[参考译文] LP8555:能否将通道并联以获得更高的输出电流?
Guru**** 2553450 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/769891/lp8555-can-the-channels-be-put-in-parallel-for-higher-output-current
器件型号:LP8555
通道是否可以并联以获得更高的输出电流?
    您好、Michael、
    是的、当然您可以这样做。
    肖恩
