[FAQ] [参考译文] [常见问题解答] TPS6594-Q1:用户指南位置
Guru**** 2534260 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1172800/faq-tps6594-q1-user-guide-locations
器件型号:TPS6594-Q1
以下是 TPS6594 EVM 的各种用户指南以及相关 PDN 的链接。
TPS65941213 + TPS65941111: https://www.ti.com/lit/pdf/slvuc99
TPS65941212 + TPS65941111: https://www.ti.com/lit/pdf/slvuc32
TPS65941213 + LP876411B4: https://www.ti.com/lit/pdf/slvucf3
TPS6594141B + LP876441B1: https://www.ti.com/lit/pdf/slvuby7
TPS65941515: https://www.ti.com/lit/pdf/slvucd4
