[参考译文] TPS544B20:TPS544B20 I2C 引脚电容
Guru**** 2812305 points
Other Parts Discussed in Thread: TPS544B20
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/838043/tps544b20-tps544b20-i2c-pin-capacitance
器件型号:TPS544B20
TPS544B20的 I2C 引脚电容是多少
    Dilip、
    每个总线段的最大电容(CBUS)= 400pF
    每个数据或 CLK 引脚的最大电容(CPIN)= 10pF
    谢谢 John
