[参考译文] TPS543C20:内部上拉 EN
Guru**** 2539500 points
Other Parts Discussed in Thread: TPS543C20
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/902157/tps543c20-internal-pull-up-en
器件型号:TPS543C20
TPS543C20
内部上拉 EN 引脚的电阻值是多少?
2.内部上拉电阻连接到的电压值是多少?
