26/2021 21:56,9806.987,2.72,701,300,10,6001,0,65535,65535,1,22.4,27299,-296,-296,100,80,10,3094,3888,627,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3908,3909,3905,3891,3894,3888,0,0,0,0,0,0,0,0,2726,22.3,22.4,-273.2,22.4,-273.2,22.3,943,SUCCESS,,3097.536204,192,0,0.1,0.2,0.3,263,1.4,1.5
    2448,5/26/2021 21:56,9810.989,2.73,701,300,10,6001,0,65535,65535,1,22.4,27299,-298,-296,100,80,10,3094,3888,627,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3908,3909,3905,3891,3893,3889,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,989,SUCCESS,,3097.204927,192,0,0.1,0.2,0.3,263,1.4,1.5
    2449,5/26/2021 21:56,9815.006,2.73,701,300,10,6001,0,65535,65535,1,22.3,27299,-296,-297,100,80,10,3093,3888,623,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3908,3909,3905,3891,3894,3889,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,950,SUCCESS,,3096.87464,192,0,0.1,0.2,0.3,263,1.4,1.5
    2450,5/26/2021 21:56,9819.019,2.73,701,300,10,6001,0,65535,65535,1,22.3,27296,-296,-296,100,80,10,3093,3888,631,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3908,3909,3905,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,958,SUCCESS,,3096.544683,192,0,0.1,0.2,0.3,263,1.4,1.5
    2451,5/26/2021 21:56,9823.031,2.73,701,300,10,6001,0,65535,65535,1,22.3,27294,-298,-297,100,80,10,3093,3888,623,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3907,3909,3905,3890,3893,3889,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,942,SUCCESS,,3096.212578,192,0,0.1,0.2,0.3,263,1.4,1.5
    2452,5/26/2021 21:56,9827.036,2.73,701,300,10,6001,0,65535,65535,1,22.3,27296,-296,-296,100,80,10,3092,3888,627,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3907,3909,3905,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,939,SUCCESS,,3095.883278,192,0,0.1,0.2,0.3,263,1.4,1.5
    2453,5/26/2021 21:56,9831.044,2.73,701,300,10,6001,0,65535,65535,1,22.3,27293,-294,-296,100,80,10,3092,3888,631,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3903,3907,3909,3905,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,964,SUCCESS,,3095.555958,192,0,0.1,0.2,0.3,263,1.4,1.5
    2454,5/26/2021 21:56,9835.045,2.73,701,300,10,6001,0,65535,65535,1,22.3,27293,-296,-296,100,80,10,3092,3888,627,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,959,SUCCESS,,3095.226987,192,0,0.1,0.2,0.3,263,1.4,1.5
    2455,5/26/2021 21:56,9839.048,2.73,701,300,10,6001,0,65535,65535,1,22.3,27292,-294,-296,100,80,10,3091,3888,631,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,946,SUCCESS,,3094.900075,192,0,0.1,0.2,0.3,263,1.4,1.5
    2456,5/26/2021 21:56,9843.059,2.73,701,300,10,6001,0,65535,65535,1,22.3,27292,-296,-296,100,80,10,3091,3888,627,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3094.570282,192,0,0.1,0.2,0.3,263,1.4,1.5
    2457,5/26/2021 21:56,9847.071,2.74,701,300,10,6001,0,65535,65535,1,22.3,27292,-296,-296,100,80,10,3091,3888,627,627,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3892,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,936,SUCCESS,,3094.240406,192,0,0.1,0.2,0.3,263,1.4,1.5
    2458,5/26/2021 21:56,9851.079,2.74,701,300,10,6001,0,65535,65535,1,22.3,27292,-298,-296,100,80,10,3090,3888,622,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,940,SUCCESS,,3093.908633,192,0,0.1,0.2,0.3,263,1.4,1.5
    2459,5/26/2021 21:57,9855.092,2.74,701,300,10,6001,0,65535,65535,1,22.3,27292,-298,-296,100,80,10,3090,3888,622,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,961,SUCCESS,,3093.576446,192,0,0.1,0.2,0.3,263,1.4,1.5
    2460,5/26/2021 21:57,9859.103,2.74,701,300,10,6001,0,65535,65535,1,22.3,27292,-296,-296,100,80,10,3090,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3892,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,965,SUCCESS,,3093.246653,192,0,0.1,0.2,0.3,263,1.4,1.5
    2461,5/26/2021 21:57,9863.117,2.74,701,300,10,6001,0,65535,65535,1,22.3,27292,-298,-296,100,80,10,3089,3888,622,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3893,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,932,SUCCESS,,3092.914383,192,0,0.1,0.2,0.3,263,1.4,1.5
    2462,5/26/2021 21:57,9867.125,2.74,701,300,10,6001,0,65535,65535,1,22.3,27292,-298,-297,100,80,10,3089,3888,622,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,21.8,939,SUCCESS,,3092.582609,192,0,0.1,0.2,0.3,263,1.4,1.5
    2463,5/26/2021 21:57,9871.138,2.74,701,300,10,6001,0,65535,65535,1,22.3,27289,-296,-296,100,80,10,3089,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3907,3908,3904,3890,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,950,SUCCESS,,3092.252651,192,0,0.1,0.2,0.3,263,1.4,1.5
    2464,5/26/2021 21:57,9875.144,2.74,701,300,10,6001,0,65535,65535,1,22.3,27289,-298,-296,100,80,10,3088,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3906,3908,3904,3890,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,937,SUCCESS,,3091.921044,192,0,0.1,0.2,0.3,263,1.4,1.5
    2465,5/26/2021 21:57,9879.148,2.74,701,300,10,6001,0,65535,65535,1,22.3,27289,-296,-296,100,80,10,3088,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3906,3908,3904,3889,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,947,SUCCESS,,3091.591826,192,0,0.1,0.2,0.3,263,1.4,1.5
    2466,5/26/2021 21:57,9883.152,2.75,701,300,10,6001,0,65535,65535,1,22.3,27289,-296,-296,100,80,10,3088,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3906,3908,3903,3889,3892,3888,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,961,SUCCESS,,3091.262608,192,0,0.1,0.2,0.3,263,1.4,1.5
    2467,5/26/2021 21:57,9887.165,2.75,701,300,10,6001,0,65535,65535,1,22.3,27286,-296,-296,100,80,10,3087,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3906,3908,3903,3889,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22,983,SUCCESS,,3090.93265,192,0,0.1,0.2,0.3,263,1.4,1.5
    2468,5/26/2021 21:57,9891.168,2.75,701,300,10,6001,0,65535,65535,1,22.3,27285,-296,-296,100,80,10,3087,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3902,3906,3907,3903,3889,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,950,SUCCESS,,3090.603515,192,0,0.1,0.2,0.3,263,1.4,1.5
    2469,5/26/2021 21:57,9895.171,2.75,701,300,10,6001,0,65535,65535,1,22.3,27285,-294,-296,100,80,10,3087,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3906,3907,3903,3889,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,960,SUCCESS,,3090.276603,192,0,0.1,0.2,0.3,263,1.4,1.5
    2470,5/26/2021 21:57,9899.182,2.75,701,300,10,6001,0,65535,65535,1,22.3,27285,-296,-296,100,80,10,3086,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3906,3907,3903,3889,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,949,SUCCESS,,3089.94681,192,0,0.1,0.2,0.3,263,1.4,1.5
    2471,5/26/2021 21:57,9903.192,2.75,701,300,10,6001,0,65535,65535,1,22.3,27285,-294,-296,100,80,10,3086,3888,626,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3906,3907,3903,3888,3891,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,982,SUCCESS,,3089.619326,192,0,0.1,0.2,0.3,263,1.4,1.5
    2472,5/26/2021 21:57,9907.206,2.75,701,300,10,6001,0,65535,65535,1,22.3,27284,-296,-296,100,80,10,3086,3888,630,626,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3905,3907,3903,3888,3891,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,983,SUCCESS,,3089.289286,192,0,0.1,0.2,0.3,263,1.4,1.5
    2473,5/26/2021 21:57,9911.214,2.75,701,300,10,6001,0,65535,65535,1,22.3,27281,-296,-296,100,80,10,3085,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3907,3903,3889,3891,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3088.95974,192,0,0.1,0.2,0.3,263,1.4,1.5
    2474,5/26/2021 21:58,9915.214,2.75,701,300,10,6001,0,65535,65535,1,22.3,27284,-296,-296,100,80,10,3085,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3905,3907,3903,3888,3891,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3088.630851,192,0,0.1,0.2,0.3,263,1.4,1.5
    2475,5/26/2021 21:58,9919.218,2.76,701,300,10,6001,0,65535,65535,1,22.3,27282,-296,-296,100,80,10,3085,3888,621,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3905,3907,3902,3888,3892,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,957,SUCCESS,,3088.301633,192,0,0.1,0.2,0.3,263,1.4,1.5
    2476,5/26/2021 21:58,9923.218,2.76,701,300,10,6001,0,65535,65535,1,22.3,27283,-296,-296,100,80,10,3084,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3901,3905,3907,3903,3888,3891,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,940,SUCCESS,,3087.972744,192,0,0.1,0.2,0.3,263,1.4,1.5
    2477,5/26/2021 21:58,9927.222,2.76,701,300,10,6001,0,65535,65535,1,22.3,27280,-296,-296,100,80,10,3084,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3907,3902,3888,3891,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,966,SUCCESS,,3087.643526,192,0,0.1,0.2,0.3,263,1.4,1.5
    2478,5/26/2021 21:58,9931.227,2.76,701,300,10,6001,0,65535,65535,1,22.3,27278,-296,-296,100,80,10,3084,3888,621,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3906,3902,3888,3891,3887,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,936,SUCCESS,,3087.314226,192,0,0.1,0.2,0.3,263,1.4,1.5
    2479,5/26/2021 21:58,9935.235,2.76,701,300,10,6001,0,65535,65535,1,22.3,27280,-296,-296,100,80,10,3083,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3907,3902,3888,3891,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,940,SUCCESS,,3086.98468,192,0,0.1,0.2,0.3,263,1.4,1.5
    2480,5/26/2021 21:58,9939.239,2.76,701,300,10,6001,0,65535,65535,1,22.3,27279,-298,-296,100,80,10,3083,3888,621,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3907,3902,3888,3891,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,970,SUCCESS,,3086.653238,192,0,0.1,0.2,0.3,263,1.4,1.5
    2481,5/26/2021 21:58,9943.249,2.76,701,300,10,6001,0,65535,65535,1,22.3,27277,-296,-296,100,80,10,3083,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3906,3902,3888,3891,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22,951,SUCCESS,,3086.323526,192,0,0.1,0.2,0.3,263,1.4,1.5
    2482,5/26/2021 21:58,9947.256,2.76,701,300,10,6001,0,65535,65535,1,22.3,27278,-294,-296,100,80,10,3082,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3906,3902,3888,3890,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,934,SUCCESS,,3085.996288,192,0,0.1,0.2,0.3,263,1.4,1.5
    2483,5/26/2021 21:58,9951.27,2.76,701,300,10,6001,0,65535,65535,1,22.3,27278,-298,-296,100,80,10,3082,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3905,3906,3902,3888,3890,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,983,SUCCESS,,3085.664018,192,0,0.1,0.2,0.3,263,1.4,1.5
    2484,5/26/2021 21:58,9955.273,2.77,701,300,10,6001,0,65535,65535,1,22.3,27274,-296,-296,100,80,10,3082,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3904,3906,3902,3888,3890,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,997,SUCCESS,,3085.334883,192,0,0.1,0.2,0.3,263,1.4,1.5
    2485,5/26/2021 21:58,9959.285,2.77,701,300,10,6001,0,65535,65535,1,22.3,27276,-294,-296,100,80,10,3081,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3904,3906,3902,3888,3890,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,953,SUCCESS,,3085.007236,192,0,0.1,0.2,0.3,263,1.4,1.5
    2486,5/26/2021 21:58,9963.295,2.77,701,300,10,6001,0,65535,65535,1,22.3,27275,-296,-296,100,80,10,3081,3888,620,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3904,3905,3902,3888,3890,3885,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.3,942,SUCCESS,,3084.677525,192,0,0.1,0.2,0.3,263,1.4,1.5
    2487,5/26/2021 21:58,9967.305,2.77,701,300,10,6001,0,65535,65535,1,22.3,27273,-296,-296,100,80,10,3081,3888,625,625,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3904,3905,3902,3888,3890,3886,0,0,0,0,0,0,0,0,2726,22.3,22.3,-273.2,22.3,-273.2,22.4,934,SUCCESS,,3084.347814,192,0,0.1,0.2,0.3,263,1.4,1.5
    2488,5/26/2021 21:58,9971.317,2.77,701,300,10,6001,0,65535,65535,1,22.3,27274,-296,-296,100,80,10,3080,3888,629,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3900,3904,3905,3902,3888,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,954,SUCCESS,,3084.017938,192,0,0.1,0.2,0.3,263,1.4,1.5
    2489,5/26/2021 21:59,9975.322,2.77,701,300,10,6001,0,65535,65535,1,22.3,27271,-296,-296,100,80,10,3080,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3906,3901,3888,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,946,SUCCESS,,3083.688638,192,0,0.1,0.2,0.3,263,1.4,1.5
    2490,5/26/2021 21:59,9979.33,2.77,701,300,10,6001,0,65535,65535,1,22.3,27271,-294,-296,100,80,10,3080,3888,629,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,940,SUCCESS,,3083.361318,192,0,0.1,0.2,0.3,263,1.4,1.5
    2491,5/26/2021 21:59,9983.343,2.77,701,300,10,6001,0,65535,65535,1,22.3,27271,-294,-296,100,80,10,3079,3888,628,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,940,SUCCESS,,3083.03359,192,0,0.1,0.2,0.3,263,1.4,1.5
    2492,5/26/2021 21:59,9987.343,2.77,701,300,10,6001,0,65535,65535,1,22.3,27271,-296,-296,100,80,10,3079,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,989,SUCCESS,,3082.704701,192,0,0.1,0.2,0.3,263,1.4,1.5
    2493,5/26/2021 21:59,9991.356,2.78,701,300,10,6001,0,65535,65535,1,22.3,27271,-296,-296,100,80,10,3079,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3889,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,944,SUCCESS,,3082.374743,192,0,0.1,0.2,0.3,263,1.4,1.5
    2494,5/26/2021 21:59,9995.36,2.78,701,300,10,6001,0,65535,65535,1,22.3,27271,-296,-296,100,80,10,3078,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,948,SUCCESS,,3082.045525,192,0,0.1,0.2,0.3,263,1.4,1.5
    2495,5/26/2021 21:59,9999.366,2.78,701,300,10,6001,0,65535,65535,1,22.3,27271,-296,-296,100,80,10,3078,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,986,SUCCESS,,3081.716143,192,0,0.1,0.2,0.3,263,1.4,1.5
    2496,5/26/2021 21:59,10003.368,2.78,701,300,10,6001,0,65535,65535,1,22.3,27270,-298,-296,100,80,10,3078,3888,620,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3889,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3081.384866,192,0,0.1,0.2,0.3,263,1.4,1.5
    2497,5/26/2021 21:59,10007.381,2.78,701,300,10,6001,0,65535,65535,1,22.3,27268,-296,-296,100,80,10,3077,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3890,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,970,SUCCESS,,3081.054909,192,0,0.1,0.2,0.3,263,1.4,1.5
    2498,5/26/2021 21:59,10011.396,2.78,701,300,10,6001,0,65535,65535,1,22.3,27269,-296,-296,100,80,10,3077,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3904,3905,3901,3887,3889,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,967,SUCCESS,,3080.724786,192,0,0.1,0.2,0.3,263,1.4,1.5
    2499,5/26/2021 21:59,10015.403,2.78,701,300,10,6001,0,65535,65535,1,22.3,27269,-296,-297,100,80,10,3077,3888,620,622,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3903,3905,3900,3887,3889,3885,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,943,SUCCESS,,3080.395322,192,0,0.1,0.2,0.3,263,1.4,1.5
    2500,5/26/2021 21:59,10019.408,2.78,701,300,10,6001,0,65535,65535,1,22.3,27268,-296,-296,100,80,10,3076,3888,624,624,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3903,3905,3900,3886,3889,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,21.9,939,SUCCESS,,3080.066022,192,0,0.1,0.2,0.3,263,1.4,1.5
    2501,5/26/2021 21:59,10023.411,2.78,701,300,10,6001,0,65535,65535,1,22.3,27265,-296,-296,100,80,10,3076,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3903,3904,3900,3886,3889,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,950,SUCCESS,,3079.736886,192,0,0.1,0.2,0.3,263,1.4,1.5
    2502,5/26/2021 21:59,10027.426,2.79,701,300,10,6001,0,65535,65535,1,22.3,27265,-298,-296,100,80,10,3076,3888,624,624,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3903,3904,3900,3886,3886,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,959,SUCCESS,,3079.404534,192,0,0.1,0.2,0.3,263,1.4,1.5
    2503,5/26/2021 21:59,10031.436,2.79,701,300,10,6001,0,65535,65535,1,22.3,27264,-298,-296,100,80,10,3075,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3903,3905,3900,3886,3889,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,943,SUCCESS,,3079.072595,192,0,0.1,0.2,0.3,263,1.4,1.5
    2504,5/26/2021 22:00,10035.45,2.79,701,300,10,6001,0,65535,65535,1,22.3,27265,-298,-296,100,80,10,3075,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3899,3903,3904,3900,3886,3889,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,947,SUCCESS,,3078.740325,192,0,0.1,0.2,0.3,263,1.4,1.5
    2505,5/26/2021 22:00,10039.455,2.79,701,300,10,6001,0,65535,65535,1,22.3,27265,-296,-296,100,80,10,3075,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3903,3904,3900,3886,3886,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.1,940,SUCCESS,,3078.411025,192,0,0.1,0.2,0.3,263,1.4,1.5
    2506,5/26/2021 22:00,10043.46,2.79,701,300,10,6001,0,65535,65535,1,22.3,27264,-298,-296,100,80,10,3074,3888,627,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3903,3904,3900,3886,3888,3884,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,949,SUCCESS,,3078.0795,192,0,0.1,0.2,0.3,263,1.4,1.5
    2507,5/26/2021 22:00,10047.47,2.79,701,300,10,6001,0,65535,65535,1,22.3,27263,-298,-296,100,80,10,3074,3888,619,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3903,3904,3900,3886,3888,3883,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,940,SUCCESS,,3077.747561,192,0,0.1,0.2,0.3,263,1.4,1.5
    2508,5/26/2021 22:00,10051.475,2.79,701,300,10,6001,0,65535,65535,1,22.3,27262,-296,-296,100,80,10,3074,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3903,3904,3900,3885,3884,3883,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.3,970,SUCCESS,,3077.418261,192,0,0.1,0.2,0.3,263,1.4,1.5
    2509,5/26/2021 22:00,10055.476,2.79,701,300,10,6001,0,65535,65535,1,22.3,27262,-298,-296,100,80,10,3073,3888,619,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3902,3904,3899,3886,3888,3883,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,995,SUCCESS,,3077.087067,192,0,0.1,0.2,0.3,263,1.4,1.5
    2510,5/26/2021 22:00,10059.488,2.79,701,300,10,6001,0,65535,65535,1,22.3,27261,-296,-296,100,80,10,3073,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3902,3904,3900,3885,3888,3883,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,935,SUCCESS,,3076.757191,192,0,0.1,0.2,0.3,263,1.4,1.5
    2511,5/26/2021 22:00,10063.502,2.8,701,300,10,6001,0,65535,65535,1,22.3,27260,-296,-296,100,80,10,3073,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3902,3904,3900,3885,3888,3883,0,0,0,0,0,0,0,0,2726,22.2,22.3,-273.2,22.3,-273.2,22.4,960,SUCCESS,,3076.427151,192,0,0.1,0.2,0.3,263,1.4,1.5
    2512,5/26/2021 22:00,10067.503,2.8,701,300,10,6001,0,65535,65535,1,22.3,27260,-296,-296,100,80,10,3072,3888,619,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3902,3904,3900,3885,3888,3883,0,0,0,0,0,0,0,0,2725,22.2,22.3,-273.2,22.3,-273.2,22.3,969,SUCCESS,,3076.09818,192,0,0.1,0.2,0.3,263,1.4,1.5
    2513,5/26/2021 22:00,10071.51,2.8,701,300,10,6001,0,65535,65535,1,22.3,27259,-294,-296,100,80,10,3072,3888,627,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3898,3902,3904,3899,3885,3888,3883,0,0,0,0,0,0,0,0,2722,22.2,22.3,-273.2,22.3,-273.2,22.3,1022,SUCCESS,,3075.770942,192,0,0.1,0.2,0.3,263,1.4,1.5
    2514,5/26/2021 22:00,10075.512,2.8,701,300,10,6001,0,65535,65535,1,22.3,27258,-296,-296,100,80,10,3072,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3904,3899,3885,3888,3883,0,0,0,0,0,0,0,0,2725,22.2,22.3,-273.2,22.3,-273.2,22.4,951,SUCCESS,,3075.441889,192,0,0.1,0.2,0.3,263,1.4,1.5
    2515,5/26/2021 22:00,10079.519,2.8,701,300,10,6001,0,65535,65535,1,22.3,27258,-296,-296,100,79,10,3071,3888,618,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3885,3888,3883,0,0,0,0,0,0,0,0,2722,22.2,22.3,-273.2,22.3,-273.2,22.3,962,SUCCESS,,3075.112424,192,0,0.1,0.2,0.3,263,1.4,1.5
    2516,5/26/2021 22:00,10083.519,2.8,701,300,10,6001,0,65535,65535,1,22.3,27257,-296,-297,100,79,10,3071,3888,623,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3885,3888,3883,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,969,SUCCESS,,3074.783535,192,0,0.1,0.2,0.3,263,1.4,1.5
    2517,5/26/2021 22:00,10087.534,2.8,701,300,10,6001,0,65535,65535,1,22.3,27257,-298,-296,100,79,10,3071,3888,623,623,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3886,3887,3883,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,959,SUCCESS,,3074.451183,192,0,0.1,0.2,0.3,263,1.4,1.5
    2518,5/26/2021 22:00,10091.539,2.8,701,300,10,6001,0,65535,65535,1,22.3,27257,-298,-297,100,79,10,3070,3888,618,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3885,3888,3883,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,970,SUCCESS,,3074.119658,192,0,0.1,0.2,0.3,263,1.4,1.5
    2519,5/26/2021 22:01,10095.548,2.8,701,300,10,6001,0,65535,65535,1,22.3,27257,-296,-297,100,79,10,3070,3888,622,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3885,3888,3883,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,21.6,941,SUCCESS,,3073.790029,192,0,0.1,0.2,0.3,263,1.4,1.5
    2520,5/26/2021 22:01,10099.55,2.81,701,300,10,6001,0,65535,65535,1,22.3,27256,-296,-296,100,79,10,3070,3888,622,622,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3885,3888,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,975,SUCCESS,,3073.460975,192,0,0.1,0.2,0.3,263,1.4,1.5
    2521,5/26/2021 22:01,10103.56,2.81,701,300,10,6001,0,65535,65535,1,22.3,27255,-298,-297,100,79,10,3069,3888,618,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3901,3903,3899,3885,3887,3883,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3073.129036,192,0,0.1,0.2,0.3,263,1.4,1.5
    2522,5/26/2021 22:01,10107.571,2.81,701,300,10,6001,0,65535,65535,1,22.3,27254,-296,-297,100,79,10,3069,3888,618,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3885,3887,3883,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,1000,SUCCESS,,3072.799243,192,0,0.1,0.2,0.3,263,1.4,1.5
    2523,5/26/2021 22:01,10111.575,2.81,701,300,10,6001,0,65535,65535,1,22.3,27253,-296,-296,100,79,10,3069,3888,622,622,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3902,3903,3899,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,953,SUCCESS,,3072.470025,192,0,0.1,0.2,0.3,263,1.4,1.5
    2524,5/26/2021 22:01,10115.58,2.81,701,300,10,6001,0,65535,65535,1,22.3,27253,-298,-297,100,79,10,3068,3888,618,620,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3901,3903,3899,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,939,SUCCESS,,3072.1385,192,0,0.1,0.2,0.3,263,1.4,1.5
    2525,5/26/2021 22:01,10119.583,2.81,701,300,10,6001,0,65535,65535,1,22.3,27252,-296,-297,100,79,10,3068,3888,618,620,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3901,3902,3899,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,935,SUCCESS,,3071.809365,192,0,0.1,0.2,0.3,263,1.4,1.5
    2526,5/26/2021 22:01,10123.598,2.81,701,300,10,6001,0,65535,65535,1,22.3,27252,-298,-297,100,79,10,3068,3888,614,620,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3897,3901,3903,3899,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,936,SUCCESS,,3071.477012,192,0,0.1,0.2,0.3,263,1.4,1.5
    2527,5/26/2021 22:01,10127.613,2.81,701,300,10,6001,0,65535,65535,1,22.3,27250,-296,-297,100,79,10,3067,3888,630,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3901,3902,3898,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,961,SUCCESS,,3071.14689,192,0,0.1,0.2,0.3,263,1.4,1.5
    2528,5/26/2021 22:01,10131.621,2.81,701,300,10,6001,0,65535,65535,1,22.3,27250,-298,-297,100,79,10,3067,3888,618,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3901,3902,3898,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,945,SUCCESS,,3070.815116,192,0,0.1,0.2,0.3,263,1.4,1.5
    2529,5/26/2021 22:01,10135.631,2.82,701,300,10,6001,0,65535,65535,1,22.3,27250,-296,-297,100,79,10,3067,3888,622,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3901,3902,3898,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,935,SUCCESS,,3070.485405,192,0,0.1,0.2,0.3,263,1.4,1.5
    2530,5/26/2021 22:01,10139.636,2.82,701,300,10,6001,0,65535,65535,1,22.3,27250,-298,-297,100,79,10,3066,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3898,3884,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,945,SUCCESS,,3070.15388,192,0,0.1,0.2,0.3,263,1.4,1.5
    2531,5/26/2021 22:01,10143.642,2.82,701,300,10,6001,0,65535,65535,1,22.3,27248,-298,-297,100,79,10,3066,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3898,3883,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,977,SUCCESS,,3069.822273,192,0,0.1,0.2,0.3,263,1.4,1.5
    2532,5/26/2021 22:01,10147.654,2.82,701,300,10,6001,0,65535,65535,1,22.3,27249,-296,-297,100,79,10,3066,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3898,3883,3887,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,941,SUCCESS,,3069.492397,192,0,0.1,0.2,0.3,263,1.4,1.5
    2533,5/26/2021 22:01,10151.664,2.82,701,300,10,6001,0,65535,65535,1,22.3,27248,-296,-297,100,79,10,3065,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3898,3883,3886,3882,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,939,SUCCESS,,3069.162686,192,0,0.1,0.2,0.3,263,1.4,1.5
    2534,5/26/2021 22:02,10155.672,2.82,701,300,10,6001,0,65535,65535,1,22.3,27246,-298,-297,100,79,10,3065,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3898,3883,3886,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,971,SUCCESS,,3068.830913,192,0,0.1,0.2,0.3,263,1.4,1.5
    2535,5/26/2021 22:02,10159.681,2.82,701,300,10,6001,0,65535,65535,1,22.3,27248,-296,-297,100,79,10,3065,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3898,3883,3886,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,941,SUCCESS,,3068.501284,192,0,0.1,0.2,0.3,263,1.4,1.5
    2536,5/26/2021 22:02,10163.685,2.82,701,300,10,6001,0,65535,65535,1,22.3,27246,-296,-297,100,79,10,3064,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3897,3883,3885,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,946,SUCCESS,,3068.172066,192,0,0.1,0.2,0.3,263,1.4,1.5
    2537,5/26/2021 22:02,10167.7,2.82,701,300,10,6001,0,65535,65535,1,22.3,27245,-298,-297,100,79,10,3064,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3896,3900,3902,3897,3883,3886,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,947,SUCCESS,,3067.839713,192,0,0.1,0.2,0.3,263,1.4,1.5
    2538,5/26/2021 22:02,10171.707,2.83,701,300,10,6001,0,65535,65535,1,22.3,27244,-296,-297,100,79,10,3064,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3895,3900,3902,3897,3883,3886,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22,965,SUCCESS,,3067.510249,192,0,0.1,0.2,0.3,263,1.4,1.5
    2539,5/26/2021 22:02,10175.722,2.83,701,300,10,6001,0,65535,65535,1,22.3,27243,-298,-297,100,79,10,3063,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3895,3900,3901,3897,3883,3885,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,955,SUCCESS,,3067.177896,192,0,0.1,0.2,0.3,263,1.4,1.5
    2540,5/26/2021 22:02,10179.725,2.83,701,300,10,6001,0,65535,65535,1,22.3,27243,-298,-297,100,79,10,3063,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3895,3900,3901,3897,3883,3886,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3066.846536,192,0,0.1,0.2,0.3,263,1.4,1.5
    2541,5/26/2021 22:02,10183.731,2.83,701,300,10,6001,0,65535,65535,1,22.3,27243,-296,-297,100,79,10,3063,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3895,3900,3901,3897,3883,3886,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3066.517154,192,0,0.1,0.2,0.3,263,1.4,1.5
    2542,5/26/2021 22:02,10187.742,2.83,701,300,10,6001,0,65535,65535,1,22.3,27243,-298,-297,100,79,10,3062,3888,617,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3895,3900,3901,3897,3883,3885,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,953,SUCCESS,,3066.185133,192,0,0.1,0.2,0.3,263,1.4,1.5
    2543,5/26/2021 22:02,10191.743,2.83,701,300,10,6001,0,65535,65535,1,22.3,27241,-296,-297,100,79,10,3062,3888,625,619,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3895,3900,3901,3897,3883,3885,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,953,SUCCESS,,3065.856161,192,0,0.1,0.2,0.3,263,1.4,1.5
    2544,5/26/2021 22:02,10195.75,2.83,701,300,10,6001,0,65535,65535,1,22.3,27241,-296,-297,100,79,10,3062,3888,621,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3901,3897,3883,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,942,SUCCESS,,3065.526697,192,0,0.1,0.2,0.3,263,1.4,1.5
    2545,5/26/2021 22:02,10199.755,2.83,701,300,10,6001,0,65535,65535,1,22.3,27240,-298,-297,100,79,10,3061,3888,616,618,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3897,3883,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,972,SUCCESS,,3065.195172,192,0,0.1,0.2,0.3,263,1.4,1.5
    2546,5/26/2021 22:02,10203.763,2.83,701,300,10,6001,0,65535,65535,1,22.3,27238,-294,-297,100,79,10,3061,3888,625,618,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3901,3897,3882,3885,3881,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,951,SUCCESS,,3064.867852,192,0,0.1,0.2,0.3,263,1.4,1.5
    2547,5/26/2021 22:02,10207.778,2.84,701,300,10,6001,0,65535,65535,1,22.3,27237,-296,-297,100,79,10,3061,3888,616,618,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,945,SUCCESS,,3064.53773,192,0,0.1,0.2,0.3,263,1.4,1.5
    2548,5/26/2021 22:02,10211.793,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-298,-297,100,79,10,3060,3888,624,618,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,959,SUCCESS,,3064.205377,192,0,0.1,0.2,0.3,263,1.4,1.5
    2549,5/26/2021 22:03,10215.795,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-296,-297,100,79,10,3060,3888,620,618,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,960,SUCCESS,,3063.876324,192,0,0.1,0.2,0.3,263,1.4,1.5
    2550,5/26/2021 22:03,10219.805,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-298,-297,100,79,10,3060,3888,616,618,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,957,SUCCESS,,3063.544385,192,0,0.1,0.2,0.3,263,1.4,1.5
    2551,5/26/2021 22:03,10223.807,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-296,-297,100,79,10,3059,3888,620,618,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,960,SUCCESS,,3063.215331,192,0,0.1,0.2,0.3,263,1.4,1.5
    2552,5/26/2021 22:03,10227.809,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-296,-296,100,79,10,3059,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,964,SUCCESS,,3062.886278,192,0,0.1,0.2,0.3,263,1.4,1.5
    2553,5/26/2021 22:03,10231.818,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-298,-296,100,79,10,3059,3888,616,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,985,SUCCESS,,3062.554422,192,0,0.1,0.2,0.3,263,1.4,1.5
    2554,5/26/2021 22:03,10235.818,2.84,701,300,10,6001,0,65535,65535,1,22.3,27236,-296,-296,100,79,10,3058,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,964,SUCCESS,,3062.225533,192,0,0.1,0.2,0.3,263,1.4,1.5
    2555,5/26/2021 22:03,10239.82,2.84,701,300,10,6001,0,65535,65535,1,22.3,27235,-296,-296,100,79,10,3058,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3899,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,963,SUCCESS,,3061.89648,192,0,0.1,0.2,0.3,263,1.4,1.5
    2556,5/26/2021 22:03,10243.827,2.85,701,300,10,6001,0,65535,65535,1,22.3,27235,-296,-296,100,79,10,3058,3888,616,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,961,SUCCESS,,3061.567015,192,0,0.1,0.2,0.3,263,1.4,1.5
    2557,5/26/2021 22:03,10247.836,2.85,701,300,10,6001,0,65535,65535,1,22.3,27233,-294,-296,100,79,10,3058,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3900,3896,3882,3885,3880,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22,943,SUCCESS,,3061.239614,192,0,0.1,0.2,0.3,263,1.4,1.5
    2558,5/26/2021 22:03,10251.85,2.85,701,300,10,6001,0,65535,65535,1,22.3,27232,-296,-296,100,79,10,3057,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3899,3896,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,941,SUCCESS,,3060.909574,192,0,0.1,0.2,0.3,263,1.4,1.5
    2559,5/26/2021 22:03,10255.862,2.85,701,300,10,6001,0,65535,65535,1,22.3,27232,-294,-296,100,79,10,3057,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3899,3895,3882,3885,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,969,SUCCESS,,3060.581927,192,0,0.1,0.2,0.3,263,1.4,1.5
    2560,5/26/2021 22:03,10259.866,2.85,701,300,10,6001,0,65535,65535,1,22.3,27229,-298,-296,100,79,10,3057,3888,620,620,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3060.250485,192,0,0.1,0.2,0.3,263,1.4,1.5
    2561,5/26/2021 22:03,10263.872,2.85,701,300,10,6001,0,65535,65535,1,22.3,27230,-298,-297,100,79,10,3056,3888,615,617,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,996,SUCCESS,,3059.918877,192,0,0.1,0.2,0.3,263,1.4,1.5
    2562,5/26/2021 22:03,10267.887,2.85,701,300,10,6001,0,65535,65535,1,22.3,27231,-296,-297,100,79,10,3056,3888,615,617,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3894,3898,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,958,SUCCESS,,3059.588755,192,0,0.1,0.2,0.3,263,1.4,1.5
    2563,5/26/2021 22:03,10271.902,2.85,701,300,10,6001,0,65535,65535,1,22.3,27228,-298,-297,100,79,10,3056,3888,619,617,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3898,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,947,SUCCESS,,3059.256402,192,0,0.1,0.2,0.3,263,1.4,1.5
    2564,5/26/2021 22:04,10275.906,2.85,701,300,10,6001,0,65535,65535,1,22.3,27230,-298,-297,100,79,10,3055,3888,619,617,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3058.92496,192,0,0.1,0.2,0.3,263,1.4,1.5
    2565,5/26/2021 22:04,10279.918,2.86,701,300,10,6001,0,65535,65535,1,22.3,27230,-298,-297,100,79,10,3055,3888,615,617,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3898,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,947,SUCCESS,,3058.592855,192,0,0.1,0.2,0.3,263,1.4,1.5
    2566,5/26/2021 22:04,10283.92,2.86,701,300,10,6001,0,65535,65535,1,22.3,27228,-296,-297,100,79,10,3054,3888,619,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,948,SUCCESS,,3058.263802,192,0,0.1,0.2,0.3,263,1.4,1.5
    2567,5/26/2021 22:04,10287.929,2.86,701,300,10,6001,0,65535,65535,1,22.3,27227,-298,-297,100,79,10,3054,3888,615,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3895,3880,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,956,SUCCESS,,3057.931946,192,0,0.1,0.2,0.3,263,1.4,1.5
    2568,5/26/2021 22:04,10291.937,2.86,701,300,10,6001,0,65535,65535,1,22.3,27228,-296,-296,100,79,10,3054,3888,619,619,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3895,3881,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,939,SUCCESS,,3057.602399,192,0,0.1,0.2,0.3,263,1.4,1.5
    2569,5/26/2021 22:04,10295.948,2.86,701,300,10,6001,0,65535,65535,1,22.3,27226,-298,-297,100,79,10,3053,3888,615,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3895,3880,3884,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.2,944,SUCCESS,,3057.270378,192,0,0.1,0.2,0.3,263,1.4,1.5
    2570,5/26/2021 22:04,10299.951,2.86,701,300,10,6001,0,65535,65535,1,22.3,27225,-294,-297,100,79,10,3053,3888,623,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3894,3880,3883,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,973,SUCCESS,,3056.943466,192,0,0.1,0.2,0.3,263,1.4,1.5
    2571,5/26/2021 22:04,10303.953,2.86,701,300,10,6001,0,65535,65535,1,22.3,27224,-296,-297,100,79,10,3053,3888,619,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3899,3894,3880,3883,3879,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,21.8,973,SUCCESS,,3056.614413,192,0,0.1,0.2,0.3,263,1.4,1.5
    2572,5/26/2021 22:04,10307.964,2.86,701,300,10,6001,0,65535,65535,1,22.3,27223,-296,-297,100,79,10,3052,3888,619,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3898,3894,3880,3883,3878,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,976,SUCCESS,,3056.284619,192,0,0.1,0.2,0.3,263,1.4,1.5
    2573,5/26/2021 22:04,10311.973,2.86,701,300,10,6001,0,65535,65535,1,22.3,27223,-296,-297,100,79,10,3052,3888,619,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3893,3897,3898,3894,3880,3883,3878,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,957,SUCCESS,,3055.95499,192,0,0.1,0.2,0.3,263,1.4,1.5
    2574,5/26/2021 22:04,10315.983,2.87,701,300,10,6001,0,65535,65535,1,22.3,27223,-300,-297,100,79,10,3052,3888,610,617,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3897,3898,3894,3880,3883,3878,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,972,SUCCESS,,3055.620824,192,0,0.1,0.2,0.3,263,1.4,1.5
    2575,5/26/2021 22:04,10319.986,2.87,701,300,10,6001,0,65535,65535,1,22.3,27222,-296,-297,100,79,10,3051,3888,618,616,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3897,3898,3894,3880,3883,3878,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,943,SUCCESS,,3055.291688,192,0,0.1,0.2,0.3,263,1.4,1.5
    2576,5/26/2021 22:04,10323.993,2.87,701,300,10,6001,0,65535,65535,1,22.3,27222,-296,-297,100,79,10,3051,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3897,3898,3894,3880,3883,3878,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,948,SUCCESS,,3054.962224,192,0,0.1,0.2,0.3,263,1.4,1.5
    2577,5/26/2021 22:04,10328.004,2.87,701,300,10,6001,0,65535,65535,1,22.3,27221,-296,-297,100,79,10,3051,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3897,3898,3894,3880,3884,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,1006,SUCCESS,,3054.63243,192,0,0.1,0.2,0.3,263,1.4,1.5
    2578,5/26/2021 22:04,10332.005,2.87,701,300,10,6001,0,65535,65535,1,22.3,27221,-296,-297,100,79,10,3051,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3898,3894,3880,3883,3878,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,968,SUCCESS,,3054.303459,192,0,0.1,0.2,0.3,263,1.4,1.5
    2579,5/26/2021 22:05,10336.008,2.87,701,300,10,6001,0,65535,65535,1,22.3,27219,-298,-297,100,79,10,3050,3888,614,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3898,3894,3880,3882,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,970,SUCCESS,,3053.9721,192,0,0.1,0.2,0.3,263,1.4,1.5
    2580,5/26/2021 22:05,10340.015,2.87,701,300,10,6001,0,65535,65535,1,22.3,27219,-298,-297,100,79,10,3050,3888,614,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3898,3894,3880,3885,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,942,SUCCESS,,3053.640409,192,0,0.1,0.2,0.3,263,1.4,1.5
    2581,5/26/2021 22:05,10344.025,2.87,701,300,10,6001,0,65535,65535,1,22.3,27218,-296,-297,100,79,10,3050,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3898,3893,3879,3883,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,949,SUCCESS,,3053.310698,192,0,0.1,0.2,0.3,263,1.4,1.5
    2582,5/26/2021 22:05,10348.027,2.87,701,300,10,6001,0,65535,65535,1,22.3,27216,-298,-297,100,79,10,3049,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.2,943,SUCCESS,,3052.979421,192,0,0.1,0.2,0.3,263,1.4,1.5
    2583,5/26/2021 22:05,10352.029,2.88,701,300,10,6001,0,65535,65535,1,22.3,27217,-296,-297,100,79,10,3049,3888,614,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3897,3893,3879,3884,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,949,SUCCESS,,3052.650368,192,0,0.1,0.2,0.3,263,1.4,1.5
    2584,5/26/2021 22:05,10356.039,2.88,701,300,10,6001,0,65535,65535,1,22.3,27216,-296,-297,100,79,10,3049,3888,614,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,992,SUCCESS,,3052.320657,192,0,0.1,0.2,0.3,263,1.4,1.5
    2585,5/26/2021 22:05,10360.045,2.88,701,300,10,6001,0,65535,65535,1,22.3,27216,-296,-297,100,79,10,3048,3888,614,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,979,SUCCESS,,3051.991275,192,0,0.1,0.2,0.3,263,1.4,1.5
    2586,5/26/2021 22:05,10364.058,2.88,701,300,10,6001,0,65535,65535,1,22.3,27215,-296,-297,100,79,10,3048,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3892,3896,3897,3893,3879,3885,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.3,972,SUCCESS,,3051.661317,192,0,0.1,0.2,0.3,263,1.4,1.5
    2587,5/26/2021 22:05,10368.069,2.88,701,300,10,6001,0,65535,65535,1,22.3,27215,-296,-297,100,79,10,3048,3888,622,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2720,22.2,22.3,-273.2,22.3,-273.2,22.3,988,SUCCESS,,3051.331524,192,0,0.1,0.2,0.3,263,1.4,1.5
    2588,5/26/2021 22:05,10372.079,2.88,701,300,10,6001,0,65535,65535,1,22.3,27215,-298,-297,100,79,10,3047,3888,613,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,22.4,938,SUCCESS,,3050.999585,192,0,0.1,0.2,0.3,263,1.4,1.5
    2589,5/26/2021 22:05,10376.081,2.88,701,300,10,6001,0,65535,65535,1,22.3,27215,-296,-297,100,79,10,3047,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2720,22.2,22.3,-273.2,22.3,-273.2,22.3,970,SUCCESS,,3050.670531,192,0,0.1,0.2,0.3,263,1.4,1.5
    2590,5/26/2021 22:05,10380.091,2.88,701,300,10,6001,0,65535,65535,1,22.3,27215,-298,-297,100,79,10,3047,3888,618,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3896,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2721,22.2,22.3,-273.2,22.3,-273.2,21.5,945,SUCCESS,,3050.338593,192,0,0.1,0.2,0.3,263,1.4,1.5
    2591,5/26/2021 22:05,10384.096,2.88,701,300,10,6001,0,65535,65535,1,22.3,27215,-296,-297,100,79,10,3046,3888,613,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3896,3897,3893,3879,3881,3877,0,0,0,0,0,0,0,0,2718,22.2,22.3,-273.2,22.3,-273.2,22.3,952,SUCCESS,,3050.009293,192,0,0.1,0.2,0.3,263,1.4,1.5
    2592,5/26/2021 22:05,10388.101,2.89,701,300,10,6001,0,65535,65535,1,22.3,27213,-296,-297,100,79,10,3046,3888,617,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3897,3893,3879,3885,3877,0,0,0,0,0,0,0,0,2717,22.2,22.3,-273.2,22.3,-273.2,22.3,936,SUCCESS,,3049.679993,192,0,0.1,0.2,0.3,263,1.4,1.5
    2593,5/26/2021 22:05,10392.103,2.89,701,300,10,6001,0,65535,65535,1,22.3,27211,-296,-297,100,79,10,3046,3888,613,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3897,3893,3879,3882,3877,0,0,0,0,0,0,0,0,2717,22.2,22.3,-273.2,22.3,-273.2,22.3,981,SUCCESS,,3049.350939,192,0,0.1,0.2,0.3,263,1.4,1.5
    2594,5/26/2021 22:06,10396.117,2.89,701,300,10,6001,0,65535,65535,1,22.3,27210,-298,-297,100,79,10,3045,3888,613,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3897,3892,3879,3881,3877,0,0,0,0,0,0,0,0,2718,22.2,22.3,-273.2,22.3,-273.2,22.3,983,SUCCESS,,3049.018669,192,0,0.1,0.2,0.3,263,1.4,1.5
    2595,5/26/2021 22:06,10400.126,2.89,701,300,10,6001,0,65535,65535,1,22.3,27211,-298,-297,100,79,10,3045,3888,617,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3896,3892,3879,3882,3877,0,0,0,0,0,0,0,0,2717,22.2,22.3,-273.2,22.3,-273.2,22.3,938,SUCCESS,,3048.686813,192,0,0.1,0.2,0.3,263,1.4,1.5
    2596,5/26/2021 22:06,10404.138,2.89,701,300,10,6001,0,65535,65535,1,22.3,27210,-298,-297,100,79,10,3045,3888,617,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.2,22.3,-273.2,22.3,-273.2,22.3,958,SUCCESS,,3048.354709,192,0,0.1,0.2,0.3,263,1.4,1.5
    2597,5/26/2021 22:06,10408.153,2.89,701,300,10,6001,0,65535,65535,1,22.3,27209,-298,-297,100,79,10,3044,3888,617,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.2,22.3,-273.2,22.3,-273.2,22.3,960,SUCCESS,,3048.022356,192,0,0.1,0.2,0.3,263,1.4,1.5
    2598,5/26/2021 22:06,10412.164,2.89,701,300,10,6001,0,65535,65535,1,22.3,27209,-298,-297,100,79,10,3044,3888,617,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3891,3895,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.2,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3047.690334,192,0,0.1,0.2,0.3,263,1.4,1.5
    2599,5/26/2021 22:06,10416.173,2.89,701,300,10,6001,0,65535,65535,1,22.3,27207,-296,-297,100,79,10,3044,3888,613,615,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3895,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,953,SUCCESS,,3047.360705,192,0,0.1,0.2,0.3,263,1.4,1.5
    2600,5/26/2021 22:06,10420.184,2.89,701,300,10,6001,0,65535,65535,1,22.3,27208,-296,-297,100,79,10,3043,3888,613,615,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,949,SUCCESS,,3047.030912,192,0,0.1,0.2,0.3,263,1.4,1.5
    2601,5/26/2021 22:06,10424.192,2.9,701,300,10,6001,0,65535,65535,1,22.3,27208,-296,-297,100,79,10,3043,3888,617,615,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3895,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,957,SUCCESS,,3046.701365,192,0,0.1,0.2,0.3,263,1.4,1.5
    2602,5/26/2021 22:06,10428.198,2.9,701,300,10,6001,0,65535,65535,1,22.3,27206,-296,-297,100,79,10,3043,3888,621,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3878,3881,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,961,SUCCESS,,3046.371983,192,0,0.1,0.2,0.3,263,1.4,1.5
    2603,5/26/2021 22:06,10432.203,2.9,701,300,10,6001,0,65535,65535,1,22.3,27205,-296,-296,100,79,10,3042,3888,617,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3878,3880,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,940,SUCCESS,,3046.042683,192,0,0.1,0.2,0.3,263,1.4,1.5
    2604,5/26/2021 22:06,10436.217,2.9,701,300,10,6001,0,65535,65535,1,22.3,27207,-296,-296,100,79,10,3042,3888,617,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3877,3880,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,963,SUCCESS,,3045.712643,192,0,0.1,0.2,0.3,263,1.4,1.5
    2605,5/26/2021 22:06,10440.247,2.9,701,300,10,6001,0,65535,65535,1,22.3,27206,-296,-296,100,79,10,3042,3888,617,617,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3878,3880,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,942,SUCCESS,,3045.381288,192,0,0.1,0.2,0.3,263,1.4,1.5
    2606,5/26/2021 22:06,10444.242,2.9,701,300,10,6001,0,65535,65535,1,22.3,27205,-296,-296,100,79,10,3041,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3877,3880,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,966,SUCCESS,,3045.05281,192,0,0.1,0.2,0.3,263,1.4,1.5
    2607,5/26/2021 22:06,10448.256,2.9,701,300,10,6001,0,65535,65535,1,22.3,27204,-298,-297,100,79,10,3041,3888,612,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3896,3892,3877,3880,3876,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,988,SUCCESS,,3044.72054,192,0,0.1,0.2,0.3,263,1.4,1.5
    2608,5/26/2021 22:06,10452.258,2.9,701,300,10,6001,0,65535,65535,1,22.3,27205,-296,-296,100,79,10,3041,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3895,3892,3877,3880,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,946,SUCCESS,,3044.391486,192,0,0.1,0.2,0.3,263,1.4,1.5
    2609,5/26/2021 22:07,10456.273,2.9,701,300,10,6001,0,65535,65535,1,22.3,27203,-298,-296,100,79,10,3040,3888,612,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3895,3891,3877,3880,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,21.7,964,SUCCESS,,3044.059134,192,0,0.1,0.2,0.3,263,1.4,1.5
    2610,5/26/2021 22:07,10460.286,2.91,701,300,10,6001,0,65535,65535,1,22.3,27203,-296,-296,100,79,10,3040,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3895,3892,3877,3880,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,957,SUCCESS,,3043.729176,192,0,0.1,0.2,0.3,263,1.4,1.5
    2611,5/26/2021 22:07,10464.299,2.91,701,300,10,6001,0,65535,65535,1,22.3,27203,-294,-296,100,79,10,3040,3888,620,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3890,3894,3895,3891,3877,3880,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,943,SUCCESS,,3043.401448,192,0,0.1,0.2,0.3,263,1.4,1.5
    2612,5/26/2021 22:07,10468.306,2.91,701,300,10,6001,0,65535,65535,1,22.3,27201,-296,-297,100,79,10,3039,3888,612,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3894,3895,3891,3877,3880,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,982,SUCCESS,,3043.071983,192,0,0.1,0.2,0.3,263,1.4,1.5
    2613,5/26/2021 22:07,10472.322,2.91,701,300,10,6001,0,65535,65535,1,22.3,27201,-296,-296,100,79,10,3039,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3895,3891,3877,3880,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,986,SUCCESS,,3042.741779,192,0,0.1,0.2,0.3,263,1.4,1.5
    2614,5/26/2021 22:07,10476.33,2.91,701,300,10,6001,0,65535,65535,1,22.3,27199,-296,-296,100,79,10,3039,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3895,3891,3877,3880,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,937,SUCCESS,,3042.412232,192,0,0.1,0.2,0.3,263,1.4,1.5
    2615,5/26/2021 22:07,10480.335,2.91,701,300,10,6001,0,65535,65535,1,22.3,27200,-296,-296,100,79,10,3038,3888,612,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3895,3891,3877,3880,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.1,948,SUCCESS,,3042.082932,192,0,0.1,0.2,0.3,263,1.4,1.5
    2616,5/26/2021 22:07,10484.347,2.91,701,300,10,6001,0,65535,65535,1,22.3,27200,-296,-296,100,79,10,3038,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3894,3895,3891,3877,3880,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,937,SUCCESS,,3041.753056,192,0,0.1,0.2,0.3,263,1.4,1.5
    2617,5/26/2021 22:07,10488.353,2.91,701,300,10,6001,0,65535,65535,1,22.3,27197,-298,-296,100,79,10,3038,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3895,3891,3876,3880,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,969,SUCCESS,,3041.421449,192,0,0.1,0.2,0.3,263,1.4,1.5
    2618,5/26/2021 22:07,10492.364,2.91,701,300,10,6001,0,65535,65535,1,22.3,27197,-296,-296,100,79,10,3037,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3895,3891,3876,3879,3875,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,936,SUCCESS,,3041.091655,192,0,0.1,0.2,0.3,263,1.4,1.5
    2619,5/26/2021 22:07,10496.368,2.92,701,300,10,6001,0,65535,65535,1,22.3,27196,-294,-296,100,79,10,3037,3888,616,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3894,3891,3876,3880,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,938,SUCCESS,,3040.764662,192,0,0.1,0.2,0.3,263,1.4,1.5
    2620,5/26/2021 22:07,10500.374,2.92,701,300,10,6001,0,65535,65535,1,22.3,27196,-296,-296,100,79,10,3037,3888,611,616,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3889,3893,3894,3891,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,949,SUCCESS,,3040.43528,192,0,0.1,0.2,0.3,263,1.4,1.5
    2621,5/26/2021 22:07,10504.382,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-296,-296,100,79,10,3036,3888,615,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3877,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,940,SUCCESS,,3040.105733,192,0,0.1,0.2,0.3,263,1.4,1.5
    2622,5/26/2021 22:07,10508.388,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-298,-296,100,79,10,3036,3888,611,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,947,SUCCESS,,3039.774125,192,0,0.1,0.2,0.3,263,1.4,1.5
    2623,5/26/2021 22:07,10512.402,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-298,-296,100,79,10,3036,3888,611,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22,958,SUCCESS,,3039.441855,192,0,0.1,0.2,0.3,263,1.4,1.5
    2624,5/26/2021 22:08,10516.411,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-296,-296,100,79,10,3035,3888,611,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,953,SUCCESS,,3039.112226,192,0,0.1,0.2,0.3,263,1.4,1.5
    2625,5/26/2021 22:08,10520.417,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-296,-296,100,79,10,3035,3888,615,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3892,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,946,SUCCESS,,3038.782844,192,0,0.1,0.2,0.3,263,1.4,1.5
    2626,5/26/2021 22:08,10524.43,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-298,-296,100,79,10,3035,3888,615,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,938,SUCCESS,,3038.450657,192,0,0.1,0.2,0.3,263,1.4,1.5
    2627,5/26/2021 22:08,10528.445,2.92,701,300,10,6001,0,65535,65535,1,22.3,27194,-296,-296,100,79,10,3034,3888,615,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,950,SUCCESS,,3038.120535,192,0,0.1,0.2,0.3,263,1.4,1.5
    2628,5/26/2021 22:08,10532.458,2.93,701,300,10,6001,0,65535,65535,1,22.3,27193,-298,-296,100,79,10,3034,3888,611,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3893,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,935,SUCCESS,,3037.788348,192,0,0.1,0.2,0.3,263,1.4,1.5
    2629,5/26/2021 22:08,10536.462,2.93,701,300,10,6001,0,65535,65535,1,22.3,27192,-294,-297,100,79,10,3034,3888,615,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3892,3893,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,955,SUCCESS,,3037.461354,192,0,0.1,0.2,0.3,263,1.4,1.5
    2630,5/26/2021 22:08,10540.476,2.93,701,300,10,6001,0,65535,65535,1,22.3,27191,-294,-296,100,79,10,3033,3888,619,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3892,3894,3890,3876,3879,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,973,SUCCESS,,3037.133544,192,0,0.1,0.2,0.3,263,1.4,1.5
    2631,5/26/2021 22:08,10544.483,2.93,701,300,10,6001,0,65535,65535,1,22.3,27192,-296,-297,100,79,10,3033,3888,615,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3892,3894,3890,3876,3879,3874,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,941,SUCCESS,,3036.80408,192,0,0.1,0.2,0.3,263,1.4,1.5
    2632,5/26/2021 22:08,10548.486,2.93,701,300,10,6001,0,65535,65535,1,22.3,27190,-294,-297,100,79,10,3033,3888,619,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3892,3893,3889,3876,3879,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,938,SUCCESS,,3036.477168,192,0,0.1,0.2,0.3,263,1.4,1.5
    2633,5/26/2021 22:08,10552.496,2.93,701,300,10,6001,0,65535,65535,1,22.3,27191,-296,-296,100,78,10,3032,3888,615,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3888,3892,3893,3890,3876,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3036.147457,192,0,0.1,0.2,0.3,263,1.4,1.5
    2634,5/26/2021 22:08,10556.5,2.93,701,300,10,6001,0,65535,65535,1,22.3,27188,-298,-297,100,78,10,3032,3888,610,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3892,3893,3889,3875,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,965,SUCCESS,,3035.816015,192,0,0.1,0.2,0.3,263,1.4,1.5
    2635,5/26/2021 22:08,10560.51,2.93,701,300,10,6001,0,65535,65535,1,22.3,27186,-298,-296,100,78,10,3032,3888,610,615,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3892,3893,3889,3875,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,943,SUCCESS,,3035.484076,192,0,0.1,0.2,0.3,263,1.4,1.5
    2636,5/26/2021 22:08,10564.523,2.93,701,300,10,6001,0,65535,65535,1,22.3,27186,-298,-297,100,78,10,3031,3888,610,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3889,3875,3877,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,963,SUCCESS,,3035.151889,192,0,0.1,0.2,0.3,263,1.4,1.5
    2637,5/26/2021 22:08,10568.536,2.94,701,300,10,6001,0,65535,65535,1,22.3,27188,-296,-297,100,78,10,3031,3888,614,612,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3892,3893,3889,3875,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,937,SUCCESS,,3034.821931,192,0,0.1,0.2,0.3,263,1.4,1.5
    2638,5/26/2021 22:08,10572.549,2.94,701,300,10,6001,0,65535,65535,1,22.3,27186,-296,-296,100,78,10,3031,3888,614,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3889,3875,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,939,SUCCESS,,3034.491973,192,0,0.1,0.2,0.3,263,1.4,1.5
    2639,5/26/2021 22:09,10576.555,2.94,701,300,10,6001,0,65535,65535,1,22.3,27185,-296,-297,100,78,10,3030,3888,610,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3889,3875,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,982,SUCCESS,,3034.162591,192,0,0.1,0.2,0.3,263,1.4,1.5
    2640,5/26/2021 22:09,10580.57,2.94,701,300,10,6001,0,65535,65535,1,22.3,27187,-298,-296,100,78,10,3030,3888,618,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3889,3875,3878,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,952,SUCCESS,,3033.830238,192,0,0.1,0.2,0.3,263,1.4,1.5
    2641,5/26/2021 22:09,10584.574,2.94,701,300,10,6001,0,65535,65535,1,22.3,27184,-298,-297,100,78,10,3030,3888,610,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3888,3875,3877,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,945,SUCCESS,,3033.498796,192,0,0.1,0.2,0.3,263,1.4,1.5
    2642,5/26/2021 22:09,10588.587,2.94,701,300,10,6001,0,65535,65535,1,22.3,27183,-296,-297,100,78,10,3029,3888,614,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3889,3874,3877,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,21.5,934,SUCCESS,,3033.168838,192,0,0.1,0.2,0.3,263,1.4,1.5
    2643,5/26/2021 22:09,10592.601,2.94,701,300,10,6001,0,65535,65535,1,22.3,27186,-296,-296,100,78,10,3029,3888,614,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3892,3889,3874,3877,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,1018,SUCCESS,,3032.838798,192,0,0.1,0.2,0.3,263,1.4,1.5
    2644,5/26/2021 22:09,10596.606,2.94,701,300,10,6001,0,65535,65535,1,22.3,27183,-296,-296,100,78,10,3029,3888,614,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3893,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3032.509498,192,0,0.1,0.2,0.3,263,1.4,1.5
    2645,5/26/2021 22:09,10600.608,2.94,701,300,10,6001,0,65535,65535,1,22.3,27182,-296,-296,100,78,10,3028,3888,618,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3892,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,960,SUCCESS,,3032.180445,192,0,0.1,0.2,0.3,263,1.4,1.5
    2646,5/26/2021 22:09,10604.622,2.95,701,300,10,6001,0,65535,65535,1,22.3,27182,-296,-296,100,78,10,3028,3888,614,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3892,3888,3874,3877,3873,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3031.850405,192,0,0.1,0.2,0.3,263,1.4,1.5
    2647,5/26/2021 22:09,10608.626,2.95,701,300,10,6001,0,65535,65535,1,22.3,27183,-298,-297,100,78,10,3028,3888,610,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3892,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,963,SUCCESS,,3031.518963,192,0,0.1,0.2,0.3,263,1.4,1.5
    2648,5/26/2021 22:09,10612.634,2.95,701,300,10,6001,0,65535,65535,1,22.3,27180,-296,-297,100,78,10,3027,3888,614,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3887,3891,3892,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,933,SUCCESS,,3031.189416,192,0,0.1,0.2,0.3,263,1.4,1.5
    2649,5/26/2021 22:09,10616.646,2.95,701,300,10,6001,0,65535,65535,1,22.3,27183,-298,-296,100,78,10,3027,3888,614,614,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3892,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,989,SUCCESS,,3030.857311,192,0,0.1,0.2,0.3,263,1.4,1.5
    2650,5/26/2021 22:09,10620.655,2.95,701,300,10,6001,0,65535,65535,1,22.3,27179,-298,-297,100,78,10,3027,3888,614,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3892,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,949,SUCCESS,,3030.525455,192,0,0.1,0.2,0.3,263,1.4,1.5
    2651,5/26/2021 22:09,10624.657,2.95,701,300,10,6001,0,65535,65535,1,22.3,27179,-294,-297,100,78,10,3026,3888,613,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3892,3888,3874,3877,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3030.198625,192,0,0.1,0.2,0.3,263,1.4,1.5
    2652,5/26/2021 22:09,10628.662,2.95,701,300,10,6001,0,65535,65535,1,22.3,27178,-296,-296,100,78,10,3026,3888,613,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3892,3888,3873,3878,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,952,SUCCESS,,3029.869325,192,0,0.1,0.2,0.3,263,1.4,1.5
    2653,5/26/2021 22:09,10632.667,2.95,701,300,10,6001,0,65535,65535,1,22.3,27179,-294,-296,100,78,10,3026,3888,613,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3892,3888,3874,3876,3872,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,963,SUCCESS,,3029.54225,192,0,0.1,0.2,0.3,263,1.4,1.5
    2654,5/26/2021 22:10,10636.682,2.95,701,300,10,6001,0,65535,65535,1,22.3,27177,-294,-296,100,78,10,3025,3888,613,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3891,3888,3873,3876,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,969,SUCCESS,,3029.214359,192,0,0.1,0.2,0.3,263,1.4,1.5
    2655,5/26/2021 22:10,10640.698,2.96,701,300,10,6001,0,65535,65535,1,22.3,27174,-298,-296,100,78,10,3025,3888,609,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3891,3887,3873,3877,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3028.881923,192,0,0.1,0.2,0.3,263,1.4,1.5
    2656,5/26/2021 22:10,10644.703,2.96,701,300,10,6001,0,65535,65535,1,22.3,27173,-296,-297,100,78,10,3025,3888,613,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3886,3890,3891,3887,3873,3876,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3028.552623,192,0,0.1,0.2,0.3,263,1.4,1.5
    2657,5/26/2021 22:10,10648.713,2.96,701,300,10,6001,0,65535,65535,1,22.3,27173,-296,-296,100,78,10,3024,3888,613,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3890,3891,3887,3873,3876,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3028.222912,192,0,0.1,0.2,0.3,263,1.4,1.5
    2658,5/26/2021 22:10,10652.715,2.96,701,300,10,6001,0,65535,65535,1,22.3,27173,-298,-297,100,78,10,3024,3888,613,611,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3890,3891,3887,3873,3877,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3027.891635,192,0,0.1,0.2,0.3,263,1.4,1.5
    2659,5/26/2021 22:10,10656.72,2.96,701,300,10,6001,0,65535,65535,1,22.3,27173,-294,-297,100,78,10,3024,3888,613,611,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3890,3891,3887,3873,3876,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,939,SUCCESS,,3027.56456,192,0,0.1,0.2,0.3,263,1.4,1.5
    2660,5/26/2021 22:10,10660.722,2.96,701,300,10,6001,0,65535,65535,1,22.3,27172,-298,-297,100,78,10,3023,3888,609,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3873,3875,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,938,SUCCESS,,3027.233284,192,0,0.1,0.2,0.3,263,1.4,1.5
    2661,5/26/2021 22:10,10664.727,2.96,701,300,10,6001,0,65535,65535,1,22.3,27172,-296,-297,100,78,10,3023,3888,609,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3873,3880,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,981,SUCCESS,,3026.903984,192,0,0.1,0.2,0.3,263,1.4,1.5
    2662,5/26/2021 22:10,10668.729,2.96,701,300,10,6001,0,65535,65535,1,22.3,27173,-296,-297,100,78,10,3023,3888,613,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3890,3891,3887,3873,3876,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,974,SUCCESS,,3026.57493,192,0,0.1,0.2,0.3,263,1.4,1.5
    2663,5/26/2021 22:10,10672.73,2.96,701,300,10,6001,0,65535,65535,1,22.3,27172,-298,-297,100,78,10,3022,3888,608,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3873,3876,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,961,SUCCESS,,3026.243736,192,0,0.1,0.2,0.3,263,1.4,1.5
    2664,5/26/2021 22:10,10676.744,2.97,701,300,10,6001,0,65535,65535,1,22.3,27172,-296,-297,100,78,10,3022,3888,613,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3873,3880,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,932,SUCCESS,,3025.913696,192,0,0.1,0.2,0.3,263,1.4,1.5
    2665,5/26/2021 22:10,10680.76,2.97,701,300,10,6001,0,65535,65535,1,22.3,27172,-296,-296,100,78,10,3022,3888,613,613,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3873,3875,3871,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3025.583492,192,0,0.1,0.2,0.3,263,1.4,1.5
    2666,5/26/2021 22:10,10684.769,2.97,701,300,10,6001,0,65535,65535,1,22.3,27171,-298,-296,100,78,10,3021,3888,608,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3872,3874,3870,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.3,992,SUCCESS,,3025.251636,192,0,0.1,0.2,0.3,263,1.4,1.5
    2667,5/26/2021 22:10,10688.773,2.97,701,300,10,6001,0,65535,65535,1,22.3,27170,-296,-296,100,78,10,3021,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3890,3887,3873,3880,3870,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,949,SUCCESS,,3024.922418,192,0,0.1,0.2,0.3,263,1.4,1.5
    2668,5/26/2021 22:10,10692.785,2.97,701,300,10,6001,0,65535,65535,1,22.3,27169,-296,-296,100,78,10,3021,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3891,3887,3872,3875,3870,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,943,SUCCESS,,3024.592543,192,0,0.1,0.2,0.3,263,1.4,1.5
    2669,5/26/2021 22:11,10696.8,2.97,701,300,10,6001,0,65535,65535,1,22.3,27167,-296,-296,100,78,10,3020,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3885,3889,3890,3886,3872,3875,3870,0,0,0,0,0,0,0,0,2717,22.1,22.3,-273.2,22.3,-273.2,22.2,956,SUCCESS,,3024.26242,192,0,0.1,0.2,0.3,263,1.4,1.5
    2670,5/26/2021 22:11,10700.803,2.97,701,300,10,6001,0,65535,65535,1,22.3,27168,-296,-296,100,78,10,3020,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3872,3875,3870,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,970,SUCCESS,,3023.933285,192,0,0.1,0.2,0.3,263,1.4,1.5
    2671,5/26/2021 22:11,10704.812,2.97,701,300,10,6001,0,65535,65535,1,22.3,27166,-298,-296,100,78,10,3020,3888,608,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3872,3875,3870,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,962,SUCCESS,,3023.601429,192,0,0.1,0.2,0.3,263,1.4,1.5
    2672,5/26/2021 22:11,10708.818,2.97,701,300,10,6001,0,65535,65535,1,22.3,27166,-296,-296,100,78,10,3019,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3872,3875,3870,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,957,SUCCESS,,3023.272046,192,0,0.1,0.2,0.3,263,1.4,1.5
    2673,5/26/2021 22:11,10712.826,2.98,701,300,10,6001,0,65535,65535,1,22.3,27166,-296,-296,100,78,10,3019,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3872,3880,3870,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,965,SUCCESS,,3022.9425,192,0,0.1,0.2,0.3,263,1.4,1.5
    2674,5/26/2021 22:11,10716.84,2.98,701,300,10,6001,0,65535,65535,1,22.3,27166,-296,-296,100,78,10,3019,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3872,3875,3870,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,959,SUCCESS,,3022.61246,192,0,0.1,0.2,0.3,263,1.4,1.5
    2675,5/26/2021 22:11,10720.846,2.98,701,300,10,6001,0,65535,65535,1,22.3,27166,-296,-296,100,78,10,3018,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3872,3874,3870,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,21.9,958,SUCCESS,,3022.283078,192,0,0.1,0.2,0.3,263,1.4,1.5
    2676,5/26/2021 22:11,10724.859,2.98,701,300,10,6001,0,65535,65535,1,22.3,27166,-298,-296,100,78,10,3018,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3886,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3021.95089,192,0,0.1,0.2,0.3,263,1.4,1.5
    2677,5/26/2021 22:11,10728.863,2.98,701,300,10,6001,0,65535,65535,1,22.3,27163,-294,-296,100,78,10,3018,3888,612,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3888,3890,3886,3872,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,937,SUCCESS,,3021.623897,192,0,0.1,0.2,0.3,263,1.4,1.5
    2678,5/26/2021 22:11,10732.872,2.98,701,300,10,6001,0,65535,65535,1,22.3,27162,-294,-296,100,78,10,3017,3888,616,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3889,3890,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,967,SUCCESS,,3021.296495,192,0,0.1,0.2,0.3,263,1.4,1.5
    2679,5/26/2021 22:11,10736.882,2.98,701,300,10,6001,0,65535,65535,1,22.3,27161,-296,-296,100,78,10,3017,3888,607,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3890,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,982,SUCCESS,,3020.966784,192,0,0.1,0.2,0.3,263,1.4,1.5
    2680,5/26/2021 22:11,10740.89,2.98,701,300,10,6001,0,65535,65535,1,22.3,27160,-296,-296,100,78,10,3017,3888,616,612,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3888,3890,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22,945,SUCCESS,,3020.637238,192,0,0.1,0.2,0.3,263,1.4,1.5
    2681,5/26/2021 22:11,10744.893,2.98,701,300,10,6001,0,65535,65535,1,22.3,27159,-296,-296,100,78,10,3016,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,969,SUCCESS,,3020.308102,192,0,0.1,0.2,0.3,263,1.4,1.5
    2682,5/26/2021 22:11,10748.899,2.99,701,300,10,6001,0,65535,65535,1,22.3,27160,-294,-296,100,78,10,3016,3888,616,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3884,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,956,SUCCESS,,3019.980945,192,0,0.1,0.2,0.3,263,1.4,1.5
    2683,5/26/2021 22:12,10752.911,2.99,701,300,10,6001,0,65535,65535,1,22.3,27159,-296,-296,100,78,10,3016,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,938,SUCCESS,,3019.65107,192,0,0.1,0.2,0.3,263,1.4,1.5
    2684,5/26/2021 22:12,10756.919,2.99,701,300,10,6001,0,65535,65535,1,22.3,27159,-294,-296,100,78,10,3015,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,951,SUCCESS,,3019.32375,192,0,0.1,0.2,0.3,263,1.4,1.5
    2685,5/26/2021 22:12,10760.924,2.99,701,300,10,6001,0,65535,65535,1,22.3,27159,-296,-296,100,78,10,3015,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,945,SUCCESS,,3018.99445,192,0,0.1,0.2,0.3,263,1.4,1.5
    2686,5/26/2021 22:12,10764.927,2.99,701,300,10,6001,0,65535,65535,1,22.3,27159,-296,-296,100,78,10,3015,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,955,SUCCESS,,3018.665314,192,0,0.1,0.2,0.3,263,1.4,1.5
    2687,5/26/2021 22:12,10768.938,2.99,701,300,10,6001,0,65535,65535,1,22.3,27159,-296,-296,100,78,10,3014,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3889,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,946,SUCCESS,,3018.335521,192,0,0.1,0.2,0.3,263,1.4,1.5
    2688,5/26/2021 22:12,10772.947,2.99,701,300,10,6001,0,65535,65535,1,22.3,27157,-298,-296,100,78,10,3014,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3888,3888,3885,3871,3874,3869,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.1,985,SUCCESS,,3018.003665,192,0,0.1,0.2,0.3,263,1.4,1.5
    2689,5/26/2021 22:12,10776.961,2.99,701,300,10,6001,0,65535,65535,1,22.3,27156,-294,-296,100,78,10,3014,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3887,3888,3885,3871,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,939,SUCCESS,,3017.675855,192,0,0.1,0.2,0.3,263,1.4,1.5
    2690,5/26/2021 22:12,10780.967,2.99,701,300,10,6001,0,65535,65535,1,22.3,27154,-294,-296,100,78,10,3013,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3887,3888,3885,3871,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,956,SUCCESS,,3017.348698,192,0,0.1,0.2,0.3,263,1.4,1.5
    2691,5/26/2021 22:12,10784.982,3,701,300,10,6001,0,65535,65535,1,22.3,27155,-294,-296,100,78,10,3013,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3887,3888,3885,3871,3874,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,959,SUCCESS,,3017.020806,192,0,0.1,0.2,0.3,263,1.4,1.5
    2692,5/26/2021 22:12,10788.994,3,701,300,10,6001,0,65535,65535,1,22.3,27154,-298,-296,100,78,10,3013,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3887,3888,3884,3870,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,962,SUCCESS,,3016.688702,192,0,0.1,0.2,0.3,263,1.4,1.5
    2693,5/26/2021 22:12,10792.999,3,701,300,10,6001,0,65535,65535,1,22.3,27153,-298,-296,100,78,10,3012,3888,606,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3883,3887,3888,3884,3870,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,949,SUCCESS,,3016.357177,192,0,0.1,0.2,0.3,263,1.4,1.5
    2694,5/26/2021 22:12,10797.002,3,701,300,10,6001,0,65535,65535,1,22.3,27152,-296,-296,100,78,10,3012,3888,615,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3887,3888,3884,3870,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,21.7,981,SUCCESS,,3016.028041,192,0,0.1,0.2,0.3,263,1.4,1.5
    2695,5/26/2021 22:12,10801.007,3,701,300,10,6001,0,65535,65535,1,22.3,27152,-296,-296,100,78,10,3012,3888,611,611,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3887,3888,3884,3870,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,981,SUCCESS,,3015.698741,192,0,0.1,0.2,0.3,263,1.4,1.5
    2696,5/26/2021 22:12,10805.013,3,701,300,10,6001,0,65535,65535,1,22.3,27152,-296,-296,100,78,10,3011,3888,614,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3887,3888,3884,3870,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,965,SUCCESS,,3015.369359,192,0,0.1,0.2,0.3,263,1.4,1.5
    2697,5/26/2021 22:12,10809.016,3,701,300,10,6001,0,65535,65535,1,22.3,27152,-296,-296,100,78,10,3011,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3887,3888,3884,3870,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,941,SUCCESS,,3015.040224,192,0,0.1,0.2,0.3,263,1.4,1.5
    2698,5/26/2021 22:13,10813.029,3,701,300,10,6001,0,65535,65535,1,22.3,27151,-296,-296,100,78,10,3011,3888,606,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3888,3884,3869,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,964,SUCCESS,,3014.710266,192,0,0.1,0.2,0.3,263,1.4,1.5
    2699,5/26/2021 22:13,10817.03,3,701,300,10,6001,0,65535,65535,1,22.3,27149,-296,-296,100,78,10,3010,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3888,3884,3869,3872,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3014.381295,192,0,0.1,0.2,0.3,263,1.4,1.5
    2700,5/26/2021 22:13,10821.041,3.01,701,300,10,6001,0,65535,65535,1,22.3,27150,-296,-296,100,78,10,3010,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3887,3888,3884,3869,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,960,SUCCESS,,3014.051501,192,0,0.1,0.2,0.3,263,1.4,1.5
    2701,5/26/2021 22:13,10825.054,3.01,701,300,10,6001,0,65535,65535,1,22.2,27149,-296,-296,100,78,10,3010,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3888,3883,3869,3873,3868,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,996,SUCCESS,,3013.721544,192,0,0.1,0.2,0.3,263,1.4,1.5
    2702,5/26/2021 22:13,10829.064,3.01,701,300,10,6001,0,65535,65535,1,22.3,27149,-294,-296,100,78,10,3009,3888,618,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3888,3883,3869,3872,3868,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,960,SUCCESS,,3013.39406,192,0,0.1,0.2,0.3,263,1.4,1.5
    2703,5/26/2021 22:13,10833.067,3.01,701,300,10,6001,0,65535,65535,1,22.2,27149,-296,-296,100,78,10,3009,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3888,3883,3869,3872,3868,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,958,SUCCESS,,3013.064925,192,0,0.1,0.2,0.3,263,1.4,1.5
    2704,5/26/2021 22:13,10837.078,3.01,701,300,10,6001,0,65535,65535,1,22.2,27147,-296,-296,100,78,10,3009,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3888,3883,3869,3872,3867,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,962,SUCCESS,,3012.735131,192,0,0.1,0.2,0.3,263,1.4,1.5
    2705,5/26/2021 22:13,10841.086,3.01,701,300,10,6001,0,65535,65535,1,22.3,27145,-296,-296,100,78,10,3008,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3882,3886,3887,3883,3869,3872,3867,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,996,SUCCESS,,3012.405585,192,0,0.1,0.2,0.3,263,1.4,1.5
    2706,5/26/2021 22:13,10845.086,3.01,701,300,10,6001,0,65535,65535,1,22.3,27147,-296,-296,100,78,10,3008,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3886,3888,3883,3869,3872,3867,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,981,SUCCESS,,3012.076696,192,0,0.1,0.2,0.3,263,1.4,1.5
    2707,5/26/2021 22:13,10849.097,3.01,701,300,10,6001,0,65535,65535,1,22.3,27145,-296,-296,100,78,10,3008,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3886,3887,3883,3869,3872,3867,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.1,978,SUCCESS,,3011.746903,192,0,0.1,0.2,0.3,263,1.4,1.5
    2708,5/26/2021 22:13,10853.098,3.01,701,300,10,6001,0,65535,65535,1,22.2,27145,-296,-296,100,78,10,3007,3888,610,610,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3883,3869,3871,3867,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,21.9,988,SUCCESS,,3011.417931,192,0,0.1,0.2,0.3,263,1.4,1.5
    2709,5/26/2021 22:13,10857.113,3.02,701,300,10,6001,0,65535,65535,1,22.2,27146,-296,-296,100,78,10,3007,3888,610,610,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3883,3869,3872,3867,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,3011.087809,192,0,0.1,0.2,0.3,263,1.4,1.5
    2710,5/26/2021 22:13,10861.124,3.02,701,300,10,6001,0,65535,65535,1,22.2,27143,-296,-296,100,78,10,3007,3888,610,610,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3883,3869,3872,3867,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,942,SUCCESS,,3010.758016,192,0,0.1,0.2,0.3,263,1.4,1.5
    2711,5/26/2021 22:13,10865.137,3.02,701,300,10,6001,0,65535,65535,1,22.2,27143,-296,-296,100,78,10,3006,3888,609,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3883,3869,3871,3867,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,964,SUCCESS,,3010.428058,192,0,0.1,0.2,0.3,263,1.4,1.5
    2712,5/26/2021 22:13,10869.145,3.02,701,300,10,6001,0,65535,65535,1,22.2,27147,-296,-296,100,78,10,3006,3888,609,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3883,3869,3871,3867,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,958,SUCCESS,,3010.098511,192,0,0.1,0.2,0.3,263,1.4,1.5
    2713,5/26/2021 22:14,10873.16,3.02,701,300,10,6001,0,65535,65535,1,22.2,27142,-296,-296,100,78,10,3006,3888,609,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3883,3869,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,978,SUCCESS,,3009.768389,192,0,0.1,0.2,0.3,263,1.4,1.5
    2714,5/26/2021 22:14,10877.17,3.02,701,300,10,6001,0,65535,65535,1,22.2,27140,-298,-297,100,78,10,3005,3888,605,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3881,3885,3887,3882,3869,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,3009.43645,192,0,0.1,0.2,0.3,263,1.4,1.5
    2715,5/26/2021 22:14,10881.173,3.02,701,300,10,6001,0,65535,65535,1,22.2,27140,-296,-297,100,78,10,3005,3888,605,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3885,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,3009.107315,192,0,0.1,0.2,0.3,263,1.4,1.5
    2716,5/26/2021 22:14,10885.182,3.02,701,300,10,6001,0,65535,65535,1,22.2,27139,-296,-296,100,78,10,3005,3888,609,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3885,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,962,SUCCESS,,3008.777686,192,0,0.1,0.2,0.3,263,1.4,1.5
    2717,5/26/2021 22:14,10889.187,3.02,701,300,10,6001,0,65535,65535,1,22.2,27137,-298,-297,100,78,10,3004,3888,605,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3885,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,942,SUCCESS,,3008.446161,192,0,0.1,0.2,0.3,263,1.4,1.5
    2718,5/26/2021 22:14,10893.189,3.03,701,300,10,6001,0,65535,65535,1,22.2,27139,-296,-296,100,78,10,3004,3888,609,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3885,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,939,SUCCESS,,3008.117108,192,0,0.1,0.2,0.3,263,1.4,1.5
    2719,5/26/2021 22:14,10897.191,3.03,701,300,10,6001,0,65535,65535,1,22.2,27138,-296,-296,100,78,10,3004,3888,605,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3885,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,940,SUCCESS,,3007.788054,192,0,0.1,0.2,0.3,263,1.4,1.5
    2720,5/26/2021 22:14,10901.205,3.03,701,300,10,6001,0,65535,65535,1,22.2,27138,-296,-296,100,78,10,3003,3888,609,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3885,3886,3882,3868,3870,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,3007.458014,192,0,0.1,0.2,0.3,263,1.4,1.5
    2721,5/26/2021 22:14,10905.216,3.03,701,300,10,6001,0,65535,65535,1,22.2,27137,-298,-296,100,78,10,3003,3888,605,609,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3884,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,951,SUCCESS,,3007.125993,192,0,0.1,0.2,0.3,263,1.4,1.5
    2722,5/26/2021 22:14,10909.228,3.03,701,300,10,6001,0,65535,65535,1,22.2,27137,-298,-297,100,78,10,3003,3888,609,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3884,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,3006.793888,192,0,0.1,0.2,0.3,263,1.4,1.5
    2723,5/26/2021 22:14,10913.233,3.03,701,300,10,6001,0,65535,65535,1,22.2,27136,-298,-297,100,78,10,3002,3888,609,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3884,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,959,SUCCESS,,3006.462363,192,0,0.1,0.2,0.3,263,1.4,1.5
    2724,5/26/2021 22:14,10917.234,3.03,701,300,10,6001,0,65535,65535,1,22.2,27136,-298,-297,100,78,10,3002,3888,609,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3884,3886,3882,3867,3871,3865,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,956,SUCCESS,,3006.131169,192,0,0.1,0.2,0.3,263,1.4,1.5
    2725,5/26/2021 22:14,10921.247,3.03,701,300,10,6001,0,65535,65535,1,22.3,27135,-296,-297,100,78,10,3002,3888,609,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3884,3886,3882,3868,3871,3866,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,951,SUCCESS,,3005.801211,192,0,0.1,0.2,0.3,263,1.4,1.5
    2726,5/26/2021 22:14,10925.258,3.03,701,300,10,6001,0,65535,65535,1,22.2,27134,-294,-296,100,78,10,3001,3888,608,608,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3880,3884,3886,3882,3868,3870,3866,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,973,SUCCESS,,3005.473646,192,0,0.1,0.2,0.3,263,1.4,1.5
    2727,5/26/2021 22:14,10929.273,3.04,701,300,10,6001,0,65535,65535,1,22.3,27132,-296,-297,100,78,10,3001,3888,604,606,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3884,3885,3881,3867,3870,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,981,SUCCESS,,3005.143524,192,0,0.1,0.2,0.3,263,1.4,1.5
    2728,5/26/2021 22:15,10933.276,3.04,701,300,10,6001,0,65535,65535,1,22.3,27131,-296,-297,100,78,10,3001,3888,604,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3870,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,948,SUCCESS,,3004.814389,192,0,0.1,0.2,0.3,263,1.4,1.5
    2729,5/26/2021 22:15,10937.289,3.04,701,300,10,6001,0,65535,65535,1,22.2,27130,-296,-297,100,78,10,3000,3888,608,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3869,3865,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,952,SUCCESS,,3004.484431,192,0,0.1,0.2,0.3,263,1.4,1.5
    2730,5/26/2021 22:15,10941.294,3.04,701,300,10,6001,0,65535,65535,1,22.2,27131,-296,-297,100,78,10,3000,3888,604,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3870,3865,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,959,SUCCESS,,3004.155131,192,0,0.1,0.2,0.3,263,1.4,1.5
    2731,5/26/2021 22:15,10945.309,3.04,701,300,10,6001,0,65535,65535,1,22.3,27130,-294,-296,100,78,10,3000,3888,608,608,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3870,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,960,SUCCESS,,3003.827239,192,0,0.1,0.2,0.3,263,1.4,1.5
    2732,5/26/2021 22:15,10949.315,3.04,701,300,10,6001,0,65535,65535,1,22.3,27131,-296,-296,100,78,10,2999,3888,612,608,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3870,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,961,SUCCESS,,3003.497857,192,0,0.1,0.2,0.3,263,1.4,1.5
    2733,5/26/2021 22:15,10953.324,3.04,701,300,10,6001,0,65535,65535,1,22.3,27128,-296,-297,100,78,10,2999,3888,604,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3869,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,945,SUCCESS,,3003.168228,192,0,0.1,0.2,0.3,263,1.4,1.5
    2734,5/26/2021 22:15,10957.338,3.04,701,300,10,6001,0,65535,65535,1,22.3,27129,-296,-296,100,78,10,2999,3888,608,608,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3867,3869,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.3,962,SUCCESS,,3002.838188,192,0,0.1,0.2,0.3,263,1.4,1.5
    2735,5/26/2021 22:15,10961.34,3.04,701,300,10,6001,0,65535,65535,1,22.3,27128,-298,-297,100,78,10,2998,3888,600,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3881,3866,3870,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,965,SUCCESS,,3002.506911,192,0,0.1,0.2,0.3,263,1.4,1.5
    2736,5/26/2021 22:15,10965.351,3.05,701,300,10,6001,0,65535,65535,1,22.3,27128,-296,-297,100,78,10,2998,3888,604,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3880,3866,3869,3865,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,948,SUCCESS,,3002.177118,192,0,0.1,0.2,0.3,263,1.4,1.5
    2737,5/26/2021 22:15,10969.355,3.05,701,300,10,6001,0,65535,65535,1,22.2,27127,-296,-297,100,78,10,2998,3888,608,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3880,3866,3869,3865,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,3001.8479,192,0,0.1,0.2,0.3,263,1.4,1.5
    2738,5/26/2021 22:15,10973.367,3.05,701,300,10,6001,0,65535,65535,1,22.2,27127,-298,-296,100,78,10,2998,3888,604,608,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3885,3880,3867,3869,3864,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,966,SUCCESS,,3001.515796,192,0,0.1,0.2,0.3,263,1.4,1.5
    2739,5/26/2021 22:15,10977.376,3.05,701,300,10,6001,0,65535,65535,1,22.2,27126,-296,-296,100,78,10,2997,3888,608,608,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3884,3880,3866,3869,3864,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.3,940,SUCCESS,,3001.186167,192,0,0.1,0.2,0.3,263,1.4,1.5
    2740,5/26/2021 22:15,10981.376,3.05,701,300,10,6001,0,65535,65535,1,22.2,27125,-298,-296,100,78,10,2997,3888,608,608,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3884,3880,3866,3869,3864,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,942,SUCCESS,,3000.855056,192,0,0.1,0.2,0.3,263,1.4,1.5
    2741,5/26/2021 22:15,10985.392,3.05,701,300,10,6001,0,65535,65535,1,22.2,27125,-298,-297,100,78,10,2997,3888,599,605,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3879,3883,3884,3880,3866,3870,3864,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,21.7,961,SUCCESS,,3000.52262,192,0,0.1,0.2,0.3,263,1.4,1.5
    2742,5/26/2021 22:15,10989.4,3.05,701,300,10,6001,0,65535,65535,1,22.2,27124,-294,-297,100,78,10,2996,3888,611,605,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3883,3884,3880,3866,3869,3864,0,0,0,0,0,0,0,0,2712,22.1,22.2,-273.2,22.2,-273.2,22.2,966,SUCCESS,,3000.1953,192,0,0.1,0.2,0.3,263,1.4,1.5
    2743,5/26/2021 22:16,10993.423,3.05,701,300,10,6001,0,65535,65535,1,22.3,27123,-298,-297,100,78,10,2996,3888,603,605,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3883,3884,3880,3866,3869,3864,0,0,0,0,0,0,0,0,2712,22.1,22.3,-273.2,22.3,-273.2,22.2,939,SUCCESS,,2999.862285,192,0,0.1,0.2,0.3,263,1.4,1.5
    2744,5/26/2021 22:16,10997.437,3.05,701,300,10,6001,0,65535,65535,1,22.3,27123,-296,-297,100,78,10,2995,3888,607,605,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3883,3884,3880,3866,3870,3864,0,0,0,0,0,0,0,0,2708,22.1,22.3,-273.2,22.3,-273.2,22.2,963,SUCCESS,,2999.532245,192,0,0.1,0.2,0.3,263,1.4,1.5
    2745,5/26/2021 22:16,11001.438,3.06,701,300,10,6001,0,65535,65535,1,22.3,27122,-294,-296,100,78,10,2995,3888,611,607,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3882,3884,3880,3866,3869,3864,0,0,0,0,0,0,0,0,2707,22.1,22.3,-273.2,22.3,-273.2,22.3,941,SUCCESS,,2999.205497,192,0,0.1,0.2,0.3,263,1.4,1.5
    2746,5/26/2021 22:16,11005.455,3.06,701,300,10,6001,0,65535,65535,1,22.3,27122,-296,-297,100,78,10,2995,3888,607,605,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3882,3884,3880,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.3,-273.2,22.3,-273.2,22.2,956,SUCCESS,,2998.87521,192,0,0.1,0.2,0.3,263,1.4,1.5
    2747,5/26/2021 22:16,11009.453,3.06,701,300,10,6001,0,65535,65535,1,22.2,27123,-296,-297,100,78,10,2994,3888,607,605,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3882,3883,3880,3866,3869,3863,0,0,0,0,0,0,0,0,2707,22.1,22.3,-273.2,22.3,-273.2,22.2,939,SUCCESS,,2998.546486,192,0,0.1,0.2,0.3,263,1.4,1.5
    2748,5/26/2021 22:16,11013.469,3.06,701,300,10,6001,0,65535,65535,1,22.2,27119,-298,-296,100,78,10,2994,3888,603,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3882,3883,3879,3866,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,989,SUCCESS,,2998.21405,192,0,0.1,0.2,0.3,263,1.4,1.5
    2749,5/26/2021 22:16,11017.486,3.06,701,300,10,6001,0,65535,65535,1,22.3,27120,-296,-297,100,78,10,2994,3888,607,605,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3882,3883,3879,3865,3868,3864,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,960,SUCCESS,,2997.883764,192,0,0.1,0.2,0.3,263,1.4,1.5
    2750,5/26/2021 22:16,11021.491,3.06,701,300,10,6001,0,65535,65535,1,22.2,27119,-296,-296,100,77,10,2993,3888,607,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3878,3882,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,943,SUCCESS,,2997.554464,192,0,0.1,0.2,0.3,263,1.4,1.5
    2751,5/26/2021 22:16,11025.516,3.06,701,300,10,6001,0,65535,65535,1,22.2,27117,-294,-296,100,77,10,2993,3888,607,607,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3882,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,988,SUCCESS,,2997.225755,192,0,0.1,0.2,0.3,263,1.4,1.5
    2752,5/26/2021 22:16,11029.516,3.06,701,300,10,6001,0,65535,65535,1,22.2,27117,-296,-297,100,77,10,2993,3888,607,605,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3882,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,954,SUCCESS,,2996.896866,192,0,0.1,0.2,0.3,263,1.4,1.5
    2753,5/26/2021 22:16,11033.554,3.06,701,300,10,6001,0,65535,65535,1,22.2,27117,-294,-296,100,77,10,2992,3888,611,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3882,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,939,SUCCESS,,2996.567096,192,0,0.1,0.2,0.3,263,1.4,1.5
    2754,5/26/2021 22:16,11037.476,3.07,701,300,10,6001,0,65535,65535,1,22.2,27117,-298,-296,100,77,10,2992,3888,606,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3882,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,951,SUCCESS,,2996.242442,192,0,0.1,0.2,0.3,263,1.4,1.5
    2755,5/26/2021 22:16,11041.486,3.07,701,300,10,6001,0,65535,65535,1,22.3,27117,-296,-296,100,77,10,2992,3888,606,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3882,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.3,-273.2,22.3,-273.2,22.3,956,SUCCESS,,2995.912731,192,0,0.1,0.2,0.3,263,1.4,1.5
    2756,5/26/2021 22:16,11045.496,3.07,701,300,10,6001,0,65535,65535,1,22.2,27116,-296,-296,100,77,10,2991,3888,610,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,962,SUCCESS,,2995.58302,192,0,0.1,0.2,0.3,263,1.4,1.5
    2757,5/26/2021 22:16,11049.501,3.07,701,300,10,6001,0,65535,65535,1,22.2,27115,-298,-297,100,77,10,2991,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3883,3879,3865,3867,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,965,SUCCESS,,2995.251495,192,0,0.1,0.2,0.3,263,1.4,1.5
    2758,5/26/2021 22:17,11053.516,3.07,701,300,10,6001,0,65535,65535,1,22.2,27116,-296,-297,100,77,10,2991,3888,606,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3883,3879,3864,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,2994.921373,192,0,0.1,0.2,0.3,263,1.4,1.5
    2759,5/26/2021 22:17,11057.53,3.07,701,300,10,6001,0,65535,65535,1,22.2,27115,-298,-297,100,77,10,2991,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3883,3879,3865,3868,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,940,SUCCESS,,2994.589103,192,0,0.1,0.2,0.3,263,1.4,1.5
    2760,5/26/2021 22:17,11061.534,3.07,701,300,10,6001,0,65535,65535,1,22.2,27114,-298,-297,100,77,10,2990,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3882,3879,3865,3867,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,21.9,946,SUCCESS,,2994.25766,192,0,0.1,0.2,0.3,263,1.4,1.5
    2761,5/26/2021 22:17,11065.539,3.07,701,300,10,6001,0,65535,65535,1,22.3,27114,-294,-297,100,77,10,2990,3888,606,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3882,3879,3865,3867,3863,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.1,963,SUCCESS,,2993.930585,192,0,0.1,0.2,0.3,263,1.4,1.5
    2762,5/26/2021 22:17,11069.54,3.07,701,300,10,6001,0,65535,65535,1,22.2,27111,-298,-297,100,77,10,2990,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3877,3881,3882,3878,3864,3867,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,951,SUCCESS,,2993.599391,192,0,0.1,0.2,0.3,263,1.4,1.5
    2763,5/26/2021 22:17,11073.551,3.08,701,300,10,6001,0,65535,65535,1,22.2,27110,-296,-297,100,77,10,2989,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3878,3864,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,957,SUCCESS,,2993.269598,192,0,0.1,0.2,0.3,263,1.4,1.5
    2764,5/26/2021 22:17,11077.565,3.08,701,300,10,6001,0,65535,65535,1,22.2,27110,-296,-297,100,77,10,2989,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3878,3864,3867,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,939,SUCCESS,,2992.939558,192,0,0.1,0.2,0.3,263,1.4,1.5
    2765,5/26/2021 22:17,11081.567,3.08,701,300,10,6001,0,65535,65535,1,22.2,27110,-300,-297,100,77,10,2989,3888,606,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3881,3882,3878,3864,3867,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,969,SUCCESS,,2992.606058,192,0,0.1,0.2,0.3,263,1.4,1.5
    2766,5/26/2021 22:17,11085.58,3.08,701,300,10,6001,0,65535,65535,1,22.2,27107,-296,-297,100,77,10,2988,3888,606,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3881,3882,3878,3864,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,970,SUCCESS,,2992.2761,192,0,0.1,0.2,0.3,263,1.4,1.5
    2767,5/26/2021 22:17,11089.585,3.08,701,300,10,6001,0,65535,65535,1,22.2,27109,-298,-296,100,77,10,2988,3888,602,606,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3878,3864,3867,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,968,SUCCESS,,2991.944575,192,0,0.1,0.2,0.3,263,1.4,1.5
    2768,5/26/2021 22:17,11093.597,3.08,701,300,10,6001,0,65535,65535,1,22.2,27109,-298,-297,100,77,10,2988,3888,602,604,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3878,3864,3867,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,943,SUCCESS,,2991.612471,192,0,0.1,0.2,0.3,263,1.4,1.5
    2769,5/26/2021 22:17,11097.599,3.08,701,300,10,6001,0,65535,65535,1,22.2,27108,-296,-297,100,77,10,2987,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3877,3863,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,943,SUCCESS,,2991.283418,192,0,0.1,0.2,0.3,263,1.4,1.5
    2770,5/26/2021 22:17,11101.611,3.08,701,300,10,6001,0,65535,65535,1,22.2,27106,-296,-297,100,77,10,2987,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3878,3863,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,959,SUCCESS,,2990.953542,192,0,0.1,0.2,0.3,263,1.4,1.5
    2771,5/26/2021 22:17,11105.617,3.08,701,300,10,6001,0,65535,65535,1,22.2,27107,-296,-297,100,77,10,2987,3888,601,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3877,3863,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,963,SUCCESS,,2990.62416,192,0,0.1,0.2,0.3,263,1.4,1.5
    2772,5/26/2021 22:17,11109.631,3.09,701,300,10,6001,0,65535,65535,1,22.2,27106,-296,-297,100,77,10,2986,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,965,SUCCESS,,2990.29412,192,0,0.1,0.2,0.3,263,1.4,1.5
    2773,5/26/2021 22:18,11113.634,3.09,701,300,10,6001,0,65535,65535,1,22.2,27105,-298,-297,100,77,10,2986,3888,601,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3882,3877,3863,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,962,SUCCESS,,2989.96276,192,0,0.1,0.2,0.3,263,1.4,1.5
    2774,5/26/2021 22:18,11117.635,3.09,701,300,10,6001,0,65535,65535,1,22.2,27104,-298,-297,100,77,10,2986,3888,601,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.1,942,SUCCESS,,2989.631566,192,0,0.1,0.2,0.3,263,1.4,1.5
    2775,5/26/2021 22:18,11121.64,3.09,701,300,10,6001,0,65535,65535,1,22.2,27103,-298,-297,100,77,10,2985,3888,601,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3881,3877,3863,3866,3862,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,964,SUCCESS,,2989.300041,192,0,0.1,0.2,0.3,263,1.4,1.5
    2776,5/26/2021 22:18,11125.645,3.09,701,300,10,6001,0,65535,65535,1,22.2,27104,-298,-297,100,77,10,2985,3888,601,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,999,SUCCESS,,2988.968516,192,0,0.1,0.2,0.3,263,1.4,1.5
    2777,5/26/2021 22:18,11129.66,3.09,701,300,10,6001,0,65535,65535,1,22.2,27102,-298,-297,100,77,10,2985,3888,609,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3880,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,951,SUCCESS,,2988.636164,192,0,0.1,0.2,0.3,263,1.4,1.5
    2778,5/26/2021 22:18,11133.664,3.09,701,300,10,6001,0,65535,65535,1,22.2,27102,-298,-297,100,77,10,2984,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3876,3880,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,962,SUCCESS,,2988.304721,192,0,0.1,0.2,0.3,263,1.4,1.5
    2779,5/26/2021 22:18,11137.666,3.09,701,300,10,6001,0,65535,65535,1,22.2,27102,-298,-297,100,77,10,2984,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.1,954,SUCCESS,,2987.973445,192,0,0.1,0.2,0.3,263,1.4,1.5
    2780,5/26/2021 22:18,11141.676,3.09,701,300,10,6001,0,65535,65535,1,22.2,27102,-296,-297,100,77,10,2984,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,975,SUCCESS,,2987.643734,192,0,0.1,0.2,0.3,263,1.4,1.5
    2781,5/26/2021 22:18,11145.689,3.1,701,300,10,6001,0,65535,65535,1,22.2,27101,-298,-297,100,77,10,2983,3888,601,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3881,3877,3863,3866,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,960,SUCCESS,,2987.311546,192,0,0.1,0.2,0.3,263,1.4,1.5
    2782,5/26/2021 22:18,11149.693,3.1,701,300,10,6001,0,65535,65535,1,22.2,27100,-296,-297,100,77,10,2983,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3880,3877,3862,3865,3861,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,965,SUCCESS,,2986.982329,192,0,0.1,0.2,0.3,263,1.4,1.5
    2783,5/26/2021 22:18,11153.694,3.1,701,300,10,6001,0,65535,65535,1,22.2,27099,-296,-297,100,77,10,2983,3888,605,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3880,3876,3862,3866,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,1003,SUCCESS,,2986.653358,192,0,0.1,0.2,0.3,263,1.4,1.5
    2784,5/26/2021 22:18,11157.701,3.1,701,300,10,6001,0,65535,65535,1,22.2,27097,-298,-297,100,77,10,2982,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3880,3877,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,2986.321667,192,0,0.1,0.2,0.3,263,1.4,1.5
    2785,5/26/2021 22:18,11161.708,3.1,701,300,10,6001,0,65535,65535,1,22.2,27098,-296,-297,100,77,10,2982,3888,604,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,936,SUCCESS,,2985.992203,192,0,0.1,0.2,0.3,263,1.4,1.5
    2786,5/26/2021 22:18,11165.721,3.1,701,300,10,6001,0,65535,65535,1,22.2,27097,-300,-297,100,77,10,2982,3888,596,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3879,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,938,SUCCESS,,2985.657786,192,0,0.1,0.2,0.3,263,1.4,1.5
    2787,5/26/2021 22:18,11169.723,3.1,701,300,10,6001,0,65535,65535,1,22.2,27096,-298,-297,100,77,10,2981,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3879,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,956,SUCCESS,,2985.326509,192,0,0.1,0.2,0.3,263,1.4,1.5
    2788,5/26/2021 22:19,11173.738,3.1,701,300,10,6001,0,65535,65535,1,22.2,27096,-296,-297,100,77,10,2981,3888,604,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3875,3879,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,942,SUCCESS,,2984.996387,192,0,0.1,0.2,0.3,263,1.4,1.5
    2789,5/26/2021 22:19,11177.744,3.1,701,300,10,6001,0,65535,65535,1,22.2,27098,-298,-297,100,77,10,2981,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3879,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,982,SUCCESS,,2984.664779,192,0,0.1,0.2,0.3,263,1.4,1.5
    2790,5/26/2021 22:19,11181.747,3.11,701,300,10,6001,0,65535,65535,1,22.2,27096,-296,-297,100,77,10,2980,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3879,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,950,SUCCESS,,2984.335644,192,0,0.1,0.2,0.3,263,1.4,1.5
    2791,5/26/2021 22:19,11185.753,3.11,701,300,10,6001,0,65535,65535,1,22.2,27094,-298,-297,100,77,10,2980,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,936,SUCCESS,,2984.004036,192,0,0.1,0.2,0.3,263,1.4,1.5
    2792,5/26/2021 22:19,11189.765,3.11,701,300,10,6001,0,65535,65535,1,22.2,27096,-296,-297,100,77,10,2980,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,964,SUCCESS,,2983.67416,192,0,0.1,0.2,0.3,263,1.4,1.5
    2793,5/26/2021 22:19,11193.775,3.11,701,300,10,6001,0,65535,65535,1,22.2,27095,-296,-297,100,77,10,2979,3888,604,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3880,3876,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,2983.344449,192,0,0.1,0.2,0.3,263,1.4,1.5
    2794,5/26/2021 22:19,11197.779,3.11,701,300,10,6001,0,65535,65535,1,22.2,27093,-296,-297,100,77,10,2979,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3879,3876,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,943,SUCCESS,,2983.015231,192,0,0.1,0.2,0.3,263,1.4,1.5
    2795,5/26/2021 22:19,11201.788,3.11,701,300,10,6001,0,65535,65535,1,22.2,27098,-298,-297,100,77,10,2979,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3880,3876,3862,3864,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.1,966,SUCCESS,,2982.683375,192,0,0.1,0.2,0.3,263,1.4,1.5
    2796,5/26/2021 22:19,11205.794,3.11,701,300,10,6001,0,65535,65535,1,22.2,27093,-296,-297,100,77,10,2978,3888,604,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3879,3875,3862,3865,3860,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,2982.353993,192,0,0.1,0.2,0.3,263,1.4,1.5
    2797,5/26/2021 22:19,11209.804,3.11,701,300,10,6001,0,65535,65535,1,22.2,27091,-298,-297,100,77,10,2978,3888,600,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3879,3875,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,984,SUCCESS,,2982.022054,192,0,0.1,0.2,0.3,263,1.4,1.5
    2798,5/26/2021 22:19,11213.811,3.11,701,300,10,6001,0,65535,65535,1,22.2,27090,-296,-297,100,77,10,2978,3888,604,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3874,3878,3879,3875,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,21.7,941,SUCCESS,,2981.69259,192,0,0.1,0.2,0.3,263,1.4,1.5
    2799,5/26/2021 22:19,11217.823,3.12,701,300,10,6001,0,65535,65535,1,22.2,27090,-296,-297,100,77,10,2977,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3875,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,947,SUCCESS,,2981.362714,192,0,0.1,0.2,0.3,263,1.4,1.5
    2800,5/26/2021 22:19,11221.833,3.12,701,300,10,6001,0,65535,65535,1,22.2,27088,-298,-297,100,77,10,2977,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3875,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,989,SUCCESS,,2981.030775,192,0,0.1,0.2,0.3,263,1.4,1.5
    2801,5/26/2021 22:19,11225.838,3.12,701,300,10,6001,0,65535,65535,1,22.2,27092,-298,-297,100,77,10,2977,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3875,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.3,984,SUCCESS,,2980.69925,192,0,0.1,0.2,0.3,263,1.4,1.5
    2802,5/26/2021 22:19,11229.843,3.12,701,300,10,6001,0,65535,65535,1,22.2,27088,-298,-297,100,77,10,2976,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3875,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.3,940,SUCCESS,,2980.367725,192,0,0.1,0.2,0.3,263,1.4,1.5
    2803,5/26/2021 22:20,11233.843,3.12,701,300,10,6001,0,65535,65535,1,22.2,27088,-294,-297,100,77,10,2976,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3875,3861,3863,3859,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.1,964,SUCCESS,,2980.041059,192,0,0.1,0.2,0.3,263,1.4,1.5
    2804,5/26/2021 22:20,11237.847,3.12,701,300,10,6001,0,65535,65535,1,22.2,27087,-296,-297,100,77,10,2976,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3874,3861,3865,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,975,SUCCESS,,2979.711841,192,0,0.1,0.2,0.3,263,1.4,1.5
    2805,5/26/2021 22:20,11241.861,3.12,701,300,10,6001,0,65535,65535,1,22.2,27088,-298,-297,100,77,10,2975,3888,599,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3874,3861,3864,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,940,SUCCESS,,2979.379571,192,0,0.1,0.2,0.3,263,1.4,1.5
    2806,5/26/2021 22:20,11245.871,3.12,701,300,10,6001,0,65535,65535,1,22.2,27086,-294,-297,100,77,10,2975,3888,599,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3874,3861,3863,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.1,981,SUCCESS,,2979.052088,192,0,0.1,0.2,0.3,263,1.4,1.5
    2807,5/26/2021 22:20,11249.879,3.12,701,300,10,6001,0,65535,65535,1,22.2,27085,-298,-296,100,77,10,2975,3888,603,603,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3879,3874,3860,3864,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,968,SUCCESS,,2978.720314,192,0,0.1,0.2,0.3,263,1.4,1.5
    2808,5/26/2021 22:20,11253.886,3.13,701,300,10,6001,0,65535,65535,1,22.2,27085,-298,-297,100,77,10,2974,3888,599,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3878,3874,3860,3863,3859,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,950,SUCCESS,,2978.388624,192,0,0.1,0.2,0.3,263,1.4,1.5
    2809,5/26/2021 22:20,11257.897,3.13,701,300,10,6001,0,65535,65535,1,22.2,27084,-296,-297,100,77,10,2974,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3873,3877,3878,3874,3860,3862,3858,0,0,0,0,0,0,0,0,2707,22.1,22.2,-273.2,22.2,-273.2,22.2,935,SUCCESS,,2978.05883,192,0,0.1,0.2,0.3,263,1.4,1.5
    2810,5/26/2021 22:20,11261.907,3.13,701,300,10,6001,0,65535,65535,1,22.2,27082,-296,-297,100,77,10,2974,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3877,3878,3874,3860,3864,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,969,SUCCESS,,2977.729119,192,0,0.1,0.2,0.3,263,1.4,1.5
    2811,5/26/2021 22:20,11265.913,3.13,701,300,10,6001,0,65535,65535,1,22.2,27082,-296,-297,100,77,10,2973,3888,599,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3877,3878,3874,3860,3863,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,979,SUCCESS,,2977.399737,192,0,0.1,0.2,0.3,263,1.4,1.5
    2812,5/26/2021 22:20,11269.925,3.13,701,300,10,6001,0,65535,65535,1,22.2,27081,-296,-297,100,77,10,2973,3888,603,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3878,3874,3860,3862,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,21.7,938,SUCCESS,,2977.069861,192,0,0.1,0.2,0.3,263,1.4,1.5
    2813,5/26/2021 22:20,11273.926,3.13,701,300,10,6001,0,65535,65535,1,22.2,27081,-298,-296,100,77,10,2973,3888,599,603,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3878,3874,3860,3867,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.1,950,SUCCESS,,2976.738668,192,0,0.1,0.2,0.3,263,1.4,1.5
    2814,5/26/2021 22:20,11277.927,3.13,701,300,10,6001,0,65535,65535,1,22.2,27081,-296,-296,100,77,10,2972,3888,602,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3878,3874,3860,3863,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,952,SUCCESS,,2976.409696,192,0,0.1,0.2,0.3,263,1.4,1.5
    2815,5/26/2021 22:20,11281.933,3.13,701,300,10,6001,0,65535,65535,1,22.2,27081,-294,-296,100,77,10,2972,3888,607,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3878,3874,3860,3861,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,958,SUCCESS,,2976.08254,192,0,0.1,0.2,0.3,263,1.4,1.5
    2816,5/26/2021 22:20,11285.945,3.13,701,300,10,6001,0,65535,65535,1,22.2,27081,-298,-297,100,77,10,2972,3888,598,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3878,3873,3860,3865,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,984,SUCCESS,,2975.750435,192,0,0.1,0.2,0.3,263,1.4,1.5
    2817,5/26/2021 22:20,11289.96,3.14,701,300,10,6001,0,65535,65535,1,22.2,27081,-294,-297,100,77,10,2971,3888,602,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3878,3873,3860,3863,3858,0,0,0,0,0,0,0,0,2707,22,22.2,-273.2,22.2,-273.2,22.2,978,SUCCESS,,2975.422544,192,0,0.1,0.2,0.3,263,1.4,1.5
    2818,5/26/2021 22:21,11293.974,3.14,701,300,10,6001,0,65535,65535,1,22.2,27078,-296,-296,100,77,10,2971,3888,602,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3877,3873,3860,3862,3858,0,0,0,0,0,0,0,0,2706,22,22.2,-273.2,22.2,-273.2,22.2,965,SUCCESS,,2975.092504,192,0,0.1,0.2,0.3,263,1.4,1.5
    2819,5/26/2021 22:21,11297.978,3.14,701,300,10,6001,0,65535,65535,1,22.2,27077,-296,-296,100,77,10,2971,3888,602,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3872,3876,3877,3873,3859,3863,3857,0,0,0,0,0,0,0,0,2706,22,22.2,-273.2,22.2,-273.2,22.1,962,SUCCESS,,2974.763286,192,0,0.1,0.2,0.3,263,1.4,1.5
    2820,5/26/2021 22:21,11301.988,3.14,701,300,10,6001,0,65535,65535,1,22.2,27076,-296,-296,100,77,10,2970,3888,602,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,,0,0,3871,3876,3877,3873,3860,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,952,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2974.433575,192,0,0.1,0.2,0.3,263,1.4,1.5
    2821,5/26/2021 22:21,11306.003,3.14,701,300,10,6001,0,65535,65535,1,22.2,27076,-298,-296,100,77,10,2970,3888,598,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3876,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,941,SUCCESS,,2974.101222,192,0,0.1,0.2,0.3,263,1.4,1.5
    2822,5/26/2021 22:21,11310.016,3.14,701,300,10,6001,0,65535,65535,1,22.2,27075,-298,-296,100,77,10,2970,3888,598,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3876,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,941,SUCCESS,,2973.769035,192,0,0.1,0.2,0.3,263,1.4,1.5
    2823,5/26/2021 22:21,11314.028,3.14,701,300,10,6001,0,65535,65535,1,22.2,27075,-296,-296,100,77,10,2969,3888,602,602,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3876,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,958,SUCCESS,,2973.439159,192,0,0.1,0.2,0.3,263,1.4,1.5
    2824,5/26/2021 22:21,11318.041,3.14,701,300,10,6001,0,65535,65535,1,22.2,27075,-298,-297,100,77,10,2969,3888,598,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3876,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,968,SUCCESS,,2973.106972,192,0,0.1,0.2,0.3,263,1.4,1.5
    2825,5/26/2021 22:21,11322.055,3.15,701,300,10,6001,0,65535,65535,1,22.2,27074,-296,-297,100,77,10,2969,3888,602,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,963,SUCCESS,,2972.776932,192,0,0.1,0.2,0.3,263,1.4,1.5
    2826,5/26/2021 22:21,11326.056,3.15,701,300,10,6001,0,65535,65535,1,22.2,27074,-296,-297,100,77,10,2968,3888,602,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,1015,SUCCESS,,2972.447961,192,0,0.1,0.2,0.3,263,1.4,1.5
    2827,5/26/2021 22:21,11330.058,3.15,701,300,10,6001,0,65535,65535,1,22.2,27074,-298,-297,100,77,10,2968,3888,598,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3877,3873,3859,3861,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,952,SUCCESS,,2972.116684,192,0,0.1,0.2,0.3,263,1.4,1.5
    2828,5/26/2021 22:21,11334.06,3.15,701,300,10,6001,0,65535,65535,1,22.2,27074,-296,-297,100,77,10,2968,3888,602,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,977,SUCCESS,,2971.787631,192,0,0.1,0.2,0.3,263,1.4,1.5
    2829,5/26/2021 22:21,11338.062,3.15,701,300,10,6001,0,65535,65535,1,22.2,27074,-298,-297,100,77,10,2967,3888,601,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3877,3873,3859,3862,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,963,SUCCESS,,2971.456354,192,0,0.1,0.2,0.3,263,1.4,1.5
    2830,5/26/2021 22:21,11342.07,3.15,701,300,10,6001,0,65535,65535,1,22.2,27072,-296,-297,100,77,10,2967,3888,601,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3876,3873,3859,3861,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,2971.126808,192,0,0.1,0.2,0.3,263,1.4,1.5
    2831,5/26/2021 22:21,11346.077,3.15,701,300,10,6001,0,65535,65535,1,22.2,27071,-296,-296,100,77,10,2967,3888,606,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3871,3875,3876,3873,3859,3861,3857,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,21.7,944,SUCCESS,,2970.797343,192,0,0.1,0.2,0.3,263,1.4,1.5
    2832,5/26/2021 22:21,11350.079,3.15,701,300,10,6001,0,65535,65535,1,22.2,27068,-296,-296,100,77,10,2966,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,2970.46829,192,0,0.1,0.2,0.3,263,1.4,1.5
    2833,5/26/2021 22:22,11354.086,3.15,701,300,10,6001,0,65535,65535,1,22.2,27068,-296,-296,100,77,10,2966,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,976,SUCCESS,,2970.138825,192,0,0.1,0.2,0.3,263,1.4,1.5
    2834,5/26/2021 22:22,11358.087,3.16,701,300,10,6001,0,65535,65535,1,22.2,27067,-296,-296,100,77,10,2966,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,946,SUCCESS,,2969.809854,192,0,0.1,0.2,0.3,263,1.4,1.5
    2835,5/26/2021 22:22,11362.094,3.16,701,300,10,6001,0,65535,65535,1,22.2,27067,-300,-296,100,77,10,2965,3888,597,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,939,SUCCESS,,2969.475938,192,0,0.1,0.2,0.3,263,1.4,1.5
    2836,5/26/2021 22:22,11366.096,3.16,701,300,10,6001,0,65535,65535,1,22.2,27066,-294,-296,100,77,10,2965,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,958,SUCCESS,,2969.149108,192,0,0.1,0.2,0.3,263,1.4,1.5
    2837,5/26/2021 22:22,11370.099,3.16,701,300,10,6001,0,65535,65535,1,22.2,27067,-298,-296,100,77,10,2965,3888,597,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,949,SUCCESS,,2968.817748,192,0,0.1,0.2,0.3,263,1.4,1.5
    2838,5/26/2021 22:22,11374.106,3.16,701,300,10,6001,0,65535,65535,1,22.2,27066,-296,-296,100,77,10,2964,3888,597,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3872,3858,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,964,SUCCESS,,2968.488284,192,0,0.1,0.2,0.3,263,1.4,1.5
    2839,5/26/2021 22:22,11378.11,3.16,701,300,10,6001,0,65535,65535,1,22.2,27066,-294,-296,100,77,10,2964,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3871,3857,3862,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,970,SUCCESS,,2968.16129,192,0,0.1,0.2,0.3,263,1.4,1.5
    2840,5/26/2021 22:22,11382.112,3.16,701,300,10,6001,0,65535,65535,1,22.2,27065,-296,-296,100,77,10,2964,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3871,3857,3861,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,941,SUCCESS,,2967.832237,192,0,0.1,0.2,0.3,263,1.4,1.5
    2841,5/26/2021 22:22,11386.113,3.16,701,300,10,6001,0,65535,65535,1,22.2,27064,-296,-297,100,77,10,2963,3888,601,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3871,3857,3860,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.3,946,SUCCESS,,2967.503266,192,0,0.1,0.2,0.3,263,1.4,1.5
    2842,5/26/2021 22:22,11390.126,3.16,701,300,10,6001,0,65535,65535,1,22.2,27063,-294,-297,100,77,10,2963,3888,597,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3870,3874,3876,3871,3857,3860,3856,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,957,SUCCESS,,2967.175538,192,0,0.1,0.2,0.3,263,1.4,1.5
    2843,5/26/2021 22:22,11394.136,3.17,701,300,10,6001,0,65535,65535,1,22.2,27062,-296,-296,100,77,10,2963,3888,601,601,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,967,SUCCESS,,2966.845826,192,0,0.1,0.2,0.3,263,1.4,1.5
    2844,5/26/2021 22:22,11398.138,3.17,701,300,10,6001,0,65535,65535,1,22.2,27061,-294,-297,100,77,10,2962,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,943,SUCCESS,,2966.518996,192,0,0.1,0.2,0.3,263,1.4,1.5
    2845,5/26/2021 22:22,11402.152,3.17,701,300,10,6001,0,65535,65535,1,22.2,27061,-298,-296,100,77,10,2962,3888,596,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3861,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,960,SUCCESS,,2966.186726,192,0,0.1,0.2,0.3,263,1.4,1.5
    2846,5/26/2021 22:22,11406.159,3.17,701,300,10,6001,0,65535,65535,1,22.2,27061,-296,-297,100,77,10,2962,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3874,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,939,SUCCESS,,2965.857262,192,0,0.1,0.2,0.3,263,1.4,1.5
    2847,5/26/2021 22:22,11410.173,3.17,701,300,10,6001,0,65535,65535,1,22.2,27060,-296,-297,100,77,10,2961,3888,596,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,963,SUCCESS,,2965.527222,192,0,0.1,0.2,0.3,263,1.4,1.5
    2848,5/26/2021 22:23,11414.181,3.17,701,300,10,6001,0,65535,65535,1,22.2,27060,-298,-297,100,77,10,2961,3888,596,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,952,SUCCESS,,2965.195449,192,0,0.1,0.2,0.3,263,1.4,1.5
    2849,5/26/2021 22:23,11418.192,3.17,701,300,10,6001,0,65535,65535,1,22.2,27060,-296,-297,100,77,10,2961,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,936,SUCCESS,,2964.865655,192,0,0.1,0.2,0.3,263,1.4,1.5
    2850,5/26/2021 22:23,11422.2,3.17,701,300,10,6001,0,65535,65535,1,22.2,27060,-294,-296,100,77,10,2960,3888,600,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,978,SUCCESS,,2964.538335,192,0,0.1,0.2,0.3,263,1.4,1.5
    2851,5/26/2021 22:23,11426.201,3.17,701,300,10,6001,0,65535,65535,1,22.2,27059,-296,-297,100,77,10,2960,3888,596,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3875,3871,3857,3860,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,942,SUCCESS,,2964.209364,192,0,0.1,0.2,0.3,263,1.4,1.5
    2852,5/26/2021 22:23,11430.202,3.18,701,300,10,6001,0,65535,65535,1,22.2,27057,-296,-297,100,77,10,2960,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3873,3874,3870,3857,3859,3855,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,956,SUCCESS,,2963.880393,192,0,0.1,0.2,0.3,263,1.4,1.5
    2853,5/26/2021 22:23,11434.205,3.18,701,300,10,6001,0,65535,65535,1,22.2,27056,-298,-297,100,77,10,2959,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3869,3873,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,940,SUCCESS,,2963.549034,192,0,0.1,0.2,0.3,263,1.4,1.5
    2854,5/26/2021 22:23,11438.211,3.18,701,300,10,6001,0,65535,65535,1,22.2,27054,-296,-297,100,77,10,2959,3888,596,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3873,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,954,SUCCESS,,2963.219651,192,0,0.1,0.2,0.3,263,1.4,1.5
    2855,5/26/2021 22:23,11442.217,3.18,701,300,10,6001,0,65535,65535,1,22.2,27054,-296,-297,100,77,10,2959,3888,604,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3873,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,2962.890269,192,0,0.1,0.2,0.3,263,1.4,1.5
    2856,5/26/2021 22:23,11446.231,3.18,701,300,10,6001,0,65535,65535,1,22.2,27053,-298,-297,100,77,10,2958,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3873,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,941,SUCCESS,,2962.557999,192,0,0.1,0.2,0.3,263,1.4,1.5
    2857,5/26/2021 22:23,11450.234,3.18,701,300,10,6001,0,65535,65535,1,22.2,27054,-296,-297,100,77,10,2958,3888,600,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3873,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,939,SUCCESS,,2962.228864,192,0,0.1,0.2,0.3,263,1.4,1.5
    2858,5/26/2021 22:23,11454.239,3.18,701,300,10,6001,0,65535,65535,1,22.2,27052,-296,-296,100,77,10,2958,3888,600,600,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,972,SUCCESS,,2961.899564,192,0,0.1,0.2,0.3,263,1.4,1.5
    2859,5/26/2021 22:23,11458.252,3.18,701,300,10,6001,0,65535,65535,1,22.2,27054,-296,-297,100,77,10,2957,3888,599,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3873,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,945,SUCCESS,,2961.569606,192,0,0.1,0.2,0.3,263,1.4,1.5
    2860,5/26/2021 22:23,11462.267,3.18,701,300,10,6001,0,65535,65535,1,22.2,27053,-298,-297,100,77,10,2957,3888,595,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,940,SUCCESS,,2961.237253,192,0,0.1,0.2,0.3,263,1.4,1.5
    2861,5/26/2021 22:23,11466.277,3.19,701,300,10,6001,0,65535,65535,1,22.2,27052,-298,-297,100,77,10,2957,3888,595,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3874,3870,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,943,SUCCESS,,2960.905314,192,0,0.1,0.2,0.3,263,1.4,1.5
    2862,5/26/2021 22:23,11470.282,3.19,701,300,10,6001,0,65535,65535,1,22.2,27052,-298,-297,100,77,10,2956,3888,595,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3874,3869,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,954,SUCCESS,,2960.573789,192,0,0.1,0.2,0.3,263,1.4,1.5
    2863,5/26/2021 22:24,11474.285,3.19,701,300,10,6001,0,65535,65535,1,22.2,27053,-296,-296,100,77,10,2956,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3873,3869,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,951,SUCCESS,,2960.244654,192,0,0.1,0.2,0.3,263,1.4,1.5
    2864,5/26/2021 22:24,11478.297,3.19,701,300,10,6001,0,65535,65535,1,22.2,27050,-296,-296,100,77,10,2956,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3873,3869,3856,3859,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,945,SUCCESS,,2959.914778,192,0,0.1,0.2,0.3,263,1.4,1.5
    2865,5/26/2021 22:24,11482.302,3.19,701,300,10,6001,0,65535,65535,1,22.2,27048,-296,-296,100,77,10,2955,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3874,3869,3856,3858,3854,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,967,SUCCESS,,2959.585478,192,0,0.1,0.2,0.3,263,1.4,1.5
    2866,5/26/2021 22:24,11486.306,3.19,701,300,10,6001,0,65535,65535,1,22.2,27050,-296,-296,100,77,10,2955,3888,603,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3873,3869,3855,3858,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,994,SUCCESS,,2959.25626,192,0,0.1,0.2,0.3,263,1.4,1.5
    2867,5/26/2021 22:24,11490.309,3.19,701,300,10,6001,0,65535,65535,1,22.2,27047,-296,-296,100,77,10,2955,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3868,3872,3873,3869,3855,3858,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,944,SUCCESS,,2958.927125,192,0,0.1,0.2,0.3,263,1.4,1.5
    2868,5/26/2021 22:24,11494.318,3.19,701,300,10,6001,0,65535,65535,1,22.2,27046,-296,-296,100,76,10,2954,3888,603,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3858,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,21.9,972,SUCCESS,,2958.597496,192,0,0.1,0.2,0.3,263,1.4,1.5
    2869,5/26/2021 22:24,11498.324,3.19,701,300,10,6001,0,65535,65535,1,22.2,27048,-296,-296,100,76,10,2954,3888,603,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3858,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,963,SUCCESS,,2958.268114,192,0,0.1,0.2,0.3,263,1.4,1.5
    2870,5/26/2021 22:24,11502.327,3.2,701,300,10,6001,0,65535,65535,1,22.2,27046,-296,-296,100,76,10,2954,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3858,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,962,SUCCESS,,2957.938978,192,0,0.1,0.2,0.3,263,1.4,1.5
    2871,5/26/2021 22:24,11506.335,3.2,701,300,10,6001,0,65535,65535,1,22.2,27047,-294,-296,100,76,10,2953,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3857,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,984,SUCCESS,,2957.611658,192,0,0.1,0.2,0.3,263,1.4,1.5
    2872,5/26/2021 22:24,11510.342,3.2,701,300,10,6001,0,65535,65535,1,22.2,27049,-296,-296,100,76,10,2953,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3859,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,966,SUCCESS,,2957.282194,192,0,0.1,0.2,0.3,263,1.4,1.5
    2873,5/26/2021 22:24,11514.349,3.2,701,300,10,6001,0,65535,65535,1,22.2,27046,-296,-296,100,76,10,2953,3888,599,599,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,959,SUCCESS,,2956.952729,192,0,0.1,0.2,0.3,263,1.4,1.5
    2874,5/26/2021 22:24,11518.359,3.2,701,300,10,6001,0,65535,65535,1,22.2,27044,-294,-296,100,76,10,2952,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3867,3871,3873,3869,3855,3857,3853,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,974,SUCCESS,,2956.625246,192,0,0.1,0.2,0.3,263,1.4,1.5
    2875,5/26/2021 22:24,11522.374,3.2,701,300,10,6001,0,65535,65535,1,22.2,27043,-296,-296,100,76,10,2952,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3871,3873,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,942,SUCCESS,,2956.295124,192,0,0.1,0.2,0.3,263,1.4,1.5
    2876,5/26/2021 22:24,11526.389,3.2,701,300,10,6001,0,65535,65535,1,22.2,27042,-296,-296,100,76,10,2952,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3871,3873,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,941,SUCCESS,,2955.965001,192,0,0.1,0.2,0.3,263,1.4,1.5
    2877,5/26/2021 22:24,11530.399,3.2,701,300,10,6001,0,65535,65535,1,22.2,27041,-296,-296,100,76,10,2951,3888,602,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3871,3873,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,940,SUCCESS,,2955.63529,192,0,0.1,0.2,0.3,263,1.4,1.5
    2878,5/26/2021 22:25,11534.4,3.2,701,300,10,6001,0,65535,65535,1,22.2,27040,-298,-296,100,76,10,2951,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3871,3872,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,994,SUCCESS,,2955.304096,192,0,0.1,0.2,0.3,263,1.4,1.5
    2879,5/26/2021 22:25,11538.407,3.21,701,300,10,6001,0,65535,65535,1,22.2,27039,-296,-296,100,76,10,2951,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,962,SUCCESS,,2954.974632,192,0,0.1,0.2,0.3,263,1.4,1.5
    2880,5/26/2021 22:25,11542.419,3.21,701,300,10,6001,0,65535,65535,1,22.2,27039,-296,-296,100,76,10,2950,3888,594,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3854,3855,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,958,SUCCESS,,2954.644756,192,0,0.1,0.2,0.3,263,1.4,1.5
    2881,5/26/2021 22:25,11546.419,3.21,701,300,10,6001,0,65535,65535,1,22.2,27039,-298,-296,100,76,10,2950,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,948,SUCCESS,,2954.313645,192,0,0.1,0.2,0.3,263,1.4,1.5
    2882,5/26/2021 22:25,11550.434,3.21,701,300,10,6001,0,65535,65535,1,22.2,27039,-294,-296,100,76,10,2950,3888,602,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,981,SUCCESS,,2953.985754,192,0,0.1,0.2,0.3,263,1.4,1.5
    2883,5/26/2021 22:25,11554.445,3.21,701,300,10,6001,0,65535,65535,1,22.2,27038,-296,-296,100,76,9,2949,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,970,SUCCESS,,2953.65596,192,0,0.1,0.2,0.3,263,1.4,1.5
    2884,5/26/2021 22:25,11558.455,3.21,701,300,10,6001,0,65535,65535,1,22.2,27039,-294,-296,100,76,9,2949,3888,594,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3853,3856,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,943,SUCCESS,,2953.328477,192,0,0.1,0.2,0.3,263,1.4,1.5
    2885,5/26/2021 22:25,11562.466,3.21,701,300,10,6001,0,65535,65535,1,22.2,27039,-296,-296,100,76,9,2949,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3868,3854,3857,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,941,SUCCESS,,2952.998684,192,0,0.1,0.2,0.3,263,1.4,1.5
    2886,5/26/2021 22:25,11566.477,3.21,701,300,10,6001,0,65535,65535,1,22.2,27037,-296,-296,100,76,9,2948,3888,602,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3872,3867,3853,3852,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,984,SUCCESS,,2952.66889,192,0,0.1,0.2,0.3,263,1.4,1.5
    2887,5/26/2021 22:25,11570.483,3.21,701,300,10,6001,0,65535,65535,1,22.2,27036,-296,-296,100,76,9,2948,3888,602,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3870,3871,3867,3854,3856,3852,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,948,SUCCESS,,2952.339508,192,0,0.1,0.2,0.3,263,1.4,1.5
    2888,5/26/2021 22:25,11574.487,3.22,701,300,10,6001,0,65535,65535,1,22.2,27036,-296,-296,100,76,9,2948,3888,598,598,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3869,3871,3867,3853,3856,3851,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,935,SUCCESS,,2952.01029,192,0,0.1,0.2,0.3,263,1.4,1.5
    2889,5/26/2021 22:25,11578.495,3.22,701,300,10,6001,0,65535,65535,1,22.2,27034,-294,-296,100,76,9,2947,3888,593,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3867,3854,3855,3851,0,0,0,0,0,0,0,0,2703,22,22.1,-273.2,22.1,-273.2,22.2,945,SUCCESS,,2951.68297,192,0,0.1,0.2,0.3,263,1.4,1.5
    2890,5/26/2021 22:25,11582.509,3.22,701,300,10,6001,0,65535,65535,1,22.1,27033,-296,-296,100,76,9,2947,3888,606,597,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3866,3869,3871,3867,3853,3856,3851,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.1,953,SUCCESS,,2951.35293,192,0,0.1,0.2,0.3,263,1.4,1.5
    2891,5/26/2021 22:25,11586.525,3.22,701,300,10,6001,0,65535,65535,1,22.2,27033,-298,-296,100,76,9,2947,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3867,3853,3856,3851,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,21.5,987,SUCCESS,,2951.020495,192,0,0.1,0.2,0.3,263,1.4,1.5
    2892,5/26/2021 22:25,11590.532,3.22,701,300,10,6001,0,65535,65535,1,22.2,27033,-296,-296,100,76,9,2946,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3867,3852,3857,3851,0,0,0,0,0,0,0,0,2703,22,22.2,-273.2,22.2,-273.2,22.2,960,SUCCESS,,2950.69103,192,0,0.1,0.2,0.3,263,1.4,1.5
    2893,5/26/2021 22:26,11594.535,3.22,701,300,10,6001,0,65535,65535,1,22.1,27032,-296,-296,100,76,9,2946,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3866,3852,3856,3851,0,0,0,0,0,0,0,0,2699,22,22.2,-273.2,22.2,-273.2,22.1,953,SUCCESS,,2950.361895,192,0,0.1,0.2,0.3,263,1.4,1.5
    2894,5/26/2021 22:26,11598.539,3.22,701,300,10,6001,0,65535,65535,1,22.2,27030,-298,-296,100,76,9,2946,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3867,3852,3856,3851,0,0,0,0,0,0,0,0,2699,22,22.2,-273.2,22.2,-273.2,22.1,948,SUCCESS,,2950.030453,192,0,0.1,0.2,0.3,263,1.4,1.5
    2895,5/26/2021 22:26,11602.545,3.22,701,300,10,6001,0,65535,65535,1,22.2,27030,-296,-296,100,76,9,2945,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3866,3852,3856,3851,0,0,0,0,0,0,0,0,2699,22,22.2,-273.2,22.2,-273.2,22.2,950,SUCCESS,,2949.70107,192,0,0.1,0.2,0.3,263,1.4,1.5
    2896,5/26/2021 22:26,11606.552,3.22,701,300,10,6001,0,65535,65535,1,22.2,27030,-296,-296,100,76,9,2945,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3866,3852,3855,3851,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,989,SUCCESS,,2949.371606,192,0,0.1,0.2,0.3,263,1.4,1.5
    2897,5/26/2021 22:26,11610.565,3.23,701,300,10,6001,0,65535,65535,1,22.2,27029,-296,-296,100,76,9,2945,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3870,3866,3852,3856,3851,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,984,SUCCESS,,2949.041648,192,0,0.1,0.2,0.3,263,1.4,1.5
    2898,5/26/2021 22:26,11614.57,3.23,701,300,10,6001,0,65535,65535,1,22.2,27029,-296,-296,100,76,9,2944,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3871,3866,3852,3856,3851,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,983,SUCCESS,,2948.712348,192,0,0.1,0.2,0.3,263,1.4,1.5
    2899,5/26/2021 22:26,11618.577,3.23,701,300,10,6001,0,65535,65535,1,22.2,27027,-294,-296,100,76,9,2944,3888,601,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3869,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,964,SUCCESS,,2948.38511,192,0,0.1,0.2,0.3,263,1.4,1.5
    2900,5/26/2021 22:26,11622.584,3.23,701,300,10,6001,0,65535,65535,1,22.2,27027,-294,-296,100,76,9,2944,3888,601,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3869,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,935,SUCCESS,,2948.057871,192,0,0.1,0.2,0.3,263,1.4,1.5
    2901,5/26/2021 22:26,11626.592,3.23,701,300,10,6001,0,65535,65535,1,22.2,27028,-294,-296,100,76,9,2943,3888,601,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3865,3868,3870,3866,3852,3856,3850,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.2,947,SUCCESS,,2947.730551,192,0,0.1,0.2,0.3,263,1.4,1.5
    2902,5/26/2021 22:26,11630.604,3.23,701,300,10,6001,0,65535,65535,1,22.1,27025,-298,-296,100,76,9,2943,3888,593,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,953,SUCCESS,,2947.398447,192,0,0.1,0.2,0.3,263,1.4,1.5
    2903,5/26/2021 22:26,11634.606,3.23,701,300,10,6001,0,65535,65535,1,22.1,27025,-296,-296,100,76,9,2943,3888,597,597,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,943,SUCCESS,,2947.069394,192,0,0.1,0.2,0.3,263,1.4,1.5
    2904,5/26/2021 22:26,11638.609,3.23,701,300,10,6001,0,65535,65535,1,22.1,27025,-298,-296,100,76,9,2942,3888,592,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,947,SUCCESS,,2946.738034,192,0,0.1,0.2,0.3,263,1.4,1.5
    2905,5/26/2021 22:26,11642.611,3.23,701,300,10,6001,0,65535,65535,1,22.2,27024,-298,-296,100,76,9,2942,3888,592,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.2,968,SUCCESS,,2946.406758,192,0,0.1,0.2,0.3,263,1.4,1.5
    2906,5/26/2021 22:26,11646.613,3.24,701,300,10,6001,0,65535,65535,1,22.2,27024,-296,-296,100,76,9,2942,3888,596,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3870,3866,3852,3855,3850,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.2,935,SUCCESS,,2946.077704,192,0,0.1,0.2,0.3,263,1.4,1.5
    2907,5/26/2021 22:26,11650.621,3.24,701,300,10,6001,0,65535,65535,1,22.2,27022,-296,-296,100,76,9,2941,3888,596,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3869,3865,3851,3855,3849,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,966,SUCCESS,,2945.748158,192,0,0.1,0.2,0.3,263,1.4,1.5
    2908,5/26/2021 22:27,11654.621,3.24,701,300,10,6001,0,65535,65535,1,22.1,27019,-296,-296,100,76,9,2941,3888,600,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3868,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,944,SUCCESS,,2945.419269,192,0,0.1,0.2,0.3,263,1.4,1.5
