[参考译文] TPS54335AEVM-010:相位裕度过低问题。
Guru**** 2642185 points
Other Parts Discussed in Thread: LM25011, TPS54335A
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/836017/tps54335aevm-010-phase-margin-is-too-low-issue
器件型号:TPS54335AEVM-010
主题中讨论的其他器件:LM25011TPS54335A
您好、专家、
如果我将 EVM Comp 值用于 Webench、Webench 将显示错误消息。 哪一个是正确的? 谢谢!
