[参考译文] BQ25703A:BQ25703A 电池充电问题
Guru**** 2553260 points
Other Parts Discussed in Thread: BQ25703A
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1167696/bq25703a-bq25703a-battery-charging-problem
器件型号:BQ25703A
尊敬的 TI:
你好。
我们使用的是 BQ25703A IC、但会出现充电问题。 首次施加直流电源时、充电效果良好。 但是、存在一个问题、即在断开直流电源后重新插入时、它不会充电。 它始终仅在第一个直流电源开启后引导时充电、而在引导完成后再次开启直流电源时不充电。
任何帮助都值得注意、请提供适当的解决方案
Richard
    DC = 12V
    电池2节8.4V
    您好 Richard、
    您能否在器件充电时以及在重新插入适配器时不充电时提供寄存器转储?
    Khalid
    您好~!、Khalid
    首先是冷启动的寄存器
    0 1 2 3 4 5 6 7 8 9 A b c d e f 0123456789abcdef
    00:0E 02 c0 05 00 22 00 02 00 0A 40 1D 00 16 00 41????????????@??????????????????????
    10:FF 关断关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    20:00 A4 00 00 00 00 41 00 80 00 16 00 1c 4b 4D 40 78。。。。。。??公里@x
    30:10 02 B7 02 00 54 4a 20 81 ff a0 ff 01 ff ?...TJ ??..
    40:FF 关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    50:FF 关断关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    60:FF 关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    70:FF 关断关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    80:FF 关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    90:FF 关断关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    A0:FF ff ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    B0:FF 关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    C0:FF 关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    D0:FF 关断关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    E0:FF 关断 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    F0:FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF ff ff ff ff ff ff ff ff ff (FF 关闭 FF
    然后、重新插入直流插孔。
    00:0E 02 00 00 00 22 00 02 00 0A 40 1D 00 16 00 0A??????????@????
    20:00 A8 00 00 0A 00 88 00 00 06 46 49 40 78 ....?...?Fi@x
    您好、Richard、
    看起来您已进入 IINDPM。  IINDPM = 500mA。 是这样吗?
    老虎
    嗨、Tiger。
    没错。
    设置如下所示。
    IINDPM 值是否与不充电有关?
    您好、Richard、
    第二个插件后、充电电流寄存器复位为零。 您需要再次设置充电电流寄存器。
    老虎