    2909,5/26/2021 22:27,11658.628,3.24,701,300,10,6001,0,65535,65535,1,22.1,27020,-296,-296,100,76,9,2941,3888,596,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3870,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,973,SUCCESS,,2945.089804,192,0,0.1,0.2,0.3,263,1.4,1.5
    2910,5/26/2021 22:27,11662.634,3.24,701,300,10,6001,0,65535,65535,1,22.2,27020,-298,-296,100,76,9,2940,3888,592,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3864,3868,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,963,SUCCESS,,2944.758196,192,0,0.1,0.2,0.3,263,1.4,1.5
    2911,5/26/2021 22:27,11666.635,3.24,701,300,10,6001,0,65535,65535,1,22.1,27019,-298,-296,100,76,9,2940,3888,596,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3868,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,945,SUCCESS,,2944.427003,192,0,0.1,0.2,0.3,263,1.4,1.5
    2912,5/26/2021 22:27,11670.644,3.24,701,300,10,6001,0,65535,65535,1,22.1,27019,-298,-296,100,76,9,2940,3888,596,596,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3868,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,958,SUCCESS,,2944.095146,192,0,0.1,0.2,0.3,263,1.4,1.5
    2913,5/26/2021 22:27,11674.644,3.24,701,300,10,6001,0,65535,65535,1,22.1,27019,-298,-297,100,76,9,2939,3888,592,594,65535,3000,28875,00C0,0,3637,12,107,0,4,2,,8006,0,0,0,0,0,0,0,3863,3868,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,958,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2943.764035,192,0,0.1,0.2,0.3,263,1.4,1.5
    2914,5/26/2021 22:27,11678.646,3.24,701,300,10,6001,0,65535,65535,1,22.1,27019,-294,-296,100,76,9,2939,3888,592,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,965,SUCCESS,,2943.437205,192,0,0.1,0.2,0.3,263,1.4,1.5
    2915,5/26/2021 22:27,11682.659,3.25,701,300,10,6001,0,65535,65535,1,22.1,27019,-296,-296,100,76,9,2939,3888,596,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3868,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,993,SUCCESS,,2943.107248,192,0,0.1,0.2,0.3,263,1.4,1.5
    2916,5/26/2021 22:27,11686.662,3.25,701,300,10,6001,0,65535,65535,1,22.1,27017,-296,-296,100,76,9,2938,3888,596,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,949,SUCCESS,,2942.778112,192,0,0.1,0.2,0.3,263,1.4,1.5
    2917,5/26/2021 22:27,11690.673,3.25,701,300,10,6001,0,65535,65535,1,22.1,27018,-296,-296,100,76,9,2938,3888,600,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3869,3865,3851,3854,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,937,SUCCESS,,2942.448319,192,0,0.1,0.2,0.3,263,1.4,1.5
    2918,5/26/2021 22:27,11694.683,3.25,701,300,10,6001,0,65535,65535,1,22.1,27017,-298,-296,100,76,9,2938,3888,592,596,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3869,3865,3850,3854,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,965,SUCCESS,,2942.11638,192,0,0.1,0.2,0.3,263,1.4,1.5
    2919,5/26/2021 22:27,11698.692,3.25,701,300,10,6001,0,65535,65535,1,22.1,27016,-294,-296,100,76,9,2937,3888,595,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3868,3865,3850,3853,3849,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,21.5,968,SUCCESS,,2941.788978,192,0,0.1,0.2,0.3,263,1.4,1.5
    2920,5/26/2021 22:27,11702.698,3.25,701,300,10,6001,0,65535,65535,1,22.1,27015,-296,-296,100,76,9,2937,3888,591,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3868,3864,3850,3853,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,946,SUCCESS,,2941.459596,192,0,0.1,0.2,0.3,263,1.4,1.5
    2921,5/26/2021 22:27,11706.699,3.25,701,300,10,6001,0,65535,65535,1,22.1,27016,-298,-297,100,76,9,2937,3888,591,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3863,3867,3868,3864,3850,3854,3848,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,958,SUCCESS,,2941.128402,192,0,0.1,0.2,0.3,263,1.4,1.5
    2922,5/26/2021 22:27,11710.711,3.25,701,300,10,6001,0,65535,65535,1,22.1,27011,-296,-296,100,76,9,2937,3888,599,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3864,3850,3853,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,980,SUCCESS,,2940.798526,192,0,0.1,0.2,0.3,263,1.4,1.5
    2923,5/26/2021 22:28,11714.712,3.25,701,300,10,6001,0,65535,65535,1,22.1,27011,-296,-296,100,76,9,2936,3888,595,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3864,3850,3853,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,954,SUCCESS,,2940.469555,192,0,0.1,0.2,0.3,263,1.4,1.5
    2924,5/26/2021 22:28,11718.728,3.26,701,300,10,6001,0,65535,65535,1,22.1,27010,-298,-297,100,76,9,2936,3888,595,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3864,3850,3853,3848,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.2,965,SUCCESS,,2940.13712,192,0,0.1,0.2,0.3,263,1.4,1.5
    2925,5/26/2021 22:28,11722.738,3.26,701,300,10,6001,0,65535,65535,1,22.1,27010,-296,-297,100,76,9,2936,3888,599,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3864,3850,3852,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,942,SUCCESS,,2939.807409,192,0,0.1,0.2,0.3,263,1.4,1.5
    2926,5/26/2021 22:28,11726.742,3.26,701,300,10,6001,0,65535,65535,1,22.2,27011,-298,-297,100,76,9,2935,3888,595,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3864,3849,3853,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,963,SUCCESS,,2939.475966,192,0,0.1,0.2,0.3,263,1.4,1.5
    2927,5/26/2021 22:28,11730.743,3.26,701,300,10,6001,0,65535,65535,1,22.1,27011,-298,-296,100,76,9,2935,3888,595,595,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3864,3849,3853,3848,0,0,0,0,0,0,0,0,2698,22,22.2,-273.2,22.2,-273.2,22.1,983,SUCCESS,,2939.144773,192,0,0.1,0.2,0.3,263,1.4,1.5
    2928,5/26/2021 22:28,11734.752,3.26,701,300,10,6001,0,65535,65535,1,22.1,27008,-296,-296,100,76,9,2935,3888,595,595,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3868,3863,3849,3852,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,936,SUCCESS,,2938.815144,192,0,0.1,0.2,0.3,263,1.4,1.5
    2929,5/26/2021 22:28,11738.759,3.26,701,300,10,6001,0,65535,65535,1,22.1,27007,-298,-297,100,76,9,2934,3888,591,593,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3867,3863,3849,3852,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,999,SUCCESS,,2938.483453,192,0,0.1,0.2,0.3,263,1.4,1.5
    2930,5/26/2021 22:28,11742.77,3.26,701,300,10,6001,0,65535,65535,1,22.1,27008,-296,-296,100,76,9,2934,3888,595,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3867,3863,3849,3853,3848,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,951,SUCCESS,,2938.15366,192,0,0.1,0.2,0.3,263,1.4,1.5
    2931,5/26/2021 22:28,11746.781,3.26,701,300,10,6001,0,65535,65535,1,22.1,27006,-296,-296,100,76,9,2934,3888,595,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3866,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,939,SUCCESS,,2937.823866,192,0,0.1,0.2,0.3,263,1.4,1.5
    2932,5/26/2021 22:28,11750.784,3.26,701,300,10,6001,0,65535,65535,1,22.1,27006,-294,-296,100,76,9,2933,3888,595,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3866,3867,3863,3849,3852,3848,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,945,SUCCESS,,2937.496955,192,0,0.1,0.2,0.3,263,1.4,1.5
    2933,5/26/2021 22:28,11754.788,3.27,701,300,10,6001,0,65535,65535,1,22.1,27009,-294,-296,100,76,9,2933,3888,595,595,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3862,3865,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,21.4,950,SUCCESS,,2937.169961,192,0,0.1,0.2,0.3,263,1.4,1.5
    2934,5/26/2021 22:28,11758.792,3.27,701,300,10,6001,0,65535,65535,1,22.1,27005,-294,-296,100,76,9,2932,3888,598,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,991,SUCCESS,,2936.842968,192,0,0.1,0.2,0.3,263,1.4,1.5
    2935,5/26/2021 22:28,11762.796,3.27,701,300,10,6001,0,65535,65535,1,22.1,27003,-296,-296,100,76,9,2932,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,947,SUCCESS,,2936.51375,192,0,0.1,0.2,0.3,263,1.4,1.5
    2936,5/26/2021 22:28,11766.801,3.27,701,300,10,6001,0,65535,65535,1,22.1,27005,-296,-296,100,76,9,2932,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,936,SUCCESS,,2936.18445,192,0,0.1,0.2,0.3,263,1.4,1.5
    2937,5/26/2021 22:28,11770.804,3.27,701,300,10,6001,0,65535,65535,1,22.1,27002,-298,-296,100,76,9,2931,3888,590,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,994,SUCCESS,,2935.853091,192,0,0.1,0.2,0.3,263,1.4,1.5
    2938,5/26/2021 22:29,11774.806,3.27,701,300,10,6001,0,65535,65535,1,22.1,27001,-298,-296,100,76,9,2931,3888,590,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3867,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,950,SUCCESS,,2935.521814,192,0,0.1,0.2,0.3,263,1.4,1.5
    2939,5/26/2021 22:29,11778.82,3.27,701,300,10,6001,0,65535,65535,1,22.1,27003,-296,-296,100,76,9,2931,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3866,3863,3849,3852,3847,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,959,SUCCESS,,2935.191774,192,0,0.1,0.2,0.3,263,1.4,1.5
    2940,5/26/2021 22:29,11782.825,3.27,701,300,10,6001,0,65535,65535,1,22.1,27000,-296,-296,100,76,9,2930,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3861,3865,3866,3862,3848,3852,3846,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.2,950,SUCCESS,,2934.862474,192,0,0.1,0.2,0.3,263,1.4,1.5
    2941,5/26/2021 22:29,11786.835,3.27,701,300,10,6001,0,65535,65535,1,22.1,27001,-296,-296,100,76,9,2930,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3865,3866,3863,3848,3852,3846,0,0,0,0,0,0,0,0,2698,22,22.1,-273.2,22.1,-273.2,22.1,957,SUCCESS,,2934.532763,192,0,0.1,0.2,0.3,263,1.4,1.5
    2942,5/26/2021 22:29,11790.842,3.28,701,300,10,6001,0,65535,65535,1,22.1,26999,-298,-296,100,76,9,2930,3888,590,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3865,3866,3862,3848,3851,3847,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,945,SUCCESS,,2934.201073,192,0,0.1,0.2,0.3,263,1.4,1.5
    2943,5/26/2021 22:29,11794.849,3.28,701,300,10,6001,0,65535,65535,1,22.1,26998,-296,-296,100,76,9,2930,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3865,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,982,SUCCESS,,2933.871608,192,0,0.1,0.2,0.3,263,1.4,1.5
    2944,5/26/2021 22:29,11798.862,3.28,701,300,10,6001,0,65535,65535,1,22.1,26999,-296,-296,100,76,9,2929,3888,590,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3865,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,985,SUCCESS,,2933.54165,192,0,0.1,0.2,0.3,263,1.4,1.5
    2945,5/26/2021 22:29,11802.872,3.28,701,300,10,6001,0,65535,65535,1,22.1,26998,-296,-296,100,76,9,2929,3888,590,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3865,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,943,SUCCESS,,2933.211939,192,0,0.1,0.2,0.3,263,1.4,1.5
    2946,5/26/2021 22:29,11806.879,3.28,701,300,10,6001,0,65535,65535,1,22.1,26998,-296,-296,100,76,9,2929,3888,598,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3865,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22,972,SUCCESS,,2932.882475,192,0,0.1,0.2,0.3,263,1.4,1.5
    2947,5/26/2021 22:29,11810.884,3.28,701,300,10,6001,0,65535,65535,1,22.1,26997,-296,-296,100,76,9,2928,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3864,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,21.5,949,SUCCESS,,2932.553175,192,0,0.1,0.2,0.3,263,1.4,1.5
    2948,5/26/2021 22:29,11814.887,3.28,701,300,10,6001,0,65535,65535,1,22.1,26997,-296,-296,100,76,9,2928,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3864,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,949,SUCCESS,,2932.224039,192,0,0.1,0.2,0.3,263,1.4,1.5
    2949,5/26/2021 22:29,11818.892,3.28,701,300,10,6001,0,65535,65535,1,22.1,26997,-294,-296,100,76,9,2928,3888,594,594,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3864,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,936,SUCCESS,,2931.896964,192,0,0.1,0.2,0.3,263,1.4,1.5
    2950,5/26/2021 22:29,11822.896,3.28,701,300,10,6001,0,65535,65535,1,22.1,26997,-296,-296,100,76,9,2927,3888,593,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3864,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,950,SUCCESS,,2931.567746,192,0,0.1,0.2,0.3,263,1.4,1.5
    2951,5/26/2021 22:29,11826.899,3.29,701,300,10,6001,0,65535,65535,1,22.1,26997,-296,-296,100,76,9,2927,3888,597,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3864,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,968,SUCCESS,,2931.238611,192,0,0.1,0.2,0.3,263,1.4,1.5
    2952,5/26/2021 22:29,11830.911,3.29,701,300,10,6001,0,65535,65535,1,22.1,26997,-294,-296,100,76,9,2927,3888,593,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3864,3866,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,939,SUCCESS,,2930.910964,192,0,0.1,0.2,0.3,263,1.4,1.5
    2953,5/26/2021 22:30,11834.915,3.29,701,300,10,6001,0,65535,65535,1,22.1,26995,-296,-296,100,76,9,2926,3888,589,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3860,3863,3865,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,962,SUCCESS,,2930.581746,192,0,0.1,0.2,0.3,263,1.4,1.5
    2954,5/26/2021 22:30,11838.923,3.29,701,300,10,6001,0,65535,65535,1,22.1,26994,-296,-296,100,76,9,2926,3888,597,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3864,3865,3862,3848,3851,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,955,SUCCESS,,2930.2522,192,0,0.1,0.2,0.3,263,1.4,1.5
    2955,5/26/2021 22:30,11842.927,3.29,701,300,10,6001,0,65535,65535,1,22.1,26990,-296,-296,100,76,9,2926,3888,593,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3848,3850,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,954,SUCCESS,,2929.922982,192,0,0.1,0.2,0.3,263,1.4,1.5
    2956,5/26/2021 22:30,11846.938,3.29,701,300,10,6001,0,65535,65535,1,22.1,26991,-296,-297,100,76,9,2925,3888,589,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3847,3852,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,939,SUCCESS,,2929.593189,192,0,0.1,0.2,0.3,263,1.4,1.5
    2957,5/26/2021 22:30,11850.944,3.29,701,300,10,6001,0,65535,65535,1,22.1,26990,-298,-296,100,76,9,2925,3888,593,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3847,3850,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,1013,SUCCESS,,2929.261581,192,0,0.1,0.2,0.3,263,1.4,1.5
    2958,5/26/2021 22:30,11854.95,3.29,701,300,10,6001,0,65535,65535,1,22.1,26990,-298,-297,100,76,9,2925,3888,589,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3847,3850,3846,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,941,SUCCESS,,2928.929973,192,0,0.1,0.2,0.3,263,1.4,1.5
    2959,5/26/2021 22:30,11858.951,3.29,701,300,10,6001,0,65535,65535,1,22.1,26990,-298,-297,100,76,9,2924,3888,593,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3847,3852,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,974,SUCCESS,,2928.598779,192,0,0.1,0.2,0.3,263,1.4,1.5
    2960,5/26/2021 22:30,11862.963,3.3,701,300,10,6001,0,65535,65535,1,22.1,26989,-298,-297,100,76,9,2924,3888,593,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3860,3847,3850,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,946,SUCCESS,,2928.266675,192,0,0.1,0.2,0.3,263,1.4,1.5
    2961,5/26/2021 22:30,11866.965,3.3,701,300,10,6001,0,65535,65535,1,22.1,26989,-296,-297,100,76,9,2924,3888,593,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3846,3849,3845,0,0,0,0,0,0,0,0,2697,21.9,22.1,-273.2,22.1,-273.2,21.5,976,SUCCESS,,2927.937621,192,0,0.1,0.2,0.3,263,1.4,1.5
    2962,5/26/2021 22:30,11870.969,3.3,701,300,10,6001,0,65535,65535,1,22.1,26988,-296,-297,100,76,9,2923,3888,597,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3861,3846,3853,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,941,SUCCESS,,2927.608404,192,0,0.1,0.2,0.3,263,1.4,1.5
    2963,5/26/2021 22:30,11874.974,3.3,701,300,10,6001,0,65535,65535,1,22.1,26988,-296,-296,100,76,9,2923,3888,593,593,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3860,3846,3850,3845,0,0,0,0,0,0,0,0,2697,21.9,22.1,-273.2,22.1,-273.2,22.1,935,SUCCESS,,2927.279104,192,0,0.1,0.2,0.3,263,1.4,1.5
    2964,5/26/2021 22:30,11878.984,3.3,701,300,10,6001,0,65535,65535,1,22.1,26987,-298,-297,100,76,9,2923,3888,593,591,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3864,3860,3846,3849,3845,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.1,941,SUCCESS,,2926.947165,192,0,0.1,0.2,0.3,263,1.4,1.5
    2965,5/26/2021 22:30,11882.996,3.3,701,300,10,6001,0,65535,65535,1,22.1,26986,-296,-297,100,76,9,2922,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3863,3865,3860,3846,3849,3845,0,0,0,0,0,0,0,0,2695,21.9,22.1,-273.2,22.1,-273.2,22.1,947,SUCCESS,,2926.617289,192,0,0.1,0.2,0.3,263,1.4,1.5
    2966,5/26/2021 22:30,11886.996,3.3,701,300,10,6001,0,65535,65535,1,22.1,26986,-298,-297,100,76,9,2922,3888,588,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3864,3860,3846,3849,3844,0,0,0,0,0,0,0,0,2698,21.9,22.1,-273.2,22.1,-273.2,22.2,971,SUCCESS,,2926.286178,192,0,0.1,0.2,0.3,263,1.4,1.5
    2967,5/26/2021 22:30,11891,3.3,701,300,10,6001,0,65535,65535,1,22.1,26985,-296,-297,100,76,9,2922,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3859,3862,3864,3860,3846,3849,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,945,SUCCESS,,2925.95696,192,0,0.1,0.2,0.3,263,1.4,1.5
    2968,5/26/2021 22:31,11895.006,3.3,701,300,10,6001,0,65535,65535,1,22.1,26983,-296,-297,100,76,9,2921,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3864,3860,3846,3849,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22,963,SUCCESS,,2925.627578,192,0,0.1,0.2,0.3,263,1.4,1.5
    2969,5/26/2021 22:31,11899.006,3.31,701,300,10,6001,0,65535,65535,1,22.1,26983,-298,-297,100,76,9,2921,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3864,3860,3846,3849,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,958,SUCCESS,,2925.296467,192,0,0.1,0.2,0.3,263,1.4,1.5
    2970,5/26/2021 22:31,11903.013,3.31,701,300,10,6001,0,65535,65535,1,22.1,26983,-296,-297,100,76,9,2921,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3864,3860,3846,3849,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,943,SUCCESS,,2924.967003,192,0,0.1,0.2,0.3,263,1.4,1.5
    2971,5/26/2021 22:31,11907.016,3.31,701,300,10,6001,0,65535,65535,1,22.1,26983,-296,-297,100,76,9,2920,3888,596,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3864,3860,3845,3849,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,962,SUCCESS,,2924.637867,192,0,0.1,0.2,0.3,263,1.4,1.5
    2972,5/26/2021 22:31,11911.03,3.31,701,300,10,6001,0,65535,65535,1,22.1,26982,-298,-297,100,76,9,2920,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3858,3862,3863,3860,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,948,SUCCESS,,2924.305597,192,0,0.1,0.2,0.3,263,1.4,1.5
    2973,5/26/2021 22:31,11915.033,3.31,701,300,10,6001,0,65535,65535,1,22.1,26978,-296,-297,100,76,9,2920,3888,588,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3862,3863,3859,3846,3848,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,939,SUCCESS,,2923.976461,192,0,0.1,0.2,0.3,263,1.4,1.5
    2974,5/26/2021 22:31,11919.036,3.31,701,300,10,6001,0,65535,65535,1,22.1,26978,-296,-297,100,76,9,2919,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3862,3863,3859,3845,3848,3844,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,938,SUCCESS,,2923.647326,192,0,0.1,0.2,0.3,263,1.4,1.5
    2975,5/26/2021 22:31,11923.039,3.31,701,300,10,6001,0,65535,65535,1,22.1,26977,-298,-297,100,76,9,2919,3888,588,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3862,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,21.6,936,SUCCESS,,2923.315966,192,0,0.1,0.2,0.3,263,1.4,1.5
    2976,5/26/2021 22:31,11927.051,3.31,701,300,10,6001,0,65535,65535,1,22.1,26977,-296,-297,100,76,9,2919,3888,592,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3862,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,939,SUCCESS,,2922.986091,192,0,0.1,0.2,0.3,263,1.4,1.5
    2977,5/26/2021 22:31,11931.06,3.31,701,300,10,6001,0,65535,65535,1,22.1,26976,-298,-297,100,76,9,2918,3888,588,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,946,SUCCESS,,2922.654235,192,0,0.1,0.2,0.3,263,1.4,1.5
    2978,5/26/2021 22:31,11935.069,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-296,-297,100,76,9,2918,3888,591,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,995,SUCCESS,,2922.324606,192,0,0.1,0.2,0.3,263,1.4,1.5
    2979,5/26/2021 22:31,11939.073,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-298,-297,100,76,9,2918,3888,588,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,930,SUCCESS,,2921.993164,192,0,0.1,0.2,0.3,263,1.4,1.5
    2980,5/26/2021 22:31,11943.085,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-300,-297,100,76,9,2917,3888,583,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,950,SUCCESS,,2921.65883,192,0,0.1,0.2,0.3,263,1.4,1.5
    2981,5/26/2021 22:31,11947.095,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-298,-297,100,76,9,2917,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,945,SUCCESS,,2921.326891,192,0,0.1,0.2,0.3,263,1.4,1.5
    2982,5/26/2021 22:31,11951.101,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-296,-297,100,76,9,2917,3888,591,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,1011,SUCCESS,,2920.997509,192,0,0.1,0.2,0.3,263,1.4,1.5
    2983,5/26/2021 22:32,11955.113,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-298,-297,100,75,9,2916,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3863,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,1016,SUCCESS,,2920.665405,192,0,0.1,0.2,0.3,263,1.4,1.5
    2984,5/26/2021 22:32,11959.116,3.32,701,300,10,6001,0,65535,65535,1,22.1,26976,-296,-297,100,75,9,2916,3888,595,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3861,3862,3859,3845,3848,3843,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,957,SUCCESS,,2920.336269,192,0,0.1,0.2,0.3,263,1.4,1.5
    2985,5/26/2021 22:32,11963.118,3.32,701,300,10,6001,0,65535,65535,1,22.1,26973,-296,-297,100,75,9,2916,3888,591,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3857,3860,3862,3858,3844,3848,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,939,SUCCESS,,2920.007216,192,0,0.1,0.2,0.3,263,1.4,1.5
    2986,5/26/2021 22:32,11967.128,3.32,701,300,10,6001,0,65535,65535,1,22.1,26970,-298,-297,100,75,9,2915,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3858,3845,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,961,SUCCESS,,2919.675277,192,0,0.1,0.2,0.3,263,1.4,1.5
    2987,5/26/2021 22:32,11971.132,3.33,701,300,10,6001,0,65535,65535,1,22.1,26970,-296,-297,100,75,9,2915,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3861,3862,3858,3844,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,967,SUCCESS,,2919.346059,192,0,0.1,0.2,0.3,263,1.4,1.5
    2988,5/26/2021 22:32,11975.141,3.33,701,300,10,6001,0,65535,65535,1,22.1,26970,-298,-297,100,75,9,2915,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3858,3844,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,940,SUCCESS,,2919.014203,192,0,0.1,0.2,0.3,263,1.4,1.5
    2989,5/26/2021 22:32,11979.148,3.33,701,300,10,6001,0,65535,65535,1,22.1,26969,-296,-297,100,75,9,2914,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3858,3844,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,940,SUCCESS,,2918.684739,192,0,0.1,0.2,0.3,263,1.4,1.5
    2990,5/26/2021 22:32,11983.151,3.33,701,300,10,6001,0,65535,65535,1,22.1,26969,-296,-297,100,75,9,2914,3888,591,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3858,3844,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,946,SUCCESS,,2918.355603,192,0,0.1,0.2,0.3,263,1.4,1.5
    2991,5/26/2021 22:32,11987.155,3.33,701,300,10,6001,0,65535,65535,1,22.1,26969,-298,-297,100,75,9,2914,3888,587,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3858,3844,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,979,SUCCESS,,2918.024161,192,0,0.1,0.2,0.3,263,1.4,1.5
    2992,5/26/2021 22:32,11991.166,3.33,701,300,10,6001,0,65535,65535,1,22.1,26969,-296,-297,100,75,9,2913,3888,587,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3858,3844,3846,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,955,SUCCESS,,2917.694368,192,0,0.1,0.2,0.3,263,1.4,1.5
    2993,5/26/2021 22:32,11995.176,3.33,701,300,10,6001,0,65535,65535,1,22.1,26968,-298,-297,100,75,9,2913,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3857,3843,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,939,SUCCESS,,2917.362429,192,0,0.1,0.2,0.3,263,1.4,1.5
    2994,5/26/2021 22:32,11999.178,3.33,701,300,10,6001,0,65535,65535,1,22.1,26967,-298,-297,100,75,9,2913,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3857,3843,3847,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,938,SUCCESS,,2917.031152,192,0,0.1,0.2,0.3,263,1.4,1.5
    2995,5/26/2021 22:32,12003.189,3.33,701,300,10,6001,0,65535,65535,1,22.1,26966,-296,-297,100,75,9,2912,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3856,3860,3862,3857,3843,3846,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,955,SUCCESS,,2916.701359,192,0,0.1,0.2,0.3,263,1.4,1.5
    2996,5/26/2021 22:32,12007.204,3.34,701,300,10,6001,0,65535,65535,1,22.1,26966,-298,-297,100,75,9,2912,3888,586,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3860,3861,3857,3843,3846,3842,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,948,SUCCESS,,2916.369006,192,0,0.1,0.2,0.3,263,1.4,1.5
    2997,5/26/2021 22:32,12011.206,3.34,701,300,10,6001,0,65535,65535,1,22.1,26964,-298,-297,100,75,9,2912,3888,594,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3860,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,978,SUCCESS,,2916.037729,192,0,0.1,0.2,0.3,263,1.4,1.5
    2998,5/26/2021 22:33,12015.218,3.34,701,300,10,6001,0,65535,65535,1,22.1,26965,-298,-297,100,75,9,2911,3888,586,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,942,SUCCESS,,2915.705625,192,0,0.1,0.2,0.3,263,1.4,1.5
    2999,5/26/2021 22:33,12019.22,3.34,701,300,10,6001,0,65535,65535,1,22.1,26963,-298,-297,100,75,9,2911,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,945,SUCCESS,,2915.374348,192,0,0.1,0.2,0.3,263,1.4,1.5
    3000,5/26/2021 22:33,12023.223,3.34,701,300,10,6001,0,65535,65535,1,22.1,26963,-296,-297,100,75,9,2911,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,938,SUCCESS,,2915.045213,192,0,0.1,0.2,0.3,263,1.4,1.5
    3001,5/26/2021 22:33,12027.225,3.34,701,300,10,6001,0,65535,65535,1,22.1,26961,-298,-297,100,75,9,2910,3888,586,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,966,SUCCESS,,2914.713936,192,0,0.1,0.2,0.3,263,1.4,1.5
    3002,5/26/2021 22:33,12031.229,3.34,701,300,10,6001,0,65535,65535,1,22.1,26962,-294,-296,100,75,9,2910,3888,596,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22,-273.2,22,-273.2,22.1,943,SUCCESS,,2914.386943,192,0,0.1,0.2,0.3,263,1.4,1.5
    3003,5/26/2021 22:33,12035.241,3.34,701,300,10,6001,0,65535,65535,1,22.1,26962,-296,-296,100,75,9,2910,3888,594,590,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3861,3857,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,951,SUCCESS,,2914.057067,192,0,0.1,0.2,0.3,263,1.4,1.5
    3004,5/26/2021 22:33,12039.256,3.34,701,300,10,6001,0,65535,65535,1,22.1,26959,-296,-297,100,75,9,2909,3888,586,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3855,3859,3860,3856,3843,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,982,SUCCESS,,2913.726945,192,0,0.1,0.2,0.3,263,1.4,1.5
    3005,5/26/2021 22:33,12043.266,3.35,701,300,10,6001,0,65535,65535,1,22.1,26958,-298,-297,100,75,9,2909,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3859,3860,3856,3842,3846,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,954,SUCCESS,,2913.395006,192,0,0.1,0.2,0.3,263,1.4,1.5
    3006,5/26/2021 22:33,12047.281,3.35,701,300,10,6001,0,65535,65535,1,22.1,26957,-296,-297,100,75,9,2909,3888,590,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3859,3860,3856,3842,3845,3841,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,974,SUCCESS,,2913.064884,192,0,0.1,0.2,0.3,263,1.4,1.5
    3007,5/26/2021 22:33,12051.287,3.35,701,300,10,6001,0,65535,65535,1,22.1,26956,-298,-297,100,75,9,2908,3888,586,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3859,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,952,SUCCESS,,2912.733276,192,0,0.1,0.2,0.3,263,1.4,1.5
    3008,5/26/2021 22:33,12055.292,3.35,701,300,10,6001,0,65535,65535,1,22.1,26957,-296,-297,100,75,9,2908,3888,589,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3859,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,21.6,979,SUCCESS,,2912.403976,192,0,0.1,0.2,0.3,263,1.4,1.5
    3009,5/26/2021 22:33,12059.293,3.35,701,300,10,6001,0,65535,65535,1,22.1,26957,-296,-297,100,75,9,2908,3888,586,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3859,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,968,SUCCESS,,2912.075005,192,0,0.1,0.2,0.3,263,1.4,1.5
    3010,5/26/2021 22:33,12063.293,3.35,701,300,10,6001,0,65535,65535,1,22.1,26955,-296,-297,100,75,9,2907,3888,585,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,1039,SUCCESS,,2911.746116,192,0,0.1,0.2,0.3,263,1.4,1.5
    3011,5/26/2021 22:33,12067.303,3.35,701,300,10,6001,0,65535,65535,1,22.1,26955,-298,-297,100,75,9,2907,3888,589,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,959,SUCCESS,,2911.414177,192,0,0.1,0.2,0.3,263,1.4,1.5
    3012,5/26/2021 22:33,12071.308,3.35,701,300,10,6001,0,65535,65535,1,22.1,26955,-298,-297,100,75,9,2907,3888,585,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,968,SUCCESS,,2911.082652,192,0,0.1,0.2,0.3,263,1.4,1.5
    3013,5/26/2021 22:34,12075.31,3.35,701,300,10,6001,0,65535,65535,1,22.1,26955,-298,-297,100,75,9,2906,3888,585,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,951,SUCCESS,,2910.751375,192,0,0.1,0.2,0.3,263,1.4,1.5
    3014,5/26/2021 22:34,12079.317,3.36,701,300,10,6001,0,65535,65535,1,22.1,26956,-296,-297,100,75,9,2906,3888,589,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3860,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.2,937,SUCCESS,,2910.421911,192,0,0.1,0.2,0.3,263,1.4,1.5
    3015,5/26/2021 22:34,12083.318,3.36,701,300,10,6001,0,65535,65535,1,22.1,26956,-298,-297,100,75,9,2906,3888,585,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3859,3856,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,956,SUCCESS,,2910.090717,192,0,0.1,0.2,0.3,263,1.4,1.5
    3016,5/26/2021 22:34,12087.321,3.36,701,300,10,6001,0,65535,65535,1,22.1,26954,-296,-296,100,75,9,2905,3888,589,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3857,3859,3855,3842,3845,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,935,SUCCESS,,2909.761581,192,0,0.1,0.2,0.3,263,1.4,1.5
    3017,5/26/2021 22:34,12091.335,3.36,701,300,10,6001,0,65535,65535,1,22.1,26951,-296,-296,100,75,9,2905,3888,589,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3854,3858,3859,3855,3842,3844,3840,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,1004,SUCCESS,,2909.431541,192,0,0.1,0.2,0.3,263,1.4,1.5
    3018,5/26/2021 22:34,12095.339,3.36,701,300,10,6001,0,65535,65535,1,22.1,26949,-298,-296,100,75,9,2905,3888,585,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3855,3841,3845,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,946,SUCCESS,,2909.100099,192,0,0.1,0.2,0.3,263,1.4,1.5
    3019,5/26/2021 22:34,12099.343,3.36,701,300,10,6001,0,65535,65535,1,22.1,26949,-294,-296,100,75,9,2904,3888,593,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3855,3841,3844,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,957,SUCCESS,,2908.773106,192,0,0.1,0.2,0.3,263,1.4,1.5
    3020,5/26/2021 22:34,12103.344,3.36,701,300,10,6001,0,65535,65535,1,22.1,26948,-296,-296,100,75,9,2904,3888,589,589,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3855,3841,3844,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,974,SUCCESS,,2908.444135,192,0,0.1,0.2,0.3,263,1.4,1.5
    3021,5/26/2021 22:34,12107.359,3.36,701,300,10,6001,0,65535,65535,1,22.1,26948,-296,-297,100,75,9,2904,3888,589,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3854,3841,3845,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,947,SUCCESS,,2908.114013,192,0,0.1,0.2,0.3,263,1.4,1.5
    3022,5/26/2021 22:34,12111.363,3.36,701,300,10,6001,0,65535,65535,1,22.1,26948,-296,-297,100,75,9,2903,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3855,3841,3844,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,21.6,955,SUCCESS,,2907.784795,192,0,0.1,0.2,0.3,263,1.4,1.5
    3023,5/26/2021 22:34,12115.37,3.37,701,300,10,6001,0,65535,65535,1,22.1,26948,-298,-297,100,75,9,2903,3888,584,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3855,3841,3843,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,964,SUCCESS,,2907.453104,192,0,0.1,0.2,0.3,263,1.4,1.5
    3024,5/26/2021 22:34,12119.375,3.37,701,300,10,6001,0,65535,65535,1,22.1,26947,-296,-297,100,75,9,2903,3888,584,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3853,3857,3859,3855,3841,3844,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,941,SUCCESS,,2907.123804,192,0,0.1,0.2,0.3,263,1.4,1.5
    3025,5/26/2021 22:34,12123.377,3.37,701,300,10,6001,0,65535,65535,1,22.1,26947,-296,-297,100,75,9,2902,3888,584,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3857,3859,3854,3841,3844,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,947,SUCCESS,,2906.794751,192,0,0.1,0.2,0.3,263,1.4,1.5
    3026,5/26/2021 22:34,12127.38,3.37,701,300,10,6001,0,65535,65535,1,22.1,26944,-296,-297,100,75,9,2902,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3857,3859,3854,3840,3842,3839,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,953,SUCCESS,,2906.465615,192,0,0.1,0.2,0.3,263,1.4,1.5
    3027,5/26/2021 22:34,12131.387,3.37,701,300,10,6001,0,65535,65535,1,22.1,26943,-296,-297,100,75,9,2902,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3857,3859,3854,3840,3843,3839,0,0,0,0,0,0,0,0,2694,21.9,22,-273.2,22,-273.2,21.3,963,SUCCESS,,2906.136151,192,0,0.1,0.2,0.3,263,1.4,1.5
    3028,5/26/2021 22:35,12135.398,3.37,701,300,10,6001,0,65535,65535,1,22.1,26942,-298,-297,100,75,9,2901,3888,584,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3857,3858,3854,3840,3843,3838,0,0,0,0,0,0,0,0,2694,21.9,22,-273.2,22,-273.2,22.1,932,SUCCESS,,2905.804129,192,0,0.1,0.2,0.3,263,1.4,1.5
    3029,5/26/2021 22:35,12139.399,3.37,701,300,10,6001,0,65535,65535,1,22,26943,-296,-297,100,75,9,2901,3888,592,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3859,3854,3840,3843,3838,0,0,0,0,0,0,0,0,2694,21.9,22,-273.2,22,-273.2,22.1,956,SUCCESS,,2905.475158,192,0,0.1,0.2,0.3,263,1.4,1.5
    3030,5/26/2021 22:35,12143.411,3.37,701,300,10,6001,0,65535,65535,1,22,26941,-296,-296,100,75,9,2901,3888,588,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3858,3854,3840,3843,3838,0,0,0,0,0,0,0,0,2694,21.9,22,-273.2,22,-273.2,22.1,937,SUCCESS,,2905.145283,192,0,0.1,0.2,0.3,263,1.4,1.5
    3031,5/26/2021 22:35,12147.414,3.37,701,300,10,6001,0,65535,65535,1,22,26941,-296,-297,100,75,9,2900,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3858,3854,3840,3843,3838,0,0,0,0,0,0,0,0,2694,21.9,22.1,-273.2,22.1,-273.2,22.1,949,SUCCESS,,2904.816147,192,0,0.1,0.2,0.3,263,1.4,1.5
    3032,5/26/2021 22:35,12151.423,3.38,701,300,10,6001,0,65535,65535,1,22,26940,-294,-297,100,75,9,2900,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3858,3854,3840,3839,3838,0,0,0,0,0,0,0,0,2693,21.9,22,-273.2,22,-273.2,22.1,974,SUCCESS,,2904.488745,192,0,0.1,0.2,0.3,263,1.4,1.5
    3033,5/26/2021 22:35,12155.424,3.38,701,300,10,6001,0,65535,65535,1,22,26941,-298,-296,100,75,9,2900,3888,588,588,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3857,3854,3840,3843,3838,0,0,0,0,0,0,0,0,2694,21.9,22,-273.2,22,-273.2,22.1,940,SUCCESS,,2904.157551,192,0,0.1,0.2,0.3,263,1.4,1.5
    3034,5/26/2021 22:35,12159.427,3.38,701,300,10,6001,0,65535,65535,1,22,26941,-298,-297,100,75,9,2899,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3858,3854,3840,3843,3838,0,0,0,0,0,0,0,0,2693,21.9,22,-273.2,22,-273.2,22.1,968,SUCCESS,,2903.826192,192,0,0.1,0.2,0.3,263,1.4,1.5
    3035,5/26/2021 22:35,12163.433,3.38,701,300,10,6001,0,65535,65535,1,22,26941,-296,-297,100,75,9,2899,3888,588,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3858,3854,3840,3844,3838,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,993,SUCCESS,,2903.49681,192,0,0.1,0.2,0.3,263,1.4,1.5
    3036,5/26/2021 22:35,12167.448,3.38,701,300,10,6001,0,65535,65535,1,22,26938,-296,-297,100,75,9,2899,3888,584,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3852,3856,3858,3853,3840,3843,3838,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,953,SUCCESS,,2903.166688,192,0,0.1,0.2,0.3,263,1.4,1.5
    3037,5/26/2021 22:35,12171.452,3.38,701,300,10,6001,0,65535,65535,1,22,26936,-298,-297,100,75,9,2898,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3856,3857,3853,3839,3843,3838,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,957,SUCCESS,,2902.835245,192,0,0.1,0.2,0.3,263,1.4,1.5
    3038,5/26/2021 22:35,12175.467,3.38,701,300,10,6001,0,65535,65535,1,22,26936,-298,-297,100,75,9,2898,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3853,3839,3843,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,943,SUCCESS,,2902.502893,192,0,0.1,0.2,0.3,263,1.4,1.5
    3039,5/26/2021 22:35,12179.476,3.38,701,300,10,6001,0,65535,65535,1,22,26935,-298,-297,100,75,9,2898,3888,583,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3856,3857,3853,3839,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,951,SUCCESS,,2902.171036,192,0,0.1,0.2,0.3,263,1.4,1.5
    3040,5/26/2021 22:35,12183.484,3.38,701,300,10,6001,0,65535,65535,1,22,26935,-298,-297,100,75,9,2897,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3853,3839,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2901.839263,192,0,0.1,0.2,0.3,263,1.4,1.5
    3041,5/26/2021 22:35,12187.499,3.39,701,300,10,6001,0,65535,65535,1,22,26934,-298,-297,100,75,9,2897,3888,583,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3853,3839,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,21.8,945,SUCCESS,,2901.50691,192,0,0.1,0.2,0.3,263,1.4,1.5
    3042,5/26/2021 22:35,12191.514,3.39,701,300,10,6001,0,65535,65535,1,22,26934,-296,-297,100,75,9,2897,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3856,3857,3853,3839,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,943,SUCCESS,,2901.176788,192,0,0.1,0.2,0.3,263,1.4,1.5
    3043,5/26/2021 22:36,12195.519,3.39,701,300,10,6001,0,65535,65535,1,22,26934,-296,-297,100,75,9,2896,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3853,3839,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,970,SUCCESS,,2900.847488,192,0,0.1,0.2,0.3,263,1.4,1.5
    3044,5/26/2021 22:36,12199.526,3.39,701,300,10,6001,0,65535,65535,1,22,26934,-298,-297,100,75,9,2896,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3852,3838,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,984,SUCCESS,,2900.515798,192,0,0.1,0.2,0.3,263,1.4,1.5
    3045,5/26/2021 22:36,12203.535,3.39,701,300,10,6001,0,65535,65535,1,22,26932,-298,-297,100,75,9,2896,3888,591,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3852,3839,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,955,SUCCESS,,2900.183941,192,0,0.1,0.2,0.3,263,1.4,1.5
    3046,5/26/2021 22:36,12207.535,3.39,701,300,10,6001,0,65535,65535,1,22,26932,-296,-297,100,75,9,2895,3888,583,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3856,3852,3838,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,954,SUCCESS,,2899.855053,192,0,0.1,0.2,0.3,263,1.4,1.5
    3047,5/26/2021 22:36,12211.541,3.39,701,300,10,6001,0,65535,65535,1,22,26931,-298,-297,100,75,9,2895,3888,583,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3852,3838,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,931,SUCCESS,,2899.523445,192,0,0.1,0.2,0.3,263,1.4,1.5
    3048,5/26/2021 22:36,12215.557,3.39,701,300,10,6001,0,65535,65535,1,22,26931,-298,-297,100,75,9,2895,3888,591,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3851,3855,3857,3852,3838,3841,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,945,SUCCESS,,2899.191009,192,0,0.1,0.2,0.3,263,1.4,1.5
    3049,5/26/2021 22:36,12219.56,3.39,701,300,10,6001,0,65535,65535,1,22,26931,-298,-296,100,75,9,2894,3888,587,587,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3855,3857,3852,3838,3842,3837,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,959,SUCCESS,,2898.85965,192,0,0.1,0.2,0.3,263,1.4,1.5
    3050,5/26/2021 22:36,12223.571,3.4,701,300,10,6001,0,65535,65535,1,22,26928,-296,-297,100,75,9,2894,3888,591,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3854,3856,3852,3838,3842,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,954,SUCCESS,,2898.529856,192,0,0.1,0.2,0.3,263,1.4,1.5
    3051,5/26/2021 22:36,12227.584,3.4,701,300,10,6001,0,65535,65535,1,22,26927,-296,-297,100,75,9,2894,3888,587,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3854,3856,3852,3838,3841,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,953,SUCCESS,,2898.199899,192,0,0.1,0.2,0.3,263,1.4,1.5
    3052,5/26/2021 22:36,12231.586,3.4,701,300,10,6001,0,65535,65535,1,22,26927,-298,-297,100,75,9,2893,3888,582,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3854,3856,3852,3838,3841,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,964,SUCCESS,,2897.868622,192,0,0.1,0.2,0.3,263,1.4,1.5
    3053,5/26/2021 22:36,12235.588,3.4,701,300,10,6001,0,65535,65535,1,22,26927,-296,-297,100,75,9,2893,3888,586,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3854,3856,3852,3838,3841,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,932,SUCCESS,,2897.539569,192,0,0.1,0.2,0.3,263,1.4,1.5
    3054,5/26/2021 22:36,12239.601,3.4,701,300,10,6001,0,65535,65535,1,22,26925,-296,-297,100,75,9,2893,3888,586,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3854,3856,3851,3838,3841,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,934,SUCCESS,,2897.209611,192,0,0.1,0.2,0.3,263,1.4,1.5
    3055,5/26/2021 22:36,12243.611,3.4,701,300,10,6001,0,65535,65535,1,22,26926,-300,-297,100,75,9,2892,3888,578,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3854,3856,3851,3838,3841,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,935,SUCCESS,,2896.875444,192,0,0.1,0.2,0.3,263,1.4,1.5
    3056,5/26/2021 22:36,12247.623,3.4,701,300,10,6001,0,65535,65535,1,22,26927,-298,-297,100,75,9,2892,3888,582,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3854,3856,3852,3838,3841,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.2,972,SUCCESS,,2896.54334,192,0,0.1,0.2,0.3,263,1.4,1.5
    3057,5/26/2021 22:36,12251.635,3.4,701,300,10,6001,0,65535,65535,1,22,26923,-296,-297,100,75,9,2892,3888,586,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3850,3854,3856,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,932,SUCCESS,,2896.213464,192,0,0.1,0.2,0.3,263,1.4,1.5
    3058,5/26/2021 22:37,12255.642,3.4,701,300,10,6001,0,65535,65535,1,22,26922,-296,-297,100,75,9,2891,3888,586,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3854,3856,3851,3837,3840,3836,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,979,SUCCESS,,2895.884,192,0,0.1,0.2,0.3,263,1.4,1.5
    3059,5/26/2021 22:37,12259.655,3.41,701,300,10,6001,0,65535,65535,1,22,26922,-294,-296,100,75,9,2891,3888,590,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3856,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,964,SUCCESS,,2895.556271,192,0,0.1,0.2,0.3,263,1.4,1.5
    3060,5/26/2021 22:37,12263.669,3.41,701,300,10,6001,0,65535,65535,1,22,26921,-294,-296,100,75,9,2891,3888,586,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3855,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,943,SUCCESS,,2895.228461,192,0,0.1,0.2,0.3,263,1.4,1.5
    3061,5/26/2021 22:37,12267.67,3.41,701,300,10,6001,0,65535,65535,1,22,26920,-296,-297,100,75,9,2890,3888,582,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3855,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,960,SUCCESS,,2894.89949,192,0,0.1,0.2,0.3,263,1.4,1.5
    3062,5/26/2021 22:37,12271.678,3.41,701,300,10,6001,0,65535,65535,1,22,26920,-296,-296,100,75,9,2890,3888,586,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3855,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,970,SUCCESS,,2894.569944,192,0,0.1,0.2,0.3,263,1.4,1.5
    3063,5/26/2021 22:37,12275.686,3.41,701,300,10,6001,0,65535,65535,1,22,26920,-298,-297,100,75,9,2890,3888,582,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3855,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,951,SUCCESS,,2894.23817,192,0,0.1,0.2,0.3,263,1.4,1.5
    3064,5/26/2021 22:37,12279.713,3.41,701,300,10,6001,0,65535,65535,1,22,26920,-296,-296,100,75,9,2889,3888,586,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3855,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,961,SUCCESS,,2893.907061,192,0,0.1,0.2,0.3,263,1.4,1.5
    3065,5/26/2021 22:37,12283.719,3.41,701,300,10,6001,0,65535,65535,1,22,26920,-298,-296,100,75,9,2889,3888,586,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3849,3853,3854,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,942,SUCCESS,,2893.575454,192,0,0.1,0.2,0.3,263,1.4,1.5
    3066,5/26/2021 22:37,12287.734,3.41,701,300,10,6001,0,65535,65535,1,22,26919,-296,-296,100,75,9,2889,3888,586,586,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3851,3837,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,944,SUCCESS,,2893.245331,192,0,0.1,0.2,0.3,263,1.4,1.5
    3067,5/26/2021 22:37,12291.771,3.41,701,300,10,6001,0,65535,65535,1,22,26920,-294,-296,100,75,9,2888,3888,589,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3836,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,951,SUCCESS,,2892.915643,192,0,0.1,0.2,0.3,263,1.4,1.5
    3068,5/26/2021 22:37,12295.782,3.42,701,300,10,6001,0,65535,65535,1,22,26918,-296,-296,100,75,9,2888,3888,585,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3855,3851,3836,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2892.58585,192,0,0.1,0.2,0.3,263,1.4,1.5
    3069,5/26/2021 22:37,12299.797,3.42,701,300,10,6001,0,65535,65535,1,22,26915,-298,-296,100,75,9,2888,3888,585,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3836,3840,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.2,967,SUCCESS,,2892.253497,192,0,0.1,0.2,0.3,263,1.4,1.5
    3070,5/26/2021 22:37,12303.723,3.42,701,300,10,6001,0,65535,65535,1,22,26914,-294,-296,100,75,9,2887,3888,589,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3836,3839,3835,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,942,SUCCESS,,2891.932874,192,0,0.1,0.2,0.3,263,1.4,1.5
    3071,5/26/2021 22:37,12307.73,3.42,701,300,10,6001,0,65535,65535,1,22,26913,-298,-297,100,75,9,2887,3888,581,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3836,3839,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,945,SUCCESS,,2891.601183,192,0,0.1,0.2,0.3,263,1.4,1.5
    3072,5/26/2021 22:37,12311.732,3.42,701,300,10,6001,0,65535,65535,1,22,26913,-296,-297,100,75,9,2887,3888,585,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3836,3839,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,966,SUCCESS,,2891.27213,192,0,0.1,0.2,0.3,263,1.4,1.5
    3073,5/26/2021 22:38,12315.743,3.42,701,300,10,6001,0,65535,65535,1,22,26913,-298,-296,100,75,9,2886,3888,581,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3836,3839,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,946,SUCCESS,,2890.940108,192,0,0.1,0.2,0.3,263,1.4,1.5
    3074,5/26/2021 22:38,12319.749,3.42,701,300,10,6001,0,65535,65535,1,22,26912,-296,-297,100,75,9,2886,3888,581,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3850,3835,3839,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,21.9,939,SUCCESS,,2890.610726,192,0,0.1,0.2,0.3,263,1.4,1.5
    3075,5/26/2021 22:38,12323.754,3.42,701,300,10,6001,0,65535,65535,1,22,26910,-296,-296,100,75,9,2886,3888,581,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3849,3835,3839,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,935,SUCCESS,,2890.281426,192,0,0.1,0.2,0.3,263,1.4,1.5
    3076,5/26/2021 22:38,12327.765,3.42,701,300,10,6001,0,65535,65535,1,22,26912,-296,-296,100,75,9,2885,3888,585,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3852,3854,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,940,SUCCESS,,2889.951633,192,0,0.1,0.2,0.3,263,1.4,1.5
    3077,5/26/2021 22:38,12331.78,3.43,701,300,10,6001,0,65535,65535,1,22,26911,-296,-296,100,75,9,2885,3888,585,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3852,3854,3849,3835,3839,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,943,SUCCESS,,2889.62151,192,0,0.1,0.2,0.3,263,1.4,1.5
    3078,5/26/2021 22:38,12335.787,3.43,701,300,10,6001,0,65535,65535,1,22,26909,-296,-296,100,75,9,2885,3888,589,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3848,3851,3854,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,950,SUCCESS,,2889.292046,192,0,0.1,0.2,0.3,263,1.4,1.5
    3079,5/26/2021 22:38,12339.798,3.43,701,300,10,6001,0,65535,65535,1,22,26908,-296,-296,100,75,9,2884,3888,581,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2888.962253,192,0,0.1,0.2,0.3,263,1.4,1.5
    3080,5/26/2021 22:38,12343.804,3.43,701,300,10,6001,0,65535,65535,1,22,26908,-296,-296,100,75,9,2884,3888,585,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,986,SUCCESS,,2888.63287,192,0,0.1,0.2,0.3,263,1.4,1.5
    3081,5/26/2021 22:38,12347.81,3.43,701,300,10,6001,0,65535,65535,1,22,26907,-296,-296,100,75,9,2884,3888,585,585,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,950,SUCCESS,,2888.303488,192,0,0.1,0.2,0.3,263,1.4,1.5
    3082,5/26/2021 22:38,12351.821,3.43,701,300,10,6001,0,65535,65535,1,22,26907,-298,-296,100,75,9,2883,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,984,SUCCESS,,2887.971466,192,0,0.1,0.2,0.3,263,1.4,1.5
    3083,5/26/2021 22:38,12355.832,3.43,701,300,10,6001,0,65535,65535,1,22,26908,-296,-296,100,75,9,2883,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3834,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,956,SUCCESS,,2887.641673,192,0,0.1,0.2,0.3,263,1.4,1.5
    3084,5/26/2021 22:38,12359.845,3.43,701,300,10,6001,0,65535,65535,1,22,26907,-298,-296,100,75,9,2883,3888,588,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3833,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,946,SUCCESS,,2887.309486,192,0,0.1,0.2,0.3,263,1.4,1.5
    3085,5/26/2021 22:38,12363.846,3.43,701,300,10,6001,0,65535,65535,1,22,26906,-296,-296,100,75,9,2882,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3851,3852,3848,3834,3838,3833,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,955,SUCCESS,,2886.980515,192,0,0.1,0.2,0.3,263,1.4,1.5
    3086,5/26/2021 22:38,12367.848,3.44,701,300,10,6001,0,65535,65535,1,22,26906,-294,-296,100,75,9,2882,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3847,3851,3853,3849,3835,3838,3833,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,953,SUCCESS,,2886.653685,192,0,0.1,0.2,0.3,263,1.4,1.5
    3087,5/26/2021 22:38,12371.863,3.44,701,300,10,6001,0,65535,65535,1,22,26903,-298,-296,100,75,9,2882,3888,580,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3851,3852,3848,3835,3838,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,936,SUCCESS,,2886.321332,192,0,0.1,0.2,0.3,263,1.4,1.5
    3088,5/26/2021 22:39,12375.866,3.44,701,300,10,6001,0,65535,65535,1,22,26901,-298,-296,100,75,9,2881,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3851,3852,3848,3834,3838,3833,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,21.6,936,SUCCESS,,2885.989973,192,0,0.1,0.2,0.3,263,1.4,1.5
    3089,5/26/2021 22:39,12379.876,3.44,701,300,10,6001,0,65535,65535,1,22,26904,-298,-296,100,75,9,2881,3888,580,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3851,3852,3848,3834,3838,3833,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,945,SUCCESS,,2885.658034,192,0,0.1,0.2,0.3,263,1.4,1.5
    3090,5/26/2021 22:39,12383.887,3.44,701,300,10,6001,0,65535,65535,1,22,26901,-298,-296,100,75,9,2881,3888,580,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3850,3852,3848,3834,3838,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,943,SUCCESS,,2885.326012,192,0,0.1,0.2,0.3,263,1.4,1.5
    3091,5/26/2021 22:39,12387.897,3.44,701,300,10,6001,0,65535,65535,1,22,26900,-296,-296,100,75,9,2880,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3850,3852,3848,3834,3837,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,972,SUCCESS,,2884.996301,192,0,0.1,0.2,0.3,263,1.4,1.5
    3092,5/26/2021 22:39,12391.909,3.44,701,300,10,6001,0,65535,65535,1,22,26899,-298,-297,100,75,9,2880,3888,580,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3851,3852,3848,3834,3838,3832,0,0,0,0,0,0,0,0,2688,21.9,22,-273.2,22,-273.2,22.1,938,SUCCESS,,2884.664196,192,0,0.1,0.2,0.3,263,1.4,1.5
    3093,5/26/2021 22:39,12395.913,3.44,701,300,10,6001,0,65535,65535,1,22,26899,-296,-297,100,75,9,2880,3888,584,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3850,3852,3848,3834,3837,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,965,SUCCESS,,2884.334979,192,0,0.1,0.2,0.3,263,1.4,1.5
    3094,5/26/2021 22:39,12399.92,3.44,701,300,10,6001,0,65535,65535,1,22,26899,-294,-296,100,75,9,2879,3888,588,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3850,3852,3848,3834,3836,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,948,SUCCESS,,2884.00774,192,0,0.1,0.2,0.3,263,1.4,1.5
    3095,5/26/2021 22:39,12403.924,3.45,701,300,10,6001,0,65535,65535,1,22,26898,-296,-296,100,75,9,2879,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3849,3852,3848,3834,3837,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,941,SUCCESS,,2883.678523,192,0,0.1,0.2,0.3,263,1.4,1.5
    3096,5/26/2021 22:39,12407.933,3.45,701,300,10,6001,0,65535,65535,1,22,26899,-296,-296,100,75,9,2879,3888,584,584,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3850,3851,3847,3834,3837,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22,976,SUCCESS,,2883.348894,192,0,0.1,0.2,0.3,263,1.4,1.5
    3097,5/26/2021 22:39,12411.934,3.45,701,300,10,6001,0,65535,65535,1,22,26898,-296,-296,100,75,9,2878,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3846,3849,3851,3847,3834,3837,3832,0,0,0,0,0,0,0,0,2689,21.9,22,-273.2,22,-273.2,22.1,963,SUCCESS,,2883.019923,192,0,0.1,0.2,0.3,263,1.4,1.5
    3098,5/26/2021 22:39,12415.936,3.45,701,300,10,6001,0,65535,65535,1,22,26896,-298,-296,100,75,9,2878,3888,579,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3834,3838,3832,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2882.688646,192,0,0.1,0.2,0.3,263,1.4,1.5
    3099,5/26/2021 22:39,12419.941,3.45,701,300,10,6001,0,65535,65535,1,22,26895,-296,-296,100,75,9,2878,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3833,3837,3832,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,941,SUCCESS,,2882.359346,192,0,0.1,0.2,0.3,263,1.4,1.5
    3100,5/26/2021 22:39,12423.951,3.45,701,300,10,6001,0,65535,65535,1,22,26893,-296,-296,100,74,9,2877,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3833,3836,3831,0,0,0,0,0,0,0,0,2686,21.9,22,-273.2,22,-273.2,22,956,SUCCESS,,2882.029635,192,0,0.1,0.2,0.3,263,1.4,1.5
    3101,5/26/2021 22:39,12427.965,3.45,701,300,10,6001,0,65535,65535,1,22,26892,-300,-297,100,74,9,2877,3888,575,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3833,3837,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,21.9,960,SUCCESS,,2881.695135,192,0,0.1,0.2,0.3,263,1.4,1.5
    3102,5/26/2021 22:39,12431.979,3.45,701,300,10,6001,0,65535,65535,1,22,26893,-296,-296,100,74,9,2877,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3833,3836,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,984,SUCCESS,,2881.365095,192,0,0.1,0.2,0.3,263,1.4,1.5
    3103,5/26/2021 22:40,12435.982,3.45,701,300,10,6001,0,65535,65535,1,22,26892,-298,-296,100,74,9,2876,3888,579,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3833,3835,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,958,SUCCESS,,2881.033735,192,0,0.1,0.2,0.3,263,1.4,1.5
    3104,5/26/2021 22:40,12439.983,3.46,701,300,10,6001,0,65535,65535,1,22,26892,-298,-296,100,74,9,2876,3888,579,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3847,3832,3841,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,951,SUCCESS,,2880.702541,192,0,0.1,0.2,0.3,263,1.4,1.5
    3105,5/26/2021 22:40,12443.995,3.46,701,300,10,6001,0,65535,65535,1,22,26890,-296,-296,100,74,9,2876,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3846,3832,3836,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,974,SUCCESS,,2880.372666,192,0,0.1,0.2,0.3,263,1.4,1.5
    3106,5/26/2021 22:40,12448.008,3.46,701,300,10,6001,0,65535,65535,1,22,26891,-296,-296,100,74,9,2875,3888,579,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3846,3833,3835,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,971,SUCCESS,,2880.042708,192,0,0.1,0.2,0.3,263,1.4,1.5
    3107,5/26/2021 22:40,12452.008,3.46,701,300,10,6001,0,65535,65535,1,22,26890,-296,-296,100,74,9,2875,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3849,3851,3846,3833,3839,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,21.8,949,SUCCESS,,2879.713819,192,0,0.1,0.2,0.3,263,1.4,1.5
    3108,5/26/2021 22:40,12456.01,3.46,701,300,10,6001,0,65535,65535,1,22,26887,-298,-296,100,74,9,2875,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3845,3848,3850,3846,3832,3836,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,987,SUCCESS,,2879.382543,192,0,0.1,0.2,0.3,263,1.4,1.5
    3109,5/26/2021 22:40,12460.026,3.46,701,300,10,6001,0,65535,65535,1,22,26887,-298,-297,100,74,9,2875,3888,575,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3832,3835,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,949,SUCCESS,,2879.050107,192,0,0.1,0.2,0.3,263,1.4,1.5
    3110,5/26/2021 22:40,12464.028,3.46,701,300,10,6001,0,65535,65535,1,22,26887,-296,-296,100,74,9,2874,3888,587,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3832,3835,3831,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,961,SUCCESS,,2878.721054,192,0,0.1,0.2,0.3,263,1.4,1.5
    3111,5/26/2021 22:40,12468.042,3.46,701,300,10,6001,0,65535,65535,1,22,26885,-298,-296,100,74,9,2874,3888,583,583,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3832,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,955,SUCCESS,,2878.388784,192,0,0.1,0.2,0.3,263,1.4,1.5
    3112,5/26/2021 22:40,12472.043,3.46,701,300,10,6001,0,65535,65535,1,22,26885,-296,-297,100,74,9,2874,3888,583,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3832,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,941,SUCCESS,,2878.059813,192,0,0.1,0.2,0.3,263,1.4,1.5
    3113,5/26/2021 22:40,12476.054,3.47,701,300,10,6001,0,65535,65535,1,22,26885,-298,-296,100,74,9,2873,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3831,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,954,SUCCESS,,2877.727791,192,0,0.1,0.2,0.3,263,1.4,1.5
    3114,5/26/2021 22:40,12480.057,3.47,701,300,10,6001,0,65535,65535,1,22,26883,-296,-296,100,74,9,2873,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3832,3835,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,968,SUCCESS,,2877.398655,192,0,0.1,0.2,0.3,263,1.4,1.5
    3115,5/26/2021 22:40,12484.062,3.47,701,300,10,6001,0,65535,65535,1,22,26883,-294,-296,100,74,9,2873,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3848,3850,3846,3832,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,941,SUCCESS,,2877.07158,192,0,0.1,0.2,0.3,263,1.4,1.5
    3116,5/26/2021 22:40,12488.071,3.47,701,300,10,6001,0,65535,65535,1,22,26884,-294,-296,100,74,9,2872,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3844,3848,3850,3846,3832,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,969,SUCCESS,,2876.744179,192,0,0.1,0.2,0.3,263,1.4,1.5
    3117,5/26/2021 22:40,12492.071,3.47,701,300,10,6001,0,65535,65535,1,22,26881,-298,-296,100,74,9,2872,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,,0,0,0,0,0,0,3843,3848,3849,3846,3831,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,961,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2876.413068,192,0,0.1,0.2,0.3,263,1.4,1.5
    3118,5/26/2021 22:41,12496.077,3.47,701,300,10,6001,0,65535,65535,1,22,26880,-294,-296,100,74,9,2872,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3848,3849,3845,3831,3834,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,940,SUCCESS,,2876.085911,192,0,0.1,0.2,0.3,263,1.4,1.5
    3119,5/26/2021 22:41,12500.08,3.47,701,300,10,6001,0,65535,65535,1,22,26881,-296,-296,100,74,9,2871,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3848,3849,3845,3831,3835,3830,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,968,SUCCESS,,2875.756775,192,0,0.1,0.2,0.3,263,1.4,1.5
    3120,5/26/2021 22:41,12504.094,3.47,701,300,10,6001,0,65535,65535,1,22,26878,-296,-296,100,74,9,2871,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3847,3849,3845,3831,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,954,SUCCESS,,2875.426735,192,0,0.1,0.2,0.3,263,1.4,1.5
    3121,5/26/2021 22:41,12508.104,3.47,701,300,10,6001,0,65535,65535,1,22,26878,-294,-296,100,74,9,2871,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3847,3849,3845,3831,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,21.5,977,SUCCESS,,2875.099252,192,0,0.1,0.2,0.3,263,1.4,1.5
    3122,5/26/2021 22:41,12512.118,3.48,701,300,10,6001,0,65535,65535,1,22,26878,-296,-296,100,74,9,2870,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3847,3849,3845,3831,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,955,SUCCESS,,2874.769212,192,0,0.1,0.2,0.3,263,1.4,1.5
    3123,5/26/2021 22:41,12516.118,3.48,701,300,10,6001,0,65535,65535,1,22,26878,-296,-297,100,74,9,2870,3888,582,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3847,3849,3845,3831,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,932,SUCCESS,,2874.440323,192,0,0.1,0.2,0.3,263,1.4,1.5
    3124,5/26/2021 22:41,12520.127,3.48,701,300,10,6001,0,65535,65535,1,22,26878,-296,-296,100,74,9,2870,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3847,3849,3845,3831,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,942,SUCCESS,,2874.110694,192,0,0.1,0.2,0.3,263,1.4,1.5
    3125,5/26/2021 22:41,12524.128,3.48,701,300,10,6001,0,65535,65535,1,22,26877,-298,-296,100,74,9,2869,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3847,3849,3845,3830,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,969,SUCCESS,,2873.7795,192,0,0.1,0.2,0.3,263,1.4,1.5
    3126,5/26/2021 22:41,12528.134,3.48,701,300,10,6001,0,65535,65535,1,22,26876,-296,-296,100,74,9,2869,3888,582,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3847,3848,3845,3830,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,21.9,966,SUCCESS,,2873.450118,192,0,0.1,0.2,0.3,263,1.4,1.5
    3127,5/26/2021 22:41,12532.149,3.48,701,300,10,6001,0,65535,65535,1,22,26876,-298,-296,100,74,9,2869,3888,578,582,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3843,3846,3848,3845,3829,3834,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,978,SUCCESS,,2873.117765,192,0,0.1,0.2,0.3,263,1.4,1.5
    3128,5/26/2021 22:41,12536.157,3.48,701,300,10,6001,0,65535,65535,1,22,26873,-296,-296,100,74,9,2868,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3844,3830,3833,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,940,SUCCESS,,2872.788219,192,0,0.1,0.2,0.3,263,1.4,1.5
    3129,5/26/2021 22:41,12540.172,3.48,701,300,10,6001,0,65535,65535,1,22,26873,-294,-296,100,74,9,2868,3888,585,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3844,3829,3834,3829,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,955,SUCCESS,,2872.460327,192,0,0.1,0.2,0.3,263,1.4,1.5
    3130,5/26/2021 22:41,12544.177,3.48,701,300,10,6001,0,65535,65535,1,22,26872,-294,-296,100,74,9,2868,3888,585,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3844,3830,3834,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,982,SUCCESS,,2872.133252,192,0,0.1,0.2,0.3,263,1.4,1.5
    3131,5/26/2021 22:41,12548.181,3.49,701,300,10,6001,0,65535,65535,1,22,26870,-296,-296,100,74,9,2867,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3844,3829,3833,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,965,SUCCESS,,2871.804034,192,0,0.1,0.2,0.3,263,1.4,1.5
    3132,5/26/2021 22:41,12552.189,3.49,701,300,10,6001,0,65535,65535,1,22,26870,-296,-296,100,74,9,2867,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3844,3829,3833,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,954,SUCCESS,,2871.474488,192,0,0.1,0.2,0.3,263,1.4,1.5
    3133,5/26/2021 22:42,12556.199,3.49,701,300,10,6001,0,65535,65535,1,22,26870,-296,-296,100,74,9,2867,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3844,3829,3833,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,944,SUCCESS,,2871.144776,192,0,0.1,0.2,0.3,263,1.4,1.5
    3134,5/26/2021 22:42,12560.213,3.49,701,300,10,6001,0,65535,65535,1,22,26869,-296,-296,100,74,9,2866,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3843,3829,3833,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,944,SUCCESS,,2870.814736,192,0,0.1,0.2,0.3,263,1.4,1.5
    3135,5/26/2021 22:42,12564.22,3.49,701,300,10,6001,0,65535,65535,1,22,26870,-298,-296,100,74,9,2866,3888,577,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3848,3843,3829,3833,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,938,SUCCESS,,2870.483046,192,0,0.1,0.2,0.3,263,1.4,1.5
    3136,5/26/2021 22:42,12568.233,3.49,701,300,10,6001,0,65535,65535,1,22,26869,-296,-296,100,74,9,2866,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3847,3843,3829,3833,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,940,SUCCESS,,2870.153088,192,0,0.1,0.2,0.3,263,1.4,1.5
    3137,5/26/2021 22:42,12572.236,3.49,701,300,10,6001,0,65535,65535,1,22,26866,-296,-296,100,74,9,2865,3888,585,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,939,SUCCESS,,2869.823953,192,0,0.1,0.2,0.3,263,1.4,1.5
    3138,5/26/2021 22:42,12576.246,3.49,701,300,10,6001,0,65535,65535,1,22,26867,-298,-296,100,74,9,2865,3888,577,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3842,3846,3847,3843,3829,3832,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,959,SUCCESS,,2869.492014,192,0,0.1,0.2,0.3,263,1.4,1.5
    3139,5/26/2021 22:42,12580.25,3.49,701,300,10,6001,0,65535,65535,1,22,26866,-294,-296,100,74,9,2865,3888,581,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3828,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,978,SUCCESS,,2869.16502,192,0,0.1,0.2,0.3,263,1.4,1.5
    3140,5/26/2021 22:42,12584.25,3.5,701,300,10,6001,0,65535,65535,1,22,26865,-294,-296,100,74,9,2864,3888,577,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,960,SUCCESS,,2868.838354,192,0,0.1,0.2,0.3,263,1.4,1.5
    3141,5/26/2021 22:42,12588.265,3.5,701,300,10,6001,0,65535,65535,1,22,26865,-298,-296,100,74,9,2864,3888,577,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,956,SUCCESS,,2868.506001,192,0,0.1,0.2,0.3,263,1.4,1.5
    3142,5/26/2021 22:42,12592.276,3.5,701,300,10,6001,0,65535,65535,1,22,26863,-294,-296,100,74,9,2864,3888,577,581,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,961,SUCCESS,,2868.178436,192,0,0.1,0.2,0.3,263,1.4,1.5
    3143,5/26/2021 22:42,12596.278,3.5,701,300,10,6001,0,65535,65535,1,22,26864,-296,-296,100,74,9,2863,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,977,SUCCESS,,2867.849383,192,0,0.1,0.2,0.3,263,1.4,1.5
    3144,5/26/2021 22:42,12600.283,3.5,701,300,10,6001,0,65535,65535,1,22,26864,-296,-296,100,74,9,2863,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3841,3845,3847,3843,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2867.520083,192,0,0.1,0.2,0.3,263,1.4,1.5
    3145,5/26/2021 22:42,12604.29,3.5,701,300,10,6001,0,65535,65535,1,22,26862,-294,-296,100,74,9,2863,3888,584,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3845,3846,3842,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,969,SUCCESS,,2867.192844,192,0,0.1,0.2,0.3,263,1.4,1.5
    3146,5/26/2021 22:42,12608.298,3.5,701,300,10,6001,0,65535,65535,1,22,26863,-296,-296,100,74,9,2862,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3845,3846,3843,3829,3831,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,986,SUCCESS,,2866.863298,192,0,0.1,0.2,0.3,263,1.4,1.5
    3147,5/26/2021 22:42,12612.299,3.5,701,300,10,6001,0,65535,65535,1,22,26862,-294,-296,100,74,9,2862,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3845,3846,3843,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,959,SUCCESS,,2866.536549,192,0,0.1,0.2,0.3,263,1.4,1.5
    3148,5/26/2021 22:43,12616.306,3.5,701,300,10,6001,0,65535,65535,1,22,26859,-294,-296,100,74,9,2862,3888,584,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3829,3832,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,964,SUCCESS,,2866.209311,192,0,0.1,0.2,0.3,263,1.4,1.5
    3149,5/26/2021 22:43,12620.311,3.51,701,300,10,6001,0,65535,65535,1,22,26858,-298,-296,100,74,9,2861,3888,576,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3828,3831,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2865.877786,192,0,0.1,0.2,0.3,263,1.4,1.5
    3150,5/26/2021 22:43,12624.311,3.51,701,300,10,6001,0,65535,65535,1,22,26858,-296,-296,100,74,9,2861,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3845,3846,3842,3828,3831,3827,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,944,SUCCESS,,2865.548897,192,0,0.1,0.2,0.3,263,1.4,1.5
    3151,5/26/2021 22:43,12628.322,3.51,701,300,10,6001,0,65535,65535,1,22,26857,-298,-296,100,74,9,2861,3888,584,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,947,SUCCESS,,2865.216875,192,0,0.1,0.2,0.3,263,1.4,1.5
    3152,5/26/2021 22:43,12632.331,3.51,701,300,10,6001,0,65535,65535,1,22,26857,-294,-296,100,74,9,2860,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,937,SUCCESS,,2864.889474,192,0,0.1,0.2,0.3,263,1.4,1.5
    3153,5/26/2021 22:43,12636.339,3.51,701,300,10,6001,0,65535,65535,1,22,26857,-294,-296,100,74,9,2860,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,960,SUCCESS,,2864.562154,192,0,0.1,0.2,0.3,263,1.4,1.5
    3154,5/26/2021 22:43,12640.348,3.51,701,300,10,6001,0,65535,65535,1,22,26857,-296,-296,100,74,9,2860,3888,576,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,967,SUCCESS,,2864.232525,192,0,0.1,0.2,0.3,263,1.4,1.5
    3155,5/26/2021 22:43,12644.356,3.51,701,300,10,6001,0,65535,65535,1,22,26856,-296,-296,100,74,9,2859,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3844,3846,3842,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,961,SUCCESS,,2863.902978,192,0,0.1,0.2,0.3,263,1.4,1.5
    3156,5/26/2021 22:43,12648.371,3.51,701,300,10,6001,0,65535,65535,1,22,26856,-296,-296,100,74,9,2859,3888,583,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3840,3843,3846,3842,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,977,SUCCESS,,2863.572856,192,0,0.1,0.2,0.3,263,1.4,1.5
    3157,5/26/2021 22:43,12652.38,3.51,701,300,10,6001,0,65535,65535,1,22,26853,-298,-296,100,74,9,2859,3888,580,580,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3828,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,966,SUCCESS,,2863.241,192,0,0.1,0.2,0.3,263,1.4,1.5
    3158,5/26/2021 22:43,12656.38,3.52,701,300,10,6001,0,65535,65535,1,22,26852,-296,-296,100,74,9,2858,3888,579,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3827,3830,3825,0,0,0,0,0,0,0,0,2681,21.9,22,-273.2,22,-273.2,22,934,SUCCESS,,2862.912111,192,0,0.1,0.2,0.3,263,1.4,1.5
    3159,5/26/2021 22:43,12660.395,3.52,701,300,10,6001,0,65535,65535,1,22,26852,-294,-296,100,74,9,2858,3888,579,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3827,3831,3826,0,0,0,0,0,0,0,0,2681,21.9,22,-273.2,22,-273.2,21.7,968,SUCCESS,,2862.584219,192,0,0.1,0.2,0.3,263,1.4,1.5
    3160,5/26/2021 22:43,12664.408,3.52,701,300,10,6001,0,65535,65535,1,22,26851,-296,-296,100,74,9,2858,3888,575,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3827,3831,3826,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22.1,939,SUCCESS,,2862.254261,192,0,0.1,0.2,0.3,263,1.4,1.5
    3161,5/26/2021 22:43,12668.418,3.52,701,300,10,6001,0,65535,65535,1,22,26850,-296,-296,100,74,9,2857,3888,579,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3827,3830,3825,0,0,0,0,0,0,0,0,2685,21.9,22,-273.2,22,-273.2,22,949,SUCCESS,,2861.92455,192,0,0.1,0.2,0.3,263,1.4,1.5
    3162,5/26/2021 22:43,12672.43,3.52,701,300,10,6001,0,65535,65535,1,22,26849,-298,-296,100,74,9,2857,3888,579,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3827,3830,3825,0,0,0,0,0,0,0,0,2684,21.9,22,-273.2,22,-273.2,22,955,SUCCESS,,2861.592446,192,0,0.1,0.2,0.3,263,1.4,1.5
    3163,5/26/2021 22:44,12676.437,3.52,701,300,10,6001,0,65535,65535,1,22,26849,-294,-296,100,74,9,2857,3888,579,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3840,3827,3830,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,942,SUCCESS,,2861.265208,192,0,0.1,0.2,0.3,263,1.4,1.5
    3164,5/26/2021 22:44,12680.445,3.52,701,300,10,6001,0,65535,65535,1,22,26848,-296,-296,100,74,9,2856,3888,583,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3841,3827,3830,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,994,SUCCESS,,2860.935661,192,0,0.1,0.2,0.3,263,1.4,1.5
    3165,5/26/2021 22:44,12684.449,3.52,701,300,10,6001,0,65535,65535,1,22,26850,-298,-296,100,74,9,2856,3888,575,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3839,3843,3845,3840,3827,3830,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,943,SUCCESS,,2860.604219,192,0,0.1,0.2,0.3,263,1.4,1.5
    3166,5/26/2021 22:44,12688.461,3.52,701,300,10,6001,0,65535,65535,1,22,26849,-296,-296,100,74,9,2856,3888,579,579,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3843,3845,3840,3826,3830,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,946,SUCCESS,,2860.274343,192,0,0.1,0.2,0.3,263,1.4,1.5
    3167,5/26/2021 22:44,12692.464,3.53,701,300,10,6001,0,65535,65535,1,22,26846,-300,-297,100,74,9,2855,3888,571,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3843,3845,3840,3826,3830,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,960,SUCCESS,,2859.94076,192,0,0.1,0.2,0.3,263,1.4,1.5
    3168,5/26/2021 22:44,12696.476,3.53,701,300,10,6001,0,65535,65535,1,22,26845,-296,-297,100,74,9,2855,3888,579,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3843,3844,3840,3826,3829,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,980,SUCCESS,,2859.610884,192,0,0.1,0.2,0.3,263,1.4,1.5
    3169,5/26/2021 22:44,12700.483,3.53,701,300,10,6001,0,65535,65535,1,22,26844,-296,-297,100,74,9,2855,3888,579,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3842,3844,3840,3826,3830,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,957,SUCCESS,,2859.28142,192,0,0.1,0.2,0.3,263,1.4,1.5
    3170,5/26/2021 22:44,12704.486,3.53,701,300,10,6001,0,65535,65535,1,22,26844,-298,-297,100,74,9,2854,3888,575,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3842,3844,3840,3826,3829,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,946,SUCCESS,,2858.95006,192,0,0.1,0.2,0.3,263,1.4,1.5
    3171,5/26/2021 22:44,12708.494,3.53,701,300,10,6001,0,65535,65535,1,22,26844,-296,-297,100,74,9,2854,3888,579,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3842,3844,3840,3826,3829,3825,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,944,SUCCESS,,2858.620514,192,0,0.1,0.2,0.3,263,1.4,1.5
    3172,5/26/2021 22:44,12712.509,3.53,701,300,10,6001,0,65535,65535,1,22,26843,-296,-297,100,74,9,2854,3888,579,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3842,3844,3840,3826,3830,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,977,SUCCESS,,2858.290391,192,0,0.1,0.2,0.3,263,1.4,1.5
    3173,5/26/2021 22:44,12716.52,3.53,701,300,10,6001,0,65535,65535,1,22,26843,-298,-297,100,74,9,2853,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3838,3842,3844,3840,3826,3829,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,21.4,994,SUCCESS,,2857.95837,192,0,0.1,0.2,0.3,263,1.4,1.5
    3174,5/26/2021 22:44,12720.528,3.53,701,300,10,6001,0,65535,65535,1,22,26842,-296,-297,100,74,9,2853,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3842,3843,3840,3826,3829,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,958,SUCCESS,,2857.628823,192,0,0.1,0.2,0.3,263,1.4,1.5
    3175,5/26/2021 22:44,12724.539,3.53,701,300,10,6001,0,65535,65535,1,22,26842,-298,-297,100,74,9,2853,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3842,3844,3840,3826,3830,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,954,SUCCESS,,2857.296801,192,0,0.1,0.2,0.3,263,1.4,1.5
    3176,5/26/2021 22:44,12728.546,3.54,701,300,10,6001,0,65535,65535,1,22,26840,-296,-297,100,74,9,2852,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3842,3843,3840,3826,3829,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,942,SUCCESS,,2856.967337,192,0,0.1,0.2,0.3,263,1.4,1.5
    3177,5/26/2021 22:44,12732.556,3.54,701,300,10,6001,0,65535,65535,1,22,26838,-296,-297,100,74,9,2852,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3842,3843,3839,3825,3828,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,962,SUCCESS,,2856.637626,192,0,0.1,0.2,0.3,263,1.4,1.5
    3178,5/26/2021 22:45,12736.567,3.54,701,300,10,6001,0,65535,65535,1,22,26838,-298,-297,100,74,9,2852,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3842,3843,3839,3826,3833,3824,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,957,SUCCESS,,2856.305604,192,0,0.1,0.2,0.3,263,1.4,1.5
    3179,5/26/2021 22:45,12740.567,3.54,701,300,10,6001,0,65535,65535,1,22,26838,-296,-297,100,74,9,2851,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3842,3843,3839,3825,3828,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,972,SUCCESS,,2855.976715,192,0,0.1,0.2,0.3,263,1.4,1.5
    3180,5/26/2021 22:45,12744.574,3.54,701,300,10,6001,0,65535,65535,1,22,26836,-294,-296,100,74,9,2851,3888,578,578,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3841,3843,3839,3825,3827,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,986,SUCCESS,,2855.649477,192,0,0.1,0.2,0.3,263,1.4,1.5
    3181,5/26/2021 22:45,12748.577,3.54,701,300,10,6001,0,65535,65535,1,22,26836,-296,-297,100,74,9,2851,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3841,3843,3839,3825,3829,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,966,SUCCESS,,2855.320341,192,0,0.1,0.2,0.3,263,1.4,1.5
    3182,5/26/2021 22:45,12752.58,3.54,701,300,10,6001,0,65535,65535,1,22,26836,-296,-297,100,74,9,2850,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3841,3843,3838,3825,3828,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,937,SUCCESS,,2854.991206,192,0,0.1,0.2,0.3,263,1.4,1.5
    3183,5/26/2021 22:45,12756.592,3.54,701,300,10,6001,0,65535,65535,1,22,26835,-296,-297,100,74,9,2850,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3841,3843,3839,3825,3827,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,942,SUCCESS,,2854.66133,192,0,0.1,0.2,0.3,263,1.4,1.5
    3184,5/26/2021 22:45,12760.594,3.54,701,300,10,6001,0,65535,65535,1,22,26833,-298,-297,100,74,9,2850,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3837,3840,3842,3838,3825,3831,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,963,SUCCESS,,2854.330054,192,0,0.1,0.2,0.3,263,1.4,1.5
    3185,5/26/2021 22:45,12764.595,3.55,701,300,10,6001,0,65535,65535,1,22,26832,-298,-297,100,74,9,2849,3888,578,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3825,3828,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,986,SUCCESS,,2853.99886,192,0,0.1,0.2,0.3,263,1.4,1.5
    3186,5/26/2021 22:45,12768.603,3.55,701,300,10,6001,0,65535,65535,1,22,26832,-298,-297,100,74,9,2849,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3825,3828,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,978,SUCCESS,,2853.667086,192,0,0.1,0.2,0.3,263,1.4,1.5
    3187,5/26/2021 22:45,12772.608,3.55,701,300,10,6001,0,65535,65535,1,22,26832,-298,-297,100,74,9,2849,3888,574,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3825,3828,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,942,SUCCESS,,2853.335561,192,0,0.1,0.2,0.3,263,1.4,1.5
    3188,5/26/2021 22:45,12776.621,3.55,701,300,10,6001,0,65535,65535,1,22,26830,-294,-297,100,74,9,2848,3888,577,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3824,3828,3823,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22.1,959,SUCCESS,,2853.007833,192,0,0.1,0.2,0.3,263,1.4,1.5
    3189,5/26/2021 22:45,12780.623,3.55,701,300,10,6001,0,65535,65535,1,22,26830,-298,-297,100,74,9,2848,3888,573,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3824,3827,3823,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,967,SUCCESS,,2852.676556,192,0,0.1,0.2,0.3,263,1.4,1.5
    3190,5/26/2021 22:45,12784.638,3.55,701,300,10,6001,0,65535,65535,1,22,26829,-294,-297,100,74,9,2848,3888,577,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3824,3827,3822,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,951,SUCCESS,,2852.348665,192,0,0.1,0.2,0.3,263,1.4,1.5
    3191,5/26/2021 22:45,12788.651,3.55,701,300,10,6001,0,65535,65535,1,22,26829,-296,-297,100,74,9,2847,3888,577,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3824,3827,3822,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,959,SUCCESS,,2852.018707,192,0,0.1,0.2,0.3,263,1.4,1.5
    3192,5/26/2021 22:45,12792.662,3.55,701,300,10,6001,0,65535,65535,1,22,26828,-298,-297,100,74,9,2847,3888,573,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3836,3840,3842,3838,3824,3827,3822,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22.1,986,SUCCESS,,2851.686685,192,0,0.1,0.2,0.3,263,1.4,1.5
    3193,5/26/2021 22:46,12796.672,3.55,701,300,10,6001,0,65535,65535,1,22,26829,-294,-297,100,74,9,2847,3888,577,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3840,3842,3837,3824,3827,3822,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22.1,950,SUCCESS,,2851.359202,192,0,0.1,0.2,0.3,263,1.4,1.5
    3194,5/26/2021 22:46,12800.68,3.56,701,300,10,6001,0,65535,65535,1,22,26825,-296,-296,100,74,9,2846,3888,577,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3840,3842,3837,3823,3827,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,21.9,985,SUCCESS,,2851.029655,192,0,0.1,0.2,0.3,263,1.4,1.5
    3195,5/26/2021 22:46,12804.691,3.56,701,300,10,6001,0,65535,65535,1,22,26824,-296,-297,100,74,9,2846,3888,577,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3842,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22.1,945,SUCCESS,,2850.699862,192,0,0.1,0.2,0.3,263,1.4,1.5
    3196,5/26/2021 22:46,12808.699,3.56,701,300,10,6001,0,65535,65535,1,22,26824,-294,-296,100,74,9,2846,3888,577,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3841,3837,3823,3826,3822,0,0,0,0,0,0,0,0,2680,21.9,22,-273.2,22,-273.2,22,948,SUCCESS,,2850.372542,192,0,0.1,0.2,0.3,263,1.4,1.5
    3197,5/26/2021 22:46,12812.71,3.56,701,300,10,6001,0,65535,65535,1,22,26822,-298,-296,100,74,9,2845,3888,577,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3841,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22.1,966,SUCCESS,,2850.04052,192,0,0.1,0.2,0.3,263,1.4,1.5
    3198,5/26/2021 22:46,12816.721,3.56,701,300,10,6001,0,65535,65535,1,22,26822,-296,-297,100,74,9,2845,3888,573,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3841,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,976,SUCCESS,,2849.710727,192,0,0.1,0.2,0.3,263,1.4,1.5
    3199,5/26/2021 22:46,12820.728,3.56,701,300,10,6001,0,65535,65535,1,22,26822,-296,-297,100,74,9,2845,3888,581,577,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3841,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,961,SUCCESS,,2849.381263,192,0,0.1,0.2,0.3,263,1.4,1.5
    3200,5/26/2021 22:46,12824.731,3.56,701,300,10,6001,0,65535,65535,1,22,26822,-298,-297,100,74,9,2844,3888,576,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3841,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22.1,944,SUCCESS,,2849.049903,192,0,0.1,0.2,0.3,263,1.4,1.5
    3201,5/26/2021 22:46,12828.745,3.56,701,300,10,6001,0,65535,65535,1,22,26822,-296,-297,100,74,9,2844,3888,576,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3835,3839,3841,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,945,SUCCESS,,2848.719863,192,0,0.1,0.2,0.3,263,1.4,1.5
    3202,5/26/2021 22:46,12832.75,3.56,701,300,10,6001,0,65535,65535,1,22,26820,-296,-296,100,74,9,2844,3888,576,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3837,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,956,SUCCESS,,2848.390563,192,0,0.1,0.2,0.3,263,1.4,1.5
    3203,5/26/2021 22:46,12836.762,3.57,701,300,10,6001,0,65535,65535,1,22,26818,-298,-296,100,74,9,2843,3888,572,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3823,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,964,SUCCESS,,2848.058459,192,0,0.1,0.2,0.3,263,1.4,1.5
    3204,5/26/2021 22:46,12840.771,3.57,701,300,10,6001,0,65535,65535,1,22,26816,-296,-296,100,74,9,2843,3888,576,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3822,3825,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,974,SUCCESS,,2847.72883,192,0,0.1,0.2,0.3,263,1.4,1.5
    3205,5/26/2021 22:46,12844.783,3.57,701,300,10,6001,0,65535,65535,1,22,26817,-300,-297,100,74,9,2843,3888,569,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3822,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,939,SUCCESS,,2847.394496,192,0,0.1,0.2,0.3,263,1.4,1.5
    3206,5/26/2021 22:46,12848.785,3.57,701,300,10,6001,0,65535,65535,1,22,26817,-296,-297,100,74,9,2842,3888,576,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3822,3826,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,21.4,939,SUCCESS,,2847.065443,192,0,0.1,0.2,0.3,263,1.4,1.5
    3207,5/26/2021 22:46,12852.795,3.57,701,300,10,6001,0,65535,65535,1,22,26815,-298,-297,100,74,9,2842,3888,572,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3822,3826,3821,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,957,SUCCESS,,2846.733504,192,0,0.1,0.2,0.3,263,1.4,1.5
    3208,5/26/2021 22:47,12856.803,3.57,701,300,10,6001,0,65535,65535,1,22,26815,-298,-297,100,74,9,2842,3888,572,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3822,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,981,SUCCESS,,2846.401731,192,0,0.1,0.2,0.3,263,1.4,1.5
    3209,5/26/2021 22:47,12860.804,3.57,701,300,10,6001,0,65535,65535,1,22,26815,-296,-297,100,74,9,2841,3888,576,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3840,3836,3822,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,21.9,981,SUCCESS,,2846.07276,192,0,0.1,0.2,0.3,263,1.4,1.5
    3210,5/26/2021 22:47,12864.807,3.57,701,300,10,6001,0,65535,65535,1,22,26814,-296,-297,100,74,9,2841,3888,576,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3838,3840,3835,3822,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,963,SUCCESS,,2845.743624,192,0,0.1,0.2,0.3,263,1.4,1.5
    3211,5/26/2021 22:47,12868.821,3.57,701,300,10,6001,0,65535,65535,1,22,26812,-296,-297,100,74,9,2841,3888,580,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3822,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,947,SUCCESS,,2845.413584,192,0,0.1,0.2,0.3,263,1.4,1.5
    3212,5/26/2021 22:47,12872.836,3.58,701,300,10,6001,0,65535,65535,1,22,26812,-296,-296,100,74,9,2840,3888,580,576,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3834,3838,3839,3835,3821,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,21.9,996,SUCCESS,,2845.083462,192,0,0.1,0.2,0.3,263,1.4,1.5
    3213,5/26/2021 22:47,12876.851,3.58,701,300,10,6001,0,65535,65535,1,22,26810,-298,-297,100,74,9,2840,3888,572,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3821,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,969,SUCCESS,,2844.751109,192,0,0.1,0.2,0.3,263,1.4,1.5
    3214,5/26/2021 22:47,12880.856,3.58,701,300,10,6001,0,65535,65535,1,22,26811,-296,-297,100,74,9,2840,3888,572,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3821,3824,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,973,SUCCESS,,2844.421809,192,0,0.1,0.2,0.3,263,1.4,1.5
    3215,5/26/2021 22:47,12884.871,3.58,701,300,10,6001,0,65535,65535,1,22,26810,-296,-296,100,74,9,2839,3888,575,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3821,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,950,SUCCESS,,2844.091687,192,0,0.1,0.2,0.3,263,1.4,1.5
    3216,5/26/2021 22:47,12888.887,3.58,701,300,10,6001,0,65535,65535,1,22,26810,-298,-297,100,74,9,2839,3888,572,574,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3821,3825,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,946,SUCCESS,,2843.759251,192,0,0.1,0.2,0.3,263,1.4,1.5
    3217,5/26/2021 22:47,12892.899,3.58,701,300,10,6001,0,65535,65535,1,22,26810,-296,-296,100,74,9,2839,3888,579,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3821,3824,3820,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,993,SUCCESS,,2843.429376,192,0,0.1,0.2,0.3,263,1.4,1.5
    3218,5/26/2021 22:47,12896.914,3.58,701,300,10,6001,0,65535,65535,1,22,26809,-296,-296,100,73,9,2838,3888,575,575,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3833,3837,3839,3835,3821,3824,3819,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,21.9,965,SUCCESS,,2843.099254,192,0,0.1,0.2,0.3,263,1.4,1.5
    3219,5/26/2021 22:47,12900.922,3.58,701,300,10,6001,0,65535,65535,1,22,26807,-298,-297,100,73,9,2838,3888,571,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3837,3839,3835,3821,3824,3819,0,0,0,0,0,0,0,0,2679,21.8,22,-273.2,22,-273.2,21.9,965,SUCCESS,,2842.76748,192,0,0.1,0.2,0.3,263,1.4,1.5
    3220,5/26/2021 22:47,12904.924,3.58,701,300,10,6001,0,65535,65535,1,22,26807,-296,-297,100,73,9,2838,3888,575,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3837,3838,3835,3821,3824,3819,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,960,SUCCESS,,2842.438427,192,0,0.1,0.2,0.3,263,1.4,1.5
    3221,5/26/2021 22:47,12908.935,3.59,701,300,10,6001,0,65535,65535,1,22,26805,-298,-297,100,73,9,2837,3888,571,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3837,3838,3834,3821,3824,3819,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,949,SUCCESS,,2842.106405,192,0,0.1,0.2,0.3,263,1.4,1.5
    3222,5/26/2021 22:48,12912.946,3.59,701,300,10,6001,0,65535,65535,1,22,26804,-296,-297,100,73,9,2837,3888,571,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3837,3838,3834,3820,3824,3819,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22,953,SUCCESS,,2841.776612,192,0,0.1,0.2,0.3,263,1.4,1.5
    3223,5/26/2021 22:48,12916.958,3.59,701,300,10,6001,0,65535,65535,1,22,26804,-298,-297,100,73,9,2837,3888,575,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3819,0,0,0,0,0,0,0,0,2680,21.8,22,-273.2,22,-273.2,22.1,994,SUCCESS,,2841.444508,192,0,0.1,0.2,0.3,263,1.4,1.5
    3224,5/26/2021 22:48,12920.96,3.59,701,300,10,6001,0,65535,65535,1,22,26802,-298,-297,100,73,9,2836,3888,575,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3819,0,0,0,0,0,0,0,0,2677,21.8,22,-273.2,22,-273.2,22,935,SUCCESS,,2841.113231,192,0,0.1,0.2,0.3,263,1.4,1.5
    3225,5/26/2021 22:48,12924.961,3.59,701,300,10,6001,0,65535,65535,1,22,26802,-296,-297,100,73,9,2836,3888,575,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3819,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.8,947,SUCCESS,,2840.78426,192,0,0.1,0.2,0.3,263,1.4,1.5
    3226,5/26/2021 22:48,12928.963,3.59,701,300,10,6001,0,65535,65535,1,22,26801,-296,-297,100,73,9,2836,3888,575,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,931,SUCCESS,,2840.455206,192,0,0.1,0.2,0.3,263,1.4,1.5
    3227,5/26/2021 22:48,12932.969,3.59,701,300,10,6001,0,65535,65535,1,22,26801,-298,-297,100,73,9,2835,3888,571,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,1002,SUCCESS,,2840.123599,192,0,0.1,0.2,0.3,263,1.4,1.5
    3228,5/26/2021 22:48,12936.975,3.59,701,300,10,6001,0,65535,65535,1,22,26800,-296,-297,100,73,9,2835,3888,575,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,965,SUCCESS,,2839.794216,192,0,0.1,0.2,0.3,263,1.4,1.5
    3229,5/26/2021 22:48,12940.981,3.59,701,300,10,6001,0,65535,65535,1,22,26801,-298,-297,100,73,9,2835,3888,567,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3832,3836,3838,3834,3820,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,944,SUCCESS,,2839.462609,192,0,0.1,0.2,0.3,263,1.4,1.5
    3230,5/26/2021 22:48,12944.986,3.6,701,300,10,6001,0,65535,65535,1,22,26799,-298,-297,100,73,9,2834,3888,574,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3834,3819,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.7,955,SUCCESS,,2839.131084,192,0,0.1,0.2,0.3,263,1.4,1.5
    3231,5/26/2021 22:48,12949,3.6,701,300,10,6001,0,65535,65535,1,22,26798,-296,-297,100,73,9,2834,3888,578,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3834,3820,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,941,SUCCESS,,2838.801044,192,0,0.1,0.2,0.3,263,1.4,1.5
    3232,5/26/2021 22:48,12953.011,3.6,701,300,10,6001,0,65535,65535,1,22,26796,-298,-297,100,73,9,2834,3888,574,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3833,3819,3823,3818,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,992,SUCCESS,,2838.469022,192,0,0.1,0.2,0.3,263,1.4,1.5
    3233,5/26/2021 22:48,12957.026,3.6,701,300,10,6001,0,65535,65535,1,22,26795,-296,-297,100,73,9,2833,3888,574,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3833,3819,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,977,SUCCESS,,2838.1389,192,0,0.1,0.2,0.3,263,1.4,1.5
    3234,5/26/2021 22:48,12961.027,3.6,701,300,10,6001,0,65535,65535,1,22,26797,-296,-297,100,73,9,2833,3888,574,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3833,3819,3823,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,968,SUCCESS,,2837.809929,192,0,0.1,0.2,0.3,263,1.4,1.5
    3235,5/26/2021 22:48,12965.038,3.6,701,300,10,6001,0,65535,65535,1,22,26795,-300,-297,100,73,9,2833,3888,570,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3833,3819,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22.1,981,SUCCESS,,2837.475679,192,0,0.1,0.2,0.3,263,1.4,1.5
    3236,5/26/2021 22:48,12969.039,3.6,701,300,10,6001,0,65535,65535,1,22,26794,-296,-297,100,73,9,2832,3888,574,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3833,3819,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,954,SUCCESS,,2837.146708,192,0,0.1,0.2,0.3,263,1.4,1.5
    3237,5/26/2021 22:49,12973.041,3.6,701,300,10,6001,0,65535,65535,1,22,26795,-296,-297,100,73,9,2832,3888,574,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3833,3818,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,944,SUCCESS,,2836.817654,192,0,0.1,0.2,0.3,263,1.4,1.5
    3238,5/26/2021 22:49,12977.056,3.6,701,300,10,6001,0,65535,65535,1,22,26793,-300,-297,100,73,9,2832,3888,566,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3834,3837,3832,3818,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,977,SUCCESS,,2836.483071,192,0,0.1,0.2,0.3,263,1.4,1.5
    3239,5/26/2021 22:49,12981.059,3.61,701,300,10,6001,0,65535,65535,1,22,26792,-296,-297,100,73,9,2831,3888,574,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3831,3835,3837,3832,3818,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,943,SUCCESS,,2836.153935,192,0,0.1,0.2,0.3,263,1.4,1.5
    3240,5/26/2021 22:49,12985.074,3.61,701,300,10,6001,0,65535,65535,1,22,26794,-298,-297,100,73,9,2831,3888,570,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3830,3835,3837,3832,3818,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,946,SUCCESS,,2835.821583,192,0,0.1,0.2,0.3,263,1.4,1.5
    3241,5/26/2021 22:49,12989.087,3.61,701,300,10,6001,0,65535,65535,1,22,26790,-298,-297,100,73,9,2831,3888,570,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3830,3834,3836,3832,3818,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,976,SUCCESS,,2835.489395,192,0,0.1,0.2,0.3,263,1.4,1.5
    3242,5/26/2021 22:49,12993.094,3.61,701,300,10,6001,0,65535,65535,1,22,26789,-298,-297,100,73,9,2830,3888,570,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3830,3834,3836,3832,3818,3821,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,941,SUCCESS,,2835.157705,192,0,0.1,0.2,0.3,263,1.4,1.5
    3243,5/26/2021 22:49,12997.105,3.61,701,300,10,6001,0,65535,65535,1,22,26791,-298,-297,100,73,9,2830,3888,570,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3830,3834,3836,3832,3818,3822,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.9,972,SUCCESS,,2834.825683,192,0,0.1,0.2,0.3,263,1.4,1.5
    3244,5/26/2021 22:49,13001.112,3.61,701,300,10,6001,0,65535,65535,1,22,26788,-296,-297,100,73,9,2830,3888,574,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3830,3834,3836,3832,3818,3821,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,952,SUCCESS,,2834.496219,192,0,0.1,0.2,0.3,263,1.4,1.5
    3245,5/26/2021 22:49,13005.116,3.61,701,300,10,6001,0,65535,65535,1,22,26787,-298,-297,100,73,9,2829,3888,570,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3830,3834,3836,3832,3818,3821,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,972,SUCCESS,,2834.164776,192,0,0.1,0.2,0.3,263,1.4,1.5
    3246,5/26/2021 22:49,13009.125,3.61,701,300,10,6001,0,65535,65535,1,22,26788,-296,-297,100,73,9,2829,3888,573,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3834,3836,3832,3818,3821,3817,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22.1,941,SUCCESS,,2833.835148,192,0,0.1,0.2,0.3,263,1.4,1.5
    3247,5/26/2021 22:49,13013.125,3.61,701,300,10,6001,0,65535,65535,1,22,26786,-296,-297,100,73,9,2829,3888,573,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3834,3835,3832,3818,3821,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,986,SUCCESS,,2833.506259,192,0,0.1,0.2,0.3,263,1.4,1.5
    3248,5/26/2021 22:49,13017.14,3.62,701,300,10,6001,0,65535,65535,1,22,26784,-298,-297,100,73,9,2828,3888,569,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3834,3836,3831,3818,3821,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,956,SUCCESS,,2833.173906,192,0,0.1,0.2,0.3,263,1.4,1.5
    3249,5/26/2021 22:49,13021.142,3.62,701,300,10,6001,0,65535,65535,1,22,26784,-298,-297,100,73,9,2828,3888,569,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3834,3835,3831,3818,3822,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.7,939,SUCCESS,,2832.842629,192,0,0.1,0.2,0.3,263,1.4,1.5
    3250,5/26/2021 22:49,13025.149,3.62,701,300,10,6001,0,65535,65535,1,22,26783,-298,-297,100,73,9,2828,3888,569,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3818,3821,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22.1,978,SUCCESS,,2832.510939,192,0,0.1,0.2,0.3,263,1.4,1.5
    3251,5/26/2021 22:49,13029.156,3.62,701,300,10,6001,0,65535,65535,1,22,26783,-296,-297,100,73,9,2827,3888,565,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3818,3820,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.9,968,SUCCESS,,2832.181474,192,0,0.1,0.2,0.3,263,1.4,1.5
    3252,5/26/2021 22:50,13033.164,3.62,701,300,10,6001,0,65535,65535,1,22,26782,-296,-297,100,73,9,2827,3888,577,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3817,3822,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,972,SUCCESS,,2831.851928,192,0,0.1,0.2,0.3,263,1.4,1.5
    3253,5/26/2021 22:50,13037.168,3.62,701,300,10,6001,0,65535,65535,1,22,26780,-298,-297,100,73,9,2827,3888,573,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3817,3820,3816,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,963,SUCCESS,,2831.520485,192,0,0.1,0.2,0.3,263,1.4,1.5
    3254,5/26/2021 22:50,13041.175,3.62,701,300,10,6001,0,65535,65535,1,22,26780,-298,-297,100,73,9,2826,3888,569,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3817,3819,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,942,SUCCESS,,2831.188795,192,0,0.1,0.2,0.3,263,1.4,1.5
    3255,5/26/2021 22:50,13045.178,3.62,701,300,10,6001,0,65535,65535,1,22,26779,-296,-297,100,73,9,2826,3888,573,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3817,3821,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,932,SUCCESS,,2830.859659,192,0,0.1,0.2,0.3,263,1.4,1.5
    3256,5/26/2021 22:50,13049.184,3.62,701,300,10,6001,0,65535,65535,1,22,26779,-296,-297,100,73,9,2826,3888,573,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3829,3833,3835,3831,3817,3820,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.9,948,SUCCESS,,2830.530277,192,0,0.1,0.2,0.3,263,1.4,1.5
    3257,5/26/2021 22:50,13053.185,3.63,701,300,10,6001,0,65535,65535,1,22,26780,-294,-296,100,73,9,2825,3888,577,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3831,3817,3818,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,958,SUCCESS,,2830.203529,192,0,0.1,0.2,0.3,263,1.4,1.5
    3258,5/26/2021 22:50,13057.191,3.63,701,300,10,6001,0,65535,65535,1,22,26777,-296,-296,100,73,9,2825,3888,573,573,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3816,3820,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,943,SUCCESS,,2829.874146,192,0,0.1,0.2,0.3,263,1.4,1.5
    3259,5/26/2021 22:50,13061.198,3.63,701,300,10,6001,0,65535,65535,1,22,26778,-298,-297,100,73,9,2825,3888,569,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3817,3820,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,976,SUCCESS,,2829.542456,192,0,0.1,0.2,0.3,263,1.4,1.5
    3260,5/26/2021 22:50,13065.198,3.63,701,300,10,6001,0,65535,65535,1,22,26776,-294,-297,100,73,9,2824,3888,572,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3817,3819,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,978,SUCCESS,,2829.215789,192,0,0.1,0.2,0.3,263,1.4,1.5
    3261,5/26/2021 22:50,13069.204,3.63,701,300,10,6001,0,65535,65535,1,22,26775,-294,-296,100,73,9,2824,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3816,3820,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,939,SUCCESS,,2828.888633,192,0,0.1,0.2,0.3,263,1.4,1.5
    3262,5/26/2021 22:50,13073.211,3.63,701,300,10,6001,0,65535,65535,1,22,26774,-298,-296,100,73,9,2824,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3816,3819,3814,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,979,SUCCESS,,2828.556942,192,0,0.1,0.2,0.3,263,1.4,1.5
    3263,5/26/2021 22:50,13077.213,3.63,701,300,10,6001,0,65535,65535,1,22,26773,-296,-296,100,73,9,2823,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3816,3819,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.5,948,SUCCESS,,2828.227889,192,0,0.1,0.2,0.3,263,1.4,1.5
    3264,5/26/2021 22:50,13081.22,3.63,701,300,10,6001,0,65535,65535,1,22,26775,-298,-296,100,73,9,2823,3888,568,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3828,3832,3834,3830,3816,3819,3815,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,22,969,SUCCESS,,2827.896198,192,0,0.1,0.2,0.3,263,1.4,1.5
    3265,5/26/2021 22:50,13085.223,3.63,701,300,10,6001,0,65535,65535,1,22,26772,-296,-296,100,73,9,2823,3888,568,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3827,3832,3834,3830,3816,3819,3814,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.9,947,SUCCESS,,2827.567063,192,0,0.1,0.2,0.3,263,1.4,1.5
    3266,5/26/2021 22:50,13089.238,3.64,701,300,10,6001,0,65535,65535,1,22,26771,-294,-296,100,73,9,2822,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3827,3832,3834,3829,3816,3819,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,951,SUCCESS,,2827.239171,192,0,0.1,0.2,0.3,263,1.4,1.5
    3267,5/26/2021 22:51,13093.241,3.64,701,300,10,6001,0,65535,65535,1,22,26770,-296,-296,100,73,9,2822,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3827,3831,3834,3829,3815,3819,3814,0,0,0,0,0,0,0,0,2676,21.8,22,-273.2,22,-273.2,21.9,979,SUCCESS,,2826.910035,192,0,0.1,0.2,0.3,263,1.4,1.5
    3268,5/26/2021 22:51,13097.254,3.64,701,300,10,6001,0,65535,65535,1,22,26770,-296,-297,100,73,9,2822,3888,572,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3827,3831,3834,3829,3815,3819,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,960,SUCCESS,,2826.580078,192,0,0.1,0.2,0.3,263,1.4,1.5
    3269,5/26/2021 22:51,13101.268,3.64,701,300,10,6001,0,65535,65535,1,22,26768,-296,-296,100,73,9,2821,3888,568,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3827,3831,3833,3829,3815,3818,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,990,SUCCESS,,2826.250038,192,0,0.1,0.2,0.3,263,1.4,1.5
    3270,5/26/2021 22:51,13105.283,3.64,701,300,10,6001,0,65535,65535,1,22,26767,-298,-296,100,73,9,2821,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3827,3831,3833,3829,3815,3818,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,953,SUCCESS,,2825.917685,192,0,0.1,0.2,0.3,263,1.4,1.5
    3271,5/26/2021 22:51,13109.295,3.64,701,300,10,6001,0,65535,65535,1,22,26766,-296,-297,100,73,9,2821,3888,568,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3831,3833,3829,3815,3818,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,21.9,946,SUCCESS,,2825.587809,192,0,0.1,0.2,0.3,263,1.4,1.5
    3272,5/26/2021 22:51,13113.309,3.64,701,300,10,6001,0,65535,65535,1,22,26766,-296,-296,100,73,9,2821,3888,572,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3831,3833,3829,3815,3818,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,1000,SUCCESS,,2825.257769,192,0,0.1,0.2,0.3,263,1.4,1.5
    3273,5/26/2021 22:51,13117.32,3.64,701,300,10,6001,0,65535,65535,1,22,26766,-298,-297,100,73,9,2820,3888,572,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3831,3833,3829,3815,3818,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,964,SUCCESS,,2824.925748,192,0,0.1,0.2,0.3,263,1.4,1.5
    3274,5/26/2021 22:51,13121.326,3.64,701,300,10,6001,0,65535,65535,1,22,26766,-294,-296,100,73,9,2820,3888,576,572,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3831,3832,3828,3815,3818,3814,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,945,SUCCESS,,2824.598591,192,0,0.1,0.2,0.3,263,1.4,1.5
    3275,5/26/2021 22:51,13125.33,3.65,701,300,10,6001,0,65535,65535,1,22,26763,-296,-296,100,73,9,2820,3888,568,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3831,3832,3828,3815,3818,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,947,SUCCESS,,2824.269373,192,0,0.1,0.2,0.3,263,1.4,1.5
    3276,5/26/2021 22:51,13129.346,3.65,701,300,10,6001,0,65535,65535,1,22,26761,-298,-296,100,73,9,2819,3888,568,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3815,3818,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,960,SUCCESS,,2823.936938,192,0,0.1,0.2,0.3,263,1.4,1.5
    3277,5/26/2021 22:51,13133.351,3.65,701,300,10,6001,0,65535,65535,1,22,26762,-296,-296,100,73,9,2819,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3814,3818,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,931,SUCCESS,,2823.607638,192,0,0.1,0.2,0.3,263,1.4,1.5
    3278,5/26/2021 22:51,13137.352,3.65,701,300,10,6001,0,65535,65535,1,22,26762,-294,-296,100,73,9,2818,3888,575,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3815,3818,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,947,SUCCESS,,2823.280889,192,0,0.1,0.2,0.3,263,1.4,1.5
    3279,5/26/2021 22:51,13141.354,3.65,701,300,10,6001,0,65535,65535,1,22,26760,-296,-296,100,73,9,2818,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3814,3817,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,965,SUCCESS,,2822.951836,192,0,0.1,0.2,0.3,263,1.4,1.5
    3280,5/26/2021 22:51,13145.365,3.65,701,300,10,6001,0,65535,65535,1,22,26759,-296,-296,100,73,9,2818,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3814,3817,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,22,934,SUCCESS,,2822.622043,192,0,0.1,0.2,0.3,263,1.4,1.5
    3281,5/26/2021 22:51,13149.37,3.65,701,300,10,6001,0,65535,65535,1,22,26760,-296,-296,100,73,9,2817,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3814,3818,3812,0,0,0,0,0,0,0,0,2672,21.7,22,-273.2,22,-273.2,22,962,SUCCESS,,2822.292743,192,0,0.1,0.2,0.3,263,1.4,1.5
    3282,5/26/2021 22:52,13153.38,3.65,701,300,10,6001,0,65535,65535,1,22,26759,-296,-296,100,73,9,2817,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3832,3828,3814,3817,3813,0,0,0,0,0,0,0,0,2676,21.7,22,-273.2,22,-273.2,21.4,992,SUCCESS,,2821.963031,192,0,0.1,0.2,0.3,263,1.4,1.5
    3283,5/26/2021 22:52,13157.386,3.65,701,300,10,6001,0,65535,65535,1,22,26758,-298,-296,100,73,9,2817,3888,567,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3830,3831,3828,3814,3817,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,951,SUCCESS,,2821.631424,192,0,0.1,0.2,0.3,263,1.4,1.5
    3284,5/26/2021 22:52,13161.396,3.66,701,300,10,6001,0,65535,65535,1,22,26758,-294,-296,100,73,9,2816,3888,575,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3829,3832,3828,3814,3817,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,956,SUCCESS,,2821.30394,192,0,0.1,0.2,0.3,263,1.4,1.5
    3285,5/26/2021 22:52,13165.408,3.66,701,300,10,6001,0,65535,65535,1,22,26755,-296,-296,100,73,9,2816,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3829,3831,3827,3814,3816,3812,0,0,0,0,0,0,0,0,2675,21.7,22,-273.2,22,-273.2,22,961,SUCCESS,,2820.974065,192,0,0.1,0.2,0.3,263,1.4,1.5
    3286,5/26/2021 22:52,13169.419,3.66,701,300,10,6001,0,65535,65535,1,22,26755,-298,-296,100,73,9,2816,3888,567,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3829,3831,3827,3814,3816,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,950,SUCCESS,,2820.642043,192,0,0.1,0.2,0.3,263,1.4,1.5
    3287,5/26/2021 22:52,13173.429,3.66,701,300,10,6001,0,65535,65535,1,22,26756,-296,-296,100,73,9,2815,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3829,3831,3827,3814,3817,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,958,SUCCESS,,2820.312332,192,0,0.1,0.2,0.3,263,1.4,1.5
    3288,5/26/2021 22:52,13177.434,3.66,701,300,10,6001,0,65535,65535,1,22,26754,-298,-296,100,73,9,2815,3888,571,571,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3829,3831,3827,3814,3816,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,950,SUCCESS,,2819.980807,192,0,0.1,0.2,0.3,263,1.4,1.5
    3289,5/26/2021 22:52,13181.435,3.66,701,300,10,6001,0,65535,65535,1,22,26755,-298,-297,100,73,9,2815,3888,567,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3826,3829,3831,3827,3813,3816,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,943,SUCCESS,,2819.649613,192,0,0.1,0.2,0.3,263,1.4,1.5
    3290,5/26/2021 22:52,13185.439,3.66,701,300,10,6001,0,65535,65535,1,22,26754,-296,-297,100,73,9,2815,3888,567,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3825,3829,3831,3827,3813,3816,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,978,SUCCESS,,2819.320395,192,0,0.1,0.2,0.3,263,1.4,1.5
    3291,5/26/2021 22:52,13189.443,3.66,701,300,10,6001,0,65535,65535,1,22,26752,-296,-297,100,73,9,2814,3888,567,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3825,3829,3831,3826,3813,3816,3812,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,951,SUCCESS,,2818.991178,192,0,0.1,0.2,0.3,263,1.4,1.5
    3292,5/26/2021 22:52,13193.458,3.66,701,300,10,6001,0,65535,65535,1,22,26751,-296,-297,100,73,9,2814,3888,570,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3825,3829,3831,3826,3813,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,936,SUCCESS,,2818.661055,192,0,0.1,0.2,0.3,263,1.4,1.5
    3293,5/26/2021 22:52,13197.473,3.67,701,300,10,6001,0,65535,65535,1,22,26752,-296,-296,100,73,9,2814,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3825,3828,3831,3827,3813,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,952,SUCCESS,,2818.330933,192,0,0.1,0.2,0.3,263,1.4,1.5
    3294,5/26/2021 22:52,13201.479,3.67,701,300,10,6001,0,65535,65535,1,22,26750,-298,-297,100,73,9,2813,3888,566,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3825,3828,3831,3826,3813,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,952,SUCCESS,,2817.999325,192,0,0.1,0.2,0.3,263,1.4,1.5
    3295,5/26/2021 22:52,13205.492,3.67,701,300,10,6001,0,65535,65535,1,22,26749,-294,-296,100,73,9,2813,3888,574,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3831,3826,3812,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,949,SUCCESS,,2817.671597,192,0,0.1,0.2,0.3,263,1.4,1.5
    3296,5/26/2021 22:52,13209.502,3.67,701,300,10,6001,0,65535,65535,1,22,26747,-298,-296,100,73,9,2813,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3831,3826,3812,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,955,SUCCESS,,2817.339658,192,0,0.1,0.2,0.3,263,1.4,1.5
    3297,5/26/2021 22:53,13213.513,3.67,701,300,10,6001,0,65535,65535,1,22,26747,-296,-296,100,73,9,2812,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3830,3826,3812,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,947,SUCCESS,,2817.009865,192,0,0.1,0.2,0.3,263,1.4,1.5
    3298,5/26/2021 22:53,13217.516,3.67,701,300,10,6001,0,65535,65535,1,22,26747,-294,-296,100,73,9,2812,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3830,3826,3812,3815,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22.1,956,SUCCESS,,2816.682953,192,0,0.1,0.2,0.3,263,1.4,1.5
    3299,5/26/2021 22:53,13221.53,3.67,701,300,10,6001,0,65535,65535,1,22,26746,-298,-296,100,73,9,2812,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3830,3826,3812,3816,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,954,SUCCESS,,2816.350683,192,0,0.1,0.2,0.3,263,1.4,1.5
    3300,5/26/2021 22:53,13225.533,3.67,701,300,10,6001,0,65535,65535,1,22,26746,-296,-296,100,73,9,2811,3888,574,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3830,3826,3812,3815,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,970,SUCCESS,,2816.021548,192,0,0.1,0.2,0.3,263,1.4,1.5
    3301,5/26/2021 22:53,13229.545,3.67,701,300,10,6001,0,65535,65535,1,22,26744,-298,-296,100,73,9,2811,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3824,3828,3830,3826,3812,3815,3811,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.3,945,SUCCESS,,2815.689443,192,0,0.1,0.2,0.3,263,1.4,1.5
    3302,5/26/2021 22:53,13233.549,3.68,701,300,10,6001,0,65535,65535,1,22,26744,-298,-296,100,73,9,2811,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3828,3829,3825,3812,3815,3810,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,963,SUCCESS,,2815.358001,192,0,0.1,0.2,0.3,263,1.4,1.5
    3303,5/26/2021 22:53,13237.553,3.68,701,300,10,6001,0,65535,65535,1,22,26741,-296,-297,100,73,9,2810,3888,566,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3827,3829,3825,3812,3815,3810,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,936,SUCCESS,,2815.028783,192,0,0.1,0.2,0.3,263,1.4,1.5
    3304,5/26/2021 22:53,13241.56,3.68,701,300,10,6001,0,65535,65535,1,22,26741,-296,-296,100,73,9,2810,3888,570,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3827,3829,3825,3811,3815,3810,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,952,SUCCESS,,2814.699319,192,0,0.1,0.2,0.3,263,1.4,1.5
    3305,5/26/2021 22:53,13245.563,3.68,701,300,10,6001,0,65535,65535,1,22,26736,-296,-296,100,73,9,2810,3888,566,570,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3827,3829,3825,3812,3815,3810,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,941,SUCCESS,,2814.370183,192,0,0.1,0.2,0.3,263,1.4,1.5
    3306,5/26/2021 22:53,13249.564,3.68,701,300,10,6001,0,65535,65535,1,22,26740,-294,-296,100,73,9,2809,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3827,3829,3825,3811,3814,3810,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,956,SUCCESS,,2814.043435,192,0,0.1,0.2,0.3,263,1.4,1.5
    3307,5/26/2021 22:53,13253.573,3.68,701,300,10,6001,0,65535,65535,1,22,26740,-298,-296,100,73,9,2809,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3827,3829,3825,3811,3815,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,947,SUCCESS,,2813.711579,192,0,0.1,0.2,0.3,263,1.4,1.5
    3308,5/26/2021 22:53,13257.581,3.68,701,300,10,6001,0,65535,65535,1,22,26739,-298,-297,100,73,9,2809,3888,569,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3827,3829,3825,3811,3815,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.8,970,SUCCESS,,2813.379805,192,0,0.1,0.2,0.3,263,1.4,1.5
    3309,5/26/2021 22:53,13261.589,3.68,701,300,10,6001,0,65535,65535,1,22,26738,-294,-297,100,73,9,2808,3888,565,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3826,3829,3825,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,967,SUCCESS,,2813.052485,192,0,0.1,0.2,0.3,263,1.4,1.5
    3310,5/26/2021 22:53,13265.59,3.68,701,300,10,6001,0,65535,65535,1,22,26737,-298,-297,100,73,9,2808,3888,565,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3826,3829,3825,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,953,SUCCESS,,2812.721291,192,0,0.1,0.2,0.3,263,1.4,1.5
    3311,5/26/2021 22:53,13269.603,3.69,701,300,10,6001,0,65535,65535,1,22,26735,-294,-296,100,73,9,2808,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3823,3826,3828,3824,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,979,SUCCESS,,2812.393563,192,0,0.1,0.2,0.3,263,1.4,1.5
    3312,5/26/2021 22:54,13273.612,3.69,701,300,10,6001,0,65535,65535,1,22,26734,-298,-296,100,73,9,2807,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3822,3826,3828,3824,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,946,SUCCESS,,2812.061707,192,0,0.1,0.2,0.3,263,1.4,1.5
    3313,5/26/2021 22:54,13277.628,3.69,701,300,10,6001,0,65535,65535,1,22,26734,-296,-296,100,73,9,2807,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3822,3826,3828,3824,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,976,SUCCESS,,2811.731503,192,0,0.1,0.2,0.3,263,1.4,1.5
    3314,5/26/2021 22:54,13281.638,3.69,701,300,10,6001,0,65535,65535,1,22,26734,-296,-296,100,73,9,2807,3888,573,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3822,3826,3828,3824,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,981,SUCCESS,,2811.401791,192,0,0.1,0.2,0.3,263,1.4,1.5
    3315,5/26/2021 22:54,13285.646,3.69,701,300,10,6001,0,65535,65535,1,22,26734,-296,-296,100,73,9,2806,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3822,3826,3828,3824,3811,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,973,SUCCESS,,2811.072245,192,0,0.1,0.2,0.3,263,1.4,1.5
    3316,5/26/2021 22:54,13289.648,3.69,701,300,10,6001,0,65535,65535,1,22,26731,-296,-296,100,73,9,2806,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3822,3826,3828,3824,3810,3814,3809,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,966,SUCCESS,,2810.743191,192,0,0.1,0.2,0.3,263,1.4,1.5
    3317,5/26/2021 22:54,13293.651,3.69,701,300,10,6001,0,65535,65535,1,22,26732,-296,-296,100,73,9,2806,3888,569,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3822,3826,3828,3824,3810,3814,3808,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,962,SUCCESS,,2810.414056,192,0,0.1,0.2,0.3,263,1.4,1.5
    3318,5/26/2021 22:54,13297.657,3.69,701,300,10,6001,0,65535,65535,1,22,26729,-300,-297,100,73,9,2805,3888,561,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3826,3828,3823,3810,3814,3808,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,939,SUCCESS,,2810.080223,192,0,0.1,0.2,0.3,263,1.4,1.5
    3319,5/26/2021 22:54,13301.666,3.69,701,300,10,6001,0,65535,65535,1,22,26728,-294,-296,100,73,9,2805,3888,572,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3826,3828,3823,3810,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,939,SUCCESS,,2809.752821,192,0,0.1,0.2,0.3,263,1.4,1.5
    3320,5/26/2021 22:54,13305.675,3.7,701,300,10,6001,0,65535,65535,1,22,26728,-298,-296,100,73,9,2805,3888,565,569,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3826,3828,3823,3810,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.3,941,SUCCESS,,2809.420965,192,0,0.1,0.2,0.3,263,1.4,1.5
    3321,5/26/2021 22:54,13309.676,3.7,701,300,10,6001,0,65535,65535,1,21.9,26726,-296,-297,100,73,9,2804,3888,568,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,21.9,969,SUCCESS,,2809.091994,192,0,0.1,0.2,0.3,263,1.4,1.5
    3322,5/26/2021 22:54,13313.685,3.7,701,300,10,6001,0,65535,65535,1,21.9,26726,-296,-296,100,73,9,2804,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,21.9,950,SUCCESS,,2808.762365,192,0,0.1,0.2,0.3,263,1.4,1.5
    3323,5/26/2021 22:54,13317.69,3.7,701,300,10,6001,0,65535,65535,1,21.9,26726,-296,-296,100,73,9,2804,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,21.9,965,SUCCESS,,2808.433065,192,0,0.1,0.2,0.3,263,1.4,1.5
    3324,5/26/2021 22:54,13321.696,3.7,701,300,10,6001,0,65535,65535,1,21.9,26725,-294,-296,100,73,9,2803,3888,572,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,22,964,SUCCESS,,2808.105908,192,0,0.1,0.2,0.3,263,1.4,1.5
    3325,5/26/2021 22:54,13325.699,3.7,701,300,10,6001,0,65535,65535,1,22,26725,-296,-296,100,73,9,2803,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3812,3808,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,968,SUCCESS,,2807.776773,192,0,0.1,0.2,0.3,263,1.4,1.5
    3326,5/26/2021 22:54,13329.711,3.7,701,300,10,6001,0,65535,65535,1,22,26725,-296,-296,100,73,9,2803,3888,564,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3813,3808,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,1002,SUCCESS,,2807.446897,192,0,0.1,0.2,0.3,263,1.4,1.5
    3327,5/26/2021 22:55,13333.713,3.7,701,300,10,6001,0,65535,65535,1,21.9,26725,-296,-296,100,73,9,2802,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3821,3825,3827,3823,3809,3812,3808,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,21.9,934,SUCCESS,,2807.117844,192,0,0.1,0.2,0.3,263,1.4,1.5
    3328,5/26/2021 22:55,13337.717,3.7,701,300,10,6001,0,65535,65535,1,21.9,26722,-296,-296,100,73,9,2802,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3825,3826,3823,3809,3812,3808,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,21.9,949,SUCCESS,,2806.788626,192,0,0.1,0.2,0.3,263,1.4,1.5
    3329,5/26/2021 22:55,13341.72,3.71,701,300,10,6001,0,65535,65535,1,22,26721,-296,-296,100,73,9,2802,3888,564,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3825,3826,3823,3809,3816,3807,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,940,SUCCESS,,2806.45949,192,0,0.1,0.2,0.3,263,1.4,1.5
    3330,5/26/2021 22:55,13345.736,3.71,701,300,10,6001,0,65535,65535,1,21.9,26721,-294,-296,100,73,9,2801,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3824,3826,3823,3809,3812,3807,0,0,0,0,0,0,0,0,2671,21.7,21.9,-273.2,21.9,-273.2,22,940,SUCCESS,,2806.131517,192,0,0.1,0.2,0.3,263,1.4,1.5
    3331,5/26/2021 22:55,13349.748,3.71,701,300,10,6001,0,65535,65535,1,22,26720,-298,-296,100,73,9,2801,3888,564,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3824,3826,3823,3809,3812,3807,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,960,SUCCESS,,2805.799413,192,0,0.1,0.2,0.3,263,1.4,1.5
    3332,5/26/2021 22:55,13353.763,3.71,701,300,10,6001,0,65535,65535,1,22,26720,-296,-296,100,73,9,2801,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3824,3826,3823,3808,3813,3807,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,964,SUCCESS,,2805.46929,192,0,0.1,0.2,0.3,263,1.4,1.5
    3333,5/26/2021 22:55,13357.769,3.71,701,300,10,6001,0,65535,65535,1,22,26717,-296,-296,100,73,9,2800,3888,571,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3824,3826,3823,3808,3812,3806,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,954,SUCCESS,,2805.139908,192,0,0.1,0.2,0.3,263,1.4,1.5
    3334,5/26/2021 22:55,13361.775,3.71,701,300,10,6001,0,65535,65535,1,22,26717,-296,-296,100,73,9,2800,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3824,3826,3822,3808,3811,3807,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,959,SUCCESS,,2804.810526,192,0,0.1,0.2,0.3,263,1.4,1.5
    3335,5/26/2021 22:55,13365.783,3.71,701,300,10,6001,0,65535,65535,1,22,26719,-296,-296,100,73,9,2800,3888,568,568,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3824,3826,3822,3808,3816,3807,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,941,SUCCESS,,2804.480979,192,0,0.1,0.2,0.3,263,1.4,1.5
    3336,5/26/2021 22:55,13369.784,3.71,701,300,10,6001,0,65535,65535,1,22,26716,-296,-296,100,72,9,2799,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3823,3826,3822,3808,3811,3806,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,22,971,SUCCESS,,2804.152008,192,0,0.1,0.2,0.3,263,1.4,1.5
    3337,5/26/2021 22:55,13373.799,3.71,701,300,10,6001,0,65535,65535,1,22,26715,-296,-296,100,72,9,2799,3888,564,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3820,3823,3826,3822,3808,3811,3806,0,0,0,0,0,0,0,0,2671,21.7,22,-273.2,22,-273.2,21.9,941,SUCCESS,,2803.821886,192,0,0.1,0.2,0.3,263,1.4,1.5
    3338,5/26/2021 22:55,13377.809,3.72,701,300,10,6001,0,65535,65535,1,22,26714,-296,-296,100,72,9,2799,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3826,3821,3808,3811,3806,0,0,0,0,0,0,0,0,2670,21.7,21.9,-273.2,21.9,-273.2,22,961,SUCCESS,,2803.492175,192,0,0.1,0.2,0.3,263,1.4,1.5
    3339,5/26/2021 22:55,13381.817,3.72,701,300,10,6001,0,65535,65535,1,21.9,26713,-296,-296,100,72,9,2798,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3825,3821,3808,3811,3806,0,0,0,0,0,0,0,0,2667,21.7,22,-273.2,22,-273.2,21.3,981,SUCCESS,,2803.162628,192,0,0.1,0.2,0.3,263,1.4,1.5
    3340,5/26/2021 22:55,13385.826,3.72,701,300,10,6001,0,65535,65535,1,22,26713,-296,-296,100,72,9,2798,3888,563,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3825,3821,3807,3810,3806,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,959,SUCCESS,,2802.832999,192,0,0.1,0.2,0.3,263,1.4,1.5
    3341,5/26/2021 22:55,13389.831,3.72,701,300,10,6001,0,65535,65535,1,21.9,26713,-296,-296,100,72,9,2798,3888,563,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3825,3821,3808,3815,3806,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,948,SUCCESS,,2802.503699,192,0,0.1,0.2,0.3,263,1.4,1.5
    3342,5/26/2021 22:56,13393.839,3.72,701,300,10,6001,0,65535,65535,1,21.9,26711,-296,-296,100,72,9,2797,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3825,3821,3807,3811,3805,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,945,SUCCESS,,2802.174153,192,0,0.1,0.2,0.3,263,1.4,1.5
    3343,5/26/2021 22:56,13397.845,3.72,701,300,10,6001,0,65535,65535,1,21.9,26710,-296,-296,100,72,9,2797,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3825,3821,3807,3810,3805,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,940,SUCCESS,,2801.84477,192,0,0.1,0.2,0.3,263,1.4,1.5
    3344,5/26/2021 22:56,13401.845,3.72,701,300,10,6001,0,65535,65535,1,21.9,26711,-296,-296,100,72,9,2797,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3819,3823,3825,3821,3807,3811,3805,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,995,SUCCESS,,2801.515881,192,0,0.1,0.2,0.3,263,1.4,1.5
    3345,5/26/2021 22:56,13405.86,3.72,701,300,10,6001,0,65535,65535,1,21.9,26709,-298,-296,100,72,9,2796,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3823,3825,3821,3806,3810,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,948,SUCCESS,,2801.183529,192,0,0.1,0.2,0.3,263,1.4,1.5
    3346,5/26/2021 22:56,13409.867,3.72,701,300,10,6001,0,65535,65535,1,21.9,26708,-296,-296,100,72,9,2796,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3822,3825,3821,3807,3810,3805,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,950,SUCCESS,,2800.854064,192,0,0.1,0.2,0.3,263,1.4,1.5
    3347,5/26/2021 22:56,13413.879,3.73,701,300,10,6001,0,65535,65535,1,21.9,26708,-296,-296,100,72,9,2796,3888,571,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3822,3825,3820,3806,3810,3805,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,968,SUCCESS,,2800.524189,192,0,0.1,0.2,0.3,263,1.4,1.5
    3348,5/26/2021 22:56,13417.883,3.73,701,300,10,6001,0,65535,65535,1,21.9,26705,-296,-296,100,72,9,2795,3888,563,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3822,3824,3820,3806,3810,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,978,SUCCESS,,2800.194971,192,0,0.1,0.2,0.3,263,1.4,1.5
    3349,5/26/2021 22:56,13421.889,3.73,701,300,10,6001,0,65535,65535,1,21.9,26704,-296,-296,100,72,9,2795,3888,563,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3822,3824,3820,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,945,SUCCESS,,2799.865589,192,0,0.1,0.2,0.3,263,1.4,1.5
    3350,5/26/2021 22:56,13425.904,3.73,701,300,10,6001,0,65535,65535,1,21.9,26704,-298,-296,100,72,9,2795,3888,567,567,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3822,3824,3820,3806,3810,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,975,SUCCESS,,2799.533236,192,0,0.1,0.2,0.3,263,1.4,1.5
    3351,5/26/2021 22:56,13429.916,3.73,701,300,10,6001,0,65535,65535,1,21.9,26703,-296,-296,100,72,9,2794,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3822,3824,3820,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,970,SUCCESS,,2799.20336,192,0,0.1,0.2,0.3,263,1.4,1.5
    3352,5/26/2021 22:56,13433.921,3.73,701,300,10,6001,0,65535,65535,1,21.9,26701,-298,-296,100,72,9,2794,3888,563,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3821,3824,3820,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,943,SUCCESS,,2798.871835,192,0,0.1,0.2,0.3,263,1.4,1.5
    3353,5/26/2021 22:56,13437.936,3.73,701,300,10,6001,0,65535,65535,1,21.9,26702,-296,-296,100,72,9,2794,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3821,3824,3820,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,943,SUCCESS,,2798.541713,192,0,0.1,0.2,0.3,263,1.4,1.5
    3354,5/26/2021 22:56,13441.939,3.73,701,300,10,6001,0,65535,65535,1,21.9,26701,-298,-296,100,72,9,2793,3888,562,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3818,3821,3823,3820,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,994,SUCCESS,,2798.210354,192,0,0.1,0.2,0.3,263,1.4,1.5
    3355,5/26/2021 22:56,13445.947,3.73,701,300,10,6001,0,65535,65535,1,21.9,26700,-298,-296,100,72,9,2793,3888,562,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3821,3823,3820,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,937,SUCCESS,,2797.87858,192,0,0.1,0.2,0.3,263,1.4,1.5
    3356,5/26/2021 22:56,13449.957,3.74,701,300,10,6001,0,65535,65535,1,21.9,26699,-294,-296,100,72,9,2793,3888,570,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3821,3823,3819,3806,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,954,SUCCESS,,2797.551097,192,0,0.1,0.2,0.3,263,1.4,1.5
    3357,5/26/2021 22:57,13453.972,3.74,701,300,10,6001,0,65535,65535,1,21.9,26699,-296,-296,100,72,9,2792,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3821,3823,3819,3805,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,1000,SUCCESS,,2797.220975,192,0,0.1,0.2,0.3,263,1.4,1.5
    3358,5/26/2021 22:57,13457.985,3.74,701,300,10,6001,0,65535,65535,1,21.9,26698,-298,-296,100,72,9,2792,3888,562,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3821,3823,3819,3805,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.6,943,SUCCESS,,2796.888788,192,0,0.1,0.2,0.3,263,1.4,1.5
    3359,5/26/2021 22:57,13461.987,3.74,701,300,10,6001,0,65535,65535,1,21.9,26698,-296,-296,100,72,9,2792,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3820,3823,3819,3805,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,956,SUCCESS,,2796.559734,192,0,0.1,0.2,0.3,263,1.4,1.5
    3360,5/26/2021 22:57,13465.993,3.74,701,300,10,6001,0,65535,65535,1,21.9,26697,-296,-296,100,72,9,2791,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3820,3823,3819,3805,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,964,SUCCESS,,2796.230352,192,0,0.1,0.2,0.3,263,1.4,1.5
    3361,5/26/2021 22:57,13470.007,3.74,701,300,10,6001,0,65535,65535,1,21.9,26696,-294,-296,100,72,9,2791,3888,570,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3820,3823,3819,3805,3809,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,955,SUCCESS,,2795.902542,192,0,0.1,0.2,0.3,263,1.4,1.5
    3362,5/26/2021 22:57,13474.016,3.74,701,300,10,6001,0,65535,65535,1,21.9,26695,-296,-296,100,72,9,2791,3888,570,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3817,3820,3823,3818,3805,3808,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,946,SUCCESS,,2795.572913,192,0,0.1,0.2,0.3,263,1.4,1.5
