[参考译文] TPS2640EVM:引脚 Cdvdt 上额外增加24.3KOhm 电阻器?
Guru**** 2812305 points
Other Parts Discussed in Thread: TPS2640EVM
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1170105/tps2640evm-additional-24-3kohm-resistor-at-pin-cdvdt
器件型号:TPS2640EVM
TPS2640EVM 显示了与 Cdvdt 串联的额外24.3KOhm 电阻器、数据表中未对此进行说明或说明。
为什么引入了该电阻器、是否必须填充该电阻器?
Walter
