[参考译文] BQ78350:为单节 LiFePO4电池寻找类似的 IC
Guru**** 2609955 points
Other Parts Discussed in Thread: BQ78350
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1011256/bq78350-looking-for-similar-ic-for-single-lifepo4-cell
器件型号:BQ78350
 单个 LiFePO4单元是否存在类似 BQ78350的 IC? 正在寻找没有充电器的电池监控器/保护器