    3363,5/26/2021 22:57,13478.031,3.74,701,300,10,6001,0,65535,65535,1,21.9,26694,-296,-296,100,72,9,2790,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3816,3820,3822,3818,3805,3808,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,951,SUCCESS,,2795.242791,192,0,0.1,0.2,0.3,263,1.4,1.5
    3364,5/26/2021 22:57,13482.042,3.75,701,300,10,6001,0,65535,65535,1,21.9,26691,-298,-296,100,72,9,2790,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3816,3820,3822,3818,3805,3808,3804,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,931,SUCCESS,,2794.910769,192,0,0.1,0.2,0.3,263,1.4,1.5
    3365,5/26/2021 22:57,13486.042,3.75,701,300,10,6001,0,65535,65535,1,21.9,26691,-296,-296,100,72,9,2790,3888,566,566,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3816,3820,3822,3818,3804,3808,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,955,SUCCESS,,2794.58188,192,0,0.1,0.2,0.3,263,1.4,1.5
    3366,5/26/2021 22:57,13490.052,3.75,701,300,10,6001,0,65535,65535,1,21.9,26691,-298,-296,100,72,9,2789,3888,562,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3816,3820,3822,3818,3804,3808,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,973,SUCCESS,,2794.249941,192,0,0.1,0.2,0.3,263,1.4,1.5
    3367,5/26/2021 22:57,13494.061,3.75,701,300,10,6001,0,65535,65535,1,21.9,26691,-296,-296,100,72,9,2789,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3816,3820,3822,3818,3804,3808,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,943,SUCCESS,,2793.920313,192,0,0.1,0.2,0.3,263,1.4,1.5
    3368,5/26/2021 22:57,13498.069,3.75,701,300,10,6001,0,65535,65535,1,21.9,26690,-298,-296,100,72,9,2789,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3816,3820,3822,3818,3804,3807,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,953,SUCCESS,,2793.588539,192,0,0.1,0.2,0.3,263,1.4,1.5
    3369,5/26/2021 22:57,13502.079,3.75,701,300,10,6001,0,65535,65535,1,21.9,26691,-298,-296,100,72,9,2788,3888,561,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3820,3822,3818,3804,3808,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,962,SUCCESS,,2793.2566,192,0,0.1,0.2,0.3,263,1.4,1.5
    3370,5/26/2021 22:57,13506.09,3.75,701,300,10,6001,0,65535,65535,1,21.9,26689,-296,-296,100,72,9,2788,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3820,3821,3818,3804,3808,3803,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,945,SUCCESS,,2792.926807,192,0,0.1,0.2,0.3,263,1.4,1.5
    3371,5/26/2021 22:57,13510.103,3.75,701,300,10,6001,0,65535,65535,1,21.9,26687,-296,-296,100,72,9,2788,3888,561,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3820,3821,3818,3803,3807,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,979,SUCCESS,,2792.596849,192,0,0.1,0.2,0.3,263,1.4,1.5
    3372,5/26/2021 22:58,13514.112,3.75,701,300,10,6001,0,65535,65535,1,21.9,26685,-298,-296,100,72,9,2787,3888,561,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3820,3821,3818,3803,3807,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,939,SUCCESS,,2792.264993,192,0,0.1,0.2,0.3,263,1.4,1.5
    3373,5/26/2021 22:58,13518.115,3.76,701,300,10,6001,0,65535,65535,1,21.9,26686,-296,-296,100,72,9,2787,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3820,3821,3817,3803,3808,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,972,SUCCESS,,2791.935858,192,0,0.1,0.2,0.3,263,1.4,1.5
    3374,5/26/2021 22:58,13522.124,3.76,701,300,10,6001,0,65535,65535,1,21.9,26685,-296,-296,100,72,9,2787,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3820,3821,3817,3803,3807,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,981,SUCCESS,,2791.606229,192,0,0.1,0.2,0.3,263,1.4,1.5
    3375,5/26/2021 22:58,13526.132,3.76,701,300,10,6001,0,65535,65535,1,21.9,26684,-296,-297,100,72,9,2786,3888,561,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3819,3821,3817,3803,3807,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,967,SUCCESS,,2791.276682,192,0,0.1,0.2,0.3,263,1.4,1.5
    3376,5/26/2021 22:58,13530.138,3.76,701,300,10,6001,0,65535,65535,1,21.9,26683,-296,-296,100,72,9,2786,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3819,3821,3817,3803,3807,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,949,SUCCESS,,2790.9473,192,0,0.1,0.2,0.3,263,1.4,1.5
    3377,5/26/2021 22:58,13534.141,3.76,701,300,10,6001,0,65535,65535,1,21.9,26684,-296,-296,100,72,9,2786,3888,561,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3819,3821,3817,3803,3806,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.7,942,SUCCESS,,2790.618164,192,0,0.1,0.2,0.3,263,1.4,1.5
    3378,5/26/2021 22:58,13538.15,3.76,701,300,10,6001,0,65535,65535,1,21.9,26683,-296,-296,100,72,9,2785,3888,565,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3819,3821,3817,3803,3806,3802,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,969,SUCCESS,,2790.288535,192,0,0.1,0.2,0.3,263,1.4,1.5
    3379,5/26/2021 22:58,13542.164,3.76,701,300,10,6001,0,65535,65535,1,21.9,26680,-296,-296,100,72,9,2785,3888,568,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3815,3819,3821,3817,3803,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,958,SUCCESS,,2789.958495,192,0,0.1,0.2,0.3,263,1.4,1.5
    3380,5/26/2021 22:58,13546.169,3.76,701,300,10,6001,0,65535,65535,1,21.9,26680,-298,-296,100,72,9,2785,3888,561,565,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3819,3820,3817,3803,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,981,SUCCESS,,2789.62697,192,0,0.1,0.2,0.3,263,1.4,1.5
    3381,5/26/2021 22:58,13550.177,3.76,701,300,10,6001,0,65535,65535,1,21.9,26678,-296,-296,100,72,9,2784,3888,568,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3820,3816,3803,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,1006,SUCCESS,,2789.297424,192,0,0.1,0.2,0.3,263,1.4,1.5
    3382,5/26/2021 22:58,13554.182,3.77,701,300,10,6001,0,65535,65535,1,21.9,26678,-298,-296,100,72,9,2784,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3820,3816,3803,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,1012,SUCCESS,,2788.965899,192,0,0.1,0.2,0.3,263,1.4,1.5
    3383,5/26/2021 22:58,13558.182,3.77,701,300,10,6001,0,65535,65535,1,21.9,26678,-296,-296,100,72,9,2784,3888,561,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3819,3816,3802,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,952,SUCCESS,,2788.63701,192,0,0.1,0.2,0.3,263,1.4,1.5
    3384,5/26/2021 22:58,13562.184,3.77,701,300,10,6001,0,65535,65535,1,21.9,26677,-296,-296,100,72,9,2783,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3820,3816,3802,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,946,SUCCESS,,2788.307956,192,0,0.1,0.2,0.3,263,1.4,1.5
    3385,5/26/2021 22:58,13566.188,3.77,701,300,10,6001,0,65535,65535,1,21.9,26672,-294,-296,100,72,9,2783,3888,557,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3820,3816,3802,3806,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,958,SUCCESS,,2787.980963,192,0,0.1,0.2,0.3,263,1.4,1.5
    3386,5/26/2021 22:58,13570.199,3.77,701,300,10,6001,0,65535,65535,1,21.9,26676,-296,-296,100,72,9,2783,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3820,3816,3802,3805,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,961,SUCCESS,,2787.65117,192,0,0.1,0.2,0.3,263,1.4,1.5
    3387,5/26/2021 22:59,13574.212,3.77,701,300,10,6001,0,65535,65535,1,21.9,26674,-296,-296,100,72,9,2782,3888,560,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3818,3819,3816,3802,3805,3801,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,955,SUCCESS,,2787.321212,192,0,0.1,0.2,0.3,263,1.4,1.5
    3388,5/26/2021 22:59,13578.213,3.77,701,300,10,6001,0,65535,65535,1,21.9,26673,-298,-296,100,72,9,2782,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3816,3802,3805,3800,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,963,SUCCESS,,2786.990018,192,0,0.1,0.2,0.3,263,1.4,1.5
    3389,5/26/2021 22:59,13582.216,3.77,701,300,10,6001,0,65535,65535,1,21.9,26671,-298,-296,100,72,9,2782,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3814,3817,3819,3815,3802,3804,3800,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,981,SUCCESS,,2786.658659,192,0,0.1,0.2,0.3,263,1.4,1.5
    3390,5/26/2021 22:59,13586.219,3.77,701,300,10,6001,0,65535,65535,1,21.9,26670,-296,-296,100,72,9,2781,3888,560,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3815,3801,3805,3800,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,958,SUCCESS,,2786.329523,192,0,0.1,0.2,0.3,263,1.4,1.5
    3391,5/26/2021 22:59,13590.219,3.78,701,300,10,6001,0,65535,65535,1,21.9,26670,-296,-296,100,72,9,2781,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3815,3801,3805,3800,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,973,SUCCESS,,2786.000634,192,0,0.1,0.2,0.3,263,1.4,1.5
    3392,5/26/2021 22:59,13594.222,3.78,701,300,10,6001,0,65535,65535,1,21.9,26669,-296,-296,100,72,9,2781,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3815,3801,3804,3800,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,21.9,944,SUCCESS,,2785.671499,192,0,0.1,0.2,0.3,263,1.4,1.5
    3393,5/26/2021 22:59,13598.227,3.78,701,300,10,6001,0,65535,65535,1,21.9,26670,-296,-296,100,72,9,2780,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3815,3801,3804,3800,0,0,0,0,0,0,0,0,2667,21.7,21.9,-273.2,21.9,-273.2,22,995,SUCCESS,,2785.342199,192,0,0.1,0.2,0.3,263,1.4,1.5
    3394,5/26/2021 22:59,13602.24,3.78,701,300,10,6001,0,65535,65535,1,21.9,26669,-296,-296,100,72,9,2780,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3815,3801,3804,3800,0,0,0,0,0,0,0,0,2663,21.7,21.9,-273.2,21.9,-273.2,21.9,954,SUCCESS,,2785.012241,192,0,0.1,0.2,0.3,263,1.4,1.5
    3395,5/26/2021 22:59,13606.245,3.78,701,300,10,6001,0,65535,65535,1,21.9,26669,-296,-296,100,72,9,2780,3888,564,564,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3813,3817,3819,3815,3801,3804,3800,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,947,SUCCESS,,2784.682941,192,0,0.1,0.2,0.3,263,1.4,1.5
    3396,5/26/2021 22:59,13610.248,3.78,701,300,10,6001,0,65535,65535,1,21.9,26668,-294,-296,100,72,9,2779,3888,567,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3817,3819,3815,3801,3804,3799,0,0,0,0,0,0,0,0,2666,21.7,21.9,-273.2,21.9,-273.2,21.5,944,SUCCESS,,2784.356029,192,0,0.1,0.2,0.3,263,1.4,1.5
    3397,5/26/2021 22:59,13614.256,3.78,701,300,10,6001,0,65535,65535,1,21.9,26667,-298,-296,100,72,9,2779,3888,560,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3817,3819,3815,3801,3804,3799,0,0,0,0,0,0,0,0,2666,21.7,21.9,-273.2,21.9,-273.2,21.9,974,SUCCESS,,2784.024256,192,0,0.1,0.2,0.3,263,1.4,1.5
    3398,5/26/2021 22:59,13618.268,3.78,701,300,10,6001,0,65535,65535,1,21.9,26667,-298,-296,100,72,9,2779,3888,560,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3817,3819,3815,3801,3804,3799,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,956,SUCCESS,,2783.692151,192,0,0.1,0.2,0.3,263,1.4,1.5
    3399,5/26/2021 22:59,13622.274,3.78,701,300,10,6001,0,65535,65535,1,21.9,26666,-296,-296,100,72,9,2778,3888,563,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3816,3819,3814,3800,3804,3799,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,981,SUCCESS,,2783.362769,192,0,0.1,0.2,0.3,263,1.4,1.5
    3400,5/26/2021 22:59,13626.28,3.79,701,300,10,6001,0,65535,65535,1,21.9,26663,-294,-296,100,72,9,2778,3888,567,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3816,3818,3814,3800,3804,3799,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,950,SUCCESS,,2783.035613,192,0,0.1,0.2,0.3,263,1.4,1.5
    3401,5/26/2021 22:59,13630.291,3.79,701,300,10,6001,0,65535,65535,1,21.9,26662,-296,-296,100,72,9,2778,3888,563,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3816,3818,3814,3800,3803,3799,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,937,SUCCESS,,2782.705819,192,0,0.1,0.2,0.3,263,1.4,1.5
    3402,5/26/2021 23:00,13634.301,3.79,701,300,10,6001,0,65535,65535,1,21.9,26662,-296,-296,100,72,9,2777,3888,563,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3816,3818,3814,3800,3803,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,952,SUCCESS,,2782.376108,192,0,0.1,0.2,0.3,263,1.4,1.5
    3403,5/26/2021 23:00,13638.31,3.79,701,300,10,6001,0,65535,65535,1,21.9,26661,-296,-296,100,72,9,2777,3888,559,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3816,3818,3814,3800,3803,3799,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,966,SUCCESS,,2782.046479,192,0,0.1,0.2,0.3,263,1.4,1.5
    3404,5/26/2021 23:00,13642.322,3.79,701,300,10,6001,0,65535,65535,1,21.9,26661,-298,-296,100,72,9,2777,3888,559,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3816,3818,3814,3800,3803,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,22,935,SUCCESS,,2781.714375,192,0,0.1,0.2,0.3,263,1.4,1.5
    3405,5/26/2021 23:00,13646.326,3.79,701,300,10,6001,0,65535,65535,1,21.9,26661,-294,-296,100,72,9,2776,3888,567,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3812,3815,3818,3814,3800,3803,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,951,SUCCESS,,2781.387381,192,0,0.1,0.2,0.3,263,1.4,1.5
    3406,5/26/2021 23:00,13650.326,3.79,701,300,10,6001,0,65535,65535,1,21.9,26660,-298,-296,100,72,9,2776,3888,559,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3818,3814,3800,3805,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,951,SUCCESS,,2781.05627,192,0,0.1,0.2,0.3,263,1.4,1.5
    3407,5/26/2021 23:00,13654.332,3.79,701,300,10,6001,0,65535,65535,1,21.9,26658,-296,-297,100,72,9,2776,3888,559,561,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3817,3813,3800,3803,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,953,SUCCESS,,2780.726888,192,0,0.1,0.2,0.3,263,1.4,1.5
    3408,5/26/2021 23:00,13658.345,3.79,701,300,10,6001,0,65535,65535,1,21.9,26656,-296,-296,100,72,9,2775,3888,563,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3817,3813,3799,3803,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,938,SUCCESS,,2780.39693,192,0,0.1,0.2,0.3,263,1.4,1.5
    3409,5/26/2021 23:00,13662.353,3.8,701,300,10,6001,0,65535,65535,1,21.9,26657,-296,-296,100,72,9,2775,3888,559,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3817,3813,3800,3805,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,947,SUCCESS,,2780.067384,192,0,0.1,0.2,0.3,263,1.4,1.5
    3410,5/26/2021 23:00,13666.356,3.8,701,300,10,6001,0,65535,65535,1,21.9,26655,-296,-296,100,72,9,2775,3888,566,563,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3817,3813,3799,3803,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,946,SUCCESS,,2779.738248,192,0,0.1,0.2,0.3,263,1.4,1.5
    3411,5/26/2021 23:00,13670.367,3.8,701,300,10,6001,0,65535,65535,1,21.9,26656,-296,-296,100,72,9,2774,3888,562,562,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3817,3813,3798,3802,3798,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,948,SUCCESS,,2779.408455,192,0,0.1,0.2,0.3,263,1.4,1.5
    3412,5/26/2021 23:00,13674.368,3.8,701,300,10,6001,0,65535,65535,1,21.9,26656,-298,-296,100,72,9,2774,3888,562,562,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3811,3815,3817,3812,3799,3805,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,953,SUCCESS,,2779.077261,192,0,0.1,0.2,0.3,263,1.4,1.5
    3413,5/26/2021 23:00,13678.39,3.8,701,300,10,6001,0,65535,65535,1,21.9,26653,-296,-296,100,72,9,2774,3888,566,562,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3815,3817,3812,3799,3802,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,993,SUCCESS,,2778.746563,192,0,0.1,0.2,0.3,263,1.4,1.5
    3414,5/26/2021 23:00,13682.413,3.8,701,300,10,6001,0,65535,65535,1,21.9,26652,-298,-296,100,72,9,2773,3888,562,562,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3817,3812,3798,3802,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,935,SUCCESS,,2778.413548,192,0,0.1,0.2,0.3,263,1.4,1.5
    3415,5/26/2021 23:00,13686.422,3.8,701,300,10,6001,0,65535,65535,1,21.9,26651,-298,-296,100,72,9,2773,3888,558,562,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3817,3812,3798,3805,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,967,SUCCESS,,2778.081692,192,0,0.1,0.2,0.3,263,1.4,1.5
    3416,5/26/2021 23:00,13690.438,3.8,701,300,10,6001,0,65535,65535,1,21.9,26649,-296,-296,100,72,9,2773,3888,562,562,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3816,3812,3799,3802,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,939,SUCCESS,,2777.751488,192,0,0.1,0.2,0.3,263,1.4,1.5
    3417,5/26/2021 23:01,13694.46,3.8,701,300,10,6001,0,65535,65535,1,21.9,26650,-298,-297,100,72,9,2772,3888,558,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3817,3812,3798,3802,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,933,SUCCESS,,2777.418555,192,0,0.1,0.2,0.3,263,1.4,1.5
    3418,5/26/2021 23:01,13698.47,3.81,701,300,10,6001,0,65535,65535,1,21.9,26649,-296,-297,100,72,9,2772,3888,558,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3816,3812,3798,3806,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,945,SUCCESS,,2777.088844,192,0,0.1,0.2,0.3,263,1.4,1.5
    3419,5/26/2021 23:01,13702.485,3.81,701,300,10,6001,0,65535,65535,1,21.9,26649,-296,-297,100,72,9,2772,3888,562,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3816,3812,3798,3802,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,944,SUCCESS,,2776.758722,192,0,0.1,0.2,0.3,263,1.4,1.5
    3420,5/26/2021 23:01,13706.492,3.81,701,300,10,6001,0,65535,65535,1,21.9,26648,-296,-297,100,72,9,2771,3888,562,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3816,3812,3798,3801,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,938,SUCCESS,,2776.429258,192,0,0.1,0.2,0.3,263,1.4,1.5
    3421,5/26/2021 23:01,13710.5,3.81,701,300,10,6001,0,65535,65535,1,21.9,26647,-298,-297,100,72,9,2771,3888,562,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3810,3814,3816,3812,3798,3801,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,947,SUCCESS,,2776.097484,192,0,0.1,0.2,0.3,263,1.4,1.5
    3422,5/26/2021 23:01,13714.516,3.81,701,300,10,6001,0,65535,65535,1,21.9,26646,-298,-297,100,72,9,2771,3888,562,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3814,3816,3812,3798,3801,3797,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,945,SUCCESS,,2775.765049,192,0,0.1,0.2,0.3,263,1.4,1.5
    3423,5/26/2021 23:01,13718.554,3.81,701,300,10,6001,0,65535,65535,1,21.9,26645,-296,-297,100,72,9,2770,3888,561,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3814,3816,3812,3798,3801,3796,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,940,SUCCESS,,2775.433035,192,0,0.1,0.2,0.3,263,1.4,1.5
    3424,5/26/2021 23:01,13722.562,3.81,701,300,10,6001,0,65535,65535,1,21.9,26644,-296,-297,100,72,9,2770,3888,565,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3814,3816,3811,3798,3801,3796,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,957,SUCCESS,,2775.103489,192,0,0.1,0.2,0.3,263,1.4,1.5
    3425,5/26/2021 23:01,13726.562,3.81,701,300,10,6001,0,65535,65535,1,21.9,26643,-298,-296,100,72,9,2770,3888,558,560,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3813,3815,3811,3798,3801,3796,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,22,943,SUCCESS,,2774.772378,192,0,0.1,0.2,0.3,263,1.4,1.5
    3426,5/26/2021 23:01,13730.594,3.81,701,300,10,6001,0,65535,65535,1,21.9,26642,-296,-297,100,72,9,2769,3888,561,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3813,3815,3811,3798,3801,3796,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,982,SUCCESS,,2774.440858,192,0,0.1,0.2,0.3,263,1.4,1.5
    3427,5/26/2021 23:01,13734.609,3.82,701,300,10,6001,0,65535,65535,1,21.9,26642,-296,-296,100,72,9,2769,3888,561,561,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3813,3815,3811,3797,3801,3796,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,940,SUCCESS,,2774.110735,192,0,0.1,0.2,0.3,263,1.4,1.5
    3428,5/26/2021 23:01,13738.528,3.82,701,300,10,6001,0,65535,65535,1,21.9,26642,-298,-297,100,72,9,2769,3888,558,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3813,3815,3811,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,947,SUCCESS,,2773.786329,192,0,0.1,0.2,0.3,263,1.4,1.5
    3429,5/26/2021 23:01,13742.539,3.82,701,300,10,6001,0,65535,65535,1,21.9,26640,-296,-297,100,72,9,2768,3888,561,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3813,3815,3811,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,949,SUCCESS,,2773.456536,192,0,0.1,0.2,0.3,263,1.4,1.5
    3430,5/26/2021 23:01,13746.545,3.82,701,300,10,6001,0,65535,65535,1,21.9,26640,-296,-297,100,72,9,2768,3888,561,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3813,3815,3811,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,940,SUCCESS,,2773.127154,192,0,0.1,0.2,0.3,263,1.4,1.5
    3431,5/26/2021 23:01,13750.55,3.82,701,300,10,6001,0,65535,65535,1,21.9,26639,-298,-297,100,72,9,2768,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3809,3812,3815,3811,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,943,SUCCESS,,2772.795629,192,0,0.1,0.2,0.3,263,1.4,1.5
    3432,5/26/2021 23:02,13754.564,3.82,701,300,10,6001,0,65535,65535,1,21.9,26638,-298,-297,100,72,9,2767,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3815,3811,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,937,SUCCESS,,2772.463359,192,0,0.1,0.2,0.3,263,1.4,1.5
    3433,5/26/2021 23:02,13758.565,3.82,701,300,10,6001,0,65535,65535,1,21.9,26636,-298,-297,100,72,9,2767,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3815,3810,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,953,SUCCESS,,2772.132165,192,0,0.1,0.2,0.3,263,1.4,1.5
    3434,5/26/2021 23:02,13762.571,3.82,701,300,10,6001,0,65535,65535,1,21.9,26636,-298,-297,100,72,9,2767,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3814,3810,3797,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.5,949,SUCCESS,,2771.800557,192,0,0.1,0.2,0.3,263,1.4,1.5
    3435,5/26/2021 23:02,13766.572,3.82,701,300,10,6001,0,65535,65535,1,21.9,26636,-294,-297,100,72,9,2766,3888,564,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3814,3810,3796,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,22,957,SUCCESS,,2771.473809,192,0,0.1,0.2,0.3,263,1.4,1.5
    3436,5/26/2021 23:02,13770.578,3.83,701,300,10,6001,0,65535,65535,1,21.9,26635,-298,-297,100,72,9,2766,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3814,3810,3796,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,941,SUCCESS,,2771.142201,192,0,0.1,0.2,0.3,263,1.4,1.5
    3437,5/26/2021 23:02,13774.582,3.83,701,300,10,6001,0,65535,65535,1,21.9,26635,-298,-297,100,72,9,2766,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3814,3810,3796,3800,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,969,SUCCESS,,2770.810759,192,0,0.1,0.2,0.3,263,1.4,1.5
    3438,5/26/2021 23:02,13778.594,3.83,701,300,10,6001,0,65535,65535,1,21.9,26635,-298,-297,100,72,9,2765,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3814,3810,3796,3799,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,966,SUCCESS,,2770.478654,192,0,0.1,0.2,0.3,263,1.4,1.5
    3439,5/26/2021 23:02,13782.597,3.83,701,300,10,6001,0,65535,65535,1,21.9,26634,-298,-297,100,72,9,2765,3888,557,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3808,3812,3814,3809,3796,3799,3795,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,935,SUCCESS,,2770.147295,192,0,0.1,0.2,0.3,263,1.4,1.5
    3440,5/26/2021 23:02,13786.61,3.83,701,300,10,6001,0,65535,65535,1,21.9,26630,-298,-297,100,72,9,2765,3888,560,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3814,3809,3796,3799,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,950,SUCCESS,,2769.815108,192,0,0.1,0.2,0.3,263,1.4,1.5
    3441,5/26/2021 23:02,13790.612,3.83,701,300,10,6001,0,65535,65535,1,21.9,26629,-298,-297,100,72,9,2764,3888,560,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3813,3809,3796,3799,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,939,SUCCESS,,2769.483831,192,0,0.1,0.2,0.3,263,1.4,1.5
    3442,5/26/2021 23:02,13794.627,3.83,701,300,10,6001,0,65535,65535,1,21.9,26628,-296,-297,100,72,9,2764,3888,560,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3813,3809,3795,3799,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,954,SUCCESS,,2769.153709,192,0,0.1,0.2,0.3,263,1.4,1.5
    3443,5/26/2021 23:02,13798.637,3.83,701,300,10,6001,0,65535,65535,1,21.9,26628,-294,-297,100,72,9,2764,3888,560,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3813,3809,3795,3799,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,977,SUCCESS,,2768.826225,192,0,0.1,0.2,0.3,263,1.4,1.5
    3444,5/26/2021 23:02,13802.652,3.83,701,300,10,6001,0,65535,65535,1,21.9,26627,-298,-297,100,72,9,2763,3888,556,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3813,3809,3795,3798,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,959,SUCCESS,,2768.493873,192,0,0.1,0.2,0.3,263,1.4,1.5
    3445,5/26/2021 23:02,13806.66,3.84,701,300,10,6001,0,65535,65535,1,21.9,26628,-298,-297,100,72,9,2763,3888,556,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3813,3809,3795,3798,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,961,SUCCESS,,2768.162099,192,0,0.1,0.2,0.3,263,1.4,1.5
    3446,5/26/2021 23:02,13810.672,3.84,701,300,10,6001,0,65535,65535,1,21.9,26625,-296,-297,100,72,9,2763,3888,556,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3807,3811,3813,3809,3795,3798,3794,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,973,SUCCESS,,2767.832224,192,0,0.1,0.2,0.3,263,1.4,1.5
    3447,5/26/2021 23:03,13814.685,3.84,701,300,10,6001,0,65535,65535,1,21.9,26626,-300,-297,100,72,9,2762,3888,564,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3811,3813,3809,3795,3798,3793,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.8,960,SUCCESS,,2767.497807,192,0,0.1,0.2,0.3,263,1.4,1.5
    3448,5/26/2021 23:03,13818.695,3.84,701,300,10,6001,0,65535,65535,1,21.9,26626,-296,-297,100,72,9,2762,3888,556,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3811,3812,3809,3794,3798,3793,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,22,982,SUCCESS,,2767.168096,192,0,0.1,0.2,0.3,263,1.4,1.5
    3449,5/26/2021 23:03,13822.703,3.84,701,300,10,6001,0,65535,65535,1,21.9,26623,-298,-297,100,72,9,2762,3888,560,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3811,3812,3808,3795,3798,3793,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,22,955,SUCCESS,,2766.836323,192,0,0.1,0.2,0.3,263,1.4,1.5
    3450,5/26/2021 23:03,13826.712,3.84,701,300,10,6001,0,65535,65535,1,21.9,26622,-296,-297,100,72,9,2762,3888,556,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3810,3812,3808,3795,3798,3793,0,0,0,0,0,0,0,0,2662,21.7,21.9,-273.2,21.9,-273.2,21.9,969,SUCCESS,,2766.506694,192,0,0.1,0.2,0.3,263,1.4,1.5
    3451,5/26/2021 23:03,13830.718,3.84,701,300,10,6001,0,65535,65535,1,21.9,26621,-296,-297,100,72,9,2761,3888,560,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3810,3812,3808,3794,3798,3793,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,940,SUCCESS,,2766.177311,192,0,0.1,0.2,0.3,263,1.4,1.5
    3452,5/26/2021 23:03,13834.723,3.84,701,300,10,6001,0,65535,65535,1,21.9,26620,-298,-297,100,72,9,2761,3888,560,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3810,3812,3808,3794,3798,3793,0,0,0,0,0,0,0,0,2661,21.7,21.9,-273.2,21.9,-273.2,21.9,956,SUCCESS,,2765.845786,192,0,0.1,0.2,0.3,263,1.4,1.5
    3453,5/26/2021 23:03,13838.732,3.84,701,300,10,6001,0,65535,65535,1,21.9,26620,-296,-297,100,72,9,2761,3888,552,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3810,3812,3808,3794,3798,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.5,974,SUCCESS,,2765.516158,192,0,0.1,0.2,0.3,263,1.4,1.5
    3454,5/26/2021 23:03,13842.741,3.85,701,300,10,6001,0,65535,65535,1,21.9,26620,-298,-297,100,71,9,2760,3888,559,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3810,3812,3808,3794,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,996,SUCCESS,,2765.184301,192,0,0.1,0.2,0.3,263,1.4,1.5
    3455,5/26/2021 23:03,13846.755,3.85,701,300,10,6001,0,65535,65535,1,21.9,26619,-296,-297,100,71,9,2760,3888,556,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3806,3810,3812,3808,3794,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,975,SUCCESS,,2764.854261,192,0,0.1,0.2,0.3,263,1.4,1.5
    3456,5/26/2021 23:03,13850.76,3.85,701,300,10,6001,0,65535,65535,1,21.9,26616,-296,-297,100,71,9,2760,3888,559,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3805,3809,3811,3808,3794,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,966,SUCCESS,,2764.524961,192,0,0.1,0.2,0.3,263,1.4,1.5
    3457,5/26/2021 23:03,13854.766,3.85,701,300,10,6001,0,65535,65535,1,21.9,26616,-298,-297,100,71,9,2759,3888,556,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3805,3809,3811,3807,3794,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,949,SUCCESS,,2764.193354,192,0,0.1,0.2,0.3,263,1.4,1.5
    3458,5/26/2021 23:03,13858.773,3.85,701,300,10,6001,0,65535,65535,1,21.9,26616,-296,-297,100,71,9,2759,3888,559,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3805,3809,3811,3808,3794,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,22,970,SUCCESS,,2763.863889,192,0,0.1,0.2,0.3,263,1.4,1.5
    3459,5/26/2021 23:03,13862.78,3.85,701,300,10,6001,0,65535,65535,1,21.9,26613,-294,-297,100,71,9,2759,3888,559,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3805,3809,3811,3807,3794,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,22,946,SUCCESS,,2763.536651,192,0,0.1,0.2,0.3,263,1.4,1.5
    3460,5/26/2021 23:03,13866.785,3.85,701,300,10,6001,0,65535,65535,1,21.9,26614,-298,-297,100,71,9,2758,3888,559,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3805,3809,3811,3807,3793,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,967,SUCCESS,,2763.205126,192,0,0.1,0.2,0.3,263,1.4,1.5
    3461,5/26/2021 23:03,13870.79,3.85,701,300,10,6001,0,65535,65535,1,21.9,26615,-296,-297,100,71,9,2758,3888,555,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3805,3809,3811,3807,3793,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,1000,SUCCESS,,2762.875826,192,0,0.1,0.2,0.3,263,1.4,1.5
    3462,5/26/2021 23:04,13874.792,3.85,701,300,10,6001,0,65535,65535,1,21.8,26610,-296,-296,100,71,9,2758,3888,563,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3809,3811,3807,3793,3797,3792,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,965,SUCCESS,,2762.546773,192,0,0.1,0.2,0.3,263,1.4,1.5
    3463,5/26/2021 23:04,13878.806,3.86,701,300,10,6001,0,65535,65535,1,21.8,26612,-298,-297,100,71,9,2757,3888,559,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3809,3811,3807,3793,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,985,SUCCESS,,2762.214503,192,0,0.1,0.2,0.3,263,1.4,1.5
    3464,5/26/2021 23:04,13882.819,3.86,701,300,10,6001,0,65535,65535,1,21.9,26610,-296,-297,100,71,9,2757,3888,559,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3809,3811,3807,3793,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,22,970,SUCCESS,,2761.884545,192,0,0.1,0.2,0.3,263,1.4,1.5
    3465,5/26/2021 23:04,13886.832,3.86,701,300,10,6001,0,65535,65535,1,21.8,26608,-298,-296,100,71,9,2756,3888,555,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3811,3807,3793,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,957,SUCCESS,,2761.552358,192,0,0.1,0.2,0.3,263,1.4,1.5
    3466,5/26/2021 23:04,13890.848,3.86,701,300,10,6001,0,65535,65535,1,21.8,26609,-296,-297,100,71,9,2756,3888,559,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3811,3806,3792,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,960,SUCCESS,,2761.222153,192,0,0.1,0.2,0.3,263,1.4,1.5
    3467,5/26/2021 23:04,13894.848,3.86,701,300,10,6001,0,65535,65535,1,21.9,26608,-294,-296,100,71,9,2756,3888,562,559,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3810,3806,3792,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.2,955,SUCCESS,,2760.895486,192,0,0.1,0.2,0.3,263,1.4,1.5
    3468,5/26/2021 23:04,13898.862,3.86,701,300,10,6001,0,65535,65535,1,21.8,26604,-298,-296,100,71,9,2755,3888,555,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3810,3806,3792,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.8,-273.2,21.9,939,SUCCESS,,2760.563216,192,0,0.1,0.2,0.3,263,1.4,1.5
    3469,5/26/2021 23:04,13902.869,3.86,701,300,10,6001,0,65535,65535,1,21.9,26607,-298,-297,100,71,9,2755,3888,555,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3810,3806,3792,3795,3791,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,945,SUCCESS,,2760.231526,192,0,0.1,0.2,0.3,263,1.4,1.5
    3470,5/26/2021 23:04,13906.881,3.86,701,300,10,6001,0,65535,65535,1,21.9,26606,-296,-296,100,71,9,2755,3888,558,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3810,3806,3792,3796,3791,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,943,SUCCESS,,2759.90165,192,0,0.1,0.2,0.3,263,1.4,1.5
    3471,5/26/2021 23:04,13910.896,3.86,701,300,10,6001,0,65535,65535,1,21.8,26606,-298,-297,100,71,9,2755,3888,555,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3804,3808,3810,3806,3792,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,966,SUCCESS,,2759.569298,192,0,0.1,0.2,0.3,263,1.4,1.5
    3472,5/26/2021 23:04,13914.913,3.87,701,300,10,6001,0,65535,65535,1,21.8,26604,-296,-297,100,71,9,2754,3888,558,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3808,3810,3806,3792,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,22,949,SUCCESS,,2759.239011,192,0,0.1,0.2,0.3,263,1.4,1.5
    3473,5/26/2021 23:04,13918.921,3.87,701,300,10,6001,0,65535,65535,1,21.8,26604,-298,-297,100,71,9,2754,3888,558,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3808,3810,3806,3792,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,972,SUCCESS,,2758.907238,192,0,0.1,0.2,0.3,263,1.4,1.5
    3474,5/26/2021 23:04,13922.937,3.87,701,300,10,6001,0,65535,65535,1,21.8,26603,-298,-297,100,71,9,2754,3888,558,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3808,3809,3805,3792,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.8,940,SUCCESS,,2758.574802,192,0,0.1,0.2,0.3,263,1.4,1.5
    3475,5/26/2021 23:04,13926.946,3.87,701,300,10,6001,0,65535,65535,1,21.8,26602,-296,-297,100,71,9,2753,3888,558,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3805,3792,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,953,SUCCESS,,2758.245173,192,0,0.1,0.2,0.3,263,1.4,1.5
    3476,5/26/2021 23:04,13930.951,3.87,701,300,10,6001,0,65535,65535,1,21.8,26602,-298,-296,100,71,9,2753,3888,554,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3805,3792,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,965,SUCCESS,,2757.913648,192,0,0.1,0.2,0.3,263,1.4,1.5
    3477,5/26/2021 23:05,13934.954,3.87,701,300,10,6001,0,65535,65535,1,21.8,26601,-296,-296,100,71,9,2753,3888,558,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3805,3791,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,22,977,SUCCESS,,2757.584513,192,0,0.1,0.2,0.3,263,1.4,1.5
    3478,5/26/2021 23:05,13938.962,3.87,701,300,10,6001,0,65535,65535,1,21.8,26599,-296,-296,100,71,9,2752,3888,562,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3805,3791,3794,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,949,SUCCESS,,2757.254966,192,0,0.1,0.2,0.3,263,1.4,1.5
    3479,5/26/2021 23:05,13942.974,3.87,701,300,10,6001,0,65535,65535,1,21.8,26599,-298,-296,100,71,9,2752,3888,554,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3805,3791,3795,3790,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,966,SUCCESS,,2756.922861,192,0,0.1,0.2,0.3,263,1.4,1.5
    3480,5/26/2021 23:05,13946.988,3.87,701,300,10,6001,0,65535,65535,1,21.8,26597,-298,-296,100,71,9,2752,3888,558,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3804,3791,3795,3789,0,0,0,0,0,0,0,0,2658,21.7,21.9,-273.2,21.9,-273.2,21.9,943,SUCCESS,,2756.590591,192,0,0.1,0.2,0.3,263,1.4,1.5
    3481,5/26/2021 23:05,13950.991,3.88,701,300,10,6001,0,65535,65535,1,21.8,26597,-296,-296,100,71,9,2751,3888,558,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3803,3807,3809,3805,3791,3794,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.7,964,SUCCESS,,2756.261456,192,0,0.1,0.2,0.3,263,1.4,1.5
    3482,5/26/2021 23:05,13954.991,3.88,701,300,10,6001,0,65535,65535,1,21.8,26595,-298,-296,100,71,9,2751,3888,554,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3802,3807,3809,3804,3791,3794,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,948,SUCCESS,,2755.930345,192,0,0.1,0.2,0.3,263,1.4,1.5
    3483,5/26/2021 23:05,13958.996,3.88,701,300,10,6001,0,65535,65535,1,21.8,26595,-298,-296,100,71,9,2751,3888,558,558,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3802,3806,3809,3804,3791,3794,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,943,SUCCESS,,2755.59882,192,0,0.1,0.2,0.3,263,1.4,1.5
    3484,5/26/2021 23:05,13963.001,3.88,701,300,10,6001,0,65535,65535,1,21.8,26594,-298,-297,100,71,9,2750,3888,554,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3802,3806,3808,3804,3790,3794,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,939,SUCCESS,,2755.267295,192,0,0.1,0.2,0.3,263,1.4,1.5
    3485,5/26/2021 23:05,13967.015,3.88,701,300,10,6001,0,65535,65535,1,21.8,26593,-296,-297,100,71,9,2750,3888,561,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3802,3806,3808,3804,3790,3794,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,22,942,SUCCESS,,2754.937255,192,0,0.1,0.2,0.3,263,1.4,1.5
    3486,5/26/2021 23:05,13971.021,3.88,701,300,10,6001,0,65535,65535,1,21.8,26593,-298,-297,100,71,9,2750,3888,557,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3802,3806,3808,3804,3790,3795,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,950,SUCCESS,,2754.605647,192,0,0.1,0.2,0.3,263,1.4,1.5
    3487,5/26/2021 23:05,13975.024,3.88,701,300,10,6001,0,65535,65535,1,21.8,26592,-296,-297,100,71,9,2749,3888,557,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3802,3806,3808,3804,3790,3794,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,960,SUCCESS,,2754.276511,192,0,0.1,0.2,0.3,263,1.4,1.5
    3488,5/26/2021 23:05,13979.032,3.88,701,300,10,6001,0,65535,65535,1,21.8,26592,-296,-297,100,71,9,2749,3888,557,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3806,3808,3804,3790,3793,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,955,SUCCESS,,2753.946965,192,0,0.1,0.2,0.3,263,1.4,1.5
    3489,5/26/2021 23:05,13983.044,3.88,701,300,10,6001,0,65535,65535,1,21.8,26591,-296,-296,100,71,9,2749,3888,557,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3806,3808,3804,3790,3793,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,960,SUCCESS,,2753.617089,192,0,0.1,0.2,0.3,263,1.4,1.5
    3490,5/26/2021 23:05,13987.058,3.89,701,300,10,6001,0,65535,65535,1,21.8,26588,-298,-297,100,71,9,2748,3888,553,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3806,3808,3803,3790,3793,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.6,980,SUCCESS,,2753.284819,192,0,0.1,0.2,0.3,263,1.4,1.5
    3491,5/26/2021 23:05,13991.064,3.89,701,300,10,6001,0,65535,65535,1,21.8,26589,-296,-297,100,71,9,2748,3888,557,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3805,3808,3803,3790,3792,3789,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,940,SUCCESS,,2752.955437,192,0,0.1,0.2,0.3,263,1.4,1.5
    3492,5/26/2021 23:06,13995.072,3.89,701,300,10,6001,0,65535,65535,1,21.8,26588,-294,-297,100,71,9,2748,3888,553,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3806,3808,3803,3790,3797,3788,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,962,SUCCESS,,2752.628117,192,0,0.1,0.2,0.3,263,1.4,1.5
    3493,5/26/2021 23:06,13999.075,3.89,701,300,10,6001,0,65535,65535,1,21.8,26587,-298,-297,100,71,9,2747,3888,553,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3805,3807,3803,3789,3793,3788,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,940,SUCCESS,,2752.296758,192,0,0.1,0.2,0.3,263,1.4,1.5
    3494,5/26/2021 23:06,14003.087,3.89,701,300,10,6001,0,65535,65535,1,21.8,26586,-296,-296,100,71,9,2747,3888,557,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3805,3807,3803,3789,3792,3788,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,947,SUCCESS,,2751.966882,192,0,0.1,0.2,0.3,263,1.4,1.5
    3495,5/26/2021 23:06,14007.099,3.89,701,300,10,6001,0,65535,65535,1,21.8,26585,-296,-297,100,71,9,2747,3888,553,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3805,3807,3803,3789,3793,3788,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,933,SUCCESS,,2751.637006,192,0,0.1,0.2,0.3,263,1.4,1.5
    3496,5/26/2021 23:06,14011.106,3.89,701,300,10,6001,0,65535,65535,1,21.8,26586,-296,-296,100,71,9,2746,3888,557,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3801,3805,3807,3803,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,942,SUCCESS,,2751.307542,192,0,0.1,0.2,0.3,263,1.4,1.5
    3497,5/26/2021 23:06,14015.115,3.89,701,300,10,6001,0,65535,65535,1,21.8,26584,-296,-296,100,71,9,2746,3888,560,557,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3807,3803,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,981,SUCCESS,,2750.977913,192,0,0.1,0.2,0.3,263,1.4,1.5
    3498,5/26/2021 23:06,14019.118,3.89,701,300,10,6001,0,65535,65535,1,21.8,26584,-296,-296,100,71,9,2746,3888,553,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3805,3807,3803,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.8,964,SUCCESS,,2750.648778,192,0,0.1,0.2,0.3,263,1.4,1.5
    3499,5/26/2021 23:06,14023.12,3.9,701,300,10,6001,0,65535,65535,1,21.8,26584,-296,-296,100,71,9,2745,3888,556,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3805,3807,3803,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,953,SUCCESS,,2750.319724,192,0,0.1,0.2,0.3,263,1.4,1.5
    3500,5/26/2021 23:06,14027.126,3.9,701,300,10,6001,0,65535,65535,1,21.8,26581,-296,-296,100,71,9,2745,3888,556,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,940,SUCCESS,,2749.990342,192,0,0.1,0.2,0.3,263,1.4,1.5
    3501,5/26/2021 23:06,14031.127,3.9,701,300,10,6001,0,65535,65535,1,21.8,26581,-296,-296,100,71,9,2745,3888,556,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,993,SUCCESS,,2749.661371,192,0,0.1,0.2,0.3,263,1.4,1.5
    3502,5/26/2021 23:06,14035.128,3.9,701,300,10,6001,0,65535,65535,1,21.8,26580,-294,-296,100,71,9,2744,3888,560,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3789,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,936,SUCCESS,,2749.334623,192,0,0.1,0.2,0.3,263,1.4,1.5
    3503,5/26/2021 23:06,14039.142,3.9,701,300,10,6001,0,65535,65535,1,21.8,26579,-298,-297,100,71,9,2744,3888,552,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3788,3792,3787,0,0,0,0,0,0,0,0,2654,21.7,21.8,-273.2,21.8,-273.2,21.9,955,SUCCESS,,2749.002353,192,0,0.1,0.2,0.3,263,1.4,1.5
    3504,5/26/2021 23:06,14043.154,3.9,701,300,10,6001,0,65535,65535,1,21.8,26579,-296,-297,100,71,9,2744,3888,556,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3788,3792,3787,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.5,959,SUCCESS,,2748.672477,192,0,0.1,0.2,0.3,263,1.4,1.5
    3505,5/26/2021 23:06,14047.155,3.9,701,300,10,6001,0,65535,65535,1,21.8,26577,-296,-296,100,71,9,2743,3888,556,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3788,3792,3786,0,0,0,0,0,0,0,0,2658,21.7,21.8,-273.2,21.8,-273.2,21.9,951,SUCCESS,,2748.343506,192,0,0.1,0.2,0.3,263,1.4,1.5
    3506,5/26/2021 23:06,14051.17,3.9,701,300,10,6001,0,65535,65535,1,21.8,26577,-300,-297,100,71,9,2743,3888,549,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3788,3791,3786,0,0,0,0,0,0,0,0,2654,21.7,21.8,-273.2,21.8,-273.2,21.8,980,SUCCESS,,2748.008923,192,0,0.1,0.2,0.3,263,1.4,1.5
    3507,5/26/2021 23:07,14055.181,3.9,701,300,10,6001,0,65535,65535,1,21.8,26577,-294,-297,100,71,9,2743,3888,560,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3800,3804,3806,3802,3787,3791,3786,0,0,0,0,0,0,0,0,2657,21.7,21.8,-273.2,21.8,-273.2,21.8,944,SUCCESS,,2747.681358,192,0,0.1,0.2,0.3,263,1.4,1.5
    3508,5/26/2021 23:07,14059.188,3.91,701,300,10,6001,0,65535,65535,1,21.8,26574,-298,-297,100,71,9,2742,3888,552,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3806,3801,3788,3791,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,947,SUCCESS,,2747.349667,192,0,0.1,0.2,0.3,263,1.4,1.5
    3509,5/26/2021 23:07,14063.202,3.91,701,300,10,6001,0,65535,65535,1,21.8,26573,-294,-297,100,71,9,2742,3888,556,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3805,3801,3788,3790,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,942,SUCCESS,,2747.021857,192,0,0.1,0.2,0.3,263,1.4,1.5
    3510,5/26/2021 23:07,14067.214,3.91,701,300,10,6001,0,65535,65535,1,21.8,26572,-296,-296,100,71,9,2742,3888,560,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3805,3801,3787,3791,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,966,SUCCESS,,2746.691981,192,0,0.1,0.2,0.3,263,1.4,1.5
    3511,5/26/2021 23:07,14071.224,3.91,701,300,10,6001,0,65535,65535,1,21.8,26572,-298,-297,100,71,9,2741,3888,548,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3805,3801,3787,3790,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,950,SUCCESS,,2746.360043,192,0,0.1,0.2,0.3,263,1.4,1.5
    3512,5/26/2021 23:07,14075.232,3.91,701,300,10,6001,0,65535,65535,1,21.8,26571,-298,-297,100,71,9,2741,3888,552,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3805,3801,3787,3790,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,946,SUCCESS,,2746.028269,192,0,0.1,0.2,0.3,263,1.4,1.5
    3513,5/26/2021 23:07,14079.245,3.91,701,300,10,6001,0,65535,65535,1,21.8,26571,-296,-296,100,71,9,2741,3888,556,556,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3805,3801,3787,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,944,SUCCESS,,2745.698311,192,0,0.1,0.2,0.3,263,1.4,1.5
    3514,5/26/2021 23:07,14083.251,3.91,701,300,10,6001,0,65535,65535,1,21.8,26571,-296,-297,100,71,9,2740,3888,552,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3799,3803,3805,3801,3787,3790,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,940,SUCCESS,,2745.368929,192,0,0.1,0.2,0.3,263,1.4,1.5
    3515,5/26/2021 23:07,14087.254,3.91,701,300,10,6001,0,65535,65535,1,21.8,26569,-296,-297,100,71,9,2740,3888,559,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3803,3804,3801,3787,3790,3786,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,939,SUCCESS,,2745.039794,192,0,0.1,0.2,0.3,263,1.4,1.5
    3516,5/26/2021 23:07,14091.26,3.91,701,300,10,6001,0,65535,65535,1,21.8,26569,-298,-297,100,71,9,2740,3888,552,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3803,3805,3801,3787,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,977,SUCCESS,,2744.708186,192,0,0.1,0.2,0.3,263,1.4,1.5
    3517,5/26/2021 23:07,14095.264,3.92,701,300,10,6001,0,65535,65535,1,21.8,26567,-298,-297,100,71,9,2739,3888,555,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3803,3804,3800,3787,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,942,SUCCESS,,2744.376744,192,0,0.1,0.2,0.3,263,1.4,1.5
    3518,5/26/2021 23:07,14099.265,3.92,701,300,10,6001,0,65535,65535,1,21.8,26566,-296,-297,100,71,9,2739,3888,555,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3803,3804,3800,3787,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.7,941,SUCCESS,,2744.047773,192,0,0.1,0.2,0.3,263,1.4,1.5
    3519,5/26/2021 23:07,14103.27,3.92,701,300,10,6001,0,65535,65535,1,21.8,26565,-296,-297,100,71,9,2739,3888,555,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3802,3804,3800,3786,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,952,SUCCESS,,2743.718473,192,0,0.1,0.2,0.3,263,1.4,1.5
    3520,5/26/2021 23:07,14107.275,3.92,701,300,10,6001,0,65535,65535,1,21.8,26565,-296,-297,100,71,9,2738,3888,555,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3802,3804,3800,3787,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,961,SUCCESS,,2743.389173,192,0,0.1,0.2,0.3,263,1.4,1.5
    3521,5/26/2021 23:07,14111.28,3.92,701,300,10,6001,0,65535,65535,1,21.8,26564,-296,-296,100,71,9,2738,3888,559,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3802,3804,3800,3786,3790,3785,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,948,SUCCESS,,2743.059873,192,0,0.1,0.2,0.3,263,1.4,1.5
    3522,5/26/2021 23:08,14115.286,3.92,701,300,10,6001,0,65535,65535,1,21.8,26563,-298,-297,100,71,9,2738,3888,555,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3798,3802,3804,3800,3786,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,953,SUCCESS,,2742.728265,192,0,0.1,0.2,0.3,263,1.4,1.5
    3523,5/26/2021 23:08,14119.297,3.92,701,300,10,6001,0,65535,65535,1,21.8,26561,-294,-297,100,71,9,2737,3888,555,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3802,3804,3800,3786,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,955,SUCCESS,,2742.4007,192,0,0.1,0.2,0.3,263,1.4,1.5
    3524,5/26/2021 23:08,14123.3,3.92,701,300,10,6001,0,65535,65535,1,21.8,26561,-296,-296,100,71,9,2737,3888,555,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3800,3786,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,953,SUCCESS,,2742.071564,192,0,0.1,0.2,0.3,263,1.4,1.5
    3525,5/26/2021 23:08,14127.304,3.92,701,300,10,6001,0,65535,65535,1,21.8,26559,-296,-296,100,71,9,2737,3888,555,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3800,3786,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,955,SUCCESS,,2741.742346,192,0,0.1,0.2,0.3,263,1.4,1.5
    3526,5/26/2021 23:08,14131.311,3.93,701,300,10,6001,0,65535,65535,1,21.8,26558,-294,-296,100,71,9,2736,3888,555,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3800,3786,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,958,SUCCESS,,2741.415108,192,0,0.1,0.2,0.3,263,1.4,1.5
    3527,5/26/2021 23:08,14135.314,3.93,701,300,10,6001,0,65535,65535,1,21.8,26558,-296,-296,100,71,9,2736,3888,555,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3799,3785,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,960,SUCCESS,,2741.085973,192,0,0.1,0.2,0.3,263,1.4,1.5
    3528,5/26/2021 23:08,14139.326,3.93,701,300,10,6001,0,65535,65535,1,21.8,26558,-296,-296,100,71,9,2736,3888,555,555,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3799,3785,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,942,SUCCESS,,2740.756097,192,0,0.1,0.2,0.3,263,1.4,1.5
    3529,5/26/2021 23:08,14143.34,3.93,701,300,10,6001,0,65535,65535,1,21.8,26558,-296,-296,100,71,9,2735,3888,558,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3799,3786,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,943,SUCCESS,,2740.426057,192,0,0.1,0.2,0.3,263,1.4,1.5
    3530,5/26/2021 23:08,14147.349,3.93,701,300,10,6001,0,65535,65535,1,21.8,26557,-298,-296,100,71,9,2735,3888,551,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3799,3785,3789,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,935,SUCCESS,,2740.094201,192,0,0.1,0.2,0.3,263,1.4,1.5
    3531,5/26/2021 23:08,14151.36,3.93,701,300,10,6001,0,65535,65535,1,21.8,26558,-294,-296,100,71,9,2735,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3799,3785,3788,3784,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,938,SUCCESS,,2739.766636,192,0,0.1,0.2,0.3,263,1.4,1.5
    3532,5/26/2021 23:08,14155.376,3.93,701,300,10,6001,0,65535,65535,1,21.8,26556,-294,-296,100,71,9,2734,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3797,3801,3803,3799,3785,3788,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.1,958,SUCCESS,,2739.438663,192,0,0.1,0.2,0.3,263,1.4,1.5
    3533,5/26/2021 23:08,14159.376,3.93,701,300,10,6001,0,65535,65535,1,21.8,26554,-296,-296,100,71,9,2734,3888,550,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3801,3802,3798,3785,3788,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,969,SUCCESS,,2739.109774,192,0,0.1,0.2,0.3,263,1.4,1.5
    3534,5/26/2021 23:08,14163.38,3.93,701,300,10,6001,0,65535,65535,1,21.8,26552,-294,-296,100,71,9,2734,3888,558,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3800,3802,3798,3785,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,965,SUCCESS,,2738.78278,192,0,0.1,0.2,0.3,263,1.4,1.5
    3535,5/26/2021 23:08,14167.382,3.94,701,300,10,6001,0,65535,65535,1,21.8,26552,-296,-296,100,71,9,2733,3888,550,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3800,3802,3798,3784,3788,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,964,SUCCESS,,2738.453727,192,0,0.1,0.2,0.3,263,1.4,1.5
    3536,5/26/2021 23:08,14171.396,3.94,701,300,10,6001,0,65535,65535,1,21.8,26549,-296,-296,100,71,9,2733,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3800,3802,3798,3784,3788,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,955,SUCCESS,,2738.123687,192,0,0.1,0.2,0.3,263,1.4,1.5
    3537,5/26/2021 23:09,14175.409,3.94,701,300,10,6001,0,65535,65535,1,21.8,26551,-296,-296,100,71,9,2733,3888,558,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3800,3802,3798,3784,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,953,SUCCESS,,2737.793729,192,0,0.1,0.2,0.3,263,1.4,1.5
    3538,5/26/2021 23:09,14179.423,3.94,701,300,10,6001,0,65535,65535,1,21.8,26550,-296,-296,100,71,9,2732,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3800,3802,3798,3784,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,971,SUCCESS,,2737.463689,192,0,0.1,0.2,0.3,263,1.4,1.5
    3539,5/26/2021 23:09,14183.429,3.94,701,300,10,6001,0,65535,65535,1,21.8,26550,-296,-296,100,71,9,2732,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3796,3800,3802,3798,3784,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,938,SUCCESS,,2737.134307,192,0,0.1,0.2,0.3,263,1.4,1.5
    3540,5/26/2021 23:09,14187.434,3.94,701,300,10,6001,0,65535,65535,1,21.8,26548,-296,-296,100,71,9,2732,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3800,3802,3798,3784,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,960,SUCCESS,,2736.805007,192,0,0.1,0.2,0.3,263,1.4,1.5
    3541,5/26/2021 23:09,14191.445,3.94,701,300,10,6001,0,65535,65535,1,21.8,26547,-298,-296,100,71,9,2731,3888,550,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3800,3802,3797,3784,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,964,SUCCESS,,2736.472985,192,0,0.1,0.2,0.3,263,1.4,1.5
    3542,5/26/2021 23:09,14195.448,3.94,701,300,10,6001,0,65535,65535,1,21.8,26547,-296,-296,100,71,9,2731,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3800,3801,3797,3784,3787,3783,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,943,SUCCESS,,2736.14385,192,0,0.1,0.2,0.3,263,1.4,1.5
    3543,5/26/2021 23:09,14199.46,3.94,701,300,10,6001,0,65535,65535,1,21.8,26545,-296,-296,100,71,9,2731,3888,554,554,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3799,3801,3797,3784,3787,3782,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,933,SUCCESS,,2735.813974,192,0,0.1,0.2,0.3,263,1.4,1.5
    3544,5/26/2021 23:09,14203.473,3.95,701,300,10,6001,0,65535,65535,1,21.8,26545,-296,-296,100,71,9,2730,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3799,3801,3797,3783,3787,3782,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,951,SUCCESS,,2735.484016,192,0,0.1,0.2,0.3,263,1.4,1.5
    3545,5/26/2021 23:09,14207.484,3.95,701,300,10,6001,0,65535,65535,1,21.8,26546,-294,-296,100,71,9,2730,3888,557,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3799,3801,3797,3783,3787,3782,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,987,SUCCESS,,2735.156451,192,0,0.1,0.2,0.3,263,1.4,1.5
    3546,5/26/2021 23:09,14211.498,3.95,701,300,10,6001,0,65535,65535,1,21.8,26543,-294,-296,100,71,9,2730,3888,557,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3799,3801,3797,3783,3787,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,978,SUCCESS,,2734.828641,192,0,0.1,0.2,0.3,263,1.4,1.5
    3547,5/26/2021 23:09,14215.512,3.95,701,300,10,6001,0,65535,65535,1,21.8,26542,-294,-296,100,71,9,2729,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3799,3801,3797,3783,3787,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,950,SUCCESS,,2734.500831,192,0,0.1,0.2,0.3,263,1.4,1.5
    3548,5/26/2021 23:09,14219.517,3.95,701,300,10,6001,0,65535,65535,1,21.8,26543,-298,-296,100,71,9,2729,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3795,3798,3801,3797,3783,3787,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,958,SUCCESS,,2734.169306,192,0,0.1,0.2,0.3,263,1.4,1.5
    3549,5/26/2021 23:09,14223.53,3.95,701,300,10,6001,0,65535,65535,1,21.8,26541,-300,-296,100,71,9,2729,3888,549,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3799,3801,3797,3783,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,948,SUCCESS,,2733.83489,192,0,0.1,0.2,0.3,263,1.4,1.5
    3550,5/26/2021 23:09,14227.537,3.95,701,300,10,6001,0,65535,65535,1,21.8,26541,-296,-296,100,71,9,2728,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3799,3801,3797,3783,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,988,SUCCESS,,2733.505425,192,0,0.1,0.2,0.3,263,1.4,1.5
    3551,5/26/2021 23:09,14231.541,3.95,701,300,10,6001,0,65535,65535,1,21.8,26539,-298,-296,100,71,9,2728,3888,549,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3801,3797,3783,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.2,989,SUCCESS,,2733.173983,192,0,0.1,0.2,0.3,263,1.4,1.5
    3552,5/26/2021 23:10,14235.544,3.95,701,300,10,6001,0,65535,65535,1,21.8,26539,-294,-296,100,71,9,2728,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3796,3783,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,979,SUCCESS,,2732.847071,192,0,0.1,0.2,0.3,263,1.4,1.5
    3553,5/26/2021 23:10,14239.553,3.96,701,300,10,6001,0,65535,65535,1,21.8,26537,-296,-296,100,71,9,2727,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3796,3783,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,965,SUCCESS,,2732.517443,192,0,0.1,0.2,0.3,263,1.4,1.5
    3554,5/26/2021 23:10,14243.562,3.96,701,300,10,6001,0,65535,65535,1,21.8,26538,-298,-296,100,71,9,2727,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3796,3782,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,985,SUCCESS,,2732.185586,192,0,0.1,0.2,0.3,263,1.4,1.5
    3555,5/26/2021 23:10,14247.568,3.96,701,300,10,6001,0,65535,65535,1,21.8,26536,-296,-296,100,71,9,2727,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3796,3782,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.8,1013,SUCCESS,,2731.856204,192,0,0.1,0.2,0.3,263,1.4,1.5
    3556,5/26/2021 23:10,14251.573,3.96,701,300,10,6001,0,65535,65535,1,21.8,26537,-296,-296,100,71,9,2726,3888,556,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3796,3782,3786,3781,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,952,SUCCESS,,2731.526904,192,0,0.1,0.2,0.3,263,1.4,1.5
    3557,5/26/2021 23:10,14255.585,3.96,701,300,10,6001,0,65535,65535,1,21.8,26536,-298,-296,100,71,9,2726,3888,553,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3795,3782,3786,3780,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,949,SUCCESS,,2731.1948,192,0,0.1,0.2,0.3,263,1.4,1.5
    3558,5/26/2021 23:10,14259.595,3.96,701,300,10,6001,0,65535,65535,1,21.8,26535,-296,-296,100,71,9,2726,3888,556,553,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3798,3800,3795,3782,3786,3780,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,955,SUCCESS,,2730.865089,192,0,0.1,0.2,0.3,263,1.4,1.5
    3559,5/26/2021 23:10,14263.597,3.96,701,300,10,6001,0,65535,65535,1,21.8,26532,-298,-296,100,71,9,2725,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3794,3798,3800,3795,3782,3785,3780,0,0,0,0,0,0,0,0,2650,21.7,21.8,-273.2,21.8,-273.2,21.9,937,SUCCESS,,2730.533812,192,0,0.1,0.2,0.3,263,1.4,1.5
    3560,5/26/2021 23:10,14267.611,3.96,701,300,10,6001,0,65535,65535,1,21.8,26532,-296,-296,100,71,9,2725,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3797,3800,3795,3782,3786,3780,0,0,0,0,0,0,0,0,2652,21.7,21.8,-273.2,21.8,-273.2,21.9,945,SUCCESS,,2730.203772,192,0,0.1,0.2,0.3,263,1.4,1.5
    3561,5/26/2021 23:10,14271.616,3.96,701,300,10,6001,0,65535,65535,1,21.8,26529,-296,-296,100,71,9,2725,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3797,3799,3795,3781,3785,3780,0,0,0,0,0,0,0,0,2652,21.7,21.8,-273.2,21.8,-273.2,21.9,969,SUCCESS,,2729.874472,192,0,0.1,0.2,0.3,263,1.4,1.5
    3562,5/26/2021 23:10,14275.625,3.97,701,300,10,6001,0,65535,65535,1,21.8,26530,-296,-296,100,71,9,2724,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3797,3799,3795,3781,3784,3780,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,940,SUCCESS,,2729.544843,192,0,0.1,0.2,0.3,263,1.4,1.5
    3563,5/26/2021 23:10,14279.638,3.97,701,300,10,6001,0,65535,65535,1,21.8,26530,-296,-296,100,71,9,2724,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3797,3799,3795,3781,3785,3780,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,951,SUCCESS,,2729.214885,192,0,0.1,0.2,0.3,263,1.4,1.5
    3564,5/26/2021 23:10,14283.651,3.97,701,300,10,6001,0,65535,65535,1,21.8,26529,-298,-296,100,71,9,2724,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3797,3799,3795,3781,3785,3780,0,0,0,0,0,0,0,0,2653,21.7,21.8,-273.2,21.8,-273.2,21.9,976,SUCCESS,,2728.882698,192,0,0.1,0.2,0.3,263,1.4,1.5
    3565,5/26/2021 23:10,14287.651,3.97,701,300,10,6001,0,65535,65535,1,21.8,26529,-298,-296,100,71,9,2723,3888,548,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3793,3797,3799,3795,3781,3784,3780,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.2,946,SUCCESS,,2728.551587,192,0,0.1,0.2,0.3,263,1.4,1.5
    3566,5/26/2021 23:10,14291.666,3.97,701,300,10,6001,0,65535,65535,1,21.8,26528,-296,-296,100,71,9,2723,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3797,3799,3795,3781,3787,3780,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,946,SUCCESS,,2728.221465,192,0,0.1,0.2,0.3,263,1.4,1.5
    3567,5/26/2021 23:11,14295.674,3.97,701,300,10,6001,0,65535,65535,1,21.8,26528,-296,-296,100,71,9,2723,3888,548,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3797,3798,3795,3781,3784,3780,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,938,SUCCESS,,2727.891918,192,0,0.1,0.2,0.3,263,1.4,1.5
    3568,5/26/2021 23:11,14299.675,3.97,701,300,10,6001,0,65535,65535,1,21.8,26527,-298,-296,100,71,9,2722,3888,544,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3797,3798,3794,3780,3784,3780,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,974,SUCCESS,,2727.560724,192,0,0.1,0.2,0.3,263,1.4,1.5
    3569,5/26/2021 23:11,14303.68,3.97,701,300,10,6001,0,65535,65535,1,21.8,26525,-294,-296,100,71,9,2722,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3796,3798,3794,3781,3784,3779,0,0,0,0,0,0,0,0,2650,21.7,21.8,-273.2,21.8,-273.2,21.9,985,SUCCESS,,2727.233649,192,0,0.1,0.2,0.3,263,1.4,1.5
    3570,5/26/2021 23:11,14307.692,3.97,701,300,10,6001,0,65535,65535,1,21.8,26525,-296,-296,100,71,9,2722,3888,556,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3797,3798,3794,3781,3784,3779,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,938,SUCCESS,,2726.903774,192,0,0.1,0.2,0.3,263,1.4,1.5
    3571,5/26/2021 23:11,14311.691,3.98,701,300,10,6001,0,65535,65535,1,21.8,26523,-296,-297,100,70,9,2721,3888,548,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3796,3798,3794,3780,3784,3779,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,938,SUCCESS,,2726.574967,192,0,0.1,0.2,0.3,263,1.4,1.5
    3572,5/26/2021 23:11,14315.694,3.98,701,300,10,6001,0,65535,65535,1,21.8,26523,-296,-296,100,70,9,2721,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3796,3798,3794,3780,3788,3779,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,980,SUCCESS,,2726.245831,192,0,0.1,0.2,0.3,263,1.4,1.5
    3573,5/26/2021 23:11,14319.705,3.98,701,300,10,6001,0,65535,65535,1,21.8,26523,-296,-296,100,70,9,2721,3888,552,552,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3796,3798,3794,3780,3784,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,941,SUCCESS,,2725.916038,192,0,0.1,0.2,0.3,263,1.4,1.5
    3574,5/26/2021 23:11,14323.709,3.98,701,300,10,6001,0,65535,65535,1,21.8,26521,-296,-296,100,70,9,2720,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3796,3798,3794,3780,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,967,SUCCESS,,2725.58682,192,0,0.1,0.2,0.3,263,1.4,1.5
    3575,5/26/2021 23:11,14327.719,3.98,701,300,10,6001,0,65535,65535,1,21.8,26521,-296,-296,100,70,9,2720,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3796,3798,3794,3780,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,957,SUCCESS,,2725.257109,192,0,0.1,0.2,0.3,263,1.4,1.5
    3576,5/26/2021 23:11,14331.73,3.98,701,300,10,6001,0,65535,65535,1,21.8,26520,-298,-296,100,70,9,2720,3888,548,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3792,3796,3798,3794,3780,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,944,SUCCESS,,2724.925088,192,0,0.1,0.2,0.3,263,1.4,1.5
    3577,5/26/2021 23:11,14335.741,3.98,701,300,10,6001,0,65535,65535,1,21.8,26519,-296,-296,100,70,9,2719,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3795,3798,3794,3780,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,935,SUCCESS,,2724.595294,192,0,0.1,0.2,0.3,263,1.4,1.5
    3578,5/26/2021 23:11,14339.756,3.98,701,300,10,6001,0,65535,65535,1,21.8,26517,-296,-296,100,70,9,2719,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3795,3797,3793,3780,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,954,SUCCESS,,2724.265172,192,0,0.1,0.2,0.3,263,1.4,1.5
    3579,5/26/2021 23:11,14343.763,3.98,701,300,10,6001,0,65535,65535,1,21.8,26517,-296,-296,100,70,9,2719,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3795,3797,3793,3779,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,957,SUCCESS,,2723.935708,192,0,0.1,0.2,0.3,263,1.4,1.5
    3580,5/26/2021 23:11,14347.772,3.99,701,300,10,6001,0,65535,65535,1,21.8,26516,-296,-296,100,70,9,2718,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3795,3797,3793,3779,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,963,SUCCESS,,2723.606079,192,0,0.1,0.2,0.3,263,1.4,1.5
    3581,5/26/2021 23:11,14351.789,3.99,701,300,10,6001,0,65535,65535,1,21.8,26516,-296,-296,100,70,9,2718,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3795,3797,3793,3779,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,942,SUCCESS,,2723.275792,192,0,0.1,0.2,0.3,263,1.4,1.5
    3582,5/26/2021 23:12,14355.793,3.99,701,300,10,6001,0,65535,65535,1,21.8,26515,-298,-297,100,70,9,2718,3888,547,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3791,3795,3797,3793,3779,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.7,958,SUCCESS,,2722.94435,192,0,0.1,0.2,0.3,263,1.4,1.5
    3583,5/26/2021 23:12,14359.794,3.99,701,300,10,6001,0,65535,65535,1,21.8,26514,-296,-296,100,70,9,2717,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3795,3797,3793,3779,3782,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,943,SUCCESS,,2722.615379,192,0,0.1,0.2,0.3,263,1.4,1.5
    3584,5/26/2021 23:12,14363.801,3.99,701,300,10,6001,0,65535,65535,1,21.8,26515,-296,-297,100,70,9,2717,3888,547,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3795,3797,3793,3779,3783,3778,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,968,SUCCESS,,2722.285914,192,0,0.1,0.2,0.3,263,1.4,1.5
    3585,5/26/2021 23:12,14367.806,3.99,701,300,10,6001,0,65535,65535,1,21.8,26513,-296,-296,100,70,9,2717,3888,554,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3795,3797,3793,3779,3782,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,954,SUCCESS,,2721.956614,192,0,0.1,0.2,0.3,263,1.4,1.5
    3586,5/26/2021 23:12,14371.807,3.99,701,300,10,6001,0,65535,65535,1,21.8,26511,-296,-296,100,70,9,2716,3888,547,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3797,3792,3779,3781,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,963,SUCCESS,,2721.627643,192,0,0.1,0.2,0.3,263,1.4,1.5
    3587,5/26/2021 23:12,14375.813,3.99,701,300,10,6001,0,65535,65535,1,21.8,26509,-296,-296,100,70,9,2716,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3796,3792,3778,3782,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,940,SUCCESS,,2721.298261,192,0,0.1,0.2,0.3,263,1.4,1.5
    3588,5/26/2021 23:12,14379.822,3.99,701,300,10,6001,0,65535,65535,1,21.8,26509,-294,-296,100,70,9,2716,3888,551,551,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3796,3792,3778,3782,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,962,SUCCESS,,2720.970859,192,0,0.1,0.2,0.3,263,1.4,1.5
    3589,5/26/2021 23:12,14383.829,4,701,300,10,6001,0,65535,65535,1,21.8,26508,-296,-296,100,70,9,2715,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3796,3792,3778,3781,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21,940,SUCCESS,,2720.641395,192,0,0.1,0.2,0.3,263,1.4,1.5
    3590,5/26/2021 23:12,14387.837,4,701,300,10,6001,0,65535,65535,1,21.8,26509,-296,-296,100,70,9,2715,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3796,3792,3778,3781,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,953,SUCCESS,,2720.311848,192,0,0.1,0.2,0.3,263,1.4,1.5
    3591,5/26/2021 23:12,14391.843,4,701,300,10,6001,0,65535,65535,1,21.8,26508,-296,-296,100,70,9,2715,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3796,3792,3778,3781,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,966,SUCCESS,,2719.982466,192,0,0.1,0.2,0.3,263,1.4,1.5
    3592,5/26/2021 23:12,14395.85,4,701,300,10,6001,0,65535,65535,1,21.8,26508,-294,-296,100,70,9,2714,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3790,3794,3796,3792,3778,3781,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,969,SUCCESS,,2719.655228,192,0,0.1,0.2,0.3,263,1.4,1.5
    3593,5/26/2021 23:12,14399.852,4,701,300,10,6001,0,65535,65535,1,21.8,26508,-296,-296,100,70,9,2714,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3794,3796,3792,3778,3781,3777,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,932,SUCCESS,,2719.326174,192,0,0.1,0.2,0.3,263,1.4,1.5
    3594,5/26/2021 23:12,14403.857,4,701,300,10,6001,0,65535,65535,1,21.8,26506,-298,-296,100,70,9,2714,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3794,3796,3792,3778,3781,3776,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,965,SUCCESS,,2718.994649,192,0,0.1,0.2,0.3,263,1.4,1.5
    3595,5/26/2021 23:12,14407.867,4,701,300,10,6001,0,65535,65535,1,21.8,26504,-296,-296,100,70,9,2713,3888,546,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3794,3795,3791,3778,3781,3776,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,963,SUCCESS,,2718.664938,192,0,0.1,0.2,0.3,263,1.4,1.5
    3596,5/26/2021 23:12,14411.874,4,701,300,10,6001,0,65535,65535,1,21.8,26502,-296,-296,100,70,9,2713,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3794,3795,3791,3777,3781,3776,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,949,SUCCESS,,2718.335474,192,0,0.1,0.2,0.3,263,1.4,1.5
    3597,5/26/2021 23:13,14415.885,4,701,300,10,6001,0,65535,65535,1,21.8,26502,-298,-296,100,70,9,2713,3888,546,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3793,3795,3791,3777,3781,3776,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,961,SUCCESS,,2718.003452,192,0,0.1,0.2,0.3,263,1.4,1.5
    3598,5/26/2021 23:13,14419.891,4.01,701,300,10,6001,0,65535,65535,1,21.8,26501,-296,-296,100,70,9,2712,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3793,3795,3791,3777,3781,3776,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,940,SUCCESS,,2717.67407,192,0,0.1,0.2,0.3,263,1.4,1.5
    3599,5/26/2021 23:13,14423.891,4.01,701,300,10,6001,0,65535,65535,1,21.8,26501,-296,-296,100,70,9,2712,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3793,3795,3791,3777,3780,3776,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.9,986,SUCCESS,,2717.345181,192,0,0.1,0.2,0.3,263,1.4,1.5
    3600,5/26/2021 23:13,14427.9,4.01,701,300,10,6001,0,65535,65535,1,21.8,26499,-296,-296,100,70,9,2712,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3789,3793,3795,3790,3777,3780,3776,0,0,0,0,0,0,0,0,2649,21.7,21.8,-273.2,21.8,-273.2,21.8,977,SUCCESS,,2717.015552,192,0,0.1,0.2,0.3,263,1.4,1.5
    3601,5/26/2021 23:13,14431.905,4.01,701,300,10,6001,0,65535,65535,1,21.8,26498,-296,-296,100,70,9,2711,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3793,3795,3790,3777,3781,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,959,SUCCESS,,2716.686252,192,0,0.1,0.2,0.3,263,1.4,1.5
    3602,5/26/2021 23:13,14435.909,4.01,701,300,10,6001,0,65535,65535,1,21.8,26498,-298,-296,100,70,9,2711,3888,550,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3793,3794,3790,3777,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,967,SUCCESS,,2716.35481,192,0,0.1,0.2,0.3,263,1.4,1.5
    3603,5/26/2021 23:13,14439.917,4.01,701,300,10,6001,0,65535,65535,1,21.8,26497,-296,-296,100,70,9,2711,3888,546,550,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3793,3795,3790,3777,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,951,SUCCESS,,2716.025263,192,0,0.1,0.2,0.3,263,1.4,1.5
    3604,5/26/2021 23:13,14443.927,4.01,701,300,10,6001,0,65535,65535,1,21.7,26497,-296,-296,100,70,9,2710,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3792,3794,3790,3777,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.7,-273.2,21.7,-273.2,21.9,965,SUCCESS,,2715.695552,192,0,0.1,0.2,0.3,263,1.4,1.5
    3605,5/26/2021 23:13,14447.93,4.01,701,300,10,6001,0,65535,65535,1,21.8,26496,-296,-296,100,70,9,2710,3888,546,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3792,3794,3790,3776,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,948,SUCCESS,,2715.366416,192,0,0.1,0.2,0.3,263,1.4,1.5
    3606,5/26/2021 23:13,14451.933,4.01,701,300,10,6001,0,65535,65535,1,21.8,26496,-294,-296,100,70,9,2710,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3792,3794,3790,3776,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,944,SUCCESS,,2715.039505,192,0,0.1,0.2,0.3,263,1.4,1.5
    3607,5/26/2021 23:13,14455.948,4.02,701,300,10,6001,0,65535,65535,1,21.8,26495,-294,-296,100,70,9,2710,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3792,3794,3790,3776,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.7,944,SUCCESS,,2714.711613,192,0,0.1,0.2,0.3,263,1.4,1.5
    3608,5/26/2021 23:13,14459.964,4.02,701,300,10,6001,0,65535,65535,1,21.8,26495,-298,-296,100,70,9,2709,3888,545,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3788,3792,3794,3790,3776,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,961,SUCCESS,,2714.379178,192,0,0.1,0.2,0.3,263,1.4,1.5
    3609,5/26/2021 23:13,14463.973,4.02,701,300,10,6001,0,65535,65535,1,21.7,26494,-296,-296,100,70,9,2709,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3792,3794,3790,3776,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.7,-273.2,21.8,950,SUCCESS,,2714.049549,192,0,0.1,0.2,0.3,263,1.4,1.5
    3610,5/26/2021 23:13,14467.978,4.02,701,300,10,6001,0,65535,65535,1,21.8,26492,-294,-296,100,70,9,2709,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3792,3794,3790,3776,3780,3775,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,966,SUCCESS,,2713.722474,192,0,0.1,0.2,0.3,263,1.4,1.5
    3611,5/26/2021 23:13,14471.987,4.02,701,300,10,6001,0,65535,65535,1,21.8,26491,-296,-296,100,70,9,2708,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3792,3794,3789,3776,3779,3774,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,943,SUCCESS,,2713.392845,192,0,0.1,0.2,0.3,263,1.4,1.5
    3612,5/26/2021 23:14,14475.994,4.02,701,300,10,6001,0,65535,65535,1,21.8,26491,-294,-296,100,70,9,2708,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3792,3793,3789,3776,3779,3774,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,961,SUCCESS,,2713.065606,192,0,0.1,0.2,0.3,263,1.4,1.5
    3613,5/26/2021 23:14,14479.999,4.02,701,300,10,6001,0,65535,65535,1,21.7,26487,-298,-296,100,70,9,2707,3888,545,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3792,3793,3789,3776,3780,3774,0,0,0,0,0,0,0,0,2648,21.6,21.7,-273.2,21.7,-273.2,21.8,947,SUCCESS,,2712.734081,192,0,0.1,0.2,0.3,263,1.4,1.5
    3614,5/26/2021 23:14,14484.005,4.02,701,300,10,6001,0,65535,65535,1,21.7,26488,-296,-296,100,70,9,2707,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3791,3793,3789,3775,3779,3774,0,0,0,0,0,0,0,0,2645,21.6,21.7,-273.2,21.7,-273.2,21.8,955,SUCCESS,,2712.404699,192,0,0.1,0.2,0.3,263,1.4,1.5
    3615,5/26/2021 23:14,14488.016,4.02,701,300,10,6001,0,65535,65535,1,21.7,26488,-296,-296,100,70,9,2707,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3791,3793,3789,3775,3779,3774,0,0,0,0,0,0,0,0,2649,21.6,21.7,-273.2,21.7,-273.2,21.9,956,SUCCESS,,2712.074906,192,0,0.1,0.2,0.3,263,1.4,1.5
    3616,5/26/2021 23:14,14492.026,4.03,701,300,10,6001,0,65535,65535,1,21.8,26484,-298,-296,100,70,9,2706,3888,545,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3791,3793,3789,3775,3779,3773,0,0,0,0,0,0,0,0,2648,21.6,21.8,-273.2,21.8,-273.2,21.8,961,SUCCESS,,2711.742967,192,0,0.1,0.2,0.3,263,1.4,1.5
    3617,5/26/2021 23:14,14496.028,4.03,701,300,10,6001,0,65535,65535,1,21.8,26485,-296,-297,100,70,9,2706,3888,549,547,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3787,3791,3793,3789,3775,3778,3773,0,0,0,0,0,0,0,0,2649,21.6,21.8,-273.2,21.8,-273.2,21.8,944,SUCCESS,,2711.413914,192,0,0.1,0.2,0.3,263,1.4,1.5
    3618,5/26/2021 23:14,14500.035,4.03,701,300,10,6001,0,65535,65535,1,21.7,26485,-296,-296,100,70,9,2706,3888,549,549,65535,3000,28875,00C0,0,3638,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3791,3792,3789,3775,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,966,SUCCESS,,2711.084449,192,0,0.1,0.2,0.3,263,1.4,1.5
    3619,5/26/2021 23:14,14504.037,4.03,701,300,10,6001,0,65535,65535,1,21.7,26484,-298,-297,100,70,9,2705,3888,545,546,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3775,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.9,966,SUCCESS,,2710.753173,192,0,0.1,0.2,0.3,263,1.4,1.5
    3620,5/26/2021 23:14,14508.039,4.03,701,300,10,6001,0,65535,65535,1,21.7,26482,-296,-297,100,70,9,2705,3888,548,546,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3775,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,970,SUCCESS,,2710.424119,192,0,0.1,0.2,0.3,263,1.4,1.5
    3621,5/26/2021 23:14,14512.046,4.03,701,300,10,6001,0,65535,65535,1,21.8,26482,-296,-296,100,70,9,2705,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3775,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.7,943,SUCCESS,,2710.094655,192,0,0.1,0.2,0.3,263,1.4,1.5
    3622,5/26/2021 23:14,14516.048,4.03,701,300,10,6001,0,65535,65535,1,21.8,26482,-296,-296,100,70,9,2704,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3774,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.4,940,SUCCESS,,2709.765601,192,0,0.1,0.2,0.3,263,1.4,1.5
    3623,5/26/2021 23:14,14520.054,4.03,701,300,10,6001,0,65535,65535,1,21.8,26481,-294,-296,100,70,9,2704,3888,552,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3774,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.9,949,SUCCESS,,2709.438445,192,0,0.1,0.2,0.3,263,1.4,1.5
    3624,5/26/2021 23:14,14524.056,4.03,701,300,10,6001,0,65535,65535,1,21.8,26480,-298,-296,100,70,9,2704,3888,544,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3774,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.7,1018,SUCCESS,,2709.107168,192,0,0.1,0.2,0.3,263,1.4,1.5
    3625,5/26/2021 23:14,14528.067,4.04,701,300,10,6001,0,65535,65535,1,21.8,26480,-298,-296,100,70,9,2704,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3774,3778,3773,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,996,SUCCESS,,2708.775146,192,0,0.1,0.2,0.3,263,1.4,1.5
    3626,5/26/2021 23:14,14532.069,4.04,701,300,10,6001,0,65535,65535,1,21.8,26478,-296,-296,100,70,9,2703,3888,544,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3787,3774,3777,3773,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,957,SUCCESS,,2708.446093,192,0,0.1,0.2,0.3,263,1.4,1.5
    3627,5/26/2021 23:15,14536.084,4.04,701,300,10,6001,0,65535,65535,1,21.8,26479,-296,-296,100,70,9,2703,3888,544,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3786,3790,3792,3788,3774,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.7,965,SUCCESS,,2708.115971,192,0,0.1,0.2,0.3,263,1.4,1.5
    3628,5/26/2021 23:15,14540.093,4.04,701,300,10,6001,0,65535,65535,1,21.8,26479,-294,-296,100,70,9,2703,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3790,3792,3787,3774,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,940,SUCCESS,,2707.788569,192,0,0.1,0.2,0.3,263,1.4,1.5
    3629,5/26/2021 23:15,14544.096,4.04,701,300,10,6001,0,65535,65535,1,21.8,26476,-296,-296,100,70,9,2702,3888,544,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3790,3792,3787,3773,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.9,939,SUCCESS,,2707.459434,192,0,0.1,0.2,0.3,263,1.4,1.5
    3630,5/26/2021 23:15,14548.1,4.04,701,300,10,6001,0,65535,65535,1,21.7,26474,-296,-296,100,70,9,2702,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3789,3791,3787,3773,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,963,SUCCESS,,2707.130216,192,0,0.1,0.2,0.3,263,1.4,1.5
    3631,5/26/2021 23:15,14552.113,4.04,701,300,10,6001,0,65535,65535,1,21.7,26475,-296,-296,100,70,9,2702,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3789,3791,3787,3773,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,936,SUCCESS,,2706.800258,192,0,0.1,0.2,0.3,263,1.4,1.5
    3632,5/26/2021 23:15,14556.128,4.04,701,300,10,6001,0,65535,65535,1,21.7,26474,-296,-296,100,70,9,2701,3888,548,548,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3789,3791,3787,3773,3776,3772,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,936,SUCCESS,,2706.470136,192,0,0.1,0.2,0.3,263,1.4,1.5
    3633,5/26/2021 23:15,14560.143,4.04,701,300,10,6001,0,65535,65535,1,21.8,26474,-296,-297,100,70,9,2701,3888,551,546,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3789,3791,3787,3773,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,956,SUCCESS,,2706.140014,192,0,0.1,0.2,0.3,263,1.4,1.5
    3634,5/26/2021 23:15,14564.151,4.05,701,300,10,6001,0,65535,65535,1,21.8,26473,-296,-297,100,70,9,2701,3888,544,546,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3785,3789,3791,3787,3773,3777,3772,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,991,SUCCESS,,2705.810467,192,0,0.1,0.2,0.3,263,1.4,1.5
    3635,5/26/2021 23:15,14568.154,4.05,701,300,10,6001,0,65535,65535,1,21.8,26471,-298,-297,100,70,9,2700,3888,544,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3789,3790,3787,3773,3776,3772,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,951,SUCCESS,,2705.479108,192,0,0.1,0.2,0.3,263,1.4,1.5
    3636,5/26/2021 23:15,14572.156,4.05,701,300,10,6001,0,65535,65535,1,21.8,26470,-296,-297,100,70,9,2700,3888,547,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3789,3790,3786,3773,3776,3771,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,956,SUCCESS,,2705.150054,192,0,0.1,0.2,0.3,263,1.4,1.5
    3637,5/26/2021 23:15,14576.167,4.05,701,300,10,6001,0,65535,65535,1,21.8,26470,-298,-297,100,70,9,2700,3888,547,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3789,3790,3786,3773,3778,3771,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,960,SUCCESS,,2704.818033,192,0,0.1,0.2,0.3,263,1.4,1.5
    3638,5/26/2021 23:15,14580.175,4.05,701,300,10,6001,0,65535,65535,1,21.8,26467,-296,-297,100,70,9,2699,3888,543,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3789,3790,3786,3772,3775,3771,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,945,SUCCESS,,2704.488486,192,0,0.1,0.2,0.3,263,1.4,1.5
    3639,5/26/2021 23:15,14584.188,4.05,701,300,10,6001,0,65535,65535,1,21.8,26469,-294,-297,100,70,9,2699,3888,551,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3789,3790,3786,3773,3776,3771,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,939,SUCCESS,,2704.160758,192,0,0.1,0.2,0.3,263,1.4,1.5
    3640,5/26/2021 23:15,14588.203,4.05,701,300,10,6001,0,65535,65535,1,21.7,26467,-298,-297,100,70,9,2699,3888,543,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3789,3790,3786,3773,3777,3771,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,956,SUCCESS,,2703.828405,192,0,0.1,0.2,0.3,263,1.4,1.5
    3641,5/26/2021 23:15,14592.208,4.05,701,300,10,6001,0,65535,65535,1,21.7,26466,-296,-297,100,70,9,2698,3888,547,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3788,3790,3786,3772,3775,3771,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.4,951,SUCCESS,,2703.499105,192,0,0.1,0.2,0.3,263,1.4,1.5
    3642,5/26/2021 23:16,14596.214,4.05,701,300,10,6001,0,65535,65535,1,21.7,26467,-296,-297,100,70,9,2698,3888,547,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3788,3790,3786,3772,3775,3770,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,965,SUCCESS,,2703.169723,192,0,0.1,0.2,0.3,263,1.4,1.5
    3643,5/26/2021 23:16,14600.225,4.06,701,300,10,6001,0,65535,65535,1,21.7,26465,-296,-297,100,70,9,2698,3888,543,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3788,3790,3786,3772,3777,3770,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.9,965,SUCCESS,,2702.839929,192,0,0.1,0.2,0.3,263,1.4,1.5
    3644,5/26/2021 23:16,14604.233,4.06,701,300,10,6001,0,65535,65535,1,21.8,26464,-296,-297,100,70,9,2697,3888,547,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3784,3788,3790,3786,3772,3775,3770,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.8,-273.2,21.8,975,SUCCESS,,2702.510383,192,0,0.1,0.2,0.3,263,1.4,1.5
    3645,5/26/2021 23:16,14608.235,4.06,701,300,10,6001,0,65535,65535,1,21.7,26463,-296,-297,100,70,9,2697,3888,547,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3788,3790,3786,3771,3775,3770,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.7,956,SUCCESS,,2702.181329,192,0,0.1,0.2,0.3,263,1.4,1.5
    3646,5/26/2021 23:16,14612.242,4.06,701,300,10,6001,0,65535,65535,1,21.7,26461,-298,-297,100,70,9,2697,3888,543,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3788,3789,3786,3771,3775,3770,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,949,SUCCESS,,2701.849639,192,0,0.1,0.2,0.3,263,1.4,1.5
    3647,5/26/2021 23:16,14616.252,4.06,701,300,10,6001,0,65535,65535,1,21.8,26460,-296,-297,100,70,9,2696,3888,546,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3788,3789,3785,3771,3775,3770,0,0,0,0,0,0,0,0,2644,21.6,21.8,-273.2,21.8,-273.2,21.8,988,SUCCESS,,2701.519928,192,0,0.1,0.2,0.3,263,1.4,1.5
    3648,5/26/2021 23:16,14620.261,4.06,701,300,10,6001,0,65535,65535,1,21.7,26460,-298,-297,100,70,9,2696,3888,543,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3787,3789,3785,3771,3775,3770,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,968,SUCCESS,,2701.188071,192,0,0.1,0.2,0.3,263,1.4,1.5
    3649,5/26/2021 23:16,14624.274,4.06,701,300,10,6001,0,65535,65535,1,21.7,26460,-298,-297,100,70,9,2696,3888,546,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3787,3789,3785,3771,3778,3770,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,940,SUCCESS,,2700.855884,192,0,0.1,0.2,0.3,263,1.4,1.5
    3650,5/26/2021 23:16,14628.282,4.06,701,300,10,6001,0,65535,65535,1,21.7,26459,-296,-297,100,70,9,2695,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3787,3789,3785,3771,3775,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,938,SUCCESS,,2700.526338,192,0,0.1,0.2,0.3,263,1.4,1.5
    3651,5/26/2021 23:16,14632.286,4.06,701,300,10,6001,0,65535,65535,1,21.7,26460,-296,-297,100,70,9,2695,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3787,3789,3785,3771,3775,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,939,SUCCESS,,2700.19712,192,0,0.1,0.2,0.3,263,1.4,1.5
    3652,5/26/2021 23:16,14636.296,4.07,701,300,10,6001,0,65535,65535,1,21.7,26459,-296,-297,100,70,9,2695,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3783,3787,3789,3785,3771,3775,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,946,SUCCESS,,2699.867409,192,0,0.1,0.2,0.3,263,1.4,1.5
    3653,5/26/2021 23:16,14640.309,4.07,701,300,10,6001,0,65535,65535,1,21.7,26456,-298,-297,100,70,9,2694,3888,542,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3787,3789,3785,3771,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.9,972,SUCCESS,,2699.535221,192,0,0.1,0.2,0.3,263,1.4,1.5
    3654,5/26/2021 23:16,14644.314,4.07,701,300,10,6001,0,65535,65535,1,21.7,26456,-298,-297,100,70,9,2694,3888,542,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3787,3789,3784,3771,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.7,940,SUCCESS,,2699.203696,192,0,0.1,0.2,0.3,263,1.4,1.5
    3655,5/26/2021 23:16,14648.319,4.07,701,300,10,6001,0,65535,65535,1,21.7,26456,-296,-297,100,70,9,2694,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3787,3789,3784,3771,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.1,969,SUCCESS,,2698.874396,192,0,0.1,0.2,0.3,263,1.4,1.5
    3656,5/26/2021 23:16,14652.32,4.07,701,300,10,6001,0,65535,65535,1,21.7,26454,-296,-297,100,70,9,2693,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3787,3788,3784,3771,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,972,SUCCESS,,2698.545425,192,0,0.1,0.2,0.3,263,1.4,1.5
    3657,5/26/2021 23:17,14656.331,4.07,701,300,10,6001,0,65535,65535,1,21.7,26453,-296,-297,100,70,9,2693,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3786,3788,3784,3770,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,984,SUCCESS,,2698.215632,192,0,0.1,0.2,0.3,263,1.4,1.5
    3658,5/26/2021 23:17,14660.334,4.07,701,300,10,6001,0,65535,65535,1,21.7,26453,-296,-297,100,70,9,2693,3888,546,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3786,3788,3784,3770,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,940,SUCCESS,,2697.886496,192,0,0.1,0.2,0.3,263,1.4,1.5
    3659,5/26/2021 23:17,14664.347,4.07,701,300,10,6001,0,65535,65535,1,21.7,26453,-298,-297,100,70,9,2692,3888,542,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3782,3786,3788,3784,3770,3774,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,944,SUCCESS,,2697.554309,192,0,0.1,0.2,0.3,263,1.4,1.5
    3660,5/26/2021 23:17,14668.355,4.07,701,300,10,6001,0,65535,65535,1,21.7,26452,-296,-296,100,70,9,2692,3888,546,546,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3786,3788,3784,3770,3773,3769,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,967,SUCCESS,,2697.224763,192,0,0.1,0.2,0.3,263,1.4,1.5
    3661,5/26/2021 23:17,14672.368,4.08,701,300,10,6001,0,65535,65535,1,21.7,26450,-296,-296,100,70,9,2692,3888,542,546,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3786,3788,3784,3770,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,946,SUCCESS,,2696.894805,192,0,0.1,0.2,0.3,263,1.4,1.5
    3662,5/26/2021 23:17,14676.374,4.08,701,300,10,6001,0,65535,65535,1,21.7,26449,-298,-297,100,70,9,2691,3888,542,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3786,3787,3784,3770,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,947,SUCCESS,,2696.563197,192,0,0.1,0.2,0.3,263,1.4,1.5
    3663,5/26/2021 23:17,14680.389,4.08,701,300,10,6001,0,65535,65535,1,21.7,26449,-296,-297,100,70,9,2691,3888,545,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3786,3787,3783,3770,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,943,SUCCESS,,2696.233075,192,0,0.1,0.2,0.3,263,1.4,1.5
    3664,5/26/2021 23:17,14684.398,4.08,701,300,10,6001,0,65535,65535,1,21.7,26448,-298,-297,100,70,9,2691,3888,542,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3786,3787,3783,3769,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,966,SUCCESS,,2695.901219,192,0,0.1,0.2,0.3,263,1.4,1.5
    3665,5/26/2021 23:17,14688.413,4.08,701,300,10,6001,0,65535,65535,1,21.7,26448,-294,-297,100,70,9,2690,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3770,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,1002,SUCCESS,,2695.573327,192,0,0.1,0.2,0.3,263,1.4,1.5
    3666,5/26/2021 23:17,14692.421,4.08,701,300,10,6001,0,65535,65535,1,21.7,26447,-298,-297,100,70,9,2690,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3770,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.9,957,SUCCESS,,2695.241554,192,0,0.1,0.2,0.3,263,1.4,1.5
    3667,5/26/2021 23:17,14696.428,4.08,701,300,10,6001,0,65535,65535,1,21.7,26446,-298,-297,100,70,9,2690,3888,542,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3769,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,981,SUCCESS,,2694.909863,192,0,0.1,0.2,0.3,263,1.4,1.5
    3668,5/26/2021 23:17,14700.436,4.08,701,300,10,6001,0,65535,65535,1,21.7,26446,-296,-297,100,70,9,2689,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3769,3773,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,947,SUCCESS,,2694.580316,192,0,0.1,0.2,0.3,263,1.4,1.5
    3669,5/26/2021 23:17,14704.438,4.08,701,300,10,6001,0,65535,65535,1,21.7,26446,-296,-297,100,70,9,2689,3888,541,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3769,3772,3768,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,955,SUCCESS,,2694.251263,192,0,0.1,0.2,0.3,263,1.4,1.5
    3670,5/26/2021 23:17,14708.449,4.09,701,300,10,6001,0,65535,65535,1,21.7,26445,-296,-297,100,70,9,2689,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3769,3772,3767,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,944,SUCCESS,,2693.92147,192,0,0.1,0.2,0.3,263,1.4,1.5
    3671,5/26/2021 23:17,14712.463,4.09,701,300,10,6001,0,65535,65535,1,21.7,26443,-296,-297,100,70,9,2688,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3781,3785,3787,3783,3769,3772,3767,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.7,961,SUCCESS,,2693.59143,192,0,0.1,0.2,0.3,263,1.4,1.5
    3672,5/26/2021 23:18,14716.474,4.09,701,300,10,6001,0,65535,65535,1,21.7,26443,-298,-297,100,70,9,2688,3888,541,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3787,3783,3769,3772,3767,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.7,956,SUCCESS,,2693.259408,192,0,0.1,0.2,0.3,263,1.4,1.5
    3673,5/26/2021 23:18,14720.482,4.09,701,300,10,6001,0,65535,65535,1,21.7,26442,-296,-297,100,70,9,2688,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3785,3786,3783,3769,3772,3767,0,0,0,0,0,0,0,0,2644,21.6,21.7,-273.2,21.7,-273.2,21.8,943,SUCCESS,,2692.929861,192,0,0.1,0.2,0.3,263,1.4,1.5
    3674,5/26/2021 23:18,14724.489,4.09,701,300,10,6001,0,65535,65535,1,21.7,26441,-296,-297,100,70,9,2687,3888,545,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3769,3772,3767,0,0,0,0,0,0,0,0,2643,21.6,21.7,-273.2,21.7,-273.2,21.8,983,SUCCESS,,2692.600397,192,0,0.1,0.2,0.3,263,1.4,1.5
    3675,5/26/2021 23:18,14728.504,4.09,701,300,10,6001,0,65535,65535,1,21.7,26439,-296,-297,100,70,9,2687,3888,541,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3769,3772,3767,0,0,0,0,0,0,0,0,2643,21.6,21.7,-273.2,21.7,-273.2,21.7,960,SUCCESS,,2692.270275,192,0,0.1,0.2,0.3,263,1.4,1.5
    3676,5/26/2021 23:18,14732.519,4.09,701,300,10,6001,0,65535,65535,1,21.7,26440,-298,-296,100,70,9,2687,3888,545,545,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3768,3772,3767,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,969,SUCCESS,,2691.937922,192,0,0.1,0.2,0.3,263,1.4,1.5
    3677,5/26/2021 23:18,14736.529,4.09,701,300,10,6001,0,65535,65535,1,21.7,26439,-294,-296,100,70,9,2686,3888,544,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3768,3772,3767,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,944,SUCCESS,,2691.610439,192,0,0.1,0.2,0.3,263,1.4,1.5
    3678,5/26/2021 23:18,14740.541,4.09,701,300,10,6001,0,65535,65535,1,21.7,26439,-296,-296,100,70,9,2686,3888,544,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3768,3772,3767,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,958,SUCCESS,,2691.280563,192,0,0.1,0.2,0.3,263,1.4,1.5
    3679,5/26/2021 23:18,14744.556,4.1,701,300,10,6001,0,65535,65535,1,21.7,26439,-296,-296,100,70,9,2686,3888,541,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3768,3772,3767,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,962,SUCCESS,,2690.950441,192,0,0.1,0.2,0.3,263,1.4,1.5
    3680,5/26/2021 23:18,14748.559,4.1,701,300,10,6001,0,65535,65535,1,21.7,26437,-298,-296,100,70,9,2685,3888,541,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3780,3784,3786,3782,3768,3771,3767,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,943,SUCCESS,,2690.619081,192,0,0.1,0.2,0.3,263,1.4,1.5
    3681,5/26/2021 23:18,14752.571,4.1,701,300,10,6001,0,65535,65535,1,21.7,26436,-296,-297,100,70,9,2685,3888,544,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3784,3786,3781,3768,3771,3766,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,995,SUCCESS,,2690.289206,192,0,0.1,0.2,0.3,263,1.4,1.5
    3682,5/26/2021 23:18,14756.584,4.1,701,300,10,6001,0,65535,65535,1,21.7,26436,-296,-297,100,70,9,2685,3888,544,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3784,3786,3781,3768,3771,3766,0,0,0,0,0,0,0,0,2641,21.6,21.7,-273.2,21.7,-273.2,21.8,967,SUCCESS,,2689.959248,192,0,0.1,0.2,0.3,263,1.4,1.5
    3683,5/26/2021 23:18,14760.599,4.1,701,300,10,6001,0,65535,65535,1,21.7,26433,-298,-297,100,70,9,2684,3888,537,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3784,3785,3781,3767,3771,3766,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.1,952,SUCCESS,,2689.626895,192,0,0.1,0.2,0.3,263,1.4,1.5
    3684,5/26/2021 23:18,14764.613,4.1,701,300,10,6001,0,65535,65535,1,21.7,26432,-296,-297,100,70,9,2684,3888,544,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3784,3785,3781,3767,3771,3766,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,944,SUCCESS,,2689.296855,192,0,0.1,0.2,0.3,263,1.4,1.5
    3685,5/26/2021 23:18,14768.622,4.1,701,300,10,6001,0,65535,65535,1,21.7,26432,-296,-297,100,70,9,2684,3888,544,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3783,3785,3781,3767,3771,3766,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,947,SUCCESS,,2688.967226,192,0,0.1,0.2,0.3,263,1.4,1.5
    3686,5/26/2021 23:18,14772.637,4.1,701,300,10,6001,0,65535,65535,1,21.7,26431,-298,-297,100,70,9,2683,3888,540,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3783,3785,3781,3767,3771,3766,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,968,SUCCESS,,2688.634874,192,0,0.1,0.2,0.3,263,1.4,1.5
    3687,5/26/2021 23:19,14776.638,4.1,701,300,10,6001,0,65535,65535,1,21.7,26431,-296,-297,100,70,9,2683,3888,544,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3779,3783,3785,3781,3767,3771,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,948,SUCCESS,,2688.305903,192,0,0.1,0.2,0.3,263,1.4,1.5
    3688,5/26/2021 23:19,14780.638,4.11,701,300,10,6001,0,65535,65535,1,21.7,26429,-298,-297,100,70,9,2683,3888,540,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3783,3784,3781,3767,3770,3766,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,945,SUCCESS,,2687.974791,192,0,0.1,0.2,0.3,263,1.4,1.5
    3689,5/26/2021 23:19,14784.642,4.11,701,300,10,6001,0,65535,65535,1,21.7,26430,-298,-297,100,69,9,2682,3888,540,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3783,3784,3781,3767,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,940,SUCCESS,,2687.643349,192,0,0.1,0.2,0.3,263,1.4,1.5
    3690,5/26/2021 23:19,14788.657,4.11,701,300,10,6001,0,65535,65535,1,21.7,26425,-296,-296,100,69,9,2682,3888,544,544,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3783,3784,3780,3766,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,939,SUCCESS,,2687.313227,192,0,0.1,0.2,0.3,263,1.4,1.5
    3691,5/26/2021 23:19,14792.658,4.11,701,300,10,6001,0,65535,65535,1,21.7,26426,-298,-297,100,69,9,2682,3888,540,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3783,3784,3780,3767,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,937,SUCCESS,,2686.982033,192,0,0.1,0.2,0.3,263,1.4,1.5
    3692,5/26/2021 23:19,14796.661,4.11,701,300,10,6001,0,65535,65535,1,21.7,26426,-296,-297,100,69,9,2681,3888,543,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3783,3784,3780,3766,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,956,SUCCESS,,2686.652898,192,0,0.1,0.2,0.3,263,1.4,1.5
    3693,5/26/2021 23:19,14800.661,4.11,701,300,10,6001,0,65535,65535,1,21.7,26423,-294,-296,100,69,9,2681,3888,547,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3783,3784,3780,3767,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,953,SUCCESS,,2686.326231,192,0,0.1,0.2,0.3,263,1.4,1.5
    3694,5/26/2021 23:19,14804.673,4.11,701,300,10,6001,0,65535,65535,1,21.7,26426,-300,-297,100,69,9,2681,3888,536,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3782,3784,3780,3766,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,960,SUCCESS,,2685.991898,192,0,0.1,0.2,0.3,263,1.4,1.5
    3695,5/26/2021 23:19,14808.677,4.11,701,300,10,6001,0,65535,65535,1,21.7,26424,-296,-296,100,69,9,2680,3888,543,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3782,3784,3780,3766,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,966,SUCCESS,,2685.66268,192,0,0.1,0.2,0.3,263,1.4,1.5
    3696,5/26/2021 23:19,14812.683,4.11,701,300,10,6001,0,65535,65535,1,21.7,26421,-298,-296,100,69,9,2680,3888,540,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3782,3784,3780,3766,3770,3765,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,966,SUCCESS,,2685.331072,192,0,0.1,0.2,0.3,263,1.4,1.5
    3697,5/26/2021 23:19,14816.698,4.12,701,300,10,6001,0,65535,65535,1,21.7,26423,-298,-297,100,69,9,2680,3888,543,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3778,3782,3784,3780,3766,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,1009,SUCCESS,,2684.998719,192,0,0.1,0.2,0.3,263,1.4,1.5
    3698,5/26/2021 23:19,14820.698,4.12,701,300,10,6001,0,65535,65535,1,21.7,26422,-296,-297,100,69,9,2679,3888,543,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3782,3783,3780,3766,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,959,SUCCESS,,2684.66983,192,0,0.1,0.2,0.3,263,1.4,1.5
    3699,5/26/2021 23:19,14824.71,4.12,701,300,10,6001,0,65535,65535,1,21.7,26421,-296,-297,100,69,9,2679,3888,539,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3782,3784,3780,3766,3768,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,982,SUCCESS,,2684.339955,192,0,0.1,0.2,0.3,263,1.4,1.5
    3700,5/26/2021 23:19,14828.717,4.12,701,300,10,6001,0,65535,65535,1,21.7,26420,-296,-297,100,69,9,2679,3888,539,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3782,3783,3780,3766,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,943,SUCCESS,,2684.01049,192,0,0.1,0.2,0.3,263,1.4,1.5
    3701,5/26/2021 23:19,14832.722,4.12,701,300,10,6001,0,65535,65535,1,21.7,26420,-298,-296,100,69,9,2678,3888,539,543,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3779,3766,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,983,SUCCESS,,2683.678965,192,0,0.1,0.2,0.3,263,1.4,1.5
    3702,5/26/2021 23:20,14836.725,4.12,701,300,10,6001,0,65535,65535,1,21.7,26418,-298,-297,100,69,9,2678,3888,539,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3779,3765,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,949,SUCCESS,,2683.347606,192,0,0.1,0.2,0.3,263,1.4,1.5
    3703,5/26/2021 23:20,14840.738,4.12,701,300,10,6001,0,65535,65535,1,21.7,26418,-296,-297,100,69,9,2678,3888,543,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3779,3765,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,974,SUCCESS,,2683.017648,192,0,0.1,0.2,0.3,263,1.4,1.5
    3704,5/26/2021 23:20,14844.738,4.12,701,300,10,6001,0,65535,65535,1,21.7,26418,-298,-297,100,69,9,2677,3888,539,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3779,3765,3769,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,953,SUCCESS,,2682.686537,192,0,0.1,0.2,0.3,263,1.4,1.5
    3705,5/26/2021 23:20,14848.75,4.12,701,300,10,6001,0,65535,65535,1,21.7,26416,-298,-297,100,69,9,2677,3888,539,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3779,3765,3768,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,956,SUCCESS,,2682.354433,192,0,0.1,0.2,0.3,263,1.4,1.5
    3706,5/26/2021 23:20,14852.754,4.13,701,300,10,6001,0,65535,65535,1,21.7,26418,-294,-297,100,69,9,2677,3888,543,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3779,3765,3768,3764,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,945,SUCCESS,,2682.027439,192,0,0.1,0.2,0.3,263,1.4,1.5
    3707,5/26/2021 23:20,14856.758,4.13,701,300,10,6001,0,65535,65535,1,21.7,26415,-296,-297,100,69,9,2676,3888,539,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3778,3765,3768,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,948,SUCCESS,,2681.698221,192,0,0.1,0.2,0.3,263,1.4,1.5
    3708,5/26/2021 23:20,14860.772,4.13,701,300,10,6001,0,65535,65535,1,21.7,26414,-294,-297,100,69,9,2676,3888,546,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3777,3781,3783,3778,3764,3764,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,984,SUCCESS,,2681.370411,192,0,0.1,0.2,0.3,263,1.4,1.5
    3709,5/26/2021 23:20,14864.781,4.13,701,300,10,6001,0,65535,65535,1,21.7,26413,-294,-296,100,69,9,2676,3888,542,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3776,3781,3783,3778,3765,3768,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,946,SUCCESS,,2681.04301,192,0,0.1,0.2,0.3,263,1.4,1.5
    3710,5/26/2021 23:20,14868.792,4.13,701,300,10,6001,0,65535,65535,1,21.7,26414,-298,-297,100,69,9,2675,3888,539,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3776,3781,3783,3778,3764,3768,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,945,SUCCESS,,2680.710988,192,0,0.1,0.2,0.3,263,1.4,1.5
    3711,5/26/2021 23:20,14872.804,4.13,701,300,10,6001,0,65535,65535,1,21.7,26413,-296,-297,100,69,9,2675,3888,542,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3776,3781,3783,3778,3764,3767,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,960,SUCCESS,,2680.381113,192,0,0.1,0.2,0.3,263,1.4,1.5
    3712,5/26/2021 23:20,14876.811,4.13,701,300,10,6001,0,65535,65535,1,21.7,26412,-296,-297,100,69,9,2675,3888,539,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3776,3781,3782,3778,3764,3767,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,941,SUCCESS,,2680.051648,192,0,0.1,0.2,0.3,263,1.4,1.5
    3713,5/26/2021 23:20,14880.814,4.13,701,300,10,6001,0,65535,65535,1,21.7,26411,-296,-297,100,69,9,2674,3888,538,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3776,3781,3782,3778,3764,3767,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,937,SUCCESS,,2679.722513,192,0,0.1,0.2,0.3,263,1.4,1.5
    3714,5/26/2021 23:20,14884.825,4.13,701,300,10,6001,0,65535,65535,1,21.7,26410,-296,-297,100,69,9,2674,3888,542,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3782,3778,3764,3768,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,974,SUCCESS,,2679.392719,192,0,0.1,0.2,0.3,263,1.4,1.5
    3715,5/26/2021 23:20,14888.837,4.14,701,300,10,6001,0,65535,65535,1,21.7,26409,-298,-297,100,69,9,2674,3888,538,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3782,3778,3764,3767,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,961,SUCCESS,,2679.060615,192,0,0.1,0.2,0.3,263,1.4,1.5
    3716,5/26/2021 23:20,14892.843,4.14,701,300,10,6001,0,65535,65535,1,21.7,26409,-294,-297,100,69,9,2673,3888,542,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3782,3778,3764,3767,3763,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.4,943,SUCCESS,,2678.733458,192,0,0.1,0.2,0.3,263,1.4,1.5
    3717,5/26/2021 23:21,14896.849,4.14,701,300,10,6001,0,65535,65535,1,21.7,26407,-296,-297,100,69,9,2673,3888,546,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3781,3778,3764,3766,3762,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,989,SUCCESS,,2678.404076,192,0,0.1,0.2,0.3,263,1.4,1.5
    3718,5/26/2021 23:21,14900.855,4.14,701,300,10,6001,0,65535,65535,1,21.7,26408,-296,-297,100,69,9,2673,3888,546,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3781,3777,3764,3767,3762,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,959,SUCCESS,,2678.074694,192,0,0.1,0.2,0.3,263,1.4,1.5
    3719,5/26/2021 23:21,14904.855,4.14,701,300,10,6001,0,65535,65535,1,21.7,26406,-294,-297,100,69,9,2672,3888,542,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3781,3778,3764,3767,3762,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,950,SUCCESS,,2677.748027,192,0,0.1,0.2,0.3,263,1.4,1.5
    3720,5/26/2021 23:21,14908.86,4.14,701,300,10,6001,0,65535,65535,1,21.7,26405,-298,-296,100,69,9,2672,3888,538,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3781,3777,3764,3767,3762,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,978,SUCCESS,,2677.416502,192,0,0.1,0.2,0.3,263,1.4,1.5
    3721,5/26/2021 23:21,14912.87,4.14,701,300,10,6001,0,65535,65535,1,21.7,26405,-298,-296,100,69,9,2672,3888,542,542,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3781,3777,3763,3766,3762,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,946,SUCCESS,,2677.084563,192,0,0.1,0.2,0.3,263,1.4,1.5
    3722,5/26/2021 23:21,14916.872,4.14,701,300,10,6001,0,65535,65535,1,21.7,26405,-296,-296,100,69,9,2671,3888,545,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3780,3781,3777,3763,3767,3762,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,963,SUCCESS,,2676.75551,192,0,0.1,0.2,0.3,263,1.4,1.5
    3723,5/26/2021 23:21,14920.876,4.14,701,300,10,6001,0,65535,65535,1,21.7,26403,-296,-296,100,69,9,2671,3888,541,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3779,3781,3777,3763,3767,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,941,SUCCESS,,2676.426292,192,0,0.1,0.2,0.3,263,1.4,1.5
    3724,5/26/2021 23:21,14924.878,4.15,701,300,10,6001,0,65535,65535,1,21.7,26401,-296,-296,100,69,9,2671,3888,545,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3779,3781,3777,3763,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,942,SUCCESS,,2676.097239,192,0,0.1,0.2,0.3,263,1.4,1.5
    3725,5/26/2021 23:21,14928.888,4.15,701,300,10,6001,0,65535,65535,1,21.7,26402,-294,-296,100,69,9,2670,3888,545,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3775,3779,3781,3777,3763,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,959,SUCCESS,,2675.769755,192,0,0.1,0.2,0.3,263,1.4,1.5
    3726,5/26/2021 23:21,14932.896,4.15,701,300,10,6001,0,65535,65535,1,21.7,26402,-298,-296,100,69,9,2670,3888,538,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3779,3781,3777,3763,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,950,SUCCESS,,2675.437982,192,0,0.1,0.2,0.3,263,1.4,1.5
    3727,5/26/2021 23:21,14936.9,4.15,701,300,10,6001,0,65535,65535,1,21.7,26399,-296,-296,100,69,9,2670,3888,541,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3779,3780,3776,3763,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,963,SUCCESS,,2675.108764,192,0,0.1,0.2,0.3,263,1.4,1.5
    3728,5/26/2021 23:21,14940.909,4.15,701,300,10,6001,0,65535,65535,1,21.7,26399,-296,-296,100,69,9,2669,3888,541,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3779,3780,3776,3763,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,954,SUCCESS,,2674.779135,192,0,0.1,0.2,0.3,263,1.4,1.5
    3729,5/26/2021 23:21,14944.915,4.15,701,300,10,6001,0,65535,65535,1,21.7,26399,-296,-296,100,69,9,2669,3888,541,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3778,3780,3776,3762,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,987,SUCCESS,,2674.449753,192,0,0.1,0.2,0.3,263,1.4,1.5
    3730,5/26/2021 23:21,14948.923,4.15,701,300,10,6001,0,65535,65535,1,21.7,26397,-298,-296,100,69,9,2669,3888,537,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3778,3780,3776,3762,3765,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.7,974,SUCCESS,,2674.11798,192,0,0.1,0.2,0.3,263,1.4,1.5
    3731,5/26/2021 23:22,14952.932,4.15,701,300,10,6001,0,65535,65535,1,21.7,26396,-298,-296,100,69,9,2668,3888,537,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3774,3778,3780,3776,3762,3766,3761,0,0,0,0,0,0,0,0,2640,21.6,21.7,-273.2,21.7,-273.2,21.8,933,SUCCESS,,2673.786124,192,0,0.1,0.2,0.3,263,1.4,1.5
    3732,5/26/2021 23:22,14956.937,4.15,701,300,10,6001,0,65535,65535,1,21.7,26396,-296,-297,100,69,9,2668,3888,541,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3780,3776,3762,3766,3760,0,0,0,0,0,0,0,0,2636,21.6,21.7,-273.2,21.7,-273.2,21.8,979,SUCCESS,,2673.456824,192,0,0.1,0.2,0.3,263,1.4,1.5
    3733,5/26/2021 23:22,14960.942,4.16,701,300,10,6001,0,65535,65535,1,21.7,26394,-296,-296,100,69,9,2668,3888,541,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3780,3776,3762,3765,3760,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,953,SUCCESS,,2673.127524,192,0,0.1,0.2,0.3,263,1.4,1.5
    3734,5/26/2021 23:22,14964.943,4.16,701,300,10,6001,0,65535,65535,1,21.7,26393,-296,-296,100,69,9,2667,3888,537,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3780,3775,3762,3765,3760,0,0,0,0,0,0,0,0,2636,21.6,21.7,-273.2,21.7,-273.2,21.8,961,SUCCESS,,2672.798553,192,0,0.1,0.2,0.3,263,1.4,1.5
    3735,5/26/2021 23:22,14968.951,4.16,701,300,10,6001,0,65535,65535,1,21.7,26394,-296,-297,100,69,9,2667,3888,537,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3780,3775,3761,3765,3760,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.1,977,SUCCESS,,2672.469006,192,0,0.1,0.2,0.3,263,1.4,1.5
    3736,5/26/2021 23:22,14972.957,4.16,701,300,10,6001,0,65535,65535,1,21.7,26392,-294,-296,100,69,9,2667,3888,541,541,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3780,3775,3761,3765,3760,0,0,0,0,0,0,0,0,2639,21.6,21.7,-273.2,21.7,-273.2,21.8,969,SUCCESS,,2672.141849,192,0,0.1,0.2,0.3,263,1.4,1.5
    3737,5/26/2021 23:22,14976.96,4.16,701,300,10,6001,0,65535,65535,1,21.7,26391,-296,-296,100,69,9,2666,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3780,3775,3761,3765,3760,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,950,SUCCESS,,2671.812714,192,0,0.1,0.2,0.3,263,1.4,1.5
    3738,5/26/2021 23:22,14980.966,4.16,701,300,10,6001,0,65535,65535,1,21.7,26391,-296,-296,100,69,9,2666,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3779,3775,3761,3765,3760,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,946,SUCCESS,,2671.483331,192,0,0.1,0.2,0.3,263,1.4,1.5
    3739,5/26/2021 23:22,14984.979,4.16,701,300,10,6001,0,65535,65535,1,21.7,26388,-298,-296,100,69,9,2666,3888,537,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3778,3779,3775,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,931,SUCCESS,,2671.151144,192,0,0.1,0.2,0.3,263,1.4,1.5
    3740,5/26/2021 23:22,14988.991,4.16,701,300,10,6001,0,65535,65535,1,21.7,26388,-296,-296,100,69,9,2665,3888,544,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3777,3779,3775,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,950,SUCCESS,,2670.821269,192,0,0.1,0.2,0.3,263,1.4,1.5
    3741,5/26/2021 23:22,14992.994,4.16,701,300,10,6001,0,65535,65535,1,21.7,26389,-294,-296,100,69,9,2665,3888,544,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3773,3777,3779,3775,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,932,SUCCESS,,2670.494357,192,0,0.1,0.2,0.3,263,1.4,1.5
    3742,5/26/2021 23:22,14996.999,4.17,701,300,10,6001,0,65535,65535,1,21.7,26387,-298,-296,100,69,9,2665,3888,537,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3775,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,944,SUCCESS,,2670.162832,192,0,0.1,0.2,0.3,263,1.4,1.5
    3743,5/26/2021 23:22,15001.012,4.17,701,300,10,6001,0,65535,65535,1,21.7,26387,-296,-296,100,69,9,2664,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3775,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,958,SUCCESS,,2669.832874,192,0,0.1,0.2,0.3,263,1.4,1.5
    3744,5/26/2021 23:22,15005.024,4.17,701,300,10,6001,0,65535,65535,1,21.7,26387,-296,-296,100,69,9,2664,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3774,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,941,SUCCESS,,2669.502999,192,0,0.1,0.2,0.3,263,1.4,1.5
    3745,5/26/2021 23:22,15009.027,4.17,701,300,10,6001,0,65535,65535,1,21.7,26384,-298,-296,100,69,9,2664,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3775,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,945,SUCCESS,,2669.171639,192,0,0.1,0.2,0.3,263,1.4,1.5
    3746,5/26/2021 23:23,15013.036,4.17,701,300,10,6001,0,65535,65535,1,21.7,26384,-296,-296,100,69,9,2663,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3774,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,938,SUCCESS,,2668.84201,192,0,0.1,0.2,0.3,263,1.4,1.5
    3747,5/26/2021 23:23,15017.048,4.17,701,300,10,6001,0,65535,65535,1,21.7,26384,-296,-296,100,69,9,2663,3888,536,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3774,3761,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,956,SUCCESS,,2668.512135,192,0,0.1,0.2,0.3,263,1.4,1.5
    3748,5/26/2021 23:23,15021.055,4.17,701,300,10,6001,0,65535,65535,1,21.7,26384,-296,-297,100,69,9,2663,3888,536,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3774,3760,3764,3759,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,949,SUCCESS,,2668.18267,192,0,0.1,0.2,0.3,263,1.4,1.5
    3749,5/26/2021 23:23,15025.059,4.17,701,300,10,6001,0,65535,65535,1,21.7,26382,-294,-296,100,69,9,2662,3888,543,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3774,3760,3764,3758,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,946,SUCCESS,,2667.855677,192,0,0.1,0.2,0.3,263,1.4,1.5
    3750,5/26/2021 23:23,15029.063,4.17,701,300,10,6001,0,65535,65535,1,21.7,26383,-298,-296,100,69,9,2662,3888,540,540,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3777,3778,3774,3760,3764,3758,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,940,SUCCESS,,2667.524235,192,0,0.1,0.2,0.3,263,1.4,1.5
    3751,5/26/2021 23:23,15033.073,4.18,701,300,10,6001,0,65535,65535,1,21.7,26381,-296,-297,100,69,9,2662,3888,540,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3776,3778,3774,3760,3763,3758,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,932,SUCCESS,,2667.194524,192,0,0.1,0.2,0.3,263,1.4,1.5
    3752,5/26/2021 23:23,15037.075,4.18,701,300,10,6001,0,65535,65535,1,21.7,26379,-296,-296,100,69,9,2661,3888,543,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3772,3776,3778,3774,3759,3763,3758,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.8,988,SUCCESS,,2666.86547,192,0,0.1,0.2,0.3,263,1.4,1.5
    3753,5/26/2021 23:23,15041.086,4.18,701,300,10,6001,0,65535,65535,1,21.7,26378,-298,-296,100,69,9,2661,3888,536,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3776,3778,3773,3760,3763,3758,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,964,SUCCESS,,2666.533449,192,0,0.1,0.2,0.3,263,1.4,1.5
    3754,5/26/2021 23:23,15045.097,4.18,701,300,10,6001,0,65535,65535,1,21.7,26378,-294,-296,100,69,9,2661,3888,539,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3776,3778,3773,3759,3763,3758,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.2,983,SUCCESS,,2666.205884,192,0,0.1,0.2,0.3,263,1.4,1.5
    3755,5/26/2021 23:23,15049.11,4.18,701,300,10,6001,0,65535,65535,1,21.7,26377,-296,-296,100,69,9,2660,3888,543,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3776,3777,3773,3759,3763,3758,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.7,940,SUCCESS,,2665.875926,192,0,0.1,0.2,0.3,263,1.4,1.5
    3756,5/26/2021 23:23,15053.115,4.18,701,300,10,6001,0,65535,65535,1,21.7,26376,-298,-296,100,69,9,2660,3888,539,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3776,3777,3773,3759,3763,3757,0,0,0,0,0,0,0,0,2635,21.6,21.7,-273.2,21.7,-273.2,21.8,959,SUCCESS,,2665.544401,192,0,0.1,0.2,0.3,263,1.4,1.5
    3757,5/26/2021 23:23,15057.127,4.18,701,300,10,6001,0,65535,65535,1,21.7,26377,-294,-296,100,69,9,2660,3888,539,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3775,3777,3773,3759,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.8,940,SUCCESS,,2665.216754,192,0,0.1,0.2,0.3,263,1.4,1.5
    3758,5/26/2021 23:23,15061.129,4.18,701,300,10,6001,0,65535,65535,1,21.7,26375,-296,-296,100,69,9,2659,3888,535,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3776,3777,3773,3759,3763,3758,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.7,953,SUCCESS,,2664.887701,192,0,0.1,0.2,0.3,263,1.4,1.5
    3759,5/26/2021 23:23,15065.139,4.18,701,300,10,6001,0,65535,65535,1,21.7,26376,-294,-297,100,69,9,2659,3888,539,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3776,3777,3773,3759,3763,3758,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.7,944,SUCCESS,,2664.560218,192,0,0.1,0.2,0.3,263,1.4,1.5
    3760,5/26/2021 23:23,15069.142,4.19,701,300,10,6001,0,65535,65535,1,21.6,26375,-296,-296,100,69,9,2659,3888,543,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3771,3775,3777,3773,3759,3762,3758,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,955,SUCCESS,,2664.231082,192,0,0.1,0.2,0.3,263,1.4,1.5
    3761,5/26/2021 23:24,15073.153,4.19,701,300,10,6001,0,65535,65535,1,21.7,26375,-296,-296,100,69,9,2658,3888,535,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3777,3773,3759,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2663.901289,192,0,0.1,0.2,0.3,263,1.4,1.5
    3762,5/26/2021 23:24,15077.16,4.19,701,300,10,6001,0,65535,65535,1,21.6,26372,-294,-296,100,69,9,2658,3888,542,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3777,3772,3759,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.7,953,SUCCESS,,2663.57405,192,0,0.1,0.2,0.3,263,1.4,1.5
    3763,5/26/2021 23:24,15081.172,4.19,701,300,10,6001,0,65535,65535,1,21.7,26371,-298,-296,100,69,9,2658,3888,535,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3777,3772,3759,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.7,958,SUCCESS,,2663.241946,192,0,0.1,0.2,0.3,263,1.4,1.5
    3764,5/26/2021 23:24,15085.18,4.19,701,300,10,6001,0,65535,65535,1,21.6,26371,-298,-297,100,69,9,2657,3888,535,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3777,3772,3758,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.8,975,SUCCESS,,2662.910173,192,0,0.1,0.2,0.3,263,1.4,1.5
    3765,5/26/2021 23:24,15089.181,4.19,701,300,10,6001,0,65535,65535,1,21.7,26369,-294,-296,100,69,9,2657,3888,542,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3776,3772,3758,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.7,949,SUCCESS,,2662.583424,192,0,0.1,0.2,0.3,263,1.4,1.5
    3766,5/26/2021 23:24,15093.191,4.19,701,300,10,6001,0,65535,65535,1,21.6,26369,-298,-296,100,69,9,2657,3888,535,539,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3776,3772,3758,3762,3757,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,939,SUCCESS,,2662.251485,192,0,0.1,0.2,0.3,263,1.4,1.5
    3767,5/26/2021 23:24,15097.202,4.19,701,300,10,6001,0,65535,65535,1,21.6,26368,-296,-296,100,69,9,2656,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3776,3772,3758,3761,3757,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.8,944,SUCCESS,,2661.921692,192,0,0.1,0.2,0.3,263,1.4,1.5
    3768,5/26/2021 23:24,15101.206,4.19,701,300,10,6001,0,65535,65535,1,21.6,26370,-294,-296,100,69,9,2656,3888,542,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3776,3772,3758,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,939,SUCCESS,,2661.594699,192,0,0.1,0.2,0.3,263,1.4,1.5
    3769,5/26/2021 23:24,15105.208,4.2,701,300,10,6001,0,65535,65535,1,21.6,26368,-298,-296,100,69,9,2656,3888,535,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3770,3775,3776,3772,3758,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,953,SUCCESS,,2661.263422,192,0,0.1,0.2,0.3,263,1.4,1.5
    3770,5/26/2021 23:24,15109.212,4.2,701,300,10,6001,0,65535,65535,1,21.6,26366,-296,-296,100,69,9,2655,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3774,3776,3772,3758,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,963,SUCCESS,,2660.934204,192,0,0.1,0.2,0.3,263,1.4,1.5
    3771,5/26/2021 23:24,15113.221,4.2,701,300,10,6001,0,65535,65535,1,21.6,26367,-296,-296,100,69,9,2655,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3774,3776,3772,3757,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,955,SUCCESS,,2660.604575,192,0,0.1,0.2,0.3,263,1.4,1.5
    3772,5/26/2021 23:24,15117.23,4.2,701,300,10,6001,0,65535,65535,1,21.6,26364,-298,-297,100,69,9,2655,3888,535,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3774,3775,3771,3758,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,948,SUCCESS,,2660.272719,192,0,0.1,0.2,0.3,263,1.4,1.5
    3773,5/26/2021 23:24,15121.232,4.2,701,300,10,6001,0,65535,65535,1,21.6,26364,-296,-296,100,69,9,2654,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3774,3776,3772,3757,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.4,989,SUCCESS,,2659.943666,192,0,0.1,0.2,0.3,263,1.4,1.5
    3774,5/26/2021 23:24,15125.241,4.2,701,300,10,6001,0,65535,65535,1,21.7,26364,-296,-296,100,69,9,2654,3888,534,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3774,3775,3771,3757,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.6,981,SUCCESS,,2659.614037,192,0,0.1,0.2,0.3,263,1.4,1.5
    3775,5/26/2021 23:24,15129.25,4.2,701,300,10,6001,0,65535,65535,1,21.7,26361,-296,-296,100,69,9,2654,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3773,3775,3771,3757,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.7,-273.2,21.7,-273.2,21.7,972,SUCCESS,,2659.284408,192,0,0.1,0.2,0.3,263,1.4,1.5
    3776,5/26/2021 23:25,15133.255,4.2,701,300,10,6001,0,65535,65535,1,21.6,26362,-296,-296,100,69,9,2653,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3774,3775,3771,3757,3761,3756,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,952,SUCCESS,,2658.955108,192,0,0.1,0.2,0.3,263,1.4,1.5
    3777,5/26/2021 23:25,15137.263,4.2,701,300,10,6001,0,65535,65535,1,21.6,26360,-298,-296,100,69,9,2653,3888,534,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3773,3775,3771,3757,3760,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2658.623335,192,0,0.1,0.2,0.3,263,1.4,1.5
    3778,5/26/2021 23:25,15141.266,4.21,701,300,10,6001,0,65535,65535,1,21.6,26360,-296,-296,100,69,9,2653,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3773,3775,3771,3757,3760,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2658.294199,192,0,0.1,0.2,0.3,263,1.4,1.5
    3779,5/26/2021 23:25,15145.276,4.21,701,300,10,6001,0,65535,65535,1,21.6,26358,-296,-296,100,69,9,2652,3888,538,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3769,3773,3775,3771,3756,3760,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2657.964488,192,0,0.1,0.2,0.3,263,1.4,1.5
    3780,5/26/2021 23:25,15149.287,4.21,701,300,10,6001,0,65535,65535,1,21.6,26357,-296,-297,100,69,9,2652,3888,534,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3768,3773,3775,3770,3756,3760,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,989,SUCCESS,,2657.634695,192,0,0.1,0.2,0.3,263,1.4,1.5
    3781,5/26/2021 23:25,15153.303,4.21,701,300,10,6001,0,65535,65535,1,21.6,26356,-294,-296,100,69,9,2652,3888,541,538,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3768,3773,3775,3770,3756,3760,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,976,SUCCESS,,2657.306721,192,0,0.1,0.2,0.3,263,1.4,1.5
    3782,5/26/2021 23:25,15157.304,4.21,701,300,10,6001,0,65535,65535,1,21.6,26357,-298,-296,100,69,9,2651,3888,537,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3768,3773,3775,3770,3756,3760,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.8,983,SUCCESS,,2656.975528,192,0,0.1,0.2,0.3,263,1.4,1.5
    3783,5/26/2021 23:25,15161.305,4.21,701,300,10,6001,0,65535,65535,1,21.6,26356,-296,-296,100,69,9,2651,3888,537,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3768,3773,3774,3770,3756,3759,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,947,SUCCESS,,2656.646556,192,0,0.1,0.2,0.3,263,1.4,1.5
    3784,5/26/2021 23:25,15165.31,4.21,701,300,10,6001,0,65535,65535,1,21.6,26355,-294,-296,100,69,9,2651,3888,541,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3768,3773,3774,3770,3756,3759,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,948,SUCCESS,,2656.319481,192,0,0.1,0.2,0.3,263,1.4,1.5
    3785,5/26/2021 23:25,15169.325,4.21,701,300,10,6001,0,65535,65535,1,21.6,26353,-298,-296,100,69,9,2650,3888,537,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3773,3774,3770,3756,3759,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.8,952,SUCCESS,,2655.987129,192,0,0.1,0.2,0.3,263,1.4,1.5
    3786,5/26/2021 23:25,15173.34,4.21,701,300,10,6001,0,65535,65535,1,21.6,26354,-294,-296,100,69,9,2650,3888,541,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3774,3770,3756,3759,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,946,SUCCESS,,2655.659237,192,0,0.1,0.2,0.3,263,1.4,1.5
    3787,5/26/2021 23:25,15177.354,4.22,701,300,10,6001,0,65535,65535,1,21.6,26353,-294,-296,100,69,9,2650,3888,537,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3774,3770,3756,3759,3755,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,946,SUCCESS,,2655.331427,192,0,0.1,0.2,0.3,263,1.4,1.5
    3788,5/26/2021 23:25,15181.355,4.22,701,300,10,6001,0,65535,65535,1,21.6,26353,-296,-296,100,69,9,2650,3888,537,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3774,3770,3755,3759,3754,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,976,SUCCESS,,2655.002456,192,0,0.1,0.2,0.3,263,1.4,1.5
    3789,5/26/2021 23:25,15185.357,4.22,701,300,10,6001,0,65535,65535,1,21.6,26350,-296,-296,100,69,9,2649,3888,533,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3756,3759,3754,0,0,0,0,0,0,0,0,2634,21.5,21.6,-273.2,21.6,-273.2,21.7,943,SUCCESS,,2654.673403,192,0,0.1,0.2,0.3,263,1.4,1.5
    3790,5/26/2021 23:25,15189.359,4.22,701,300,10,6001,0,65535,65535,1,21.6,26350,-296,-296,100,69,9,2649,3888,541,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3755,3759,3754,0,0,0,0,0,0,0,0,2635,21.5,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2654.344349,192,0,0.1,0.2,0.3,263,1.4,1.5
    3791,5/26/2021 23:26,15193.363,4.22,701,300,10,6001,0,65535,65535,1,21.6,26348,-298,-296,100,69,9,2649,3888,533,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3756,3759,3754,0,0,0,0,0,0,0,0,2634,21.5,21.6,-273.2,21.6,-273.2,21.7,984,SUCCESS,,2654.012907,192,0,0.1,0.2,0.3,263,1.4,1.5
    3792,5/26/2021 23:26,15197.37,4.22,701,300,10,6001,0,65535,65535,1,21.6,26349,-296,-296,100,69,9,2648,3888,540,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3755,3760,3754,0,0,0,0,0,0,0,0,2632,21.5,21.6,-273.2,21.6,-273.2,21.8,974,SUCCESS,,2653.683443,192,0,0.1,0.2,0.3,263,1.4,1.5
    3793,5/26/2021 23:26,15201.385,4.22,701,300,10,6001,0,65535,65535,1,21.6,26348,-296,-296,100,69,9,2648,3888,533,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3755,3758,3754,0,0,0,0,0,0,0,0,2632,21.5,21.6,-273.2,21.6,-273.2,21.7,946,SUCCESS,,2653.35332,192,0,0.1,0.2,0.3,263,1.4,1.5
    3794,5/26/2021 23:26,15205.397,4.22,701,300,10,6001,0,65535,65535,1,21.6,26349,-296,-296,100,69,9,2648,3888,540,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3755,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,1029,SUCCESS,,2653.023445,192,0,0.1,0.2,0.3,263,1.4,1.5
    3795,5/26/2021 23:26,15209.41,4.22,701,300,10,6001,0,65535,65535,1,21.6,26347,-296,-296,100,69,9,2647,3888,540,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3755,3760,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,937,SUCCESS,,2652.693487,192,0,0.1,0.2,0.3,263,1.4,1.5
    3796,5/26/2021 23:26,15213.411,4.23,701,300,10,6001,0,65535,65535,1,21.6,26346,-300,-296,100,69,9,2647,3888,533,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3771,3773,3769,3755,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,984,SUCCESS,,2652.36007,192,0,0.1,0.2,0.3,263,1.4,1.5
    3797,5/26/2021 23:26,15217.414,4.23,701,300,10,6001,0,65535,65535,1,21.6,26347,-296,-296,100,69,9,2647,3888,537,537,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3772,3773,3769,3755,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.4,1007,SUCCESS,,2652.030935,192,0,0.1,0.2,0.3,263,1.4,1.5
    3798,5/26/2021 23:26,15221.422,4.23,701,300,10,6001,0,65535,65535,1,21.6,26345,-296,-296,100,69,9,2646,3888,540,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3771,3772,3769,3755,3760,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,956,SUCCESS,,2651.701388,192,0,0.1,0.2,0.3,263,1.4,1.5
