[参考译文] TPS63020:FB 引脚输入泄漏
Guru**** 2779905 points
Other Parts Discussed in Thread: TPS63020
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/778456/tps63020-fb-pin-input-leakage
器件型号:TPS63020
您好、TPS63020 FB 引脚上的泄漏电流是多少?
    您好 Kalle、
    流入 FB 引脚的典型电流为0.01uA。
