[参考译文] BQ25606:BQ25606电池断开连接
Guru**** 2387080 points
Other Parts Discussed in Thread: BQ25606
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/922952/bq25606-bq25606-batt-disconnect
器件型号:BQ25606
 当10kΩ 两个 k Ω 电阻器和电池的 TS 引脚断开连接时、STAT 引脚的状态是什么? 谢谢!