    3799,5/26/2021 23:26,15225.431,4.23,701,300,10,6001,0,65535,65535,1,21.6,26346,-296,-296,100,69,9,2646,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3767,3771,3773,3769,3755,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,963,SUCCESS,,2651.371759,192,0,0.1,0.2,0.3,263,1.4,1.5
    3800,5/26/2021 23:26,15229.439,4.23,701,300,10,6001,0,65535,65535,1,21.6,26345,-296,-296,100,69,9,2645,3888,540,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3771,3773,3769,3755,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,963,SUCCESS,,2651.042213,192,0,0.1,0.2,0.3,263,1.4,1.5
    3801,5/26/2021 23:26,15233.45,4.23,701,300,10,6001,0,65535,65535,1,21.6,26342,-298,-296,100,69,9,2645,3888,533,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3771,3772,3768,3754,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2650.710191,192,0,0.1,0.2,0.3,263,1.4,1.5
    3802,5/26/2021 23:26,15237.456,4.23,701,300,10,6001,0,65535,65535,1,21.6,26343,-298,-296,100,69,9,2645,3888,533,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3771,3772,3768,3754,3757,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.8,975,SUCCESS,,2650.378583,192,0,0.1,0.2,0.3,263,1.4,1.5
    3803,5/26/2021 23:26,15241.465,4.23,701,300,10,6001,0,65535,65535,1,21.6,26342,-294,-296,100,69,9,2644,3888,540,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3771,3772,3768,3754,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,976,SUCCESS,,2650.051181,192,0,0.1,0.2,0.3,263,1.4,1.5
    3804,5/26/2021 23:26,15245.47,4.23,701,300,10,6001,0,65535,65535,1,21.6,26341,-296,-296,100,69,9,2644,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3770,3772,3768,3754,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,941,SUCCESS,,2649.721881,192,0,0.1,0.2,0.3,263,1.4,1.5
    3805,5/26/2021 23:26,15249.471,4.24,701,300,10,6001,0,65535,65535,1,21.6,26339,-294,-296,100,69,9,2644,3888,540,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3770,3772,3768,3754,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,955,SUCCESS,,2649.395133,192,0,0.1,0.2,0.3,263,1.4,1.5
    3806,5/26/2021 23:27,15253.478,4.24,701,300,10,6001,0,65535,65535,1,21.6,26340,-296,-296,100,69,9,2644,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3770,3772,3768,3754,3758,3753,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,964,SUCCESS,,2649.065669,192,0,0.1,0.2,0.3,263,1.4,1.5
    3807,5/26/2021 23:27,15257.478,4.24,701,300,10,6001,0,65535,65535,1,21.6,26339,-296,-296,100,68,9,2643,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3770,3772,3768,3754,3758,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,932,SUCCESS,,2648.73678,192,0,0.1,0.2,0.3,263,1.4,1.5
    3808,5/26/2021 23:27,15261.481,4.24,701,300,10,6001,0,65535,65535,1,21.6,26338,-294,-296,100,68,9,2643,3888,539,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3766,3770,3772,3767,3753,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,945,SUCCESS,,2648.409868,192,0,0.1,0.2,0.3,263,1.4,1.5
    3809,5/26/2021 23:27,15265.492,4.24,701,300,10,6001,0,65535,65535,1,21.6,26337,-294,-296,100,68,9,2643,3888,539,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3770,3772,3767,3753,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2648.082303,192,0,0.1,0.2,0.3,263,1.4,1.5
    3810,5/26/2021 23:27,15269.493,4.24,701,300,10,6001,0,65535,65535,1,21.6,26335,-296,-296,100,68,9,2642,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3770,3772,3767,3753,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,931,SUCCESS,,2647.753332,192,0,0.1,0.2,0.3,263,1.4,1.5
    3811,5/26/2021 23:27,15273.5,4.24,701,300,10,6001,0,65535,65535,1,21.6,26334,-296,-296,100,68,9,2642,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3770,3771,3767,3753,3756,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,971,SUCCESS,,2647.423868,192,0,0.1,0.2,0.3,263,1.4,1.5
    3812,5/26/2021 23:27,15277.511,4.24,701,300,10,6001,0,65535,65535,1,21.6,26335,-298,-296,100,68,9,2642,3888,536,536,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3770,3771,3767,3753,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,966,SUCCESS,,2647.091846,192,0,0.1,0.2,0.3,263,1.4,1.5
    3813,5/26/2021 23:27,15281.516,4.24,701,300,10,6001,0,65535,65535,1,21.6,26334,-298,-296,100,68,9,2641,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3770,3771,3767,3753,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,941,SUCCESS,,2646.760321,192,0,0.1,0.2,0.3,263,1.4,1.5
    3814,5/26/2021 23:27,15285.531,4.25,701,300,10,6001,0,65535,65535,1,21.6,26332,-298,-296,100,68,9,2641,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3771,3767,3753,3756,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,975,SUCCESS,,2646.427968,192,0,0.1,0.2,0.3,263,1.4,1.5
    3815,5/26/2021 23:27,15289.532,4.25,701,300,10,6001,0,65535,65535,1,21.6,26333,-298,-296,100,68,9,2641,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3769,3771,3767,3753,3757,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,941,SUCCESS,,2646.096774,192,0,0.1,0.2,0.3,263,1.4,1.5
    3816,5/26/2021 23:27,15293.564,4.25,701,300,10,6001,0,65535,65535,1,21.6,26332,-296,-296,100,68,9,2640,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3765,3769,3771,3767,3753,3756,3752,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21,979,SUCCESS,,2645.765254,192,0,0.1,0.2,0.3,263,1.4,1.5
    3817,5/26/2021 23:27,15297.579,4.25,701,300,10,6001,0,65535,65535,1,21.6,26330,-296,-296,100,68,9,2640,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3767,3753,3756,3751,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2645.435132,192,0,0.1,0.2,0.3,263,1.4,1.5
    3818,5/26/2021 23:27,15301.594,4.25,701,300,10,6001,0,65535,65535,1,21.6,26329,-296,-296,100,68,9,2640,3888,539,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3751,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,941,SUCCESS,,2645.10501,192,0,0.1,0.2,0.3,263,1.4,1.5
    3819,5/26/2021 23:27,15305.595,4.25,701,300,10,6001,0,65535,65535,1,21.6,26329,-296,-296,100,68,9,2639,3888,531,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3751,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,986,SUCCESS,,2644.776039,192,0,0.1,0.2,0.3,263,1.4,1.5
    3820,5/26/2021 23:27,15309.609,4.25,701,300,10,6001,0,65535,65535,1,21.6,26328,-296,-296,100,68,9,2639,3888,531,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3751,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,940,SUCCESS,,2644.445999,192,0,0.1,0.2,0.3,263,1.4,1.5
    3821,5/26/2021 23:28,15313.626,4.25,701,300,10,6001,0,65535,65535,1,21.6,26328,-296,-296,100,68,9,2639,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3751,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,957,SUCCESS,,2644.115712,192,0,0.1,0.2,0.3,263,1.4,1.5
    3822,5/26/2021 23:28,15317.641,4.25,701,300,10,6001,0,65535,65535,1,21.6,26327,-298,-296,100,68,9,2638,3888,531,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,979,SUCCESS,,2643.783359,192,0,0.1,0.2,0.3,263,1.4,1.5
    3823,5/26/2021 23:28,15321.657,4.26,701,300,10,6001,0,65535,65535,1,21.6,26326,-298,-296,100,68,9,2638,3888,531,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,954,SUCCESS,,2643.450924,192,0,0.1,0.2,0.3,263,1.4,1.5
    3824,5/26/2021 23:28,15325.673,4.26,701,300,10,6001,0,65535,65535,1,21.6,26326,-296,-296,100,68,9,2638,3888,531,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3769,3770,3766,3752,3756,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,946,SUCCESS,,2643.120719,192,0,0.1,0.2,0.3,263,1.4,1.5
    3825,5/26/2021 23:28,15329.686,4.26,701,300,10,6001,0,65535,65535,1,21.6,26325,-296,-296,100,68,9,2637,3888,531,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3764,3768,3770,3766,3752,3756,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,949,SUCCESS,,2642.790761,192,0,0.1,0.2,0.3,263,1.4,1.5
    3826,5/26/2021 23:28,15333.703,4.26,701,300,10,6001,0,65535,65535,1,21.6,26323,-298,-296,100,68,9,2637,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3768,3769,3766,3752,3756,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,948,SUCCESS,,2642.458243,192,0,0.1,0.2,0.3,263,1.4,1.5
    3827,5/26/2021 23:28,15337.72,4.26,701,300,10,6001,0,65535,65535,1,21.6,26323,-296,-296,100,68,9,2637,3888,535,535,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3768,3770,3765,3751,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,939,SUCCESS,,2642.127956,192,0,0.1,0.2,0.3,263,1.4,1.5
    3828,5/26/2021 23:28,15341.719,4.26,701,300,10,6001,0,65535,65535,1,21.6,26322,-298,-296,100,68,9,2636,3888,531,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3768,3770,3765,3752,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.6,956,SUCCESS,,2641.796928,192,0,0.1,0.2,0.3,263,1.4,1.5
    3829,5/26/2021 23:28,15345.735,4.26,701,300,10,6001,0,65535,65535,1,21.6,26320,-298,-296,100,68,9,2636,3888,538,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3768,3769,3765,3751,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,956,SUCCESS,,2641.464493,192,0,0.1,0.2,0.3,263,1.4,1.5
    3830,5/26/2021 23:28,15349.75,4.26,701,300,10,6001,0,65535,65535,1,21.6,26321,-294,-296,100,68,9,2636,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3768,3769,3765,3751,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,946,SUCCESS,,2641.136601,192,0,0.1,0.2,0.3,263,1.4,1.5
    3831,5/26/2021 23:28,15353.766,4.26,701,300,10,6001,0,65535,65535,1,21.6,26320,-296,-296,100,68,9,2635,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3768,3769,3765,3751,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.8,988,SUCCESS,,2640.806396,192,0,0.1,0.2,0.3,263,1.4,1.5
    3832,5/26/2021 23:28,15357.695,4.27,701,300,10,6001,0,65535,65535,1,21.6,26319,-296,-296,100,68,9,2635,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3767,3769,3765,3751,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,950,SUCCESS,,2640.483345,192,0,0.1,0.2,0.3,263,1.4,1.5
    3833,5/26/2021 23:28,15361.7,4.27,701,300,10,6001,0,65535,65535,1,21.6,26320,-296,-296,100,68,9,2635,3888,531,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3767,3769,3765,3751,3755,3750,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,982,SUCCESS,,2640.154045,192,0,0.1,0.2,0.3,263,1.4,1.5
    3834,5/26/2021 23:28,15365.711,4.27,701,300,10,6001,0,65535,65535,1,21.6,26318,-298,-297,100,68,9,2634,3888,534,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3767,3769,3765,3751,3755,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,954,SUCCESS,,2639.822024,192,0,0.1,0.2,0.3,263,1.4,1.5
    3835,5/26/2021 23:28,15369.714,4.27,701,300,10,6001,0,65535,65535,1,21.6,26317,-298,-296,100,68,9,2634,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3767,3769,3765,3751,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.8,960,SUCCESS,,2639.490664,192,0,0.1,0.2,0.3,263,1.4,1.5
    3836,5/26/2021 23:29,15373.719,4.27,701,300,10,6001,0,65535,65535,1,21.6,26318,-298,-296,100,68,9,2634,3888,530,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3763,3767,3769,3765,3751,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,956,SUCCESS,,2639.159139,192,0,0.1,0.2,0.3,263,1.4,1.5
    3837,5/26/2021 23:29,15377.723,4.27,701,300,10,6001,0,65535,65535,1,21.6,26317,-296,-296,100,68,9,2633,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3767,3769,3765,3750,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2638.829921,192,0,0.1,0.2,0.3,263,1.4,1.5
    3838,5/26/2021 23:29,15381.728,4.27,701,300,10,6001,0,65535,65535,1,21.6,26314,-296,-296,100,68,9,2633,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3767,3768,3764,3750,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,977,SUCCESS,,2638.500621,192,0,0.1,0.2,0.3,263,1.4,1.5
    3839,5/26/2021 23:29,15385.736,4.27,701,300,10,6001,0,65535,65535,1,21.6,26315,-298,-297,100,68,9,2633,3888,530,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3767,3768,3765,3750,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.1,970,SUCCESS,,2638.168848,192,0,0.1,0.2,0.3,263,1.4,1.5
    3840,5/26/2021 23:29,15389.739,4.27,701,300,10,6001,0,65535,65535,1,21.6,26314,-296,-296,100,68,9,2632,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3767,3768,3764,3750,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,983,SUCCESS,,2637.839713,192,0,0.1,0.2,0.3,263,1.4,1.5
    3841,5/26/2021 23:29,15393.747,4.28,701,300,10,6001,0,65535,65535,1,21.6,26313,-296,-296,100,68,9,2632,3888,534,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3767,3768,3764,3750,3754,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2637.510166,192,0,0.1,0.2,0.3,263,1.4,1.5
    3842,5/26/2021 23:29,15397.757,4.28,701,300,10,6001,0,65535,65535,1,21.6,26313,-294,-296,100,68,9,2632,3888,537,534,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3766,3768,3764,3750,3753,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,1004,SUCCESS,,2637.182683,192,0,0.1,0.2,0.3,263,1.4,1.5
    3843,5/26/2021 23:29,15401.768,4.28,701,300,10,6001,0,65535,65535,1,21.6,26312,-296,-296,100,68,9,2631,3888,533,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3768,3764,3750,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,938,SUCCESS,,2636.852889,192,0,0.1,0.2,0.3,263,1.4,1.5
    3844,5/26/2021 23:29,15405.769,4.28,701,300,10,6001,0,65535,65535,1,21.6,26313,-296,-296,100,68,9,2631,3888,533,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3762,3766,3768,3764,3750,3753,3749,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,952,SUCCESS,,2636.523918,192,0,0.1,0.2,0.3,263,1.4,1.5
    3845,5/26/2021 23:29,15409.781,4.28,701,300,10,6001,0,65535,65535,1,21.6,26310,-296,-296,100,68,9,2631,3888,533,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3764,3750,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,939,SUCCESS,,2636.194043,192,0,0.1,0.2,0.3,263,1.4,1.5
    3846,5/26/2021 23:29,15413.788,4.28,701,300,10,6001,0,65535,65535,1,21.6,26310,-296,-296,100,68,9,2630,3888,533,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3764,3750,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,979,SUCCESS,,2635.864578,192,0,0.1,0.2,0.3,263,1.4,1.5
    3847,5/26/2021 23:29,15417.79,4.28,701,300,10,6001,0,65535,65535,1,21.6,26307,-300,-297,100,68,9,2630,3888,526,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3764,3749,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,995,SUCCESS,,2635.531078,192,0,0.1,0.2,0.3,263,1.4,1.5
    3848,5/26/2021 23:29,15421.793,4.28,701,300,10,6001,0,65535,65535,1,21.6,26307,-296,-297,100,68,9,2630,3888,530,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3763,3749,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,956,SUCCESS,,2635.201943,192,0,0.1,0.2,0.3,263,1.4,1.5
    3849,5/26/2021 23:29,15425.804,4.28,701,300,10,6001,0,65535,65535,1,21.6,26309,-296,-297,100,68,9,2629,3888,533,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3763,3749,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,980,SUCCESS,,2634.872149,192,0,0.1,0.2,0.3,263,1.4,1.5
    3850,5/26/2021 23:29,15429.814,4.29,701,300,10,6001,0,65535,65535,1,21.6,26305,-296,-297,100,68,9,2629,3888,533,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3763,3749,3753,3748,0,0,0,0,0,0,0,0,2631,21.5,21.6,-273.2,21.6,-273.2,21.7,954,SUCCESS,,2634.542438,192,0,0.1,0.2,0.3,263,1.4,1.5
    3851,5/26/2021 23:30,15433.821,4.29,701,300,10,6001,0,65535,65535,1,21.6,26305,-296,-296,100,68,9,2629,3888,537,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3763,3749,3753,3748,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,949,SUCCESS,,2634.212974,192,0,0.1,0.2,0.3,263,1.4,1.5
    3852,5/26/2021 23:30,15437.832,4.29,701,300,10,6001,0,65535,65535,1,21.6,26308,-296,-297,100,68,9,2628,3888,529,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3763,3749,3753,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,967,SUCCESS,,2633.88318,192,0,0.1,0.2,0.3,263,1.4,1.5
    3853,5/26/2021 23:30,15441.838,4.29,701,300,10,6001,0,65535,65535,1,21.6,26305,-296,-297,100,68,9,2628,3888,533,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3766,3767,3763,3749,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,979,SUCCESS,,2633.553798,192,0,0.1,0.2,0.3,263,1.4,1.5
    3854,5/26/2021 23:30,15445.84,4.29,701,300,10,6001,0,65535,65535,1,21.6,26305,-296,-296,100,68,9,2628,3888,533,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3761,3765,3767,3763,3749,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,945,SUCCESS,,2633.224745,192,0,0.1,0.2,0.3,263,1.4,1.5
    3855,5/26/2021 23:30,15449.854,4.29,701,300,10,6001,0,65535,65535,1,21.6,26304,-298,-296,100,68,9,2627,3888,529,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3766,3763,3749,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,969,SUCCESS,,2632.892475,192,0,0.1,0.2,0.3,263,1.4,1.5
    3856,5/26/2021 23:30,15453.862,4.29,701,300,10,6001,0,65535,65535,1,21.6,26301,-296,-296,100,68,9,2627,3888,533,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3767,3763,3749,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,953,SUCCESS,,2632.562928,192,0,0.1,0.2,0.3,263,1.4,1.5
    3857,5/26/2021 23:30,15457.877,4.29,701,300,10,6001,0,65535,65535,1,21.6,26300,-298,-296,100,68,9,2627,3888,529,533,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3766,3762,3749,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2632.230575,192,0,0.1,0.2,0.3,263,1.4,1.5
    3858,5/26/2021 23:30,15461.888,4.29,701,300,10,6001,0,65535,65535,1,21.6,26300,-296,-296,100,68,9,2626,3888,529,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3766,3762,3748,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.3,946,SUCCESS,,2631.900782,192,0,0.1,0.2,0.3,263,1.4,1.5
    3859,5/26/2021 23:30,15465.89,4.3,701,300,10,6001,0,65535,65535,1,21.6,26300,-294,-296,100,68,9,2626,3888,532,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3766,3762,3748,3752,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,978,SUCCESS,,2631.573952,192,0,0.1,0.2,0.3,263,1.4,1.5
    3860,5/26/2021 23:30,15469.897,4.3,701,300,10,6001,0,65535,65535,1,21.6,26299,-296,-296,100,68,9,2626,3888,532,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3766,3762,3748,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,956,SUCCESS,,2631.244488,192,0,0.1,0.2,0.3,263,1.4,1.5
    3861,5/26/2021 23:30,15473.907,4.3,701,300,10,6001,0,65535,65535,1,21.6,26297,-296,-296,100,68,9,2625,3888,529,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3760,3765,3766,3762,3748,3752,3747,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,972,SUCCESS,,2630.914776,192,0,0.1,0.2,0.3,263,1.4,1.5
    3862,5/26/2021 23:30,15477.917,4.3,701,300,10,6001,0,65535,65535,1,21.6,26296,-296,-296,100,68,9,2625,3888,532,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3766,3762,3748,3752,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,976,SUCCESS,,2630.585065,192,0,0.1,0.2,0.3,263,1.4,1.5
    3863,5/26/2021 23:30,15481.923,4.3,701,300,10,6001,0,65535,65535,1,21.6,26297,-300,-296,100,68,9,2625,3888,529,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3766,3762,3748,3751,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,972,SUCCESS,,2630.251232,192,0,0.1,0.2,0.3,263,1.4,1.5
    3864,5/26/2021 23:30,15485.938,4.3,701,300,10,6001,0,65535,65535,1,21.6,26295,-296,-297,100,68,9,2624,3888,528,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3766,3762,3748,3753,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,947,SUCCESS,,2629.92111,192,0,0.1,0.2,0.3,263,1.4,1.5
    3865,5/26/2021 23:30,15489.951,4.3,701,300,10,6001,0,65535,65535,1,21.6,26294,-298,-297,100,68,9,2624,3888,532,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3766,3761,3747,3751,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,941,SUCCESS,,2629.588923,192,0,0.1,0.2,0.3,263,1.4,1.5
    3866,5/26/2021 23:31,15493.962,4.3,701,300,10,6001,0,65535,65535,1,21.6,26293,-298,-297,100,68,9,2624,3888,528,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3766,3761,3747,3750,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,932,SUCCESS,,2629.256901,192,0,0.1,0.2,0.3,263,1.4,1.5
    3867,5/26/2021 23:31,15497.97,4.3,701,300,10,6001,0,65535,65535,1,21.6,26293,-294,-297,100,68,9,2623,3888,532,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3765,3761,3747,3754,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,943,SUCCESS,,2628.929581,192,0,0.1,0.2,0.3,263,1.4,1.5
    3868,5/26/2021 23:31,15501.978,4.31,701,300,10,6001,0,65535,65535,1,21.6,26293,-296,-297,100,68,9,2623,3888,528,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3765,3761,3747,3751,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,945,SUCCESS,,2628.600034,192,0,0.1,0.2,0.3,263,1.4,1.5
    3869,5/26/2021 23:31,15505.994,4.31,701,300,10,6001,0,65535,65535,1,21.6,26293,-296,-296,100,68,9,2623,3888,535,532,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3764,3765,3761,3747,3751,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,945,SUCCESS,,2628.26983,192,0,0.1,0.2,0.3,263,1.4,1.5
    3870,5/26/2021 23:31,15510.001,4.31,701,300,10,6001,0,65535,65535,1,21.6,26292,-296,-296,100,68,9,2622,3888,531,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3763,3765,3761,3747,3751,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,939,SUCCESS,,2627.940365,192,0,0.1,0.2,0.3,263,1.4,1.5
    3871,5/26/2021 23:31,15514.006,4.31,701,300,10,6001,0,65535,65535,1,21.6,26292,-300,-296,100,68,9,2622,3888,524,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3759,3763,3765,3761,3747,3750,3746,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,995,SUCCESS,,2627.606615,192,0,0.1,0.2,0.3,263,1.4,1.5
    3872,5/26/2021 23:31,15518.017,4.31,701,300,10,6001,0,65535,65535,1,21.6,26290,-296,-296,100,68,9,2622,3888,531,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3765,3761,3746,3750,3746,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,953,SUCCESS,,2627.276822,192,0,0.1,0.2,0.3,263,1.4,1.5
    3873,5/26/2021 23:31,15522.022,4.31,701,300,10,6001,0,65535,65535,1,21.6,26288,-294,-296,100,68,8,2621,3888,535,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3747,3753,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.7,999,SUCCESS,,2626.949747,192,0,0.1,0.2,0.3,263,1.4,1.5
    3874,5/26/2021 23:31,15526.025,4.31,701,300,10,6001,0,65535,65535,1,21.6,26288,-296,-296,100,68,8,2621,3888,531,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3747,3750,3745,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2626.620611,192,0,0.1,0.2,0.3,263,1.4,1.5
    3875,5/26/2021 23:31,15530.026,4.31,701,300,10,6001,0,65535,65535,1,21.6,26286,-294,-296,100,68,8,2621,3888,535,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3746,3750,3746,0,0,0,0,0,0,0,0,2626,21.5,21.6,-273.2,21.6,-273.2,21.6,992,SUCCESS,,2626.293863,192,0,0.1,0.2,0.3,263,1.4,1.5
    3876,5/26/2021 23:31,15534.032,4.32,701,300,10,6001,0,65535,65535,1,21.6,26286,-298,-296,100,68,8,2620,3888,528,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3746,3750,3745,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,941,SUCCESS,,2625.962255,192,0,0.1,0.2,0.3,263,1.4,1.5
    3877,5/26/2021 23:31,15538.034,4.32,701,300,10,6001,0,65535,65535,1,21.6,26286,-296,-296,100,68,8,2620,3888,531,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3746,3750,3745,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,971,SUCCESS,,2625.633202,192,0,0.1,0.2,0.3,263,1.4,1.5
    3878,5/26/2021 23:31,15542.047,4.32,701,300,10,6001,0,65535,65535,1,21.6,26286,-296,-296,100,68,8,2620,3888,531,531,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3746,3750,3745,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,963,SUCCESS,,2625.303244,192,0,0.1,0.2,0.3,263,1.4,1.5
    3879,5/26/2021 23:31,15546.048,4.32,701,300,10,6001,0,65535,65535,1,21.6,26285,-298,-297,100,68,8,2619,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3746,3750,3745,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,945,SUCCESS,,2624.97205,192,0,0.1,0.2,0.3,263,1.4,1.5
    3880,5/26/2021 23:31,15550.055,4.32,701,300,10,6001,0,65535,65535,1,21.6,26285,-298,-297,100,68,8,2619,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3763,3764,3760,3746,3750,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,934,SUCCESS,,2624.64036,192,0,0.1,0.2,0.3,263,1.4,1.5
    3881,5/26/2021 23:32,15554.058,4.32,701,300,10,6001,0,65535,65535,1,21.6,26282,-298,-297,100,68,8,2619,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3762,3764,3759,3746,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,1027,SUCCESS,,2624.309,192,0,0.1,0.2,0.3,263,1.4,1.5
    3882,5/26/2021 23:32,15558.065,4.32,701,300,10,6001,0,65535,65535,1,21.6,26282,-298,-297,100,68,8,2618,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3762,3764,3759,3746,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.4,958,SUCCESS,,2623.97731,192,0,0.1,0.2,0.3,263,1.4,1.5
    3883,5/26/2021 23:32,15562.071,4.32,701,300,10,6001,0,65535,65535,1,21.6,26282,-296,-297,100,68,8,2618,3888,531,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3758,3762,3763,3759,3746,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,983,SUCCESS,,2623.647928,192,0,0.1,0.2,0.3,263,1.4,1.5
    3884,5/26/2021 23:32,15566.08,4.32,701,300,10,6001,0,65535,65535,1,21.6,26281,-298,-297,100,68,8,2618,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3764,3759,3746,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,936,SUCCESS,,2623.316071,192,0,0.1,0.2,0.3,263,1.4,1.5
    3885,5/26/2021 23:32,15570.082,4.33,701,300,10,6001,0,65535,65535,1,21.6,26280,-296,-297,100,68,8,2617,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3763,3759,3745,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2622.987018,192,0,0.1,0.2,0.3,263,1.4,1.5
    3886,5/26/2021 23:32,15574.09,4.33,701,300,10,6001,0,65535,65535,1,21.6,26280,-298,-297,100,68,8,2617,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3763,3759,3746,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,959,SUCCESS,,2622.655245,192,0,0.1,0.2,0.3,263,1.4,1.5
    3887,5/26/2021 23:32,15578.092,4.33,701,300,10,6001,0,65535,65535,1,21.6,26279,-298,-297,100,68,8,2617,3888,527,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3763,3759,3745,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2622.323968,192,0,0.1,0.2,0.3,263,1.4,1.5
    3888,5/26/2021 23:32,15582.094,4.33,701,300,10,6001,0,65535,65535,1,21.6,26279,-294,-297,100,68,8,2616,3888,527,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3763,3759,3745,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2621.997138,192,0,0.1,0.2,0.3,263,1.4,1.5
    3889,5/26/2021 23:32,15586.103,4.33,701,300,10,6001,0,65535,65535,1,21.6,26278,-296,-297,100,68,8,2616,3888,527,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3762,3763,3759,3745,3749,3744,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,946,SUCCESS,,2621.667509,192,0,0.1,0.2,0.3,263,1.4,1.5
    3890,5/26/2021 23:32,15590.113,4.33,701,300,10,6001,0,65535,65535,1,21.6,26277,-298,-297,100,68,8,2616,3888,527,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3763,3759,3745,3748,3743,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,952,SUCCESS,,2621.33557,192,0,0.1,0.2,0.3,263,1.4,1.5
    3891,5/26/2021 23:32,15594.12,4.33,701,300,10,6001,0,65535,65535,1,21.6,26277,-298,-297,100,68,8,2615,3888,530,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3757,3762,3763,3759,3745,3748,3743,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,960,SUCCESS,,2621.00388,192,0,0.1,0.2,0.3,263,1.4,1.5
    3892,5/26/2021 23:32,15598.134,4.33,701,300,10,6001,0,65535,65535,1,21.6,26274,-296,-297,100,68,8,2615,3888,527,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3762,3763,3759,3745,3749,3743,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,947,SUCCESS,,2620.67384,192,0,0.1,0.2,0.3,263,1.4,1.5
    3893,5/26/2021 23:32,15602.148,4.33,701,300,10,6001,0,65535,65535,1,21.6,26276,-298,-297,100,68,8,2615,3888,530,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3763,3759,3745,3748,3743,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,980,SUCCESS,,2620.34157,192,0,0.1,0.2,0.3,263,1.4,1.5
    3894,5/26/2021 23:32,15606.155,4.34,701,300,10,6001,0,65535,65535,1,21.6,26274,-296,-296,100,68,8,2614,3888,530,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3763,3758,3744,3748,3743,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2620.012105,192,0,0.1,0.2,0.3,263,1.4,1.5
    3895,5/26/2021 23:32,15610.158,4.34,701,300,10,6001,0,65535,65535,1,21.6,26272,-298,-297,100,68,8,2614,3888,526,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3763,3758,3744,3748,3743,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,971,SUCCESS,,2619.680746,192,0,0.1,0.2,0.3,263,1.4,1.5
    3896,5/26/2021 23:33,15614.163,4.34,701,300,10,6001,0,65535,65535,1,21.6,26273,-296,-297,100,68,8,2614,3888,530,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3763,3758,3744,3748,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,948,SUCCESS,,2619.351446,192,0,0.1,0.2,0.3,263,1.4,1.5
    3897,5/26/2021 23:33,15618.165,4.34,701,300,10,6001,0,65535,65535,1,21.6,26272,-296,-296,100,68,8,2613,3888,530,530,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3762,3758,3744,3748,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,978,SUCCESS,,2619.022393,192,0,0.1,0.2,0.3,263,1.4,1.5
    3898,5/26/2021 23:33,15622.171,4.34,701,300,10,6001,0,65535,65535,1,21.6,26271,-298,-297,100,68,8,2613,3888,526,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3762,3758,3744,3748,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,963,SUCCESS,,2618.690785,192,0,0.1,0.2,0.3,263,1.4,1.5
    3899,5/26/2021 23:33,15626.18,4.34,701,300,10,6001,0,65535,65535,1,21.6,26271,-294,-297,100,68,8,2613,3888,530,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3762,3758,3744,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,964,SUCCESS,,2618.363383,192,0,0.1,0.2,0.3,263,1.4,1.5
    3900,5/26/2021 23:33,15630.184,4.34,701,300,10,6001,0,65535,65535,1,21.6,26270,-298,-296,100,68,8,2612,3888,526,529,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3761,3762,3758,3744,3748,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2618.031941,192,0,0.1,0.2,0.3,263,1.4,1.5
    3901,5/26/2021 23:33,15634.189,4.34,701,300,10,6001,0,65535,65535,1,21.6,26267,-298,-297,100,68,8,2612,3888,526,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3756,3760,3761,3758,3744,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,942,SUCCESS,,2617.700416,192,0,0.1,0.2,0.3,263,1.4,1.5
    3902,5/26/2021 23:33,15638.202,4.34,701,300,10,6001,0,65535,65535,1,21.6,26268,-296,-297,100,68,8,2612,3888,529,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3758,3744,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,940,SUCCESS,,2617.370458,192,0,0.1,0.2,0.3,263,1.4,1.5
    3903,5/26/2021 23:33,15642.21,4.35,701,300,10,6001,0,65535,65535,1,21.6,26268,-298,-297,100,68,8,2611,3888,526,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3757,3743,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,965,SUCCESS,,2617.038685,192,0,0.1,0.2,0.3,263,1.4,1.5
    3904,5/26/2021 23:33,15646.215,4.35,701,300,10,6001,0,65535,65535,1,21.6,26266,-296,-297,100,68,8,2611,3888,526,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3757,3744,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,959,SUCCESS,,2616.709385,192,0,0.1,0.2,0.3,263,1.4,1.5
    3905,5/26/2021 23:33,15650.231,4.35,701,300,10,6001,0,65535,65535,1,21.6,26265,-296,-297,100,68,8,2611,3888,529,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3757,3743,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2616.37918,192,0,0.1,0.2,0.3,263,1.4,1.5
    3906,5/26/2021 23:33,15654.235,4.35,701,300,10,6001,0,65535,65535,1,21.6,26265,-300,-297,100,68,8,2610,3888,526,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3757,3743,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,939,SUCCESS,,2616.045514,192,0,0.1,0.2,0.3,263,1.4,1.5
    3907,5/26/2021 23:33,15658.243,4.35,701,300,10,6001,0,65535,65535,1,21.6,26264,-296,-297,100,68,8,2610,3888,529,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3757,3743,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,964,SUCCESS,,2615.715967,192,0,0.1,0.2,0.3,263,1.4,1.5
    3908,5/26/2021 23:33,15662.249,4.35,701,300,10,6001,0,65535,65535,1,21.6,26265,-296,-297,100,68,8,2610,3888,529,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3759,3761,3757,3743,3747,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.6,957,SUCCESS,,2615.386585,192,0,0.1,0.2,0.3,263,1.4,1.5
    3909,5/26/2021 23:33,15666.257,4.35,701,300,10,6001,0,65535,65535,1,21.6,26263,-300,-297,100,68,8,2609,3888,525,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3760,3761,3757,3743,3747,3741,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,1003,SUCCESS,,2615.052585,192,0,0.1,0.2,0.3,263,1.4,1.5
    3910,5/26/2021 23:33,15670.267,4.35,701,300,10,6001,0,65535,65535,1,21.6,26262,-296,-297,100,68,8,2609,3888,529,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3759,3761,3757,3743,3746,3741,0,0,0,0,0,0,0,0,2623,21.4,21.6,-273.2,21.6,-273.2,21.7,937,SUCCESS,,2614.722874,192,0,0.1,0.2,0.3,263,1.4,1.5
    3911,5/26/2021 23:34,15674.268,4.35,701,300,10,6001,0,65535,65535,1,21.6,26260,-296,-297,100,68,8,2609,3888,525,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3759,3761,3757,3743,3746,3742,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,940,SUCCESS,,2614.393903,192,0,0.1,0.2,0.3,263,1.4,1.5
    3912,5/26/2021 23:34,15678.282,4.36,701,300,10,6001,0,65535,65535,1,21.6,26260,-296,-297,100,68,8,2608,3888,529,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3755,3759,3761,3757,3742,3746,3741,0,0,0,0,0,0,0,0,2625,21.4,21.6,-273.2,21.6,-273.2,21.6,1009,SUCCESS,,2614.063863,192,0,0.1,0.2,0.3,263,1.4,1.5
    3913,5/26/2021 23:34,15682.289,4.36,701,300,10,6001,0,65535,65535,1,21.6,26259,-296,-297,100,68,8,2608,3888,529,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3761,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,952,SUCCESS,,2613.734398,192,0,0.1,0.2,0.3,263,1.4,1.5
    3914,5/26/2021 23:34,15686.297,4.36,701,300,10,6001,0,65535,65535,1,21.6,26259,-298,-297,100,68,8,2608,3888,525,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3760,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2626,21.4,21.6,-273.2,21.6,-273.2,21.7,964,SUCCESS,,2613.402625,192,0,0.1,0.2,0.3,263,1.4,1.5
    3915,5/26/2021 23:34,15690.305,4.36,701,300,10,6001,0,65535,65535,1,21.6,26258,-298,-297,100,68,8,2607,3888,525,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3760,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.1,966,SUCCESS,,2613.070851,192,0,0.1,0.2,0.3,263,1.4,1.5
    3916,5/26/2021 23:34,15694.318,4.36,701,300,10,6001,0,65535,65535,1,21.6,26258,-296,-296,100,68,8,2607,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3760,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,933,SUCCESS,,2612.740894,192,0,0.1,0.2,0.3,263,1.4,1.5
    3917,5/26/2021 23:34,15698.326,4.36,701,300,10,6001,0,65535,65535,1,21.6,26258,-296,-297,100,68,8,2607,3888,528,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3760,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,965,SUCCESS,,2612.411347,192,0,0.1,0.2,0.3,263,1.4,1.5
    3918,5/26/2021 23:34,15702.339,4.36,701,300,10,6001,0,65535,65535,1,21.6,26258,-296,-297,100,68,8,2606,3888,528,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3760,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,967,SUCCESS,,2612.081389,192,0,0.1,0.2,0.3,263,1.4,1.5
    3919,5/26/2021 23:34,15706.351,4.36,701,300,10,6001,0,65535,65535,1,21.6,26258,-296,-297,100,68,8,2606,3888,528,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3754,3759,3760,3756,3742,3746,3741,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,971,SUCCESS,,2611.751514,192,0,0.1,0.2,0.3,263,1.4,1.5
    3920,5/26/2021 23:34,15710.352,4.36,701,300,10,6001,0,65535,65535,1,21.6,26256,-296,-297,100,68,8,2606,3888,528,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3759,3760,3756,3742,3745,3741,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,947,SUCCESS,,2611.422543,192,0,0.1,0.2,0.3,263,1.4,1.5
    3921,5/26/2021 23:34,15714.366,4.37,701,300,10,6001,0,65535,65535,1,21.6,26257,-293,-296,100,68,8,2605,3888,533,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3760,3756,3741,3745,3740,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,948,SUCCESS,,2611.095848,192,0,0.1,0.2,0.3,263,1.4,1.5
    3922,5/26/2021 23:34,15718.368,4.37,701,300,10,6001,0,65535,65535,1,21.6,26252,-296,-296,100,68,8,2605,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3745,3740,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,976,SUCCESS,,2610.766794,192,0,0.1,0.2,0.3,263,1.4,1.5
    3923,5/26/2021 23:34,15722.375,4.37,701,300,10,6001,0,65535,65535,1,21.6,26250,-298,-296,100,68,8,2605,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3744,3740,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,957,SUCCESS,,2610.435104,192,0,0.1,0.2,0.3,263,1.4,1.5
    3924,5/26/2021 23:34,15726.385,4.37,701,300,10,6001,0,65535,65535,1,21.6,26254,-296,-296,100,67,8,2604,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3745,3740,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,996,SUCCESS,,2610.105393,192,0,0.1,0.2,0.3,263,1.4,1.5
    3925,5/26/2021 23:34,15730.387,4.37,701,300,10,6001,0,65535,65535,1,21.6,26250,-298,-296,100,67,8,2604,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3745,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,947,SUCCESS,,2609.774116,192,0,0.1,0.2,0.3,263,1.4,1.5
    3926,5/26/2021 23:35,15734.396,4.37,701,300,10,6001,0,65535,65535,1,21.6,26252,-296,-296,100,67,8,2604,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2609.444487,192,0,0.1,0.2,0.3,263,1.4,1.5
    3927,5/26/2021 23:35,15738.402,4.37,701,300,10,6001,0,65535,65535,1,21.6,26253,-298,-296,100,67,8,2603,3888,524,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3745,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,952,SUCCESS,,2609.112879,192,0,0.1,0.2,0.3,263,1.4,1.5
    3928,5/26/2021 23:35,15742.414,4.37,701,300,10,6001,0,65535,65535,1,21.6,26249,-296,-296,100,67,8,2603,3888,528,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,932,SUCCESS,,2608.783004,192,0,0.1,0.2,0.3,263,1.4,1.5
    3929,5/26/2021 23:35,15746.416,4.37,701,300,10,6001,0,65535,65535,1,21.6,26249,-296,-296,100,67,8,2603,3888,531,528,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,968,SUCCESS,,2608.45395,192,0,0.1,0.2,0.3,263,1.4,1.5
    3930,5/26/2021 23:35,15750.423,4.38,701,300,10,6001,0,65535,65535,1,21.6,26249,-298,-296,100,67,8,2602,3888,524,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3753,3758,3759,3755,3741,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,988,SUCCESS,,2608.12226,192,0,0.1,0.2,0.3,263,1.4,1.5
    3931,5/26/2021 23:35,15754.43,4.38,701,300,10,6001,0,65535,65535,1,21.6,26247,-296,-296,100,67,8,2602,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3759,3755,3740,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,966,SUCCESS,,2607.792795,192,0,0.1,0.2,0.3,263,1.4,1.5
    3932,5/26/2021 23:35,15758.44,4.38,701,300,10,6001,0,65535,65535,1,21.6,26245,-296,-296,100,67,8,2602,3888,531,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3759,3755,3741,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,957,SUCCESS,,2607.463084,192,0,0.1,0.2,0.3,263,1.4,1.5
    3933,5/26/2021 23:35,15762.451,4.38,701,300,10,6001,0,65535,65535,1,21.6,26244,-296,-297,100,67,8,2601,3888,524,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3759,3754,3740,3745,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,957,SUCCESS,,2607.133291,192,0,0.1,0.2,0.3,263,1.4,1.5
    3934,5/26/2021 23:35,15766.462,4.38,701,300,10,6001,0,65535,65535,1,21.6,26244,-294,-296,100,67,8,2601,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3758,3755,3740,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.4,945,SUCCESS,,2606.805726,192,0,0.1,0.2,0.3,263,1.4,1.5
    3935,5/26/2021 23:35,15770.466,4.38,701,300,10,6001,0,65535,65535,1,21.6,26244,-296,-296,100,67,8,2601,3888,524,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3758,3755,3740,3744,3739,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,968,SUCCESS,,2606.476508,192,0,0.1,0.2,0.3,263,1.4,1.5
    3936,5/26/2021 23:35,15774.474,4.38,701,300,10,6001,0,65535,65535,1,21.6,26243,-296,-296,100,67,8,2600,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3758,3754,3740,3744,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2606.146961,192,0,0.1,0.2,0.3,263,1.4,1.5
    3937,5/26/2021 23:35,15778.48,4.38,701,300,10,6001,0,65535,65535,1,21.6,26243,-296,-296,100,67,8,2600,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3758,3754,3740,3743,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,960,SUCCESS,,2605.817579,192,0,0.1,0.2,0.3,263,1.4,1.5
    3938,5/26/2021 23:35,15782.487,4.38,701,300,10,6001,0,65535,65535,1,21.6,26242,-296,-296,100,67,8,2600,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3758,3754,3740,3743,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,938,SUCCESS,,2605.488115,192,0,0.1,0.2,0.3,263,1.4,1.5
    3939,5/26/2021 23:35,15786.487,4.39,701,300,10,6001,0,65535,65535,1,21.6,26241,-296,-296,100,67,8,2599,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3757,3758,3754,3739,3744,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,959,SUCCESS,,2605.159226,192,0,0.1,0.2,0.3,263,1.4,1.5
    3940,5/26/2021 23:35,15790.502,4.39,701,300,10,6001,0,65535,65535,1,21.6,26238,-294,-296,100,67,8,2599,3888,530,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3756,3758,3753,3740,3743,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,954,SUCCESS,,2604.831334,192,0,0.1,0.2,0.3,263,1.4,1.5
    3941,5/26/2021 23:36,15794.505,4.39,701,300,10,6001,0,65535,65535,1,21.6,26240,-296,-296,100,67,8,2599,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3752,3756,3758,3754,3739,3741,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,985,SUCCESS,,2604.502199,192,0,0.1,0.2,0.3,263,1.4,1.5
    3942,5/26/2021 23:36,15798.517,4.39,701,300,10,6001,0,65535,65535,1,21.6,26239,-296,-296,100,67,8,2598,3888,527,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3758,3753,3739,3743,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,959,SUCCESS,,2604.172323,192,0,0.1,0.2,0.3,263,1.4,1.5
    3943,5/26/2021 23:36,15802.522,4.39,701,300,10,6001,0,65535,65535,1,21.6,26238,-298,-296,100,67,8,2598,3888,523,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3758,3753,3739,3743,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,968,SUCCESS,,2603.840798,192,0,0.1,0.2,0.3,263,1.4,1.5
    3944,5/26/2021 23:36,15806.524,4.39,701,300,10,6001,0,65535,65535,1,21.6,26238,-296,-296,100,67,8,2598,3888,523,527,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3739,3741,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,984,SUCCESS,,2603.511745,192,0,0.1,0.2,0.3,263,1.4,1.5
    3945,5/26/2021 23:36,15810.526,4.39,701,300,10,6001,0,65535,65535,1,21.6,26237,-296,-296,100,67,8,2597,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3739,3742,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,949,SUCCESS,,2603.182691,192,0,0.1,0.2,0.3,263,1.4,1.5
    3946,5/26/2021 23:36,15814.537,4.39,701,300,10,6001,0,65535,65535,1,21.6,26236,-296,-296,100,67,8,2597,3888,523,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3739,3742,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,949,SUCCESS,,2602.852898,192,0,0.1,0.2,0.3,263,1.4,1.5
    3947,5/26/2021 23:36,15818.547,4.39,701,300,10,6001,0,65535,65535,1,21.6,26236,-296,-297,100,67,8,2597,3888,523,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3739,3740,3738,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,957,SUCCESS,,2602.523187,192,0,0.1,0.2,0.3,263,1.4,1.5
    3948,5/26/2021 23:36,15822.552,4.4,701,300,10,6001,0,65535,65535,1,21.6,26236,-296,-296,100,67,8,2597,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3738,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,934,SUCCESS,,2602.193887,192,0,0.1,0.2,0.3,263,1.4,1.5
    3949,5/26/2021 23:36,15826.553,4.4,701,300,10,6001,0,65535,65535,1,21.6,26235,-298,-296,100,67,8,2596,3888,523,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3739,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,981,SUCCESS,,2601.862693,192,0,0.1,0.2,0.3,263,1.4,1.5
    3950,5/26/2021 23:36,15830.565,4.4,701,300,10,6001,0,65535,65535,1,21.6,26233,-296,-297,100,67,8,2596,3888,526,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3751,3756,3757,3753,3738,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,954,SUCCESS,,2601.532818,192,0,0.1,0.2,0.3,263,1.4,1.5
    3951,5/26/2021 23:36,15834.571,4.4,701,300,10,6001,0,65535,65535,1,21.6,26232,-298,-296,100,67,8,2595,3888,522,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3756,3757,3752,3738,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,961,SUCCESS,,2601.20121,192,0,0.1,0.2,0.3,263,1.4,1.5
    3952,5/26/2021 23:36,15838.583,4.4,701,300,10,6001,0,65535,65535,1,21.6,26230,-296,-296,100,67,8,2595,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,988,SUCCESS,,2600.871334,192,0,0.1,0.2,0.3,263,1.4,1.5
    3953,5/26/2021 23:36,15842.59,4.4,701,300,10,6001,0,65535,65535,1,21.6,26230,-296,-296,100,67,8,2595,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.2,960,SUCCESS,,2600.54187,192,0,0.1,0.2,0.3,263,1.4,1.5
    3954,5/26/2021 23:36,15846.593,4.4,701,300,10,6001,0,65535,65535,1,21.6,26230,-296,-296,100,67,8,2594,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,958,SUCCESS,,2600.212734,192,0,0.1,0.2,0.3,263,1.4,1.5
    3955,5/26/2021 23:36,15850.597,4.4,701,300,10,6001,0,65535,65535,1,21.6,26228,-294,-296,100,67,8,2594,3888,529,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3742,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,936,SUCCESS,,2599.885741,192,0,0.1,0.2,0.3,263,1.4,1.5
    3956,5/26/2021 23:37,15854.612,4.4,701,300,10,6001,0,65535,65535,1,21.6,26229,-296,-296,100,67,8,2594,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,970,SUCCESS,,2599.555619,192,0,0.1,0.2,0.3,263,1.4,1.5
    3957,5/26/2021 23:37,15858.617,4.41,701,300,10,6001,0,65535,65535,1,21.6,26229,-298,-296,100,67,8,2593,3888,522,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,949,SUCCESS,,2599.224094,192,0,0.1,0.2,0.3,263,1.4,1.5
    3958,5/26/2021 23:37,15862.625,4.41,701,300,10,6001,0,65535,65535,1,21.6,26228,-296,-296,100,67,8,2593,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3738,3741,3737,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2598.894547,192,0,0.1,0.2,0.3,263,1.4,1.5
    3959,5/26/2021 23:37,15866.641,4.41,701,300,10,6001,0,65535,65535,1,21.6,26228,-298,-296,100,67,8,2593,3888,526,526,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3755,3756,3752,3738,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,960,SUCCESS,,2598.562111,192,0,0.1,0.2,0.3,263,1.4,1.5
    3960,5/26/2021 23:37,15870.65,4.41,701,300,10,6001,0,65535,65535,1,21.6,26227,-296,-297,100,67,8,2592,3888,522,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3750,3755,3756,3752,3737,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,985,SUCCESS,,2598.232483,192,0,0.1,0.2,0.3,263,1.4,1.5
    3961,5/26/2021 23:37,15874.659,4.41,701,300,10,6001,0,65535,65535,1,21.6,26227,-294,-296,100,67,8,2592,3888,529,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3755,3752,3737,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,951,SUCCESS,,2597.905081,192,0,0.1,0.2,0.3,263,1.4,1.5
    3962,5/26/2021 23:37,15878.661,4.41,701,300,10,6001,0,65535,65535,1,21.6,26224,-296,-296,100,67,8,2592,3888,525,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3756,3751,3737,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,943,SUCCESS,,2597.576028,192,0,0.1,0.2,0.3,263,1.4,1.5
    3963,5/26/2021 23:37,15882.676,4.41,701,300,10,6001,0,65535,65535,1,21.6,26224,-296,-296,100,67,8,2591,3888,525,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3755,3751,3737,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,960,SUCCESS,,2597.245905,192,0,0.1,0.2,0.3,263,1.4,1.5
    3964,5/26/2021 23:37,15886.679,4.41,701,300,10,6001,0,65535,65535,1,21.6,26223,-298,-296,100,67,8,2591,3888,525,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3755,3751,3737,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,949,SUCCESS,,2596.914546,192,0,0.1,0.2,0.3,263,1.4,1.5
    3965,5/26/2021 23:37,15890.694,4.41,701,300,10,6001,0,65535,65535,1,21.6,26222,-298,-297,100,67,8,2591,3888,522,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3755,3751,3737,3740,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,949,SUCCESS,,2596.582193,192,0,0.1,0.2,0.3,263,1.4,1.5
    3966,5/26/2021 23:37,15894.7,4.42,701,300,10,6001,0,65535,65535,1,21.6,26221,-296,-297,100,67,8,2591,3888,522,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3755,3751,3737,3741,3736,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,943,SUCCESS,,2596.252811,192,0,0.1,0.2,0.3,263,1.4,1.5
    3967,5/26/2021 23:37,15898.71,4.42,701,300,10,6001,0,65535,65535,1,21.6,26222,-298,-297,100,67,8,2590,3888,525,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3754,3755,3751,3737,3741,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,965,SUCCESS,,2595.920872,192,0,0.1,0.2,0.3,263,1.4,1.5
    3968,5/26/2021 23:37,15902.714,4.42,701,300,10,6001,0,65535,65535,1,21.6,26221,-296,-297,100,67,8,2590,3888,521,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3753,3755,3750,3737,3740,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,944,SUCCESS,,2595.591654,192,0,0.1,0.2,0.3,263,1.4,1.5
    3969,5/26/2021 23:37,15906.719,4.42,701,300,10,6001,0,65535,65535,1,21.6,26218,-296,-297,100,67,8,2590,3888,525,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3749,3753,3755,3750,3736,3740,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2595.262354,192,0,0.1,0.2,0.3,263,1.4,1.5
    3970,5/26/2021 23:37,15910.724,4.42,701,300,10,6001,0,65535,65535,1,21.6,26217,-296,-297,100,67,8,2589,3888,525,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3755,3750,3736,3740,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,951,SUCCESS,,2594.933054,192,0,0.1,0.2,0.3,263,1.4,1.5
    3971,5/26/2021 23:38,15914.736,4.42,701,300,10,6001,0,65535,65535,1,21.6,26216,-296,-296,100,67,8,2589,3888,525,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3755,3750,3736,3740,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,939,SUCCESS,,2594.603179,192,0,0.1,0.2,0.3,263,1.4,1.5
    3972,5/26/2021 23:38,15918.751,4.42,701,300,10,6001,0,65535,65535,1,21.6,26218,-296,-296,100,67,8,2589,3888,528,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3755,3750,3736,3740,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.1,941,SUCCESS,,2594.273056,192,0,0.1,0.2,0.3,263,1.4,1.5
    3973,5/26/2021 23:38,15922.752,4.42,701,300,10,6001,0,65535,65535,1,21.6,26216,-298,-296,100,67,8,2588,3888,521,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3754,3750,3736,3740,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,940,SUCCESS,,2593.941863,192,0,0.1,0.2,0.3,263,1.4,1.5
    3974,5/26/2021 23:38,15926.767,4.42,701,300,10,6001,0,65535,65535,1,21.6,26216,-298,-296,100,67,8,2588,3888,525,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3754,3750,3736,3739,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2593.60951,192,0,0.1,0.2,0.3,263,1.4,1.5
    3975,5/26/2021 23:38,15930.777,4.43,701,300,10,6001,0,65535,65535,1,21.6,26215,-298,-296,100,67,8,2588,3888,521,525,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3754,3750,3736,3739,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.6,966,SUCCESS,,2593.277571,192,0,0.1,0.2,0.3,263,1.4,1.5
    3976,5/26/2021 23:38,15934.784,4.43,701,300,10,6001,0,65535,65535,1,21.6,26214,-296,-297,100,67,8,2587,3888,524,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3754,3750,3736,3739,3735,0,0,0,0,0,0,0,0,2622,21.4,21.6,-273.2,21.6,-273.2,21.7,973,SUCCESS,,2592.948106,192,0,0.1,0.2,0.3,263,1.4,1.5
    3977,5/26/2021 23:38,15938.785,4.43,701,300,10,6001,0,65535,65535,1,21.6,26214,-296,-297,100,67,8,2587,3888,521,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3748,3753,3754,3750,3736,3739,3734,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,977,SUCCESS,,2592.619135,192,0,0.1,0.2,0.3,263,1.4,1.5
    3978,5/26/2021 23:38,15942.795,4.43,701,300,10,6001,0,65535,65535,1,21.6,26213,-296,-296,100,67,8,2587,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3754,3750,3735,3739,3735,0,0,0,0,0,0,0,0,2618,21.4,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2592.289424,192,0,0.1,0.2,0.3,263,1.4,1.5
    3979,5/26/2021 23:38,15946.803,4.43,701,300,10,6001,0,65535,65535,1,21.6,26213,-296,-297,100,67,8,2586,3888,521,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3754,3750,3735,3739,3734,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,966,SUCCESS,,2591.959878,192,0,0.1,0.2,0.3,263,1.4,1.5
    3980,5/26/2021 23:38,15950.817,4.43,701,300,10,6001,0,65535,65535,1,21.6,26211,-298,-296,100,67,8,2586,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3754,3749,3735,3739,3734,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,949,SUCCESS,,2591.627608,192,0,0.1,0.2,0.3,263,1.4,1.5
    3981,5/26/2021 23:38,15954.822,4.43,701,300,10,6001,0,65535,65535,1,21.6,26210,-296,-297,100,67,8,2586,3888,521,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3739,3734,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,962,SUCCESS,,2591.298308,192,0,0.1,0.2,0.3,263,1.4,1.5
    3982,5/26/2021 23:38,15958.837,4.43,701,300,10,6001,0,65535,65535,1,21.6,26209,-296,-297,100,67,8,2585,3888,524,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3739,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,961,SUCCESS,,2590.968185,192,0,0.1,0.2,0.3,263,1.4,1.5
    3983,5/26/2021 23:38,15962.851,4.43,701,300,10,6001,0,65535,65535,1,21.6,26208,-294,-296,100,67,8,2585,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3738,3734,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,951,SUCCESS,,2590.640375,192,0,0.1,0.2,0.3,263,1.4,1.5
    3984,5/26/2021 23:38,15966.856,4.44,701,300,10,6001,0,65535,65535,1,21.6,26208,-296,-296,100,67,8,2585,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,953,SUCCESS,,2590.311075,192,0,0.1,0.2,0.3,263,1.4,1.5
    3985,5/26/2021 23:38,15970.862,4.44,701,300,10,6001,0,65535,65535,1,21.6,26207,-294,-297,100,67,8,2584,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3739,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,940,SUCCESS,,2589.983919,192,0,0.1,0.2,0.3,263,1.4,1.5
    3986,5/26/2021 23:39,15974.868,4.44,701,300,10,6001,0,65535,65535,1,21.6,26207,-296,-296,100,67,8,2584,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,959,SUCCESS,,2589.654536,192,0,0.1,0.2,0.3,263,1.4,1.5
    3987,5/26/2021 23:39,15978.88,4.44,701,300,10,6001,0,65535,65535,1,21.6,26207,-296,-296,100,67,8,2584,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,934,SUCCESS,,2589.324661,192,0,0.1,0.2,0.3,263,1.4,1.5
    3988,5/26/2021 23:39,15982.882,4.44,701,300,10,6001,0,65535,65535,1,21.6,26207,-296,-296,100,67,8,2583,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3747,3752,3753,3749,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,970,SUCCESS,,2588.995608,192,0,0.1,0.2,0.3,263,1.4,1.5
    3989,5/26/2021 23:39,15986.889,4.44,701,300,10,6001,0,65535,65535,1,21.6,26205,-296,-296,100,67,8,2583,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3752,3753,3749,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,965,SUCCESS,,2588.666143,192,0,0.1,0.2,0.3,263,1.4,1.5
    3990,5/26/2021 23:39,15990.891,4.44,701,300,10,6001,0,65535,65535,1,21.6,26205,-296,-296,100,67,8,2583,3888,524,524,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,963,SUCCESS,,2588.33709,192,0,0.1,0.2,0.3,263,1.4,1.5
    3991,5/26/2021 23:39,15994.9,4.44,701,300,10,6001,0,65535,65535,1,21.6,26203,-296,-296,100,67,8,2582,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3734,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.2,964,SUCCESS,,2588.007461,192,0,0.1,0.2,0.3,263,1.4,1.5
    3992,5/26/2021 23:39,15998.915,4.44,701,300,10,6001,0,65535,65535,1,21.6,26202,-296,-296,100,67,8,2582,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3735,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,967,SUCCESS,,2587.677339,192,0,0.1,0.2,0.3,263,1.4,1.5
    3993,5/26/2021 23:39,16002.916,4.45,701,300,10,6001,0,65535,65535,1,21.6,26203,-296,-296,100,67,8,2582,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3734,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,946,SUCCESS,,2587.348368,192,0,0.1,0.2,0.3,263,1.4,1.5
    3994,5/26/2021 23:39,16006.931,4.45,701,300,10,6001,0,65535,65535,1,21.6,26202,-296,-296,100,67,8,2581,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3734,3738,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,964,SUCCESS,,2587.018245,192,0,0.1,0.2,0.3,263,1.4,1.5
    3995,5/26/2021 23:39,16010.937,4.45,701,300,10,6001,0,65535,65535,1,21.6,26200,-296,-296,100,67,8,2581,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3734,3737,3733,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,942,SUCCESS,,2586.688863,192,0,0.1,0.2,0.3,263,1.4,1.5
    3996,5/26/2021 23:39,16014.945,4.45,701,300,10,6001,0,65535,65535,1,21.6,26205,-296,-296,100,67,8,2581,3888,520,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3751,3752,3748,3734,3737,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,935,SUCCESS,,2586.359316,192,0,0.1,0.2,0.3,263,1.4,1.5
    3997,5/26/2021 23:39,16018.952,4.45,701,300,10,6001,0,65535,65535,1,21.6,26200,-296,-296,100,67,8,2580,3888,519,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3750,3752,3748,3734,3737,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,961,SUCCESS,,2586.029852,192,0,0.1,0.2,0.3,263,1.4,1.5
    3998,5/26/2021 23:39,16022.967,4.45,701,300,10,6001,0,65535,65535,1,21.6,26197,-296,-297,100,67,8,2580,3888,523,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3750,3752,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,944,SUCCESS,,2585.69973,192,0,0.1,0.2,0.3,263,1.4,1.5
    3999,5/26/2021 23:39,16026.968,4.45,701,300,10,6001,0,65535,65535,1,21.6,26197,-296,-296,100,67,8,2580,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3750,3752,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.7,945,SUCCESS,,2585.370759,192,0,0.1,0.2,0.3,263,1.4,1.5
    4000,5/26/2021 23:39,16030.981,4.45,701,300,10,6001,0,65535,65535,1,21.6,26196,-296,-296,100,67,8,2579,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3746,3750,3752,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.5,944,SUCCESS,,2585.040801,192,0,0.1,0.2,0.3,263,1.4,1.5
    4001,5/26/2021 23:40,16034.996,4.45,701,300,10,6001,0,65535,65535,1,21.6,26194,-296,-296,100,67,8,2579,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3745,3750,3751,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.7,946,SUCCESS,,2584.710679,192,0,0.1,0.2,0.3,263,1.4,1.5
    4002,5/26/2021 23:40,16038.997,4.46,701,300,10,6001,0,65535,65535,1,21.6,26195,-294,-296,100,67,8,2579,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3745,3750,3751,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,944,SUCCESS,,2584.38393,192,0,0.1,0.2,0.3,263,1.4,1.5
    4003,5/26/2021 23:40,16042.997,4.46,701,300,10,6001,0,65535,65535,1,21.6,26195,-296,-296,100,67,8,2578,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3745,3750,3751,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,943,SUCCESS,,2584.055041,192,0,0.1,0.2,0.3,263,1.4,1.5
    4004,5/26/2021 23:40,16046.998,4.46,701,300,10,6001,0,65535,65535,1,21.5,26194,-296,-296,100,67,8,2578,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3745,3750,3751,3747,3733,3737,3732,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,942,SUCCESS,,2583.72607,192,0,0.1,0.2,0.3,263,1.4,1.5
    4005,5/26/2021 23:40,16051,4.46,701,300,10,6001,0,65535,65535,1,21.6,26195,-294,-296,100,67,8,2578,3888,523,523,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3745,3749,3751,3747,3733,3736,3732,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,939,SUCCESS,,2583.39924,192,0,0.1,0.2,0.3,263,1.4,1.5
    4006,5/26/2021 23:40,16054.999,4.46,701,300,10,6001,0,65535,65535,1,21.6,26193,-298,-296,100,67,8,2577,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3745,3750,3751,3747,3733,3736,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,948,SUCCESS,,2583.068212,192,0,0.1,0.2,0.3,263,1.4,1.5
    4007,5/26/2021 23:40,16059.01,4.46,701,300,10,6001,0,65535,65535,1,21.6,26189,-294,-296,100,67,8,2577,3888,526,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3733,3736,3732,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,947,SUCCESS,,2582.740647,192,0,0.1,0.2,0.3,263,1.4,1.5
    4008,5/26/2021 23:40,16063.013,4.46,701,300,10,6001,0,65535,65535,1,21.6,26188,-298,-296,100,67,8,2577,3888,519,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3736,3731,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.6,941,SUCCESS,,2582.409288,192,0,0.1,0.2,0.3,263,1.4,1.5
    4009,5/26/2021 23:40,16067.018,4.46,701,300,10,6001,0,65535,65535,1,21.6,26188,-298,-296,100,67,8,2576,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3733,3736,3731,0,0,0,0,0,0,0,0,2617,21.4,21.6,-273.2,21.6,-273.2,21.5,957,SUCCESS,,2582.077763,192,0,0.1,0.2,0.3,263,1.4,1.5
    4010,5/26/2021 23:40,16071.025,4.46,701,300,10,6001,0,65535,65535,1,21.6,26187,-296,-296,100,67,8,2576,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3735,3731,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,978,SUCCESS,,2581.748298,192,0,0.1,0.2,0.3,263,1.4,1.5
    4011,5/26/2021 23:40,16075.034,4.47,701,300,10,6001,0,65535,65535,1,21.6,26188,-296,-296,100,67,8,2576,3888,519,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3736,3731,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.7,953,SUCCESS,,2581.418669,192,0,0.1,0.2,0.3,263,1.4,1.5
    4012,5/26/2021 23:40,16079.037,4.47,701,300,10,6001,0,65535,65535,1,21.6,26188,-296,-296,100,67,8,2575,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3736,3731,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,952,SUCCESS,,2581.089534,192,0,0.1,0.2,0.3,263,1.4,1.5
    4013,5/26/2021 23:40,16083.041,4.47,701,300,10,6001,0,65535,65535,1,21.6,26187,-296,-296,100,67,8,2575,3888,518,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3735,3731,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,961,SUCCESS,,2580.760316,192,0,0.1,0.2,0.3,263,1.4,1.5
    4014,5/26/2021 23:40,16087.044,4.47,701,300,10,6001,0,65535,65535,1,21.6,26188,-296,-296,100,67,8,2575,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3736,3731,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.7,940,SUCCESS,,2580.43118,192,0,0.1,0.2,0.3,263,1.4,1.5
    4015,5/26/2021 23:40,16091.056,4.47,701,300,10,6001,0,65535,65535,1,21.6,26186,-294,-296,100,67,8,2574,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3746,3732,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,970,SUCCESS,,2580.103534,192,0,0.1,0.2,0.3,263,1.4,1.5
    4016,5/26/2021 23:41,16095.067,4.47,701,300,10,6001,0,65535,65535,1,21.6,26186,-296,-296,100,67,8,2574,3888,518,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3749,3750,3746,3732,3732,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,987,SUCCESS,,2579.77374,192,0,0.1,0.2,0.3,263,1.4,1.5
    4017,5/26/2021 23:41,16099.076,4.47,701,300,10,6001,0,65535,65535,1,21.6,26185,-296,-296,100,67,8,2574,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3749,3750,3746,3732,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,943,SUCCESS,,2579.444111,192,0,0.1,0.2,0.3,263,1.4,1.5
    4018,5/26/2021 23:41,16103.082,4.47,701,300,10,6001,0,65535,65535,1,21.6,26186,-296,-296,100,67,8,2573,3888,518,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3744,3749,3750,3745,3732,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,950,SUCCESS,,2579.114729,192,0,0.1,0.2,0.3,263,1.4,1.5
    4019,5/26/2021 23:41,16107.097,4.47,701,300,10,6001,0,65535,65535,1,21.6,26182,-296,-296,100,67,8,2573,3888,518,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3748,3750,3746,3731,3731,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,956,SUCCESS,,2578.784607,192,0,0.1,0.2,0.3,263,1.4,1.5
    4020,5/26/2021 23:41,16111.1,4.48,701,300,10,6001,0,65535,65535,1,21.6,26182,-294,-296,100,67,8,2573,3888,522,522,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3748,3749,3745,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,949,SUCCESS,,2578.457695,192,0,0.1,0.2,0.3,263,1.4,1.5
    4021,5/26/2021 23:41,16115.115,4.48,701,300,10,6001,0,65535,65535,1,21.6,26181,-296,-296,100,67,8,2572,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3748,3749,3745,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,952,SUCCESS,,2578.127573,192,0,0.1,0.2,0.3,263,1.4,1.5
    4022,5/26/2021 23:41,16119.13,4.48,701,300,10,6001,0,65535,65535,1,21.6,26181,-294,-296,100,67,8,2572,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3748,3749,3745,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,944,SUCCESS,,2577.799681,192,0,0.1,0.2,0.3,263,1.4,1.5
    4023,5/26/2021 23:41,16123.139,4.48,701,300,10,6001,0,65535,65535,1,21.6,26181,-296,-296,100,67,8,2572,3888,525,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3748,3749,3745,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,957,SUCCESS,,2577.470053,192,0,0.1,0.2,0.3,263,1.4,1.5
    4024,5/26/2021 23:41,16127.144,4.48,701,300,10,6001,0,65535,65535,1,21.6,26180,-298,-296,100,67,8,2571,3888,518,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3743,3748,3749,3745,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,935,SUCCESS,,2577.138528,192,0,0.1,0.2,0.3,263,1.4,1.5
    4025,5/26/2021 23:41,16131.149,4.48,701,300,10,6001,0,65535,65535,1,21.5,26181,-296,-296,100,67,8,2571,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3748,3749,3745,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.5,-273.2,21.5,-273.2,21.5,948,SUCCESS,,2576.809228,192,0,0.1,0.2,0.3,263,1.4,1.5
    4026,5/26/2021 23:41,16135.154,4.48,701,300,10,6001,0,65535,65535,1,21.5,26177,-298,-296,100,67,8,2571,3888,518,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3749,3744,3731,3734,3730,0,0,0,0,0,0,0,0,2617,21.3,21.5,-273.2,21.5,-273.2,21.6,958,SUCCESS,,2576.477703,192,0,0.1,0.2,0.3,263,1.4,1.5
    4027,5/26/2021 23:41,16139.162,4.48,701,300,10,6001,0,65535,65535,1,21.5,26177,-296,-296,100,67,8,2570,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3749,3744,3731,3735,3730,0,0,0,0,0,0,0,0,2617,21.3,21.5,-273.2,21.5,-273.2,21.7,967,SUCCESS,,2576.148156,192,0,0.1,0.2,0.3,263,1.4,1.5
    4028,5/26/2021 23:41,16143.172,4.48,701,300,10,6001,0,65535,65535,1,21.5,26177,-296,-296,100,67,8,2570,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3749,3744,3731,3734,3729,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.7,956,SUCCESS,,2575.818445,192,0,0.1,0.2,0.3,263,1.4,1.5
    4029,5/26/2021 23:41,16147.171,4.49,701,300,10,6001,0,65535,65535,1,21.6,26176,-296,-296,100,67,8,2570,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3731,3734,3729,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,960,SUCCESS,,2575.489638,192,0,0.1,0.2,0.3,263,1.4,1.5
    4030,5/26/2021 23:41,16151.178,4.49,701,300,10,6001,0,65535,65535,1,21.6,26175,-296,-296,100,67,8,2569,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3730,3734,3729,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,952,SUCCESS,,2575.160174,192,0,0.1,0.2,0.3,263,1.4,1.5
    4031,5/26/2021 23:42,16155.19,4.49,701,300,10,6001,0,65535,65535,1,21.5,26175,-296,-296,100,67,8,2569,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3730,3735,3729,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,939,SUCCESS,,2574.830298,192,0,0.1,0.2,0.3,263,1.4,1.5
    4032,5/26/2021 23:42,16159.194,4.49,701,300,10,6001,0,65535,65535,1,21.5,26173,-296,-297,100,67,8,2569,3888,521,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3730,3733,3729,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,948,SUCCESS,,2574.50108,192,0,0.1,0.2,0.3,263,1.4,1.5
    4033,5/26/2021 23:42,16163.195,4.49,701,300,10,6001,0,65535,65535,1,21.6,26174,-296,-297,100,67,8,2568,3888,521,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3730,3734,3729,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,999,SUCCESS,,2574.172109,192,0,0.1,0.2,0.3,263,1.4,1.5
    4034,5/26/2021 23:42,16167.199,4.49,701,300,10,6001,0,65535,65535,1,21.5,26174,-296,-296,100,67,8,2568,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3730,3734,3728,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,948,SUCCESS,,2573.842891,192,0,0.1,0.2,0.3,263,1.4,1.5
    4035,5/26/2021 23:42,16171.21,4.49,701,300,10,6001,0,65535,65535,1,21.5,26172,-296,-296,100,67,8,2568,3888,521,521,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3746,3747,3744,3730,3733,3728,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,950,SUCCESS,,2573.513098,192,0,0.1,0.2,0.3,263,1.4,1.5
    4036,5/26/2021 23:42,16175.218,4.49,701,300,10,6001,0,65535,65535,1,21.5,26173,-298,-296,100,67,8,2567,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3742,3747,3748,3744,3729,3733,3729,0,0,0,0,0,0,0,0,2617,21.3,21.5,-273.2,21.5,-273.2,21.6,958,SUCCESS,,2573.181325,192,0,0.1,0.2,0.3,263,1.4,1.5
    4037,5/26/2021 23:42,16179.224,4.49,701,300,10,6001,0,65535,65535,1,21.5,26168,-296,-296,100,67,8,2567,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3730,3733,3728,0,0,0,0,0,0,0,0,2617,21.3,21.6,-273.2,21.6,-273.2,21.6,950,SUCCESS,,2572.851943,192,0,0.1,0.2,0.3,263,1.4,1.5
    4038,5/26/2021 23:42,16183.227,4.5,701,300,10,6001,0,65535,65535,1,21.6,26168,-296,-296,100,67,8,2567,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3730,3733,3728,0,0,0,0,0,0,0,0,2617,21.3,21.5,-273.2,21.5,-273.2,21.6,952,SUCCESS,,2572.522807,192,0,0.1,0.2,0.3,263,1.4,1.5
    4039,5/26/2021 23:42,16187.228,4.5,701,300,10,6001,0,65535,65535,1,21.5,26167,-296,-296,100,66,8,2566,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3733,3728,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,955,SUCCESS,,2572.193836,192,0,0.1,0.2,0.3,263,1.4,1.5
    4040,5/26/2021 23:42,16191.238,4.5,701,300,10,6001,0,65535,65535,1,21.5,26167,-296,-296,100,66,8,2566,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3733,3728,0,0,0,0,0,0,0,0,2617,21.3,21.5,-273.2,21.5,-273.2,21.6,942,SUCCESS,,2571.864125,192,0,0.1,0.2,0.3,263,1.4,1.5
    4041,5/26/2021 23:42,16195.253,4.5,701,300,10,6001,0,65535,65535,1,21.5,26166,-296,-296,100,66,8,2566,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3733,3728,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,936,SUCCESS,,2571.534003,192,0,0.1,0.2,0.3,263,1.4,1.5
    4042,5/26/2021 23:42,16199.254,4.5,701,300,10,6001,0,65535,65535,1,21.5,26166,-298,-296,100,66,8,2565,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3732,3728,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21,967,SUCCESS,,2571.202809,192,0,0.1,0.2,0.3,263,1.4,1.5
    4043,5/26/2021 23:42,16203.263,4.5,701,300,10,6001,0,65535,65535,1,21.5,26166,-296,-296,100,66,8,2565,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3733,3728,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,951,SUCCESS,,2570.87318,192,0,0.1,0.2,0.3,263,1.4,1.5
    4044,5/26/2021 23:42,16207.27,4.5,701,300,10,6001,0,65535,65535,1,21.5,26165,-296,-296,100,66,8,2565,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3732,3728,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,938,SUCCESS,,2570.543715,192,0,0.1,0.2,0.3,263,1.4,1.5
    4045,5/26/2021 23:42,16211.274,4.5,701,300,10,6001,0,65535,65535,1,21.5,26165,-298,-296,100,66,8,2564,3888,516,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3743,3729,3732,3728,0,0,0,0,0,0,0,0,2616,21.3,21.5,-273.2,21.5,-273.2,21.7,964,SUCCESS,,2570.212273,192,0,0.1,0.2,0.3,263,1.4,1.5
    4046,5/26/2021 23:43,16215.283,4.5,701,300,10,6001,0,65535,65535,1,21.5,26164,-296,-296,100,66,8,2564,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3747,3742,3729,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.7,979,SUCCESS,,2569.882644,192,0,0.1,0.2,0.3,263,1.4,1.5
    4047,5/26/2021 23:43,16219.287,4.51,701,300,10,6001,0,65535,65535,1,21.5,26164,-294,-296,100,66,8,2564,3888,523,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3745,3747,3742,3729,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.7,951,SUCCESS,,2569.555651,192,0,0.1,0.2,0.3,263,1.4,1.5
    4048,5/26/2021 23:43,16223.294,4.51,701,300,10,6001,0,65535,65535,1,21.5,26162,-296,-296,100,66,8,2563,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3741,3746,3746,3742,3729,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,944,SUCCESS,,2569.226186,192,0,0.1,0.2,0.3,263,1.4,1.5
    4049,5/26/2021 23:43,16227.3,4.51,701,300,10,6001,0,65535,65535,1,21.5,26161,-296,-296,100,66,8,2563,3888,520,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3740,3746,3746,3742,3729,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,977,SUCCESS,,2568.896804,192,0,0.1,0.2,0.3,263,1.4,1.5
    4050,5/26/2021 23:43,16231.306,4.51,701,300,10,6001,0,65535,65535,1,21.5,26161,-296,-296,100,66,8,2563,3888,527,520,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3740,3745,3746,3742,3729,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,986,SUCCESS,,2568.567422,192,0,0.1,0.2,0.3,263,1.4,1.5
    4051,5/26/2021 23:43,16235.311,4.51,701,300,10,6001,0,65535,65535,1,21.5,26160,-298,-296,100,66,8,2562,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3740,3745,3746,3742,3729,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,943,SUCCESS,,2568.235897,192,0,0.1,0.2,0.3,263,1.4,1.5
    4052,5/26/2021 23:43,16239.311,4.51,701,300,10,6001,0,65535,65535,1,21.5,26160,-296,-296,100,66,8,2562,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3740,3745,3746,3742,3728,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,949,SUCCESS,,2567.907008,192,0,0.1,0.2,0.3,263,1.4,1.5
    4053,5/26/2021 23:43,16243.323,4.51,701,300,10,6001,0,65535,65535,1,21.5,26159,-296,-296,100,66,8,2562,3888,523,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3740,3745,3746,3742,3728,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,958,SUCCESS,,2567.577133,192,0,0.1,0.2,0.3,263,1.4,1.5
    4054,5/26/2021 23:43,16247.335,4.51,701,300,10,6001,0,65535,65535,1,21.5,26159,-294,-296,100,66,8,2561,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3740,3745,3746,3742,3728,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,941,SUCCESS,,2567.249486,192,0,0.1,0.2,0.3,263,1.4,1.5
    4055,5/26/2021 23:43,16251.348,4.51,701,300,10,6001,0,65535,65535,1,21.5,26160,-296,-296,100,66,8,2561,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3746,3742,3728,3732,3727,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,986,SUCCESS,,2566.919528,192,0,0.1,0.2,0.3,263,1.4,1.5
    4056,5/26/2021 23:43,16255.351,4.52,701,300,10,6001,0,65535,65535,1,21.5,26156,-298,-296,100,66,8,2561,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3746,3741,3728,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,957,SUCCESS,,2566.588169,192,0,0.1,0.2,0.3,263,1.4,1.5
    4057,5/26/2021 23:43,16259.361,4.52,701,300,10,6001,0,65535,65535,1,21.5,26154,-296,-296,100,66,8,2560,3888,522,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3746,3741,3728,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,946,SUCCESS,,2566.258458,192,0,0.1,0.2,0.3,263,1.4,1.5
    4058,5/26/2021 23:43,16263.368,4.52,701,300,10,6001,0,65535,65535,1,21.5,26154,-296,-296,100,66,8,2560,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,979,SUCCESS,,2565.928993,192,0,0.1,0.2,0.3,263,1.4,1.5
    4059,5/26/2021 23:43,16267.383,4.52,701,300,10,6001,0,65535,65535,1,21.5,26153,-294,-296,100,66,8,2560,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,964,SUCCESS,,2565.601101,192,0,0.1,0.2,0.3,263,1.4,1.5
    4060,5/26/2021 23:43,16271.393,4.52,701,300,10,6001,0,65535,65535,1,21.5,26153,-296,-296,100,66,8,2559,3888,522,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,956,SUCCESS,,2565.27139,192,0,0.1,0.2,0.3,263,1.4,1.5
    4061,5/26/2021 23:44,16275.394,4.52,701,300,10,6001,0,65535,65535,1,21.5,26153,-298,-296,100,66,8,2559,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,937,SUCCESS,,2564.940196,192,0,0.1,0.2,0.3,263,1.4,1.5
    4062,5/26/2021 23:44,16279.398,4.52,701,300,10,6001,0,65535,65535,1,21.5,26153,-298,-296,100,66,8,2559,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3726,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,950,SUCCESS,,2564.608754,192,0,0.1,0.2,0.3,263,1.4,1.5
    4063,5/26/2021 23:44,16283.398,4.52,701,300,10,6001,0,65535,65535,1,21.5,26152,-296,-296,100,66,8,2558,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,934,SUCCESS,,2564.279865,192,0,0.1,0.2,0.3,263,1.4,1.5
    4064,5/26/2021 23:44,16287.408,4.52,701,300,10,6001,0,65535,65535,1,21.5,26152,-300,-296,100,66,8,2558,3888,512,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3731,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,946,SUCCESS,,2563.945699,192,0,0.1,0.2,0.3,263,1.4,1.5
    4065,5/26/2021 23:44,16291.411,4.53,701,300,10,6001,0,65535,65535,1,21.5,26151,-296,-296,100,66,8,2558,3888,519,519,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,952,SUCCESS,,2563.616563,192,0,0.1,0.2,0.3,263,1.4,1.5
    4066,5/26/2021 23:44,16295.418,4.53,701,300,10,6001,0,65535,65535,1,21.5,26150,-296,-296,100,66,8,2557,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3739,3744,3745,3741,3727,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,945,SUCCESS,,2563.287099,192,0,0.1,0.2,0.3,263,1.4,1.5
    4067,5/26/2021 23:44,16299.431,4.53,701,300,10,6001,0,65535,65535,1,21.5,26150,-298,-296,100,66,8,2557,3888,515,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3741,3727,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,948,SUCCESS,,2562.954911,192,0,0.1,0.2,0.3,263,1.4,1.5
    4068,5/26/2021 23:44,16303.446,4.53,701,300,10,6001,0,65535,65535,1,21.5,26148,-296,-296,100,66,8,2557,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3744,3744,3740,3726,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,963,SUCCESS,,2562.624789,192,0,0.1,0.2,0.3,263,1.4,1.5
    4069,5/26/2021 23:44,16307.461,4.53,701,300,10,6001,0,65535,65535,1,21.5,26146,-294,-296,100,66,8,2556,3888,522,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3740,3726,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,965,SUCCESS,,2562.296898,192,0,0.1,0.2,0.3,263,1.4,1.5
    4070,5/26/2021 23:44,16311.473,4.53,701,300,10,6001,0,65535,65535,1,21.5,26148,-296,-296,100,66,8,2556,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3740,3726,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,937,SUCCESS,,2561.967022,192,0,0.1,0.2,0.3,263,1.4,1.5
    4071,5/26/2021 23:44,16315.476,4.53,701,300,10,6001,0,65535,65535,1,21.5,26146,-296,-296,100,66,8,2556,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3740,3726,3730,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,950,SUCCESS,,2561.637886,192,0,0.1,0.2,0.3,263,1.4,1.5
    4072,5/26/2021 23:44,16319.478,4.53,701,300,10,6001,0,65535,65535,1,21.5,26145,-298,-296,100,66,8,2555,3888,514,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3740,3726,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,933,SUCCESS,,2561.30661,192,0,0.1,0.2,0.3,263,1.4,1.5
    4073,5/26/2021 23:44,16323.484,4.53,701,300,10,6001,0,65535,65535,1,21.5,26147,-296,-296,100,66,8,2555,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3740,3726,3730,3725,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,942,SUCCESS,,2560.977228,192,0,0.1,0.2,0.3,263,1.4,1.5
    4074,5/26/2021 23:44,16327.496,4.54,701,300,10,6001,0,65535,65535,1,21.5,26145,-298,-296,100,66,8,2555,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3743,3744,3740,3726,3730,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,20.8,953,SUCCESS,,2560.645123,192,0,0.1,0.2,0.3,263,1.4,1.5
    4075,5/26/2021 23:44,16331.502,4.54,701,300,10,6001,0,65535,65535,1,21.5,26142,-296,-296,100,66,8,2554,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3742,3744,3739,3726,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,941,SUCCESS,,2560.315741,192,0,0.1,0.2,0.3,263,1.4,1.5
    4076,5/26/2021 23:45,16335.505,4.54,701,300,10,6001,0,65535,65535,1,21.5,26145,-296,-296,100,66,8,2554,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3742,3744,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,969,SUCCESS,,2559.986605,192,0,0.1,0.2,0.3,263,1.4,1.5
    4077,5/26/2021 23:45,16339.513,4.54,701,300,10,6001,0,65535,65535,1,21.5,26141,-298,-296,100,66,8,2554,3888,514,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3738,3742,3744,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,951,SUCCESS,,2559.654832,192,0,0.1,0.2,0.3,263,1.4,1.5
    4078,5/26/2021 23:45,16343.529,4.54,701,300,10,6001,0,65535,65535,1,21.5,26139,-296,-297,100,66,8,2553,3888,514,516,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,959,SUCCESS,,2559.324628,192,0,0.1,0.2,0.3,263,1.4,1.5
    4079,5/26/2021 23:45,16347.538,4.54,701,300,10,6001,0,65535,65535,1,21.5,26139,-296,-296,100,66,8,2553,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,939,SUCCESS,,2558.994999,192,0,0.1,0.2,0.3,263,1.4,1.5
    4080,5/26/2021 23:45,16351.552,4.54,701,300,10,6001,0,65535,65535,1,21.5,26139,-296,-296,100,66,8,2553,3888,518,518,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,1007,SUCCESS,,2558.664959,192,0,0.1,0.2,0.3,263,1.4,1.5
    4081,5/26/2021 23:45,16355.553,4.54,701,300,10,6001,0,65535,65535,1,21.5,26140,-296,-296,100,66,8,2552,3888,517,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,988,SUCCESS,,2558.335988,192,0,0.1,0.2,0.3,263,1.4,1.5
    4082,5/26/2021 23:45,16359.56,4.54,701,300,10,6001,0,65535,65535,1,21.5,26141,-294,-296,100,66,8,2552,3888,517,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,952,SUCCESS,,2558.008749,192,0,0.1,0.2,0.3,263,1.4,1.5
    4083,5/26/2021 23:45,16363.566,4.55,701,300,10,6001,0,65535,65535,1,21.5,26139,-296,-297,100,66,8,2552,3888,514,516,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3729,3724,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,955,SUCCESS,,2557.679367,192,0,0.1,0.2,0.3,263,1.4,1.5
    4084,5/26/2021 23:45,16367.571,4.55,701,300,10,6001,0,65535,65535,1,21.5,26137,-298,-296,100,66,8,2551,3888,521,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3737,3742,3743,3739,3725,3728,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,970,SUCCESS,,2557.347842,192,0,0.1,0.2,0.3,263,1.4,1.5
    4085,5/26/2021 23:45,16371.573,4.55,701,300,10,6001,0,65535,65535,1,21.5,26136,-298,-296,100,66,8,2551,3888,517,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3742,3743,3739,3725,3730,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,946,SUCCESS,,2557.016565,192,0,0.1,0.2,0.3,263,1.4,1.5
    4086,5/26/2021 23:45,16375.585,4.55,701,300,10,6001,0,65535,65535,1,21.5,26133,-296,-297,100,66,8,2551,3888,514,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3739,3724,3728,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,953,SUCCESS,,2556.68669,192,0,0.1,0.2,0.3,263,1.4,1.5
    4087,5/26/2021 23:45,16379.599,4.55,701,300,10,6001,0,65535,65535,1,21.5,26134,-296,-297,100,66,8,2550,3888,513,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3742,3742,3739,3724,3728,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,936,SUCCESS,,2556.35665,192,0,0.1,0.2,0.3,263,1.4,1.5
    4088,5/26/2021 23:45,16383.607,4.55,701,300,10,6001,0,65535,65535,1,21.5,26133,-296,-296,100,66,8,2550,3888,517,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3739,3724,3729,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,944,SUCCESS,,2556.027103,192,0,0.1,0.2,0.3,263,1.4,1.5
    4089,5/26/2021 23:45,16387.616,4.55,701,300,10,6001,0,65535,65535,1,21.5,26132,-296,-297,100,66,8,2550,3888,517,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3738,3724,3728,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,1052,SUCCESS,,2555.697474,192,0,0.1,0.2,0.3,263,1.4,1.5
    4090,5/26/2021 23:45,16391.618,4.55,701,300,10,6001,0,65535,65535,1,21.4,26132,-296,-296,100,66,8,2549,3888,517,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3738,3724,3727,3723,0,0,0,0,0,0,0,0,2613,21.3,21.4,-273.2,21.4,-273.2,21.6,933,SUCCESS,,2555.368421,192,0,0.1,0.2,0.3,263,1.4,1.5
    4091,5/26/2021 23:46,16395.623,4.55,701,300,10,6001,0,65535,65535,1,21.5,26132,-298,-296,100,66,8,2549,3888,513,517,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3738,3724,3729,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,943,SUCCESS,,2555.036896,192,0,0.1,0.2,0.3,263,1.4,1.5
    4092,5/26/2021 23:46,16399.63,4.56,701,300,10,6001,0,65535,65535,1,21.5,26132,-296,-297,100,66,8,2549,3888,513,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3738,3724,3727,3723,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.7,953,SUCCESS,,2554.707431,192,0,0.1,0.2,0.3,263,1.4,1.5
    4093,5/26/2021 23:46,16403.642,4.56,701,300,10,6001,0,65535,65535,1,21.5,26130,-298,-296,100,66,8,2548,3888,516,516,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3738,3724,3726,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,940,SUCCESS,,2554.375327,192,0,0.1,0.2,0.3,263,1.4,1.5
    4094,5/26/2021 23:46,16407.654,4.56,701,300,10,6001,0,65535,65535,1,21.5,26131,-298,-297,100,66,8,2548,3888,513,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3738,3724,3730,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,943,SUCCESS,,2554.043223,192,0,0.1,0.2,0.3,263,1.4,1.5
    4095,5/26/2021 23:46,16411.666,4.56,701,300,10,6001,0,65535,65535,1,21.5,26129,-294,-297,100,66,8,2548,3888,516,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3741,3742,3738,3724,3727,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,963,SUCCESS,,2553.715576,192,0,0.1,0.2,0.3,263,1.4,1.5
    4096,5/26/2021 23:46,16415.674,4.56,701,300,10,6001,0,65535,65535,1,21.5,26129,-300,-297,100,66,8,2547,3888,516,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3736,3741,3742,3737,3724,3726,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.5,941,SUCCESS,,2553.381576,192,0,0.1,0.2,0.3,263,1.4,1.5
    4097,5/26/2021 23:46,16419.68,4.56,701,300,10,6001,0,65535,65535,1,21.5,26127,-298,-297,100,66,8,2547,3888,513,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3741,3741,3738,3724,3729,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.3,979,SUCCESS,,2553.049968,192,0,0.1,0.2,0.3,263,1.4,1.5
    4098,5/26/2021 23:46,16423.692,4.56,701,300,10,6001,0,65535,65535,1,21.5,26126,-296,-297,100,66,8,2547,3888,513,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3740,3741,3737,3724,3727,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,937,SUCCESS,,2552.720093,192,0,0.1,0.2,0.3,263,1.4,1.5
    4099,5/26/2021 23:46,16427.705,4.56,701,300,10,6001,0,65535,65535,1,21.5,26125,-298,-297,100,66,8,2546,3888,513,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3740,3741,3737,3723,3727,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,955,SUCCESS,,2552.387905,192,0,0.1,0.2,0.3,263,1.4,1.5
    4100,5/26/2021 23:46,16431.715,4.56,701,300,10,6001,0,65535,65535,1,21.5,26125,-296,-297,100,66,8,2546,3888,516,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3740,3741,3737,3723,3727,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,969,SUCCESS,,2552.058194,192,0,0.1,0.2,0.3,263,1.4,1.5
    4101,5/26/2021 23:46,16435.717,4.57,701,300,10,6001,0,65535,65535,1,21.5,26125,-296,-297,100,66,8,2546,3888,516,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3740,3741,3737,3723,3727,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,943,SUCCESS,,2551.729141,192,0,0.1,0.2,0.3,263,1.4,1.5
    4102,5/26/2021 23:46,16439.723,4.57,701,300,10,6001,0,65535,65535,1,21.5,26124,-298,-297,100,66,8,2545,3888,512,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3740,3741,3737,3723,3726,3722,0,0,0,0,0,0,0,0,2613,21.3,21.5,-273.2,21.5,-273.2,21.6,954,SUCCESS,,2551.397533,192,0,0.1,0.2,0.3,263,1.4,1.5
    4103,5/26/2021 23:46,16443.737,4.57,701,300,10,6001,0,65535,65535,1,21.5,26125,-296,-297,100,66,8,2545,3888,516,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3740,3741,3737,3723,3726,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,947,SUCCESS,,2551.067493,192,0,0.1,0.2,0.3,263,1.4,1.5
    4104,5/26/2021 23:46,16447.741,4.57,701,300,10,6001,0,65535,65535,1,21.5,26123,-296,-297,100,66,8,2545,3888,516,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3739,3741,3737,3723,3727,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,969,SUCCESS,,2550.738275,192,0,0.1,0.2,0.3,263,1.4,1.5
    4105,5/26/2021 23:46,16451.744,4.57,701,300,10,6001,0,65535,65535,1,21.4,26123,-298,-297,100,66,8,2544,3888,512,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3739,3741,3737,3723,3727,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,954,SUCCESS,,2550.406916,192,0,0.1,0.2,0.3,263,1.4,1.5
    4106,5/26/2021 23:47,16455.747,4.57,701,300,10,6001,0,65535,65535,1,21.5,26120,-296,-297,100,66,8,2544,3888,516,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3735,3739,3741,3737,3722,3726,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,945,SUCCESS,,2550.07778,192,0,0.1,0.2,0.3,263,1.4,1.5
    4107,5/26/2021 23:47,16459.753,4.57,701,300,10,6001,0,65535,65535,1,21.4,26119,-298,-297,100,66,8,2544,3888,512,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3734,3739,3740,3736,3722,3726,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,939,SUCCESS,,2549.746173,192,0,0.1,0.2,0.3,263,1.4,1.5
    4108,5/26/2021 23:47,16463.754,4.57,701,300,10,6001,0,65535,65535,1,21.5,26119,-298,-297,100,66,8,2543,3888,512,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3734,3739,3740,3736,3722,3726,3721,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,954,SUCCESS,,2549.414979,192,0,0.1,0.2,0.3,263,1.4,1.5
    4109,5/26/2021 23:47,16467.766,4.57,701,300,10,6001,0,65535,65535,1,21.4,26118,-298,-297,100,66,8,2543,3888,515,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3734,3739,3740,3736,3722,3725,3721,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,947,SUCCESS,,2549.082874,192,0,0.1,0.2,0.3,263,1.4,1.5
    4110,5/26/2021 23:47,16471.779,4.58,701,300,10,6001,0,65535,65535,1,21.4,26118,-298,-297,100,66,8,2543,3888,512,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3734,3739,3740,3736,3722,3726,3721,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,943,SUCCESS,,2548.750687,192,0,0.1,0.2,0.3,263,1.4,1.5
    4111,5/26/2021 23:47,16475.788,4.58,701,300,10,6001,0,65535,65535,1,21.5,26118,-296,-297,100,66,8,2542,3888,515,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3734,3739,3740,3736,3722,3726,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,966,SUCCESS,,2548.421058,192,0,0.1,0.2,0.3,263,1.4,1.5
    4112,5/26/2021 23:47,16479.795,4.58,701,300,10,6001,0,65535,65535,1,21.5,26117,-298,-297,100,66,8,2542,3888,512,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3734,3739,3740,3736,3722,3725,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.5,955,SUCCESS,,2548.089368,192,0,0.1,0.2,0.3,263,1.4,1.5
    4113,5/26/2021 23:47,16483.799,4.58,701,300,10,6001,0,65535,65535,1,21.5,26117,-296,-297,100,66,8,2542,3888,515,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3739,3740,3736,3722,3725,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.5,955,SUCCESS,,2547.76015,192,0,0.1,0.2,0.3,263,1.4,1.5
    4114,5/26/2021 23:47,16487.808,4.58,701,300,10,6001,0,65535,65535,1,21.5,26115,-296,-297,100,66,8,2541,3888,515,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3739,3740,3736,3722,3725,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,945,SUCCESS,,2547.430521,192,0,0.1,0.2,0.3,263,1.4,1.5
    4115,5/26/2021 23:47,16491.809,4.58,701,300,10,6001,0,65535,65535,1,21.5,26114,-296,-297,100,66,8,2541,3888,515,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3739,3739,3735,3722,3725,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,983,SUCCESS,,2547.10155,192,0,0.1,0.2,0.3,263,1.4,1.5
    4116,5/26/2021 23:47,16495.818,4.58,701,300,10,6001,0,65535,65535,1,21.5,26113,-296,-297,100,66,8,2541,3888,512,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3739,3739,3736,3722,3725,3721,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.5,975,SUCCESS,,2546.771921,192,0,0.1,0.2,0.3,263,1.4,1.5
    4117,5/26/2021 23:47,16499.819,4.58,701,300,10,6001,0,65535,65535,1,21.5,26111,-296,-297,100,66,8,2540,3888,518,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3725,3720,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.6,951,SUCCESS,,2546.44295,192,0,0.1,0.2,0.3,263,1.4,1.5
    4118,5/26/2021 23:47,16503.824,4.58,701,300,10,6001,0,65535,65535,1,21.4,26111,-298,-297,100,66,8,2540,3888,511,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3725,3720,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,962,SUCCESS,,2546.111425,192,0,0.1,0.2,0.3,263,1.4,1.5
    4119,5/26/2021 23:47,16507.835,4.59,701,300,10,6001,0,65535,65535,1,21.4,26111,-296,-297,100,66,8,2540,3888,515,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3725,3720,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,988,SUCCESS,,2545.781631,192,0,0.1,0.2,0.3,263,1.4,1.5
    4120,5/26/2021 23:47,16511.849,4.59,701,300,10,6001,0,65535,65535,1,21.5,26111,-296,-296,100,66,8,2540,3888,518,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3725,3720,0,0,0,0,0,0,0,0,2608,21.3,21.5,-273.2,21.5,-273.2,21.5,967,SUCCESS,,2545.451591,192,0,0.1,0.2,0.3,263,1.4,1.5
    4121,5/26/2021 23:48,16515.852,4.59,701,300,10,6001,0,65535,65535,1,21.4,26111,-296,-296,100,66,8,2539,3888,515,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3725,3720,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,983,SUCCESS,,2545.122456,192,0,0.1,0.2,0.3,263,1.4,1.5
    4122,5/26/2021 23:48,16519.854,4.59,701,300,10,6001,0,65535,65535,1,21.4,26111,-296,-296,100,66,8,2539,3888,515,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3724,3720,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,948,SUCCESS,,2544.793403,192,0,0.1,0.2,0.3,263,1.4,1.5
    4123,5/26/2021 23:48,16523.864,4.59,701,300,10,6001,0,65535,65535,1,21.4,26111,-298,-296,100,66,8,2539,3888,511,515,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3725,3720,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,943,SUCCESS,,2544.461464,192,0,0.1,0.2,0.3,263,1.4,1.5
    4124,5/26/2021 23:48,16527.871,4.59,701,300,10,6001,0,65535,65535,1,21.4,26109,-296,-297,100,66,8,2538,3888,511,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,946,SUCCESS,,2544.131999,192,0,0.1,0.2,0.3,263,1.4,1.5
    4125,5/26/2021 23:48,16531.872,4.59,701,300,10,6001,0,65535,65535,1,21.4,26109,-296,-296,100,66,8,2538,3888,518,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3739,3735,3721,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,959,SUCCESS,,2543.803028,192,0,0.1,0.2,0.3,263,1.4,1.5
    4126,5/26/2021 23:48,16535.873,4.59,701,300,10,6001,0,65535,65535,1,21.4,26109,-298,-297,100,66,8,2538,3888,514,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3733,3738,3738,3735,3721,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,975,SUCCESS,,2543.471834,192,0,0.1,0.2,0.3,263,1.4,1.5
    4127,5/26/2021 23:48,16539.88,4.59,701,300,10,6001,0,65535,65535,1,21.4,26107,-296,-297,100,66,8,2537,3888,514,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3735,3721,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,974,SUCCESS,,2543.14237,192,0,0.1,0.2,0.3,263,1.4,1.5
    4128,5/26/2021 23:48,16543.884,4.6,701,300,10,6001,0,65535,65535,1,21.4,26106,-296,-297,100,66,8,2537,3888,514,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3734,3720,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,972,SUCCESS,,2542.813152,192,0,0.1,0.2,0.3,263,1.4,1.5
    4129,5/26/2021 23:48,16547.886,4.6,701,300,10,6001,0,65535,65535,1,21.4,26104,-298,-297,100,66,8,2537,3888,507,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3734,3720,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,946,SUCCESS,,2542.481875,192,0,0.1,0.2,0.3,263,1.4,1.5
    4130,5/26/2021 23:48,16551.89,4.6,701,300,10,6001,0,65535,65535,1,21.4,26104,-296,-297,100,66,8,2536,3888,514,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3734,3720,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,945,SUCCESS,,2542.152658,192,0,0.1,0.2,0.3,263,1.4,1.5
    4131,5/26/2021 23:48,16555.904,4.6,701,300,10,6001,0,65535,65535,1,21.4,26103,-298,-297,100,66,8,2536,3888,514,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3734,3720,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,952,SUCCESS,,2541.820388,192,0,0.1,0.2,0.3,263,1.4,1.5
    4132,5/26/2021 23:48,16559.917,4.6,701,300,10,6001,0,65535,65535,1,21.4,26104,-296,-297,100,66,8,2536,3888,511,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3734,3720,3724,3719,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,946,SUCCESS,,2541.49043,192,0,0.1,0.2,0.3,263,1.4,1.5
    4133,5/26/2021 23:48,16563.93,4.6,701,300,10,6001,0,65535,65535,1,21.4,26102,-296,-297,100,66,8,2535,3888,517,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3737,3738,3734,3720,3724,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,950,SUCCESS,,2541.160472,192,0,0.1,0.2,0.3,263,1.4,1.5
    4134,5/26/2021 23:48,16567.942,4.6,701,300,10,6001,0,65535,65535,1,21.4,26101,-296,-297,100,66,8,2535,3888,510,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3736,3738,3733,3720,3723,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,985,SUCCESS,,2540.830596,192,0,0.1,0.2,0.3,263,1.4,1.5
    4135,5/26/2021 23:48,16571.947,4.6,701,300,10,6001,0,65535,65535,1,21.4,26100,-296,-297,100,66,8,2535,3888,514,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3736,3738,3733,3719,3723,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,964,SUCCESS,,2540.501296,192,0,0.1,0.2,0.3,263,1.4,1.5
    4136,5/26/2021 23:49,16575.95,4.6,701,300,10,6001,0,65535,65535,1,21.4,26100,-294,-296,100,66,8,2534,3888,517,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3732,3736,3738,3733,3719,3723,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,945,SUCCESS,,2540.174385,192,0,0.1,0.2,0.3,263,1.4,1.5
    4137,5/26/2021 23:49,16579.955,4.61,701,300,10,6001,0,65535,65535,1,21.4,26098,-296,-296,100,66,8,2534,3888,514,514,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3723,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,955,SUCCESS,,2539.845085,192,0,0.1,0.2,0.3,263,1.4,1.5
    4138,5/26/2021 23:49,16583.969,4.61,701,300,10,6001,0,65535,65535,1,21.4,26097,-296,-296,100,66,8,2533,3888,513,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3722,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,965,SUCCESS,,2539.515045,192,0,0.1,0.2,0.3,263,1.4,1.5
    4139,5/26/2021 23:49,16587.979,4.61,701,300,10,6001,0,65535,65535,1,21.4,26097,-296,-296,100,66,8,2533,3888,513,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3723,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.2,971,SUCCESS,,2539.185334,192,0,0.1,0.2,0.3,263,1.4,1.5
    4140,5/26/2021 23:49,16591.985,4.61,701,300,10,6001,0,65535,65535,1,21.4,26097,-298,-296,100,66,8,2533,3888,510,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3723,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,940,SUCCESS,,2538.853726,192,0,0.1,0.2,0.3,263,1.4,1.5
    4141,5/26/2021 23:49,16596.001,4.61,701,300,10,6001,0,65535,65535,1,21.4,26096,-296,-296,100,66,8,2533,3888,513,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3722,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,939,SUCCESS,,2538.523521,192,0,0.1,0.2,0.3,263,1.4,1.5
    4142,5/26/2021 23:49,16600.009,4.61,701,300,10,6001,0,65535,65535,1,21.4,26096,-298,-297,100,66,8,2532,3888,510,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3722,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,947,SUCCESS,,2538.191748,192,0,0.1,0.2,0.3,263,1.4,1.5
    4143,5/26/2021 23:49,16604.022,4.61,701,300,10,6001,0,65535,65535,1,21.4,26098,-296,-297,100,66,8,2532,3888,513,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3731,3736,3737,3733,3719,3722,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,966,SUCCESS,,2537.86179,192,0,0.1,0.2,0.3,263,1.4,1.5
    4144,5/26/2021 23:49,16608.027,4.61,701,300,10,6001,0,65535,65535,1,21.4,26094,-296,-297,100,66,8,2532,3888,513,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3733,3719,3722,3718,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,969,SUCCESS,,2537.53249,192,0,0.1,0.2,0.3,263,1.4,1.5
    4145,5/26/2021 23:49,16612.037,4.61,701,300,10,6001,0,65535,65535,1,21.4,26091,-298,-297,100,66,8,2531,3888,510,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3736,3736,3733,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,936,SUCCESS,,2537.200551,192,0,0.1,0.2,0.3,263,1.4,1.5
    4146,5/26/2021 23:49,16616.041,4.62,701,300,10,6001,0,65535,65535,1,21.4,26095,-294,-297,100,66,8,2531,3888,517,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3736,3736,3733,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,932,SUCCESS,,2536.873558,192,0,0.1,0.2,0.3,263,1.4,1.5
    4147,5/26/2021 23:49,16620.046,4.62,701,300,10,6001,0,65535,65535,1,21.4,26091,-298,-296,100,66,8,2531,3888,510,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3719,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,951,SUCCESS,,2536.542033,192,0,0.1,0.2,0.3,263,1.4,1.5
    4148,5/26/2021 23:49,16624.059,4.62,701,300,10,6001,0,65535,65535,1,21.4,26089,-298,-297,100,66,8,2530,3888,513,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,951,SUCCESS,,2536.209846,192,0,0.1,0.2,0.3,263,1.4,1.5
    4149,5/26/2021 23:49,16628.074,4.62,701,300,10,6001,0,65535,65535,1,21.4,26094,-292,-296,100,66,8,2530,3888,513,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,943,SUCCESS,,2535.884185,192,0,0.1,0.2,0.3,263,1.4,1.5
    4150,5/26/2021 23:49,16632.079,4.62,701,300,10,6001,0,65535,65535,1,21.4,26090,-296,-296,100,66,8,2530,3888,509,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,941,SUCCESS,,2535.554885,192,0,0.1,0.2,0.3,263,1.4,1.5
    4151,5/26/2021 23:50,16636.092,4.62,701,300,10,6001,0,65535,65535,1,21.4,26090,-294,-296,100,66,8,2529,3888,516,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,958,SUCCESS,,2535.227156,192,0,0.1,0.2,0.3,263,1.4,1.5
    4152,5/26/2021 23:50,16640.094,4.62,701,300,10,6001,0,65535,65535,1,21.4,26090,-296,-296,100,66,8,2529,3888,509,513,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3718,3722,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,932,SUCCESS,,2534.898103,192,0,0.1,0.2,0.3,263,1.4,1.5
    4153,5/26/2021 23:50,16644.111,4.62,701,300,10,6001,0,65535,65535,1,21.4,26088,-300,-297,100,66,8,2529,3888,509,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3736,3732,3718,3721,3717,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,20.9,956,SUCCESS,,2534.563353,192,0,0.1,0.2,0.3,263,1.4,1.5
    4154,5/26/2021 23:50,16648.109,4.62,701,300,10,6001,0,65535,65535,1,21.4,26087,-296,-296,100,66,8,2528,3888,512,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3730,3735,3735,3732,3718,3722,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,943,SUCCESS,,2534.234629,192,0,0.1,0.2,0.3,263,1.4,1.5
    4155,5/26/2021 23:50,16652.125,4.63,701,300,10,6001,0,65535,65535,1,21.4,26087,-296,-296,100,66,8,2528,3888,512,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3735,3735,3731,3718,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,954,SUCCESS,,2533.904424,192,0,0.1,0.2,0.3,263,1.4,1.5
    4156,5/26/2021 23:50,16656.141,4.63,701,300,10,6001,0,65535,65535,1,21.4,26084,-298,-297,100,66,8,2528,3888,512,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3718,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,958,SUCCESS,,2533.571989,192,0,0.1,0.2,0.3,263,1.4,1.5
    4157,5/26/2021 23:50,16660.157,4.63,701,300,10,6001,0,65535,65535,1,21.4,26084,-296,-296,100,65,8,2527,3888,512,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3717,3720,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,981,SUCCESS,,2533.241784,192,0,0.1,0.2,0.3,263,1.4,1.5
    4158,5/26/2021 23:50,16664.158,4.63,701,300,10,6001,0,65535,65535,1,21.4,26084,-298,-296,100,65,8,2527,3888,512,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3718,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,942,SUCCESS,,2532.91059,192,0,0.1,0.2,0.3,263,1.4,1.5
    4159,5/26/2021 23:50,16668.173,4.63,701,300,10,6001,0,65535,65535,1,21.4,26083,-296,-297,100,65,8,2527,3888,509,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3718,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,939,SUCCESS,,2532.580468,192,0,0.1,0.2,0.3,263,1.4,1.5
    4160,5/26/2021 23:50,16672.189,4.63,701,300,10,6001,0,65535,65535,1,21.4,26083,-296,-296,100,65,8,2526,3888,516,512,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3717,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,945,SUCCESS,,2532.250264,192,0,0.1,0.2,0.3,263,1.4,1.5
    4161,5/26/2021 23:50,16676.188,4.63,701,300,10,6001,0,65535,65535,1,21.4,26083,-298,-297,100,65,8,2526,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3717,3720,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,959,SUCCESS,,2531.919235,192,0,0.1,0.2,0.3,263,1.4,1.5
    4162,5/26/2021 23:50,16680.189,4.63,701,300,10,6001,0,65535,65535,1,21.4,26082,-296,-297,100,65,8,2526,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3717,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,938,SUCCESS,,2531.590264,192,0,0.1,0.2,0.3,263,1.4,1.5
    4163,5/26/2021 23:50,16684.22,4.63,701,300,10,6001,0,65535,65535,1,21.4,26083,-298,-297,100,65,8,2525,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3734,3735,3731,3717,3721,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,946,SUCCESS,,2531.256587,192,0,0.1,0.2,0.3,263,1.4,1.5
    4164,5/26/2021 23:50,16688.234,4.64,701,300,10,6001,0,65535,65535,1,21.4,26081,-296,-297,100,65,8,2525,3888,508,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3733,3735,3731,3717,3720,3716,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,950,SUCCESS,,2530.926547,192,0,0.1,0.2,0.3,263,1.4,1.5
    4165,5/26/2021 23:50,16692.236,4.64,701,300,10,6001,0,65535,65535,1,21.4,26078,-298,-297,100,65,8,2525,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3733,3735,3730,3717,3720,3715,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,954,SUCCESS,,2530.59527,192,0,0.1,0.2,0.3,263,1.4,1.5
    4166,5/26/2021 23:51,16696.253,4.64,701,300,10,6001,0,65535,65535,1,21.4,26078,-298,-297,100,65,8,2524,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3729,3733,3735,3730,3716,3720,3715,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.5,952,SUCCESS,,2530.262752,192,0,0.1,0.2,0.3,263,1.4,1.5
    4167,5/26/2021 23:51,16700.267,4.64,701,300,10,6001,0,65535,65535,1,21.4,26076,-296,-297,100,65,8,2524,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3735,3730,3716,3720,3715,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21,979,SUCCESS,,2529.932712,192,0,0.1,0.2,0.3,263,1.4,1.5
    4168,5/26/2021 23:51,16704.265,4.64,701,300,10,6001,0,65535,65535,1,21.4,26076,-296,-297,100,65,8,2524,3888,512,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3734,3730,3716,3719,3715,0,0,0,0,0,0,0,0,2608,21.3,21.4,-273.2,21.4,-273.2,21.6,941,SUCCESS,,2529.603988,192,0,0.1,0.2,0.3,263,1.4,1.5
    4169,5/26/2021 23:51,16708.282,4.64,701,300,10,6001,0,65535,65535,1,21.4,26076,-296,-297,100,65,8,2523,3888,511,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3734,3730,3716,3721,3715,0,0,0,0,0,0,0,0,2605,21.3,21.4,-273.2,21.4,-273.2,21.6,955,SUCCESS,,2529.273701,192,0,0.1,0.2,0.3,263,1.4,1.5
    4170,5/26/2021 23:51,16712.297,4.64,701,300,10,6001,0,65535,65535,1,21.4,26076,-294,-296,100,65,8,2523,3888,511,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3734,3730,3716,3720,3715,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,939,SUCCESS,,2528.945809,192,0,0.1,0.2,0.3,263,1.4,1.5
    4171,5/26/2021 23:51,16716.313,4.64,701,300,10,6001,0,65535,65535,1,21.4,26076,-296,-296,100,65,8,2523,3888,511,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3734,3730,3716,3719,3715,0,0,0,0,0,0,0,0,2605,21.3,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2528.615605,192,0,0.1,0.2,0.3,263,1.4,1.5
    4172,5/26/2021 23:51,16720.313,4.64,701,300,10,6001,0,65535,65535,1,21.4,26075,-298,-297,100,65,8,2522,3888,508,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3734,3730,3716,3724,3715,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,939,SUCCESS,,2528.284494,192,0,0.1,0.2,0.3,263,1.4,1.5
    4173,5/26/2021 23:51,16724.334,4.65,701,300,10,6001,0,65535,65535,1,21.4,26075,-294,-296,100,65,8,2522,3888,515,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3728,3733,3734,3730,3716,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,949,SUCCESS,,2527.956112,192,0,0.1,0.2,0.3,263,1.4,1.5
    4174,5/26/2021 23:51,16728.345,4.65,701,300,10,6001,0,65535,65535,1,21.4,26075,-298,-297,100,65,8,2522,3888,508,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3734,3730,3716,3719,3715,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.4,957,SUCCESS,,2527.62409,192,0,0.1,0.2,0.3,263,1.4,1.5
    4175,5/26/2021 23:51,16732.345,4.65,701,300,10,6001,0,65535,65535,1,21.4,26071,-298,-297,100,65,8,2521,3888,508,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3721,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,967,SUCCESS,,2527.292979,192,0,0.1,0.2,0.3,263,1.4,1.5
    4176,5/26/2021 23:51,16736.277,4.65,701,300,10,6001,0,65535,65535,1,21.4,26070,-296,-297,100,65,8,2521,3888,511,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3716,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,964,SUCCESS,,2526.969681,192,0,0.1,0.2,0.3,263,1.4,1.5
    4177,5/26/2021 23:51,16740.277,4.65,701,300,10,6001,0,65535,65535,1,21.4,26070,-298,-297,100,65,8,2521,3888,508,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,943,SUCCESS,,2526.63857,192,0,0.1,0.2,0.3,263,1.4,1.5
    4178,5/26/2021 23:51,16744.292,4.65,701,300,10,6001,0,65535,65535,1,21.4,26070,-298,-297,100,65,8,2520,3888,507,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,945,SUCCESS,,2526.306218,192,0,0.1,0.2,0.3,263,1.4,1.5
    4179,5/26/2021 23:51,16748.301,4.65,701,300,10,6001,0,65535,65535,1,21.4,26069,-296,-296,100,65,8,2520,3888,511,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3716,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,945,SUCCESS,,2525.976589,192,0,0.1,0.2,0.3,263,1.4,1.5
    4180,5/26/2021 23:51,16752.309,4.65,701,300,10,6001,0,65535,65535,1,21.4,26068,-298,-297,100,65,8,2520,3888,507,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,952,SUCCESS,,2525.644815,192,0,0.1,0.2,0.3,263,1.4,1.5
    4181,5/26/2021 23:52,16756.318,4.65,701,300,10,6001,0,65535,65535,1,21.4,26069,-298,-297,100,65,8,2519,3888,507,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,966,SUCCESS,,2525.312959,192,0,0.1,0.2,0.3,263,1.4,1.5
    4182,5/26/2021 23:52,16760.328,4.66,701,300,10,6001,0,65535,65535,1,21.4,26069,-294,-296,100,65,8,2519,3888,514,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,942,SUCCESS,,2524.985476,192,0,0.1,0.2,0.3,263,1.4,1.5
    4183,5/26/2021 23:52,16764.341,4.66,701,300,10,6001,0,65535,65535,1,21.4,26067,-296,-296,100,65,8,2519,3888,511,511,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3714,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2524.655518,192,0,0.1,0.2,0.3,263,1.4,1.5
    4184,5/26/2021 23:52,16768.355,4.66,701,300,10,6001,0,65535,65535,1,21.4,26067,-296,-296,100,65,8,2518,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,947,SUCCESS,,2524.325478,192,0,0.1,0.2,0.3,263,1.4,1.5
    4185,5/26/2021 23:52,16772.362,4.66,701,300,10,6001,0,65535,65535,1,21.4,26067,-296,-296,100,65,8,2518,3888,507,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,984,SUCCESS,,2523.996014,192,0,0.1,0.2,0.3,263,1.4,1.5
    4186,5/26/2021 23:52,16776.362,4.66,701,300,10,6001,0,65535,65535,1,21.4,26067,-296,-296,100,65,8,2518,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3727,3732,3733,3729,3715,3719,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21,939,SUCCESS,,2523.667125,192,0,0.1,0.2,0.3,263,1.4,1.5
    4187,5/26/2021 23:52,16780.37,4.66,701,300,10,6001,0,65535,65535,1,21.4,26063,-294,-296,100,65,8,2517,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3731,3732,3728,3715,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,965,SUCCESS,,2523.339805,192,0,0.1,0.2,0.3,263,1.4,1.5
    4188,5/26/2021 23:52,16784.374,4.66,701,300,10,6001,0,65535,65535,1,21.4,26063,-296,-296,100,65,8,2517,3888,507,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3731,3732,3728,3715,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,973,SUCCESS,,2523.010587,192,0,0.1,0.2,0.3,263,1.4,1.5
    4189,5/26/2021 23:52,16788.378,4.66,701,300,10,6001,0,65535,65535,1,21.4,26063,-296,-296,100,65,8,2517,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3731,3732,3728,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,936,SUCCESS,,2522.681369,192,0,0.1,0.2,0.3,263,1.4,1.5
    4190,5/26/2021 23:52,16792.379,4.66,701,300,10,6001,0,65535,65535,1,21.4,26062,-296,-296,100,65,8,2516,3888,507,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3731,3732,3728,3715,3717,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,997,SUCCESS,,2522.352398,192,0,0.1,0.2,0.3,263,1.4,1.5
    4191,5/26/2021 23:52,16796.391,4.67,701,300,10,6001,0,65535,65535,1,21.4,26062,-296,-296,100,65,8,2516,3888,507,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3731,3732,3728,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,958,SUCCESS,,2522.022523,192,0,0.1,0.2,0.3,263,1.4,1.5
    4192,5/26/2021 23:52,16800.396,4.67,701,300,10,6001,0,65535,65535,1,21.4,26062,-296,-296,100,65,8,2516,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3731,3732,3728,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,935,SUCCESS,,2521.693223,192,0,0.1,0.2,0.3,263,1.4,1.5
    4193,5/26/2021 23:52,16804.399,4.67,701,300,10,6001,0,65535,65535,1,21.4,26062,-298,-296,100,65,8,2515,3888,506,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3726,3730,3732,3728,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,947,SUCCESS,,2521.361863,192,0,0.1,0.2,0.3,263,1.4,1.5
    4194,5/26/2021 23:52,16808.409,4.67,701,300,10,6001,0,65535,65535,1,21.4,26062,-296,-297,100,65,8,2515,3888,510,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3731,3732,3727,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,950,SUCCESS,,2521.032152,192,0,0.1,0.2,0.3,263,1.4,1.5
    4195,5/26/2021 23:52,16812.413,4.67,701,300,10,6001,0,65535,65535,1,21.4,26058,-296,-296,100,65,8,2515,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3732,3727,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,977,SUCCESS,,2520.702934,192,0,0.1,0.2,0.3,263,1.4,1.5
    4196,5/26/2021 23:53,16816.424,4.67,701,300,10,6001,0,65535,65535,1,21.4,26057,-298,-296,100,65,8,2514,3888,510,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3732,3727,3714,3718,3713,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,942,SUCCESS,,2520.370913,192,0,0.1,0.2,0.3,263,1.4,1.5
    4197,5/26/2021 23:53,16820.432,4.67,701,300,10,6001,0,65535,65535,1,21.4,26055,-296,-296,100,65,8,2514,3888,513,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3717,3712,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,952,SUCCESS,,2520.041366,192,0,0.1,0.2,0.3,263,1.4,1.5
    4198,5/26/2021 23:53,16824.446,4.67,701,300,10,6001,0,65535,65535,1,21.4,26055,-296,-296,100,65,8,2514,3888,506,510,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3717,3712,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,1013,SUCCESS,,2519.711326,192,0,0.1,0.2,0.3,263,1.4,1.5
    4199,5/26/2021 23:53,16828.447,4.67,701,300,10,6001,0,65535,65535,1,21.4,26055,-296,-296,100,65,8,2513,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3717,3712,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,963,SUCCESS,,2519.382355,192,0,0.1,0.2,0.3,263,1.4,1.5
    4200,5/26/2021 23:53,16832.46,4.68,701,300,10,6001,0,65535,65535,1,21.4,26055,-294,-296,100,65,8,2513,3888,506,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3717,3712,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2519.054626,192,0,0.1,0.2,0.3,263,1.4,1.5
    4201,5/26/2021 23:53,16836.468,4.68,701,300,10,6001,0,65535,65535,1,21.4,26055,-296,-296,100,65,8,2513,3888,513,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3717,3712,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,955,SUCCESS,,2518.72508,192,0,0.1,0.2,0.3,263,1.4,1.5
    4202,5/26/2021 23:53,16840.476,4.68,701,300,10,6001,0,65535,65535,1,21.4,26055,-296,-296,100,65,8,2512,3888,513,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3717,3712,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,963,SUCCESS,,2518.395533,192,0,0.1,0.2,0.3,263,1.4,1.5
    4203,5/26/2021 23:53,16844.489,4.68,701,300,10,6001,0,65535,65535,1,21.4,26054,-294,-296,100,65,8,2512,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3731,3727,3713,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,950,SUCCESS,,2518.067805,192,0,0.1,0.2,0.3,263,1.4,1.5
    4204,5/26/2021 23:53,16848.49,4.68,701,300,10,6001,0,65535,65535,1,21.4,26052,-296,-296,100,65,8,2512,3888,506,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3725,3730,3730,3727,3713,3717,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,934,SUCCESS,,2517.738834,192,0,0.1,0.2,0.3,263,1.4,1.5
    4205,5/26/2021 23:53,16852.503,4.68,701,300,10,6001,0,65535,65535,1,21.4,26053,-296,-296,100,65,8,2511,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3727,3713,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,936,SUCCESS,,2517.408876,192,0,0.1,0.2,0.3,263,1.4,1.5
    4206,5/26/2021 23:53,16856.517,4.68,701,300,10,6001,0,65535,65535,1,21.4,26048,-298,-296,100,65,8,2511,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,938,SUCCESS,,2517.076606,192,0,0.1,0.2,0.3,263,1.4,1.5
    4207,5/26/2021 23:53,16860.524,4.68,701,300,10,6001,0,65535,65535,1,21.4,26048,-296,-297,100,65,8,2511,3888,502,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,963,SUCCESS,,2516.747141,192,0,0.1,0.2,0.3,263,1.4,1.5
    4208,5/26/2021 23:53,16864.536,4.68,701,300,10,6001,0,65535,65535,1,21.4,26049,-294,-296,100,65,8,2510,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,936,SUCCESS,,2516.419495,192,0,0.1,0.2,0.3,263,1.4,1.5
    4209,5/26/2021 23:53,16868.536,4.69,701,300,10,6001,0,65535,65535,1,21.4,26048,-296,-296,100,65,8,2510,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,984,SUCCESS,,2516.090606,192,0,0.1,0.2,0.3,263,1.4,1.5
    4210,5/26/2021 23:53,16872.545,4.69,701,300,10,6001,0,65535,65535,1,21.4,26048,-296,-297,100,65,8,2510,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,958,SUCCESS,,2515.760977,192,0,0.1,0.2,0.3,263,1.4,1.5
    4211,5/26/2021 23:54,16876.552,4.69,701,300,10,6001,0,65535,65535,1,21.4,26048,-296,-296,100,65,8,2509,3888,509,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,985,SUCCESS,,2515.431513,192,0,0.1,0.2,0.3,263,1.4,1.5
    4212,5/26/2021 23:54,16880.555,4.69,701,300,10,6001,0,65535,65535,1,21.4,26046,-300,-297,100,65,8,2509,3888,502,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3715,3711,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,969,SUCCESS,,2515.097929,192,0,0.1,0.2,0.3,263,1.4,1.5
    4213,5/26/2021 23:54,16884.568,4.69,701,300,10,6001,0,65535,65535,1,21.4,26047,-294,-296,100,65,8,2509,3888,512,509,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3725,3712,3716,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,935,SUCCESS,,2514.770201,192,0,0.1,0.2,0.3,263,1.4,1.5
    4214,5/26/2021 23:54,16888.576,4.69,701,300,10,6001,0,65535,65535,1,21.4,26046,-294,-296,100,65,8,2508,3888,512,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3712,3716,3710,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.5,956,SUCCESS,,2514.442881,192,0,0.1,0.2,0.3,263,1.4,1.5
    4215,5/26/2021 23:54,16892.578,4.69,701,300,10,6001,0,65535,65535,1,21.4,26045,-296,-296,100,65,8,2508,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3726,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,939,SUCCESS,,2514.113828,192,0,0.1,0.2,0.3,263,1.4,1.5
    4216,5/26/2021 23:54,16896.591,4.69,701,300,10,6001,0,65535,65535,1,21.4,26043,-294,-296,100,65,8,2508,3888,512,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3724,3729,3730,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.6,990,SUCCESS,,2513.786099,192,0,0.1,0.2,0.3,263,1.4,1.5
    4217,5/26/2021 23:54,16900.6,4.69,701,300,10,6001,0,65535,65535,1,21.4,26043,-298,-296,100,65,8,2507,3888,505,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3729,3730,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.6,953,SUCCESS,,2513.454243,192,0,0.1,0.2,0.3,263,1.4,1.5
    4218,5/26/2021 23:54,16904.603,4.7,701,300,10,6001,0,65535,65535,1,21.4,26041,-296,-296,100,65,8,2507,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3728,3729,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,952,SUCCESS,,2513.125108,192,0,0.1,0.2,0.3,263,1.4,1.5
    4219,5/26/2021 23:54,16908.605,4.7,701,300,10,6001,0,65535,65535,1,21.4,26044,-296,-296,100,65,8,2507,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3728,3729,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,945,SUCCESS,,2512.796054,192,0,0.1,0.2,0.3,263,1.4,1.5
    4220,5/26/2021 23:54,16912.607,4.7,701,300,10,6001,0,65535,65535,1,21.4,26041,-298,-296,100,65,8,2506,3888,505,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3728,3729,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.5,964,SUCCESS,,2512.464778,192,0,0.1,0.2,0.3,263,1.4,1.5
    4221,5/26/2021 23:54,16916.61,4.7,701,300,10,6001,0,65535,65535,1,21.4,26041,-294,-296,100,65,8,2506,3888,511,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3728,3729,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,938,SUCCESS,,2512.137866,192,0,0.1,0.2,0.3,263,1.4,1.5
    4222,5/26/2021 23:54,16920.61,4.7,701,300,10,6001,0,65535,65535,1,21.4,26044,-296,-296,100,65,8,2506,3888,511,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3728,3729,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.3,21.4,-273.2,21.4,-273.2,21.5,939,SUCCESS,,2511.808977,192,0,0.1,0.2,0.3,263,1.4,1.5
    4223,5/26/2021 23:54,16924.617,4.7,701,300,10,6001,0,65535,65535,1,21.4,26040,-294,-296,100,65,8,2505,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3728,3729,3725,3711,3715,3710,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.5,962,SUCCESS,,2511.481739,192,0,0.1,0.2,0.3,263,1.4,1.5
    4224,5/26/2021 23:54,16928.62,4.7,701,300,10,6001,0,65535,65535,1,21.4,26038,-298,-296,100,65,8,2505,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3728,3729,3725,3711,3714,3710,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.4,952,SUCCESS,,2511.150379,192,0,0.1,0.2,0.3,263,1.4,1.5
    4225,5/26/2021 23:54,16932.626,4.7,701,300,10,6001,0,65535,65535,1,21.4,26043,-298,-296,100,65,8,2505,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3723,3727,3729,3724,3711,3715,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.4,953,SUCCESS,,2510.818771,192,0,0.1,0.2,0.3,263,1.4,1.5
    4226,5/26/2021 23:55,16936.633,4.7,701,300,10,6001,0,65535,65535,1,21.4,26037,-296,-296,100,65,8,2504,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3729,3724,3711,3715,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.4,952,SUCCESS,,2510.489307,192,0,0.1,0.2,0.3,263,1.4,1.5
    4227,5/26/2021 23:55,16940.634,4.71,701,300,10,6001,0,65535,65535,1,21.4,26036,-296,-296,100,65,8,2504,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3714,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.4,961,SUCCESS,,2510.160336,192,0,0.1,0.2,0.3,263,1.4,1.5
    4228,5/26/2021 23:55,16944.636,4.71,701,300,10,6001,0,65535,65535,1,21.4,26035,-296,-296,100,65,8,2504,3888,508,508,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3715,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.5,942,SUCCESS,,2509.831283,192,0,0.1,0.2,0.3,263,1.4,1.5
    4229,5/26/2021 23:55,16948.64,4.71,701,300,10,6001,0,65535,65535,1,21.4,26034,-296,-296,100,65,8,2503,3888,504,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3714,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.6,942,SUCCESS,,2509.502065,192,0,0.1,0.2,0.3,263,1.4,1.5
    4230,5/26/2021 23:55,16952.655,4.71,701,300,10,6001,0,65535,65535,1,21.4,26034,-296,-296,100,65,8,2503,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3713,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.5,960,SUCCESS,,2509.171943,192,0,0.1,0.2,0.3,263,1.4,1.5
    4231,5/26/2021 23:55,16956.664,4.71,701,300,10,6001,0,65535,65535,1,21.4,26033,-298,-296,100,65,8,2503,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3714,3709,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,21.5,933,SUCCESS,,2508.840086,192,0,0.1,0.2,0.3,263,1.4,1.5
    4232,5/26/2021 23:55,16960.667,4.71,701,300,10,6001,0,65535,65535,1,21.4,26032,-296,-296,100,65,8,2502,3888,504,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3714,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,967,SUCCESS,,2508.510951,192,0,0.1,0.2,0.3,263,1.4,1.5
    4233,5/26/2021 23:55,16964.671,4.71,701,300,10,6001,0,65535,65535,1,21.4,26032,-296,-296,100,65,8,2502,3888,511,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3728,3724,3710,3713,3708,0,0,0,0,0,0,0,0,2604,21.2,21.4,-273.2,21.4,-273.2,20.8,941,SUCCESS,,2508.181733,192,0,0.1,0.2,0.3,263,1.4,1.5
    4234,5/26/2021 23:55,16968.678,4.71,701,300,10,6001,0,65535,65535,1,21.4,26031,-298,-296,100,65,8,2502,3888,511,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3727,3724,3710,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.6,967,SUCCESS,,2507.850043,192,0,0.1,0.2,0.3,263,1.4,1.5
    4235,5/26/2021 23:55,16972.684,4.71,701,300,10,6001,0,65535,65535,1,21.4,26031,-296,-296,100,65,8,2501,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3727,3724,3710,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.6,942,SUCCESS,,2507.52066,192,0,0.1,0.2,0.3,263,1.4,1.5
    4236,5/26/2021 23:55,16976.692,4.72,701,300,10,6001,0,65535,65535,1,21.4,26030,-296,-296,100,65,8,2501,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3722,3727,3727,3724,3710,3712,3708,0,0,0,0,0,0,0,0,2603,21.2,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2507.191114,192,0,0.1,0.2,0.3,263,1.4,1.5
    4237,5/26/2021 23:55,16980.707,4.72,701,300,10,6001,0,65535,65535,1,21.4,26029,-296,-296,100,65,8,2501,3888,504,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3727,3728,3723,3710,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,955,SUCCESS,,2506.860991,192,0,0.1,0.2,0.3,263,1.4,1.5
    4238,5/26/2021 23:55,16984.718,4.72,701,300,10,6001,0,65535,65535,1,21.4,26028,-296,-296,100,65,8,2500,3888,510,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3726,3727,3723,3709,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,963,SUCCESS,,2506.531198,192,0,0.1,0.2,0.3,263,1.4,1.5
    4239,5/26/2021 23:55,16988.728,4.72,701,300,10,6001,0,65535,65535,1,21.4,26027,-298,-296,100,65,8,2500,3888,503,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3726,3727,3723,3709,3710,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,963,SUCCESS,,2506.199259,192,0,0.1,0.2,0.3,263,1.4,1.5
    4240,5/26/2021 23:55,16992.731,4.72,701,300,10,6001,0,65535,65535,1,21.4,26027,-296,-296,100,65,8,2500,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3726,3727,3723,3709,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,943,SUCCESS,,2505.870124,192,0,0.1,0.2,0.3,263,1.4,1.5
    4241,5/26/2021 23:56,16996.743,4.72,701,300,10,6001,0,65535,65535,1,21.4,26027,-296,-296,100,65,8,2499,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3726,3727,3723,3709,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,961,SUCCESS,,2505.540248,192,0,0.1,0.2,0.3,263,1.4,1.5
    4242,5/26/2021 23:56,17000.754,4.72,701,300,10,6001,0,65535,65535,1,21.4,26027,-296,-296,100,65,8,2499,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3725,3727,3722,3709,3709,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,937,SUCCESS,,2505.210455,192,0,0.1,0.2,0.3,263,1.4,1.5
    4243,5/26/2021 23:56,17004.763,4.72,701,300,10,6001,0,65535,65535,1,21.4,26026,-296,-296,100,65,8,2499,3888,507,507,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3725,3727,3722,3709,3713,3708,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.6,960,SUCCESS,,2504.880826,192,0,0.1,0.2,0.3,263,1.4,1.5
    4244,5/26/2021 23:56,17008.765,4.72,701,300,10,6001,0,65535,65535,1,21.4,26025,-298,-296,100,65,8,2498,3888,503,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3726,3727,3722,3709,3712,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.6,948,SUCCESS,,2504.549549,192,0,0.1,0.2,0.3,263,1.4,1.5
    4245,5/26/2021 23:56,17012.768,4.73,701,300,10,6001,0,65535,65535,1,21.4,26022,-296,-296,100,65,8,2498,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3725,3727,3722,3710,3711,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,937,SUCCESS,,2504.220414,192,0,0.1,0.2,0.3,263,1.4,1.5
    4246,5/26/2021 23:56,17016.777,4.73,701,300,10,6001,0,65535,65535,1,21.4,26022,-296,-296,100,65,8,2498,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3721,3725,3727,3722,3709,3712,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,946,SUCCESS,,2503.890785,192,0,0.1,0.2,0.3,263,1.4,1.5
    4247,5/26/2021 23:56,17020.78,4.73,701,300,10,6001,0,65535,65535,1,21.4,26021,-296,-296,100,65,8,2497,3888,503,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3712,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2503.561649,192,0,0.1,0.2,0.3,263,1.4,1.5
    4248,5/26/2021 23:56,17024.781,4.73,701,300,10,6001,0,65535,65535,1,21.4,26021,-294,-296,100,65,8,2497,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3713,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,940,SUCCESS,,2503.234901,192,0,0.1,0.2,0.3,263,1.4,1.5
    4249,5/26/2021 23:56,17028.783,4.73,701,300,10,6001,0,65535,65535,1,21.4,26020,-296,-296,100,65,8,2497,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3711,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,959,SUCCESS,,2502.905848,192,0,0.1,0.2,0.3,263,1.4,1.5
    4250,5/26/2021 23:56,17032.785,4.73,701,300,10,6001,0,65535,65535,1,21.4,26020,-294,-296,100,65,8,2496,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3712,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,953,SUCCESS,,2502.579018,192,0,0.1,0.2,0.3,263,1.4,1.5
    4251,5/26/2021 23:56,17036.793,4.73,701,300,10,6001,0,65535,65535,1,21.4,26020,-296,-296,100,65,8,2496,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3712,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,942,SUCCESS,,2502.249471,192,0,0.1,0.2,0.3,263,1.4,1.5
    4252,5/26/2021 23:56,17040.799,4.73,701,300,10,6001,0,65535,65535,1,21.4,26019,-298,-296,100,65,8,2496,3888,503,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3711,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,954,SUCCESS,,2501.917863,192,0,0.1,0.2,0.3,263,1.4,1.5
    4253,5/26/2021 23:56,17044.813,4.73,701,300,10,6001,0,65535,65535,1,21.4,26019,-296,-296,100,65,8,2495,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3720,3725,3726,3722,3708,3711,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,975,SUCCESS,,2501.587823,192,0,0.1,0.2,0.3,263,1.4,1.5
