[参考译文] TPSM53602:禁用时的输出电压行为
Guru**** 2513255 points
Other Parts Discussed in Thread: TPSM53602
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/936832/tpsm53602-vout-behavior-when-disabled
器件型号:TPSM53602
未启用 TPSM53602时、Vout 是浮动还是变为0v?
