[参考译文] TPS54302:TPS54302能否实现100%占空比?
Guru**** 2392145 points
Other Parts Discussed in Thread: TPS54302
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1039464/tps54302-can-tps54302-achieve-100-duty-cycle
器件型号:TPS54302
您好,团队
TPS54302能否实现100%占空比?谢谢。
    TPS54302无法支持100%的实际占空比, 当 BOOT UVLO 被触发时,高侧 FET 关断,低侧 FET 导通,为 BOOT 电容器充电。
    BRS、
    年轻
