[参考译文] LM2642:负电压输出
Guru**** 2524550 points
Other Parts Discussed in Thread: LM2642
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/871458/lm2642-negative-voltage-output
器件型号:LM2642
我们能否从 LM2642生成负电压(例如-12V)?  如果是,我们是否需要对此多加注意?
