[参考译文] HSS-MOTHERBOARDEVM:HSS-MOTHERBOARDEVM
Guru**** 674950 points
Other Parts Discussed in Thread: HSS-MOTHERBOARDEVM
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/873301/hss-motherboardevm-hss-motherboardevm
器件型号:HSS-MOTHERBOARDEVM
是否可以使用 HSS-MOTHERBOARDEVM 在30或40安培下测试此 TPS2HB08BQPWPRQ1?
    HSS-MOTHERBOARDEVM 能够在很短的时间内提供30-40A 的电流、但该器件无法处理该电流。
