[参考译文] 编译器/BQ25601:是否需要用于 Rockchip RK3399的 BQ25601驱动程序代码?
Guru**** 2534260 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/837482/compiler-bq25601-need-driver-code-of-bq25601-for-rockchip-rk3399
器件型号:BQ25601
工具/软件:TI C/C++编译器