    4254,5/26/2021 23:56,17048.82,4.74,701,300,10,6001,0,65535,65535,1,21.4,26018,-296,-296,100,65,8,2495,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3725,3726,3722,3708,3711,3707,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.3,953,SUCCESS,,2501.258359,192,0,0.1,0.2,0.3,263,1.4,1.5
    4255,5/26/2021 23:56,17052.829,4.74,701,300,10,6001,0,65535,65535,1,21.4,26016,-298,-296,100,65,8,2495,3888,502,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3725,3725,3721,3708,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,954,SUCCESS,,2500.926503,192,0,0.1,0.2,0.3,263,1.4,1.5
    4256,5/26/2021 23:57,17056.835,4.74,701,300,10,6001,0,65535,65535,1,21.4,26015,-296,-296,100,65,8,2494,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,20.7,968,SUCCESS,,2500.59712,192,0,0.1,0.2,0.3,263,1.4,1.5
    4257,5/26/2021 23:57,17060.844,4.74,701,300,10,6001,0,65535,65535,1,21.4,26015,-294,-296,100,65,8,2494,3888,509,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,945,SUCCESS,,2500.269719,192,0,0.1,0.2,0.3,263,1.4,1.5
    4258,5/26/2021 23:57,17064.848,4.74,701,300,10,6001,0,65535,65535,1,21.4,26013,-296,-296,100,65,8,2494,3888,506,506,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,936,SUCCESS,,2499.940501,192,0,0.1,0.2,0.3,263,1.4,1.5
    4259,5/26/2021 23:57,17068.863,4.74,701,300,10,6001,0,65535,65535,1,21.4,26013,-298,-296,100,65,8,2493,3888,502,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,952,SUCCESS,,2499.608148,192,0,0.1,0.2,0.3,263,1.4,1.5
    4260,5/26/2021 23:57,17072.864,4.74,701,300,10,6001,0,65535,65535,1,21.4,26013,-298,-296,100,65,8,2493,3888,502,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,938,SUCCESS,,2499.276954,192,0,0.1,0.2,0.3,263,1.4,1.5
    4261,5/26/2021 23:57,17076.865,4.74,701,300,10,6001,0,65535,65535,1,21.4,26013,-294,-296,100,65,8,2493,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3710,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,956,SUCCESS,,2498.950206,192,0,0.1,0.2,0.3,263,1.4,1.5
    4262,5/26/2021 23:57,17080.87,4.74,701,300,10,6001,0,65535,65535,1,21.4,26013,-296,-296,100,65,8,2492,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,951,SUCCESS,,2498.620906,192,0,0.1,0.2,0.3,263,1.4,1.5
    4263,5/26/2021 23:57,17084.876,4.75,701,300,10,6001,0,65535,65535,1,21.4,26012,-298,-296,100,65,8,2492,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3711,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,939,SUCCESS,,2498.289298,192,0,0.1,0.2,0.3,263,1.4,1.5
    4264,5/26/2021 23:57,17088.878,4.75,701,300,10,6001,0,65535,65535,1,21.4,26012,-294,-296,100,65,8,2492,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3725,3721,3707,3710,3706,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,953,SUCCESS,,2497.962468,192,0,0.1,0.2,0.3,263,1.4,1.5
    4265,5/26/2021 23:57,17092.893,4.75,701,300,10,6001,0,65535,65535,1,21.4,26010,-296,-296,100,65,8,2491,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3719,3724,3724,3721,3707,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,960,SUCCESS,,2497.632346,192,0,0.1,0.2,0.3,263,1.4,1.5
    4266,5/26/2021 23:57,17096.905,4.75,701,300,10,6001,0,65535,65535,1,21.4,26008,-296,-296,100,65,8,2491,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3707,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,939,SUCCESS,,2497.30247,192,0,0.1,0.2,0.3,263,1.4,1.5
    4267,5/26/2021 23:57,17100.911,4.75,701,300,10,6001,0,65535,65535,1,21.4,26007,-296,-296,100,65,8,2491,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3707,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,983,SUCCESS,,2496.973088,192,0,0.1,0.2,0.3,263,1.4,1.5
    4268,5/26/2021 23:57,17104.916,4.75,701,300,10,6001,0,65535,65535,1,21.4,26007,-296,-296,100,65,8,2490,3888,508,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3706,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,969,SUCCESS,,2496.643788,192,0,0.1,0.2,0.3,263,1.4,1.5
    4269,5/26/2021 23:57,17108.931,4.75,701,300,10,6001,0,65535,65535,1,21.4,26008,-296,-296,100,65,8,2490,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3707,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,997,SUCCESS,,2496.313666,192,0,0.1,0.2,0.3,263,1.4,1.5
    4270,5/26/2021 23:58,17112.946,4.75,701,300,10,6001,0,65535,65535,1,21.4,26006,-296,-296,100,65,8,2490,3888,508,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3707,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,20.8,950,SUCCESS,,2495.983544,192,0,0.1,0.2,0.3,263,1.4,1.5
    4271,5/26/2021 23:58,17116.955,4.75,701,300,10,6001,0,65535,65535,1,21.4,26006,-298,-296,100,65,8,2489,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3706,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,954,SUCCESS,,2495.651688,192,0,0.1,0.2,0.3,263,1.4,1.5
    4272,5/26/2021 23:58,17120.963,4.76,701,300,10,6001,0,65535,65535,1,21.4,26006,-294,-296,100,65,8,2489,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3723,3724,3720,3706,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.3,946,SUCCESS,,2495.324368,192,0,0.1,0.2,0.3,263,1.4,1.5
    4273,5/26/2021 23:58,17124.965,4.76,701,300,10,6001,0,65535,65535,1,21.4,26004,-294,-296,100,65,8,2489,3888,505,505,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3722,3724,3719,3706,3709,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,959,SUCCESS,,2494.997538,192,0,0.1,0.2,0.3,263,1.4,1.5
    4274,5/26/2021 23:58,17128.974,4.76,701,300,10,6001,0,65535,65535,1,21.4,26004,-298,-296,100,64,8,2488,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3722,3724,3719,3706,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,968,SUCCESS,,2494.665681,192,0,0.1,0.2,0.3,263,1.4,1.5
    4275,5/26/2021 23:58,17132.983,4.76,701,300,10,6001,0,65535,65535,1,21.4,26003,-296,-296,100,64,8,2488,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3722,3724,3719,3706,3710,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,941,SUCCESS,,2494.336053,192,0,0.1,0.2,0.3,263,1.4,1.5
    4276,5/26/2021 23:58,17136.998,4.76,701,300,10,6001,0,65535,65535,1,21.4,26001,-296,-296,100,64,8,2488,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3722,3724,3719,3706,3709,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,946,SUCCESS,,2494.00593,192,0,0.1,0.2,0.3,263,1.4,1.5
    4277,5/26/2021 23:58,17141.007,4.76,701,300,10,6001,0,65535,65535,1,21.4,26001,-296,-296,100,64,8,2488,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3718,3722,3724,3719,3705,3709,3705,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,935,SUCCESS,,2493.676301,192,0,0.1,0.2,0.3,263,1.4,1.5
    4278,5/26/2021 23:58,17145.009,4.76,701,300,10,6001,0,65535,65535,1,21.4,26000,-296,-296,100,64,8,2487,3888,497,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3722,3723,3719,3705,3709,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,952,SUCCESS,,2493.347248,192,0,0.1,0.2,0.3,263,1.4,1.5
    4279,5/26/2021 23:58,17149.011,4.76,701,300,10,6001,0,65535,65535,1,21.4,25999,-296,-297,100,64,8,2487,3888,501,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3717,3722,3723,3719,3705,3708,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,955,SUCCESS,,2493.018195,192,0,0.1,0.2,0.3,263,1.4,1.5
    4280,5/26/2021 23:58,17153.021,4.76,701,300,10,6001,0,65535,65535,1,21.4,25999,-296,-296,100,64,8,2487,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3717,3722,3723,3719,3705,3709,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,976,SUCCESS,,2492.688484,192,0,0.1,0.2,0.3,263,1.4,1.5
    4281,5/26/2021 23:58,17157.029,4.77,701,300,10,6001,0,65535,65535,1,21.4,25999,-296,-296,100,64,8,2486,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3717,3722,3723,3719,3705,3709,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2492.358937,192,0,0.1,0.2,0.3,263,1.4,1.5
    4282,5/26/2021 23:58,17161.033,4.77,701,300,10,6001,0,65535,65535,1,21.4,25998,-296,-296,100,64,8,2486,3888,501,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3717,3722,3723,3719,3705,3708,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,975,SUCCESS,,2492.029719,192,0,0.1,0.2,0.3,263,1.4,1.5
    4283,5/26/2021 23:58,17165.04,4.77,701,300,10,6001,0,65535,65535,1,21.4,25997,-296,-296,100,64,8,2486,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3717,3722,3723,3719,3705,3708,3704,0,0,0,0,0,0,0,0,2595,21.2,21.4,-273.2,21.4,-273.2,21.5,949,SUCCESS,,2491.700255,192,0,0.1,0.2,0.3,263,1.4,1.5
    4284,5/26/2021 23:58,17169.05,4.77,701,300,10,6001,0,65535,65535,1,21.4,25998,-298,-296,100,64,8,2485,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3717,3722,3722,3719,3705,3708,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.2,936,SUCCESS,,2491.368316,192,0,0.1,0.2,0.3,263,1.4,1.5
    4285,5/26/2021 23:59,17173.059,4.77,701,300,10,6001,0,65535,65535,1,21.4,25994,-296,-296,100,64,8,2485,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3722,3722,3718,3705,3708,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,947,SUCCESS,,2491.038687,192,0,0.1,0.2,0.3,263,1.4,1.5
    4286,5/26/2021 23:59,17177.075,4.77,701,300,10,6001,0,65535,65535,1,21.4,25993,-294,-296,100,64,8,2484,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3705,3708,3704,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,949,SUCCESS,,2490.710714,192,0,0.1,0.2,0.3,263,1.4,1.5
    4287,5/26/2021 23:59,17181.081,4.77,701,300,10,6001,0,65535,65535,1,21.4,25992,-298,-296,100,64,8,2484,3888,500,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3705,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,950,SUCCESS,,2490.379106,192,0,0.1,0.2,0.3,263,1.4,1.5
    4288,5/26/2021 23:59,17185.09,4.77,701,300,10,6001,0,65535,65535,1,21.4,25993,-296,-296,100,64,8,2484,3888,504,504,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,953,SUCCESS,,2490.049477,192,0,0.1,0.2,0.3,263,1.4,1.5
    4289,5/26/2021 23:59,17189.102,4.77,701,300,10,6001,0,65535,65535,1,21.4,25992,-296,-296,100,64,8,2483,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,1019,SUCCESS,,2489.719601,192,0,0.1,0.2,0.3,263,1.4,1.5
    4290,5/26/2021 23:59,17193.106,4.78,701,300,10,6001,0,65535,65535,1,21.4,25992,-298,-296,100,64,8,2483,3888,500,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,942,SUCCESS,,2489.388159,192,0,0.1,0.2,0.3,263,1.4,1.5
    4291,5/26/2021 23:59,17197.106,4.78,701,300,10,6001,0,65535,65535,1,21.4,25991,-296,-296,100,64,8,2483,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.4,942,SUCCESS,,2489.05927,192,0,0.1,0.2,0.3,263,1.4,1.5
    4292,5/26/2021 23:59,17201.108,4.78,701,300,10,6001,0,65535,65535,1,21.4,25991,-296,-296,100,64,8,2482,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3722,3718,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,940,SUCCESS,,2488.730217,192,0,0.1,0.2,0.3,263,1.4,1.5
    4293,5/26/2021 23:59,17205.111,4.78,701,300,10,6001,0,65535,65535,1,21.4,25992,-294,-296,100,64,8,2482,3888,507,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3721,3722,3717,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,968,SUCCESS,,2488.403305,192,0,0.1,0.2,0.3,263,1.4,1.5
    4294,5/26/2021 23:59,17209.127,4.78,701,300,10,6001,0,65535,65535,1,21.4,25991,-294,-296,100,64,8,2482,3888,507,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3716,3721,3721,3718,3704,3708,3703,0,0,0,0,0,0,0,0,2599,21.2,21.4,-273.2,21.4,-273.2,21.5,937,SUCCESS,,2488.075332,192,0,0.1,0.2,0.3,263,1.4,1.5
    4295,5/26/2021 23:59,17213.138,4.78,701,300,10,6001,0,65535,65535,1,21.4,25989,-298,-296,100,64,8,2482,3888,500,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3704,3708,3702,0,0,0,0,0,0,0,0,2595,21.2,21.4,-273.2,21.4,-273.2,21.5,942,SUCCESS,,2487.74331,192,0,0.1,0.2,0.3,263,1.4,1.5
    4296,5/26/2021 23:59,17217.148,4.78,701,300,10,6001,0,65535,65535,1,21.4,25988,-296,-296,100,64,8,2481,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3704,3708,3702,0,0,0,0,0,0,0,0,2595,21.2,21.4,-273.2,21.4,-273.2,21.4,973,SUCCESS,,2487.413599,192,0,0.1,0.2,0.3,263,1.4,1.5
    4297,5/26/2021 23:59,17221.156,4.78,701,300,10,6001,0,65535,65535,1,21.4,25986,-296,-296,100,64,8,2481,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3721,3721,3717,3704,3707,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,940,SUCCESS,,2487.084053,192,0,0.1,0.2,0.3,263,1.4,1.5
    4298,5/26/2021 23:59,17225.17,4.78,701,300,10,6001,0,65535,65535,1,21.4,25986,-298,-296,100,64,8,2481,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3704,3707,3702,0,0,0,0,0,0,0,0,2595,21.2,21.4,-273.2,21.4,-273.2,20.9,969,SUCCESS,,2486.751783,192,0,0.1,0.2,0.3,263,1.4,1.5
    4299,5/26/2021 23:59,17229.177,4.79,701,300,10,6001,0,65535,65535,1,21.4,25988,-296,-296,100,64,8,2480,3888,506,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3704,3707,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,934,SUCCESS,,2486.422318,192,0,0.1,0.2,0.3,263,1.4,1.5
    4300,5/27/2021 0:00,17233.185,4.79,701,300,10,6001,0,65535,65535,1,21.4,25986,-298,-296,100,64,8,2480,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3703,3707,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,942,SUCCESS,,2486.090545,192,0,0.1,0.2,0.3,263,1.4,1.5
    4301,5/27/2021 0:00,17237.187,4.79,701,300,10,6001,0,65535,65535,1,21.4,25985,-296,-296,100,64,8,2480,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3703,3707,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,938,SUCCESS,,2485.761491,192,0,0.1,0.2,0.3,263,1.4,1.5
    4302,5/27/2021 0:00,17241.199,4.79,701,300,10,6001,0,65535,65535,1,21.4,25987,-294,-296,100,64,8,2479,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3704,3708,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,951,SUCCESS,,2485.433845,192,0,0.1,0.2,0.3,263,1.4,1.5
    4303,5/27/2021 0:00,17245.209,4.79,701,300,10,6001,0,65535,65535,1,21.4,25985,-296,-296,100,64,8,2479,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3703,3707,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,951,SUCCESS,,2485.104134,192,0,0.1,0.2,0.3,263,1.4,1.5
    4304,5/27/2021 0:00,17249.212,4.79,701,300,10,6001,0,65535,65535,1,21.4,25984,-296,-296,100,64,8,2479,3888,503,503,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3717,3703,3707,3702,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,966,SUCCESS,,2484.774998,192,0,0.1,0.2,0.3,263,1.4,1.5
    4305,5/27/2021 0:00,17253.218,4.79,701,300,10,6001,0,65535,65535,1,21.4,25983,-296,-296,100,64,8,2478,3888,506,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3719,3721,3716,3703,3707,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,942,SUCCESS,,2484.445616,192,0,0.1,0.2,0.3,263,1.4,1.5
    4306,5/27/2021 0:00,17257.221,4.79,701,300,10,6001,0,65535,65535,1,21.4,25981,-298,-297,100,64,8,2478,3888,499,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3720,3721,3716,3703,3707,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,937,SUCCESS,,2484.114256,192,0,0.1,0.2,0.3,263,1.4,1.5
    4307,5/27/2021 0:00,17261.234,4.79,701,300,10,6001,0,65535,65535,1,21.4,25981,-296,-297,100,64,8,2478,3888,502,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3719,3720,3716,3703,3706,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,956,SUCCESS,,2483.784299,192,0,0.1,0.2,0.3,263,1.4,1.5
    4308,5/27/2021 0:00,17265.235,4.8,701,300,10,6001,0,65535,65535,1,21.4,25980,-298,-296,100,64,8,2477,3888,502,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3715,3719,3721,3716,3702,3707,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,956,SUCCESS,,2483.453105,192,0,0.1,0.2,0.3,263,1.4,1.5
    4309,5/27/2021 0:00,17269.251,4.8,701,300,10,6001,0,65535,65535,1,21.4,25979,-298,-297,100,64,8,2477,3888,499,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3720,3716,3702,3706,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,940,SUCCESS,,2483.120669,192,0,0.1,0.2,0.3,263,1.4,1.5
    4310,5/27/2021 0:00,17273.251,4.8,701,300,10,6001,0,65535,65535,1,21.4,25979,-296,-297,100,64,8,2477,3888,506,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3720,3716,3702,3705,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,938,SUCCESS,,2482.79178,192,0,0.1,0.2,0.3,263,1.4,1.5
    4311,5/27/2021 0:00,17277.257,4.8,701,300,10,6001,0,65535,65535,1,21.4,25978,-298,-297,100,64,8,2476,3888,499,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3720,3716,3702,3709,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,950,SUCCESS,,2482.460173,192,0,0.1,0.2,0.3,263,1.4,1.5
    4312,5/27/2021 0:00,17281.269,4.8,701,300,10,6001,0,65535,65535,1,21.4,25978,-296,-297,100,64,8,2476,3888,505,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3720,3716,3702,3706,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21,941,SUCCESS,,2482.130297,192,0,0.1,0.2,0.3,263,1.4,1.5
    4313,5/27/2021 0:00,17285.285,4.8,701,300,10,6001,0,65535,65535,1,21.4,25977,-296,-296,100,64,8,2476,3888,502,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3719,3716,3702,3706,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,960,SUCCESS,,2481.800093,192,0,0.1,0.2,0.3,263,1.4,1.5
    4314,5/27/2021 0:00,17289.285,4.8,701,300,10,6001,0,65535,65535,1,21.4,25978,-296,-296,100,64,8,2475,3888,502,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3720,3716,3702,3707,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,957,SUCCESS,,2481.471204,192,0,0.1,0.2,0.3,263,1.4,1.5
    4315,5/27/2021 0:01,17293.286,4.8,701,300,10,6001,0,65535,65535,1,21.4,25977,-296,-296,100,64,8,2475,3888,502,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3714,3719,3720,3716,3702,3705,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,949,SUCCESS,,2481.142233,192,0,0.1,0.2,0.3,263,1.4,1.5
    4316,5/27/2021 0:01,17297.292,4.8,701,300,10,6001,0,65535,65535,1,21.4,25973,-296,-296,100,64,8,2475,3888,505,502,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3702,3704,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,960,SUCCESS,,2480.81285,192,0,0.1,0.2,0.3,263,1.4,1.5
    4317,5/27/2021 0:01,17301.306,4.81,701,300,10,6001,0,65535,65535,1,21.4,25975,-298,-296,100,64,8,2474,3888,498,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3702,3710,3701,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,984,SUCCESS,,2480.48058,192,0,0.1,0.2,0.3,263,1.4,1.5
    4318,5/27/2021 0:01,17305.312,4.81,701,300,10,6001,0,65535,65535,1,21.4,25973,-296,-296,100,64,8,2474,3888,501,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3705,3700,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,947,SUCCESS,,2480.151198,192,0,0.1,0.2,0.3,263,1.4,1.5
    4319,5/27/2021 0:01,17309.321,4.81,701,300,10,6001,0,65535,65535,1,21.4,25971,-298,-296,100,64,8,2474,3888,498,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3702,3705,3700,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,933,SUCCESS,,2479.819342,192,0,0.1,0.2,0.3,263,1.4,1.5
    4320,5/27/2021 0:01,17313.335,4.81,701,300,10,6001,0,65535,65535,1,21.4,25972,-300,-296,100,64,8,2473,3888,498,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3702,3710,3700,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,933,SUCCESS,,2479.484842,192,0,0.1,0.2,0.3,263,1.4,1.5
    4321,5/27/2021 0:01,17317.336,4.81,701,300,10,6001,0,65535,65535,1,21.4,25971,-296,-296,100,64,8,2473,3888,501,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3705,3700,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,977,SUCCESS,,2479.155871,192,0,0.1,0.2,0.3,263,1.4,1.5
    4322,5/27/2021 0:01,17321.351,4.81,701,300,10,6001,0,65535,65535,1,21.4,25971,-298,-296,100,64,8,2473,3888,501,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3704,3700,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,947,SUCCESS,,2478.823518,192,0,0.1,0.2,0.3,263,1.4,1.5
    4323,5/27/2021 0:01,17325.358,4.81,701,300,10,6001,0,65535,65535,1,21.4,25970,-296,-296,100,64,8,2472,3888,501,501,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3707,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,941,SUCCESS,,2478.494054,192,0,0.1,0.2,0.3,263,1.4,1.5
    4324,5/27/2021 0:01,17329.372,4.81,4701,300,10,6001,0,65535,65535,1,21.4,25970,-298,-296,100,64,8,2472,3888,498,501,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,958,SUCCESS,,2478.161784,192,0,0.1,0.2,0.3,327,1.4,1.5
    4325,5/27/2021 0:01,17333.381,4.81,4701,300,10,6001,0,65535,65535,1,21.4,25969,-294,-296,100,64,8,2472,3888,504,501,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,941,SUCCESS,,2477.834382,192,0,0.1,0.2,0.3,327,1.4,1.5
    4326,5/27/2021 0:01,17337.384,4.82,4701,300,10,6001,0,65535,65535,1,21.4,25970,-296,-296,100,64,8,2471,3888,501,501,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.2,955,SUCCESS,,2477.505246,192,0,0.1,0.2,0.3,327,1.4,1.5
    4327,5/27/2021 0:01,17341.396,4.82,4701,300,10,6001,0,65535,65535,1,21.4,25968,-298,-296,100,64,8,2471,3888,498,501,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3713,3718,3719,3715,3701,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,935,SUCCESS,,2477.173142,192,0,0.1,0.2,0.3,327,1.4,1.5
    4328,5/27/2021 0:01,17345.396,4.82,4701,300,10,6001,0,65535,65535,1,21.4,25965,-296,-297,100,64,8,2471,3888,501,499,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3712,3717,3718,3715,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,949,SUCCESS,,2476.844253,192,0,0.1,0.2,0.3,327,1.4,1.5
    4329,5/27/2021 0:01,17349.402,4.82,4701,300,10,6001,0,65535,65535,1,21.4,25965,-296,-296,100,64,8,2470,3888,501,501,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3712,3717,3718,3714,3701,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,950,SUCCESS,,2476.514871,192,0,0.1,0.2,0.3,327,1.4,1.5
    4330,5/27/2021 0:02,17353.408,4.82,4701,300,10,6001,0,65535,65535,1,21.4,25964,-298,-297,100,64,8,2470,3888,497,499,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3712,3717,3718,3714,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,935,SUCCESS,,2476.183263,192,0,0.1,0.2,0.3,327,1.4,1.5
    4331,5/27/2021 0:02,17357.419,4.82,4701,300,10,6001,0,65535,65535,1,21.4,25964,-296,-296,100,64,8,2470,3888,501,501,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3712,3717,3718,3714,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,958,SUCCESS,,2475.85347,192,0,0.1,0.2,0.3,327,1.4,1.5
    4332,5/27/2021 0:02,17361.423,4.82,701,300,10,6001,0,65535,65535,1,21.4,25964,-296,-296,100,64,8,2469,3888,500,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3712,3717,3718,3714,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,957,SUCCESS,,2475.524252,192,0,0.1,0.2,0.3,263,1.4,1.5
    4333,5/27/2021 0:02,17365.425,4.82,701,300,10,6001,0,65535,65535,1,21.4,25964,-296,-296,100,64,8,2469,3888,500,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3712,3717,3718,3714,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,973,SUCCESS,,2475.195199,192,0,0.1,0.2,0.3,263,1.4,1.5
    4334,5/27/2021 0:02,17369.431,4.82,701,300,10,6001,0,65535,65535,1,21.4,25963,-294,-296,100,64,8,2469,3888,500,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3717,3718,3714,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,934,SUCCESS,,2474.868042,192,0,0.1,0.2,0.3,263,1.4,1.5
    4335,5/27/2021 0:02,17373.441,4.83,701,300,10,6001,0,65535,65535,1,21.4,25962,-298,-296,100,64,8,2468,3888,500,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3718,3713,3700,3704,3699,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,973,SUCCESS,,2474.536103,192,0,0.1,0.2,0.3,263,1.4,1.5
    4336,5/27/2021 0:02,17377.456,4.83,701,300,10,6001,0,65535,65535,1,21.4,25961,-296,-296,100,64,8,2468,3888,500,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3717,3718,3713,3700,3704,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,936,SUCCESS,,2474.205981,192,0,0.1,0.2,0.3,263,1.4,1.5
    4337,5/27/2021 0:02,17381.463,4.83,701,300,10,6001,0,65535,65535,1,21.4,25960,-294,-296,100,64,8,2468,3888,500,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3718,3713,3700,3704,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,998,SUCCESS,,2473.878743,192,0,0.1,0.2,0.3,263,1.4,1.5
    4338,5/27/2021 0:02,17385.474,4.83,701,300,10,6001,0,65535,65535,1,21.4,25958,-296,-296,100,64,8,2467,3888,497,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3700,3703,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,940,SUCCESS,,2473.548949,192,0,0.1,0.2,0.3,263,1.4,1.5
    4339,5/27/2021 0:02,17389.474,4.83,701,300,10,6001,0,65535,65535,1,21.4,25958,-298,-296,100,64,8,2467,3888,497,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3703,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,935,SUCCESS,,2473.217838,192,0,0.1,0.2,0.3,263,1.4,1.5
    4340,5/27/2021 0:02,17393.48,4.83,701,300,10,6001,0,65535,65535,1,21.4,25956,-298,-296,100,64,8,2467,3888,497,500,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3703,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.2,977,SUCCESS,,2472.88623,192,0,0.1,0.2,0.3,263,1.4,1.5
    4341,5/27/2021 0:02,17397.482,4.83,701,300,10,6001,0,65535,65535,1,21.4,25957,-300,-297,100,64,8,2466,3888,497,498,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3703,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,944,SUCCESS,,2472.55273,192,0,0.1,0.2,0.3,263,1.4,1.5
    4342,5/27/2021 0:02,17401.496,4.83,701,300,10,6001,0,65535,65535,1,21.4,25957,-298,-297,100,64,8,2466,3888,500,498,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3703,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,943,SUCCESS,,2472.22046,192,0,0.1,0.2,0.3,263,1.4,1.5
    4343,5/27/2021 0:02,17405.505,4.83,4701,300,10,6001,0,65535,65535,1,21.4,25956,-296,-297,100,64,8,2466,3888,497,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3703,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,950,SUCCESS,,2471.890831,192,0,0.1,0.2,0.3,327,1.4,1.5
    4344,5/27/2021 0:02,17409.512,4.84,4701,300,10,6001,0,65535,65535,1,21.4,25956,-298,-297,100,64,8,2465,3888,500,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3702,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,946,SUCCESS,,2471.559141,192,0,0.1,0.2,0.3,327,1.4,1.5
    4345,5/27/2021 0:03,17413.526,4.84,4701,300,10,6001,0,65535,65535,1,21.4,25956,-298,-297,100,64,8,2465,3888,500,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3716,3713,3699,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,976,SUCCESS,,2471.226871,192,0,0.1,0.2,0.3,327,1.4,1.5
    4346,5/27/2021 0:03,17417.526,4.84,4701,300,10,6001,0,65535,65535,1,21.4,25955,-294,-297,100,64,8,2465,3888,496,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3702,3698,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,1002,SUCCESS,,2470.900204,192,0,0.1,0.2,0.3,327,1.4,1.5
    4347,5/27/2021 0:03,17421.533,4.84,701,300,10,6001,0,65535,65535,1,21.4,25954,-296,-297,100,64,8,2464,3888,499,498,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3711,3716,3717,3713,3699,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,948,SUCCESS,,2470.57074,192,0,0.1,0.2,0.3,263,1.4,1.5
    4348,5/27/2021 0:03,17425.545,4.84,701,300,10,6001,0,65535,65535,1,21.4,25953,-296,-296,100,64,8,2464,3888,499,499,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3713,3699,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,941,SUCCESS,,2470.240864,192,0,0.1,0.2,0.3,263,1.4,1.5
    4349,5/27/2021 0:03,17429.552,4.84,701,300,10,6001,0,65535,65535,1,21.4,25950,-298,-297,100,64,8,2464,3888,496,498,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3712,3698,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,965,SUCCESS,,2469.909174,192,0,0.1,0.2,0.3,263,1.4,1.5
    4350,5/27/2021 0:03,17433.557,4.84,4701,300,10,6001,0,65535,65535,1,21.4,25950,-298,-297,100,64,8,2463,3888,499,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3712,3698,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,964,SUCCESS,,2469.577649,192,0,0.1,0.2,0.3,327,1.4,1.5
    4351,5/27/2021 0:03,17437.571,4.84,4701,300,10,6001,0,65535,65535,1,21.4,25950,-296,-297,100,64,8,2463,3888,499,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3712,3698,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,955,SUCCESS,,2469.247609,192,0,0.1,0.2,0.3,327,1.4,1.5
    4352,5/27/2021 0:03,17441.586,4.84,4701,300,10,6001,0,65535,65535,1,21.4,25950,-296,-297,100,64,8,2463,3888,496,498,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3712,3698,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,955,SUCCESS,,2468.917486,192,0,0.1,0.2,0.3,327,1.4,1.5
    4353,5/27/2021 0:03,17445.593,4.85,4701,300,10,6001,0,65535,65535,1,21.4,25950,-296,-296,100,64,8,2462,3888,502,499,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3711,3698,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,965,SUCCESS,,2468.588022,192,0,0.1,0.2,0.3,327,1.4,1.5
    4354,5/27/2021 0:03,17449.594,4.85,701,300,10,6001,0,65535,65535,1,21.4,25947,-296,-297,100,64,8,2462,3888,496,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3711,3698,3702,3697,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.5,941,SUCCESS,,2468.259051,192,0,0.1,0.2,0.3,263,1.4,1.5
    4355,5/27/2021 0:03,17453.61,4.85,701,300,10,6001,0,65535,65535,1,21.4,25948,-298,-297,100,64,8,2462,3888,496,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3712,3698,3702,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,968,SUCCESS,,2467.926615,192,0,0.1,0.2,0.3,263,1.4,1.5
    4356,5/27/2021 0:03,17457.614,4.85,701,300,10,6001,0,65535,65535,1,21.4,25948,-296,-297,100,64,8,2461,3888,502,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3711,3698,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,971,SUCCESS,,2467.597398,192,0,0.1,0.2,0.3,263,1.4,1.5
    4357,5/27/2021 0:03,17461.619,4.85,701,300,10,6001,0,65535,65535,1,21.4,25948,-296,-297,100,64,8,2461,3888,496,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3716,3711,3698,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,946,SUCCESS,,2467.268098,192,0,0.1,0.2,0.3,263,1.4,1.5
    4358,5/27/2021 0:03,17465.626,4.85,701,300,10,6001,0,65535,65535,1,21.4,25947,-296,-297,100,64,8,2461,3888,502,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3710,3715,3715,3711,3698,3702,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,976,SUCCESS,,2466.938633,192,0,0.1,0.2,0.3,263,1.4,1.5
    4359,5/27/2021 0:03,17469.634,4.85,701,300,10,6001,0,65535,65535,1,21.4,25946,-298,-297,100,64,8,2460,3888,499,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3715,3715,3711,3698,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,20.7,953,SUCCESS,,2466.60686,192,0,0.1,0.2,0.3,263,1.4,1.5
    4360,5/27/2021 0:04,17473.637,4.85,701,300,10,6001,0,65535,65535,1,21.4,25945,-296,-297,100,64,8,2460,3888,499,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3698,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,960,SUCCESS,,2466.277724,192,0,0.1,0.2,0.3,263,1.4,1.5
    4361,5/27/2021 0:04,17477.648,4.85,701,300,10,6001,0,65535,65535,1,21.4,25942,-296,-297,100,64,8,2460,3888,499,497,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3698,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,964,SUCCESS,,2465.947931,192,0,0.1,0.2,0.3,327,1.4,1.5
    4362,5/27/2021 0:04,17481.654,4.86,4701,300,10,6001,0,65535,65535,1,21.4,25944,-298,-297,100,64,8,2459,3888,495,497,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3697,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,943,SUCCESS,,2465.616323,192,0,0.1,0.2,0.3,327,1.4,1.5
    4363,5/27/2021 0:04,17485.669,4.86,4701,300,10,6001,0,65535,65535,1,21.4,25943,-298,-297,100,64,8,2459,3888,495,497,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3697,3701,3696,0,0,0,0,0,0,0,0,2591,21.2,21.4,-273.2,21.4,-273.2,21.4,943,SUCCESS,,2465.28397,192,0,0.1,0.2,0.3,327,1.4,1.5
    4364,5/27/2021 0:04,17489.68,4.86,4701,300,10,6001,0,65535,65535,1,21.4,25943,-294,-297,100,64,8,2459,3888,502,497,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3697,3701,3696,0,0,0,0,0,0,0,0,2594,21.2,21.4,-273.2,21.4,-273.2,21.4,952,SUCCESS,,2464.956405,192,0,0.1,0.2,0.3,327,1.4,1.5
    4365,5/27/2021 0:04,17493.696,4.86,701,300,10,6001,0,65535,65535,1,21.4,25943,-296,-297,100,64,8,2458,3888,498,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3697,3701,3696,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.4,1040,SUCCESS,,2464.626201,192,0,0.1,0.2,0.3,263,1.4,1.5
    4366,5/27/2021 0:04,17497.711,4.86,701,300,10,6001,0,65535,65535,1,21.4,25943,-296,-297,100,64,8,2458,3888,498,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3697,3701,3696,0,0,0,0,0,0,0,0,2591,21.2,21.4,-273.2,21.4,-273.2,21.5,948,SUCCESS,,2464.296079,192,0,0.1,0.2,0.3,263,1.4,1.5
    4367,5/27/2021 0:04,17501.724,4.86,701,300,10,6001,0,65535,65535,1,21.4,25941,-298,-297,100,64,8,2458,3888,495,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3709,3714,3715,3711,3697,3701,3695,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.5,987,SUCCESS,,2463.963891,192,0,0.1,0.2,0.3,263,1.4,1.5
    4368,5/27/2021 0:04,17505.735,4.86,701,300,10,6001,0,65535,65535,1,21.4,25942,-296,-297,100,64,8,2457,3888,498,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3714,3715,3711,3697,3700,3695,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.4,944,SUCCESS,,2463.634098,192,0,0.1,0.2,0.3,263,1.4,1.5
    4369,5/27/2021 0:04,17509.745,4.86,701,300,10,6001,0,65535,65535,1,21.4,25938,-296,-297,100,64,8,2457,3888,498,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3700,3695,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.4,951,SUCCESS,,2463.304387,192,0,0.1,0.2,0.3,263,1.4,1.5
    4370,5/27/2021 0:04,17513.748,4.86,701,300,10,6001,0,65535,65535,1,21.4,25935,-298,-297,100,64,8,2457,3888,495,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3715,3710,3696,3700,3695,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.5,957,SUCCESS,,2462.973028,192,0,0.1,0.2,0.3,263,1.4,1.5
    4371,5/27/2021 0:04,17517.752,4.87,701,300,10,6001,0,65535,65535,1,21.4,25936,-296,-297,100,64,8,2456,3888,494,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3700,3695,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.4,962,SUCCESS,,2462.64381,192,0,0.1,0.2,0.3,263,1.4,1.5
    4372,5/27/2021 0:04,17521.757,4.87,701,300,10,6001,0,65535,65535,1,21.3,25936,-298,-297,100,64,8,2456,3888,494,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3700,3695,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,961,SUCCESS,,2462.312285,192,0,0.1,0.2,0.3,263,1.4,1.5
    4373,5/27/2021 0:04,17525.762,4.87,4701,300,10,6001,0,65535,65535,1,21.4,25934,-298,-297,100,64,8,2456,3888,494,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3700,3695,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.4,943,SUCCESS,,2461.98076,192,0,0.1,0.2,0.3,327,1.4,1.5
    4374,5/27/2021 0:04,17529.762,4.87,4701,300,10,6001,0,65535,65535,1,21.4,25936,-296,-297,100,64,8,2455,3888,498,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3699,3695,0,0,0,0,0,0,0,0,2590,21.1,21.4,-273.2,21.4,-273.2,20.7,957,SUCCESS,,2461.651871,192,0,0.1,0.2,0.3,327,1.4,1.5
    4375,5/27/2021 0:05,17533.772,4.87,4701,300,10,6001,0,65535,65535,1,21.3,25934,-298,-297,100,64,8,2455,3888,494,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.5,990,SUCCESS,,2461.319932,192,0,0.1,0.2,0.3,327,1.4,1.5
    4376,5/27/2021 0:05,17537.772,4.87,701,300,10,6001,0,65535,65535,1,21.4,25934,-296,-297,100,64,8,2455,3888,498,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.5,956,SUCCESS,,2460.991043,192,0,0.1,0.2,0.3,263,1.4,1.5
    4377,5/27/2021 0:05,17541.779,4.87,701,300,10,6001,0,65535,65535,1,21.3,25934,-296,-297,100,64,8,2454,3888,501,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3713,3714,3710,3696,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.4,-273.2,21.4,-273.2,21.5,941,SUCCESS,,2460.661579,192,0,0.1,0.2,0.3,263,1.4,1.5
    4378,5/27/2021 0:05,17545.781,4.87,701,300,10,6001,0,65535,65535,1,21.4,25932,-298,-297,100,64,8,2454,3888,494,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3708,3712,3713,3710,3696,3699,3694,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.3,964,SUCCESS,,2460.330302,192,0,0.1,0.2,0.3,263,1.4,1.5
    4379,5/27/2021 0:05,17549.783,4.87,701,300,10,6001,0,65535,65535,1,21.4,25930,-298,-297,100,64,8,2454,3888,494,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3696,3698,3694,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.5,938,SUCCESS,,2459.999025,192,0,0.1,0.2,0.3,263,1.4,1.5
    4380,5/27/2021 0:05,17553.791,4.88,4701,300,10,6001,0,65535,65535,1,21.4,25929,-294,-297,100,64,8,2453,3888,497,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3710,3695,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.5,991,SUCCESS,,2459.671705,192,0,0.1,0.2,0.3,327,1.4,1.5
    4381,5/27/2021 0:05,17557.804,4.88,4701,300,10,6001,0,65535,65535,1,21.3,25930,-298,-297,100,64,8,2453,3888,497,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3695,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,967,SUCCESS,,2459.339518,192,0,0.1,0.2,0.3,327,1.4,1.5
    4382,5/27/2021 0:05,17561.82,4.88,4701,300,10,6001,0,65535,65535,1,21.4,25929,-296,-296,100,64,8,2453,3888,497,497,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3695,3698,3694,0,0,0,0,0,0,0,0,2590,21.1,21.4,-273.2,21.4,-273.2,21.4,979,SUCCESS,,2459.009314,192,0,0.1,0.2,0.3,327,1.4,1.5
    4383,5/27/2021 0:05,17565.835,4.88,4701,300,10,6001,0,65535,65535,1,21.4,25929,-298,-296,100,64,8,2452,3888,497,497,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3695,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.5,950,SUCCESS,,2458.676961,192,0,0.1,0.2,0.3,327,1.4,1.5
    4384,5/27/2021 0:05,17569.845,4.88,701,300,10,6001,0,65535,65535,1,21.4,25929,-298,-296,100,64,8,2452,3888,497,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3695,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.4,-273.2,21.4,-273.2,21.4,939,SUCCESS,,2458.345022,192,0,0.1,0.2,0.3,263,1.4,1.5
    4385,5/27/2021 0:05,17573.848,4.88,701,300,10,6001,0,65535,65535,1,21.4,25928,-296,-296,100,64,8,2452,3888,500,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3695,3698,3694,0,0,0,0,0,0,0,0,2590,21.1,21.4,-273.2,21.4,-273.2,21.4,1002,SUCCESS,,2458.015886,192,0,0.1,0.2,0.3,263,1.4,1.5
    4386,5/27/2021 0:05,17577.86,4.88,701,300,10,6001,0,65535,65535,1,21.4,25928,-296,-296,100,64,8,2451,3888,497,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3711,3713,3708,3695,3699,3694,0,0,0,0,0,0,0,0,2590,21.2,21.4,-273.2,21.4,-273.2,21.4,939,SUCCESS,,2457.686011,192,0,0.1,0.2,0.3,263,1.4,1.5
    4387,5/27/2021 0:05,17581.868,4.88,701,300,10,6001,0,65535,65535,1,21.4,25927,-296,-296,100,64,8,2451,3888,497,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3711,3713,3708,3695,3699,3694,0,0,0,0,0,0,0,0,2590,21.1,21.4,-273.2,21.4,-273.2,21.5,994,SUCCESS,,2457.356464,192,0,0.1,0.2,0.3,263,1.4,1.5
    4388,5/27/2021 0:05,17585.876,4.88,701,300,10,6001,0,65535,65535,1,21.3,25925,-296,-296,100,64,8,2451,3888,500,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3712,3713,3709,3695,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,954,SUCCESS,,2457.026918,192,0,0.1,0.2,0.3,263,1.4,1.5
    4389,5/27/2021 0:05,17589.884,4.89,701,300,10,6001,0,65535,65535,1,21.3,25923,-296,-296,100,64,8,2450,3888,493,497,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3711,3712,3708,3695,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,948,SUCCESS,,2456.697371,192,0,0.1,0.2,0.3,263,1.4,1.5
    4390,5/27/2021 0:06,17593.887,4.89,701,300,10,6001,0,65535,65535,1,21.3,25923,-298,-297,100,64,8,2450,3888,497,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3707,3711,3712,3708,3695,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,944,SUCCESS,,2456.366011,192,0,0.1,0.2,0.3,263,1.4,1.5
    4391,5/27/2021 0:06,17597.899,4.89,4701,300,10,6001,0,65535,65535,1,21.3,25923,-298,-297,100,64,8,2450,3888,497,495,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3695,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,978,SUCCESS,,2456.033907,192,0,0.1,0.2,0.3,327,1.4,1.5
    4392,5/27/2021 0:06,17601.906,4.89,4701,300,10,6001,0,65535,65535,1,21.3,25923,-296,-297,100,63,8,2449,3888,496,495,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,20.9,942,SUCCESS,,2455.704443,192,0,0.1,0.2,0.3,327,1.4,1.5
    4393,5/27/2021 0:06,17605.905,4.89,4701,300,10,6001,0,65535,65535,1,21.3,25922,-296,-297,100,63,8,2449,3888,496,495,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,943,SUCCESS,,2455.375636,192,0,0.1,0.2,0.3,327,1.4,1.5
    4394,5/27/2021 0:06,17609.907,4.89,4701,300,10,6001,0,65535,65535,1,21.3,25922,-298,-296,100,63,8,2449,3888,496,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3694,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,987,SUCCESS,,2455.044359,192,0,0.1,0.2,0.3,327,1.4,1.5
    4395,5/27/2021 0:06,17613.922,4.89,701,300,10,6001,0,65535,65535,1,21.3,25922,-296,-297,100,63,8,2448,3888,496,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2454.714237,192,0,0.1,0.2,0.3,263,1.4,1.5
    4396,5/27/2021 0:06,17617.931,4.89,701,300,10,6001,0,65535,65535,1,21.3,25922,-296,-296,100,63,8,2448,3888,496,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3698,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,947,SUCCESS,,2454.384608,192,0,0.1,0.2,0.3,263,1.4,1.5
    4397,5/27/2021 0:06,17621.936,4.89,701,300,10,6001,0,65535,65535,1,21.3,25920,-298,-296,100,63,8,2448,3888,493,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3711,3712,3708,3694,3694,3693,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,977,SUCCESS,,2454.053083,192,0,0.1,0.2,0.3,263,1.4,1.5
    4398,5/27/2021 0:06,17625.947,4.9,701,300,10,6001,0,65535,65535,1,21.3,25920,-296,-296,100,63,8,2447,3888,496,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3710,3711,3708,3694,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,950,SUCCESS,,2453.72329,192,0,0.1,0.2,0.3,263,1.4,1.5
    4399,5/27/2021 0:06,17629.952,4.9,701,300,10,6001,0,65535,65535,1,21.3,25917,-296,-296,100,63,8,2447,3888,496,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3706,3710,3711,3707,3694,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2453.39399,192,0,0.1,0.2,0.3,263,1.4,1.5
    4400,5/27/2021 0:06,17633.964,4.9,701,300,10,6001,0,65535,65535,1,21.3,25915,-296,-296,100,63,8,2447,3888,496,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3693,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.5,945,SUCCESS,,2453.064114,192,0,0.1,0.2,0.3,263,1.4,1.5
    4401,5/27/2021 0:06,17637.969,4.9,701,300,10,6001,0,65535,65535,1,21.3,25915,-298,-296,100,63,8,2446,3888,492,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3694,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,941,SUCCESS,,2452.732589,192,0,0.1,0.2,0.3,263,1.4,1.5
    4402,5/27/2021 0:06,17641.982,4.9,701,300,10,6001,0,65535,65535,1,21.3,25915,-296,-296,100,63,8,2446,3888,496,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3693,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,964,SUCCESS,,2452.402631,192,0,0.1,0.2,0.3,327,1.4,1.5
    4403,5/27/2021 0:06,17645.997,4.9,4701,300,10,6001,0,65535,65535,1,21.3,25915,-296,-296,100,63,8,2446,3888,496,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3693,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,976,SUCCESS,,2452.072509,192,0,0.1,0.2,0.3,327,1.4,1.5
    4404,5/27/2021 0:06,17650.006,4.9,4701,300,10,6001,0,65535,65535,1,21.3,25915,-296,-296,100,63,8,2445,3888,496,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3693,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,956,SUCCESS,,2451.74288,192,0,0.1,0.2,0.3,327,1.4,1.5
    4405,5/27/2021 0:07,17654.007,4.9,4701,300,10,6001,0,65535,65535,1,21.3,25914,-296,-296,100,63,8,2445,3888,496,496,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,965,SUCCESS,,2451.413909,192,0,0.1,0.2,0.3,327,1.4,1.5
    4406,5/27/2021 0:07,17658.015,4.91,701,300,10,6001,0,65535,65535,1,21.3,25914,-296,-296,100,63,8,2445,3888,496,496,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3711,3707,3693,3697,3692,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,983,SUCCESS,,2451.084363,192,0,0.1,0.2,0.3,263,1.4,1.5
    4407,5/27/2021 0:07,17662.029,4.91,701,300,10,6001,0,65535,65535,1,21.3,25912,-294,-296,100,63,8,2444,3888,492,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3710,3707,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2450.756553,192,0,0.1,0.2,0.3,263,1.4,1.5
    4408,5/27/2021 0:07,17666.036,4.91,701,300,10,6001,0,65535,65535,1,21.3,25913,-296,-297,100,63,8,2444,3888,492,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3710,3710,3707,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.5,969,SUCCESS,,2450.427088,192,0,0.1,0.2,0.3,263,1.4,1.5
    4409,5/27/2021 0:07,17670.051,4.91,701,300,10,6001,0,65535,65535,1,21.3,25911,-294,-297,100,63,8,2444,3888,495,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3710,3710,3707,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,957,SUCCESS,,2450.099196,192,0,0.1,0.2,0.3,263,1.4,1.5
    4410,5/27/2021 0:07,17674.054,4.91,701,300,10,6001,0,65535,65535,1,21.3,25909,-296,-296,100,63,8,2443,3888,495,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,974,SUCCESS,,2449.770061,192,0,0.1,0.2,0.3,263,1.4,1.5
    4411,5/27/2021 0:07,17678.058,4.91,701,300,10,6001,0,65535,65535,1,21.3,25909,-296,-297,100,63,8,2443,3888,495,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2449.440843,192,0,0.1,0.2,0.3,263,1.4,1.5
    4412,5/27/2021 0:07,17682.06,4.91,701,300,10,6001,0,65535,65535,1,21.3,25909,-294,-296,100,63,8,2443,3888,495,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3693,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,944,SUCCESS,,2449.114013,192,0,0.1,0.2,0.3,263,1.4,1.5
    4413,5/27/2021 0:07,17686.071,4.91,701,300,10,6001,0,65535,65535,1,21.3,25908,-298,-296,100,63,8,2442,3888,492,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3705,3709,3710,3706,3692,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,947,SUCCESS,,2448.781991,192,0,0.1,0.2,0.3,263,1.4,1.5
    4414,5/27/2021 0:07,17690.087,4.91,4701,300,10,6001,0,65535,65535,1,21.3,25908,-298,-297,100,63,8,2442,3888,492,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3692,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,932,SUCCESS,,2448.449556,192,0,0.1,0.2,0.3,327,1.4,1.5
    4415,5/27/2021 0:07,17694.094,4.92,4701,300,10,6001,0,65535,65535,1,21.3,25907,-298,-297,100,63,8,2442,3888,492,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3692,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,955,SUCCESS,,2448.117865,192,0,0.1,0.2,0.3,327,1.4,1.5
    4416,5/27/2021 0:07,17698.102,4.92,4701,300,10,6001,0,65535,65535,1,21.3,25908,-296,-297,100,63,8,2441,3888,491,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3692,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,969,SUCCESS,,2447.788319,192,0,0.1,0.2,0.3,327,1.4,1.5
    4417,5/27/2021 0:07,17702.112,4.92,701,300,10,6001,0,65535,65535,1,21.3,25908,-296,-296,100,63,8,2441,3888,495,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3709,3710,3706,3692,3696,3691,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,957,SUCCESS,,2447.458608,192,0,0.1,0.2,0.3,263,1.4,1.5
    4418,5/27/2021 0:07,17706.124,4.92,701,300,10,6001,0,65535,65535,1,21.3,25905,-296,-296,100,63,8,2441,3888,495,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3708,3710,3706,3692,3696,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,943,SUCCESS,,2447.128732,192,0,0.1,0.2,0.3,263,1.4,1.5
    4419,5/27/2021 0:07,17710.129,4.92,701,300,10,6001,0,65535,65535,1,21.3,25905,-296,-296,100,63,8,2440,3888,495,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3708,3710,3705,3692,3695,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,955,SUCCESS,,2446.799432,192,0,0.1,0.2,0.3,263,1.4,1.5
    4420,5/27/2021 0:08,17714.141,4.92,701,300,10,6001,0,65535,65535,1,21.3,25903,-296,-296,100,63,8,2440,3888,495,495,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3708,3709,3705,3692,3695,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,957,SUCCESS,,2446.469556,192,0,0.1,0.2,0.3,263,1.4,1.5
    4421,5/27/2021 0:08,17718.143,4.92,4701,300,10,6001,0,65535,65535,1,21.3,25902,-298,-296,100,63,8,2440,3888,491,495,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3708,3709,3705,3691,3696,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,940,SUCCESS,,2446.13828,192,0,0.1,0.2,0.3,327,1.4,1.5
    4422,5/27/2021 0:08,17722.149,4.92,4701,300,10,6001,0,65535,65535,1,21.3,25902,-298,-296,100,63,8,2439,3888,494,494,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3709,3705,3691,3695,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,955,SUCCESS,,2445.806672,192,0,0.1,0.2,0.3,327,1.4,1.5
    4423,5/27/2021 0:08,17726.16,4.92,4701,300,10,6001,0,65535,65535,1,21.3,25902,-296,-296,100,63,8,2439,3888,494,494,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3704,3708,3709,3705,3691,3695,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,1002,SUCCESS,,2445.476879,192,0,0.1,0.2,0.3,327,1.4,1.5
    4424,5/27/2021 0:08,17730.17,4.93,4701,300,10,6001,0,65535,65535,1,21.3,25901,-298,-296,100,63,8,2439,3888,494,494,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3709,3705,3691,3695,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,959,SUCCESS,,2445.14494,192,0,0.1,0.2,0.3,327,1.4,1.5
    4425,5/27/2021 0:08,17734.174,4.93,701,300,10,6001,0,65535,65535,1,21.3,25901,-296,-296,100,63,8,2438,3888,491,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3709,3705,3691,3694,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2444.815722,192,0,0.1,0.2,0.3,263,1.4,1.5
    4426,5/27/2021 0:08,17738.182,4.93,701,300,10,6001,0,65535,65535,1,21.3,25901,-296,-296,100,63,8,2438,3888,494,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3709,3705,3691,3694,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,948,SUCCESS,,2444.486175,192,0,0.1,0.2,0.3,263,1.4,1.5
    4427,5/27/2021 0:08,17742.19,4.93,701,300,10,6001,0,65535,65535,1,21.3,25901,-296,-297,100,63,8,2438,3888,491,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3709,3705,3691,3695,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.3,940,SUCCESS,,2444.156629,192,0,0.1,0.2,0.3,263,1.4,1.5
    4428,5/27/2021 0:08,17746.202,4.93,701,300,10,6001,0,65535,65535,1,21.3,25898,-296,-296,100,63,8,2437,3888,494,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3708,3705,3691,3694,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,943,SUCCESS,,2443.826753,192,0,0.1,0.2,0.3,263,1.4,1.5
    4429,5/27/2021 0:08,17750.206,4.93,701,300,10,6001,0,65535,65535,1,21.3,25900,-296,-297,100,63,8,2437,3888,491,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3708,3705,3691,3694,3690,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,954,SUCCESS,,2443.497535,192,0,0.1,0.2,0.3,263,1.4,1.5
    4430,5/27/2021 0:08,17754.211,4.93,701,300,10,6001,0,65535,65535,1,21.3,25899,-296,-297,100,63,8,2437,3888,491,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3703,3708,3708,3705,3691,3694,3689,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2443.168235,192,0,0.1,0.2,0.3,263,1.4,1.5
    4431,5/27/2021 0:08,17758.226,4.93,701,300,10,6001,0,65535,65535,1,21.3,25896,-296,-296,100,63,8,2436,3888,494,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3705,3691,3694,3690,0,0,0,0,0,0,0,0,2586,21.1,21.3,-273.2,21.3,-273.2,21.4,950,SUCCESS,,2442.838113,192,0,0.1,0.2,0.3,263,1.4,1.5
    4432,5/27/2021 0:08,17762.242,4.93,701,300,10,6001,0,65535,65535,1,21.3,25896,-296,-296,100,63,8,2436,3888,490,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3694,3689,0,0,0,0,0,0,0,0,2586,21.1,21.3,-273.2,21.3,-273.2,21.4,932,SUCCESS,,2442.507909,192,0,0.1,0.2,0.3,263,1.4,1.5
    4433,5/27/2021 0:08,17766.256,4.94,701,300,10,6001,0,65535,65535,1,21.3,25893,-298,-296,100,63,8,2436,3888,494,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3694,3689,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2442.175639,192,0,0.1,0.2,0.3,263,1.4,1.5
    4434,5/27/2021 0:08,17770.27,4.94,701,300,10,6001,0,65535,65535,1,21.3,25894,-296,-296,100,63,8,2435,3888,494,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3694,3689,0,0,0,0,0,0,0,0,2590,21.1,21.3,-273.2,21.3,-273.2,21.4,984,SUCCESS,,2441.845599,192,0,0.1,0.2,0.3,263,1.4,1.5
    4435,5/27/2021 0:09,17774.284,4.94,701,300,10,6001,0,65535,65535,1,21.3,25894,-298,-296,100,63,8,2435,3888,490,494,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3694,3689,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,988,SUCCESS,,2441.513329,192,0,0.1,0.2,0.3,263,1.4,1.5
    4436,5/27/2021 0:09,17778.292,4.94,4701,300,10,6001,0,65535,65535,1,21.3,25894,-294,-296,100,63,8,2435,3888,497,494,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3694,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,965,SUCCESS,,2441.186009,192,0,0.1,0.2,0.3,327,1.4,1.5
    4437,5/27/2021 0:09,17782.304,4.94,4701,300,10,6001,0,65535,65535,1,21.3,25894,-296,-296,100,63,8,2434,3888,493,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3693,3689,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,966,SUCCESS,,2440.856133,192,0,0.1,0.2,0.3,327,1.4,1.5
    4438,5/27/2021 0:09,17786.314,4.94,4701,300,10,6001,0,65535,65535,1,21.3,25893,-296,-296,100,63,8,2434,3888,493,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3694,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,989,SUCCESS,,2440.526422,192,0,0.1,0.2,0.3,327,1.4,1.5
    4439,5/27/2021 0:09,17790.319,4.94,4701,300,10,6001,0,65535,65535,1,21.3,25892,-296,-296,100,63,8,2434,3888,493,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,973,SUCCESS,,2440.197122,192,0,0.1,0.2,0.3,327,1.4,1.5
    4440,5/27/2021 0:09,17794.319,4.94,701,300,10,6001,0,65535,65535,1,21.3,25892,-296,-296,100,63,8,2433,3888,493,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3707,3708,3704,3690,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2439.868233,192,0,0.1,0.2,0.3,263,1.4,1.5
    4441,5/27/2021 0:09,17798.332,4.94,701,300,10,6001,0,65535,65535,1,21.3,25890,-298,-297,100,63,8,2433,3888,490,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3706,3708,3704,3689,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2439.536046,192,0,0.1,0.2,0.3,263,1.4,1.5
    4442,5/27/2021 0:09,17802.336,4.95,701,300,10,6001,0,65535,65535,1,21.3,25892,-296,-296,100,63,8,2433,3888,493,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3706,3707,3704,3690,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,966,SUCCESS,,2439.206828,192,0,0.1,0.2,0.3,263,1.4,1.5
    4443,5/27/2021 0:09,17806.336,4.95,4701,300,10,6001,0,65535,65535,1,21.3,25889,-294,-296,100,63,8,2432,3888,496,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3706,3707,3703,3690,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,980,SUCCESS,,2438.880161,192,0,0.1,0.2,0.3,327,1.4,1.5
    4444,5/27/2021 0:09,17810.342,4.95,4701,300,10,6001,0,65535,65535,1,21.3,25887,-296,-296,100,63,8,2432,3888,493,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3702,3706,3707,3703,3689,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,944,SUCCESS,,2438.550779,192,0,0.1,0.2,0.3,327,1.4,1.5
    4445,5/27/2021 0:09,17814.355,4.95,4701,300,10,6001,0,65535,65535,1,21.3,25886,-298,-296,100,63,8,2432,3888,490,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3706,3707,3703,3689,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,960,SUCCESS,,2438.218592,192,0,0.1,0.2,0.3,327,1.4,1.5
    4446,5/27/2021 0:09,17818.366,4.95,4701,300,10,6001,0,65535,65535,1,21.3,25887,-296,-296,100,63,8,2431,3888,493,493,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3706,3707,3703,3689,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,968,SUCCESS,,2437.888799,192,0,0.1,0.2,0.3,327,1.4,1.5
    4447,5/27/2021 0:09,17822.372,4.95,701,300,10,6001,0,65535,65535,1,21.3,25887,-296,-296,100,63,8,2431,3888,493,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3706,3707,3703,3689,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2437.559416,192,0,0.1,0.2,0.3,263,1.4,1.5
    4448,5/27/2021 0:09,17826.381,4.95,701,300,10,6001,0,65535,65535,1,21.3,25886,-296,-296,100,63,8,2431,3888,486,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3706,3707,3703,3689,3693,3688,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,966,SUCCESS,,2437.229788,192,0,0.1,0.2,0.3,263,1.4,1.5
    4449,5/27/2021 0:09,17830.394,4.95,701,300,10,6001,0,65535,65535,1,21.3,25886,-298,-296,100,63,8,2430,3888,493,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3705,3707,3703,3689,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,20.8,941,SUCCESS,,2436.8976,192,0,0.1,0.2,0.3,263,1.4,1.5
    4450,5/27/2021 0:10,17834.394,4.95,701,300,10,6001,0,65535,65535,1,21.3,25885,-296,-296,100,63,8,2430,3888,496,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3705,3707,3703,3688,3693,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,971,SUCCESS,,2436.568711,192,0,0.1,0.2,0.3,263,1.4,1.5
    4451,5/27/2021 0:10,17838.396,4.96,701,300,10,6001,0,65535,65535,1,21.3,25885,-296,-296,100,63,8,2430,3888,489,493,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3705,3707,3703,3689,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,938,SUCCESS,,2436.239658,192,0,0.1,0.2,0.3,263,1.4,1.5
    4452,5/27/2021 0:10,17842.399,4.96,701,300,10,6001,0,65535,65535,1,21.3,25882,-296,-296,100,63,8,2429,3888,489,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3705,3706,3702,3688,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,965,SUCCESS,,2435.910523,192,0,0.1,0.2,0.3,263,1.4,1.5
    4453,5/27/2021 0:10,17846.412,4.96,701,300,10,6001,0,65535,65535,1,21.3,25881,-296,-296,100,63,8,2429,3888,489,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3705,3706,3702,3688,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2435.580565,192,0,0.1,0.2,0.3,263,1.4,1.5
    4454,5/27/2021 0:10,17850.42,4.96,701,300,10,6001,0,65535,65535,1,21.3,25882,-296,-296,100,63,8,2429,3888,492,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3701,3705,3706,3702,3688,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,943,SUCCESS,,2435.251018,192,0,0.1,0.2,0.3,263,1.4,1.5
    4455,5/27/2021 0:10,17854.431,4.96,4701,300,10,6001,0,65535,65535,1,21.3,25880,-294,-296,100,63,8,2429,3888,496,492,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3706,3702,3688,3691,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2434.923453,192,0,0.1,0.2,0.3,327,1.4,1.5
    4456,5/27/2021 0:10,17858.441,4.96,4701,300,10,6001,0,65535,65535,1,21.3,25880,-296,-296,100,63,8,2428,3888,492,492,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3706,3702,3688,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,961,SUCCESS,,2434.593742,192,0,0.1,0.2,0.3,327,1.4,1.5
    4457,5/27/2021 0:10,17862.445,4.96,4701,300,10,6001,0,65535,65535,1,21.3,25881,-296,-296,100,63,8,2428,3888,492,492,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3706,3702,3688,3692,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,1003,SUCCESS,,2434.264524,192,0,0.1,0.2,0.3,327,1.4,1.5
    4458,5/27/2021 0:10,17866.454,4.96,701,300,10,6001,0,65535,65535,1,21.3,25879,-296,-296,100,63,8,2428,3888,496,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3706,3702,3688,3691,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,974,SUCCESS,,2433.934895,192,0,0.1,0.2,0.3,263,1.4,1.5
    4459,5/27/2021 0:10,17870.463,4.96,701,300,10,6001,0,65535,65535,1,21.3,25880,-298,-296,100,63,8,2427,3888,489,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3706,3702,3688,3691,3687,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,932,SUCCESS,,2433.603039,192,0,0.1,0.2,0.3,263,1.4,1.5
    4460,5/27/2021 0:10,17874.478,4.97,701,300,10,6001,0,65535,65535,1,21.3,25878,-294,-296,100,63,8,2427,3888,492,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3706,3702,3688,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,938,SUCCESS,,2433.275148,192,0,0.1,0.2,0.3,263,1.4,1.5
    4461,5/27/2021 0:10,17878.487,4.97,701,300,10,6001,0,65535,65535,1,21.3,25878,-298,-296,100,63,8,2427,3888,492,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3705,3705,3702,3688,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,955,SUCCESS,,2432.943291,192,0,0.1,0.2,0.3,263,1.4,1.5
    4462,5/27/2021 0:10,17882.498,4.97,701,300,10,6001,0,65535,65535,1,21.3,25876,-294,-296,100,63,8,2426,3888,488,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3704,3705,3701,3687,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,942,SUCCESS,,2432.615726,192,0,0.1,0.2,0.3,263,1.4,1.5
    4463,5/27/2021 0:10,17886.509,4.97,701,300,10,6001,0,65535,65535,1,21.3,25876,-296,-296,100,63,8,2426,3888,488,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3700,3704,3705,3701,3688,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,20.8,934,SUCCESS,,2432.285933,192,0,0.1,0.2,0.3,263,1.4,1.5
    4464,5/27/2021 0:10,17890.509,4.97,701,300,10,6001,0,65535,65535,1,21.3,25875,-296,-296,100,63,8,2426,3888,492,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3688,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,994,SUCCESS,,2431.957044,192,0,0.1,0.2,0.3,263,1.4,1.5
    4465,5/27/2021 0:11,17894.515,4.97,701,300,10,6001,0,65535,65535,1,21.3,25874,-294,-296,100,63,8,2425,3888,488,492,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3688,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,959,SUCCESS,,2431.629888,192,0,0.1,0.2,0.3,263,1.4,1.5
    4466,5/27/2021 0:11,17898.526,4.97,4701,300,10,6001,0,65535,65535,1,21.3,25873,-296,-296,100,63,8,2425,3888,492,492,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,930,SUCCESS,,2431.300094,192,0,0.1,0.2,0.3,327,1.4,1.5
    4467,5/27/2021 0:11,17902.526,4.97,4701,300,10,6001,0,65535,65535,1,21.3,25873,-296,-296,100,63,8,2425,3888,491,491,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,962,SUCCESS,,2430.971205,192,0,0.1,0.2,0.3,327,1.4,1.5
    4468,5/27/2021 0:11,17906.537,4.97,4701,300,10,6001,0,65535,65535,1,21.3,25873,-294,-296,100,63,8,2424,3888,491,491,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2430.64364,192,0,0.1,0.2,0.3,327,1.4,1.5
    4469,5/27/2021 0:11,17910.541,4.98,4701,300,10,6001,0,65535,65535,1,21.3,25872,-296,-296,100,63,8,2424,3888,495,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3691,3685,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.3,947,SUCCESS,,2430.314423,192,0,0.1,0.2,0.3,263,1.4,1.5
    4470,5/27/2021 0:11,17914.553,4.98,701,300,10,6001,0,65535,65535,1,21.3,25872,-294,-296,100,63,8,2423,3888,494,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3691,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,971,SUCCESS,,2429.986776,192,0,0.1,0.2,0.3,263,1.4,1.5
    4471,5/27/2021 0:11,17918.555,4.98,701,300,10,6001,0,65535,65535,1,21.3,25872,-294,-296,100,63,8,2423,3888,494,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3690,3686,0,0,0,0,0,0,0,0,2585,21.1,21.3,-273.2,21.3,-273.2,21.4,956,SUCCESS,,2429.659946,192,0,0.1,0.2,0.3,263,1.4,1.5
    4472,5/27/2021 0:11,17922.566,4.98,701,300,10,6001,0,65535,65535,1,21.3,25872,-296,-296,100,63,8,2423,3888,491,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3705,3701,3687,3692,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,955,SUCCESS,,2429.330153,192,0,0.1,0.2,0.3,263,1.4,1.5
    4473,5/27/2021 0:11,17926.574,4.98,4701,300,10,6001,0,65535,65535,1,21.3,25871,-296,-296,100,63,8,2423,3888,491,491,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3704,3704,3701,3687,3691,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,951,SUCCESS,,2429.000606,192,0,0.1,0.2,0.3,327,1.4,1.5
    4474,5/27/2021 0:11,17930.575,4.98,4701,300,10,6001,0,65535,65535,1,21.3,25870,-298,-296,100,63,8,2422,3888,488,491,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3703,3704,3701,3687,3690,3686,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,944,SUCCESS,,2428.669412,192,0,0.1,0.2,0.3,327,1.4,1.5
    4475,5/27/2021 0:11,17934.587,4.98,4701,300,10,6001,0,65535,65535,1,21.3,25868,-298,-296,100,63,8,2422,3888,488,491,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3703,3704,3700,3687,3692,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,932,SUCCESS,,2428.337308,192,0,0.1,0.2,0.3,327,1.4,1.5
    4476,5/27/2021 0:11,17938.596,4.98,4701,300,10,6001,0,65535,65535,1,21.3,25867,-296,-296,100,63,8,2422,3888,491,491,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3703,3704,3700,3687,3690,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,971,SUCCESS,,2428.007679,192,0,0.1,0.2,0.3,327,1.4,1.5
    4477,5/27/2021 0:11,17942.605,4.98,701,300,10,6001,0,65535,65535,1,21.3,25866,-294,-296,100,63,8,2421,3888,494,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3699,3703,3704,3700,3685,3690,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.1,978,SUCCESS,,2427.680277,192,0,0.1,0.2,0.3,263,1.4,1.5
    4478,5/27/2021 0:11,17946.606,4.99,701,300,10,6001,0,65535,65535,1,21.3,25866,-298,-296,100,63,8,2421,3888,487,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3703,3704,3700,3686,3692,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,945,SUCCESS,,2427.349083,192,0,0.1,0.2,0.3,263,1.4,1.5
    4479,5/27/2021 0:11,17950.61,4.99,701,300,10,6001,0,65535,65535,1,21.3,25865,-294,-296,100,63,8,2421,3888,494,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3703,3704,3700,3686,3690,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,949,SUCCESS,,2427.02209,192,0,0.1,0.2,0.3,263,1.4,1.5
    4480,5/27/2021 0:12,17954.623,4.99,701,300,10,6001,0,65535,65535,1,21.3,25866,-296,-296,100,63,8,2420,3888,494,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3703,3704,3700,3686,3690,3685,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,945,SUCCESS,,2426.692132,192,0,0.1,0.2,0.3,263,1.4,1.5
    4481,5/27/2021 0:12,17958.634,4.99,701,300,10,6001,0,65535,65535,1,21.3,25865,-296,-296,100,63,8,2420,3888,491,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3703,3704,3700,3686,3690,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,949,SUCCESS,,2426.362339,192,0,0.1,0.2,0.3,263,1.4,1.5
    4482,5/27/2021 0:12,17962.639,4.99,701,300,10,6001,0,65535,65535,1,21.3,25863,-294,-296,100,63,8,2420,3888,491,491,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3702,3704,3699,3686,3690,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21,949,SUCCESS,,2426.035264,192,0,0.1,0.2,0.3,263,1.4,1.5
    4483,5/27/2021 0:12,17966.643,4.99,701,300,10,6001,0,65535,65535,1,21.3,25862,-298,-296,100,63,8,2419,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3702,3704,3699,3686,3690,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,957,SUCCESS,,2425.703821,192,0,0.1,0.2,0.3,263,1.4,1.5
    4484,5/27/2021 0:12,17970.657,4.99,701,300,10,6001,0,65535,65535,1,21.3,25861,-296,-296,100,63,8,2419,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3702,3703,3699,3685,3690,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,958,SUCCESS,,2425.373781,192,0,0.1,0.2,0.3,263,1.4,1.5
    4485,5/27/2021 0:12,17974.666,4.99,701,300,10,6001,0,65535,65535,1,21.3,25861,-294,-296,100,63,8,2419,3888,494,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3702,3703,3699,3685,3690,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,962,SUCCESS,,2425.04638,192,0,0.1,0.2,0.3,263,1.4,1.5
    4486,5/27/2021 0:12,17978.675,4.99,701,300,10,6001,0,65535,65535,1,21.3,25861,-296,-296,100,63,8,2418,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3702,3704,3699,3685,3689,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,938,SUCCESS,,2424.716751,192,0,0.1,0.2,0.3,263,1.4,1.5
    4487,5/27/2021 0:12,17982.689,5,701,300,10,6001,0,65535,65535,1,21.3,25860,-296,-296,100,63,8,2418,3888,487,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3698,3702,3703,3699,3685,3690,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,962,SUCCESS,,2424.386711,192,0,0.1,0.2,0.3,263,1.4,1.5
    4488,5/27/2021 0:12,17986.694,5,4701,300,10,6001,0,65535,65535,1,21.3,25858,-296,-296,100,63,8,2418,3888,490,490,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3703,3699,3685,3689,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,933,SUCCESS,,2424.057411,192,0,0.1,0.2,0.3,327,1.4,1.5
    4489,5/27/2021 0:12,17990.7,5,4701,300,10,6001,0,65535,65535,1,21.3,25858,-296,-296,100,63,8,2417,3888,490,490,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3703,3699,3685,3689,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,961,SUCCESS,,2423.728029,192,0,0.1,0.2,0.3,327,1.4,1.5
    4490,5/27/2021 0:12,17994.714,5,4701,300,10,6001,0,65535,65535,1,21.3,25859,-294,-296,100,63,8,2417,3888,490,490,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3703,3699,3685,3689,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2423.400219,192,0,0.1,0.2,0.3,327,1.4,1.5
    4491,5/27/2021 0:12,17998.72,5,4701,300,10,6001,0,65535,65535,1,21.3,25858,-296,-296,100,63,8,2417,3888,490,490,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3703,3699,3685,3689,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,954,SUCCESS,,2423.070836,192,0,0.1,0.2,0.3,327,1.4,1.5
    4492,5/27/2021 0:12,18002.736,5,701,300,10,6001,0,65535,65535,1,21.3,25859,-296,-296,100,63,8,2416,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3703,3699,3685,3688,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,938,SUCCESS,,2422.740632,192,0,0.1,0.2,0.3,263,1.4,1.5
    4493,5/27/2021 0:12,18006.739,5,701,300,10,6001,0,65535,65535,1,21.3,25857,-296,-296,100,63,8,2416,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3702,3699,3685,3689,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,982,SUCCESS,,2422.411496,192,0,0.1,0.2,0.3,263,1.4,1.5
    4494,5/27/2021 0:12,18010.751,5,701,300,10,6001,0,65535,65535,1,21.3,25857,-298,-296,100,63,8,2416,3888,486,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3701,3703,3699,3685,3688,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,964,SUCCESS,,2422.079392,192,0,0.1,0.2,0.3,263,1.4,1.5
    4495,5/27/2021 0:13,18014.752,5,701,300,10,6001,0,65535,65535,1,21.3,25854,-298,-296,100,63,8,2415,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3702,3702,3699,3685,3688,3683,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,954,SUCCESS,,2421.748198,192,0,0.1,0.2,0.3,263,1.4,1.5
    4496,5/27/2021 0:13,18018.76,5.01,701,300,10,6001,0,65535,65535,1,21.3,25853,-296,-296,100,63,8,2415,3888,486,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3701,3702,3698,3685,3688,3684,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2421.418651,192,0,0.1,0.2,0.3,263,1.4,1.5
    4497,5/27/2021 0:13,18022.782,5.01,701,300,10,6001,0,65535,65535,1,21.3,25854,-296,-296,100,63,8,2415,3888,490,490,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3697,3701,3702,3698,3685,3688,3683,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2421.087954,192,0,0.1,0.2,0.3,263,1.4,1.5
    4498,5/27/2021 0:13,18026.783,5.01,701,300,10,6001,0,65535,65535,1,21.3,25852,-296,-296,100,63,8,2414,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3688,3683,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,941,SUCCESS,,2420.758983,192,0,0.1,0.2,0.3,263,1.4,1.5
    4499,5/27/2021 0:13,18030.797,5.01,4701,300,10,6001,0,65535,65535,1,21.3,25852,-296,-296,100,63,8,2414,3888,489,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3688,3683,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.3,947,SUCCESS,,2420.428943,192,0,0.1,0.2,0.3,327,1.4,1.5
    4500,5/27/2021 0:13,18034.813,5.01,4701,300,10,6001,0,65535,65535,1,21.3,25852,-294,-296,100,63,8,2414,3888,493,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3688,3683,0,0,0,0,0,0,0,0,2585,21,21.3,-273.2,21.3,-273.2,21.4,943,SUCCESS,,2420.100969,192,0,0.1,0.2,0.3,327,1.4,1.5
    4501,5/27/2021 0:13,18038.814,5.01,4701,300,10,6001,0,65535,65535,1,21.3,25852,-296,-296,100,63,8,2413,3888,489,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3688,3683,0,0,0,0,0,0,0,0,2584,21,21.3,-273.2,21.3,-273.2,21.4,954,SUCCESS,,2419.771998,192,0,0.1,0.2,0.3,327,1.4,1.5
    4502,5/27/2021 0:13,18042.814,5.01,4701,300,10,6001,0,65535,65535,1,21.3,25852,-298,-296,100,63,8,2413,3888,486,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3688,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,971,SUCCESS,,2419.440887,192,0,0.1,0.2,0.3,327,1.4,1.5
    4503,5/27/2021 0:13,18046.845,5.01,701,300,10,6001,0,65535,65535,1,21.3,25852,-296,-296,100,63,8,2413,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3688,3683,0,0,0,0,0,0,0,0,2582,21,21.3,-273.2,21.3,-273.2,21.3,943,SUCCESS,,2419.109449,192,0,0.1,0.2,0.3,263,1.4,1.5
    4504,5/27/2021 0:13,18050.843,5.01,701,300,10,6001,0,65535,65535,1,21.3,25850,-300,-296,100,63,8,2412,3888,482,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3701,3702,3698,3684,3687,3682,0,0,0,0,0,0,0,0,2584,21,21.3,-273.2,21.3,-273.2,21.4,981,SUCCESS,,2418.776283,192,0,0.1,0.2,0.3,263,1.4,1.5
    4505,5/27/2021 0:13,18054.859,5.02,701,300,10,6001,0,65535,65535,1,21.3,25850,-296,-296,100,63,8,2412,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3701,3702,3698,3684,3688,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,947,SUCCESS,,2418.446078,192,0,0.1,0.2,0.3,263,1.4,1.5
    4506,5/27/2021 0:13,18058.876,5.02,701,300,10,6001,0,65535,65535,1,21.3,25848,-296,-296,100,63,8,2412,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3700,3701,3697,3684,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,938,SUCCESS,,2418.115791,192,0,0.1,0.2,0.3,263,1.4,1.5
    4507,5/27/2021 0:13,18062.893,5.02,4701,300,10,6001,0,65535,65535,1,21.3,25847,-298,-296,100,63,8,2411,3888,485,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3696,3700,3701,3697,3684,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,937,SUCCESS,,2417.783273,192,0,0.1,0.2,0.3,327,1.4,1.5
    4508,5/27/2021 0:13,18066.906,5.02,4701,300,10,6001,0,65535,65535,1,21.3,25846,-296,-296,100,63,8,2411,3888,489,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3700,3701,3697,3684,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,956,SUCCESS,,2417.453315,192,0,0.1,0.2,0.3,327,1.4,1.5
    4509,5/27/2021 0:13,18070.907,5.02,4701,300,10,6001,0,65535,65535,1,21.3,25846,-296,-296,100,63,8,2411,3888,489,489,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3700,3701,3697,3684,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,953,SUCCESS,,2417.124344,192,0,0.1,0.2,0.3,327,1.4,1.5
    4510,5/27/2021 0:14,18074.923,5.02,701,300,10,6001,0,65535,65535,1,21.3,25846,-296,-296,100,62,8,2410,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3700,3701,3697,3683,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,954,SUCCESS,,2416.79414,192,0,0.1,0.2,0.3,263,1.4,1.5
    4511,5/27/2021 0:14,18078.938,5.02,701,300,10,6001,0,65535,65535,1,21.3,25845,-296,-296,100,62,8,2410,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3700,3701,3697,3683,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,956,SUCCESS,,2416.464018,192,0,0.1,0.2,0.3,263,1.4,1.5
    4512,5/27/2021 0:14,18082.938,5.02,701,300,10,6001,0,65535,65535,1,21.3,25845,-296,-296,100,62,8,2410,3888,489,489,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3699,3701,3697,3683,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2416.135129,192,0,0.1,0.2,0.3,263,1.4,1.5
    4513,5/27/2021 0:14,18086.954,5.02,701,300,10,6001,0,65535,65535,1,21.3,25845,-296,-296,100,62,8,2409,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3699,3701,3697,3683,3687,3682,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,944,SUCCESS,,2415.804924,192,0,0.1,0.2,0.3,263,1.4,1.5
    4514,5/27/2021 0:14,18090.969,5.03,701,300,10,6001,0,65535,65535,1,21.3,25843,-296,-296,100,62,8,2409,3888,485,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3699,3701,3696,3683,3687,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,943,SUCCESS,,2415.474802,192,0,0.1,0.2,0.3,263,1.4,1.5
    4515,5/27/2021 0:14,18094.985,5.03,701,300,10,6001,0,65535,65535,1,21.3,25841,-296,-296,100,62,8,2409,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3699,3700,3696,3683,3687,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2415.144598,192,0,0.1,0.2,0.3,263,1.4,1.5
    4516,5/27/2021 0:14,18098.91,5.03,701,300,10,6001,0,65535,65535,1,21.3,25841,-296,-296,100,62,8,2408,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3695,3699,3701,3696,3682,3686,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,973,SUCCESS,,2414.821875,192,0,0.1,0.2,0.3,263,1.4,1.5
    4517,5/27/2021 0:14,18102.925,5.03,701,300,10,6001,0,65535,65535,1,21.3,25842,-296,-296,100,62,8,2408,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3701,3696,3682,3687,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,985,SUCCESS,,2414.491753,192,0,0.1,0.2,0.3,263,1.4,1.5
    4518,5/27/2021 0:14,18106.934,5.03,701,300,10,6001,0,65535,65535,1,21.3,25840,-298,-296,100,62,8,2408,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3686,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,949,SUCCESS,,2414.159897,192,0,0.1,0.2,0.3,263,1.4,1.5
    4519,5/27/2021 0:14,18110.942,5.03,701,300,10,6001,0,65535,65535,1,21.3,25838,-296,-296,100,62,8,2407,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3686,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,936,SUCCESS,,2413.83035,192,0,0.1,0.2,0.3,263,1.4,1.5
    4520,5/27/2021 0:14,18114.956,5.03,701,300,10,6001,0,65535,65535,1,21.3,25839,-298,-296,100,62,8,2407,3888,488,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3687,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,20.8,937,SUCCESS,,2413.49808,192,0,0.1,0.2,0.3,263,1.4,1.5
    4521,5/27/2021 0:14,18118.96,5.03,701,300,10,6001,0,65535,65535,1,21.3,25838,-298,-296,100,62,8,2407,3888,485,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3686,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,964,SUCCESS,,2413.166638,192,0,0.1,0.2,0.3,263,1.4,1.5
    4522,5/27/2021 0:14,18122.963,5.03,4701,300,10,6001,0,65535,65535,1,21.3,25837,-294,-296,100,62,8,2406,3888,488,488,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3686,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2412.839726,192,0,0.1,0.2,0.3,327,1.4,1.5
    4523,5/27/2021 0:14,18126.975,5.04,4701,300,10,6001,0,65535,65535,1,21.3,25838,-296,-296,100,62,8,2406,3888,484,488,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3686,3681,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,935,SUCCESS,,2412.509851,192,0,0.1,0.2,0.3,327,1.4,1.5
    4524,5/27/2021 0:14,18130.98,5.04,4701,300,10,6001,0,65535,65535,1,21.3,25837,-296,-296,100,62,8,2406,3888,488,488,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3700,3696,3682,3686,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,961,SUCCESS,,2412.180551,192,0,0.1,0.2,0.3,327,1.4,1.5
    4525,5/27/2021 0:15,18134.994,5.04,701,300,10,6001,0,65535,65535,1,21.3,25836,-296,-296,100,62,8,2405,3888,491,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3699,3699,3695,3682,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,978,SUCCESS,,2411.850511,192,0,0.1,0.2,0.3,263,1.4,1.5
    4526,5/27/2021 0:15,18139.009,5.04,701,300,10,6001,0,65535,65535,1,21.3,25835,-296,-296,100,62,8,2405,3888,484,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3698,3699,3695,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,995,SUCCESS,,2411.520389,192,0,0.1,0.2,0.3,263,1.4,1.5
    4527,5/27/2021 0:15,18143.015,5.04,701,300,10,6001,0,65535,65535,1,21.3,25834,-296,-296,100,62,8,2405,3888,484,488,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3698,3699,3696,3682,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,939,SUCCESS,,2411.191006,192,0,0.1,0.2,0.3,263,1.4,1.5
    4528,5/27/2021 0:15,18147.026,5.04,701,300,10,6001,0,65535,65535,1,21.3,25831,-296,-296,100,62,8,2404,3888,487,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3698,3699,3695,3682,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,975,SUCCESS,,2410.861213,192,0,0.1,0.2,0.3,263,1.4,1.5
    4529,5/27/2021 0:15,18151.032,5.04,4701,300,10,6001,0,65535,65535,1,21.3,25836,-296,-296,100,62,8,2404,3888,484,487,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3695,3682,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,952,SUCCESS,,2410.531831,192,0,0.1,0.2,0.3,327,1.4,1.5
    4530,5/27/2021 0:15,18155.037,5.04,4701,300,10,6001,0,65535,65535,1,21.3,25832,-296,-296,100,62,8,2404,3888,487,487,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3694,3698,3699,3695,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,935,SUCCESS,,2410.202531,192,0,0.1,0.2,0.3,327,1.4,1.5
    4531,5/27/2021 0:15,18159.041,5.04,4701,300,10,6001,0,65535,65535,1,21.3,25831,-296,-296,100,62,8,2403,3888,487,487,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3695,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,946,SUCCESS,,2409.873313,192,0,0.1,0.2,0.3,327,1.4,1.5
    4532,5/27/2021 0:15,18163.054,5.05,4701,300,10,6001,0,65535,65535,1,21.3,25835,-296,-296,100,62,8,2403,3888,487,487,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3695,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,955,SUCCESS,,2409.543355,192,0,0.1,0.2,0.3,327,1.4,1.5
    4533,5/27/2021 0:15,18167.057,5.05,701,300,10,6001,0,65535,65535,1,21.3,25830,-296,-296,100,62,8,2403,3888,490,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3695,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,945,SUCCESS,,2409.21422,192,0,0.1,0.2,0.3,263,1.4,1.5
    4534,5/27/2021 0:15,18171.072,5.05,701,300,10,6001,0,65535,65535,1,21.3,25831,-296,-296,100,62,8,2402,3888,490,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3694,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,20.9,962,SUCCESS,,2408.884098,192,0,0.1,0.2,0.3,263,1.4,1.5
    4535,5/27/2021 0:15,18175.083,5.05,701,300,10,6001,0,65535,65535,1,21.3,25831,-296,-296,100,62,8,2402,3888,487,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3694,3681,3685,3680,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,965,SUCCESS,,2408.554304,192,0,0.1,0.2,0.3,263,1.4,1.5
    4536,5/27/2021 0:15,18179.093,5.05,701,300,10,6001,0,65535,65535,1,21.3,25829,-298,-296,100,62,8,2402,3888,484,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,941,SUCCESS,,2408.222365,192,0,0.1,0.2,0.3,263,1.4,1.5
    4537,5/27/2021 0:15,18183.101,5.05,701,300,10,6001,0,65535,65535,1,21.3,25827,-298,-296,100,62,8,2401,3888,483,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,966,SUCCESS,,2407.890592,192,0,0.1,0.2,0.3,263,1.4,1.5
    4538,5/27/2021 0:15,18187.105,5.05,701,300,10,6001,0,65535,65535,1,21.3,25827,-294,-296,100,62,8,2401,3888,490,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3698,3699,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,950,SUCCESS,,2407.563599,192,0,0.1,0.2,0.3,263,1.4,1.5
    4539,5/27/2021 0:15,18191.11,5.05,701,300,10,6001,0,65535,65535,1,21.3,25826,-300,-296,100,62,8,2401,3888,480,487,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3697,3698,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,938,SUCCESS,,2407.229849,192,0,0.1,0.2,0.3,263,1.4,1.5
    4540,5/27/2021 0:16,18195.114,5.05,4701,300,10,6001,0,65535,65535,1,21.3,25825,-296,-296,100,62,8,2400,3888,486,486,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3697,3698,3694,3680,3682,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,939,SUCCESS,,2406.900631,192,0,0.1,0.2,0.3,327,1.4,1.5
    4541,5/27/2021 0:16,18199.125,5.06,4701,300,10,6001,0,65535,65535,1,21.3,25825,-298,-296,100,62,8,2400,3888,483,486,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3697,3698,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,945,SUCCESS,,2406.568609,192,0,0.1,0.2,0.3,327,1.4,1.5
    4542,5/27/2021 0:16,18203.132,5.06,4701,300,10,6001,0,65535,65535,1,21.3,25825,-298,-296,100,62,8,2400,3888,483,486,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3693,3697,3698,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,996,SUCCESS,,2406.236919,192,0,0.1,0.2,0.3,327,1.4,1.5
    4543,5/27/2021 0:16,18207.14,5.06,4701,300,10,6001,0,65535,65535,1,21.3,25824,-296,-296,100,62,8,2399,3888,486,486,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3697,3698,3694,3680,3683,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,940,SUCCESS,,2405.907372,192,0,0.1,0.2,0.3,327,1.4,1.5
    4544,5/27/2021 0:16,18211.151,5.06,701,300,10,6001,0,65535,65535,1,21.3,25824,-296,-296,100,62,8,2399,3888,486,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3697,3698,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,944,SUCCESS,,2405.577579,192,0,0.1,0.2,0.3,263,1.4,1.5
    4545,5/27/2021 0:16,18215.153,5.06,701,300,10,6001,0,65535,65535,1,21.3,25822,-300,-296,100,62,8,2399,3888,483,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3696,3698,3694,3680,3684,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,965,SUCCESS,,2405.244079,192,0,0.1,0.2,0.3,263,1.4,1.5
    4546,5/27/2021 0:16,18219.154,5.06,701,300,10,6001,0,65535,65535,1,21.3,25822,-296,-296,100,62,8,2398,3888,486,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3696,3698,3694,3680,3681,3679,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,964,SUCCESS,,2404.915108,192,0,0.1,0.2,0.3,263,1.4,1.5
    4547,5/27/2021 0:16,18223.162,5.06,701,300,10,6001,0,65535,65535,1,21.3,25822,-296,-296,100,62,8,2398,3888,483,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3696,3698,3694,3679,3684,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,966,SUCCESS,,2404.585561,192,0,0.1,0.2,0.3,263,1.4,1.5
    4548,5/27/2021 0:16,18227.176,5.06,701,300,10,6001,0,65535,65535,1,21.3,25819,-296,-297,100,62,8,2398,3888,486,484,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3696,3697,3693,3679,3683,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,982,SUCCESS,,2404.255521,192,0,0.1,0.2,0.3,263,1.4,1.5
    4549,5/27/2021 0:16,18231.179,5.06,701,300,10,6001,0,65535,65535,1,21.3,25820,-298,-296,100,62,8,2397,3888,486,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3692,3696,3698,3693,3679,3681,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,948,SUCCESS,,2403.924161,192,0,0.1,0.2,0.3,263,1.4,1.5
    4550,5/27/2021 0:16,18235.183,5.07,701,300,10,6001,0,65535,65535,1,21.3,25817,-296,-296,100,62,8,2397,3888,486,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3679,3683,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,944,SUCCESS,,2403.594944,192,0,0.1,0.2,0.3,263,1.4,1.5
    4551,5/27/2021 0:16,18239.186,5.07,701,300,10,6001,0,65535,65535,1,21.3,25817,-296,-296,100,62,8,2397,3888,486,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3679,3683,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,962,SUCCESS,,2403.265808,192,0,0.1,0.2,0.3,263,1.4,1.5
    4552,5/27/2021 0:16,18243.192,5.07,701,300,10,6001,0,65535,65535,1,21.3,25816,-298,-296,100,62,8,2396,3888,482,486,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3678,3680,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,999,SUCCESS,,2402.9342,192,0,0.1,0.2,0.3,263,1.4,1.5
    4553,5/27/2021 0:16,18247.205,5.07,701,300,10,6001,0,65535,65535,1,21.3,25817,-296,-297,100,62,8,2396,3888,482,484,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3678,3683,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,937,SUCCESS,,2402.604243,192,0,0.1,0.2,0.3,263,1.4,1.5
    4554,5/27/2021 0:16,18251.206,5.07,701,300,10,6001,0,65535,65535,1,21.3,25815,-296,-297,100,62,8,2396,3888,486,484,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3678,3683,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,937,SUCCESS,,2402.275271,192,0,0.1,0.2,0.3,263,1.4,1.5
    4555,5/27/2021 0:17,18255.221,5.07,4701,300,10,6001,0,65535,65535,1,21.3,25814,-296,-296,100,62,8,2395,3888,485,485,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3678,3683,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,972,SUCCESS,,2401.945149,192,0,0.1,0.2,0.3,327,1.4,1.5
    4556,5/27/2021 0:17,18259.233,5.07,4701,300,10,6001,0,65535,65535,1,21.3,25813,-296,-297,100,62,8,2395,3888,482,484,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3678,3683,3678,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,942,SUCCESS,,2401.615274,192,0,0.1,0.2,0.3,327,1.4,1.5
    4557,5/27/2021 0:17,18263.24,5.07,4701,300,10,6001,0,65535,65535,1,21.3,25812,-296,-296,100,62,8,2395,3888,485,485,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3696,3693,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,981,SUCCESS,,2401.285809,192,0,0.1,0.2,0.3,327,1.4,1.5
    4558,5/27/2021 0:17,18267.242,5.07,4701,300,10,6001,0,65535,65535,1,21.3,25813,-298,-297,100,62,8,2394,3888,485,484,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3696,3697,3693,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,932,SUCCESS,,2400.954533,192,0,0.1,0.2,0.3,327,1.4,1.5
    4559,5/27/2021 0:17,18271.257,5.08,4701,300,10,6001,0,65535,65535,1,21.3,25812,-296,-297,100,62,8,2394,3888,485,484,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3695,3696,3693,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,951,SUCCESS,,2400.62441,192,0,0.1,0.2,0.3,327,1.4,1.5
    4560,5/27/2021 0:17,18275.273,5.08,4701,300,10,6001,0,65535,65535,1,21.3,25812,-296,-297,100,62,8,2394,3888,485,484,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3691,3695,3696,3692,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,970,SUCCESS,,2400.294206,192,0,0.1,0.2,0.3,327,1.4,1.5
    4561,5/27/2021 0:17,18279.275,5.08,4701,300,10,6001,0,65535,65535,1,21.3,25810,-298,-297,100,62,8,2393,3888,482,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3695,3696,3692,3678,3683,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,945,SUCCESS,,2399.962929,192,0,0.1,0.2,0.3,327,1.4,1.5
    4562,5/27/2021 0:17,18283.279,5.08,4701,300,10,6001,0,65535,65535,1,21.3,25810,-296,-297,100,62,8,2393,3888,488,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3695,3696,3692,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,949,SUCCESS,,2399.633711,192,0,0.1,0.2,0.3,327,1.4,1.5
    4563,5/27/2021 0:17,18287.286,5.08,701,300,10,6001,0,65535,65535,1,21.3,25810,-296,-296,100,62,8,2393,3888,485,485,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3695,3696,3692,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,958,SUCCESS,,2399.304247,192,0,0.1,0.2,0.3,263,1.4,1.5
    4564,5/27/2021 0:17,18291.296,5.08,701,300,10,6001,0,65535,65535,1,21.3,25810,-298,-297,100,62,8,2392,3888,482,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3696,3692,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,956,SUCCESS,,2398.972308,192,0,0.1,0.2,0.3,263,1.4,1.5
    4565,5/27/2021 0:17,18295.301,5.08,701,300,10,6001,0,65535,65535,1,21.3,25809,-296,-296,100,62,8,2392,3888,485,485,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3696,3692,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,969,SUCCESS,,2398.643008,192,0,0.1,0.2,0.3,263,1.4,1.5
    4566,5/27/2021 0:17,18299.31,5.08,701,300,10,6001,0,65535,65535,1,21.3,25807,-298,-297,100,62,8,2392,3888,485,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3696,3691,3678,3682,3676,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,949,SUCCESS,,2398.311152,192,0,0.1,0.2,0.3,263,1.4,1.5
    4567,5/27/2021 0:17,18303.32,5.08,701,300,10,6001,0,65535,65535,1,21.3,25807,-296,-297,100,62,8,2391,3888,481,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3696,3692,3678,3682,3677,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.4,963,SUCCESS,,2397.981441,192,0,0.1,0.2,0.3,263,1.4,1.5
    4568,5/27/2021 0:17,18307.32,5.09,701,300,10,6001,0,65535,65535,1,21.3,25807,-296,-297,100,62,8,2391,3888,485,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3696,3691,3678,3681,3676,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,931,SUCCESS,,2397.652552,192,0,0.1,0.2,0.3,263,1.4,1.5
    4569,5/27/2021 0:17,18311.334,5.09,701,300,10,6001,0,65535,65535,1,21.3,25805,-300,-297,100,62,8,2391,3888,478,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3695,3691,3678,3681,3676,0,0,0,0,0,0,0,0,2581,21,21.3,-273.2,21.3,-273.2,21.3,939,SUCCESS,,2397.318052,192,0,0.1,0.2,0.3,263,1.4,1.5
    4570,5/27/2021 0:18,18315.345,5.09,4701,300,10,6001,0,65535,65535,1,21.2,25805,-296,-297,100,62,8,2390,3888,484,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3695,3691,3678,3682,3676,0,0,0,0,0,0,0,0,2577,21,21.2,-273.2,21.2,-273.2,21.3,942,SUCCESS,,2396.988259,192,0,0.1,0.2,0.3,327,1.4,1.5
    4571,5/27/2021 0:18,18319.351,5.09,4701,300,10,6001,0,65535,65535,1,21.2,25805,-298,-297,100,62,8,2390,3888,481,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3694,3695,3691,3678,3681,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,1010,SUCCESS,,2396.656651,192,0,0.1,0.2,0.3,327,1.4,1.5
    4572,5/27/2021 0:18,18323.366,5.09,4701,300,10,6001,0,65535,65535,1,21.2,25805,-296,-297,100,62,8,2390,3888,484,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3690,3694,3695,3691,3678,3681,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,20.7,934,SUCCESS,,2396.326529,192,0,0.1,0.2,0.3,327,1.4,1.5
    4573,5/27/2021 0:18,18327.381,5.09,4701,300,10,6001,0,65535,65535,1,21.3,25805,-296,-297,100,62,8,2389,3888,484,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3694,3695,3691,3678,3682,3676,0,0,0,0,0,0,0,0,2576,21,21.3,-273.2,21.3,-273.2,21.4,949,SUCCESS,,2395.996406,192,0,0.1,0.2,0.3,327,1.4,1.5
    4574,5/27/2021 0:18,18331.394,5.09,701,300,10,6001,0,65535,65535,1,21.2,25804,-296,-297,100,62,8,2389,3888,484,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3694,3695,3691,3678,3681,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,967,SUCCESS,,2395.666449,192,0,0.1,0.2,0.3,263,1.4,1.5
    4575,5/27/2021 0:18,18335.406,5.09,701,300,10,6001,0,65535,65535,1,21.2,25804,-296,-297,100,62,8,2389,3888,484,483,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3694,3695,3691,3678,3681,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,958,SUCCESS,,2395.336573,192,0,0.1,0.2,0.3,263,1.4,1.5
    4576,5/27/2021 0:18,18339.419,5.09,701,300,10,6001,0,65535,65535,1,21.2,25804,-296,-297,100,62,8,2388,3888,484,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3694,3695,3691,3678,3682,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,943,SUCCESS,,2395.006615,192,0,0.1,0.2,0.3,263,1.4,1.5
    4577,5/27/2021 0:18,18343.433,5.1,701,300,10,6001,0,65535,65535,1,21.3,25802,-296,-297,100,62,8,2388,3888,484,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3693,3694,3691,3678,3680,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.3,-273.2,21.3,943,SUCCESS,,2394.676575,192,0,0.1,0.2,0.3,263,1.4,1.5
    4578,5/27/2021 0:18,18347.445,5.1,701,300,10,6001,0,65535,65535,1,21.3,25802,-296,-297,100,62,8,2388,3888,484,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3693,3694,3691,3678,3680,3676,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.3,-273.2,21.3,947,SUCCESS,,2394.3467,192,0,0.1,0.2,0.3,263,1.4,1.5
    4579,5/27/2021 0:18,18351.447,5.1,701,300,10,6001,0,65535,65535,1,21.2,25801,-296,-297,100,62,8,2387,3888,484,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3693,3694,3690,3678,3680,3676,0,0,0,0,0,0,0,0,2576,21,21.3,-273.2,21.3,-273.2,21.3,967,SUCCESS,,2394.017646,192,0,0.1,0.2,0.3,263,1.4,1.5
    4580,5/27/2021 0:18,18355.449,5.1,701,300,10,6001,0,65535,65535,1,21.3,25801,-298,-297,100,62,8,2387,3888,481,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3693,3694,3691,3678,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.3,-273.2,21.3,-273.2,21.3,952,SUCCESS,,2393.68637,192,0,0.1,0.2,0.3,263,1.4,1.5
    4581,5/27/2021 0:18,18359.452,5.1,701,300,10,6001,0,65535,65535,1,21.3,25799,-296,-297,100,62,8,2387,3888,484,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3693,3694,3690,3678,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,948,SUCCESS,,2393.357234,192,0,0.1,0.2,0.3,263,1.4,1.5
    4582,5/27/2021 0:18,18363.461,5.1,701,300,10,6001,0,65535,65535,1,21.2,25798,-296,-296,100,62,8,2386,3888,480,484,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3689,3693,3694,3690,3678,3681,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,962,SUCCESS,,2393.027605,192,0,0.1,0.2,0.3,263,1.4,1.5
    4583,5/27/2021 0:18,18367.461,5.1,701,300,10,6001,0,65535,65535,1,21.2,25798,-296,-297,100,62,8,2386,3888,484,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3693,3694,3690,3677,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,948,SUCCESS,,2392.698716,192,0,0.1,0.2,0.3,263,1.4,1.5
    4584,5/27/2021 0:18,18371.476,5.1,701,300,10,6001,0,65535,65535,1,21.2,25798,-294,-296,100,62,8,2386,3888,484,484,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3693,3694,3690,3678,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,953,SUCCESS,,2392.370825,192,0,0.1,0.2,0.3,263,1.4,1.5
    4585,5/27/2021 0:19,18375.486,5.1,4701,300,10,6001,0,65535,65535,1,21.2,25797,-296,-296,100,62,8,2385,3888,487,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3693,3694,3690,3677,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,940,SUCCESS,,2392.041114,192,0,0.1,0.2,0.3,327,1.4,1.5
    4586,5/27/2021 0:19,18379.501,5.11,4701,300,10,6001,0,65535,65535,1,21.2,25797,-296,-296,100,62,8,2385,3888,487,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3693,3694,3690,3677,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,937,SUCCESS,,2391.710991,192,0,0.1,0.2,0.3,327,1.4,1.5
    4587,5/27/2021 0:19,18383.507,5.11,4701,300,10,6001,0,65535,65535,1,21.2,25797,-296,-296,100,62,8,2385,3888,480,483,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3693,3694,3690,3677,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,933,SUCCESS,,2391.381609,192,0,0.1,0.2,0.3,327,1.4,1.5
    4588,5/27/2021 0:19,18387.519,5.11,4701,300,10,6001,0,65535,65535,1,21.2,25795,-298,-297,100,62,8,2384,3888,480,482,65535,3000,28875,00C0,0,3637,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3692,3694,3690,3677,3680,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,985,SUCCESS,,2391.049505,192,0,0.1,0.2,0.3,327,1.4,1.5
    4589,5/27/2021 0:19,18391.53,5.11,701,300,10,6001,0,65535,65535,1,21.2,25796,-296,-297,100,62,8,2384,3888,483,482,65535,3000,28875,00C0,0,3637,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3692,3693,3690,3677,3680,3675,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,940,SUCCESS,,2390.719711,192,0,0.1,0.2,0.3,263,1.4,1.5
    4590,5/27/2021 0:19,18395.544,5.11,701,300,10,6001,0,65535,65535,1,21.2,25794,-296,-297,100,62,8,2384,3888,474,482,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3692,3693,3690,3677,3680,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,942,SUCCESS,,2390.389671,192,0,0.1,0.2,0.3,263,1.4,1.5
    4591,5/27/2021 0:19,18399.554,5.11,701,300,10,6001,0,65535,65535,1,21.2,25793,-296,-297,100,62,8,2383,3888,483,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3692,3693,3690,3676,3680,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,955,SUCCESS,,2390.05996,192,0,0.1,0.2,0.3,263,1.4,1.5
    4592,5/27/2021 0:19,18403.558,5.11,4701,300,10,6001,0,65535,65535,1,21.2,25791,-296,-297,100,62,8,2383,3888,486,481,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3692,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.2,944,SUCCESS,,2389.730743,192,0,0.1,0.2,0.3,327,1.4,1.5
    4593,5/27/2021 0:19,18407.57,5.11,4701,300,10,6001,0,65535,65535,1,21.2,25791,-300,-297,100,62,8,2383,3888,483,481,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3688,3692,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,954,SUCCESS,,2389.396409,192,0,0.1,0.2,0.3,327,1.4,1.5
    4594,5/27/2021 0:19,18411.571,5.11,4701,300,10,6001,0,65535,65535,1,21.2,25789,-296,-297,100,62,8,2382,3888,483,481,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3692,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,946,SUCCESS,,2389.067438,192,0,0.1,0.2,0.3,327,1.4,1.5
    4595,5/27/2021 0:19,18415.575,5.12,4701,300,10,6001,0,65535,65535,1,21.2,25790,-298,-296,100,62,8,2382,3888,483,483,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3692,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,942,SUCCESS,,2388.735996,192,0,0.1,0.2,0.3,327,1.4,1.5
    4596,5/27/2021 0:19,18419.589,5.12,701,300,10,6001,0,65535,65535,1,21.2,25790,-296,-297,100,62,8,2382,3888,483,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3692,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21,944,SUCCESS,,2388.405956,192,0,0.1,0.2,0.3,263,1.4,1.5
    4597,5/27/2021 0:19,18423.604,5.12,701,300,10,6001,0,65535,65535,1,21.2,25789,-296,-297,100,62,8,2381,3888,483,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3692,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,962,SUCCESS,,2388.075834,192,0,0.1,0.2,0.3,263,1.4,1.5
    4598,5/27/2021 0:19,18427.611,5.12,701,300,10,6001,0,65535,65535,1,21.2,25789,-294,-296,100,62,8,2381,3888,479,483,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3693,3689,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.2,938,SUCCESS,,2387.748595,192,0,0.1,0.2,0.3,263,1.4,1.5
    4599,5/27/2021 0:19,18431.618,5.12,701,300,10,6001,0,65535,65535,1,21.2,25788,-296,-296,100,62,8,2381,3888,479,483,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3693,3689,3675,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,961,SUCCESS,,2387.419131,192,0,0.1,0.2,0.3,263,1.4,1.5
    4600,5/27/2021 0:20,18435.625,5.12,701,300,10,6001,0,65535,65535,1,21.2,25788,-296,-296,100,62,8,2380,3888,482,482,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3693,3688,3676,3679,3674,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,963,SUCCESS,,2387.089666,192,0,0.1,0.2,0.3,263,1.4,1.5
    4601,5/27/2021 0:20,18439.634,5.12,701,300,10,6001,0,65535,65535,1,21.2,25787,-296,-296,100,62,8,2380,3888,482,482,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3693,3688,3675,3679,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,984,SUCCESS,,2386.760038,192,0,0.1,0.2,0.3,263,1.4,1.5
    4602,5/27/2021 0:20,18443.639,5.12,701,300,10,6001,0,65535,65535,1,21.2,25787,-296,-296,100,62,8,2380,3888,482,482,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3692,3688,3675,3679,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,962,SUCCESS,,2386.430738,192,0,0.1,0.2,0.3,263,1.4,1.5
    4603,5/27/2021 0:20,18447.641,5.12,701,300,10,6001,0,65535,65535,1,21.2,25784,-298,-296,100,62,8,2379,3888,482,482,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3692,3688,3675,3679,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,956,SUCCESS,,2386.099461,192,0,0.1,0.2,0.3,263,1.4,1.5
    4604,5/27/2021 0:20,18451.651,5.13,701,300,10,6001,0,65535,65535,1,21.2,25784,-298,-297,100,62,8,2379,3888,479,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3692,3688,3675,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,960,SUCCESS,,2385.767522,192,0,0.1,0.2,0.3,263,1.4,1.5
    4605,5/27/2021 0:20,18455.654,5.13,701,300,10,6001,0,65535,65535,1,21.2,25784,-296,-297,100,62,8,2379,3888,482,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3692,3688,3675,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,954,SUCCESS,,2385.438386,192,0,0.1,0.2,0.3,263,1.4,1.5
    4606,5/27/2021 0:20,18459.664,5.13,701,300,10,6001,0,65535,65535,1,21.2,25786,-296,-296,100,62,8,2379,3888,482,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3692,3688,3674,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,943,SUCCESS,,2385.108675,192,0,0.1,0.2,0.3,263,1.4,1.5
    4607,5/27/2021 0:20,18463.672,5.13,4701,300,10,6001,0,65535,65535,1,21.2,25783,-298,-297,100,62,8,2378,3888,485,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3687,3691,3692,3688,3675,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,945,SUCCESS,,2384.776902,192,0,0.1,0.2,0.3,327,1.4,1.5
    4608,5/27/2021 0:20,18467.682,5.13,4701,300,10,6001,0,65535,65535,1,21.2,25781,-296,-297,100,62,8,2378,3888,482,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3691,3692,3688,3674,3677,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,953,SUCCESS,,2384.447191,192,0,0.1,0.2,0.3,327,1.4,1.5
    4609,5/27/2021 0:20,18471.69,5.13,4701,300,10,6001,0,65535,65535,1,21.2,25782,-298,-297,100,62,8,2377,3888,479,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3691,3692,3688,3674,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,955,SUCCESS,,2384.115418,192,0,0.1,0.2,0.3,327,1.4,1.5
    4610,5/27/2021 0:20,18475.701,5.13,4701,300,10,6001,0,65535,65535,1,21.2,25782,-296,-297,100,62,8,2377,3888,482,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3690,3692,3688,3674,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,948,SUCCESS,,2383.785624,192,0,0.1,0.2,0.3,327,1.4,1.5
    4611,5/27/2021 0:20,18479.716,5.13,701,300,10,6001,0,65535,65535,1,21.2,25780,-296,-296,100,62,8,2377,3888,482,482,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3691,3691,3688,3674,3677,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,949,SUCCESS,,2383.455502,192,0,0.1,0.2,0.3,263,1.4,1.5
    4612,5/27/2021 0:20,18483.723,5.13,701,300,10,6001,0,65535,65535,1,21.2,25784,-298,-297,100,62,8,2376,3888,478,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3690,3691,3688,3674,3678,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,969,SUCCESS,,2383.123811,192,0,0.1,0.2,0.3,263,1.4,1.5
    4613,5/27/2021 0:20,18487.734,5.14,701,300,10,6001,0,65535,65535,1,21.2,25777,-298,-297,100,62,8,2376,3888,478,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3690,3691,3687,3674,3677,3672,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,973,SUCCESS,,2382.79179,192,0,0.1,0.2,0.3,263,1.4,1.5
    4614,5/27/2021 0:20,18491.745,5.14,701,300,10,6001,0,65535,65535,1,21.2,25777,-296,-297,100,62,8,2376,3888,482,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3690,3691,3687,3674,3677,3673,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,959,SUCCESS,,2382.461996,192,0,0.1,0.2,0.3,263,1.4,1.5
    4615,5/27/2021 0:21,18495.747,5.14,701,300,10,6001,0,65535,65535,1,21.2,25777,-296,-297,100,62,8,2375,3888,481,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3690,3691,3687,3674,3677,3672,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.2,961,SUCCESS,,2382.132943,192,0,0.1,0.2,0.3,263,1.4,1.5
    4616,5/27/2021 0:21,18499.762,5.14,701,300,10,6001,0,65535,65535,1,21.2,25777,-294,-296,100,62,8,2375,3888,485,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3686,3690,3691,3687,3674,3677,3672,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,944,SUCCESS,,2381.805051,192,0,0.1,0.2,0.3,263,1.4,1.5
    4617,5/27/2021 0:21,18503.771,5.14,701,300,10,6001,0,65535,65535,1,21.2,25776,-298,-297,100,62,8,2375,3888,478,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3674,3676,3672,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,941,SUCCESS,,2381.473195,192,0,0.1,0.2,0.3,263,1.4,1.5
    4618,5/27/2021 0:21,18507.786,5.14,4701,300,10,6001,0,65535,65535,1,21.2,25774,-296,-297,100,62,8,2374,3888,481,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3673,3677,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,951,SUCCESS,,2381.143073,192,0,0.1,0.2,0.3,327,1.4,1.5
    4619,5/27/2021 0:21,18511.791,5.14,4701,300,10,6001,0,65535,65535,1,21.2,25776,-296,-296,100,62,8,2374,3888,481,481,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3673,3677,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,961,SUCCESS,,2380.813773,192,0,0.1,0.2,0.3,327,1.4,1.5
    4620,5/27/2021 0:21,18515.792,5.14,4701,300,10,6001,0,65535,65535,1,21.2,25774,-298,-297,100,62,8,2374,3888,478,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,992,SUCCESS,,2380.482579,192,0,0.1,0.2,0.3,327,1.4,1.5
    4621,5/27/2021 0:21,18519.795,5.14,4701,300,10,6001,0,65535,65535,1,21.2,25774,-296,-297,100,62,8,2373,3888,481,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3673,3677,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,943,SUCCESS,,2380.153444,192,0,0.1,0.2,0.3,327,1.4,1.5
    4622,5/27/2021 0:21,18523.805,5.15,701,300,10,6001,0,65535,65535,1,21.2,25775,-294,-296,100,62,8,2373,3888,481,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3673,3677,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,993,SUCCESS,,2379.82596,192,0,0.1,0.2,0.3,263,1.4,1.5
    4623,5/27/2021 0:21,18527.806,5.15,701,300,10,6001,0,65535,65535,1,21.2,25773,-300,-297,100,62,8,2373,3888,471,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3690,3691,3687,3673,3677,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,962,SUCCESS,,2379.492544,192,0,0.1,0.2,0.3,263,1.4,1.5
    4624,5/27/2021 0:21,18531.818,5.15,701,300,10,6001,0,65535,65535,1,21.2,25771,-296,-297,100,62,8,2372,3888,481,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3691,3687,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,951,SUCCESS,,2379.162668,192,0,0.1,0.2,0.3,263,1.4,1.5
    4625,5/27/2021 0:21,18535.822,5.15,701,300,10,6001,0,65535,65535,1,21.2,25772,-296,-297,100,62,8,2372,3888,478,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3690,3687,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,945,SUCCESS,,2378.83345,192,0,0.1,0.2,0.3,263,1.4,1.5
    4626,5/27/2021 0:21,18539.826,5.15,4701,300,10,6001,0,65535,65535,1,21.2,25772,-298,-297,100,62,8,2372,3888,481,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3690,3687,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,946,SUCCESS,,2378.502008,192,0,0.1,0.2,0.3,327,1.4,1.5
    4627,5/27/2021 0:21,18543.83,5.15,4701,300,10,6001,0,65535,65535,1,21.2,25770,-294,-297,100,62,8,2372,3888,481,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3690,3686,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,941,SUCCESS,,2378.175015,192,0,0.1,0.2,0.3,327,1.4,1.5
    4628,5/27/2021 0:21,18547.835,5.15,4701,300,10,6001,0,65535,65535,1,21.2,25770,-298,-297,100,61,8,2371,3888,481,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3690,3686,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.2,984,SUCCESS,,2377.84349,192,0,0.1,0.2,0.3,327,1.4,1.5
    4629,5/27/2021 0:21,18551.839,5.15,4701,300,10,6001,0,65535,65535,1,21.2,25771,-296,-297,100,61,8,2371,3888,481,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3690,3686,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,20.7,946,SUCCESS,,2377.514272,192,0,0.1,0.2,0.3,327,1.4,1.5
    4630,5/27/2021 0:22,18555.851,5.15,701,300,10,6001,0,65535,65535,1,21.2,25770,-296,-296,100,61,8,2371,3888,477,481,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3685,3689,3690,3686,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,1002,SUCCESS,,2377.184396,192,0,0.1,0.2,0.3,263,1.4,1.5
    4631,5/27/2021 0:22,18559.859,5.16,701,300,10,6001,0,65535,65535,1,21.2,25768,-298,-297,100,61,8,2370,3888,477,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3689,3690,3686,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,961,SUCCESS,,2376.852623,192,0,0.1,0.2,0.3,263,1.4,1.5
    4632,5/27/2021 0:22,18563.868,5.16,701,300,10,6001,0,65535,65535,1,21.2,25769,-296,-297,100,61,8,2370,3888,480,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3689,3690,3686,3673,3677,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,932,SUCCESS,,2376.522994,192,0,0.1,0.2,0.3,263,1.4,1.5
    4633,5/27/2021 0:22,18567.883,5.16,701,300,10,6001,0,65535,65535,1,21.2,25768,-296,-296,100,61,8,2370,3888,477,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3690,3685,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,964,SUCCESS,,2376.192872,192,0,0.1,0.2,0.3,263,1.4,1.5
    4634,5/27/2021 0:22,18571.884,5.16,701,300,10,6001,0,65535,65535,1,21.2,25768,-296,-297,100,61,8,2369,3888,477,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3690,3685,3673,3676,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,937,SUCCESS,,2375.863901,192,0,0.1,0.2,0.3,263,1.4,1.5
    4635,5/27/2021 0:22,18575.884,5.16,701,300,10,6001,0,65535,65535,1,21.2,25766,-296,-296,100,61,8,2369,3888,483,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3689,3685,3672,3677,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,979,SUCCESS,,2375.535012,192,0,0.1,0.2,0.3,263,1.4,1.5
    4636,5/27/2021 0:22,18579.887,5.16,701,300,10,6001,0,65535,65535,1,21.2,25765,-298,-297,100,61,8,2369,3888,480,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3690,3685,3672,3675,3671,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,948,SUCCESS,,2375.203653,192,0,0.1,0.2,0.3,263,1.4,1.5
    4637,5/27/2021 0:22,18583.901,5.16,701,300,10,6001,0,65535,65535,1,21.2,25765,-298,-297,100,61,8,2368,3888,480,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3689,3685,3672,3676,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,983,SUCCESS,,2374.871383,192,0,0.1,0.2,0.3,263,1.4,1.5
    4638,5/27/2021 0:22,18587.907,5.16,701,300,10,6001,0,65535,65535,1,21.2,25764,-296,-297,100,61,8,2368,3888,477,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3689,3685,3672,3676,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,964,SUCCESS,,2374.542,192,0,0.1,0.2,0.3,263,1.4,1.5
    4639,5/27/2021 0:22,18591.913,5.16,701,300,10,6001,0,65535,65535,1,21.2,25764,-296,-297,100,61,8,2368,3888,477,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3689,3685,3672,3675,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,987,SUCCESS,,2374.212618,192,0,0.1,0.2,0.3,263,1.4,1.5
    4640,5/27/2021 0:22,18595.929,5.17,701,300,10,6001,0,65535,65535,1,21.2,25763,-294,-297,100,61,8,2367,3888,480,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3689,3685,3672,3676,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,933,SUCCESS,,2373.884645,192,0,0.1,0.2,0.3,263,1.4,1.5
    4641,5/27/2021 0:22,18599.934,5.17,4701,300,10,6001,0,65535,65535,1,21.2,25764,-298,-296,100,61,8,2367,3888,480,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3684,3688,3689,3685,3672,3675,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,946,SUCCESS,,2373.55312,192,0,0.1,0.2,0.3,327,1.4,1.5
    4642,5/27/2021 0:22,18603.935,5.17,4701,300,10,6001,0,65535,65535,1,21.2,25762,-298,-296,100,61,8,2367,3888,480,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3688,3689,3685,3672,3674,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.3,940,SUCCESS,,2373.221926,192,0,0.1,0.2,0.3,327,1.4,1.5
    4643,5/27/2021 0:22,18607.944,5.17,4701,300,10,6001,0,65535,65535,1,21.2,25761,-296,-296,100,61,8,2366,3888,480,480,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3688,3689,3685,3671,3675,3670,0,0,0,0,0,0,0,0,2576,21,21.2,-273.2,21.2,-273.2,21.4,954,SUCCESS,,2372.892297,192,0,0.1,0.2,0.3,327,1.4,1.5
    4644,5/27/2021 0:22,18611.952,5.17,4701,300,10,6001,0,65535,65535,1,21.2,25760,-298,-296,100,61,8,2366,3888,480,480,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3687,3688,3685,3671,3675,3670,0,0,0,0,0,0,0,0,2573,21,21.2,-273.2,21.2,-273.2,21.3,942,SUCCESS,,2372.560524,192,0,0.1,0.2,0.3,263,1.4,1.5
    4645,5/27/2021 0:23,18615.962,5.17,701,300,10,6001,0,65535,65535,1,21.2,25761,-296,-296,100,61,8,2365,3888,479,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3688,3688,3685,3671,3674,3670,0,0,0,0,0,0,0,0,2573,21,21.2,-273.2,21.2,-273.2,21.2,949,SUCCESS,,2372.230813,192,0,0.1,0.2,0.3,263,1.4,1.5
    4646,5/27/2021 0:23,18619.964,5.17,701,300,10,6001,0,65535,65535,1,21.2,25758,-296,-296,100,61,8,2365,3888,479,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3688,3689,3685,3671,3674,3670,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,962,SUCCESS,,2371.901759,192,0,0.1,0.2,0.3,263,1.4,1.5
    4647,5/27/2021 0:23,18623.973,5.17,701,300,10,6001,0,65535,65535,1,21.2,25757,-294,-296,100,61,8,2365,3888,483,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3671,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,938,SUCCESS,,2371.574358,192,0,0.1,0.2,0.3,263,1.4,1.5
    4648,5/27/2021 0:23,18627.977,5.17,701,300,10,6001,0,65535,65535,1,21.2,25758,-296,-296,100,61,8,2365,3888,479,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3687,3688,3685,3671,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21,962,SUCCESS,,2371.24514,192,0,0.1,0.2,0.3,263,1.4,1.5
    4649,5/27/2021 0:23,18631.979,5.18,701,300,10,6001,0,65535,65535,1,21.2,25758,-296,-296,100,61,8,2364,3888,479,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3687,3688,3685,3671,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.2,944,SUCCESS,,2370.916086,192,0,0.1,0.2,0.3,263,1.4,1.5
    4650,5/27/2021 0:23,18635.991,5.18,701,300,10,6001,0,65535,65535,1,21.2,25757,-298,-296,100,61,8,2364,3888,476,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3687,3688,3684,3671,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.2,978,SUCCESS,,2370.583982,192,0,0.1,0.2,0.3,263,1.4,1.5
    4651,5/27/2021 0:23,18639.995,5.18,701,300,10,6001,0,65535,65535,1,21.2,25755,-294,-296,100,61,8,2364,3888,482,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3683,3687,3688,3684,3671,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,969,SUCCESS,,2370.256989,192,0,0.1,0.2,0.3,263,1.4,1.5
    4652,5/27/2021 0:23,18644.004,5.18,4701,300,10,6001,0,65535,65535,1,21.2,25756,-298,-296,100,61,8,2363,3888,476,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3674,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,973,SUCCESS,,2369.925133,192,0,0.1,0.2,0.3,327,1.4,1.5
    4653,5/27/2021 0:23,18648.016,5.18,4701,300,10,6001,0,65535,65535,1,21.2,25756,-298,-297,100,61,8,2363,3888,476,477,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,940,SUCCESS,,2369.593028,192,0,0.1,0.2,0.3,327,1.4,1.5
    4654,5/27/2021 0:23,18652.03,5.18,4701,300,10,6001,0,65535,65535,1,21.2,25755,-296,-296,100,61,8,2363,3888,479,479,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,959,SUCCESS,,2369.262988,192,0,0.1,0.2,0.3,327,1.4,1.5
    4655,5/27/2021 0:23,18656.038,5.18,4701,300,10,6001,0,65535,65535,1,21.2,25753,-296,-297,100,61,8,2362,3888,476,477,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3674,3669,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,979,SUCCESS,,2368.933441,192,0,0.1,0.2,0.3,327,1.4,1.5
    4656,5/27/2021 0:23,18660.051,5.18,701,300,10,6001,0,65535,65535,1,21.2,25753,-298,-296,100,61,8,2362,3888,479,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3674,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,967,SUCCESS,,2368.601254,192,0,0.1,0.2,0.3,263,1.4,1.5
    4657,5/27/2021 0:23,18664.057,5.18,701,300,10,6001,0,65535,65535,1,21.2,25753,-296,-296,100,61,8,2362,3888,479,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,961,SUCCESS,,2368.271872,192,0,0.1,0.2,0.3,263,1.4,1.5
    4658,5/27/2021 0:23,18668.061,5.19,701,300,10,6001,0,65535,65535,1,21.2,25753,-296,-297,100,61,8,2361,3888,479,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3687,3688,3684,3670,3674,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,943,SUCCESS,,2367.942654,192,0,0.1,0.2,0.3,263,1.4,1.5
    4659,5/27/2021 0:23,18672.064,5.19,701,300,10,6001,0,65535,65535,1,21.2,25751,-296,-296,100,61,8,2361,3888,482,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3686,3687,3684,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,971,SUCCESS,,2367.613519,192,0,0.1,0.2,0.3,263,1.4,1.5
    4660,5/27/2021 0:24,18676.069,5.19,701,300,10,6001,0,65535,65535,1,21.2,25750,-298,-296,100,61,8,2361,3888,475,479,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3686,3687,3684,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,947,SUCCESS,,2367.281994,192,0,0.1,0.2,0.3,263,1.4,1.5
    4661,5/27/2021 0:24,18680.079,5.19,701,300,10,6001,0,65535,65535,1,21.2,25750,-296,-296,100,61,8,2360,3888,478,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3686,3687,3684,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,954,SUCCESS,,2366.952283,192,0,0.1,0.2,0.3,263,1.4,1.5
    4662,5/27/2021 0:24,18684.087,5.19,701,300,10,6001,0,65535,65535,1,21.2,25749,-294,-296,100,61,8,2360,3888,478,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3686,3687,3683,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,968,SUCCESS,,2366.624963,192,0,0.1,0.2,0.3,263,1.4,1.5
    4663,5/27/2021 0:24,18688.091,5.19,4701,300,10,6001,0,65535,65535,1,21.2,25749,-296,-296,100,61,8,2360,3888,478,478,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3686,3687,3683,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,973,SUCCESS,,2366.295745,192,0,0.1,0.2,0.3,327,1.4,1.5
    4664,5/27/2021 0:24,18692.105,5.19,4701,300,10,6001,0,65535,65535,1,21.2,25748,-296,-296,100,61,8,2359,3888,478,478,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3682,3686,3687,3683,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,943,SUCCESS,,2365.965705,192,0,0.1,0.2,0.3,327,1.4,1.5
    4665,5/27/2021 0:24,18696.109,5.19,4701,300,10,6001,0,65535,65535,1,21.2,25749,-294,-296,100,61,8,2359,3888,478,478,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3686,3687,3683,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,959,SUCCESS,,2365.638711,192,0,0.1,0.2,0.3,327,1.4,1.5
    4666,5/27/2021 0:24,18700.123,5.19,4701,300,10,6001,0,65535,65535,1,21.2,25748,-294,-296,100,61,8,2359,3888,478,478,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3686,3687,3683,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,941,SUCCESS,,2365.310901,192,0,0.1,0.2,0.3,327,1.4,1.5
    4667,5/27/2021 0:24,18704.128,5.2,701,300,10,6001,0,65535,65535,1,21.2,25747,-294,-296,100,61,8,2358,3888,478,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3686,3687,3683,3669,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.4,956,SUCCESS,,2364.983826,192,0,0.1,0.2,0.3,263,1.4,1.5
    4668,5/27/2021 0:24,18708.134,5.2,701,300,10,6001,0,65535,65535,1,21.2,25745,-298,-296,100,61,8,2358,3888,478,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3687,3683,3670,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,978,SUCCESS,,2364.652219,192,0,0.1,0.2,0.3,263,1.4,1.5
    4669,5/27/2021 0:24,18712.145,5.2,701,300,10,6001,0,65535,65535,1,21.2,25745,-298,-296,100,61,8,2358,3888,481,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3687,3683,3669,3673,3668,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,966,SUCCESS,,2364.320197,192,0,0.1,0.2,0.3,263,1.4,1.5
    4670,5/27/2021 0:24,18716.16,5.2,701,300,10,6001,0,65535,65535,1,21.2,25745,-296,-296,100,61,8,2357,3888,478,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3687,3682,3669,3673,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,938,SUCCESS,,2363.990075,192,0,0.1,0.2,0.3,263,1.4,1.5
    4671,5/27/2021 0:24,18720.17,5.2,701,300,10,6001,0,65535,65535,1,21.2,25743,-298,-297,100,61,8,2357,3888,475,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3686,3682,3669,3673,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,943,SUCCESS,,2363.658136,192,0,0.1,0.2,0.3,263,1.4,1.5
    4672,5/27/2021 0:24,18724.183,5.2,701,300,10,6001,0,65535,65535,1,21.2,25743,-296,-297,100,61,8,2357,3888,478,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3686,3682,3669,3673,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21,959,SUCCESS,,2363.328178,192,0,0.1,0.2,0.3,263,1.4,1.5
    4673,5/27/2021 0:24,18728.195,5.2,701,300,10,6001,0,65535,65535,1,21.2,25743,-296,-296,100,61,8,2356,3888,478,478,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3686,3682,3669,3673,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,994,SUCCESS,,2362.998303,192,0,0.1,0.2,0.3,263,1.4,1.5
    4674,5/27/2021 0:24,18732.202,5.2,4701,300,10,6001,0,65535,65535,1,21.2,25742,-296,-297,100,61,8,2356,3888,478,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3686,3682,3669,3673,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,956,SUCCESS,,2362.668838,192,0,0.1,0.2,0.3,327,1.4,1.5
    4675,5/27/2021 0:25,18736.208,5.2,4701,300,10,6001,0,65535,65535,1,21.2,25742,-296,-297,100,61,8,2356,3888,478,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3681,3685,3686,3682,3669,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,1007,SUCCESS,,2362.339456,192,0,0.1,0.2,0.3,327,1.4,1.5
    4676,5/27/2021 0:25,18740.21,5.21,4701,300,10,6001,0,65535,65535,1,21.2,25740,-298,-296,100,61,8,2355,3888,477,477,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3685,3686,3682,3669,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.4,935,SUCCESS,,2362.008179,192,0,0.1,0.2,0.3,327,1.4,1.5
    4677,5/27/2021 0:25,18744.214,5.21,4701,300,10,6001,0,65535,65535,1,21.2,25740,-296,-296,100,61,8,2355,3888,482,477,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3685,3686,3682,3668,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,958,SUCCESS,,2361.678961,192,0,0.1,0.2,0.3,327,1.4,1.5
    4678,5/27/2021 0:25,18748.216,5.21,701,300,10,6001,0,65535,65535,1,21.1,25740,-296,-296,100,61,8,2355,3888,481,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3685,3686,3682,3668,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,942,SUCCESS,,2361.349908,192,0,0.1,0.2,0.3,263,1.4,1.5
    4679,5/27/2021 0:25,18752.215,5.21,701,300,10,6001,0,65535,65535,1,21.2,25739,-300,-296,100,61,8,2354,3888,477,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3685,3686,3682,3668,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.2,-273.2,21.3,943,SUCCESS,,2361.016658,192,0,0.1,0.2,0.3,263,1.4,1.5
    4680,5/27/2021 0:25,18756.22,5.21,701,300,10,6001,0,65535,65535,1,21.2,25740,-296,-296,100,61,8,2354,3888,477,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3684,3686,3682,3668,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,963,SUCCESS,,2360.687358,192,0,0.1,0.2,0.3,263,1.4,1.5
    4681,5/27/2021 0:25,18760.222,5.21,701,300,10,6001,0,65535,65535,1,21.1,25738,-298,-296,100,61,8,2354,3888,474,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3685,3685,3682,3668,3672,3667,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.1,-273.2,21.3,937,SUCCESS,,2360.356081,192,0,0.1,0.2,0.3,263,1.4,1.5
    4682,5/27/2021 0:25,18764.238,5.21,701,300,10,6001,0,65535,65535,1,21.2,25735,-296,-296,100,61,8,2353,3888,477,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.2,-273.2,21.3,936,SUCCESS,,2360.025877,192,0,0.1,0.2,0.3,263,1.4,1.5
    4683,5/27/2021 0:25,18768.24,5.21,701,300,10,6001,0,65535,65535,1,21.2,25738,-296,-296,100,61,8,2353,3888,477,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,949,SUCCESS,,2359.696824,192,0,0.1,0.2,0.3,263,1.4,1.5
    4684,5/27/2021 0:25,18772.241,5.21,701,300,10,6001,0,65535,65535,1,21.2,25735,-298,-296,100,61,8,2353,3888,474,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,984,SUCCESS,,2359.36563,192,0,0.1,0.2,0.3,263,1.4,1.5
    4685,5/27/2021 0:25,18776.254,5.22,701,300,10,6001,0,65535,65535,1,21.2,25735,-296,-296,100,61,8,2352,3888,477,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,988,SUCCESS,,2359.035672,192,0,0.1,0.2,0.3,263,1.4,1.5
    4686,5/27/2021 0:25,18780.257,5.22,701,300,10,6001,0,65535,65535,1,21.2,25739,-296,-296,100,61,8,2352,3888,477,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3680,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,950,SUCCESS,,2358.706536,192,0,0.1,0.2,0.3,263,1.4,1.5
    4687,5/27/2021 0:25,18784.265,5.22,701,300,10,6001,0,65535,65535,1,21.2,25734,-298,-296,100,61,8,2352,3888,474,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3681,3667,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.2,940,SUCCESS,,2358.374763,192,0,0.1,0.2,0.3,263,1.4,1.5
    4688,5/27/2021 0:25,18788.27,5.22,701,300,10,6001,0,65535,65535,1,21.1,25734,-298,-296,100,61,8,2351,3888,473,477,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,936,SUCCESS,,2358.043238,192,0,0.1,0.2,0.3,263,1.4,1.5
    4689,5/27/2021 0:25,18792.272,5.22,4701,300,10,6001,0,65535,65535,1,21.1,25738,-296,-296,100,61,8,2351,3888,477,477,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3681,3668,3671,3666,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,985,SUCCESS,,2357.714185,192,0,0.1,0.2,0.3,327,1.4,1.5
    4690,5/27/2021 0:26,18796.283,5.22,4701,300,10,6001,0,65535,65535,1,21.2,25731,-296,-296,100,61,8,2351,3888,477,477,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3680,3667,3671,3665,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,954,SUCCESS,,2357.384391,192,0,0.1,0.2,0.3,327,1.4,1.5
    4691,5/27/2021 0:26,18800.289,5.22,4701,300,10,6001,0,65535,65535,1,21.2,25730,-296,-296,100,61,8,2350,3888,476,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3681,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,20.7,1042,SUCCESS,,2357.055009,192,0,0.1,0.2,0.3,327,1.4,1.5
    4692,5/27/2021 0:26,18804.303,5.22,4701,300,10,6001,0,65535,65535,1,21.2,25730,-296,-296,100,61,8,2350,3888,476,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3684,3681,3667,3671,3665,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,953,SUCCESS,,2356.724969,192,0,0.1,0.2,0.3,327,1.4,1.5
    4693,5/27/2021 0:26,18808.317,5.22,701,300,10,6001,0,65535,65535,1,21.2,25729,-296,-296,100,61,8,2350,3888,473,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3684,3685,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,974,SUCCESS,,2356.394929,192,0,0.1,0.2,0.3,263,1.4,1.5
    4694,5/27/2021 0:26,18812.318,5.23,701,300,10,6001,0,65535,65535,1,21.2,25728,-296,-296,100,61,8,2349,3888,479,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3683,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.2,-273.2,21.2,-273.2,21.3,964,SUCCESS,,2356.065958,192,0,0.1,0.2,0.3,263,1.4,1.5
    4695,5/27/2021 0:26,18816.324,5.23,701,300,10,6001,0,65535,65535,1,21.1,25728,-296,-296,100,61,8,2349,3888,476,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3683,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,950,SUCCESS,,2355.736576,192,0,0.1,0.2,0.3,263,1.4,1.5
    4696,5/27/2021 0:26,18820.334,5.23,701,300,10,6001,0,65535,65535,1,21.1,25728,-296,-296,100,61,8,2349,3888,476,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3683,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,987,SUCCESS,,2355.406865,192,0,0.1,0.2,0.3,263,1.4,1.5
    4697,5/27/2021 0:26,18824.339,5.23,4701,300,10,6001,0,65535,65535,1,21.1,25728,-296,-296,100,61,8,2348,3888,476,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3683,3684,3680,3667,3668,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,945,SUCCESS,,2355.077565,192,0,0.1,0.2,0.3,327,1.4,1.5
    4698,5/27/2021 0:26,18828.345,5.23,4701,300,10,6001,0,65535,65535,1,21.1,25728,-296,-296,100,61,8,2348,3888,476,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3679,3683,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,953,SUCCESS,,2354.748183,192,0,0.1,0.2,0.3,327,1.4,1.5
    4699,5/27/2021 0:26,18832.345,5.23,4701,300,10,6001,0,65535,65535,1,21.1,25727,-294,-296,100,61,8,2348,3888,476,476,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3683,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,940,SUCCESS,,2354.421516,192,0,0.1,0.2,0.3,327,1.4,1.5
    4700,5/27/2021 0:26,18836.347,5.23,701,300,10,6001,0,65535,65535,1,21.1,25726,-298,-296,100,61,8,2347,3888,473,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3683,3684,3680,3666,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,936,SUCCESS,,2354.090239,192,0,0.1,0.2,0.3,263,1.4,1.5
    4701,5/27/2021 0:26,18840.356,5.23,701,300,10,6001,0,65535,65535,1,21.1,25726,-296,-296,100,61,8,2347,3888,476,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3682,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,944,SUCCESS,,2353.76061,192,0,0.1,0.2,0.3,263,1.4,1.5
    4702,5/27/2021 0:26,18844.362,5.23,701,300,10,6001,0,65535,65535,1,21.1,25726,-296,-296,100,61,8,2347,3888,476,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3682,3684,3680,3667,3670,3665,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,951,SUCCESS,,2353.431228,192,0,0.1,0.2,0.3,263,1.4,1.5
    4703,5/27/2021 0:26,18848.372,5.24,701,300,10,6001,0,65535,65535,1,21.1,25725,-298,-296,100,61,8,2346,3888,472,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3682,3684,3680,3666,3670,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,944,SUCCESS,,2353.099289,192,0,0.1,0.2,0.3,263,1.4,1.5
