[参考译文] TPS1663:PTC 保险丝交叉推荐
Guru**** 2815985 points
Other Parts Discussed in Thread: TPS2662, TPS2595
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/888390/tps1663-ptc-fuse-cross-recommendation
器件型号:TPS1663
主题中讨论的其他器件:TPS2662TPS2595
是否可以用电子保险丝替换以下 PTC 保险丝?
https://www.digikey.com/product-detail/en/littelfuse-inc/2920L185DR/F2871CT-ND/1833225
https://www.digikey.com/product-detail/en/littelfuse-inc/0805L035YR/F2771CT-ND/1212827
Kevin
