[FAQ] [参考译文] [常见问题解答] TPS23880是否与 TPS2388引脚对引脚兼容?
Guru**** 2798555 points
Other Parts Discussed in Thread: TPS23880, TPS2388
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/785122/faq-is-the-tps23880-pin-to-pin-compatible-with-the-tps2388
器件型号:TPS23880
主题中讨论的其他器件: TPS2388
我的客户询问 TPS23880是否可以直接替代 TPS2388?