    4704,5/27/2021 0:26,18852.377,5.24,701,300,10,6001,0,65535,65535,1,21.1,25724,-294,-296,100,61,8,2346,3888,476,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3682,3684,3680,3666,3670,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,937,SUCCESS,,2352.772214,192,0,0.1,0.2,0.3,263,1.4,1.5
    4705,5/27/2021 0:27,18856.39,5.24,701,300,10,6001,0,65535,65535,1,21.1,25722,-296,-296,100,61,8,2346,3888,476,476,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3682,3684,3679,3667,3670,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,20.5,972,SUCCESS,,2352.442256,192,0,0.1,0.2,0.3,263,1.4,1.5
    4706,5/27/2021 0:27,18860.395,5.24,701,300,10,6001,0,65535,65535,1,21.1,25722,-296,-296,100,61,8,2345,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3667,3668,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,944,SUCCESS,,2352.112956,192,0,0.1,0.2,0.3,263,1.4,1.5
    4707,5/27/2021 0:27,18864.404,5.24,701,300,10,6001,0,65535,65535,1,21.1,25721,-298,-296,100,61,8,2345,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3678,3682,3683,3679,3666,3669,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,948,SUCCESS,,2351.7811,192,0,0.1,0.2,0.3,263,1.4,1.5
    4708,5/27/2021 0:27,18868.417,5.24,4701,300,10,6001,0,65535,65535,1,21.1,25720,-296,-296,100,61,8,2345,3888,475,475,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3666,3669,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,968,SUCCESS,,2351.451143,192,0,0.1,0.2,0.3,327,1.4,1.5
    4709,5/27/2021 0:27,18872.42,5.24,4701,300,10,6001,0,65535,65535,1,21.1,25720,-296,-296,100,61,8,2344,3888,478,475,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3666,3668,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,943,SUCCESS,,2351.122007,192,0,0.1,0.2,0.3,327,1.4,1.5
    4710,5/27/2021 0:27,18876.426,5.24,4701,300,10,6001,0,65535,65535,1,21.1,25720,-294,-296,100,61,8,2344,3888,475,475,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3666,3669,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,950,SUCCESS,,2350.79485,192,0,0.1,0.2,0.3,327,1.4,1.5
    4711,5/27/2021 0:27,18880.44,5.24,4701,300,10,6001,0,65535,65535,1,21.1,25719,-294,-296,100,61,8,2344,3888,478,475,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3666,3669,3664,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,936,SUCCESS,,2350.46704,192,0,0.1,0.2,0.3,327,1.4,1.5
    4712,5/27/2021 0:27,18884.443,5.25,701,300,10,6001,0,65535,65535,1,21.1,25719,-296,-296,100,61,8,2343,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3666,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,965,SUCCESS,,2350.137905,192,0,0.1,0.2,0.3,263,1.4,1.5
    4713,5/27/2021 0:27,18888.45,5.25,701,300,10,6001,0,65535,65535,1,21.1,25717,-298,-296,100,61,8,2343,3888,478,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3665,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.2,944,SUCCESS,,2349.806214,192,0,0.1,0.2,0.3,263,1.4,1.5
    4714,5/27/2021 0:27,18892.453,5.25,701,300,10,6001,0,65535,65535,1,21.1,25717,-296,-296,100,61,8,2343,3888,478,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3683,3679,3665,3669,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,938,SUCCESS,,2349.477079,192,0,0.1,0.2,0.3,263,1.4,1.5
    4715,5/27/2021 0:27,18896.467,5.25,701,300,10,6001,0,65535,65535,1,21.1,25718,-296,-296,100,61,8,2342,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3682,3682,3679,3665,3669,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.1,952,SUCCESS,,2349.147039,192,0,0.1,0.2,0.3,263,1.4,1.5
    4716,5/27/2021 0:27,18900.481,5.25,701,300,10,6001,0,65535,65535,1,21.1,25715,-294,-296,100,61,8,2342,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3681,3682,3679,3665,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,943,SUCCESS,,2348.819229,192,0,0.1,0.2,0.3,263,1.4,1.5
    4717,5/27/2021 0:27,18904.491,5.25,701,300,10,6001,0,65535,65535,1,21.1,25715,-296,-296,100,61,8,2342,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3681,3682,3679,3665,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,981,SUCCESS,,2348.489518,192,0,0.1,0.2,0.3,263,1.4,1.5
    4718,5/27/2021 0:27,18908.503,5.25,701,300,10,6001,0,65535,65535,1,21.1,25715,-294,-296,100,61,8,2341,3888,475,475,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3681,3682,3679,3665,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,959,SUCCESS,,2348.161871,192,0,0.1,0.2,0.3,263,1.4,1.5
    4719,5/27/2021 0:27,18912.515,5.25,4701,300,10,6001,0,65535,65535,1,21.1,25714,-296,-296,100,61,8,2341,3888,475,475,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3681,3682,3678,3665,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,940,SUCCESS,,2347.831995,192,0,0.1,0.2,0.3,327,1.4,1.5
    4720,5/27/2021 0:28,18916.527,5.25,4701,300,10,6001,0,65535,65535,1,21.1,25713,-296,-296,100,61,8,2341,3888,475,475,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3677,3681,3682,3678,3665,3668,3663,0,0,0,0,0,0,0,0,2571,21,21.1,-273.2,21.1,-273.2,21.2,945,SUCCESS,,2347.50212,192,0,0.1,0.2,0.3,327,1.4,1.5
    4721,5/27/2021 0:28,18920.535,5.26,4701,300,10,6001,0,65535,65535,1,21.1,25713,-296,-296,100,61,8,2340,3888,474,474,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3682,3678,3665,3668,3663,0,0,0,0,0,0,0,0,2572,21,21.1,-273.2,21.1,-273.2,21.3,988,SUCCESS,,2347.172573,192,0,0.1,0.2,0.3,327,1.4,1.5
    4722,5/27/2021 0:28,18924.537,5.26,4701,300,10,6001,0,65535,65535,1,21.1,25713,-296,-296,100,61,8,2340,3888,474,474,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3681,3682,3678,3665,3668,3663,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,981,SUCCESS,,2346.84352,192,0,0.1,0.2,0.3,327,1.4,1.5
    4723,5/27/2021 0:28,18928.55,5.26,701,300,10,6001,0,65535,65535,1,21.1,25712,-296,-296,100,61,8,2340,3888,474,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3682,3678,3664,3668,3663,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,941,SUCCESS,,2346.513562,192,0,0.1,0.2,0.3,263,1.4,1.5
    4724,5/27/2021 0:28,18932.561,5.26,701,300,10,6001,0,65535,65535,1,21.1,25711,-298,-296,100,61,8,2339,3888,471,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3682,3678,3664,3668,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,940,SUCCESS,,2346.18154,192,0,0.1,0.2,0.3,263,1.4,1.5
    4725,5/27/2021 0:28,18936.573,5.26,701,300,10,6001,0,65535,65535,1,21.1,25711,-296,-296,100,61,8,2339,3888,474,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3682,3678,3664,3668,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,944,SUCCESS,,2345.851665,192,0,0.1,0.2,0.3,263,1.4,1.5
    4726,5/27/2021 0:28,18940.576,5.26,701,300,10,6001,0,65535,65535,1,21.1,25710,-296,-296,100,61,8,2339,3888,474,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3682,3677,3664,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,962,SUCCESS,,2345.522529,192,0,0.1,0.2,0.3,263,1.4,1.5
    4727,5/27/2021 0:28,18944.584,5.26,701,300,10,6001,0,65535,65535,1,21.1,25708,-296,-296,100,61,8,2338,3888,474,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3682,3677,3664,3668,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,948,SUCCESS,,2345.192983,192,0,0.1,0.2,0.3,263,1.4,1.5
    4728,5/27/2021 0:28,18948.592,5.26,701,300,10,6001,0,65535,65535,1,21.1,25706,-298,-296,100,61,8,2338,3888,471,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3675,3680,3681,3677,3664,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,942,SUCCESS,,2344.861209,192,0,0.1,0.2,0.3,263,1.4,1.5
    4729,5/27/2021 0:28,18952.6,5.26,701,300,10,6001,0,65535,65535,1,21.1,25706,-296,-296,100,61,8,2338,3888,474,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3676,3680,3681,3677,3664,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,964,SUCCESS,,2344.531663,192,0,0.1,0.2,0.3,263,1.4,1.5
    4730,5/27/2021 0:28,18956.602,5.27,4701,300,10,6001,0,65535,65535,1,21.1,25706,-296,-296,100,61,8,2337,3888,474,474,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3675,3680,3681,3677,3664,3668,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,967,SUCCESS,,2344.202609,192,0,0.1,0.2,0.3,327,1.4,1.5
    4731,5/27/2021 0:28,18960.617,5.27,4701,300,10,6001,0,65535,65535,1,21.1,25705,-296,-296,100,61,8,2337,3888,474,474,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3675,3680,3681,3677,3664,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,962,SUCCESS,,2343.872487,192,0,0.1,0.2,0.3,327,1.4,1.5
    4732,5/27/2021 0:28,18964.627,5.27,4701,300,10,6001,0,65535,65535,1,21.1,25704,-294,-296,100,61,8,2337,3888,477,474,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3675,3680,3681,3677,3663,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,939,SUCCESS,,2343.545004,192,0,0.1,0.2,0.3,327,1.4,1.5
    4733,5/27/2021 0:28,18968.638,5.27,4701,300,10,6001,0,65535,65535,1,21.1,25704,-296,-296,100,61,8,2336,3888,477,474,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3680,3681,3677,3664,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,947,SUCCESS,,2343.21521,192,0,0.1,0.2,0.3,327,1.4,1.5
    4734,5/27/2021 0:28,18972.652,5.27,701,300,10,6001,0,65535,65535,1,21.1,25704,-296,-296,100,61,8,2336,3888,477,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3680,3681,3677,3664,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,951,SUCCESS,,2342.88517,192,0,0.1,0.2,0.3,263,1.4,1.5
    4735,5/27/2021 0:29,18976.662,5.27,701,300,10,6001,0,65535,65535,1,21.1,25703,-298,-296,100,61,8,2336,3888,470,474,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3677,3663,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,991,SUCCESS,,2342.553231,192,0,0.1,0.2,0.3,263,1.4,1.5
    4736,5/27/2021 0:29,18980.675,5.27,701,300,10,6001,0,65535,65535,1,21.1,25702,-296,-296,100,61,8,2335,3888,470,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3677,3663,3667,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,990,SUCCESS,,2342.223274,192,0,0.1,0.2,0.3,263,1.4,1.5
    4737,5/27/2021 0:29,18984.681,5.27,701,300,10,6001,0,65535,65535,1,21.1,25701,-296,-296,100,61,8,2335,3888,470,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3677,3663,3666,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,962,SUCCESS,,2341.893891,192,0,0.1,0.2,0.3,263,1.4,1.5
    4738,5/27/2021 0:29,18988.683,5.27,701,300,10,6001,0,65535,65535,1,21.1,25701,-296,-296,100,61,8,2335,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3677,3663,3665,3662,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,943,SUCCESS,,2341.564838,192,0,0.1,0.2,0.3,263,1.4,1.5
    4739,5/27/2021 0:29,18992.696,5.28,701,300,10,6001,0,65535,65535,1,21.1,25698,-296,-296,100,61,8,2334,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3666,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,983,SUCCESS,,2341.23488,192,0,0.1,0.2,0.3,263,1.4,1.5
    4740,5/27/2021 0:29,18996.71,5.28,701,300,10,6001,0,65535,65535,1,21.1,25699,-294,-296,100,61,8,2334,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3665,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,954,SUCCESS,,2340.90707,192,0,0.1,0.2,0.3,263,1.4,1.5
    4741,5/27/2021 0:29,19000.719,5.28,701,300,10,6001,0,65535,65535,1,21.1,25698,-294,-296,100,61,8,2334,3888,470,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3665,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,971,SUCCESS,,2340.579669,192,0,0.1,0.2,0.3,263,1.4,1.5
    4742,5/27/2021 0:29,19004.734,5.28,701,300,10,6001,0,65535,65535,1,21.1,25699,-298,-296,100,61,8,2333,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3666,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,940,SUCCESS,,2340.247316,192,0,0.1,0.2,0.3,263,1.4,1.5
    4743,5/27/2021 0:29,19008.738,5.28,701,300,10,6001,0,65535,65535,1,21.1,25698,-298,-296,100,61,8,2333,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3665,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,937,SUCCESS,,2339.915874,192,0,0.1,0.2,0.3,263,1.4,1.5
    4744,5/27/2021 0:29,19012.745,5.28,701,300,10,6001,0,65535,65535,1,21.1,25698,-296,-296,100,61,8,2333,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3665,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,943,SUCCESS,,2339.586409,192,0,0.1,0.2,0.3,263,1.4,1.5
    4745,5/27/2021 0:29,19016.761,5.28,4701,300,10,6001,0,65535,65535,1,21.1,25698,-296,-296,100,60,8,2332,3888,473,473,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3666,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,967,SUCCESS,,2339.256205,192,0,0.1,0.2,0.3,327,1.4,1.5
    4746,5/27/2021 0:29,19020.775,5.28,4701,300,10,6001,0,65535,65535,1,21.1,25696,-298,-296,100,60,8,2332,3888,473,473,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,968,SUCCESS,,2338.923935,192,0,0.1,0.2,0.3,327,1.4,1.5
    4747,5/27/2021 0:29,19024.783,5.28,4701,300,10,6001,0,65535,65535,1,21.1,25697,-294,-296,100,60,8,2332,3888,473,473,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3663,3665,3661,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,937,SUCCESS,,2338.596615,192,0,0.1,0.2,0.3,327,1.4,1.5
    4748,5/27/2021 0:29,19028.789,5.29,4701,300,10,6001,0,65535,65535,1,21.1,25697,-296,-296,100,60,8,2331,3888,476,473,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3679,3680,3676,3662,3666,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,949,SUCCESS,,2338.267233,192,0,0.1,0.2,0.3,327,1.4,1.5
    4749,5/27/2021 0:29,19032.804,5.29,701,300,10,6001,0,65535,65535,1,21.1,25694,-298,-296,100,60,8,2331,3888,469,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3676,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,947,SUCCESS,,2337.93488,192,0,0.1,0.2,0.3,263,1.4,1.5
    4750,5/27/2021 0:30,19036.808,5.29,701,300,10,6001,0,65535,65535,1,21.1,25694,-294,-296,100,60,8,2331,3888,473,473,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3676,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,982,SUCCESS,,2337.607886,192,0,0.1,0.2,0.3,263,1.4,1.5
    4751,5/27/2021 0:30,19040.816,5.29,701,300,10,6001,0,65535,65535,1,21.1,25693,-296,-296,100,60,8,2330,3888,476,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3675,3662,3666,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,983,SUCCESS,,2337.27834,192,0,0.1,0.2,0.3,263,1.4,1.5
    4752,5/27/2021 0:30,19044.82,5.29,701,300,10,6001,0,65535,65535,1,21.1,25694,-296,-296,100,60,8,2330,3888,472,472,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3676,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,954,SUCCESS,,2336.949122,192,0,0.1,0.2,0.3,327,1.4,1.5
    4753,5/27/2021 0:30,19048.829,5.29,4701,300,10,6001,0,65535,65535,1,21.1,25693,-294,-296,100,60,8,2330,3888,476,472,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,956,SUCCESS,,2336.62172,192,0,0.1,0.2,0.3,327,1.4,1.5
    4754,5/27/2021 0:30,19052.843,5.29,4701,300,10,6001,0,65535,65535,1,21.1,25692,-296,-296,100,60,8,2329,3888,469,472,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,948,SUCCESS,,2336.29168,192,0,0.1,0.2,0.3,327,1.4,1.5
    4755,5/27/2021 0:30,19056.858,5.29,4701,300,10,6001,0,65535,65535,1,21.1,25693,-294,-296,100,60,8,2329,3888,475,472,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,940,SUCCESS,,2335.963789,192,0,0.1,0.2,0.3,327,1.4,1.5
    4756,5/27/2021 0:30,19060.869,5.29,701,300,10,6001,0,65535,65535,1,21.1,25693,-298,-296,100,60,8,2329,3888,469,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,949,SUCCESS,,2335.631767,192,0,0.1,0.2,0.3,263,1.4,1.5
    4757,5/27/2021 0:30,19064.877,5.3,701,300,10,6001,0,65535,65535,1,21.1,25693,-296,-296,100,60,8,2328,3888,472,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3678,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,20.6,953,SUCCESS,,2335.30222,192,0,0.1,0.2,0.3,263,1.4,1.5
    4758,5/27/2021 0:30,19068.884,5.3,701,300,10,6001,0,65535,65535,1,21.1,25693,-294,-296,100,60,8,2328,3888,475,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,945,SUCCESS,,2334.974982,192,0,0.1,0.2,0.3,263,1.4,1.5
    4759,5/27/2021 0:30,19072.891,5.3,701,300,10,6001,0,65535,65535,1,21.1,25692,-298,-296,100,60,8,2328,3888,469,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3679,3675,3661,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,939,SUCCESS,,2334.643291,192,0,0.1,0.2,0.3,263,1.4,1.5
    4760,5/27/2021 0:30,19076.896,5.3,701,300,10,6001,0,65535,65535,1,21.1,25690,-296,-296,100,60,8,2327,3888,472,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3679,3675,3661,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,937,SUCCESS,,2334.313991,192,0,0.1,0.2,0.3,263,1.4,1.5
    4761,5/27/2021 0:30,19080.906,5.3,701,300,10,6001,0,65535,65535,1,21.1,25689,-296,-296,100,60,8,2327,3888,472,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3679,3675,3662,3665,3660,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,959,SUCCESS,,2333.98428,192,0,0.1,0.2,0.3,263,1.4,1.5
    4762,5/27/2021 0:30,19084.915,5.3,701,300,10,6001,0,65535,65535,1,21.1,25690,-294,-296,100,60,8,2327,3888,475,472,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3679,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,965,SUCCESS,,2333.656879,192,0,0.1,0.2,0.3,263,1.4,1.5
    4763,5/27/2021 0:30,19088.93,5.3,701,300,10,6001,0,65535,65535,1,21.1,25689,-296,-296,100,60,8,2326,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3679,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,963,SUCCESS,,2333.326756,192,0,0.1,0.2,0.3,263,1.4,1.5
    4764,5/27/2021 0:31,19092.939,5.3,4701,300,10,6001,0,65535,65535,1,21.1,25688,-296,-296,100,60,8,2326,3888,471,471,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,952,SUCCESS,,2332.997128,192,0,0.1,0.2,0.3,327,1.4,1.5
    4765,5/27/2021 0:31,19096.943,5.3,4701,300,10,6001,0,65535,65535,1,21.1,25687,-298,-296,100,60,8,2326,3888,468,471,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,981,SUCCESS,,2332.665685,192,0,0.1,0.2,0.3,327,1.4,1.5
    4766,5/27/2021 0:31,19100.949,5.31,4701,300,10,6001,0,65535,65535,1,21.1,25685,-296,-296,100,60,8,2325,3888,471,471,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21,950,SUCCESS,,2332.336303,192,0,0.1,0.2,0.3,327,1.4,1.5
    4767,5/27/2021 0:31,19104.958,5.31,701,300,10,6001,0,65535,65535,1,21.1,25687,-296,-296,100,60,8,2325,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3674,3677,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,953,SUCCESS,,2332.006674,192,0,0.1,0.2,0.3,263,1.4,1.5
    4768,5/27/2021 0:31,19108.961,5.31,701,300,10,6001,0,65535,65535,1,21.1,25685,-294,-296,100,60,8,2325,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3677,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,956,SUCCESS,,2331.679763,192,0,0.1,0.2,0.3,263,1.4,1.5
    4769,5/27/2021 0:31,19112.974,5.31,701,300,10,6001,0,65535,65535,1,21.1,25686,-296,-296,100,60,8,2324,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3676,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,996,SUCCESS,,2331.349805,192,0,0.1,0.2,0.3,263,1.4,1.5
    4770,5/27/2021 0:31,19116.98,5.31,701,300,10,6001,0,65535,65535,1,21.1,25686,-298,-297,100,60,8,2324,3888,468,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3677,3678,3674,3661,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.3,944,SUCCESS,,2331.018197,192,0,0.1,0.2,0.3,263,1.4,1.5
    4771,5/27/2021 0:31,19120.99,5.31,701,300,10,6001,0,65535,65535,1,21.1,25687,-296,-297,100,60,8,2324,3888,471,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3677,3678,3674,3660,3665,3659,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,965,SUCCESS,,2330.688486,192,0,0.1,0.2,0.3,263,1.4,1.5
    4772,5/27/2021 0:31,19125.003,5.31,701,300,10,6001,0,65535,65535,1,21.1,25685,-298,-296,100,60,8,2323,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3676,3677,3674,3660,3664,3659,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.3,938,SUCCESS,,2330.356299,192,0,0.1,0.2,0.3,263,1.4,1.5
    4773,5/27/2021 0:31,19129.005,5.31,701,300,10,6001,0,65535,65535,1,21.1,25683,-298,-296,100,60,8,2323,3888,468,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3676,3678,3673,3660,3665,3658,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,951,SUCCESS,,2330.025022,192,0,0.1,0.2,0.3,263,1.4,1.5
    4774,5/27/2021 0:31,19133.009,5.31,701,300,10,6001,0,65535,65535,1,21.1,25682,-296,-296,100,60,8,2323,3888,474,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3676,3677,3673,3660,3664,3658,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.3,979,SUCCESS,,2329.695804,192,0,0.1,0.2,0.3,263,1.4,1.5
    4775,5/27/2021 0:31,19137.011,5.32,701,300,10,6001,0,65535,65535,1,21.1,25681,-298,-296,100,60,8,2322,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3676,3677,3673,3660,3664,3658,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,946,SUCCESS,,2329.364528,192,0,0.1,0.2,0.3,263,1.4,1.5
    4776,5/27/2021 0:31,19141.012,5.32,701,300,10,6001,0,65535,65535,1,21.1,25681,-296,-296,100,60,8,2322,3888,474,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3673,3676,3677,3673,3660,3664,3658,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,978,SUCCESS,,2329.035556,192,0,0.1,0.2,0.3,263,1.4,1.5
    4777,5/27/2021 0:31,19145.025,5.32,701,300,10,6001,0,65535,65535,1,21.1,25682,-296,-296,100,60,8,2322,3888,471,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3676,3677,3673,3660,3664,3658,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,932,SUCCESS,,2328.705599,192,0,0.1,0.2,0.3,263,1.4,1.5
    4778,5/27/2021 0:31,19149.031,5.32,701,300,10,6001,0,65535,65535,1,21.1,25680,-294,-296,100,60,8,2322,3888,468,471,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,,0,0,0,0,0,0,0,3672,3676,3677,3673,3660,3663,3658,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,933,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2328.378442,192,0,0.1,0.2,0.3,263,1.4,1.5
    4779,5/27/2021 0:32,19153.039,5.32,4701,300,10,6001,0,65535,65535,1,21.1,25680,-296,-296,100,60,8,2321,3888,470,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3676,3677,3672,3660,3664,3658,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,948,SUCCESS,,2328.048895,192,0,0.1,0.2,0.3,327,1.4,1.5
    4780,5/27/2021 0:32,19157.044,5.32,4701,300,10,6001,0,65535,65535,1,21.1,25680,-296,-296,100,60,8,2321,3888,470,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3676,3677,3673,3660,3664,3658,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,977,SUCCESS,,2327.719595,192,0,0.1,0.2,0.3,327,1.4,1.5
    4781,5/27/2021 0:32,19161.052,5.32,4701,300,10,6001,0,65535,65535,1,21.1,25678,-296,-296,100,60,8,2321,3888,470,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3676,3677,3672,3660,3660,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,974,SUCCESS,,2327.390049,192,0,0.1,0.2,0.3,327,1.4,1.5
    4782,5/27/2021 0:32,19165.064,5.32,701,300,10,6001,0,65535,65535,1,21.1,25677,-296,-296,100,60,8,2320,3888,473,470,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3675,3677,3672,3660,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,962,SUCCESS,,2327.060173,192,0,0.1,0.2,0.3,263,1.4,1.5
    4783,5/27/2021 0:32,19169.068,5.32,701,300,10,6001,0,65535,65535,1,21.1,25677,-300,-296,100,60,8,2320,3888,467,470,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3676,3676,3672,3660,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,950,SUCCESS,,2326.726506,192,0,0.1,0.2,0.3,263,1.4,1.5
    4784,5/27/2021 0:32,19173.081,5.33,701,300,10,6001,0,65535,65535,1,21.1,25676,-296,-296,100,60,8,2320,3888,470,470,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3672,3675,3677,3672,3659,3659,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,947,SUCCESS,,2326.396549,192,0,0.1,0.2,0.3,263,1.4,1.5
    4785,5/27/2021 0:32,19177.087,5.33,701,300,10,6001,0,65535,65535,1,21.1,25673,-296,-296,100,60,8,2319,3888,473,470,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3675,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.3,965,SUCCESS,,2326.067166,192,0,0.1,0.2,0.3,263,1.4,1.5
    4786,5/27/2021 0:32,19181.093,5.33,4701,300,10,6001,0,65535,65535,1,21.1,25673,-294,-296,100,60,8,2319,3888,467,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3675,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,21,21.1,-273.2,21.1,-273.2,21.2,965,SUCCESS,,2325.74001,192,0,0.1,0.2,0.3,327,1.4,1.5
    4787,5/27/2021 0:32,19185.095,5.33,4701,300,10,6001,0,65535,65535,1,21.1,25673,-298,-296,100,60,8,2319,3888,467,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3675,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.3,973,SUCCESS,,2325.408733,192,0,0.1,0.2,0.3,327,1.4,1.5
    4788,5/27/2021 0:32,19189.102,5.33,4701,300,10,6001,0,65535,65535,1,21.1,25673,-296,-296,100,60,8,2318,3888,470,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3675,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,971,SUCCESS,,2325.079269,192,0,0.1,0.2,0.3,327,1.4,1.5
    4789,5/27/2021 0:32,19193.107,5.33,4701,300,10,6001,0,65535,65535,1,21.1,25673,-298,-296,100,60,8,2318,3888,467,470,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3675,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,945,SUCCESS,,2324.747744,192,0,0.1,0.2,0.3,327,1.4,1.5
    4790,5/27/2021 0:32,19197.12,5.33,701,300,10,6001,0,65535,65535,1,21.1,25673,-296,-296,100,60,8,2317,3888,470,470,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,963,SUCCESS,,2324.417786,192,0,0.1,0.2,0.3,263,1.4,1.5
    4791,5/27/2021 0:32,19201.125,5.33,701,300,10,6001,0,65535,65535,1,21.1,25672,-298,-296,100,60,8,2317,3888,467,470,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,947,SUCCESS,,2324.086261,192,0,0.1,0.2,0.3,263,1.4,1.5
    4792,5/27/2021 0:32,19205.132,5.33,701,300,10,6001,0,65535,65535,1,21.1,25673,-300,-297,100,60,8,2317,3888,463,468,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2564,20.9,21.1,-273.2,21.1,-273.2,21.1,952,SUCCESS,,2323.752344,192,0,0.1,0.2,0.3,263,1.4,1.5
    4793,5/27/2021 0:32,19209.134,5.34,701,300,10,6001,0,65535,65535,1,21.1,25673,-296,-296,100,60,8,2316,3888,469,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3663,3656,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21,964,SUCCESS,,2323.423291,192,0,0.1,0.2,0.3,263,1.4,1.5
    4794,5/27/2021 0:33,19213.137,5.34,701,300,10,6001,0,65535,65535,1,21.1,25671,-296,-296,100,60,8,2316,3888,469,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3663,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,967,SUCCESS,,2323.094155,192,0,0.1,0.2,0.3,263,1.4,1.5
    4795,5/27/2021 0:33,19217.141,5.34,701,300,10,6001,0,65535,65535,1,21.1,25670,-294,-296,100,60,8,2316,3888,473,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3662,3657,0,0,0,0,0,0,0,0,2567,20.9,21.1,-273.2,21.1,-273.2,21.2,943,SUCCESS,,2322.767162,192,0,0.1,0.2,0.3,263,1.4,1.5
    4796,5/27/2021 0:33,19221.151,5.34,701,300,10,6001,0,65535,65535,1,21.1,25669,-296,-296,100,60,8,2316,3888,469,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3676,3672,3659,3663,3656,0,0,0,0,0,0,0,0,2566,20.9,21,-273.2,21,-273.2,21.2,948,SUCCESS,,2322.437451,192,0,0.1,0.2,0.3,263,1.4,1.5
    4797,5/27/2021 0:33,19225.153,5.34,701,300,10,6001,0,65535,65535,1,21.1,25669,-296,-296,100,60,8,2315,3888,469,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3676,3672,3659,3662,3656,0,0,0,0,0,0,0,0,2564,20.9,21,-273.2,21,-273.2,21.2,977,SUCCESS,,2322.108398,192,0,0.1,0.2,0.3,263,1.4,1.5
    4798,5/27/2021 0:33,19229.158,5.34,701,300,10,6001,0,65535,65535,1,21.1,25668,-296,-296,100,60,8,2315,3888,469,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3671,3674,3675,3672,3658,3662,3656,0,0,0,0,0,0,0,0,2566,20.9,21.1,-273.2,21.1,-273.2,21.2,947,SUCCESS,,2321.779098,192,0,0.1,0.2,0.3,263,1.4,1.5
    4799,5/27/2021 0:33,19233.169,5.34,701,300,10,6001,0,65535,65535,1,21.1,25667,-296,-296,100,60,8,2315,3888,469,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3675,3672,3659,3662,3656,0,0,0,0,0,0,0,0,2566,20.9,21.1,-273.2,21.1,-273.2,21.2,960,SUCCESS,,2321.449304,192,0,0.1,0.2,0.3,263,1.4,1.5
    4800,5/27/2021 0:33,19237.183,5.34,701,300,10,6001,0,65535,65535,1,21.1,25667,-298,-296,100,60,8,2314,3888,466,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3675,3672,3659,3662,3656,0,0,0,0,0,0,0,0,2563,20.9,21.1,-273.2,21.1,-273.2,21.3,976,SUCCESS,,2321.117034,192,0,0.1,0.2,0.3,263,1.4,1.5
    4801,5/27/2021 0:33,19241.185,5.34,4701,300,10,6001,0,65535,65535,1,21.1,25667,-296,-296,100,60,8,2314,3888,469,469,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3675,3672,3658,3662,3656,0,0,0,0,0,0,0,0,2563,20.9,21.1,-273.2,21.1,-273.2,21.1,982,SUCCESS,,2320.787981,192,0,0.1,0.2,0.3,327,1.4,1.5
    4802,5/27/2021 0:33,19245.192,5.35,4701,300,10,6001,0,65535,65535,1,21.1,25667,-298,-296,100,60,8,2314,3888,469,469,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3675,3672,3658,3662,3656,0,0,0,0,0,0,0,0,2563,20.9,21.1,-273.2,21.1,-273.2,21.1,933,SUCCESS,,2320.45629,192,0,0.1,0.2,0.3,327,1.4,1.5
    4803,5/27/2021 0:33,19249.201,5.35,4701,300,10,6001,0,65535,65535,1,21.1,25666,-298,-297,100,60,8,2313,3888,469,467,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3675,3672,3658,3661,3656,0,0,0,0,0,0,0,0,2563,20.9,21.1,-273.2,21.1,-273.2,21.3,961,SUCCESS,,2320.124434,192,0,0.1,0.2,0.3,327,1.4,1.5
    4804,5/27/2021 0:33,19253.214,5.35,4701,300,10,6001,0,65535,65535,1,21.1,25667,-298,-296,100,60,8,2313,3888,469,469,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3674,3675,3672,3658,3662,3656,0,0,0,0,0,0,0,0,2563,20.9,21.1,-273.2,21.1,-273.2,21.2,980,SUCCESS,,2319.792247,192,0,0.1,0.2,0.3,327,1.4,1.5
    4805,5/27/2021 0:33,19257.217,5.35,701,300,10,6001,0,65535,65535,1,21,25667,-296,-297,100,60,8,2313,3888,469,467,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3673,3675,3672,3657,3662,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.1,944,SUCCESS,,2319.463111,192,0,0.1,0.2,0.3,263,1.4,1.5
    4806,5/27/2021 0:33,19261.231,5.35,701,300,10,6001,0,65535,65535,1,21,25665,-296,-296,100,60,8,2312,3888,472,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3673,3674,3672,3658,3661,3656,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,944,SUCCESS,,2319.133071,192,0,0.1,0.2,0.3,263,1.4,1.5
    4807,5/27/2021 0:33,19265.234,5.35,701,300,10,6001,0,65535,65535,1,21,25663,-296,-296,100,60,8,2312,3888,472,469,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3673,3674,3672,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,947,SUCCESS,,2318.803936,192,0,0.1,0.2,0.3,263,1.4,1.5
    4808,5/27/2021 0:33,19269.248,5.35,701,300,10,6001,0,65535,65535,1,21,25662,-296,-297,100,60,8,2312,3888,466,467,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3673,3674,3672,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,975,SUCCESS,,2318.473896,192,0,0.1,0.2,0.3,263,1.4,1.5
    4809,5/27/2021 0:34,19273.249,5.35,701,300,10,6001,0,65535,65535,1,21,25662,-296,-296,100,60,8,2311,3888,468,468,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3673,3674,3672,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,943,SUCCESS,,2318.144925,192,0,0.1,0.2,0.3,263,1.4,1.5
    4810,5/27/2021 0:34,19277.258,5.35,701,300,10,6001,0,65535,65535,1,21,25662,-296,-296,100,60,8,2311,3888,465,468,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3673,3674,3672,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,965,SUCCESS,,2317.815296,192,0,0.1,0.2,0.3,263,1.4,1.5
    4811,5/27/2021 0:34,19281.259,5.36,701,300,10,6001,0,65535,65535,1,21,25661,-296,-297,100,60,8,2311,3888,465,467,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3670,3673,3674,3672,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,949,SUCCESS,,2317.486325,192,0,0.1,0.2,0.3,263,1.4,1.5
    4812,5/27/2021 0:34,19285.271,5.36,4701,300,10,6001,0,65535,65535,1,21,25660,-296,-297,100,60,8,2310,3888,465,467,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3673,3674,3672,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,937,SUCCESS,,2317.156449,192,0,0.1,0.2,0.3,327,1.4,1.5
    4813,5/27/2021 0:34,19289.279,5.36,4701,300,10,6001,0,65535,65535,1,21,25660,-298,-297,100,60,8,2310,3888,468,467,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3673,3674,3672,3657,3660,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,943,SUCCESS,,2316.824676,192,0,0.1,0.2,0.3,327,1.4,1.5
    4814,5/27/2021 0:34,19293.293,5.36,4701,300,10,6001,0,65535,65535,1,21,25659,-296,-297,100,60,8,2310,3888,471,467,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3673,3674,3671,3657,3661,3655,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,946,SUCCESS,,2316.494636,192,0,0.1,0.2,0.3,327,1.4,1.5
    4815,5/27/2021 0:34,19297.297,5.36,4701,300,10,6001,0,65535,65535,1,21,25658,-298,-296,100,60,8,2309,3888,468,468,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3673,3674,3671,3657,3661,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,1004,SUCCESS,,2316.163194,192,0,0.1,0.2,0.3,327,1.4,1.5
    4816,5/27/2021 0:34,19301.303,5.36,701,300,10,6001,0,65535,65535,1,21,25658,-300,-297,100,60,8,2309,3888,468,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3672,3674,3671,3657,3661,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,20.9,951,SUCCESS,,2315.82936,192,0,0.1,0.2,0.3,263,1.4,1.5
    4817,5/27/2021 0:34,19305.316,5.36,701,300,10,6001,0,65535,65535,1,21,25658,-298,-297,100,60,8,2309,3888,468,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3672,3673,3671,3657,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,961,SUCCESS,,2315.497173,192,0,0.1,0.2,0.3,263,1.4,1.5
    4818,5/27/2021 0:34,19309.327,5.36,701,300,10,6001,0,65535,65535,1,21,25657,-298,-297,100,60,8,2308,3888,465,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3672,3674,3671,3657,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,944,SUCCESS,,2315.165151,192,0,0.1,0.2,0.3,263,1.4,1.5
    4819,5/27/2021 0:34,19313.343,5.36,701,300,10,6001,0,65535,65535,1,21,25654,-296,-297,100,60,8,2308,3888,468,466,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3674,3671,3657,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,942,SUCCESS,,2314.834947,192,0,0.1,0.2,0.3,327,1.4,1.5
    4820,5/27/2021 0:34,19317.343,5.37,4701,300,10,6001,0,65535,65535,1,21,25656,-296,-297,100,60,8,2308,3888,468,466,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3669,3672,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,965,SUCCESS,,2314.506058,192,0,0.1,0.2,0.3,327,1.4,1.5
    4821,5/27/2021 0:34,19321.348,5.37,4701,300,10,6001,0,65535,65535,1,21,25654,-298,-297,100,60,8,2307,3888,464,466,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3673,3670,3657,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,938,SUCCESS,,2314.174533,192,0,0.1,0.2,0.3,327,1.4,1.5
    4822,5/27/2021 0:34,19325.363,5.37,4701,300,10,6001,0,65535,65535,1,21.1,25654,-296,-297,100,60,8,2307,3888,464,466,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,955,SUCCESS,,2313.844411,192,0,0.1,0.2,0.3,327,1.4,1.5
    4823,5/27/2021 0:34,19329.373,5.37,701,300,10,6001,0,65535,65535,1,21,25653,-296,-297,100,60,8,2307,3888,464,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,943,SUCCESS,,2313.5147,192,0,0.1,0.2,0.3,263,1.4,1.5
    4824,5/27/2021 0:35,19333.383,5.37,701,300,10,6001,0,65535,65535,1,21,25653,-300,-297,100,60,8,2306,3888,461,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,996,SUCCESS,,2313.180533,192,0,0.1,0.2,0.3,263,1.4,1.5
    4825,5/27/2021 0:35,19337.396,5.37,701,300,10,6001,0,65535,65535,1,21,25652,-296,-297,100,60,8,2306,3888,467,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,956,SUCCESS,,2312.850575,192,0,0.1,0.2,0.3,263,1.4,1.5
    4826,5/27/2021 0:35,19341.401,5.37,701,300,10,6001,0,65535,65535,1,21,25653,-296,-297,100,60,8,2306,3888,467,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3672,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,952,SUCCESS,,2312.521275,192,0,0.1,0.2,0.3,263,1.4,1.5
    4827,5/27/2021 0:35,19345.415,5.37,701,300,10,6001,0,65535,65535,1,21,25652,-298,-297,100,60,8,2305,3888,464,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,949,SUCCESS,,2312.189005,192,0,0.1,0.2,0.3,263,1.4,1.5
    4828,5/27/2021 0:35,19349.418,5.37,701,300,10,6001,0,65535,65535,1,21,25651,-296,-297,100,60,8,2305,3888,467,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3670,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,962,SUCCESS,,2311.85987,192,0,0.1,0.2,0.3,263,1.4,1.5
    4829,5/27/2021 0:35,19353.427,5.38,701,300,10,6001,0,65535,65535,1,21,25651,-298,-297,100,60,8,2305,3888,464,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3669,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,936,SUCCESS,,2311.528014,192,0,0.1,0.2,0.3,263,1.4,1.5
    4830,5/27/2021 0:35,19357.43,5.38,701,300,10,6001,0,65535,65535,1,21,25651,-296,-297,100,60,8,2304,3888,467,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3669,3656,3660,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,935,SUCCESS,,2311.198878,192,0,0.1,0.2,0.3,263,1.4,1.5
    4831,5/27/2021 0:35,19361.437,5.38,701,300,10,6001,0,65535,65535,1,21,25650,-296,-297,100,60,8,2304,3888,467,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3669,3656,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,943,SUCCESS,,2310.869414,192,0,0.1,0.2,0.3,263,1.4,1.5
    4832,5/27/2021 0:35,19365.438,5.38,701,300,10,6001,0,65535,65535,1,21,25652,-298,-297,100,60,8,2304,3888,464,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3669,3656,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,947,SUCCESS,,2310.53822,192,0,0.1,0.2,0.3,263,1.4,1.5
    4833,5/27/2021 0:35,19369.447,5.38,701,300,10,6001,0,65535,65535,1,21,25650,-296,-297,100,60,8,2303,3888,467,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3668,3671,3673,3669,3656,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,955,SUCCESS,,2310.208591,192,0,0.1,0.2,0.3,263,1.4,1.5
    4834,5/27/2021 0:35,19373.456,5.38,701,300,10,6001,0,65535,65535,1,21,25648,-298,-297,100,60,8,2303,3888,467,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3671,3672,3669,3656,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,937,SUCCESS,,2309.876735,192,0,0.1,0.2,0.3,263,1.4,1.5
    4835,5/27/2021 0:35,19377.457,5.38,701,300,10,6001,0,65535,65535,1,21,25648,-298,-297,100,60,8,2303,3888,464,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3671,3672,3669,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,959,SUCCESS,,2309.545541,192,0,0.1,0.2,0.3,263,1.4,1.5
    4836,5/27/2021 0:35,19381.465,5.38,701,300,10,6001,0,65535,65535,1,21,25647,-296,-297,100,60,8,2302,3888,470,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3671,3672,3669,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.1,946,SUCCESS,,2309.215994,192,0,0.1,0.2,0.3,263,1.4,1.5
    4837,5/27/2021 0:35,19385.472,5.38,701,300,10,6001,0,65535,65535,1,21,25645,-298,-297,100,60,8,2302,3888,463,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3671,3672,3669,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,956,SUCCESS,,2308.884304,192,0,0.1,0.2,0.3,263,1.4,1.5
    4838,5/27/2021 0:35,19389.484,5.39,701,300,10,6001,0,65535,65535,1,21,25649,-294,-297,100,60,8,2302,3888,470,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3672,3668,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,973,SUCCESS,,2308.556657,192,0,0.1,0.2,0.3,263,1.4,1.5
    4839,5/27/2021 0:36,19393.489,5.39,701,300,10,6001,0,65535,65535,1,21,25646,-296,-297,100,60,8,2301,3888,470,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3672,3668,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,20.6,980,SUCCESS,,2308.227357,192,0,0.1,0.2,0.3,263,1.4,1.5
    4840,5/27/2021 0:36,19397.501,5.39,701,300,10,6001,0,65535,65535,1,21,25644,-298,-297,100,60,8,2301,3888,463,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3672,3668,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,940,SUCCESS,,2307.895253,192,0,0.1,0.2,0.3,263,1.4,1.5
    4841,5/27/2021 0:36,19401.512,5.39,701,300,10,6001,0,65535,65535,1,21,25649,-296,-297,100,60,8,2301,3888,466,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3672,3668,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,945,SUCCESS,,2307.565459,192,0,0.1,0.2,0.3,263,1.4,1.5
    4842,5/27/2021 0:36,19405.519,5.39,701,300,10,6001,0,65535,65535,1,21,25645,-298,-296,100,60,8,2300,3888,469,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3672,3668,3655,3659,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,939,SUCCESS,,2307.233769,192,0,0.1,0.2,0.3,263,1.4,1.5
    4843,5/27/2021 0:36,19409.525,5.39,701,300,10,6001,0,65535,65535,1,21,25643,-294,-297,100,60,8,2300,3888,466,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3671,3668,3655,3658,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,957,SUCCESS,,2306.906612,192,0,0.1,0.2,0.3,263,1.4,1.5
    4844,5/27/2021 0:36,19413.527,5.39,701,300,10,6001,0,65535,65535,1,21,25647,-296,-296,100,60,8,2300,3888,463,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3670,3671,3668,3655,3658,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.1,977,SUCCESS,,2306.577559,192,0,0.1,0.2,0.3,263,1.4,1.5
    4845,5/27/2021 0:36,19417.538,5.39,701,300,10,6001,0,65535,65535,1,21,25642,-300,-296,100,60,8,2299,3888,466,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3669,3671,3668,3654,3658,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,957,SUCCESS,,2306.243309,192,0,0.1,0.2,0.3,263,1.4,1.5
    4846,5/27/2021 0:36,19421.545,5.39,701,300,10,6001,0,65535,65535,1,21,25641,-298,-296,100,60,8,2299,3888,466,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3668,3654,3658,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,943,SUCCESS,,2305.911618,192,0,0.1,0.2,0.3,263,1.4,1.5
    4847,5/27/2021 0:36,19425.555,5.4,701,300,10,6001,0,65535,65535,1,21,25641,-296,-296,100,60,8,2299,3888,466,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3667,3669,3671,3668,3654,3658,3654,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,966,SUCCESS,,2305.581907,192,0,0.1,0.2,0.3,263,1.4,1.5
    4848,5/27/2021 0:36,19429.556,5.4,701,300,10,6001,0,65535,65535,1,21,25640,-298,-296,100,60,8,2298,3888,466,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3668,3654,3658,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,20.7,950,SUCCESS,,2305.250713,192,0,0.1,0.2,0.3,263,1.4,1.5
    4849,5/27/2021 0:36,19433.557,5.4,701,300,10,6001,0,65535,65535,1,21,25640,-294,-296,100,60,8,2298,3888,466,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3668,3654,3657,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,932,SUCCESS,,2304.923965,192,0,0.1,0.2,0.3,263,1.4,1.5
    4850,5/27/2021 0:36,19437.566,5.4,701,300,10,6001,0,65535,65535,1,21,25639,-294,-296,100,60,8,2298,3888,466,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3668,3654,3658,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,937,SUCCESS,,2304.596563,192,0,0.1,0.2,0.3,263,1.4,1.5
    4851,5/27/2021 0:36,19441.58,5.4,701,300,10,6001,0,65535,65535,1,21,25639,-298,-296,100,60,8,2297,3888,462,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3668,3654,3657,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,976,SUCCESS,,2304.264293,192,0,0.1,0.2,0.3,263,1.4,1.5
    4852,5/27/2021 0:36,19445.593,5.4,701,300,10,6001,0,65535,65535,1,21,25637,-296,-296,100,60,8,2297,3888,462,466,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3668,3654,3657,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.3,959,SUCCESS,,2303.934335,192,0,0.1,0.2,0.3,263,1.4,1.5
    4853,5/27/2021 0:36,19449.6,5.4,4701,300,10,6001,0,65535,65535,1,21,25637,-296,-296,100,60,8,2297,3888,462,466,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3671,3667,3654,3657,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,935,SUCCESS,,2303.604871,192,0,0.1,0.2,0.3,327,1.4,1.5
    4854,5/27/2021 0:37,19453.613,5.4,4701,300,10,6001,0,65535,65535,1,21,25637,-296,-296,100,60,8,2296,3888,465,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3670,3667,3654,3657,3653,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,953,SUCCESS,,2303.274913,192,0,0.1,0.2,0.3,327,1.4,1.5
    4855,5/27/2021 0:37,19457.622,5.4,4701,300,10,6001,0,65535,65535,1,21,25636,-294,-296,100,60,8,2296,3888,465,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3667,3654,3656,3652,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.1,956,SUCCESS,,2302.947511,192,0,0.1,0.2,0.3,327,1.4,1.5
    4856,5/27/2021 0:37,19461.629,5.41,4701,300,10,6001,0,65535,65535,1,21,25634,-296,-296,100,60,8,2296,3888,462,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3667,3654,3657,3652,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,942,SUCCESS,,2302.618047,192,0,0.1,0.2,0.3,327,1.4,1.5
    4857,5/27/2021 0:37,19465.631,5.41,701,300,10,6001,0,65535,65535,1,21,25636,-296,-296,100,60,8,2295,3888,465,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3670,3667,3654,3657,3652,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,967,SUCCESS,,2302.288994,192,0,0.1,0.2,0.3,263,1.4,1.5
    4858,5/27/2021 0:37,19469.637,5.41,701,300,10,6001,0,65535,65535,1,21,25635,-296,-296,100,60,8,2295,3888,462,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3666,3669,3670,3667,3653,3656,3652,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,946,SUCCESS,,2301.959611,192,0,0.1,0.2,0.3,263,1.4,1.5
    4859,5/27/2021 0:37,19473.651,5.41,701,300,10,6001,0,65535,65535,1,21,25633,-296,-296,100,60,8,2295,3888,465,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3667,3653,3657,3652,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,931,SUCCESS,,2301.629571,192,0,0.1,0.2,0.3,263,1.4,1.5
    4860,5/27/2021 0:37,19477.661,5.41,701,300,10,6001,0,65535,65535,1,21,25634,-296,-296,100,60,8,2294,3888,465,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3667,3653,3657,3652,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,999,SUCCESS,,2301.29986,192,0,0.1,0.2,0.3,327,1.4,1.5
    4861,5/27/2021 0:37,19481.676,5.41,4701,300,10,6001,0,65535,65535,1,21,25633,-296,-296,100,60,8,2294,3888,465,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3667,3653,3655,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,953,SUCCESS,,2300.969738,192,0,0.1,0.2,0.3,327,1.4,1.5
    4862,5/27/2021 0:37,19485.682,5.41,4701,300,10,6001,0,65535,65535,1,21,25633,-296,-296,100,60,8,2294,3888,465,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3667,3653,3657,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,967,SUCCESS,,2300.640356,192,0,0.1,0.2,0.3,327,1.4,1.5
    4863,5/27/2021 0:37,19489.688,5.41,4701,300,10,6001,0,65535,65535,1,21,25632,-294,-296,100,59,7,2293,3888,468,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3666,3653,3657,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,949,SUCCESS,,2300.313199,192,0,0.1,0.2,0.3,327,1.4,1.5
    4864,5/27/2021 0:37,19493.694,5.41,701,300,10,6001,0,65535,65535,1,21,25633,-294,-296,100,59,7,2293,3888,468,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3669,3666,3653,3655,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,965,SUCCESS,,2299.986043,192,0,0.1,0.2,0.3,263,1.4,1.5
    4865,5/27/2021 0:37,19497.701,5.42,701,300,10,6001,0,65535,65535,1,21,25632,-296,-296,100,59,7,2293,3888,465,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3670,3666,3653,3657,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,956,SUCCESS,,2299.656578,192,0,0.1,0.2,0.3,263,1.4,1.5
    4866,5/27/2021 0:37,19501.709,5.42,701,300,10,6001,0,65535,65535,1,21,25630,-296,-296,100,59,7,2292,3888,465,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3669,3666,3653,3657,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,951,SUCCESS,,2299.327031,192,0,0.1,0.2,0.3,263,1.4,1.5
    4867,5/27/2021 0:37,19505.722,5.42,701,300,10,6001,0,65535,65535,1,21,25629,-298,-296,100,59,7,2292,3888,461,465,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3669,3666,3653,3654,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,943,SUCCESS,,2298.994844,192,0,0.1,0.2,0.3,263,1.4,1.5
    4868,5/27/2021 0:37,19509.738,5.42,4701,300,10,6001,0,65535,65535,1,21,25630,-296,-296,100,59,7,2292,3888,465,465,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3669,3666,3653,3656,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.1,1016,SUCCESS,,2298.66464,192,0,0.1,0.2,0.3,327,1.4,1.5
    4869,5/27/2021 0:38,19513.747,5.42,4701,300,10,6001,0,65535,65535,1,21,25629,-296,-296,100,59,7,2291,3888,461,464,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3669,3666,3653,3656,3650,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,976,SUCCESS,,2298.335011,192,0,0.1,0.2,0.3,327,1.4,1.5
    4870,5/27/2021 0:38,19517.762,5.42,4701,300,10,6001,0,65535,65535,1,21,25629,-298,-297,100,59,7,2291,3888,461,463,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3665,3669,3669,3666,3653,3656,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,944,SUCCESS,,2298.002658,192,0,0.1,0.2,0.3,327,1.4,1.5
    4871,5/27/2021 0:38,19521.765,5.42,4701,300,10,6001,0,65535,65535,1,21,25628,-294,-296,100,59,7,2291,3888,464,464,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3669,3666,3653,3656,3651,0,0,0,0,0,0,0,0,2563,20.9,21,-273.2,21,-273.2,21.2,957,SUCCESS,,2297.675746,192,0,0.1,0.2,0.3,327,1.4,1.5
    4872,5/27/2021 0:38,19525.768,5.42,701,300,10,6001,0,65535,65535,1,21,25627,-296,-296,100,59,7,2290,3888,461,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3666,3653,3656,3651,0,0,0,0,0,0,0,0,2559,20.9,21,-273.2,21,-273.2,21.2,939,SUCCESS,,2297.346611,192,0,0.1,0.2,0.3,263,1.4,1.5
    4873,5/27/2021 0:38,19529.779,5.42,701,300,10,6001,0,65535,65535,1,21,25626,-296,-296,100,59,7,2290,3888,467,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3666,3653,3656,3651,0,0,0,0,0,0,0,0,2559,20.8,21,-273.2,21,-273.2,21.2,945,SUCCESS,,2297.016818,192,0,0.1,0.2,0.3,263,1.4,1.5
    4874,5/27/2021 0:38,19533.781,5.43,701,300,10,6001,0,65535,65535,1,21,25625,-296,-296,100,59,7,2290,3888,464,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3665,3652,3656,3651,0,0,0,0,0,0,0,0,2563,20.8,21,-273.2,21,-273.2,21.2,973,SUCCESS,,2296.687764,192,0,0.1,0.2,0.3,263,1.4,1.5
    4875,5/27/2021 0:38,19537.795,5.43,701,300,10,6001,0,65535,65535,1,21,25624,-294,-296,100,59,7,2289,3888,461,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3665,3652,3656,3651,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,958,SUCCESS,,2296.359954,192,0,0.1,0.2,0.3,263,1.4,1.5
    4876,5/27/2021 0:38,19541.796,5.43,701,300,10,6001,0,65535,65535,1,21,25624,-296,-296,100,59,7,2289,3888,464,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3665,3652,3656,3650,0,0,0,0,0,0,0,0,2563,20.8,21,-273.2,21,-273.2,20.7,944,SUCCESS,,2296.030983,192,0,0.1,0.2,0.3,263,1.4,1.5
    4877,5/27/2021 0:38,19545.802,5.43,701,300,10,6001,0,65535,65535,1,21,25624,-298,-296,100,59,7,2289,3888,464,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3665,3652,3656,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.3,936,SUCCESS,,2295.699375,192,0,0.1,0.2,0.3,263,1.4,1.5
    4878,5/27/2021 0:38,19549.815,5.43,701,300,10,6001,0,65535,65535,1,21,25623,-296,-296,100,59,7,2288,3888,467,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3665,3652,3656,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,938,SUCCESS,,2295.369418,192,0,0.1,0.2,0.3,263,1.4,1.5
    4879,5/27/2021 0:38,19553.824,5.43,4701,300,10,6001,0,65535,65535,1,21,25623,-294,-296,100,59,7,2288,3888,464,464,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3669,3668,3665,3652,3655,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,946,SUCCESS,,2295.042016,192,0,0.1,0.2,0.3,327,1.4,1.5
    4880,5/27/2021 0:38,19557.832,5.43,4701,300,10,6001,0,65535,65535,1,21,25623,-298,-296,100,59,7,2288,3888,464,464,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3668,3668,3665,3651,3655,3650,0,0,0,0,0,0,0,0,2562,20.8,21,-273.2,21,-273.2,21.1,956,SUCCESS,,2294.710243,192,0,0.1,0.2,0.3,327,1.4,1.5
    4881,5/27/2021 0:38,19561.84,5.43,4701,300,10,6001,0,65535,65535,1,21,25622,-296,-296,100,59,7,2287,3888,464,464,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3668,3668,3665,3652,3655,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,945,SUCCESS,,2294.380696,192,0,0.1,0.2,0.3,327,1.4,1.5
    4882,5/27/2021 0:38,19565.854,5.43,4701,300,10,6001,0,65535,65535,1,21,25620,-296,-296,100,59,7,2287,3888,467,464,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3664,3668,3668,3665,3652,3655,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,977,SUCCESS,,2294.050656,192,0,0.1,0.2,0.3,327,1.4,1.5
    4883,5/27/2021 0:38,19569.854,5.44,701,300,10,6001,0,65535,65535,1,21,25620,-298,-296,100,59,7,2287,3888,460,464,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3668,3668,3665,3651,3655,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,962,SUCCESS,,2293.719545,192,0,0.1,0.2,0.3,263,1.4,1.5
    4884,5/27/2021 0:39,19573.868,5.44,701,300,10,6001,0,65535,65535,1,21,25619,-298,-296,100,59,7,2286,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,,8006,0,0,0,0,0,0,0,3663,3668,3668,3665,3651,3655,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,955,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2293.387275,192,0,0.1,0.2,0.3,263,1.4,1.5
    4885,5/27/2021 0:39,19577.879,5.44,701,300,10,6001,0,65535,65535,1,21,25620,-296,-296,100,59,7,2286,3888,460,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3668,3668,3665,3651,3655,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,938,SUCCESS,,2293.057481,192,0,0.1,0.2,0.3,263,1.4,1.5
    4886,5/27/2021 0:39,19581.892,5.44,701,300,10,6001,0,65535,65535,1,21,25619,-298,-296,100,59,7,2286,3888,460,463,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3668,3668,3665,3651,3655,3650,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,956,SUCCESS,,2292.725294,192,0,0.1,0.2,0.3,327,1.4,1.5
    4887,5/27/2021 0:39,19585.906,5.44,4701,300,10,6001,0,65535,65535,1,21,25618,-296,-296,100,59,7,2285,3888,463,463,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3665,3651,3655,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,956,SUCCESS,,2292.395254,192,0,0.1,0.2,0.3,327,1.4,1.5
    4888,5/27/2021 0:39,19589.907,5.44,4701,300,10,6001,0,65535,65535,1,21,25617,-294,-296,100,59,7,2285,3888,463,463,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,948,SUCCESS,,2292.068506,192,0,0.1,0.2,0.3,327,1.4,1.5
    4889,5/27/2021 0:39,19593.918,5.44,4701,300,10,6001,0,65535,65535,1,21,25617,-294,-296,100,59,7,2285,3888,463,463,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3655,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,993,SUCCESS,,2291.740941,192,0,0.1,0.2,0.3,327,1.4,1.5
    4890,5/27/2021 0:39,19597.928,5.44,701,300,10,6001,0,65535,65535,1,21,25617,-296,-296,100,59,7,2284,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3655,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,967,SUCCESS,,2291.41123,192,0,0.1,0.2,0.3,263,1.4,1.5
    4891,5/27/2021 0:39,19601.929,5.44,701,300,10,6001,0,65535,65535,1,21,25616,-296,-296,100,59,7,2284,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,948,SUCCESS,,2291.082259,192,0,0.1,0.2,0.3,263,1.4,1.5
    4892,5/27/2021 0:39,19605.941,5.45,701,300,10,6001,0,65535,65535,1,21,25617,-298,-296,100,59,7,2284,3888,466,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,953,SUCCESS,,2290.750154,192,0,0.1,0.2,0.3,263,1.4,1.5
    4893,5/27/2021 0:39,19609.944,5.45,701,300,10,6001,0,65535,65535,1,21,25616,-296,-296,100,59,7,2283,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,940,SUCCESS,,2290.421019,192,0,0.1,0.2,0.3,263,1.4,1.5
    4894,5/27/2021 0:39,19613.97,5.45,701,300,10,6001,0,65535,65535,1,21,25616,-296,-296,100,59,7,2283,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,939,SUCCESS,,2290.089992,192,0,0.1,0.2,0.3,263,1.4,1.5
    4895,5/27/2021 0:39,19617.985,5.45,701,300,10,6001,0,65535,65535,1,21,25615,-294,-296,100,59,7,2283,3888,466,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,946,SUCCESS,,2289.7621,192,0,0.1,0.2,0.3,263,1.4,1.5
    4896,5/27/2021 0:39,19622.006,5.45,701,300,10,6001,0,65535,65535,1,21,25616,-298,-296,100,59,7,2282,3888,459,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3663,3667,3668,3664,3651,3654,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,976,SUCCESS,,2289.429251,192,0,0.1,0.2,0.3,263,1.4,1.5
    4897,5/27/2021 0:39,19626.017,5.45,701,300,10,6001,0,65535,65535,1,21,25615,-296,-296,100,59,7,2282,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3667,3668,3664,3651,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,954,SUCCESS,,2289.099458,192,0,0.1,0.2,0.3,263,1.4,1.5
    4898,5/27/2021 0:39,19630.048,5.45,701,300,10,6001,0,65535,65535,1,21,25613,-296,-296,100,59,7,2282,3888,463,463,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3667,3668,3664,3650,3654,3649,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,970,SUCCESS,,2288.76802,192,0,0.1,0.2,0.3,263,1.4,1.5
    4899,5/27/2021 0:40,19634.084,5.45,701,300,10,6001,0,65535,65535,1,21,25611,-298,-297,100,59,7,2281,3888,459,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3654,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,20.8,981,SUCCESS,,2288.433929,192,0,0.1,0.2,0.3,263,1.4,1.5
    4900,5/27/2021 0:40,19638.094,5.46,701,300,10,6001,0,65535,65535,1,21,25611,-296,-297,100,59,7,2281,3888,462,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3654,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,941,SUCCESS,,2288.104218,192,0,0.1,0.2,0.3,263,1.4,1.5
    4901,5/27/2021 0:40,19642.027,5.46,701,300,10,6001,0,65535,65535,1,21,25611,-298,-297,100,59,7,2281,3888,459,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3654,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,965,SUCCESS,,2287.778653,192,0,0.1,0.2,0.3,263,1.4,1.5
    4902,5/27/2021 0:40,19646.042,5.46,701,300,10,6001,0,65535,65535,1,21,25611,-296,-297,100,59,7,2280,3888,462,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3654,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,999,SUCCESS,,2287.44853,192,0,0.1,0.2,0.3,263,1.4,1.5
    4903,5/27/2021 0:40,19650.046,5.46,701,300,10,6001,0,65535,65535,1,21,25611,-294,-297,100,59,7,2280,3888,462,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,948,SUCCESS,,2287.121537,192,0,0.1,0.2,0.3,263,1.4,1.5
    4904,5/27/2021 0:40,19654.056,5.46,701,300,10,6001,0,65535,65535,1,21,25610,-296,-296,100,59,7,2280,3888,462,462,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3654,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21,948,SUCCESS,,2286.791826,192,0,0.1,0.2,0.3,263,1.4,1.5
    4905,5/27/2021 0:40,19658.067,5.46,4701,300,10,6001,0,65535,65535,1,21,25610,-296,-296,100,59,7,2279,3888,462,462,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3668,3663,3650,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,942,SUCCESS,,2286.462033,192,0,0.1,0.2,0.3,327,1.4,1.5
    4906,5/27/2021 0:40,19662.079,5.46,4701,300,10,6001,0,65535,65535,1,21,25610,-294,-296,100,59,7,2279,3888,462,462,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3667,3663,3650,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,959,SUCCESS,,2286.134386,192,0,0.1,0.2,0.3,327,1.4,1.5
    4907,5/27/2021 0:40,19666.094,5.46,4701,300,10,6001,0,65535,65535,1,21,25609,-298,-296,100,59,7,2279,3888,459,462,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3667,3663,3649,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,955,SUCCESS,,2285.802033,192,0,0.1,0.2,0.3,327,1.4,1.5
    4908,5/27/2021 0:40,19670.108,5.46,4701,300,10,6001,0,65535,65535,1,21,25609,-294,-296,100,59,7,2278,3888,462,462,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3666,3667,3663,3650,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,971,SUCCESS,,2285.474223,192,0,0.1,0.2,0.3,327,1.4,1.5
    4909,5/27/2021 0:40,19674.11,5.47,701,300,10,6001,0,65535,65535,1,21,25608,-298,-296,100,59,7,2278,3888,465,462,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3665,3667,3663,3649,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,942,SUCCESS,,2285.142946,192,0,0.1,0.2,0.3,263,1.4,1.5
    4910,5/27/2021 0:40,19678.111,5.47,701,300,10,6001,0,65535,65535,1,21,25608,-296,-296,100,59,7,2278,3888,462,462,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3667,3663,3649,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,942,SUCCESS,,2284.813975,192,0,0.1,0.2,0.3,263,1.4,1.5
    4911,5/27/2021 0:40,19682.111,5.47,701,300,10,6001,0,65535,65535,1,21,25606,-296,-296,100,59,7,2277,3888,458,462,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3667,3663,3649,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,938,SUCCESS,,2284.485086,192,0,0.1,0.2,0.3,263,1.4,1.5
    4912,5/27/2021 0:40,19686.113,5.47,701,300,10,6001,0,65535,65535,1,21,25606,-296,-296,100,59,7,2277,3888,465,462,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3662,3665,3667,3663,3649,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,966,SUCCESS,,2284.156033,192,0,0.1,0.2,0.3,263,1.4,1.5
    4913,5/27/2021 0:40,19690.123,5.47,701,300,10,6001,0,65535,65535,1,21,25606,-294,-296,100,59,7,2277,3888,462,462,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3667,3663,3649,3653,3648,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,943,SUCCESS,,2283.82855,192,0,0.1,0.2,0.3,263,1.4,1.5
    4914,5/27/2021 0:41,19694.133,5.47,701,300,10,6001,0,65535,65535,1,21,25604,-296,-296,100,59,7,2276,3888,461,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3667,3663,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,969,SUCCESS,,2283.498839,192,0,0.1,0.2,0.3,263,1.4,1.5
    4915,5/27/2021 0:41,19698.141,5.47,701,300,10,6001,0,65535,65535,1,21,25605,-298,-296,100,59,7,2276,3888,458,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3667,3663,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,955,SUCCESS,,2283.167065,192,0,0.1,0.2,0.3,263,1.4,1.5
    4916,5/27/2021 0:41,19702.154,5.47,701,300,10,6001,0,65535,65535,1,21,25605,-294,-296,100,59,7,2276,3888,461,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3667,3662,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,962,SUCCESS,,2282.839337,192,0,0.1,0.2,0.3,263,1.4,1.5
    4917,5/27/2021 0:41,19706.166,5.47,701,300,10,6001,0,65535,65535,1,21,25603,-296,-296,100,59,7,2275,3888,458,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3666,3662,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,947,SUCCESS,,2282.509461,192,0,0.1,0.2,0.3,263,1.4,1.5
    4918,5/27/2021 0:41,19710.171,5.48,701,300,10,6001,0,65535,65535,1,21,25603,-298,-296,100,59,7,2275,3888,461,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3666,3662,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,20.9,942,SUCCESS,,2282.177936,192,0,0.1,0.2,0.3,263,1.4,1.5
    4919,5/27/2021 0:41,19714.175,5.48,701,300,10,6001,0,65535,65535,1,21,25605,-296,-296,100,59,7,2275,3888,461,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3666,3662,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,1002,SUCCESS,,2281.848719,192,0,0.1,0.2,0.3,263,1.4,1.5
    4920,5/27/2021 0:41,19718.182,5.48,4701,300,10,6001,0,65535,65535,1,21,25602,-298,-296,100,59,7,2274,3888,458,461,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3665,3666,3662,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,946,SUCCESS,,2281.517028,192,0,0.1,0.2,0.3,327,1.4,1.5
    4921,5/27/2021 0:41,19722.185,5.48,4701,300,10,6001,0,65535,65535,1,21,25602,-296,-296,100,59,7,2274,3888,461,461,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3665,3666,3662,3649,3652,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,956,SUCCESS,,2281.187893,192,0,0.1,0.2,0.3,327,1.4,1.5
    4922,5/27/2021 0:41,19726.189,5.48,4701,300,10,6001,0,65535,65535,1,21,25604,-296,-296,100,59,7,2274,3888,461,461,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3665,3666,3662,3649,3653,3647,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,939,SUCCESS,,2280.858675,192,0,0.1,0.2,0.3,327,1.4,1.5
    4923,5/27/2021 0:41,19730.203,5.48,4701,300,10,6001,0,65535,65535,1,21,25600,-296,-296,100,59,7,2273,3888,458,461,65535,3000,28875,00C0,0,3636,12,,0,4,2,8040,8006,0,0,0,0,0,0,0,3661,3664,3666,3662,3649,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,957,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2280.528635,192,0,0.1,0.2,0.3,0,0.4,0.5
    4924,5/27/2021 0:41,19734.213,5.48,701,300,10,6001,0,65535,65535,1,21,25599,-298,-296,100,59,7,2273,3888,461,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3666,3662,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,975,SUCCESS,,2280.196696,192,0,0.1,0.2,0.3,263,1.4,1.5
    4925,5/27/2021 0:41,19738.219,5.48,701,300,10,6001,0,65535,65535,1,21,25599,-296,-296,100,59,7,2273,3888,464,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3665,3662,3649,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,955,SUCCESS,,2279.867314,192,0,0.1,0.2,0.3,263,1.4,1.5
    4926,5/27/2021 0:41,19742.229,5.48,701,300,10,6001,0,65535,65535,1,21,25597,-296,-296,100,59,7,2272,3888,461,461,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3665,3662,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,949,SUCCESS,,2279.537603,192,0,0.1,0.2,0.3,263,1.4,1.5
    4927,5/27/2021 0:41,19746.23,5.49,701,300,10,6001,0,65535,65535,1,21,25596,-296,-296,100,59,7,2272,3888,461,461,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3665,3661,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,959,SUCCESS,,2279.208631,192,0,0.1,0.2,0.3,327,1.4,1.5
    4928,5/27/2021 0:41,19750.241,5.49,4701,300,10,6001,0,65535,65535,1,21,25596,-296,-296,100,59,7,2272,3888,461,461,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3665,3661,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,987,SUCCESS,,2278.878838,192,0,0.1,0.2,0.3,327,1.4,1.5
    4929,5/27/2021 0:42,19754.244,5.49,4701,300,10,6001,0,65535,65535,1,21,25596,-296,-296,100,59,7,2271,3888,460,460,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3663,3665,3661,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,968,SUCCESS,,2278.549703,192,0,0.1,0.2,0.3,327,1.4,1.5
    4930,5/27/2021 0:42,19758.258,5.49,4701,300,10,6001,0,65535,65535,1,21,25597,-294,-296,100,59,7,2271,3888,463,460,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3665,3661,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,963,SUCCESS,,2278.221893,192,0,0.1,0.2,0.3,327,1.4,1.5
    4931,5/27/2021 0:42,19762.264,5.49,701,300,10,6001,0,65535,65535,1,21,25595,-298,-296,100,59,7,2271,3888,457,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3663,3665,3661,3648,3652,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,966,SUCCESS,,2277.890285,192,0,0.1,0.2,0.3,263,1.4,1.5
    4932,5/27/2021 0:42,19766.265,5.49,701,300,10,6001,0,65535,65535,1,21,25595,-296,-296,100,59,7,2270,3888,460,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3664,3665,3661,3648,3651,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,20.8,938,SUCCESS,,2277.561314,192,0,0.1,0.2,0.3,263,1.4,1.5
    4933,5/27/2021 0:42,19770.271,5.49,701,300,10,6001,0,65535,65535,1,21,25594,-296,-296,100,59,7,2270,3888,460,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3663,3665,3661,3648,3651,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,968,SUCCESS,,2277.231931,192,0,0.1,0.2,0.3,263,1.4,1.5
    4934,5/27/2021 0:42,19774.273,5.49,701,300,10,6001,0,65535,65535,1,21,25594,-298,-296,100,59,7,2270,3888,457,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3660,3663,3665,3661,3648,3651,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,1011,SUCCESS,,2276.900655,192,0,0.1,0.2,0.3,263,1.4,1.5
    4935,5/27/2021 0:42,19778.286,5.49,701,300,10,6001,0,65535,65535,1,21,25593,-296,-296,100,59,7,2269,3888,460,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3665,3661,3648,3651,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,966,SUCCESS,,2276.570697,192,0,0.1,0.2,0.3,263,1.4,1.5
    4936,5/27/2021 0:42,19782.292,5.5,701,300,10,6001,0,65535,65535,1,21,25593,-298,-296,100,59,7,2269,3888,457,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,,0,0,0,0,0,0,0,3660,3663,3665,3661,3648,3650,3646,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,2930,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2276.239089,192,0,0.1,0.2,0.3,263,1.4,1.5
    4937,5/27/2021 0:42,19786.294,5.5,701,300,10,6001,0,65535,65535,1,21,25592,-296,-296,100,59,7,2269,3888,460,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3665,3661,3647,3652,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,965,SUCCESS,,2275.910036,192,0,0.1,0.2,0.3,263,1.4,1.5
    4938,5/27/2021 0:42,19790.298,5.5,701,300,10,6001,0,65535,65535,1,21,25589,-294,-296,100,59,7,2268,3888,463,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3661,3647,3651,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,953,SUCCESS,,2275.583043,192,0,0.1,0.2,0.3,263,1.4,1.5
    4939,5/27/2021 0:42,19794.31,5.5,701,300,10,6001,0,65535,65535,1,21,25589,-296,-296,100,59,7,2268,3888,460,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3661,3648,3650,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,946,SUCCESS,,2275.253167,192,0,0.1,0.2,0.3,263,1.4,1.5
    4940,5/27/2021 0:42,19798.309,5.5,701,300,10,6001,0,65535,65535,1,21,25589,-296,-296,100,59,7,2268,3888,460,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3660,3648,3652,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,956,SUCCESS,,2274.92436,192,0,0.1,0.2,0.3,263,1.4,1.5
    4941,5/27/2021 0:42,19802.324,5.5,701,300,10,6001,0,65535,65535,1,21,25589,-296,-296,100,59,7,2267,3888,463,460,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3660,3647,3651,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,945,SUCCESS,,2274.594238,192,0,0.1,0.2,0.3,263,1.4,1.5
    4942,5/27/2021 0:42,19806.337,5.5,4701,300,10,6001,0,65535,65535,1,21,25589,-298,-296,100,59,7,2267,3888,460,460,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3660,3647,3650,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,982,SUCCESS,,2274.262051,192,0,0.1,0.2,0.3,327,1.4,1.5
    4943,5/27/2021 0:42,19810.343,5.5,4701,300,10,6001,0,65535,65535,1,21,25589,-296,-296,100,59,7,2267,3888,463,460,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3660,3647,3655,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,940,SUCCESS,,2273.932669,192,0,0.1,0.2,0.3,327,1.4,1.5
    4944,5/27/2021 0:43,19814.349,5.5,4701,300,10,6001,0,65535,65535,1,21,25588,-298,-296,100,59,7,2266,3888,456,459,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3660,3647,3651,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,957,SUCCESS,,2273.601061,192,0,0.1,0.2,0.3,327,1.4,1.5
    4945,5/27/2021 0:43,19818.357,5.51,4701,300,10,6001,0,65535,65535,1,21,25588,-296,-296,100,59,7,2266,3888,459,459,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3663,3664,3660,3647,3649,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,997,SUCCESS,,2273.271514,192,0,0.1,0.2,0.3,327,1.4,1.5
    4946,5/27/2021 0:43,19822.358,5.51,701,300,10,6001,0,65535,65535,1,21,25587,-296,-296,100,59,7,2266,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3662,3664,3660,3646,3655,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,941,SUCCESS,,2272.942543,192,0,0.1,0.2,0.3,263,1.4,1.5
    4947,5/27/2021 0:43,19826.359,5.51,701,300,10,6001,0,65535,65535,1,21,25586,-298,-296,100,59,7,2265,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3662,3664,3660,3647,3650,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,977,SUCCESS,,2272.611349,192,0,0.1,0.2,0.3,263,1.4,1.5
    4948,5/27/2021 0:43,19830.364,5.51,701,300,10,6001,0,65535,65535,1,21,25585,-296,-296,100,59,7,2265,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3662,3663,3660,3646,3650,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,957,SUCCESS,,2272.282049,192,0,0.1,0.2,0.3,263,1.4,1.5
    4949,5/27/2021 0:43,19834.367,5.51,701,300,10,6001,0,65535,65535,1,21,25585,-298,-296,100,59,7,2265,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3662,3663,3660,3646,3655,3645,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,948,SUCCESS,,2271.95069,192,0,0.1,0.2,0.3,263,1.4,1.5
    4950,5/27/2021 0:43,19838.38,5.51,701,300,10,6001,0,65535,65535,1,21,25583,-298,-296,100,59,7,2265,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3662,3663,3660,3646,3650,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,933,SUCCESS,,2271.618503,192,0,0.1,0.2,0.3,263,1.4,1.5
    4951,5/27/2021 0:43,19842.381,5.51,701,300,10,6001,0,65535,65535,1,21,25586,-298,-296,100,59,7,2264,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3660,3646,3650,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,20.6,963,SUCCESS,,2271.287309,192,0,0.1,0.2,0.3,263,1.4,1.5
    4952,5/27/2021 0:43,19846.382,5.51,701,300,10,6001,0,65535,65535,1,21,25584,-298,-296,100,59,7,2264,3888,456,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3659,3662,3663,3660,3646,3650,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,966,SUCCESS,,2270.956115,192,0,0.1,0.2,0.3,263,1.4,1.5
    4953,5/27/2021 0:43,19850.385,5.51,701,300,10,6001,0,65535,65535,1,21,25583,-298,-296,100,59,7,2264,3888,456,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3650,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,962,SUCCESS,,2270.624755,192,0,0.1,0.2,0.3,263,1.4,1.5
    4954,5/27/2021 0:43,19854.393,5.52,701,300,10,6001,0,65535,65535,1,21,25583,-298,-296,100,59,7,2263,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3660,3646,3650,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,936,SUCCESS,,2270.292982,192,0,0.1,0.2,0.3,263,1.4,1.5
    4955,5/27/2021 0:43,19858.401,5.52,701,300,10,6001,0,65535,65535,1,21,25582,-298,-296,100,59,7,2263,3888,459,459,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3650,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21,984,SUCCESS,,2269.961209,192,0,0.1,0.2,0.3,263,1.4,1.5
    4956,5/27/2021 0:43,19862.409,5.52,701,300,10,6001,0,65535,65535,1,21,25582,-296,-297,100,59,7,2263,3888,459,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3649,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.2,984,SUCCESS,,2269.631662,192,0,0.1,0.2,0.3,263,1.4,1.5
    4957,5/27/2021 0:43,19866.424,5.52,4701,300,10,6001,0,65535,65535,1,21,25581,-296,-297,100,59,7,2262,3888,459,457,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3649,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,954,SUCCESS,,2269.30154,192,0,0.1,0.2,0.3,327,1.4,1.5
    4958,5/27/2021 0:43,19870.428,5.52,4701,300,10,6001,0,65535,65535,1,21,25581,-298,-296,100,59,7,2262,3888,459,459,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3649,3644,0,0,0,0,0,0,0,0,2555,20.8,21,-273.2,21,-273.2,21.1,950,SUCCESS,,2268.970098,192,0,0.1,0.2,0.3,327,1.4,1.5
    4959,5/27/2021 0:44,19874.437,5.52,4701,300,10,6001,0,65535,65535,1,21,25581,-294,-296,100,59,7,2262,3888,455,459,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3649,3643,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,962,SUCCESS,,2268.642696,192,0,0.1,0.2,0.3,327,1.4,1.5
    4960,5/27/2021 0:44,19878.441,5.52,4701,300,10,6001,0,65535,65535,1,21,25580,-294,-296,100,59,7,2261,3888,461,458,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3649,3644,0,0,0,0,0,0,0,0,2558,20.8,21,-273.2,21,-273.2,21.1,938,SUCCESS,,2268.315703,192,0,0.1,0.2,0.3,327,1.4,1.5
    4961,5/27/2021 0:44,19882.455,5.52,701,300,10,6001,0,65535,65535,1,21,25581,-296,-296,100,59,7,2261,3888,455,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3658,3662,3663,3659,3646,3649,3643,0,0,0,0,0,0,0,0,2555,20.8,21,-273.2,21,-273.2,21.1,974,SUCCESS,,2267.985663,192,0,0.1,0.2,0.3,263,1.4,1.5
    4962,5/27/2021 0:44,19886.456,5.52,701,300,10,6001,0,65535,65535,1,21,25579,-296,-296,100,59,7,2261,3888,458,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3659,3646,3649,3643,0,0,0,0,0,0,0,0,2555,20.8,21,-273.2,21,-273.2,21.1,958,SUCCESS,,2267.656691,192,0,0.1,0.2,0.3,263,1.4,1.5
    4963,5/27/2021 0:44,19890.47,5.53,701,300,10,6001,0,65535,65535,1,21,25577,-296,-296,100,59,7,2260,3888,455,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3663,3659,3645,3649,3643,0,0,0,0,0,0,0,0,2555,20.8,21,-273.2,21,-273.2,21.2,981,SUCCESS,,2267.326651,192,0,0.1,0.2,0.3,263,1.4,1.5
    4964,5/27/2021 0:44,19894.477,5.53,701,300,10,6001,0,65535,65535,1,21,25576,-294,-296,100,59,7,2260,3888,455,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3659,3645,3649,3643,0,0,0,0,0,0,0,0,2555,20.8,21,-273.2,21,-273.2,21.1,933,SUCCESS,,2266.999413,192,0,0.1,0.2,0.3,263,1.4,1.5
    4965,5/27/2021 0:44,19898.485,5.53,701,300,10,6001,0,65535,65535,1,21,25576,-296,-296,100,59,7,2259,3888,458,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3659,3645,3649,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,20.5,941,SUCCESS,,2266.669866,192,0,0.1,0.2,0.3,263,1.4,1.5
    4966,5/27/2021 0:44,19902.498,5.53,701,300,10,6001,0,65535,65535,1,21,25576,-296,-296,100,59,7,2259,3888,458,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3659,3645,3649,3643,0,0,0,0,0,0,0,0,2555,20.8,21,-273.2,21,-273.2,21.2,940,SUCCESS,,2266.339909,192,0,0.1,0.2,0.3,263,1.4,1.5
    4967,5/27/2021 0:44,19906.51,5.53,701,300,10,6001,0,65535,65535,1,21,25576,-296,-296,100,59,7,2259,3888,458,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3659,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,950,SUCCESS,,2266.010033,192,0,0.1,0.2,0.3,263,1.4,1.5
    4968,5/27/2021 0:44,19910.511,5.53,701,300,10,6001,0,65535,65535,1,21,25576,-298,-296,100,59,7,2258,3888,455,458,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3658,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,976,SUCCESS,,2265.678839,192,0,0.1,0.2,0.3,327,1.4,1.5
    4969,5/27/2021 0:44,19914.513,5.53,4701,300,10,6001,0,65535,65535,1,21,25574,-298,-297,100,59,7,2258,3888,455,456,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3661,3662,3658,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,959,SUCCESS,,2265.347563,192,0,0.1,0.2,0.3,327,1.4,1.5
    4970,5/27/2021 0:44,19918.523,5.53,4701,300,10,6001,0,65535,65535,1,21,25575,-296,-296,100,59,7,2258,3888,458,458,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,980,SUCCESS,,2265.017851,192,0,0.1,0.2,0.3,327,1.4,1.5
    4971,5/27/2021 0:44,19922.528,5.53,4701,300,10,6001,0,65535,65535,1,21,25573,-296,-296,100,59,7,2258,3888,458,458,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3649,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,958,SUCCESS,,2264.688551,192,0,0.1,0.2,0.3,327,1.4,1.5
    4972,5/27/2021 0:44,19926.542,5.54,701,300,10,6001,0,65535,65535,1,20.9,25573,-296,-296,100,59,7,2257,3888,458,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,944,SUCCESS,,2264.358511,192,0,0.1,0.2,0.3,263,1.4,1.5
    4973,5/27/2021 0:44,19930.555,5.54,701,300,10,6001,0,65535,65535,1,21,25573,-294,-296,100,59,7,2257,3888,461,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3649,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,963,SUCCESS,,2264.030783,192,0,0.1,0.2,0.3,263,1.4,1.5
    4974,5/27/2021 0:45,19934.561,5.54,701,300,10,6001,0,65535,65535,1,21,25572,-294,-296,100,59,7,2257,3888,461,458,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,945,SUCCESS,,2263.703626,192,0,0.1,0.2,0.3,263,1.4,1.5
    4975,5/27/2021 0:45,19938.574,5.54,701,300,10,6001,0,65535,65535,1,21,25572,-294,-296,100,59,7,2256,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,960,SUCCESS,,2263.375898,192,0,0.1,0.2,0.3,263,1.4,1.5
    4976,5/27/2021 0:45,19942.58,5.54,701,300,10,6001,0,65535,65535,1,21,25572,-294,-296,100,59,7,2256,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3662,3658,3645,3648,3643,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,984,SUCCESS,,2263.048741,192,0,0.1,0.2,0.3,263,1.4,1.5
    4977,5/27/2021 0:45,19946.584,5.54,701,300,10,6001,0,65535,65535,1,21,25572,-296,-296,100,59,7,2256,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3662,3658,3645,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,957,SUCCESS,,2262.719524,192,0,0.1,0.2,0.3,263,1.4,1.5
    4978,5/27/2021 0:45,19950.592,5.54,701,300,10,6001,0,65535,65535,1,21,25570,-296,-296,100,58,7,2255,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3645,3648,3642,0,0,0,0,0,0,0,0,2557,20.8,21,-273.2,21,-273.2,21.2,942,SUCCESS,,2262.389977,192,0,0.1,0.2,0.3,263,1.4,1.5
    4979,5/27/2021 0:45,19954.601,5.54,701,300,10,6001,0,65535,65535,1,21,25571,-296,-296,100,58,7,2255,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3657,3660,3661,3658,3644,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,20.5,964,SUCCESS,,2262.060348,192,0,0.1,0.2,0.3,263,1.4,1.5
    4980,5/27/2021 0:45,19958.606,5.54,4701,300,10,6001,0,65535,65535,1,21,25571,-296,-296,100,58,7,2255,3888,457,457,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3645,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,945,SUCCESS,,2261.731048,192,0,0.1,0.2,0.3,327,1.4,1.5
    4981,5/27/2021 0:45,19962.619,5.55,4701,300,10,6001,0,65535,65535,1,21,25568,-294,-296,100,58,7,2254,3888,460,457,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3644,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,949,SUCCESS,,2261.40332,192,0,0.1,0.2,0.3,327,1.4,1.5
    4982,5/27/2021 0:45,19966.633,5.55,4701,300,10,6001,0,65535,65535,1,21,25568,-296,-296,100,58,7,2254,3888,457,457,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3644,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,963,SUCCESS,,2261.07328,192,0,0.1,0.2,0.3,327,1.4,1.5
    4983,5/27/2021 0:45,19970.643,5.55,701,300,10,6001,0,65535,65535,1,21,25568,-296,-296,100,58,7,2254,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3644,3648,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,938,SUCCESS,,2260.743569,192,0,0.1,0.2,0.3,263,1.4,1.5
    4984,5/27/2021 0:45,19974.65,5.55,701,300,10,6001,0,65535,65535,1,21,25568,-294,-296,100,58,7,2253,3888,460,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,932,SUCCESS,,2260.41633,192,0,0.1,0.2,0.3,263,1.4,1.5
    4985,5/27/2021 0:45,19978.654,5.55,701,300,10,6001,0,65535,65535,1,21,25568,-296,-296,100,58,7,2253,3888,457,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3660,3661,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,943,SUCCESS,,2260.087113,192,0,0.1,0.2,0.3,263,1.4,1.5
    4986,5/27/2021 0:45,19982.661,5.55,701,300,10,6001,0,65535,65535,1,20.9,25567,-296,-296,100,58,7,2253,3888,460,457,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,20.9,-273.2,21.1,970,SUCCESS,,2259.757648,192,0,0.1,0.2,0.3,263,1.4,1.5
    4987,5/27/2021 0:45,19986.67,5.55,701,300,10,6001,0,65535,65535,1,20.9,25566,-296,-296,100,58,7,2252,3888,460,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,957,SUCCESS,,2259.428019,192,0,0.1,0.2,0.3,263,1.4,1.5
    4988,5/27/2021 0:45,19990.672,5.55,701,300,10,6001,0,65535,65535,1,21,25567,-298,-296,100,58,7,2252,3888,453,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,21,-273.2,20.8,945,SUCCESS,,2259.096743,192,0,0.1,0.2,0.3,263,1.4,1.5
    4989,5/27/2021 0:46,19994.679,5.55,701,300,10,6001,0,65535,65535,1,21,25565,-296,-296,100,58,7,2252,3888,456,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,948,SUCCESS,,2258.767278,192,0,0.1,0.2,0.3,263,1.4,1.5
    4990,5/27/2021 0:46,19998.688,5.56,701,300,10,6001,0,65535,65535,1,21,25564,-296,-296,100,58,7,2251,3888,459,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3643,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,960,SUCCESS,,2258.437649,192,0,0.1,0.2,0.3,263,1.4,1.5
    4991,5/27/2021 0:46,20002.695,5.56,701,300,10,6001,0,65535,65535,1,21,25566,-294,-296,100,58,7,2251,3888,456,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3644,3647,3642,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,932,SUCCESS,,2258.110411,192,0,0.1,0.2,0.3,263,1.4,1.5
    4992,5/27/2021 0:46,20006.705,5.56,701,300,10,6001,0,65535,65535,1,21,25565,-296,-296,100,58,7,2251,3888,456,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3643,3647,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,943,SUCCESS,,2257.7807,192,0,0.1,0.2,0.3,263,1.4,1.5
    4993,5/27/2021 0:46,20010.708,5.56,701,300,10,6001,0,65535,65535,1,21,25563,-296,-296,100,58,7,2250,3888,459,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3643,3646,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,942,SUCCESS,,2257.451564,192,0,0.1,0.2,0.3,263,1.4,1.5
    4994,5/27/2021 0:46,20014.716,5.56,701,300,10,6001,0,65535,65535,1,21,25563,-294,-296,100,58,7,2250,3888,456,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3656,3659,3660,3657,3643,3647,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,942,SUCCESS,,2257.124244,192,0,0.1,0.2,0.3,263,1.4,1.5
    4995,5/27/2021 0:46,20018.721,5.56,701,300,10,6001,0,65535,65535,1,21,25561,-296,-296,100,58,7,2250,3888,456,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3659,3660,3656,3643,3647,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21,969,SUCCESS,,2256.794944,192,0,0.1,0.2,0.3,263,1.4,1.5
    4996,5/27/2021 0:46,20022.731,5.56,701,300,10,6001,0,65535,65535,1,21,25560,-294,-296,100,58,7,2249,3888,456,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3659,3660,3656,3643,3646,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,949,SUCCESS,,2256.467461,192,0,0.1,0.2,0.3,263,1.4,1.5
    4997,5/27/2021 0:46,20026.745,5.56,701,300,10,6001,0,65535,65535,1,21,25565,-294,-296,100,58,7,2249,3888,459,456,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3659,3660,3656,3643,3646,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,20.6,961,SUCCESS,,2256.139651,192,0,0.1,0.2,0.3,263,1.4,1.5
    4998,5/27/2021 0:46,20030.748,5.56,4701,300,10,6001,0,65535,65535,1,21,25560,-298,-296,100,58,7,2249,3888,453,456,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3659,3660,3656,3643,3646,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,958,SUCCESS,,2255.808291,192,0,0.1,0.2,0.3,327,1.4,1.5
    4999,5/27/2021 0:46,20034.75,5.57,4701,300,10,6001,0,65535,65535,1,21,25560,-296,-296,100,58,7,2248,3888,459,456,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3658,3660,3656,3643,3646,3641,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.2,974,SUCCESS,,2255.479238,192,0,0.1,0.2,0.3,327,1.4,1.5
    5000,5/27/2021 0:46,20038.757,5.57,4701,300,10,6001,0,65535,65535,1,20.9,25564,-296,-296,100,58,7,2248,3888,456,456,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3659,3660,3656,3643,3646,3641,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,932,SUCCESS,,2255.149774,192,0,0.1,0.2,0.3,327,1.4,1.5
    5001,5/27/2021 0:46,20042.767,5.57,4701,300,10,6001,0,65535,65535,1,21,25558,-298,-296,100,58,7,2248,3888,453,456,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3658,3660,3656,3643,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.2,1022,SUCCESS,,2254.817835,192,0,0.1,0.2,0.3,327,1.4,1.5
    5002,5/27/2021 0:46,20046.778,5.57,701,300,10,6001,0,65535,65535,1,21,25557,-296,-296,100,58,7,2247,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3659,3660,3656,3643,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,945,SUCCESS,,2254.488041,192,0,0.1,0.2,0.3,263,1.4,1.5
    5003,5/27/2021 0:46,20050.794,5.57,701,300,10,6001,0,65535,65535,1,21,25560,-296,-296,100,58,7,2247,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3655,3658,3659,3656,3643,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,957,SUCCESS,,2254.157837,192,0,0.1,0.2,0.3,263,1.4,1.5
    5004,5/27/2021 0:47,20054.803,5.57,701,300,10,6001,0,65535,65535,1,21,25556,-298,-296,100,58,7,2247,3888,452,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3656,3643,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,980,SUCCESS,,2253.825981,192,0,0.1,0.2,0.3,263,1.4,1.5
    5005,5/27/2021 0:47,20058.805,5.57,701,300,10,6001,0,65535,65535,1,21,25554,-294,-296,100,58,7,2246,3888,458,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3656,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,938,SUCCESS,,2253.499151,192,0,0.1,0.2,0.3,263,1.4,1.5
    5006,5/27/2021 0:47,20062.808,5.57,4701,300,10,6001,0,65535,65535,1,20.9,25555,-296,-296,100,58,7,2246,3888,455,455,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3656,3642,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,950,SUCCESS,,2253.170015,192,0,0.1,0.2,0.3,327,1.4,1.5
    5007,5/27/2021 0:47,20066.816,5.57,4701,300,10,6001,0,65535,65535,1,21,25555,-296,-296,100,58,7,2246,3888,455,455,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3656,3642,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,952,SUCCESS,,2252.840469,192,0,0.1,0.2,0.3,327,1.4,1.5
    5008,5/27/2021 0:47,20070.826,5.58,4701,300,10,6001,0,65535,65535,1,21,25555,-296,-296,100,58,7,2245,3888,455,455,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3656,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,947,SUCCESS,,2252.510758,192,0,0.1,0.2,0.3,327,1.4,1.5
    5009,5/27/2021 0:47,20074.835,5.58,701,300,10,6001,0,65535,65535,1,21,25553,-296,-296,100,58,7,2245,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3656,3642,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21,947,SUCCESS,,2252.181129,192,0,0.1,0.2,0.3,263,1.4,1.5
    5010,5/27/2021 0:47,20078.838,5.58,701,300,10,6001,0,65535,65535,1,21,25554,-296,-296,100,58,7,2245,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3659,3655,3642,3646,3640,0,0,0,0,0,0,0,0,2554,20.8,21,-273.2,21,-273.2,21.1,960,SUCCESS,,2251.851993,192,0,0.1,0.2,0.3,263,1.4,1.5
    5011,5/27/2021 0:47,20082.85,5.58,701,300,10,6001,0,65535,65535,1,20.9,25553,-296,-296,100,58,7,2244,3888,458,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3658,3659,3655,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.2,968,SUCCESS,,2251.522118,192,0,0.1,0.2,0.3,263,1.4,1.5
    5012,5/27/2021 0:47,20086.865,5.58,701,300,10,6001,0,65535,65535,1,20.9,25553,-296,-296,100,58,7,2244,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3659,3655,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,950,SUCCESS,,2251.191995,192,0,0.1,0.2,0.3,263,1.4,1.5
    5013,5/27/2021 0:47,20090.868,5.58,701,300,10,6001,0,65535,65535,1,20.9,25552,-296,-296,100,58,7,2244,3888,458,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3659,3655,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,947,SUCCESS,,2250.86286,192,0,0.1,0.2,0.3,263,1.4,1.5
    5014,5/27/2021 0:47,20094.883,5.58,701,300,10,6001,0,65535,65535,1,20.9,25552,-298,-296,100,58,7,2243,3888,452,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3659,3655,3642,3644,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21,947,SUCCESS,,2250.530507,192,0,0.1,0.2,0.3,263,1.4,1.5
    5015,5/27/2021 0:47,20098.888,5.58,701,300,10,6001,0,65535,65535,1,20.9,25552,-296,-296,100,58,7,2243,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3659,3655,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,944,SUCCESS,,2250.201207,192,0,0.1,0.2,0.3,263,1.4,1.5
    5016,5/27/2021 0:47,20102.903,5.58,701,300,10,6001,0,65535,65535,1,20.9,25551,-294,-296,100,58,7,2243,3888,455,455,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3658,3655,3642,3645,3640,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,991,SUCCESS,,2249.873315,192,0,0.1,0.2,0.3,263,1.4,1.5
    5017,5/27/2021 0:47,20106.906,5.59,701,300,10,6001,0,65535,65535,1,20.9,25551,-298,-296,100,58,7,2242,3888,454,454,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3654,3657,3658,3655,3642,3643,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,939,SUCCESS,,2249.541956,192,0,0.1,0.2,0.3,263,1.4,1.5
    5018,5/27/2021 0:47,20110.92,5.59,701,300,10,6001,0,65535,65535,1,20.9,25550,-296,-296,100,58,7,2242,3888,454,454,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3657,3658,3655,3641,3645,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21,944,SUCCESS,,2249.211916,192,0,0.1,0.2,0.3,263,1.4,1.5
    5019,5/27/2021 0:48,20114.928,5.59,701,300,10,6001,0,65535,65535,1,20.9,25548,-296,-296,100,58,7,2242,3888,454,454,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3657,3658,3654,3642,3645,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,940,SUCCESS,,2248.882369,192,0,0.1,0.2,0.3,263,1.4,1.5
    5020,5/27/2021 0:48,20118.937,5.59,701,300,10,6001,0,65535,65535,1,20.9,25548,-298,-297,100,58,7,2241,3888,451,453,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3657,3658,3654,3642,3643,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21,957,SUCCESS,,2248.550513,192,0,0.1,0.2,0.3,263,1.4,1.5
    5021,5/27/2021 0:48,20122.944,5.59,4701,300,10,6001,0,65535,65535,1,20.9,25548,-296,-297,100,58,7,2241,3888,457,453,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3657,3658,3654,3642,3645,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,974,SUCCESS,,2248.221049,192,0,0.1,0.2,0.3,327,1.4,1.5
    5022,5/27/2021 0:48,20126.946,5.59,4701,300,10,6001,0,65535,65535,1,20.9,25547,-298,-296,100,58,7,2241,3888,451,454,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3657,3658,3654,3642,3645,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,983,SUCCESS,,2247.889772,192,0,0.1,0.2,0.3,327,1.4,1.5
    5023,5/27/2021 0:48,20130.958,5.59,4701,300,10,6001,0,65535,65535,1,20.9,25546,-296,-297,100,58,7,2240,3888,454,453,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3658,3654,3641,3644,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,935,SUCCESS,,2247.559896,192,0,0.1,0.2,0.3,327,1.4,1.5
    5024,5/27/2021 0:48,20134.962,5.59,701,300,10,6001,0,65535,65535,1,20.9,25547,-294,-297,100,58,7,2240,3888,454,453,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3657,3658,3654,3641,3645,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21,953,SUCCESS,,2247.232903,192,0,0.1,0.2,0.3,263,1.4,1.5
    5025,5/27/2021 0:48,20138.965,5.59,701,300,10,6001,0,65535,65535,1,20.9,25546,-296,-296,100,58,7,2240,3888,454,454,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3658,3654,3641,3645,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,968,SUCCESS,,2246.903768,192,0,0.1,0.2,0.3,263,1.4,1.5
    5026,5/27/2021 0:48,20142.972,5.6,701,300,10,6001,0,65535,65535,1,20.9,25546,-298,-297,100,58,7,2239,3888,454,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3658,3654,3641,3644,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,967,SUCCESS,,2246.572077,192,0,0.1,0.2,0.3,263,1.4,1.5
    5027,5/27/2021 0:48,20146.976,5.6,701,300,10,6001,0,65535,65535,1,20.9,25545,-296,-296,100,58,7,2239,3888,454,454,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3657,3654,3641,3644,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,969,SUCCESS,,2246.242859,192,0,0.1,0.2,0.3,263,1.4,1.5
    5028,5/27/2021 0:48,20150.983,5.6,701,300,10,6001,0,65535,65535,1,20.9,25543,-298,-297,100,58,7,2239,3888,451,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3657,3654,3641,3644,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,968,SUCCESS,,2245.911169,192,0,0.1,0.2,0.3,263,1.4,1.5
    5029,5/27/2021 0:48,20154.984,5.6,701,300,10,6001,0,65535,65535,1,20.9,25544,-296,-297,100,58,7,2238,3888,451,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3657,3654,3641,3644,3639,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,948,SUCCESS,,2245.582198,192,0,0.1,0.2,0.3,263,1.4,1.5
    5030,5/27/2021 0:48,20158.986,5.6,701,300,10,6001,0,65535,65535,1,20.9,25544,-296,-297,100,58,7,2238,3888,451,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3657,3654,3640,3644,3639,0,0,0,0,0,0,0,0,2554,20.8,20.9,-273.2,20.9,-273.2,21.1,958,SUCCESS,,2245.253144,192,0,0.1,0.2,0.3,263,1.4,1.5
    5031,5/27/2021 0:48,20162.992,5.6,701,300,10,6001,0,65535,65535,1,20.9,25543,-296,-297,100,58,7,2238,3888,451,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3657,3654,3641,3644,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,949,SUCCESS,,2244.923762,192,0,0.1,0.2,0.3,263,1.4,1.5
    5032,5/27/2021 0:48,20167.007,5.6,701,300,10,6001,0,65535,65535,1,20.9,25543,-298,-297,100,58,7,2237,3888,453,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3654,3640,3644,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21,951,SUCCESS,,2244.591409,192,0,0.1,0.2,0.3,263,1.4,1.5
    5033,5/27/2021 0:48,20171.01,5.6,701,300,10,6001,0,65535,65535,1,20.9,25542,-296,-297,100,58,7,2237,3888,450,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3653,3656,3657,3654,3640,3644,3639,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,946,SUCCESS,,2244.262274,192,0,0.1,0.2,0.3,263,1.4,1.5
    5034,5/27/2021 0:49,20175.023,5.6,701,300,10,6001,0,65535,65535,1,20.9,25542,-298,-297,100,58,7,2237,3888,453,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3653,3640,3644,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21,947,SUCCESS,,2243.930086,192,0,0.1,0.2,0.3,263,1.4,1.5
    5035,5/27/2021 0:49,20179.04,5.61,701,300,10,6001,0,65535,65535,1,20.9,25540,-296,-297,100,58,7,2236,3888,453,452,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3653,3640,3643,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,1001,SUCCESS,,2243.5998,192,0,0.1,0.2,0.3,327,1.4,1.5
    5036,5/27/2021 0:49,20183.052,5.61,4701,300,10,6001,0,65535,65535,1,20.9,25540,-298,-297,100,58,7,2236,3888,450,452,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3653,3640,3644,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21,980,SUCCESS,,2243.267695,192,0,0.1,0.2,0.3,327,1.4,1.5
    5037,5/27/2021 0:49,20187.053,5.61,4701,300,10,6001,0,65535,65535,1,20.9,25539,-296,-297,100,58,7,2236,3888,453,452,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3653,3640,3644,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,980,SUCCESS,,2242.938724,192,0,0.1,0.2,0.3,327,1.4,1.5
    5038,5/27/2021 0:49,20191.059,5.61,4701,300,10,6001,0,65535,65535,1,20.9,25540,-298,-297,100,58,7,2235,3888,450,452,65535,3000,28875,00C0,0,3636,12,147,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3653,3640,3643,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,949,SUCCESS,,2242.607116,192,0,0.1,0.2,0.3,327,1.4,1.5
    5039,5/27/2021 0:49,20195.065,5.61,701,300,10,6001,0,65535,65535,1,20.9,25539,-298,-297,100,58,7,2235,3888,450,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3656,3657,3653,3640,3643,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,937,SUCCESS,,2242.275509,192,0,0.1,0.2,0.3,263,1.4,1.5
    5040,5/27/2021 0:49,20199.065,5.61,701,300,10,6001,0,65535,65535,1,20.9,25538,-296,-297,100,58,7,2235,3888,453,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3655,3657,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21,937,SUCCESS,,2241.94662,192,0,0.1,0.2,0.3,263,1.4,1.5
    5041,5/27/2021 0:49,20203.079,5.61,701,300,10,6001,0,65535,65535,1,20.9,25538,-296,-296,100,58,7,2234,3888,453,453,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3655,3657,3653,3640,3643,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,961,SUCCESS,,2241.61658,192,0,0.1,0.2,0.3,263,1.4,1.5
    5042,5/27/2021 0:49,20207.087,5.61,701,300,10,6001,0,65535,65535,1,20.9,25535,-298,-297,100,58,7,2234,3888,450,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3657,3653,3640,3643,3638,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,952,SUCCESS,,2241.284806,192,0,0.1,0.2,0.3,263,1.4,1.5
    5043,5/27/2021 0:49,20211.089,5.61,701,300,10,6001,0,65535,65535,1,20.9,25536,-296,-296,100,58,7,2234,3888,453,453,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3655,3657,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,964,SUCCESS,,2240.955753,192,0,0.1,0.2,0.3,263,1.4,1.5
    5044,5/27/2021 0:49,20215.095,5.62,701,300,10,6001,0,65535,65535,1,20.9,25535,-296,-296,100,58,7,2233,3888,453,453,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3656,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,939,SUCCESS,,2240.626371,192,0,0.1,0.2,0.3,263,1.4,1.5
    5045,5/27/2021 0:49,20219.097,5.62,701,300,10,6001,0,65535,65535,1,20.9,25536,-296,-297,100,58,7,2233,3888,453,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3652,3655,3656,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21,959,SUCCESS,,2240.297318,192,0,0.1,0.2,0.3,263,1.4,1.5
    5046,5/27/2021 0:49,20223.107,5.62,701,300,10,6001,0,65535,65535,1,20.9,25535,-298,-296,100,58,7,2233,3888,450,453,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3656,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,980,SUCCESS,,2239.965379,192,0,0.1,0.2,0.3,263,1.4,1.5
    5047,5/27/2021 0:49,20227.108,5.62,701,300,10,6001,0,65535,65535,1,20.9,25535,-296,-297,100,58,7,2232,3888,452,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3656,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2550,20.7,20.9,-273.2,20.9,-273.2,21.1,946,SUCCESS,,2239.636408,192,0,0.1,0.2,0.3,263,1.4,1.5
    5048,5/27/2021 0:49,20231.117,5.62,701,300,10,6001,0,65535,65535,1,20.9,25534,-296,-297,100,58,7,2232,3888,452,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3656,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,20.9,947,SUCCESS,,2239.306779,192,0,0.1,0.2,0.3,263,1.4,1.5
    5049,5/27/2021 0:50,20235.132,5.62,701,300,10,6001,0,65535,65535,1,20.9,25535,-298,-297,100,58,7,2232,3888,452,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3656,3653,3640,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,999,SUCCESS,,2238.974426,192,0,0.1,0.2,0.3,263,1.4,1.5
    5050,5/27/2021 0:50,20239.148,5.62,701,300,10,6001,0,65535,65535,1,20.9,25533,-296,-297,100,58,7,2231,3888,449,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3655,3656,3653,3639,3642,3637,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,958,SUCCESS,,2238.644221,192,0,0.1,0.2,0.3,263,1.4,1.5
    5051,5/27/2021 0:50,20243.144,5.62,701,300,10,6001,0,65535,65535,1,20.9,25532,-294,-296,100,58,7,2231,3888,452,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3654,3656,3652,3639,3643,3637,0,0,0,0,0,0,0,0,2554,20.7,20.9,-273.2,20.9,-273.2,21.1,953,SUCCESS,,2238.317881,192,0,0.1,0.2,0.3,263,1.4,1.5
    5052,5/27/2021 0:50,20247.148,5.62,701,300,10,6001,0,65535,65535,1,20.9,25532,-300,-297,100,58,7,2231,3888,449,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3654,3656,3652,3639,3643,3637,0,0,0,0,0,0,0,0,2553,20.7,20.9,-273.2,20.9,-273.2,21,979,SUCCESS,,2237.984215,192,0,0.1,0.2,0.3,263,1.4,1.5
    5053,5/27/2021 0:50,20251.162,5.63,701,300,10,6001,0,65535,65535,1,20.9,25533,-296,-297,100,58,7,2230,3888,452,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3654,3656,3652,3639,3643,3637,0,0,0,0,0,0,0,0,2553,20.7,20.9,-273.2,20.9,-273.2,21.1,948,SUCCESS,,2237.654175,192,0,0.1,0.2,0.3,263,1.4,1.5
    5054,5/27/2021 0:50,20255.168,5.63,701,300,10,6001,0,65535,65535,1,20.9,25533,-296,-296,100,58,7,2230,3888,452,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3654,3655,3652,3639,3643,3637,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,943,SUCCESS,,2237.324793,192,0,0.1,0.2,0.3,263,1.4,1.5
    5055,5/27/2021 0:50,20259.178,5.63,701,300,10,6001,0,65535,65535,1,20.9,25531,-298,-297,100,58,7,2230,3888,449,451,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,3651,3654,3656,3652,3639,3642,3637,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,932,SUCCESS,,2236.992854,192,0,0.1,0.2,0.3,263,1.4,1.5
    5056,5/27/2021 0:50,20263.187,5.63,701,300,10,6001,0,65535,65535,1,20.9,25531,-296,-296,100,58,7,2229,3888,452,452,65535,3000,28875,00C0,0,3636,12,107,0,4,2,8040,8006,0,0,0,0,0,0,0,,,3656,3652,3639,3642,3637,0,0,0,0,0,0,0,0,2553,20.7,20.9,-273.2,20.9,-273.2,21,976,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,2236.663225,192,0,0.1,0.2,0.3,263,1.4,1.5
    5057,5/27/2021 0:50,20267.189,5.63,701,300,10,6001,0,65535,65535,1,20.9,25530,-296,-296,8,7,1,254,3632,52,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3651,3654,3656,3652,3639,3642,3637,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,20.7,979,SUCCESS,,2236.334171,704,0,0.1,0.2,0.3,263,1.4,1.5
    5058,5/27/2021 0:50,20271.194,5.63,701,300,10,6001,0,65535,65535,1,20.9,25530,-296,-296,8,7,1,254,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3651,3654,3655,3652,3639,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,953,SUCCESS,,2236.004871,704,0,0.1,0.2,0.3,263,1.4,1.5
    5059,5/27/2021 0:50,20275.194,5.63,701,300,10,6001,0,65535,65535,1,20.9,25529,-296,-296,8,7,1,253,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3651,3654,3655,3652,3639,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,966,SUCCESS,,2235.675983,704,0,0.1,0.2,0.3,263,1.4,1.5
    5060,5/27/2021 0:50,20279.2,5.63,701,300,10,6001,0,65535,65535,1,20.9,25527,-298,-296,8,7,1,253,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3654,3655,3651,3639,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,949,SUCCESS,,2235.344375,704,0,0.1,0.2,0.3,263,1.4,1.5
    5061,5/27/2021 0:50,20283.205,5.63,701,300,10,6001,0,65535,65535,1,20.9,25527,-296,-296,8,7,1,253,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3654,3655,3651,3639,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,954,SUCCESS,,2235.015075,704,0,0.1,0.2,0.3,263,1.4,1.5
    5062,5/27/2021 0:50,20287.218,5.64,701,300,10,6001,0,65535,65535,1,20.9,25527,-296,-296,8,7,1,252,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3654,3655,3651,3639,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,950,SUCCESS,,2234.685117,704,0,0.1,0.2,0.3,263,1.4,1.5
    5063,5/27/2021 0:50,20291.229,5.64,701,300,10,6001,0,65535,65535,1,20.9,25527,-296,-296,8,7,1,252,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3654,3655,3651,3639,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,962,SUCCESS,,2234.355324,704,0,0.1,0.2,0.3,263,1.4,1.5
    5064,5/27/2021 0:51,20295.231,5.64,701,300,10,6001,0,65535,65535,1,20.9,25527,-296,-296,8,7,1,252,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3654,3655,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,960,SUCCESS,,2234.02627,704,0,0.1,0.2,0.3,263,1.4,1.5
    5065,5/27/2021 0:51,20299.236,5.64,701,300,10,6001,0,65535,65535,1,20.9,25526,-300,-296,8,7,1,251,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3654,3655,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,938,SUCCESS,,2233.69252,704,0,0.1,0.2,0.3,263,1.4,1.5
    5066,5/27/2021 0:51,20303.238,5.64,701,300,10,6001,0,65535,65535,1,20.9,25525,-298,-297,8,7,1,251,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3653,3655,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,20.3,1011,SUCCESS,,2233.361244,704,0,0.1,0.2,0.3,263,1.4,1.5
    5067,5/27/2021 0:51,20307.247,5.64,701,300,10,6001,0,65535,65535,1,20.9,25524,-296,-297,8,7,1,251,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3653,3655,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,946,SUCCESS,,2233.031615,704,0,0.1,0.2,0.3,263,1.4,1.5
    5068,5/27/2021 0:51,20311.259,5.64,701,300,10,6001,0,65535,65535,1,20.9,25524,-298,-297,8,7,1,250,3632,50,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3653,3654,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,963,SUCCESS,,2232.69951,704,0,0.1,0.2,0.3,263,1.4,1.5
    5069,5/27/2021 0:51,20315.273,5.64,701,300,10,6001,0,65535,65535,1,20.9,25524,-296,-297,8,7,1,250,3632,51,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,946,SUCCESS,,2232.36947,704,0,0.1,0.2,0.3,263,1.4,1.5
    5070,5/27/2021 0:51,20319.274,5.64,701,300,10,6001,0,65535,65535,1,20.9,25524,-298,-296,8,7,1,250,3632,50,51,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3650,3653,3654,3651,3638,3641,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,968,SUCCESS,,2232.038276,704,0,0.1,0.2,0.3,263,1.4,1.5
    5071,5/27/2021 0:51,20323.284,5.65,701,300,10,6001,0,65535,65535,1,20.9,25523,-296,-297,8,7,1,249,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3638,3641,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,968,SUCCESS,,2231.708565,704,0,0.1,0.2,0.3,263,1.4,1.5
    5072,5/27/2021 0:51,20327.293,5.65,701,300,10,6001,0,65535,65535,1,20.9,25523,-294,-296,8,7,1,249,3632,51,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3638,3642,3636,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,957,SUCCESS,,2231.381164,704,0,0.1,0.2,0.3,263,1.4,1.5
    5073,5/27/2021 0:51,20331.295,5.65,701,300,10,6001,0,65535,65535,1,20.9,25521,-298,-296,8,7,1,249,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3638,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,943,SUCCESS,,2231.049887,704,0,0.1,0.2,0.3,263,1.4,1.5
    5074,5/27/2021 0:51,20335.298,5.65,701,300,10,6001,0,65535,65535,1,20.9,25519,-298,-297,8,7,1,248,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3638,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,938,SUCCESS,,2230.718528,704,0,0.1,0.2,0.3,263,1.4,1.5
    5075,5/27/2021 0:51,20339.307,5.65,701,300,10,6001,0,65535,65535,1,20.9,25522,-296,-296,8,7,1,248,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3650,3637,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,944,SUCCESS,,2230.388899,704,0,0.1,0.2,0.3,263,1.4,1.5
    5076,5/27/2021 0:51,20343.314,5.65,701,300,10,6001,0,65535,65535,1,20.9,25520,-296,-296,8,7,1,248,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3637,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,942,SUCCESS,,2230.059434,704,0,0.1,0.2,0.3,263,1.4,1.5
    5077,5/27/2021 0:51,20347.323,5.65,701,300,10,6001,0,65535,65535,1,20.9,25520,-298,-297,8,7,1,247,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3637,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,947,SUCCESS,,2229.727578,704,0,0.1,0.2,0.3,263,1.4,1.5
    5078,5/27/2021 0:51,20351.338,5.65,701,300,10,6001,0,65535,65535,1,20.9,25521,-294,-296,8,7,1,247,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3651,3637,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,977,SUCCESS,,2229.399686,704,0,0.1,0.2,0.3,263,1.4,1.5
    5079,5/27/2021 0:52,20355.352,5.65,701,300,10,6001,0,65535,65535,1,20.9,25520,-298,-296,8,7,1,247,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3650,3637,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,946,SUCCESS,,2229.067416,704,0,0.1,0.2,0.3,263,1.4,1.5
    5080,5/27/2021 0:52,20359.361,5.66,701,300,10,6001,0,65535,65535,1,20.9,25519,-296,-296,8,7,1,246,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3653,3654,3650,3637,3640,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,938,SUCCESS,,2228.737788,704,0,0.1,0.2,0.3,263,1.4,1.5
    5081,5/27/2021 0:52,20363.388,5.66,701,300,10,6001,0,65535,65535,1,20.9,25520,-296,-296,8,7,1,246,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3654,3650,3637,3641,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,941,SUCCESS,,2228.406679,704,0,0.1,0.2,0.3,263,1.4,1.5
    5082,5/27/2021 0:52,20367.384,5.66,701,300,10,6001,0,65535,65535,1,20.9,25517,-294,-297,8,7,1,246,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3654,3650,3637,3640,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,948,SUCCESS,,2228.080339,704,0,0.1,0.2,0.3,263,1.4,1.5
    5083,5/27/2021 0:52,20371.388,5.66,701,300,10,6001,0,65535,65535,1,20.9,25518,-294,-297,8,7,1,245,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3654,3650,3637,3640,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,980,SUCCESS,,2227.753345,704,0,0.1,0.2,0.3,263,1.4,1.5
    5084,5/27/2021 0:52,20375.39,5.66,701,300,10,6001,0,65535,65535,1,20.9,25517,-296,-296,8,7,1,245,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3654,3650,3637,3641,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,956,SUCCESS,,2227.424292,704,0,0.1,0.2,0.3,263,1.4,1.5
    5085,5/27/2021 0:52,20379.398,5.66,701,300,10,6001,0,65535,65535,1,20.9,25516,-296,-296,8,7,1,245,3632,50,50,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3653,3650,3637,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,954,SUCCESS,,2227.094745,704,0,0.1,0.2,0.3,263,1.4,1.5
    5086,5/27/2021 0:52,20383.404,5.66,701,300,10,6001,0,65535,65535,1,20.9,25515,-296,-296,8,7,1,244,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3653,3650,3637,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,941,SUCCESS,,2226.765363,704,0,0.1,0.2,0.3,263,1.4,1.5
    5087,5/27/2021 0:52,20387.413,5.66,701,300,10,6001,0,65535,65535,1,20.9,25515,-298,-297,8,7,1,244,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3653,3649,3637,3640,3635,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,986,SUCCESS,,2226.433507,704,0,0.1,0.2,0.3,263,1.4,1.5
    5088,5/27/2021 0:52,20391.418,5.66,701,300,10,6001,0,65535,65535,1,20.9,25514,-296,-297,8,7,1,244,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3652,3653,3649,3637,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,942,SUCCESS,,2226.104207,704,0,0.1,0.2,0.3,263,1.4,1.5
    5089,5/27/2021 0:52,20395.422,5.67,701,300,10,6001,0,65535,65535,1,20.9,25513,-298,-296,8,7,1,243,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3652,3653,3649,3637,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,939,SUCCESS,,2225.772765,704,0,0.1,0.2,0.3,263,1.4,1.5
    5090,5/27/2021 0:52,20399.426,5.67,701,300,10,6001,0,65535,65535,1,20.9,25513,-296,-297,8,7,1,243,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3649,3652,3653,3650,3637,3641,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,955,SUCCESS,,2225.443547,704,0,0.1,0.2,0.3,263,1.4,1.5
    5091,5/27/2021 0:52,20403.438,5.67,701,300,10,6001,0,65535,65535,1,20.9,25512,-294,-296,8,7,1,243,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3652,3653,3649,3636,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,957,SUCCESS,,2225.1159,704,0,0.1,0.2,0.3,263,1.4,1.5
    5092,5/27/2021 0:52,20407.447,5.67,701,300,10,6001,0,65535,65535,1,20.9,25511,-298,-296,8,7,1,242,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3652,3653,3649,3636,3639,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,968,SUCCESS,,2224.784044,704,0,0.1,0.2,0.3,263,1.4,1.5
    5093,5/27/2021 0:52,20411.455,5.67,701,300,10,6001,0,65535,65535,1,20.9,25511,-296,-296,8,7,1,242,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3643,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,954,SUCCESS,,2224.454498,704,0,0.1,0.2,0.3,263,1.4,1.5
    5094,5/27/2021 0:53,20415.458,5.67,701,300,10,6001,0,65535,65535,1,20.9,25512,-296,-296,8,7,1,242,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,943,SUCCESS,,2224.125362,704,0,0.1,0.2,0.3,263,1.4,1.5
    5095,5/27/2021 0:53,20419.46,5.67,701,300,10,6001,0,65535,65535,1,20.9,25511,-300,-297,8,7,1,241,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,996,SUCCESS,,2223.791862,704,0,0.1,0.2,0.3,263,1.4,1.5
    5096,5/27/2021 0:53,20423.467,5.67,701,300,10,6001,0,65535,65535,1,20.9,25511,-296,-297,8,7,1,241,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3641,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,988,SUCCESS,,2223.462398,704,0,0.1,0.2,0.3,263,1.4,1.5
    5097,5/27/2021 0:53,20427.469,5.67,701,300,10,6001,0,65535,65535,1,20.9,25511,-296,-297,8,7,1,241,3632,49,49,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,959,SUCCESS,,2223.133344,704,0,0.1,0.2,0.3,263,1.4,1.5
    5098,5/27/2021 0:53,20431.48,5.68,701,300,10,6001,0,65535,65535,1,20.9,25510,-296,-297,8,7,1,240,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,960,SUCCESS,,2222.803551,704,0,0.1,0.2,0.3,263,1.4,1.5
    5099,5/27/2021 0:53,20435.484,5.68,701,300,10,6001,0,65535,65535,1,20.9,25511,-298,-297,8,7,1,240,3632,49,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3643,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,940,SUCCESS,,2222.472109,704,0,0.1,0.2,0.3,263,1.4,1.5
    5100,5/27/2021 0:53,20439.498,5.68,701,300,10,6001,0,65535,65535,1,20.9,25510,-298,-297,8,7,1,240,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3652,3649,3636,3640,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,943,SUCCESS,,2222.139839,704,0,0.1,0.2,0.3,263,1.4,1.5
    5101,5/27/2021 0:53,20443.497,5.68,701,300,10,6001,0,65535,65535,1,20.9,25510,-296,-297,8,7,1,239,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3653,3649,3636,3639,3634,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,997,SUCCESS,,2221.811032,704,0,0.1,0.2,0.3,263,1.4,1.5
    5102,5/27/2021 0:53,20447.497,5.68,701,300,10,6001,0,65535,65535,1,20.9,25509,-294,-296,8,7,1,239,3632,49,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3652,3649,3636,3643,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,961,SUCCESS,,2221.484365,704,0,0.1,0.2,0.3,263,1.4,1.5
    5103,5/27/2021 0:53,20451.506,5.68,701,300,10,6001,0,65535,65535,1,20.9,25507,-298,-297,8,7,1,239,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3648,3651,3652,3648,3636,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,966,SUCCESS,,2221.152509,704,0,0.1,0.2,0.3,263,1.4,1.5
    5104,5/27/2021 0:53,20455.521,5.68,701,300,10,6001,0,65535,65535,1,20.9,25506,-296,-297,8,7,1,239,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3651,3652,3648,3636,3638,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,981,SUCCESS,,2220.822387,704,0,0.1,0.2,0.3,263,1.4,1.5
    5105,5/27/2021 0:53,20459.534,5.68,701,300,10,6001,0,65535,65535,1,20.9,25506,-296,-296,8,7,1,238,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3651,3652,3648,3635,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,938,SUCCESS,,2220.492429,704,0,0.1,0.2,0.3,263,1.4,1.5
    5106,5/27/2021 0:53,20463.538,5.68,701,300,10,6001,0,65535,65535,1,20.9,25506,-296,-296,8,7,1,238,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3651,3652,3648,3635,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,1042,SUCCESS,,2220.163211,704,0,0.1,0.2,0.3,263,1.4,1.5
    5107,5/27/2021 0:53,20467.54,5.69,701,300,10,6001,0,65535,65535,1,20.9,25505,-294,-296,8,7,1,238,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3651,3652,3648,3636,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,933,SUCCESS,,2219.836381,704,0,0.1,0.2,0.3,263,1.4,1.5
    5108,5/27/2021 0:53,20471.55,5.69,701,300,10,6001,0,65535,65535,1,20.9,25504,-296,-296,8,7,1,237,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3651,3652,3648,3635,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,20.8,966,SUCCESS,,2219.50667,704,0,0.1,0.2,0.3,263,1.4,1.5
    5109,5/27/2021 0:54,20475.555,5.69,701,300,10,6001,0,65535,65535,1,20.9,25503,-296,-296,8,7,1,237,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,946,SUCCESS,,2219.17737,704,0,0.1,0.2,0.3,263,1.4,1.5
    5110,5/27/2021 0:54,20479.565,5.69,701,300,10,6001,0,65535,65535,1,20.9,25502,-296,-296,8,7,1,236,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,968,SUCCESS,,2218.847659,704,0,0.1,0.2,0.3,263,1.4,1.5
    5111,5/27/2021 0:54,20483.568,5.69,701,300,10,6001,0,65535,65535,1,20.9,25502,-298,-296,8,7,1,236,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3639,3633,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,953,SUCCESS,,2218.5163,704,0,0.1,0.2,0.3,263,1.4,1.5
    5112,5/27/2021 0:54,20487.579,5.69,701,300,10,6001,0,65535,65535,1,20.9,25501,-296,-296,8,7,1,236,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3639,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,1000,SUCCESS,,2218.186506,704,0,0.1,0.2,0.3,263,1.4,1.5
    5113,5/27/2021 0:54,20491.587,5.69,701,300,10,6001,0,65535,65535,1,20.9,25502,-296,-296,8,7,1,235,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,962,SUCCESS,,2217.85696,704,0,0.1,0.2,0.3,263,1.4,1.5
    5114,5/27/2021 0:54,20495.601,5.69,701,300,10,6001,0,65535,65535,1,20.9,25502,-296,-296,8,7,1,235,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3639,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,981,SUCCESS,,2217.52692,704,0,0.1,0.2,0.3,263,1.4,1.5
    5115,5/27/2021 0:54,20499.608,5.69,701,300,10,6001,0,65535,65535,1,20.9,25500,-296,-296,8,7,1,235,3632,48,48,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3647,3650,3651,3648,3635,3639,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,963,SUCCESS,,2217.197455,704,0,0.1,0.2,0.3,263,1.4,1.5
    5116,5/27/2021 0:54,20503.618,5.7,701,300,10,6001,0,65535,65535,1,20.9,25500,-298,-296,8,7,1,234,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3650,3651,3648,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,995,SUCCESS,,2216.865516,704,0,0.1,0.2,0.3,263,1.4,1.5
    5117,5/27/2021 0:54,20507.623,5.7,701,300,10,6001,0,65535,65535,1,20.9,25500,-296,-296,8,7,1,234,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3650,3651,3648,3635,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,957,SUCCESS,,2216.536216,704,0,0.1,0.2,0.3,263,1.4,1.5
    5118,5/27/2021 0:54,20511.628,5.7,701,300,10,6001,0,65535,65535,1,20.9,25497,-296,-296,8,7,1,234,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3648,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,966,SUCCESS,,2216.206916,704,0,0.1,0.2,0.3,263,1.4,1.5
    5119,5/27/2021 0:54,20515.643,5.7,701,300,10,6001,0,65535,65535,1,20.9,25497,-298,-296,8,7,1,233,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3648,3635,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,970,SUCCESS,,2215.874564,704,0,0.1,0.2,0.3,263,1.4,1.5
    5120,5/27/2021 0:54,20519.643,5.7,701,300,10,6001,0,65535,65535,1,20.9,25498,-296,-296,8,7,1,233,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,959,SUCCESS,,2215.545675,704,0,0.1,0.2,0.3,263,1.4,1.5
    5121,5/27/2021 0:54,20523.654,5.7,701,300,10,6001,0,65535,65535,1,20.9,25497,-296,-296,8,7,1,233,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,945,SUCCESS,,2215.215881,704,0,0.1,0.2,0.3,263,1.4,1.5
    5122,5/27/2021 0:54,20527.656,5.7,701,300,10,6001,0,65535,65535,1,20.9,25497,-296,-296,8,7,1,233,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,20.9,973,SUCCESS,,2214.886828,704,0,0.1,0.2,0.3,263,1.4,1.5
    5123,5/27/2021 0:54,20531.659,5.7,701,300,10,6001,0,65535,65535,1,20.9,25497,-296,-296,8,7,1,232,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,985,SUCCESS,,2214.557693,704,0,0.1,0.2,0.3,263,1.4,1.5
    5124,5/27/2021 0:55,20535.671,5.7,701,300,10,6001,0,65535,65535,1,20.9,25496,-296,-296,8,7,1,232,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3638,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,963,SUCCESS,,2214.227817,704,0,0.1,0.2,0.3,263,1.4,1.5
    5125,5/27/2021 0:55,20539.677,5.71,701,300,10,6001,0,65535,65535,1,20.9,25497,-294,-296,8,7,1,232,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3637,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,978,SUCCESS,,2213.90066,704,0,0.1,0.2,0.3,263,1.4,1.5
    5126,5/27/2021 0:55,20543.685,5.71,701,300,10,6001,0,65535,65535,1,20.9,25497,-296,-296,8,7,1,231,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3651,3647,3634,3637,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,966,SUCCESS,,2213.571114,704,0,0.1,0.2,0.3,263,1.4,1.5
    5127,5/27/2021 0:55,20547.697,5.71,701,300,10,6001,0,65535,65535,1,20.9,25495,-296,-296,8,7,1,231,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3650,3647,3634,3638,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,950,SUCCESS,,2213.241238,704,0,0.1,0.2,0.3,263,1.4,1.5
    5128,5/27/2021 0:55,20551.705,5.71,701,300,10,6001,0,65535,65535,1,20.9,25495,-296,-296,8,7,1,231,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3650,3647,3634,3637,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,939,SUCCESS,,2212.911691,704,0,0.1,0.2,0.3,263,1.4,1.5
    5129,5/27/2021 0:55,20555.706,5.71,701,300,10,6001,0,65535,65535,1,20.9,25493,-296,-296,8,7,1,230,3632,46,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3650,3647,3634,3637,3632,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,953,SUCCESS,,2212.58272,704,0,0.1,0.2,0.3,263,1.4,1.5
    5130,5/27/2021 0:55,20559.72,5.71,701,300,10,6001,0,65535,65535,1,20.9,25493,-296,-296,8,7,1,230,3632,46,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3650,3646,3634,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,940,SUCCESS,,2212.25268,704,0,0.1,0.2,0.3,263,1.4,1.5
    5131,5/27/2021 0:55,20563.731,5.71,701,300,10,6001,0,65535,65535,1,20.9,25493,-296,-296,8,7,1,230,3632,47,47,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3646,3649,3650,3647,3634,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,20.6,972,SUCCESS,,2211.922887,704,0,0.1,0.2,0.3,263,1.4,1.5
    5132,5/27/2021 0:55,20567.746,5.71,701,300,10,6001,0,65535,65535,1,20.9,25493,-296,-296,8,7,1,229,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3649,3650,3646,3634,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,963,SUCCESS,,2211.592765,704,0,0.1,0.2,0.3,263,1.4,1.5
    5133,5/27/2021 0:55,20571.76,5.71,701,300,10,6001,0,65535,65535,1,20.9,25492,-298,-296,8,7,1,229,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3649,3650,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,932,SUCCESS,,2211.260495,704,0,0.1,0.2,0.3,263,1.4,1.5
    5134,5/27/2021 0:55,20575.771,5.72,701,300,10,6001,0,65535,65535,1,20.9,25491,-294,-296,8,7,1,229,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3649,3650,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,970,SUCCESS,,2210.93293,704,0,0.1,0.2,0.3,263,1.4,1.5
    5135,5/27/2021 0:55,20579.783,5.72,701,300,10,6001,0,65535,65535,1,20.9,25491,-296,-297,8,7,1,228,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3649,3650,3646,3634,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,962,SUCCESS,,2210.603054,704,0,0.1,0.2,0.3,263,1.4,1.5
    5136,5/27/2021 0:55,20583.786,5.72,701,300,10,6001,0,65535,65535,1,20.9,25491,-296,-296,8,7,1,228,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,972,SUCCESS,,2210.273919,704,0,0.1,0.2,0.3,263,1.4,1.5
    5137,5/27/2021 0:55,20587.793,5.72,701,300,10,6001,0,65535,65535,1,20.9,25490,-294,-296,8,7,1,228,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21.1,961,SUCCESS,,2209.94668,704,0,0.1,0.2,0.3,263,1.4,1.5
    5138,5/27/2021 0:55,20591.796,5.72,701,300,10,6001,0,65535,65535,1,20.9,25490,-298,-296,8,7,1,227,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3650,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,958,SUCCESS,,2209.615321,704,0,0.1,0.2,0.3,263,1.4,1.5
    5139,5/27/2021 0:56,20595.804,5.72,701,300,10,6001,0,65535,65535,1,20.9,25489,-296,-296,8,7,1,227,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,950,SUCCESS,,2209.285774,704,0,0.1,0.2,0.3,263,1.4,1.5
    5140,5/27/2021 0:56,20599.81,5.72,701,300,10,6001,0,65535,65535,1,20.9,25490,-296,-296,8,7,1,227,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,20.6,959,SUCCESS,,2208.956392,704,0,0.1,0.2,0.3,263,1.4,1.5
    5141,5/27/2021 0:56,20603.82,5.72,701,300,10,6001,0,65535,65535,1,20.9,25489,-296,-296,8,7,1,226,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2549,20.7,20.9,-273.2,20.9,-273.2,21,949,SUCCESS,,2208.626681,704,0,0.1,0.2,0.3,263,1.4,1.5
    5142,5/27/2021 0:56,20607.825,5.72,701,300,10,6001,0,65535,65535,1,20.9,25488,-294,-296,8,7,1,226,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3637,3631,0,0,0,0,0,0,0,0,2546,20.7,20.9,-273.2,20.9,-273.2,21,952,SUCCESS,,2208.299606,704,0,0.1,0.2,0.3,263,1.4,1.5
    5143,5/27/2021 0:56,20611.829,5.73,701,300,10,6001,0,65535,65535,1,20.9,25488,-296,-296,8,7,1,226,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3636,3631,0,0,0,0,0,0,0,0,2546,20.7,20.9,-273.2,20.9,-273.2,21.1,940,SUCCESS,,2207.970388,704,0,0.1,0.2,0.3,263,1.4,1.5
    5144,5/27/2021 0:56,20615.836,5.73,701,300,10,6001,0,65535,65535,1,20.9,25487,-298,-296,8,7,1,225,3632,45,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3636,3631,0,0,0,0,0,0,0,0,2548,20.7,20.9,-273.2,20.9,-273.2,21,968,SUCCESS,,2207.638698,704,0,0.1,0.2,0.3,263,1.4,1.5
    5145,5/27/2021 0:56,20619.841,5.73,701,300,10,6001,0,65535,65535,1,20.9,25487,-294,-296,8,7,1,225,3632,46,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3636,3631,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,944,SUCCESS,,2207.311623,704,0,0.1,0.2,0.3,263,1.4,1.5
    5146,5/27/2021 0:56,20623.85,5.73,701,300,10,6001,0,65535,65535,1,20.9,25487,-298,-296,8,7,1,225,3632,45,46,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21.1,983,SUCCESS,,2206.979766,704,0,0.1,0.2,0.3,263,1.4,1.5
    5147,5/27/2021 0:56,20627.861,5.73,701,300,10,6001,0,65535,65535,1,20.9,25486,-296,-296,8,7,1,224,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,940,SUCCESS,,2206.649973,704,0,0.1,0.2,0.3,263,1.4,1.5
    5148,5/27/2021 0:56,20631.862,5.73,701,300,10,6001,0,65535,65535,1,20.9,25487,-296,-296,8,7,1,224,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3645,3648,3649,3646,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,962,SUCCESS,,2206.321002,704,0,0.1,0.2,0.3,263,1.4,1.5
    5149,5/27/2021 0:56,20635.865,5.73,701,300,10,6001,0,65535,65535,1,20.9,25486,-296,-296,8,7,1,224,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3649,3645,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,935,SUCCESS,,2205.991866,704,0,0.1,0.2,0.3,263,1.4,1.5
    5150,5/27/2021 0:56,20639.875,5.73,701,300,10,6001,0,65535,65535,1,20.9,25487,-296,-296,8,7,1,223,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3648,3649,3645,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,948,SUCCESS,,2205.662155,704,0,0.1,0.2,0.3,263,1.4,1.5
    5151,5/27/2021 0:56,20643.885,5.73,701,300,10,6001,0,65535,65535,1,20.9,25485,-296,-296,8,7,1,223,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3649,3645,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,947,SUCCESS,,2205.332444,704,0,0.1,0.2,0.3,263,1.4,1.5
    5152,5/27/2021 0:56,20647.897,5.74,701,300,10,6001,0,65535,65535,1,20.9,25484,-296,-296,8,7,1,223,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3649,3645,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,967,SUCCESS,,2205.002569,704,0,0.1,0.2,0.3,263,1.4,1.5
    5153,5/27/2021 0:56,20651.902,5.74,701,300,10,6001,0,65535,65535,1,20.9,25485,-296,-296,8,7,1,222,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3649,3645,3633,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,953,SUCCESS,,2204.673269,704,0,0.1,0.2,0.3,263,1.4,1.5
    5154,5/27/2021 0:57,20655.904,5.74,701,300,10,6001,0,65535,65535,1,20.9,25483,-298,-296,8,7,1,222,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,20.4,947,SUCCESS,,2204.341992,704,0,0.1,0.2,0.3,263,1.4,1.5
    5155,5/27/2021 0:57,20659.91,5.74,701,300,10,6001,0,65535,65535,1,20.9,25482,-296,-296,8,7,1,222,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3636,3630,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21.1,938,SUCCESS,,2204.01261,704,0,0.1,0.2,0.3,263,1.4,1.5
    5156,5/27/2021 0:57,20663.921,5.74,701,300,10,6001,0,65535,65535,1,20.9,25482,-294,-296,8,7,1,221,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21.1,948,SUCCESS,,2203.685045,704,0,0.1,0.2,0.3,263,1.4,1.5
    5157,5/27/2021 0:57,20667.935,5.74,701,300,10,6001,0,65535,65535,1,20.9,25481,-296,-296,8,7,1,221,3632,44,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,967,SUCCESS,,2203.355005,704,0,0.1,0.2,0.3,263,1.4,1.5
    5158,5/27/2021 0:57,20671.936,5.74,701,300,10,6001,0,65535,65535,1,20.9,25480,-294,-296,8,7,1,221,3632,44,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3635,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,964,SUCCESS,,2203.028256,704,0,0.1,0.2,0.3,263,1.4,1.5
    5159,5/27/2021 0:57,20675.942,5.74,701,300,10,6001,0,65535,65535,1,20.9,25480,-296,-296,8,7,1,220,3632,44,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,959,SUCCESS,,2202.698874,704,0,0.1,0.2,0.3,263,1.4,1.5
    5160,5/27/2021 0:57,20679.945,5.74,701,300,10,6001,0,65535,65535,1,20.9,25479,-296,-296,8,7,1,220,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21.1,968,SUCCESS,,2202.369739,704,0,0.1,0.2,0.3,263,1.4,1.5
    5161,5/27/2021 0:57,20683.948,5.75,701,300,10,6001,0,65535,65535,1,20.9,25480,-296,-296,8,7,1,220,3632,45,45,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3644,3647,3648,3645,3632,3635,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,946,SUCCESS,,2202.040603,704,0,0.1,0.2,0.3,263,1.4,1.5
    5162,5/27/2021 0:57,20687.95,5.75,701,300,10,6001,0,65535,65535,1,20.9,25481,-298,-296,8,7,1,219,3632,44,44,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3643,3647,3648,3645,3632,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.9,-273.2,21,975,SUCCESS,,2201.709326,704,0,0.1,0.2,0.3,263,1.4,1.5
