[参考译文] Linux/BQ27210:当前电池电源
Guru**** 2682545 points
Other Parts Discussed in Thread: BQ27210, BQEVSW
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/773715/linux-bq27210-current-battery-power
器件型号:BQ27210
主题中讨论的其他器件: BQEVSW
工具/软件:Linux
我们通过 I2C 将 bq27210芯片安装到 imx6平台。 但使用官方网站上提供的驱动程序、我没有找到有关当前电池电量的信息。 如何获取有关当前电池电量的信息?
调试信息如下所示:
root@imx6qsabersd:~# dmesg |grep bq
[1.905829] power_supply bq27210-0:uevent
[1.905838] power_supply bq27210-0:power_supply_name=bq27210-0
[1.906098] bq27xxx-battery 2-0055:芯片不支持数据存储器更新
[1.913396] bq27xxx-battery 2-0055:电池未校准! 忽略容量值
[1.921496] power_supply bq27210-0:power_supply_changed
[1.921522] power_supply bq27210-0:power_supply_changed_work
[1.921538] power_supply bq27210-0:power_supply_am_i_supplied 0
[1.921548] power_supply bq27210-0:power_supply_update_bat_LEDs 2.
[1.921568] power_supply bq27210-0:uevent
[1.921576] power_supply bq27210-0:power_supply_name=bq27210-0
[1.921598] power_supply bq27210-0:power_supply_am_i_supplied 0
[1.921608] POWER_SUPPLY bq27210-0:传播状态=放电
[1.921619] power_supply bq27210-0:prop Present = 1
[1.923517] power_supply bq27210-0:power_supply_changed
[1.924107] POWER_SUPPLY bq27210-0:PROP VOLTGE_NOW = 4183000
[1.925553] power_supply bq27210-0:prop Current_Now=0
[1.925567] power_supply bq27210-0:驱动程序没有`capacity'属性的数据
[1.925579] power_supply bq27210-0:prop capacity_level=Normal
[1.925591] POWER_SUPPLY bq27210-0:PROP TEMP=231
[ 1.925601] POWER_SUPPLY bq27210-0:驱动器没有`time_TO_empty_Now'属性的数据
[ 1.925609] power_supply bq27210-0:`器没有"Time_TO_empty_avg"属性的数据
[1.925617] power_supply bq27210-0:`没有"Time_TO_FULL_Now"属性的数据
[1.925626] power_supply bq27210-0:prop technology=锂离子电池
[1.925635] power_supply bq27210-0:驱动器没有`CHARGE_FULLE"属性的数据
[1.926248] POWER_SUPPLY bq27210-0:`器没有"CHARGE_Now"属性的数据
[1.926258] POWER_SUPPLY bq27210-0:PROP CHARGE_FULL_Design=2010624
[1.92626268] power_supply bq27210-0:prop cycle_count=7
[1.926275] POWER_SUPPLY bq27210-0:驱动程序没有`health'属性的数据
[1.926283] POWER_SUPPLY bq27210-0:prop =德州仪器
[1.926299] power_supply bq27210-0:power_supply_changed_work
[1.926312] POWER_SUPPLY bq27210-0:POWER_SUPPLY_AM_I_SUPPLY 0
[1.926318] POWER_SUPPLY bq27210-0:POWER_SUPPLY_UPDATE_BAT_LED 2.
[1.926336] POWER_SUPPLY bq27210-0:uevent
[1.926342] power_supply bq27210-0:power_supply_name=bq27210-0
[1.926359] power_supply bq27210-0:power_supply_am_i_supplied 0
[1.926366] POWER_SUPPLY bq27210-0:传播状态=放电
[1.926375] POWER_SUPPLY bq27210-0:传播存在=1
[1.927229] POWER_SUPPLY bq27210-0:PROP VOLTGE_NOW = 4183000
[1.928596] POWER_SUPPLY bq27210-0:PROP CURRENT_NOW = 0
[1.928605] POWER_SUPPLY bq27210-0:驱动程序没有`capacity'属性的数据
[1.928613] power_supply bq27210-0:prop capacity_level=Normal
[1.928622] POWER_SUPPLY bq27210-0:PROP TEMP=231
[1.928629] POWER_SUPPLY bq27210-0:驱动程序没有`TIME_TO_EMPTY_NOW '属性的数据
[1.928635] POWER_SUPPLY bq27210-0:`器没有"TIME_TO_EMPTY_avg"属性的数据
[ 1.928641] POWER_SUPPLY bq27210-0:驱动器没有`time_TO_FULL_Now'属性的数据
[1.928649] power_supply bq27210-0:prop technology=锂离子电池
[1.928656] POWER_SUPPLY bq27210-0:驱动器没有`CHARGE_FULLE"属性的数据
[1.929289] POWER_SUPPLY bq27210-0:驱动器没有`CHARGE_NOW '属性的数据
[1.929299] POWER_SUPPLY bq27210-0:PROP CHARGE_FULL_Design=2010624
[1.929307] power_supply bq27210-0:prop cycle_count=7
[1.929315] power_supply bq27210-0:驱动程序没有`health'属性的数据
[1.929322] power_supply bq27210-0:prop =德州仪器
[9.199696] POWER_SUPPLY bq27210-0:uevent
[9.199709] power_supply bq27210-0:power_supply_name=bq27210-0
[9.209979] power_supply bq27210-0:power_supply_am_i_supplied 0
[9.209996] power_supply bq27210-0:传播状态=正在放电
root@imx6qsabersd:/sys/class/power_supply CD bq27210-0
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 ls
Capacity Current_Now Present time_TO_empty_avg volte_now
capacity_level cycle_count 状态 time_TO_empty_now
CHARGE_FULLL 器件子系统 TIME_TO_FULL_NOW
CHARGE_FULL_Design 运行状况技术类型
CHARGE_NOW 电源温度 uevent
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat health
CAT:运行状况:无可用数据
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat power/
CAT:power/:是一个目录
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat volte_now
4183000
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat 容量
类别:容量:无可用数据
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat curry_now
0
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat present
1
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat status
放电
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat temp
229
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat charge _现在
CAT:CHARGE_NOW:无可用数据
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat 类型
电池
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat time_TO_full_now
CAT:Time_TO_FULL_Now:无可用数据
root@imx6qsabersd:/sys/class/power_supply/bq27210-0 cat time_TO_empty_avg
CAT:TIME_TO_EMPTY_avg:无可用数据
    你(们)好,Kane
    我建议您先对器件使用 bqEVSW 来执行器件评估、以便在尝试与主机通信之前了解如何配置和使用监测计。
    Onyx
