[参考译文] BQ76920:热敏电阻电流切换
Guru**** 2539500 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/843307/bq76920-thermistor-current-switching
器件型号:BQ76920
热敏电阻电流是通过热敏电阻寄存器切换、还是根据需要快速打开/关闭?  如果快速切换,时间是多少?