    5163,5/27/2021 0:57,20691.962,5.75,701,300,10,6001,0,65535,65535,1,20.8,25479,-298,-296,8,7,1,219,3632,44,44,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3643,3646,3648,3645,3632,3635,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.8,-273.2,21.1,947,SUCCESS,,2201.377222,704,0,0.1,0.2,0.3,263,1.4,1.5
    5164,5/27/2021 0:57,20695.975,5.75,701,300,10,6001,0,65535,65535,1,20.8,25478,-296,-296,8,7,1,219,3632,44,44,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3643,3646,3648,3645,3632,3635,3629,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21.1,968,SUCCESS,,2201.047264,704,0,0.1,0.2,0.3,263,1.4,1.5
    5165,5/27/2021 0:57,20699.98,5.75,701,300,10,6001,0,65535,65535,1,20.9,25478,-296,-296,8,7,1,218,3632,44,44,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3632,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,952,SUCCESS,,2200.717964,704,0,0.1,0.2,0.3,263,1.4,1.5
    5166,5/27/2021 0:57,20703.982,5.75,701,300,10,6001,0,65535,65535,1,20.9,25477,-296,-296,8,7,1,218,3632,44,44,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3635,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,950,SUCCESS,,2200.388911,704,0,0.1,0.2,0.3,263,1.4,1.5
    5167,5/27/2021 0:57,20707.986,5.75,701,300,10,6001,0,65535,65535,1,20.9,25476,-296,-296,8,7,1,218,3632,44,44,65535,3000,28875,02C0,0,3571,11,107,0,4,2,4440,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3635,3629,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,20.9,972,SUCCESS,,2200.059693,704,0,0.1,0.2,0.3,263,1.4,1.5
    5168,5/27/2021 0:57,20711.997,5.75,701,300,10,6001,0,65535,65535,1,20.9,25476,-294,-296,8,6,1,217,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3636,3629,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21.1,944,SUCCESS,,2199.732128,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5169,5/27/2021 0:58,20716.011,5.75,701,300,10,6001,0,65535,65535,1,20.8,25476,-296,-296,8,6,1,217,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3635,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,978,SUCCESS,,2199.402088,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5170,5/27/2021 0:58,20720.027,5.76,701,300,10,6001,0,65535,65535,1,20.9,25475,-298,-296,8,6,1,217,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,946,SUCCESS,,2199.069653,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5171,5/27/2021 0:58,20724.033,5.76,701,300,10,6001,0,65535,65535,1,20.9,25475,-296,-296,8,6,1,216,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3635,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,960,SUCCESS,,2198.74027,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5172,5/27/2021 0:58,20728.037,5.76,701,300,10,6001,0,65535,65535,1,20.9,25474,-296,-296,8,6,1,216,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3648,3644,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,952,SUCCESS,,2198.411053,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5173,5/27/2021 0:58,20732.043,5.76,701,300,10,6001,0,65535,65535,1,20.9,25474,-300,-296,8,6,1,216,3632,43,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3647,3644,3631,3633,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,945,SUCCESS,,2198.077219,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5174,5/27/2021 0:58,20736.045,5.76,701,300,10,6001,0,65535,65535,1,20.9,25473,-296,-296,8,6,1,215,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3647,3644,3631,3639,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,944,SUCCESS,,2197.748166,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5175,5/27/2021 0:58,20740.048,5.76,701,300,10,6001,0,65535,65535,1,20.8,25473,-296,-296,8,6,1,215,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3647,3643,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,963,SUCCESS,,2197.41903,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5176,5/27/2021 0:58,20744.053,5.76,701,300,10,6001,0,65535,65535,1,20.9,25472,-296,-296,8,6,1,215,3632,44,44,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3647,3643,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,949,SUCCESS,,2197.08973,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5177,5/27/2021 0:58,20748.066,5.76,701,300,10,6001,0,65535,65535,1,20.9,25471,-294,-296,8,6,1,214,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3647,3643,3631,3638,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,20.5,938,SUCCESS,,2196.762002,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5178,5/27/2021 0:58,20752.08,5.76,701,300,10,6001,0,65535,65535,1,20.9,25472,-298,-296,8,6,1,214,3632,44,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3643,3646,3647,3643,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,962,SUCCESS,,2196.429732,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5179,5/27/2021 0:58,20756.092,5.77,701,300,10,6001,0,65535,65535,1,20.9,25472,-296,-296,8,6,1,214,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3647,3643,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,943,SUCCESS,,2196.099856,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5180,5/27/2021 0:58,20760.105,5.77,701,300,10,6001,0,65535,65535,1,20.9,25470,-294,-296,8,6,1,213,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3646,3647,3643,3630,3638,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,950,SUCCESS,,2195.772128,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5181,5/27/2021 0:58,20764.119,5.77,701,300,10,6001,0,65535,65535,1,20.9,25468,-298,-296,8,6,1,213,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3647,3643,3630,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21.1,933,SUCCESS,,2195.439858,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5182,5/27/2021 0:58,20768.127,5.77,701,300,10,6001,0,65535,65535,1,20.8,25468,-296,-296,8,6,1,213,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3647,3643,3630,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,958,SUCCESS,,2195.110311,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5183,5/27/2021 0:58,20772.135,5.77,701,300,10,6001,0,65535,65535,1,20.8,25468,-296,-296,8,6,1,212,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3631,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,948,SUCCESS,,2194.780765,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5184,5/27/2021 0:59,20776.138,5.77,701,300,10,6001,0,65535,65535,1,20.9,25467,-298,-296,8,6,1,212,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3630,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,944,SUCCESS,,2194.449405,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5185,5/27/2021 0:59,20780.15,5.77,701,300,10,6001,0,65535,65535,1,20.9,25468,-294,-296,8,6,1,212,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3630,3633,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,954,SUCCESS,,2194.121759,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5186,5/27/2021 0:59,20784.162,5.77,701,300,10,6001,0,65535,65535,1,20.9,25468,-296,-296,8,6,1,211,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3630,3634,3628,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,951,SUCCESS,,2193.791883,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5187,5/27/2021 0:59,20788.169,5.77,701,300,10,6001,0,65535,65535,1,20.9,25468,-296,-296,8,6,1,211,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3630,3634,3627,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,946,SUCCESS,,2193.462419,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5188,5/27/2021 0:59,20792.178,5.78,701,300,10,6001,0,65535,65535,1,20.8,25467,-296,-296,8,6,1,211,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3630,3633,3628,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,983,SUCCESS,,2193.13279,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5189,5/27/2021 0:59,20796.182,5.78,701,300,10,6001,0,65535,65535,1,20.9,25466,-294,-296,8,6,1,210,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3629,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,938,SUCCESS,,2192.805796,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5190,5/27/2021 0:59,20800.197,5.78,701,300,10,6001,0,65535,65535,1,20.8,25464,-296,-296,8,6,1,210,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3630,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,967,SUCCESS,,2192.475674,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5191,5/27/2021 0:59,20804.199,5.78,701,300,10,6001,0,65535,65535,1,20.8,25466,-294,-296,8,6,1,210,3632,43,43,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3629,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,952,SUCCESS,,2192.148844,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5192,5/27/2021 0:59,20808.207,5.78,701,300,10,6001,0,65535,65535,1,20.9,25466,-294,-296,8,6,1,209,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3643,3629,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,970,SUCCESS,,2191.821524,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5193,5/27/2021 0:59,20812.21,5.78,701,300,10,6001,0,65535,65535,1,20.8,25463,-294,-296,8,6,1,209,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3644,3646,3643,3629,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21.1,948,SUCCESS,,2191.494613,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5194,5/27/2021 0:59,20816.221,5.78,701,300,10,6001,0,65535,65535,1,20.8,25463,-296,-296,8,6,1,209,3632,43,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3642,3629,3632,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,956,SUCCESS,,2191.164819,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5195,5/27/2021 0:59,20820.23,5.78,701,300,10,6001,0,65535,65535,1,20.9,25463,-296,-296,8,6,1,208,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3645,3646,3642,3629,3632,3627,0,0,0,0,0,0,0,0,2545,20.7,20.9,-273.2,20.9,-273.2,21,945,SUCCESS,,2190.83519,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5196,5/27/2021 0:59,20824.234,5.78,701,300,10,6001,0,65535,65535,1,20.8,25463,-296,-296,8,6,1,208,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3642,3644,3646,3642,3629,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,963,SUCCESS,,2190.505973,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5197,5/27/2021 0:59,20828.241,5.79,701,300,10,6001,0,65535,65535,1,20.8,25461,-298,-296,8,6,1,208,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3633,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,981,SUCCESS,,2190.174282,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5198,5/27/2021 0:59,20832.244,5.79,701,300,10,6001,0,65535,65535,1,20.9,25461,-298,-296,8,6,1,207,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3646,3642,3629,3632,3627,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.9,-273.2,21,933,SUCCESS,,2189.842923,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5199,5/27/2021 1:00,20836.259,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-296,-296,8,6,1,207,3632,42,42,65535,3000,28875,0AC0,0,3571,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3633,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,20.9,941,SUCCESS,,2189.5128,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5200,5/27/2021 1:00,20840.261,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-296,-296,8,6,1,207,3632,42,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,982,SUCCESS,,2189.183747,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5201,5/27/2021 1:00,20844.275,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-296,-296,8,6,1,206,3632,42,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,963,SUCCESS,,2188.853707,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5202,5/27/2021 1:00,20848.286,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-296,-296,8,6,1,206,3632,41,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,952,SUCCESS,,2188.523914,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5203,5/27/2021 1:00,20852.295,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-294,-296,8,6,1,206,3632,41,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,943,SUCCESS,,2188.196512,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5204,5/27/2021 1:00,20856.304,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-296,-296,8,6,1,205,3632,42,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3643,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,987,SUCCESS,,2187.866883,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5205,5/27/2021 1:00,20860.308,5.79,701,300,10,6001,0,65535,65535,1,20.8,25459,-298,-296,8,6,1,205,3632,41,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3644,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,20.9,962,SUCCESS,,2187.535441,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5206,5/27/2021 1:00,20864.314,5.8,701,300,10,6001,0,65535,65535,1,20.8,25458,-296,-296,8,6,1,205,3632,42,42,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3643,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,956,SUCCESS,,2187.206059,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5207,5/27/2021 1:00,20868.321,5.8,701,300,10,6001,0,65535,65535,1,20.8,25457,-296,-296,8,6,1,204,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,972,SUCCESS,,2186.876594,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5208,5/27/2021 1:00,20872.33,5.8,701,300,10,6001,0,65535,65535,1,20.8,25457,-296,-296,8,6,1,204,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3643,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,940,SUCCESS,,2186.546965,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5209,5/27/2021 1:00,20876.345,5.8,701,300,10,6001,0,65535,65535,1,20.8,25455,-296,-296,8,6,1,204,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3628,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,20.7,939,SUCCESS,,2186.216843,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5210,5/27/2021 1:00,20880.36,5.8,701,300,10,6001,0,65535,65535,1,20.8,25458,-296,-296,8,6,1,203,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3641,3643,3645,3642,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,940,SUCCESS,,2185.886721,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5211,5/27/2021 1:00,20884.369,5.8,701,300,10,6001,0,65535,65535,1,20.8,25456,-296,-296,8,6,1,203,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3629,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,980,SUCCESS,,2185.557092,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5212,5/27/2021 1:00,20888.383,5.8,701,300,10,6001,0,65535,65535,1,20.8,25456,-296,-296,8,6,1,203,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3629,3631,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,981,SUCCESS,,2185.227052,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5213,5/27/2021 1:00,20892.384,5.8,701,300,10,6001,0,65535,65535,1,20.8,25456,-296,-296,8,6,1,202,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3628,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,979,SUCCESS,,2184.898081,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5214,5/27/2021 1:01,20896.397,5.8,701,300,10,6001,0,65535,65535,1,20.8,25455,-296,-296,8,6,1,202,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3628,3632,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21.1,975,SUCCESS,,2184.568123,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5215,5/27/2021 1:01,20900.398,5.81,701,300,10,6001,0,65535,65535,1,20.8,25454,-294,-296,8,6,1,202,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3628,3631,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,966,SUCCESS,,2184.241375,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5216,5/27/2021 1:01,20904.412,5.81,701,300,10,6001,0,65535,65535,1,20.8,25454,-298,-296,8,6,1,201,3632,40,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3645,3641,3628,3631,3626,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,953,SUCCESS,,2183.909105,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5217,5/27/2021 1:01,20908.42,5.81,701,300,10,6001,0,65535,65535,1,20.8,25452,-296,-296,8,6,1,201,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3644,3641,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,959,SUCCESS,,2183.579558,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5218,5/27/2021 1:01,20912.434,5.81,701,300,10,6001,0,65535,65535,1,20.8,25452,-298,-296,8,6,1,201,3632,40,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3644,3641,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,945,SUCCESS,,2183.247288,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5219,5/27/2021 1:01,20916.443,5.81,701,300,10,6001,0,65535,65535,1,20.8,25454,-296,-296,8,6,1,200,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3644,3641,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,952,SUCCESS,,2182.917659,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5220,5/27/2021 1:01,20920.455,5.81,701,300,10,6001,0,65535,65535,1,20.8,25452,-294,-296,8,6,1,200,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3644,3641,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,944,SUCCESS,,2182.590013,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5221,5/27/2021 1:01,20924.456,5.81,701,300,10,6001,0,65535,65535,1,20.8,25451,-296,-296,8,6,1,200,3632,41,41,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3643,3644,3641,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,955,SUCCESS,,2182.261041,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5222,5/27/2021 1:01,20928.469,5.81,701,300,10,6001,0,65535,65535,1,20.8,25451,-296,-296,8,6,1,199,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3642,3644,3640,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,945,SUCCESS,,2181.931084,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5223,5/27/2021 1:01,20932.474,5.81,701,300,10,6001,0,65535,65535,1,20.8,25452,-296,-296,8,6,1,199,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3640,3643,3644,3641,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,20.6,934,SUCCESS,,2181.601784,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5224,5/27/2021 1:01,20936.482,5.82,701,300,10,6001,0,65535,65535,1,20.8,25450,-296,-296,8,6,1,199,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3644,3640,3627,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,20.9,944,SUCCESS,,2181.272237,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5225,5/27/2021 1:01,20940.49,5.82,701,300,10,6001,0,65535,65535,1,20.8,25451,-296,-296,8,6,1,198,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3644,3640,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,951,SUCCESS,,2180.94269,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5226,5/27/2021 1:01,20944.501,5.82,701,300,10,6001,0,65535,65535,1,20.8,25447,-296,-296,8,6,1,198,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,962,SUCCESS,,2180.612897,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5227,5/27/2021 1:01,20948.504,5.82,701,300,10,6001,0,65535,65535,1,20.8,25447,-296,-296,8,6,1,198,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3628,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,968,SUCCESS,,2180.283761,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5228,5/27/2021 1:01,20952.522,5.82,701,300,10,6001,0,65535,65535,1,20.8,25451,-294,-296,8,6,1,197,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,950,SUCCESS,,2179.955625,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5229,5/27/2021 1:02,20956.532,5.82,701,300,10,6001,0,65535,65535,1,20.8,25447,-296,-296,8,6,1,197,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,963,SUCCESS,,2179.625914,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5230,5/27/2021 1:02,20960.548,5.82,701,300,10,6001,0,65535,65535,1,20.8,25445,-296,-296,8,6,1,197,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3630,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,956,SUCCESS,,2179.295709,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5231,5/27/2021 1:02,20964.571,5.82,701,300,10,6001,0,65535,65535,1,20.8,25451,-296,-296,8,6,1,196,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3631,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,20.9,946,SUCCESS,,2178.964929,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5232,5/27/2021 1:02,20968.579,5.82,701,300,10,6001,0,65535,65535,1,20.8,25445,-298,-296,8,6,1,196,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3630,3624,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,941,SUCCESS,,2178.633156,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5233,5/27/2021 1:02,20972.579,5.83,701,300,10,6001,0,65535,65535,1,20.8,25446,-296,-296,8,6,1,196,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3630,3624,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,940,SUCCESS,,2178.304267,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5234,5/27/2021 1:02,20976.604,5.83,701,300,10,6001,0,65535,65535,1,20.8,25450,-296,-296,8,6,1,195,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3630,3625,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,992,SUCCESS,,2177.973323,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5235,5/27/2021 1:02,20980.577,5.83,701,300,10,6001,0,65535,65535,1,20.8,25445,-294,-296,8,6,1,195,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3630,3624,0,0,0,0,0,0,0,0,2545,20.7,20.8,-273.2,20.8,-273.2,21,956,SUCCESS,,2177.648861,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5236,5/27/2021 1:02,20984.61,5.83,701,300,10,6001,0,65535,65535,1,20.8,25445,-296,-296,8,6,1,195,3632,40,40,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3640,3627,3630,3624,0,0,0,0,0,0,0,0,2541,20.7,20.8,-273.2,20.8,-273.2,21,964,SUCCESS,,2177.317259,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5237,5/27/2021 1:02,20988.628,5.83,701,300,10,6001,0,65535,65535,1,20.8,25448,-294,-296,8,6,1,194,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3639,3626,3630,3624,0,0,0,0,0,0,0,0,2541,20.7,20.8,-273.2,20.8,-273.2,21,941,SUCCESS,,2176.989122,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5238,5/27/2021 1:02,20992.641,5.83,701,300,10,6001,0,65535,65535,1,20.8,25444,-296,-296,8,6,1,194,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3641,3643,3639,3626,3630,3624,0,0,0,0,0,0,0,0,2541,20.7,20.8,-273.2,20.8,-273.2,21,956,SUCCESS,,2176.659164,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5239,5/27/2021 1:02,20996.657,5.83,701,300,10,6001,0,65535,65535,1,20.8,25444,-296,-296,8,6,1,194,3632,40,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3642,3643,3639,3626,3630,3624,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,953,SUCCESS,,2176.32896,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5240,5/27/2021 1:02,21000.664,5.83,701,300,10,6001,0,65535,65535,1,20.8,25443,-300,-296,8,6,1,193,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3642,3643,3639,3626,3631,3624,0,0,0,0,0,0,0,0,2541,20.7,20.8,-273.2,20.8,-273.2,21,951,SUCCESS,,2175.995043,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5241,5/27/2021 1:02,21004.597,5.83,701,300,10,6001,0,65535,65535,1,20.8,25443,-294,-296,8,6,1,193,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3643,3639,3626,3630,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,951,SUCCESS,,2175.673848,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5242,5/27/2021 1:02,21008.601,5.84,701,300,10,6001,0,65535,65535,1,20.8,25442,-294,-296,8,6,1,193,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3639,3641,3643,3639,3626,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,954,SUCCESS,,2175.346855,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5243,5/27/2021 1:02,21012.605,5.84,701,300,10,6001,0,65535,65535,1,20.8,25441,-296,-296,8,6,1,192,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3630,3624,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,988,SUCCESS,,2175.017637,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5244,5/27/2021 1:03,21016.611,5.84,701,300,10,6001,0,65535,65535,1,20.8,25440,-296,-296,8,6,1,192,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3643,3639,3626,3630,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,954,SUCCESS,,2174.688255,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5245,5/27/2021 1:03,21020.617,5.84,701,300,10,6001,0,65535,65535,1,20.8,25439,-298,-296,8,6,1,192,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3630,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,980,SUCCESS,,2174.356647,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5246,5/27/2021 1:03,21024.63,5.84,701,300,10,6001,0,65535,65535,1,20.8,25438,-296,-296,8,6,1,191,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3630,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,951,SUCCESS,,2174.026689,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5247,5/27/2021 1:03,21028.638,5.84,701,300,10,6001,0,65535,65535,1,20.8,25439,-296,-296,8,6,1,191,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,944,SUCCESS,,2173.697143,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5248,5/27/2021 1:03,21032.64,5.84,701,300,10,6001,0,65535,65535,1,20.8,25438,-298,-296,8,6,1,191,3632,38,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,940,SUCCESS,,2173.365866,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5249,5/27/2021 1:03,21036.645,5.84,701,300,10,6001,0,65535,65535,1,20.8,25438,-296,-296,8,6,1,190,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3634,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,934,SUCCESS,,2173.036566,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5250,5/27/2021 1:03,21040.646,5.84,701,300,10,6001,0,65535,65535,1,20.8,25438,-296,-296,8,6,1,190,3632,39,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,1012,SUCCESS,,2172.707595,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5251,5/27/2021 1:03,21044.651,5.85,701,300,10,6001,0,65535,65535,1,20.8,25437,-298,-296,8,6,1,190,3632,38,39,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3638,3641,3642,3639,3626,3628,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,982,SUCCESS,,2172.37607,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5252,5/27/2021 1:03,21048.654,5.85,701,300,10,6001,0,65535,65535,1,20.8,25438,-296,-296,8,6,1,189,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3626,3630,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,20.9,959,SUCCESS,,2172.046934,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5253,5/27/2021 1:03,21052.657,5.85,701,300,10,6001,0,65535,65535,1,20.8,25436,-296,-296,8,6,1,189,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3626,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,958,SUCCESS,,2171.717799,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5254,5/27/2021 1:03,21056.665,5.85,701,300,10,6001,0,65535,65535,1,20.8,25436,-298,-296,8,6,1,189,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3626,3628,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,935,SUCCESS,,2171.386025,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5255,5/27/2021 1:03,21060.668,5.85,701,300,10,6001,0,65535,65535,1,20.8,25437,-296,-296,8,6,1,188,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3626,3633,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,958,SUCCESS,,2171.05689,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5256,5/27/2021 1:03,21064.684,5.85,701,300,10,6001,0,65535,65535,1,20.8,25436,-296,-296,8,6,1,188,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3638,3625,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,944,SUCCESS,,2170.726685,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5257,5/27/2021 1:03,21068.689,5.85,701,300,10,6001,0,65535,65535,1,20.8,25435,-296,-296,8,6,1,188,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3638,3625,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,20.9,938,SUCCESS,,2170.397385,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5258,5/27/2021 1:03,21072.7,5.85,701,300,10,6001,0,65535,65535,1,20.8,25434,-298,-296,8,6,1,187,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3625,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,942,SUCCESS,,2170.065364,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5259,5/27/2021 1:04,21076.708,5.85,701,300,10,6001,0,65535,65535,1,20.8,25434,-298,-296,8,6,1,187,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3625,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,950,SUCCESS,,2169.73359,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5260,5/27/2021 1:04,21080.721,5.86,701,300,10,6001,0,65535,65535,1,20.8,25434,-296,-296,8,6,1,187,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3642,3639,3625,3629,3623,0,0,0,0,0,0,0,0,2540,20.7,20.8,-273.2,20.8,-273.2,21,967,SUCCESS,,2169.403633,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5261,5/27/2021 1:04,21084.734,5.86,701,300,10,6001,0,65535,65535,1,20.8,25434,-296,-296,8,6,1,186,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3633,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,20.9,956,SUCCESS,,2169.073675,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5262,5/27/2021 1:04,21088.747,5.86,701,300,10,6001,0,65535,65535,1,20.8,25433,-296,-296,8,6,1,186,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3629,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,21,944,SUCCESS,,2168.743717,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5263,5/27/2021 1:04,21092.756,5.86,701,300,10,6001,0,65535,65535,1,20.8,25431,-296,-296,8,6,1,186,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,20.4,995,SUCCESS,,2168.414088,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5264,5/27/2021 1:04,21096.767,5.86,701,300,10,6001,0,65535,65535,1,20.8,25431,-296,-297,8,6,1,186,3632,38,38,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.8,-273.2,21,953,SUCCESS,,2168.084295,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5265,5/27/2021 1:04,21100.77,5.86,701,300,10,6001,0,65535,65535,1,20.7,25431,-296,-297,8,6,1,185,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,989,SUCCESS,,2167.755159,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5266,5/27/2021 1:04,21104.784,5.86,701,300,10,6001,0,65535,65535,1,20.7,25431,-294,-297,8,6,1,185,3632,38,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.7,-273.2,21,937,SUCCESS,,2167.427349,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5267,5/27/2021 1:04,21108.792,5.86,701,300,10,6001,0,65535,65535,1,20.8,25431,-296,-297,8,6,1,185,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3638,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.8,-273.2,21,947,SUCCESS,,2167.097803,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5268,5/27/2021 1:04,21112.796,5.86,701,300,10,6001,0,65535,65535,1,20.8,25430,-298,-297,8,6,1,184,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3640,3641,3637,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,21,956,SUCCESS,,2166.76636,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5269,5/27/2021 1:04,21116.806,5.87,701,300,10,6001,0,65535,65535,1,20.8,25427,-298,-296,8,6,1,184,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3639,3640,3637,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,20.9,961,SUCCESS,,2166.434421,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5270,5/27/2021 1:04,21120.812,5.87,701,300,10,6001,0,65535,65535,1,20.8,25428,-298,-296,8,6,1,184,3632,38,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3639,3641,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,21,976,SUCCESS,,2166.102814,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5271,5/27/2021 1:04,21124.819,5.87,701,300,10,6001,0,65535,65535,1,20.8,25429,-296,-296,8,6,1,183,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3639,3641,3637,3625,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,21,963,SUCCESS,,2165.773349,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5272,5/27/2021 1:04,21128.833,5.87,701,300,10,6001,0,65535,65535,1,20.8,25427,-298,-296,8,6,1,183,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3639,3640,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,21,986,SUCCESS,,2165.441079,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5273,5/27/2021 1:04,21132.848,5.87,701,300,10,6001,0,65535,65535,1,20.7,25427,-294,-297,8,6,1,183,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3639,3640,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,956,SUCCESS,,2165.113188,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5274,5/27/2021 1:05,21136.862,5.87,701,300,10,6001,0,65535,65535,1,20.7,25426,-296,-296,8,6,1,182,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3637,3639,3640,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,938,SUCCESS,,2164.783148,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5275,5/27/2021 1:05,21140.868,5.87,701,300,10,6001,0,65535,65535,1,20.7,25425,-296,-296,8,6,1,182,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,965,SUCCESS,,2164.453765,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5276,5/27/2021 1:05,21144.871,5.87,701,300,10,6001,0,65535,65535,1,20.7,25427,-296,-296,8,6,1,182,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,943,SUCCESS,,2164.12463,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5277,5/27/2021 1:05,21148.875,5.87,701,300,10,6001,0,65535,65535,1,20.7,25425,-296,-296,8,5,1,181,3632,36,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3624,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,960,SUCCESS,,2163.795412,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5278,5/27/2021 1:05,21152.885,5.88,701,300,10,6001,0,65535,65535,1,20.8,25426,-296,-297,8,5,1,181,3632,37,37,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3623,3628,3622,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,20.9,946,SUCCESS,,2163.465701,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5279,5/27/2021 1:05,21156.893,5.88,701,300,10,6001,0,65535,65535,1,20.8,25425,-294,-296,8,5,1,180,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3623,3628,3621,0,0,0,0,0,0,0,0,2540,20.6,20.8,-273.2,20.8,-273.2,21,955,SUCCESS,,2163.138381,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5280,5/27/2021 1:05,21160.906,5.88,701,300,10,6001,0,65535,65535,1,20.7,25423,-298,-297,8,5,1,180,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,986,SUCCESS,,2162.806194,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5281,5/27/2021 1:05,21164.92,5.88,701,300,10,6001,0,65535,65535,1,20.7,25424,-296,-297,8,5,1,180,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3623,3628,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,950,SUCCESS,,2162.476154,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5282,5/27/2021 1:05,21168.934,5.88,701,300,10,6001,0,65535,65535,1,20.7,25423,-296,-297,8,5,1,180,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3624,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,948,SUCCESS,,2162.146114,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5283,5/27/2021 1:05,21172.944,5.88,701,300,10,6001,0,65535,65535,1,20.7,25423,-300,-297,8,5,1,179,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3637,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,956,SUCCESS,,2161.811947,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5284,5/27/2021 1:05,21176.948,5.88,701,300,10,6001,0,65535,65535,1,20.7,25423,-296,-297,8,5,1,179,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3639,3640,3636,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,945,SUCCESS,,2161.482729,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5285,5/27/2021 1:05,21180.954,5.88,701,300,10,6001,0,65535,65535,1,20.7,25421,-296,-297,8,5,1,179,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3638,3640,3636,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,977,SUCCESS,,2161.153347,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5286,5/27/2021 1:05,21184.962,5.88,701,300,10,6001,0,65535,65535,1,20.7,25421,-298,-297,8,5,1,178,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3638,3640,3636,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,965,SUCCESS,,2160.821574,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5287,5/27/2021 1:05,21188.969,5.89,701,300,10,6001,0,65535,65535,1,20.7,25421,-296,-297,8,5,1,178,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3638,3639,3637,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,939,SUCCESS,,2160.492109,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5288,5/27/2021 1:06,21192.98,5.89,701,300,10,6001,0,65535,65535,1,20.7,25421,-298,-297,8,5,1,178,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3638,3640,3636,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,950,SUCCESS,,2160.160088,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5289,5/27/2021 1:06,21196.988,5.89,701,300,10,6001,0,65535,65535,1,20.7,25419,-298,-297,8,5,1,177,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3638,3639,3636,3623,3626,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,953,SUCCESS,,2159.828314,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5290,5/27/2021 1:06,21200.998,5.89,701,300,10,6001,0,65535,65535,1,20.7,25420,-296,-297,8,5,1,177,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3636,3638,3639,3636,3623,3627,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,943,SUCCESS,,2159.498603,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5291,5/27/2021 1:06,21205.004,5.89,701,300,10,6001,0,65535,65535,1,20.7,25419,-298,-297,8,5,1,177,3632,35,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3627,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,939,SUCCESS,,2159.166995,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5292,5/27/2021 1:06,21209.015,5.89,701,300,10,6001,0,65535,65535,1,20.7,25418,-298,-297,8,5,1,176,3632,36,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3626,3621,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,941,SUCCESS,,2158.834974,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5293,5/27/2021 1:06,21213.023,5.89,701,300,10,6001,0,65535,65535,1,20.7,25418,-296,-297,8,5,1,176,3632,35,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3627,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,963,SUCCESS,,2158.505427,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5294,5/27/2021 1:06,21217.028,5.89,701,300,10,6001,0,65535,65535,1,20.7,25417,-298,-297,8,5,1,176,3632,35,36,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3627,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,981,SUCCESS,,2158.173902,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5295,5/27/2021 1:06,21221.035,5.89,701,300,10,6001,0,65535,65535,1,20.7,25417,-298,-297,8,5,1,175,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2157.842211,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5296,5/27/2021 1:06,21225.04,5.9,701,300,10,6001,0,65535,65535,1,20.7,25418,-298,-297,8,5,1,175,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,978,SUCCESS,,2157.510686,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5297,5/27/2021 1:06,21229.041,5.9,701,300,10,6001,0,65535,65535,1,20.7,25416,-298,-297,8,5,1,175,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3637,3639,3636,3623,3627,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,945,SUCCESS,,2157.179493,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5298,5/27/2021 1:06,21233.052,5.9,701,300,10,6001,0,65535,65535,1,20.7,25417,-300,-297,8,5,1,174,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3638,3639,3636,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,950,SUCCESS,,2156.845243,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5299,5/27/2021 1:06,21237.066,5.9,701,300,10,6001,0,65535,65535,1,20.7,25416,-296,-297,8,5,1,174,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3637,3639,3636,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,938,SUCCESS,,2156.515203,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5300,5/27/2021 1:06,21241.064,5.9,701,300,10,6001,0,65535,65535,1,20.7,25416,-296,-297,8,5,1,174,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3637,3639,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,975,SUCCESS,,2156.186478,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5301,5/27/2021 1:06,21245.079,5.9,701,300,10,6001,0,65535,65535,1,20.7,25416,-296,-297,8,5,1,173,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3639,3636,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,964,SUCCESS,,2155.856356,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5302,5/27/2021 1:06,21249.086,5.9,701,300,10,6001,0,65535,65535,1,20.7,25415,-296,-297,8,5,1,173,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3639,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,1001,SUCCESS,,2155.526891,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5303,5/27/2021 1:07,21253.088,5.9,701,300,10,6001,0,65535,65535,1,20.7,25411,-296,-297,8,5,1,173,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3639,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,970,SUCCESS,,2155.197838,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5304,5/27/2021 1:07,21257.09,5.9,701,300,10,6001,0,65535,65535,1,20.7,25415,-296,-296,8,5,1,172,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3635,3637,3639,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,944,SUCCESS,,2154.868785,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5305,5/27/2021 1:07,21261.097,5.91,701,300,10,6001,0,65535,65535,1,20.7,25414,-296,-296,8,5,1,172,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3639,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,938,SUCCESS,,2154.53932,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5306,5/27/2021 1:07,21265.109,5.91,701,300,10,6001,0,65535,65535,1,20.7,25411,-296,-296,8,5,1,172,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3639,3635,3623,3625,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,941,SUCCESS,,2154.209445,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5307,5/27/2021 1:07,21269.122,5.91,701,300,10,6001,0,65535,65535,1,20.7,25413,-296,-296,8,5,1,171,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3638,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2153.879487,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5308,5/27/2021 1:07,21273.125,5.91,701,300,10,6001,0,65535,65535,1,20.7,25414,-296,-296,8,5,1,171,3632,35,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3638,3635,3623,3626,3620,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,947,SUCCESS,,2153.550351,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5309,5/27/2021 1:07,21277.134,5.91,701,300,10,6001,0,65535,65535,1,20.7,25408,-298,-296,8,5,1,171,3632,34,35,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3637,3638,3635,3623,3626,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,945,SUCCESS,,2153.218495,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5310,5/27/2021 1:07,21281.15,5.91,701,300,10,6001,0,65535,65535,1,20.7,25410,-296,-296,8,5,1,170,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3636,3638,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,952,SUCCESS,,2152.888291,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5311,5/27/2021 1:07,21285.165,5.91,701,300,10,6001,0,65535,65535,1,20.7,25409,-296,-296,8,5,1,170,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3638,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,985,SUCCESS,,2152.558169,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5312,5/27/2021 1:07,21289.17,5.91,701,300,10,6001,0,65535,65535,1,20.7,25409,-298,-296,8,5,1,170,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3636,3638,3634,3623,3626,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,944,SUCCESS,,2152.226644,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5313,5/27/2021 1:07,21293.178,5.91,701,300,10,6001,0,65535,65535,1,20.7,25409,-296,-297,8,5,1,169,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3636,3638,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,955,SUCCESS,,2151.897097,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5314,5/27/2021 1:07,21297.181,5.92,701,300,10,6001,0,65535,65535,1,20.7,25408,-298,-297,8,5,1,169,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3634,3636,3638,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,962,SUCCESS,,2151.565738,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5315,5/27/2021 1:07,21301.181,5.92,701,300,10,6001,0,65535,65535,1,20.7,25407,-296,-297,8,5,1,169,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,993,SUCCESS,,2151.236849,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5316,5/27/2021 1:07,21305.182,5.92,701,300,10,6001,0,65535,65535,1,20.7,25408,-294,-297,8,5,1,168,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,952,SUCCESS,,2150.9101,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5317,5/27/2021 1:07,21309.193,5.92,701,300,10,6001,0,65535,65535,1,20.7,25409,-298,-297,8,5,1,168,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.4,972,SUCCESS,,2150.578079,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5318,5/27/2021 1:08,21313.198,5.92,701,300,10,6001,0,65535,65535,1,20.7,25407,-298,-296,8,5,1,168,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,947,SUCCESS,,2150.246554,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5319,5/27/2021 1:08,21317.203,5.92,701,300,10,6001,0,65535,65535,1,20.7,25406,-296,-296,8,5,1,167,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,954,SUCCESS,,2149.917254,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5320,5/27/2021 1:08,21321.212,5.92,701,300,10,6001,0,65535,65535,1,20.7,25407,-298,-296,8,5,1,167,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3623,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,947,SUCCESS,,2149.585398,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5321,5/27/2021 1:08,21325.214,5.92,701,300,10,6001,0,65535,65535,1,20.7,25405,-296,-296,8,5,1,167,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3624,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,966,SUCCESS,,2149.256344,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5322,5/27/2021 1:08,21329.229,5.92,701,300,10,6001,0,65535,65535,1,20.7,25406,-296,-296,8,5,1,166,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,961,SUCCESS,,2148.926222,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5323,5/27/2021 1:08,21333.239,5.93,701,300,10,6001,0,65535,65535,1,20.7,25406,-294,-296,8,5,1,166,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,982,SUCCESS,,2148.598739,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5324,5/27/2021 1:08,21337.248,5.93,701,300,10,6001,0,65535,65535,1,20.7,25406,-296,-296,8,5,1,166,3632,34,34,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3623,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,974,SUCCESS,,2148.26911,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5325,5/27/2021 1:08,21341.261,5.93,701,300,10,6001,0,65535,65535,1,20.7,25405,-294,-296,8,5,1,165,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,949,SUCCESS,,2147.941381,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5326,5/27/2021 1:08,21345.265,5.93,701,300,10,6001,0,65535,65535,1,20.7,25406,-294,-296,8,5,1,165,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3624,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2147.614388,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5327,5/27/2021 1:08,21349.27,5.93,701,300,10,6001,0,65535,65535,1,20.7,25404,-296,-296,8,5,1,165,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3623,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,953,SUCCESS,,2147.285088,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5328,5/27/2021 1:08,21353.274,5.93,701,300,10,6001,0,65535,65535,1,20.7,25404,-296,-296,8,5,1,164,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3625,3619,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,948,SUCCESS,,2146.95587,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5329,5/27/2021 1:08,21357.289,5.93,701,300,10,6001,0,65535,65535,1,20.7,25403,-296,-296,8,5,1,164,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3622,3625,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,948,SUCCESS,,2146.625748,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5330,5/27/2021 1:08,21361.292,5.93,701,300,10,6001,0,65535,65535,1,20.7,25403,-296,-296,8,5,1,164,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3621,3621,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,948,SUCCESS,,2146.296613,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5331,5/27/2021 1:08,21365.303,5.93,701,300,10,6001,0,65535,65535,1,20.7,25403,-296,-296,8,5,1,163,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3621,3624,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,980,SUCCESS,,2145.966819,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5332,5/27/2021 1:08,21369.313,5.94,701,300,10,6001,0,65535,65535,1,20.7,25402,-294,-296,8,5,1,163,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3633,3636,3637,3634,3621,3624,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,940,SUCCESS,,2145.639336,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5333,5/27/2021 1:09,21373.32,5.94,701,300,10,6001,0,65535,65535,1,20.7,25402,-296,-296,8,5,1,163,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3636,3637,3634,3621,3620,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,973,SUCCESS,,2145.309871,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5334,5/27/2021 1:09,21377.331,5.94,701,300,10,6001,0,65535,65535,1,20.7,25403,-298,-297,8,5,1,162,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3636,3637,3634,3621,3624,3618,0,0,0,0,0,0,0,0,2539,20.6,20.7,-273.2,20.7,-273.2,20.9,975,SUCCESS,,2144.97785,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5335,5/27/2021 1:09,21381.341,5.94,701,300,10,6001,0,65535,65535,1,20.7,25401,-296,-297,8,5,1,162,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3636,3637,3634,3621,3624,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2144.648139,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5336,5/27/2021 1:09,21385.349,5.94,701,300,10,6001,0,65535,65535,1,20.7,25402,-296,-296,8,5,1,162,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3637,3633,3621,3621,3618,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,21,953,SUCCESS,,2144.318592,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5337,5/27/2021 1:09,21389.356,5.94,701,300,10,6001,0,65535,65535,1,20.7,25399,-296,-297,8,5,1,161,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3637,3634,3621,3623,3618,0,0,0,0,0,0,0,0,2537,20.6,20.7,-273.2,20.7,-273.2,20.9,945,SUCCESS,,2143.989128,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5338,5/27/2021 1:09,21393.37,5.94,701,300,10,6001,0,65535,65535,1,20.7,25397,-294,-297,8,5,1,161,3632,33,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3636,3633,3620,3624,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,944,SUCCESS,,2143.661318,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5339,5/27/2021 1:09,21397.38,5.94,701,300,10,6001,0,65535,65535,1,20.7,25398,-294,-296,8,5,1,161,3632,32,33,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3636,3633,3620,3624,3617,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,942,SUCCESS,,2143.333834,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5340,5/27/2021 1:09,21401.384,5.94,701,300,10,6001,0,65535,65535,1,20.7,25396,-296,-297,8,5,1,160,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3636,3633,3620,3623,3618,0,0,0,0,0,0,0,0,2537,20.6,20.7,-273.2,20.7,-273.2,20.9,963,SUCCESS,,2143.004616,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5341,5/27/2021 1:09,21405.399,5.95,701,300,10,6001,0,65535,65535,1,20.7,25397,-296,-296,8,5,1,160,3632,33,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3636,3633,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,980,SUCCESS,,2142.674494,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5342,5/27/2021 1:09,21409.403,5.95,701,300,10,6001,0,65535,65535,1,20.7,25397,-298,-296,8,5,1,160,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3636,3633,3620,3623,3617,0,0,0,0,0,0,0,0,2540,20.6,20.7,-273.2,20.7,-273.2,20.9,944,SUCCESS,,2142.343052,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5343,5/27/2021 1:09,21413.406,5.95,701,300,10,6001,0,65535,65535,1,20.7,25396,-296,-296,8,5,1,159,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3635,3636,3633,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.7,971,SUCCESS,,2142.013916,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5344,5/27/2021 1:09,21417.406,5.95,701,300,10,6001,0,65535,65535,1,20.7,25396,-296,-296,8,5,1,159,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3634,3636,3633,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,955,SUCCESS,,2141.685028,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5345,5/27/2021 1:09,21421.413,5.95,701,300,10,6001,0,65535,65535,1,20.7,25395,-298,-296,8,5,1,159,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,966,SUCCESS,,2141.353337,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5346,5/27/2021 1:09,21425.418,5.95,701,300,10,6001,0,65535,65535,1,20.7,25395,-298,-296,8,5,1,158,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,950,SUCCESS,,2141.021812,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5347,5/27/2021 1:09,21429.42,5.95,701,300,10,6001,0,65535,65535,1,20.7,25395,-296,-296,8,5,1,158,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,942,SUCCESS,,2140.692759,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5348,5/27/2021 1:10,21433.428,5.95,701,300,10,6001,0,65535,65535,1,20.7,25394,-296,-296,8,5,1,158,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3632,3634,3636,3633,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,971,SUCCESS,,2140.363212,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5349,5/27/2021 1:10,21437.443,5.95,701,300,10,6001,0,65535,65535,1,20.7,25393,-296,-296,8,5,1,157,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2140.03309,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5350,5/27/2021 1:10,21441.448,5.96,701,300,10,6001,0,65535,65535,1,20.7,25393,-298,-297,8,5,1,157,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3619,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,961,SUCCESS,,2139.701565,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5351,5/27/2021 1:10,21445.457,5.96,701,300,10,6001,0,65535,65535,1,20.7,25393,-296,-297,8,5,1,157,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2139.371936,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5352,5/27/2021 1:10,21449.467,5.96,701,300,10,6001,0,65535,65535,1,20.7,25393,-298,-297,8,5,1,156,3632,31,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,942,SUCCESS,,2139.039997,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5353,5/27/2021 1:10,21453.479,5.96,701,300,10,6001,0,65535,65535,1,20.7,25392,-296,-297,8,5,1,156,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3619,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,960,SUCCESS,,2138.710121,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5354,5/27/2021 1:10,21457.487,5.96,701,300,10,6001,0,65535,65535,1,20.7,25392,-296,-297,8,5,1,156,3632,32,32,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3620,3623,3617,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,959,SUCCESS,,2138.380575,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5355,5/27/2021 1:10,21461.501,5.96,701,300,10,6001,0,65535,65535,1,20.7,25390,-298,-296,8,5,1,155,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3619,3623,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.8,973,SUCCESS,,2138.048305,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5356,5/27/2021 1:10,21465.509,5.96,701,300,10,6001,0,65535,65535,1,20.7,25391,-296,-296,8,5,1,155,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3636,3632,3619,3623,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,1007,SUCCESS,,2137.718758,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5357,5/27/2021 1:10,21469.514,5.96,701,300,10,6001,0,65535,65535,1,20.7,25390,-296,-296,8,5,1,155,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3632,3619,3623,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,974,SUCCESS,,2137.389458,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5358,5/27/2021 1:10,21473.525,5.96,701,300,10,6001,0,65535,65535,1,20.7,25389,-298,-296,8,5,1,154,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3632,3619,3623,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,947,SUCCESS,,2137.057436,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5359,5/27/2021 1:10,21477.53,5.97,701,300,10,6001,0,65535,65535,1,20.7,25389,-296,-297,8,5,1,154,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3632,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,959,SUCCESS,,2136.728136,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5360,5/27/2021 1:10,21481.533,5.97,701,300,10,6001,0,65535,65535,1,20.7,25389,-296,-297,8,5,1,154,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3632,3619,3623,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,939,SUCCESS,,2136.399001,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5361,5/27/2021 1:10,21485.544,5.97,701,300,10,6001,0,65535,65535,1,20.7,25388,-296,-297,8,5,1,153,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3632,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,990,SUCCESS,,2136.069208,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5362,5/27/2021 1:10,21489.559,5.97,701,300,10,6001,0,65535,65535,1,20.7,25389,-296,-297,8,5,1,153,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,947,SUCCESS,,2135.739085,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5363,5/27/2021 1:11,21493.567,5.97,701,300,10,6001,0,65535,65535,1,20.7,25386,-298,-297,8,5,1,153,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3634,3635,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,951,SUCCESS,,2135.407312,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5364,5/27/2021 1:11,21497.569,5.97,701,300,10,6001,0,65535,65535,1,20.7,25389,-294,-297,8,5,1,152,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3631,3633,3635,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,972,SUCCESS,,2135.080482,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5365,5/27/2021 1:11,21501.574,5.97,701,300,10,6001,0,65535,65535,1,20.7,25386,-296,-296,8,5,1,152,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3635,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,944,SUCCESS,,2134.751182,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5366,5/27/2021 1:11,21505.576,5.97,701,300,10,6001,0,65535,65535,1,20.7,25386,-298,-296,8,5,1,152,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,947,SUCCESS,,2134.419905,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5367,5/27/2021 1:11,21509.589,5.97,701,300,10,6001,0,65535,65535,1,20.7,25386,-296,-296,8,5,1,151,3632,31,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3635,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,930,SUCCESS,,2134.089948,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5368,5/27/2021 1:11,21513.601,5.98,701,300,10,6001,0,65535,65535,1,20.7,25385,-296,-296,8,5,1,151,3632,30,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3635,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,954,SUCCESS,,2133.760072,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5369,5/27/2021 1:11,21517.608,5.98,701,300,10,6001,0,65535,65535,1,20.7,25385,-296,-296,8,5,1,151,3632,30,31,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3619,3622,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2133.430608,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5370,5/27/2021 1:11,21521.622,5.98,701,300,10,6001,0,65535,65535,1,20.7,25384,-294,-296,8,5,1,150,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3619,3622,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,945,SUCCESS,,2133.102798,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5371,5/27/2021 1:11,21525.626,5.98,701,300,10,6001,0,65535,65535,1,20.7,25385,-298,-296,8,5,1,150,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3619,3621,3616,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,957,SUCCESS,,2132.771355,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5372,5/27/2021 1:11,21529.638,5.98,701,300,10,6001,0,65535,65535,1,20.7,25383,-296,-296,8,5,1,150,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,951,SUCCESS,,2132.44148,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5373,5/27/2021 1:11,21533.651,5.98,701,300,10,6001,0,65535,65535,1,20.7,25384,-296,-296,8,5,1,149,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3619,3622,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,932,SUCCESS,,2132.111522,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5374,5/27/2021 1:11,21537.665,5.98,701,300,10,6001,0,65535,65535,1,20.7,25383,-296,-296,8,5,1,149,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3618,3622,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.6,979,SUCCESS,,2131.781482,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5375,5/27/2021 1:11,21541.679,5.98,701,300,10,6001,0,65535,65535,1,20.7,25384,-294,-296,8,5,1,149,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3630,3633,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,948,SUCCESS,,2131.453672,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5376,5/27/2021 1:11,21545.684,5.98,701,300,10,6001,0,65535,65535,1,20.7,25381,-294,-296,8,5,1,148,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,943,SUCCESS,,2131.126597,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5377,5/27/2021 1:11,21549.692,5.99,701,300,10,6001,0,65535,65535,1,20.7,25380,-296,-296,8,5,1,148,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2130.79705,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5378,5/27/2021 1:12,21553.708,5.99,701,300,10,6001,0,65535,65535,1,20.7,25381,-296,-296,8,5,1,148,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.8,953,SUCCESS,,2130.466846,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5379,5/27/2021 1:12,21557.714,5.99,701,300,10,6001,0,65535,65535,1,20.7,25380,-298,-296,8,5,1,147,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,931,SUCCESS,,2130.135238,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5380,5/27/2021 1:12,21561.716,5.99,701,300,10,6001,0,65535,65535,1,20.7,25379,-296,-296,8,5,1,147,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3618,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,947,SUCCESS,,2129.806185,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5381,5/27/2021 1:12,21565.72,5.99,701,300,10,6001,0,65535,65535,1,20.7,25380,-294,-296,8,5,1,147,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3617,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2129.479191,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5382,5/27/2021 1:12,21569.732,5.99,701,300,10,6001,0,65535,65535,1,20.7,25379,-296,-296,8,5,1,146,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3617,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,942,SUCCESS,,2129.149316,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5383,5/27/2021 1:12,21573.736,5.99,701,300,10,6001,0,65535,65535,1,20.7,25377,-296,-296,8,5,1,146,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3634,3631,3617,3622,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.3,949,SUCCESS,,2128.820098,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5384,5/27/2021 1:12,21577.75,5.99,701,300,10,6001,0,65535,65535,1,20.7,25377,-296,-296,8,5,1,146,3632,30,30,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3633,3630,3617,3620,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,944,SUCCESS,,2128.490058,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5385,5/27/2021 1:12,21581.763,5.99,701,300,10,6001,0,65535,65535,1,20.7,25377,-296,-296,8,4,1,145,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3633,3631,3617,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,975,SUCCESS,,2128.1601,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5386,5/27/2021 1:12,21585.773,6,701,300,10,6001,0,65535,65535,1,20.7,25373,-296,-296,8,4,1,145,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3633,3630,3617,3621,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,950,SUCCESS,,2127.830389,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5387,5/27/2021 1:12,21589.776,6,701,300,10,6001,0,65535,65535,1,20.7,25377,-296,-296,8,4,1,145,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3633,3630,3617,3620,3615,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,946,SUCCESS,,2127.501254,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5388,5/27/2021 1:12,21593.778,6,701,300,10,6001,0,65535,65535,1,20.7,25376,-296,-296,8,4,1,144,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3632,3633,3630,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,946,SUCCESS,,2127.1722,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5389,5/27/2021 1:12,21597.79,6,701,300,10,6001,0,65535,65535,1,20.7,25375,-296,-296,8,4,1,144,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3630,3617,3621,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,980,SUCCESS,,2126.842325,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5390,5/27/2021 1:12,21601.805,6,701,300,10,6001,0,65535,65535,1,20.7,25375,-296,-296,8,4,1,144,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3630,3617,3621,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,963,SUCCESS,,2126.512203,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5391,5/27/2021 1:12,21605.815,6,701,300,10,6001,0,65535,65535,1,20.7,25373,-296,-296,8,4,1,143,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3629,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,939,SUCCESS,,2126.182491,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5392,5/27/2021 1:12,21609.82,6,701,300,10,6001,0,65535,65535,1,20.7,25374,-296,-296,8,4,1,143,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3629,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,951,SUCCESS,,2125.853191,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5393,5/27/2021 1:13,21613.824,6,701,300,10,6001,0,65535,65535,1,20.7,25373,-298,-296,8,4,1,143,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3630,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,945,SUCCESS,,2125.521749,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5394,5/27/2021 1:13,21617.839,6,701,300,10,6001,0,65535,65535,1,20.7,25375,-296,-296,8,4,1,142,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3630,3617,3621,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,963,SUCCESS,,2125.191627,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5395,5/27/2021 1:13,21621.844,6.01,701,300,10,6001,0,65535,65535,1,20.7,25374,-294,-296,8,4,1,142,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3629,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,21,972,SUCCESS,,2124.864552,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5396,5/27/2021 1:13,21625.859,6.01,701,300,10,6001,0,65535,65535,1,20.7,25373,-294,-296,8,4,1,142,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3630,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2124.53666,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5397,5/27/2021 1:13,21629.867,6.01,701,300,10,6001,0,65535,65535,1,20.7,25373,-296,-296,8,4,1,141,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3633,3629,3617,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,950,SUCCESS,,2124.207114,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5398,5/27/2021 1:13,21633.877,6.01,701,300,10,6001,0,65535,65535,1,20.7,25371,-298,-296,8,4,1,141,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,939,SUCCESS,,2123.875175,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5399,5/27/2021 1:13,21637.891,6.01,701,300,10,6001,0,65535,65535,1,20.7,25371,-296,-296,8,4,1,141,3632,29,29,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.8,945,SUCCESS,,2123.545135,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5400,5/27/2021 1:13,21641.901,6.01,701,300,10,6001,0,65535,65535,1,20.7,25371,-296,-296,8,4,1,140,3632,29,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,932,SUCCESS,,2123.215424,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5401,5/27/2021 1:13,21645.912,6.01,701,300,10,6001,0,65535,65535,1,20.7,25371,-298,-296,8,4,1,140,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,951,SUCCESS,,2122.883402,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5402,5/27/2021 1:13,21649.919,6.01,701,300,10,6001,0,65535,65535,1,20.7,25371,-296,-296,8,4,1,140,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,944,SUCCESS,,2122.553938,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5403,5/27/2021 1:13,21653.922,6.01,701,300,10,6001,0,65535,65535,1,20.7,25371,-296,-296,8,4,1,139,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2122.224802,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5404,5/27/2021 1:13,21657.937,6.02,701,300,10,6001,0,65535,65535,1,20.7,25371,-296,-296,8,4,1,139,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2121.89468,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5405,5/27/2021 1:13,21661.947,6.02,701,300,10,6001,0,65535,65535,1,20.7,25370,-296,-296,8,4,1,139,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,930,SUCCESS,,2121.564969,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5406,5/27/2021 1:13,21665.956,6.02,701,300,10,6001,0,65535,65535,1,20.7,25370,-296,-296,8,4,1,138,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3629,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,953,SUCCESS,,2121.23534,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5407,5/27/2021 1:13,21669.969,6.02,701,300,10,6001,0,65535,65535,1,20.7,25369,-296,-296,8,4,1,138,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,942,SUCCESS,,2120.905382,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5408,5/27/2021 1:14,21673.977,6.02,701,300,10,6001,0,65535,65535,1,20.7,25368,-296,-296,8,4,1,138,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3629,3616,3620,3614,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,949,SUCCESS,,2120.575835,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5409,5/27/2021 1:14,21677.988,6.02,701,300,10,6001,0,65535,65535,1,20.7,25369,-298,-296,8,4,1,137,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3628,3615,3620,3614,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,970,SUCCESS,,2120.243814,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5410,5/27/2021 1:14,21682.002,6.02,701,300,10,6001,0,65535,65535,1,20.7,25368,-296,-296,8,4,1,137,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3628,3616,3622,3613,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.4,943,SUCCESS,,2119.913774,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5411,5/27/2021 1:14,21686.012,6.02,701,300,10,6001,0,65535,65535,1,20.7,25367,-298,-296,8,4,1,137,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3632,3628,3616,3620,3613,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,975,SUCCESS,,2119.581835,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5412,5/27/2021 1:14,21690.016,6.03,701,300,10,6001,0,65535,65535,1,20.7,25368,-296,-296,8,4,1,136,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3630,3631,3628,3616,3620,3613,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,941,SUCCESS,,2119.252617,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5413,5/27/2021 1:14,21694.022,6.03,701,300,10,6001,0,65535,65535,1,20.7,25368,-296,-296,8,4,1,136,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3631,3628,3616,3621,3613,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.9,981,SUCCESS,,2118.923235,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5414,5/27/2021 1:14,21698.028,6.03,701,300,10,6001,0,65535,65535,1,20.7,25365,-296,-296,8,4,1,136,3632,28,28,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3630,3632,3628,3616,3620,3613,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,943,SUCCESS,,2118.593853,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5415,5/27/2021 1:14,21702.032,6.03,701,300,10,6001,0,65535,65535,1,20.7,25368,-296,-296,8,4,1,135,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3630,3631,3628,3616,3618,3613,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2118.264635,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5416,5/27/2021 1:14,21706.034,6.03,701,300,10,6001,0,65535,65535,1,20.7,25366,-296,-296,8,4,1,135,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3628,3631,3631,3628,3616,3623,3613,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,955,SUCCESS,,2117.935581,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5417,5/27/2021 1:14,21710.042,6.03,701,300,10,6001,0,65535,65535,1,20.7,25365,-298,-296,8,4,1,135,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3616,3619,3613,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,960,SUCCESS,,2117.603808,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5418,5/27/2021 1:14,21714.042,6.03,701,300,10,6001,0,65535,65535,1,20.7,25364,-296,-296,8,4,1,134,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3616,3619,3613,0,0,0,0,0,0,0,0,2536,20.6,20.7,-273.2,20.7,-273.2,20.8,955,SUCCESS,,2117.274919,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5419,5/27/2021 1:14,21718.055,6.03,701,300,10,6001,0,65535,65535,1,20.7,25365,-296,-296,8,4,1,134,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3616,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.3,948,SUCCESS,,2116.944961,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5420,5/27/2021 1:14,21722.061,6.03,701,300,10,6001,0,65535,65535,1,20.7,25362,-296,-296,8,4,1,134,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3616,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,941,SUCCESS,,2116.615579,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5421,5/27/2021 1:14,21726.075,6.04,701,300,10,6001,0,65535,65535,1,20.7,25362,-296,-296,8,4,1,133,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3616,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,948,SUCCESS,,2116.285539,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5422,5/27/2021 1:14,21730.088,6.04,701,300,10,6001,0,65535,65535,1,20.7,25362,-298,-296,8,4,1,133,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3615,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,956,SUCCESS,,2115.953352,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5423,5/27/2021 1:15,21734.095,6.04,701,300,10,6001,0,65535,65535,1,20.7,25362,-298,-296,8,4,1,133,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3629,3631,3628,3615,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,937,SUCCESS,,2115.621661,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5424,5/27/2021 1:15,21738.102,6.04,701,300,10,6001,0,65535,65535,1,20.7,25361,-296,-296,8,4,1,132,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3630,3631,3628,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,946,SUCCESS,,2115.292197,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5425,5/27/2021 1:15,21742.105,6.04,701,300,10,6001,0,65535,65535,1,20.7,25361,-298,-296,8,4,1,132,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3629,3631,3627,3615,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,964,SUCCESS,,2114.960838,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5426,5/27/2021 1:15,21746.109,6.04,701,300,10,6001,0,65535,65535,1,20.7,25360,-296,-296,8,4,1,132,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3629,3631,3627,3615,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,957,SUCCESS,,2114.63162,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5427,5/27/2021 1:15,21750.122,6.04,701,300,10,6001,0,65535,65535,1,20.7,25359,-298,-296,8,4,1,131,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3629,3630,3627,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,944,SUCCESS,,2114.299433,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5428,5/27/2021 1:15,21754.133,6.04,701,300,10,6001,0,65535,65535,1,20.7,25359,-296,-297,8,4,1,131,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3627,3629,3631,3627,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,950,SUCCESS,,2113.969639,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5429,5/27/2021 1:15,21758.139,6.04,701,300,10,6001,0,65535,65535,1,20.7,25357,-294,-296,8,4,1,131,3632,27,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3631,3627,3615,3619,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,973,SUCCESS,,2113.642483,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5430,5/27/2021 1:15,21762.146,6.05,701,300,10,6001,0,65535,65535,1,20.7,25357,-296,-296,8,4,1,131,3632,26,27,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,980,SUCCESS,,2113.313018,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5431,5/27/2021 1:15,21766.162,6.05,701,300,10,6001,0,65535,65535,1,20.7,25358,-296,-296,8,4,1,130,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,970,SUCCESS,,2112.982814,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5432,5/27/2021 1:15,21770.171,6.05,701,300,10,6001,0,65535,65535,1,20.7,25357,-296,-296,8,4,1,130,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,1006,SUCCESS,,2112.653185,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5433,5/27/2021 1:15,21774.185,6.05,701,300,10,6001,0,65535,65535,1,20.7,25357,-296,-296,8,4,1,130,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3615,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,963,SUCCESS,,2112.323145,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5434,5/27/2021 1:15,21778.186,6.05,701,300,10,6001,0,65535,65535,1,20.7,25356,-294,-296,8,4,1,129,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3614,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,946,SUCCESS,,2111.996396,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5435,5/27/2021 1:15,21782.189,6.05,701,300,10,6001,0,65535,65535,1,20.7,25357,-294,-296,8,4,1,129,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3614,3618,3611,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,992,SUCCESS,,2111.669485,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5436,5/27/2021 1:15,21786.199,6.05,701,300,10,6001,0,65535,65535,1,20.7,25356,-300,-296,8,4,1,128,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3629,3630,3627,3614,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,952,SUCCESS,,2111.335318,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5437,5/27/2021 1:15,21790.207,6.05,701,300,10,6001,0,65535,65535,1,20.7,25356,-296,-296,8,4,1,128,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3618,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,967,SUCCESS,,2111.005771,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5438,5/27/2021 1:16,21794.221,6.05,701,300,10,6001,0,65535,65535,1,20.7,25355,-296,-296,8,4,1,128,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3618,3611,0,0,0,0,0,0,0,0,2535,20.5,20.7,-273.2,20.7,-273.2,20.9,936,SUCCESS,,2110.675731,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5439,5/27/2021 1:16,21798.223,6.06,701,300,10,6001,0,65535,65535,1,20.7,25355,-296,-296,8,4,1,127,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3617,3612,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,988,SUCCESS,,2110.346678,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5440,5/27/2021 1:16,21802.23,6.06,701,300,10,6001,0,65535,65535,1,20.7,25355,-296,-296,8,4,1,127,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3618,3612,0,0,0,0,0,0,0,0,2532,20.5,20.7,-273.2,20.7,-273.2,20.9,959,SUCCESS,,2110.017214,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5441,5/27/2021 1:16,21806.238,6.06,701,300,10,6001,0,65535,65535,1,20.7,25353,-296,-296,8,4,1,127,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3618,3611,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.9,942,SUCCESS,,2109.687667,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5442,5/27/2021 1:16,21810.241,6.06,701,300,10,6001,0,65535,65535,1,20.7,25353,-296,-296,8,4,1,126,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,986,SUCCESS,,2109.358531,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5443,5/27/2021 1:16,21814.246,6.06,701,300,10,6001,0,65535,65535,1,20.7,25354,-296,-296,8,4,1,126,3632,26,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3626,3628,3630,3627,3614,3617,3611,0,0,0,0,0,0,0,0,2536,20.5,20.7,-273.2,20.7,-273.2,20.8,974,SUCCESS,,2109.029231,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5444,5/27/2021 1:16,21818.26,6.06,701,300,10,6001,0,65535,65535,1,20.7,25353,-296,-296,8,4,1,126,3632,25,26,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3630,3627,3614,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,952,SUCCESS,,2108.699191,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5445,5/27/2021 1:16,21822.263,6.06,701,300,10,6001,0,65535,65535,1,20.7,25352,-296,-296,8,4,1,125,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3630,3627,3614,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,962,SUCCESS,,2108.370056,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5446,5/27/2021 1:16,21826.268,6.06,701,300,10,6001,0,65535,65535,1,20.7,25352,-296,-296,8,4,1,125,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3614,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2108.040756,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5447,5/27/2021 1:16,21830.27,6.06,701,300,10,6001,0,65535,65535,1,20.7,25351,-296,-296,8,4,1,125,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3614,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,975,SUCCESS,,2107.711703,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5448,5/27/2021 1:16,21834.285,6.07,701,300,10,6001,0,65535,65535,1,20.7,25352,-294,-296,8,4,1,125,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,954,SUCCESS,,2107.383811,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5449,5/27/2021 1:16,21838.287,6.07,701,300,10,6001,0,65535,65535,1,20.7,25351,-298,-296,8,4,1,124,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,967,SUCCESS,,2107.052534,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5450,5/27/2021 1:16,21842.298,6.07,701,300,10,6001,0,65535,65535,1,20.7,25351,-296,-296,8,4,1,124,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,954,SUCCESS,,2106.722741,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5451,5/27/2021 1:16,21846.304,6.07,701,300,10,6001,0,65535,65535,1,20.7,25350,-296,-296,8,4,1,124,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3630,3627,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,935,SUCCESS,,2106.393359,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5452,5/27/2021 1:16,21850.319,6.07,701,300,10,6001,0,65535,65535,1,20.7,25351,-298,-296,8,4,1,123,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,950,SUCCESS,,2106.061006,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5453,5/27/2021 1:17,21854.331,6.07,701,300,10,6001,0,65535,65535,1,20.7,25349,-296,-296,8,4,1,123,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3626,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,938,SUCCESS,,2105.73113,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5454,5/27/2021 1:17,21858.345,6.07,701,300,10,6001,0,65535,65535,1,20.7,25349,-296,-296,8,4,1,123,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3627,3613,3616,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,974,SUCCESS,,2105.40109,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5455,5/27/2021 1:17,21862.35,6.07,701,300,10,6001,0,65535,65535,1,20.7,25349,-296,-296,8,4,1,122,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3626,3613,3617,3611,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,950,SUCCESS,,2105.07179,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5456,5/27/2021 1:17,21866.355,6.07,701,300,10,6001,0,65535,65535,1,20.7,25350,-294,-296,8,4,1,122,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3626,3613,3617,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,959,SUCCESS,,2104.744715,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5457,5/27/2021 1:17,21870.362,6.08,701,300,10,6001,0,65535,65535,1,20.7,25348,-296,-296,8,4,1,122,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3626,3613,3616,3610,0,0,0,0,0,0,0,0,2532,20.5,20.7,-273.2,20.7,-273.2,20.9,967,SUCCESS,,2104.415251,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5458,5/27/2021 1:17,21874.372,6.08,701,300,10,6001,0,65535,65535,1,20.7,25349,-296,-296,8,4,1,121,3632,24,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3626,3613,3617,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,974,SUCCESS,,2104.08554,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5459,5/27/2021 1:17,21878.372,6.08,701,300,10,6001,0,65535,65535,1,20.7,25347,-294,-296,8,4,1,121,3632,25,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3628,3629,3626,3613,3616,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,959,SUCCESS,,2103.758873,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5460,5/27/2021 1:17,21882.376,6.08,701,300,10,6001,0,65535,65535,1,20.7,25346,-296,-296,8,4,1,121,3632,24,25,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3629,3626,3613,3616,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,963,SUCCESS,,2103.429655,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5461,5/27/2021 1:17,21886.39,6.08,701,300,10,6001,0,65535,65535,1,20.7,25347,-296,-296,8,4,1,120,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3629,3626,3613,3616,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,962,SUCCESS,,2103.099615,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5462,5/27/2021 1:17,21890.394,6.08,701,300,10,6001,0,65535,65535,1,20.7,25345,-298,-296,8,4,1,120,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3629,3626,3613,3616,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,946,SUCCESS,,2102.768173,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5463,5/27/2021 1:17,21894.399,6.08,701,300,10,6001,0,65535,65535,1,20.7,25344,-298,-296,8,4,1,120,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3629,3626,3613,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,929,SUCCESS,,2102.436648,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5464,5/27/2021 1:17,21898.408,6.08,701,300,10,6001,0,65535,65535,1,20.7,25347,-296,-296,8,4,1,119,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3628,3625,3613,3616,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,944,SUCCESS,,2102.107019,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5465,5/27/2021 1:17,21902.414,6.08,701,300,10,6001,0,65535,65535,1,20.7,25344,-296,-296,8,4,1,119,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3628,3626,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,948,SUCCESS,,2101.777637,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5466,5/27/2021 1:17,21906.419,6.09,701,300,10,6001,0,65535,65535,1,20.7,25345,-296,-296,8,4,1,119,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3628,3625,3613,3616,3610,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,944,SUCCESS,,2101.448337,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5467,5/27/2021 1:17,21910.425,6.09,701,300,10,6001,0,65535,65535,1,20.7,25345,-296,-296,8,4,1,118,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3625,3627,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.4,944,SUCCESS,,2101.118955,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5468,5/27/2021 1:18,21914.435,6.09,701,300,10,6001,0,65535,65535,1,20.7,25342,-296,-296,8,4,1,118,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3627,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,967,SUCCESS,,2100.789244,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5469,5/27/2021 1:18,21918.448,6.09,701,300,10,6001,0,65535,65535,1,20.7,25342,-296,-296,8,4,1,118,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,933,SUCCESS,,2100.459286,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5470,5/27/2021 1:18,21922.461,6.09,701,300,10,6001,0,65535,65535,1,20.7,25344,-296,-296,8,4,1,117,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3627,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,971,SUCCESS,,2100.129328,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5471,5/27/2021 1:18,21926.467,6.09,701,300,10,6001,0,65535,65535,1,20.7,25341,-296,-296,8,4,1,117,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,947,SUCCESS,,2099.799946,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5472,5/27/2021 1:18,21930.474,6.09,701,300,10,6001,0,65535,65535,1,20.7,25340,-296,-296,8,4,1,117,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3627,3628,3625,3612,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,971,SUCCESS,,2099.470481,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5473,5/27/2021 1:18,21934.482,6.09,701,300,10,6001,0,65535,65535,1,20.7,25342,-296,-296,8,4,1,116,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,948,SUCCESS,,2099.140935,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5474,5/27/2021 1:18,21938.49,6.09,701,300,10,6001,0,65535,65535,1,20.7,25340,-298,-296,8,4,1,116,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,964,SUCCESS,,2098.809161,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5475,5/27/2021 1:18,21942.493,6.1,701,300,10,6001,0,65535,65535,1,20.7,25339,-296,-296,8,4,1,116,3632,24,24,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,938,SUCCESS,,2098.480026,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5476,5/27/2021 1:18,21946.494,6.1,701,300,10,6001,0,65535,65535,1,20.7,25339,-298,-296,8,4,1,115,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.6,945,SUCCESS,,2098.148832,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5477,5/27/2021 1:18,21950.496,6.1,701,300,10,6001,0,65535,65535,1,20.7,25339,-296,-296,8,4,1,115,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3624,3626,3628,3625,3612,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,959,SUCCESS,,2097.819779,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5478,5/27/2021 1:18,21954.503,6.1,701,300,10,6001,0,65535,65535,1,20.7,25337,-296,-296,8,4,1,115,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3628,3624,3612,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,940,SUCCESS,,2097.490314,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5479,5/27/2021 1:18,21958.509,6.1,701,300,10,6001,0,65535,65535,1,20.7,25336,-296,-296,8,4,1,114,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3628,3624,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,964,SUCCESS,,2097.160932,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5480,5/27/2021 1:18,21962.519,6.1,701,300,10,6001,0,65535,65535,1,20.7,25337,-296,-296,8,4,1,114,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3612,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,967,SUCCESS,,2096.831221,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5481,5/27/2021 1:18,21966.528,6.1,701,300,10,6001,0,65535,65535,1,20.7,25336,-296,-296,8,4,1,114,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3612,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,942,SUCCESS,,2096.501592,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5482,5/27/2021 1:18,21970.531,6.1,701,300,10,6001,0,65535,65535,1,20.7,25337,-298,-296,8,4,1,113,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3612,3616,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,942,SUCCESS,,2096.170233,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5483,5/27/2021 1:19,21974.533,6.1,701,300,10,6001,0,65535,65535,1,20.7,25336,-296,-296,8,4,1,113,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3611,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,973,SUCCESS,,2095.841179,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5484,5/27/2021 1:19,21978.545,6.11,701,300,10,6001,0,65535,65535,1,20.7,25335,-298,-296,8,4,1,113,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3611,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,940,SUCCESS,,2095.509075,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5485,5/27/2021 1:19,21982.548,6.11,701,300,10,6001,0,65535,65535,1,20.7,25335,-296,-296,8,4,1,112,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3611,3617,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,955,SUCCESS,,2095.179939,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5486,5/27/2021 1:19,21986.551,6.11,701,300,10,6001,0,65535,65535,1,20.7,25334,-294,-296,8,4,1,112,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3626,3627,3624,3611,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,934,SUCCESS,,2094.853028,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5487,5/27/2021 1:19,21990.555,6.11,701,300,10,6001,0,65535,65535,1,20.7,25334,-298,-296,8,4,1,112,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3624,3611,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,946,SUCCESS,,2094.521585,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5488,5/27/2021 1:19,21994.559,6.11,701,300,10,6001,0,65535,65535,1,20.7,25334,-294,-296,8,4,1,111,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3624,3611,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,944,SUCCESS,,2094.194592,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5489,5/27/2021 1:19,21998.564,6.11,701,300,10,6001,0,65535,65535,1,20.7,25333,-296,-296,8,4,1,111,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3624,3611,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.2,957,SUCCESS,,2093.865292,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5490,5/27/2021 1:19,22002.573,6.11,701,300,10,6001,0,65535,65535,1,20.7,25331,-298,-296,8,4,1,111,3632,23,23,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3623,3610,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,946,SUCCESS,,2093.533436,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5491,5/27/2021 1:19,22006.583,6.11,701,300,10,6001,0,65535,65535,1,20.7,25332,-296,-296,8,4,1,110,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3623,3611,3617,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,998,SUCCESS,,2093.203725,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5492,5/27/2021 1:19,22010.595,6.11,701,300,10,6001,0,65535,65535,1,20.7,25332,-298,-296,8,4,1,110,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3624,3611,3615,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,954,SUCCESS,,2092.87162,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5493,5/27/2021 1:19,22014.605,6.12,701,300,10,6001,0,65535,65535,1,20.7,25330,-296,-296,8,4,1,110,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3626,3623,3611,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,946,SUCCESS,,2092.541909,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5494,5/27/2021 1:19,22018.613,6.12,701,300,10,6001,0,65535,65535,1,20.7,25333,-296,-297,8,4,1,109,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3627,3623,3611,3617,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,982,SUCCESS,,2092.212363,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5495,5/27/2021 1:19,22022.624,6.12,701,300,10,6001,0,65535,65535,1,20.7,25329,-298,-297,8,4,1,109,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3623,3625,3626,3623,3611,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,990,SUCCESS,,2091.880341,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5496,5/27/2021 1:19,22026.63,6.12,701,300,10,6001,0,65535,65535,1,20.7,25328,-296,-297,8,4,1,109,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3625,3626,3623,3611,3614,3609,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,952,SUCCESS,,2091.550959,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5497,5/27/2021 1:19,22030.642,6.12,701,300,10,6001,0,65535,65535,1,20.7,25330,-300,-297,8,3,1,108,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3625,3626,3623,3611,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,985,SUCCESS,,2091.216625,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5498,5/27/2021 1:20,22034.651,6.12,701,300,10,6001,0,65535,65535,1,20.7,25329,-298,-297,8,3,1,108,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3625,3626,3623,3611,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.6,932,SUCCESS,,2090.884769,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5499,5/27/2021 1:20,22038.661,6.12,701,300,10,6001,0,65535,65535,1,20.7,25328,-298,-297,8,3,1,108,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3625,3626,3623,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,969,SUCCESS,,2090.55283,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5500,5/27/2021 1:20,22042.676,6.12,701,300,10,6001,0,65535,65535,1,20.7,25328,-298,-297,8,3,1,107,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3623,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,936,SUCCESS,,2090.220478,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5501,5/27/2021 1:20,22046.68,6.12,701,300,10,6001,0,65535,65535,1,20.7,25328,-296,-297,8,3,1,107,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3623,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,939,SUCCESS,,2089.89126,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5502,5/27/2021 1:20,22050.689,6.13,701,300,10,6001,0,65535,65535,1,20.7,25327,-296,-296,8,3,1,107,3632,22,22,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3623,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.3,958,SUCCESS,,2089.561631,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5503,5/27/2021 1:20,22054.689,6.13,701,300,10,6001,0,65535,65535,1,20.7,25327,-298,-296,8,3,1,106,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3623,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,955,SUCCESS,,2089.23052,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5504,5/27/2021 1:20,22058.694,6.13,701,300,10,6001,0,65535,65535,1,20.7,25326,-296,-296,8,3,1,106,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3623,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,966,SUCCESS,,2088.90122,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5505,5/27/2021 1:20,22062.702,6.13,701,300,10,6001,0,65535,65535,1,20.7,25327,-298,-296,8,3,1,106,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3622,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,959,SUCCESS,,2088.569446,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5506,5/27/2021 1:20,22066.71,6.13,701,300,10,6001,0,65535,65535,1,20.7,25326,-298,-297,8,3,1,105,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3622,3610,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,952,SUCCESS,,2088.237673,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5507,5/27/2021 1:20,22070.712,6.13,701,300,10,6001,0,65535,65535,1,20.7,25325,-294,-296,8,3,1,105,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3622,3610,3613,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,963,SUCCESS,,2087.910843,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5508,5/27/2021 1:20,22074.725,6.13,701,300,10,6001,0,65535,65535,1,20.7,25326,-296,-297,8,3,1,105,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3623,3609,3614,3608,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,951,SUCCESS,,2087.580885,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5509,5/27/2021 1:20,22078.731,6.13,701,300,10,6001,0,65535,65535,1,20.7,25323,-296,-297,8,3,1,104,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3622,3609,3614,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,944,SUCCESS,,2087.251503,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5510,5/27/2021 1:20,22082.746,6.13,701,300,10,6001,0,65535,65535,1,20.7,25324,-296,-296,8,3,1,104,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3622,3609,3613,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,945,SUCCESS,,2086.921381,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5511,5/27/2021 1:20,22086.753,6.14,701,300,10,6001,0,65535,65535,1,20.7,25323,-298,-297,8,3,1,104,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3626,3622,3609,3614,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,941,SUCCESS,,2086.58969,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5512,5/27/2021 1:20,22090.766,6.14,701,300,10,6001,0,65535,65535,1,20.7,25322,-296,-297,8,3,1,103,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3625,3622,3609,3613,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,940,SUCCESS,,2086.259733,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5513,5/27/2021 1:21,22094.771,6.14,701,300,10,6001,0,65535,65535,1,20.7,25321,-298,-297,8,3,1,103,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3625,3622,3609,3612,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,990,SUCCESS,,2085.928208,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5514,5/27/2021 1:21,22098.785,6.14,701,300,10,6001,0,65535,65535,1,20.7,25322,-296,-297,8,3,1,103,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3613,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.7,970,SUCCESS,,2085.598168,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5515,5/27/2021 1:21,22102.787,6.14,701,300,10,6001,0,65535,65535,1,20.7,25322,-294,-297,8,3,1,102,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3622,3624,3625,3622,3609,3613,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,936,SUCCESS,,2085.271338,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5516,5/27/2021 1:21,22106.796,6.14,701,300,10,6001,0,65535,65535,1,20.7,25319,-298,-297,8,3,1,102,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3612,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,958,SUCCESS,,2084.939481,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5517,5/27/2021 1:21,22110.799,6.14,701,300,10,6001,0,65535,65535,1,20.7,25320,-296,-297,8,3,1,102,3632,21,21,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3613,3607,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,992,SUCCESS,,2084.610346,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5518,5/27/2021 1:21,22114.806,6.14,701,300,10,6001,0,65535,65535,1,20.7,25321,-294,-296,8,3,1,101,3632,21,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3613,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,949,SUCCESS,,2084.283108,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5519,5/27/2021 1:21,22118.82,6.14,701,300,10,6001,0,65535,65535,1,20.7,25319,-298,-296,8,3,1,101,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,991,SUCCESS,,2083.950838,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5520,5/27/2021 1:21,22122.834,6.15,701,300,10,6001,0,65535,65535,1,20.7,25319,-296,-296,8,3,1,101,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3613,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,966,SUCCESS,,2083.620798,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5521,5/27/2021 1:21,22126.844,6.15,701,300,10,6001,0,65535,65535,1,20.7,25320,-296,-296,8,3,1,100,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3613,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,949,SUCCESS,,2083.291086,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5522,5/27/2021 1:21,22130.855,6.15,701,300,10,6001,0,65535,65535,1,20.7,25319,-296,-296,8,3,1,100,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.9,946,SUCCESS,,2082.961293,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5523,5/27/2021 1:21,22134.866,6.15,701,300,10,6001,0,65535,65535,1,20.6,25318,-296,-296,8,3,1,100,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3621,3624,3625,3622,3609,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.9,951,SUCCESS,,2082.6315,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5524,5/27/2021 1:21,22138.867,6.15,701,300,10,6001,0,65535,65535,1,20.7,25319,-298,-296,8,3,1,99,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3625,3622,3609,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,990,SUCCESS,,2082.300306,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5525,5/27/2021 1:21,22142.873,6.15,701,300,10,6001,0,65535,65535,1,20.7,25317,-298,-297,8,3,1,99,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3625,3622,3609,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,942,SUCCESS,,2081.968698,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5526,5/27/2021 1:21,22146.882,6.15,701,300,10,6001,0,65535,65535,1,20.7,25316,-298,-296,8,3,1,99,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3625,3622,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,965,SUCCESS,,2081.636842,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5527,5/27/2021 1:21,22150.89,6.15,701,300,10,6001,0,65535,65535,1,20.7,25316,-298,-297,8,3,1,98,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3625,3622,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,943,SUCCESS,,2081.305069,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5528,5/27/2021 1:22,22154.894,6.15,701,300,10,6001,0,65535,65535,1,20.7,25317,-296,-297,8,3,1,98,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3625,3621,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,937,SUCCESS,,2080.975851,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5529,5/27/2021 1:22,22158.9,6.16,701,300,10,6001,0,65535,65535,1,20.7,25316,-298,-297,8,3,1,98,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3624,3621,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,931,SUCCESS,,2080.644243,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5530,5/27/2021 1:22,22162.91,6.16,701,300,10,6001,0,65535,65535,1,20.7,25316,-298,-297,8,3,1,97,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3624,3621,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,969,SUCCESS,,2080.312304,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5531,5/27/2021 1:22,22166.915,6.16,701,300,10,6001,0,65535,65535,1,20.7,25316,-294,-297,8,3,1,97,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3624,3624,3622,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.7,952,SUCCESS,,2079.985229,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5532,5/27/2021 1:22,22170.93,6.16,701,300,10,6001,0,65535,65535,1,20.7,25314,-298,-297,8,3,1,97,3632,20,20,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3624,3621,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,940,SUCCESS,,2079.652876,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5533,5/27/2021 1:22,22174.931,6.16,701,300,10,6001,0,65535,65535,1,20.7,25314,-296,-297,8,3,1,96,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3624,3621,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.3,959,SUCCESS,,2079.323905,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5534,5/27/2021 1:22,22178.947,6.16,701,300,10,6001,0,65535,65535,1,20.7,25313,-294,-296,8,3,1,96,3632,20,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3624,3621,3608,3611,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,933,SUCCESS,,2078.995932,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5535,5/27/2021 1:22,22182.953,6.16,701,300,10,6001,0,65535,65535,1,20.7,25313,-298,-297,8,3,1,96,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3624,3621,3608,3612,3606,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,958,SUCCESS,,2078.664324,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5536,5/27/2021 1:22,22186.964,6.16,701,300,10,6001,0,65535,65535,1,20.6,25312,-298,-297,8,3,1,95,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3624,3621,3608,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.9,953,SUCCESS,,2078.332303,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5537,5/27/2021 1:22,22190.97,6.16,701,300,10,6001,0,65535,65535,1,20.6,25312,-296,-296,8,3,1,95,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3620,3623,3624,3621,3608,3611,3606,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,941,SUCCESS,,2078.00292,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5538,5/27/2021 1:22,22194.985,6.17,701,300,10,6001,0,65535,65535,1,20.7,25310,-296,-297,8,3,1,95,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3623,3623,3621,3608,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.8,941,SUCCESS,,2077.672798,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5539,5/27/2021 1:22,22198.988,6.17,701,300,10,6001,0,65535,65535,1,20.6,25310,-296,-296,8,3,1,94,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3623,3624,3621,3608,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,952,SUCCESS,,2077.343663,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5540,5/27/2021 1:22,22202.997,6.17,701,300,10,6001,0,65535,65535,1,20.6,25310,-296,-296,8,3,1,94,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3621,3608,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,967,SUCCESS,,2077.014034,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5541,5/27/2021 1:22,22207.001,6.17,701,300,10,6001,0,65535,65535,1,20.7,25310,-298,-297,8,3,1,94,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3623,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.7,-273.2,20.7,-273.2,20.9,946,SUCCESS,,2076.682591,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5542,5/27/2021 1:22,22211.011,6.17,701,300,10,6001,0,65535,65535,1,20.6,25303,-296,-296,8,3,1,93,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3621,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,979,SUCCESS,,2076.35288,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5543,5/27/2021 1:23,22215.021,6.17,701,300,10,6001,0,65535,65535,1,20.6,25307,-296,-296,8,3,1,93,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.9,951,SUCCESS,,2076.023169,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5544,5/27/2021 1:23,22219.036,6.17,701,300,10,6001,0,65535,65535,1,20.6,25307,-296,-297,8,3,1,93,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,953,SUCCESS,,2075.693047,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5545,5/27/2021 1:23,22223.039,6.17,701,300,10,6001,0,65535,65535,1,20.6,25305,-296,-296,8,3,1,92,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,965,SUCCESS,,2075.363911,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5546,5/27/2021 1:23,22227.055,6.17,701,300,10,6001,0,65535,65535,1,20.6,25307,-296,-297,8,3,1,92,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.7,950,SUCCESS,,2075.033707,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5547,5/27/2021 1:23,22231.058,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-296,-297,8,3,1,92,3632,19,19,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2530,20.5,20.6,-273.2,20.6,-273.2,20.9,961,SUCCESS,,2074.704571,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5548,5/27/2021 1:23,22235.069,6.18,701,300,10,6001,0,65535,65535,1,20.6,25308,-298,-297,8,3,1,91,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,968,SUCCESS,,2074.37255,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5549,5/27/2021 1:23,22239.076,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-296,-297,8,3,1,91,3632,19,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,986,SUCCESS,,2074.043085,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5550,5/27/2021 1:23,22243.083,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-294,-297,8,3,1,91,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2531,20.5,20.6,-273.2,20.6,-273.2,20.8,937,SUCCESS,,2073.715847,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5551,5/27/2021 1:23,22247.091,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-298,-296,8,3,1,90,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2528,20.5,20.6,-273.2,20.6,-273.2,20.9,951,SUCCESS,,2073.384074,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5552,5/27/2021 1:23,22251.1,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-296,-296,8,3,1,90,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,983,SUCCESS,,2073.054445,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5553,5/27/2021 1:23,22255.115,6.18,701,300,10,6001,0,65535,65535,1,20.6,25306,-296,-296,8,3,1,90,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2528,20.5,20.6,-273.2,20.6,-273.2,20.9,959,SUCCESS,,2072.724323,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5554,5/27/2021 1:23,22259.118,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-298,-297,8,3,1,89,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2528,20.5,20.6,-273.2,20.6,-273.2,20.8,938,SUCCESS,,2072.392963,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5555,5/27/2021 1:23,22263.119,6.18,701,300,10,6001,0,65535,65535,1,20.6,25307,-294,-297,8,3,1,89,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2528,20.5,20.6,-273.2,20.6,-273.2,20.9,938,SUCCESS,,2072.066215,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5556,5/27/2021 1:23,22267.127,6.19,701,300,10,6001,0,65535,65535,1,20.6,25306,-296,-297,8,3,1,89,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,947,SUCCESS,,2071.736668,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5557,5/27/2021 1:23,22271.136,6.19,701,300,10,6001,0,65535,65535,1,20.6,25306,-296,-297,8,3,1,88,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3620,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,967,SUCCESS,,2071.407039,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5558,5/27/2021 1:24,22275.144,6.19,701,300,10,6001,0,65535,65535,1,20.6,25307,-294,-296,8,3,1,88,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3622,3623,3620,3607,3611,3605,0,0,0,0,0,0,0,0,2530,20.5,20.6,-273.2,20.6,-273.2,20.8,971,SUCCESS,,2071.079719,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5559,5/27/2021 1:24,22279.151,6.19,701,300,10,6001,0,65535,65535,1,20.6,25305,-296,-296,8,3,1,88,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.2,959,SUCCESS,,2070.750255,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5560,5/27/2021 1:24,22283.166,6.19,701,300,10,6001,0,65535,65535,1,20.6,25304,-296,-296,8,3,1,87,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,933,SUCCESS,,2070.420133,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5561,5/27/2021 1:24,22287.173,6.19,701,300,10,6001,0,65535,65535,1,20.6,25304,-298,-296,8,3,1,87,3632,18,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3605,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,949,SUCCESS,,2070.088442,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5562,5/27/2021 1:24,22291.188,6.19,701,300,10,6001,0,65535,65535,1,20.6,25304,-300,-297,8,3,1,87,3632,17,18,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,990,SUCCESS,,2069.753859,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5563,5/27/2021 1:24,22295.201,6.19,701,300,10,6001,0,65535,65535,1,20.6,25304,-296,-297,8,3,1,86,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,961,SUCCESS,,2069.423901,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5564,5/27/2021 1:24,22299.206,6.19,701,300,10,6001,0,65535,65535,1,20.6,25304,-298,-297,8,3,1,86,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,977,SUCCESS,,2069.092376,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5565,5/27/2021 1:24,22303.213,6.2,701,300,10,6001,0,65535,65535,1,20.6,25304,-298,-297,8,3,1,86,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3623,3619,3607,3610,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,933,SUCCESS,,2068.760685,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5566,5/27/2021 1:24,22307.225,6.2,701,300,10,6001,0,65535,65535,1,20.6,25303,-296,-297,8,3,1,85,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3621,3623,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,959,SUCCESS,,2068.43081,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5567,5/27/2021 1:24,22311.238,6.2,701,300,10,6001,0,65535,65535,1,20.6,25302,-296,-297,8,3,1,85,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,938,SUCCESS,,2068.100852,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5568,5/27/2021 1:24,22315.247,6.2,701,300,10,6001,0,65535,65535,1,20.6,25301,-296,-296,8,3,1,85,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3623,3619,3606,3610,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.9,945,SUCCESS,,2067.771223,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5569,5/27/2021 1:24,22319.262,6.2,701,300,10,6001,0,65535,65535,1,20.6,25302,-294,-296,8,3,1,84,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3623,3619,3607,3613,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,951,SUCCESS,,2067.443331,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5570,5/27/2021 1:24,22323.272,6.2,701,300,10,6001,0,65535,65535,1,20.6,25301,-298,-296,8,3,1,84,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3619,3607,3611,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,958,SUCCESS,,2067.111393,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5571,5/27/2021 1:24,22327.287,6.2,701,300,10,6001,0,65535,65535,1,20.6,25301,-296,-296,8,3,1,84,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3619,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.7,967,SUCCESS,,2066.78127,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5572,5/27/2021 1:24,22331.292,6.2,701,300,10,6001,0,65535,65535,1,20.6,25300,-296,-296,8,3,1,83,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3619,3607,3614,3604,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,947,SUCCESS,,2066.45197,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5573,5/27/2021 1:25,22335.295,6.2,701,300,10,6001,0,65535,65535,1,20.6,25301,-296,-296,8,3,1,83,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3619,3607,3611,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,949,SUCCESS,,2066.122835,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5574,5/27/2021 1:25,22339.303,6.21,701,300,10,6001,0,65535,65535,1,20.6,25300,-294,-296,8,3,1,83,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3618,3607,3611,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,952,SUCCESS,,2065.795515,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5575,5/27/2021 1:25,22343.303,6.21,701,300,10,6001,0,65535,65535,1,20.6,25300,-296,-296,8,3,1,82,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3618,3607,3611,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,960,SUCCESS,,2065.466626,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5576,5/27/2021 1:25,22347.307,6.21,701,300,10,6001,0,65535,65535,1,20.6,25300,-298,-296,8,3,1,82,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3622,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,931,SUCCESS,,2065.135184,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5577,5/27/2021 1:25,22351.307,6.21,701,300,10,6001,0,65535,65535,1,20.6,25298,-296,-296,8,3,1,82,3632,17,17,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,946,SUCCESS,,2064.806295,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5578,5/27/2021 1:25,22355.316,6.21,701,300,10,6001,0,65535,65535,1,20.6,25298,-296,-296,8,3,1,81,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3622,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,955,SUCCESS,,2064.476666,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5579,5/27/2021 1:25,22359.319,6.21,701,300,10,6001,0,65535,65535,1,20.6,25299,-296,-296,8,3,1,81,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3622,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,974,SUCCESS,,2064.14753,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5580,5/27/2021 1:25,22363.321,6.21,701,300,10,6001,0,65535,65535,1,20.6,25298,-294,-296,8,3,1,81,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3619,3620,3622,3618,3607,3609,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,983,SUCCESS,,2063.8207,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5581,5/27/2021 1:25,22367.325,6.21,701,300,10,6001,0,65535,65535,1,20.6,25298,-296,-296,8,3,1,80,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3622,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,950,SUCCESS,,2063.491483,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5582,5/27/2021 1:25,22371.334,6.21,701,300,10,6001,0,65535,65535,1,20.6,25298,-296,-296,8,3,1,80,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3621,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,987,SUCCESS,,2063.161854,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5583,5/27/2021 1:25,22375.349,6.22,701,300,10,6001,0,65535,65535,1,20.6,25298,-298,-296,8,3,1,80,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3621,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,984,SUCCESS,,2062.829501,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5584,5/27/2021 1:25,22379.351,6.22,701,300,10,6001,0,65535,65535,1,20.6,25296,-296,-296,8,3,1,79,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3620,3621,3618,3607,3610,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,958,SUCCESS,,2062.500448,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5585,5/27/2021 1:25,22383.365,6.22,701,300,10,6001,0,65535,65535,1,20.6,25295,-298,-296,8,3,1,79,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3620,3621,3617,3607,3610,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,967,SUCCESS,,2062.168178,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5586,5/27/2021 1:25,22387.37,6.22,701,300,10,6001,0,65535,65535,1,20.6,25296,-296,-296,8,3,1,79,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3618,3620,3621,3618,3607,3610,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,965,SUCCESS,,2061.838878,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5587,5/27/2021 1:25,22391.384,6.22,701,300,10,6001,0,65535,65535,1,20.6,25294,-296,-296,8,3,1,78,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3620,3621,3617,3607,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,935,SUCCESS,,2061.508838,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5588,5/27/2021 1:26,22395.39,6.22,701,300,10,6001,0,65535,65535,1,20.6,25292,-296,-296,8,3,1,78,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3620,3621,3617,3607,3609,3603,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.9,945,SUCCESS,,2061.179455,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5589,5/27/2021 1:26,22399.391,6.22,701,300,10,6001,0,65535,65535,1,20.6,25293,-294,-296,8,3,1,78,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3621,3617,3607,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,940,SUCCESS,,2060.852707,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5590,5/27/2021 1:26,22403.398,6.22,701,300,10,6001,0,65535,65535,1,20.6,25294,-296,-296,8,3,1,77,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3621,3617,3607,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,967,SUCCESS,,2060.523243,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5591,5/27/2021 1:26,22407.413,6.22,701,300,10,6001,0,65535,65535,1,20.6,25291,-298,-296,8,3,1,77,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3621,3617,3607,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,934,SUCCESS,,2060.19089,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5592,5/27/2021 1:26,22411.428,6.23,701,300,10,6001,0,65535,65535,1,20.6,25291,-296,-296,8,3,1,77,3632,16,16,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3620,3617,3607,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,943,SUCCESS,,2059.860768,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5593,5/27/2021 1:26,22415.443,6.23,701,300,10,6001,0,65535,65535,1,20.6,25290,-298,-296,8,3,1,76,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3620,3620,3617,3607,3608,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,969,SUCCESS,,2059.528415,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5594,5/27/2021 1:26,22419.445,6.23,701,300,10,6001,0,65535,65535,1,20.6,25292,-298,-296,8,3,1,76,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3620,3617,3606,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,950,SUCCESS,,2059.197138,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5595,5/27/2021 1:26,22423.46,6.23,701,300,10,6001,0,65535,65535,1,20.6,25291,-296,-296,8,3,1,76,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3620,3617,3607,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.5,982,SUCCESS,,2058.867016,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5596,5/27/2021 1:26,22427.47,6.23,701,300,10,6001,0,65535,65535,1,20.6,25290,-296,-296,8,3,1,75,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3620,3617,3606,3608,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,956,SUCCESS,,2058.537305,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5597,5/27/2021 1:26,22431.473,6.23,701,300,10,6001,0,65535,65535,1,20.6,25290,-296,-296,8,3,1,75,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3620,3617,3606,3609,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,1002,SUCCESS,,2058.208169,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5598,5/27/2021 1:26,22435.478,6.23,701,300,10,6001,0,65535,65535,1,20.6,25290,-298,-296,8,3,1,75,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3606,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.7,932,SUCCESS,,2057.876644,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5599,5/27/2021 1:26,22439.487,6.23,701,300,10,6001,0,65535,65535,1,20.6,25289,-298,-296,8,3,1,74,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3617,3619,3620,3617,3606,3608,3602,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,943,SUCCESS,,2057.544788,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5600,5/27/2021 1:26,22443.491,6.23,701,300,10,6001,0,65535,65535,1,20.6,25287,-296,-296,8,3,1,74,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3606,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,958,SUCCESS,,2057.21557,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5601,5/27/2021 1:26,22447.504,6.24,701,300,10,6001,0,65535,65535,1,20.6,25287,-294,-296,8,3,1,74,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3606,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,999,SUCCESS,,2056.887842,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5602,5/27/2021 1:26,22451.506,6.24,701,300,10,6001,0,65535,65535,1,20.6,25287,-298,-296,8,3,1,73,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.6,949,SUCCESS,,2056.556565,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5603,5/27/2021 1:27,22455.52,6.24,701,300,10,6001,0,65535,65535,1,20.6,25286,-294,-296,8,3,1,73,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3606,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,937,SUCCESS,,2056.228755,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5604,5/27/2021 1:27,22459.525,6.24,701,300,10,6001,0,65535,65535,1,20.6,25286,-294,-296,8,3,1,73,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3618,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.2,950,SUCCESS,,2055.90168,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5605,5/27/2021 1:27,22463.54,6.24,701,300,10,6001,0,65535,65535,1,20.6,25286,-298,-296,8,2,1,72,3632,14,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.9,940,SUCCESS,,2055.569328,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5606,5/27/2021 1:27,22467.543,6.24,701,300,10,6001,0,65535,65535,1,20.6,25285,-296,-296,8,2,1,72,3632,14,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,965,SUCCESS,,2055.240192,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5607,5/27/2021 1:27,22471.548,6.24,701,300,10,6001,0,65535,65535,1,20.6,25285,-298,-296,8,2,1,72,3632,15,15,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,953,SUCCESS,,2054.908667,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5608,5/27/2021 1:27,22475.56,6.24,701,300,10,6001,0,65535,65535,1,20.6,25286,-296,-296,8,2,1,71,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3619,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,943,SUCCESS,,2054.578791,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5609,5/27/2021 1:27,22479.571,6.24,701,300,10,6001,0,65535,65535,1,20.6,25284,-296,-296,8,2,1,71,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3618,3620,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,932,SUCCESS,,2054.248998,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5610,5/27/2021 1:27,22483.571,6.25,701,300,10,6001,0,65535,65535,1,20.6,25284,-296,-296,8,2,1,71,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3616,3618,3619,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,983,SUCCESS,,2053.920109,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5611,5/27/2021 1:27,22487.581,6.25,701,300,10,6001,0,65535,65535,1,20.6,25283,-296,-296,8,2,1,70,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.7,950,SUCCESS,,2053.590398,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5612,5/27/2021 1:27,22491.583,6.25,701,300,10,6001,0,65535,65535,1,20.6,25282,-296,-296,8,2,1,70,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3620,3617,3604,3607,3601,0,0,0,0,0,0,0,0,2527,20.5,20.6,-273.2,20.6,-273.2,20.8,936,SUCCESS,,2053.261345,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5613,5/27/2021 1:27,22495.586,6.25,701,300,10,6001,0,65535,65535,1,20.6,25283,-296,-296,8,2,1,70,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3605,3608,3601,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.3,968,SUCCESS,,2052.932209,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5614,5/27/2021 1:27,22499.598,6.25,701,300,10,6001,0,65535,65535,1,20.6,25282,-296,-296,8,2,1,70,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3604,3607,3601,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,943,SUCCESS,,2052.602334,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5615,5/27/2021 1:27,22503.611,6.25,701,300,10,6001,0,65535,65535,1,20.5,25281,-298,-296,8,2,1,69,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3604,3607,3601,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,968,SUCCESS,,2052.270146,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5616,5/27/2021 1:27,22507.626,6.25,701,300,10,6001,0,65535,65535,1,20.5,25281,-298,-296,8,2,1,69,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3604,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,938,SUCCESS,,2051.937794,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5617,5/27/2021 1:27,22511.641,6.25,701,300,10,6001,0,65535,65535,1,20.6,25280,-294,-296,8,2,1,69,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3604,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.7,957,SUCCESS,,2051.609902,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5618,5/27/2021 1:28,22515.656,6.25,701,300,10,6001,0,65535,65535,1,20.6,25278,-298,-296,8,2,1,68,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3604,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,958,SUCCESS,,2051.277549,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5619,5/27/2021 1:28,22519.673,6.26,701,300,10,6001,0,65535,65535,1,20.6,25279,-294,-296,8,2,1,68,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3604,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,954,SUCCESS,,2050.949494,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5620,5/27/2021 1:28,22523.674,6.26,701,300,10,6001,0,65535,65535,1,20.6,25279,-294,-296,8,2,1,68,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3604,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,960,SUCCESS,,2050.622746,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5621,5/27/2021 1:28,22527.688,6.26,701,300,10,6001,0,65535,65535,1,20.6,25278,-296,-296,8,2,1,67,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3618,3619,3617,3604,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,967,SUCCESS,,2050.292706,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5622,5/27/2021 1:28,22531.72,6.26,701,300,10,6001,0,65535,65535,1,20.6,25278,-296,-296,8,2,1,67,3632,14,14,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3603,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,937,SUCCESS,,2049.961186,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5623,5/27/2021 1:28,22535.719,6.26,701,300,10,6001,0,65535,65535,1,20.5,25277,-296,-296,8,2,1,66,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,940,SUCCESS,,2049.632379,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5624,5/27/2021 1:28,22539.735,6.26,701,300,10,6001,0,65535,65535,1,20.6,25278,-296,-296,8,2,1,66,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3604,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,980,SUCCESS,,2049.302175,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5625,5/27/2021 1:28,22543.751,6.26,701,300,10,6001,0,65535,65535,1,20.6,25278,-294,-296,8,2,1,66,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3617,3619,3617,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,985,SUCCESS,,2048.974201,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5626,5/27/2021 1:28,22547.696,6.26,701,300,10,6001,0,65535,65535,1,20.6,25277,-296,-296,8,2,1,65,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3603,3607,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.5,980,SUCCESS,,2048.649835,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5627,5/27/2021 1:28,22551.782,6.26,701,300,10,6001,0,65535,65535,1,20.6,25277,-296,-296,8,2,1,65,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,959,SUCCESS,,2048.313875,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5628,5/27/2021 1:28,22555.71,6.27,701,300,10,6001,0,65535,65535,1,20.6,25279,-296,-296,8,2,1,65,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.7,970,SUCCESS,,2047.990906,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5629,5/27/2021 1:28,22559.719,6.27,701,300,10,6001,0,65535,65535,1,20.5,25275,-296,-296,8,2,1,64,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3617,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,939,SUCCESS,,2047.661277,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5630,5/27/2021 1:28,22563.733,6.27,701,300,10,6001,0,65535,65535,1,20.5,25274,-296,-296,8,2,1,64,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3617,3619,3616,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,948,SUCCESS,,2047.331237,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5631,5/27/2021 1:28,22567.734,6.27,701,300,10,6001,0,65535,65535,1,20.5,25277,-296,-296,8,2,1,64,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3617,3618,3617,3603,3606,3600,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,944,SUCCESS,,2047.002266,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5632,5/27/2021 1:28,22571.746,6.27,701,300,10,6001,0,65535,65535,1,20.5,25275,-296,-296,8,2,1,64,3632,13,13,65535,3000,28875,0AC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3617,3619,3616,3603,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,944,SUCCESS,,2046.67239,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5633,5/27/2021 1:29,22575.748,6.27,701,300,10,6001,0,65535,65535,1,20.5,25275,-294,-296,8,2,1,63,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3617,3619,3616,3603,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,963,SUCCESS,,2046.34556,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5634,5/27/2021 1:29,22579.748,6.27,701,300,10,6001,0,65535,65535,1,20.6,25278,-296,-296,8,2,1,63,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3615,3617,3619,3616,3603,3607,3599,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,942,SUCCESS,,2046.016671,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5635,5/27/2021 1:29,22583.751,6.27,701,300,10,6001,0,65535,65535,1,20.5,25274,-296,-296,8,2,1,63,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3617,3619,3615,3603,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.4,938,SUCCESS,,2045.687536,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5636,5/27/2021 1:29,22587.764,6.27,701,300,10,6001,0,65535,65535,1,20.5,25272,-296,-296,8,2,1,62,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3603,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,943,SUCCESS,,2045.357578,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5637,5/27/2021 1:29,22591.772,6.28,701,300,10,6001,0,65535,65535,1,20.6,25271,-296,-296,8,2,1,62,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3616,3602,3607,3599,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,932,SUCCESS,,2045.028031,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5638,5/27/2021 1:29,22595.777,6.28,701,300,10,6001,0,65535,65535,1,20.6,25270,-296,-296,8,2,1,62,3632,13,13,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3602,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.6,-273.2,20.6,-273.2,20.8,976,SUCCESS,,2044.698731,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5639,5/27/2021 1:29,22599.783,6.28,701,300,10,6001,0,65535,65535,1,20.5,25270,-296,-296,8,2,1,61,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3602,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,955,SUCCESS,,2044.369349,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5640,5/27/2021 1:29,22603.796,6.28,701,300,10,6001,0,65535,65535,1,20.5,25270,-296,-296,8,2,1,61,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3602,3607,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,974,SUCCESS,,2044.039391,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5641,5/27/2021 1:29,22607.804,6.28,701,300,10,6001,0,65535,65535,1,20.5,25270,-296,-296,8,2,1,61,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3602,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,968,SUCCESS,,2043.709845,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5642,5/27/2021 1:29,22611.819,6.28,701,300,10,6001,0,65535,65535,1,20.5,25269,-298,-296,8,2,1,60,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3602,3604,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,954,SUCCESS,,2043.377492,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5643,5/27/2021 1:29,22615.833,6.28,701,300,10,6001,0,65535,65535,1,20.5,25270,-296,-296,8,2,1,60,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3618,3615,3602,3606,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,958,SUCCESS,,2043.047452,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5644,5/27/2021 1:29,22619.834,6.28,701,300,10,6001,0,65535,65535,1,20.5,25269,-294,-296,8,2,1,60,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3617,3615,3602,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,955,SUCCESS,,2042.720704,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5645,5/27/2021 1:29,22623.848,6.28,701,300,10,6001,0,65535,65535,1,20.5,25267,-296,-296,8,2,1,59,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3615,3617,3615,3602,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,988,SUCCESS,,2042.390664,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5646,5/27/2021 1:29,22627.858,6.29,701,300,10,6001,0,65535,65535,1,20.5,25268,-296,-296,8,2,1,59,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3617,3614,3602,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,942,SUCCESS,,2042.060953,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5647,5/27/2021 1:29,22631.863,6.29,701,300,10,6001,0,65535,65535,1,20.5,25266,-296,-296,8,2,1,59,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3615,3602,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,970,SUCCESS,,2041.731653,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5648,5/27/2021 1:30,22635.869,6.29,701,300,10,6001,0,65535,65535,1,20.5,25266,-296,-296,8,2,1,58,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3614,3616,3617,3614,3601,3602,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.7,977,SUCCESS,,2041.40227,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5649,5/27/2021 1:30,22639.871,6.29,701,300,10,6001,0,65535,65535,1,20.5,25264,-296,-296,8,2,1,58,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,967,SUCCESS,,2041.073217,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5650,5/27/2021 1:30,22643.881,6.29,701,300,10,6001,0,65535,65535,1,20.5,25265,-296,-296,8,2,1,58,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3602,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,969,SUCCESS,,2040.743506,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5651,5/27/2021 1:30,22647.896,6.29,701,300,10,6001,0,65535,65535,1,20.5,25264,-296,-296,8,2,1,57,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,951,SUCCESS,,2040.413384,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5652,5/27/2021 1:30,22651.902,6.29,701,300,10,6001,0,65535,65535,1,20.5,25264,-294,-296,8,2,1,57,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,949,SUCCESS,,2040.086227,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5653,5/27/2021 1:30,22655.91,6.29,701,300,10,6001,0,65535,65535,1,20.5,25264,-296,-296,8,2,1,57,3632,12,12,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2527,20.4,20.5,-273.2,20.5,-273.2,20.8,950,SUCCESS,,2039.75668,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5654,5/27/2021 1:30,22659.922,6.29,701,300,10,6001,0,65535,65535,1,20.5,25264,-296,-296,8,2,1,56,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3602,3602,3599,0,0,0,0,0,0,0,0,2526,20.4,20.5,-273.2,20.5,-273.2,20.8,956,SUCCESS,,2039.426805,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5655,5/27/2021 1:30,22663.928,6.3,701,300,10,6001,0,65535,65535,1,20.5,25263,-296,-296,8,2,1,56,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3613,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2523,20.4,20.5,-273.2,20.5,-273.2,20.7,957,SUCCESS,,2039.097423,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5656,5/27/2021 1:30,22667.939,6.3,701,300,10,6001,0,65535,65535,1,20.5,25263,-298,-296,8,2,1,56,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2523,20.4,20.5,-273.2,20.5,-273.2,20.7,938,SUCCESS,,2038.765401,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5657,5/27/2021 1:30,22671.953,6.3,701,300,10,6001,0,65535,65535,1,20.5,25264,-296,-296,8,2,1,55,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,939,SUCCESS,,2038.435361,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5658,5/27/2021 1:30,22675.958,6.3,701,300,10,6001,0,65535,65535,1,20.5,25262,-296,-296,8,2,1,55,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3617,3614,3601,3604,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.6,992,SUCCESS,,2038.106061,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5659,5/27/2021 1:30,22679.972,6.3,701,300,10,6001,0,65535,65535,1,20.5,25262,-296,-296,8,2,1,55,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3617,3614,3601,3605,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,939,SUCCESS,,2037.776021,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5660,5/27/2021 1:30,22683.987,6.3,701,300,10,6001,0,65535,65535,1,20.5,25261,-292,-296,8,2,1,54,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3617,3613,3601,3605,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,945,SUCCESS,,2037.45036,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5661,5/27/2021 1:30,22688.002,6.3,701,300,10,6001,0,65535,65535,1,20.5,25262,-298,-296,8,2,1,54,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3617,3614,3601,3604,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,937,SUCCESS,,2037.118007,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5662,5/27/2021 1:30,22692.014,6.3,701,300,10,6001,0,65535,65535,1,20.5,25262,-296,-296,8,2,1,54,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3615,3616,3614,3601,3604,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,941,SUCCESS,,2036.788131,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5663,5/27/2021 1:31,22696.023,6.3,701,300,10,6001,0,65535,65535,1,20.5,25259,-296,-296,8,2,1,53,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3601,3604,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,947,SUCCESS,,2036.458503,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5664,5/27/2021 1:31,22700.029,6.31,701,300,10,6001,0,65535,65535,1,20.5,25260,-296,-296,8,2,1,53,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3617,3614,3601,3603,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,946,SUCCESS,,2036.12912,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5665,5/27/2021 1:31,22704.041,6.31,701,300,10,6001,0,65535,65535,1,20.5,25258,-296,-296,8,2,1,53,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3601,3604,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,945,SUCCESS,,2035.799245,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5666,5/27/2021 1:31,22708.042,6.31,701,300,10,6001,0,65535,65535,1,20.5,25260,-296,-296,8,2,1,52,3632,11,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3601,3604,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,945,SUCCESS,,2035.470274,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5667,5/27/2021 1:31,22712.049,6.31,701,300,10,6001,0,65535,65535,1,20.5,25257,-298,-296,8,2,1,52,3632,10,11,65535,3000,28875,0AC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,955,SUCCESS,,2035.138583,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5668,5/27/2021 1:31,22716.064,6.31,701,300,10,6001,0,65535,65535,1,20.5,25257,-296,-296,8,2,1,52,3632,10,11,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3604,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,938,SUCCESS,,2034.808461,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5669,5/27/2021 1:31,22720.066,6.31,701,300,10,6001,0,65535,65535,1,20.5,25258,-296,-296,8,2,1,51,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,1005,SUCCESS,,2034.479408,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5670,5/27/2021 1:31,22724.078,6.31,701,300,10,6001,0,65535,65535,1,20.5,25256,-296,-296,8,2,1,51,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3599,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,941,SUCCESS,,2034.149532,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5671,5/27/2021 1:31,22728.081,6.31,701,300,10,6001,0,65535,65535,1,20.5,25257,-296,-296,8,2,1,51,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,967,SUCCESS,,2033.820396,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5672,5/27/2021 1:31,22732.095,6.31,701,300,10,6001,0,65535,65535,1,20.5,25257,-296,-296,8,2,1,50,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,969,SUCCESS,,2033.490356,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5673,5/27/2021 1:31,22736.099,6.32,701,300,10,6001,0,65535,65535,1,20.5,25256,-296,-296,8,2,1,50,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,950,SUCCESS,,2033.161139,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5674,5/27/2021 1:31,22740.106,6.32,701,300,10,6001,0,65535,65535,1,20.5,25256,-296,-296,8,2,1,50,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3613,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,961,SUCCESS,,2032.831674,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5675,5/27/2021 1:31,22744.12,6.32,701,300,10,6001,0,65535,65535,1,20.5,25254,-296,-296,8,2,1,49,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,983,SUCCESS,,2032.501634,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5676,5/27/2021 1:31,22748.127,6.32,701,300,10,6001,0,65535,65535,1,20.5,25256,-298,-296,8,2,1,49,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3616,3612,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,938,SUCCESS,,2032.169944,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5677,5/27/2021 1:31,22752.134,6.32,701,300,10,6001,0,65535,65535,1,20.5,25255,-296,-296,8,2,1,49,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,962,SUCCESS,,2031.840479,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5678,5/27/2021 1:32,22756.142,6.32,701,300,10,6001,0,65535,65535,1,20.5,25256,-298,-296,8,2,1,48,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,960,SUCCESS,,2031.508706,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5679,5/27/2021 1:32,22760.156,6.32,701,300,10,6001,0,65535,65535,1,20.5,25253,-296,-296,8,2,1,48,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3598,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,942,SUCCESS,,2031.178666,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5680,5/27/2021 1:32,22764.163,6.32,701,300,10,6001,0,65535,65535,1,20.5,25254,-298,-296,8,2,1,48,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,980,SUCCESS,,2030.846975,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5681,5/27/2021 1:32,22768.177,6.32,701,300,10,6001,0,65535,65535,1,20.5,25255,-296,-296,8,2,1,47,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,987,SUCCESS,,2030.516935,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5682,5/27/2021 1:32,22772.187,6.33,701,300,10,6001,0,65535,65535,1,20.5,25253,-298,-296,8,2,1,47,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,1005,SUCCESS,,2030.184996,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5683,5/27/2021 1:32,22776.202,6.33,701,300,10,6001,0,65535,65535,1,20.5,25252,-296,-296,8,2,1,47,3632,10,10,65535,3000,28875,0AC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,941,SUCCESS,,2029.854874,2752,0,0.1,1.2,0.3,263,1.4,1.5
