[参考译文] TL431:TL431数据表中的,,如何测量图中的小信号电压放大 VS 频率? 您能否提供原理图和计算公式? 非常感谢~
Guru**** 2694555 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/790556/tl431-dears-in-the-tl431-datesheet-how-the-graph-figure-small-signal-voltage-amplification-vs-frequency-be-measure-could-you-offer-the-schematic-and-computational-formula-many-thanks
器件型号:TL431
