[参考译文] TPS54302:如何计算 Tj?
Guru**** 2535750 points
Other Parts Discussed in Thread: TPS54302
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/807782/tps54302-how-to-calculate-tj
器件型号:TPS54302
你好
 ℃。测试 TPS54302的顶部表面温度,即100 μ m
如何计算 Tj?
Vin=24V、Vout=20V、 如何设置 TPS54302的最大电流?