    5684,5/27/2021 1:32,22780.208,6.33,701,300,10,6001,0,65535,65535,1,20.5,25254,-296,-296,8,2,1,46,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,935,SUCCESS,,2029.525492,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5685,5/27/2021 1:32,22784.212,6.33,701,300,10,6001,0,65535,65535,1,20.5,25252,-296,-296,8,2,1,46,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3600,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,947,SUCCESS,,2029.196274,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5686,5/27/2021 1:32,22788.218,6.33,701,300,10,6001,0,65535,65535,1,20.5,25252,-294,-296,8,2,1,46,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,941,SUCCESS,,2028.869118,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5687,5/27/2021 1:32,22792.225,6.33,701,300,10,6001,0,65535,65535,1,20.5,25252,-296,-296,8,2,1,45,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3612,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,949,SUCCESS,,2028.539653,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5688,5/27/2021 1:32,22796.234,6.33,701,300,10,6001,0,65535,65535,1,20.5,25251,-298,-296,8,2,1,45,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,941,SUCCESS,,2028.207797,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5689,5/27/2021 1:32,22800.239,6.33,701,300,10,6001,0,65535,65535,1,20.5,25251,-298,-296,8,2,1,45,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,980,SUCCESS,,2027.876272,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5690,5/27/2021 1:32,22804.242,6.33,701,300,10,6001,0,65535,65535,1,20.5,25250,-298,-296,8,2,1,44,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,947,SUCCESS,,2027.544913,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5691,5/27/2021 1:32,22808.256,6.34,701,300,10,6001,0,65535,65535,1,20.5,25251,-296,-296,8,2,1,44,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3612,3599,3603,3597,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,955,SUCCESS,,2027.214873,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5692,5/27/2021 1:32,22812.262,6.34,701,300,10,6001,0,65535,65535,1,20.5,25250,-296,-296,8,2,1,44,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3612,3599,3603,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,943,SUCCESS,,2026.88549,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5693,5/27/2021 1:33,22816.269,6.34,701,300,10,6001,0,65535,65535,1,20.5,25249,-298,-296,8,2,1,43,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3612,3599,3603,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,969,SUCCESS,,2026.5538,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5694,5/27/2021 1:33,22820.282,6.34,701,300,10,6001,0,65535,65535,1,20.5,25247,-298,-296,8,2,1,43,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3599,3602,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,945,SUCCESS,,2026.221613,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5695,5/27/2021 1:33,22824.297,6.34,701,300,10,6001,0,65535,65535,1,20.5,25248,-296,-296,8,2,1,43,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3615,3611,3599,3603,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,939,SUCCESS,,2025.89149,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5696,5/27/2021 1:33,22828.302,6.34,701,300,10,6001,0,65535,65535,1,20.5,25248,-298,-296,8,2,1,42,3632,8,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3599,3603,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,966,SUCCESS,,2025.559965,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5697,5/27/2021 1:33,22832.31,6.34,701,300,10,6001,0,65535,65535,1,20.5,25246,-296,-296,8,2,1,42,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3614,3614,3611,3599,3603,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,942,SUCCESS,,2025.230419,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5698,5/27/2021 1:33,22836.318,6.34,701,300,10,6001,0,65535,65535,1,20.5,25248,-294,-296,8,2,1,42,3632,9,9,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3599,3603,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,970,SUCCESS,,2024.903099,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5699,5/27/2021 1:33,22840.324,6.34,701,300,10,6001,0,65535,65535,1,20.5,25247,-296,-296,8,2,1,41,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3598,3602,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,959,SUCCESS,,2024.573716,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5700,5/27/2021 1:33,22844.327,6.35,701,300,10,6001,0,65535,65535,1,20.5,25246,-298,-296,8,2,1,41,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3598,3602,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,947,SUCCESS,,2024.242357,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5701,5/27/2021 1:33,22848.34,6.35,701,300,10,6001,0,65535,65535,1,20.5,25246,-294,-296,8,2,1,41,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3598,3602,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,961,SUCCESS,,2023.914629,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5702,5/27/2021 1:33,22852.348,6.35,701,300,10,6001,0,65535,65535,1,20.5,25246,-296,-296,8,2,1,40,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3614,3614,3611,3598,3602,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,973,SUCCESS,,2023.585082,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5703,5/27/2021 1:33,22856.362,6.35,701,300,10,6001,0,65535,65535,1,20.5,25245,-296,-296,8,2,1,40,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3611,3614,3614,3611,3598,3602,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,936,SUCCESS,,2023.255042,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5704,5/27/2021 1:33,22860.369,6.35,701,300,10,6001,0,65535,65535,1,20.5,25244,-294,-296,8,2,1,40,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3613,3614,3611,3598,3601,3596,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,961,SUCCESS,,2022.927804,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5705,5/27/2021 1:33,22864.383,6.35,701,300,10,6001,0,65535,65535,1,20.5,25248,-296,-296,8,2,1,39,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3613,3614,3611,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,936,SUCCESS,,2022.597764,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5706,5/27/2021 1:33,22868.391,6.35,701,300,10,6001,0,65535,65535,1,20.5,25243,-296,-296,8,2,1,39,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3613,3614,3611,3598,3602,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,954,SUCCESS,,2022.268217,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5707,5/27/2021 1:33,22872.396,6.35,701,300,10,6001,0,65535,65535,1,20.5,25240,-296,-296,8,2,1,39,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3613,3614,3611,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,950,SUCCESS,,2021.938917,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5708,5/27/2021 1:34,22876.405,6.35,701,300,10,6001,0,65535,65535,1,20.5,25246,-296,-296,8,2,1,38,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3613,3613,3611,3598,3602,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,943,SUCCESS,,2021.609288,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5709,5/27/2021 1:34,22880.419,6.36,701,300,10,6001,0,65535,65535,1,20.5,25242,-296,-296,8,2,1,38,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3613,3613,3611,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,948,SUCCESS,,2021.279248,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5710,5/27/2021 1:34,22884.427,6.36,701,300,10,6001,0,65535,65535,1,20.5,25240,-296,-296,8,2,1,38,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3612,3613,3611,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,936,SUCCESS,,2020.949701,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5711,5/27/2021 1:34,22888.431,6.36,701,300,10,6001,0,65535,65535,1,20.5,25239,-292,-296,8,2,1,37,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3612,3613,3610,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,977,SUCCESS,,2020.624933,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5712,5/27/2021 1:34,22892.444,6.36,701,300,10,6001,0,65535,65535,1,20.5,25239,-298,-296,8,2,1,37,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3612,3613,3610,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20,961,SUCCESS,,2020.292745,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5713,5/27/2021 1:34,22896.451,6.36,701,300,10,6001,0,65535,65535,1,20.5,25239,-298,-296,8,2,1,37,3632,8,8,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3612,3613,3610,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,963,SUCCESS,,2019.961055,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5714,5/27/2021 1:34,22900.46,6.36,701,300,10,6001,0,65535,65535,1,20.5,25239,-296,-296,8,1,1,36,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3610,3612,3613,3610,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,968,SUCCESS,,2019.631426,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5715,5/27/2021 1:34,22904.468,6.36,701,300,10,6001,0,65535,65535,1,20.5,25239,-296,-296,8,1,1,36,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,974,SUCCESS,,2019.301879,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5716,5/27/2021 1:34,22908.482,6.36,701,300,10,6001,0,65535,65535,1,20.5,25238,-296,-296,8,1,1,36,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,943,SUCCESS,,2018.971839,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5717,5/27/2021 1:34,22912.486,6.36,701,300,10,6001,0,65535,65535,1,20.5,25237,-296,-296,8,1,1,35,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,942,SUCCESS,,2018.642621,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5718,5/27/2021 1:34,22916.496,6.37,701,300,10,6001,0,65535,65535,1,20.5,25237,-296,-296,8,1,1,35,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3598,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,959,SUCCESS,,2018.31291,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5719,5/27/2021 1:34,22920.508,6.37,701,300,10,6001,0,65535,65535,1,20.5,25237,-296,-296,8,1,1,35,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,948,SUCCESS,,2017.983035,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5720,5/27/2021 1:34,22924.515,6.37,701,300,10,6001,0,65535,65535,1,20.5,25237,-296,-296,8,1,1,34,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,947,SUCCESS,,2017.65357,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5721,5/27/2021 1:34,22928.527,6.37,701,300,10,6001,0,65535,65535,1,20.5,25237,-296,-296,8,1,1,34,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.1,952,SUCCESS,,2017.323695,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5722,5/27/2021 1:34,22932.541,6.37,701,300,10,6001,0,65535,65535,1,20.5,25236,-296,-296,8,1,1,34,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,944,SUCCESS,,2016.993655,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5723,5/27/2021 1:35,22936.547,6.37,701,300,10,6001,0,65535,65535,1,20.5,25236,-298,-296,8,1,1,33,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3610,3597,3600,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,963,SUCCESS,,2016.662047,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5724,5/27/2021 1:35,22940.554,6.37,701,300,10,6001,0,65535,65535,1,20.5,25236,-296,-296,8,1,1,33,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3601,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,955,SUCCESS,,2016.332583,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5725,5/27/2021 1:35,22944.567,6.37,701,300,10,6001,0,65535,65535,1,20.5,25235,-296,-296,8,1,1,33,3632,7,7,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3602,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,984,SUCCESS,,2016.002625,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5726,5/27/2021 1:35,22948.574,6.37,701,300,10,6001,0,65535,65535,1,20.5,25235,-296,-296,8,1,1,32,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3612,3613,3610,3597,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,943,SUCCESS,,2015.67316,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5727,5/27/2021 1:35,22952.587,6.38,701,300,10,6001,0,65535,65535,1,20.5,25235,-298,-296,8,1,1,32,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3610,3597,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,983,SUCCESS,,2015.340973,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5728,5/27/2021 1:35,22956.594,6.38,701,300,10,6001,0,65535,65535,1,20.5,25235,-298,-296,8,1,1,32,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3610,3597,3601,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,977,SUCCESS,,2015.009283,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5729,5/27/2021 1:35,22960.604,6.38,701,300,10,6001,0,65535,65535,1,20.5,25234,-296,-296,8,1,1,31,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3610,3597,3601,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,946,SUCCESS,,2014.679571,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5730,5/27/2021 1:35,22964.605,6.38,701,300,10,6001,0,65535,65535,1,20.5,25235,-296,-296,8,1,1,31,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3610,3596,3600,3595,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20,973,SUCCESS,,2014.3506,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5731,5/27/2021 1:35,22968.612,6.38,701,300,10,6001,0,65535,65535,1,20.5,25235,-296,-296,8,1,1,31,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3610,3597,3604,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,937,SUCCESS,,2014.021136,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5732,5/27/2021 1:35,22972.626,6.38,701,300,10,6001,0,65535,65535,1,20.5,25234,-294,-296,8,1,1,30,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3597,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.6,965,SUCCESS,,2013.693326,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5733,5/27/2021 1:35,22976.637,6.38,701,300,10,6001,0,65535,65535,1,20.5,25232,-298,-296,8,1,1,30,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3609,3597,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,965,SUCCESS,,2013.361304,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5734,5/27/2021 1:35,22980.642,6.38,701,300,10,6001,0,65535,65535,1,20.5,25234,-296,-296,8,1,1,30,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3609,3611,3613,3609,3597,3605,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,985,SUCCESS,,2013.032004,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5735,5/27/2021 1:35,22984.651,6.38,701,300,10,6001,0,65535,65535,1,20.5,25232,-296,-296,8,1,1,29,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3596,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,951,SUCCESS,,2012.702375,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5736,5/27/2021 1:35,22988.659,6.39,701,300,10,6001,0,65535,65535,1,20.5,25231,-294,-296,8,1,1,29,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3596,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.6,984,SUCCESS,,2012.375055,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5737,5/27/2021 1:35,22992.661,6.39,701,300,10,6001,0,65535,65535,1,20.5,25231,-296,-296,8,1,1,29,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3596,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,965,SUCCESS,,2012.046002,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5738,5/27/2021 1:36,22996.67,6.39,701,300,10,6001,0,65535,65535,1,20.5,25230,-296,-296,8,1,1,28,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3596,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,963,SUCCESS,,2011.716373,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5739,5/27/2021 1:36,23000.675,6.39,701,300,10,6001,0,65535,65535,1,20.5,25231,-296,-296,8,1,1,28,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3596,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,968,SUCCESS,,2011.387073,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5740,5/27/2021 1:36,23004.686,6.39,701,300,10,6001,0,65535,65535,1,20.5,25231,-296,-297,8,1,1,28,3632,6,6,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3613,3609,3596,3600,3594,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,943,SUCCESS,,2011.05728,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5741,5/27/2021 1:36,23008.69,6.39,701,300,10,6001,0,65535,65535,1,20.5,25229,-298,-296,8,1,1,27,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3613,3609,3596,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,958,SUCCESS,,2010.725838,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5742,5/27/2021 1:36,23012.705,6.39,701,300,10,6001,0,65535,65535,1,20.5,25229,-294,-296,8,1,1,27,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3611,3612,3609,3596,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,938,SUCCESS,,2010.397946,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5743,5/27/2021 1:36,23016.717,6.39,701,300,10,6001,0,65535,65535,1,20.5,25229,-296,-296,8,1,1,27,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3613,3609,3596,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,962,SUCCESS,,2010.06807,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5744,5/27/2021 1:36,23020.732,6.39,701,300,10,6001,0,65535,65535,1,20.5,25228,-298,-297,8,1,1,26,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3612,3609,3596,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,975,SUCCESS,,2009.735718,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5745,5/27/2021 1:36,23024.733,6.4,701,300,10,6001,0,65535,65535,1,20.5,25226,-296,-297,8,1,1,26,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3612,3609,3595,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.8,940,SUCCESS,,2009.406746,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5746,5/27/2021 1:36,23028.737,6.4,701,300,10,6001,0,65535,65535,1,20.5,25227,-296,-297,8,1,1,26,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3612,3609,3595,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,944,SUCCESS,,2009.077529,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5747,5/27/2021 1:36,23032.747,6.4,701,300,10,6001,0,65535,65535,1,20.5,25227,-298,-297,8,1,1,25,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3610,3612,3608,3595,3599,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,967,SUCCESS,,2008.74559,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5748,5/27/2021 1:36,23036.762,6.4,701,300,10,6001,0,65535,65535,1,20.5,25226,-296,-297,8,1,1,25,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3612,3608,3595,3600,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,944,SUCCESS,,2008.415468,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5749,5/27/2021 1:36,23040.775,6.4,701,300,10,6001,0,65535,65535,1,20.5,25226,-294,-297,8,1,1,25,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3612,3608,3595,3599,3593,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,982,SUCCESS,,2008.087739,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5750,5/27/2021 1:36,23044.778,6.4,701,300,10,6001,0,65535,65535,1,20.5,25224,-296,-297,8,1,1,24,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3608,3610,3612,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,942,SUCCESS,,2007.758604,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5751,5/27/2021 1:36,23048.783,6.4,701,300,10,6001,0,65535,65535,1,20.5,25225,-298,-297,8,1,1,24,3632,5,5,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3610,3612,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,969,SUCCESS,,2007.427079,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5752,5/27/2021 1:36,23052.794,6.4,701,300,10,6001,0,65535,65535,1,20.5,25224,-298,-297,8,1,1,24,3632,5,5,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3610,3612,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.6,968,SUCCESS,,2007.095057,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5753,5/27/2021 1:37,23056.807,6.4,701,300,10,6001,0,65535,65535,1,20.5,25223,-298,-297,8,1,1,23,3632,5,5,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3610,3611,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.4,949,SUCCESS,,2006.76287,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5754,5/27/2021 1:37,23060.813,6.41,701,300,10,6001,0,65535,65535,1,20.5,25222,-294,-297,8,1,1,23,3632,5,5,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,970,SUCCESS,,2006.435713,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5755,5/27/2021 1:37,23064.814,6.41,701,300,10,6001,0,65535,65535,1,20.5,25221,-296,-297,8,1,1,23,3632,5,5,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3595,3598,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,938,SUCCESS,,2006.106742,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5756,5/27/2021 1:37,23068.823,6.41,701,300,10,6001,0,65535,65535,1,20.5,25221,-296,-297,8,1,1,22,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,966,SUCCESS,,2005.777113,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5757,5/27/2021 1:37,23072.831,6.41,701,300,10,6001,0,65535,65535,1,20.5,25221,-298,-297,8,1,1,22,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,967,SUCCESS,,2005.44534,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5758,5/27/2021 1:37,23076.832,6.41,701,300,10,6001,0,65535,65535,1,20.5,25219,-298,-297,8,1,1,22,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,960,SUCCESS,,2005.114146,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5759,5/27/2021 1:37,23080.843,6.41,701,300,10,6001,0,65535,65535,1,20.5,25221,-296,-297,8,1,1,21,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3595,3599,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,983,SUCCESS,,2004.784353,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5760,5/27/2021 1:37,23084.857,6.41,701,300,10,6001,0,65535,65535,1,20.5,25219,-296,-297,8,1,1,21,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3594,3598,3592,0,0,0,0,0,0,0,0,2522,20.4,20.5,-273.2,20.5,-273.2,20.7,941,SUCCESS,,2004.454313,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5761,5/27/2021 1:37,23088.861,6.41,701,300,10,6001,0,65535,65535,1,20.5,25220,-294,-297,8,1,1,21,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3594,3598,3592,0,0,0,0,0,0,0,0,2521,20.3,20.5,-273.2,20.5,-273.2,20.7,940,SUCCESS,,2004.127319,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5762,5/27/2021 1:37,23092.867,6.41,701,300,10,6001,0,65535,65535,1,20.5,25220,-294,-297,8,1,1,20,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3608,3594,3598,3592,0,0,0,0,0,0,0,0,2519,20.3,20.5,-273.2,20.5,-273.2,20.2,951,SUCCESS,,2003.800163,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5763,5/27/2021 1:37,23096.875,6.42,701,300,10,6001,0,65535,65535,1,20.5,25219,-296,-297,8,1,1,20,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3611,3608,3594,3598,3592,0,0,0,0,0,0,0,0,2519,20.3,20.5,-273.2,20.5,-273.2,20.7,956,SUCCESS,,2003.470616,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5764,5/27/2021 1:37,23100.885,6.42,701,300,10,6001,0,65535,65535,1,20.5,25217,-296,-297,8,1,1,20,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3611,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,962,SUCCESS,,2003.140905,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5765,5/27/2021 1:37,23104.895,6.42,701,300,10,6001,0,65535,65535,1,20.4,25218,-296,-296,8,1,1,19,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3611,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,966,SUCCESS,,2002.811194,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5766,5/27/2021 1:37,23108.907,6.42,701,300,10,6001,0,65535,65535,1,20.5,25217,-298,-297,8,1,1,19,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3611,3608,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.8,941,SUCCESS,,2002.479089,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5767,5/27/2021 1:38,23112.922,6.42,701,300,10,6001,0,65535,65535,1,20.5,25218,-296,-297,8,1,1,19,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3607,3609,3611,3607,3595,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,960,SUCCESS,,2002.148967,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5768,5/27/2021 1:38,23116.923,6.42,701,300,10,6001,0,65535,65535,1,20.5,25216,-296,-296,8,1,1,18,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.6,942,SUCCESS,,2001.819996,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5769,5/27/2021 1:38,23120.929,6.42,701,300,10,6001,0,65535,65535,1,20.5,25217,-298,-296,8,1,1,18,3632,4,4,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3611,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,979,SUCCESS,,2001.488388,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5770,5/27/2021 1:38,23124.94,6.42,701,300,10,6001,0,65535,65535,1,20.5,25215,-296,-296,8,1,1,18,3632,4,4,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,960,SUCCESS,,2001.158595,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5771,5/27/2021 1:38,23128.953,6.42,701,300,10,6001,0,65535,65535,1,20.5,25217,-298,-296,8,1,1,17,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3609,3611,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.8,940,SUCCESS,,2000.826408,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5772,5/27/2021 1:38,23132.963,6.43,701,300,10,6001,0,65535,65535,1,20.5,25215,-296,-296,8,1,1,17,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,968,SUCCESS,,2000.496696,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5773,5/27/2021 1:38,23136.975,6.43,701,300,10,6001,0,65535,65535,1,20.5,25215,-296,-296,8,1,1,17,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2521,20.3,20.5,-273.2,20.5,-273.2,20.7,985,SUCCESS,,2000.166821,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5774,5/27/2021 1:38,23140.975,6.43,701,300,10,6001,0,65535,65535,1,20.5,25214,-298,-297,8,1,1,16,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,953,SUCCESS,,1999.83571,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5775,5/27/2021 1:38,23144.988,6.43,701,300,10,6001,0,65535,65535,1,20.5,25215,-294,-297,8,1,1,16,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,989,SUCCESS,,1999.507981,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5776,5/27/2021 1:38,23148.993,6.43,701,300,10,6001,0,65535,65535,1,20.5,25215,-296,-296,8,1,1,16,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3595,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,962,SUCCESS,,1999.178681,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5777,5/27/2021 1:38,23153.001,6.43,701,300,10,6001,0,65535,65535,1,20.5,25214,-296,-296,8,1,1,16,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3594,3597,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,992,SUCCESS,,1998.849135,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5778,5/27/2021 1:38,23157.014,6.43,701,300,10,6001,0,65535,65535,1,20.5,25215,-294,-296,8,1,1,15,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3607,3594,3598,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.6,958,SUCCESS,,1998.521406,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5779,5/27/2021 1:38,23161.025,6.43,701,300,10,6001,0,65535,65535,1,20.5,25213,-300,-296,8,1,1,15,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3606,3595,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.6,948,SUCCESS,,1998.187156,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5780,5/27/2021 1:38,23165.033,6.43,701,300,10,6001,0,65535,65535,1,20.5,25212,-296,-297,8,1,1,15,3632,3,3,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3610,3606,3594,3597,3592,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,944,SUCCESS,,1997.85761,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5781,5/27/2021 1:38,23169.041,6.44,701,300,10,6001,0,65535,65535,1,20.5,25212,-296,-296,8,1,1,14,3632,3,3,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3606,3608,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,949,SUCCESS,,1997.528063,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5782,5/27/2021 1:39,23173.043,6.44,701,300,10,6001,0,65535,65535,1,20.4,25210,-296,-296,8,1,1,14,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,944,SUCCESS,,1997.19901,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5783,5/27/2021 1:39,23177.048,6.44,701,300,10,6001,0,65535,65535,1,20.5,25209,-298,-296,8,1,1,14,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.6,978,SUCCESS,,1996.867485,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5784,5/27/2021 1:39,23181.061,6.44,701,300,10,6001,0,65535,65535,1,20.5,25212,-296,-296,8,1,1,13,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.6,941,SUCCESS,,1996.537527,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5785,5/27/2021 1:39,23185.063,6.44,701,300,10,6001,0,65535,65535,1,20.5,25209,-296,-296,8,1,1,13,3632,3,3,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,956,SUCCESS,,1996.208474,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5786,5/27/2021 1:39,23189.071,6.44,701,300,10,6001,0,65535,65535,1,20.4,25209,-296,-296,8,1,1,13,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,948,SUCCESS,,1995.878927,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5787,5/27/2021 1:39,23193.08,6.44,701,300,10,6001,0,65535,65535,1,20.4,25212,-296,-296,8,1,1,12,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,953,SUCCESS,,1995.549298,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5788,5/27/2021 1:39,23197.083,6.44,701,300,10,6001,0,65535,65535,1,20.4,25209,-296,-296,8,1,1,12,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,940,SUCCESS,,1995.220163,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5789,5/27/2021 1:39,23201.096,6.44,701,300,10,6001,0,65535,65535,1,20.4,25209,-298,-296,8,1,1,11,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,938,SUCCESS,,1994.887975,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5790,5/27/2021 1:39,23205.111,6.45,701,300,10,6001,0,65535,65535,1,20.4,25211,-298,-296,8,1,1,11,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,956,SUCCESS,,1994.555623,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5791,5/27/2021 1:39,23209.116,6.45,701,300,10,6001,0,65535,65535,1,20.4,25209,-296,-297,8,1,1,11,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3597,3591,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,985,SUCCESS,,1994.226323,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5792,5/27/2021 1:39,23213.13,6.45,701,300,10,6001,0,65535,65535,1,20.5,25207,-298,-296,8,1,1,10,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3594,3596,3591,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,971,SUCCESS,,1993.894053,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5793,5/27/2021 1:39,23217.135,6.45,701,300,10,6001,0,65535,65535,1,20.4,25208,-298,-296,8,1,1,10,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3593,3597,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,966,SUCCESS,,1993.562528,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5794,5/27/2021 1:39,23221.137,6.45,701,300,10,6001,0,65535,65535,1,20.4,25207,-296,-296,8,1,1,10,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3593,3596,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20,958,SUCCESS,,1993.233474,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5795,5/27/2021 1:39,23225.142,6.45,701,300,10,6001,0,65535,65535,1,20.4,25206,-296,-296,8,1,1,10,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3606,3593,3596,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,937,SUCCESS,,1992.904174,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5796,5/27/2021 1:39,23229.157,6.45,701,300,10,6001,0,65535,65535,1,20.4,25206,-294,-296,8,1,1,9,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3605,3607,3609,3605,3593,3596,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,956,SUCCESS,,1992.576283,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5797,5/27/2021 1:40,23233.161,6.45,701,300,10,6001,0,65535,65535,1,20.4,25205,-296,-296,8,1,1,9,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3608,3605,3594,3596,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,957,SUCCESS,,1992.247065,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5798,5/27/2021 1:40,23237.173,6.45,701,300,10,6001,0,65535,65535,1,20.4,25204,-298,-296,8,1,1,9,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3608,3605,3593,3596,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,953,SUCCESS,,1991.91496,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5799,5/27/2021 1:40,23241.181,6.46,701,300,10,6001,0,65535,65535,1,20.5,25203,-296,-297,8,1,1,8,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3609,3605,3593,3597,3590,0,0,0,0,0,0,0,0,2518,20.3,20.5,-273.2,20.5,-273.2,20.7,945,SUCCESS,,1991.585414,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5800,5/27/2021 1:40,23245.194,6.46,701,300,10,6001,0,65535,65535,1,20.4,25204,-296,-296,8,1,1,8,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3609,3605,3593,3596,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,968,SUCCESS,,1991.255456,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5801,5/27/2021 1:40,23249.195,6.46,701,300,10,6001,0,65535,65535,1,20.4,25203,-296,-296,8,1,1,8,3632,2,2,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3608,3605,3593,3595,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,963,SUCCESS,,1990.926485,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5802,5/27/2021 1:40,23253.21,6.46,701,300,10,6001,0,65535,65535,1,20.4,25203,-296,-296,8,1,1,7,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3608,3605,3593,3597,3590,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,963,SUCCESS,,1990.596363,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5803,5/27/2021 1:40,23257.214,6.46,701,300,10,6001,0,65535,65535,1,20.4,25203,-298,-296,8,1,1,7,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3608,3605,3593,3596,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,946,SUCCESS,,1990.26492,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5804,5/27/2021 1:40,23261.229,6.46,701,300,10,6001,0,65535,65535,1,20.4,25202,-296,-296,8,1,1,7,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3604,3607,3608,3605,3593,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,968,SUCCESS,,1989.934798,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5805,5/27/2021 1:40,23265.232,6.46,701,300,10,6001,0,65535,65535,1,20.4,25200,-296,-296,8,1,1,6,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3607,3608,3605,3592,3597,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,944,SUCCESS,,1989.605663,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5806,5/27/2021 1:40,23269.235,6.46,701,300,10,6001,0,65535,65535,1,20.4,25199,-296,-296,8,1,1,6,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3607,3608,3605,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,969,SUCCESS,,1989.276527,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5807,5/27/2021 1:40,23273.245,6.46,701,300,10,6001,0,65535,65535,1,20.4,25199,-296,-297,8,1,1,6,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3608,3605,3592,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,961,SUCCESS,,1988.946816,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5808,5/27/2021 1:40,23277.253,6.47,701,300,10,6001,0,65535,65535,1,20.4,25198,-298,-296,8,1,1,5,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3608,3605,3592,3600,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.5,984,SUCCESS,,1988.615043,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5809,5/27/2021 1:40,23281.261,6.47,701,300,10,6001,0,65535,65535,1,20.4,25199,-298,-296,8,1,1,5,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3607,3608,3605,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,943,SUCCESS,,1988.283269,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5810,5/27/2021 1:40,23285.274,6.47,701,300,10,6001,0,65535,65535,1,20.4,25198,-296,-296,8,1,1,5,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3608,3605,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,933,SUCCESS,,1987.953311,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5811,5/27/2021 1:40,23289.279,6.47,701,300,10,6001,0,65535,65535,1,20.4,25198,-296,-296,8,1,1,4,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3608,3605,3592,3597,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,945,SUCCESS,,1987.624011,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5812,5/27/2021 1:41,23293.287,6.47,701,300,10,6001,0,65535,65535,1,20.4,25196,-294,-297,8,1,1,4,3632,1,1,65535,3000,28875,0BC0,0,3569,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3608,3604,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,938,SUCCESS,,1987.296691,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5813,5/27/2021 1:41,23297.292,6.47,701,300,10,6001,0,65535,65535,1,20.4,25198,-296,-297,8,1,1,4,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3608,3605,3592,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,947,SUCCESS,,1986.967391,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5814,5/27/2021 1:41,23301.298,6.47,701,300,10,6001,0,65535,65535,1,20.4,25196,-296,-297,8,1,1,3,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1986.638009,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5815,5/27/2021 1:41,23305.313,6.47,701,300,10,6001,0,65535,65535,1,20.4,25196,-294,-296,8,1,1,3,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,938,SUCCESS,,1986.310118,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5816,5/27/2021 1:41,23309.319,6.47,701,300,10,6001,0,65535,65535,1,20.4,25195,-296,-296,8,1,1,3,3632,1,1,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3592,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,955,SUCCESS,,1985.980735,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5817,5/27/2021 1:41,23313.321,6.48,701,300,10,6001,0,65535,65535,1,20.4,25196,-298,-297,8,1,1,2,3632,0,0,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,947,SUCCESS,,1985.649459,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5818,5/27/2021 1:41,23317.325,6.48,701,300,10,6001,0,65535,65535,1,20.4,25196,-296,-297,8,1,1,2,3632,0,0,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3592,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,958,SUCCESS,,1985.320241,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5819,5/27/2021 1:41,23321.336,6.48,701,300,10,6001,0,65535,65535,1,20.4,25195,-298,-296,8,1,1,2,3632,0,0,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3605,3607,3604,3592,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,947,SUCCESS,,1984.988219,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5820,5/27/2021 1:41,23325.343,6.48,701,300,10,6001,0,65535,65535,1,20.4,25196,-296,-297,8,1,1,1,3632,0,0,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3591,3595,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,939,SUCCESS,,1984.658755,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5821,5/27/2021 1:41,23329.344,6.48,701,300,10,6001,0,65535,65535,1,20.4,25194,-296,-297,8,1,1,1,3632,0,0,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3605,3607,3604,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1984.329784,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5822,5/27/2021 1:41,23333.354,6.48,701,300,10,6001,0,65535,65535,1,20.4,25194,-298,-296,8,1,1,1,3632,0,0,65535,3000,28875,0BC0,0,3570,11,107,0,4,2,4444,8006,0,0,0,0,0,0,0,3603,3605,3607,3604,3591,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.2,966,SUCCESS,,1983.997845,3008,0,0.1,1.2,0.3,263,1.4,1.5
    5823,5/27/2021 1:41,23337.362,6.48,701,300,10,6001,0,65535,65535,1,20.4,25195,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3606,3607,3604,3591,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,958,SUCCESS,,1983.668298,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5824,5/27/2021 1:41,23341.364,6.48,701,300,10,6001,0,65535,65535,1,20.4,25194,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3607,3604,3591,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,936,SUCCESS,,1983.341468,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5825,5/27/2021 1:41,23345.378,6.48,701,300,10,6001,0,65535,65535,1,20.4,25193,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3604,3591,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1983.009198,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5826,5/27/2021 1:41,23349.388,6.49,701,300,10,6001,0,65535,65535,1,20.4,25191,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3589,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,949,SUCCESS,,1982.677259,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5827,5/27/2021 1:42,23353.39,6.49,701,300,10,6001,0,65535,65535,1,20.4,25191,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3607,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,940,SUCCESS,,1982.348206,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5828,5/27/2021 1:42,23357.393,6.49,701,300,10,6001,0,65535,65535,1,20.4,25191,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,955,SUCCESS,,1982.016846,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5829,5/27/2021 1:42,23361.399,6.49,701,300,10,6001,0,65535,65535,1,20.4,25190,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,954,SUCCESS,,1981.687464,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5830,5/27/2021 1:42,23365.41,6.49,701,300,10,6001,0,65535,65535,1,20.4,25190,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,952,SUCCESS,,1981.355443,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5831,5/27/2021 1:42,23369.426,6.49,701,300,10,6001,0,65535,65535,1,20.4,25190,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,949,SUCCESS,,1981.025238,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5832,5/27/2021 1:42,23373.432,6.49,701,300,10,6001,0,65535,65535,1,20.4,25190,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,962,SUCCESS,,1980.698081,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5833,5/27/2021 1:42,23377.441,6.49,701,300,10,6001,0,65535,65535,1,20.4,25190,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,968,SUCCESS,,1980.366225,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5834,5/27/2021 1:42,23381.444,6.49,701,300,10,6001,0,65535,65535,1,20.4,25190,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,965,SUCCESS,,1980.03709,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5835,5/27/2021 1:42,23385.452,6.5,701,300,10,6001,0,65535,65535,1,20.4,25190,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,959,SUCCESS,,1979.707543,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5836,5/27/2021 1:42,23389.461,6.5,701,300,10,6001,0,65535,65535,1,20.4,25190,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,19.9,950,SUCCESS,,1979.380141,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5837,5/27/2021 1:42,23393.462,6.5,701,300,10,6001,0,65535,65535,1,20.4,25190,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,947,SUCCESS,,1979.05117,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5838,5/27/2021 1:42,23397.472,6.5,701,300,10,6001,0,65535,65535,1,20.4,25188,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,934,SUCCESS,,1978.721459,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5839,5/27/2021 1:42,23401.478,6.5,701,300,10,6001,0,65535,65535,1,20.4,25190,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3591,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,979,SUCCESS,,1978.389851,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5840,5/27/2021 1:42,23405.489,6.5,701,300,10,6001,0,65535,65535,1,20.4,25189,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3605,3606,3603,3590,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,965,SUCCESS,,1978.060058,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5841,5/27/2021 1:42,23409.494,6.5,701,300,10,6001,0,65535,65535,1,20.4,25187,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3603,3590,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,968,SUCCESS,,1977.728533,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5842,5/27/2021 1:43,23413.5,6.5,701,300,10,6001,0,65535,65535,1,20.4,25188,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,959,SUCCESS,,1977.399151,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5843,5/27/2021 1:43,23417.501,6.5,701,300,10,6001,0,65535,65535,1,20.4,25188,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3588,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1977.072403,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5844,5/27/2021 1:43,23421.515,6.51,701,300,10,6001,0,65535,65535,1,20.4,25187,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,942,SUCCESS,,1976.742363,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5845,5/27/2021 1:43,23425.528,6.51,701,300,10,6001,0,65535,65535,1,20.4,25186,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,943,SUCCESS,,1976.414634,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5846,5/27/2021 1:43,23429.541,6.51,701,300,10,6001,0,65535,65535,1,20.4,25186,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,961,SUCCESS,,1976.084676,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5847,5/27/2021 1:43,23433.556,6.51,701,300,10,6001,0,65535,65535,1,20.4,25186,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,978,SUCCESS,,1975.754554,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5848,5/27/2021 1:43,23437.56,6.51,701,300,10,6001,0,65535,65535,1,20.4,25186,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,966,SUCCESS,,1975.427561,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5849,5/27/2021 1:43,23441.568,6.51,701,300,10,6001,0,65535,65535,1,20.4,25185,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,19.9,971,SUCCESS,,1975.100241,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5850,5/27/2021 1:43,23445.583,6.51,701,300,10,6001,0,65535,65535,1,20.4,25186,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,950,SUCCESS,,1974.770119,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5851,5/27/2021 1:43,23449.586,6.51,701,300,10,6001,0,65535,65535,1,20.4,25185,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3605,3602,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,955,SUCCESS,,1974.443207,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5852,5/27/2021 1:43,23453.59,6.51,701,300,10,6001,0,65535,65535,1,20.4,25184,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3605,3602,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,958,SUCCESS,,1974.113989,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5853,5/27/2021 1:43,23457.601,6.52,701,300,10,6001,0,65535,65535,1,20.4,25183,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3603,3605,3601,3590,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,966,SUCCESS,,1973.784196,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5854,5/27/2021 1:43,23461.617,6.52,701,300,10,6001,0,65535,65535,1,20.4,25182,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3603,3605,3601,3589,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,931,SUCCESS,,1973.453991,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5855,5/27/2021 1:43,23465.631,6.52,701,300,10,6001,0,65535,65535,1,20.4,25180,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3604,3606,3602,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,950,SUCCESS,,1973.123951,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5856,5/27/2021 1:43,23469.635,6.52,701,300,10,6001,0,65535,65535,1,20.4,25182,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3603,3605,3601,3589,3594,3587,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,961,SUCCESS,,1972.794734,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5857,5/27/2021 1:44,23473.646,6.52,701,300,10,6001,0,65535,65535,1,20.4,25183,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,951,SUCCESS,,1972.462712,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5858,5/27/2021 1:44,23477.659,6.52,701,300,10,6001,0,65535,65535,1,20.4,25181,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.4,938,SUCCESS,,1972.132754,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5859,5/27/2021 1:44,23481.672,6.52,701,300,10,6001,0,65535,65535,1,20.4,25181,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3603,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,948,SUCCESS,,1971.802796,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5860,5/27/2021 1:44,23485.676,6.52,701,300,10,6001,0,65535,65535,1,20.4,25180,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,981,SUCCESS,,1971.473579,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5861,5/27/2021 1:44,23489.677,6.52,701,300,10,6001,0,65535,65535,1,20.4,25176,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.7,936,SUCCESS,,1971.14683,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5862,5/27/2021 1:44,23493.685,6.53,701,300,10,6001,0,65535,65535,1,20.4,25180,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,961,SUCCESS,,1970.817284,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5863,5/27/2021 1:44,23497.696,6.53,701,300,10,6001,0,65535,65535,1,20.4,25180,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,934,SUCCESS,,1970.48749,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5864,5/27/2021 1:44,23501.704,6.53,701,300,10,6001,0,65535,65535,1,20.4,25178,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,956,SUCCESS,,1970.157944,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5865,5/27/2021 1:44,23505.711,6.53,701,300,10,6001,0,65535,65535,1,20.4,25179,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,949,SUCCESS,,1969.826253,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5866,5/27/2021 1:44,23509.724,6.53,701,300,10,6001,0,65535,65535,1,20.4,25180,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,951,SUCCESS,,1969.496295,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5867,5/27/2021 1:44,23513.73,6.53,701,300,10,6001,0,65535,65535,1,20.4,25179,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3602,3603,3605,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2517,20.3,20.4,-273.2,20.4,-273.2,20.5,966,SUCCESS,,1969.164688,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5868,5/27/2021 1:44,23517.734,6.53,701,300,10,6001,0,65535,65535,1,20.4,25178,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3603,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.3,20.4,-273.2,20.4,-273.2,20.6,967,SUCCESS,,1968.83547,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5869,5/27/2021 1:44,23521.741,6.53,701,300,10,6001,0,65535,65535,1,20.4,25177,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.2,20.4,-273.2,20.4,-273.2,20.6,968,SUCCESS,,1968.506005,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5870,5/27/2021 1:44,23525.745,6.53,701,300,10,6001,0,65535,65535,1,20.4,25178,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.2,20.4,-273.2,20.4,-273.2,20.6,945,SUCCESS,,1968.174563,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5871,5/27/2021 1:44,23529.752,6.54,701,300,10,6001,0,65535,65535,1,20.4,25176,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3603,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.2,20.4,-273.2,20.4,-273.2,20.6,970,SUCCESS,,1967.842873,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5872,5/27/2021 1:45,23533.764,6.54,701,300,10,6001,0,65535,65535,1,20.4,25177,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3603,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2518,20.2,20.4,-273.2,20.4,-273.2,20.7,943,SUCCESS,,1967.515226,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5873,5/27/2021 1:45,23537.767,6.54,701,300,10,6001,0,65535,65535,1,20.4,25176,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3589,3594,3586,0,0,0,0,0,0,0,0,2517,20.2,20.4,-273.2,20.4,-273.2,20.6,971,SUCCESS,,1967.188314,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5874,5/27/2021 1:45,23541.776,6.54,701,300,10,6001,0,65535,65535,1,20.4,25175,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3589,3594,3585,0,0,0,0,0,0,0,0,2514,20.3,20.4,-273.2,20.4,-273.2,20.6,970,SUCCESS,,1966.860913,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5875,5/27/2021 1:45,23545.781,6.54,701,300,10,6001,0,65535,65535,1,20.4,25174,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3588,3593,3585,0,0,0,0,0,0,0,0,2518,20.2,20.4,-273.2,20.4,-273.2,20.7,958,SUCCESS,,1966.531613,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5876,5/27/2021 1:45,23549.785,6.54,701,300,10,6001,0,65535,65535,1,20.4,25175,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3588,3594,3585,0,0,0,0,0,0,0,0,2514,20.2,20.4,-273.2,20.4,-273.2,20.6,954,SUCCESS,,1966.202395,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5877,5/27/2021 1:45,23553.799,6.54,701,300,10,6001,0,65535,65535,1,20.4,25174,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3588,3593,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.7,994,SUCCESS,,1965.872355,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5878,5/27/2021 1:45,23557.805,6.54,701,300,10,6001,0,65535,65535,1,20.4,25174,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3602,3604,3601,3588,3593,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,964,SUCCESS,,1965.542973,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5879,5/27/2021 1:45,23561.813,6.54,701,300,10,6001,0,65535,65535,1,20.4,25174,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3588,3594,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,977,SUCCESS,,1965.213426,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5880,5/27/2021 1:45,23565.826,6.55,701,300,10,6001,0,65535,65535,1,20.4,25172,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3601,3602,3604,3601,3588,3593,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.3,950,SUCCESS,,1964.885698,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5881,5/27/2021 1:45,23569.831,6.55,701,300,10,6001,0,65535,65535,1,20.4,25171,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3602,3603,3601,3588,3592,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,953,SUCCESS,,1964.556398,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5882,5/27/2021 1:45,23573.833,6.55,701,300,10,6001,0,65535,65535,1,20.4,25171,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3601,3588,3594,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,967,SUCCESS,,1964.229568,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5883,5/27/2021 1:45,23577.848,6.55,701,300,10,6001,0,65535,65535,1,20.4,25168,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,986,SUCCESS,,1963.899445,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5884,5/27/2021 1:45,23581.852,6.55,701,300,10,6001,0,65535,65535,1,20.4,25170,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3601,3588,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,949,SUCCESS,,1963.568003,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5885,5/27/2021 1:45,23585.857,6.55,701,300,10,6001,0,65535,65535,1,20.4,25171,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.7,945,SUCCESS,,1963.238703,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5886,5/27/2021 1:45,23589.86,6.55,701,300,10,6001,0,65535,65535,1,20.4,25169,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3600,3588,3592,3585,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,972,SUCCESS,,1962.909568,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5887,5/27/2021 1:46,23593.872,6.55,701,300,10,6001,0,65535,65535,1,20.4,25170,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3601,3588,3590,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,949,SUCCESS,,1962.577463,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5888,5/27/2021 1:46,23597.875,6.55,701,300,10,6001,0,65535,65535,1,20.4,25169,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,972,SUCCESS,,1962.250551,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5889,5/27/2021 1:46,23601.876,6.56,701,300,10,6001,0,65535,65535,1,20.4,25169,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3600,3601,3603,3600,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,978,SUCCESS,,1961.919358,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5890,5/27/2021 1:46,23605.889,6.56,701,300,10,6001,0,65535,65535,1,20.4,25168,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,,0,0,0,0,0,0,3600,3601,3603,3601,3588,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,975,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,1961.58717,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5891,5/27/2021 1:46,23609.895,6.56,701,300,10,6001,0,65535,65535,1,20.4,25168,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,954,SUCCESS,,1961.257788,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5892,5/27/2021 1:46,23613.906,6.56,701,300,10,6001,0,65535,65535,1,20.4,25168,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.7,974,SUCCESS,,1960.927995,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5893,5/27/2021 1:46,23617.921,6.56,701,300,10,6001,0,65535,65535,1,20.4,25167,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.7,943,SUCCESS,,1960.597873,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5894,5/27/2021 1:46,23621.927,6.56,701,300,10,6001,0,65535,65535,1,20.4,25167,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3603,3600,3587,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,983,SUCCESS,,1960.26849,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5895,5/27/2021 1:46,23625.937,6.56,701,300,10,6001,0,65535,65535,1,20.4,25165,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3601,3588,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,972,SUCCESS,,1959.938779,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5896,5/27/2021 1:46,23629.942,6.56,701,300,10,6001,0,65535,65535,1,20.4,25166,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3601,3587,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,967,SUCCESS,,1959.609479,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5897,5/27/2021 1:46,23633.951,6.56,701,300,10,6001,0,65535,65535,1,20.4,25167,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3603,3600,3587,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,944,SUCCESS,,1959.27985,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5898,5/27/2021 1:46,23637.962,6.57,701,300,10,6001,0,65535,65535,1,20.4,25165,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3603,3601,3587,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.4,996,SUCCESS,,1958.950057,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5899,5/27/2021 1:46,23641.973,6.57,701,300,10,6001,0,65535,65535,1,20.4,25165,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3601,3602,3601,3587,3592,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,975,SUCCESS,,1958.620264,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5900,5/27/2021 1:46,23645.984,6.57,701,300,10,6001,0,65535,65535,1,20.4,25163,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3603,3601,3587,3591,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.5,943,SUCCESS,,1958.288242,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5901,5/27/2021 1:46,23649.996,6.57,701,300,10,6001,0,65535,65535,1,20.4,25163,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3602,3601,3587,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,945,SUCCESS,,1957.958366,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5902,5/27/2021 1:47,23654.005,6.57,701,300,10,6001,0,65535,65535,1,20.4,25162,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3602,3600,3587,3591,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,984,SUCCESS,,1957.628738,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5903,5/27/2021 1:47,23658.015,6.57,701,300,10,6001,0,65535,65535,1,20.4,25162,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3602,3601,3587,3591,3584,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.7,942,SUCCESS,,1957.299026,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5904,5/27/2021 1:47,23662.015,6.57,701,300,10,6001,0,65535,65535,1,20.4,25163,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3602,3601,3587,3591,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,942,SUCCESS,,1956.970138,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5905,5/27/2021 1:47,23666.025,6.57,701,300,10,6001,0,65535,65535,1,20.4,25162,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3602,3601,3587,3591,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,932,SUCCESS,,1956.640426,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5906,5/27/2021 1:47,23670.033,6.58,701,300,10,6001,0,65535,65535,1,20.4,25161,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3599,3600,3602,3601,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,972,SUCCESS,,1956.308653,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5907,5/27/2021 1:47,23674.048,6.58,701,300,10,6001,0,65535,65535,1,20.4,25160,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3602,3601,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,971,SUCCESS,,1955.978531,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5908,5/27/2021 1:47,23678.063,6.58,701,300,10,6001,0,65535,65535,1,20.4,25161,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3602,3600,3586,3591,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,941,SUCCESS,,1955.650639,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5909,5/27/2021 1:47,23682.066,6.58,701,300,10,6001,0,65535,65535,1,20.4,25160,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3602,3601,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,968,SUCCESS,,1955.321504,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5910,5/27/2021 1:47,23686.079,6.58,701,300,10,6001,0,65535,65535,1,20.4,25160,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3602,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,941,SUCCESS,,1954.991546,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5911,5/27/2021 1:47,23690.08,6.58,701,300,10,6001,0,65535,65535,1,20.4,25160,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3601,3601,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.2,957,SUCCESS,,1954.660352,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5912,5/27/2021 1:47,23694.093,6.58,701,300,10,6001,0,65535,65535,1,20.4,25158,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3602,3601,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1954.330394,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5913,5/27/2021 1:47,23698.095,6.58,701,300,10,6001,0,65535,65535,1,20.4,25158,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,,0,0,3598,3600,3601,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,2914,ERROR : Please check C:\Users\Craig\Dropbox\_Active Projects\Ocean Server\Battery\Data NASA\NASA DischargeLog 2021_05_26 EV2400 #2.log.err,,1954.003564,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5914,5/27/2021 1:47,23702.097,6.58,701,300,10,6001,0,65535,65535,1,20.4,25158,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3601,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,948,SUCCESS,,1953.672288,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5915,5/27/2021 1:47,23706.099,6.59,701,300,10,6001,0,65535,65535,1,20.4,25158,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3601,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,972,SUCCESS,,1953.343234,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5916,5/27/2021 1:47,23710.102,6.59,701,300,10,6001,0,65535,65535,1,20.4,25158,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3601,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,951,SUCCESS,,1953.016323,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5917,5/27/2021 1:48,23714.105,6.59,701,300,10,6001,0,65535,65535,1,20.4,25157,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3599,3601,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,951,SUCCESS,,1952.687187,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5918,5/27/2021 1:48,23718.107,6.59,701,300,10,6001,0,65535,65535,1,20.4,25156,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3600,3601,3600,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,944,SUCCESS,,1952.358134,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5919,5/27/2021 1:48,23722.119,6.59,701,300,10,6001,0,65535,65535,1,20.4,25156,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3599,3601,3599,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,962,SUCCESS,,1952.026029,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5920,5/27/2021 1:48,23726.128,6.59,701,300,10,6001,0,65535,65535,1,20.4,25156,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3598,3599,3601,3599,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,953,SUCCESS,,1951.6964,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5921,5/27/2021 1:48,23730.142,6.59,701,300,10,6001,0,65535,65535,1,20.4,25155,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3599,3601,3599,3585,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,942,SUCCESS,,1951.36636,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5922,5/27/2021 1:48,23734.145,6.59,701,300,10,6001,0,65535,65535,1,20.4,25156,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3599,3601,3599,3586,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,956,SUCCESS,,1951.037225,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5923,5/27/2021 1:48,23738.154,6.59,701,300,10,6001,0,65535,65535,1,20.4,25155,-292,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3599,3601,3599,3585,3590,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,992,SUCCESS,,1950.71205,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5924,5/27/2021 1:48,23742.168,6.6,701,300,10,6001,0,65535,65535,1,20.4,25155,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3599,3601,3599,3586,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.7,952,SUCCESS,,1950.38201,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5925,5/27/2021 1:48,23746.172,6.6,701,300,10,6001,0,65535,65535,1,20.4,25154,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3599,3601,3599,3586,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,941,SUCCESS,,1950.052793,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5926,5/27/2021 1:48,23750.186,6.6,701,300,10,6001,0,65535,65535,1,20.4,25154,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3601,3599,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,958,SUCCESS,,1949.722753,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5927,5/27/2021 1:48,23754.191,6.6,701,300,10,6001,0,65535,65535,1,20.4,25153,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3601,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,969,SUCCESS,,1949.393453,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5928,5/27/2021 1:48,23758.197,6.6,701,300,10,6001,0,65535,65535,1,20.4,25151,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3601,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,937,SUCCESS,,1949.061845,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5929,5/27/2021 1:48,23762.201,6.6,701,300,10,6001,0,65535,65535,1,20.4,25151,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,943,SUCCESS,,1948.734851,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5930,5/27/2021 1:48,23766.206,6.6,701,300,10,6001,0,65535,65535,1,20.4,25150,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,938,SUCCESS,,1948.405551,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5931,5/27/2021 1:48,23770.21,6.6,701,300,10,6001,0,65535,65535,1,20.4,25150,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.4,982,SUCCESS,,1948.078558,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5932,5/27/2021 1:49,23774.224,6.6,701,300,10,6001,0,65535,65535,1,20.4,25150,-300,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,967,SUCCESS,,1947.744058,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5933,5/27/2021 1:49,23778.225,6.61,701,300,10,6001,0,65535,65535,1,20.4,25150,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,969,SUCCESS,,1947.415087,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5934,5/27/2021 1:49,23782.231,6.61,701,300,10,6001,0,65535,65535,1,20.4,25150,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,945,SUCCESS,,1947.08793,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5935,5/27/2021 1:49,23786.241,6.61,701,300,10,6001,0,65535,65535,1,20.4,25150,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3584,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,982,SUCCESS,,1946.755991,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5936,5/27/2021 1:49,23790.247,6.61,701,300,10,6001,0,65535,65535,1,20.4,25149,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3585,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,945,SUCCESS,,1946.426609,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5937,5/27/2021 1:49,23794.247,6.61,701,300,10,6001,0,65535,65535,1,20.4,25148,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3584,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,960,SUCCESS,,1946.099943,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5938,5/27/2021 1:49,23798.25,6.61,701,300,10,6001,0,65535,65535,1,20.4,25148,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3584,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,959,SUCCESS,,1945.770807,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5939,5/27/2021 1:49,23802.254,6.61,701,300,10,6001,0,65535,65535,1,20.4,25148,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3584,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,955,SUCCESS,,1945.443814,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5940,5/27/2021 1:49,23806.267,6.61,701,300,10,6001,0,65535,65535,1,20.4,25146,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3600,3598,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,962,SUCCESS,,1945.113856,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5941,5/27/2021 1:49,23810.278,6.61,701,300,10,6001,0,65535,65535,1,20.4,25148,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,942,SUCCESS,,1944.781834,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5942,5/27/2021 1:49,23814.282,6.62,701,300,10,6001,0,65535,65535,1,20.4,25147,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3597,3598,3600,3598,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,939,SUCCESS,,1944.450392,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5943,5/27/2021 1:49,23818.299,6.62,701,300,10,6001,0,65535,65535,1,20.4,25147,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3600,3597,3584,3589,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,939,SUCCESS,,1944.117874,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5944,5/27/2021 1:49,23822.313,6.62,701,300,10,6001,0,65535,65535,1,20.4,25146,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3600,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,939,SUCCESS,,1943.787834,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5945,5/27/2021 1:49,23826.313,6.62,701,300,10,6001,0,65535,65535,1,20.4,25146,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3600,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,960,SUCCESS,,1943.456723,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5946,5/27/2021 1:49,23830.329,6.62,701,300,10,6001,0,65535,65535,1,20.4,25142,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3600,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.4,940,SUCCESS,,1943.126518,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5947,5/27/2021 1:50,23834.344,6.62,701,300,10,6001,0,65535,65535,1,20.4,25145,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3599,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.5,940,SUCCESS,,1942.798626,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5948,5/27/2021 1:50,23838.36,6.62,701,300,10,6001,0,65535,65535,1,20.4,25145,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3600,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1942.470653,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5949,5/27/2021 1:50,23842.376,6.62,701,300,10,6001,0,65535,65535,1,20.4,25146,-300,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3599,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,939,SUCCESS,,1942.135986,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5950,5/27/2021 1:50,23846.376,6.62,701,300,10,6001,0,65535,65535,1,20.4,25145,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3599,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,986,SUCCESS,,1941.807098,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5951,5/27/2021 1:50,23850.391,6.63,701,300,10,6001,0,65535,65535,1,20.4,25145,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3599,3597,3583,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,954,SUCCESS,,1941.476975,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5952,5/27/2021 1:50,23854.39,6.63,701,300,10,6001,0,65535,65535,1,20.4,25146,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3596,3598,3599,3597,3584,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,948,SUCCESS,,1941.148169,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5953,5/27/2021 1:50,23858.406,6.63,701,300,10,6001,0,65535,65535,1,20.4,25144,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3599,3597,3583,3587,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.5,961,SUCCESS,,1940.815733,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5954,5/27/2021 1:50,23862.405,6.63,701,300,10,6001,0,65535,65535,1,20.4,25144,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3599,3597,3583,3587,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,944,SUCCESS,,1940.486926,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5955,5/27/2021 1:50,23866.437,6.63,701,300,10,6001,0,65535,65535,1,20.4,25142,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3599,3596,3583,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,942,SUCCESS,,1940.157646,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5956,5/27/2021 1:50,23870.361,6.63,701,300,10,6001,0,65535,65535,1,20.4,25140,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3599,3596,3583,3587,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,954,SUCCESS,,1939.837186,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5957,5/27/2021 1:50,23874.369,6.63,701,300,10,6001,0,65535,65535,1,20.4,25141,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3599,3597,3583,3587,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,946,SUCCESS,,1939.50764,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5958,5/27/2021 1:50,23878.382,6.63,701,300,10,6001,0,65535,65535,1,20.4,25140,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3588,3582,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,948,SUCCESS,,1939.177682,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5959,5/27/2021 1:50,23882.387,6.63,701,300,10,6001,0,65535,65535,1,20.4,25140,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,952,SUCCESS,,1938.848382,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5960,5/27/2021 1:50,23886.397,6.64,701,300,10,6001,0,65535,65535,1,20.4,25140,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3587,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,985,SUCCESS,,1938.516443,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5961,5/27/2021 1:50,23890.4,6.64,701,300,10,6001,0,65535,65535,1,20.4,25140,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3588,3583,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,960,SUCCESS,,1938.187308,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5962,5/27/2021 1:51,23894.402,6.64,701,300,10,6001,0,65535,65535,1,20.4,25138,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3587,3582,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,959,SUCCESS,,1937.858254,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5963,5/27/2021 1:51,23898.411,6.64,701,300,10,6001,0,65535,65535,1,20.4,25138,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3587,3582,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.3,1030,SUCCESS,,1937.528625,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5964,5/27/2021 1:51,23902.411,6.64,701,300,10,6001,0,65535,65535,1,20.4,25139,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3591,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.5,944,SUCCESS,,1937.199736,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5965,5/27/2021 1:51,23906.413,6.64,701,300,10,6001,0,65535,65535,1,20.4,25138,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3596,3583,3587,3582,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,999,SUCCESS,,1936.870683,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5966,5/27/2021 1:51,23910.42,6.64,701,300,10,6001,0,65535,65535,1,20.4,25138,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3595,3583,3586,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,973,SUCCESS,,1936.543445,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5967,5/27/2021 1:51,23914.42,6.64,701,300,10,6001,0,65535,65535,1,20.4,25137,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3595,3583,3591,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.1,956,SUCCESS,,1936.212334,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5968,5/27/2021 1:51,23918.431,6.64,701,300,10,6001,0,65535,65535,1,20.4,25138,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3595,3583,3587,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,947,SUCCESS,,1935.884769,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5969,5/27/2021 1:51,23922.438,6.65,701,300,10,6001,0,65535,65535,1,20.4,25137,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3595,3598,3598,3595,3583,3587,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.5,942,SUCCESS,,1935.553078,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5970,5/27/2021 1:51,23926.446,6.65,701,300,10,6001,0,65535,65535,1,20.4,25136,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3598,3595,3582,3587,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,984,SUCCESS,,1935.223531,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5971,5/27/2021 1:51,23930.453,6.65,701,300,10,6001,0,65535,65535,1,20.4,25136,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3598,3595,3583,3587,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,939,SUCCESS,,1934.894067,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5972,5/27/2021 1:51,23934.455,6.65,701,300,10,6001,0,65535,65535,1,20.4,25135,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3598,3595,3583,3586,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.5,959,SUCCESS,,1934.56279,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5973,5/27/2021 1:51,23938.46,6.65,701,300,10,6001,0,65535,65535,1,20.4,25134,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3582,3587,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,965,SUCCESS,,1934.23349,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5974,5/27/2021 1:51,23942.467,6.65,701,300,10,6001,0,65535,65535,1,20.4,25135,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3583,3587,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,956,SUCCESS,,1933.904026,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5975,5/27/2021 1:51,23946.475,6.65,701,300,10,6001,0,65535,65535,1,20.4,25133,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2512,20.2,20.4,-273.2,20.4,-273.2,20.6,997,SUCCESS,,1933.574479,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5976,5/27/2021 1:51,23950.49,6.65,701,300,10,6001,0,65535,65535,1,20.4,25132,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3582,3586,3581,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,938,SUCCESS,,1933.244357,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5977,5/27/2021 1:52,23954.504,6.65,701,300,10,6001,0,65535,65535,1,20.4,25131,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,982,SUCCESS,,1932.914317,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5978,5/27/2021 1:52,23958.519,6.66,701,300,10,6001,0,65535,65535,1,20.4,25132,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,967,SUCCESS,,1932.584195,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5979,5/27/2021 1:52,23962.531,6.66,701,300,10,6001,0,65535,65535,1,20.4,25132,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3598,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2510,20.2,20.4,-273.2,20.4,-273.2,20.6,940,SUCCESS,,1932.254319,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5980,5/27/2021 1:52,23966.545,6.66,701,300,10,6001,0,65535,65535,1,20.4,25131,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3597,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,941,SUCCESS,,1931.924279,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5981,5/27/2021 1:52,23970.554,6.66,701,300,10,6001,0,65535,65535,1,20.4,25131,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3597,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,948,SUCCESS,,1931.59465,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5982,5/27/2021 1:52,23974.563,6.66,701,300,10,6001,0,65535,65535,1,20.4,25131,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3597,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,941,SUCCESS,,1931.267249,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5983,5/27/2021 1:52,23978.572,6.66,701,300,10,6001,0,65535,65535,1,20.4,25131,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3597,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2513,20.2,20.4,-273.2,20.4,-273.2,20.6,946,SUCCESS,,1930.93762,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5984,5/27/2021 1:52,23982.574,6.66,701,300,10,6001,0,65535,65535,1,20.4,25130,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3597,3597,3595,3582,3586,3580,0,0,0,0,0,0,0,0,2512,20.2,20.4,-273.2,20.4,-273.2,20.6,943,SUCCESS,,1930.608566,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5985,5/27/2021 1:52,23986.587,6.66,701,300,10,6001,0,65535,65535,1,20.4,25130,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3596,3597,3595,3581,3586,3580,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,945,SUCCESS,,1930.278609,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5986,5/27/2021 1:52,23990.595,6.66,701,300,10,6001,0,65535,65535,1,20.4,25130,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3596,3597,3594,3582,3586,3580,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,947,SUCCESS,,1929.946835,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5987,5/27/2021 1:52,23994.597,6.67,701,300,10,6001,0,65535,65535,1,20.4,25126,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3597,3597,3594,3581,3586,3579,0,0,0,0,0,0,0,0,2510,20.2,20.4,-273.2,20.4,-273.2,20.6,1008,SUCCESS,,1929.617782,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5988,5/27/2021 1:52,23998.605,6.67,701,300,10,6001,0,65535,65535,1,20.4,25128,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3596,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,950,SUCCESS,,1929.288235,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5989,5/27/2021 1:52,24002.612,6.67,701,300,10,6001,0,65535,65535,1,20.4,25125,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3594,3596,3597,3594,3581,3586,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,975,SUCCESS,,1928.958771,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5990,5/27/2021 1:52,24006.628,6.67,701,300,10,6001,0,65535,65535,1,20.4,25125,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3596,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,943,SUCCESS,,1928.628566,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5991,5/27/2021 1:52,24010.635,6.67,701,300,10,6001,0,65535,65535,1,20.4,25125,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3596,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,962,SUCCESS,,1928.296876,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5992,5/27/2021 1:53,24014.637,6.67,701,300,10,6001,0,65535,65535,1,20.4,25126,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3596,3597,3594,3581,3586,3579,0,0,0,0,0,0,0,0,2510,20.2,20.4,-273.2,20.4,-273.2,20.5,978,SUCCESS,,1927.967823,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5993,5/27/2021 1:53,24018.644,6.67,701,300,10,6001,0,65535,65535,1,20.4,25125,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3596,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,973,SUCCESS,,1927.640584,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5994,5/27/2021 1:53,24022.649,6.67,701,300,10,6001,0,65535,65535,1,20.4,25125,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3596,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.5,948,SUCCESS,,1927.309059,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5995,5/27/2021 1:53,24026.656,6.67,701,300,10,6001,0,65535,65535,1,20.4,25124,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3595,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,947,SUCCESS,,1926.979595,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5996,5/27/2021 1:53,24030.663,6.68,701,300,10,6001,0,65535,65535,1,20.3,25123,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3595,3597,3594,3581,3586,3579,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,965,SUCCESS,,1926.65013,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5997,5/27/2021 1:53,24034.667,6.68,701,300,10,6001,0,65535,65535,1,20.3,25123,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3595,3597,3594,3581,3585,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.1,972,SUCCESS,,1926.318688,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5998,5/27/2021 1:53,24038.67,6.68,701,300,10,6001,0,65535,65535,1,20.4,25122,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3593,3595,3597,3594,3581,3585,3578,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,942,SUCCESS,,1925.989553,3024,0,0.1,1.2,1.3,263,1.4,1.5
    5999,5/27/2021 1:53,24042.675,6.68,701,300,10,6001,0,65535,65535,1,20.4,25121,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3594,3581,3585,3578,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,953,SUCCESS,,1925.660253,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6000,5/27/2021 1:53,24046.681,6.68,701,300,10,6001,0,65535,65535,1,20.4,25122,-294,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3594,3581,3584,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.5,945,SUCCESS,,1925.333096,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6001,5/27/2021 1:53,24050.686,6.68,701,300,10,6001,0,65535,65535,1,20.4,25122,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3593,3581,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,943,SUCCESS,,1925.003796,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6002,5/27/2021 1:53,24054.693,6.68,701,300,10,6001,0,65535,65535,1,20.3,25121,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3594,3581,3585,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,936,SUCCESS,,1924.672105,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6003,5/27/2021 1:53,24058.696,6.68,701,300,10,6001,0,65535,65535,1,20.4,25121,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3594,3581,3585,3579,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.6,977,SUCCESS,,1924.340746,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6004,5/27/2021 1:53,24062.71,6.68,701,300,10,6001,0,65535,65535,1,20.4,25119,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3594,3580,3585,3578,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.5,964,SUCCESS,,1924.010706,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6005,5/27/2021 1:53,24066.719,6.69,701,300,10,6001,0,65535,65535,1,20.3,25119,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3585,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.5,984,SUCCESS,,1923.681077,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6006,5/27/2021 1:53,24070.726,6.69,701,300,10,6001,0,65535,65535,1,20.3,25119,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,948,SUCCESS,,1923.351613,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6007,5/27/2021 1:54,24074.728,6.69,701,300,10,6001,0,65535,65535,1,20.4,25118,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.4,-273.2,20.4,-273.2,20.5,982,SUCCESS,,1923.022559,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6008,5/27/2021 1:54,24078.737,6.69,701,300,10,6001,0,65535,65535,1,20.3,25118,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3595,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,962,SUCCESS,,1922.69293,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6009,5/27/2021 1:54,24082.737,6.69,701,300,10,6001,0,65535,65535,1,20.3,25118,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,992,SUCCESS,,1922.366264,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6010,5/27/2021 1:54,24086.74,6.69,701,300,10,6001,0,65535,65535,1,20.3,25118,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,19.8,941,SUCCESS,,1922.037128,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6011,5/27/2021 1:54,24090.749,6.69,701,300,10,6001,0,65535,65535,1,20.3,25117,-294,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,965,SUCCESS,,1921.709726,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6012,5/27/2021 1:54,24094.763,6.69,701,300,10,6001,0,65535,65535,1,20.3,25117,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,958,SUCCESS,,1921.379686,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6013,5/27/2021 1:54,24098.77,6.69,701,300,10,6001,0,65535,65535,1,20.3,25116,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.5,957,SUCCESS,,1921.047996,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6014,5/27/2021 1:54,24102.773,6.7,701,300,10,6001,0,65535,65535,1,20.3,25114,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,949,SUCCESS,,1920.71886,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6015,5/27/2021 1:54,24106.781,6.7,701,300,10,6001,0,65535,65535,1,20.3,25118,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3592,3594,3597,3593,3580,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,944,SUCCESS,,1920.389314,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6016,5/27/2021 1:54,24110.791,6.7,701,300,10,6001,0,65535,65535,1,20.4,25116,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3593,3579,3584,3578,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.5,945,SUCCESS,,1920.059603,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6017,5/27/2021 1:54,24114.798,6.7,701,300,10,6001,0,65535,65535,1,20.3,25113,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3593,3580,3584,3577,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,939,SUCCESS,,1919.727912,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6018,5/27/2021 1:54,24118.803,6.7,701,300,10,6001,0,65535,65535,1,20.3,25116,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3593,3580,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,967,SUCCESS,,1919.396387,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6019,5/27/2021 1:54,24122.816,6.7,701,300,10,6001,0,65535,65535,1,20.3,25115,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3593,3579,3584,3577,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,936,SUCCESS,,1919.066429,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6020,5/27/2021 1:54,24126.822,6.7,701,300,10,6001,0,65535,65535,1,20.3,25114,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3592,3579,3584,3577,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,962,SUCCESS,,1918.734821,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6021,5/27/2021 1:54,24130.83,6.7,701,300,10,6001,0,65535,65535,1,20.3,25113,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3596,3592,3579,3584,3577,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.6,969,SUCCESS,,1918.403048,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6022,5/27/2021 1:55,24134.841,6.7,701,300,10,6001,0,65535,65535,1,20.3,25113,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,943,SUCCESS,,1918.073255,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6023,5/27/2021 1:55,24138.847,6.71,701,300,10,6001,0,65535,65535,1,20.3,25113,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3597,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,952,SUCCESS,,1917.743873,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6024,5/27/2021 1:55,24142.851,6.71,701,300,10,6001,0,65535,65535,1,20.3,25112,-294,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3596,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.2,20.3,-273.2,20.3,-273.2,20.5,972,SUCCESS,,1917.416879,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6025,5/27/2021 1:55,24146.857,6.71,701,300,10,6001,0,65535,65535,1,20.3,25111,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3596,3592,3578,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,958,SUCCESS,,1917.087497,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6026,5/27/2021 1:55,24150.864,6.71,701,300,10,6001,0,65535,65535,1,20.3,25113,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3596,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,936,SUCCESS,,1916.758033,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6027,5/27/2021 1:55,24154.869,6.71,701,300,10,6001,0,65535,65535,1,20.3,25110,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3596,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,983,SUCCESS,,1916.426508,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6028,5/27/2021 1:55,24158.877,6.71,701,300,10,6001,0,65535,65535,1,20.3,25111,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3594,3596,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,938,SUCCESS,,1916.096961,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6029,5/27/2021 1:55,24162.886,6.71,701,300,10,6001,0,65535,65535,1,20.3,25110,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3596,3592,3579,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,951,SUCCESS,,1915.765105,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6030,5/27/2021 1:55,24166.901,6.71,701,300,10,6001,0,65535,65535,1,20.3,25111,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3596,3592,3578,3583,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,966,SUCCESS,,1915.437213,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6031,5/27/2021 1:55,24170.912,6.71,701,300,10,6001,0,65535,65535,1,20.3,25108,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3570,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3592,3578,3582,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,934,SUCCESS,,1915.10742,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6032,5/27/2021 1:55,24174.928,6.72,701,300,10,6001,0,65535,65535,1,20.3,25109,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3592,3578,3584,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,934,SUCCESS,,1914.777215,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6033,5/27/2021 1:55,24178.933,6.72,701,300,10,6001,0,65535,65535,1,20.3,25108,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3592,3578,3582,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,945,SUCCESS,,1914.45014,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6034,5/27/2021 1:55,24182.947,6.72,701,300,10,6001,0,65535,65535,1,20.3,25108,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3592,3578,3581,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,967,SUCCESS,,1914.1201,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6035,5/27/2021 1:55,24186.963,6.72,701,300,10,6001,0,65535,65535,1,20.3,25107,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3591,3578,3582,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,961,SUCCESS,,1913.789896,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6036,5/27/2021 1:55,24190.97,6.72,701,300,10,6001,0,65535,65535,1,20.3,25107,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3592,3578,3582,3577,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,953,SUCCESS,,1913.460431,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6037,5/27/2021 1:56,24194.975,6.72,701,300,10,6001,0,65535,65535,1,20.3,25106,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3591,3578,3580,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,942,SUCCESS,,1913.128906,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6038,5/27/2021 1:56,24198.989,6.72,701,300,10,6001,0,65535,65535,1,20.3,25105,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3595,3591,3578,3582,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,988,SUCCESS,,1912.796636,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6039,5/27/2021 1:56,24203,6.72,701,300,10,6001,0,65535,65535,1,20.3,25106,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3593,3595,3591,3578,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,940,SUCCESS,,1912.464615,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6040,5/27/2021 1:56,24207.007,6.72,701,300,10,6001,0,65535,65535,1,20.3,25105,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3595,3591,3577,3579,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.1,981,SUCCESS,,1912.132924,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6041,5/27/2021 1:56,24211.008,6.73,701,300,10,6001,0,65535,65535,1,20.3,25104,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3578,3582,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,965,SUCCESS,,1911.803953,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6042,5/27/2021 1:56,24215.018,6.73,701,300,10,6001,0,65535,65535,1,20.3,25103,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3578,3582,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,971,SUCCESS,,1911.472014,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6043,5/27/2021 1:56,24219.028,6.73,701,300,10,6001,0,65535,65535,1,20.3,25104,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,965,SUCCESS,,1911.142303,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6044,5/27/2021 1:56,24223.041,6.73,701,300,10,6001,0,65535,65535,1,20.3,25103,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3576,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,931,SUCCESS,,1910.812345,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6045,5/27/2021 1:56,24227.052,6.73,701,300,10,6001,0,65535,65535,1,20.3,25102,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,966,SUCCESS,,1910.480324,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6046,5/27/2021 1:56,24231.064,6.73,701,300,10,6001,0,65535,65535,1,20.3,25102,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3578,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,971,SUCCESS,,1910.150448,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6047,5/27/2021 1:56,24235.07,6.73,701,300,10,6001,0,65535,65535,1,20.3,25102,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,979,SUCCESS,,1909.821066,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6048,5/27/2021 1:56,24239.086,6.73,701,300,10,6001,0,65535,65535,1,20.3,25101,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,978,SUCCESS,,1909.48863,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6049,5/27/2021 1:56,24243.092,6.73,701,300,10,6001,0,65535,65535,1,20.3,25102,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,941,SUCCESS,,1909.159248,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6050,5/27/2021 1:56,24247.093,6.74,701,300,10,6001,0,65535,65535,1,20.3,25101,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,957,SUCCESS,,1908.830277,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6051,5/27/2021 1:56,24251.106,6.74,701,300,10,6001,0,65535,65535,1,20.3,25102,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3591,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,967,SUCCESS,,1908.500319,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6052,5/27/2021 1:57,24255.11,6.74,701,300,10,6001,0,65535,65535,1,20.3,25100,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3590,3592,3594,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,940,SUCCESS,,1908.171101,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6053,5/27/2021 1:57,24259.116,6.74,701,300,10,6001,0,65535,65535,1,20.3,25100,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3590,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,966,SUCCESS,,1907.839494,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6054,5/27/2021 1:57,24263.128,6.74,701,300,10,6001,0,65535,65535,1,20.3,25100,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3590,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,967,SUCCESS,,1907.507389,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6055,5/27/2021 1:57,24267.131,6.74,701,300,10,6001,0,65535,65535,1,20.3,25101,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3590,3592,3594,3591,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.4,952,SUCCESS,,1907.178254,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6056,5/27/2021 1:57,24271.134,6.74,701,300,10,6001,0,65535,65535,1,20.3,25100,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3590,3592,3594,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,945,SUCCESS,,1906.846894,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6057,5/27/2021 1:57,24275.147,6.74,701,300,10,6001,0,65535,65535,1,20.3,25099,-298,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3590,3592,3594,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,933,SUCCESS,,1906.514707,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6058,5/27/2021 1:57,24279.153,6.74,701,300,10,6001,0,65535,65535,1,20.3,25099,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,942,SUCCESS,,1906.185325,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6059,5/27/2021 1:57,24283.161,6.75,701,300,10,6001,0,65535,65535,1,20.3,25096,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3592,3593,3590,3577,3581,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,940,SUCCESS,,1905.855778,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6060,5/27/2021 1:57,24287.176,6.75,701,300,10,6001,0,65535,65535,1,20.3,25097,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,943,SUCCESS,,1905.527886,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6061,5/27/2021 1:57,24291.181,6.75,701,300,10,6001,0,65535,65535,1,20.3,25097,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,964,SUCCESS,,1905.198586,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6062,5/27/2021 1:57,24295.184,6.75,701,300,10,6001,0,65535,65535,1,20.3,25096,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3589,3577,3581,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,960,SUCCESS,,1904.869451,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6063,5/27/2021 1:57,24299.199,6.75,701,300,10,6001,0,65535,65535,1,20.3,25097,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,980,SUCCESS,,1904.539329,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6064,5/27/2021 1:57,24303.208,6.75,701,300,10,6001,0,65535,65535,1,20.3,25096,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3590,3577,3582,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,1008,SUCCESS,,1904.2097,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6065,5/27/2021 1:57,24307.224,6.75,701,300,10,6001,0,65535,65535,1,20.3,25094,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3589,3577,3581,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,935,SUCCESS,,1903.879495,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6066,5/27/2021 1:57,24311.237,6.75,701,300,10,6001,0,65535,65535,1,20.3,25095,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3589,3577,3581,3575,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,953,SUCCESS,,1903.547308,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6067,5/27/2021 1:58,24315.246,6.75,701,300,10,6001,0,65535,65535,1,20.3,25094,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3592,3589,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,944,SUCCESS,,1903.219906,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6068,5/27/2021 1:58,24319.249,6.76,701,300,10,6001,0,65535,65535,1,20.3,25093,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3592,3589,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,957,SUCCESS,,1902.892995,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6069,5/27/2021 1:58,24323.257,6.76,701,300,10,6001,0,65535,65535,1,20.3,25093,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3593,3589,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,979,SUCCESS,,1902.561221,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6070,5/27/2021 1:58,24327.26,6.76,701,300,10,6001,0,65535,65535,1,20.3,25093,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3592,3589,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,976,SUCCESS,,1902.229862,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6071,5/27/2021 1:58,24331.272,6.76,701,300,10,6001,0,65535,65535,1,20.3,25093,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3592,3589,3577,3580,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,980,SUCCESS,,1901.899986,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6072,5/27/2021 1:58,24335.279,6.76,701,300,10,6001,0,65535,65535,1,20.3,25093,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3591,3592,3589,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,942,SUCCESS,,1901.570522,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6073,5/27/2021 1:58,24339.281,6.76,701,300,10,6001,0,65535,65535,1,20.3,25091,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,970,SUCCESS,,1901.239245,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6074,5/27/2021 1:58,24343.285,6.76,701,300,10,6001,0,65535,65535,1,20.3,25093,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3589,3590,3592,3588,3577,3580,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,19.7,969,SUCCESS,,1900.910028,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6075,5/27/2021 1:58,24347.3,6.76,701,300,10,6001,0,65535,65535,1,20.3,25091,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3591,3592,3589,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,946,SUCCESS,,1900.579905,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6076,5/27/2021 1:58,24351.307,6.76,701,300,10,6001,0,65535,65535,1,20.3,25090,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,945,SUCCESS,,1900.252667,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6077,5/27/2021 1:58,24355.322,6.77,701,300,10,6001,0,65535,65535,1,20.3,25089,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3591,3592,3588,3577,3580,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,994,SUCCESS,,1899.922545,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6078,5/27/2021 1:58,24359.334,6.77,701,300,10,6001,0,65535,65535,1,20.3,25090,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3581,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,937,SUCCESS,,1899.592669,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6079,5/27/2021 1:58,24363.341,6.77,701,300,10,6001,0,65535,65535,1,20.3,25089,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3580,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,948,SUCCESS,,1899.263205,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6080,5/27/2021 1:58,24367.355,6.77,701,300,10,6001,0,65535,65535,1,20.3,25089,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3580,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,952,SUCCESS,,1898.930935,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6081,5/27/2021 1:58,24371.362,6.77,701,300,10,6001,0,65535,65535,1,20.3,25089,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3580,3574,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,939,SUCCESS,,1898.60147,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6082,5/27/2021 1:59,24375.37,6.77,701,300,10,6001,0,65535,65535,1,20.3,25088,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2508,20.1,20.3,-273.2,20.3,-273.2,20.5,965,SUCCESS,,1898.269697,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6083,5/27/2021 1:59,24379.381,6.77,701,300,10,6001,0,65535,65535,1,20.3,25088,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,967,SUCCESS,,1897.939904,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6084,5/27/2021 1:59,24383.382,6.77,701,300,10,6001,0,65535,65535,1,20.3,25087,-293,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.6,999,SUCCESS,,1897.614267,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6085,5/27/2021 1:59,24387.394,6.77,701,300,10,6001,0,65535,65535,1,20.3,25088,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3591,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.4,966,SUCCESS,,1897.284391,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6086,5/27/2021 1:59,24391.404,6.78,701,300,10,6001,0,65535,65535,1,20.3,25088,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3590,3592,3588,3577,3579,3573,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,942,SUCCESS,,1896.952452,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6087,5/27/2021 1:59,24395.419,6.78,701,300,10,6001,0,65535,65535,1,20.3,25087,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2508,20.1,20.3,-273.2,20.3,-273.2,19.8,956,SUCCESS,,1896.62233,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6088,5/27/2021 1:59,24399.423,6.78,701,300,10,6001,0,65535,65535,1,20.3,25086,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,962,SUCCESS,,1896.290888,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6089,5/27/2021 1:59,24403.432,6.78,701,300,10,6001,0,65535,65535,1,20.3,25085,-296,-297,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2508,20.1,20.3,-273.2,20.3,-273.2,20.6,946,SUCCESS,,1895.961259,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6090,5/27/2021 1:59,24407.434,6.78,701,300,10,6001,0,65535,65535,1,20.3,25086,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2509,20.1,20.3,-273.2,20.3,-273.2,20.5,943,SUCCESS,,1895.629982,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6091,5/27/2021 1:59,24411.446,6.78,701,300,10,6001,0,65535,65535,1,20.3,25086,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3580,3573,0,0,0,0,0,0,0,0,2505,20.1,20.3,-273.2,20.3,-273.2,20.6,994,SUCCESS,,1895.300107,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6092,5/27/2021 1:59,24415.453,6.78,701,300,10,6001,0,65535,65535,1,20.3,25084,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3579,3573,0,0,0,0,0,0,0,0,2505,20.1,20.3,-273.2,20.3,-273.2,20.6,961,SUCCESS,,1894.970642,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6093,5/27/2021 1:59,24419.457,6.78,701,300,10,6001,0,65535,65535,1,20.3,25084,-298,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3579,3573,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.6,989,SUCCESS,,1894.6392,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6094,5/27/2021 1:59,24423.465,6.78,701,300,10,6001,0,65535,65535,1,20.3,25086,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3580,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,942,SUCCESS,,1894.309653,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6095,5/27/2021 1:59,24427.476,6.79,701,300,10,6001,0,65535,65535,1,20.3,25085,-294,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3579,3573,0,0,0,0,0,0,0,0,2505,20.1,20.3,-273.2,20.3,-273.2,20.5,996,SUCCESS,,1893.982088,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6096,5/27/2021 1:59,24431.484,6.79,701,300,10,6001,0,65535,65535,1,20.3,25083,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,942,SUCCESS,,1893.652542,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6097,5/27/2021 2:00,24435.499,6.79,701,300,10,6001,0,65535,65535,1,20.3,25084,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3588,3589,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,959,SUCCESS,,1893.322419,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6098,5/27/2021 2:00,24439.509,6.79,701,300,10,6001,0,65535,65535,1,20.3,25083,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,961,SUCCESS,,1892.992708,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6099,5/27/2021 2:00,24443.517,6.79,701,300,10,6001,0,65535,65535,1,20.3,25083,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,938,SUCCESS,,1892.663162,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6100,5/27/2021 2:00,24447.52,6.79,701,300,10,6001,0,65535,65535,1,20.3,25084,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,1000,SUCCESS,,1892.334026,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6101,5/27/2021 2:00,24451.527,6.79,701,300,10,6001,0,65535,65535,1,20.3,25083,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3589,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,945,SUCCESS,,1892.004562,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6102,5/27/2021 2:00,24455.529,6.79,701,300,10,6001,0,65535,65535,1,20.3,25082,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3587,3588,3591,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,942,SUCCESS,,1891.675508,3024,0,0.1,1.2,1.3,263,1.4,1.5
    6103,5/27/2021 2:00,24459.535,6.79,701,300,10,6001,0,65535,65535,1,20.3,25081,-296,-296,8,0,0,0,3632,0,0,65535,3000,28875,0BD0,0,3569,11,107,0,4,2,4445,8006,0,0,0,0,0,0,0,3586,3588,3590,3588,3577,3579,3572,0,0,0,0,0,0,0,0,2504,20.1,20.3,-273.2,20.3,-273.2,20.5,941,SUCCESS,,1891.346126,3024,0,0.1,1.2,1.3,263
