[参考译文] BQMTESTER:我正在尝试获取 BQM 测试器的副本、该测试器将对 BQ20Z655-R1进行校准和编程
Guru**** 2811625 points
Other Parts Discussed in Thread: BQMTESTER
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/874644/bqmtester-i-am-trying-to-get-a-copy-of-the-bqm-tester-which-will-calibrate-and-program-the-bq20z655-r1
器件型号:BQMTESTER
主题中讨论的其他器件:BQ20Z655-R1
您能给我一个链接、我可以在其中获取支持 BQ20Z655-R1的 BQM 测试仪的安装文件吗
